[GRASS-SVN] r59429 - grass-addons/grass7/raster/r.stream.basins
Thu Mar 27 08:10:38 PDT 2014
Author: martinl
Date: 2014-03-27 08:10:37 -0700 (Thu, 27 Mar 2014)
New Revision: 59429
   grass-addons/grass7/raster/r.stream.basins/Makefile
   grass-addons/grass7/raster/r.stream.basins/basins_fill.c
   grass-addons/grass7/raster/r.stream.basins/basins_inputs.c
   grass-addons/grass7/raster/r.stream.basins/io.c
   grass-addons/grass7/raster/r.stream.basins/io.h
   grass-addons/grass7/raster/r.stream.basins/local_vars.h
   grass-addons/grass7/raster/r.stream.basins/main.c
r.stream.basins: more guisection, message correction
                 various minor cosmetics
Modified: grass-addons/grass7/raster/r.stream.basins/Makefile
--- grass-addons/grass7/raster/r.stream.basins/Makefile	2014-03-27 15:07:02 UTC (rev 59428)
+++ grass-addons/grass7/raster/r.stream.basins/Makefile	2014-03-27 15:10:37 UTC (rev 59429)
@@ -11,4 +11,3 @@
 include $(MODULE_TOPDIR)/include/Make/Module.make
 default: cmd
Modified: grass-addons/grass7/raster/r.stream.basins/basins_fill.c
--- grass-addons/grass7/raster/r.stream.basins/basins_fill.c	2014-03-27 15:07:02 UTC (rev 59428)
+++ grass-addons/grass7/raster/r.stream.basins/basins_fill.c	2014-03-27 15:10:37 UTC (rev 59429)
@@ -24,7 +24,7 @@
 int fifo_insert(POINT point)
     if (fifo_count == fifo_max)
-	G_fatal_error("fifo queue: circular buffer too small");
+        G_fatal_error(_("Circular buffer too small"));
     fifo_points[tail++] = point;
     if (tail > fifo_max) {
Modified: grass-addons/grass7/raster/r.stream.basins/basins_inputs.c
--- grass-addons/grass7/raster/r.stream.basins/basins_inputs.c	2014-03-27 15:07:02 UTC (rev 59428)
+++ grass-addons/grass7/raster/r.stream.basins/basins_inputs.c	2014-03-27 15:10:37 UTC (rev 59429)
@@ -23,17 +23,17 @@
     for (n = 0, outlets_num = 0; answers[n] != NULL; n += 2, outlets_num++) {
 	if (!G_scan_easting(answers[n], &X, G_projection()))
-	    G_fatal_error("Wrong coordinate <%s>", answers[n]);
+            G_fatal_error(_("Wrong coordinate '%s'"), answers[n]);
 	if (!answers[n + 1])
-	    G_fatal_error("Missing north coordinate for east %g", X);
+	    G_fatal_error(_("Missing north coordinate for east %g"), X);
 	if (!G_scan_northing(answers[n + 1], &Y, G_projection()))
-	    G_fatal_error("Wrong coordinate <%s>", answers[n + 1]);
+	    G_fatal_error(_("Wrong coordinate '%s'"), answers[n + 1]);
 	if (X < window.west || X > window.east ||
 	    Y < window.south || Y > window.north)
-	    G_fatal_error("Coordinates outside window");
+	    G_fatal_error(_("Coordinates outside window"));
 	outlets[outlets_num].r = (window.north - Y) / window.ns_res;
 	outlets[outlets_num].c = (X - window.west) / window.ew_res;
@@ -45,7 +45,6 @@
 int process_vector(char *in_point)
-    char *mapset;
     struct Cell_head window;
     struct Map_info Map;
     struct bound_box box;
@@ -57,13 +56,8 @@
     sites = Vect_new_line_struct();
     cats = Vect_new_cats_struct();
-    mapset = G_find_vector2(in_point, "");
-    if (mapset == NULL)
-	G_fatal_error(_("Vector map <%s> not found"), in_point);
+    Vect_open_old(&Map, in_point, "");
-    if (Vect_open_old(&Map, in_point, mapset) < 0)
-	G_fatal_error("Cannot open vector map <%s>", in_point);
     G_get_window(&window);
     Vect_region_box(&window, &box);
@@ -216,8 +210,7 @@
 	    segment_get(streams, &streams_cell, r, c);
 	    if (streams_cell > 0) {
 		if (outlets_num > 6 * (out_max - 1))
-		    G_fatal_error
-			("Stream and direction maps probably do not match");
+		    G_fatal_error(_("Stream and direction maps probably do not match"));
 		if (outlets_num > (out_max - 1))
 		    outlets =
Modified: grass-addons/grass7/raster/r.stream.basins/io.c
--- grass-addons/grass7/raster/r.stream.basins/io.c	2014-03-27 15:07:02 UTC (rev 59428)
+++ grass-addons/grass7/raster/r.stream.basins/io.c	2014-03-27 15:10:37 UTC (rev 59429)
@@ -14,7 +14,7 @@
     int r;
     if (data_type < 0 || data_type > 2)
-	G_fatal_error(_("ram_creat: Cannot create map of unrecognised type"));
+	G_fatal_error(_("Unable to create raster map of unrecognised type"));
     map->data_type = data_type;
     map->map_name = NULL;
@@ -76,10 +76,10 @@
     if (check_res)
 	if (this_window.ew_res != cellhd.ew_res ||
 	    this_window.ns_res != cellhd.ns_res)
-	    G_fatal_error(_("Region resolution and map %s resolution differs. \
-		Run g.region rast=%s to set proper region resolution"),
-			  input_map_name, input_map_name);
+          G_fatal_error(_("Region resolution and raster map <%s> resolution differs. "
+                          "Run 'g.region rast=%s' to set proper region resolution."),
+                        input_map_name, input_map_name);
     /* checking if input map is of required type */
     if (check_data_type != map->data_type)
 	G_debug(1,
@@ -87,7 +87,7 @@
     input_data_type = Rast_map_type(input_map_name, mapset);
     if (check_data_type != -1)
 	if (input_data_type != check_data_type)
-	    G_fatal_error(_("<%s> is not of type %s"),
+	    G_fatal_error(_("Raster map <%s> is not of type '%s'"),
 			  input_map_name, maptypes[check_data_type]);
     input_map_fd = Rast_open_old(input_map_name, mapset);
@@ -117,7 +117,7 @@
     input_buffer = Rast_allocate_buf(input_data_type);
     /* start reading */
-    G_message(_("Reading map <%s>"), input_map_name);
+    G_message(_("Reading raster map <%s>..."), input_map_name);
     for (r = 0; r < map->nrows; ++r) {
 	G_percent(r, map->nrows, 2);
@@ -145,7 +145,7 @@
 					 input_data_type);
 		    break;
 		default:
-		    G_fatal_error(_("ram_open:Wrong internal data type"));
+		    G_fatal_error(_("Wrong internal data type"));
 		    break;
     }				/*end for r */
@@ -192,7 +192,7 @@
 	G_debug(1,
 		"ram_write:required map type and internal map type differs: conversion forced!");
-    G_message(_("Writing map <%s>"), output_map_name);
+    G_message(_("Writing raster map <%s>..."), output_map_name);
     output_fd = Rast_open_new(output_map_name, output_data_type);
     /* writing */
@@ -229,17 +229,17 @@
     Rast_short_history(output_map_name, "raster", &history);
     Rast_command_history(&history);
     Rast_write_history(output_map_name, &history);
-    G_message(_("<%s> Done"), output_map_name);
+    /* G_message(_("<%s> Done"), output_map_name); */
     return 0;
 int ram_release_map(MAP *map)
-     * free memory allocated for map, set pointer to null;
+   * free memory allocated for map, set pointer to null;
     int r;
 	G_free((map->map)[r]);
     G_free(map->map);
@@ -294,8 +294,8 @@
 	seg->data_size = sizeof(DCELL);
 	break;
     default:
-	G_fatal_error(_("seg_create: unrecognisabe data type"));
+	G_fatal_error(_("Unrecognisable data type"));
     filename = G_tempfile();
     fd = creat(filename, 0666);
@@ -305,18 +305,18 @@
 		       seg->data_size)) {
 	close(fd);
 	unlink(filename);
-	G_fatal_error(_("seg_create: cannot format segment"));
+	G_fatal_error(_("Unable to format segment"));
     close(fd);
     if (0 > (fd = open(filename, 2))) {
 	unlink(filename);
-	G_fatal_error(_("seg_create: cannot re-open file"));
+	G_fatal_error(_("Unable re-open file '%s'"), filename);
     if (0 > (fd = segment_init(&(seg->seg), fd, number_of_segs))) {
 	unlink(filename);
-	G_fatal_error(_("seg_create: cannot init segment file or out of memory"));
+	G_fatal_error(_("Unable to init segment file or out of memory"));
     seg->filename = G_store(filename);
@@ -351,7 +351,7 @@
     /* checking if map exist */
     mapset = (char *)G_find_raster2(input_map_name, "");
     if (mapset == NULL)
-	G_fatal_error(_("seg_read:Raster map <%s> not found"),
+	G_fatal_error(_("Raster map <%s> not found"),
 		      input_map_name);
     seg->mapset = mapset;
@@ -363,8 +363,8 @@
     if (check_res)
     if (check_data_type != seg->data_type)
@@ -373,7 +373,7 @@
     input_fd = Rast_open_old(input_map_name, mapset);
@@ -441,7 +441,7 @@
 	    G_free(input_buffer);
 	    G_free(target_buffer);
 	    Rast_close(input_fd);
-	    G_fatal_error(_("seg_read: Cannot segment put row %d for map %s"),
+	    G_fatal_error(_("Unable to segment put row %d for raster map <%s>"),
 			  r, input_map_name);
     }				/* end for row */
@@ -495,7 +495,7 @@
 	G_debug(1,
     output_buffer = Rast_allocate_buf(output_data_type);
     segment_flush(&(seg->seg));
@@ -505,7 +505,7 @@
 	G_percent(r, seg->nrows, 2);
 	if (0 > segment_get_row(&(seg->seg), output_buffer, r))
-	    G_warning(_("seg_write: Cannot segment read row %d for map %s"),
+	    G_warning(_("Unable to segment read row %d for raster map <%s>"),
 		      r, output_map_name);
 	if (convert_to_null) {
@@ -528,7 +528,7 @@
 			Rast_set_d_null_value(row + c * (seg->data_size), 1);
 		break;
 	    default:
-		G_warning(_("ram_null:Cannot convert to null at: %d %d"), r,
+		G_warning(_("Unable to convert to null at: %d %d"), r,
 			  c);
@@ -541,7 +541,7 @@
-    G_message(_("%s Done"), output_map_name);
+    /* G_message(_("%s Done"), output_map_name); */
     return 0;
Modified: grass-addons/grass7/raster/r.stream.basins/io.h
--- grass-addons/grass7/raster/r.stream.basins/io.h	2014-03-27 15:07:02 UTC (rev 59428)
+++ grass-addons/grass7/raster/r.stream.basins/io.h	2014-03-27 15:10:37 UTC (rev 59429)
@@ -56,4 +56,3 @@
 int seg_reset_map (SEG *, int);
 int seg_write_map(SEG *, char *, RASTER_MAP_TYPE, int, double);
 int seg_release_map(SEG *);
Modified: grass-addons/grass7/raster/r.stream.basins/local_vars.h
--- grass-addons/grass7/raster/r.stream.basins/local_vars.h	2014-03-27 15:07:02 UTC (rev 59428)
+++ grass-addons/grass7/raster/r.stream.basins/local_vars.h	2014-03-27 15:10:37 UTC (rev 59429)
@@ -32,9 +32,3 @@
 GLOBAL int nrows, ncols;
 GLOBAL int fifo_max;
 GLOBAL POINT* fifo_points;
Modified: grass-addons/grass7/raster/r.stream.basins/main.c
--- grass-addons/grass7/raster/r.stream.basins/main.c	2014-03-27 15:07:02 UTC (rev 59428)
+++ grass-addons/grass7/raster/r.stream.basins/main.c	2014-03-27 15:10:37 UTC (rev 59429)
@@ -5,17 +5,17 @@
  * PURPOSE:      Calculate basins according user' input data.
  *               It uses multiple type of inputs:
- * 							 r.stream.order, r.stream.extract or r.watershed stream  map
+ * 		 r.stream.order, r.stream.extract or r.watershed stream  map
  *               list of categoires to create basins (require stream map);
  *               vector file containing outputs;
  *               list of coordinates;
  *               with analogous  direction map;
- * COPYRIGHT:    (C) 2002,2010 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002,2010-2014 by the GRASS Development Team
  *               This program is free software under the GNU General Public
- *   	    	 	  License (>=v2). Read the file COPYING that comes with GRASS
- *   	    	 	  for details.
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
 #define MAIN
@@ -44,53 +44,51 @@
     G_gisinit(argv[0]);
     module = G_define_module();
-    module->description = _("Delineate basins according user' input. \
-	Input can be stream network, point file with outlets or outlet coordinates");
+    module->label = _("Delineates basins according stream network.");
+    module->description = _("Input can be stream network, vector point map  with outlets or outlet coordinates.");
     G_add_keyword(_("raster"));
     G_add_keyword(_("hydrology"));
-    G_add_keyword("basins creation");
+    G_add_keyword(_("stream network"));
+    G_add_keyword(_("basins creation"));
     in_dir_opt = G_define_standard_option(G_OPT_R_INPUT);	/* input direction file */
     in_dir_opt->key = "dirs";
-    in_dir_opt->description = _("Name of flow direction input map");
+    in_dir_opt->description = _("Name of input flow direction raster map");
-    in_coor_opt = G_define_option();	/* input coordinates of outlet */
-    in_coor_opt->key = "coors";
-    in_coor_opt->type = TYPE_STRING;
-    in_coor_opt->key_desc = "x,y";
-    in_coor_opt->answers = NULL;
+    in_coor_opt = G_define_standard_option(G_OPT_M_COORS);	/* input coordinates of outlet */
     in_coor_opt->required = NO;
     in_coor_opt->multiple = YES;
-    in_coor_opt->description = _("Basin's outlet's coordinates: E,N");
+    in_coor_opt->description = _("Basin's outlet's coordinates");
     in_stm_opt = G_define_standard_option(G_OPT_R_INPUT);	/* input stream file file */
     in_stm_opt->key = "streams";
     in_stm_opt->required = NO;
-    in_stm_opt->description = _("Name of stream mask input map");
+    in_stm_opt->description = _("Name of input stream mask raster map");
+    in_stm_opt->guisection = _("Input maps");
-    in_stm_cat_opt = G_define_option();	/* input stream category - optional */
-    in_stm_cat_opt->key = "cats";
-    in_stm_cat_opt->type = TYPE_STRING;
+    in_stm_cat_opt = G_define_standard_option(G_OPT_V_CATS);	/* input stream category - optional */
     in_stm_cat_opt->required = NO;
     in_stm_cat_opt->description =
-	_("Create basins only for these categories:");
+	_("Create basins only for these categories");
     in_point_opt = G_define_standard_option(G_OPT_V_INPUT);	/* input point outputs - optional */
     in_point_opt->key = "points";
     in_point_opt->required = NO;
-    in_point_opt->description = _("Name of vector points map");
+    in_point_opt->description = _("Name of input vector points map");
+    in_point_opt->guisection = _("Input maps");
     opt_swapsize = G_define_option();
     opt_swapsize->key = "memory";
     opt_swapsize->type = TYPE_INTEGER;
     opt_swapsize->answer = "300";
     opt_swapsize->description = _("Max memory used in memory swap mode (MB)");
-    opt_swapsize->guisection = _("Optional");
+    opt_swapsize->guisection = _("Memory settings");
     opt_basins = G_define_standard_option(G_OPT_R_OUTPUT);
     opt_basins->key = "basins";
-    opt_basins->description = _("Output basin map");
+    opt_basins->description = _("Name for output basin raster map");
+    opt_basins->guisection = _("Output maps");
     /*flags */
     flag_zerofill = G_define_flag();
     flag_zerofill->key = 'z';
@@ -109,7 +107,8 @@
     flag_segmentation = G_define_flag();
     flag_segmentation->key = 'm';
     flag_segmentation->description = _("Use memory swap (operation is slow)");
+    flag_segmentation->guisection = _("Memory settings");
     if (G_parser(argc, argv))	/* parser */
 	exit(EXIT_FAILURE);
@@ -122,7 +121,7 @@
 	G_fatal_error(_("One basin's outlet definition is required"));
     if (in_stm_cat_opt->answers && !in_stm_opt->answer)
-	G_fatal_error(_("If cats stream file is required"));
+        G_fatal_error(_("Option <%s> required"), in_stm_opt->key);
     if (in_coor_opt->answers)
 	b_test += 1;
@@ -137,16 +136,12 @@
     nrows = Rast_window_rows();
     ncols = Rast_window_cols();
-    if (G_legal_filename(opt_basins->answer) < 0)
-	G_fatal_error(_("<%s> is an illegal basin name"), opt_basins->answer);
     /* ALL IN RAM VERSION */
     if (!segmentation) {
 	MAP map_dirs, map_streams, map_basins;
 	CELL **streams = NULL, **dirs, **basins;
-	G_message("ALL IN RAM CALCULATION");
+	G_message("All in RAM calculation...");
 	ram_create_map(&map_dirs, CELL_TYPE);
 	ram_read_map(&map_dirs, in_dir_opt->answer, 1, CELL_TYPE);
@@ -155,12 +150,12 @@
 	switch (b_test) {
 	case 1:
-	    G_message("Calculate basins using coordinates...");
+	    G_message(_("Calculating basins using coordinates..."));
 	    outlets_num = process_coors(in_coor_opt->answers);
 	    break;
 	case 2:
-	    G_message("Calculate basins using streams...");
+	    G_message(_("Calculating basins using streams..."));
 	    ram_create_map(&map_streams, CELL_TYPE);
 	    ram_read_map(&map_streams, in_stm_opt->answer, 1, CELL_TYPE);
 	    streams = (CELL **) map_streams.map;
@@ -172,7 +167,7 @@
 	    break;
 	case 4:
-	    G_message("Calculate basins using point file...");
+	    G_message(_("Calculating basins using vector point map..."));
 	    outlets_num = process_vector(in_point_opt->answer);
 	    break;
@@ -201,8 +196,8 @@
 	SEGMENT *streams = NULL, *dirs, *basins;
 	int number_of_segs;
-	G_message("MEMORY SWAP CALCULATION: MAY TAKE SOME TIME!");
+        G_message(_("Memory swap calculation (may take some time)..."));
 	number_of_segs = (int)atof(opt_swapsize->answer);
 	number_of_segs = number_of_segs < 32 ? (int)(32 / 0.12) : number_of_segs / 0.12;
@@ -212,12 +207,12 @@
 	switch (b_test) {
 	case 1:
 	    break;
 	case 2:
 	    seg_create_map(&map_streams, SROWS, SCOLS, number_of_segs,
 			   CELL_TYPE);
 	    seg_read_map(&map_streams, in_stm_opt->answer, 1, CELL_TYPE);
@@ -230,7 +225,7 @@
 	    break;
 	case 4:
+	    G_message(_("Calculate basins using vector point map..."));
 	    break;
