[GRASS-SVN] r59369 - in grass/trunk/temporal: t.merge t.rast.accdetect t.rast.accdetect/test_suite t.rast.accumulate t.rast.accumulate/test_suite t.rast.import t.rast.mapcalc2 t.rast.neighbors t.rast3d.mapcalc2 t.register t.remove t.select t.shift t.snap t.vect.mapcalc t.vect.mapcalc/test_suite
svn_grass at osgeo.org
Wed Mar 26 08:21:32 PDT 2014
Author: neteler
Date: 2014-03-26 08:21:32 -0700 (Wed, 26 Mar 2014)
New Revision: 59369
grass/trunk/temporal/t.merge/Makefile
grass/trunk/temporal/t.merge/t.merge.html
grass/trunk/temporal/t.merge/t.merge.py
grass/trunk/temporal/t.merge/test.t.merge.sh
grass/trunk/temporal/t.rast.accdetect/Makefile
grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.html
grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
grass/trunk/temporal/t.rast.accdetect/test_suite/test.t.rast.accdetect.reverse.sh
grass/trunk/temporal/t.rast.accdetect/test_suite/test.t.rast.accdetect.sh
grass/trunk/temporal/t.rast.accumulate/Makefile
grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html
grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py
grass/trunk/temporal/t.rast.accumulate/test_suite/test.t.rast.accumulate.sh
grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh
grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh
grass/trunk/temporal/t.rast.mapcalc2/Makefile
grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.html
grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.py
grass/trunk/temporal/t.rast.mapcalc2/test.t.rast.mapcalc2.sh
grass/trunk/temporal/t.rast.neighbors/Makefile
grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh
grass/trunk/temporal/t.rast3d.mapcalc2/Makefile
grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html
grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.py
grass/trunk/temporal/t.rast3d.mapcalc2/test.t.rast3d.mapcalc2.sh
grass/trunk/temporal/t.register/test.t.register.raster.file.timezone.sh
grass/trunk/temporal/t.register/test.t.register.raster.timestamp.sh
grass/trunk/temporal/t.remove/test.t.remove.sh
grass/trunk/temporal/t.select/Makefile
grass/trunk/temporal/t.select/t.select.html
grass/trunk/temporal/t.select/t.select.py
grass/trunk/temporal/t.select/test.t.select.sh
grass/trunk/temporal/t.shift/Makefile
grass/trunk/temporal/t.shift/t.shift.html
grass/trunk/temporal/t.shift/t.shift.py
grass/trunk/temporal/t.shift/test.t.shift.absolue.sh
grass/trunk/temporal/t.shift/test.t.shift.relative.sh
grass/trunk/temporal/t.snap/Makefile
grass/trunk/temporal/t.snap/t.snap.html
grass/trunk/temporal/t.snap/t.snap.py
grass/trunk/temporal/t.snap/test.t.snap.absolute.sh
grass/trunk/temporal/t.snap/test.t.snap.relative.sh
grass/trunk/temporal/t.vect.mapcalc/Makefile
grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.html
grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.py
grass/trunk/temporal/t.vect.mapcalc/test_suite/test.t.vect.mapcalc.sh
svn propset
Property changes on: grass/trunk/temporal/t.merge/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Modified: grass/trunk/temporal/t.merge/t.merge.html
--- grass/trunk/temporal/t.merge/t.merge.html 2014-03-26 15:19:40 UTC (rev 59368)
+++ grass/trunk/temporal/t.merge/t.merge.html 2014-03-26 15:21:32 UTC (rev 59369)
@@ -208,5 +208,5 @@
Sören Gebbert
-<p><i>Last changed: $Date: 2012-11-04 16:05:21 +0100 (So, 04. Nov 2012) $</i>
+<p><i>Last changed: $Date$</i>
Property changes on: grass/trunk/temporal/t.merge/t.merge.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass/trunk/temporal/t.merge/t.merge.py
+ text/x-python
+ native
Property changes on: grass/trunk/temporal/t.merge/test.t.merge.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.rast.accdetect/Makefile
+ text/x-makefile
+ native
Modified: grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.html
--- grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.html 2014-03-26 15:19:40 UTC (rev 59368)
+++ grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.html 2014-03-26 15:21:32 UTC (rev 59369)
@@ -60,4 +60,4 @@
Sören Gebbert
-<p><i>Last changed: $Date: 2012-08-29 14:55:21 +0200 (Mi, 29. Aug 2012) $</i>
Property changes on: grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
+ text/x-python
+ native
Property changes on: grass/trunk/temporal/t.rast.accdetect/test_suite/test.t.rast.accdetect.reverse.sh
Added: svn:executable
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.rast.accdetect/test_suite/test.t.rast.accdetect.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.rast.accumulate/Makefile
+ text/x-makefile
+ native
Modified: grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html
--- grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html 2014-03-26 15:19:40 UTC (rev 59368)
+++ grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html 2014-03-26 15:21:32 UTC (rev 59369)
@@ -271,4 +271,4 @@
Sören Gebbert
Property changes on: grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py
+ text/x-python
+ native
Property changes on: grass/trunk/temporal/t.rast.accumulate/test_suite/test.t.rast.accumulate.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.rast.import/test.t.rast.import.relative.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.rast.mapcalc2/Makefile
+ text/x-makefile
+ native
Modified: grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.html
--- grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.html 2014-03-26 15:19:40 UTC (rev 59368)
+++ grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.html 2014-03-26 15:21:32 UTC (rev 59369)
@@ -340,5 +340,5 @@
Thomas Leppelt, Soeren Gebbert, Thuenen Institut, Germany <br>
-<p><i>Last changed: $Date: 2013-07-24 17:35:20 +0100 (Thu, 24 Jul 2013) $</i>
Property changes on: grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass/trunk/temporal/t.rast.mapcalc2/t.rast.mapcalc2.py
+ text/x-python
+ native
Property changes on: grass/trunk/temporal/t.rast.mapcalc2/test.t.rast.mapcalc2.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.rast.neighbors/Makefile
+ text/x-makefile
+ native
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html 2014-03-26 15:19:40 UTC (rev 59368)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html 2014-03-26 15:21:32 UTC (rev 59369)
@@ -175,4 +175,4 @@
Sören Gebbert
Property changes on: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
+ text/x-python
+ native
Property changes on: grass/trunk/temporal/t.rast.neighbors/test.t.rast.neighbors.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.rast3d.mapcalc2/Makefile
+ text/x-makefile
+ native
Modified: grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html
--- grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html 2014-03-26 15:19:40 UTC (rev 59368)
+++ grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html 2014-03-26 15:21:32 UTC (rev 59369)
@@ -31,5 +31,5 @@
Property changes on: grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.py
+ text/x-python
+ native
Property changes on: grass/trunk/temporal/t.rast3d.mapcalc2/test.t.rast3d.mapcalc2.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.register/test.t.register.raster.file.timezone.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.register/test.t.register.raster.timestamp.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.remove/test.t.remove.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.select/Makefile
+ text/x-makefile
+ native
Modified: grass/trunk/temporal/t.select/t.select.html
--- grass/trunk/temporal/t.select/t.select.html 2014-03-26 15:19:40 UTC (rev 59368)
+++ grass/trunk/temporal/t.select/t.select.html 2014-03-26 15:21:32 UTC (rev 59369)
@@ -276,5 +276,5 @@
Property changes on: grass/trunk/temporal/t.select/t.select.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass/trunk/temporal/t.select/t.select.py
+ text/x-python
+ native
Property changes on: grass/trunk/temporal/t.select/test.t.select.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.shift/Makefile
+ text/x-makefile
+ native
Modified: grass/trunk/temporal/t.shift/t.shift.html
--- grass/trunk/temporal/t.shift/t.shift.html 2014-03-26 15:19:40 UTC (rev 59368)
+++ grass/trunk/temporal/t.shift/t.shift.html 2014-03-26 15:21:32 UTC (rev 59369)
@@ -184,5 +184,5 @@
Sören Gebbert
-<p><i>Last changed: $Date: 2013-01-22 14:44:08 +0100 (Di, 22. Jan 2013) $</i>
Property changes on: grass/trunk/temporal/t.shift/t.shift.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass/trunk/temporal/t.shift/t.shift.py
+ text/x-python
+ native
Property changes on: grass/trunk/temporal/t.shift/test.t.shift.absolue.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.shift/test.t.shift.relative.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.snap/Makefile
+ text/x-makefile
+ native
Modified: grass/trunk/temporal/t.snap/t.snap.html
--- grass/trunk/temporal/t.snap/t.snap.html 2014-03-26 15:19:40 UTC (rev 59368)
+++ grass/trunk/temporal/t.snap/t.snap.html 2014-03-26 15:21:32 UTC (rev 59369)
@@ -172,5 +172,5 @@
Sören Gebbert
Property changes on: grass/trunk/temporal/t.snap/t.snap.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass/trunk/temporal/t.snap/t.snap.py
+ text/x-python
+ native
Property changes on: grass/trunk/temporal/t.snap/test.t.snap.absolute.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.snap/test.t.snap.relative.sh
+ text/x-sh
+ native
Property changes on: grass/trunk/temporal/t.vect.mapcalc/Makefile
+ text/x-makefile
+ native
Modified: grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.html
--- grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.html 2014-03-26 15:19:40 UTC (rev 59368)
+++ grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.html 2014-03-26 15:21:32 UTC (rev 59369)
@@ -336,5 +336,5 @@
Property changes on: grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Property changes on: grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.py
+ text/x-python
+ native
Property changes on: grass/trunk/temporal/t.vect.mapcalc/test_suite/test.t.vect.mapcalc.sh
+ text/x-sh
+ native
