[GRASS-SVN] r59360 - grass/trunk/raster/r.colors
Wed Mar 26 07:22:57 PDT 2014
Author: neteler
Date: 2014-03-26 07:22:56 -0700 (Wed, 26 Mar 2014)
New Revision: 59360
   grass/trunk/raster/r.colors/r.colors.html
r.colors manual: cosmetics
Modified: grass/trunk/raster/r.colors/r.colors.html
--- grass/trunk/raster/r.colors/r.colors.html	2014-03-26 13:51:12 UTC (rev 59359)
+++ grass/trunk/raster/r.colors/r.colors.html	2014-03-26 14:22:56 UTC (rev 59360)
@@ -6,17 +6,12 @@
 by <b>map</b> or as <b>file</b> using an input file with one map name per line)
 must exist in the user's current mapset search path.
 <p>The <b>rast</b> option allows user to specify a raster map <i>name</i>
 from which to copy the color map.
 <p>The <b>volume</b> option allows user to specify a volume (3d raster)
 map <i>name</i> from which to copy the color map.
-<p>All color tables are stored in <tt>$GISBASE/etc/colors/</tt>. Further
-user-defined color tables can also be stored in this directory for
-access from the <em>color</em> parameter.
 <p>The <b>-e</b> flag equalizes the original raster's color table. It can
 preclude the need for <em>grey.eq</em> rule, when used as
 <b>-e color=</b><em>grey</em>. Note however, that this will not yield
@@ -227,7 +222,17 @@
 end
 </pre></div>
+<h2>NOTES</h2>
+All color tables are stored in <tt>$GISBASE/etc/colors/</tt>. Further
+user-defined color tables can also be stored in this directory for
+access from the <em>color</em> parameter or in a user defined directory.
+See also <em>r.colors.out</em> for printing color tables easily to the
+terminal.
+<p>
+The color table assigned to a raster map is stored in
+<tt>$GISDBASE/location/mapset/colr/</tt>.
 <h2>EXAMPLES</h2>
 The below example shows how you can specify colors for a three
