[GRASS-SVN] r59516 - grass/trunk/gui/wxpython/modules
svn_grass at osgeo.org
Sat Mar 29 15:57:01 PDT 2014
Author: annakrat
Date: 2014-03-29 15:57:01 -0700 (Sat, 29 Mar 2014)
New Revision: 59516
grass/trunk/gui/wxpython/modules/mcalc_builder.py
wxGUI/mapcalc: add copy button and show overwrite flag in command
Modified: grass/trunk/gui/wxpython/modules/mcalc_builder.py
--- grass/trunk/gui/wxpython/modules/mcalc_builder.py 2014-03-29 21:59:02 UTC (rev 59515)
+++ grass/trunk/gui/wxpython/modules/mcalc_builder.py 2014-03-29 22:57:01 UTC (rev 59516)
@@ -147,6 +147,8 @@
self.btn_load = wx.Button(parent = self.panel, id = wx.ID_ANY,
label = _("&Load"))
self.btn_load.SetToolTipString(_('Load expression from file'))
+ self.btn_copy = wx.Button(parent=self.panel, id=wx.ID_COPY)
+ self.btn_copy.SetToolTipString(_("Copy the current command string to the clipboard"))
self.btn = dict()
self.btn['pow'] = wx.Button(parent = self.panel, id = wx.ID_ANY, label = "^")
@@ -253,12 +255,14 @@
self.btn_help.Bind(wx.EVT_BUTTON, self.OnHelp)
self.btn_save.Bind(wx.EVT_BUTTON, self.OnSaveExpression)
self.btn_load.Bind(wx.EVT_BUTTON, self.OnLoadExpression)
+ self.btn_copy.Bind(wx.EVT_BUTTON, self.OnCopy)
self.mapselect.Bind(wx.EVT_TEXT, self.OnSelectTextEvt)
self.function.Bind(wx.EVT_COMBOBOX, self._return_funct)
self.function.Bind(wx.EVT_TEXT_ENTER, self.OnSelect)
self.newmaptxt.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
self.text_mcalc.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
+ self.overwrite.Bind(wx.EVT_CHECKBOX, self.OnUpdateStatusBar)
self._layout()
@@ -335,6 +339,8 @@
flag = wx.ALL, border = 5)
buttonSizer4.Add(item = self.btn_save,
+ buttonSizer4.Add(item = self.btn_copy,
+ flag = wx.ALL, border = 5)
buttonSizer4.AddSpacer(30)
buttonSizer4.Add(item = self.btn_help,
@@ -442,14 +448,23 @@
def OnUpdateStatusBar(self, event):
"""!Update statusbar text"""
+ command = self._getCommand()
+ self.SetStatusText(command)
+ event.Skip()
+ def _getCommand(self):
+ """!Returns entire command as string."""
expr = self.text_mcalc.GetValue().strip().replace("\n", " ")
cmd = 'r.mapcalc'
if self.rast3d:
cmd = 'r3.mapcalc'
- self.SetStatusText("{cmd} '{new} = {expr}'".format(cmd=cmd, expr=expr,
- new=self.newmaptxt.GetValue()))
- event.Skip()
+ overwrite = ''
+ if self.overwrite.IsChecked():
+ overwrite = ' --overwrite'
+ return '{cmd} "{new} = {expr}"{overwrite}'.format(cmd=cmd, expr=expr,
+ new=self.newmaptxt.GetValue(),
+ overwrite=overwrite)
def _addSomething(self, what):
"""!Inserts operators, map names, and functions into text area
@@ -583,7 +598,16 @@
self.text_mcalc.SetInsertionPointEnd()
dlg.Destroy()
+ def OnCopy(self, event):
+ cmddata = wx.TextDataObject()
+ cmddata.SetText(command)
+ if wx.TheClipboard.Open():
+ wx.TheClipboard.SetData(cmddata)
+ wx.TheClipboard.Close()
+ self.SetStatusText(_("'{cmd}' copied to clipboard").format(cmd=command))
def OnClear(self, event):
"""!Clears text area
