[GRASS-SVN] r59316 - grass/trunk/gui/wxpython/web_services
svn_grass at osgeo.org
Mon Mar 24 12:36:41 PDT 2014
Author: turek
Date: 2014-03-24 12:36:37 -0700 (Mon, 24 Mar 2014)
New Revision: 59316
grass/trunk/gui/wxpython/web_services/dialogs.py
grass/trunk/gui/wxpython/web_services/widgets.py
wms fill layer name if it is empty according to selected item
Modified: grass/trunk/gui/wxpython/web_services/dialogs.py
--- grass/trunk/gui/wxpython/web_services/dialogs.py 2014-03-24 18:22:51 UTC (rev 59315)
+++ grass/trunk/gui/wxpython/web_services/dialogs.py 2014-03-24 19:36:37 UTC (rev 59316)
@@ -125,6 +125,7 @@
self.ws_panels[ws]['panel'] = WSPanel(parent = self.reqDataPanel,
web_service = ws)
self.ws_panels[ws]['panel'].capParsed.connect(self.OnPanelCapParsed)
+ self.ws_panels[ws]['panel'].layerSelected.connect(self.OnLayerSelected)
# buttons
self.btn_close = wx.Button(parent = self, id = wx.ID_CLOSE)
@@ -145,6 +146,11 @@
self.settsManager.settingsLoaded.connect(self.OnSettingsLoaded)
self.settsManager.settingsSaving.connect(self.OnSettingsSaving)
+ def OnLayerSelected(self, title):
+ if not self.layerName.GetValue().strip():
+ self.layerName.SetValue(title)
def _doLayout(self):
dialogSizer = wx.BoxSizer(wx.VERTICAL)
@@ -331,6 +337,7 @@
"""!Update layer name to web service panel
lname = event.GetString()
+ lname = lname.encode('ascii', 'replace')
for v in self.ws_panels.itervalues():
v['panel'].SetOutputLayerName(lname.strip())
@@ -541,7 +548,8 @@
shutil.copyfile(cap_file, cmd_cap_file)
lcmd.append('capfile=' + cmd_cap_file)
- layer = ltree.AddLayer(ltype = 'wms', lname = self.layerName.GetValue(),
+ layer = ltree.AddLayer(ltype = 'wms',
+ lname = self.active_ws_panel.GetOutputLayerName(),
lchecked = True, lcmd = lcmd)
Modified: grass/trunk/gui/wxpython/web_services/widgets.py
--- grass/trunk/gui/wxpython/web_services/widgets.py 2014-03-24 18:22:51 UTC (rev 59315)
+++ grass/trunk/gui/wxpython/web_services/widgets.py 2014-03-24 19:36:37 UTC (rev 59316)
@@ -125,6 +125,8 @@
self._layout()
+ self.layerSelected = self.list.layerSelected
self.Bind(EVT_CMD_DONE, self.OnCapDownloadDone)
self.Bind(EVT_CMD_OUTPUT, self.OnCmdOutput)
@@ -819,6 +821,9 @@
self.o_layer_name = name
+ def GetOutputLayerName(self):
+ return self.o_layer_name
def GetCapFile(self):
"""!Get path to file where capabilities are saved
@@ -852,6 +857,8 @@
self.root = None
self.Bind(wx.EVT_TREE_SEL_CHANGING, self.OnListSelChanging)
+ self.layerSelected = Signal('LayersList.layerSelected')
def LoadData(self, cap = None):
"""!Load data into list
@@ -950,6 +957,9 @@
def OnListSelChanging(self, event):
"""!Do not allow to select items, which cannot be requested from server.
+ def _emitSelected(layer):
+ title = layer.GetLayerData('title')
+ self.layerSelected.emit(title = title)
def _selectRequestableChildren(item, list_to_check, items_to_sel):
@@ -971,6 +981,8 @@
if not self.HasFlag(wx.TR_MULTIPLE):
return
+ _emitSelected(self.GetPyData(cur_item)['layer'])
items_to_chck = []
items_to_sel = []
chck_item = cur_item
@@ -984,7 +996,9 @@
while items_to_sel:
self.SelectItem(items_to_sel.pop(), unselect_others=False)
+ else:
def GetItemCount(self):
"""!Required for listmix.ListCtrlAutoWidthMixin
