[GRASS-SVN] r59192 - grass/trunk/lib/python/pygrass/raster
Tue Mar 4 07:23:21 PST 2014
Author: zarch
Date: 2014-03-04 07:23:21 -0800 (Tue, 04 Mar 2014)
New Revision: 59192
   grass/trunk/lib/python/pygrass/raster/__init__.py
Before closing the RasterNumpy class check if is open or not and add an additional parameter to set the name of the raster map.
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2014-03-04 09:41:21 UTC (rev 59191)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2014-03-04 15:23:21 UTC (rev 59192)
@@ -640,10 +640,15 @@
         # if the map is open or not
         self._fd = 1
-    def close(self):
-        self._write()
-        os.remove(self.filename)
-        self._fd = None
+    def close(self, name=''):
+        if self.is_open():
+            name = name if name else self.name
+            if not name:
+                raise RuntimeError('Raster name not set neither '
+                                   'given as parameter.')
+            self._write()
+            os.remove(self.filename)
+            self._fd = None
     def get_value(self, point, region=None):
         """This method returns the pixel value of a given pair of coordinates:
