[GRASS-SVN] r59336 - in grass/trunk: db/db.login lib/db/dbmi_base
Tue Mar 25 09:36:48 PDT 2014
Author: martinl
Date: 2014-03-25 09:36:47 -0700 (Tue, 25 Mar 2014)
New Revision: 59336
   grass/trunk/db/db.login/main.c
   grass/trunk/lib/db/dbmi_base/login.c
dbmilib+db.login: use HOST_DIRSEP
Modified: grass/trunk/db/db.login/main.c
--- grass/trunk/db/db.login/main.c	2014-03-25 16:24:14 UTC (rev 59335)
+++ grass/trunk/db/db.login/main.c	2014-03-25 16:36:47 UTC (rev 59336)
@@ -74,7 +74,7 @@
     if (password->answer)
-        G_important_message(_("The password was stored in file (%s/dblogin)"), G_config_path());
+	G_important_message(_("The password was stored in file (%s%cdblogin)"), G_config_path(), HOST_DIRSEP);
     exit(EXIT_SUCCESS);
Modified: grass/trunk/lib/db/dbmi_base/login.c
--- grass/trunk/lib/db/dbmi_base/login.c	2014-03-25 16:24:14 UTC (rev 59335)
+++ grass/trunk/lib/db/dbmi_base/login.c	2014-03-25 16:36:47 UTC (rev 59336)
@@ -43,7 +43,7 @@
     if (!file) {
 	file = (char *)db_malloc(GPATH_MAX);
-	sprintf(file, "%s/dblogin", G_config_path());
+	sprintf(file, "%s%cdblogin", G_config_path(), HOST_DIRSEP);
     return file;
