[GRASS-SVN] r59340 - grass-addons/grass7/raster/r.stream.basins
Tue Mar 25 13:34:39 PDT 2014
Author: hellik
Date: 2014-03-25 13:34:39 -0700 (Tue, 25 Mar 2014)
New Revision: 59340
   grass-addons/grass7/raster/r.stream.basins/r.stream.basins.html
Modified: grass-addons/grass7/raster/r.stream.basins/r.stream.basins.html
--- grass-addons/grass7/raster/r.stream.basins/r.stream.basins.html	2014-03-25 19:23:40 UTC (rev 59339)
+++ grass-addons/grass7/raster/r.stream.basins/r.stream.basins.html	2014-03-25 20:34:39 UTC (rev 59340)
@@ -3,16 +3,16 @@
 <dt><b>-z</b></dt>
 <dd>Creates zero-value background instead of NULL. For some reason (like map
 algebra calculation) zero-valued background may be required. This flag produces
-zero-filled background instead of null (default).</dd>
+zero-filled background instead of NULL (default).</dd>
 <dt><b>-c</b></dt>
 <dd>By default r.stream.basins uses streams category as basin category. In some
-cases - for example if stream map is product of map algebra and separete streams
-may not have unique values this option will create new category sequence for
-each basin (do not work in vector point mode)
+cases - for example if stream map is a product of map algebra and separate streams
+may not have unique values this option will create a new category sequence for
+each basin (do not work in vector point mode).
 </dd>
 <dt><b>-l</b></dt>
 <dd>By default r.stream.basins create basins for all unique streams. This option
-delinate basins only for last streams ignoring upstreams (do not work in vector
+delineate basins only for last streams ignoring upstreams (do not work in vector
 point mode).
 </dd>
