[GRASS-SVN] r59295 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun Mar 23 07:18:01 PDT 2014
Author: martinl
Date: 2014-03-23 07:18:00 -0700 (Sun, 23 Mar 2014)
New Revision: 59295
grass/trunk/lib/vector/Vlib/open_pg.c
vlib/pg: fix drop_table() when no PostGIS Topology is available
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c 2014-03-23 12:05:33 UTC (rev 59294)
+++ grass/trunk/lib/vector/Vlib/open_pg.c 2014-03-23 14:18:00 UTC (rev 59295)
@@ -98,13 +98,6 @@
if (!pg_info->conn)
connect_db(pg_info);
- /* get DB name */
- pg_info->db_name = G_store(PQdb(pg_info->conn));
- if (!pg_info->db_name) {
- G_warning(_("Unable to get database name"));
- return -1;
/* get fid and geometry column */
sprintf(stmt, "SELECT f_geometry_column, coord_dimension, srid, type "
"FROM geometry_columns WHERE f_table_schema = '%s' AND "
@@ -248,16 +241,9 @@
G_debug(1, "V1_open_new_pg(): conninfo='%s' table='%s'",
pg_info->conninfo, pg_info->table_name);
- /* connect database */
+ /* connect database & get DB name */
- /* get DB name */
- return -1;
/* if schema not defined, use 'public' */
if (!pg_info->schema_name)
pg_info->schema_name = G_store("public");
@@ -462,34 +448,38 @@
PGresult *result, *result_drop;
- /* drop topology schema(s) related to the feature table */
- sprintf(stmt, "SELECT t.name FROM topology.layer AS l JOIN "
- "topology.topology AS t ON l.topology_id = t.id "
- "WHERE l.table_name = '%s'", pg_info->table_name);
- G_debug(2, "SQL: %s", stmt);
- result = PQexec(pg_info->conn, stmt);
- if (!result || PQresultStatus(result) != PGRES_TUPLES_OK) {
- G_warning(_("Execution failed: %s"), PQerrorMessage(pg_info->conn));
- PQclear(result);
- return -1;
- for (i = 0; i < PQntuples(result); i++) {
- topo_schema = PQgetvalue(result, i, 0);
- sprintf(stmt, "SELECT topology.DropTopology('%s')",
- topo_schema);
+ /* check if topology schema exists */
+ sprintf(stmt, "SELECT COUNT(*) FROM pg_tables WHERE schemaname = 'topology'");
+ if (Vect__execute_get_value_pg(pg_info->conn, stmt) != 0) {
+ /* drop topology schema(s) related to the feature table */
+ sprintf(stmt, "SELECT t.name FROM topology.layer AS l JOIN "
+ "topology.topology AS t ON l.topology_id = t.id "
+ "WHERE l.table_name = '%s'", pg_info->table_name);
- result_drop = PQexec(pg_info->conn, stmt);
- if (!result_drop || PQresultStatus(result_drop) != PGRES_TUPLES_OK)
+ result = PQexec(pg_info->conn, stmt);
+ if (!result || PQresultStatus(result) != PGRES_TUPLES_OK) {
- G_verbose_message(_("PostGIS topology schema <%s> dropped"),
- topo_schema);
- PQclear(result_drop);
+ PQclear(result);
+ return -1;
+ for (i = 0; i < PQntuples(result); i++) {
+ topo_schema = PQgetvalue(result, i, 0);
+ sprintf(stmt, "SELECT topology.DropTopology('%s')",
+ topo_schema);
+ G_debug(2, "SQL: %s", stmt);
+ result_drop = PQexec(pg_info->conn, stmt);
+ if (!result_drop || PQresultStatus(result_drop) != PGRES_TUPLES_OK)
+ G_warning(_("Execution failed: %s"), PQerrorMessage(pg_info->conn));
+ G_verbose_message(_("PostGIS topology schema <%s> dropped"),
+ topo_schema);
+ PQclear(result_drop);
+ PQclear(result);
- PQclear(result);
/* drop feature table */
sprintf(stmt, "DROP TABLE \"%s\".\"%s\"",
pg_info->schema_name, pg_info->table_name);
@@ -520,10 +510,16 @@
_("Connection to PostgreSQL database failed."),
+ /* get DB name */
+ pg_info->db_name = G_store(PQdb(pg_info->conn));
+ if (!pg_info->db_name)
+ G_warning(_("Unable to get database name"));
sprintf(stmt, "SELECT COUNT(*) FROM pg_tables WHERE tablename = 'spatial_ref_sys'");
if (Vect__execute_get_value_pg(pg_info->conn, stmt) != 1) {
PQfinish(pg_info->conn);
- G_fatal_error(_("Spatial-enabled PostGIS database is required"));
+ G_fatal_error(_("<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."),
+ pg_info->db_name ? pg_info->db_name : pg_info->conninfo);
if (pg_info->toposchema_name) {
@@ -531,7 +527,8 @@
if (Vect__execute_get_value_pg(pg_info->conn, stmt) == 0) {
- G_fatal_error(_("PostGIS Topology extension not found in the database"));
+ G_fatal_error(_("PostGIS Topology extension not found in the database <%s>"),
+ pg_info->db_name);
