[GRASS-SVN] r59508 - grass-addons/grass7/raster/r.basin
svn_grass at osgeo.org
Sat Mar 29 08:47:13 PDT 2014
Author: madi
Date: 2014-03-29 08:47:13 -0700 (Sat, 29 Mar 2014)
New Revision: 59508
grass-addons/grass7/raster/r.basin/r.basin.py
Update r.basin according to unified r.stream.* syntax
Modified: grass-addons/grass7/raster/r.basin/r.basin.py
--- grass-addons/grass7/raster/r.basin/r.basin.py 2014-03-29 00:12:48 UTC (rev 59507)
+++ grass-addons/grass7/raster/r.basin/r.basin.py 2014-03-29 15:47:13 UTC (rev 59508)
@@ -138,10 +138,10 @@
# Stream extraction
#### check if we have the r.stream.extract addon
- if not grass.find_program('r.stream.extract', '--help'):
- grass.fatal(_("The 'r.stream.extract' module was not found, install it first:") +
- "\n" +
- "g.extension r.stream.extract")
+ ##if not grass.find_program('r.stream.extract', '--help'):
+ ##grass.fatal(_("The 'r.stream.extract' module was not found, install it first:") +
+ ##"\n" +
+ ##"g.extension r.stream.extract")
grass.run_command('r.stream.extract', elevation = r_elevation,
accumulation = r_accumulation,
@@ -161,9 +161,9 @@
"\n" +
"g.extension r.stream.basins")
- grass.run_command('r.stream.basins', dir = r_drainage,
+ grass.run_command('r.stream.basins', direction = r_drainage,
basins = r_basin,
- coors = '%s' % (coordinates),
+ coordinates = '%s' % (coordinates),
overwrite = True)
grass.message( "Delineation of basin done" )
@@ -272,12 +272,13 @@
grass.message( "Creating %s" % r_hack )
#### check if we have the r.stream.order addon
- if not grass.find_program('r.stream.order', '--help'):
- grass.fatal(_("The 'r.stream.order' module was not found, install it first:") +
- "\n" +
- "g.extension r.stream.order")
- grass.run_command('r.stream.order', stream = r_stream_e,
- dir = r_drainage_e,
+ ##if not grass.find_program('r.stream.order', '--help'):
+ ##grass.fatal(_("The 'r.stream.order' module was not found, install it first:") +
+ ##"\n" +
+ ##"g.extension r.stream.order")
+ grass.run_command('r.stream.order', stream_rast = r_stream_e,
+ direction = r_drainage_e,
strahler = r_strahler,
shreve = r_shreve,
horton = r_horton,
@@ -302,12 +303,13 @@
overwrite = True)
#### check if we have the r.stream.distance addon
- if not grass.find_program('r.stream.distance', '--help'):
- grass.fatal(_("The 'r.stream.distance' module was not found, install it first:") +
- "\n" +
- "g.extension r.stream.distance")
- grass.run_command('r.stream.distance', stream = r_outlet,
- dir = r_drainage,
+ ##if not grass.find_program('r.stream.distance', '--help'):
+ ##grass.fatal(_("The 'r.stream.distance' module was not found, install it first:") +
+ ##"\n" +
+ ##"g.extension r.stream.distance")
+ grass.run_command('r.stream.distance', stream_raster = r_outlet,
+ direction = r_drainage,
flags = 'o',
distance = r_distance,
overwrite = True)
@@ -343,22 +345,22 @@
# Creation of map of hillslope distance to river network
- grass.run_command("r.stream.distance", stream = r_stream_e,
- dir = r_drainage,
- elevation = 'r_elevation_crop' ,
+ grass.run_command("r.stream.distance", stream_rast = r_stream_e,
+ elevation = 'r_elevation_crop',
distance = r_hillslope_distance,
overwrite = True)
# Mean elevation
- grass.run_command("r.statistics2", base = r_basin,
+ grass.run_command("r.stats.zonal", base = r_basin,
cover = "r_elevation_crop",
method = "average",
output = r_height_average,
overwrite = True)
- grass.message("r.statistics2 done")
+ grass.message("r.stats.zonal done")
mean_elev = float(grass.read_command('r.info', flags = 'r',
map = r_height_average).split('\n')[0].split('=')[1])
grass.message("r.info done")
@@ -523,7 +525,7 @@
t_c = ((4 * math.sqrt(area_basin)) + (1.5 * mainchannel)) / (0.8 * math.sqrt(HM))
# Mean hillslope length
- grass.run_command("r.statistics2", cover = r_stream_e,
+ grass.run_command("r.stats.zonal", cover = r_stream_e,
base = r_mask,
method = "average",
output = r_average_hillslope,
@@ -553,12 +555,13 @@
# Statistics
#### check if we have the r.stream.stats addon
- if not grass.find_program('r.stream.stats', '--help'):
- grass.fatal(_("The 'r.stream.stats' module was not found, install it first:") +
- "\n" +
- "g.extension r.stream.stats")
- stream_stats = grass.read_command('r.stream.stats', stream = r_strahler,
+ ##if not grass.find_program('r.stream.stats', '--help'):
+ ##grass.fatal(_("The 'r.stream.stats' module was not found, install it first:") +
+ ##"\n" +
+ ##"g.extension r.stream.stats")
+ stream_stats = grass.read_command('r.stream.stats', stream_rast = r_strahler,
elevation = 'r_elevation_crop' )
