[GRASS-SVN] r59415 - in grass-addons/grass7/raster: r.stream.channel r.stream.distance r.stream.order
svn_grass at osgeo.org
Thu Mar 27 06:56:22 PDT 2014
Author: martinl
Date: 2014-03-27 06:56:22 -0700 (Thu, 27 Mar 2014)
New Revision: 59415
grass-addons/grass7/raster/r.stream.channel/main.c
grass-addons/grass7/raster/r.stream.distance/main.c
grass-addons/grass7/raster/r.stream.order/main.c
r.stream.*: guisection cosmetics
Modified: grass-addons/grass7/raster/r.stream.channel/main.c
--- grass-addons/grass7/raster/r.stream.channel/main.c 2014-03-27 13:53:38 UTC (rev 59414)
+++ grass-addons/grass7/raster/r.stream.channel/main.c 2014-03-27 13:56:22 UTC (rev 59415)
@@ -74,33 +74,33 @@
out_identifier_opt->key = "identifier";
out_identifier_opt->required = NO;
out_identifier_opt->description = _("Name for output unique stream identifier raster map");
- out_identifier_opt->guisection = _("Output");
+ out_identifier_opt->guisection = _("Output maps");
out_distance_opt = G_define_standard_option(G_OPT_R_OUTPUT);
out_distance_opt->key = "distance";
out_distance_opt->required = NO;
out_distance_opt->description = _("Name for output init/join/outlet distance raster map");
- out_distance_opt->guisection = _("Output");
+ out_distance_opt->guisection = _("Output maps");
out_difference_opt = G_define_standard_option(G_OPT_R_OUTPUT);
out_difference_opt->key = "difference";
out_difference_opt->required = NO;
out_difference_opt->description =
_("Name for output elevation init/join/outlet difference raster map");
- out_difference_opt->guisection = _("Output");
+ out_difference_opt->guisection = _("Output maps");
out_gradient_opt = G_define_standard_option(G_OPT_R_OUTPUT);
out_gradient_opt->key = "gradient";
out_gradient_opt->required = NO;
out_gradient_opt->description =
_("Name for output mean init/join/outlet gradient of stream raster map");
- out_gradient_opt->guisection = _("Output");
+ out_gradient_opt->guisection = _("Output maps");
out_curvature_opt = G_define_standard_option(G_OPT_R_OUTPUT);
out_curvature_opt->key = "curvature";
out_curvature_opt->required = NO;
out_curvature_opt->description = _("Name for output local stream curvature raster map");
- out_curvature_opt->guisection = _("Output");
+ out_curvature_opt->guisection = _("Output maps");
opt_swapsize = G_define_option();
opt_swapsize->key = "memory";
Modified: grass-addons/grass7/raster/r.stream.distance/main.c
--- grass-addons/grass7/raster/r.stream.distance/main.c 2014-03-27 13:53:38 UTC (rev 59414)
+++ grass-addons/grass7/raster/r.stream.distance/main.c 2014-03-27 13:56:22 UTC (rev 59415)
@@ -65,7 +65,7 @@
in_elev_opt = G_define_standard_option(G_OPT_R_ELEV);
in_elev_opt->required = NO;
- in_elev_opt->guisection = _("Input");
+ in_elev_opt->guisection = _("Input maps");
in_method_opt = G_define_option();
in_method_opt->key = "method";
@@ -79,13 +79,13 @@
out_dist_opt->key = "distance";
out_dist_opt->required = NO;
out_dist_opt->description = _("Name for output distance/accumulation raster map");
- out_dist_opt->guisection = _("Output");
+ out_dist_opt->guisection = _("Output maps");
out_diff_opt = G_define_standard_option(G_OPT_R_OUTPUT);
out_diff_opt->key = "difference";
out_diff_opt->required = NO;
out_diff_opt->description = _("Name for output elevation difference raster map");
- out_diff_opt->guisection = _("Output");
+ out_diff_opt->guisection = _("Output maps");
Modified: grass-addons/grass7/raster/r.stream.order/main.c
--- grass-addons/grass7/raster/r.stream.order/main.c 2014-03-27 13:53:38 UTC (rev 59414)
+++ grass-addons/grass7/raster/r.stream.order/main.c 2014-03-27 13:56:22 UTC (rev 59415)
@@ -82,7 +82,7 @@
opt_input[i]->key = input[i].name;
opt_input[i]->required = input[i].required;
opt_input[i]->description = _(input[i].description);
- opt_input[i]->guisection = _("Input");
+ opt_input[i]->guisection = _("Input maps");
opt_vector = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -90,14 +90,14 @@
opt_vector->required = NO;
opt_vector->description =
_("Name for output vector map to write stream atributes");
- opt_vector->guisection = _("Output");
+ opt_vector->guisection = _("Output maps");
for (i = 0; i < orders_size; ++i) {
opt_output[i] = G_define_standard_option(G_OPT_R_OUTPUT);
opt_output[i]->key = output[i].name;
opt_output[i]->required = NO;
opt_output[i]->description = _(output[i].description);
- opt_output[i]->guisection = _("Output");
+ opt_output[i]->guisection = _("Output maps");
