[GRASS-SVN] r59312 - in grass/trunk/gui/wxpython: mapdisp mapwin nviz
svn_grass at osgeo.org
Mon Mar 24 10:42:50 PDT 2014
Author: turek
Date: 2014-03-24 10:42:50 -0700 (Mon, 24 Mar 2014)
New Revision: 59312
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapwin/base.py
grass/trunk/gui/wxpython/mapwin/buffered.py
grass/trunk/gui/wxpython/nviz/mapwindow.py
wxgui:fix wms in vdigit
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2014-03-24 16:28:00 UTC (rev 59311)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2014-03-24 17:42:50 UTC (rev 59312)
@@ -292,7 +292,7 @@
CloseButton(False).DestroyOnClose(True).
Layer(0))
- self.MapWindow = self.MapWindowVDigit
+ self._switchMapWindow(self.MapWindowVDigit)
if self._mgr.GetPane('2d').IsShown():
self._mgr.GetPane('2d').Hide()
@@ -362,7 +362,7 @@
Map = self.Map, tree = self.tree, lmgr = self._layerManager)
self._setUpMapWindow(self.MapWindow3D)
self.MapWindow3D.mapQueried.connect(self.Query)
- self.MapWindow = self.MapWindow3D
+ self._switchMapWindow(self.MapWindow3D)
self.MapWindow.SetNamedCursor('default')
# here was AddNvizTools in lmgr
@@ -382,7 +382,7 @@
self.MapWindow3D.overlayHidden.connect(self._hideOverlay)
self.legend.overlayChanged.connect(self.MapWindow3D.UpdateOverlays)
else:
os.environ['GRASS_REGION'] = self.Map.SetRegion(windres = True, windres3 = True)
self.MapWindow3D.GetDisplay().Init()
del os.environ['GRASS_REGION']
@@ -436,7 +436,7 @@
self._mgr.GetPane('2d').Show()
self._mgr.GetPane('3d').Hide()
- self.MapWindow = self.MapWindow2D
+ self._switchMapWindow(self.MapWindow2D)
# here was RemoveNvizTools form lmgr
self.ending3dMode.emit()
try:
@@ -503,7 +503,7 @@
if name == 'vdigit':
self._mgr.GetPane('vdigit').Hide()
self.toolbars['map'].combo.SetValue(_("2D view"))
self.toolbars['map'].Enable2D(True)
@@ -1334,3 +1334,10 @@
handler).
self.GetMapToolbar().SelectDefault()
+ def _switchMapWindow(self, map_win):
+ """!Notifies activated and disactivated map_wins."""
+ self.MapWindow.DisactivateWin()
+ map_win.ActivateWin()
+ self.MapWindow = map_win
Modified: grass/trunk/gui/wxpython/mapwin/base.py
--- grass/trunk/gui/wxpython/mapwin/base.py 2014-03-24 16:28:00 UTC (rev 59311)
+++ grass/trunk/gui/wxpython/mapwin/base.py 2014-03-24 17:42:50 UTC (rev 59312)
@@ -383,3 +383,11 @@
self.zoomtype = zoomType
self.pen = wx.Pen(colour='Red', width=2, style=wx.SHORT_DASH)
self.SetNamedCursor('cross')
+ def DisactivateWin(self):
+ """!Use when the class instance is hidden in MapFrame."""
+ raise NotImplementedError()
+ def ActivateWin(self):
+ """!Used when the class instance is activated in MapFrame."""
Modified: grass/trunk/gui/wxpython/mapwin/buffered.py
--- grass/trunk/gui/wxpython/mapwin/buffered.py 2014-03-24 16:28:00 UTC (rev 59311)
+++ grass/trunk/gui/wxpython/mapwin/buffered.py 2014-03-24 17:42:50 UTC (rev 59312)
@@ -175,8 +175,9 @@
self._buffer = wx.EmptyBitmap(max(1, self.Map.width), max(1, self.Map.height))
self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
# rerender when Map reports change
- self.Map.layerChanged.connect(lambda: self.UpdateMap())
+ self.Map.layerChanged.connect(self.OnUpdateMap)
# vars for handling mouse clicks
self.dragid = -1
@@ -184,7 +185,20 @@
# list for registration of graphics to draw
self.graphicsSetList = []
+ def OnUpdateMap(self):
+ # before lambda func was used, however it was problem
+ # to disconnect it from signal
+ self.UpdateMap()
+ self.Map.layerChanged.disconnect(self.OnUpdateMap)
def _definePseudoDC(self):
"""!Define PseudoDC objects to use
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py 2014-03-24 16:28:00 UTC (rev 59311)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py 2014-03-24 17:42:50 UTC (rev 59312)
@@ -2590,3 +2590,11 @@
@param textinfo text metadata (text, font, color, rotation)
return self.parent.MapWindow2D.TextBounds(textinfo, relcoords = True)
+ pass
+ pass
