[GRASS-SVN] r59204 - in grass/trunk/gui/wxpython: gui_core iscatt lmgr mapwin
svn_grass at osgeo.org
Thu Mar 6 04:59:49 PST 2014
Author: turek
Date: 2014-03-06 04:59:49 -0800 (Thu, 06 Mar 2014)
New Revision: 59204
grass/trunk/gui/wxpython/gui_core/gselect.py
grass/trunk/gui/wxpython/iscatt/controllers.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/mapwin/buffered.py
merge more update map requests into one according to delay limit
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2014-03-06 04:31:21 UTC (rev 59203)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2014-03-06 12:59:49 UTC (rev 59204)
@@ -2144,7 +2144,7 @@
btnId=self.buttonInsCoords.GetId(),
toggleHandler=self.buttonInsCoords.SetValue)
self._doLayout()
- self.coordsField.Bind(wx.EVT_TEXT, lambda event : self._draw())
+ self.coordsField.Bind(wx.EVT_TEXT, lambda event : self._draw(delay=1))
def _doLayout(self):
self.dialogSizer = wx.BoxSizer(wx.HORIZONTAL)
@@ -2174,12 +2174,11 @@
self.registered = False
return
def drawCleanUp(self):
if self.drawMapWin:
self.drawMapWin.UnregisterGraphicsToDraw(self.pointsToDraw)
- def _draw(self):
+ def _draw(self, delay):
"""!Draws points representing inserted coordinates in mapwindow."""
if self.drawMapWin != self.mapWin:
self.drawCleanUp()
@@ -2198,7 +2197,7 @@
i = i * 2
self.pointsToDraw.AddItem(coords=(coords[i], coords[i + 1]))
- self._giface.updateMap.emit(render=False, renderVector=False)
+ self._giface.updateMap.emit(render=False, renderVector=False, delay=delay)
def _getCoords(self):
"""!Get list of coordinates.
@@ -2226,7 +2225,7 @@
value = prevCoords + str(e) + "," + str(n)
self.coordsField.SetValue(value)
- self._draw()
+ self._draw(delay=0)
def OnClose(self):
"""!Unregistrates _onMapClickHandler from mapWin"""
Modified: grass/trunk/gui/wxpython/iscatt/controllers.py
--- grass/trunk/gui/wxpython/iscatt/controllers.py 2014-03-06 04:31:21 UTC (rev 59203)
+++ grass/trunk/gui/wxpython/iscatt/controllers.py 2014-03-06 12:59:49 UTC (rev 59204)
@@ -1111,6 +1111,8 @@
bands = res.split('\n')
self.scatt_mgr.SetBands(bands)
+#TODO uses it also BufferedMapWindow class -> move to core?
class gThread(threading.Thread, wx.EvtHandler):
"""!Thread for scatter plot backend"""
requestId = 0
@@ -1140,7 +1142,10 @@
"""!Run command in queue
@param args unnamed command arguments
- @param kwds named command arguments
+ @param kwds named command arguments,
+ keyword 'callable' represents function to be run,
+ keyword 'ondone' represents function to be
+ called after the callable is done
@return request id in queue
@@ -1171,7 +1176,7 @@
ret = None
exception = None
- time.sleep(.1)
+ time.sleep(.01)
if self.terminate:
return
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2014-03-06 04:31:21 UTC (rev 59203)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2014-03-06 12:59:49 UTC (rev 59204)
@@ -1748,9 +1748,12 @@
lcmd = cmd,
lgroup = None)
- def _updateCurrentMap(self):
+ def _updateCurrentMap(self, **kwargs):
"""!Updates map of the current map window."""
- self.GetMapDisplay().GetWindow().UpdateMap()
+ if kwargs.has_key('delay'):
+ self.GetMapDisplay().GetWindow().UpdateMap(delay=kwargs['delay'])
+ else:
+ self.GetMapDisplay().GetWindow().UpdateMap()
def OnMapCreated(self, name, ltype, add=None):
"""!Decides wheter the map should be added to layer tree."""
Modified: grass/trunk/gui/wxpython/mapwin/buffered.py
--- grass/trunk/gui/wxpython/mapwin/buffered.py 2014-03-06 04:31:21 UTC (rev 59203)
+++ grass/trunk/gui/wxpython/mapwin/buffered.py 2014-03-06 12:59:49 UTC (rev 59204)
@@ -33,6 +33,7 @@
import grass.script as grass
from gui_core.dialogs import SavedRegion
from core.gcmd import RunCommand, GException, GError, GMessage
from core.debug import Debug
@@ -41,6 +42,7 @@
from core.utils import GetGEventAttribsForHandler, _
import core.utils as utils
from mapwin.graphics import GraphicsSet
+from iscatt.controllers import gThread
try:
import grass.lib.gis as gislib
@@ -90,6 +92,20 @@
# ID of poly line resulting from cumulative rubber band lines (e.g. measurement)
self.plineid = None
+ # following class members deals with merging more updateMap request
+ # into one UpdateMap process
+ # thread where timer for measuring delay limit
+ self.renderTimingThr = gThread();
+ # relevant timer id given by the thread
+ self.timerRunId = None
+ # time, of last updateMap request
+ self.lastUpdateMapReq = None
+ # defines time limit for waiting for another update request
+ self.updDelay = 0
+ # holds information about level of rendering during the delay limit
+ self.render = self.renderVector = False
# Emitted when zoom of a window is changed
self.zoomChanged = Signal('BufferedWindow.zoomChanged')
@@ -169,7 +185,7 @@
# list for registration of graphics to draw
self.graphicsSetList = []
def _definePseudoDC(self):
"""!Define PseudoDC objects to use
@@ -661,25 +677,84 @@
def IsAlwaysRenderEnabled(self):
return self.alwaysRender
- def UpdateMap(self, render = True, renderVector = True):
+ def UpdateMap(self, render=True, renderVector=True, delay=0.0):
"""!Updates the canvas anytime there is a change to the
underlaying images or to the geometry of the canvas.
This method should not be called directly.
- @todo change direct calling of UpdateMap method to emittig grass
+ @todo change direct calling of UpdateMap method to emitting grass
interface updateMap signal
+ @todo consider using strong/weak signal instead of delay limit in giface
@param render re-render map composition
@param renderVector re-render vector map layer enabled for editing (used for digitizer)
+ @param delay defines time threshold in seconds for postponing rendering to merge more update requests.
+ If another request do come within the limit, rendering is delayed again.
+ Next delay limit is chosen according to the lowest delay value of all requests
+ which have come during waiting period.
+ Arguments 'render' and 'renderVector' have priority for True. It means that
+ if more UpdateMap requests come within waiting period and at least one request
+ has argument set for True, map will be updated with the True value of the argument.
+ if self.timerRunId is None or delay < self.updDelay:
+ self.updDelay = delay
+ if render:
+ self.render = render
+ if renderVector:
+ self.renderVector = renderVector
+ updTime = time.time()
+ self.lastUpdateMapReq = updTime
+ if self.updDelay == 0.0:
+ self._runUpdateMap()
+ else:
+ self.timerRunId = self.renderTimingThr.GetId()
+ self.renderTimingThr.Run(callable=self._timingFunction,
+ ondone=self._onUpdateMap,
+ pid=self.timerRunId)
+ def _timingFunction(self, pid):
+ """!Timer measuring elapsed time, since last update request.
+ It terminates, when delay limit is exceeded.
+ @param pid - id which defines whether it is newest timer, or there is another one
+ (representing newer Update map request).
+ If it is not the newest, it is terminated.
+ while True:
+ time.sleep(.01)
+ if updTime > self.lastUpdateMapReq + self.updDelay or pid != self.timerRunId:
+ return
+ def _onUpdateMap(self, event):
+ if self.timerRunId == event.pid:
+ def _runUpdateMap(self):
+ """!Update map when delay limit is over."""
+ self._updateM(self.render, self.renderVector)
+ def _updateM(self, render=True, renderVector=True):
+ @see method UpdateMap for arguments description.
+ self.resize = False
start = time.clock()
- self.resize = False
# was if self.Map.cmdfile and ...
if self.IsAlwaysRenderEnabled() and self.img is None:
render = True
# render background image if needed
@@ -1160,7 +1235,7 @@
self.Zoom(begin, end, zoomtype)
# redraw map
- self.UpdateMap()
+ self.UpdateMap(delay=0.2)
self.Refresh()
self.processMouse = True
