[GRASS-SVN] r59197 - grass/trunk/gui/wxpython/rlisetup
Wed Mar 5 04:57:20 PST 2014
Author: lucadelu
Date: 2014-03-05 04:57:20 -0800 (Wed, 05 Mar 2014)
New Revision: 59197
   grass/trunk/gui/wxpython/rlisetup/__init__.py
   grass/trunk/gui/wxpython/rlisetup/frame.py
   grass/trunk/gui/wxpython/rlisetup/functions.py
   grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
   grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
   grass/trunk/gui/wxpython/rlisetup/wizard.py
g.gui.rlisetup: a lot of improvements, thanks also to Mohammed Rashad
Modified: grass/trunk/gui/wxpython/rlisetup/__init__.py
--- grass/trunk/gui/wxpython/rlisetup/__init__.py	2014-03-05 10:50:47 UTC (rev 59196)
+++ grass/trunk/gui/wxpython/rlisetup/__init__.py	2014-03-05 12:57:20 UTC (rev 59197)
@@ -3,4 +3,5 @@
     'wizard',
     'functions',
     'frame',
+    'sampling_frame'
Modified: grass/trunk/gui/wxpython/rlisetup/frame.py
--- grass/trunk/gui/wxpython/rlisetup/frame.py	2014-03-05 10:50:47 UTC (rev 59196)
+++ grass/trunk/gui/wxpython/rlisetup/frame.py	2014-03-05 12:57:20 UTC (rev 59197)
@@ -13,16 +13,101 @@
 from grass.script import core as grass
 from rlisetup.functions import retRLiPath
 from rlisetup.wizard import RLIWizard
+import locale
+import codecs
+class ViewFrame(wx.Frame):
+    def __init__(self, parent, conf, giface=None, id=wx.ID_ANY,
+                 title=_("Modify the configuration file"),
+                 style=wx.DEFAULT_FRAME_STYLE | wx.RESIZE_BORDER, **kwargs):
+        ###VARIABLES
+        self.parent = parent
+        self.rlipath = retRLiPath()
+        self.confile = conf
+        self.pathfile = os.path.join(self.rlipath, conf)
+        wx.Frame.__init__(self, parent=parent, id=id, title=title,
+                          **kwargs)
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'),
+                             wx.BITMAP_TYPE_ICO))
+        self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
+        self.confilesBox = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
+                                        label=_("View and modify the " \
+                                        "configuration file '{name}'".format(name=self.confile)))
+        self.textCtrl = wx.TextCtrl(parent=self.panel, id=wx.ID_ANY,
+                                    style=wx.TE_MULTILINE, size=(-1, 75))
+        self.textCtrl.Bind(wx.EVT_TEXT, self.OnFileText)
+        f = open(self.pathfile)
+        self.textCtrl.SetValue(''.join(f.readlines()))
+        f.close()
+        ###BUTTONS      #definition
+        self.btn_close = wx.Button(parent=self, id=wx.ID_CLOSE)
+        self.btn_ok = wx.Button(parent=self, id=wx.ID_OK)
+        self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
+        self.btn_ok.Bind(wx.EVT_BUTTON, self.OnOk)
+        self._layout()
+        self.enc = locale.getdefaultlocale()[1]
+    def _layout(self):
+        """Set the layout"""
+        panelsizer = wx.GridBagSizer(1, 1)
+        mainsizer = wx.BoxSizer(wx.VERTICAL)
+        ###CONFILES
+        confilesSizer = wx.StaticBoxSizer(self.confilesBox, wx.HORIZONTAL)
+        confilesSizer.Add(item=self.textCtrl, proportion=1, flag=wx.EXPAND)
+        ###END CONFILES
+        ###BUTTONS
+        buttonSizer = wx.BoxSizer(wx.HORIZONTAL)
+        buttonSizer.Add(item=self.btn_ok, flag=wx.ALL, border=5)
+        buttonSizer.Add(item=self.btn_close, flag=wx.ALL, border=5)
+        ###END BUTTONS
+        #add listbox to staticbox
+        panelsizer.Add(item=confilesSizer, pos=(0, 0), flag=wx.EXPAND,
+                       border=3)
+        #add panel and buttons
+        mainsizer.Add(item=self.panel, proportion=1, flag=wx.EXPAND, border=3)
+        mainsizer.Add(item=buttonSizer, proportion=0, flag=wx.EXPAND, border=3)
+        panelsizer.AddGrowableRow(0)
+        panelsizer.AddGrowableCol(0)
+        self.panel.SetAutoLayout(True)
+        self.panel.SetSizerAndFit(panelsizer)
+        self.SetSizer(mainsizer)
+        self.Layout()
+    def OnClose(self, event):
+        """!Close window"""
+        self.Destroy()
+    def OnOk(self, event):
+        """!Launches help"""
+        dlg = wx.MessageDialog(parent=self.parent,
+                                message=_("Are you sure that you want modify" \
+                                          " r.li configuration file {name}?" \
+                                          "\nYou could broke the configuration" \
+                                          " file...").format(name=self.confile),
+                                caption=_("WARNING"),
+                                style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_WARNING)
+        if dlg.ShowModal() == wx.ID_YES:
+            f = codecs.open(self.pathfile, encoding=self.enc, mode='w',
+                            errors='replace')
+            f.write(self.text + os.linesep)
+            f.close()
+        dlg.Destroy()
+        self.Destroy()
+    def OnFileText(self, event):
+        """File input interactively entered"""
+        self.text = event.GetString()
 class RLiSetupFrame(wx.Frame):
-    def __init__(self, parent, giface = None, id=wx.ID_ANY, title=_("GRASS" \
+    def __init__(self, parent, giface=None, id=wx.ID_ANY, title=_("GRASS" \
                  " GIS Setup for r.li modules"),
         ###VARIABLES
-        self.cmd = "r.li.setup"
+#        self.cmd = "r.li.setup"
         self.listfiles = self.ListFiles()
         ###END VARIABLES
@@ -37,25 +122,29 @@
                                         label=_('Available sampling area configuration files'))
         self.listfileBox = wx.ListBox(parent=self.panel,  id=wx.ID_ANY,
                     choices=self.listfiles)
-        ###BUTTONS
-        #definition
-        self.btn_close = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
-        self.btn_help = wx.Button(parent=self.panel, id=wx.ID_HELP)
-        self.btn_remove = wx.Button(parent=self.panel, id=wx.ID_ANY,
+        self.btn_help = wx.Button(parent=self, id=wx.ID_HELP)
+        self.btn_remove = wx.Button(parent=self, id=wx.ID_ANY,
                                     label=_("Remove"))
         self.btn_remove.SetToolTipString(_('Remove a configuration file'))
-        self.btn_new = wx.Button(parent=self.panel, id=wx.ID_ANY,
+        self.btn_new = wx.Button(parent=self, id=wx.ID_ANY,
                                  label=_("Create"))
         self.btn_new.SetToolTipString(_('Create a new configuration file'))
-        self.btn_rename = wx.Button(parent=self.panel, id=wx.ID_ANY,
+        self.btn_rename = wx.Button(parent=self, id=wx.ID_ANY,
                                     label=_("Rename"))
         self.btn_rename.SetToolTipString(_('Rename a configuration file'))
+        self.btn_view = wx.Button(parent=self, id=wx.ID_ANY,
+                                    label=_("View"))
+        self.btn_view.SetToolTipString(_('View a configuration file'))
         #set action for button
         self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
         self.btn_remove.Bind(wx.EVT_BUTTON, self.OnRemove)
         self.btn_new.Bind(wx.EVT_BUTTON, self.OnNew)
         self.btn_rename.Bind(wx.EVT_BUTTON, self.OnRename)
+        self.btn_view.Bind(wx.EVT_BUTTON, self.OnView)
         self._layout()
         ###END BUTTONS
@@ -67,7 +156,8 @@
     def _layout(self):
-        sizer = wx.BoxSizer(wx.VERTICAL)
         ###CONFILES
         confilesSizer.Add(item=self.listfileBox, proportion=1,
@@ -77,19 +167,25 @@
         buttonSizer.Add(item=self.btn_new, flag=wx.ALL, border=5)
         buttonSizer.Add(item=self.btn_rename, flag=wx.ALL, border=5)
+        buttonSizer.Add(item=self.btn_view, flag=wx.ALL, border=5)
         buttonSizer.Add(item=self.btn_remove, flag=wx.ALL, border=5)
         buttonSizer.Add(item=self.btn_help, flag=wx.ALL, border=5)
         ###END BUTTONS
-        #add to sizer
-        sizer.Add(item=confilesSizer, proportion=0,
-                  flag=wx.ALIGN_LEFT | wx.EXPAND | wx.ALL, border=3)
-        sizer.Add(item=buttonSizer, proportion=0,
-                  flag=wx.ALIGN_RIGHT | wx.ALL, border=3)
-        #set dimension
+                       border=3)
-        self.panel.SetSizer(sizer)
-        sizer.Fit(self.panel)
         self.Layout()
     def ListFiles(self):
@@ -101,7 +197,7 @@
         for l in os.listdir(self.rlipath):
             if os.path.isfile(os.path.join(self.rlipath, l)):
                 listfiles.append(l)
-        return listfiles
+        return sorted(listfiles)
         """!Close window"""
@@ -109,14 +205,22 @@
     def OnHelp(self, event):
-        gcmd.RunCommand('g.manual', parent = self, entry = 'wxGUI.rlisetup')
+        gcmd.RunCommand('g.manual', parent=self, entry='wxGUI.rlisetup')
     def OnRemove(self, event):
         """!Remove configuration file from path and update the list"""
         confile = self.listfiles[self.listfileBox.GetSelections()[0]]
-        self.listfileBox.Delete(self.listfileBox.GetSelections()[0])
-        grass.try_remove(os.path.join(self.rlipath, confile))
-        self.listfiles = self.ListFiles()
+                                message=_("Do you want remove r.li " \
+                                          "configuration file <%s>?") % confile,
+                                caption=_("Remove new r.li configuration file?"),
+                                style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+            self.listfileBox.Delete(self.listfileBox.GetSelections()[0])
+            grass.try_remove(os.path.join(self.rlipath, confile))
+            self.listfiles = self.ListFiles()
+        dlg.Destroy()
         return
     def OnNew(self, event):
@@ -145,3 +249,14 @@
             self.listfileBox.Clear()
             self.listfileBox.Set(self.listfiles)
+    def OnView(self, event):
+        """!Show and edit a configuration file"""
+        try:
+            confile = self.listfiles[self.listfileBox.GetSelections()[0]]
+        except:
+            gcmd.GMessage(parent=self,
+                          message=_("You have to select a configuration file"))
+            return
+        frame = ViewFrame(self, conf=confile)
+        frame.Show()
Modified: grass/trunk/gui/wxpython/rlisetup/functions.py
--- grass/trunk/gui/wxpython/rlisetup/functions.py	2014-03-05 10:50:47 UTC (rev 59196)
+++ grass/trunk/gui/wxpython/rlisetup/functions.py	2014-03-05 12:57:20 UTC (rev 59197)
@@ -7,8 +7,39 @@
 import wx
 import os
 import sys
+from grass.script import core as grass
+from core.gcmd import GError
+class SamplingType:
+    KMWINC = samplingtype=moving, regionbox=keyboard, shape=circle
+    KMWINR = samplingtype moving, regionbox=keyboard, shape=rectangle
+    MMWINC = samplingtype=moving, regionbox=mouse, shape=circle
+    MMWINR = samplingtype moving, regionbox=mouse, shape=rectangle
+    KUNITSC = samplingtype=units, regionbox=keyboard, shape=cirlce
+    KUNITSR = samplingtype=units, regionbox=keyboard, shape=rectangle
+    MUNITSC = samplingtype=units, regionbox=mouse, shape=cirlce
+    MUNITSR = samplingtype=units, regionbox=mouse, shape=rectangle
+    WHOLE = 'whole'
+    REGIONS = 'regions'
+    UNITS = 'units'
+    VECT = 'vect'
+    MVWIN = 'moving'
+    KMVWINC = 'kmvwin_circle'
+    KMVWINR = 'kmvwin_rectangle'
+    MMVWINC = 'mmvwin_circle'
+    MMVWINR = 'mmvwin_rectangle'
+    KUNITSC = 'kunits_circle'
+    KUNITSR = 'kunits_rectangle'
+    MUNITSC = 'munits_circle'
+    MUNITSR = 'munits_rectangle'
 def checkValue(value):
     if value == '':
         wx.FindWindowById(wx.ID_FORWARD).Enable(False)
@@ -17,7 +48,7 @@
 def retRLiPath():
-    # configuration directory
+    """Return the directory of configuration files for r.li"""
     if sys.platform == 'win32':
         grass_config_dirname = "GRASS7"
         grass_config_dir = os.path.join(os.getenv('APPDATA'),
@@ -33,3 +64,42 @@
     else:
         os.mkdir(rlipath)
         return rlipath
+def convertFeature(vect, outrast, cat, origrast):
+    """Convert a single feature to a raster"""
+    tmp_vect = "tmp_{rast}".format(rast=outrast)
+    grass.run_command('v.extract', input=vect, output=tmp_vect, cats=cat,
+                      overwrite=True, quiet=True)
+    grass.run_command('g.region', vect=tmp_vect, align=origrast)
+    grass.run_command('v.to.rast', input=vect, output=outrast, use='cat',
+                      cats=cat, overwrite=True, quiet=True)
+    grass.run_command('g.remove', vect=tmp_vect, quiet=True)
+def obtainAreaVector(outrast):
+    """Create the string for configuration file"""
+    reg = grass.region()
+    return "MASKEDOVERLAYAREA {name}|{n}|{s}|{e}|{w}\n".format(name=outrast,
+                                                             n=reg['n'],
+                                                             s=reg['s'],
+                                                             e=reg['e'],
+                                                             w=reg['w'])
+def sampleAreaVector(vect, rast, vect_cats, progDialog=None):
+    """Create the strings to add to the configuration file using vector"""
+    areanum = len(vect_cats)
+    output = []
+    #TODO if areanum == 0 exit from the program
+    if areanum == 0:
+        GError(message=_("The polygon seems to have 0 areas"))
+        return None
+    for n in range(areanum):
+        cat = vect_cats[n]
+        rast_name = "{name}_{cat}".format(name=vect.split('@')[0], cat=cat)
+        convertFeature(vect, rast_name, cat, rast)
+        output.append(obtainAreaVector(rast_name))
+        if progDialog:
+            progDialog.Update(n)
+    return output
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py	2014-03-05 10:50:47 UTC (rev 59196)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py	2014-03-05 12:57:20 UTC (rev 59197)
@@ -46,7 +46,7 @@
     app = wx.PySimpleApp()
     if not CheckWxVersion([2, 9]):
         wx.InitAllImageHandlers()
-    frame = RLiSetupFrame(parent = None, giface = StandaloneGrassInterface())
+    frame = RLiSetupFrame(parent=None, giface=StandaloneGrassInterface())
     frame.Show()
     app.MainLoop()
Modified: grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
--- grass/trunk/gui/wxpython/rlisetup/sampling_frame.py	2014-03-05 10:50:47 UTC (rev 59196)
+++ grass/trunk/gui/wxpython/rlisetup/sampling_frame.py	2014-03-05 12:57:20 UTC (rev 59197)
@@ -22,6 +22,22 @@
 import wx
 import wx.aui
+#start new import
+import tempfile
+from core.gcmd        import RunCommand
+import grass.script.core as grass
+from core import gcmd
+try:
+    from grass.lib.gis    import *
+    from grass.lib.vector import *
+    from grass.lib.raster import *
+except ImportError:
+    pass
+#end new import
 # adding a path to wxGUI modules
 if __name__ == '__main__':
     WXGUIBASE = os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython')
@@ -39,17 +55,36 @@
 from grass.pydispatch.signal import Signal
 from grass.pydispatch.errors import DispatcherKeyError
+from functions import SamplingType
+class Circle:
+    def __init__(self, pt, r):
+        self.point = pt
+        self.radius = r
+class MaskedArea(object):
+    def __init__(self, region, raster):
+        self.region = region
+        self.raster = raster
 class RLiSetupMapPanel(wx.Panel):
     """!Panel with mapwindow used in r.li.setup"""
-    def __init__(self, parent, map_=None):
+    def __init__(self, parent, samplingType, graphicsType="rect", icon=None,
+                 map_=None):
         wx.Panel.__init__(self, parent=parent)
         self.mapWindowProperties = MapWindowProperties()
         self.mapWindowProperties.setValuesFromUserSettings()
+        self.samplingtype = samplingType
+        self.gtype = graphicsType
-        self._region = {}
-        self.sampleFrameChanged = Signal('RLiSetupMapPanel.sampleFrameChanged')
+        ##print self.gtype
+        ##print samplingType
         if map_:
             self.map_ = map_
@@ -69,6 +104,10 @@
         self._toolSwitcher.toggleToolChanged.connect(self._onToolChanged)
         self.toolbar = RLiSetupToolbar(self, self._toolSwitcher)
+        self.polycoords = []
+        self.coords = []
+        self.catId = 1
         self._mgr.AddPane(self.toolbar,
                           wx.aui.AuiPaneInfo().
                           Name("maptoolbar").Caption(_("Map Toolbar")).
@@ -77,19 +116,32 @@
                           BestSize((self.toolbar.GetBestSize())))
         self._mgr.Update()
-        self.toolbar.SelectDefault()
+        if self.samplingtype != SamplingType.VECT:
+            self.toolbar.SelectDefault()
+        #print self.samplingtype
+        if self.samplingtype == SamplingType.REGIONS:
+            self.afterRegionDrawn = Signal('RLiSetupMapPanel.afterRegionDrawn')
+            self._registeredGraphics = self.mapWindow.RegisterGraphicsToDraw(graphicsType='line')
+        elif self.samplingtype in [SamplingType.MUNITSR, SamplingType.KUNITSR,
+                                   SamplingType.KMVWINR, SamplingType.MMVWINR]:
+            self.sampleFrameChanged = Signal('RLiSetupMapPanel.sampleFrameChanged')
+            self._registeredGraphics = self.mapWindow.RegisterGraphicsToDraw(graphicsType='box')
+        elif self.samplingtype in [SamplingType.MUNITSC, SamplingType.KUNITSC,
+                                   SamplingType.KMVWINC, SamplingType.MMVWINC]:
+            self.afterCircleDrawn = Signal('RLiSetupMapPanel.afterCircleDrawn')
+        else:
-        self._registeredGraphics = self.mapWindow.RegisterGraphicsToDraw(graphicsType='rectangle')
-        self._registeredGraphics.AddPen('rlisetup', wx.Pen(wx.GREEN, width=3, style=wx.SOLID))
-        self._registeredGraphics.AddItem(coords=[[0, 0], [0, 0]], penName='rlisetup', hide=True)
+        self._registeredGraphics.AddPen('rlisetup', wx.Pen(wx.GREEN, width=2,
+                                                           style=wx.SHORT_DASH))
+        self._registeredGraphics.AddItem(coords=[[0, 0], [0, 0]],
+                                         penName='rlisetup', hide=True)
     def GetMap(self):
         return self.map_
-    def GetRegion(self):
-        """!Returns currently drawn region in a dict"""
-        return self._region
     def OnPan(self, event):
         """!Panning, set mouse to drag."""
         self.mapWindow.SetModePan()
@@ -106,22 +158,225 @@
         layers = self.map_.GetListOfLayers()
         self.mapWindow.ZoomToMap(layers=layers, ignoreNulls=False, render=True)
+    def OnDrawRadius(self, event):
+        """!Start draw mode"""
+        self.mapWindow.mouse['use'] = "None"
+        self.mapWindow.mouse['box'] = "line"
+        self.mapWindow.pen = wx.Pen(colour=wx.RED, width=1,
+        self.mapWindow.SetNamedCursor('cross')
+        self.mapWindow.mouseLeftUp.connect(self._radiusDrawn)
+    def OnDigitizeRegion(self, event):
+        self.mapWindow.mouseLeftDown.connect(self._mouseLeftDown)
+        self.mapWindow.mouseMoving.connect(self._mouseMoving)
+        self.mapWindow.mouseDClick.connect(self._mouseDbClick)
     def OnDraw(self, event):
-        self.mapWindow.mouse['use'] = None
         self.mapWindow.mouse['box'] = "box"
-        self.mapWindow.pen = wx.Pen(colour=wx.RED, width=2, style=wx.SHORT_DASH)
+        self.mapWindow.pen = wx.Pen(colour=wx.RED, width=2,
         self.mapWindow.mouseLeftUp.connect(self._rectangleDrawn)
+    def _mouseLeftDown(self, x, y):
+        self.polycoords.append((x, y))
+        self.coords.append((x, y))
+        if len(self.polycoords) > 1:
+            item = self._registeredGraphics.GetItem(0)
+            item.SetCoords(self.polycoords)
+            self.coords = []
+            item.SetPropertyVal('hide', False)
+            self._registeredGraphics.Draw(self.mapWindow.pdc)
+    def _mouseMoving(self, x, y):
+        self.mapWindow.mouse['end'] = (x, y)
+        if len(self.coords) > 0:
+            mouse = self.mapWindow.mouse
+            item.SetCoords([self.coords[0], mouse['end']])
+            self.mapWindow.ClearLines()
+            self._registeredGraphics.Draw(self.mapWindow.pdcTmp)
+    def _mouseDbClick(self, x, y):
+            self.polycoords.append(self.polycoords[0])
+            self.createRegion()
+    def createRegion(self):
+        dlg = wx.TextEntryDialog(None, 'Name of sample region',
+                                 'Create region', 'region' + str(self.catId))
+        ret = dlg.ShowModal()
+        if ret == wx.ID_OK:
+            raster = dlg.GetValue()
+            marea = self.writeArea(self.polycoords, raster)
+            self.nextRegion(next=True, area=marea)
+        else:
+            self.nextRegion(next=False)
+        dlg.Destroy()
+    def nextRegion(self, next=True, area=None):
+        self.coords = []
+        item.SetPropertyVal('hide', True)
+        layers = self.map_.GetListOfLayers()
+        self.mapWindow.ZoomToMap(layers=layers, ignoreNulls=False, render=True)
+        if next is True:
+            self.afterRegionDrawn.emit(marea=area)
+        else:
+            gcmd.GMessage(parent=self.parent,
+                          message=_("Raster map not created. redraw region again."))
+    def writeArea(self, coords, rasterName):
+        polyfile = tempfile.NamedTemporaryFile(delete=False)
+        polyfile.write("AREA\n")
+        for coor in coords:
+            east, north = coor
+            point = " %s %s\n" % (east, north)
+            polyfile.write(point)
+        catbuf = "=%d a\n" % self.catId
+        polyfile.write(catbuf)
+        self.catId = self.catId + 1
+        polyfile.close()
+        region_settings = grass.parse_command('g.region', flags='p',
+                                              delimiter=':')
+        pname = polyfile.name.split('/')[-1]
+        tmpraster = "rast_" + pname
+        tmpvector = "vect_" + pname
+        RunCommand('r.in.poly', input=polyfile.name, output=tmpraster,
+                   rows=region_settings['rows'], overwrite=True)
+        RunCommand('r.to.vect', input=tmpraster, output=tmpvector,
+                   type='area', overwrite=True)
+        RunCommand('v.to.rast', input=tmpvector, output=rasterName,
+                   value=1, use='val', overwrite=True)
+        grass.use_temp_region()
+        grass.run_command('g.region', vect=tmpvector)
+        region = grass.region()
+        marea = MaskedArea(region, rasterName)
+        RunCommand('g.remove', rast=tmpraster)
+        RunCommand('g.remove', vect=tmpvector)
+        os.unlink(polyfile.name)
+        return marea
     def _onToolChanged(self):
         """!Helper function to disconnect drawing"""
         try:
             self.mapWindow.mouseLeftUp.disconnect(self._rectangleDrawn)
+            self.mapWindow.mouseLeftUp.disconnect(self._radiusDrawn)
+            self.mapWindow.mouseMoving.disconnect(self._mouseMoving)
+            self.mapWindow.mouseLeftDown.disconnect(self._mouseLeftDown)
+            self.mapWindow.mouseDClick.disconnect(self._mouseDbClick)
         except DispatcherKeyError:
             pass
+    def _radiusDrawn(self, x, y):
+        """!When drawing finished, get region values"""
+        p1 = mouse['begin']
+        p2 = mouse['end']
+        dist, (north, east) = self.mapWindow.Distance(p1, p2, False)
+        circle = Circle(p1, dist)
+        self.mapWindow.pdcTmp.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
+        pen = wx.Pen(colour=wx.RED, width=2)
+        self.mapWindow.pdcTmp.SetPen(pen)
+        self.mapWindow.pdcTmp.DrawCircle(circle.point[0], circle.point[1],
+                                         circle.radius)
+        self.createCricle(circle)
+    def createCricle(self, c):
+            circle = self.writeCircle(c, raster)
+            self.nextCircle(next=True, circle=c)
+        else:
+            self.nextCircle(next=False)
+        dlg.Destroy()
+    def nextCircle(self, next=True, circle=None):
+        if next is True:
+            self.afterCircleDrawn.emit(mcircle=circle)
+        else:
+    def writeCircle(self, circle, rasterName):
+        polyfile.close()
+                                              delimiter=':')
+        return marea
     def _rectangleDrawn(self):
@@ -129,7 +384,7 @@
         p1 = self.mapWindow.Pixel2Cell(mouse['begin'])
         p2 = self.mapWindow.Pixel2Cell(mouse['end'])
         item.SetCoords([p1, p2])
-        self._region = {'n': max(p1[1], p2[1]),
+        region = {'n': max(p1[1], p2[1]),
                         's': min(p1[1], p2[1]),
                         'w': min(p1[0], p2[0]),
                         'e': max(p1[0], p2[0])}
@@ -137,12 +392,43 @@
-        self.sampleFrameChanged.emit()
+        if self.samplingtype == SamplingType.MUNITSR:
+            dlg = wx.MessageDialog(self, "Is this area ok?",
+                                   "select sampling unit",
+                                   wx.YES_NO | wx.ICON_QUESTION)
+            if ret == wx.ID_YES:
+                grass.run_command('g.region', n=region['n'], s=region['s'],
+                                  e=region['e'], w=region['w'])
+                tregion = grass.region()
+                self.sampleFrameChanged.emit(region=tregion)
+                                         render=True)
+            else:
+            dlg.Destroy()
+        elif self.samplingtype != SamplingType.WHOLE:
+            self.sampleFrameChanged.emit(region=region)
 icons = {'draw': MetaIcon(img='edit',
                           label=_('Draw sampling frame'),
-                          desc=_('Draw sampling frame by clicking and dragging'))}
+                          desc=_('Draw sampling frame by clicking and dragging')),
+         'digitizeunit': MetaIcon(img='edit',
+                          label=_('Draw sampling rectangle'),
+                          desc=_('Draw sampling rectangle by clicking and dragging')),
+         'digitizeunitc': MetaIcon(img='line-create',
+                          label=_('Draw sampling circle'),
+                          desc=_('Draw sampling circle radius by clicking and dragging')),
+         'digitizeregion': MetaIcon(img='polygon-create',
+                          label=_('Draw sampling region'),
+                          desc=_('Draw sampling region by polygon. Right Double click to end drawing'))}
 class RLiSetupToolbar(BaseToolbar):
@@ -151,32 +437,83 @@
     def __init__(self, parent, toolSwitcher):
         """!RLiSetup toolbar constructor
-        BaseToolbar.__init__(self, parent, toolSwitcher, style=wx.NO_BORDER | wx.TB_VERTICAL)
+        BaseToolbar.__init__(self, parent, toolSwitcher,
+                             style=wx.NO_BORDER | wx.TB_VERTICAL)
         self.InitToolbar(self._toolbarData())
-        self._default = self.draw
-        for tool in (self.draw, self.pan, self.zoomIn, self.zoomOut):
-            self.toolSwitcher.AddToolToGroup(group='mouseUse', toolbar=self, tool=tool)
+        if self.parent.samplingtype == SamplingType.REGIONS:
+            self._default = self.digitizeregion
+            self.toolSwitcher.AddToolToGroup(group='mouseUse', toolbar=self, tool=self.digitizeregion)
+        elif self.parent.samplingtype == SamplingType.MUNITSR:
+            self._default = self.digitizeunit
+            self.toolSwitcher.AddToolToGroup(group='mouseUse', toolbar=self, tool=self.digitizeunit)
+        else:
+            self._default = self.draw
+            self.toolSwitcher.AddToolToGroup(group='mouseUse', toolbar=self, tool=self.draw)
+        elif self.parent.samplingtype == SamplingType.MUNITSC:
+            self._default = self.digitizeunitc
+        elif self.parent.samplingtype == SamplingType.VECT:
+            self._default = None
+        else:
+        for tool in (self._default, self.pan, self.zoomIn, self.zoomOut):
+            if tool:
+                                                 toolbar=self, tool=tool)
         # realize the toolbar
         self.Realize()
     def _toolbarData(self):
         """!Toolbar data"""
-        return self._getToolbarData((('draw', icons['draw'],
+            drawTool = ('digitizeregion', icons['digitizeregion'],
+                                     self.parent.OnDigitizeRegion,
+                                     wx.ITEM_CHECK)
+            drawTool = ('digitizeunit', icons['digitizeunit'],
                                      self.parent.OnDraw,
-                                     wx.ITEM_CHECK),
-                                     (None, ),
-                                     ('pan', BaseIcons['pan'],
+                                     wx.ITEM_CHECK)
+            drawTool = ('digitizeunitc', icons['digitizeunitc'],
+                                     self.parent.OnDrawRadius,
+                                     wx.ITEM_CHECK)
+        else:
+            drawTool = ('draw', icons['draw'],
+                         self.parent.OnDraw,
+                         wx.ITEM_CHECK)
+        if self.parent.samplingtype == SamplingType.VECT:
+            return self._getToolbarData((
+                       ('pan', BaseIcons['pan'],
                                       self.parent.OnPan,
                                       wx.ITEM_CHECK),
-                                     ('zoomIn', BaseIcons['zoomIn'],
+                       ('zoomIn', BaseIcons['zoomIn'],
                                       self.parent.OnZoomIn,
                                       wx.ITEM_CHECK),
-                                     ('zoomOut', BaseIcons['zoomOut'],
+                       ('zoomOut', BaseIcons['zoomOut'],
                                       self.parent.OnZoomOut,
                                       wx.ITEM_CHECK),
-                                     ('zoomExtent', BaseIcons['zoomExtent'],
-                                      self.parent.OnZoomToMap),
+                       ('zoomExtent', BaseIcons['zoomExtent'],
+                                      self.parent.OnZoomToMap),))
+        else:
+            return self._getToolbarData((drawTool, (None, ),
+                                      self.parent.OnPan,
+                                      wx.ITEM_CHECK),
+                                      self.parent.OnZoomIn,
+                                      wx.ITEM_CHECK),
+                                      self.parent.OnZoomOut,
+                                      wx.ITEM_CHECK),
Modified: grass/trunk/gui/wxpython/rlisetup/wizard.py
--- grass/trunk/gui/wxpython/rlisetup/wizard.py	2014-03-05 10:50:47 UTC (rev 59196)
+++ grass/trunk/gui/wxpython/rlisetup/wizard.py	2014-03-05 12:57:20 UTC (rev 59197)
@@ -9,7 +9,7 @@
  - RLIWizard (the main wizard)
  - FirstPage (first page of wizard, choose name of conf file, raster, vector,
               sampling region)
- - Keybord (page to insert region areas from keybord)
+ - Keyboard (page to insert region areas from keyboard)
  - SamplingAreas (define sampling area)
  - SummaryPage (show choosen options)
@@ -32,15 +32,15 @@
 import wx.lib.scrolledpanel as scrolled
 from gui_core import gselect
-from core import gcmd
 from core.utils import _
 from location_wizard.wizard import TitledPage as TitledPage
 from rlisetup.functions import checkValue, retRLiPath
 from rlisetup.sampling_frame import RLiSetupMapPanel
 from grass.script import raster as grast
+from functions import SamplingType, sampleAreaVector, convertFeature, obtainAreaVector
+from core.gcmd import GError, GMessage, RunCommand
 #@NOTE: r.li.setup writes in the settings file with
 ## r.li.windows.tcl:
 #exec echo "SAMPLINGFRAME $per_x|$per_y|$per_rl|$per_cl" >> $env(TMP).set
@@ -48,7 +48,7 @@
 class RLIWizard(object):
-    Start wizard here and finish wizard here
+    !Start wizard here and finish wizard here
     def __init__(self, parent):
@@ -57,14 +57,20 @@
                                  title=_("Create new configuration file for " \
                                  "r.li modules"))
+        self.msAreaList = []
         #pages
         self.startpage = FirstPage(self.wizard, self)
         self.drawsampleframepage = DrawSampleFramePage(self.wizard, self)
-        self.keyboardpage = KeybordPage(self.wizard, self)
+        self.keyboardpage = KeyboardPage(self.wizard, self)
         self.samplingareapage = SamplingAreasPage(self.wizard, self)
         self.summarypage = SummaryPage(self.wizard, self)
         self.units = SampleUnitsKeyPage(self.wizard, self)
+        self.drawunits = SampleUnitsMousePage(self.wizard, self)
+        self.drawsampleunitspage = DrawSampleUnitsPage(self.wizard, self)
+        self.vectorareas = VectorAreasPage(self.wizard, self)
         self.moving = MovingWindows(self.wizard, self)
+        self.regions = DrawRegionsPage(self.wizard, self)
         #order of pages
         self.startpage.SetNext(self.samplingareapage)
@@ -74,10 +80,25 @@
         self.drawsampleframepage.SetPrev(self.startpage)
         self.samplingareapage.SetPrev(self.startpage)
         self.samplingareapage.SetNext(self.summarypage)
+        self.regions.SetPrev(self.samplingareapage)
+        self.regions.SetNext(self.summarypage)
         self.units.SetPrev(self.samplingareapage)
         self.units.SetNext(self.summarypage)
+        self.drawunits.SetPrev(self.samplingareapage)
+        self.drawunits.SetNext(self.drawsampleunitspage)
+        self.drawsampleunitspage.SetPrev(self.drawunits)
+        self.drawsampleunitspage.SetNext(self.summarypage)
         self.moving.SetPrev(self.samplingareapage)
         self.moving.SetNext(self.summarypage)
+        self.vectorareas.SetPrev(self.samplingareapage)
+        self.vectorareas.SetNext(self.summarypage)
         self.summarypage.SetPrev(self.samplingareapage)
         #layout
@@ -87,7 +108,11 @@
         self.samplingareapage.DoLayout()
         self.summarypage.DoLayout()
         self.units.DoLayout()
+        self.drawunits.DoLayout()
+        self.drawsampleunitspage.DoLayout()
+        self.regions.DoLayout()
         self.moving.DoLayout()
+        self.vectorareas.DoLayout()
         self.wizard.FitToPage(self.startpage)
         #run_wizard
@@ -100,20 +125,19 @@
             if dlg.ShowModal() == wx.ID_NO:
                 self._cleanup()
-                dlg.Destroy()
             else:
                 self._write_confile()
                 self._cleanup()
-                dlg.Destroy()
+            dlg.Destroy()
         else:
             self.wizard.Destroy()
-            gcmd.GMessage(parent=self.parent,
+            GMessage(parent=self.parent,
                      message=_("r.li.setup wizard canceled. "
                                 "Configuration file not created."))
             self._cleanup()
     def _write_confile(self):
-        """Write the configuration file"""
+        """!Write the configuration file"""
         f = open(os.path.join(self.rlipath, self.startpage.conf_name), 'w')
         self.rasterinfo = grast.raster_info(self.startpage.rast)
         self._write_region(f)
@@ -131,7 +155,7 @@
         self.SF_EWRES = self.gregion['ewres']
     def _write_region(self, fil):
-        """Write the region"""
+        """!Write the region"""
         if self.startpage.region == 'whole':
             fil.write("SAMPLINGFRAME 0|0|1|1\n")
             self._temp_region()
@@ -163,22 +187,21 @@
             self.per_y = float(self.SF_Y) / float(self.rasterinfo['rows'])
             self.per_rl = float(self.SF_RL) / float(self.rasterinfo['rows'])
             self.per_cl = float(self.SF_CL) / float(self.rasterinfo['cols'])
-            #import pdb; pdb.set_trace()
             fil.write("SAMPLINGFRAME %r|%r|%r|%r\n" % (self.per_x, self.per_y,
                                                        self.per_rl, self.per_cl))
         elif self.startpage.region == 'draw':
             self._temp_region()
-            frame = self.drawsampleframepage.GetSampleFrame()
+            tregion = self.drawsampleframepage.tregion
             # should we call this? with align param?
-            gcmd.RunCommand('g.region', align=self.startpage.rast,
-                            n=frame['n'], s=frame['s'],
-                            w=frame['w'], e=frame['e'])
+            RunCommand('g.region', align=self.startpage.rast,
+                            n=tregion['n'], s=tregion['s'],
+                            w=tregion['w'], e=tregion['e'])
             newreg = grass.region()
-            self.SF_N = newreg['n']  #	set env(SF_N) $n
+            self.SF_N = newreg['n']  # set env(SF_N) $n
             self.SF_S = newreg['s']  # set env(SF_S) $s
             self.SF_E = newreg['e']  # set env(SF_E) $e
-            self.SF_W = newreg['w']  # set env(SF_W) $w
+            self.SF_W = newreg['w']  # set env(SF_W) $w
             self.SF_Y = abs(round(self.gregion['n'] - newreg['n']) / newreg['nsres'])
 #		 set env(SF_Y) [expr abs(round(($s_n - $n) / $nres)) ]
             self.SF_X = abs(round(self.gregion['w'] - newreg['w']) / newreg['ewres'])
@@ -199,7 +222,7 @@
     def _circle(self, radius, mask):
-        """create a circle mask"""
+        """!Create a circle mask"""
         self.CIR_RL = round((2 * float(radius)) / float(self.rasterinfo['ewres']))
         self.CIR_CL = round((2 * float(radius)) / float(self.rasterinfo['nsres']))
         if not self.CIR_RL % 2:
@@ -220,40 +243,84 @@
         grass.run_command('g.region', rast=self.startpage.rast)
+    def getSamplingType(self):
+        """!Obtain the sampling type"""
+        devicetype = self.samplingareapage.regionbox
+        samplingtype = self.samplingareapage.samplingtype
+        shapetype = self.units.boxtype
+        if samplingtype == SamplingType.UNITS:
+            if devicetype == 'mouse':
+                if shapetype == 'circle':
+                    samtype = SamplingType.MUNITSC
+                else:
+                    samtype = SamplingType.MUNITSR
+            elif devicetype == 'keyboard':
+                    samtype = SamplingType.KUNITSC
+                else:
+                    samtype = SamplingType.KUNITSR
+        elif samplingtype == SamplingType.MVWIN:
+                    samtype = SamplingType.MMVWINC
+                else:
+                    samtype = SamplingType.MMVWINR
+                    samtype = SamplingType.KMVWINC
+                else:
+                    samtype = SamplingType.KMVWINR
+        elif samplingtype == SamplingType.WHOLE:
+            samtype = SamplingType.WHOLE
+        elif samplingtype == SamplingType.REGIONS:
+            samtype = SamplingType.REGIONS
+        elif samplingtype == SamplingType.VECT:
+            samtype = SamplingType.VECT
+        return samtype
     def _write_area(self, fil):
-        if self.samplingareapage.samplingtype == 'whole':
+        """!Write the area according the type"""
+        samtype = self.getSamplingType()
+        #sampling type is whole
+        if samtype == SamplingType.WHOLE:
             #this two variable are unused, problably to remove
-            x = float(self.SF_X) / float(self.rasterinfo['cols'])
-            y = float(self.SF_Y) / float(self.rasterinfo['rows'])
-            if self.startpage.region == 'whole':
-                fil.write("SAMPLEAREA %r|%r|%r|%r\n" % (self.per_x, self.per_y,
-                                                        rl, cl))
-            elif self.startpage.region == 'key':
-                                                        rl, cl))
-        elif self.samplingareapage.samplingtype == 'moving':
-            if self.moving.boxtype == 'circle':
-                self._circle(self.moving.width, self.moving.height)
-                cl = float(self.CIR_CL) / float(self.rasterinfo['cols'])
-                rl = float(self.CIR_RL) / float(self.rasterinfo['rows'])
-            else:
-                cl = float(self.moving.width) / float(self.rasterinfo['cols'])
-                rl = float(self.moving.height) / float(self.rasterinfo['rows'])
+            x = float(self.SF_X) / float(self.rasterinfo['cols'])
+            y = float(self.SF_Y) / float(self.rasterinfo['rows'])
+            fil.write("SAMPLEAREA %r|%r|%r|%r\n" % (self.per_x, self.per_y,
+                                                    rl, cl))
+        ##KMWINC = samplingtype=moving, regionbox=keyboard, shape=circle
+        elif samtype == SamplingType.KMVWINC:
+            self._circle(self.moving.width, self.moving.height)
+            cl = float(self.CIR_CL) / float(self.rasterinfo['cols'])
+            rl = float(self.CIR_RL) / float(self.rasterinfo['rows'])
             fil.write("SAMPLEAREA -1|-1|%r|%r" % (rl, cl))
-                fil.write("|%s" % self.moving.height)
+            fil.write("|%s" % self.moving.height)
             fil.write("\nMOVINGWINDOW\n")
-        elif self.samplingareapage.samplingtype == 'units':
-            if self.units.boxtype == 'circle':
+        ##KMWINR = samplingtype moving, regionbox=keyboard, shape=rectangle
+        elif samtype == SamplingType.KMVWINR:
+            cl = float(self.moving.width) / float(self.rasterinfo['cols'])
+            rl = float(self.moving.height) / float(self.rasterinfo['rows'])
+            fil.write("SAMPLEAREA -1|-1|%r|%r" % (rl, cl))
+            fil.write("\nMOVINGWINDOW\n")
+        ##KUNITSC = samplingtype=units, regionbox=keyboard, shape=cirlce
+        ##KUNITSR = samplingtype=units, regionbox=keyboard, shape=rectangle
+        elif samtype == SamplingType.KUNITSC or samtype == SamplingType.KUNITSR:
+            if samtype == SamplingType.KUNITSC:
                 self._circle(self.units.width, self.units.height)
             else:
-                cl = float(self.units.width) / float(self.rasterinfo['cols'])
-                rl = float(self.units.height) / float(self.rasterinfo['rows'])
             fil.write("SAMPLEAREA -1|-1|%r|%r\n" % (rl, cl))
             if self.units.distrtype == 'non_overlapping':
                 fil.write("RANDOMNONOVERLAPPING %s\n" % self.units.distr1)
@@ -267,8 +334,60 @@
             elif self.units.distrtype == 'centered_oversites':
                 fil.write("")
+        #elif self.samplingareapage.samplingtype == SamplingType.UNITS and self.samplingareapage.regionbox=='mouse':
+        ##MUNITSC = samplingtype=units, regionbox=mouse, shape=cirlce
+        elif self.samplingareapage.samplingtype == SamplingType.MUNITSC:
+            print "not added"
+        ##MUNITSR = samplingtype=units, regionbox=mouse, shape=rectangle
+        elif self.samplingareapage.samplingtype == SamplingType.MUNITSR:
+            for tregion in self.msAreaList:
+                rows = float(self.rasterinfo['rows'])
+                cols = float(self.rasterinfo['cols'])
+                # get the raster region into rastregion
+                grass.run_command('g.region', rast=self.startpage.rast)
+                rastregion = grass.region()
+                s_n = rastregion['n']
+                s_w = rastregion['w']
+                abs_y = abs(round((float(s_n) - tregion['n']) / tregion['nsres']))
+                abs_x = abs(round((float(s_w) - tregion['w']) / tregion['ewres']))
+                abs_rl = abs(round((tregion['n'] - tregion['s']) / tregion['nsres']))
+                abs_cl = abs(round((tregion['e'] - tregion['w']) / tregion['ewres']))
+                x = float(abs_x) / float(cols)
+                y = float(abs_y) / float(rows)
+                rl = float(abs_rl) / float(rows)
+                cl = float(abs_cl) / float(cols)
+                sarea = str(x) + "|" + str(y) + "|" + str(rl) + "|" + str(cl)
+                fil.write("SQUAREAREA %s\n" % sarea)
+        elif self.samplingareapage.samplingtype == SamplingType.REGIONS:
+            for marea in self.msAreaList:
+                gregion = marea.region
+                abs_y = self.SF_Y + abs(round((self.SF_N - gregion['n']) / self.SF_NSRES))
+                abs_x = self.SF_X + abs(round((self.SF_W - gregion['w']) / self.SF_EWRES))
+                abs_rl = abs(round(gregion['n'] - gregion['s']) / self.SF_NSRES)
+                abs_cl = abs(round(gregion['e'] - gregion['w']) / self.SF_EWRES)
+                maskArea = str(x) + "|" + str(y) + "|" + str(rl) + "|" + str(cl) + "|" + marea.raster
+                fil.write("SQUAREAREA %s\n" % maskArea)
+        elif self.samplingareapage.samplingtype == SamplingType.VECT:
+                fil.write(marea)
+            fil.write("RASTERMAP {name}\n".format(name=self.startpage.rast))
+            fil.write("VECTORMAP {name}\n".format(name=self.startpage.vect))
     def _cleanup(self):
-        """Clean all the variables to save into configuration file"""
+        """!Clean all the variables to save into configuration file"""
         self.startpage.conf_name = ''
         self.startpage.rast = ''
         self.startpage.vect = ''
@@ -281,6 +400,7 @@
         self.units.width = ''
         self.units.height = ''
         self.units.boxtype = ''
+        self.regions.numregions = 0
         self.moving.width = ''
         self.moving.height = ''
         self.moving.boxtype = ''
@@ -288,9 +408,8 @@
 class FirstPage(TitledPage):
-    Set name of configuration file, choose raster and optionally vector/sites
+    !Set name of configuration file, choose raster and optionally vector/sites
     def __init__(self, wizard, parent):
         TitledPage.__init__(self, wizard, _("Select maps and define name"))
@@ -329,8 +448,6 @@
         self.vectselect = gselect.Select(parent=self, id=wx.ID_ANY,
                                          size=(250, -1), type='vector',
                                          multiple=False)
-        self.vectsellabel.Enable(False)
-        self.vectselect.Enable(False)
         self.sizer.Add(item=self.vectsellabel, border=5, pos=(2, 0),
                         flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
         self.sizer.Add(item=self.vectselect, border=5, pos=(2, 1),
@@ -345,8 +462,6 @@
                                       majorDimension=1,
                                       style=wx.RA_SPECIFY_ROWS)
-#        self.sampling_reg.EnableItem(2, False)  # disable 'draw' for now
-#        self.sampling_reg.SetItemToolTip(2, _("This option is not supported yet"))
         self.sizer.Add(item=self.sampling_reg,
                         flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
                         pos=(4, 0), span=(1, 2))
@@ -356,31 +471,27 @@
         self.newconftxt.Bind(wx.EVT_TEXT, self.OnNameChanged)
         self.vectselect.Bind(wx.EVT_TEXT, self.OnVector)
         self.mapselect.Bind(wx.EVT_TEXT, self.OnRast)
-        #self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
         self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
         wx.CallAfter(wx.FindWindowById(wx.ID_FORWARD).Enable, False)
-        # wx.FindWindowById(wx.ID_FORWARD).Enable(False)
-        # self.OnName(None)
     def OnSampling(self, event):
-        """!Change map type"""
+        """!Change region type"""
         if event.GetInt() == 0:
             self.region = 'whole'
             self.SetNext(self.parent.samplingareapage)
         elif event.GetInt() == 1:
             self.region = 'key'
             self.SetNext(self.parent.keyboardpage)
-        elif event.GetInt() == 2: # currently disabled
+        elif event.GetInt() == 2:  # currently disabled
             self.region = 'draw'
             self.SetNext(self.parent.drawsampleframepage)
     def OnName(self, event):
         """!Sets the name of configuration file"""
         if self.conf_name in self.parent.parent.listfiles:
-            gcmd.GMessage(parent=self,
-                          message=_("The configuration file %s "
-                                    "already exists, please change name") % self.conf_name)
+            GMessage(parent=self, message=_("The configuration file %s "
+                     "already exists, please change name") % self.conf_name)
             self.newconftxt.SetValue('')
             self.conf_name = ''
@@ -408,7 +519,8 @@
         @return True if configuration file is given and raster xor vector map,
         False otherwise
-        return bool(self.conf_name and (bool(self.rast) != bool(self.vect)))
+        #R#return bool(self.conf_name and (bool(self.rast) != bool(self.vect)))
+        return bool(self.conf_name and bool(self.rast))
     def OnExitPage(self, event=None):
         """!Function during exiting"""
@@ -428,11 +540,11 @@
                 self.parent.samplingareapage.SetPrev(self.parent.drawsampleframepage)
                 return
-class KeybordPage(TitledPage):
+class KeyboardPage(TitledPage):
+    !Choose the region setting the values of border using the keyboard
         TitledPage.__init__(self, wizard, _("Insert sampling frame parameter"))
@@ -526,6 +638,7 @@
     def OnEnterPage(self, event):
         """!Sets the default values, for the entire map
+        #R# check if raster exists before anything
         if self.col_len == '' and self.row_len == '':
             rastinfo = grast.raster_info(self.parent.startpage.rast)
             self.col_len = rastinfo['cols']
@@ -543,32 +656,36 @@
 class DrawSampleFramePage(TitledPage):
+    """!Choose the region setting the values drawing a box"""
         TitledPage.__init__(self, wizard, _("Draw sampling frame"))
-        self.mapPanel = RLiSetupMapPanel(self)
-        self.mapPanel.sampleFrameChanged.connect(self.SampleFrameChanged)
-        self.sizer.Add(item=self.mapPanel, flag=wx.EXPAND, pos=(0, 0))
-        self.sizer.AddGrowableCol(0)
-        self.sizer.AddGrowableRow(0)
-        self._raster = None
+        self.mapPanel = None
+        self.tregion = None
-    def SampleFrameChanged(self):
-        region = self.GetSampleFrame()
+    def SampleFrameChanged(self, region):
+        """"!Enables the next dialog when region is set"""
         if region:
+            self.tregion = region
             wx.FindWindowById(wx.ID_FORWARD).Enable(True)
         else:
-            wx.FindWindowById(wx.ID_FORWARD).Enable(False)
-    def GetSampleFrame(self):
-        return self.mapPanel.GetRegion()
+            wx.FindWindowById(wx.ID_FORWARD).Enable(False)
-        self.SampleFrameChanged()
+        """!Function during entering"""
+        if self.mapPanel is None:
+            self.mapPanel = RLiSetupMapPanel(self, samplingType='drawFrame')
+            self.mapPanel.sampleFrameChanged.connect(self.SampleFrameChanged)
+            self.sizer.Add(item=self.mapPanel, flag=wx.EXPAND, pos=(0, 0))
+            self.sizer.AddGrowableCol(0)
+            self.sizer.AddGrowableRow(0)
+            self._raster = None
+        else:
+            self.mapPanel._region = {}
+        self.SampleFrameChanged(region=None)
         rast = self.parent.startpage.rast
         if self._raster != rast:
             map_ = self.mapPanel.GetMap()
@@ -577,19 +694,328 @@
             map_.AddLayer(ltype='raster', command=cmdlist, active=True,
                               name=rast, hidden=False, opacity=1.0,
                               render=True)
         if event.GetDirection():
             self.parent.samplingareapage.SetPrev(self)
+        else:
+            wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+class SampleUnitsMousePage(TitledPage):
+    """!Choose the sampling area setting the values using the mouse"""
+    def __init__(self, wizard, parent):
+        TitledPage.__init__(self, wizard, _("Draw sampling units"))
+        self.numregions = ''
+        # type of shape
+        self.typeBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
+                                   majorDimension=1, style=wx.RA_SPECIFY_COLS,
+                                   label=" %s " % _("Select type of shape"),
+                                   choices=[_('Rectangle'), _('Circle')])
+        self.sizer.Add(self.typeBox, flag=wx.ALIGN_LEFT, pos=(0, 0),
+                            span=(1, 2))
+        self.regionPanelSizer = wx.GridBagSizer(1, 2)
+        self.regionNumPanel = wx.Panel(parent=self, id=wx.ID_ANY)
+        self.regionNumLabel = wx.StaticText(parent=self.regionNumPanel,
+                                            id=wx.ID_ANY,
+                                            label=_('Number of sampling area to draw:'))
+        self.regionNumTxt = wx.TextCtrl(parent=self.regionNumPanel,
+                                        id=wx.ID_ANY, size=(50, -1))
+        self.regionPanelSizer.Add(self.regionNumLabel, flag=wx.ALIGN_CENTER,
+                                  pos=(0, 0))
+        self.regionPanelSizer.Add(self.regionNumTxt, flag=wx.ALIGN_CENTER,
+                                  pos=(0, 1))
+        self.regionNumPanel.SetSizer(self.regionPanelSizer)
+        self.sizer.Add(self.regionNumPanel, flag=wx.ALIGN_LEFT, pos=(1, 0),
+                            span=(1, 2))
+        self.typeBox.Bind(wx.EVT_RADIOBOX, self.OnType)
+        self.regionNumTxt.Bind(wx.EVT_TEXT, self.OnNumRegions)
+        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
+        self.OnType(None)
+        self.regionNumTxt.SetValue('')
+    def OnEnterPage(self, event):
+        if self.numregions:
+        else:
+    def OnType(self, event):
+        chosen = self.typeBox.GetSelection()
+        if chosen == 0:
+            self.drawtype = 'rectangle'
+        else:
+            self.drawtype = 'circle'
+    def OnNumRegions(self, event):
+        """!Set the number of region"""
+        if event.GetString():
+            self.SetNext(self.parent.drawsampleunitspage)
+            self.numregions = event.GetString()
+        else:
+    def OnExitPage(self, event=None):
+        """!Function during exiting"""
+        if event.GetDirection():
+            self.SetNext(self.drawsampleunitspage)
+            self.SetPrev(self.samplingareapage)
+class DrawSampleUnitsPage(TitledPage):
+    """!Choose the sampling area drawing them"""
+        self.regioncount = 0
+        #self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
+        #region = self.GetSampleUnitRegion()
+        if region:
+            self.parent.msAreaList.append(region)
+        self.regioncount = self.regioncount + 1
+        numregions = int(self.parent.drawunits.numregions)
+        drawtype = self.parent.drawunits.drawtype
+        if self.regioncount > numregions:
+        else:
+            self.title.SetLabel(_('Draw Sampling ' + drawtype  + ' ' \
+                                  + str(self.regioncount) + ' of ' \
+                                  + str(numregions) ))
+    def afterCircleDrawn(self):
+        if region:
+        else:
+            gtype = self.parent.drawunits.drawtype
+            self.mapPanel = RLiSetupMapPanel(self, samplingType=self.parent.samplingareapage.samplingtype,
+                                             graphicsType=gtype)
+            if gtype == 'circle':
+                self.mapPanel.afterCircleDrawn.connect(self.afterCircleDrawn)
+            else:
+            self.sizer.Add(item=self.mapPanel, flag=wx.EXPAND, pos=(1, 0))
+            self.sizer.AddGrowableRow(1)
+        rast = self.parent.startpage.rast
+        if self._raster != rast:
+            map_ = self.mapPanel.GetMap()
+            map_.DeleteAllLayers()
+            cmdlist = ['d.rast', 'map=%s' % rast]
+            map_.AddLayer(ltype='raster', command=cmdlist, active=True,
+                              name=rast, hidden=False, opacity=1.0,
+                              render=True)
+        #!Function during exiting
+        print event.GetDirection()
+        #if event.GetDirection():
+        #    self.SetNext(self.parent.samplingareapage)
+        #    self.parent.samplingareapage.SetPrev(self)
+class DrawRegionsPage(TitledPage):
+        TitledPage.__init__(self, wizard, _("Draw sampling region"))
+    def afterRegionDrawn(self, marea):
+        if marea:
+            self.parent.msAreaList.append(marea)
+        numregions = int(self.parent.samplingareapage.numregions)
+        else:
+            self.title.SetLabel(_('Draw sample region ' + str(self.regioncount) + ' of ' + str(numregions) ))
+            #print self.parent.samplingareapage.samplingtype
+            self.mapPanel = RLiSetupMapPanel(self, samplingType=self.parent.samplingareapage.samplingtype, graphicsType="line")
+            self.mapPanel.afterRegionDrawn.connect(self.afterRegionDrawn)
+        self.afterRegionDrawn(marea=None)
+                              render=True)
+    #def OnExitPage(self, event=None):
+        #print event.GetDirection()
+class VectorAreasPage(TitledPage):
+    """!Choose the sampling area using the vector features"""
+        TitledPage.__init__(self, wizard, _("Select sampling areas"))
+        self.areascount = 0
+        self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
+        self.areaPanelSizer = wx.GridBagSizer(1, 3)
+        self.areaPanel = wx.Panel(parent=self, id=wx.ID_ANY)
+        self.areaText = wx.StaticText(parent=self.areaPanel, id=wx.ID_ANY,
+                                     label=_('Is this area ok?'))
+        self.areaOK = wx.Button(self.areaPanel, wx.ID_ANY, 'Yes', (50, 80))
+        self.areaNO = wx.Button(self.areaPanel, wx.ID_ANY, 'No', (50, 80))
+        self.areaOK.Bind(wx.EVT_BUTTON, self.OnYes)
+        self.areaNO.Bind(wx.EVT_BUTTON, self.OnNo)
+        self.areaPanelSizer.Add(self.areaText, flag=wx.ALIGN_CENTER,
+                                  pos=(0, 0))
+        self.areaPanelSizer.Add(self.areaOK, flag=wx.ALIGN_CENTER,
+                                  pos=(0, 1))
+        self.areaPanelSizer.Add(self.areaNO, flag=wx.ALIGN_CENTER,
+                                  pos=(0, 2))
+        self.areaPanel.SetSizer(self.areaPanelSizer)
+        self.sizer.Add(self.areaPanel, flag=wx.ALIGN_CENTER, pos=(2, 0))
+    def afterRegionDrawn(self):
+        """!Function to update the title and the number of selected area"""
+        self.areascount = self.areascount + 1
+        if self.areascount == self.areanum:
+            return True
+        else:
+            self.title.SetLabel(_('Select sample area ' + str(self.areascount + 1) \
+                                  + ' of ' + str(self.areanum)))
+            return False
+    def OnYes(self, event):
+        """!Function to create the string for the conf file if the area
+        is selected"""
+        self.parent.msAreaList.append(obtainAreaVector(self.outname))
+        if not self.afterRegionDrawn():
+            self.newCat()
+    def OnNo(self, event):
+        """!Function to pass to the next feature if it is not selected"""
+            self.newCat()
+    def newCat(self):
+        """!Convert to raster and draw the new feature"""
+        cat = self.vect_cats[self.areascount]
+        self.outname = "{name}_{cat}".format(name=self.vect.split('@')[0],
+                                             cat=cat)
+        convertFeature(self.vect, self.outname, cat, self.rast)
+        cmdlistcat = ['d.rast', 'map=%s' % self.outname]
+        self.map_.AddLayer(ltype='raster', command=cmdlistcat, active=True,
+                      name=self.outname, hidden=False, opacity=1.0,
+                      render=True)
+        for l in self.map_.GetListOfLayers():
+            if l.name == self.outname:
+                self.mapPanel.mapWindow.ZoomToMap(layers=[l], render=True,
+                                                  ignoreNulls=True)
+            elif l.name != self.rast:
+                self.map_.DeleteLayer(l)
+        self.areaText.SetLabel("Is this area (cat={n}) ok?".format(n=cat))
+        """!Function during entering: draw the raster map and the first vector
+        feature"""
+                                             graphicsType="line")
+        self.rast = self.parent.startpage.rast
+        self.vect = self.parent.startpage.vect
+        self.vect_cats = sorted(set(grass.parse_command('v.category',
+                                                        input=self.vect,
+                                                        type='centroid',
+                                                        option='print').keys()))
+        self.areanum = len(self.vect_cats)
+        if self.areanum == 0:
+            GError(parent=self, message=_("The polygon seems to have 0 areas"))
+            self.parent.wizard.ShowPage(self.parent.samplingareapage)
+            return
+        self.title.SetLabel(_('Select sample area 1 of ' + str(self.areanum)))
+        if self._raster != self.rast:
+            self.map_ = self.mapPanel.GetMap()
+            self.map_.DeleteAllLayers()
+            cmdlist = ['d.rast', 'map=%s' % self.rast]
+            self.map_.AddLayer(ltype='raster', command=cmdlist, active=True,
+                              name=self.rast, hidden=False, opacity=1.0,
+                              render=True)
+        self.newCat()
+        grass.del_temp_region()
+#        if event.GetDirection():
+#            self.SetNext(self.parent.samplingareapage)
+#            self.parent.samplingareapage.SetPrev(self)
 class SamplingAreasPage(TitledPage):
         TitledPage.__init__(self, wizard, _("Insert sampling areas"))
         self.samplingtype = 'whole'
@@ -605,9 +1031,6 @@
                                                  "overlayed vector map")],
                                       majorDimension=1,
                                       style=wx.RA_SPECIFY_COLS | wx.NO_BORDER)
-        self.radioBox.EnableItem(1, False)
-        self.radioBox.SetItemToolTip(1, _("This option is not supported yet"))
         # layout
         self.sizer.SetVGap(10)
         self.sizer.Add(item=self.radioBox, flag=wx.ALIGN_LEFT, pos=(0, 0))
@@ -625,10 +1048,58 @@
         # bindings
         self.radioBox.Bind(wx.EVT_RADIOBOX, self.SetVal)
         self.regionBox.Bind(wx.EVT_RADIOBOX, self.OnRegionDraw)
-        self.regionbox = 'keybord'
+        self.regionbox = 'keyboard'
+                                            id=wx.ID_ANY,
+                                            label=_('Number of regions to draw:'))
+                                  pos=(0, 0))
+                                  pos=(0, 1))
+        self.sizer.Add(self.regionNumPanel, flag=wx.ALIGN_CENTER, pos=(2, 0))
+                                     label=_('Do you want to check vector areas?'))
+        self.areaOK.SetToolTip(wx.ToolTip(_("Select if use area by area")))
+        self.areaNO.SetToolTip(wx.ToolTip(_("All the features will be used")))
+        self.areaOK.Bind(wx.EVT_BUTTON, self.OnVectYes)
+        self.areaNO.Bind(wx.EVT_BUTTON, self.OnVectNo)
+                                  pos=(0, 0))
+                                  pos=(0, 1))
+                                  pos=(0, 2))
+        self.sizer.Add(self.areaPanel, flag=wx.ALIGN_CENTER, pos=(3, 0))
+        self.calculatingAreas = wx.StaticText(parent=self, id=wx.ID_ANY,
+                                     label=_('Analysing all vector features...'))
+        self.sizer.Add(self.calculatingAreas, flag=wx.ALIGN_CENTER, pos=(4, 0))
+        """!Obtain the number of regions"""
+            self.SetNext(self.parent.regions)
+        else:
         """!Insert values into text controls for summary of location
         creation options
@@ -636,63 +1107,114 @@
         self.SetVal(None)
         if self.parent.startpage.vect:
             self.radioBox.ShowItem(4, True)
+            self.vect_data = []
         else:
             self.radioBox.ShowItem(4, False)
         self.sizer.Layout()
     def SetVal(self, event):
         """!Choose method"""
         radio = self.radioBox.GetSelection()
         if radio == 0:
-            self.samplingtype = 'whole'
+            self.samplingtype = SamplingType.WHOLE
             self.DrawNothing()
-        # elif event.GetInt() == 1: # disabled
-        # self.samplingtype = 'regions'
-        # self.Region()
+        elif radio == 1:
+            self.samplingtype = SamplingType.REGIONS
         elif radio == 2:
-            self.samplingtype = 'units'
-            self.SetNext(self.parent.units)
-            self.KeyDraw()
+            self.samplingtype = SamplingType.UNITS
+            regtype = self.regionBox.GetSelection()
+            self.RegionDraw(regtype)
         elif radio == 3:
-            self.samplingtype = 'moving'
+            self.samplingtype = SamplingType.MVWIN
             self.SetNext(self.parent.moving)
-            self.KeyDraw()
         elif radio == 4:
-            self.samplingtype = 'vector'
-            self.DrawNothing()
+            self.samplingtype = SamplingType.VECT
+        self.ShowExtraOptions(self.samplingtype)
-    def Region(self):
-        """show this only if radio2 it is selected"""
-        try:
+    def ShowExtraOptions(self, samtype):
+        """!Show some extra options for some sampling type"""
+        if samtype == SamplingType.REGIONS:
             self.sizer.Hide(self.regionBox)
-            self.sizer.Remove(self.regionBox)
-            self.sizer.Layout()
-        except:
-            pass
-        gcmd.GMessage(parent=self, message=_("Function not supported yet"))
+            self.sizer.Hide(self.areaPanel)
+            self.sizer.Hide(self.calculatingAreas)
+            self.sizer.Show(self.regionNumPanel)
+        elif samtype == SamplingType.UNITS or  samtype == SamplingType.MVWIN:
+            self.sizer.Hide(self.regionNumPanel)
+            self.sizer.Show(self.regionBox)
+        elif samtype == SamplingType.VECT:
+            self.sizer.Hide(self.regionBox)
+            self.sizer.Show(self.areaPanel)
+        self.sizer.Layout()
+    def OnRegionDraw(self, event):
+        self.RegionDraw(event.GetInt())
         return
-    def KeyDraw(self):
-        """Show this only if radio3 and radio4 it is selected"""
-        self.sizer.Show(self.regionBox)
+    def OnVectYes(self, event):
+        """!The user choose to select the vector areas, this function set the
+        next page to VectorAreasPage"""
+        self.SetNext(self.parent.vectorareas)
+        self.parent.wizard.ShowPage(self.parent.vectorareas)
-    def OnRegionDraw(self, event):
-        """Function called by KeyDraw to find what method is choosed"""
-        if event.GetInt() == 0:
+    def OnVectNo(self, event):
+        """!The user choose to use all the vector areas, this function analyses
+        all the vector areas and fill the msAreaList variable"""
+        self.sizer.Show(self.calculatingAreas)
+        self.SetNext(self.parent.summarypage)
+        vect_cats = sorted(set(grass.parse_command('v.category', input=self.parent.startpage.vect,
+                                                   option='print',
+                                                   type='centroid').keys()))
+        self._progressDlg = wx.ProgressDialog(title=_("Analysing vector"),
+                                              message="Analysing vector",
+                                              maximum=len(vect_cats),
+                                              parent=self,
+                                              style=wx.PD_CAN_ABORT | wx.PD_APP_MODAL |
+                                              wx.PD_AUTO_HIDE | wx.PD_SMOOTH)
+        self._progressDlgMax = len(vect_cats)
+        self.parent.msAreaList = sampleAreaVector(self.parent.startpage.vect,
+                                                  self.parent.startpage.rast,
+                                                  vect_cats,
+                                                  self._progressDlg)
+        if self.parent.msAreaList:
+            self.calculatingAreas.SetLabel(_("All feature are been analyzed."))
+            self.parent.wizard.ShowPage(self.parent.summarypage)
+        else:
+            self.calculatingAreas.SetLabel(_("An error occurred"))
+        self._progressDlg.Destroy()
+        self._progressDlg = None
+    def RegionDraw(self, regtype):
+        """!Set the next page to units or drawunits"""
+        if regtype == 0:
+        elif regtype == 1:
+            self.regionbox = 'mouse'
+            self.SetNext(self.parent.drawunits)
-        elif event.GetInt() == 1:
-            self.regionbox = 'drawmouse'
-            return
-            #self.SetNext(self.parent.draw)
     def DrawNothing(self):
+        """Remove all the optional choices. Used also when the wizard enter in
+           SamplingAreasPage, all the optional choices should be hide here"""
         self.sizer.Layout()
@@ -788,8 +1310,15 @@
         self.scrollPanel.SetSizer(self.panelSizer)
         self.OnType(None)
+            self.SetPrev(self.parent.samplingareapage)
         self.widthLabel.SetLabel(self.widthLabels[chosen])
@@ -919,7 +1448,6 @@
 class SummaryPage(TitledPage):
     """!Shows summary result of choosing data"""
         TitledPage.__init__(self, wizard, _("Summary"))
         global rlisettings
@@ -1044,8 +1572,8 @@
         self.regiontxt.SetLabel(self.parent.startpage.region)
         self.vecttxt.SetLabel(self.parent.startpage.vect)
         if self.parent.startpage.region == 'key':
-            #region keybord values
-            self.regionkeylabel.SetLabel(_('Region keybord values:'))
+            #region keyboard values
+            self.regionkeylabel.SetLabel(_('Region keyboard values:'))
             regKeyVals = "Column left up: %s - Row left up: %s\n" \
                          "Column length: %s - Row length: %s\n" % (
                          self.parent.keyboardpage.col_up,
@@ -1057,7 +1585,8 @@
             self.regionkeylabel.SetLabel("")
             self.regionkeytxt.SetLabel("")
-        if self.parent.samplingareapage.samplingtype == 'units':
+        if self.parent.samplingareapage.samplingtype == SamplingType.UNITS \
+        and self.parent.samplingareapage.regionbox=='keyboard':
             self.shapelabel.SetLabel(_('Type of shape:'))
             self.shapetxt.SetLabel(self.parent.units.boxtype)
             if self.parent.units.boxtype == 'circle':
@@ -1081,6 +1610,11 @@
                 self.unitsmoretxt.SetLabel(self.parent.units.distr1)
                 self.unitsmorelabel2.SetLabel(_("Number column strates:"))
                 self.unitsmoretxt2.SetLabel(self.parent.units.distr2)
+        elif self.parent.samplingareapage.samplingtype == SamplingType.UNITS \
+        and self.parent.samplingareapage.regionbox == 'mouse':
+            self.shapelabel.SetLabel(_('Type of shape:'))
+            self.shapetxt.SetLabel(self.parent.units.boxtype)
+            self.unitstxt.SetLabel('by mouse')
         elif self.parent.samplingareapage.samplingtype == 'moving':
             self.shapetxt.SetLabel(self.parent.moving.boxtype)
