[GRASS-SVN] r59310 - grass-addons/grass7/vector/v.in.geopaparazzi
svn_grass at osgeo.org
Mon Mar 24 09:02:22 PDT 2014
Author: lucadelu
Date: 2014-03-24 09:02:22 -0700 (Mon, 24 Mar 2014)
New Revision: 59310
grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.html
grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.py
v.in.geopaparazzi: cleanup PEP8, fix problems discovered by Hayashi-san and Venka-san, update documentation
Modified: grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.html
--- grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.html 2014-03-24 15:33:48 UTC (rev 59309)
+++ grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.html 2014-03-24 16:02:22 UTC (rev 59310)
@@ -2,9 +2,23 @@
<em>v.in.geopaparazzi</em> imports all elements saved into Geopaparazzi. You can import bookmarks, images (warning the path to images it's relative of Android device), notes (one layer for each category) and tracks.
+<h2>EXAMPLES</h2>
+To import all the elements in the Geopaparazzi database you have to use:
+<div class="code"><pre>
+v.in.geopaparazzi -bint database=/path/to/your/geopaparazzi.db base=mydata
+</pre></div>
+To import only the tracks in 3D format
+v.in.geopaparazzi -tz database=/path/to/your/geopaparazzi.db base=track3d
+</pre></div>
<h2>REFERENCES</h2>
-<a href="http://code.google.com/p/geopaparazzi/">Geopaparazzi</a>
+<a href="http://geopaparazzi.github.io/geopaparazzi/">Geopaparazzi</a>
<p>
<a href="http://code.google.com/p/geopaparazzi/wiki/DbTables">Geopaparazzi Tables schema</a>
Modified: grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.py
--- grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.py 2014-03-24 15:33:48 UTC (rev 59309)
+++ grass-addons/grass7/vector/v.in.geopaparazzi/v.in.geopaparazzi.py 2014-03-24 16:02:22 UTC (rev 59310)
@@ -18,7 +18,7 @@
#% keywords: vector
#%end
#%flag
-#% key: b
+#% key: b
#% description: Import bookmarks
#%end
#%flag
@@ -49,16 +49,16 @@
#% required : yes
#%end
-import sys, os
+import sys
+import os
import shutil
from grass.script import core as grass
from grass.script import db as grassdb
+from types import DictType, ListType
import json
-import pdb
-def returnClear(c,query):
+def returnClear(c, query):
"""Funtion to return a list of value from a query"""
c.execute(query)
bad = c.fetchall()
@@ -67,20 +67,41 @@
good.append(b[0])
return good
-def returnAll(c,query):
+def returnAll(c, query):
"""Function to return all the values from a query"""
c.execute(query)
return c.fetchall()
-def checkEle(c,table):
+def checkEle(c, table):
"""Function to return the number of elements in a table"""
c.execute("select count(_id) from %s" % table)
return c.fetchone()[0]
+def checkForm(jsonn):
+ """Function to check the forms"""
+ try:
+ form = jsonn['form']
+ except:
+ try:
+ form = jsonn['forms']
+ except:
+ grass.fatal(_("Error importing notes"))
+ if type(form) == DictType:
+ values = form['formitems']
+ elif type(form) == ListType and len(form) == 1:
+ values = form[0]['formitems']
+ elif type(form) == ListType and len(form) > 1:
+ grass.warning(_("Form contains more fields and it is no yet supported"))
+ return values
def returnFormKeys(attr):
"""Function to return a string with the columns' name and type of form"""
- js=json.loads(attr[0][3])
- values=js['form']['formitems']
+ js = json.loads(attr[0][3])
+ values = checkForm(js)
res = ''
for v in values:
if v['type'].lower() == 'double':
@@ -94,14 +115,16 @@
res += ", %s %s" % (v['key'].replace(' ', '_'), typ)
return res
def returnFormValues(attr):
"""Function to return a string with the values of form"""
- js=json.loads(attr)
+ js = json.loads(attr)
return','.join("'%s'" % v['value'] for v in values)
-def importGeom(vname, typ, c, owrite, z, cat = None):
- psel = "SELECT lat, lon"
+def importGeom(vname, typ, c, owrite, z, cat=None):
+ psel = "SELECT lon, lat"
if z == 'z':
psel += ", altim"
zcol = 3
@@ -113,12 +136,13 @@
points = returnAll(c, psel)
wpoi = '\n'.join(['|'.join([str(col) for col in row]) for row in points])
# import points using v.in.ascii
- if grass.write_command('v.in.ascii', flags = 't%s' % z, input='-',
- output = vname, stdin = wpoi, z = zcol,
- overwrite = owrite, quiet = True) != 0:
- grass.fatal(_("Error importing %s" % vname))
- return points
+ if grass.write_command('v.in.ascii', flags='t%s' % z, input='-', z=zcol,
+ output=vname, stdin=wpoi, overwrite=owrite,
+ quiet=True) != 0:
+ grass.fatal(_("Error importing %s" % vname))
+ return points
def main():
indb = options['database']
prefix = options['basename']
@@ -142,40 +166,41 @@
if not locn:
# create new location and move to it creating new gisrc file
new_loc = grass.basename(grass.tempfile(create=False))
- grass.create_location(dbase = env['GISDBASE'],
- location = 'geopaparazzi_%s' % new_loc,
- epsg = '4326',
- desc = 'Temporary location for v.in.geopaparazzi')
+ new_loc_name = 'geopaparazzi_%s' % new_loc
+ grass.create_location(dbase=env['GISDBASE'], epsg='4326',
+ location=new_loc_name,
+ desc='Temporary location for v.in.geopaparazzi')
grc = os.getenv('GISRC')
- shutil.copyfile(grc,grc+'.old')
- newrc = open(grc,'w')
+ shutil.copyfile(grc, grc + '.old')
+ newrc = open(grc, 'w')
newrc.write('GISDBASE: %s\n' % env['GISDBASE'])
- newrc.write('LOCATION_NAME: geopaparazzi_%s\n' % new_loc)
+ newrc.write('LOCATION_NAME: %s\n' % new_loc_name)
newrc.write('MAPSET: PERMANENT\n')
newrc.write('GRASS_GUI: text\n')
newrc.close()
+ grass.run_command('db.connect', flags="d", quiet=True)
# load bookmarks
if flags['b']:
# check if elements in bookmarks table are more the 0
if checkEle(curs, 'bookmarks') != 0:
- bookname = prefix + '_book'
+ bookname = prefix + '_book'
pois = importGeom(bookname, 'bookmarks', curs, owrite, '')
sql = 'CREATE TABLE %s (cat int, text text)' % bookname
- grass.write_command('db.execute', input='-', stdin = sql)
+ grass.write_command('db.execute', input='-', stdin=sql)
# select attributes
sql = "select text from bookmarks order by _id"
- allattri = returnClear(curs,sql)
+ allattri = returnClear(curs, sql)
# add values using insert statement
idcat = 1
for row in allattri:
- values = "%d,'%s'" % (idcat,str(row))
+ values = "%d,'%s'" % (idcat, str(row))
sql = "insert into %s values(%s)" % (bookname, values)
idcat += 1
# at the end connect table to vector
- grass.run_command('v.db.connect', map = bookname,
- table = bookname, quiet = True)
+ grass.run_command('v.db.connect', map=bookname,
+ table=bookname, quiet=True)
else:
grass.warning(_("No bookmarks found, escape them"))
# load images
@@ -186,21 +211,22 @@
pois = importGeom(imagename, 'images', curs, owrite, d3)
sql = 'CREATE TABLE %s (cat int, azim int, ' % imagename
sql += 'path text, ts text, text text)'
# select attributes
sql = "select azim, path, ts, text from images order by _id"
- allattri = returnAll(curs,sql)
+ allattri = returnAll(curs, sql)
idcat = 1
- values = "%d,'%d','%s','%s','%s'" % (idcat,row[0],
- str(row[1]), str(row[2]), str(row[3]))
+ values = "%d,'%d','%s','%s','%s'" % (idcat, row[0],
+ str(row[1]), str(row[2]),
+ str(row[3]))
sql = "insert into %s values(%s)" % (imagename, values)
idcat += 1
- grass.run_command('v.db.connect', map = imagename,
- table = imagename, quiet = True)
+ grass.run_command('v.db.connect', map=imagename, table=imagename,
+ quiet=True)
else:
grass.warning(_("No images found, escape them"))
# if tracks or nodes should be imported create a connection with sqlite3
@@ -209,66 +235,68 @@
# check if elements in notes table are more the 0
if checkEle(curs, 'notes') != 0:
# select each categories
- categories = returnClear(curs,"select cat from notes group by cat")
- # for each category
+ categories = returnClear(curs, "select cat from notes group by cat")
+ # for each category
for cat in categories:
- # select lat, lon for create point layer
- catname = prefix + '_notes_' + cat
- pois = importGeom(catname, 'notes', curs, owrite, d3, cat )
- # select form to understand the number
- forms = returnClear(curs,"select _id from notes where cat = '%s' " \
- "and form is not null order by _id" % cat)
+ # select lat, lon for create point layer
+ catname = prefix + '_notes_' + cat
+ pois = importGeom(catname, 'notes', curs, owrite, d3, cat)
+ # select form to understand the number
+ forms = returnClear(curs, "select _id from notes where cat = '%s' " \
+ "and form is not null order by _id" % cat)
# if number of form is different from 0 and number of point
# remove the vector because some form it is different
if len(forms) != 0 and len(forms) != len(pois):
- grass.run_command('g.remove', vect = catname, quiet = True)
- grass.warning(_("Vector %s not imported because number of " \
- "points and form is different"))
+ grass.run_command('g.remove', vect=catname, quiet=True)
+ grass.warning(_("Vector %s not imported because number" \
+ " of points and form is different"))
# if form it's 0 there is no form
elif len(forms) == 0:
# create table without form
sql = 'CREATE TABLE %s (cat int, ts text, ' % catname
sql += 'text text, geopap_cat text)'
# select attributes
sql = "select ts, text, cat from notes where "\
"cat='%s' order by _id" % cat
idcat = 1
- values = "%d,'%s','%s','%s'" % (idcat,str(row[0]),
- str(row[1]), str(row[2]))
+ values = "%d,'%s','%s','%s'" % (idcat, str(row[0]),
+ str(row[1]),
+ str(row[2]))
sql = "insert into %s values(%s)" % (catname, values)
idcat += 1
- grass.run_command('v.db.connect', map = catname,
- table = catname, quiet = True)
+ grass.run_command('v.db.connect', map=catname,
+ table=catname, quiet=True)
# create table with form
else:
# select all the attribute
sql = "select ts, text, cat, form from notes where "\
- "cat='%s' order by _id" % cat
+ "cat='%s' order by _id" % cat
# return string of form's categories too create table
keys = returnFormKeys(allattri)
sql += 'text text, geopap_cat text %s)' % keys
# it's for the number of categories
idcat = 1
- # for each feature insert value
+ # for each feature insert value
- values = "%d,'%s','%s','%s'," % (idcat,str(row[0]),
+ values = "%d,'%s','%s','%s'," % (idcat, str(row[0]),
+ str(row[1]),
+ str(row[2]))
values += returnFormValues(row[3])
idcat += 1
# at the end connect table with vector
else:
grass.warning(_("No notes found, escape them"))
# load tracks
@@ -279,7 +307,7 @@
# define string for insert data at the end
tracks = ''
# return ids of tracks
- ids = returnClear(curs,"select _id from gpslogs")
+ ids = returnClear(curs, "select _id from gpslogs")
# for each track
for i in ids:
# select all the points coordinates
@@ -287,7 +315,7 @@
if flags['z']:
tsel += ", altim"
tsel += " from gpslog_data where logid=%s order by _id" % i
- trackpoints = returnAll(curs,tsel)
+ trackpoints = returnAll(curs, tsel)
wpoi = '\n'.join(['|'.join([str(col) for col in row]) for row in trackpoints])
tracks += "%s\n" % wpoi
if flags['z']:
@@ -295,55 +323,58 @@
else:
tracks += 'NaN|Nan\n'
# import lines
- if grass.write_command('v.in.lines', flags = d3, input = '-',
- out = tracksname, stdin = tracks,
+ if grass.write_command('v.in.lines', flags=d3, input='-',
+ out=tracksname, stdin=tracks,
+ overwrite=owrite, quiet=True) != 0:
grass.fatal(_("Error importing %s" % tracksname))
# create table for line
- sql = 'CREATE TABLE %s (cat int, startts text, endts text, ' % tracksname
- sql += ' text text, color text, width int)'
- sql = "select logid, startts, endts, text, color, width from gpslogs, "\
- "gpslogsproperties where gpslogs._id=gpslogsproperties.logid"
+ sql='CREATE TABLE %s (cat int, startts text, ' % tracksname
+ sql += 'endts text, text text, color text, width int)'
+ sql = "select logid, startts, endts, text, color, width from" \
+ " gpslogs, gpslogsproperties where gpslogs._id=" \
+ "gpslogsproperties.logid"
# return attributes
# for each line insert attribute
- values = "%d,'%s','%s','%s','%s',%d" % (row[0],str(row[1]),
- str(row[2]), str(row[3]), str(row[4]), row[5])
+ values = "%d,'%s','%s','%s','%s',%d" % (row[0], str(row[1]),
+ str(row[2]),
+ str(row[3]),
+ str(row[4]), row[5])
sql = "insert into %s values(%s)" % (tracksname, values)
# at the end connect map with table
- grass.run_command('v.db.connect', map = tracksname,
- table = tracksname, quiet = True)
+ grass.run_command('v.db.connect', map=tracksname,
+ table=tracksname, quiet=True)
else:
grass.warning(_("No tracks found, escape them"))
# if location it's not latlong reproject it
if not locn:
# copy restore the original location
- shutil.copyfile(grc+'.old',grc)
+ shutil.copyfile(grc + '.old', grc)
# reproject bookmarks
if flags['b'] and checkEle(curs, 'bookmarks') != 0:
- grass.run_command('v.proj', quiet = True, input = bookname,
- mapset = 'PERMANENT')
+ grass.run_command('v.proj', quiet=True, input=bookname,
+ location='geopaparazzi_%s' % new_loc,
+ mapset='PERMANENT')
# reproject images
if flags['i'] and checkEle(curs, 'images') != 0:
- grass.run_command('v.proj', quiet = True, input = imagename,
+ grass.run_command('v.proj', quiet=True, input=imagename,
# reproject notes
if flags['n'] and checkEle(curs, 'notes') != 0:
catname = prefix + '_node_' + cat
- grass.run_command('v.proj', quiet = True, input = catname,
+ grass.run_command('v.proj', quiet=True, input=catname,
# reproject track
if flags['t'] and checkEle(curs, 'gpslogs') != 0:
- grass.run_command('v.proj', quiet = True, input = tracksname,
+ grass.run_command('v.proj', quiet=True, input=tracksname,
if __name__ == "__main__":
options, flags = grass.parser()
