[GRASS-SVN] r59448 - grass/trunk/raster/r.watershed/front
svn_grass at osgeo.org
Thu Mar 27 10:28:18 PDT 2014
Author: martinl
Date: 2014-03-27 10:28:18 -0700 (Thu, 27 Mar 2014)
New Revision: 59448
grass/trunk/raster/r.watershed/front/r.watershed.html
r.watershed: major manual update
options section removed
Modified: grass/trunk/raster/r.watershed/front/r.watershed.html
--- grass/trunk/raster/r.watershed/front/r.watershed.html 2014-03-27 17:16:46 UTC (rev 59447)
+++ grass/trunk/raster/r.watershed/front/r.watershed.html 2014-03-27 17:28:18 UTC (rev 59448)
@@ -1,11 +1,12 @@
<h2>DESCRIPTION</h2>
-<em>r.watershed</em> generates a set of maps indicating:
-1) flow accumulation, drainage direction, the location of streams and watershed basins, and
-2) the LS and S factors of the Revised Universal Soil Loss Equation (RUSLE).
+<em>r.watershed</em> generates a set of maps indicating: 1) flow
+accumulation, drainage direction, the location of streams and
+watershed basins, and 2) the LS and S factors of the Revised Universal
+Soil Loss Equation (RUSLE).
+<!-- Interactive mode not activated in GRASS 7.
<p>
-<!-- Interactive mode not activated in GRASS 7.
<em>r.watershed</em> can be run either interactively or non-interactively.
The interactive version of
<em>r.watershed</em> can prepare inputs to lumped-parameter hydrologic models.
@@ -17,355 +18,369 @@
<em>r.watershed</em> cannot create this file.
-<h2>OPTIONS</h2>
+<h2>NOTES</h2>
-<dl>
-<dt><em>-m</em>
+Without flag <b>-m</b> set, the entire analysis is run in memory
+maintained by the operating system. This can be limiting, but is very
+fast. Setting this flag causes the program to manage memory on disk
+which allows very large maps to be processed but is slower.
-<dd>Without this flag set, the entire analysis is run in memory
-maintained by the operating system. This can be limiting, but is
-very fast. Setting this flag causes the program to manage memory
-on disk which allows very large maps to be processed but is slower.
+<p>
+Flag <b>-s</b> force the module to use single flow direction (SFD, D8)
+instead of multiple flow direction (MFD). MFD is enabled by default.
-<dt><em>-s</em>
+<p>
+By <b>-4</b> flag the user allow only horizontal and vertical flow of
+water. Stream and slope lengths are approximately the same as outputs
+from default surface flow (allows horizontal, vertical, and diagonal
+flow of water). This flag will also make the drainage basins look
+more homogeneous.
-<dd>Use single flow direction (SFD, D8) instead of multiple flow direction (MFD).
-MFD is enabled by default.
-<dt><em>-4</em>
-<dd>Allow only horizontal and vertical flow of water.
-Stream and slope lengths are approximately the same as outputs from default
-surface flow (allows horizontal, vertical, and diagonal flow of water).
-This flag will also make the drainage basins look more homogeneous.
-<dt><em>-a</em>
-<dd>Use positive flow accumulation even for likely underestimates. When this
-flag is not set, cells with a flow accumulation value that is likely to be
-an underestimate are converted to the negative. See below for a detailed
+<p>
+When <b>-a</b> flag is specified the module will use positive flow
+accumulation even for likely underestimates. When this flag is not
+set, cells with a flow accumulation value that is likely to be an
+underestimate are converted to the negative. See below for a detailed
description of flow accumulation output.
-<dt><em>memory</em>
+<p>
+Option <b>convergence</b> specifies convergence factor for MFD. Lower
+values result in higher divergence, flow is more widely
+distributed. Higher values result in higher convergence, flow is less
+widely distributed, becoming more similar to SFD.
-<dd>Maximum amount of memory in MB to be used with -m set. More memory
-speeds up the processes.
+<p>
+Option <b>elevation</b> specifies the elevation data on which entire
+analysis is based. NULL (nodata) cells are ignored, zero and negative
+values are valid elevation data. Gaps in the elevation map that are
+located within the area of interest must be filled beforehand,
+e.g. with <em><a href="r.fillnulls.html">r.fillnulls</a></em>, to
+avoid distortions.
-<dt><em>convergence</em>
+<p>
+Map of actual depressions or sinkholes in the landscape that are large
+enough to slow and store surface runoff from a storm event. All cells
+that are not NULL and not zero indicate depressions. Water will flow
+into but not out of depressions.
-<dd>Convergence factor for MFD. Lower values result in higher divergence,
-flow is more widely distributed. Higher values result in higher convergence,
-flow is less widely distributed, becoming more similar to SFD.
+<p>
+Raster <b>flow</b> map specifies amount of overland flow per cell.
+This map indicates the amount of overland flow units that each cell
+will contribute to the watershed basin model. Overland flow units
+represent the amount of overland flow each cell contributes to surface
+flow. If omitted, a value of one (1) is assumed.
-<dt><em>elevation</em>
+<p>
+Input Raster map or value containing the percent of disturbed land
+(i.e., croplands, and construction sites) where the raster or input
+value of 17 equals 17%. If no map or value is
+given, <em>r.watershed</em> assumes no disturbed land. This input is
+used for the RUSLE calculations.
-<dd>Input map: Elevation on which entire analysis is based. NULL (nodata)
-cells are ignored, zero and negative values are valid elevation data.
-Gaps in the elevation map that are located within the area of interest
-must be filled beforehand, e.g. with <em>r.fillnulls</em>, to avoid
-distortions.
+<p>
+Option <b>blocking</b> specifies terrain that will block overland
+surface flow. errain that will block overland surface flow and
+restart the slope length for the RUSLE. All cells that are not NULL
+and not zero indicate blocking terrain.
-<dt><em>depression</em>
+<p>
+Option <b>threshold</b> specifies the minimum size of an exterior
+watershed basin in cells, if no flow map is input, or overland flow
+units when a flow map is given. Warning: low threshold values will
+dramactically increase run time and generate difficult to read basin
+and half_basin results. This parameter also controls the level of
+detail in the <b>stream</b> segments map.
-<dd>Input map: Map layer of actual depressions or sinkholes in the
-landscape that are large enough to slow and store surface runoff from
-a storm event. All cells that are not NULL and not zero indicate
-depressions. Water will flow into but not out of depressions.
+<p>
+Value given by <b>max_slope_length</b> option indicates the maximum
+length of overland surface flow in meters. If overland flow travels
+greater than the maximum length, the program assumes the maximum
+length (it assumes that landscape characteristics not discernible in
+the digital elevation model exist that maximize the slope length).
+This input is used for the RUSLE calculations and is a sensitive
+parameter.
-<dt><em>flow</em>
+<p>
+Output <b>accumulation</b> map contains the absolute value of each
+cell in this output map is the amount of overland flow that traverses
+the cell. This value will be the number of upland cells plus one if no
+overland flow map is given. If the overland flow map is given, the
+value will be in overland flow units. Negative numbers indicate that
+those cells possibly have surface runoff from outside of the current
+geographic region. Thus, any cells with negative values cannot have
+their surface runoff and sedimentation yields calculated accurately.
-<dd>Input map: amount of overland flow per cell. This map indicates the
-amount of overland flow units that each cell will contribute to the
-watershed basin model. Overland flow units represent the amount of
-overland flow each cell contributes to surface flow. If omitted, a
-value of one (1) is assumed.
+<p>
+Output <b>tci</b> raster map contains topographic index TCI is
+computed as
+<tt>ln(α / tan(β))</tt> where α a is the cumulative
+uplsope area draining through a point per unit contour length and
+<tt>tan(β)</tt> is the local slope angle. The TCI reflects the
+tendency of water to accumulate at any point in the catchment and the
+tendency for gravitaional forces to move that water downslope (Quinn
+et al. 1991). This value will be negative if <tt>α /
+tan(β) < 1</tt>.
-<dt><em>disturbed_land</em>
+<p>
+Output <b>drainage</b> raster map contains drainage direction.
+Provides the "aspect" for each cell measured CCW from East.
+Multiplying positive values by 45 will give the direction in degrees
+that the surface runoff will travel from that cell. The value 0
+(zero) indicates that the cell is a depression area (defined by the
+depression input map). Negative values indicate that surface runoff
+is leaving the boundaries of the current geographic region. The
+absolute value of these negative cells indicates the direction of
+flow.
-<dd>Raster map input layer or value containing the percent of disturbed
-land (i.e., croplands, and construction sites) where the raster or input
-value of 17 equals 17%. If no map or value is given, <em>r.watershed</em>
-assumes no disturbed land. This input is used for the RUSLE calculations.
+<p>
+The output <b>basin</b> map contains unique label for each watershed
+basin. Each basin will be given a unique positive even integer. Areas
+along edges may not be large enough to create an exterior watershed
+basin. 0 values indicate that the cell is not part of a complete
+watershed basin in the current geographic region.
-<dt><em>blocking</em>
+<p>
+The output <b>stream</b> contains stream segments. Values correspond
+to the watershed basin values. Can be vectorized after thinning
+(<em><a href="r.thin.html">r.thin</a></em>) with
+<em><a href="r.to.vect.html">r.to.vect</a></em>.
-<dd>Input map: terrain that will block overland surface flow. Terrain
-that will block overland surface flow and restart the slope length
-for the RUSLE. All cells that are not NULL and not zero indicate blocking
-terrain.
+<p>
+The output <b>half_basin</b> raster map stores each half-basin is
+given a unique value. Watershed basins are divided into left and right
+sides. The right-hand side cell of the watershed basin (looking
+upstream) are given even values corresponding to the values in basin.
+The left-hand side cells of the watershed basin are given odd values
+which are one less than the value of the watershed basin.
-<dt><em>threshold</em>
+<p>
+The output <b>length_slope</b> raster map stores slope length and
+steepness (LS) factor for the Revised Universal Soil Loss Equation
+(RUSLE). Equations taken from <em>Revised Universal Soil Loss
+Equation for Western Rangelands</em> (Weltz et al. 1987). Since the LS
+factor is a small number (usually less than one), the GRASS output map
+is of type DCELL.
-<dd>The minimum size of an exterior watershed basin in cells, if no flow
-map is input, or overland flow units when a flow map is given.
-Warning: low threshold values will dramactically increase run time and
-generate difficult to read basin and half_basin results.
-This parameter also controls the level of detail in the <em>stream</em>
-segments map.
-<dt><em>max_slope_length</em>
-<dd>Input value indicating the maximum length of overland surface flow
-in meters. If overland flow travels greater than the maximum length,
-the program assumes the maximum length (it assumes that landscape
-characteristics not discernible in the digital elevation model exist
-that maximize the slope length). This input is used for the RUSLE calculations
-and is a sensitive parameter.
-<dt><em>accumulation</em>
-<dd>Output map: The absolute value of each cell in this output map layer is
-the amount of overland flow that traverses the cell. This value will be
-the number of upland cells plus one if no overland flow map is given. If
-the overland flow map is given, the value will be in overland flow units.
-Negative numbers indicate that those cells possibly have surface runoff
-from outside of the current geographic region. Thus, any cells with
-negative values cannot have their surface runoff and sedimentation yields
-calculated accurately.
-<dt><em>tci</em>
-<dd>Output map: The topographic index TCI is computed as
-<em>ln(α / tan(β))</em> where α a is the cumulative
-uplsope area draining through a point per unit contour length and
-tan(β) is the local slope angle. The TCI reflects the tendency of
-water to accumulate at any point in the catchment and the tendency for
-gravitaional forces to move that water downslope (Quinn et al. 1991).
-This value will be negative if α / tan(β) < 1.
-<dt><em>drainage</em>
-<dd>Output map: drainage direction. Provides the "aspect" for each
-cell measured CCW from East. Multiplying positive values by 45 will give
-the direction in degrees that the surface runoff will travel from that
-cell. The value 0 (zero) indicates that the cell is a depression area
-(defined by the depression input map). Negative values indicate that
-surface runoff is leaving the boundaries of the current geographic
-region. The absolute value of these negative cells indicates the
-direction of flow.
-<dt><em>basin</em>
-<dd>Output map: Unique label for each watershed basin. Each basin will
-be given a unique positive even integer. Areas along edges may not
-be large enough to create an exterior watershed basin. 0 values
-indicate that the cell is not part of a complete watershed basin
-in the current geographic region.
-<dt><em>stream</em>
-<dd>Output map: stream segments. Values correspond to the watershed
-basin values. Can be vectorized after thinning (<em>r.thin</em>) with
-<em>r.to.vect</em>.
-<dt><em>half_basin</em>
-<dd>Output map: each half-basin is given a unique value. Watershed
-basins are divided into left and right sides. The right-hand side
-cell of the watershed basin (looking upstream) are given even values
-corresponding to the values in basin. The left-hand side
-cells of the watershed basin are given odd values which are one less
-than the value of the watershed basin.
-<dt><em>length_slope</em>
-<dd>Output map: slope length and steepness (LS) factor for the Revised
-Universal Soil Loss Equation (RUSLE). Equations taken from <em>Revised
-Universal Soil Loss Equation for Western Rangelands</em>
-(Weltz et al. 1987). Since the LS factor is a small number (usually less
-than one), the GRASS output map is of type DCELL.
-<dt><em>slope_steepness</em>
-<dd>Output map: slope steepness (S) factor for the Universal Soil
-Loss Equation (RUSLE). Equations taken from article entitled
+<p>
+The output <b>slope_steepness</b> raster map stores slope steepness
+(S) factor for the Universal Soil Loss Equation (RUSLE). Equations
+taken from article entitled
<em>Revised Slope Steepness Factor for the Universal Soil
Loss Equation</em> (McCool et al. 1987). Since the S factor is a small
number (usually less than one), the GRASS output map is of type DCELL.
-</dd>
-</dl>
+<h3>A<sup>T</sup> least-cost search algorithm</h3>
-<h2>NOTES</h2>
-<h3>A<sup>T</sup> least-cost search algorithm</h3>
-<em>r.watershed</em> uses an A<sup>T</sup> least-cost search algorithm
-(see <a href="#references">REFERENCES</a> section) designed to minimize
-the impact of DEM data errors. Compared to <em>r.terraflow</em>, this
-algorithm provides more accurate results in areas of low slope as well
-as DEMs constructed with techniques that mistake canopy tops as the
-ground elevation. Kinner et al. (2005), for example, used SRTM and IFSAR
-DEMs to compare <em>r.watershed</em> against <em>r.terraflow</em>
-results in Panama. <em>r.terraflow</em> was unable to replicate stream
-locations in the larger valleys while <em>r.watershed</em> performed
-much better. Thus, if forest canopy exists in valleys, SRTM, IFSAR, and
-similar data products will cause major errors in <em>r.terraflow</em>
-stream output. Under similar conditions, <em>r.watershed</em> will
-generate better <b>stream</b> and <b>half_basin</b> results. If
-watershed divides contain flat to low slope, <em>r.watershed</em>
-will generate better basin results than <em>r.terraflow</em>.
-(<em>r.terraflow</em> uses the same type of algorithm as ESRI's ArcGIS
-watershed software which fails under these conditions.) Also, if watershed
-divides contain forest canopy mixed with uncanopied areas using SRTM, IFSAR,
-and similar data products, <em>r.watershed</em> will generate better basin
-results than <em>r.terraflow</em>.
-The algorithm produces results similar to those obtained when running
+<em>r.watershed</em> uses an A<sup>T</sup> least-cost search algorithm
+(see REFERENCES section) designed to minimize the impact of DEM data
+errors. Compared
+to <em><a href="r.terraflow.html">r.terraflow</a></em>, this algorithm
+provides more accurate results in areas of low slope as well as DEMs
+constructed with techniques that mistake canopy tops as the ground
+elevation. Kinner et al. (2005), for example, used SRTM and IFSAR DEMs
+to compare <em>r.watershed</em>
+against <em><a href="r.terraflow.html">r.terraflow</a></em> results in
+Panama. <em><a href="r.terraflow.html">r.terraflow</a></em> was unable
+to replicate stream locations in the larger valleys
+while <em>r.watershed</em> performed much better. Thus, if forest
+canopy exists in valleys, SRTM, IFSAR, and similar data products will
+cause major errors in <em>r.terraflow</em> stream output. Under
+similar conditions, <em>r.watershed</em> will generate
+better <b>stream</b> and <b>half_basin</b> results. If watershed
+divides contain flat to low slope, <em>r.watershed</em> will generate
+better basin results
+than <em><a href="r.terraflow.html">r.terraflow</a></em>. (<em><a href="r.terraflow.html">r.terraflow</a></em>
+uses the same type of algorithm as ESRI's ArcGIS watershed software
+which fails under these conditions.) Also, if watershed divides
+contain forest canopy mixed with uncanopied areas using SRTM, IFSAR,
+and similar data products, <em>r.watershed</em> will generate better
+basin results
+than <em><a href="r.terraflow.html">r.terraflow</a></em>. The
+algorithm produces results similar to those obtained when running
<em><a href="r.cost.html">r.cost</a></em> and
-<em><a href="r.drain.html">r.drain</a></em> on every cell on the map.
+<em><a href="r.drain.html">r.drain</a></em> on every cell on the raster map.
<h3>Multiple flow direction (MFD)</h3>
-<em>r.watershed</em> offers two methods to calculate surface flow:
-single flow direction (SFD, D8) and multiple flow direction (MFD). With
-MFD, water flow is distributed to all neighbouring cells with lower
-elevation, using slope towards neighbouring cells as a weighing factor
-for proportional distribution. The A<sup>T</sup> least-cost path is
-always included. As a result, depressions and obstacles are traversed
-with a gracefull flow convergence before the overflow. The convergence
-factor causes flow accumulation to converge more strongly with higher
-values. The supported range is 1 to 10, recommended is a convergence
-factor of 5 (Holmgren, 1994). If many small sliver basins are created
-with MFD, setting the convergence factor to a higher value can reduce
-the amount of small sliver basins.
+<em>r.watershed</em> offers two methods to calculate surface flow:
+single flow direction (SFD, D8) and multiple flow direction
+(MFD). With MFD, water flow is distributed to all neighbouring cells
+with lower elevation, using slope towards neighbouring cells as a
+weighing factor for proportional distribution. The A<sup>T</sup>
+least-cost path is always included. As a result, depressions and
+obstacles are traversed with a gracefull flow convergence before the
+overflow. The convergence factor causes flow accumulation to converge
+more strongly with higher values. The supported range is 1 to 10,
+recommended is a convergence factor of 5 (Holmgren, 1994). If many
+small sliver basins are created with MFD, setting the convergence
+factor to a higher value can reduce the amount of small sliver basins.
<h3>In-memory mode and disk swap mode</h3>
There are two versions of this program: <em>ram</em> and <em>seg</em>.
<em>ram</em> is used by default, <em>seg</em> can be used by setting
-the <em>-m</em> flag.
-<br>
-The <em>ram</em> version requires a maximum of 31 MB of RAM for 1 million
-cells. Together with the amount of system memory (RAM) available, this
-value can be used to estimate whether the current region can be
-processed with the <em>ram</em> version.
-<br>
+the <b>-m</b> flag.
+<p>
+The <em>ram</em> version requires a maximum of 31 MB of RAM for 1
+million cells. Together with the amount of system memory (RAM)
+available, this value can be used to estimate whether the current
+region can be processed with the <em>ram</em> version.
+<p>
The <em>ram</em> version uses virtual memory managed by the operating
-system to store all the data structures and is faster than the <em>seg</em>
-version; <em>seg</em> uses the GRASS segmentation library which manages
-data in disk files. <em>seg</em> uses only as much system memory (RAM) as
-specified with the <em>memory</em> option, allowing other processes to
-operate on the same system, even when the current geographic region is huge.
-<br>
-Due to memory requirements of both programs, it is quite easy to run out of
-memory when working with huge map regions. If the <em>ram</em> version runs
-out of memory and the resolution size of the current geographic region
-cannot be increased, either more memory needs to be added to the computer,
-or the swap space size needs to be increased. If <em>seg</em> runs out of
-memory, additional disk space needs to be freed up for the program to run.
-The <em>r.terraflow</em> module was specifically designed with huge
-regions in mind and may be useful here as an alternative, although disk
-space requirements of <em>r.terraflow</em> are several times higher than
-of <em>seg</em>.
+system to store all the data structures and is faster than
+the <em>seg</em> version; <em>seg</em> uses the GRASS segmentation
+library which manages data in disk files. <em>seg</em> uses only as
+much system memory (RAM) as specified with the <b>memory</b> option,
+allowing other processes to operate on the same system, even when the
+current geographic region is huge.
+<p>
+Due to memory requirements of both programs, it is quite easy to run
+out of memory when working with huge map regions. If the <em>ram</em>
+version runs out of memory and the resolution size of the current
+geographic region cannot be increased, either more memory needs to be
+added to the computer, or the swap space size needs to be
+increased. If <em>seg</em> runs out of memory, additional disk space
+needs to be freed up for the program to run.
+The <em><a href="r.terraflow.html">r.terraflow</a></em> module was
+specifically designed with huge regions in mind and may be useful here
+as an alternative, although disk space requirements
+of <em><a href="r.terraflow.html">r.terraflow</a></em> are several times higher than of <em>seg</em>.
<h3>Large regions with many cells</h3>
-The upper limit of the <em>ram</em> version is 2 billion
-(2<sup>31</sup> - 1) cells, whereas the upper limit for the <em>seg</em>
-version is 9 billion billion (2<sup>63</sup> - 1) cells.<br>
-In some situations, the region size (number of cells) may be too large for
-the amount of time or memory available. Running <em>r.watershed</em> may
-then require use of a coarser resolution. To make the results more closely
-resemble the finer terrain data, create a map layer containing the
-lowest elevation values at the coarser resolution. This is done by:
-1) Setting the current geographic region equal to the elevation map
-layer with <em>g.region</em>, and 2) Use the <em>r.neighbors</em> or
-<em>r.resamp.stats</em> command to find the lowest value for an area
-equal in size to the desired resolution. For example, if the resolution
-of the elevation data is 30 meters and the resolution of the geographic
-region for <em>r.watershed</em> will be 90 meters: use the minimum
-function for a 3 by 3 neighborhood. After changing to the resolution at
-which <em>r.watershed</em> will be run, <em>r.watershed</em> should be run
-using the values from the <em>neighborhood</em> output map layer that
-represents the minimum elevation within the region of the coarser cell.
+The upper limit of the <em>ram</em> version is 2 billion
+(2<sup>31</sup> - 1) cells, whereas the upper limit for
+the <em>seg</em> version is 9 billion billion (2<sup>63</sup> - 1)
+cells.<br> In some situations, the region size (number of cells) may
+be too large for the amount of time or memory
+available. Running <em>r.watershed</em> may then require use of a
+coarser resolution. To make the results more closely resemble the
+finer terrain data, create a map layer containing the lowest elevation
+values at the coarser resolution. This is done by: 1) Setting the
+current geographic region equal to the elevation map layer
+with <em><a href="g.region.html">g.region</a></em>, and 2) Use
+the <em><a href="r.neighbors.html">r.neighbors</a></em> or
+<em><a href="r.resamp.stats.html">r.resamp.stats</a></em> command to
+find the lowest value for an area equal in size to the desired
+resolution. For example, if the resolution of the elevation data is 30
+meters and the resolution of the geographic region
+for <em>r.watershed</em> will be 90 meters: use the minimum function
+for a 3 by 3 neighborhood. After changing to the resolution at
+which <em>r.watershed</em> will be run, <em>r.watershed</em> should be
+run using the values from the <b>neighborhood</b> output map layer
+that represents the minimum elevation within the region of the coarser
+cell.
<h3>Basin threshold</h3>
-The minimum size of drainage basins, defined by the <em>threshold</em>
+The minimum size of drainage basins, defined by the <b>threshold</b>
parameter, is only relevant for those watersheds with a single stream
-having at least the <em>threshold</em> of cells flowing into it.
-(These watersheds are called exterior basins.)
-Interior drainage basins contain stream segments below multiple tributaries.
-Interior drainage basins can be of any size because the length of
-an interior stream segment is determined by the distance between the
-tributaries flowing into it.
+having at least the <b>threshold</b> of cells flowing into it.
+(These watersheds are called exterior basins.) Interior drainage
+basins contain stream segments below multiple tributaries. Interior
+drainage basins can be of any size because the length of an interior
+stream segment is determined by the distance between the tributaries
+flowing into it.
<h3>MASK and no data</h3>
-<p>
The <em>r.watershed</em> program does not require the user to have the
current geographic region filled with elevation values. Areas without
-elevation data (masked or NULL cells) are ignored. It is NOT necessary to
-create a raster map (or raster reclassification) named <tt>MASK</tt> for
-NULL cells. Areas without elevation data will be treated as if they are
-off the edge of the region. Such areas will reduce the memory necessary
-to run the program. Masking out unimportant areas can significantly
-reduce processing time if the watersheds of interest occupy a small
-percentage of the overall area.
+elevation data (masked or NULL cells) are ignored. It is NOT necessary
+to create a raster map (or raster reclassification)
+named <tt>MASK</tt> for NULL cells. Areas without elevation data will
+be treated as if they are off the edge of the region. Such areas will
+reduce the memory necessary to run the program. Masking out
+unimportant areas can significantly reduce processing time if the
+watersheds of interest occupy a small percentage of the overall area.
<p>
-Gaps (NULL cells) in the elevation map that are located within the area
-of interest will heavily influence the analysis: water will
-flow into but not out of these gaps. These gaps must be filled beforehand,
-e.g. with <em>r.fillnulls</em>.
+Gaps (NULL cells) in the elevation map that are located within the
+area of interest will heavily influence the analysis: water will flow
+into but not out of these gaps. These gaps must be filled beforehand,
+e.g. with <em><a href="r.fillnulls.html">r.fillnulls</a></em>.
<p>
-Zero (0) and negative values will be treated as elevation data (not no_data).
+Zero (0) and negative values will be treated as elevation data (not
+no_data).
<h3>Further processing of output layers</h3>
-<p>
-Problem areas, i.e. those parts of a basin with a likely underestimate of
-flow accumulation, can be easily identified with e.g.
+Problem areas, i.e. those parts of a basin with a likely underestimate
+of flow accumulation, can be easily identified with e.g.
<div class="code"><pre>
r.mapcalc "problems = if(flow_acc < 0, basin, null())"
</pre></div>
If the region of interest contains such problem areas, and this is not
desired, the computational region must be expanded until the catchment
area for the region of interest is completely included.
<p>
-To isolate an individual river network using the output of this module,
-a number of approaches may be considered.
+To isolate an individual river network using the output of this
+module, a number of approaches may be considered.
<ol>
<li>Use a resample of the basins catchment raster map as a MASK.<br>
- The equivalent vector map method is similar using <em>v.select</em> or
- <em>v.overlay</em>.
-<li>Use the <em>r.cost</em> module with a point in the river as a starting
- point.
-<li>Use the <em>v.net.iso</em> module with a node in the river as a
- starting point.
+ The equivalent vector map method is similar
+ using <em><a href="v.select.html">v.select</a></em> or
+ <em><a href="v.overlay.html">v.overlay</a></em>.
+<li>Use the <em><a href="r.cost.html">r.cost</a></em> module with a
+ point in the river as a starting point.
+<li>Use the <em><a href="v.net.iso.html">v.net.iso</a></em> module
+ with a node in the river as a starting point.
</ol>
All individual river networks in the stream segments output can be
identified through their ultimate outlet points. These points are all
cells in the stream segments output with negative drainage direction.
-These points can be used as start points for <em>r.water.outlet</em> or
-<em>v.net.iso</em>.
+These points can be used as start points
+for <em><a href="r.water.outlet.html">r.water.outlet</a></em> or
+<em><a href="v.net.iso.html">v.net.iso<a/></em>.
<p>
-To create <i>river mile</i> segmentation from a vectorized streams map,
-try the <em>v.net.iso</em> or <em>v.lrs.segment</em> modules.
+To create <i>river mile</i> segmentation from a vectorized streams
+map, try
+the <em><a href="v.net.iso.html">v.net.iso<a/></em>or <em><a href="v.lrs.segment.html">v.lrs.segment</a></em>
+modules.
<p>
-The stream segments output can be easily vectorized after thinning with
-<em>r.thin</em>. Each stream segment in the vector map will have the
-value of the associated basin. To isolate subbasins and streams for a
-larger basin, a MASK for the larger basin can be created with
-<em>r.water.outlet</em>. The stream segments output serves as a guide
-where to place the outlet point used as input to <em>r.water.outlet</em>.
-The basin threshold must have been sufficiently small to isolate a
+The stream segments output can be easily vectorized after thinning
+with
+<em><a href="r.thin.html">r.thin</a></em>. Each stream segment in the
+vector map will have the value of the associated basin. To isolate
+subbasins and streams for a larger basin, a MASK for the larger basin
+can be created with
+<em><a href="r.water.outlet.html">r.water.outlet</a></em>. The stream
+segments output serves as a guide where to place the outlet point used
+as input to <em><a href="r.water.outlet.html">r.water.outlet</a></em>.
+The basin threshold must have been sufficiently small to isolate a
stream network and subbasins within the larger basin.
<h2>EXAMPLES</h2>
-<i>These examples use the Spearfish sample dataset.</i>
-<p>
-Convert <em>r.watershed</em> streams map output to a vector layer.
-<p>
-If you want a detailed stream network, set the threshold option
-small to create lots of catchment basins, as only one stream is
-presented per catchment. The r.to.vect -v flag preserves the
-catchment ID as the vector category number.
+These examples use the Spearfish sample dataset.
+<h3>Convert <em>r.watershed</em> streams map output to a vector map</h3>
+If you want a detailed stream network, set the threshold option small
+to create lots of catchment basins, as only one stream is presented
+per catchment. The <tt>r.to.vect -v</tt> flag preserves the catchment
+ID as the vector category number.
r.watershed elev=elevation.dem stream=rwater.stream
r.to.vect -v in=rwater.stream out=rwater_stream
</pre></div>
-<br>
<p>
Set a different color table for the accumulation map:
MAP=rwater.accum
r.watershed elev=elevation.dem accum=$MAP
@@ -388,15 +403,15 @@
100% red
EOF
</pre></div>
-<br>
+<p>
+Create a more detailed stream map using the accumulation map and
+convert it to a vector output map. The accumulation cut-off, and
+therefore fractal dimension, is arbitrary; in this example we use the
+map's mean number of upstream catchment cells (calculated in the above
+example by <em><a href="r.univar.html">r.univar</a></em>) as the
+cut-off value. This only works with SFD, not with MFD.
-<p>
-Create a more detailed stream map using the accumulation map and convert
-it to a vector output map. The accumulation cut-off, and therefore fractal
-dimension, is arbitrary; in this example we use the map's mean number of
-upstream catchment cells (calculated in the above example by <em>r.univar</em>)
-as the cut-off value. This only works with SFD, not with MFD.
r.watershed elev=elevation.dem accum=rwater.accum
@@ -414,22 +429,21 @@
r.to.vect in=rwater.course.Thin out=rwater_course type=line
v.db.dropcolumn map=rwater_course column=label
</pre></div>
<!-- can't set line attribute to catchment it is in as v.what.rast and
v.distance only work for point features. Could create endpoint node
points map and upload to that ?? -->
<!-- Note value column containing accumulation cells in output vector
may not necessarily reference the downstream end of the line! drop it? -->
-<br>
-<p>
-Create watershed basins map and convert to a vector polygon map
+<h3>Create watershed basins map and convert to a vector polygon map</h3>
r.watershed elev=elevation.dem basin=rwater.basin thresh=15000
r.to.vect -s in=rwater.basin out=rwater_basins type=area
v.db.dropcolumn map=rwater_basins column=label
v.db.renamecolumn map=rwater_basins column=value,catchment
</pre></div>
-<br>
<p>
Display output in a nice way
@@ -438,61 +452,54 @@
d.shadedmap rel=elevation.dem.shade drape=rwater.basin bright=40
d.vect rwater_course color=orange
</pre></div>
-<br>
-<a name="references"></a>
<h2>REFERENCES</h2>
-Ehlschlaeger C. (1989). <i>Using the A<sup>T</sup> Search Algorithm
+<ul>
+<li>Ehlschlaeger C. (1989). <i>Using the A<sup>T</sup> Search Algorithm
to Develop Hydrologic Models from Digital Elevation Data</i>,
<b>Proceedings of International Geographic Information Systems (IGIS)
Symposium '89</b>, pp 275-281 (Baltimore, MD, 18-19 March 1989).<br>
URL: <a href="http://chuck.ehlschlaeger.info/older/IGIS/paper.html">
http://chuck.ehlschlaeger.info/older/IGIS/paper.html</a>
-<p>
-Holmgren P. (1994). <i>Multiple flow direction algorithms for runoff
+<li>Holmgren P. (1994). <i>Multiple flow direction algorithms for runoff
modelling in grid based elevation models: An empirical evaluation.</i>
<b>Hydrological Processes</b> Vol 8(4), 327-334.<br>
DOI: <a href="http://dx.doi.org/10.1002/hyp.3360080405">10.1002/hyp.3360080405</a>
-<p>
-Kinner D., Mitasova H., Harmon R., Toma L., Stallard R. (2005).
+<li>Kinner D., Mitasova H., Harmon R., Toma L., Stallard R. (2005).
<i>GIS-based Stream Network Analysis for The Chagres River Basin,
Republic of Panama</i>. <b>The Rio Chagres: A Multidisciplinary Profile of
a Tropical Watershed</b>, R. Harmon (Ed.), Springer/Kluwer, p.83-95.<br>
URL: <a href="http://www4.ncsu.edu/~hmitaso/measwork/panama/panama.html">
http://www4.ncsu.edu/~hmitaso/measwork/panama/panama.html</a>
-<p>
-McCool et al. (1987). <i>Revised Slope Steepness Factor for the Universal
+<li>McCool et al. (1987). <i>Revised Slope Steepness Factor for the Universal
Soil Loss Equation</i>, <b>Transactions of the ASAE</b> Vol 30(5).
-<p>
-Metz M., Mitasova H., Harmon R. (2011). <i>Efficient extraction of
+<li>Metz M., Mitasova H., Harmon R. (2011). <i>Efficient extraction of
drainage networks from massive, radar-based elevation models with least
cost path search</i>, <b>Hydrol. Earth Syst. Sci.</b> Vol 15, 667-678.<br>
DOI: <a href="http://dx.doi.org/10.5194/hess-15-667-2011">10.5194/hess-15-667-2011</a>
-<p>
-Quinn P., K. Beven K., Chevallier P., Planchon O. (1991). <i>The
+<li>Quinn P., K. Beven K., Chevallier P., Planchon O. (1991). <i>The
prediction of hillslope flow paths for distributed hydrological modelling
using Digital Elevation Models</i>, <b>Hydrological Processes</b> Vol 5(1),
p.59-79.<br>
DOI: <a href="http://dx.doi.org/10.1002/hyp.3360050106">10.1002/hyp.3360050106</a>
-<p>
-Weltz M. A., Renard K.G., Simanton J. R. (1987). <i>Revised Universal Soil
+<li>Weltz M. A., Renard K.G., Simanton J. R. (1987). <i>Revised Universal Soil
Loss Equation for Western Rangelands</i>, <b>U.S.A./Mexico Symposium of
Strategies for Classification and Management of Native Vegetation for
Food Production In Arid Zones</b> (Tucson, AZ, 12-16 Oct. 1987).
+</li>
+</ul>
-<a name="seealso"></a>
<h2>SEE ALSO</h2>
<em>
-<a href="g.region.html">g.region</a>,
+ <a href="g.region.html">g.region</a>,
<a href="r.cost.html">r.cost</a>,
<a href="r.drain.html">r.drain</a>,
<a href="r.fillnulls.html">r.fillnulls</a>,
