[GRASS-SVN] r59525 - grass/branches/releasebranch_7_0/misc/m.nviz.image
Sun Mar 30 21:03:21 PDT 2014
Author: annakrat
Date: 2014-03-30 21:03:21 -0700 (Sun, 30 Mar 2014)
New Revision: 59525
   grass/branches/releasebranch_7_0/misc/m.nviz.image/args.c
m.nviz.image: vpoint_size,position are double, not integer (merged from trunk, r59524)
Modified: grass/branches/releasebranch_7_0/misc/m.nviz.image/args.c
--- grass/branches/releasebranch_7_0/misc/m.nviz.image/args.c	2014-03-31 04:00:54 UTC (rev 59524)
+++ grass/branches/releasebranch_7_0/misc/m.nviz.image/args.c	2014-03-31 04:03:21 UTC (rev 59525)
@@ -409,16 +409,16 @@
     params->vpoint_layer->key = "vpoint_layer";
     params->vpoint_layer->answer = "1";
-    /* point width */
+    /* point size */
     params->vpoint_size = G_define_option();
     params->vpoint_size->key = "vpoint_size";
     params->vpoint_size->key_desc = "value";
-    params->vpoint_size->type = TYPE_INTEGER;
+    params->vpoint_size->type = TYPE_DOUBLE;
     params->vpoint_size->required = NO;
     params->vpoint_size->multiple = YES;
     params->vpoint_size->description = _("Icon size (map units)");
     params->vpoint_size->guisection = _("Vector points");
-    params->vpoint_size->options = "1-1000";
+    params->vpoint_size->options = "0-1000";
     params->vpoint_size->answer = "100";
     params->vpoint_size_column = G_define_standard_option(G_OPT_DB_COLUMN);
@@ -503,7 +503,7 @@
     params->vpoint_pos = G_define_option();
     params->vpoint_pos->key = "vpoint_position";
     params->vpoint_pos->key_desc = "x,y,z";
-    params->vpoint_pos->type = TYPE_INTEGER;
+    params->vpoint_pos->type = TYPE_DOUBLE;
     params->vpoint_pos->required = NO;
     params->vpoint_pos->multiple = YES;
     params->vpoint_pos->description = _("Vector points position");
