[GRASS-SVN] r59283 - grass/trunk/lib/vector/Vlib
    svn_grass at osgeo.org
    Tue Mar 18 09:54:23 PDT 2014
Author: turek
Date: 2014-03-18 09:54:22 -0700 (Tue, 18 Mar 2014)
New Revision: 59283
   grass/trunk/lib/vector/Vlib/level_two.c
Vect_get_line_nodes: extended dox params description
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c	2014-03-18 16:10:45 UTC (rev 59282)
+++ grass/trunk/lib/vector/Vlib/level_two.c	2014-03-18 16:54:22 UTC (rev 59283)
@@ -300,7 +300,7 @@
    \param Map pointer to Map_info struct
    \param line line id
-   \param n1, n2 ids of line nodes (or NULL)
+   \param n1 (start node), n2 (end node) ids of line nodes (or NULL)
    \return 1
