[GRASS-SVN] r59420 - grass-addons/grass7/raster/r.stream.snap
Thu Mar 27 07:33:35 PDT 2014
Author: martinl
Date: 2014-03-27 07:33:35 -0700 (Thu, 27 Mar 2014)
New Revision: 59420
   grass-addons/grass7/raster/r.stream.snap/Makefile
   grass-addons/grass7/raster/r.stream.snap/io.c
   grass-addons/grass7/raster/r.stream.snap/io.h
   grass-addons/grass7/raster/r.stream.snap/local_proto.h
   grass-addons/grass7/raster/r.stream.snap/main.c
   grass-addons/grass7/raster/r.stream.snap/points_io.c
   grass-addons/grass7/raster/r.stream.snap/snap.c
r.stream.snap: more guisection, message correction
               various minor cosmetics
Modified: grass-addons/grass7/raster/r.stream.snap/Makefile
--- grass-addons/grass7/raster/r.stream.snap/Makefile	2014-03-27 14:29:36 UTC (rev 59419)
+++ grass-addons/grass7/raster/r.stream.snap/Makefile	2014-03-27 14:33:35 UTC (rev 59420)
@@ -11,4 +11,3 @@
 include $(MODULE_TOPDIR)/include/Make/Module.make
 default: cmd
Modified: grass-addons/grass7/raster/r.stream.snap/io.c
--- grass-addons/grass7/raster/r.stream.snap/io.c	2014-03-27 14:29:36 UTC (rev 59419)
+++ grass-addons/grass7/raster/r.stream.snap/io.c	2014-03-27 14:33:35 UTC (rev 59420)
@@ -14,7 +14,7 @@
     int r;
     if (data_type < 0 || data_type > 2)
-	G_fatal_error(_("ram_creat: Cannot create map of unrecognised type"));
+	G_fatal_error(_("Unable to create raster map of unrecognised type"));
     map->data_type = data_type;
     map->map_name = NULL;
@@ -53,7 +53,7 @@
      * map pointer to map stucture (created with create_map);
      * check_res: [1]: check res correspondence between region and map [0 no check];
      * check_data_type [CELL, FCELL, DCELL] check if reading map is of particular type, [-1] no check;
+5     */
     int r, c;
     char *mapset;
@@ -76,9 +76,9 @@
     if (check_res)
 	if (this_window.ew_res != cellhd.ew_res ||
 	    this_window.ns_res != cellhd.ns_res)
-	    G_fatal_error(_("Region resolution and map %s resolution differs. \
-		Run g.region rast=%s to set proper region resolution"),
-			  input_map_name, input_map_name);
+          G_fatal_error(_("Region resolution and raster map <%s> resolution differs. "
+                          "Run 'g.region rast=%s' to set proper region resolution."),
+                        input_map_name, input_map_name);
     /* checking if input map is of required type */
     if (check_data_type != map->data_type)
@@ -87,7 +87,7 @@
     input_data_type = Rast_map_type(input_map_name, mapset);
     if (check_data_type != -1)
 	if (input_data_type != check_data_type)
-	    G_fatal_error(_("<%s> is not of type %s"),
+	    G_fatal_error(_("Raster map <%s> is not of type '%s'"),
 			  input_map_name, maptypes[check_data_type]);
     input_map_fd = Rast_open_old(input_map_name, mapset);
@@ -117,7 +117,7 @@
     input_buffer = Rast_allocate_buf(input_data_type);
     /* start reading */
-    G_message(_("Reading map <%s>"), input_map_name);
+    G_message(_("Reading raster map <%s>..."), input_map_name);
     for (r = 0; r < map->nrows; ++r) {
 	G_percent(r, map->nrows, 2);
@@ -145,7 +145,7 @@
 					 input_data_type);
 		    break;
 		default:
-		    G_fatal_error(_("ram_open:Wrong internal data type"));
+		    G_fatal_error(_("Wrong internal data type"));
 		    break;
     }				/*end for r */
@@ -192,7 +192,7 @@
 	G_debug(1,
 		"ram_write:required map type and internal map type differs: conversion forced!");
-    G_message(_("Writing map <%s>"), output_map_name);
+    G_message(_("Writing raster map <%s>..."), output_map_name);
     output_fd = Rast_open_new(output_map_name, output_data_type);
     /* writing */
@@ -229,7 +229,7 @@
     Rast_short_history(output_map_name, "raster", &history);
     Rast_command_history(&history);
     Rast_write_history(output_map_name, &history);
-    G_message(_("<%s> Done"), output_map_name);
+    /* G_message(_("<%s> Done"), output_map_name); */
     return 0;
@@ -294,7 +294,7 @@
 	seg->data_size = sizeof(DCELL);
 	break;
     default:
-	G_fatal_error(_("seg_create: unrecognisabe data type"));
+	G_fatal_error(_("Unrecognisable data type"));
     filename = G_tempfile();
@@ -305,18 +305,18 @@
 		       seg->data_size)) {
 	close(fd);
 	unlink(filename);
-	G_fatal_error(_("seg_create: cannot format segment"));
+	G_fatal_error(_("Unable to format segment"));
     close(fd);
     if (0 > (fd = open(filename, 2))) {
 	unlink(filename);
-	G_fatal_error(_("seg_create: cannot re-open file"));
+	G_fatal_error(_("Unable to re-open file '%s'"), filename);
     if (0 > (fd = segment_init(&(seg->seg), fd, number_of_segs))) {
 	unlink(filename);
-	G_fatal_error(_("seg_create: cannot init segment file or out of memory"));
+	G_fatal_error(_("Unable to init segment file or out of memory"));
     seg->filename = G_store(filename);
@@ -351,7 +351,7 @@
     /* checking if map exist */
     mapset = (char *)G_find_raster2(input_map_name, "");
     if (mapset == NULL)
-	G_fatal_error(_("seg_read:Raster map <%s> not found"),
+	G_fatal_error(_("Raster map <%s> not found"),
 		      input_map_name);
     seg->mapset = mapset;
@@ -363,9 +363,9 @@
     if (check_res)
     if (check_data_type != seg->data_type)
 	G_debug(1,
@@ -373,7 +373,7 @@
     input_fd = Rast_open_old(input_map_name, mapset);
@@ -401,7 +401,7 @@
     /* end opening and checking */
     target_buffer = Rast_allocate_buf(seg->data_type);
@@ -441,7 +441,7 @@
 	    G_free(input_buffer);
 	    G_free(target_buffer);
 	    Rast_close(input_fd);
-	    G_fatal_error(_("seg_read: Cannot segment put row %d for map %s"),
+	    G_fatal_error(_("Unable to segment put row %d for raster map <%s>"),
 			  r, input_map_name);
     }				/* end for row */
@@ -495,7 +495,7 @@
 	G_debug(1,
     output_buffer = Rast_allocate_buf(output_data_type);
     segment_flush(&(seg->seg));
@@ -505,7 +505,7 @@
 	G_percent(r, seg->nrows, 2);
 	if (0 > segment_get_row(&(seg->seg), output_buffer, r))
-	    G_warning(_("seg_write: Cannot segment read row %d for map %s"),
+	    G_warning(_("Unable to segment read row %d for raster map <%s>"),
 		      r, output_map_name);
 	if (convert_to_null) {
@@ -528,7 +528,7 @@
 			Rast_set_d_null_value(row + c * (seg->data_size), 1);
 		break;
 	    default:
-		G_warning(_("ram_null:Cannot convert to null at: %d %d"), r,
+		G_warning(_("Unable to convert to NULL at: %d %d"), r,
 			  c);
@@ -541,7 +541,7 @@
-    G_message(_("%s Done"), output_map_name);
+    /*G_message(_("%s Done"), output_map_name); */
     return 0;
Modified: grass-addons/grass7/raster/r.stream.snap/io.h
--- grass-addons/grass7/raster/r.stream.snap/io.h	2014-03-27 14:29:36 UTC (rev 59419)
+++ grass-addons/grass7/raster/r.stream.snap/io.h	2014-03-27 14:33:35 UTC (rev 59420)
@@ -56,4 +56,3 @@
 int seg_reset_map (SEG *, int);
 int seg_write_map(SEG *, char *, RASTER_MAP_TYPE, int, double);
 int seg_release_map(SEG *);
Modified: grass-addons/grass7/raster/r.stream.snap/local_proto.h
--- grass-addons/grass7/raster/r.stream.snap/local_proto.h	2014-03-27 14:29:36 UTC (rev 59419)
+++ grass-addons/grass7/raster/r.stream.snap/local_proto.h	2014-03-27 14:33:35 UTC (rev 59420)
@@ -8,4 +8,3 @@
 /* points_io.c */
 int write_points(char *, int);
Modified: grass-addons/grass7/raster/r.stream.snap/main.c
--- grass-addons/grass7/raster/r.stream.snap/main.c	2014-03-27 14:29:36 UTC (rev 59419)
+++ grass-addons/grass7/raster/r.stream.snap/main.c	2014-03-27 14:33:35 UTC (rev 59420)
@@ -9,11 +9,11 @@
  *               maximum snap distance and minimum accumulation value to snap
- * COPYRIGHT:    (C) 2002,2010 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002,2010-2014 by the GRASS Development Team
  *               This program is free software under the GNU General Public
- *   	    	 	  License (>=v2). Read the file COPYING that comes with GRASS
- *   	    	 	  for details.
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
 #define MAIN
@@ -44,11 +44,12 @@
     G_gisinit(argv[0]);
     module = G_define_module();
-    module->description = _("Delineate basins according user' input. \
-	Input can be stream network, point file with outlets or outlet coordinates");
+    module->label = _("Delineates basins for stream network.");
+    module->description = _("Input can be stream network, point vector map with outlets or outlet coordinates.");
     G_add_keyword(_("raster"));
     G_add_keyword(_("hydrology"));
-    G_add_keyword("basins creation");
+    G_add_keyword(_("stream network"));
+    G_add_keyword(_("basins creation"));
     in_points_opt = G_define_standard_option(G_OPT_V_INPUT);
     in_points_opt->description = _("Name of input vector points map");
@@ -59,13 +60,15 @@
     in_stream_opt = G_define_standard_option(G_OPT_R_INPUT);
     in_stream_opt->key = "streams";
     in_stream_opt->required = NO;
-    in_stream_opt->description = _("Name of stream map");
+    in_stream_opt->description = _("Name of input streams mask raster map");
+    in_stream_opt->guisection = _("Input maps");
     in_accum_opt = G_define_standard_option(G_OPT_R_INPUT);
     in_accum_opt->key = "accum";
     in_accum_opt->required = NO;
-    in_accum_opt->description = _("Name of accumulation map");
+    in_accum_opt->description = _("Name of input accumulation raster map");
+    in_accum_opt->guisection = _("Input maps");
     opt_accum_treshold = G_define_option();
     opt_accum_treshold->key = "accumtres";
     opt_accum_treshold->type = TYPE_DOUBLE;
@@ -104,7 +107,7 @@
 		      out_points_opt->answer);
     if (!in_stream_opt->answer && !in_accum_opt->answer)
-	G_fatal_error(_("At least one map of accumulation or streams is required"));
+	G_fatal_error(_("At least one of accumulation or streams raster maps is required"));
     if (!in_accum_opt->answer)
 	accum_treshold = -1;
@@ -133,11 +136,12 @@
     write_points(out_points_opt->answer, number_of_points);
     for (i = 0; i < number_of_points; ++i)
 	G_message("AFTER %d %d %d %d",
 		  points[i].r, points[i].c, points[i].di, points[i].dj);
     if (in_stream_opt->answer)
 	seg_release_map(&map_streams);
     if (in_accum_opt->answer)
Modified: grass-addons/grass7/raster/r.stream.snap/points_io.c
--- grass-addons/grass7/raster/r.stream.snap/points_io.c	2014-03-27 14:29:36 UTC (rev 59419)
+++ grass-addons/grass7/raster/r.stream.snap/points_io.c	2014-03-27 14:33:35 UTC (rev 59420)
@@ -2,7 +2,6 @@
 int read_points(char *in_point, SEGMENT * streams, SEGMENT * accum)
-    char *mapset;
     struct Cell_head window;
     struct Map_info Map;
     struct bound_box box;
@@ -16,13 +15,8 @@
     sites = Vect_new_line_struct();
     cats = Vect_new_cats_struct();
-    mapset = G_find_vector2(in_point, "");
-    if (mapset == NULL)
-	G_fatal_error(_("Vector map <%s> not found"), in_point);
-    if (Vect_open_old(&Map, in_point, mapset) < 0)
-	G_fatal_error("Cannot open vector map <%s>", in_point);
+    Vect_open_old(&Map, in_point, "");
     G_get_window(&window);
     Vect_region_box(&window, &box);
Modified: grass-addons/grass7/raster/r.stream.snap/snap.c
--- grass-addons/grass7/raster/r.stream.snap/snap.c	2014-03-27 14:29:36 UTC (rev 59419)
+++ grass-addons/grass7/raster/r.stream.snap/snap.c	2014-03-27 14:33:35 UTC (rev 59420)
@@ -103,7 +103,8 @@
-	if (sumaccum > 0)
+        /* TODO: this should be fixed by someone who knows the code */
+	if (sumaccum > 0)
 	    /* accum_treshold=(sumaccum/naccum+maxaccum)/2 */ ;
 	accum_treshold = sumaccum / naccum;
@@ -129,8 +130,8 @@
     }				/* end of non-streams version */
     if (di == -1 && dj == -1) {
-	G_warning(_("cannot snap point with cat %d, in a given radius. \
-		Increase search radius"), point->cat);
+	G_warning(_("Unable to snap point with cat %d, in a given radius. "
+                    "Increase search radius."), point->cat);
 	di = 0;
 	dj = 0;
 	status = 2;
