[GRASS-SVN] r59453 - grass/trunk/gui/wxpython/rlisetup
svn_grass at osgeo.org
Thu Mar 27 11:06:44 PDT 2014
Author: lucadelu
Date: 2014-03-27 11:06:43 -0700 (Thu, 27 Mar 2014)
New Revision: 59453
grass/trunk/gui/wxpython/rlisetup/wizard.py
g.gui.rlisetup: add some checks about user choose, PEP8 cleaning
Modified: grass/trunk/gui/wxpython/rlisetup/wizard.py
--- grass/trunk/gui/wxpython/rlisetup/wizard.py 2014-03-27 18:03:21 UTC (rev 59452)
+++ grass/trunk/gui/wxpython/rlisetup/wizard.py 2014-03-27 18:06:43 UTC (rev 59453)
@@ -329,7 +329,6 @@
##KUNITSC = samplingtype=units, regionbox=keyboard, shape=cirlce
##KUNITSR = samplingtype=units, regionbox=keyboard, shape=rectangle
elif samtype == SamplingType.KUNITSC or samtype == SamplingType.KUNITSR:
if samtype == SamplingType.KUNITSC:
self._circle(self.units.width, self.units.height)
cl = float(self.CIR_CL) / float(self.rasterinfo['cols'])
@@ -915,9 +914,6 @@
def RegionDraw(self, regtype):
"""!Set the next page to units or drawunits"""
- #TODO add only to commit the last changes, remove after more testing
-# if self.radioBox.GetSelection() == 2:
-# self.regionBox.EnableItem(1, False)
if regtype == 0:
self.regionbox = 'keyboard'
if self.samplingtype == SamplingType.UNITS:
@@ -958,8 +954,11 @@
if self.regioncount > numregions:
wx.FindWindowById(wx.ID_FORWARD).Enable(True)
+ self.parent.wizard.ShowPage(self.parent.summarypage)
else:
- self.title.SetLabel(_('Draw sample region ' + str(self.regioncount) + ' of ' + str(numregions) ))
+ self.title.SetLabel(_('Draw sample region ' + \
+ str(self.regioncount) + ' of ' + \
+ str(numregions)))
wx.FindWindowById(wx.ID_FORWARD).Enable(False)
def OnEnterPage(self, event):
@@ -1020,7 +1019,8 @@
self.typeBox = wx.RadioBox(parent=self.scrollPanel, id=wx.ID_ANY,
majorDimension=1, style=wx.RA_SPECIFY_COLS,
label=" %s " % _("Select type of shape"),
- choices=[_('Rectangle'), _('Circle')])
+ choices=[_('Rectangle'), _('Circle'),
+ ('None')])
self.panelSizer.Add(self.typeBox, flag=wx.ALIGN_LEFT, pos=(0, 0),
span=(1, 2))
@@ -1096,6 +1096,9 @@
def OnEnterPage(self, event=None):
"""!Function during entering"""
+ # This is an hack to force the user to choose Rectangle or Circle
+ self.typeBox.SetSelection(2),
+ self.typeBox.ShowItem(2, False)
self.panelSizer.Layout()
def OnExitPage(self, event=None):
@@ -1180,7 +1183,8 @@
# type of shape
self.typeBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
- choices=[_('Rectangle'), _('Circle')],
+ ('None')],
majorDimension=1,
style=wx.RA_SPECIFY_COLS)
@@ -1213,6 +1217,9 @@
self.heightTxt.Bind(wx.EVT_TEXT, self.OnHeight)
if self.parent.samplingareapage.samplingtype == SamplingType.MVWIN:
self.title.SetLabel(_("Set moving windows"))
self.OnType(None)
@@ -1257,8 +1264,10 @@
+ choices=[_('Rectangle'), _('Circle'), ('')])
self.sizer.Add(self.typeBox, flag=wx.ALIGN_LEFT, pos=(0, 0),
span=(1, 2))
@@ -1303,6 +1312,8 @@
SamplingType.MUNITSC]:
self.title.SetLabel(_("Draw sampling region"))
self.sizer.Show(self.regionNumPanel)
+ if self.typeBox.GetSelection() == 2:
+ wx.FindWindowById(wx.ID_FORWARD).Enable(False)
self.sizer.Layout()
def OnType(self, event):
@@ -1312,6 +1323,7 @@
SamplingType.MMVWINR,
SamplingType.MMVWINC]:
self.parent.samplingareapage.samplingtype = SamplingType.MMVWINR
+ wx.FindWindowById(wx.ID_FORWARD).Enable(True)
else:
self.parent.samplingareapage.samplingtype = SamplingType.MUNITSR
self.drawtype = 'rectangle'
@@ -1320,6 +1332,7 @@
self.parent.samplingareapage.samplingtype = SamplingType.MMVWINC
else:
self.parent.samplingareapage.samplingtype = SamplingType.MUNITSC
self.drawtype = 'circle'
@@ -1358,11 +1371,12 @@
drawtype = self.parent.drawunits.drawtype
if self.regioncount > self.numregions:
else:
- self.title.SetLabel(_('Draw Sampling ' + drawtype + ' ' \
+ self.title.SetLabel(_('Draw Sampling ' + drawtype + ' ' \
+ str(self.regioncount) + ' of ' \
- + str(self.numregions) ))
- wx.FindWindowById(wx.ID_FORWARD).Enable(False)
+ + str(self.numregions)))
@@ -1372,11 +1386,11 @@
SamplingType.MMVWINR]:
self.numregions = 1
else:
- self.numregions = int(self.parent.drawunits.numregions)
+ self.numregions = int(self.parent.drawunits.numregions)
self.regioncount = 0
if self.mapPanel:
self.sizer.Remove(self.mapPanel)
gtype = self.parent.drawunits.drawtype
self.mapPanel = RLiSetupMapPanel(self,
samplingType=self.parent.samplingareapage.samplingtype,
@@ -1660,7 +1674,7 @@
self.regionkeytxt.SetLabel("")
if self.parent.samplingareapage.samplingtype == SamplingType.UNITS \
- and self.parent.samplingareapage.regionbox=='keyboard':
+ and self.parent.samplingareapage.regionbox == 'keyboard':
self.shapelabel.SetLabel(_('Type of shape:'))
self.shapetxt.SetLabel(self.parent.units.boxtype)
if self.parent.units.boxtype == 'circle':
