[GRASS-SVN] r59425 - grass-addons/grass7/raster/r.stream.stats
svn_grass at osgeo.org
Thu Mar 27 07:48:14 PDT 2014
Author: martinl
Date: 2014-03-27 07:48:13 -0700 (Thu, 27 Mar 2014)
New Revision: 59425
grass-addons/grass7/raster/r.stream.stats/Makefile
grass-addons/grass7/raster/r.stream.stats/io.c
grass-addons/grass7/raster/r.stream.stats/io.h
grass-addons/grass7/raster/r.stream.stats/local_proto.h
grass-addons/grass7/raster/r.stream.stats/local_vars.h
grass-addons/grass7/raster/r.stream.stats/main.c
grass-addons/grass7/raster/r.stream.stats/stats_calculate.c
grass-addons/grass7/raster/r.stream.stats/stats_prepare.c
r.stream.stats: more guisection, message correction
various minor cosmetics
Modified: grass-addons/grass7/raster/r.stream.stats/Makefile
--- grass-addons/grass7/raster/r.stream.stats/Makefile 2014-03-27 14:44:22 UTC (rev 59424)
+++ grass-addons/grass7/raster/r.stream.stats/Makefile 2014-03-27 14:48:13 UTC (rev 59425)
@@ -8,4 +8,3 @@
include $(MODULE_TOPDIR)/include/Make/Module.make
default: cmd
Modified: grass-addons/grass7/raster/r.stream.stats/io.c
--- grass-addons/grass7/raster/r.stream.stats/io.c 2014-03-27 14:44:22 UTC (rev 59424)
+++ grass-addons/grass7/raster/r.stream.stats/io.c 2014-03-27 14:48:13 UTC (rev 59425)
@@ -14,7 +14,7 @@
int r;
if (data_type < 0 || data_type > 2)
- G_fatal_error(_("ram_creat: Cannot create map of unrecognised type"));
+ G_fatal_error(_("Unable to create raster map of unrecognised type"));
map->data_type = data_type;
map->map_name = NULL;
@@ -76,9 +76,9 @@
if (check_res)
if (this_window.ew_res != cellhd.ew_res ||
this_window.ns_res != cellhd.ns_res)
- G_fatal_error(_("Region resolution and map %s resolution differs. \
- Run g.region rast=%s to set proper region resolution"),
- input_map_name, input_map_name);
+ G_fatal_error(_("Region resolution and raster map <%s> resolution differs. "
+ "Run 'g.region rast=%s' to set proper region resolution."),
+ input_map_name, input_map_name);
/* checking if input map is of required type */
if (check_data_type != map->data_type)
@@ -87,7 +87,7 @@
input_data_type = Rast_map_type(input_map_name, mapset);
if (check_data_type != -1)
if (input_data_type != check_data_type)
- G_fatal_error(_("<%s> is not of type %s"),
+ G_fatal_error(_("Raster map <%s> is not of type '%s'"),
input_map_name, maptypes[check_data_type]);
input_map_fd = Rast_open_old(input_map_name, mapset);
@@ -117,7 +117,7 @@
input_buffer = Rast_allocate_buf(input_data_type);
/* start reading */
- G_message(_("Reading map <%s>"), input_map_name);
+ G_message(_("Reading raster map <%s>..."), input_map_name);
for (r = 0; r < map->nrows; ++r) {
G_percent(r, map->nrows, 2);
@@ -145,7 +145,7 @@
input_data_type);
break;
default:
- G_fatal_error(_("ram_open:Wrong internal data type"));
+ G_fatal_error(_("Wrong internal data type"));
break;
} /*end for r */
@@ -192,7 +192,7 @@
G_debug(1,
"ram_write:required map type and internal map type differs: conversion forced!");
- G_message(_("Writing map <%s>"), output_map_name);
+ G_message(_("Writing raster map <%s>..."), output_map_name);
output_fd = Rast_open_new(output_map_name, output_data_type);
/* writing */
@@ -229,7 +229,7 @@
Rast_short_history(output_map_name, "raster", &history);
Rast_command_history(&history);
Rast_write_history(output_map_name, &history);
- G_message(_("<%s> Done"), output_map_name);
+ /*G_message(_("<%s> Done"), output_map_name); */
return 0;
@@ -294,7 +294,7 @@
seg->data_size = sizeof(DCELL);
break;
default:
- G_fatal_error(_("seg_create: unrecognisabe data type"));
+ G_fatal_error(_("Unrecognisable data type"));
filename = G_tempfile();
@@ -305,18 +305,18 @@
seg->data_size)) {
close(fd);
unlink(filename);
- G_fatal_error(_("seg_create: cannot format segment"));
+ G_fatal_error(_("Unable to format segment"));
close(fd);
if (0 > (fd = open(filename, 2))) {
unlink(filename);
- G_fatal_error(_("seg_create: cannot re-open file"));
+ G_fatal_error(_("Unable to re-open file '%s'"), filename);
if (0 > (fd = segment_init(&(seg->seg), fd, number_of_segs))) {
unlink(filename);
- G_fatal_error(_("seg_create: cannot init segment file or out of memory"));
+ G_fatal_error(_("Unable to init segment file or out of memory"));
seg->filename = G_store(filename);
@@ -351,7 +351,7 @@
/* checking if map exist */
mapset = (char *)G_find_raster2(input_map_name, "");
if (mapset == NULL)
- G_fatal_error(_("seg_read:Raster map <%s> not found"),
+ G_fatal_error(_("Raster map <%s> not found"),
input_map_name);
seg->mapset = mapset;
@@ -363,9 +363,9 @@
if (check_res)
if (check_data_type != seg->data_type)
G_debug(1,
@@ -373,7 +373,7 @@
+ G_fatal_error(_("Raster <%s> is not of type '%s'"),
input_fd = Rast_open_old(input_map_name, mapset);
@@ -401,7 +401,7 @@
/* end opening and checking */
target_buffer = Rast_allocate_buf(seg->data_type);
@@ -495,7 +495,7 @@
G_debug(1,
output_buffer = Rast_allocate_buf(output_data_type);
segment_flush(&(seg->seg));
@@ -505,7 +505,7 @@
G_percent(r, seg->nrows, 2);
if (0 > segment_get_row(&(seg->seg), output_buffer, r))
- G_warning(_("seg_write: Cannot segment read row %d for map %s"),
+ G_warning(_("Unable to segment read row %d for raster map <%s>"),
r, output_map_name);
if (convert_to_null) {
@@ -541,7 +541,7 @@
- G_message(_("%s Done"), output_map_name);
+ /*G_message(_("%s Done"), output_map_name); */
return 0;
Modified: grass-addons/grass7/raster/r.stream.stats/io.h
--- grass-addons/grass7/raster/r.stream.stats/io.h 2014-03-27 14:44:22 UTC (rev 59424)
+++ grass-addons/grass7/raster/r.stream.stats/io.h 2014-03-27 14:48:13 UTC (rev 59425)
@@ -56,4 +56,3 @@
int seg_reset_map (SEG *, int);
int seg_write_map(SEG *, char *, RASTER_MAP_TYPE, int, double);
int seg_release_map(SEG *);
Modified: grass-addons/grass7/raster/r.stream.stats/local_proto.h
--- grass-addons/grass7/raster/r.stream.stats/local_proto.h 2014-03-27 14:44:22 UTC (rev 59424)
+++ grass-addons/grass7/raster/r.stream.stats/local_proto.h 2014-03-27 14:48:13 UTC (rev 59425)
@@ -23,4 +23,3 @@
int print_stats(int order_max);
int print_stats_total(void);
int print_stats_orders(int order_max);
Modified: grass-addons/grass7/raster/r.stream.stats/local_vars.h
--- grass-addons/grass7/raster/r.stream.stats/local_vars.h 2014-03-27 14:44:22 UTC (rev 59424)
+++ grass-addons/grass7/raster/r.stream.stats/local_vars.h 2014-03-27 14:48:13 UTC (rev 59425)
@@ -61,8 +61,6 @@
float drainage_density;
} STATS;
#ifdef MAIN
# define GLOBAL
#else
@@ -82,7 +80,3 @@
GLOBAL STREAM *stat_streams;
GLOBAL STATS *ord_stats;
GLOBAL STATS stats_total;
Modified: grass-addons/grass7/raster/r.stream.stats/main.c
--- grass-addons/grass7/raster/r.stream.stats/main.c 2014-03-27 14:44:22 UTC (rev 59424)
+++ grass-addons/grass7/raster/r.stream.stats/main.c 2014-03-27 14:48:13 UTC (rev 59425)
@@ -13,11 +13,11 @@
* If input stream comes from r.stream.extract direction map
* from r.stream.extract dir map must be patched with that of r.watershed.
- * COPYRIGHT: (C) 2002,2010 by the GRASS Development Team
+ * COPYRIGHT: (C) 2002,2010-2014 by the GRASS Development Team
* This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * License (>=v2). Read the file COPYING that comes with GRASS
+ * for details.
#define MAIN
@@ -49,33 +49,29 @@
/* initialize module */
module = G_define_module();
module->description =
- _("Calculate Horton's statistics for Strahler and Horton ordered networks created with r.stream.order");
+ _("Calculates Horton's statistics for Strahler and Horton ordered networks created with r.stream.order.");
G_add_keyword(_("raster"));
G_add_keyword(_("hydrology"));
- G_add_keyword("Horton's statistics");
- G_add_keyword("Bifurcation ratio");
- G_add_keyword("Drainage density");
- G_add_keyword("Catchment statistics");
+ G_add_keyword(_("stream network"));
+ G_add_keyword(_("Horton's statistics"));
in_stm_opt = G_define_standard_option(G_OPT_R_INPUT);
in_stm_opt->key = "streams";
- in_stm_opt->description = "Name of streams mask input map";
+ in_stm_opt->description = _("Name of input streams mask raster map");
in_dir_opt = G_define_standard_option(G_OPT_R_INPUT);
in_dir_opt->key = "dirs";
- in_dir_opt->description = "Name of flow direction input map";
+ in_dir_opt->description = _("Name of input flow direction raster map");
- in_elev_opt = G_define_standard_option(G_OPT_R_INPUT);
- in_elev_opt->key = "elevation";
- in_elev_opt->description = "Name of elevation map";
+ in_elev_opt = G_define_standard_option(G_OPT_R_ELEV);
opt_swapsize = G_define_option();
opt_swapsize->key = "memory";
opt_swapsize->type = TYPE_INTEGER;
opt_swapsize->answer = "300";
opt_swapsize->description = _("Max memory used in memory swap mode (MB)");
- opt_swapsize->guisection = _("Optional");
+ opt_swapsize->guisection = _("Memory settings");
opt_output = G_define_standard_option(G_OPT_F_OUTPUT);
opt_output->required = NO;
opt_output->description =
@@ -84,15 +80,18 @@
flag_segmentation = G_define_flag();
flag_segmentation->key = 'm';
flag_segmentation->description = _("Use memory swap (operation is slow)");
+ flag_segmentation->guisection = _("Memory settings");
flag_catchment_total = G_define_flag();
flag_catchment_total->key = 'c';
flag_catchment_total->description =
_("Print only catchment's statistics");
+ flag_catchment_total->guisection = _("Print");
flag_orders_summary = G_define_flag();
flag_orders_summary->key = 'o';
flag_orders_summary->description = _("Print only orders' statistics");
+ flag_orders_summary->guisection = _("Print");
if (G_parser(argc, argv)) /* parser */
exit(EXIT_FAILURE);
@@ -104,7 +103,7 @@
filename = opt_output->answer;
if (filename != NULL)
if (NULL == freopen(filename, "w", stdout))
- G_fatal_error(_("Unable to open file <%s> for writing"),
+ G_fatal_error(_("Unable to open file '%s' for writing"),
filename);
nrows = Rast_window_rows();
@@ -115,7 +114,7 @@
CELL **streams, **dirs;
FCELL **elevation;
- G_message(_("ALL IN RAM CALCULATION"));
+ G_message(_("All in RAM calculation..."));
ram_create_map(&map_streams, CELL_TYPE);
ram_read_map(&map_streams, in_stm_opt->answer, 1, CELL_TYPE);
@@ -153,7 +152,7 @@
SEG map_dirs, map_streams, map_elevation;
SEGMENT *streams, *dirs, *elevation;
- G_message(_("MEMORY SWAP CALCULATION - MAY TAKE SOME TIME"));
+ G_message(_("Memory swap calculation (may take some time)..."));
number_of_segs = (int)atof(opt_swapsize->answer);
number_of_segs = number_of_segs < 32 ? (int)(32 / 0.18) : number_of_segs / 0.18;
Modified: grass-addons/grass7/raster/r.stream.stats/stats_calculate.c
--- grass-addons/grass7/raster/r.stream.stats/stats_calculate.c 2014-03-27 14:44:22 UTC (rev 59424)
+++ grass-addons/grass7/raster/r.stream.stats/stats_calculate.c 2014-03-27 14:48:13 UTC (rev 59425)
@@ -27,7 +27,7 @@
return result;
-int stats(order_max)
+int stats(int order_max)
int i;
int num, ord_num;
Modified: grass-addons/grass7/raster/r.stream.stats/stats_prepare.c
--- grass-addons/grass7/raster/r.stream.stats/stats_prepare.c 2014-03-27 14:44:22 UTC (rev 59424)
+++ grass-addons/grass7/raster/r.stream.stats/stats_prepare.c 2014-03-27 14:48:13 UTC (rev 59425)
@@ -4,7 +4,7 @@
int fifo_insert(POINT point)
if (fifo_count == fifo_max)
- G_fatal_error("fifo queue: circular buffer too small");
+ G_fatal_error(_("Circular buffer too small"));
fifo_points[tail++] = point;
if (tail > fifo_max) {
