[GRASS-SVN] r59520 - in grass/branches/releasebranch_7_0: locale/po raster/r.stream.channel raster/r.stream.distance raster/r.stream.order raster/r.stream.segment raster/r.stream.snap raster/r.stream.stats
svn_grass at osgeo.org
Sun Mar 30 01:37:54 PDT 2014
Author: neteler
Date: 2014-03-30 01:37:54 -0700 (Sun, 30 Mar 2014)
New Revision: 59520
grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po
grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po
grass/branches/releasebranch_7_0/locale/po/grassmods_de.po
grass/branches/releasebranch_7_0/locale/po/grassmods_el.po
grass/branches/releasebranch_7_0/locale/po/grassmods_es.po
grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po
grass/branches/releasebranch_7_0/locale/po/grassmods_it.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po
grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po
grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po
grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po
grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po
grass/branches/releasebranch_7_0/locale/po/grassmods_th.po
grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po
grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po
grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po
grass/branches/releasebranch_7_0/raster/r.stream.channel/main.c
grass/branches/releasebranch_7_0/raster/r.stream.distance/main.c
grass/branches/releasebranch_7_0/raster/r.stream.order/main.c
grass/branches/releasebranch_7_0/raster/r.stream.segment/main.c
grass/branches/releasebranch_7_0/raster/r.stream.snap/main.c
grass/branches/releasebranch_7_0/raster/r.stream.stats/main.c
r.stream.order: fix msg wording (trac #2238)
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ar.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1173,7 +1173,7 @@
#: ../raster/r.stream.stats/main.c:60 ../raster/r.stream.channel/main.c:64
#: ../raster/r.stream.order/main.c:32
#, fuzzy
-msgid "Name of input streams mask raster map"
+msgid "Name for input raster map with stream network"
msgstr "اسÙ
Ø§ÙØ®Ø±Ùطة Ø§ÙØ±Ø§Ø³ØªØ±ÙØ© اÙÙ
Ø¯Ø®ÙØ©"
#: ../raster/r.stream.snap/main.c:64 ../raster/r.stream.snap/main.c:70
@@ -9312,7 +9312,7 @@
#: ../raster/r.stream.distance/main.c:60
#, fuzzy
-msgid "Name of input streams (outlets) mask raster map"
msgstr "اسÙ
اÙÙ
ÙÙ Ø§ÙØ±Ø§Ø³ØªØ±Ù Ø§ÙØ¬Ø¯Ùد"
#: ../raster/r.stream.distance/main.c:72
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_cs.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1177,7 +1177,7 @@
#, fuzzy
msgstr "Název vstupnà rastrové mapy"
@@ -9486,7 +9486,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_de.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_de.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_de.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1155,7 +1155,7 @@
#, fuzzy
msgstr "Name der Eingabe-Rasterkarte."
@@ -8898,7 +8898,7 @@
#, fuzzy
msgstr "Rasterkarte mit Informationen zu dem FlieÃgewässersystem."
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_el.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_el.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_el.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1152,7 +1152,7 @@
#, fuzzy
msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
@@ -8976,7 +8976,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_es.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_es.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_es.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1186,7 +1186,7 @@
#, fuzzy
msgstr "Nombre del mapa ráster de entrada"
@@ -9537,7 +9537,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_fr.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1208,7 +1208,7 @@
#, fuzzy
msgstr "Nom du nouveau fichier raster"
@@ -10000,7 +10000,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_it.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_it.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_it.po 2014-03-30 08:37:54 UTC (rev 59520)
#, fuzzy
msgstr "Nome della mappa raster d'inserimento dati"
@@ -9404,7 +9404,7 @@
# codificato/classificato
#, fuzzy
msgstr "Nome della mappa raster di input del reticolo idrografico codificato"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ja.po 2014-03-30 08:37:54 UTC (rev 59520)
#, fuzzy
msgstr "å
¥åã©ã¹ã¿ã¼ãããå"
@@ -9331,7 +9331,7 @@
#, fuzzy
msgstr "å
¥åã©ã¹ã¿ã¼ãããå"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ko.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1146,7 +1146,7 @@
#, fuzzy
msgstr "ì¶ë ¥í ëì¤í°ë§µ"
@@ -9048,7 +9048,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_lv.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1172,7 +1172,7 @@
#, fuzzy
msgstr "Rastra kartes nosaukums"
@@ -9263,7 +9263,7 @@
#, fuzzy
msgstr "Jaunas rastra kartes nosaukums"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pl.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1175,7 +1175,7 @@
#, fuzzy
msgstr "Nazwa wejÅciowej mapy rastrowej"
@@ -9246,7 +9246,7 @@
#, fuzzy
msgstr "WejÅciowa mapa rastrowa zakodowanej sieci rzecznej"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pt.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1189,7 +1189,7 @@
#, fuzzy
msgstr "Nome do Raster de entrada"
@@ -9592,7 +9592,7 @@
#, fuzzy
msgstr "Nome do novo arquivo raster"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_pt_br.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1187,7 +1187,7 @@
#, fuzzy
@@ -9538,7 +9538,7 @@
#, fuzzy
msgstr "Nome do mapa raster de rede de drenagem coded de entrada"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ro.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1127,7 +1127,7 @@
#, fuzzy
msgstr "Numele a douÄ 2-%d hÄrÈi raster de intrare"
@@ -8836,7 +8836,7 @@
#, fuzzy
msgstr "Nume pentru harta vectorialÄ de intrare"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_ru.po 2014-03-30 08:37:54 UTC (rev 59520)
#, fuzzy
msgstr "Ðазвание вводного ÑаÑÑÑового ÑлоÑ"
@@ -9485,7 +9485,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_sl.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1182,7 +1182,7 @@
#, fuzzy
msgstr "Ime vhodnega rastrskega sloja"
@@ -9379,7 +9379,7 @@
#, fuzzy
msgstr "Ime novega rastrskega sloja"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_th.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_th.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_th.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1171,7 +1171,7 @@
#, fuzzy
msgstr "à¸à¸·à¹à¸à¸à¸à¸à¹à¸à¸à¸à¸µà¹à¹à¸à¸´à¸à¸ าà¸"
@@ -9364,7 +9364,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_tr.po 2014-03-30 08:37:54 UTC (rev 59520)
@@ -1169,7 +1169,7 @@
#, fuzzy
msgstr "Girdi raster haritası adı"
@@ -9131,7 +9131,7 @@
#, fuzzy
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_vi.po 2014-03-30 08:37:54 UTC (rev 59520)
#, fuzzy
msgstr "Tên bản Äá» raster Äầu và o"
@@ -9509,7 +9509,7 @@
#, fuzzy
msgstr "Tên táºp tin raster má»i"
Modified: grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po
--- grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/locale/po/grassmods_zh.po 2014-03-30 08:37:54 UTC (rev 59520)
#, fuzzy
msgstr "è¾å
¥æ
æ ¼å¾çåç§°"
@@ -9408,7 +9408,7 @@
#, fuzzy
msgstr "æ°çæ
æ ¼æä»¶çåç§°"
Modified: grass/branches/releasebranch_7_0/raster/r.stream.channel/main.c
--- grass/branches/releasebranch_7_0/raster/r.stream.channel/main.c 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/raster/r.stream.channel/main.c 2014-03-30 08:37:54 UTC (rev 59520)
@@ -61,7 +61,7 @@
in_stm_opt = G_define_standard_option(G_OPT_R_INPUT);
in_stm_opt->key = "stream_rast";
- in_stm_opt->description = _("Name of input streams mask raster map");
+ in_stm_opt->description = _("Name for input raster map with stream network");
in_dir_opt = G_define_standard_option(G_OPT_R_INPUT);
in_dir_opt->key = "direction";
Modified: grass/branches/releasebranch_7_0/raster/r.stream.distance/main.c
--- grass/branches/releasebranch_7_0/raster/r.stream.distance/main.c 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/raster/r.stream.distance/main.c 2014-03-30 08:37:54 UTC (rev 59520)
@@ -57,7 +57,7 @@
- in_stm_opt->description = _("Name of input streams (outlets) mask raster map");
Modified: grass/branches/releasebranch_7_0/raster/r.stream.order/main.c
--- grass/branches/releasebranch_7_0/raster/r.stream.order/main.c 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/raster/r.stream.order/main.c 2014-03-30 08:37:54 UTC (rev 59520)
@@ -29,7 +29,7 @@
IO input[] = {
- {"stream_rast", YES, _("Name of input streams mask raster map")},
+ {"stream_rast", YES, _("Name for input raster map with stream network")},
{"direction", YES, _("Name of input flow direction raster map")},
{"elevation", NO, _("Name of input elevation raster map")},
{"accumulation", NO, _("Name of input accumulation raster map")}
Modified: grass/branches/releasebranch_7_0/raster/r.stream.segment/main.c
--- grass/branches/releasebranch_7_0/raster/r.stream.segment/main.c 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/raster/r.stream.segment/main.c 2014-03-30 08:37:54 UTC (rev 59520)
@@ -61,7 +61,7 @@
Modified: grass/branches/releasebranch_7_0/raster/r.stream.snap/main.c
--- grass/branches/releasebranch_7_0/raster/r.stream.snap/main.c 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/raster/r.stream.snap/main.c 2014-03-30 08:37:54 UTC (rev 59520)
@@ -60,7 +60,7 @@
in_stream_opt = G_define_standard_option(G_OPT_R_INPUT);
in_stream_opt->key = "stream_rast";
in_stream_opt->required = NO;
- in_stream_opt->description = _("Name of input streams mask raster map");
+ in_stream_opt->description = _("Name for input raster map with stream network");
in_stream_opt->guisection = _("Input maps");
in_accum_opt = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/branches/releasebranch_7_0/raster/r.stream.stats/main.c
--- grass/branches/releasebranch_7_0/raster/r.stream.stats/main.c 2014-03-30 08:36:25 UTC (rev 59519)
+++ grass/branches/releasebranch_7_0/raster/r.stream.stats/main.c 2014-03-30 08:37:54 UTC (rev 59520)
@@ -57,7 +57,7 @@
