[GRASS-SVN] r59350 - grass/trunk/scripts/i.oif
svn_grass at osgeo.org
Wed Mar 26 03:54:14 PDT 2014
Author: lucadelu
Date: 2014-03-26 03:54:12 -0700 (Wed, 26 Mar 2014)
New Revision: 59350
grass/trunk/scripts/i.oif/i.oif.html
grass/trunk/scripts/i.oif/i.oif.py
i.oif: now it can work with several bands
Modified: grass/trunk/scripts/i.oif/i.oif.html
--- grass/trunk/scripts/i.oif/i.oif.html 2014-03-26 10:29:00 UTC (rev 59349)
+++ grass/trunk/scripts/i.oif/i.oif.html 2014-03-26 10:54:12 UTC (rev 59350)
@@ -17,7 +17,7 @@
<h2>NOTES</h2>
-Landsat TM:
+Landsat 1-7 TM:
Colour Composites in BGR order as important Landsat TM band combinations
(example: 234 in BGR order means: B=2, G=3, R=4):
@@ -55,8 +55,7 @@
North Carolina sample dataset:
<div class="code"><pre>
g.region rast=lsat7_2002_10 -p
-i.oif image1=lsat7_2002_10 image2=lsat7_2002_20 image3=lsat7_2002_30 \
- image4=lsat7_2002_40 image5=lsat7_2002_50 image7=lsat7_2002_70
+i.oif input=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70
</pre></div>
Modified: grass/trunk/scripts/i.oif/i.oif.py
--- grass/trunk/scripts/i.oif/i.oif.py 2014-03-26 10:29:00 UTC (rev 59349)
+++ grass/trunk/scripts/i.oif/i.oif.py 2014-03-26 10:54:12 UTC (rev 59350)
@@ -3,8 +3,11 @@
# MODULE: i.oif
-# AUTHOR(S): Markus Neteler
+# AUTHOR(S): Markus Neteler 21.July 1998
+# Updated for GRASS 5.7 by Michael Barton 2004/04/05
# Converted to Python by Glynn Clements
+# Customised by Nikos Alexandris 04. August 2013
+# Customised by Luca Delucchi Vienna Code Sprint 2014
# PURPOSE: calculates the Optimum Index factor of all band combinations
# for LANDSAT TM 1,2,3,4,5,7
# COPYRIGHT: (C) 1999,2008 by the GRASS Development Team
@@ -13,46 +16,21 @@
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
# Ref.: Jensen: Introductory digital image processing 1996, p.98
-# Input: tm1 - tm5, tm7 (not tm6)
-# written by Markus Neteler 21.July 1998
-# neteler geog.uni-hannover.de
-# updated for GRASS 5.7 by Michael Barton 2004/04/05
#% Module
-#% description: Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7
+#% description: Calculates Optimum-Index-Factor table for spectral bands
#% keywords: imagery
-#% keywords: landsat
+#% keywords: multispectral
#% keywords: statistics
#% End
-#% option G_OPT_R_INPUT
-#% key: image1
-#% description: LANDSAT TM band 1.
+#% option G_OPT_R_INPUTS
#% end
-#% key: image2
-#% description: LANDSAT TM band 2.
+#% option G_OPT_F_OUTPUT
+#% description: Name for output file (if omitted or "-" output to stdout)
+#% required: no
#% end
-#% key: image3
-#% description: LANDSAT TM band 3.
-#% end
-#% key: image4
-#% description: LANDSAT TM band 4.
-#% end
-#% key: image5
-#% description: LANDSAT TM band 5.
-#% end
-#% key: image7
-#% description: LANDSAT TM band 7.
-#% end
#% Flag
#% key: g
#% description: Print in shell script style
@@ -66,106 +44,111 @@
import os
from grass.script import core as grass
-bands = [1,2,3,4,5,7]
def oifcalc(sdev, corr, k1, k2, k3):
+ grass.debug(_("Calculating OIF for combination: %s, %s, %s" % (k1, k2,
+ k3)), 1)
# calculate SUM of Stddeviations:
ssdev = [sdev[k1], sdev[k2], sdev[k3]]
numer = sum(ssdev)
# calculate SUM of absolute(Correlation values):
- scorr = [corr[k1,k2], corr[k1,k3], corr[k2,k3]]
+ scorr = [corr[k1, k2], corr[k1, k3], corr[k2, k3]]
denom = sum(map(abs, scorr))
# Calculate OIF index:
# Divide (SUM of Stddeviations) and (SUM of Correlation)
return numer / denom
-def perms():
- for i in range(0,4):
- for j in range(i+1,5):
- for k in range(j+1,6):
- yield (bands[i], bands[j], bands[k])
+def perms(bands):
+ n = len(bands)
+ for i in range(0, n - 2):
+ for j in range(i + 1, n - 1):
+ for k in range(j + 1, n):
+ yield (bands[i], bands[j], bands[k])
def main():
shell = flags['g']
serial = flags['s']
- image = {}
- for band in bands:
- image[band] = options['image%d' % band]
+ bands = options['input'].split(',')
+ output = options['output']
# calculate the Stddev for TM bands
grass.message(_("Calculating Standard deviations for all bands..."))
stddev = {}
if serial:
for band in bands:
- grass.verbose("band %d" % band)
- s = grass.read_command('r.univar', flags = 'g', map = image[band])
- kv = grass.parse_key_val(s)
- stddev[band] = float(kv['stddev'])
+ grass.verbose("band %d" % band)
+ s = grass.read_command('r.univar', flags='g', map=band)
+ kv = grass.parse_key_val(s)
+ stddev[band] = float(kv['stddev'])
else:
- # run all bands in parallel
- if "WORKERS" in os.environ:
+ # run all bands in parallel
+ if "WORKERS" in os.environ:
workers = int(os.environ["WORKERS"])
- else:
- workers = 6
+ else:
+ workers = len(bands)
+ proc = {}
+ pout = {}
- proc = {}
- pout = {}
+ # spawn jobs in the background
+ n = 0
+ for band in bands:
+ proc[band] = grass.pipe_command('r.univar', flags='g', map=band)
+ if n % workers is 0:
+ # wait for the ones launched so far to finish
+ for bandp in bands[:n]:
+ if not proc[bandp].stdout.closed:
+ pout[bandp] = proc[bandp].communicate()[0]
+ proc[bandp].wait()
+ n = n + 1
- # spawn jobs in the background
- grass.debug("band %d, <%s> %% %d" % (band, image[band], band % workers))
- proc[band] = grass.pipe_command('r.univar', flags = 'g', map = image[band])
- if band % workers is 0:
- # wait for the ones launched so far to finish
- for bandp in bands[:band]:
- if not proc[bandp].stdout.closed:
- pout[bandp] = proc[bandp].communicate()[0]
- proc[bandp].wait()
+ # wait for jobs to finish, collect the output
+ if not proc[band].stdout.closed:
+ pout[band] = proc[band].communicate()[0]
+ proc[band].wait()
- # wait for jobs to finish, collect the output
- if not proc[band].stdout.closed:
- pout[band] = proc[band].communicate()[0]
- proc[band].wait()
- # parse the results
+ # parse the results
for band in bands:
- kv = grass.parse_key_val(pout[band])
+ kv = grass.parse_key_val(pout[band])
grass.message(_("Calculating Correlation Matrix..."))
correlation = {}
- s = grass.read_command('r.covar', flags = 'r', map = [image[band] for band in bands])
+ s = grass.read_command('r.covar', flags='r', map=[band for band in bands],
+ quiet=True)
for i, row in zip(bands, s.splitlines()):
- for j, cell in zip(bands, row.split(' ')):
- correlation[i,j] = float(cell)
+ for j, cell in zip(bands, row.split(' ')):
+ correlation[i, j] = float(cell)
# Calculate all combinations
- grass.message(_("Calculating OIF for the 20 band combinations..."))
+ grass.message(_("Calculating OIF for all band combinations..."))
oif = []
- for p in perms():
- oif.append((oifcalc(stddev, correlation, *p), p))
- oif.sort(reverse = True)
+ for p in perms(bands):
+ oif.append((oifcalc(stddev, correlation, *p), p))
+ oif.sort(reverse=True)
- grass.verbose(_("The Optimum Index Factor analysis result "
+ grass.verbose(_("The Optimum Index Factor analysis result " \
"(Best combination comes first):"))
if shell:
- fmt = "%d%d%d:%.4f\n"
+ fmt = "%s%s%s:%.4f\n"
else:
- fmt = "%d%d%d: %.4f\n"
+ fmt = "%s%s%s: %.4f\n"
- outf = file('i.oif.result', 'w')
- for v, p in oif:
- sys.stdout.write(fmt % (p + (v,)))
- outf.write(fmt % (p + (v,)))
- outf.close()
+ if not output or output == '-':
+ for v, p in oif:
+ sys.stdout.write(fmt % (p + (v,)))
+ else:
+ outf = file(output, 'w')
+ for v, p in oif:
+ outf.write(fmt % (p + (v,)))
+ outf.close()
if __name__ == "__main__":
options, flags = grass.parser()
