[GRASS-SVN] r59355 - in grass/trunk/vector: v.parallel v.segment v.split
svn_grass at osgeo.org
Wed Mar 26 04:41:41 PDT 2014
Author: neteler
Date: 2014-03-26 04:41:40 -0700 (Wed, 26 Mar 2014)
New Revision: 59355
grass/trunk/vector/v.parallel/v.parallel.html
grass/trunk/vector/v.segment/v.segment.html
grass/trunk/vector/v.split/v.split.html
v.split/segment/parallel manuals: improvements (contributed by Milena Nowotarska)
Modified: grass/trunk/vector/v.parallel/v.parallel.html
--- grass/trunk/vector/v.parallel/v.parallel.html 2014-03-26 11:22:52 UTC (rev 59354)
+++ grass/trunk/vector/v.parallel/v.parallel.html 2014-03-26 11:41:40 UTC (rev 59355)
@@ -3,6 +3,14 @@
<em>v.parallel</em> creates parallel lines to the input vector lines which
can be used as half-buffers.
+<h2>NOTES</h2>
+Usage of <b>-b</b> flag will overrule the <b>side</b> parameter.
+<h2>BUGS</h2>
+There is a problem with side-offset parallel line generation for inside corners.
+To avoid this problem, the <b>-b</b> flag might be used.
+<!-- in Vect_line_parallel(), v.segment is also affected -->
<h2>SEE ALSO</h2>
<em>
Modified: grass/trunk/vector/v.segment/v.segment.html
--- grass/trunk/vector/v.segment/v.segment.html 2014-03-26 11:22:52 UTC (rev 59354)
+++ grass/trunk/vector/v.segment/v.segment.html 2014-03-26 11:41:40 UTC (rev 59355)
@@ -1,7 +1,8 @@
<h2>DESCRIPTION</h2>
<em>v.segment</em> generates segments or points from input lines and from
-positions read from a text file or '<tt>stdin</tt>'.
+positions read from a text file or '<tt>stdin</tt>'. It includes the creation
+of parallel lines or points in given destination from the line.
<p>The format is:
<div class="code"><pre>
Modified: grass/trunk/vector/v.split/v.split.html
--- grass/trunk/vector/v.split/v.split.html 2014-03-26 11:22:52 UTC (rev 59354)
+++ grass/trunk/vector/v.split/v.split.html 2014-03-26 11:41:40 UTC (rev 59355)
@@ -1,13 +1,15 @@
-<em>v.split</em> split vector lines into shorter segments using a
-maximal distance between nodes.
+<em>v.split</em> splits vector lines into shorter segments using
+a maximal distance between nodes. The resulting length of all segments
+is expected to be equal and not higher than the given <b>length</b>
+parameter.
<h2>EXAMPLES</h2>
The examples are based on the North Carolina sample data location.
-<h3>Example 1: Inserting kilometric nodes to railroad map</h3>
+<h3>Example 1: Inserting nodes to railroad map</h3>
# extract data for this example
@@ -16,7 +18,7 @@
# show line, category, direction (to find the beginning)
d.vect myrr disp=shape,cat,dir
-# insert nodes at 1000m distance (max)
+# insert nodes at a distance not longer than 1000m
v.split myrr out=mrr_split length=1000
d.vect myrr_split disp=shape,topo
</pre></div>
@@ -29,12 +31,12 @@
v.category myrr_pol out=myrailroads option=add
</pre></div>
-<h3>Example 2: Inserting kilometric vertices to railroad map</h3>
+<h3>Example 2: Inserting vertices to railroad map</h3>
Note: first run the two steps from example 1.
-# insert vertices at 1000m distance (max)
+# insert vertices at a distance not longer than 1000m
v.split -n myrr out=myrr_split length=1000
</pre></div>
