[GRASS-SVN] r59353 - grass/trunk/scripts/i.oif
Wed Mar 26 04:11:46 PDT 2014
Author: lucadelu
Date: 2014-03-26 04:11:46 -0700 (Wed, 26 Mar 2014)
New Revision: 59353
   grass/trunk/scripts/i.oif/i.oif.py
i.oif: check the number of input maps (minimum should be 4), update messages
Modified: grass/trunk/scripts/i.oif/i.oif.py
--- grass/trunk/scripts/i.oif/i.oif.py	2014-03-26 11:01:09 UTC (rev 59352)
+++ grass/trunk/scripts/i.oif/i.oif.py	2014-03-26 11:11:46 UTC (rev 59353)
@@ -73,9 +73,13 @@
     shell = flags['g']
     serial = flags['s']
     bands = options['input'].split(',')
+    if len(bands) < 4:
+        grass.fatal(_("At least four input maps required"))
     output = options['output']
     # calculate the Stddev for TM bands
-    grass.message(_("Calculating Standard deviations for all bands..."))
+    grass.message(_("Calculating standard deviations for all bands..."))
     stddev = {}
     if serial:
@@ -134,12 +138,12 @@
     oif.sort(reverse=True)
     grass.verbose(_("The Optimum Index Factor analysis result " \
-                    "(Best combination comes first):"))
+                    "(best combination shown first):"))
     if shell:
-        fmt = "%s%s%s:%.4f\n"
+        fmt = "%s,%s,%s:%.4f\n"
     else:
-        fmt = "%s%s%s:  %.4f\n"
+        fmt = "%s, %s, %s:  %.4f\n"
     if not output or output == '-':
         for v, p in oif:
