[GRASS-SVN] r59325 - in grass/trunk/gui/wxpython: gui_core web_services
svn_grass at osgeo.org
Tue Mar 25 06:05:39 PDT 2014
Author: turek
Date: 2014-03-25 06:05:29 -0700 (Tue, 25 Mar 2014)
New Revision: 59325
grass/trunk/gui/wxpython/gui_core/widgets.py
grass/trunk/gui/wxpython/web_services/dialogs.py
grass/trunk/gui/wxpython/web_services/widgets.py
wms: add default servers button added
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2014-03-25 11:51:22 UTC (rev 59324)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2014-03-25 13:05:29 UTC (rev 59325)
@@ -1005,27 +1005,27 @@
self._layout()
+ self.SetSizer(self.settingsSizer)
+ self.settingsSizer.Fit(self)
def _layout(self):
- settingsSizer = wx.StaticBoxSizer(self.settingsBox, wx.HORIZONTAL)
- settingsSizer.Add(item = wx.StaticText(parent = self,
+ self.settingsSizer = wx.StaticBoxSizer(self.settingsBox, wx.HORIZONTAL)
+ self.settingsSizer.Add(item = wx.StaticText(parent = self,
id = wx.ID_ANY,
label = _("Load settings:")),
flag = wx.ALIGN_CENTER_VERTICAL | wx.RIGHT,
border = 5)
- settingsSizer.Add(item = self.settingsChoice,
+ self.settingsSizer.Add(item = self.settingsChoice,
proportion = 1,
flag = wx.EXPAND)
- settingsSizer.Add(item = self.btnSettingsSave,
+ self.settingsSizer.Add(item = self.btnSettingsSave,
flag = wx.LEFT | wx.RIGHT,
border = 5)
- settingsSizer.Add(item = self.btnSettingsDel,
+ self.settingsSizer.Add(item = self.btnSettingsDel,
flag = wx.RIGHT,
border = 5)
- self.SetSizer(settingsSizer)
- settingsSizer.Fit(self)
def OnSettingsChanged(self, event):
"""!Load named settings"""
name = event.GetString()
@@ -1037,6 +1037,10 @@
data = self._settings[name]
self.settingsChanged.emit(data=data)
+ def GetSettings(self):
+ """!Load named settings"""
+ return self._settings.copy()
def OnSettingsSave(self, event):
"""!Save settings"""
dlg = wx.TextEntryDialog(parent = self,
@@ -1090,6 +1094,14 @@
self._settings = settings
self._saveSettings()
+ def AddSettings(self, settings):
+ """!Add settings
+ @param settings - dict with all settigs {nameofsetting : settingdata, ....}
+ self._settings = dict(self._settings.items() + settings.items())
+ self._saveSettings()
def OnSettingsDelete(self, event):
"""!Save settings
Modified: grass/trunk/gui/wxpython/web_services/dialogs.py
--- grass/trunk/gui/wxpython/web_services/dialogs.py 2014-03-25 11:51:22 UTC (rev 59324)
+++ grass/trunk/gui/wxpython/web_services/dialogs.py 2014-03-25 13:05:29 UTC (rev 59325)
@@ -35,9 +35,8 @@
from core.gconsole import CmdThread, GStderr, EVT_CMD_DONE, EVT_CMD_OUTPUT
from gui_core.gselect import Select
-from gui_core.widgets import ManageSettingsWidget
-from web_services.widgets import WSPanel
+from web_services.widgets import WSPanel, WSManageSettingsWidget
class WSDialogBase(wx.Dialog):
"""!Base class for web service dialogs.
@@ -82,8 +81,9 @@
settingsFile = os.path.join(GetSettingsPath(), 'wxWS')
- self.settsManager = ManageSettingsWidget(parent=self,
- settingsFile=settingsFile)
+ self.settsManager = WSManageSettingsWidget(parent=self,
+ settingsFile=settingsFile,
+ default_servers=self.default_servers)
self.settingsBox = wx.StaticBox(parent = self,
id = wx.ID_ANY,
@@ -143,7 +143,6 @@
self.layerName.Bind(wx.EVT_TEXT, self.OnOutputLayerName)
self.settsManager.settingsChanged.connect(self.OnSettingsChanged)
- self.settsManager.settingsLoaded.connect(self.OnSettingsLoaded)
self.settsManager.settingsSaving.connect(self.OnSettingsSaving)
def OnLayerSelected(self, title):
@@ -303,12 +302,6 @@
else:
self.adv_conn.Collapse(True)
- def OnSettingsLoaded(self, settings):
- """!If settings are empty set default servers
- if not settings:
- self.settsManager.SetSettings(self.default_servers)
def OnClose(self, event):
"""!Close the dialog
Modified: grass/trunk/gui/wxpython/web_services/widgets.py
--- grass/trunk/gui/wxpython/web_services/widgets.py 2014-03-25 11:51:22 UTC (rev 59324)
+++ grass/trunk/gui/wxpython/web_services/widgets.py 2014-03-25 13:05:29 UTC (rev 59325)
@@ -42,6 +42,7 @@
from web_services.cap_interface import WMSCapabilities, WMTSCapabilities, OnEarthCapabilities
from gui_core.widgets import GNotebook
+from gui_core.widgets import ManageSettingsWidget
import grass.script as grass
@@ -1066,3 +1067,31 @@
l_st_list.remove(l_st)
return l_st_list
+class WSManageSettingsWidget(ManageSettingsWidget):
+ def __init__(self, parent, settingsFile, default_servers):
+ ManageSettingsWidget.__init__(self, parent, settingsFile)
+ self.default_servers = default_servers
+ def _layout(self):
+ self.btnAddDefaultServers = wx.Button(parent=self, id=wx.ID_ANY,
+ label=_("Add default servers"))
+ self.btnAddDefaultServers.Bind(wx.EVT_BUTTON, self.OnAddDefaultServers)
+ ManageSettingsWidget._layout(self)
+ self.settingsSizer.Add(item=self.btnAddDefaultServers,
+ flag=wx.RIGHT,
+ border=5)
+ def OnAddDefaultServers(self, event):
+ setts = self.GetSettings()
+ self.servers_to_add = {}
+ for k, v in self.default_servers.iteritems():
+ if k not in setts.iterkeys():
+ self.servers_to_add[k] = v
+ if self.servers_to_add:
+ self.AddSettings(self.servers_to_add)
