[GRASS-SVN] r59527 - grass/trunk/locale/po
Mon Mar 31 12:37:41 PDT 2014
Author: neteler
Date: 2014-03-31 12:37:40 -0700 (Mon, 31 Mar 2014)
New Revision: 59527
   grass/trunk/locale/po/grasslibs_ar.po
   grass/trunk/locale/po/grasslibs_cs.po
   grass/trunk/locale/po/grasslibs_de.po
   grass/trunk/locale/po/grasslibs_el.po
   grass/trunk/locale/po/grasslibs_es.po
   grass/trunk/locale/po/grasslibs_fr.po
   grass/trunk/locale/po/grasslibs_it.po
   grass/trunk/locale/po/grasslibs_ja.po
   grass/trunk/locale/po/grasslibs_ko.po
   grass/trunk/locale/po/grasslibs_lv.po
   grass/trunk/locale/po/grasslibs_ml.po
   grass/trunk/locale/po/grasslibs_pl.po
   grass/trunk/locale/po/grasslibs_pt.po
   grass/trunk/locale/po/grasslibs_pt_br.po
   grass/trunk/locale/po/grasslibs_ro.po
   grass/trunk/locale/po/grasslibs_ru.po
   grass/trunk/locale/po/grasslibs_sl.po
   grass/trunk/locale/po/grasslibs_th.po
   grass/trunk/locale/po/grasslibs_tr.po
   grass/trunk/locale/po/grasslibs_vi.po
   grass/trunk/locale/po/grasslibs_zh.po
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ro.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/locale/po/grasswxpy_cs.po
   grass/trunk/locale/po/grasswxpy_de.po
   grass/trunk/locale/po/grasswxpy_el.po
   grass/trunk/locale/po/grasswxpy_es.po
   grass/trunk/locale/po/grasswxpy_fr.po
   grass/trunk/locale/po/grasswxpy_id.po
   grass/trunk/locale/po/grasswxpy_it.po
   grass/trunk/locale/po/grasswxpy_ja.po
   grass/trunk/locale/po/grasswxpy_lv.po
   grass/trunk/locale/po/grasswxpy_ml.po
   grass/trunk/locale/po/grasswxpy_pl.po
   grass/trunk/locale/po/grasswxpy_pt.po
   grass/trunk/locale/po/grasswxpy_pt_br.po
   grass/trunk/locale/po/grasswxpy_ro.po
   grass/trunk/locale/po/grasswxpy_ru.po
   grass/trunk/locale/po/grasswxpy_th.po
   grass/trunk/locale/po/grasswxpy_tr.po
   grass/trunk/locale/po/grasswxpy_vi.po
   grass/trunk/locale/po/grasswxpy_zh.po
i18N: cleanup duplicate messages
Modified: grass/trunk/locale/po/grasslibs_ar.po
--- grass/trunk/locale/po/grasslibs_ar.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_ar.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ar\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2014-03-27 20:41+0100\n"
+"POT-Creation-Date: 2014-03-31 21:29+0200\n"
 "PO-Revision-Date: 2005-03-09 12:50+0100\n"
 "Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
 "Language-Team: Arabic <grass-translations at lists.osgeo.org>\n"
@@ -5438,7 +5438,7 @@
 msgid "Unable to parse time string: %s"
 msgstr "لم يمكن فتحه %s فى %s"
-#: ../lib/python/temporal/gui_support.py:57 ../lib/python/script/core.py:1333
+#: ../lib/python/temporal/gui_support.py:57 ../lib/python/script/core.py:1339
 #, python-format
 msgid "Invalid element '%s'"
 msgstr ""
@@ -5501,42 +5501,42 @@
 msgid "Error while computation"
 msgstr ""
-#: ../lib/python/script/core.py:928
+#: ../lib/python/script/core.py:934
 msgid "Mixing value types. Will try to compare after integer conversion"
 msgstr ""
-#: ../lib/python/script/core.py:1146
+#: ../lib/python/script/core.py:1152
 #, python-format
 msgid "Element type should be \"cell\" and not \"%s\""
 msgstr ""
-#: ../lib/python/script/core.py:1175 ../lib/python/script/core.py:1265
-#: ../lib/python/script/core.py:1320
+#: ../lib/python/script/core.py:1181 ../lib/python/script/core.py:1271
+#: ../lib/python/script/core.py:1326
 #, python-format
 msgid "Element type should be \"rast\" and not \"%s\""
 msgstr ""
-#: ../lib/python/script/core.py:1521
+#: ../lib/python/script/core.py:1527
 #, fuzzy
 msgid "Unable to list mapsets"
 msgstr " %s لم يمكن فتح"
-#: ../lib/python/script/core.py:1557
+#: ../lib/python/script/core.py:1563
 #, python-format
 msgid "Location <%s> already exists. Operation canceled."
 msgstr ""
-#: ../lib/python/script/core.py:1560
+#: ../lib/python/script/core.py:1566
 #, fuzzy, python-format
 msgid "Location <%s> already exists and will be overwritten"
 msgstr "موجود ولايمكن تغييره '%s' الفيكتور"
-#: ../lib/python/script/core.py:1692
+#: ../lib/python/script/core.py:1698
 msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
 msgstr "يجب أن لا يحوى نقطة أو قيمة معدومة <%s> اسم ماف فيكتورى غير سليم\n"
-#: ../lib/python/script/core.py:1701
+#: ../lib/python/script/core.py:1707
 msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
 msgstr " غير مسموح به والاسم غير صحيح <%c> الحرف"
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_cs.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -14,7 +14,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_cs\n"
 "PO-Revision-Date: 2010-03-07 15:47+0100\n"
 "Last-Translator: \n"
 "Language-Team:  <cs at li.org>\n"
@@ -5554,7 +5554,7 @@
 msgstr "Nelze otevřít soubor %s v <%s>"
 #, python-format
 msgstr ""
@@ -5617,42 +5617,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Nelze zavřít vstupní mapu"
 #, python-format
 msgstr ""
 msgstr "Vektorová mapa <%s> již existuje a bude přepsána."
 msgstr "Nedovolený název souboru. Soubor se nemůže jmenovat '.' nebo 'NIC'\n"
 msgstr "Nedovolený název souboru. Znak <%c> není povolen.\n"
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_de.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_de\n"
 "PO-Revision-Date: 2014-03-24 13:45+0100\n"
 "Last-Translator: Helmut Kudrnovsky <hellik at web.de>\n"
 "Language-Team: German <grass-translations at lists.osgeo.org>\n"
@@ -100,7 +100,9 @@
 #: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:838
 #, c-format
 msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr "Die Leseanfrage der Rasterkarte <%s@%s> für Zeile %d ist außerhalb der Region."
+msgstr ""
+"Die Leseanfrage der Rasterkarte <%s@%s> für Zeile %d ist außerhalb der "
+"Region."
 #: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:100
 #: ../lib/raster/get_row.c:133 ../lib/raster/get_row.c:139
@@ -132,7 +134,9 @@
 #: ../lib/raster/reclass.c:171
 #, fuzzy, c-format
 msgid "Illegal reclass format in header file for <%s@%s>"
-msgstr "Ungültiges Reklassifizierungs-Format in der Header-Datei für Karte [%s in %s]."
+msgstr ""
+"Ungültiges Reklassifizierungs-Format in der Header-Datei für Karte [%s in "
+"%s]."
 #: ../lib/raster/reclass.c:273
 msgid "Illegal reclass request"
@@ -183,15 +187,21 @@
 msgstr "Kann die History-Datei für die Vektorkarte <%s> nicht öffnen."
 #: ../lib/raster/window.c:18
-msgid "Internal error: Rast_get_window() called with split window. Use Rast_get_input_window() or Rast_get_output_window() instead."
+msgid ""
+"Internal error: Rast_get_window() called with split window. Use "
+"Rast_get_input_window() or Rast_get_output_window() instead."
 msgstr ""
 #: ../lib/raster/window.c:77
-msgid "Internal error: Rast_window_rows() called with split window. Use Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid ""
+"Internal error: Rast_window_rows() called with split window. Use "
+"Rast_input_window_rows() or Rast_output_window_rows() instead."
 msgstr ""
 #: ../lib/raster/window.c:112
-msgid "Internal error: Rast_window_cols() called with split window. Use Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid ""
+"Internal error: Rast_window_cols() called with split window. Use "
+"Rast_input_window_cols() or Rast_output_window_cols() instead."
 msgstr ""
 #: ../lib/raster/quant_rw.c:88
@@ -220,8 +230,12 @@
 #: ../lib/raster/set_window.c:131
 #, fuzzy
-msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
-msgstr "G_set_window(): Projektion/Zone unterscheidet sich von den gerade geöffneten Rasterdateien."
+msgid ""
+"Rast_set_read_window(): projection/zone differs from that of currently open "
+"raster maps"
+msgstr ""
+"G_set_window(): Projektion/Zone unterscheidet sich von den gerade geöffneten "
+"Rasterdateien."
 #: ../lib/raster/set_window.c:158
 #, c-format
@@ -326,7 +340,8 @@
 #: ../lib/raster/put_row.c:682
 #, fuzzy, c-format
 msgid "put_raster_row: raster map <%s> not open for write - request ignored"
-msgstr "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
+msgstr ""
+"%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
 #: ../lib/raster/put_row.c:689
 #, fuzzy
@@ -414,7 +429,9 @@
 #: ../lib/raster/get_cellhd.c:66
 #, fuzzy, c-format
-msgid "Unable to read header file for raster map <%s@%s>.It is a reclass of raster map <%s@%s> %s"
+msgid ""
+"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
+"map <%s@%s> %s"
 msgstr "Raster Karte Raster Karte"
 #: ../lib/raster/get_cellhd.c:70
@@ -433,7 +450,9 @@
 #: ../lib/raster/init.c:61
 #, fuzzy
 msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr "Fehler. System ist nicht initialisiert. Der Programmierer hat vergessen, G_gisinit() aufzurufen.\n"
+msgstr ""
+"Fehler. System ist nicht initialisiert. Der Programmierer hat vergessen, "
+"G_gisinit() aufzurufen.\n"
 #: ../lib/raster/quant_io.c:43
 #, fuzzy, c-format
@@ -496,7 +515,9 @@
 #: ../lib/raster/gdal.c:497
 #, c-format
-msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+msgid ""
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
 msgstr ""
 #: ../lib/raster/gdal.c:503
@@ -587,8 +608,12 @@
 #: ../lib/raster/open.c:190
 #, c-format
-msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
-msgstr "Kann die Rasterkarte <%s@%s> nicht öffnen, weil es eine Reklassifizierung der Rasterkarte <%s@%s> ist, welche nicht existiert."
+msgid ""
+"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
+"%s> which does not exist"
+msgstr ""
+"Kann die Rasterkarte <%s@%s> nicht öffnen, weil es eine Reklassifizierung "
+"der Rasterkarte <%s@%s> ist, welche nicht existiert."
 #: ../lib/raster/open.c:195
 #, fuzzy, c-format
@@ -607,7 +632,9 @@
 #: ../lib/raster/open.c:219
 #, fuzzy, c-format
-msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
+msgid ""
+"Raster map <%s> is in different projection than current region. Found <%s>, "
+"should be <%s>."
 msgstr "Raster Karte Raster Karte."
 #: ../lib/raster/open.c:226
@@ -622,7 +649,8 @@
 #: ../lib/raster/open.c:256
 #, fuzzy, c-format
-msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid ""
+"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
 msgstr "Karte"
 #: ../lib/raster/open.c:264
@@ -691,7 +719,8 @@
 #: ../lib/raster/open.c:929
 #, fuzzy
-msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid ""
+"Rast_set_quant_rules() can be called only for raster maps opened for reading"
 msgstr "Raster"
 #: ../lib/raster/color_rand.c:33
@@ -752,7 +781,8 @@
 #: ../lib/ogsf/Gv3.c:262
 #, c-format
 msgid "No features from vector map <%s> fall within current region"
-msgstr "Keine Objekte der Vektorkarte <%s> befinden sich in der aktuellen Region."
+msgstr ""
+"Keine Objekte der Vektorkarte <%s> befinden sich in der aktuellen Region."
 #: ../lib/ogsf/Gv3.c:267
 #, c-format
@@ -800,7 +830,9 @@
 #: ../lib/ogsf/Gv3.c:407
 #, c-format
-msgid "%d features without category. Unable to determine color rules for features without category."
+msgid ""
+"%d features without category. Unable to determine color rules for features "
+"without category."
 msgstr ""
 #: ../lib/ogsf/gvl_file.c:103
@@ -841,7 +873,8 @@
 #: ../lib/ogsf/Gp3.c:146
 #, c-format
 msgid "No points from vector map <%s> fall within current region"
-msgstr "Keine Punkte der Vektorkarte <%s> befinden sich in der aktuellen Region."
+msgstr ""
+"Keine Punkte der Vektorkarte <%s> befinden sich in der aktuellen Region."
 #: ../lib/ogsf/Gp3.c:151
 #, c-format
@@ -855,7 +888,9 @@
 #: ../lib/ogsf/Gp3.c:286
 #, c-format
-msgid "%d points without category. Unable to determine color rules for features without category."
+msgid ""
+"%d points without category. Unable to determine color rules for features "
 msgstr ""
 #: ../lib/ogsf/trans.c:180
@@ -919,7 +954,9 @@
 #: ../lib/ogsf/gsd_img_mpeg.c:340
 msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr "Kann nicht von der Dateiendung auf das Ausgabeformat schließen: verwende MPEG."
+msgstr ""
+"Kann nicht von der Dateiendung auf das Ausgabeformat schließen: verwende "
+"MPEG."
 #: ../lib/ogsf/gsd_img_mpeg.c:348
 msgid "Unable to find suitable output format"
@@ -945,8 +982,12 @@
 #: ../lib/ogsf/gsd_prim.c:630
 #, c-format
-msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
-msgstr "gsd_rot(): %c ist eine ungültige Achsenbestimmung. Rotation ignoriert. Bitte, unterrichten Sie die GRASS Entwicklern über diesen Fehler."
+msgid ""
+"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
+"advise GRASS developers of this error"
+msgstr ""
+"gsd_rot(): %c ist eine ungültige Achsenbestimmung. Rotation ignoriert. "
+"Bitte, unterrichten Sie die GRASS Entwicklern über diesen Fehler."
 #: ../lib/ogsf/GS2.c:1211
 #, c-format
@@ -961,13 +1002,15 @@
 #: ../lib/ogsf/GS2.c:1655
 #, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr "Rasterkarte <%s> ist außerhalb der aktuellen Region. Laden fehlgeschlagen."
+msgstr ""
+"Rasterkarte <%s> ist außerhalb der aktuellen Region. Laden fehlgeschlagen."
 #: ../lib/ogsf/GS2.c:1733 ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747
 #: ../lib/ogsf/GS2.c:1756 ../lib/ogsf/GS2.c:1764 ../lib/ogsf/GS2.c:1774
 #: ../lib/ogsf/GS2.c:1822
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr "GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
+msgstr ""
+"GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
 #: ../lib/ogsf/GS2.c:1850
 msgid "Loading failed"
@@ -986,7 +1029,8 @@
 #: ../lib/ogsf/Gs3.c:596
 #, c-format
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr "Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
+msgstr ""
+"Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
 #: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
 #, c-format
@@ -995,7 +1039,9 @@
 #: ../lib/ogsf/Gs3.c:967
 msgid "View not saved by this program,there may be some inconsistancies"
-msgstr "View wurde nicht von diesem Programm gespeichert, es können Inkonsistenzen auftreten."
+msgstr ""
+"View wurde nicht von diesem Programm gespeichert, es können Inkonsistenzen "
+"auftreten."
 #: ../lib/ogsf/gs_bm.c:124
 msgid "Bitmap mismatch"
@@ -1007,7 +1053,9 @@
 #: ../lib/ogsf/gsd_surf.c:1742
 msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr "Schnittflächenpunkte der Oberflächen passen nicht zusammen. Überprüfen Sie die Auflösung(en)."
+msgstr ""
+"Schnittflächenpunkte der Oberflächen passen nicht zusammen. Überprüfen Sie "
+"die Auflösung(en)."
 #: ../lib/ogsf/gsd_legend.c:246
 #, c-format
@@ -1242,13 +1290,17 @@
 #: ../lib/proj/convert.c:139
 #, c-format
-msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr "OGR kann die Zeichenkette im PROJ.4-Stil '%s' nicht interpretieren (OGR Fehler-Code %d)."
+msgid ""
+"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr ""
+"OGR kann die Zeichenkette im PROJ.4-Stil '%s' nicht interpretieren (OGR "
+"Fehler-Code %d)."
 #: ../lib/proj/convert.c:146
 #, c-format
 msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr "OGR kann die Zeichenkette im WKT-Stil nicht bekommen (OGR Fehler-Code %d)."
+msgstr ""
+"OGR kann die Zeichenkette im WKT-Stil nicht bekommen (OGR Fehler-Code %d)."
 #: ../lib/proj/convert.c:406
 msgid "No projection name! Projection parameters likely to be meaningless."
@@ -1261,13 +1313,21 @@
 #: ../lib/proj/convert.c:458
 #, c-format
-msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
-msgstr "Datum <%s> wurde von GRASS erkannt, doch es wurden keine Parameter gefunden. Sie sollten dies genauer untersuchen."
+msgid ""
+"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
+"want to look into this."
+msgstr ""
+"Datum <%s> wurde von GRASS erkannt, doch es wurden keine Parameter gefunden. "
+"Sie sollten dies genauer untersuchen."
 #: ../lib/proj/convert.c:462
 #, c-format
-msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
-msgstr "Ungültige Transformationsnummer %d; gültiger Wertebereich 1 bis %d. Datumstransformationsparameter bleiben unbestimmt."
+msgid ""
+"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
+"transform parameters unspecified."
+msgstr ""
+"Ungültige Transformationsnummer %d; gültiger Wertebereich 1 bis %d. "
+"Datumstransformationsparameter bleiben unbestimmt."
 #: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
 #, c-format
@@ -1348,8 +1408,12 @@
 msgstr "Ungültige Zeichenkette für Zeitstempel."
 #: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
-msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
-msgstr "Dev note: Angepasste sites Bibliothek für Vektorpunkte verwendet. (Modul sollte für die GRASS 6 Vector Library aktualisiert werden)."
+msgid ""
+"Dev note: Adapted sites library used for vector points. (module should be "
+"updated to GRASS 6 vector library)"
+msgstr ""
+"Dev note: Angepasste sites Bibliothek für Vektorpunkte verwendet. (Modul "
+"sollte für die GRASS 6 Vector Library aktualisiert werden)."
 #: ../lib/sites/sites.c:288 ../lib/db/dbmi_client/table.c:110
 #: ../lib/db/dbmi_client/copy_tab.c:218 ../lib/db/dbmi_client/copy_tab.c:295
@@ -1367,7 +1431,8 @@
 msgstr "G_oldsite_new_struct: Ungültige # Dimensionen oder Felder"
 #: ../lib/sites/sites.c:668
-msgid "G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
+msgid ""
+"G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
 msgstr ""
 #: ../lib/db/dbmi_driver/d_error.c:35
@@ -1378,7 +1443,8 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:38
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr "Ungültiger Tabellenname <%s>. Er darf '.' oder 'NULL' nicht enthalten.\n"
+msgstr ""
+"Ungültiger Tabellenname <%s>. Er darf '.' oder 'NULL' nicht enthalten.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:45
 #, fuzzy, c-format
@@ -1388,7 +1454,8 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:54
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
+msgstr ""
+"Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
 #: ../lib/db/dbmi_base/error.c:72
 #, fuzzy
@@ -1829,7 +1896,8 @@
 #: ../lib/cairodriver/read_ppm.c:56
 #, c-format
-msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid ""
+"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
 msgstr ""
 #: ../lib/cairodriver/Graph.c:67
@@ -2018,7 +2086,8 @@
 #: ../lib/init/grass.py:264
-msgid "Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+msgid ""
+"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
 msgstr "Kann keinen Speicher für temporäres Bild belegen."
 #: ../lib/init/grass.py:348
@@ -2083,7 +2152,9 @@
 #: ../lib/init/grass.py:612
 #, python-format
-msgid "Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be created by '-c' switch."
+msgid ""
+"Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be "
+"created by '-c' switch."
 msgstr ""
 #: ../lib/init/grass.py:631
@@ -2103,12 +2174,15 @@
 #: ../lib/init/grass.py:686
 #, python-format
-msgid "Invalid user interface specified - <%s>. Use the --help option to see valid interface names."
+msgid ""
+"Invalid user interface specified - <%s>. Use the --help option to see valid "
+"interface names."
 msgstr ""
 #: ../lib/init/grass.py:700
 msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
+"Error in GUI startup. If necessary, please report this error to the GRASS "
+"developers.\n"
 "Switching to text mode now.\n"
 "\n"
 "Hit RETURN to continue..."
@@ -2144,7 +2218,9 @@
 #: ../lib/init/grass.py:859
 #, python-format
-msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed."
+msgid ""
+"%(user)s is currently running GRASS in selected mapset (file %(file)s "
+"found). Concurrent use not allowed."
 msgstr ""
 #: ../lib/init/grass.py:863
@@ -2172,7 +2248,8 @@
 #: ../lib/init/grass.py:941
 #, python-format
 msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
+"found. Exiting.\n"
 "\n"
 "Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
 msgstr ""
@@ -2266,7 +2343,8 @@
 "Unable to start GRASS. You can:\n"
 " - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
 " - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /path/to/location/mapset`)"
+" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
+"path/to/location/mapset`)"
 msgstr ""
 #: ../lib/init/grass.py:1352
@@ -2297,7 +2375,9 @@
 #: ../lib/init/lock.c:42
 msgid "Concurrent mapset locking is not supported on Windows"
-msgstr "Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows nicht möglich."
+msgstr ""
+"Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows nicht "
+"möglich."
 #: ../lib/init/lock.c:60
 #, fuzzy, c-format
@@ -2341,8 +2421,10 @@
 #: ../lib/symbol/read.c:260
 #, c-format
-msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr "Falscher Symbolname: '%s' (sollte sein: Gruppe/Name oder Gruppe/Name at Mapset)."
+msgid ""
+"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr ""
+"Falscher Symbolname: '%s' (sollte sein: Gruppe/Name oder Gruppe/Name at Mapset)."
 #: ../lib/symbol/read.c:284
 #, c-format
@@ -2358,7 +2440,9 @@
 #: ../lib/driver/parse_ftcap.c:84
 #, c-format
 msgid "%s: Unable to read font definition file; use the default"
-msgstr "%s: Kann die Font-Definitionsdatei nicht lesen. Verwende die Standardeinstellung."
+msgstr ""
+"%s: Kann die Font-Definitionsdatei nicht lesen. Verwende die "
+"Standardeinstellung."
 #: ../lib/driver/parse_ftcap.c:90
 #, c-format
@@ -2393,7 +2477,8 @@
 #: ../lib/raster3d/history.c:43
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
-msgstr "Kann die History-Informationen der Karte [%s] in Mapset [%s] nicht lesen."
+msgstr ""
+"Kann die History-Informationen der Karte [%s] in Mapset [%s] nicht lesen."
 #: ../lib/raster3d/close.c:47
 #, fuzzy, c-format
@@ -3104,8 +3189,12 @@
 msgstr "Suchabstand außerhalb des Wertebereichs."
 #: ../lib/gis/gisinit.c:51 ../lib/gis/gisinit.c:83
-msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
-msgstr "Version der Bibliothek ist inkompatible mit Modul. Sie müssen GRASS erneut bauen oder verschiedene Installationen entwirren."
+msgid ""
+"Incompatible library version for module. You need to rebuild GRASS or "
+"untangle multiple installations."
+msgstr ""
+"Version der Bibliothek ist inkompatible mit Modul. Sie müssen GRASS erneut "
+"bauen oder verschiedene Installationen entwirren."
 #: ../lib/gis/gisinit.c:61
 #, c-format
@@ -3119,7 +3208,9 @@
 #: ../lib/gis/gisinit.c:97
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr "System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() aufzurufen."
+msgstr ""
+"System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() "
+"aufzurufen."
 #: ../lib/gis/mapset_msc.c:61
 #, c-format
@@ -3274,12 +3365,17 @@
 #: ../lib/gis/view.c:545
 #, c-format
 msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr " Das in \"%s\" abgespeicherte Fenster ist komplett außerhalb des derzeitigen GRASS Fensters."
+msgstr ""
+" Das in \"%s\" abgespeicherte Fenster ist komplett außerhalb des derzeitigen "
+"GRASS Fensters."
 #: ../lib/gis/view.c:549
 #, c-format
-msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr " Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem derzeitigen GRASS-Fenster."
+msgid ""
+" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr ""
+" Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem "
+"derzeitigen GRASS-Fenster."
 #: ../lib/gis/error.c:344
 msgid "WARNING: "
@@ -3326,7 +3422,8 @@
 msgstr "Datenbank"
 #: ../lib/gis/parser_standard_options.c:186
-msgid "Do not use this option if schemas are not supported by driver/database server"
+msgid ""
+"Do not use this option if schemas are not supported by driver/database server"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:195
@@ -3445,7 +3542,9 @@
 msgstr "Datentyp verwendet in Ausgabedatei"
 #: ../lib/gis/parser_standard_options.c:385
-msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
+msgid ""
+"Number of digits used as mantissa in the internal map storage, 0 -23 for "
+"float, 0 - 52 for double, max or default"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:395
@@ -3455,7 +3554,9 @@
 #: ../lib/gis/parser_standard_options.c:405
 #, fuzzy
-msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
+msgid ""
+"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
+"default: 16x16x8)"
 msgstr "Dimension der Kacheln, die für die Ausgabe verwerndet werden soll."
 #: ../lib/gis/parser_standard_options.c:415
@@ -3502,8 +3603,13 @@
 #: ../lib/gis/parser_standard_options.c:479
 #, fuzzy
-msgid "Vector features can have category values in different layers. This number determines which layer to use. When used with direct OGR access this is the layer name."
-msgstr "Eine Vektorkarte kann mit mehreren Attributdatenquellen verbunden werden.Diese Zahl gibt Auskunft über die zu benutzende Tabelle."
+msgid ""
+"Vector features can have category values in different layers. This number "
+"determines which layer to use. When used with direct OGR access this is the "
+"layer name."
+msgstr ""
+"Eine Vektorkarte kann mit mehreren Attributdatenquellen verbunden werden."
+"Diese Zahl gibt Auskunft über die zu benutzende Tabelle."
 #: ../lib/gis/parser_standard_options.c:489
 #, fuzzy
@@ -3512,8 +3618,13 @@
 #: ../lib/gis/parser_standard_options.c:491
 #, fuzzy
-msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
+msgid ""
+"A single vector map can be connected to multiple database tables. This "
+"number determines which table to use. When used with direct OGR access this "
+"is the layer name."
+msgstr ""
 #: ../lib/gis/parser_standard_options.c:500
 msgid "Category value"
@@ -3691,7 +3802,9 @@
 #: ../lib/gis/parser_standard_options.c:796
 #, fuzzy
-msgid "WHERE conditions of SQL statement without 'where' keyword used in the temporal GIS framework"
+msgid ""
+"WHERE conditions of SQL statement without 'where' keyword used in the "
+"temporal GIS framework"
 msgstr "WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'."
 #: ../lib/gis/parser_standard_options.c:797
@@ -4074,11 +4187,15 @@
 #: ../lib/gis/parser.c:491
 msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr "Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --verbose."
+msgstr ""
+"Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --"
+"verbose."
 #: ../lib/gis/parser.c:505
 msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr "Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --quiet."
+msgstr ""
+"quiet."
 #: ../lib/gis/parser.c:536
 #, c-format
@@ -4456,7 +4573,9 @@
 #: ../lib/gis/distance.c:154
 #, fuzzy, c-format
 msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
-msgstr "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgstr ""
+"G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) "
+"S=(%f,%f)(%f,%f)"
 #: ../lib/arraystats/class.c:21
 msgid "Discont algorithm currently not available because of bugs"
@@ -4474,8 +4593,12 @@
 #: ../lib/arraystats/class.c:220
 #, c-format
-msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
-msgstr "Klassengrenzen außerhalb der min-max Spanne. Anzahl der Klassen auf %i reduziert. Verwende dennoch die Wahrscheinlichkeiten für %i Klassen. "
+msgid ""
+"There are classbreaks outside the range min-max. Number of classes reduced "
+"to %i, but using probabilities for %i classes."
+msgstr ""
+"Klassengrenzen außerhalb der min-max Spanne. Anzahl der Klassen auf %i "
+"reduziert. Verwende dennoch die Wahrscheinlichkeiten für %i Klassen. "
 #: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
 #, fuzzy, c-format
@@ -4574,7 +4697,9 @@
 msgstr "Kann die Vektorkarte <%s> in <%s> nicht finden."
 #: ../lib/python/temporal/core.py:514
-msgid "Unable to initialize the temporal DBMI interface. Use t.connect to specify the driver and the database string"
+msgid ""
+"Unable to initialize the temporal DBMI interface. Use t.connect to specify "
+"the driver and the database string"
 msgstr ""
 #: ../lib/python/temporal/core.py:582
@@ -4634,7 +4759,9 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:339
-msgid "Start time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+msgid ""
+"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
+"%(l)s"
 msgstr "Kann keine Zeitstempel-Datei für %s Karte %s in Mapset %s erzeugen."
 #: ../lib/python/temporal/abstract_map_dataset.py:345
@@ -4644,7 +4771,8 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:352
-msgid "End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+msgid ""
+"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
 msgstr "Ungültige Zeitstempel-Datei für %s Karte %s in Mapset %s."
 #: ../lib/python/temporal/abstract_map_dataset.py:358
@@ -4654,7 +4782,9 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:366
-msgid "End time must be greater than start time for %(type)s map <%(id)s> with layer: %(l)s"
+msgid ""
+"End time must be greater than start time for %(type)s map <%(id)s> with "
+"layer: %(l)s"
 msgstr "Ostwert muss größer als der Westwert sein."
 #: ../lib/python/temporal/abstract_map_dataset.py:373
@@ -4669,12 +4799,16 @@
 #: ../lib/python/temporal/abstract_dataset.py:428
 #: ../lib/python/temporal/abstract_dataset.py:469
 #, python-format
-msgid "Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgid ""
+"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
+"The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:443
-msgid "Unsupported relative time unit type for %(type)s map <%(id)s> with layer %(l)s: %(u)s"
+msgid ""
+"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
+"%(l)s: %(u)s"
 #: ../lib/python/temporal/abstract_map_dataset.py:448
@@ -4684,17 +4818,22 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:457
-msgid "End time must be greater than start time for %(type)s map <%(id)s> with layer %(l)s"
+msgid ""
+"layer %(l)s"
 #: ../lib/python/temporal/abstract_map_dataset.py:766
 #, python-format
-msgid "Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is greater than end time"
+msgid ""
+"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
+"greater than end time"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:772
 #, python-format
-msgid "Map <%s> has incorrect time interval, start time is greater than end time"
+msgid ""
+"Map <%s> has incorrect time interval, start time is greater than end time"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:777
@@ -4705,7 +4844,9 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:805
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1918
 #, python-format
-msgid "Unable to delete dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
+msgid ""
+"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
+"database. The mapset of the dataset does not match the current mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:821
@@ -4715,7 +4856,9 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:870
 #, python-format
-msgid "Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal database. The mapset of the dataset does not match the current mapset"
+msgid ""
+"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:153
@@ -4764,17 +4907,23 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1575
 #, python-format
-msgid "Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgid ""
+"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1742
 #, python-format
-msgid "Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgid ""
+"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1842
 #, python-format
-msgid "Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgid ""
+"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1849
@@ -4798,11 +4947,15 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2012
-msgid "Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of the dataset does not match the current mapset"
+msgid ""
+"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
+"the dataset does not match the current mapset"
 msgstr "Rasterkarte <%s> nicht im Mapset <%s> gefunden."
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2020
-msgid "Only a map that was inserted in the temporal database can be registered in a space time dataset"
+msgid ""
+"Only a map that was inserted in the temporal database can be registered in a "
+"space time dataset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2040
@@ -4817,12 +4970,15 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2061
-msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
+"%(l)s are different"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2066
-msgid "Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2080
@@ -4832,12 +4988,16 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2089
 #, python-format
-msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> with layer %(l)s are different"
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
+"layer %(l)s are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2095
 #, python-format
-msgid "Relative time units of space time dataset <%(id)s> and map <%(map)s> are different"
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
+"different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2101
@@ -4856,12 +5016,17 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2158
 #, python-format
-msgid "Unable to unregister map from dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgid ""
+"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
+"temporal database. The mapset of the dataset does not match the current "
+"mapset"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2169
-msgid "Map <%(map)s> with layer %(l)s is not registered in space time dataset <%(base)s>"
+msgid ""
+"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
+"%(base)s>"
 msgstr "BUG: Aktualisiere die Karte, welche nicht im aktuellen Mapset ist."
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2174
@@ -4871,7 +5036,8 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:2230
 #, python-format
-msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgid ""
+"Update metadata, spatial and temporal extent from all registered maps of <%s>"
 msgstr ""
 #: ../lib/python/temporal/register.py:77
@@ -4900,7 +5066,9 @@
 #: ../lib/python/temporal/register.py:101
 #, python-format
-msgid "Space time %(sp)s dataset <%(name)s> with relative time found, but no relative unit set for %(sp)s maps"
+msgid ""
+"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
+"relative unit set for %(sp)s maps"
 msgstr ""
 #: ../lib/python/temporal/register.py:167
@@ -4914,12 +5082,16 @@
 #: ../lib/python/temporal/register.py:196
-msgid "Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has timestamp and the start time is not set."
+msgid ""
+"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
+"timestamp and the start time is not set."
 #: ../lib/python/temporal/register.py:202
-msgid "Unable to register %(t)s map <%(id)s>. The map has no timestamp and the start time is not set."
+msgid ""
+"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
+"start time is not set."
 #: ../lib/python/temporal/register.py:210
@@ -4934,17 +5106,23 @@
 #: ../lib/python/temporal/register.py:224
-msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s> with layer %(l)s. Overwrite flag is not set."
+msgid ""
+"Map is already registered in temporal database. Unable to update %(t)s map <"
+"%(id)s> with layer %(l)s. Overwrite flag is not set."
 msgstr "Vektorkarte <%s> existiert bereits und wird überschrieben."
 #: ../lib/python/temporal/register.py:231
-msgid "Map is already registered in temporal database. Unable to update %(t)s map <%(id)s>. Overwrite flag is not set."
+msgid ""
+"%(id)s>. Overwrite flag is not set."
 #: ../lib/python/temporal/register.py:255
-msgid "Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are different."
+msgid ""
+"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
+"different."
 #: ../lib/python/temporal/register.py:261
@@ -4980,7 +5158,9 @@
 #: ../lib/python/temporal/register.py:399
-msgid "Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - %(end)s"
+msgid ""
+"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
+"%(end)s"
 msgstr "Kann die Vektorkarte <%s> nicht nach <%s> kopieren."
 #: ../lib/python/temporal/register.py:404
@@ -4990,7 +5170,8 @@
 #: ../lib/python/temporal/register.py:421
-msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgid ""
+"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
 #: ../lib/python/temporal/register.py:426
@@ -5000,7 +5181,9 @@
 #: ../lib/python/temporal/abstract_dataset.py:391
 #, python-format
-msgid "Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. The mapset of the dataset does not match the current mapset"
+msgid ""
+"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
 msgstr ""
 #: ../lib/python/temporal/stds_import.py:84
@@ -5123,7 +5306,9 @@
 #: ../lib/python/temporal/stds_import.py:396
-msgid "Space time %(t)s dataset <%(sp)s> is already in the database. Use the overwrite flag."
+msgid ""
+"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
+"overwrite flag."
 #: ../lib/python/temporal/stds_import.py:416
@@ -5142,19 +5327,25 @@
 #: ../lib/python/temporal/spatial_extent.py:125
-msgid "Projections are different. Unable to compute overlapping_2d for spatial extents"
+msgid ""
+"Projections are different. Unable to compute overlapping_2d for spatial "
+"extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:536
-msgid "Projections are different. Unable to compute is_in_2d for spatial extents"
+msgid ""
+"Projections are different. Unable to compute is_in_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:676
-msgid "Projections are different. Unable to compute equivalent_2d for spatial extents"
+msgid ""
+"Projections are different. Unable to compute equivalent_2d for spatial "
+"extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:783
-msgid "Projections are different. Unable to compute cover_2d for spatial extents"
+msgid ""
+"Projections are different. Unable to compute cover_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:854
@@ -5171,7 +5362,9 @@
 #: ../lib/python/temporal/temporal_vector_algebra.py:641
 #, python-format
-msgid "Error vector maps with basename %s exist. Use --o flag to overwrite existing file"
+msgid ""
+"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
+"file"
 msgstr ""
 #: ../lib/python/temporal/temporal_vector_algebra.py:673
@@ -5201,7 +5394,9 @@
 #: ../lib/python/temporal/temporal_algebra.py:844
 #: ../lib/python/temporal/temporal_algebra.py:848
 #, python-format
-msgid "Wrong temporal type of space time dataset <%s>                                       <%s> time is required"
+msgid ""
+"Wrong temporal type of space time dataset <"
+"%s>                                       <%s> time is required"
 msgstr ""
 #: ../lib/python/temporal/list_stds.py:101
@@ -5219,7 +5414,9 @@
 #: ../lib/python/temporal/aggregation.py:138
-msgid "Raster map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgid ""
+"Raster map <%s> is already in temporal database, use overwrite flag to "
+"overwrite"
 #: ../lib/python/temporal/aggregation.py:142
@@ -5260,7 +5457,10 @@
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:151
-msgid "Found more than a single map in a sample granule. Only the first map is used for computation. Use t.rast.aggregate.ds to create synchronous raster datasets."
+msgid ""
+"Found more than a single map in a sample granule. Only the first map is used "
+"for computation. Use t.rast.aggregate.ds to create synchronous raster "
+"datasets."
 msgstr ""
 #: ../lib/python/temporal/mapcalc.py:169
@@ -5275,7 +5475,8 @@
 #: ../lib/python/temporal/open_stds.py:205
 #: ../lib/python/temporal/extract.py:112
-msgid "Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgid ""
+"Map <%s> is already in temporal database, use overwrite flag to overwrite"
 #: ../lib/python/temporal/mapcalc.py:255
@@ -5323,7 +5524,9 @@
 #: ../lib/python/temporal/open_stds.py:121
-msgid "Space time %(sp)s dataset <%(name)s> is already in the database. Use the overwrite flag."
+msgid ""
+"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
+"overwrite flag."
 #: ../lib/python/temporal/open_stds.py:155
@@ -5361,7 +5564,7 @@
 msgstr "Kann Datei %s in <%s> nicht öffnen."
 #, python-format
 msgstr ""
@@ -5424,42 +5627,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Kann die Eingabekarte nicht schließen."
 #, python-format
 msgstr ""
 msgstr "Ungültiger Dateiname.  Er darf nicht '.' oder 'NULL' sein.\n"
 msgstr "Ungültiger Dateiname. Das Zeichen <%c> ist nicht erlaubt.\n"
@@ -5484,7 +5687,8 @@
 #: ../lib/python/script/db.py:142
 #, python-format
-msgid "Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgid ""
+"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
 msgstr ""
 #: ../lib/python/script/db.py:154
@@ -5527,8 +5731,12 @@
 #: ../lib/python/script/raster.py:47
-msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
-msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
+msgid ""
+"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
+"current mapset."
+msgstr ""
+"Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im "
+"Schreibmodus geöffnet."
 #: ../lib/python/script/raster.py:105
 msgid "An error occurred while running r.mapcalc"
@@ -5655,8 +5863,12 @@
 #: ../lib/rst/interp_float/interp2d.c:214
 #, c-format
-msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
-msgstr "Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-value %f, zmin %f, zmax %f."
+msgid ""
+"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
+"cell. Z-value %f, zmin %f, zmax %f."
+msgstr ""
+"Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-"
+"value %f, zmin %f, zmax %f."
 #: ../lib/rst/interp_float/resout2d.c:77
 msgid "Temporarily changing the region to desired resolution..."
@@ -5681,8 +5893,13 @@
 msgstr ""
 #: ../lib/rst/interp_float/segmen2d.c:118
-msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
-msgstr "Es dauert zu lange Punkte für die Interpolation zu finden. Bitte ändern Sie die Region auf den Bereich, in der ihre Punkte sind. Fahre mit der Berechnung fort..."
+msgid ""
+"Taking too long to find points for interpolation - please change the region "
+"to area where your points are. Continuing calculations..."
+msgstr ""
+"Es dauert zu lange Punkte für die Interpolation zu finden. Bitte ändern Sie "
+"die Region auf den Bereich, in der ihre Punkte sind. Fahre mit der "
+"Berechnung fort..."
 #: ../lib/rst/interp_float/write2d.c:40 ../lib/rst/interp_float/write2d.c:51
 #: ../lib/rst/interp_float/write2d.c:66 ../lib/rst/interp_float/write2d.c:75
@@ -5745,7 +5962,8 @@
 #: ../lib/rst/interp_float/vinput2d.c:249
 #, c-format
 msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr "Es gibt Punkte außerhalb der angegebenen 2D/3D-Region - ignoriere %d Punkte."
+msgstr ""
+"Es gibt Punkte außerhalb der angegebenen 2D/3D-Region - ignoriere %d Punkte."
 #: ../lib/rst/interp_float/vinput2d.c:252
 #, c-format
@@ -5754,8 +5972,12 @@
 #: ../lib/rst/interp_float/vinput2d.c:256
 #, c-format
-msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
-msgstr "%d Punkte, die (nach Ausdünnung) zur Verfügung stehen, sind weniger als die angegebenen NPMIN=%d."
+msgid ""
+"%d points given for interpolation (after thinning) is less than given NPMIN="
+"%d"
+msgstr ""
+"%d Punkte, die (nach Ausdünnung) zur Verfügung stehen, sind weniger als die "
+"angegebenen NPMIN=%d."
 #: ../lib/rst/interp_float/vinput2d.c:261
 msgid "Zero points in the given region"
@@ -5763,13 +5985,22 @@
 #: ../lib/rst/interp_float/vinput2d.c:266
 #, c-format
-msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
-msgstr "Segmentation-Parameter mit ungültigen Werten: npmin= %d, segmax= %d zum glatten Aneinandersetzen der Segmente, npmin > segmax (siehe Handbuch)."
+msgid ""
+"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
+"smooth connection of segments, npmin > segmax (see manual)"
+msgstr ""
+"Segmentation-Parameter mit ungültigen Werten: npmin= %d, segmax= %d zum "
+"glatten Aneinandersetzen der Segmente, npmin > segmax (siehe Handbuch)."
 #: ../lib/rst/interp_float/vinput2d.c:272
 #, c-format
-msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
-msgstr "Es gibt weniger als %d Punkte für die Interpolation. Keine Segmentierung notwendig. Um das Programm schneller laufen zu lassen, setzen Sie segmax = %d (siehe Handbuch)."
+msgid ""
+"There are less than %d points for interpolation. No segmentation is "
+"necessary, to run the program faster set segmax=%d (see manual)"
+msgstr ""
+"Es gibt weniger als %d Punkte für die Interpolation. Keine Segmentierung "
+"notwendig. Um das Programm schneller laufen zu lassen, setzen Sie segmax = "
+"%d (siehe Handbuch)."
 #: ../lib/rst/interp_float/vinput2d.c:276
 #, c-format
@@ -5859,17 +6090,23 @@
 #: ../lib/imagery/fopen.c:79
 #, c-format
 msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht erstellen."
+msgstr ""
+"Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht "
+"erstellen."
 #: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
 #, c-format
 msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht öffnen."
+msgstr ""
+"öffnen."
 #: ../lib/imagery/fopen.c:116
 #, c-format
 msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht finden."
+msgstr ""
+"finden."
 #: ../lib/imagery/georef_tps.c:219
 msgid "Calculating forward transformation coefficients"
@@ -5899,17 +6136,24 @@
 #: ../lib/imagery/list_subgp.c:85
 #, c-format
 msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr "Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
+msgstr ""
+"Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
 #: ../lib/imagery/sigsetfile.c:41
 #, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
-msgstr "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> - <%s> nicht erstellen, da es nicht im aktuellen Mapset ist."
+msgid ""
+"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
+"is not current mapset"
+msgstr ""
+"Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> - <%s> "
+"nicht erstellen, da es nicht im aktuellen Mapset ist."
 #: ../lib/imagery/sigsetfile.c:57
 #, c-format
 msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> nicht erstellen."
+msgstr ""
+"Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> nicht "
+"erstellen."
 #: ../lib/imagery/points.c:124
 #, c-format
@@ -6022,7 +6266,9 @@
 msgstr ""
 #: ../lib/imagery/iscatt_core.c:579
-msgid "Data inconsistent. Value computed for scatter plot is out of initialized range."
+msgid ""
+"Data inconsistent. Value computed for scatter plot is out of initialized "
+"range."
 msgstr ""
 #: ../lib/imagery/iscatt_core.c:745
@@ -6071,8 +6317,12 @@
 #: ../lib/vector/diglib/plus_node.c:214
 #, c-format
-msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
-msgstr "Versuche den Winkel der Linie, die nicht an den Knoten angebunden ist, zu lesen: Knoten %d, Linie %d"
+msgid ""
+"Attempt to read line angle for the line which is not connected to the node: "
+"node %d, line %d"
+msgstr ""
+"Versuche den Winkel der Linie, die nicht an den Knoten angebunden ist, zu "
+"lesen: Knoten %d, Linie %d"
 #: ../lib/vector/diglib/plus.c:222
 msgid "Unable read topology for nodes"
@@ -6132,7 +6382,9 @@
 #: ../lib/vector/diglib/cindex_rw.c:156
 #, fuzzy, c-format
-msgid "This version of GRASS (%d.%d) is too old to read this category index format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this category index format. "
+"Try to rebuild topology or upgrade GRASS to at least version %d."
 msgstr "Vektor."
 #: ../lib/vector/diglib/port_init.c:158
@@ -6176,22 +6428,28 @@
 #: ../lib/vector/diglib/test.c:75
 #, c-format
-msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
+msgid ""
+"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
+"%.16e3E"
 msgstr ""
 #: ../lib/vector/diglib/test.c:89
 #, c-format
-msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
+msgid ""
+"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
+"%.8e3E"
 msgstr ""
 #: ../lib/vector/diglib/test.c:104
 #, c-format
-msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid ""
+"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
 msgstr ""
 #: ../lib/vector/diglib/test.c:119
 #, c-format
-msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid ""
+"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
 msgstr ""
 #: ../lib/vector/diglib/test.c:134
@@ -6201,7 +6459,8 @@
 #: ../lib/vector/diglib/test.c:150
 #, c-format
-msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid ""
+"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
 msgstr ""
 #: ../lib/vector/diglib/test.c:165
@@ -6211,17 +6470,23 @@
 #: ../lib/vector/diglib/plus_struct.c:523
 #, fuzzy, c-format
-msgid "This version of GRASS (%d.%d) is too old to read this topology format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this topology format. Try "
+"to rebuild topology or upgrade GRASS to at least version %d."
 msgstr "Vektor."
 #: ../lib/vector/diglib/plus_struct.c:529
 #, fuzzy, c-format
-msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgid ""
+"Your GRASS version does not fully support topology format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
 msgstr "Vektor."
 #: ../lib/vector/diglib/plus_struct.c:539
 #, fuzzy, c-format
-msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology."
+msgid ""
+"Old topology format version %d.%d is not supported by this release. Try to "
+"rebuild topology."
 msgstr "Vektor."
 #: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
@@ -6241,7 +6506,8 @@
 #: ../lib/vector/diglib/file.c:159
 msgid "Writing to file loaded to memory not supported"
-msgstr "Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
+msgstr ""
+"Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
 #: ../lib/vector/diglib/file.c:197
 msgid "Unable to load file to memory, file not open"
@@ -6258,17 +6524,23 @@
 #: ../lib/vector/diglib/spindex_rw.c:302
 #, fuzzy, c-format
-msgid "This version of GRASS (%d.%d) is too old to read this spatial index format. Try to rebuild topology or upgrade GRASS to at least version %d."
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this spatial index format. "
 msgstr "Vektor."
 #: ../lib/vector/diglib/spindex_rw.c:308
 #, fuzzy, c-format
-msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgid ""
+"Your GRASS version does not fully support spatial index format %d.%d of the "
 msgstr "Vektor."
 #: ../lib/vector/diglib/spindex_rw.c:317
 #, c-format
-msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
+msgid ""
+"Spatial index format version %d.%d is not supported by this release. Please "
 msgstr ""
 #: ../lib/vector/diglib/plus_area.c:217 ../lib/vector/diglib/plus_area.c:719
@@ -6301,7 +6573,8 @@
 #: ../lib/vector/diglib/plus_area.c:412
 #, c-format
 msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr "Toter Zentroid %d für Fläche registriert (Bug in der Vektorbibliothek)."
+msgstr ""
+"Toter Zentroid %d für Fläche registriert (Bug in der Vektorbibliothek)."
 #: ../lib/vector/diglib/plus_area.c:437
 #, c-format
@@ -6419,14 +6692,17 @@
 #: ../lib/vector/Vlib/intersect.c:407
 msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr "Vect_segment_intersection() FEHLER (kollineare nicht vertikale Segmente)"
+msgstr ""
+"Vect_segment_intersection() FEHLER (kollineare nicht vertikale Segmente)"
 #: ../lib/vector/Vlib/intersect.c:1157 ../lib/vector/Vlib/intersect.c:1163
 #: ../lib/vector/Vlib/intersect.c:1165 ../lib/vector/Vlib/intersect.c:1219
 #: ../lib/vector/Vlib/intersect.c:1228 ../lib/vector/Vlib/intersect.c:1249
 #: ../lib/vector/Vlib/intersect.c:1266
 msgid "Error while adding point to array. Out of memory"
-msgstr "Fehler beim Hinzufügen eines Punktes zum Array. Nicht genügend Arbeitsspeicher."
+msgstr ""
+"Fehler beim Hinzufügen eines Punktes zum Array. Nicht genügend "
+"Arbeitsspeicher."
 #: ../lib/vector/Vlib/map.c:106 ../lib/vector/Vlib/map.c:251
 msgid "Vector map name is not SQL compliant"
@@ -6724,17 +7000,20 @@
 #: ../lib/vector/Vlib/array.c:292
 #, c-format
 msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr "Kann den Datensatz in der Tabelle <%s> nicht selektieren (key %s, where %s)."
+msgstr ""
+"Kann den Datensatz in der Tabelle <%s> nicht selektieren (key %s, where %s)."
 #: ../lib/vector/Vlib/legal_vname.c:43
 #, c-format
 msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr "Ungültiger Name der Vektorkarte <%s>. Darf nicht '.' oder 'NULL' enthalten."
+msgstr ""
+"Ungültiger Name der Vektorkarte <%s>. Darf nicht '.' oder 'NULL' enthalten."
 #: ../lib/vector/Vlib/legal_vname.c:50
 #, c-format
 msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr "Ungültiger Name der Vektorkarte <%s>. Muss mit einem Buchstaben beginnen."
+msgstr ""
+"Ungültiger Name der Vektorkarte <%s>. Muss mit einem Buchstaben beginnen."
 #: ../lib/vector/Vlib/legal_vname.c:58
 #, c-format
@@ -6743,8 +7022,11 @@
 #: ../lib/vector/Vlib/legal_vname.c:65
 #, c-format
-msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr "Ungültiger Name der Vektorkarte <%s>. SQL-Schlüsselwort darf nicht als Vektorkartenname benutzt werden."
+msgid ""
+"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr ""
+"Ungültiger Name der Vektorkarte <%s>. SQL-Schlüsselwort darf nicht als "
+"Vektorkartenname benutzt werden."
 #: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
 #, c-format
@@ -6807,7 +7089,8 @@
 #: ../lib/vector/Vlib/net.c:369
 #, c-format
 msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr "Spaltentyp der Spalte <%s> wird nicht unterstützt (muss numerisch sein)."
+msgstr ""
+"Spaltentyp der Spalte <%s> wird nicht unterstützt (muss numerisch sein)."
 #: ../lib/vector/Vlib/net.c:222
 msgid "Registering arcs..."
@@ -6815,13 +7098,21 @@
 #: ../lib/vector/Vlib/net.c:251
 #, c-format
-msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
-msgstr "Datenbankeintrag für Linie %d (cat = %d, vorwärts/beide Richtung(en)) nicht gefunden (vorwärts/beide Richtung(en) der Linie übersprungen)."
+msgid ""
+"Database record for line %d (cat = %d, forward/both direction(s)) not found "
+"(forward/both direction(s) of line skipped)"
+msgstr ""
+"Datenbankeintrag für Linie %d (cat = %d, vorwärts/beide Richtung(en)) nicht "
+"gefunden (vorwärts/beide Richtung(en) der Linie übersprungen)."
 #: ../lib/vector/Vlib/net.c:270
 #, c-format
-msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
-msgstr "Datenbankeintrag für Linie %d (cat = %d, rückwärts Richtung) nicht gefunden (Richtung der Linie übersprungen)."
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not "
+"found(direction of line skipped)"
+msgstr ""
+"Datenbankeintrag für Linie %d (cat = %d, rückwärts Richtung) nicht gefunden "
+"(Richtung der Linie übersprungen)."
 #: ../lib/vector/Vlib/net.c:319
 msgid "Cannot add network arc"
@@ -6834,7 +7125,9 @@
 #: ../lib/vector/Vlib/net.c:412
 #, c-format
 msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr "Datenbankeintrag für Knoten %d (cat = %d) nicht gefunden (Kosten auf 0 gesetzt)."
+msgstr ""
+"Datenbankeintrag für Knoten %d (cat = %d) nicht gefunden (Kosten auf 0 "
+"gesetzt)."
 #: ../lib/vector/Vlib/net.c:441
 msgid "Flattening the graph..."
@@ -7117,7 +7410,9 @@
 msgstr "Die Datenbankverbindung für den Layer <%d> ist nicht definiert."
 #: ../lib/vector/Vlib/field.c:185
-msgid "More DB links defined for input vector map. Using only first DB link for output."
+msgid ""
+"More DB links defined for input vector map. Using only first DB link for "
+"output."
 msgstr ""
 #: ../lib/vector/Vlib/field.c:261
@@ -7169,12 +7464,17 @@
 msgstr "Kann den OGR DBMI-Treiber nicht öffnen."
 #: ../lib/vector/Vlib/field.c:758
-msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
-msgstr "Alle FID Tests fehlgeschlagen. Weder 'FID' noch 'ogc_fid', 'ogr_fid', 'gid' sind in der OGR DB Tabelle vorhanden."
+msgid ""
+"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
+"available in OGR DB table"
+msgstr ""
+"Alle FID Tests fehlgeschlagen. Weder 'FID' noch 'ogc_fid', 'ogr_fid', 'gid' "
+"sind in der OGR DB Tabelle vorhanden."
 #: ../lib/vector/Vlib/field.c:825
 #, c-format
-msgid "Feature table <%s> has no primary key defined. Unable to define DB links."
+msgid ""
+"Feature table <%s> has no primary key defined. Unable to define DB links."
 msgstr ""
 #: ../lib/vector/Vlib/field.c:845
@@ -7193,7 +7493,8 @@
 #: ../lib/vector/Vlib/field.c:1006
 msgid "Bug: attempt to update map which is not in current mapset"
-msgstr "Bug: Versuch eine Karte zu aktualisieren, die nicht im aktuellen Mapset ist."
+msgstr ""
+"Bug: Versuch eine Karte zu aktualisieren, die nicht im aktuellen Mapset ist."
 #: ../lib/vector/Vlib/graph.c:138
 msgid "Unable to add network arc"
@@ -7257,13 +7558,20 @@
 #: ../lib/vector/Vlib/open_nat.c:154
 #, fuzzy, c-format
-msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
-msgstr "Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte Überschuss)."
+msgid ""
+"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
+"excess)"
+msgstr ""
+"Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte "
+"Überschuss)."
 #: ../lib/vector/Vlib/open_nat.c:158
 #, fuzzy, c-format
-msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
-msgstr "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte Fehlend)."
+msgid ""
+"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr ""
+"Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte "
+"Fehlend)."
 #: ../lib/vector/Vlib/box.c:228
 #, fuzzy, c-format
@@ -7297,7 +7605,9 @@
 #: ../lib/vector/Vlib/cats.c:419
 #, c-format
 msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr "Kann die Kategorie-Zeichenkette '%s' (von '%s') nicht in eine Kategoriespanne konvertieren."
+msgstr ""
+"Kann die Kategorie-Zeichenkette '%s' (von '%s') nicht in eine "
+"Kategoriespanne konvertieren."
 #: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
 #, fuzzy
@@ -7521,8 +7831,12 @@
 #: ../lib/vector/Vlib/geos.c:55
 #, c-format
-msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
-msgstr "Vect_read_line_geos(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
+msgid ""
+"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
+"vector map <%s>: %d)"
+msgstr ""
+"Vect_read_line_geos(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in "
+"Vektorkarte <%s>: %d)."
 #: ../lib/vector/Vlib/geos.c:60
 msgid "only native format supported"
@@ -7540,7 +7854,8 @@
 #: ../lib/vector/Vlib/geos.c:104
 #, c-format
 msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr "Vect_read_area_geos(): Kann Insel-ID %d der Fläche mit ID %d nicht lesen."
+msgstr ""
+"Vect_read_area_geos(): Kann Insel-ID %d der Fläche mit ID %d nicht lesen."
 #: ../lib/vector/Vlib/geos.c:203
 #, c-format
@@ -7598,8 +7913,11 @@
 #: ../lib/vector/Vlib/build_ogr.c:82
 #, fuzzy
-msgid "Random read is not supported by OGR for this layer. Unable to build topology."
-msgstr "Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support nicht erzeugen."
+msgid ""
+"Random read is not supported by OGR for this layer. Unable to build topology."
+msgstr ""
+"Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support "
+"nicht erzeugen."
 #: ../lib/vector/Vlib/build_ogr.c:88 ../lib/vector/Vlib/build_pg.c:101
 #, c-format
@@ -7755,7 +8073,9 @@
 #: ../lib/vector/Vlib/ascii.c:860
 #, c-format
-msgid "%d features without category skipped. To export also features without category use '%s=-1'."
+msgid ""
+"%d features without category skipped. To export also features without "
+"category use '%s=-1'."
 msgstr ""
 #: ../lib/vector/Vlib/simple_features.c:225
@@ -7856,13 +8176,22 @@
 #: ../lib/vector/Vlib/open_ogr.c:279
 #, c-format
-msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
-msgstr "Objekt Indexformat Version %d.%d wird von dieser Version nicht unterstützt. Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
+msgid ""
+"Feature index format version %d.%d is not supported by this release. Try to "
+"rebuild topology or upgrade GRASS."
+msgstr ""
+"Objekt Indexformat Version %d.%d wird von dieser Version nicht unterstützt. "
+"Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
 #: ../lib/vector/Vlib/open_ogr.c:284
 #, c-format
-msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr "Ihre GRASS Version unterstützt nicht vollständig das Objekt-Indexformat %d.%d der Vektoren. Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
+msgid ""
+"Your GRASS version does not fully support feature index format %d.%d of the "
+msgstr ""
+"Ihre GRASS Version unterstützt nicht vollständig das Objekt-Indexformat %d."
+"%d der Vektoren. Versuchen Sie die Topologie zu erneuern oder GRASS zu "
+"aktualisieren."
 #: ../lib/vector/Vlib/level.c:34
 msgid "Map structure was never initialized"
@@ -7894,7 +8223,8 @@
 #: ../lib/vector/Vlib/read_pg.c:365
 #, c-format
-msgid "Requesting invalid feature from cache (%d). Number of features in cache: %d"
+msgid ""
+"Requesting invalid feature from cache (%d). Number of features in cache: %d"
 msgstr ""
 #: ../lib/vector/Vlib/read_pg.c:368
@@ -8045,7 +8375,9 @@
 msgstr "Kann Datenbankverknüpfung für Vektorkarte <%s> nicht hinzufügen."
 #: ../lib/vector/Vlib/dgraph.c:432
-msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
+msgid ""
+"Trying to add more edges to the planar_graph than the initial allocation "
+"size allows"
 msgstr ""
 #: ../lib/vector/Vlib/select.c:116
@@ -8061,7 +8393,9 @@
 #: ../lib/vector/Vlib/build_pg.c:95
 #, fuzzy
 msgid "Random read is not supported for this layer. Unable to build topology."
+msgstr ""
+"nicht erzeugen."
 #: ../lib/vector/Vlib/build_pg.c:105
 #, fuzzy
@@ -8137,7 +8471,8 @@
 #: ../lib/vector/Vlib/build_pg.c:1018
 #, c-format
-msgid "Unable to build simple features from topogeometry data. Unsupported type %d."
+msgid ""
+"Unable to build simple features from topogeometry data. Unsupported type %d."
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:361
@@ -8151,13 +8486,17 @@
 #: ../lib/vector/Vlib/buffer2.c:589
 #, fuzzy
-msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
-msgstr "Nächste Kante besucht, aber sie ist nicht die Erste !!! Beende Schleife."
+msgid ""
+"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgstr ""
+"Nächste Kante besucht, aber sie ist nicht die Erste !!! Beende Schleife."
 #: ../lib/vector/Vlib/buffer2.c:600
 #, fuzzy
-msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgid ""
+"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:648
 msgid "side != 0 feature not implemented"
@@ -8357,8 +8696,11 @@
 #: ../lib/vector/Vlib/open.c:264
-msgid "Vector map which is not in the current mapset cannot be opened for update"
-msgstr "Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht zum Aktualisierung geöffnet werden."
+msgid ""
+"Vector map which is not in the current mapset cannot be opened for update"
+msgstr ""
+"Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht zum "
+"Aktualisierung geöffnet werden."
 #: ../lib/vector/Vlib/open.c:298
 #, fuzzy, c-format
@@ -8377,8 +8719,12 @@
 #: ../lib/vector/Vlib/open.c:406 ../lib/vector/Vlib/open.c:428
 #, c-format
-msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
-msgstr "Kann die Vektorkarte <%s> nicht auf Level %d öffnen. Versuchen Sie die Topologie mit v.build neu anzulegen."
+msgid ""
+"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
+"by v.build."
+msgstr ""
+"Kann die Vektorkarte <%s> nicht auf Level %d öffnen. Versuchen Sie die "
+"Topologie mit v.build neu anzulegen."
 #: ../lib/vector/Vlib/open.c:437
 #, fuzzy, c-format
@@ -8440,7 +8786,9 @@
 #: ../lib/vector/Vlib/open.c:1133
 msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr "Größe der 'coor' Datei unterscheidet sich von dem in der Topologie-Datei gespeicherten Wert."
+msgstr ""
+"Größe der 'coor' Datei unterscheidet sich von dem in der Topologie-Datei "
+"gespeicherten Wert."
 #: ../lib/vector/Vlib/open.c:1144 ../lib/vector/Vlib/open.c:1244
 #, c-format
@@ -8468,11 +8816,13 @@
 #: ../lib/vector/Vlib/build.c:131
 msgid "Unable to add area (map closed, topo saved)"
-msgstr "Kann Fläche nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
+msgstr ""
+"Kann Fläche nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
 #: ../lib/vector/Vlib/build.c:139
 msgid "Unable to add isle (map closed, topo saved)"
-msgstr "Kann Insel nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
+msgstr ""
+"Kann Insel nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
 #: ../lib/vector/Vlib/build.c:149
 msgid "Area of size = 0.0 ignored"
@@ -8618,7 +8968,9 @@
 #: ../lib/vector/Vlib/build.c:1186
 #, fuzzy
-msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
+msgid ""
+"Unable to build spatial index from topology, vector map is not opened at "
+"topology level 2"
 msgstr "Vektor Karte"
 #: ../lib/vector/Vlib/build.c:1209
@@ -8674,423 +9026,443 @@
 msgstr "Unbekanntes Abfragewerkzeug"
 #, fuzzy
-msgid "Unable to select space time dataset register table <%s>"
-msgstr "Kann keine Daten aus der Tabelle <%s> beziehen."
+#~ msgid "Unable to select space time dataset register table <%s>"
+#~ msgstr "Kann keine Daten aus der Tabelle <%s> beziehen."
 #, fuzzy
-msgid "Unable to create timestamp file for raster3d map <%s>"
-msgstr "Raster Karte."
+#~ msgid "Unable to create timestamp file for raster3d map <%s>"
+#~ msgstr "Raster Karte."
 #, fuzzy
-msgid "Invalid datetime in timestamp for raster3d map <%s>"
-msgstr "Ungültige Zeitstempel-Datei für %s Karte %s in Mapset %s."
+#~ msgid "Invalid datetime in timestamp for raster3d map <%s>"
+#~ msgstr "Ungültige Zeitstempel-Datei für %s Karte %s in Mapset %s."
 #, fuzzy
-msgid "Unable to remove timestamp for raster3d map <%s>"
+#~ msgid "Unable to remove timestamp for raster3d map <%s>"
 #, fuzzy
-msgid "Raster3d map <%s> not found"
-msgstr "Rasterkarte <%s> wurde nicht gefunden."
+#~ msgid "Raster3d map <%s> not found"
+#~ msgstr "Rasterkarte <%s> wurde nicht gefunden."
 #, fuzzy
-msgid "Inconsistency in topology: line %d - unexpected feature type"
-msgstr "Eigenschaften"
+#~ msgid "Inconsistency in topology: line %d - unexpected feature type"
+#~ msgstr "Eigenschaften"
 #, fuzzy
-msgid ""
-"Unable to read PostGIS features\n"
-"%s"
-msgstr "Kann Objekt %d nicht schreiben."
+#~ msgid ""
+#~ "Unable to read PostGIS features\n"
+#~ "%s"
+#~ msgstr "Kann Objekt %d nicht schreiben."
 #, fuzzy
-msgid "%d %s without geometry skipped"
-msgstr "Objekt %d ohne Geometrie ignoriert."
+#~ msgid "%d %s without geometry skipped"
+#~ msgstr "Objekt %d ohne Geometrie ignoriert."
 #, fuzzy
-msgid "Performs unit and integration tests for the g3d library"
-msgstr "Führt Unit- und Integrationstest der GPDE-Bibliothek aus."
+#~ msgid "Performs unit and integration tests for the g3d library"
+#~ msgstr "Führt Unit- und Integrationstest der GPDE-Bibliothek aus."
 #, fuzzy
-msgid ""
-"\n"
-"++ Running g3d coordinate transform unit tests ++"
-msgstr ""
-"\n"
-"++ Führe 'gradient' Unit-Tests aus ++"
+#~ msgid ""
+#~ "\n"
+#~ "++ Running g3d coordinate transform unit tests ++"
+#~ msgstr ""
+#~ "\n"
+#~ "++ Führe 'gradient' Unit-Tests aus ++"
 #, fuzzy
-msgid ""
-"\n"
-"-- g3d coordinate transform unit tests failure --"
-msgstr ""
-"\n"
-"-- 'geom_data' Unit-Tests fehlgeschlagen --"
+#~ msgid ""
+#~ "\n"
+#~ "-- g3d coordinate transform unit tests failure --"
+#~ msgstr ""
+#~ "\n"
+#~ "-- 'geom_data' Unit-Tests fehlgeschlagen --"
 #, fuzzy
-msgid ""
-"\n"
-"-- g3d coordinate transform unit tests finished successfully --"
-msgstr ""
-"\n"
-"-- 'geom_data' Unit-Tests erfolgreich beendet --"
+#~ msgid ""
+#~ "\n"
+#~ "-- g3d coordinate transform unit tests finished successfully --"
+#~ msgstr ""
+#~ "\n"
+#~ "-- 'geom_data' Unit-Tests erfolgreich beendet --"
 #, fuzzy
-msgid ""
-"\n"
-"++ Running g3d put/get value large file unit tests ++"
-msgstr ""
-"\n"
-"++ Führe 'solver' Unit-Tests aus ++"
+#~ msgid ""
+#~ "\n"
+#~ "++ Running g3d put/get value large file unit tests ++"
+#~ msgstr ""
+#~ "\n"
+#~ "++ Führe 'solver' Unit-Tests aus ++"
 #, fuzzy
-msgid ""
-"\n"
-"-- g3d put/get value large file unit tests failure --"
-msgstr ""
-"\n"
-"-- 'solver' Unit-Tests fehlgeschlagen --"
+#~ msgid ""
+#~ "\n"
+#~ "-- g3d put/get value large file unit tests failure --"
+#~ msgstr ""
+#~ "\n"
+#~ "-- 'solver' Unit-Tests fehlgeschlagen --"
 #, fuzzy
-msgid ""
-"\n"
-"-- g3d put/get value large file unit tests finished successfully --"
-msgstr ""
-"\n"
-"-- 'solver' Unit-Tests erfolgreich beendet --"
+#~ msgid ""
+#~ "\n"
+#~ "-- g3d put/get value large file unit tests finished successfully --"
+#~ msgstr ""
+#~ "\n"
+#~ "-- 'solver' Unit-Tests erfolgreich beendet --"
 #, fuzzy
-msgid ""
-"\n"
-"++ Running g3d put/get value unit tests ++"
-msgstr ""
-"\n"
+#~ msgid ""
+#~ "\n"
+#~ "++ Running g3d put/get value unit tests ++"
+#~ msgstr ""
+#~ "\n"
 #, fuzzy
-msgid ""
-"\n"
-"-- g3d put/get value unit tests failure --"
-msgstr ""
-"\n"
+#~ msgid ""
+#~ "\n"
+#~ "-- g3d put/get value unit tests failure --"
+#~ msgstr ""
+#~ "\n"
 #, fuzzy
-msgid ""
-"\n"
-"-- g3d put/get value unit tests finished successfully --"
-msgstr ""
-"\n"
+#~ msgid ""
+#~ "\n"
+#~ "-- g3d put/get value unit tests finished successfully --"
+#~ msgstr ""
+#~ "\n"
 #, fuzzy
-msgid "Registering maps in the temporal database"
-msgstr "Kann die Vektorkarte <%s> in <%s> nicht finden."
+#~ msgid "Registering maps in the temporal database"
+#~ msgstr "Kann die Vektorkarte <%s> in <%s> nicht finden."
 #, fuzzy
-msgid "Space time %(t)s dataset <%(i)s> is already in database, use overwrite flag to overwrite"
-msgstr "Vektorkarte <%s> existiert bereits und wird überschrieben."
+#~ msgid ""
+#~ "Space time %(t)s dataset <%(i)s> is already in database, use overwrite "
+#~ "flag to overwrite"
+#~ msgstr "Vektorkarte <%s> existiert bereits und wird überschrieben."
 #, fuzzy
-msgid "Space time %(type)s dataset <%(id)s> not found"
+#~ msgid "Space time %(type)s dataset <%(id)s> not found"
 #, fuzzy
-msgid "Please specify base="
-msgstr ""
-"\n"
-"Bitte geben Sie ein Datum an.\n"
+#~ msgid "Please specify base="
+#~ msgstr ""
+#~ "\n"
+#~ "Bitte geben Sie ein Datum an.\n"
 #, fuzzy
-msgid "Space time %(type)s dataset <%(id)s> is already in database, use overwrite flag to overwrite"
+#~ msgid ""
+#~ "Space time %(type)s dataset <%(id)s> is already in database, use "
+#~ "overwrite flag to overwrite"
 #, fuzzy
-msgid "OGR feature %d without ID skipped"
-msgstr "OGR feature ohne ID ignoriert."
+#~ msgid "OGR feature %d without ID skipped"
+#~ msgstr "OGR feature ohne ID ignoriert."
 #, fuzzy
-msgid "database"
-msgstr "Datenbankname"
+#~ msgid "database"
+#~ msgstr "Datenbankname"
 #, fuzzy
-msgid "Prints/sets general temporal GIS database connection for current mapset."
-msgstr "Die Datenbankverbindung für den Layer <%d> nicht definiert."
+#~ msgid ""
+#~ "Prints/sets general temporal GIS database connection for current mapset."
+#~ msgstr "Die Datenbankverbindung für den Layer <%d> nicht definiert."
 #, fuzzy
-msgid "Temporal GIS database connection not defined. Run t.connect."
+#~ msgid "Temporal GIS database connection not defined. Run t.connect."
 #, fuzzy
-msgid ""
-"Default TGIS driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
-msgstr ""
-"Standard Treiber / Datenbank ist:\n"
-"Treiber: %s\n"
-"Datenbank: %s"
+#~ msgid ""
+#~ "Default TGIS driver / database set to:\n"
+#~ "driver: %s\n"
+#~ "database: %s"
+#~ msgstr ""
+#~ "Standard Treiber / Datenbank ist:\n"
+#~ "Treiber: %s\n"
+#~ "Datenbank: %s"
 #, fuzzy
-msgid "Default TGIS driver is not set"
-msgstr "Standard-Treiber wurde nicht angegeben."
+#~ msgid "Default TGIS driver is not set"
+#~ msgstr "Standard-Treiber wurde nicht angegeben."
 #, fuzzy
-msgid "Default TGIS database is not set"
-msgstr "Standard-Datenbank ist nicht angegeben."
+#~ msgid "Default TGIS database is not set"
+#~ msgstr "Standard-Datenbank ist nicht angegeben."
 #, fuzzy
-msgid "Unregister %(type)s map <%(map)s> from space time datasets"
-msgstr "Rasterkarte <%s> nicht im Mapset <%s> gefunden."
+#~ msgid "Unregister %(type)s map <%(map)s> from space time datasets"
+#~ msgstr "Rasterkarte <%s> nicht im Mapset <%s> gefunden."
 #, fuzzy
-msgid "Register %s map <%s> with layer %s in space time %s dataset <%s>"
+#~ msgid "Register %s map <%s> with layer %s in space time %s dataset <%s>"
 #, fuzzy
-msgid "Register %s map <%s> in space time %s dataset <%s>"
+#~ msgid "Register %s map <%s> in space time %s dataset <%s>"
 #, fuzzy
-msgid "Created register table <%s> for %s map <%s> with layer %s"
-msgstr "Kann keine quant-Regeln für Karte %s schreiben."
+#~ msgid "Created register table <%s> for %s map <%s> with layer %s"
+#~ msgstr "Kann keine quant-Regeln für Karte %s schreiben."
 #, fuzzy
-msgid "Unregister %s map <%s> with layer %s"
-msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
+#~ msgid "Unregister %s map <%s> with layer %s"
+#~ msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
 #, fuzzy
-msgid "Unregister %s map <%s>"
+#~ msgid "Unregister %s map <%s>"
 #, fuzzy
-msgid "Attempt to read dead feature %d"
-msgstr "Versuche ein totes Objekt zu löschen"
+#~ msgid "Attempt to read dead feature %d"
+#~ msgstr "Versuche ein totes Objekt zu löschen"
 #, fuzzy
-msgid "Reading failed: %s"
-msgstr "Laden fehlgeschlagen."
+#~ msgid "Reading failed: %s"
+#~ msgstr "Laden fehlgeschlagen."
 #, fuzzy
-msgid "Unable to get features"
+#~ msgid "Unable to get features"
 #, fuzzy
-msgid "Could not find isle box"
-msgstr "Kann die Rasterzeile nicht bekommen."
+#~ msgid "Could not find isle box"
+#~ msgstr "Kann die Rasterzeile nicht bekommen."
 #, fuzzy
-msgid "Requested feature id %d is not reasonable(max features in vector map <%s>: %d)"
-msgstr "Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
+#~ msgid ""
+#~ "Requested feature id %d is not reasonable(max features in vector map <"
+#~ "%s>: %d)"
+#~ msgstr ""
+#~ "Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in "
+#~ "Vektorkarte <%s>: %d)."
 #, fuzzy
-msgid "<%s> is not the current mapset (%s)"
-msgstr "%s ist nicht im aktuellen Mapset (%s)."
+#~ msgid "<%s> is not the current mapset (%s)"
+#~ msgstr "%s ist nicht im aktuellen Mapset (%s)."
 #, fuzzy
-msgid "Unable to get feature type"
+#~ msgid "Unable to get feature type"
 #, fuzzy
-msgid "Topology not available. Unable to insert new edge."
-msgstr "Leider keine Hilfe für den Befehl [%s] verfügbar.\n"
+#~ msgid "Topology not available. Unable to insert new edge."
+#~ msgstr "Leider keine Hilfe für den Befehl [%s] verfügbar.\n"
 #, fuzzy
-msgid "Unable to write new feature"
+#~ msgid "Unable to write new feature"
 #, fuzzy
-msgid "Unable to attach centroids"
-msgstr "Kann keinen Zentroid für die Fläche %d berechnen."
+#~ msgid "Unable to attach centroids"
+#~ msgstr "Kann keinen Zentroid für die Fläche %d berechnen."
 #, fuzzy
-msgid "Unexpected feature type (%s) - should be (%d)"
+#~ msgid "Unexpected feature type (%s) - should be (%d)"
 #, fuzzy
-msgid "Unable to read centroid %d: %s"
-msgstr "Kann die Objekt-ID %d nicht lesen."
+#~ msgid "Unable to read centroid %d: %s"
+#~ msgstr "Kann die Objekt-ID %d nicht lesen."
 #, fuzzy
-msgid "Unable to export node %d. Exiting."
-msgstr "Kann keinen Speicher für temporäres Bild belegen."
+#~ msgid "Unable to export node %d. Exiting."
+#~ msgstr "Kann keinen Speicher für temporäres Bild belegen."
 #, fuzzy
-msgid "Unable to look up account id"
-msgstr "Kann Codec nicht öffnen."
+#~ msgid "Unable to look up account id"
+#~ msgstr "Kann Codec nicht öffnen."
 #, fuzzy
-msgid "Unable to allocate memory for account name"
-msgstr "Kann keinen Speicher reservieren für einen NULL-Buffer."
+#~ msgid "Unable to allocate memory for account name"
+#~ msgstr "Kann keinen Speicher reservieren für einen NULL-Buffer."
 #, fuzzy
-msgid "Unable to allocate memory for domain name"
+#~ msgid "Unable to allocate memory for domain name"
 #, fuzzy
-msgid "Unable to remove space time dataset register table <%s>"
+#~ msgid "Unable to remove space time dataset register table <%s>"
 #, fuzzy
-msgid "Unable to drop table <%s>"
-msgstr "Kann die Tabelle <%s> nicht kopieren."
+#~ msgid "Unable to drop table <%s>"
+#~ msgstr "Kann die Tabelle <%s> nicht kopieren."
 #, fuzzy
-msgid "Unable to create the space time %s dataset register table for map <%s> with layer %s"
-msgstr "Kann Header-Datei für [%s] nicht erstellen."
+#~ msgid ""
+#~ "Unable to create the space time %s dataset register table for map <%s> "
+#~ "with layer %s"
+#~ msgstr "Kann Header-Datei für [%s] nicht erstellen."
 #, fuzzy
-msgid "Unable to find map <%s> with layer %s in temporal database"
+#~ msgid "Unable to find map <%s> with layer %s in temporal database"
 #, fuzzy
-msgid "Spatial index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
-msgstr "Vektor."
+#~ msgid ""
+#~ "Spatial index format version %d.%d is not supported by this release. Try "
+#~ "to rebuild topology or upgrade GRASS."
+#~ msgstr "Vektor."
 #, fuzzy
-msgid "Unable to read read line %d"
-msgstr "Kann Linie %d nicht lesen"
+#~ msgid "Unable to read read line %d"
+#~ msgstr "Kann Linie %d nicht lesen"
 #, fuzzy
-msgid "Unable to delete feature id %d from vector map <%s>"
-msgstr "Vektor Karte"
+#~ msgid "Unable to delete feature id %d from vector map <%s>"
+#~ msgstr "Vektor Karte"
 #, fuzzy
-msgid "Unable to open null device"
-msgstr "Kann %s nicht öffnen."
+#~ msgid "Unable to open null device"
+#~ msgstr "Kann %s nicht öffnen."
 #, fuzzy
-msgid "The support for OGR vector maps wasn't compiled in"
-msgstr "Kategorie Unterstützung für die Vektordatei [%s] in Mapset [%s] %s"
+#~ msgid "The support for OGR vector maps wasn't compiled in"
+#~ msgstr "Kategorie Unterstützung für die Vektordatei [%s] in Mapset [%s] %s"
 #, fuzzy
-msgid "End time must be later than start time"
-msgstr "Ostwert muss größer als der Westwert sein."
+#~ msgid "End time must be later than start time"
+#~ msgstr "Ostwert muss größer als der Westwert sein."
 #, fuzzy
-msgid "None"
-msgstr "nichts"
+#~ msgid "None"
+#~ msgstr "nichts"
 #, fuzzy
-msgid "Unknown"
-msgstr "nicht bekannt"
+#~ msgid "Unknown"
+#~ msgstr "nicht bekannt"
 #, fuzzy
-msgid "Uknown column <%s>"
-msgstr "Unbekannter Spaltentyp (Spalte <%s>)"
+#~ msgid "Uknown column <%s>"
+#~ msgstr "Unbekannter Spaltentyp (Spalte <%s>)"
 #, fuzzy
-msgid "test, gmath"
-msgstr "test, gpde"
+#~ msgid "test, gmath"
+#~ msgstr "test, gpde"
 #, fuzzy
-msgid "Unable to delete file '%s'. Reason: %s"
-msgstr "Kann Datei '%s' nicht löschen."
+#~ msgid "Unable to delete file '%s'. Reason: %s"
+#~ msgstr "Kann Datei '%s' nicht löschen."
 #, fuzzy
-msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
-msgstr "Kann das Verzeichnis '%s' nicht in '%s' umbenennen."
+#~ msgid "Unable to rename directory '%s' to '%s'. Reason: %s"
+#~ msgstr "Kann das Verzeichnis '%s' nicht in '%s' umbenennen."
 #, fuzzy
-msgid "Unable to delete prior null-cells file"
+#~ msgid "Unable to delete prior null-cells file"
 #, fuzzy
-msgid "Unable to close the null-cells file"
-msgstr "Kann head nicht in die plus-Datei schreiben."
+#~ msgid "Unable to close the null-cells file"
+#~ msgstr "Kann head nicht in die plus-Datei schreiben."
 #, fuzzy
-msgid "closecell: can't move [%s] to null-cells file [%s]"
-msgstr ""
-"closecell: Kann  %s\n"
-"nicht in die NULL-Datei %s verschieben."
+#~ msgid "closecell: can't move [%s] to null-cells file [%s]"
+#~ msgstr ""
+#~ "closecell: Kann  %s\n"
+#~ "nicht in die NULL-Datei %s verschieben."
 #, fuzzy
-msgid "Unable to delete the temporary null-cells file"
-msgstr "Kann keine temporäre NULL-Datei %s finden."
+#~ msgid "Unable to delete the temporary null-cells file"
+#~ msgstr "Kann keine temporäre NULL-Datei %s finden."
 #, fuzzy
-msgid "Unable to delete the empty temporary null-cells file"
+#~ msgid "Unable to delete the empty temporary null-cells file"
 #, fuzzy
-msgid "Unable to delete the prior null-cells file"
+#~ msgid "Unable to delete the prior null-cells file"
 #, fuzzy
-msgid "Unable to close the 'cell' file"
-msgstr "Kann Header-Datei nicht lesen."
+#~ msgid "Unable to close the 'cell' file"
+#~ msgstr "Kann Header-Datei nicht lesen."
 #, fuzzy
-msgid "Unable to delete prior 'fcell' file"
+#~ msgid "Unable to delete prior 'fcell' file"
 #, fuzzy
-msgid "Unable to delete the prior %s file"
-msgstr "Kann Tabelle <%s> nicht löschen."
+#~ msgid "Unable to delete the prior %s file"
+#~ msgstr "Kann Tabelle <%s> nicht löschen."
 #, fuzzy
-msgid "Unable to close file"
-msgstr "Kann Datei %s nicht öffnen."
+#~ msgid "Unable to close file"
+#~ msgstr "Kann Datei %s nicht öffnen."
 #, fuzzy
-msgid "Unable to delete the prior 'cell' file"
+#~ msgid "Unable to delete the prior 'cell' file"
 #, fuzzy
-msgid "closecell: can't move [%s] to cell file [%s]"
-msgstr ""
-"nicht in die cell-Datei %s verschieben."
+#~ msgid "closecell: can't move [%s] to cell file [%s]"
+#~ msgstr ""
+#~ "nicht in die cell-Datei %s verschieben."
 #, fuzzy
-msgid "Unable to delete the temporary 'cell' file"
-msgstr "Kann temporäre Datei nicht öffnen."
+#~ msgid "Unable to delete the temporary 'cell' file"
+#~ msgstr "Kann temporäre Datei nicht öffnen."
 #, fuzzy
-msgid "Unable to write quant file!"
-msgstr "Kann quant-Datei nicht schreiben!"
+#~ msgid "Unable to write quant file!"
+#~ msgstr "Kann quant-Datei nicht schreiben!"
 #, fuzzy
-msgid "Unable to delete the %s file"
+#~ msgid "Unable to delete the %s file"
 #, fuzzy
-msgid "Unable to write f_format file for CELL maps"
-msgstr "Kann f_format Datei für cell-Karten nicht schreiben."
+#~ msgid "Unable to write f_format file for CELL maps"
+#~ msgstr "Kann f_format Datei für cell-Karten nicht schreiben."
-msgid "taking too long to find points for interpolation--please change the region to area where your points are. Continuing calculations..."
-msgstr "Es dauert zu lange, um Punkte für die Interpolation zu finden -- bitte ändern Sie die Region auf den Bereich, in dem ihre Punkte sind. Fahre mit der Berechnung fort..."
+#~ msgid ""
+#~ "taking too long to find points for interpolation--please change the "
+#~ "region to area where your points are. Continuing calculations..."
+#~ msgstr ""
+#~ "Es dauert zu lange, um Punkte für die Interpolation zu finden -- bitte "
+#~ "ändern Sie die Region auf den Bereich, in dem ihre Punkte sind. Fahre mit "
+#~ "der Berechnung fort..."
-msgid "Reading lines from vector map ... "
-msgstr "Lese Linien der Vektorkarte ... "
+#~ msgid "Reading lines from vector map ... "
+#~ msgstr "Lese Linien der Vektorkarte ... "
-msgid "Reading nodes from vector map ... "
-msgstr "Lese Knoten der Vektorkarte ... "
+#~ msgid "Reading nodes from vector map ... "
+#~ msgstr "Lese Knoten der Vektorkarte ... "
-msgid "strip exists with insufficient data"
-msgstr "Es gibt einen Streifen mit unzureichend Daten."
+#~ msgid "strip exists with insufficient data"
+#~ msgstr "Es gibt einen Streifen mit unzureichend Daten."
-msgid "there are points outside specified 2D/3D region--ignored %d points"
-msgstr "Es sind Punkte außerhalb der angegebenen 2D/3D-Region gefunden worden - ignoriere %d Punkte."
+#~ msgid "there are points outside specified 2D/3D region--ignored %d points"
+#~ msgstr ""
+#~ "Es sind Punkte außerhalb der angegebenen 2D/3D-Region gefunden worden - "
+#~ "ignoriere %d Punkte."
-msgid "ignoring %d points -- too dense"
-msgstr "Ignoriere %d Punkte -- sie liegen zu dicht beieinander."
+#~ msgid "ignoring %d points -- too dense"
+#~ msgstr "Ignoriere %d Punkte -- sie liegen zu dicht beieinander."
-msgid "some points outside of region -- will ignore..."
-msgstr "einige Punkte sind außerhalb der Region -- ignoriere dies..."
+#~ msgid "some points outside of region -- will ignore..."
+#~ msgstr "einige Punkte sind außerhalb der Region -- ignoriere dies..."
-msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
-msgstr "G_malloc: Kann nicht %lu Byte auf %s:%d reservieren."
+#~ msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
+#~ msgstr "G_malloc: Kann nicht %lu Byte auf %s:%d reservieren."
-msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
-msgstr "G_calloc: Kann nicht %lu * %lu Byte auf %s:%d reservieren."
+#~ msgid "G_calloc: unable to allocate %lu * %lu bytes at %s:%d"
+#~ msgstr "G_calloc: Kann nicht %lu * %lu Byte auf %s:%d reservieren."
-msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
-msgstr "G_realloc: Kann nicht %lu Byte auf %s:%d reservieren."
+#~ msgid "G_realloc: unable to allocate %lu bytes at %s:%d"
+#~ msgstr "G_realloc: Kann nicht %lu Byte auf %s:%d reservieren."
-msgid " The raster map %s@%s is empty"
-msgstr " Die Rasterkarte %s@%s ist leer."
+#~ msgid " The raster map %s@%s is empty"
+#~ msgstr " Die Rasterkarte %s@%s ist leer."
 #~ msgid "Line%s of ellipsoid table file <%s> is invalid"
 #~ msgstr "Die Zeile %s der Ellipsoid-Tabelle <%s> ist ungültig."
@@ -9339,7 +9711,8 @@
 #~ "-- Hitzefluss Integrations-Tests erfolgreich beendet --"
 #~ msgid "Unable open spatial index file for write <%s>"
-#~ msgstr "Kann Datei des räumlichen Index nicht zum Schreiben von <%s> öffnen."
+#~ msgstr ""
+#~ "Kann Datei des räumlichen Index nicht zum Schreiben von <%s> öffnen."
 #~ msgid "Unable to read line %d"
 #~ msgstr "Kann Linie %d nicht lesen."
@@ -9347,17 +9720,32 @@
 #~ msgid "Unable to rewrite feature, vector map is not opened"
 #~ msgstr "Kann Objekt nicht schreiben. Vektorkarte ist nicht geöffnet."
-#~ msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
-#~ msgstr "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht auf topologischem Level geöffnet."
+#~ msgid ""
+#~ "Unable to delete feature %d, vector map <%s> is not opened on topology "
+#~ "level"
+#~ msgstr ""
+#~ "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht auf "
+#~ "topologischem Level geöffnet."
-#~ msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-#~ msgstr "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
+#~ msgid ""
+#~ "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+#~ msgstr ""
+#~ "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht im Schreibmodus "
+#~ "geöffnet."
-#~ msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
-#~ msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht auf topologischem Level geöffnet."
+#~ msgid ""
+#~ "Unable to restore feature %d, vector map <%s> is not opened on topology "
+#~ "level"
+#~ msgstr ""
+#~ "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht auf "
-#~ msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-#~ msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
+#~ msgid ""
+#~ "Unable to restore feature %d, vector map <%s> is not opened in 'write' "
+#~ "mode"
+#~ msgstr ""
+#~ "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im "
+#~ "Schreibmodus geöffnet."
 #~ msgid "Unable to open cidx file <%s> for write"
 #~ msgstr "Kann cidx Datei <%s> nicht zum Schreiben öffnen."
@@ -9366,10 +9754,14 @@
 #~ msgstr "Eingabe-Vektorkarte ist nicht offen."
 #~ msgid "Unable to write lockfile %s (disk full? Permissions?)"
-#~ msgstr "Kann \"lockfile\" %s nicht anlegen (Festplatte voll? Zugriffsrechte?)"
+#~ msgstr ""
+#~ "Kann \"lockfile\" %s nicht anlegen (Festplatte voll? Zugriffsrechte?)"
-#~ msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-#~ msgstr "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s@%s> nicht öffnen."
+#~ msgid ""
+#~ "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
+#~ msgstr ""
+#~ "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s@%s> "
+#~ "nicht öffnen."
 #~ msgid "Unable to open topo file for write <%s>"
 #~ msgstr "Kann Topologie-Datei nicht zum Schreiben von <%s> öffnen."
@@ -9510,7 +9902,8 @@
 #~ msgstr "Verwenden Sie d.mon, um ein Grafikfenster zu selektieren."
 #~ msgid "Trying to connect to something not a socket."
-#~ msgstr "Versuche eine Verbindung zu etwas herzustellen, was kein Socket ist."
+#~ msgstr ""
+#~ "Versuche eine Verbindung zu etwas herzustellen, was kein Socket ist."
 #~ msgid "Probably program error."
 #~ msgstr "Wahrscheinlich ein Programmfehler."
@@ -9579,8 +9972,12 @@
 #~ msgid "Cannot write quant rules: map %s is integer"
 #~ msgstr "Kann quant-Regeln nicht schreiben: Karte %s ist eine Integerkarte."
-#~ msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
-#~ msgstr "G_set_window(): Projektion/Zone unterscheidet sich von gerade geöffneten Rasterkarten."
+#~ msgid ""
+#~ "G_set_window(): projection/zone differs from that of currently open "
+#~ "raster maps"
+#~ msgstr ""
+#~ "G_set_window(): Projektion/Zone unterscheidet sich von gerade geöffneten "
+#~ "Rasterkarten."
 #~ msgid "The floating data range for %s@%s is empty"
 #~ msgstr "Der Fließkomma-Wertebereich von %s@%s ist leer."
@@ -9592,16 +9989,23 @@
 #~ msgstr "Quantisierungsdatei [%s] in Mapset [%s] %s."
 #~ msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-#~ msgstr "G_put_map_row: %s ist keine Integer-Karte! Benutzen Sie G_put_[f/d]_raster_row()!"
+#~ msgstr ""
+#~ "G_put_map_row: %s ist keine Integer-Karte! Benutzen Sie G_put_[f/"
+#~ "d]_raster_row()!"
 #~ msgid "%s: map [%s] not open for write - request ignored"
-#~ msgstr "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
+#~ msgstr ""
+#~ "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
 #~ msgid "%s: map [%s] not open for random write - request ignored"
-#~ msgstr "%s Karte [%s] ist nicht zum zufälligen Schreiben geöffnet - Anfrage wird ignoriert."
+#~ msgstr ""
+#~ "%s Karte [%s] ist nicht zum zufälligen Schreiben geöffnet - Anfrage wird "
+#~ "ignoriert."
 #~ msgid "%s: map [%s] not open for sequential write - request ignored"
-#~ msgstr "%s: Karte [%s] ist nicht für sequentielles Schreiben geöffnet - Anfrage wird ignoriert."
+#~ msgstr ""
+#~ "%s: Karte [%s] ist nicht für sequentielles Schreiben geöffnet - Anfrage "
+#~ "wird ignoriert."
 #~ msgid "%s: unopened file descriptor - request ignored"
 #~ msgstr "%s: Ungeöffneter Dateideskriptor - Anfrage ignoriert."
@@ -9673,8 +10077,12 @@
 #~ msgid "Layer number"
 #~ msgstr "Layer-Nummer"
-#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
-#~ msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
+#~ msgid ""
+#~ "A single vector map can be connected to multiple database tables. This "
+#~ "number determines which table to use."
+#~ msgstr ""
+#~ "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
+#~ "sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
 #~ msgid "Sorry <%s> is not a valid option\n"
 #~ msgstr "Tut mir leid, <%s> ist keine gültige Option\n"
@@ -9838,7 +10246,8 @@
 #~ msgstr "Ungültiger Zeitstempel für %s Karte %s in Mapset %s angegeben."
 #~ msgid "Can't open timestamp file for %s map %s in mapset %s"
-#~ msgstr "Kann die Zeitstempel-Datei für %s Karte %s in Mapset %s nicht öffnen."
+#~ msgstr ""
+#~ "Kann die Zeitstempel-Datei für %s Karte %s in Mapset %s nicht öffnen."
 #~ msgid "Can not create a new process!"
 #~ msgstr "Kann keinen neuen Prozess erzeugen!"
@@ -9913,7 +10322,9 @@
 #~ msgstr "Geben Sie %s Dateinamen ein."
 #~ msgid "Enter 'list' for a list of existing %s files\n"
-#~ msgstr "Geben Sie 'list' für eine Liste der bereits existierenden %s Dateien ein.\n"
+#~ msgstr ""
+#~ "Geben Sie 'list' für eine Liste der bereits existierenden %s Dateien "
+#~ "ein.\n"
 #~ msgid "Enter 'list -f' for "
 #~ msgstr "Geben Sie 'list -f' für "
@@ -9975,7 +10386,8 @@
 #~ msgstr "Zu viele reklassifizierte Kategorien für [%s in %s]."
 #~ msgid "Illegal reclass format in header file for [%s in %s]"
-#~ msgstr "Ungültiges Reklassifizierungs-Format in der Header-Datei von [%s in %s]."
+#~ msgstr ""
+#~ "Ungültiges Reklassifizierungs-Format in der Header-Datei von [%s in %s]."
 #~ msgid "Unable to create header file for [%s in %s]"
 #~ msgstr "Kann Header-Datei für [%s in %s] nicht anlegen."
@@ -10006,8 +10418,12 @@
 #~ msgid "Unable to get GIS_LOCK environment variable value"
 #~ msgstr "Kann den Inhalt der Umgebungsvariable GIS_LOCK nicht lesen."
-#~ msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
-#~ msgstr "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+#~ msgid ""
+#~ "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) "
+#~ "S=(%f,%f)(%f,%f)"
+#~ msgstr ""
+#~ "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,"
+#~ "%f) S=(%f,%f)(%f,%f)"
 #~ msgid "Unable to open raster map <%s@%s>"
 #~ msgstr "Kann die Rasterkarte <%s@%s> nicht öffnen."
@@ -10015,17 +10431,27 @@
 #~ msgid "Unable to find <%s@%s>"
 #~ msgstr "Kann <%s@%s> nicht finden."
-#~ msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
-#~ msgstr "Rasterkarte <%s@%s> ist in einer anderen Projektion als die aktuelle Region. Habe Rasterkarte <%s@%s> gefunden, sollte <%s> sein."
+#~ msgid ""
+#~ "Raster map <%s@%s> is in different projection than current region. Found "
+#~ "raster map <%s@%s>, should be <%s>."
+#~ msgstr ""
+#~ "Rasterkarte <%s@%s> ist in einer anderen Projektion als die aktuelle "
+#~ "Region. Habe Rasterkarte <%s@%s> gefunden, sollte <%s> sein."
-#~ msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-#~ msgstr "Rasterkarte <%s@%s> ist in einer anderen Zone (%d) als die aktuelle Region (%d)."
+#~ msgid ""
+#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+#~ msgstr ""
+#~ "Rasterkarte <%s@%s> ist in einer anderen Zone (%d) als die aktuelle "
+#~ "Region (%d)."
 #~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
 #~ msgstr "Rasterkarte <%s@%s>: Bytes pro Zelle (%d) zu groß."
-#~ msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-#~ msgstr "Karte <%s@%s> ist eine GDAL-Verknüpfung, aber GRASS wurde ohne GDAL-Unterstützung kompiliert."
+#~ msgid ""
+#~ "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+#~ msgstr ""
+#~ "Karte <%s@%s> ist eine GDAL-Verknüpfung, aber GRASS wurde ohne GDAL-"
+#~ "Unterstützung kompiliert."
 #~ msgid "<%s>: bad mapset"
 #~ msgstr "<%s>: schlechtes Mapset"
@@ -10033,11 +10459,16 @@
 #~ msgid "G__open_raster_new(): no temp files available"
 #~ msgstr "G__open_raster_new(): keine temp-Datei vorhanden."
-#~ msgid "Unable to write embedded null values for raster map open for random access"
-#~ msgstr "Kann eingebettete NULL-Werte nicht schreiben für Rasterkarten geöffnet für den direkten Zugriff."
+#~ msgid ""
+#~ "Unable to write embedded null values for raster map open for random access"
+#~ msgstr ""
+#~ "Kann eingebettete NULL-Werte nicht schreiben für Rasterkarten geöffnet "
+#~ "für den direkten Zugriff."
 #~ msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-#~ msgstr "G_set_fp_type(): kann nur mit FCELL_TYPE oder DCELL_TYPE aufgerufen werden."
+#~ msgstr ""
+#~ "G_set_fp_type(): kann nur mit FCELL_TYPE oder DCELL_TYPE aufgerufen "
+#~ "werden."
 #~ msgid "Unable to find '%s' in '%s'"
 #~ msgstr "Kann '%s' in '%s' nicht finden."
@@ -10045,8 +10476,11 @@
 #~ msgid "Unable to open '%s'"
 #~ msgstr "Kann '%s' nicht öffnen."
-#~ msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
-#~ msgstr "G_set_quant_rules() kann nur für zum Lesen geöffnete Rasterkarten aufgerufen werden."
+#~ msgid ""
+#~ "G_set_quant_rules() can be called only for raster maps opened for reading"
+#~ msgstr ""
+#~ "G_set_quant_rules() kann nur für zum Lesen geöffnete Rasterkarten "
+#~ "aufgerufen werden."
 #~ msgid "Enter 'list' for the list of available datums\n"
 #~ msgstr "Geben Sie 'list' für eine Liste der verfügbaren Datums ein\n"
@@ -10089,7 +10523,9 @@
 #~ msgstr " Es ist eine Reklassifikation der Rasterkarte <%s@%s> "
 #~ msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-#~ msgstr " Es ist eine Reklassifikation der Rasterkarte <%s@%s>, deren Header Datei ungültig ist."
+#~ msgstr ""
+#~ " Es ist eine Reklassifikation der Rasterkarte <%s@%s>, deren Header Datei "
+#~ "ungültig ist."
 #~ msgid " Invalid format."
 #~ msgstr " Ungültiges Format."
@@ -10098,10 +10534,13 @@
 #~ msgstr "Kann die History-Informationen der Karte [%s] nicht schreiben."
 #~ msgid "Not enough room in history file to record command line."
-#~ msgstr "Nicht genügend Platz in der History-Datei, um die Kommandozeile zu speichern."
+#~ msgstr ""
+#~ "Nicht genügend Platz in der History-Datei, um die Kommandozeile zu "
+#~ "speichern."
 #~ msgid "Not enough room in history file for command line (truncated)."
-#~ msgstr "Nicht genügend Platz in der History-Datei für die Kommandozeile (gekürzt)."
+#~ msgstr ""
+#~ "Nicht genügend Platz in der History-Datei für die Kommandozeile (gekürzt)."
 #~ msgid "Graphics driver [%s] started"
 #~ msgstr "Grafiktreiber [%s] gestartet."
@@ -10115,11 +10554,17 @@
 #~ msgid "not implemented"
 #~ msgstr "nicht implementiert"
-#~ msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
-#~ msgstr "Kann keinen räumlichen Index aus der Topologie erzeugen. Vektorkarte ist nicht auf dem topo level 2 geöffnet."
+#~ msgid ""
+#~ "Unable to build spatial index from topology, vector map is not opened at "
+#~ "topo level 2"
+#~ msgstr ""
+#~ "Kann keinen räumlichen Index aus der Topologie erzeugen. Vektorkarte ist "
+#~ "nicht auf dem topo level 2 geöffnet."
 #~ msgid "Unable to add database link, map is not opened in WRITE mode"
-#~ msgstr "Kann Datenbankverknüpfung nicht hinzufügen. Die Karte ist nicht im Schreibmodus geöffnet."
+#~ msgstr ""
+#~ "Kann Datenbankverknüpfung nicht hinzufügen. Die Karte ist nicht im "
 #~ msgid "Error in rule on row %d in %s"
 #~ msgstr "Fehler in der Regel in Zeile %d in %s."
@@ -10128,13 +10573,22 @@
 #~ msgstr "Unbekanntes Schlüsselwort %s in Vektor Header."
 #~ msgid "Next edge was visited but it is not the first one !!! breaking loop"
-#~ msgstr "Nächste Kante besucht, aber sie ist nicht die Erste!!! Beende Schleife."
+#~ msgstr ""
+#~ "Nächste Kante besucht, aber sie ist nicht die Erste!!! Beende Schleife."
-#~ msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
-#~ msgstr "Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte zuviel)."
+#~ msgid ""
+#~ "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
+#~ "excess)"
+#~ msgstr ""
+#~ "Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld "
+#~ "Byte zuviel)."
-#~ msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
-#~ msgstr "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte fehlen)."
+#~ msgid ""
+#~ "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
+#~ "missing)."
+#~ msgstr ""
+#~ "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld "
+#~ "Byte fehlen)."
 #~ msgid "Intersections: %5d"
 #~ msgstr "Überschneidungen: %5d"
@@ -10161,7 +10615,9 @@
 #~ msgstr "Kann die Rasterzeile %i nicht schreiben."
 #~ msgid "The gauss elimination solver does not work with sparse matrices"
-#~ msgstr "Der Gaußsche Eliminierungslöser kann keine dünnbesetzten Matrizen verarbeiten."
+#~ msgstr ""
+#~ "Der Gaußsche Eliminierungslöser kann keine dünnbesetzten Matrizen "
+#~ "verarbeiten."
 #~ msgid "The linear equation system is not quadratic"
 #~ msgstr "Das lineare Gleichungssystem ist nicht quadratisch."
@@ -10175,32 +10631,45 @@
 #~ msgid "Matrix is not symmetric!"
 #~ msgstr "Matrix ist nicht symmetrisch!"
-#~ msgid "The type of solver which should solve the symmetric linear equation system"
-#~ msgstr "Der Solver, der das symmetrische lineare Gleichungssystem lösen soll"
+#~ msgid ""
+#~ "The type of solver which should solve the symmetric linear equation system"
+#~ msgstr ""
+#~ "Der Solver, der das symmetrische lineare Gleichungssystem lösen soll"
 #~ msgid "The type of solver which should solve the linear equation system"
 #~ msgstr "Der Solver, der das lineare Gleichungssysteme lösen soll"
-#~ msgid "Maximum number of iteration used to solver the linear equation system"
-#~ msgstr "Maximale Anzahl Iterationen, zum Lösen des linearen Gleichungssystems"
+#~ msgid ""
+#~ "Maximum number of iteration used to solver the linear equation system"
+#~ msgstr ""
+#~ "Maximale Anzahl Iterationen, zum Lösen des linearen Gleichungssystems"
-#~ msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-#~ msgstr "Fehlerabbruchkriterien für iterative Löser (jacobi, sor, cg or bicgstab)"
+#~ msgid ""
+#~ "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+#~ msgstr ""
+#~ "Fehlerabbruchkriterien für iterative Löser (jacobi, sor, cg or bicgstab)"
-#~ msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
-#~ msgstr "Entspannungsparameter (relaxation parameter) zur Beschleunigung oder Stabilisierung der Jacobi und SOR Löser"
+#~ msgid ""
+#~ "The relaxation parameter used by the jacobi and sor solver for speedup or "
+#~ "stabilizing"
+#~ msgstr ""
+#~ "Entspannungsparameter (relaxation parameter) zur Beschleunigung oder "
+#~ "Stabilisierung der Jacobi und SOR Löser"
 #~ msgid "test, gpde"
 #~ msgstr "Test, gpde"
 #~ msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-#~ msgstr "Ungültiger Tabellenname <%s>. Er darf weder '.' noch 'NULL' enthalten.\n"
+#~ msgstr ""
+#~ "Ungültiger Tabellenname <%s>. Er darf weder '.' noch 'NULL' enthalten.\n"
 #~ msgid "Illegal table map name <%s>. Must start with a letter.\n"
-#~ msgstr "Ungültiger Tabellenname <%s>. Er muss mit einem Buchstaben beginnen.\n"
+#~ msgstr ""
+#~ "Ungültiger Tabellenname <%s>. Er muss mit einem Buchstaben beginnen.\n"
 #~ msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-#~ msgstr "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
+#~ msgstr ""
+#~ "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
 #~ msgid "Invalid view position coordinates, using %f,%f"
 #~ msgstr "Ungültige Koordinaten für den Betrachtungspunkt, verwende %f,%f"
@@ -10209,10 +10678,14 @@
 #~ msgstr "Vektor ist nicht 3D."
 #~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr "Kann die Z-Spalte <%s> nicht finden (Bitte überprüfen Sie den Name, z.B. mit v.info)."
+#~ msgstr ""
+#~ "Kann die Z-Spalte <%s> nicht finden (Bitte überprüfen Sie den Name, z.B. "
+#~ "mit v.info)."
 #~ msgid "Column type of z column is not supported (must be integer or double)"
-#~ msgstr "Spaltentype der Spalte z wird nicht unterstützt (muss integer oder double sein)."
+#~ msgstr ""
+#~ "Spaltentype der Spalte z wird nicht unterstützt (muss integer oder double "
+#~ "sein)."
 #~ msgid "Cannot read column type of smooth column"
 #~ msgstr "Kann den Spaltentyp der Smooth-Spalte nicht lesen."
@@ -10221,7 +10694,9 @@
 #~ msgstr "Spaltentyp der Smooth-Spalte (datetime) wird nicht unterstützt."
 #~ msgid "Column type of s column is not supported (must be integer or double)"
-#~ msgstr "Spaltentyp der s-Spalte wird nicht unterstützt (muss integer oder double sein)."
+#~ msgstr ""
+#~ "Spaltentyp der s-Spalte wird nicht unterstützt (muss integer oder double "
+#~ "sein)."
 #~ msgid "Unknown Location"
 #~ msgstr "Unbekannte Location"
@@ -10347,7 +10822,8 @@
 #~ msgstr "G3d_openCellOld: Fehler in G3d_readHeader"
 #~ msgid "G3d_openCellOld: projection does not match window projection"
-#~ msgstr "G3d_openCellOld: Projektion passt nicht zu der Projektion des Fensters"
+#~ msgstr ""
+#~ "G3d_openCellOld: Projektion passt nicht zu der Projektion des Fensters"
 #~ msgid "G3d_openCellOld: zone does not match window zone"
 #~ msgstr "G3d_openCellOld: Zone passt nicht zu der Zone des Fensters"
@@ -10429,11 +10905,18 @@
 #~ msgid "'%s' must be > 0 for '%s'"
 #~ msgstr "'%s' muss > 0 für '%s' sein"
-#~ msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
-#~ msgstr "Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
+#~ msgid ""
+#~ "Vect_read_line(): feature id %d is not reasonable (max features in vector "
+#~ "map <%s>: %d)"
+#~ msgstr ""
-#~ msgid "Random read is not supported by OGR for this layer, cannot build support"
-#~ msgstr "Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support nicht erzeugen."
+#~ msgid ""
+#~ "Random read is not supported by OGR for this layer, cannot build support"
+#~ msgstr ""
+#~ "Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann "
+#~ "Support nicht erzeugen."
 #~ msgid "Feature %d without geometry ignored"
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_el.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_el\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2014-03-27 20:41+0100\n"
+"POT-Creation-Date: 2014-03-31 21:29+0200\n"
 "PO-Revision-Date: 2008-10-16 11:25+0300\n"
 "Last-Translator: Vasilios Antoniou <antoniou_v at yahoo.gr>\n"
 "Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -5606,7 +5606,7 @@
 msgid "Unable to parse time string: %s"
 msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ %s óôï <%s>"
-#: ../lib/python/temporal/gui_support.py:57 ../lib/python/script/core.py:1333
+#: ../lib/python/temporal/gui_support.py:57 ../lib/python/script/core.py:1339
 #, python-format
 msgid "Invalid element '%s'"
 msgstr ""
@@ -5669,43 +5669,43 @@
 msgid "Error while computation"
 msgstr ""
-#: ../lib/python/script/core.py:928
+#: ../lib/python/script/core.py:934
 msgid "Mixing value types. Will try to compare after integer conversion"
 msgstr ""
-#: ../lib/python/script/core.py:1146
+#: ../lib/python/script/core.py:1152
 #, python-format
 msgid "Element type should be \"cell\" and not \"%s\""
 msgstr ""
-#: ../lib/python/script/core.py:1175 ../lib/python/script/core.py:1265
-#: ../lib/python/script/core.py:1320
+#: ../lib/python/script/core.py:1181 ../lib/python/script/core.py:1271
+#: ../lib/python/script/core.py:1326
 #, python-format
 msgid "Element type should be \"rast\" and not \"%s\""
 msgstr ""
-#: ../lib/python/script/core.py:1521
+#: ../lib/python/script/core.py:1527
 #, fuzzy
 msgid "Unable to list mapsets"
 msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input"
-#: ../lib/python/script/core.py:1557
+#: ../lib/python/script/core.py:1563
 #, python-format
 msgid "Location <%s> already exists. Operation canceled."
 msgstr ""
-#: ../lib/python/script/core.py:1560
+#: ../lib/python/script/core.py:1566
 #, fuzzy, python-format
 msgid "Location <%s> already exists and will be overwritten"
 msgstr ""
 "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
-#: ../lib/python/script/core.py:1692
+#: ../lib/python/script/core.py:1698
 msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
 msgstr "Ìç åðéôñåðôü üíïìá.  äåí ìðïñåß íá åßíáé  '.' Þ  'NULL'\n"
-#: ../lib/python/script/core.py:1701
+#: ../lib/python/script/core.py:1707
 msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
 msgstr "Ìç åðéôñåðôü üíïìá áñ÷åßïõ. Ï ÷áñáêôÞñáò <%c> äåí åðéôñÝðåôáé.\n"
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_es.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -15,7 +15,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_es\n"
 "PO-Revision-Date: 2013-03-20 00:13-0600\n"
 "Last-Translator: Javier García Prieto <fjgarciaprieto at hotmail.com>\n"
 "Language-Team: Español; Castellano <grass-translations at lists.osgeo.org>\n"
@@ -5770,7 +5770,7 @@
 msgstr "No se puede abrir el archivo <%s>"
 #, python-format
 msgstr ""
@@ -5834,42 +5834,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "No es posible cerrar el mapa de entrada."
 #, python-format
 msgstr ""
 msgstr "El mapa vectorial <%s> ya existe y será sobrescrito."
 msgstr "El nombre del archivo no está permitido. No puede ser '.' o 'NULL'\n"
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_fr.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -11,7 +11,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_fr\n"
 "PO-Revision-Date: 2014-02-03 07:52+0100\n"
 "Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
 "Language-Team: French <grass-translations at lists.osgeo.org>\n"
@@ -5635,7 +5635,7 @@
 msgstr "Impossible d'ouvrir le fichier %s dans <%s>"
 #, python-format
 msgstr ""
@@ -5699,42 +5699,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Impossible de fermer la carte en entrée"
 #, python-format
 msgstr ""
 msgstr "La couche vectorielle <%s> existe déjà et va être écrasé"
 msgstr "Nom de fichier illégal.  Ne peut pas être '.' ou 'NULL'\n"
 msgstr "Nom de fichier illégal. Caractère <%c> interdit.\n"
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_it.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -13,7 +13,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_it\n"
 "PO-Revision-Date: 2013-02-03 12:21+0100\n"
 "Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
@@ -5535,7 +5535,7 @@
 msgstr "Impossibile aprire il file %s in <%s>"
 #, python-format
 msgstr ""
@@ -5598,42 +5598,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Impossibile aprire %s"
 #, python-format
 msgstr ""
 msgstr "Il vettoriale <%s> è già presente e sarà sovrascritto"
 msgstr "Nome file non valido. Non può essere '.' oppure 'NULL'\n"
 msgstr "Nome del file non valido. Il carattere <%c> non è permesso.\n"
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_ja.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ja\n"
 "PO-Revision-Date: 2012-03-05 12:14+0900\n"
 "Last-Translator: Naoki Ueda <nao at locapoint.com>\n"
 "Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
@@ -5478,7 +5478,7 @@
 msgstr "ファイルを開けません %s in <%s>"
 #, python-format
 msgstr ""
@@ -5541,42 +5541,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "入力マップを閉じれません"
 #, python-format
 msgstr ""
 msgstr "ベクトルマップ <%s> は既に存在し上書きされます"
 msgstr "���"
 msgstr "���"
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_ko.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ko\n"
 "PO-Revision-Date: 2013-10-30 22:07-0500\n"
 "Last-Translator: Huidae Cho <grass4u at gmail.com>\n"
 "Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -5321,7 +5321,7 @@
 msgstr "Datum %s 테이블파일을 열 수 없습니다"
 #, python-format
 msgstr ""
@@ -5384,42 +5384,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_lv.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_lv\n"
 "PO-Revision-Date: 2014-03-01 19:39+0200\n"
 "Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
 "Language-Team: Latvian\n"
@@ -5418,7 +5418,7 @@
 msgstr "Neiespējami atvērt failu %s iekš %s"
 #, python-format
 msgstr ""
@@ -5481,42 +5481,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Neisespējami atvērt %s"
 msgstr "Vektors '%s' jau eksistē un tiks pārrakstīts."
 msgstr "Neatļauts faila nosaukums.  Nevar būt '.' vai 'NULL'\n"
 msgstr "Neatļauts faila nosaukums. zīme <%c> nav atļauta.\n"
Modified: grass/trunk/locale/po/grasslibs_ml.po
--- grass/trunk/locale/po/grasslibs_ml.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_ml.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ml\n"
 "PO-Revision-Date: 2010-08-24 11:31+0530\n"
 "Last-Translator: Mohammed Rashad <rashadkm at gmail.com>\n"
 "Language-Team: GRASS Malayalam Translation Team <rashadkm at gmail.com>\n"
@@ -5287,7 +5287,7 @@
 msgstr "ഫയൽ തുറക്കൻ പറ്റുന്നില്ല %s"
 #, python-format
 msgstr ""
@@ -5350,42 +5350,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "വെക്റ്റർ അടയ്ക്കാൻ പറ്റുന്നില്ല <%s>"
 #, python-format
 msgstr ""
 msgstr "ഈ ടേബിൾ <%s> ഡേറ്റാബേയ്സിൽ ഉണ്ട് <%s>"
 msgstr "അസാധുവായ ടേബിൾ മാപ്പിന്റെ പേർ <%s> '.' ഉണ്ടാകാൻ പാടില്ല \n"
 msgstr "അസാധുവായ ടേബിൾ മാപ്പിന്റെ പേർ <%s> ഈ അക്ഷരം അനുവദിക്കുന്നതല്ല <%c> \n"
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_pl.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_pl\n"
 "PO-Revision-Date: 2013-07-16 15:42+0100\n"
 "Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
 "Language-Team: GRASS Translation Team\n"
@@ -5462,7 +5462,7 @@
 msgstr "Nie można otworzyć pliku %s"
 #, python-format
 msgstr ""
@@ -5525,42 +5525,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Nie można zamknąć mapy wejściowej "
 #, python-format
 msgstr ""
 msgstr "Mapa wektorowa <%s> już istnieje i zostanie nadpisana"
 msgstr "Niedozwolona nazwa pliku. Nazwa nie może zawierać '.' lub 'NULL'\n"
 msgstr "Niedozwolona nazwa pliku. Znak <%c> jest niedopuszczalny.\n"
Modified: grass/trunk/locale/po/grasslibs_pt.po
--- grass/trunk/locale/po/grasslibs_pt.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_pt.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_pt\n"
 "PO-Revision-Date: 2013-12-22 16:37+0200\n"
 "Last-Translator: luisa <gem12lte at student.lu.se>\n"
 "Language-Team: gem12lte at student.lu.se\n"
@@ -5572,7 +5572,7 @@
 msgstr "Impossível abrir arquivo %s"
 #, python-format
 msgstr ""
@@ -5635,42 +5635,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Impossível fechar mapa de entrada"
 #, python-format
 msgstr ""
 msgstr "O vetor '%s' já existe e será sobrescrito."
 msgstr "Nome de arquivo ilegal. não pode ser '.' ou 'NULL'\n"
 msgstr "Nome de arquivo ilegal. O caractere <%c> não é permitido.\n"
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_pt_br.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_pt_br\n"
 "PO-Revision-Date: 2007-05-20 10:44-0300\n"
 "Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail.com>\n"
 "Language-Team: Brazilian Portuguese <grass-translations at lists.osgeo.org>\n"
@@ -5496,7 +5496,7 @@
 msgstr "não foi possível abrir o arquivo %s em %s"
 #, python-format
 msgstr ""
@@ -5559,42 +5559,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "não consegui abrir [%s]"
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ro.po
--- grass/trunk/locale/po/grasslibs_ro.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_ro.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -6,7 +6,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ro\n"
 "PO-Revision-Date: 2013-11-21 22:05+0200\n"
 "Last-Translator: Mihai Moise\n"
 "Language-Team: GRASS Translation Team <grass-translations at lists.osgeo.org>\n"
@@ -5364,7 +5364,7 @@
 msgstr "Nu s-a putut deschide rasterul <%s>"
 #, python-format
 msgstr ""
@@ -5427,42 +5427,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Nu s-a putut închide harta de intrare"
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ru.po
--- grass/trunk/locale/po/grasslibs_ru.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_ru.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -6,7 +6,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ru\n"
 "PO-Revision-Date: 2009-01-27 22:58-0600\n"
 "Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
 "Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
@@ -5550,7 +5550,7 @@
 msgstr "Невозможно открыть файл %s в <%s>"
 #, python-format
 msgstr ""
@@ -5613,42 +5613,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Невозможно закрыть исходный слой"
 #, python-format
 msgstr ""
 msgstr "Векторный слой <%s> уже существует и будет перезаписан"
 msgstr "Неправильное имя файла.  Не должно быть '.' или 'NULL'\n"
 msgstr "Неправильное имя файла. Знак <%c> недопустим.\n"
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_sl.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_sl\n"
 "PO-Revision-Date: 2005-04-26 09:38+0200\n"
 "Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
 "Language-Team: Sloven¹èina <grass-translations at lists.osgeo.org>\n"
@@ -5507,7 +5507,7 @@
 msgstr "Nezmo¾en odpreti datoteko %s v %s"
 #, python-format
 msgstr ""
@@ -5570,42 +5570,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Ne morem odpreti %s"
 #, python-format
 msgstr ""
 msgstr "Vektor '%s' ¾e obstaja in bo prepisan."
 msgstr "Neveljavno ime datoteke. Ne more biti '.' ali 'NULL'\n"
 msgstr "Neveljavno ime. Znak <%c> je prepovedan."
Modified: grass/trunk/locale/po/grasslibs_th.po
--- grass/trunk/locale/po/grasslibs_th.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_th.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_th\n"
 "PO-Revision-Date: 2008-01-05 15:19+0700\n"
 "Last-Translator: man <mansv68 at yahoo.co.th>\n"
 "Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
@@ -5543,7 +5543,7 @@
 msgstr "ไม่สามารถเปิดไฟล์ได้ %s ใน %s"
 #, python-format
 msgstr ""
@@ -5606,42 +5606,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "ไม่สามารถปิดการนำเข้าแผนที่"
 #, python-format
 msgstr ""
 msgstr "แผนที่เชิงเส้น <%s> มีอยู่แล้วและจะถูกเขียนทับ"
 msgstr "ชือไฟล์ไม่ถูกต้อง  ไม่สามารถใช้ '.' หรือ 'NULL'\n"
 msgstr "ชือไฟล์ไม่ถูกต้อง ตัวอักษร <%c> ใช้ไม่ได้\n"
Modified: grass/trunk/locale/po/grasslibs_tr.po
--- grass/trunk/locale/po/grasslibs_tr.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_tr.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -9,7 +9,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_tr\n"
 "PO-Revision-Date: 2010-11-08 15:14+0200\n"
 "Last-Translator: Saban Safak <ssafak at cvm.com.tr>\n"
 "Language-Team: Türkçe <grass-translations at lists.osgeo.org>\n"
@@ -5444,7 +5444,7 @@
 msgstr "%s içindeki <%s> dosyası açılamadı"
 #, python-format
 msgstr ""
@@ -5507,42 +5507,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Girdi haritası kapatılamıyor"
 #, python-format
 msgstr ""
 msgstr "<%s> vektör haritası zaten mevcut ve üzerine yazılacak"
 msgstr "Uygun olmayan dosya adı. '.' veya 'NULL' olmamalı\n"
 msgstr "Uygun olmayan dosya adı. <%c> karakteri kullanılamaz.\n"
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_vi.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_vi\n"
 "PO-Revision-Date: 2010-08-27 11:18+0700\n"
 "Last-Translator: \n"
 "Language-Team: American English <kde-i18n-doc at kde.org>\n"
 msgstr "Không thể mở tập tin %s trong <%s>"
 #, python-format
 msgstr ""
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "Không thể đóng bản đồ đầu vào"
 #, python-format
 msgstr ""
 msgstr "Bản đồ vec-tơ <%s> đã có và sẽ bị ghi đè"
 msgstr "Tên tập tin không hợp lệ. Không thể là '.' hay 'NULL'\n"
 msgstr "Tên tập tin không hợp lệ. Ký tự <%c> không được phép.\n"
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasslibs_zh.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_zh\n"
 "PO-Revision-Date: 2007-12-13 16:42+0100\n"
 "Last-Translator: Su Yongheng <night2008 at gmail.com>\n"
 "Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
@@ -5561,7 +5561,7 @@
 msgstr "无法打开文件 %s 在 %s 中"
 #, python-format
 msgstr ""
@@ -5624,42 +5624,42 @@
 msgstr ""
 msgstr ""
 #, python-format
 msgstr ""
 #, python-format
 msgstr ""
 #, fuzzy
 msgstr "无法打开%s"
 #, python-format
 msgstr ""
 msgstr "矢量'%s'已经存在,它将会被覆盖。"
 msgstr "非法的文件名。不能是'.'或'NULL'\n"
 msgstr "非法的文件名。不允许包含字符<%c>。\n"
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_ar.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ar\n"
 "PO-Revision-Date: 2005-03-09 12:50+0100\n"
 "Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
 "Language-Team: Arabic <grass-translations at lists.osgeo.org>\n"
@@ -1121,8 +1121,9 @@
 msgstr "%s:لم يتم الحشر بالجدول"
 #: ../raster/r.stream.snap/main.c:47
-msgid "Delineates basins for stream network."
-msgstr ""
+#, fuzzy
+msgid "Snap point to modelled river network."
+msgstr "الخريطة الفيكتورية لنقاط الإنتهاء"
 #: ../raster/r.stream.snap/main.c:48
 msgid ""
@@ -1170,11 +1171,15 @@
 msgstr "اسم الخريطة الراسترية المدخلة"
 #: ../raster/r.stream.snap/main.c:63 ../raster/r.stream.segment/main.c:64
-#: ../raster/r.stream.stats/main.c:60 ../raster/r.stream.channel/main.c:64
-#: ../raster/r.stream.order/main.c:32
+#: ../raster/r.stream.stats/main.c:60 ../raster/r.stream.distance/main.c:60
+#: ../raster/r.stream.channel/main.c:64 ../raster/r.stream.order/main.c:32
 #, fuzzy
 msgid "Name for input raster map with stream network"
-msgstr "اسم الخريطة الراسترية المدخلة"
+msgstr ""
+"#-#-#-#-#  grassmods_ar.po (grassmods_ar)  #-#-#-#-#\n"
+"اسم الخريطة الراسترية المدخلة\n"
+"اسم الملف الراسترى الجديد"
 #: ../raster/r.stream.snap/main.c:64 ../raster/r.stream.snap/main.c:70
 #: ../raster/r.spread/main.c:121 ../raster/r.spread/main.c:133
@@ -9310,11 +9315,6 @@
 msgid "watercourse distance"
 msgstr ""
-#: ../raster/r.stream.distance/main.c:60
-#, fuzzy
-msgid "Name for input raster map with stream network"
-msgstr "اسم الملف الراسترى الجديد"
 #: ../raster/r.stream.distance/main.c:72
 #, fuzzy
 msgid "Calculation method"
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_cs.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -14,7 +14,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_cs\n"
 "PO-Revision-Date: 2010-03-07 15:38+0100\n"
 "Language-Team:  <cs at li.org>\n"
@@ -1125,8 +1125,9 @@
 msgstr "Nelze vložit nový řádek: %s"
-msgstr ""
+#, fuzzy
+msgstr "Vektorová mapa s cílovými body"
 msgid ""
@@ -1174,8 +1175,8 @@
 msgstr "Název vstupní bodové vektorové vrstvy"
 #, fuzzy
 msgstr "Název vstupní rastrové mapy"
@@ -9484,11 +9485,6 @@
 msgstr "Chyba při čtení vzdáleností"
-#, fuzzy
-msgstr "Název vstupní rastrové mapy"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_de.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -9,7 +9,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_de\n"
 "PO-Revision-Date: 2014-03-24 15:17+0100\n"
 "Last-Translator: Helmut Kudrnovsky <hellik at web.de>\n"
 "Language-Team: German <grass-translations at lists.osgeo.org>\n"
@@ -208,7 +208,8 @@
 #: ../raster/r.out.pov/main.c:180
 #, c-format
 msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr "Die Rasterkarte ist zu groß! Sie hat mehr als %d Spalten oder %d Zeilen."
+msgstr ""
+"Die Rasterkarte ist zu groß! Sie hat mehr als %d Spalten oder %d Zeilen."
 #: ../raster/r.out.pov/main.c:201
 msgid "Negative elevation values in input"
@@ -221,7 +222,8 @@
 #: ../raster/r.out.vrml/main.c:51
 #, fuzzy
 msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
+msgstr ""
+"Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
 #: ../raster/r.out.vrml/main.c:58
 msgid "Name of elevation map"
@@ -243,12 +245,16 @@
 #: ../raster/r.out.vrml/main.c:95
 #, fuzzy, c-format
 msgid "Range info for [%s] not available (run r.support)"
-msgstr "Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support aus)."
+msgstr ""
+"Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support "
+"aus)."
 #: ../raster/r.out.vrml/main.c:104
 #, fuzzy, c-format
 msgid "Range info for <%s> not available (run r.support)"
+msgstr ""
+"aus)."
 #: ../raster/r.out.vrml/main.c:136
 #, c-format
@@ -324,8 +330,12 @@
 #: ../raster/r.regression.multi/main.c:156
 #: ../raster/r.regression.line/main.c:64
-msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
-msgstr "ASCII-Datei n der die Regressionskoeffizienten gespeichert werden sollen (wenn keine angegeben wird erfolgt die Ausgabe auf dem Bildschirm)."
+msgid ""
+"ASCII file for storing regression coefficients (output to screen if file not "
+"specified)."
+msgstr ""
+"ASCII-Datei n der die Regressionskoeffizienten gespeichert werden sollen "
+"(wenn keine angegeben wird erfolgt die Ausgabe auf dem Bildschirm)."
 #: ../raster/r.regression.multi/main.c:160
 #: ../raster/r.regression.line/main.c:68 ../general/g.region/main.c:142
@@ -366,8 +376,12 @@
 msgstr "1 Klasse gefunden."
 #: ../raster/r.clump/main.c:53
-msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
-msgstr "Re-Kategorisiert Daten einer Rasterkarte, indem Zellen physikalisch diskreter Areale zu eindeutigen Kategorie gruppiert werden."
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
+msgstr ""
+"Re-Kategorisiert Daten einer Rasterkarte, indem Zellen physikalisch "
+"diskreter Areale zu eindeutigen Kategorie gruppiert werden."
 #: ../raster/r.clump/main.c:64 ../raster/r.recode/main.c:66
 msgid "Title for output raster map"
@@ -430,7 +444,10 @@
 msgstr "Berechnet die Standardabweichung der Patch-Größen einer Rasterkarte."
 #: ../raster/r.sunhours/main.c:74
-msgid "Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
+msgid ""
+"Solar elevation: the angle between the direction of the geometric center of "
+"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
+"angle from due north in clockwise direction."
 msgstr ""
 #: ../raster/r.sunhours/main.c:80
@@ -532,7 +549,8 @@
 #: ../raster/r.sunhours/main.c:213
 #, fuzzy
 msgid "Cannot get projection info of current location"
-msgstr "Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
+msgstr ""
+"Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
 #: ../raster/r.sunhours/main.c:216
 #, fuzzy
@@ -673,7 +691,8 @@
 #: ../raster/r.sunhours/solpos00.c:1038 ../raster/r.sunmask/solpos00.c:993
 #, c-format
 msgid "S_decode ==> Please fix the shadowband sky factor: %f"
-msgstr "S_decode ==> Bitte berichtigen Sie den 'sky factor' des Schattenbandes: %f"
+msgstr ""
+"S_decode ==> Bitte berichtigen Sie den 'sky factor' des Schattenbandes: %f"
 #: ../raster/r.external.out/main.c:38
 #, c-format
@@ -843,8 +862,11 @@
 #: ../raster/r.in.arc/main.c:64
 #, fuzzy
-msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
-msgstr "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) GRASS Rasterkarte."
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+msgstr ""
+"Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) "
+"GRASS Rasterkarte."
 #: ../raster/r.in.arc/main.c:68
 #, fuzzy
@@ -937,7 +959,8 @@
 #: ../raster/r.stream.snap/snap.c:133
 #, c-format
-msgid "Unable to snap point with cat %d, in a given radius. Increase search radius."
+msgid ""
+"Unable to snap point with cat %d, in a given radius. Increase search radius."
 msgstr ""
 #: ../raster/r.stream.snap/io.c:17 ../raster/r.stream.segment/io.c:17
@@ -1003,8 +1026,12 @@
 #: ../raster/r.stream.slope/main.c:122 ../raster/r.stream.order/io.c:79
 #: ../raster/r.stream.order/io.c:366
 #, fuzzy, c-format
-msgid "Region resolution and raster map <%s> resolution differs. Run 'g.region rast=%s' to set proper region resolution."
-msgstr "Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen Region."
+msgid ""
+"Region resolution and raster map <%s> resolution differs. Run 'g.region rast="
+"%s' to set proper region resolution."
+msgstr ""
+"Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen "
+"Region."
 #: ../raster/r.stream.snap/io.c:90 ../raster/r.stream.snap/io.c:376
 #: ../raster/r.stream.segment/io.c:90 ../raster/r.stream.segment/io.c:376
@@ -1106,11 +1133,14 @@
 msgstr "%s: Kann nicht in WKT konvertieren."
-msgstr ""
+#, fuzzy
+msgstr "Vektorkarte mit den Stopp-Punkten"
-msgid "Input can be stream network, point vector map with outlets or outlet coordinates."
+msgid ""
+"Input can be stream network, point vector map with outlets or outlet "
+"coordinates."
 msgstr ""
 #: ../raster/r.stream.snap/main.c:50 ../raster/r.usler/main.c:53
@@ -1152,11 +1182,15 @@
 msgstr "Name der Eingabe-Vektorkarte mit Punkten."
 #, fuzzy
-msgstr "Name der Eingabe-Rasterkarte."
+msgstr ""
+"#-#-#-#-#  grassmods_de.po (grassmods_de)  #-#-#-#-#\n"
+"Name der Eingabe-Rasterkarte.\n"
+"Rasterkarte mit Informationen zu dem Fließgewässersystem."
@@ -1188,7 +1222,8 @@
 #: ../raster/r.stream.snap/main.c:91
 #, fuzzy
 msgid "Max memory used (MB)"
-msgstr "Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
+msgstr ""
+"Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
 #: ../raster/r.stream.snap/main.c:92 ../raster/r.stream.stats/main.c:73
 #: ../raster/r.stream.stats/main.c:83 ../raster/r.stream.distance/main.c:95
@@ -1266,8 +1301,12 @@
 msgstr "Raster, Kartenalgebra"
 #: ../raster/r.mode/main.c:58
-msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
-msgstr "Findet den Modalwert der Werte einer Bedeckungskarte innerhalb der Flächen mit gleichen Werten in einer benutzerdefinierten Basiskarte."
+msgid ""
+"Finds the mode of values in a cover map within areas assigned the same "
+"category value in a user-specified base map."
+msgstr ""
+"Findet den Modalwert der Werte einer Bedeckungskarte innerhalb der Flächen "
+"mit gleichen Werten in einer benutzerdefinierten Basiskarte."
 #: ../raster/r.mode/main.c:64
 msgid "Base map to be reclassified"
@@ -1308,13 +1347,20 @@
 msgstr "Location: %s\n"
 #: ../raster/r.cost/main.c:145
-msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
-msgstr "Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die Kategoriewerte der Eingabekarte repräsentieren die Kosten."
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
+msgstr ""
+"Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen "
+"zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die "
+"Kategoriewerte der Eingabekarte repräsentieren die Kosten."
 #: ../raster/r.cost/main.c:152
 #, fuzzy
 msgid "Name of input raster map containing grid cell cost information"
-msgstr "Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
+msgstr ""
+"Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
 #: ../raster/r.cost/main.c:160
 #, fuzzy
@@ -1376,7 +1422,9 @@
 #: ../raster/r.cost/main.c:218 ../raster/r.walk/main.c:254
 msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr "Kosten werden NULL-Zellen zugewiesen. Standardmäßig werden NULL-Zellen ignoriert."
+msgstr ""
+"Kosten werden NULL-Zellen zugewiesen. Standardmäßig werden NULL-Zellen "
+"ignoriert."
 #: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:239
 #: ../raster/r.walk/main.c:255 ../raster/r.walk/main.c:305
@@ -1392,7 +1440,9 @@
 #: ../raster/r.cost/main.c:234 ../raster/r.walk/main.c:300
 msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr "Gehe wie ein Pferd im Schach (Knight's move); ist etwas langsamer, aber genauer."
+msgstr ""
+"Gehe wie ein Pferd im Schach (Knight's move); ist etwas langsamer, aber "
+"genauer."
 #: ../raster/r.cost/main.c:238
 msgid "Keep null values in output raster map"
@@ -1409,7 +1459,9 @@
 #: ../raster/r.cost/main.c:298 ../raster/r.walk/main.c:363
 msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr "Es muss exakt entweder start_points, start_rast oder coordinate angegeben werden."
+msgstr ""
+"Es muss exakt entweder start_points, start_rast oder coordinate angegeben "
+"werden."
 #: ../raster/r.cost/main.c:303 ../raster/r.cost/main.c:709
 #: ../raster/r.walk/main.c:368
@@ -1449,7 +1501,8 @@
 #: ../raster/r.cost/main.c:332
 msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr "Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
+msgstr ""
+"Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
 #: ../raster/r.cost/main.c:410 ../raster/r.cost/main.c:419
 #: ../raster/r.walk/main.c:523 ../raster/r.walk/main.c:533
@@ -1482,8 +1535,12 @@
 #: ../raster/r.cost/main.c:483
 #, c-format
-msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
-msgstr "Negative Werte in Zeile %d, Spalte %d gefunden. Setze die negativen Werte auf den null_cost-Wert."
+msgid ""
+"Negative cell value found at row %d, col %d. Setting negative value to "
+"null_cost value"
+msgstr ""
+"Negative Werte in Zeile %d, Spalte %d gefunden. Setze die negativen Werte "
+"auf den null_cost-Wert."
 #: ../raster/r.cost/main.c:500
 #, fuzzy
@@ -1625,8 +1682,11 @@
 msgstr "Vektor, extrahieren"
 #: ../raster/r.transect/main.c:106
-msgid "Outputs raster map layer values lying along user defined transect line(s)."
-msgstr "Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer durch den Benutzer festgelegten Linie(n) liegen."
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+"Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer durch den "
+"Benutzer festgelegten Linie(n) liegen."
 #: ../raster/r.transect/main.c:110
 msgid "Raster map to be queried"
@@ -1660,7 +1720,9 @@
 #: ../raster/r.support/main.c:57
 msgid "Allows creation and/or modification of raster map layer support files."
-msgstr "Erlaubt das Erzeugen und/oder das Modifizieren von Rasterkarten-Support-Dateien."
+msgstr ""
+"Erlaubt das Erzeugen und/oder das Modifizieren von Rasterkarten-Support-"
+"Dateien."
 #: ../raster/r.support/main.c:67 ../raster3d/r3.support/main.c:61
 msgid "Text to use for map title"
@@ -1706,7 +1768,8 @@
 #: ../raster/r.support/main.c:130
 #, fuzzy
 msgid "Update statistics (histogram, range)"
-msgstr "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
+msgstr ""
+"Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
 #: ../raster/r.support/main.c:134
 #, fuzzy
@@ -1806,33 +1869,58 @@
 #, fuzzy, c-format
 msgid ""
 "USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold "
+"[flow=overland_flow_map] [drainage=drain_direction_map] "
+"[depression=depression_map] [accumulation=accumulation_map] "
+"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
 "\n"
 "USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold "
+"[drainage=drain_direction_map] [depression=depression_map] "
+"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
+"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
+"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
+"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
+"creation:\n"
+"[basin=watershed_basin_map] [stream=stream_segment_map] "
+"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
 "\n"
 msgstr ""
 "VERWENDUNG für Einzugsgebietskartierung:\n"
-"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+"[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
+"[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
 "\n"
 "VERWENDUNG für ARMSED-Datei Erzeugung:\n"
-"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
+"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+"[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
+"ha=half_basin_map ar=ARMSED_file_name\n"
 "\n"
 "VERWENDUNG für Hanglängenberechnung:\n"
-"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
+"[de=depression_map] [ac=accumulation_map] [di=display_map] "
+"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
+"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
 #: ../raster/r.watershed/seg/init_vars.c:132
 #, fuzzy, c-format
 msgid "SECTION 1 beginning: Initiating Variables. %d section total."
 msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
-msgstr[0] "ABSCHNITT 1 Beginne: Initialisiere Variablen. %d Abschnitte insgesamt."
-msgstr[1] "ABSCHNITT 1 Beginne: Initialisiere Variablen. %d Abschnitte insgesamt."
+msgstr[0] ""
+"ABSCHNITT 1 Beginne: Initialisiere Variablen. %d Abschnitte insgesamt."
+msgstr[1] ""
 #: ../raster/r.watershed/seg/init_vars.c:168
 #, fuzzy
 msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
-msgstr "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den Standardwert 300 MB."
+msgstr ""
+"Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den "
+"Standardwert 300 MB."
 #: ../raster/r.watershed/seg/init_vars.c:245
 #: ../raster/r.stream.extract/main.c:318
@@ -1916,7 +2004,9 @@
 #: ../raster/r.watershed/seg/do_cum.c:517
 #, fuzzy
 msgid "MFD: A * path already processed when distributing flow: %d of %"
-msgstr "MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d Zellen"
+msgstr ""
+"MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d "
+"Zellen"
 #: ../raster/r.watershed/seg/do_cum.c:521
 #: ../raster/r.watershed/ram/do_cum.c:480
@@ -2004,14 +2094,20 @@
 #: ../raster/r.watershed/ram/do_cum.c:474
 #, fuzzy, c-format
 msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
-msgid_plural "MFD: A * path already processed when distributing flow: %d of %d cells"
-msgstr[0] "MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d Zellen"
-msgstr[1] "MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d Zellen"
+msgid_plural ""
+"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgstr[0] ""
+"Zellen"
+msgstr[1] ""
+"Zellen"
 #: ../raster/r.watershed/shed/intro.c:8
 #, c-format
 msgid "%s provides a text-based user-interface to the %s program."
-msgstr "%s erstellt eine textbasierte Benutzerschnittstelle für das %s Programm. "
+msgstr ""
+"%s erstellt eine textbasierte Benutzerschnittstelle für das %s Programm. "
 #: ../raster/r.watershed/shed/intro.c:10
 #, c-format
@@ -2036,7 +2132,9 @@
 #: ../raster/r.watershed/shed/intro.c:18
 #, c-format
 msgid "divided by basin. %s will then run %s and create the report."
-msgstr "von Behältern getrennt werden. %s wird dann %s starten und einen Bericht erstellen. "
+msgstr ""
+"von Behältern getrennt werden. %s wird dann %s starten und einen Bericht "
+"erstellen. "
 #: ../raster/r.watershed/shed/valid.c:24
 msgid "accum file missing in valid_basins()"
@@ -2050,7 +2148,8 @@
 msgstr ""
 "\n"
 "\n"
-"Bitte geben Sie an welche Karten verwendet werden sollen in dem konzentrierten "
+"Bitte geben Sie an welche Karten verwendet werden sollen in dem "
+"konzentrierten "
 #: ../raster/r.watershed/shed/basin_maps.c:13
 msgid "parameter hydrologic/soil erosion model.  Continue inputing cell map"
@@ -2089,11 +2188,15 @@
 #: ../raster/r.watershed/shed/basin_maps.c:39
 msgid "1) by only including data pertaining to the basin itself, or 2) using"
-msgstr "1) es werden nur die Daten beigefügt die nur das Gebiet selbst betreffen, oder 2) "
+msgstr ""
+"1) es werden nur die Daten beigefügt die nur das Gebiet selbst betreffen, "
+"oder 2) "
 #: ../raster/r.watershed/shed/basin_maps.c:40
 msgid "data from the basin, and all basins upstream of it."
-msgstr "es werden die Daten zum jeweiligen Gebiet und allen stromaufwärts gelegenen verwendet. "
+msgstr ""
+"es werden die Daten zum jeweiligen Gebiet und allen stromaufwärts gelegenen "
+"verwendet. "
 #: ../raster/r.watershed/shed/basin_maps.c:43
 msgid ""
@@ -2178,27 +2281,36 @@
 #: ../raster/r.watershed/shed/com_line.c:28
 #, c-format
 msgid "in its fast mode or its slow mode.  If you run %s"
-msgstr "im schnellen Modus oder im langsamen Modus ausführen wollen. Wenn Sie %s "
+msgstr ""
+"im schnellen Modus oder im langsamen Modus ausführen wollen. Wenn Sie %s "
 #: ../raster/r.watershed/shed/com_line.c:30
 msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr "im schnellen Modus ausführen, wird der Computer ca. 10mal schneller fertig sein "
+msgstr ""
+"im schnellen Modus ausführen, wird der Computer ca. 10mal schneller fertig "
+"sein "
 #: ../raster/r.watershed/shed/com_line.c:31
 msgid "than in the slow mode, but will not allow other programs to run"
-msgstr "als im langsamen Modus. Aber dies wird nicht zulassen andere Programme "
+msgstr ""
+"als im langsamen Modus. Aber dies wird nicht zulassen andere Programme "
 #: ../raster/r.watershed/shed/com_line.c:32
 msgid "at the same time.  The fast mode also places all of the data into"
-msgstr "zur gleichen Zeit auszuführen. Der schnelle Modus schreibt ausßerdem alle Daten"
+msgstr ""
+"zur gleichen Zeit auszuführen. Der schnelle Modus schreibt ausßerdem alle "
+"Daten"
 #: ../raster/r.watershed/shed/com_line.c:33
 msgid "RAM, which limits the size of window that can be run.  The slow"
-msgstr "in das RAM, was die maximal zu berechnende Region begrenzt. Der langsame"
+msgstr ""
+"in das RAM, was die maximal zu berechnende Region begrenzt. Der langsame"
 #: ../raster/r.watershed/shed/com_line.c:34
 msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr "Modus verwendet Speicher auf der selben Festplatte auf der sich GRASS befindet. "
+msgstr ""
+"Modus verwendet Speicher auf der selben Festplatte auf der sich GRASS "
+"befindet. "
 #: ../raster/r.watershed/shed/com_line.c:35
 msgid "stored.  Thus, if the program does not work in the slow mode, you will"
@@ -2206,12 +2318,14 @@
 #: ../raster/r.watershed/shed/com_line.c:36
 msgid "need to remove unnecessary files from that partition.  The slow mode"
-msgstr "das Programm im langsamen Modus nicht funktioniert. Andere Prozesse können "
+msgstr ""
+"das Programm im langsamen Modus nicht funktioniert. Andere Prozesse können "
 #: ../raster/r.watershed/shed/com_line.c:37
 #, c-format
 msgid "will allow other processes to run concurrently with %s.\n"
-msgstr "gleichzeitig mit %s ausgeführt werden, wenn es im langsamen Modus ist.\n"
+msgstr ""
+"gleichzeitig mit %s ausgeführt werden, wenn es im langsamen Modus ist.\n"
 #: ../raster/r.watershed/shed/com_line.c:69
 #: ../raster/r.watershed/shed/com_line.c:182
@@ -2237,28 +2351,38 @@
 "Eine der Optionen für %s ist eine `Senkungskarte'. Eine "
 #: ../raster/r.watershed/shed/com_line.c:83
-msgid "depression map indicates all the locations in the current map window where"
+msgid ""
+"depression map indicates all the locations in the current map window where"
 msgstr "Senkungskarte zeigt alle Orte im aktuellen Fenster an wo "
 #: ../raster/r.watershed/shed/com_line.c:84
-msgid "water accumulates and does not leave by the edge of the map. Lakes without"
+msgid ""
+"water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr "sich Wasser sammelt und nicht am Kartenrand austritt. Seen ohne "
 #: ../raster/r.watershed/shed/com_line.c:85
-msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
-msgstr "Auslassströmungen und Senklöcher sind Beispiele von 'Bodensenken'. Wenn Sie eine "
+msgid ""
+"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgstr ""
+"Auslassströmungen und Senklöcher sind Beispiele von 'Bodensenken'. Wenn Sie "
+"eine "
 #: ../raster/r.watershed/shed/com_line.c:86
 msgid "have a depression map, prepare a map where non-zero values indicate the"
-msgstr "Karte der Bodensenken wünschen, müssen Sie eine Karte vorbereiten, in der die Nicht-Null Zellen "
+msgstr ""
+"Karte der Bodensenken wünschen, müssen Sie eine Karte vorbereiten, in der "
+"die Nicht-Null Zellen "
 #: ../raster/r.watershed/shed/com_line.c:87
 msgid "locations where depressions occur.\n"
 msgstr "Orte anzeigen an denen Senken vorkommen.\n"
 #: ../raster/r.watershed/shed/com_line.c:88
-msgid "Hit <return> by itself for the next question if there is no depression map."
-msgstr "Drücke <return> für die nächste Frage, wenn es keine Karte der Bodensenken gibt."
+msgid ""
+"Hit <return> by itself for the next question if there is no depression map."
+msgstr ""
+"Drücke <return> für die nächste Frage, wenn es keine Karte der Bodensenken "
+"gibt."
 #: ../raster/r.watershed/shed/com_line.c:99
 #, c-format
@@ -2270,50 +2394,79 @@
 "Das %s Programm wird die Höhenkarte in ein Anzahl von "
 #: ../raster/r.watershed/shed/com_line.c:101
-msgid "watershed basins.  The number of watershed basins is indirectly determined"
-msgstr "Einzugsgebiete unterteilen. Die Anzahl von Einzugsgebieten wird indirekt "
+msgid ""
+"watershed basins.  The number of watershed basins is indirectly determined"
+msgstr ""
+"Einzugsgebiete unterteilen. Die Anzahl von Einzugsgebieten wird indirekt "
 #: ../raster/r.watershed/shed/com_line.c:102
-msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
-msgstr "vom 'basin threshold' Wert festgelegt. Der 'basin threshold' ist die notwendige Fläche für "
+msgid ""
+"by the `basin threshold' value.  The basin threshold is the area necessary "
+"for"
+msgstr ""
+"vom 'basin threshold' Wert festgelegt. Der 'basin threshold' ist die "
+"notwendige Fläche für "
 #: ../raster/r.watershed/shed/com_line.c:103
 #, c-format
 msgid "%s to define a unique watershed basin.  This area only applies to"
-msgstr "%s um einzelne Einzugsgebiete zu definieren. Diese Fläche gilt nur für "
+msgstr ""
+"%s um einzelne Einzugsgebiete zu definieren. Diese Fläche gilt nur für "
 #: ../raster/r.watershed/shed/com_line.c:105
-msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
-msgstr "außenliegende Einzugsgebiete. Ein außenliegendes Einzugsgebiet hat keine anderen "
+msgid ""
+"`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgstr ""
+"außenliegende Einzugsgebiete. Ein außenliegendes Einzugsgebiet hat keine "
+"anderen "
 #: ../raster/r.watershed/shed/com_line.c:106
-msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
-msgstr "Einzugsgebiete die mit einfließen. Die Größe von Binneneinzugsgebieten ist festgelegt "
+msgid ""
+"drainage basins flowing into it.  Interior drainage basin size is determined"
+msgstr ""
+"Einzugsgebiete die mit einfließen. Die Größe von Binneneinzugsgebieten ist "
+"festgelegt "
 #: ../raster/r.watershed/shed/com_line.c:107
-msgid "by the surface flow going into stream segments between stream interceptions."
-msgstr "durch den Oberflächenabfluss, der in Flussabschnitten zwischen Stromunterbrechungen fließt. "
+msgid ""
+"by the surface flow going into stream segments between stream interceptions."
+msgstr ""
+"durch den Oberflächenabfluss, der in Flussabschnitten zwischen "
+"Stromunterbrechungen fließt. "
 #: ../raster/r.watershed/shed/com_line.c:108
 #, c-format
 msgid "Thus interior drainage basins can be of any size.  The %s program"
-msgstr "Daher können Binneneinzugsgebiete eine beliebige Größe haben. Das Programm %s "
+msgstr ""
+"Daher können Binneneinzugsgebiete eine beliebige Größe haben. Das Programm "
+"%s "
 #: ../raster/r.watershed/shed/com_line.c:110
 msgid "also allows the user to relate basin size to potential overland flow"
-msgstr "ermöglicht es dem Benutzer sogar die Behältergröße in Beziehung zum Oberflächenabfluss zu setzen "
+msgstr ""
+"ermöglicht es dem Benutzer sogar die Behältergröße in Beziehung zum "
+"Oberflächenabfluss zu setzen "
 #: ../raster/r.watershed/shed/com_line.c:111
-msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
-msgstr "(z.B. Flächen mit niedriger Infiltrationskapazität brauchen kleinere Flächen um "
+msgid ""
+"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr ""
+"(z.B. Flächen mit niedriger Infiltrationskapazität brauchen kleinere Flächen "
+"um "
 #: ../raster/r.watershed/shed/com_line.c:112
-msgid "develop stream channels than neighboring areas with high infiltration rates)."
-msgstr "Strömungskanäle zu entwickeln als benachbarte Flächen mit hohen Infiltrationsraten). "
+msgid ""
+"develop stream channels than neighboring areas with high infiltration rates)."
+msgstr ""
+"Strömungskanäle zu entwickeln als benachbarte Flächen mit hohen "
+"Infiltrationsraten). "
 #: ../raster/r.watershed/shed/com_line.c:113
-msgid "The user can create a map layer with potential overland flow values, and"
-msgstr "Der Benutzer kann eine Karte mit potentiellen Oerflächenabflusswerten generieren, und "
+msgid ""
+"The user can create a map layer with potential overland flow values, and"
+msgstr ""
+"Der Benutzer kann eine Karte mit potentiellen Oerflächenabflusswerten "
+"generieren, und "
 #: ../raster/r.watershed/shed/com_line.c:114
 #, c-format
@@ -2343,7 +2496,8 @@
 "How large an area (or how many overland flow units) must a drainage basin"
 msgstr ""
 "\n"
-"Welche Fläche (oder wie viele Oberflächenabfluss-Einheiten) muss ein Einzugsgebiet "
+"Welche Fläche (oder wie viele Oberflächenabfluss-Einheiten) muss ein "
+"Einzugsgebiet "
 #: ../raster/r.watershed/shed/com_line.c:132
 #, c-format
@@ -2433,7 +2587,9 @@
 #: ../raster/r.watershed/shed/com_line.c:292
 #, c-format
 msgid "%s to function (stream channels, overland flow aspect, and"
-msgstr "%s nicht unbedingt funktionieren müssen (Strömungskanäle, Oberflächenabfluss-Aspekt und "
+msgstr ""
+"%s nicht unbedingt funktionieren müssen (Strömungskanäle, Oberflächenabfluss-"
+"Aspekt und "
 #: ../raster/r.watershed/shed/com_line.c:294
 #, c-format
@@ -2441,8 +2597,11 @@
 msgstr "Bildschirmversion der Akkumulationskarte). %s hat auch die "
 #: ../raster/r.watershed/shed/com_line.c:296
-msgid "ability to generate several variables in the Revised Universal Soil Loss"
-msgstr "Möglichkeit in der verbesserten allgemeinen Bodenverlust Formel (Revised Universal Soil Loss Equation; Rusle) "
+msgid ""
+"ability to generate several variables in the Revised Universal Soil Loss"
+msgstr ""
+"Möglichkeit in der verbesserten allgemeinen Bodenverlust Formel (Revised "
+"Universal Soil Loss Equation; Rusle) "
 #: ../raster/r.watershed/shed/com_line.c:297
 msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
@@ -2459,11 +2618,17 @@
 #: ../raster/r.watershed/shed/com_line.c:349
 #, c-format
 msgid "disturbed land.  %s reflects this with an optional map layer or value"
-msgstr "gestörtem Boden. %s reflektiert das mit einer optionalen Karte oder einem Wert "
+msgstr ""
+"gestörtem Boden. %s reflektiert das mit einer optionalen Karte oder einem "
+"Wert "
 #: ../raster/r.watershed/shed/com_line.c:351
-msgid "where the value indicates the percent of disturbed (barren) land in that cell."
-msgstr "wobei der Wert den Prozentanteil von gestörtem (unfruchtbarem) Boden in der Zelle angibt. "
+msgid ""
+"where the value indicates the percent of disturbed (barren) land in that "
+"cell."
+msgstr ""
+"wobei der Wert den Prozentanteil von gestörtem (unfruchtbarem) Boden in der "
+"Zelle angibt. "
 #: ../raster/r.watershed/shed/com_line.c:352
 msgid "Type <return> if you do not have a disturbed land map layer."
@@ -2475,7 +2640,8 @@
 "Type the value indicating the percent of disturbed land.  This value will"
 msgstr ""
 "\n"
-"Geben Sie den Wert der den Prozentansatz von gestörtem Boden indiziert ein. Dieser Wert "
+"Geben Sie den Wert der den Prozentansatz von gestörtem Boden indiziert ein. "
+"Dieser Wert "
 #: ../raster/r.watershed/shed/com_line.c:365
 msgid "be used for every cell in the current region."
@@ -2496,7 +2662,8 @@
 "Overland surface flow only occurs for a set distance before swales form."
 msgstr ""
 "\n"
-"Oberflächenabfluss tritt nur für eine bestimmte Distanz auf bevor eine Senke entsteht. "
+"Oberflächenabfluss tritt nur für eine bestimmte Distanz auf bevor eine Senke "
+"entsteht. "
 #: ../raster/r.watershed/shed/com_line.c:380
 #, c-format
@@ -2506,10 +2673,12 @@
 #: ../raster/r.watershed/shed/com_line.c:382
 #, c-format
 msgid "these swales.  %s allows for an input (warning: kludge factor)"
-msgstr "Senken nicht aufnehmen. %s erlaubt eine Eingabe (Warnung: Kludge Faktor) "
+msgstr ""
+"Senken nicht aufnehmen. %s erlaubt eine Eingabe (Warnung: Kludge Faktor) "
 #: ../raster/r.watershed/shed/com_line.c:384
-msgid "that prevents the surface flow distance from getting too long.  Normally,"
+msgid ""
+"that prevents the surface flow distance from getting too long.  Normally,"
 msgstr "das verhindert dass die Distanz des Oberflächenabfluss zu lang wird. "
 #: ../raster/r.watershed/shed/com_line.c:385
@@ -2525,7 +2694,8 @@
 "Straßen, Gräben, Änderung in der Oberflächenabdeckung und andere Faktoren "
 #: ../raster/r.watershed/shed/com_line.c:401
-msgid "slope length.  You may input a raster map indicating the locations of these"
+msgid ""
+"slope length.  You may input a raster map indicating the locations of these"
 msgstr "begrenzen die Hanglänge. Eine Rasterkarte mit den Standorten dieser "
 #: ../raster/r.watershed/shed/com_line.c:402
@@ -2533,8 +2703,11 @@
 msgstr "blockierenden Faktoren sollte angegeben werden.\n"
 #: ../raster/r.watershed/shed/com_line.c:403
-msgid "Hit <return> by itself for the next question if there is no blocking map."
-msgstr "Drücke <return> für die nächste Frage wenn es keine Karte der Blockierungen gibt. "
+msgid ""
+"Hit <return> by itself for the next question if there is no blocking map."
+msgstr ""
+"Drücke <return> für die nächste Frage wenn es keine Karte der Blockierungen "
+"gibt. "
 #: ../raster/r.watershed/front/main.c:74 ../raster/r.water.outlet/main.c:69
 #: ../raster/r.basins.fill/main.c:56
@@ -2562,7 +2735,9 @@
 #: ../raster/r.watershed/front/main.c:83
 msgid "All non-NULL and non-zero cells are considered as real depressions"
-msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Bodensenke aufgefasst."
+msgstr ""
+"Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte "
+"Bodensenke aufgefasst."
 #: ../raster/r.watershed/front/main.c:89
 #, fuzzy
@@ -2582,12 +2757,16 @@
 #: ../raster/r.watershed/front/main.c:103
 #, fuzzy
 msgid "Name of input raster map blocking overland surface flow"
-msgstr "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
+msgstr ""
+"Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
 #: ../raster/r.watershed/front/main.c:105
 #, fuzzy
-msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
-msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Hindernis aufgefasst."
+msgid ""
+"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgstr ""
+"Hindernis aufgefasst."
 #: ../raster/r.watershed/front/main.c:112
 #, fuzzy
@@ -2597,7 +2776,9 @@
 #: ../raster/r.watershed/front/main.c:120
 #, fuzzy
 msgid "Maximum length of surface flow in map units"
-msgstr "Eingabewert: Maximale Länge des Oberflächenabflusses in Karteneinheiten für USLE."
+msgstr ""
+"Eingabewert: Maximale Länge des Oberflächenabflusses in Karteneinheiten für "
+"USLE."
 #: ../raster/r.watershed/front/main.c:129
 #, fuzzy
@@ -2696,11 +2877,14 @@
 #: ../raster/r.watershed/front/main.c:192
 msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
-msgstr "1 = der am meisten divergierende Fluss, 10 = der am meisten konvergierende Fluss. Empfohlen: 5."
+msgstr ""
+"1 = der am meisten divergierende Fluss, 10 = der am meisten konvergierende "
+"Fluss. Empfohlen: 5."
 #: ../raster/r.watershed/front/main.c:199
 msgid "Maximum memory to be used with -m flag (in MB)"
+msgstr ""
 #: ../raster/r.watershed/front/main.c:203
 msgid "SFD (D8) flow (default is MFD)"
@@ -2719,16 +2903,25 @@
 msgstr "Schalte Auslagerung auf Festplatte an: Operation ist langsam."
 #: ../raster/r.watershed/front/main.c:217
-msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
-msgstr "Nur benötigt wenn die Speicheranforderungen den vorhandenen Arbeitsspeicher überschreiten. Schlagen Sie im Handbuch nach wie die Speicheranforderungen berechnet werden."
+msgid ""
+"Only needed if memory requirements exceed available RAM; see manual on how "
+"to calculate memory requirements"
+msgstr ""
+"Nur benötigt wenn die Speicheranforderungen den vorhandenen Arbeitsspeicher "
+"überschreiten. Schlagen Sie im Handbuch nach wie die Speicheranforderungen "
+"berechnet werden."
 #: ../raster/r.watershed/front/main.c:222
 msgid "Use positive flow accumulation even for likely underestimates"
-msgstr "Verwende positive Flussakkumulation, auch für vorraussichtliche Unterschätzungen."
+msgstr ""
+"Verwende positive Flussakkumulation, auch für vorraussichtliche "
+"Unterschätzungen."
 #: ../raster/r.watershed/front/main.c:224
 msgid "See manual for a detailed description of flow accumulation output"
-msgstr "Siehe Handbuch für detaillierte Beschreibung der Ausgabe der Flussakkumulation."
+msgstr ""
+"Siehe Handbuch für detaillierte Beschreibung der Ausgabe der "
+"Flussakkumulation."
 #: ../raster/r.watershed/front/main.c:229
 msgid "Beautify flat areas"
@@ -2775,8 +2968,11 @@
 msgstr "vollständig"
 #: ../raster/r.composite/main.c:76
-msgid "Combines red, green and blue raster maps into a single composite raster map."
-msgstr "Kombiniert rote, grüne und blaue Rasterkarten zu einer zusammengesetzten Rasterkarte."
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
+msgstr ""
+"Kombiniert rote, grüne und blaue Rasterkarten zu einer zusammengesetzten "
+"Rasterkarte."
 #: ../raster/r.composite/main.c:90 ../raster/r.out.ppm3/main.c:63
 #, c-format
@@ -2822,7 +3018,9 @@
 #: ../raster/r.stats.zonal/main.c:104
 #, fuzzy
-msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
+msgid ""
+"Calculates category or object oriented statistics (accumulator-based "
+"statistics)."
 msgstr "Berechnet kategorie- oder objektorientierte Statistik."
 #: ../raster/r.stats.zonal/main.c:114 ../raster/r.statistics/main.c:68
@@ -2901,7 +3099,9 @@
 msgstr "Kein Punkte mit Kategorie [%d]."
 #: ../raster/r.category/main.c:55
-msgid "Manages category values and labels associated with user-specified raster map layers."
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
 msgstr "Verwaltet die Kategoriewerte und Label von Rasterkarten."
 #: ../raster/r.category/main.c:62 ../raster/r.category/main.c:71
@@ -2990,11 +3190,13 @@
 #: ../raster/r.category/main.c:87
 msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr "Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
+msgstr ""
+"Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
 #: ../raster/r.category/main.c:95
 msgid "Default label or format string for dynamic labeling"
-msgstr "Standard-Beschriftung oder eine Formatanweisung für dynamische Beschriftung."
+msgstr ""
+"Standard-Beschriftung oder eine Formatanweisung für dynamische Beschriftung."
 #: ../raster/r.category/main.c:97
 msgid "Used when no explicit label exists for the category"
@@ -3047,15 +3249,21 @@
 #: ../raster/r.category/main.c:283
 msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr "Die Karte ist eine Fließkommazahl-Karte. Ignoriere Kategorieliste, nehme stattdessen Vals-Liste."
+msgstr ""
+"Die Karte ist eine Fließkommazahl-Karte. Ignoriere Kategorieliste, nehme "
+"stattdessen Vals-Liste."
 #: ../raster/r.category/main.c:300
 msgid "vals argument is required for floating point map!"
 msgstr "vals-argument wird für Fließkomma-Karte benötigt."
 #: ../raster/r.coin/main.c:69
-msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
-msgstr "Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei Rasterkarten."
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+"Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei "
+"Rasterkarten."
 #: ../raster/r.coin/main.c:77
 msgid "Name of first raster map"
@@ -3070,8 +3278,13 @@
 msgstr "Maßeinheit"
 #: ../raster/r.coin/main.c:92
-msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr "c(ells), p(rozent), x(Prozent der Kategorien [Spalte]), y(Prozent der Kategorien [Zeile]), a(cres), h(ektar), k(Quadrat-Kilometer), m(Quadrat-Meilen)"
+msgid ""
+"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
+"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr ""
+"c(ells), p(rozent), x(Prozent der Kategorien [Spalte]), y(Prozent der "
+"Kategorien [Zeile]), a(cres), h(ektar), k(Quadrat-Kilometer), m(Quadrat-"
+"Meilen)"
 #: ../raster/r.coin/main.c:99
 msgid "Wide report, 132 columns (default: 80)"
@@ -3169,8 +3382,12 @@
 #: ../raster/r.in.xyz/main.c:165
 #, fuzzy
-msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
-msgstr "Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung univariater Statistik."
+msgid ""
+"Creates a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+"Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung "
+"univariater Statistik."
 #: ../raster/r.in.xyz/main.c:169
 msgid "ASCII file containing input data (or \"-\" to read from stdin)"
@@ -3225,7 +3442,8 @@
 #: ../raster/r.in.xyz/main.c:200
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
 msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr "Spaltenummer der X-Koordinate in der Eingabedatei (erste Spalte ist 1)."
+msgstr ""
+"Spaltenummer der X-Koordinate in der Eingabedatei (erste Spalte ist 1)."
 #: ../raster/r.in.xyz/main.c:208
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
@@ -3238,13 +3456,17 @@
 msgstr "Spaltenummer der Daten in der Eingabedatei."
 #: ../raster/r.in.xyz/main.c:218
-msgid "If a separate value column is given, this option refers to the z-coordinate column to be filtered by the zrange option"
+msgid ""
+"If a separate value column is given, this option refers to the z-coordinate "
+"column to be filtered by the zrange option"
 msgstr ""
 #: ../raster/r.in.xyz/main.c:229
 #, fuzzy
 msgid "Number of header lines to skip at top of input file"
-msgstr "Anzahl der Kopfzeilen, die am Anfang der Eingabedatei übersprungen werden soll (Punktmodus)."
+msgstr ""
+"Anzahl der Kopfzeilen, die am Anfang der Eingabedatei übersprungen werden "
+"soll (Punktmodus)."
 #: ../raster/r.in.xyz/main.c:237 ../raster/r.in.lidar/main.c:196
 msgid "Filter range for z data (min,max)"
@@ -3288,13 +3510,18 @@
 #: ../raster/r.in.xyz/main.c:297 ../raster/r.in.lidar/main.c:229
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
-msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
-msgstr "Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der größsten Beobachtungen."
+msgid ""
+"Discard <trim> percent of the smallest and <trim> percent of the largest "
+"observations"
+msgstr ""
+"Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der größsten "
+"Beobachtungen."
 #: ../raster/r.in.xyz/main.c:302 ../raster/r.in.lidar/main.c:257
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
 msgid "Scan data file for extent then exit"
-msgstr "Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
+msgstr ""
+"Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
 #: ../raster/r.in.xyz/main.c:307 ../raster/r.in.lidar/main.c:263
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:7
@@ -3312,7 +3539,9 @@
 #: ../raster/r.in.xyz/main.c:344 ../vector/v.in.ascii/main.c:185
 msgid "Please specify reasonable number of lines to skip"
-msgstr "Bitte geben Sie eine angemessene Zahl von Zeilen an, die übersprungen werden sollen."
+msgstr ""
+"Bitte geben Sie eine angemessene Zahl von Zeilen an, die übersprungen werden "
+"sollen."
 #: ../raster/r.in.xyz/main.c:349 ../raster/r.in.lidar/main.c:428
 msgid "Invalid zrange"
@@ -3333,12 +3562,17 @@
 #: ../raster/r.in.xyz/main.c:494 ../raster/r.in.lidar/main.c:608
 #, c-format
-msgid "Unable to process the hole map at once. Please set the %s option to some value lower than 100."
+msgid ""
+"Unable to process the hole map at once. Please set the %s option to some "
+"value lower than 100."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:547
-msgid "If input is not from a file it is only possible to perform a single pass."
-msgstr "Wenn die Eingabe nicht aus einer Datei kommt kann nur ein Durchgang ausgeführt werden."
+msgid ""
+"If input is not from a file it is only possible to perform a single pass."
+msgstr ""
+"Wenn die Eingabe nicht aus einer Datei kommt kann nur ein Durchgang "
+"ausgeführt werden."
 #: ../raster/r.in.xyz/main.c:559
 #, fuzzy
@@ -3360,10 +3594,12 @@
 #: ../raster/r.in.xyz/main.c:1198 ../raster/r.in.xyz/main.c:1206
 #, c-format
 msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the "
+"following character(s) in row %lu:\n"
 "[%s]"
 msgstr ""
-"Nicht genügend Datenspalten. Falsches Trennzeichen oder Spaltenanzahl? Habe die folgenden Zeichen in Zeile %lu gefunden:\n"
+"Nicht genügend Datenspalten. Falsches Trennzeichen oder Spaltenanzahl? Habe "
+"die folgenden Zeichen in Zeile %lu gefunden:\n"
 "[%s]"
 #: ../raster/r.in.xyz/main.c:685 ../raster/r.in.xyz/main.c:1202
@@ -3433,11 +3669,17 @@
 msgstr "Sites"
 #: ../raster/r.series/main.c:137
-msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
-msgstr "Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+"Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer "
+"korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
 #: ../raster/r.series/main.c:146
-msgid "Input file with one raster map name and optional one weight per line, field separator between name and weight is |"
+msgid ""
+"Input file with one raster map name and optional one weight per line, field "
+"separator between name and weight is |"
 msgstr ""
 #: ../raster/r.series/main.c:157 ../raster3d/r3.neighbors/main.c:119
@@ -3450,7 +3692,8 @@
 msgstr "Quantile für method=quantile"
 #: ../raster/r.series/main.c:172
-msgid "Weighting factor for each input map, default value is 1.0 for each input map"
+msgid ""
+"Weighting factor for each input map, default value is 1.0 for each input map"
 msgstr ""
 #: ../raster/r.series/main.c:179 ../raster/r.series.accumulate/main.c:132
@@ -3520,7 +3763,8 @@
 #: ../raster/r.grow.distance/main.c:154
 #, fuzzy
 msgid "Generates a raster map containing distances to nearest raster features."
-msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Objekten in der Eingabekarte."
+msgstr ""
+"Erzeugt eine Rasterkarte mit Distanzen zu Objekten in der Eingabekarte."
 #: ../raster/r.grow.distance/main.c:161
 #, fuzzy
@@ -3605,7 +3849,9 @@
 #: ../raster/r.out.ppm3/main.c:58
 #, fuzzy
 msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung der DERZEITIG EINGESTELLTEN REGION."
+msgstr ""
+"Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung "
+"der DERZEITIG EINGESTELLTEN REGION."
 #: ../raster/r.out.ppm3/main.c:83
 msgid "Name for new PPM file. (use out=- for stdout)"
@@ -3672,8 +3918,16 @@
 #: ../raster/r.ros/main.c:220
 #, fuzzy
-msgid "Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
-msgstr "Erstellt drei oder vier Rasterkarten, die 1) die Basisrate der (rechtwinkligen) Ausbreitungsgeschwindigkeit, 2) die maximale (Vorwärts-) Geschwindigkeit, 3) die Richtung der größten Ausbreitungsgeschwindigkeit und optional 4) die maximale Entdeckungsentfernung."
+msgid ""
+"Generates three, or four raster map layers showing the base (perpendicular) "
+"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
+"maximum ROS, and optionally the maximum potential spotting distance for fire "
+"spread simulation."
+msgstr ""
+"Erstellt drei oder vier Rasterkarten, die 1) die Basisrate der "
+"(rechtwinkligen) Ausbreitungsgeschwindigkeit, 2) die maximale (Vorwärts-) "
+"Geschwindigkeit, 3) die Richtung der größten Ausbreitungsgeschwindigkeit und "
+"optional 4) die maximale Entdeckungsentfernung."
 #: ../raster/r.ros/main.c:227
 #, fuzzy
@@ -3681,34 +3935,49 @@
 msgstr "Name der Rasterkarte mit Brennmaterial-Modellen."
 #: ../raster/r.ros/main.c:229
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the standard fuel models defined by the USDA Forest Service. Valid values are 1-13; other numbers are recognized as barriers by r.ros."
+msgid ""
+"Name of an existing raster map layer in the user's current mapset search "
+"path containing the standard fuel models defined by the USDA Forest Service. "
+"Valid values are 1-13; other numbers are recognized as barriers by r.ros."
 msgstr ""
 #: ../raster/r.ros/main.c:238
 #, fuzzy
 msgid "Raster map containing the 1-hour fuel moisture (%)"
-msgstr "Name der Rasterkarte mit den 1-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr ""
+"Name der Rasterkarte mit den 1-Stunden-Brennmaterialfeuchtigkeiten [%]."
 #: ../raster/r.ros/main.c:240 ../raster/r.spread/main.c:201
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the 1-hour (<.25\") fuel moisture (percentage content multiplied by 100)."
+msgid ""
+"path containing the 1-hour (<.25\") fuel moisture (percentage content "
+"multiplied by 100)."
 msgstr ""
 #: ../raster/r.ros/main.c:248
 #, fuzzy
 msgid "Raster map containing the 10-hour fuel moisture (%)"
-msgstr "Name der Rasterkarte mit den 10-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr ""
+"Name der Rasterkarte mit den 10-Stunden-Brennmaterialfeuchtigkeiten [%]."
 #: ../raster/r.ros/main.c:250
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the 10-hour (.25-1\") fuel moisture (percentage content multiplied by 100)."
+msgid ""
+"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
 msgstr ""
 #: ../raster/r.ros/main.c:258
 #, fuzzy
 msgid "Raster map containing the 100-hour fuel moisture (%)"
-msgstr "Name der Rasterkarte mit den 100-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr ""
+"Name der Rasterkarte mit den 100-Stunden-Brennmaterialfeuchtigkeiten [%]."
 #: ../raster/r.ros/main.c:260
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the 100-hour (1-3\") fuel moisture (percentage content multiplied by 100)."
+msgid ""
+"path containing the 100-hour (1-3\") fuel moisture (percentage content "
 msgstr ""
 #: ../raster/r.ros/main.c:267
@@ -3717,16 +3986,24 @@
 msgstr "Rasterkarte, die Werte für die Pfeillänge enthält."
 #: ../raster/r.ros/main.c:269
-msgid "Name of an existing raster map layer in the user's current mapset search path containing live (herbaceous) fuel moisture (percentage content multiplied by 100)."
+msgid ""
+"path containing live (herbaceous) fuel moisture (percentage content "
 msgstr ""
 #: ../raster/r.ros/main.c:277
 #, fuzzy
 msgid "Raster map containing midflame wind velocitys (ft/min)"
-msgstr "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/min]."
+msgstr ""
+"Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/"
+"min]."
 #: ../raster/r.ros/main.c:279 ../raster/r.spread/main.c:189
-msgid "Name of an existing raster map layer in the user's current mapset search path containing wind velocities at half of the average flame height (feet/minute)."
+msgid ""
+"path containing wind velocities at half of the average flame height (feet/"
+"minute)."
 msgstr ""
 #: ../raster/r.ros/main.c:287
@@ -3735,7 +4012,9 @@
 msgstr "Name der Rasterkarte mit den Windrichtungen [Grad]."
 #: ../raster/r.ros/main.c:289
-msgid "Name of an existing raster map layer in the user's current mapset search path containing wind direction, clockwise from north (degree)."
+msgid ""
+"path containing wind direction, clockwise from north (degree)."
 msgstr ""
 #: ../raster/r.ros/main.c:297
@@ -3744,25 +4023,37 @@
 msgstr "Name der Rasterkarte mit Hangneigung [Grad]."
 #: ../raster/r.ros/main.c:299
-msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic slope (degree)."
+msgid ""
+"path containing topographic slope (degree)."
 msgstr ""
 #: ../raster/r.ros/main.c:307
 #, fuzzy
 msgid "Raster map containing aspect (degree, CCW from E)"
-msgstr "Name der Rasterkarte mit Expositionen [Grad, gegen den Uhrzeigersinn vom Osten]."
+msgstr ""
+"Name der Rasterkarte mit Expositionen [Grad, gegen den Uhrzeigersinn vom "
+"Osten]."
 #: ../raster/r.ros/main.c:309
-msgid "Name of an existing raster map layer in the user's current mapset search path containing topographic aspect, counterclockwise from east (GRASS convention) in degrees."
+msgid ""
+"path containing topographic aspect, counterclockwise from east (GRASS "
+"convention) in degrees."
 msgstr ""
 #: ../raster/r.ros/main.c:317
 #, fuzzy
 msgid "Raster map containing elevation (m, required with -s)"
-msgstr "Name der Rasterkarte mit den Höheninformationen [m] (gefordert von dem Schalter -s)."
+msgstr ""
+"Name der Rasterkarte mit den Höheninformationen [m] (gefordert von dem "
+"Schalter -s)."
 #: ../raster/r.ros/main.c:319
-msgid "Name of an existing raster map layer in the user's current mapset search path containing elevation (meters). Option is required from spotting distance computation (when -s flag is enabled)"
+msgid ""
+"path containing elevation (meters). Option is required from spotting "
+"distance computation (when -s flag is enabled)"
 msgstr ""
 #: ../raster/r.ros/main.c:326
@@ -3776,17 +4067,23 @@
 msgstr "Auch die maximale Entdeckungsentfernung berechnen."
 #: ../raster/r.ros/main.c:345
-msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
+msgid ""
+"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
+"moisture layers is required."
 msgstr ""
 #: ../raster/r.ros/main.c:369
 #, c-format
-msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
+msgid ""
+"A wind direction layer should be given if the wind velocity layer <%s> has "
+"been given"
 msgstr ""
 #: ../raster/r.ros/main.c:374
 #, c-format
-msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
+msgid ""
+"A wind velocity layer should be given if the wind direction layer <%s> has "
+"been given"
 msgstr ""
 #: ../raster/r.ros/main.c:388
@@ -3856,11 +4153,15 @@
 #: ../raster/r.null/main.c:96
 msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr "Nur ausführen, wenn für die Karte noch keine NULL-Wert Bitmap Datei existiert."
+msgstr ""
+"Nur ausführen, wenn für die Karte noch keine NULL-Wert Bitmap Datei "
+"existiert."
 #: ../raster/r.null/main.c:102
 msgid "Create NULL-value bitmap file validating all data cells"
-msgstr "Erzeuge eine NULL-Wert Bitmap Datei, die alle Daten-Zellen für gültig erklärt."
+msgstr ""
+"Erzeuge eine NULL-Wert Bitmap Datei, die alle Daten-Zellen für gültig "
+"erklärt."
 #: ../raster/r.null/main.c:106
 msgid "Remove NULL-value bitmap file"
@@ -3876,8 +4177,13 @@
 #: ../raster/r.null/main.c:125
 #, c-format
-msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
-msgstr "Die Rasterkarte <%s> ist eine reklassifizierte Version der Karte <%s@%s>. Bedenken Sie, dass es sinnvoll sein könnte eine Kopie mit r.mapcalc zu erzeugen. Beende mich."
+msgid ""
+"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
+"with r.mapcalc. Exiting."
+msgstr ""
+"Die Rasterkarte <%s> ist eine reklassifizierte Version der Karte <%s@%s>. "
+"Bedenken Sie, dass es sinnvoll sein könnte eine Kopie mit r.mapcalc zu "
+"erzeugen. Beende mich."
 #: ../raster/r.null/main.c:131
 #, c-format
@@ -3945,12 +4251,18 @@
 msgstr "Volumen Position"
 #: ../raster/r.sunmask/main.c:119
-msgid "Calculates cast shadow areas from sun position and elevation raster map."
-msgstr "Berechnet Schattenbereiche aus der Sonnenposition und einer Höhenkarte."
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map."
+msgstr ""
+"Berechnet Schattenbereiche aus der Sonnenposition und einer Höhenkarte."
 #: ../raster/r.sunmask/main.c:120
-msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
-msgstr "Entweder wird die exakte Sonnenposition (A) oder Datum/Uhrzeit zur Berechnung der Sonnenposition durch r.sunmask (B) angegeben."
+msgid ""
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
+msgstr ""
+"Entweder wird die exakte Sonnenposition (A) oder Datum/Uhrzeit zur "
+"Berechnung der Sonnenposition durch r.sunmask (B) angegeben."
 #: ../raster/r.sunmask/main.c:134
 msgid "Altitude of the sun above horizon, degrees (A)"
@@ -3995,7 +4307,9 @@
 #: ../raster/r.sunmask/main.c:200
 msgid "East positive, offset from GMT, also use to adjust daylight savings"
-msgstr "Ost positiv, Abstand von GMT; wird auch zur Anpassung an die Winterzeit genutzt"
+msgstr ""
+"Ost positiv, Abstand von GMT; wird auch zur Anpassung an die Winterzeit "
+"genutzt"
 #: ../raster/r.sunmask/main.c:209
 msgid "Easting coordinate (point of interest)"
@@ -4039,8 +4353,12 @@
 msgstr "Definiere Sie entweder die Sonnenposition oder Ort/Datum/Zeit."
 #: ../raster/r.sunmask/main.c:280
-msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
-msgstr "Weder die Sonnenposition noch Ost/Nord, Datum/Uhrzeit/Zeitzone sind vollständig angegeben."
+msgid ""
+"Neither sun position nor east/north, date/time/timezone definition are "
+"complete"
+msgstr ""
+"Weder die Sonnenposition noch Ost/Nord, Datum/Uhrzeit/Zeitzone sind "
+"vollständig angegeben."
 #: ../raster/r.sunmask/main.c:284
 #, c-format
@@ -4048,8 +4366,12 @@
 msgstr "Berechne Sonnenposition... (verwende solpos (V. %s) vom NREL)"
 #: ../raster/r.sunmask/main.c:289
-msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
-msgstr "Verwende benutzerdefinierten Sonnenazimuth und Höhe (ignoriere eventuell anderen Werte)"
+msgid ""
+"Using user defined sun azimuth, altitude settings (ignoring eventual other "
+"values)"
+msgstr ""
+"Verwende benutzerdefinierten Sonnenazimuth und Höhe (ignoriere eventuell "
+"anderen Werte)"
 #: ../raster/r.sunmask/main.c:397
 msgid "Please correct settings"
@@ -4091,32 +4413,44 @@
 #: ../raster/r.sunmask/main.c:454
 #, c-format
 msgid "Unable to open range file for raster map <%s>"
-msgstr "Kann die Datei mit dem Wertebereich für die Rasterkarte <%s> nicht lesen."
+msgstr ""
+"Kann die Datei mit dem Wertebereich für die Rasterkarte <%s> nicht lesen."
 #: ../raster/r.sunmask/main.c:470
 msgid "Calculating shadows from DEM..."
 msgstr "Berechne Schatten des DHM..."
 #: ../raster/r.sunmask/g_solposition.c:66
-msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
-msgstr "Die Sonnenposition kann in unprojezierten Locations nicht berechnet werden. Sonnenposition muss direkt eingegeben werden."
+msgid ""
+"Unable to calculate sun position in un-projected locations. Specify "
+"sunposition directly."
+msgstr ""
+"Die Sonnenposition kann in unprojezierten Locations nicht berechnet werden. "
+"Sonnenposition muss direkt eingegeben werden."
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
-msgstr "Angegebener Punkt %f, %f ist außerhalb der aktuellen Gebietsausdehnung, ist dies beabsichtigt? Trotzdem, die Einstellungen werden verwendet."
+msgid ""
+"Specified point %f, %f outside of current region, is that intended? Anyway, "
+"it will be used."
+msgstr ""
+"Angegebener Punkt %f, %f ist außerhalb der aktuellen Gebietsausdehnung, ist "
+"dies beabsichtigt? Trotzdem, die Einstellungen werden verwendet."
 #: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
 msgid "Unable to get projection info of current location"
+msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:101 ../raster/r.latlong/main.c:103
 msgid "Unable to get projection units of current location"
-msgstr "Kann die Einheiten der Projektion der aktuellen Location nicht ermitteln."
+msgstr ""
+"Kann die Einheiten der Projektion der aktuellen Location nicht ermitteln."
 #: ../raster/r.sunmask/g_solposition.c:104 ../raster/r.latlong/main.c:105
 msgid "Unable to get projection key values of current location"
-msgstr "Kann die Kennzahlen der Projektion der aktuellen Location nicht ermitteln."
+msgstr ""
+"Kann die Kennzahlen der Projektion der aktuellen Location nicht ermitteln."
 #: ../raster/r.latlong/main.c:57
 msgid "latitude"
@@ -4325,12 +4659,14 @@
 #: ../raster/r.out.arc/main.c:94
 msgid "Use cell center reference in header instead of cell corner"
-msgstr "Verwende als Referenz im Header den Zellmittelpunkt anstelle der Zellecke."
+msgstr ""
+"Verwende als Referenz im Header den Zellmittelpunkt anstelle der Zellecke."
 #: ../raster/r.colors/rules.c:40
 #, c-format
 msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr "Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
+msgstr ""
+"Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
 #: ../raster/r.colors/rules.c:49
 #, c-format
@@ -4348,7 +4684,8 @@
 "Your color rules do not cover the whole range of data!\n"
 " (rules %f to %f but data %f to %f)"
 msgstr ""
-"Die ausgewählten Farbregeln erstrecken sich nicht über den gesamten Wertebereich!\n"
+"Die ausgewählten Farbregeln erstrecken sich nicht über den gesamten "
+"Wertebereich!\n"
 "(Regelsatz: %f - %f aber Daten: %f - %f)"
 #: ../raster/r.colors/rules.c:104 ../raster/r.reclass/parse.c:41
@@ -4403,7 +4740,9 @@
 #: ../raster/r.colors/stats.c:73
 msgid "Unable to use logarithmic scaling if range includes zero"
-msgstr "Kann keine logarithmische Skala verwenden, wenn der Wertebereich Null enthält."
+msgstr ""
+"Kann keine logarithmische Skala verwenden, wenn der Wertebereich Null "
+"enthält."
 #: ../raster/r.colors/stats.c:118
 msgid "Error opening 3d raster map"
@@ -4457,7 +4796,9 @@
 msgstr "Eingabe-Vektorkarte mit Linien."
 #: ../raster/r.colors/edit_colors.c:83
-msgid "Input map names can be defined in an input file in case a large amount of maps must be specified. This option is mutual exclusive to the map option."
+msgid ""
+"Input map names can be defined in an input file in case a large amount of "
+"maps must be specified. This option is mutual exclusive to the map option."
 msgstr ""
 #: ../raster/r.colors/edit_colors.c:96
@@ -4532,12 +4873,16 @@
 #: ../raster/r.colors/edit_colors.c:169
 #, fuzzy, c-format
 msgid "Options <%s> or <%s> must be specified"
-msgstr "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder \"rules\" muss angegeben werden!"
+msgstr ""
+"Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder "
+"\"rules\" muss angegeben werden!"
 #: ../raster/r.colors/edit_colors.c:182
 #, fuzzy, c-format
 msgid "One of -%c or options <%s>, <%s> or <%s> must be specified"
+msgstr ""
 #: ../raster/r.colors/edit_colors.c:187
 #, fuzzy, c-format
@@ -4717,7 +5062,9 @@
 #: ../raster/r.in.ascii/gethead.c:169
 msgid "ignoring type filed in header, type is set on command line"
-msgstr "Ignoriere Feldtypen des Headers, da der Typ auf der Kommandozeile gesetzt wurde."
+msgstr ""
+"Ignoriere Feldtypen des Headers, da der Typ auf der Kommandozeile gesetzt "
+"wurde."
 #: ../raster/r.in.ascii/gethead.c:176
 msgid "illegal multiplier field: using 1.0"
@@ -4725,11 +5072,15 @@
 #: ../raster/r.in.ascii/gethead.c:181
 msgid "ignoring multiplier filed in header, multiplier is set on command line"
-msgstr "Ignoriere Multiplikator-Feld im Header, da der Multiplikator auf der Kommandozeile gesetzt wurde."
+msgstr ""
+"Ignoriere Multiplikator-Feld im Header, da der Multiplikator auf der "
+"Kommandozeile gesetzt wurde."
 #: ../raster/r.in.ascii/gethead.c:189
 msgid "ignoring null filed in header, null string is set on command line"
-msgstr "Ignoriere NULL-Feld im Header, da der NULL-Wert auf der Kommandozeile gesetzt wurde."
+msgstr ""
+"Ignoriere NULL-Feld im Header, da der NULL-Wert auf der Kommandozeile "
+"gesetzt wurde."
 #: ../raster/r.in.ascii/gethead.c:218
 msgid "error in ascii data format"
@@ -4746,7 +5097,8 @@
 msgstr ""
 #: ../raster/r.stream.segment/main.c:56
-msgid "Divides network into near straight-line segments and calculate its order."
+msgid ""
+"Divides network into near straight-line segments and calculate its order."
 msgstr ""
 #: ../raster/r.stream.segment/main.c:60
@@ -4794,7 +5146,8 @@
 #: ../raster/r.stream.order/main.c:107
 #, fuzzy
 msgid "Max memory used in memory swap mode (MB)"
+msgstr ""
 #: ../raster/r.stream.segment/main.c:108 ../raster/r.stream.segment/main.c:118
 #, fuzzy
@@ -5027,7 +5380,8 @@
 #: ../raster/r.random.cells/main.c:67
 msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
-msgstr "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard [zufällig])."
+msgstr ""
+"Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard [zufällig])."
 #: ../raster/r.random.cells/init.c:70
 msgid "Distance must be >= 0.0"
@@ -5040,7 +5394,9 @@
 #: ../raster/r.grow/main.c:125 ../locale/scriptstrings/r.grow_to_translate.c:1
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr "Erzeugt eine Rasterkarte mit kontinuierlich um eine Zelle gewachsenen Flächen."
+msgstr ""
+"Erzeugt eine Rasterkarte mit kontinuierlich um eine Zelle gewachsenen "
+"Flächen."
 #: ../raster/r.grow/main.c:136 ../locale/scriptstrings/r.grow_to_translate.c:4
 msgid "Radius of buffer in raster cells"
@@ -5048,7 +5404,9 @@
 #: ../raster/r.grow/main.c:152 ../locale/scriptstrings/r.grow_to_translate.c:6
 msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
-msgstr "Wert die für Eingabezellen, die nicht-NULL sind (-1 => NULL) geschrieben werden."
+msgstr ""
+"Wert die für Eingabezellen, die nicht-NULL sind (-1 => NULL) geschrieben "
+"werden."
 #: ../raster/r.grow/main.c:158 ../locale/scriptstrings/r.grow_to_translate.c:7
 msgid "Value to write for \"grown\" cells"
@@ -5091,7 +5449,9 @@
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
 #: ../vector/v.db.select/main.c:88
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr "Name der Ausgabekarte (wenn keiner oder \"-\"  angegeben wurdeerfolgt die Ausgabe nach stdout)."
+msgstr ""
+"Name der Ausgabekarte (wenn keiner oder \"-\"  angegeben wurdeerfolgt die "
+"Ausgabe nach stdout)."
 #: ../raster/r.stats/main.c:122 ../raster/r.stats/main.c:131
 #: ../raster/r.stats/main.c:155 ../raster/r.report/parse.c:76
@@ -5115,7 +5475,8 @@
 #: ../raster/r.stats/main.c:140 ../raster/r.report/parse.c:103
 #, fuzzy
 msgid "Number of floating-point subranges to collect stats from"
-msgstr "Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
+msgstr ""
+"Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
 #: ../raster/r.stats/main.c:141 ../raster/r.stats/main.c:196
 #: ../raster/r.stats/main.c:201 ../raster/r.stats/main.c:216
@@ -5161,7 +5522,8 @@
 #: ../raster/r.stats/main.c:172
 #, fuzzy
 msgid "Print approximate (total percent may not be 100%) percents"
-msgstr "Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
+msgstr ""
+"Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
 #: ../raster/r.stats/main.c:177
 msgid "Print category labels"
@@ -5217,7 +5579,9 @@
 #: ../raster/r.stats/main.c:220 ../raster/r.report/parse.c:153
 #, fuzzy
 msgid "Read floating-point map as integer (use map's quant rules)"
-msgstr "Lese Fließkommakarte als Integerkarte (benutze Quantisierungsregeln der Karte)."
+msgstr ""
+"Lese Fließkommakarte als Integerkarte (benutze Quantisierungsregeln der "
+"Karte)."
 #: ../raster/r.stats/main.c:237
 #, c-format
@@ -5226,18 +5590,30 @@
 #: ../raster/r.stats/main.c:307
 #, c-format
-msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
-msgstr "Rasterkarte <%s> wird als Integer-Karte gelesen! Schalter '-%c' und/oder die Option '%s' werden ignoriert."
+msgid ""
+"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
+"will be ignored."
+msgstr ""
+"Rasterkarte <%s> wird als Integer-Karte gelesen! Schalter '-%c' und/oder die "
+"Option '%s' werden ignoriert."
 #: ../raster/r.stats/main.c:323
 #, c-format
-msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
-msgstr "Kategorien der Rasterkarte <%s> fehlen oder haben keine expliziten Beschriftungen. Verwende %s=%d."
+msgid ""
+"Cats for raster map <%s> are either missing or have no explicit labels. "
+"Using %s=%d."
+msgstr ""
+"Kategorien der Rasterkarte <%s> fehlen oder haben keine expliziten "
+"Beschriftungen. Verwende %s=%d."
 #: ../raster/r.stats/main.c:329
 #, c-format
-msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
-msgstr "Der Schalter '-%c' wurde gesetzt. Verwende die fp-Kategoriespanne der Rasterkarte <%s> und ignoriere die Option '%s'."
+msgid ""
+"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
+"option"
+msgstr ""
+"Der Schalter '-%c' wurde gesetzt. Verwende die fp-Kategoriespanne der "
+"Rasterkarte <%s> und ignoriere die Option '%s'."
 #: ../raster/r.stats/main.c:335 ../raster/r.contour/main.c:146
 #, c-format
@@ -5279,7 +5655,8 @@
 #: ../raster/r.drain/main.c:113
 #, fuzzy
-msgid "Traces a flow through an elevation model or cost surface on a raster map."
+msgid ""
+"Traces a flow through an elevation model or cost surface on a raster map."
 msgstr "Verfolgt einen Fluss durch ein Höhenmodell auf einer Rasterkarte."
 #: ../raster/r.drain/main.c:116
@@ -5305,7 +5682,9 @@
 #: ../raster/r.drain/main.c:132
 #, fuzzy
 msgid "Recommended for cost surface made using knight's move"
-msgstr "Ausgabe Abflußvektorkarte (empfohlen für Kostenkarten erstellt mittels Rösselsprung)."
+msgstr ""
+"Ausgabe Abflußvektorkarte (empfohlen für Kostenkarten erstellt mittels "
+"Rösselsprung)."
 #: ../raster/r.drain/main.c:142
 #, fuzzy
@@ -5331,8 +5710,12 @@
 #: ../raster/r.drain/main.c:163
 #, fuzzy
-msgid "The input raster map is a cost surface (direction surface must also be specified)"
-msgstr "Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muß auch eine Richtungskarte angegeben werden)."
+msgid ""
+"The input raster map is a cost surface (direction surface must also be "
+"specified)"
+msgstr ""
+"Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muß auch eine "
+"Richtungskarte angegeben werden)."
 #: ../raster/r.drain/main.c:175
 #, fuzzy
@@ -5345,13 +5728,21 @@
 #: ../raster/r.drain/main.c:183
 #, fuzzy, c-format
-msgid "Direction raster map <%s> not specified, if direction flag is on, a direction raster must be given"
-msgstr "Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, muß eine Richtungskarte angegeben werden."
+msgid ""
+"Direction raster map <%s> not specified, if direction flag is on, a "
+"direction raster must be given"
+msgstr ""
+"Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, "
+"muß eine Richtungskarte angegeben werden."
 #: ../raster/r.drain/main.c:190
 #, fuzzy, c-format
-msgid "Direction raster map <%s> should not be specified for Surface/Hydrology drains"
-msgstr "Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluß nicht angegeben werden."
+msgid ""
+"Direction raster map <%s> should not be specified for Surface/Hydrology "
+"drains"
+msgstr ""
+"Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluß nicht "
+"angegeben werden."
 #: ../raster/r.drain/main.c:197 ../raster/r.resamp.bspline/main.c:484
 #: ../raster/r.flow/io.c:178 ../doc/vector/v.example/main.c:98
@@ -5480,7 +5871,9 @@
 #: ../raster/r.param.scale/process.c:74
 msgid "E-W and N-S grid resolutions are different. Taking average."
-msgstr "Zellengröße in Ost-West- und Nord-Süd-Richtung ist unterschiedlich. Verwende den Mittelwert."
+msgstr ""
+"Zellengröße in Ost-West- und Nord-Süd-Richtung ist unterschiedlich. Verwende "
+"den Mittelwert."
 #: ../raster/r.param.scale/interface.c:55
 #, fuzzy
@@ -5492,8 +5885,12 @@
 msgstr "Extrahiert Terrainparameter aus einem DGM."
 #: ../raster/r.param.scale/interface.c:57
-msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
-msgstr "Verwendet einen multi-skalaren Ansatz, in dem quadratische Parameter auf jede Fenstergröße angepasst werden (über die Methode der kleinsten Quadrate)."
+msgid ""
+"Uses a multi-scale approach by taking fitting quadratic parameters to any "
+"size window (via least squares)."
+msgstr ""
+"Verwendet einen multi-skalaren Ansatz, in dem quadratische Parameter auf "
+"jede Fenstergröße angepasst werden (über die Methode der kleinsten Quadrate)."
 #: ../raster/r.param.scale/interface.c:75
 msgid "Output raster layer containing morphometric parameter"
@@ -5501,7 +5898,8 @@
 #: ../raster/r.param.scale/interface.c:79
 msgid "Slope tolerance that defines a 'flat' surface (degrees)"
-msgstr "Hangneigungstoleranz, die eine 'flache' Oberfläche definiert (in Grad)."
+msgstr ""
+"Hangneigungstoleranz, die eine 'flache' Oberfläche definiert (in Grad)."
 #: ../raster/r.param.scale/interface.c:86
 msgid "Curvature tolerance that defines 'planar' surface"
@@ -5514,7 +5912,9 @@
 #: ../raster/r.param.scale/interface.c:101
 msgid "Morphometric parameter in 'size' window to calculate"
-msgstr "Morphometrische Parameter, die innerhalb der Fenstergröße berechnet werden sollen."
+msgstr ""
+"Morphometrische Parameter, die innerhalb der Fenstergröße berechnet werden "
+"sollen."
 #: ../raster/r.param.scale/interface.c:109
 msgid "Exponent for distance weighting (0.0-4.0)"
@@ -5551,8 +5951,12 @@
 #: ../raster/r.buffer/main.c:69
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
 #, fuzzy
-msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
-msgstr "Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte haben."
+msgid ""
+"Creates a raster map showing buffer zones surrounding cells that contain non-"
+"NULL category values."
+msgstr ""
+"Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte "
+"haben."
 #: ../raster/r.buffer/main.c:81
 #: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
@@ -5589,8 +5993,12 @@
 msgstr "Lese Eingabe-Rasterkarte <%s>..."
 #: ../raster/r.covar/main.c:54
-msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
-msgstr "Gibt eine Kovarianz/Korrelations-Matrix für (eine) benutzerdefiniert Rasterkarte(n) aus."
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map "
+"layer(s)."
+msgstr ""
+"Gibt eine Kovarianz/Korrelations-Matrix für (eine) benutzerdefiniert "
+"Rasterkarte(n) aus."
 #: ../raster/r.covar/main.c:61
 msgid "Print correlation matrix"
@@ -5720,13 +6128,20 @@
 #: ../raster/r.volume/main.c:80
 #, fuzzy
-msgid "Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
-msgstr "Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
+msgid ""
+"Optionally produces a GRASS vector points map containing the calculated "
+"centroids of these clumps."
+msgstr ""
+"Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-"
+"Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
 #: ../raster/r.volume/main.c:85
 #, fuzzy
-msgid "Name of input raster map representing data that will be summed within clumps"
-msgstr "Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen aufsummiert werden."
+msgid ""
+"Name of input raster map representing data that will be summed within clumps"
+msgstr ""
+"Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen "
+"aufsummiert werden."
 #: ../raster/r.volume/main.c:91
 #, fuzzy
@@ -5734,7 +6149,8 @@
 msgstr "Name der Eingabe-Rasterkarte."
 #: ../raster/r.volume/main.c:92
-msgid "Preferably the output of r.clump. If no clump map is given than MASK is used."
+msgid ""
+"Preferably the output of r.clump. If no clump map is given than MASK is used."
 msgstr ""
 #: ../raster/r.volume/main.c:98
@@ -5758,7 +6174,9 @@
 msgstr "Erzeuge unformatierten Report."
 #: ../raster/r.volume/main.c:142
-msgid "No MASK found. If no clump map is given than the MASK is required. You need to define a clump raster map or create a MASK by r.mask command."
+msgid ""
+"No MASK found. If no clump map is given than the MASK is required. You need "
+"to define a clump raster map or create a MASK by r.mask command."
 msgstr ""
 #: ../raster/r.volume/main.c:144
@@ -5875,7 +6293,9 @@
 msgstr ""
 #: ../raster/r.stream.stats/main.c:52
-msgid "Calculates Horton's statistics for Strahler and Horton ordered networks created with r.stream.order."
+msgid ""
+"Calculates Horton's statistics for Strahler and Horton ordered networks "
+"created with r.stream.order."
 msgstr ""
 #: ../raster/r.stream.stats/main.c:56
@@ -5891,7 +6311,9 @@
 #: ../raster/r.stream.stats/main.c:78
 #, fuzzy
 msgid "Name for output file (if omitted output to stdout)"
+msgstr ""
 #: ../raster/r.stream.stats/main.c:88
 #, fuzzy
@@ -5920,7 +6342,9 @@
 msgstr "Konvertiert eine Rasterkarte in das VTK-ASCII-Format."
 #: ../raster/r.out.vtk/main.c:73
-msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
+msgid ""
+"No input maps specified. You need to specify at least one input map or three "
+"vector maps or three rgb maps."
 msgstr ""
 #: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
@@ -5935,15 +6359,20 @@
 #: ../raster/r.out.vtk/main.c:232
 msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr "Falsche RGB Karten. Karten sollten den selben Typ haben! RGB Ausgabe wurde nicht hinzugefügt!"
+msgstr ""
+"Falsche RGB Karten. Karten sollten den selben Typ haben! RGB Ausgabe wurde "
+"nicht hinzugefügt!"
 #: ../raster/r.out.vtk/main.c:261
 msgid "Writing VTK Vector Data\n"
 msgstr "Schreibe VTK Vektordaten.\n"
 #: ../raster/r.out.vtk/main.c:271
-msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr "FalscheVektorkarten. Karten sollten den selben Typ haben! Vektor-Ausgabe wurde nicht hinzugefügt!"
+msgid ""
+"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgstr ""
+"FalscheVektorkarten. Karten sollten den selben Typ haben! Vektor-Ausgabe "
+"wurde nicht hinzugefügt!"
 #: ../raster/r.out.vtk/main.c:283
 msgid "Error closing VTK-ASCII file"
@@ -6013,16 +6442,23 @@
 #: ../raster/r.out.vtk/parameters.c:61
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
-msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr "Erzeuge VTK Punktdaten anstelle von VTK Cell-Daten (wenn keine Höhenkarte angegeben wurde)."
+msgid ""
+"Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr ""
+"Erzeuge VTK Punktdaten anstelle von VTK Cell-Daten (wenn keine Höhenkarte "
+"angegeben wurde)."
 #: ../raster/r.out.vtk/parameters.c:71
-msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr "Drei (R,G,B) Rasterkarten um RGB-Werte zu erzeugen [rote Karte,grüne Karte,blaue Karte]."
+msgid ""
+"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr ""
+"Drei (R,G,B) Rasterkarten um RGB-Werte zu erzeugen [rote Karte,grüne Karte,"
+"blaue Karte]."
 #: ../raster/r.out.vtk/parameters.c:81
 msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr "Drei (x,y,z) Rasterkarten um Vektor-Werte zu erzeugen [xmap,ymap,zmap]."
+msgstr ""
+"Drei (x,y,z) Rasterkarten um Vektor-Werte zu erzeugen [xmap,ymap,zmap]."
 #: ../raster/r.out.vtk/parameters.c:88 ../raster3d/r3.out.vtk/parameters.c:98
 #: ../vector/v.out.vtk/main.c:74
@@ -6044,12 +6480,17 @@
 msgstr "Benutze Polydata-Dreiecksstreifen für die Erzeugung des Höhengitters."
 #: ../raster/r.out.vtk/parameters.c:118
-msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr "Benutze Polydata-Stützpunkte für die Höhenmodellerstellung (für vtkDelauny2D)."
+msgid ""
+"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr ""
+"Benutze Polydata-Stützpunkte für die Höhenmodellerstellung (für "
+"vtkDelauny2D)."
 #: ../raster/r.out.vtk/parameters.c:124
 msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr "Skalierungsfaktor beeinflusst den Ursprung (wenn keine Höhenkarte angegeben wurde)."
+msgstr ""
+"Skalierungsfaktor beeinflusst den Ursprung (wenn keine Höhenkarte angegeben "
+"wurde)."
 #: ../raster/r.out.vtk/parameters.c:130
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
@@ -6064,17 +6505,23 @@
 #: ../raster/r.gwflow/main.c:62
 #, fuzzy
-msgid "Name of input raster map providing Boundary condition status: 0-inactive, 1-active, 2-dirichlet"
+msgid ""
+"Name of input raster map providing Boundary condition status: 0-inactive, 1-"
+"active, 2-dirichlet"
 msgstr "Status der Randbedingungen, 0-inaktive, 1-aktive, 2-dirichlet."
 #: ../raster/r.gwflow/main.c:67
 #, fuzzy
-msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
+msgid ""
+"Name of input raster map with x-part of the hydraulic conductivity tensor in "
+"[m/s]"
 msgstr "Der X-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
 #: ../raster/r.gwflow/main.c:72
 #, fuzzy
-msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
+msgid ""
+"Name of input raster map with y-part of the hydraulic conductivity tensor in "
+"[m/s]"
 msgstr "Der Y-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
 #: ../raster/r.gwflow/main.c:77
@@ -6083,7 +6530,9 @@
 msgstr "Wasserquellen und -senken [m^3/s]."
 #: ../raster/r.gwflow/main.c:81
-msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
+msgid ""
+"Name of input raster map with storativity for confined or effective porosity "
+"for unconfined groundwater flow booth in [-] "
 msgstr ""
 #: ../raster/r.gwflow/main.c:86
@@ -6097,12 +6546,14 @@
 #: ../raster/r.gwflow/main.c:92
 #, fuzzy
-msgid "Name of input raster map describing the top surface of the aquifer in [m]"
+msgid ""
+"Name of input raster map describing the top surface of the aquifer in [m]"
 msgstr "Untere Oberfläche wasserführende Schicht [m]."
 #: ../raster/r.gwflow/main.c:96
 #, fuzzy
-msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
+msgid ""
+"Name of input raster map describing the bottom surface of the aquifer in [m]"
 #: ../raster/r.gwflow/main.c:100
@@ -6112,14 +6563,18 @@
 #: ../raster/r.gwflow/main.c:106
 #, fuzzy
-msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
+msgid ""
+"Output raster map to store the groundwater filter velocity vector part in x "
+"direction [m/s]"
 msgstr ""
 "Berechne das Vektorfeld der Grundwasserfiltrationgeschwindigkeiten [m/s]\n"
 "und schreibe die x- und y-Komponenten in Karten mit den Namen name_[xy]."
 #: ../raster/r.gwflow/main.c:112
 #, fuzzy
-msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
+msgid ""
+"Output raster map to store the groundwater filter velocity vector part in y "
+"direction [m/s]"
 msgstr ""
@@ -6142,31 +6597,41 @@
 #: ../raster/r.gwflow/main.c:140
 #, fuzzy
-msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
+msgid ""
+"Name of input raster map providing the water level (head) of the river with "
+"leakage connection in [m]"
 msgstr "Wasserstand des Flusses (head) mit Sicker-Verbindung [m]."
 #: ../raster/r.gwflow/main.c:147
 #, fuzzy
-msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
+msgid ""
+"Name of input raster map providing the leakage coefficient of the river bed "
+"in [1/s]."
 msgstr "Sicker-Koeffizient des Flussbettes [1/s]."
 #: ../raster/r.gwflow/main.c:155
 #, fuzzy
-msgid "Name of input raster map providing the height of the drainage bed in [m]"
+msgid ""
+"Name of input raster map providing the height of the drainage bed in [m]"
 msgstr "Höhe der Drainage [m]."
 #: ../raster/r.gwflow/main.c:162
 #, fuzzy
-msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
+msgid ""
+"Name of input raster map providing the leakage coefficient of the drainage "
+"bed in [1/s]"
 msgstr "Sicker-Koeffizient der Drainage [1/s]."
 #: ../raster/r.gwflow/main.c:167
 #, fuzzy
 msgid "The maximum number of iterations in the linearization approach"
-msgstr "Maximale Zahl der Iterationen zur Berechnung der Eigenvektor-Zentralität"
+msgstr ""
+"Maximale Zahl der Iterationen zur Berechnung der Eigenvektor-Zentralität"
 #: ../raster/r.gwflow/main.c:176
-msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
+msgid ""
+"Allocate a full quadratic linear equation system, default is a sparse linear "
+"equation system."
 msgstr ""
 #: ../raster/r.gwflow/main.c:209 ../raster3d/r3.gwflow/main.c:160
@@ -6175,14 +6640,20 @@
 msgstr "Art des Grundwasserflusses "
 #: ../raster/r.gwflow/main.c:212
-msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
-msgstr "Programm zur numerischen Berechnung von transienten, beschränkten und unbeschränkten Grundwasserfluss in zwei Dimensionen."
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
+msgstr ""
+"Programm zur numerischen Berechnung von transienten, beschränkten und "
+"unbeschränkten Grundwasserfluss in zwei Dimensionen."
 #: ../raster/r.gwflow/main.c:222 ../raster/r.topidx/main.c:55
 #: ../raster/r.solute.transport/main.c:244
 #, c-format
 msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr "Lat/Long Location wird nicht unterstützt von %s. Bitte, projezieren Sie die Karte zuerst."
+msgstr ""
+"Lat/Long Location wird nicht unterstützt von %s. Bitte, projezieren Sie die "
+"Karte zuerst."
 #: ../raster/r.gwflow/main.c:237
 msgid "Please provide river_head, river_leak and river_bed maps"
@@ -6194,8 +6665,11 @@
 #: ../raster/r.gwflow/main.c:263
 #, fuzzy
-msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
-msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgid ""
+"The cholesky solver dos not work with sparse matrices. You may choose a full "
+"filled quadratic matrix, flag -f."
+msgstr ""
+"Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
 #: ../raster/r.gwflow/main.c:293
 #, fuzzy, c-format
@@ -6366,8 +6840,12 @@
 msgstr "Position"
 #: ../raster/simwe/r.sim.sediment/main.c:117
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
-msgstr "Sedimenttransport und Erosions/Depositions Simulation unter Verwendung der \"path sampling\" Methode (SIMWE)."
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
+"Sedimenttransport und Erosions/Depositions Simulation unter Verwendung der "
+"\"path sampling\" Methode (SIMWE)."
 #: ../raster/simwe/r.sim.sediment/main.c:124
 #, fuzzy
@@ -6452,7 +6930,9 @@
 msgstr "Eingabe Optionen"
 #: ../raster/simwe/r.sim.sediment/main.c:181
-msgid "Name of the sampling points output text file. For each observation vector point the time series of sediment transport is stored."
+msgid ""
+"Name of the sampling points output text file. For each observation vector "
+"point the time series of sediment transport is stored."
 msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:187
@@ -6463,7 +6943,8 @@
 #: ../raster/simwe/r.sim.sediment/main.c:194
 #, fuzzy
 msgid "Name for output transp.limited erosion-deposition raster map [kg/m2s]"
-msgstr "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
+msgstr ""
+"Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
 #: ../raster/simwe/r.sim.sediment/main.c:201
 #, fuzzy
@@ -6557,12 +7038,15 @@
 #: ../raster/simwe/r.sim.water/main.c:113
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr "Hydrologische Simulation des Oberflächenabfluß mittels der \"path sampling\" Methode (SIMWE)."
+msgstr ""
+"Hydrologische Simulation des Oberflächenabfluß mittels der \"path sampling\" "
+"Methode (SIMWE)."
 #: ../raster/simwe/r.sim.water/main.c:130
 #, fuzzy
 msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
-msgstr "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
+msgstr ""
+"Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
 #: ../raster/simwe/r.sim.water/main.c:139
 msgid "Rainfall excess rate unique value [mm/hr]"
@@ -6591,7 +7075,9 @@
 msgstr "Name Rasterkarte, die den Fluß kontrolliert (Permeabilität: 0-1)."
 #: ../raster/simwe/r.sim.water/main.c:190
-msgid "Name of the sampling points output text file. For each observation vector point the time series of water depth is stored."
+msgid ""
+"point the time series of water depth is stored."
 msgstr ""
 #: ../raster/simwe/r.sim.water/main.c:196
@@ -6620,7 +7106,9 @@
 #: ../raster/simwe/r.sim.water/main.c:268
 #, fuzzy
 msgid "Diffusion increases after this water depth is reached"
-msgstr "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe erreicht wurde)."
+msgstr ""
+"Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe "
+"erreicht wurde)."
 #: ../raster/simwe/r.sim.water/main.c:276
 msgid "Diffusion increase constant"
@@ -6659,8 +7147,12 @@
 #: ../raster/simwe/simlib/input.c:58
 #, c-format
-msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
-msgstr "Rasterkarte <%s> nicht gefunden und manin_val undefiniert. Wählen Sie eine, welche prozessiert werden dürfen."
+msgid ""
+"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
+"to process"
+msgstr ""
+"Rasterkarte <%s> nicht gefunden und manin_val undefiniert. Wählen Sie eine, "
+"welche prozessiert werden dürfen."
 #: ../raster/simwe/simlib/input.c:171
 #, fuzzy
@@ -6669,7 +7161,8 @@
 #: ../raster/simwe/simlib/input.c:222
 msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
-msgstr "Die Infiltration übersteigt den Niederschlag überall! Kein Oberflächenabfluß."
+msgstr ""
+"Die Infiltration übersteigt den Niederschlag überall! Kein Oberflächenabfluß."
 #: ../raster/simwe/simlib/input.c:246
 #, c-format
@@ -6683,7 +7176,9 @@
 #: ../raster/simwe/simlib/input.c:248
 #, c-format
 msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
-msgstr "Mittlere Quellgeschwindigkeit (Regenüberschuss oder Sediment) \t= %f m/s or kg/m2s \n"
+msgstr ""
+"Mittlere Quellgeschwindigkeit (Regenüberschuss oder Sediment) \t= %f m/s or "
+"kg/m2s \n"
 #: ../raster/simwe/simlib/input.c:250
 #, c-format
@@ -6837,7 +7332,8 @@
 #: ../raster/r.timestamp/main.c:39
 msgid "Print/add/remove a timestamp for a raster map."
-msgstr "Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
+msgstr ""
+"Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
 #: ../raster/r.timestamp/main.c:48 ../vector/v.timestamp/main.c:49
 msgid "Datetime, datetime1/datetime2, or 'none' to remove"
@@ -7049,12 +7545,17 @@
 msgstr "Name der Ausgabe ASCII-Grid Datei (verwende out=- für stdout)."
 #: ../raster/r.out.ascii/main.c:91
-msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
-msgstr "Anzahl der ausgegebenen Werte, bevor ein Zeilenumbruch eingefügt wird (nur beim SURFER oder MODFLOW-Format)"
+msgid ""
+"Number of values printed before wrapping a line (only SURFER or MODFLOW "
+"format)"
+msgstr ""
+"Anzahl der ausgegebenen Werte, bevor ein Zeilenumbruch eingefügt wird (nur "
+"beim SURFER oder MODFLOW-Format)"
 #: ../raster/r.out.ascii/main.c:99
 msgid "String to represent null cell (GRASS grid only)"
-msgstr "Zeichenkette, der NULL-Werte repräsentiert (nur bei GRASS Rasterkarten)."
+msgstr ""
+"Zeichenkette, der NULL-Werte repräsentiert (nur bei GRASS Rasterkarten)."
 #: ../raster/r.out.ascii/main.c:107
 msgid "Write SURFER (Golden Software) ASCII grid"
@@ -7132,7 +7633,8 @@
 #: ../raster/r.random.surface/main.c:102
 #, fuzzy
 msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
+msgstr ""
 #: ../raster/r.random.surface/main.c:108
 msgid "Maximum cell value of distribution"
@@ -7219,8 +7721,11 @@
 #: ../raster/r.resamp.bspline/main.c:85
 #, fuzzy
-msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
-msgstr "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
+msgid ""
+"Performs bilinear or bicubic spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+"Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
 #: ../raster/r.resamp.bspline/main.c:93
 #, fuzzy
@@ -7238,7 +7743,8 @@
 #: ../raster/r.resamp.bspline/main.c:107
 #, fuzzy
-msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr "Spline-Interpolations-Schrittweite in Ost-West-Richtung."
 #: ../raster/r.resamp.bspline/main.c:108 ../raster/r.resamp.bspline/main.c:116
@@ -7294,7 +7800,9 @@
 #: ../raster/r.resamp.bspline/main.c:115
 #, fuzzy
-msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
+msgid ""
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr "Spline-Interpolations-Schrittweite in Nord-Süd-Richtung"
 #: ../raster/r.resamp.bspline/main.c:119 ../vector/v.surf.bspline/main.c:153
@@ -7322,13 +7830,18 @@
 msgstr "Behalte NULL-Werte in Ausgabekarte."
 #: ../raster/r.resamp.bspline/main.c:144 ../vector/v.surf.bspline/main.c:101
-msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
-msgstr "Finde die beste Tykhonov Regularisierung mittels der \"leave-one-out\" Kreuzvalidierung."
+msgid ""
+"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
+"cross validation method"
+msgstr ""
+"Finde die beste Tykhonov Regularisierung mittels der \"leave-one-out\" "
+"Kreuzvalidierung."
 #: ../raster/r.resamp.bspline/main.c:151
 #, fuzzy
 msgid "Maximum memory to be used (in MB)"
-msgstr "Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
+msgstr ""
+"Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
 #: ../raster/r.resamp.bspline/main.c:186
 #, fuzzy
@@ -7417,7 +7930,9 @@
 #: ../raster/r.resamp.bspline/main.c:719
 #, fuzzy
 msgid "No data within this subregion. Consider increasing the spline step."
-msgstr "Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu ändern."
+msgstr ""
+"Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu "
+"ändern."
 #: ../raster/r.resamp.bspline/main.c:735 ../vector/v.surf.bspline/main.c:883
 msgid "Writing output..."
@@ -7425,7 +7940,9 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:160
 #, fuzzy, c-format
-msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
+msgid ""
+"%d are too many cells, recommended are < 100 cells. The cross validation "
+"would take too much time."
 msgstr "%d sind zu viele Punkte. Die Kreuzvalidierung würde zu lange dauern."
 #: ../raster/r.resamp.bspline/crosscorr.c:169
@@ -7442,8 +7959,11 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:194
 #: ../vector/v.surf.bspline/crosscorr.c:151
 #, c-format
-msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
-msgstr "Zu viele Splines (%d x %d). Erwägen Sie die Splineschrittweite (\"sie=\" \"sin=\") zu ändern."
+msgid ""
+"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgstr ""
+"Zu viele Splines (%d x %d). Erwägen Sie die Splineschrittweite (\"sie=\" "
+"\"sin=\") zu ändern."
 #: ../raster/r.resamp.bspline/crosscorr.c:212
 #, fuzzy, c-format
@@ -7463,14 +7983,20 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:314
 #: ../vector/v.surf.bspline/crosscorr.c:313
-msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
-msgstr "Eine unterschiedliche Anzahl von Splines und lambda_i-Werten wurde für die Kreuzvalidierung angegeben."
+msgid ""
+"Different number of splines and lambda_i values have been taken for the "
+"cross correlation"
+msgstr ""
+"Eine unterschiedliche Anzahl von Splines und lambda_i-Werten wurde für die "
+"Kreuzvalidierung angegeben."
 #: ../raster/r.resamp.bspline/crosscorr.c:316
 #: ../vector/v.surf.bspline/crosscorr.c:315
 #, c-format
-msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
-msgstr "Der Minimalwert für den Test (rms=%lf) wurde erreicht mit: lambda_i = %.3f"
+msgid ""
+"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgstr ""
+"Der Minimalwert für den Test (rms=%lf) wurde erreicht mit: lambda_i = %.3f"
 #: ../raster/r.resamp.bspline/crosscorr.c:324
 msgid "Results into a table:"
@@ -7519,7 +8045,9 @@
 #: ../raster/r.lake/main.c:180
 #, fuzzy
 msgid "Either this parameter or a coordinates pair have to be specified"
-msgstr "Eine Karte mit Startpunkten und Koordinaten können nicht gleichzeitig verwendet werden."
+msgstr ""
+"Eine Karte mit Startpunkten und Koordinaten können nicht gleichzeitig "
+"verwendet werden."
 #: ../raster/r.lake/main.c:186
 msgid "Use negative depth values for lake raster map"
@@ -7527,15 +8055,20 @@
 #: ../raster/r.lake/main.c:191
 msgid "Overwrite seed map with result (lake) map"
-msgstr "Überschreibe die Karte mit Startpunkten mit der resultierenden Seekarte."
+msgstr ""
+"Überschreibe die Karte mit Startpunkten mit der resultierenden Seekarte."
 #: ../raster/r.lake/main.c:197
 msgid "Both seed map and coordinates cannot be specified"
+msgstr ""
 #: ../raster/r.lake/main.c:200
 msgid "Seed map or seed coordinates must be set!"
-msgstr "Entweder eine Karte mit Startpunkten oder Startkoordinaten müssen angegeben werden."
+msgstr ""
+"Entweder eine Karte mit Startpunkten oder Startkoordinaten müssen angegeben "
+"werden."
 # Einige Daten können u.U. verloren sein.er/r.lake/main.c:212
 #: ../raster/r.lake/main.c:203
@@ -7544,11 +8077,15 @@
 #: ../raster/r.lake/main.c:206
 msgid "Both lake and overwrite cannot be specified"
-msgstr "Die Einstellungen 'lake' und 'overwrite' können nicht zugleich verwendet werden."
+msgstr ""
+"Die Einstellungen 'lake' und 'overwrite' können nicht zugleich verwendet "
+"werden."
 #: ../raster/r.lake/main.c:209
 msgid "Output lake map or overwrite flag must be set!"
-msgstr "Entweder eine Ausgabe-Seekarte oder das Überschreiben-'flag' muss angegeben werden."
+msgstr ""
+"Entweder eine Ausgabe-Seekarte oder das Überschreiben-'flag' muss angegeben "
+"werden."
 #: ../raster/r.lake/main.c:236
 msgid "Seed point outside the current region"
@@ -7559,8 +8096,13 @@
 msgstr "G_malloc: Kein Speicher mehr da."
 #: ../raster/r.lake/main.c:272
-msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
-msgstr "Der angegebene Wasserstand am Startpunkt befindet sich unter der Erdoberfläche. Erhöhen Sie den Wasserstand oder verschieben Sie den Startpunkt."
+msgid ""
+"Given water level at seed point is below earth surface. Increase water level "
+"or move seed point."
+msgstr ""
+"Der angegebene Wasserstand am Startpunkt befindet sich unter der "
+"Erdoberfläche. Erhöhen Sie den Wasserstand oder verschieben Sie den "
+"Startpunkt."
 #: ../raster/r.lake/main.c:351
 #, c-format
@@ -7579,7 +8121,9 @@
 #: ../raster/r.lake/main.c:354
 msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr "Das Volumen ist nur korrekt, wenn die Seetiefe (Terrain-Rasterkarte) in Metern angegeben wurde."
+msgstr ""
+"Das Volumen ist nur korrekt, wenn die Seetiefe (Terrain-Rasterkarte) in "
+"Metern angegeben wurde."
 #: ../raster/r.quantile/main.c:63
 msgid "Computing histogram"
@@ -7619,7 +8163,8 @@
 #: ../raster/r.quantile/main.c:285
 msgid "Generate recode rules based on quantile-defined intervals."
-msgstr "Erzeuge Rekodierungs-Regeln auf Grundlage quantildefinierter Intervalle."
+msgstr ""
+"Erzeuge Rekodierungs-Regeln auf Grundlage quantildefinierter Intervalle."
 #: ../raster/r.quantile/main.c:313
 #, fuzzy
@@ -7739,7 +8284,9 @@
 #: ../raster/r.stats.quantile/main.c:469
 #, fuzzy, c-format
 msgid "Number of quantiles (%d) does not match number of output maps (%d)"
-msgstr "Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der Spalten (%d) in der Eingabe überein."
+msgstr ""
+"Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der "
+"Spalten (%d) in der Eingabe überein."
 #: ../raster/r.stats.quantile/main.c:486
 #, fuzzy, c-format
@@ -7853,12 +8400,22 @@
 msgstr "Kann den fp Bereich für die Rasterkarte <%s> nicht lesen."
 #: ../raster/r.le/r.le.patch/main.c:50
-msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
-msgstr "Berechnet Attribute, Patch-Größe, Kerngebiets-Größe, Form, Fraktale Dimension und Umfang für ein Satz von Patches in einer Landschaft."
+msgid ""
+"Calculates attribute, patch size, core (interior) size, shape, fractal "
+"dimension, and perimeter measures for sets of patches in a landscape."
+msgstr ""
+"Berechnet Attribute, Patch-Größe, Kerngebiets-Größe, Form, Fraktale "
+"Dimension und Umfang für ein Satz von Patches in einer Landschaft."
 #: ../raster/r.le/r.le.trace/main.c:57
-msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
-msgstr "Zeigt die Grenzen aller r.le-Patches und wie die Grenze verfolgt wird. Zeigt außerdem die Attribute, Größe, Umfang und Form Indices jedes Patches und speichert die Daten in eine Ausgabedatei."
+msgid ""
+"Displays the boundary of each r.le patch and shows how the boundary is "
+"traced, displays the attribute, size, perimeter and shape indices for each "
+"patch and saves the data in an output file."
+msgstr ""
+"Zeigt die Grenzen aller r.le-Patches und wie die Grenze verfolgt wird. Zeigt "
+"außerdem die Attribute, Größe, Umfang und Form Indices jedes Patches und "
+"speichert die Daten in eine Ausgabedatei."
 #: ../raster/r.le/r.le.trace/user_input.c:35
 msgid "Include sampling area boundary as perimeter"
@@ -7879,8 +8436,12 @@
 msgstr "Name der Ausgabedatei zum Speichern des Reports."
 #: ../raster/r.le/r.le.setup/main.c:59
-msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
-msgstr "Interaktives Werkzeug zur Erzeugung eine Stichproben- und Analyse-Rahmens, der von den anderen r.le-Progammen verwendet wird. "
+msgid ""
+"Interactive tool used to setup the sampling and analysis framework that will "
+"be used by the other r.le programs."
+msgstr ""
+"Interaktives Werkzeug zur Erzeugung eine Stichproben- und Analyse-Rahmens, "
+"der von den anderen r.le-Progammen verwendet wird. "
 #: ../raster/r.le/r.le.setup/main.c:63
 msgid "Raster map to use to setup sampling"
@@ -7895,8 +8456,12 @@
 msgstr "Kann Vektor nicht lesen."
 #: ../raster/r.le/r.le.pixel/main.c:47
-msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
-msgstr "Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, Nebeneinanderstellung und Kanten"
+msgid ""
+"Contains a set of measures for attributes, diversity, texture, "
+"juxtaposition, and edge."
+msgstr ""
+"Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, "
+"Nebeneinanderstellung und Kanten"
 #: ../raster/r.distance/report.c:43
 msgid "Processing..."
@@ -7941,23 +8506,45 @@
 #: ../raster/r.out.gdal/export_band.c:160
 #, c-format
-msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-msgstr "Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %d wurde verwendet um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie können NoData-Wert mit dem Parameter %s bestimmen."
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %d will "
+"be used to represent no-data values in the input map. You can specify a "
+"nodata value with the %s option."
+msgstr ""
+"Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert "
+"%d wurde verwendet um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie "
+"können NoData-Wert mit dem Parameter %s bestimmen."
 #: ../raster/r.out.gdal/export_band.c:165
 #, fuzzy, c-format
-msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %g will "
+msgstr ""
+"Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert "
+"%d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie "
+"können Nodata-Wert mit dem Parameter %s bestimmen."
 #: ../raster/r.out.gdal/export_band.c:175
 #, c-format
-msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
-msgstr "Der Standard-NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu Datenverlust führen. Bitte geben Sie einen eignen NoData-Wert mit dem Parameter %s an."
+msgid ""
+"The default nodata value is present in rasterband <%s> and would lead to "
+"data loss. Please specify a custom nodata value with the %s parameter."
+msgstr ""
+"Der Standard-NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu "
+"Datenverlust führen. Bitte geben Sie einen eignen NoData-Wert mit dem "
+"Parameter %s an."
 #: ../raster/r.out.gdal/export_band.c:182
 #, c-format
-msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
-msgstr "Der gewählte NoData-Wert %g ist im Rasterkanal <%s> vorhanden und würde zu Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem Parameter %s an."
+msgid ""
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
+msgstr ""
+"Der gewählte NoData-Wert %g ist im Rasterkanal <%s> vorhanden und würde zu "
+"Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem "
+"Parameter %s an."
 #: ../raster/r.out.gdal/export_band.c:226
 msgid "Unable to get raster band"
@@ -8077,7 +8664,9 @@
 #: ../raster/r.out.gdal/main.c:164
 #, fuzzy
 msgid "Raster data format to write (case sensitive, see also -l flag)"
-msgstr "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung beachten, siehe auch den Schalter -l)."
+msgstr ""
+"GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung "
+"beachten, siehe auch den Schalter -l)."
 #: ../raster/r.out.gdal/main.c:185
 #, fuzzy
@@ -8097,8 +8686,12 @@
 msgstr "Metadaten Schlüsselwort(e) und Wert(e), die eingefügt werden sollen."
 #: ../raster/r.out.gdal/main.c:207
-msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
-msgstr "Im Format  \"META-TAG=WERT\". Trennen Sie mehrere Einträge durch Kommas. Wird nicht von allen Treibern unterstützt."
+msgid ""
+"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
+"Not supported by all output format drivers."
+msgstr ""
+"Im Format  \"META-TAG=WERT\". Trennen Sie mehrere Einträge durch Kommas. "
+"Wird nicht von allen Treibern unterstützt."
 #: ../raster/r.out.gdal/main.c:217
 msgid "Assign a specified nodata value to output bands"
@@ -8121,8 +8714,12 @@
 #: ../raster/r.out.gdal/main.c:271
 #, c-format
-msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
-msgstr "Der Treiber <%s> unterstützt direktes Schreiben nicht. Verwende den MEM-Treiber für einen Zwischendatensatz."
+msgid ""
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
+msgstr ""
+"Der Treiber <%s> unterstützt direktes Schreiben nicht. Verwende den MEM-"
+"Treiber für einen Zwischendatensatz."
 #: ../raster/r.out.gdal/main.c:276
 msgid "Unable to get in-memory raster driver"
@@ -8145,22 +8742,36 @@
 #: ../raster/r.out.gdal/main.c:427
 msgid "Raster export would result in complete data loss, aborting."
-msgstr "Rasterexport würde kompletten Datenverlust bedeuten, breche die Aktion ab."
+msgstr ""
+"Rasterexport würde kompletten Datenverlust bedeuten, breche die Aktion ab."
 #: ../raster/r.out.gdal/main.c:438
 #, c-format
-msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
-msgstr "Präzisionsverlust: Rasterkarte <%s> vom Typ %s soll als %s exportiert werden. Dies kann verhindert werden mit %s."
+msgid ""
+"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
+"avoided by using %s."
+msgstr ""
+"Präzisionsverlust: Rasterkarte <%s> vom Typ %s soll als %s exportiert "
+"werden. Dies kann verhindert werden mit %s."
 #: ../raster/r.out.gdal/main.c:449
 #, c-format
-msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr "Präzisionsverlust: Der Wertebereich von <%s> kann nicht korrekt erhalten werden mit dem GDAL Datentyp Float32. Dies kann verhindert werden durch Export nach Int32 oder Float64."
+msgid ""
+"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
+"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgstr ""
+"Präzisionsverlust: Der Wertebereich von <%s> kann nicht korrekt erhalten "
+"werden mit dem GDAL Datentyp Float32. Dies kann verhindert werden durch "
+"Export nach Int32 oder Float64."
 #: ../raster/r.out.gdal/main.c:457
 #, c-format
-msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
-msgstr "Präzisionsverlust: Float32 kann die Präzision der DCELL Rasterkarte <%s> nicht erhalten. Dies kann verhindert werden mit Float64."
+msgid ""
+"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
+"This can be avoided by using Float64"
+msgstr ""
+"Präzisionsverlust: Float32 kann die Präzision der DCELL Rasterkarte <%s> "
+"nicht erhalten. Dies kann verhindert werden mit Float64."
 #: ../raster/r.out.gdal/main.c:466 ../raster/r.out.gdal/main.c:509
 msgid "Forcing raster export."
@@ -8229,7 +8840,10 @@
 #: ../raster/r.out.gdal/main.c:752 ../raster/r.out.gdal/main.c:765
 #: ../raster/r.out.gdal/main.c:780
 #, c-format
-msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
+msgid ""
+"Mismatch between metadata nodata value and actual nodata value in exported "
+"raster: specified nodata value %g gets converted to %d by selected GDAL "
+"datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:728 ../raster/r.out.gdal/main.c:755
@@ -8245,8 +8859,14 @@
 #: ../raster/r.out.gdal/main.c:794
 #, c-format
-msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
-msgstr "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %g wird von dem gewählten GDAL-Datentyp nach %g konvertiert."
+msgid ""
+"raster: specified nodata value %g gets converted to %g by selected GDAL "
+"datatype."
+msgstr ""
+"NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten "
+"Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %g wird von "
+"dem gewählten GDAL-Datentyp nach %g konvertiert."
 #: ../raster/r.out.gdal/main.c:797
 #, c-format
@@ -8389,8 +9009,12 @@
 msgstr "Vektor"
 #: ../raster/r.random/main.c:56
-msgid "Creates a raster map layer and vector point map containing randomly located points."
-msgstr "Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete Punkte enthalten."
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
+msgstr ""
+"Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete "
+"Punkte enthalten."
 #: ../raster/r.random/main.c:60 ../raster/r.out.bin/main.c:290
 #: ../imagery/i.zc/main.c:65
@@ -8465,7 +9089,9 @@
 msgstr "ES sind keine gültigen Locations in der aktuellen Region."
 #: ../raster/r.series.interp/main.c:68
-msgid "Interpolate raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
+msgid ""
+"Interpolate raster maps located (temporal or spatial) in between input "
+"raster maps at specific sampling positions."
 msgstr ""
 #: ../raster/r.series.interp/main.c:78
@@ -8474,7 +9100,9 @@
 msgstr "Kann die Projektionsinformation der Eingabekarte nicht ermitteln."
 #: ../raster/r.series.interp/main.c:83
-msgid "Input file with an input raster map name and data point position per line, field separator between name and sample point is |"
+msgid ""
+"Input file with an input raster map name and data point position per line, "
+"field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:95
@@ -8483,7 +9111,9 @@
 msgstr "Selektiere Feature..."
 #: ../raster/r.series.interp/main.c:99
-msgid "Input infile with an output raster map name and sample point position per line, field separator between name and sample point is |"
+msgid ""
+"Input infile with an output raster map name and sample point position per "
+"line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:109
@@ -8553,7 +9183,8 @@
 #: ../raster/r.series.interp/main.c:240
 #, fuzzy, c-format
 msgid "The number of %s maps and %s point positions must be equal"
-msgstr "Die Anzahl der Eingabe-Karten ist nicht gleich der Anzahl der Höhen-Karten."
+msgstr ""
+"Die Anzahl der Eingabe-Karten ist nicht gleich der Anzahl der Höhen-Karten."
 #: ../raster/r.series.interp/main.c:269
 #, c-format
@@ -8562,7 +9193,9 @@
 #: ../raster/r.series.interp/main.c:289
 #, c-format
-msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
+msgid ""
+"map <%s> at position %g was not interpolated. Check the interpolation "
+"interval."
 msgstr ""
 #: ../raster/r.series.interp/main.c:309
@@ -8581,34 +9214,55 @@
 #: ../raster/r.spread/main.c:109
 #, fuzzy
-msgid "Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
-msgstr "Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung und der Ursprung."
+msgid ""
+"Generates a raster map of the cumulative time of spread, given raster maps "
+"containing the rates of spread (ROS), the ROS directions and the spread "
+"origins. It optionally produces raster maps to contain backlink UTM "
+"coordinates for tracing spread paths. Usable for fire spread simulations."
+msgstr ""
+"Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und "
+"erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als "
+"Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung "
+"und der Ursprung."
 #: ../raster/r.spread/main.c:123
 #, fuzzy
 msgid "Raster map containing maximal ROS (cm/min)"
-msgstr "Name der Rasterkarte mit der Grund-Ausbreitungsgeschwindigkeit [cm/min]."
+msgstr ""
+"Name der Rasterkarte mit der Grund-Ausbreitungsgeschwindigkeit [cm/min]."
 #: ../raster/r.spread/main.c:125
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum ROS values (cm/minute)."
+msgid ""
+"Name of an existing raster map layer in the user's current mapset search "
+"path containing the maximum ROS values (cm/minute)."
 msgstr ""
 #: ../raster/r.spread/main.c:135
 #, fuzzy
 msgid "Raster map containing directions of maximal ROS (degree)"
-msgstr "Name der Rasterkarte mit den Richtungen der Maximalen Ausbreitungsgeschwindigkeit [Grad]."
+msgstr ""
+"Name der Rasterkarte mit den Richtungen der Maximalen "
+"Ausbreitungsgeschwindigkeit [Grad]."
 #: ../raster/r.spread/main.c:137
-msgid "Name of an existing raster map layer in the user's current mapset search path containing directions of the maximum ROSes, clockwise from north (degree)."
+msgid ""
+"path containing directions of the maximum ROSes, clockwise from north "
+"(degree)."
 msgstr ""
 #: ../raster/r.spread/main.c:148
 #, fuzzy
 msgid "Raster map containing base ROS (cm/min)"
+msgstr ""
 #: ../raster/r.spread/main.c:150
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the ROS values in the directions perpendicular to maximum ROSes' (cm/minute). These ROSes are also the ones without the effect of directional factors."
+msgid ""
+"path containing the ROS values in the directions perpendicular to maximum "
+"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
+"directional factors."
 msgstr ""
 #: ../raster/r.spread/main.c:162
@@ -8617,44 +9271,68 @@
 msgstr "Name der Rasterkarte mit Startpunkten."
 #: ../raster/r.spread/main.c:164
-msgid "Name of an existing raster map layer in the user's current mapset search path containing starting locations of the spread phenomenon. Any positive integers in this map are recognized as starting sources (seeds)."
+msgid ""
+"path containing starting locations of the spread phenomenon. Any positive "
+"integers in this map are recognized as starting sources (seeds)."
 msgstr ""
 #: ../raster/r.spread/main.c:175
 #, fuzzy
 msgid "Raster map containing maximal spotting distance (m, required with -s)"
-msgstr "Name der Rasterkarte mit den maximalen Entdeckungsentfernungen [m] (gefordert von dem Schalter -s)."
+msgstr ""
+"Name der Rasterkarte mit den maximalen Entdeckungsentfernungen [m] "
+"(gefordert von dem Schalter -s)."
 #: ../raster/r.spread/main.c:177
-msgid "Name of an existing raster map layer in the user's current mapset search path containing the maximum potential spotting distances (meters)."
+msgid ""
+"path containing the maximum potential spotting distances (meters)."
 msgstr ""
 #: ../raster/r.spread/main.c:187
 #, fuzzy
 msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
-msgstr "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/min] (gefordert von dem Schalter -s)."
+msgstr ""
+"Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/"
+"min] (gefordert von dem Schalter -s)."
 #: ../raster/r.spread/main.c:199
 #, fuzzy
-msgid "Raster map containing fine fuel moisture of the cell receiving a spotting firebrand (%, required with -s)"
-msgstr "Name der Rasterkarte,mit den genauen Brennmaterialfeuchtigkeiten einer Zelle, die von einem Brand erreicht wird [%] (gefordert von dem Schalter -s)."
+msgid ""
+"Raster map containing fine fuel moisture of the cell receiving a spotting "
+"firebrand (%, required with -s)"
+msgstr ""
+"Name der Rasterkarte,mit den genauen Brennmaterialfeuchtigkeiten einer "
+"Zelle, die von einem Brand erreicht wird [%] (gefordert von dem Schalter -s)."
 #: ../raster/r.spread/main.c:211
 #, fuzzy
 msgid "Basic sampling window size needed to meet certain accuracy (3)"
-msgstr "Stichprobenrahmengröße, die für eine bestimmte Genauigkeit benötigt wird (3)."
+msgstr ""
+"Stichprobenrahmengröße, die für eine bestimmte Genauigkeit benötigt wird (3)."
 #: ../raster/r.spread/main.c:213
-msgid "An odd integer ranging 3 - 15 indicating the basic sampling window size within which all cells will be considered to see whether they will be reached by the current spread cell. The default number is 3 which means a 3x3 window."
+msgid ""
+"An odd integer ranging 3 - 15 indicating the basic sampling window size "
+"within which all cells will be considered to see whether they will be "
+"reached by the current spread cell. The default number is 3 which means a "
+"3x3 window."
 msgstr ""
 #: ../raster/r.spread/main.c:223
 #, fuzzy
 msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
-msgstr "Stichprobendichte für zusätzliche Berechnungen (Spanne: 0.0 - 1.0 (0.5))."
+msgstr ""
+"Stichprobendichte für zusätzliche Berechnungen (Spanne: 0.0 - 1.0 (0.5))."
 #: ../raster/r.spread/main.c:225
-msgid "A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will be considered to see whether they will be reached by the current spread cell. The closer to 1.0 the decimal number is, the longer the program will run and the higher the simulation accuracy will be. The default number is 0.5."
+msgid ""
+"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will "
+"be considered to see whether they will be reached by the current spread "
+"cell. The closer to 1.0 the decimal number is, the longer the program will "
+"run and the higher the simulation accuracy will be. The default number is "
+"0.5."
 msgstr ""
 #: ../raster/r.spread/main.c:236
@@ -8663,7 +9341,10 @@
 msgstr "Anfangszeit für die aktuelle Simulation (0) [min]."
 #: ../raster/r.spread/main.c:238
-msgid "A non-negative number specifying the initial time for the current spread simulation (minutes). This is useful when multiple phase simulation is conducted. The default time is 0."
+msgid ""
+"A non-negative number specifying the initial time for the current spread "
+"simulation (minutes). This is useful when multiple phase simulation is "
+"conducted. The default time is 0."
 msgstr ""
 #: ../raster/r.spread/main.c:247
@@ -8671,15 +9352,25 @@
 msgstr "Simulationszeitverzögerung (fülle die Region) [min]."
 #: ../raster/r.spread/main.c:249
-msgid "A non-negative integer specifying the simulating duration time lag (minutes). The default is infinite, but the program will terminate when the current geographic region/mask has been filled. It also controls the computational time, the shorter the time lag, the faster the program will run."
+msgid ""
+"A non-negative integer specifying the simulating duration time lag "
+"(minutes). The default is infinite, but the program will terminate when the "
+"current geographic region/mask has been filled. It also controls the "
+"computational time, the shorter the time lag, the faster the program will "
+"run."
 msgstr ""
 #: ../raster/r.spread/main.c:261
 msgid "Name of raster map as a display backdrop"
-msgstr "Name der Rasterkarte, die als Hintergrundkarte im Grafikfenster benutzt werden soll."
+msgstr ""
+"Name der Rasterkarte, die als Hintergrundkarte im Grafikfenster benutzt "
+"werden soll."
 #: ../raster/r.spread/main.c:263
-msgid "Name of an existing raster map layer in the user's current mapset search path to be used as the background on which the \"live\" movement will be shown."
+msgid ""
+"path to be used as the background on which the \"live\" movement will be "
+"shown."
 msgstr ""
 #: ../raster/r.spread/main.c:272 ../raster/r.spread/main.c:284
@@ -8702,7 +9393,10 @@
 msgstr "Name der Rasterkarte mit den Ausbreitungszeiten [min]."
 #: ../raster/r.spread/main.c:276
-msgid "Name of the new raster map layer to contain the results of the cumulative spread time needed for a phenomenon to reach each cell from the starting sources (minutes)."
+msgid ""
+"Name of the new raster map layer to contain the results of the cumulative "
+"spread time needed for a phenomenon to reach each cell from the starting "
+"sources (minutes)."
 msgstr ""
 #: ../raster/r.spread/main.c:286
@@ -8711,7 +9405,9 @@
 msgstr "Name der Rasterkarte mit den X_BACK Koordinaten."
 #: ../raster/r.spread/main.c:288
-msgid "Name of the new raster map layer to contain the results of backlink information in UTM easting coordinates for each cell."
+msgid ""
+"Name of the new raster map layer to contain the results of backlink "
+"information in UTM easting coordinates for each cell."
 msgstr ""
 #: ../raster/r.spread/main.c:298
@@ -8720,7 +9416,9 @@
 msgstr "Name der Rasterkarte mit den Y_BACK Koordinaten."
 #: ../raster/r.spread/main.c:300
-msgid "Name of the new raster map layer to contain the results of backlink information in UTM northing coordinates for each cell."
+msgid ""
+"information in UTM northing coordinates for each cell."
 msgstr ""
 #: ../raster/r.spread/main.c:307
@@ -8763,8 +9461,12 @@
 #: ../raster/r.series.accumulate/main.c:84
 #, fuzzy
-msgid "Makes each output cell value a accumulationfunction of the values assigned to the corresponding cells in the input raster map layers."
-msgstr "Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
+msgid ""
+"Makes each output cell value a accumulationfunction of the values assigned "
+"to the corresponding cells in the input raster map layers."
+msgstr ""
+"Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer "
+"korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
 #: ../raster/r.series.accumulate/main.c:90
 msgid "Existing map to be added to output"
@@ -8786,11 +9488,14 @@
 msgstr "Skalierungsfaktor für X-Koordinaten"
 #: ../raster/r.series.accumulate/main.c:121
-msgid "The raster map specifying the lower accumulation limit, also called baseline"
+msgid ""
+"The raster map specifying the lower accumulation limit, also called baseline"
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:126
-msgid "The raster map specifying the upper accumulation limit, also called cutoff. Only applied to BEDD computation."
+msgid ""
+"The raster map specifying the upper accumulation limit, also called cutoff. "
+"Only applied to BEDD computation."
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:139
@@ -8798,11 +9503,15 @@
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:151
-msgid "Growing Degree Days or Winkler indices: depending on the chosen average computation set with -a flag"
+msgid ""
+"Growing Degree Days or Winkler indices: depending on the chosen average "
+"computation set with -a flag"
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:152
-msgid "Mean: either (min + max) / 2 or sum(input maps)/(number of input maps) set with -a flag"
+msgid ""
+"Mean: either (min + max) / 2 or sum(input maps)/(number of input maps) set "
+"with -a flag"
 msgstr ""
 #: ../raster/r.series.accumulate/main.c:153
@@ -8838,7 +9547,9 @@
 #: ../raster/r.topidx/main.c:42
 msgid "Creates topographic index map from elevation raster map."
-msgstr "Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis eines digitalen Höhenmodells."
+msgstr ""
+"Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis eines "
+"digitalen Höhenmodells."
 #: ../raster/r.topidx/main.c:48
 #, fuzzy
@@ -8847,8 +9558,14 @@
 #: ../raster/r.topidx/file_io.c:35
 #, c-format
-msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
-msgstr "Die Auflösung der aktuellen Region [%s x %s] ist feiner als die Auflösung der Eingabekarte [%s x %s]. Die Auflösungen der aktuellen Region muss identisch oder gröber sein als die der Eingabekarte."
+msgid ""
+"The current region resolution [%s x %s] is finer than the input map's "
+"resolution [%s x %s]. The current region resolution must be identical to, or "
+"coarser than, the input map's resolution."
+msgstr ""
+"Die Auflösung der aktuellen Region [%s x %s] ist feiner als die Auflösung "
+"der Eingabekarte [%s x %s]. Die Auflösungen der aktuellen Region muss "
+"identisch oder gröber sein als die der Eingabekarte."
 #: ../raster/r.topidx/file_io.c:42
 msgid "Reading elevation map..."
@@ -8888,7 +9605,9 @@
 msgstr "Berechne Distanzen zu allen Objekten innerhalb des Schwellwertes."
 #: ../raster/r.stream.distance/main.c:51
-msgid "The module can work in stream mode where target are streams and outlets mode where targets are outlets."
+msgid ""
+"The module can work in stream mode where target are streams and outlets mode "
+"where targets are outlets."
 msgstr ""
 #: ../raster/r.stream.distance/main.c:56
@@ -8896,11 +9615,6 @@
 msgid "watercourse distance"
 msgstr "Fehler beim Analysieren der Distanz."
-#: ../raster/r.stream.distance/main.c:60
-#, fuzzy
-msgid "Name for input raster map with stream network"
-msgstr "Rasterkarte mit Informationen zu dem Fließgewässersystem."
 #: ../raster/r.stream.distance/main.c:72
 #, fuzzy
 msgid "Calculation method"
@@ -8917,7 +9631,8 @@
 msgstr "Name der Höhenkarte."
 #: ../raster/r.stream.distance/main.c:100
-msgid "Calculate parameters for outlets (outlet mode) instead of (default) streams"
+msgid ""
+"Calculate parameters for outlets (outlet mode) instead of (default) streams"
 msgstr ""
 #: ../raster/r.stream.distance/main.c:105
@@ -8937,7 +9652,9 @@
 msgstr "Es muss mindestens ein Werkzeug ausgewählt werden."
 #: ../raster/r.stream.distance/main.c:123
-msgid "Output elevation difference raster map requires input elevation raster map to be specified"
+msgid ""
+"Output elevation difference raster map requires input elevation raster map "
+"to be specified"
 msgstr ""
 #: ../raster/r.stream.distance/main.c:144
@@ -9022,8 +9739,11 @@
 #: ../raster/r.in.gdal/main.c:112
 #, fuzzy
-msgid "Name of location to create or to read projection from for GCPs transformation"
-msgstr "Name der Location, von der Projektionsinformationen für eine GCP-Transformation gelesen werden soll."
+msgid ""
+"Name of location to create or to read projection from for GCPs transformation"
+msgstr ""
+"Name der Location, von der Projektionsinformationen für eine GCP-"
+"Transformation gelesen werden soll."
 #: ../raster/r.in.gdal/main.c:121 ../raster/r.in.gdal/main.c:129
 #: ../raster/r.external/main.c:89 ../imagery/i.landsat.toar/main.c:99
@@ -9034,7 +9754,9 @@
 msgstr "Metadaten"
 #: ../raster/r.in.gdal/main.c:128
-msgid "The offset will be added to the band number while output raster map name creation"
+msgid ""
+"The offset will be added to the band number while output raster map name "
+"creation"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:135 ../vector/v.in.lidar/main.c:180
@@ -9068,12 +9790,16 @@
 msgstr "Verwende die Nummern der Kanäle anstatt der Farbbezeichnungen."
 #: ../raster/r.in.gdal/main.c:168
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the raster file."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:193
 msgid "You have to specify a target location different from output location"
-msgstr "Sie müssen eine Ziel-Location angeben, die verschieden ist von der Ausgabe-Location."
+msgstr ""
+"Sie müssen eine Ziel-Location angeben, die verschieden ist von der Ausgabe-"
+"Location."
 #: ../raster/r.in.gdal/main.c:197
 #, fuzzy
@@ -9101,21 +9827,38 @@
 #: ../raster/r.in.gdal/main.c:262
 #, c-format
-msgid "Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin plate spline transformation (%s or %s)."
+msgid ""
+"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
+"plate spline transformation (%s or %s)."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:283
-msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
-msgstr "Die Eingabe-Rasterkarte wurde rotiert und kann daher nicht eingelesen werden. Sie können 'gdalwarp' verwenden, um die Karte zu transformieren, so dass Norden oben ist."
+msgid ""
+"Input raster map is flipped or rotated - cannot import. You may use "
+"'gdalwarp' to transform the map to North-up."
+msgstr ""
+"Die Eingabe-Rasterkarte wurde rotiert und kann daher nicht eingelesen "
+"werden. Sie können 'gdalwarp' verwenden, um die Karte zu transformieren, so "
+"dass Norden oben ist."
 #: ../raster/r.in.gdal/main.c:324
-msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
-msgstr "Die Begrenzung ist an geographische Koordinaten gebunden. Eine Überprüfung der Begrenzung und Auflösung mit r.info und eine Anpassung mit r.region dieser Parameter ist für die weitere Berechnung empfehlenswert."
+msgid ""
+"Map bounds have been constrained to geographic coordinates. You will almost "
+"certainly want to check map bounds and resolution with r.info and reset them "
+"with r.region before going any further."
+msgstr ""
+"Die Begrenzung ist an geographische Koordinaten gebunden. Eine Überprüfung "
+"der Begrenzung und Auflösung mit r.info und eine Anpassung mit r.region "
+"dieser Parameter ist für die weitere Berechnung empfehlenswert."
 #: ../raster/r.in.gdal/main.c:344 ../raster/r.in.gdal/main.c:668
 #: ../vector/v.in.lidar/main.c:343 ../vector/v.in.ogr/main.c:618
-msgid "Unable to convert input map projection to GRASS format; cannot create new location."
-msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; erstelle daher keine neue Location."
+msgid ""
+"Unable to convert input map projection to GRASS format; cannot create new "
+"location."
+msgstr ""
+"Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; "
+"erstelle daher keine neue Location."
 #: ../raster/r.in.gdal/main.c:350 ../raster/r.in.gdal/main.c:692
 #: ../vector/v.in.lidar/main.c:349 ../vector/v.in.ogr/main.c:624
@@ -9131,8 +9874,12 @@
 msgstr "Location <%s> erstellt."
 #: ../raster/r.in.gdal/main.c:365 ../raster/r.external/proj.c:18
-msgid "Unable to convert input raster map projection information to GRASS format for checking"
-msgstr "Kann die Projektion der Eingabe-Rasterkarte nicht ins GRASS-Format konvertieren, zwecks Überprüfung."
+msgid ""
+"Unable to convert input raster map projection information to GRASS format "
+"for checking"
+msgstr ""
+"Kann die Projektion der Eingabe-Rasterkarte nicht ins GRASS-Format "
+"konvertieren, zwecks Überprüfung."
 #: ../raster/r.in.gdal/main.c:381 ../raster/r.in.lidar/main.c:334
 #: ../raster/r.external/proj.c:34 ../vector/v.in.lidar/main.c:386
@@ -9147,7 +9894,8 @@
 "Projection of dataset does not appear to match current location.\n"
 "\n"
 msgstr ""
-"Die Projektion des Datensatzes scheint nicht mit der aktuellen Location übereinzustimmen.\n"
+"Die Projektion des Datensatzes scheint nicht mit der aktuellen Location "
+"übereinzustimmen.\n"
 "\n"
 #: ../raster/r.in.gdal/main.c:396 ../raster/r.external/proj.c:47
@@ -9168,20 +9916,30 @@
 #: ../raster/r.in.gdal/main.c:465
 msgid ""
 "\n"
-"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the "
+"location definition for the dataset.\n"
 msgstr ""
 "\n"
-"Sie können den Schalter '-o' von r.in.gdal verwenden, um die Prüfung der Projektion zu übersteuern und die Projektionsinformation der Location für diesen Datensatz zu verwenden.\n"
+"Sie können den Schalter '-o' von r.in.gdal verwenden, um die Prüfung der "
+"Projektion zu übersteuern und die Projektionsinformation der Location für "
+"diesen Datensatz zu verwenden.\n"
 #: ../raster/r.in.gdal/main.c:468 ../raster/r.external/proj.c:110
-msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
-msgstr "Bedenken Sie, dass es besser sein könnte eine neue Location mit den Werten des zu importierenden Datensatzes mit Hilfe des 'location'-Parameters zu erzeugen.\n"
+msgid ""
+"Consider generating a new location from the input dataset using the "
+"'location' parameter.\n"
+msgstr ""
+"Bedenken Sie, dass es besser sein könnte eine neue Location mit den Werten "
+"des zu importierenden Datensatzes mit Hilfe des 'location'-Parameters zu "
+"erzeugen.\n"
 #: ../raster/r.in.gdal/main.c:473 ../raster/r.in.lidar/main.c:417
 #: ../raster/r.external/proj.c:115 ../vector/v.in.lidar/main.c:469
 #: ../vector/v.in.ogr/main.c:741
 msgid "Projection of input dataset and current location appear to match"
-msgstr "Die Projektionsinformationen des Eingabedatensatzes und der aktuellen Location scheinen übereinzustimmen."
+msgstr ""
+"Die Projektionsinformationen des Eingabedatensatzes und der aktuellen "
+"Location scheinen übereinzustimmen."
 #: ../raster/r.in.gdal/main.c:479 ../raster/r.external/main.c:176
 msgid "Proceeding with import..."
@@ -9227,7 +9985,9 @@
 #: ../raster/r.in.gdal/main.c:701
 #, c-format
-msgid "The target for the output group <%s> has been set to location <%s>, mapset <PERMANENT>."
+msgid ""
+"The target for the output group <%s> has been set to location <%s>, mapset "
+"<PERMANENT>."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:741 ../raster/r.external/window.c:93
@@ -9376,7 +10136,9 @@
 #: ../raster/r.to.vect/main.c:98
 msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr "Benutze Rasterzellenwerte als Kategoriewerte anstelle von eindeutigen Sequenzen (nur bei CELL-Karten)."
+msgstr ""
+"Benutze Rasterzellenwerte als Kategoriewerte anstelle von eindeutigen "
+"Sequenzen (nur bei CELL-Karten)."
 #: ../raster/r.to.vect/main.c:99 ../raster/r.to.vect/main.c:106
 #: ../vector/v.buffer/main.c:304 ../vector/v.in.lidar/main.c:198
@@ -9397,7 +10159,9 @@
 #: ../raster/r.to.vect/main.c:104
 #, fuzzy
 msgid "Table is not created. Currently supported only for points."
-msgstr "Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. Derzeit werden nur Punkte unterstützt."
+msgstr ""
+"Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. "
+"Derzeit werden nur Punkte unterstützt."
 #: ../raster/r.to.vect/main.c:110
 #, fuzzy
@@ -9407,25 +10171,36 @@
 #: ../raster/r.to.vect/main.c:111
 #, fuzzy
 msgid "Recommended for massive point conversion"
-msgstr "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von extrem großen Punktmengen)."
+msgstr ""
+"Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von "
+"extrem großen Punktmengen)."
 #: ../raster/r.to.vect/main.c:124
 msgid "z flag is supported only for points"
 msgstr "Der Schalter '-z' wird nur für Punkte unterstützt."
 #: ../raster/r.to.vect/main.c:135
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
-msgstr "Die Rasterkarte hat nicht den Typ integer (CELL) daher wird der Schalter '-v' ignoriert. Rasterwerte werden in die Tabelle geschrieben."
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
+"table."
+msgstr ""
+"Die Rasterkarte hat nicht den Typ integer (CELL) daher wird der Schalter '-"
+"v' ignoriert. Rasterwerte werden in die Tabelle geschrieben."
 #: ../raster/r.to.vect/main.c:137
 #, fuzzy
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+msgstr ""
 #: ../raster/r.to.vect/main.c:139
 #, fuzzy
 msgid "Raster is not CELL, '-v' flag ignored, raster values will be lost."
+msgstr ""
 #: ../raster/r.to.vect/main.c:144
 msgid "Categories will be unique sequence, raster values will be lost."
@@ -9476,7 +10251,8 @@
 #: ../raster/r.topmodel/main.c:51
 msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr "Modul zur TOPMODEL Simulation (physikalisch basiertes hydrologisches Modell)."
+msgstr ""
+"Modul zur TOPMODEL Simulation (physikalisch basiertes hydrologisches Modell)."
 #: ../raster/r.topmodel/main.c:56
 #, fuzzy
@@ -9524,7 +10300,9 @@
 msgstr "Name der Ausgabe-Expositions-Rasterkarte."
 #: ../raster/r.topmodel/main.c:90
-msgid "Must be clipped to the catchment boundary. Used for generating outtopidxstats."
+msgid ""
+"Must be clipped to the catchment boundary. Used for generating "
+"outtopidxstats."
 msgstr ""
 #: ../raster/r.topmodel/main.c:92 ../raster/r.topmodel/main.c:102
@@ -9570,7 +10348,9 @@
 #: ../raster/r.circle/main.c:54
 msgid "Creates a raster map containing concentric rings around a given point."
-msgstr "Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen Punkt ziehen."
+msgstr ""
+"Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen "
+"Punkt ziehen."
 #: ../raster/r.circle/main.c:64
 msgid "The coordinate of the center (east,north)"
@@ -9598,7 +10378,9 @@
 #: ../raster/r.circle/main.c:117
 msgid "Please specify min and/or max radius when using the binary flag"
-msgstr "Bitte geben Sie einen min und/oder max Radius an, wenn Sie den Binären Schalter verwenden."
+msgstr ""
+"Bitte geben Sie einen min und/oder max Radius an, wenn Sie den Binären "
+"Schalter verwenden."
 #: ../raster/r.rescale.eq/main.c:53 ../raster/r.rescale/main.c:49
 #, fuzzy
@@ -9606,8 +10388,11 @@
 msgstr "Neuskalieren"
 #: ../raster/r.rescale.eq/main.c:55
-msgid "Rescales histogram equalized the range of category values in a raster map layer."
-msgstr "Reskaliert mit Histogrammnormalisierung die Kategoriewerte einer Rasterkarte."
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+"Reskaliert mit Histogrammnormalisierung die Kategoriewerte einer Rasterkarte."
 #: ../raster/r.rescale.eq/main.c:65 ../raster/r.rescale/main.c:60
 msgid "The name of the raster map to be rescaled"
@@ -9615,7 +10400,9 @@
 #: ../raster/r.rescale.eq/main.c:73 ../raster/r.rescale/main.c:68
 msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr "Wertebereich der Eingangsdaten, der reskaliert werden soll (Standard: gesamter Wertebereich der Eingabekarte)"
+msgstr ""
+"Wertebereich der Eingangsdaten, der reskaliert werden soll (Standard: "
+"gesamter Wertebereich der Eingabekarte)"
 #: ../raster/r.rescale.eq/main.c:80 ../raster/r.rescale/main.c:75
 msgid "The resulting raster map name"
@@ -9796,12 +10583,17 @@
 #: ../raster/r.surf.gauss/main.c:42
 #, fuzzy
 msgid "Generates a raster map using gaussian random number generator."
-msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
+msgstr ""
+"Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
 #: ../raster/r.surf.gauss/main.c:44
 #, fuzzy
-msgid "Mean and standard deviation of gaussian deviates can be expressed by the user."
-msgstr "Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren Spanne vom Benutzer angegeben werden kann."
+msgid ""
+"Mean and standard deviation of gaussian deviates can be expressed by the "
+"user."
+msgstr ""
+"Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren "
+"Spanne vom Benutzer angegeben werden kann."
 #: ../raster/r.surf.gauss/main.c:51
 msgid "Distribution mean"
@@ -9864,8 +10656,12 @@
 msgstr "Einzugsgebiet Durchgang %d"
 #: ../raster/r.fill.dir/main.c:89
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
-msgstr "Filtert und generiert ein depressionsloses Höhenmodell und eine Fließrichtungskarte auf Basis eines gegebenen Höhenmodells."
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
+msgstr ""
+"Filtert und generiert ein depressionsloses Höhenmodell und eine "
+"Fließrichtungskarte auf Basis eines gegebenen Höhenmodells."
 #: ../raster/r.fill.dir/main.c:96
 #, fuzzy
@@ -9874,7 +10670,8 @@
 #: ../raster/r.fill.dir/main.c:100
 #, fuzzy
-msgid "Name for output flow direction map for depressionless elevation raster map"
+msgid ""
+"Name for output flow direction map for depressionless elevation raster map"
 msgstr "(o)   Richtungskarte für abflusslose Höhenkarte."
 #: ../raster/r.fill.dir/main.c:105
@@ -9941,8 +10738,16 @@
 #: ../raster/r.walk/main.c:185
 #, fuzzy
-msgid "Computes anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
-msgstr "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte mit Reibungs-Kosten kombiniert."
+msgid ""
+"Computes anisotropic cumulative cost of moving between different geographic "
+"locations on an input elevation raster map whose cell category values "
+"represent elevation combined with an input raster map layer whose cell "
+"values represent friction cost."
+msgstr ""
+"Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die "
+"beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. "
+"Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte "
+"mit Reibungs-Kosten kombiniert."
 #: ../raster/r.walk/main.c:196
 msgid "Name of input raster map containing friction costs"
@@ -9955,15 +10760,18 @@
 #: ../raster/r.walk/main.c:274
 msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr "Koeffizienten für die Formel zum Berechnen der Geh-Energie: a, b, c, d."
+msgstr ""
+"Koeffizienten für die Formel zum Berechnen der Geh-Energie: a, b, c, d."
 #: ../raster/r.walk/main.c:284
 msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr "Lambda Koeffizient zur Kombination der Geh-Energie und den Reibungskosten."
+msgstr ""
+"Lambda Koeffizient zur Kombination der Geh-Energie und den Reibungskosten."
 #: ../raster/r.walk/main.c:294
 msgid "Slope factor determines travel energy cost per height step"
-msgstr "Hangneigungsfaktor, der die Reiseenergiekosten pro Höhenstufe ermittelt."
+msgstr ""
+"Hangneigungsfaktor, der die Reiseenergiekosten pro Höhenstufe ermittelt."
 #: ../raster/r.walk/main.c:304
 msgid "Keep null values in output map"
@@ -10000,7 +10808,9 @@
 #: ../raster/r.walk/main.c:422
 msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr "Warnung: Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
+msgstr ""
+"Warnung: Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden "
+"ausgeschlossen."
 #: ../raster/r.walk/main.c:573
 #, fuzzy, c-format
@@ -10174,8 +10984,12 @@
 msgstr "Vektor, Transformation"
 #: ../raster/r.his/main.c:68
-msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
-msgstr "Erzeugt rot, grün und blaue Rasterkarten durch Kombination des Farbtons, der Intensität und Sättigung (HIS) aus Eingabe-Rasterkarten."
+msgid ""
+"Generates red, green and blue raster map layers combining hue, intensity and "
+"saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+"Erzeugt rot, grün und blaue Rasterkarten durch Kombination des Farbtons, der "
+"Intensität und Sättigung (HIS) aus Eingabe-Rasterkarten."
 #: ../raster/r.his/main.c:77 ../display/d.his/main.c:78
 msgid "Name of layer to be used for HUE"
@@ -10183,11 +10997,13 @@
 #: ../raster/r.his/main.c:84 ../display/d.his/main.c:85
 msgid "Name of layer to be used for INTENSITY"
-msgstr "Name der Karte, die für die Intensität (INTENSITY) verwendet werden soll."
+msgstr ""
+"Name der Karte, die für die Intensität (INTENSITY) verwendet werden soll."
 #: ../raster/r.his/main.c:91 ../display/d.his/main.c:92
 msgid "Name of layer to be used for SATURATION"
-msgstr "Name der Karte, die für die Sättigung (SATURATION) verwendet werden soll"
+msgstr ""
+"Name der Karte, die für die Sättigung (SATURATION) verwendet werden soll"
 #: ../raster/r.his/main.c:98
 msgid "Name of output layer to be used for RED"
@@ -10290,7 +11106,9 @@
 #: ../raster/r.thin/main.c:59
 msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr "Dünnt Zellen, die nicht null sind und linienhafte Strukturen in einer Rasterkarte abbilden."
+msgstr ""
+"Dünnt Zellen, die nicht null sind und linienhafte Strukturen in einer "
+"Rasterkarte abbilden."
 #: ../raster/r.thin/main.c:71
 msgid "Maximal number of iterations"
@@ -10324,7 +11142,9 @@
 #: ../raster/r.thin/thin_lines.c:175
 msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr "Ausdünnung nicht vollständig. Es könnte sinnvoll sein den Wert des Parameter 'iterations' zu erhöhen."
+msgstr ""
+"Ausdünnung nicht vollständig. Es könnte sinnvoll sein den Wert des Parameter "
+"'iterations' zu erhöhen."
 #: ../raster/r.to.rast3/main.c:59 ../raster/r.to.rast3elev/main.c:136
 msgid "Could not close the map"
@@ -10358,15 +11178,20 @@
 #: ../raster/r.to.rast3/main.c:201
 msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr "Konvertiert Schnitte von 2D Rasterkarten in eine 3D-Rastervolumenkarte."
+msgstr ""
+"Konvertiert Schnitte von 2D Rasterkarten in eine 3D-Rastervolumenkarte."
 #: ../raster/r.to.rast3/main.c:213
 msgid "No output map"
 msgstr "Keine Ausgabekarte angegeben."
 #: ../raster/r.to.rast3/main.c:230 ../raster/r.to.rast3elev/main.c:427
-msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
-msgstr "Die 2D- und 3D-Regionsparameter sind unterschiedlich. Werde die Parameter der 3D-Region verwenden, um die 2D-Region anzupassen."
+msgid ""
+"The 2D and 3D region settings are different. I will use the 3D region "
+"settings to adjust the 2D region."
+msgstr ""
+"Die 2D- und 3D-Regionsparameter sind unterschiedlich. Werde die Parameter "
+"der 3D-Region verwenden, um die 2D-Region anzupassen."
 #: ../raster/r.to.rast3/main.c:244 ../raster/r.stream.extract/dseg.c:51
 #: ../raster/r.stream.extract/cseg.c:51 ../raster/r.stream.extract/seg.c:55
@@ -10410,7 +11235,8 @@
 #: ../raster/r.to.rast3/main.c:275
 msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr "Eingabekarten müssen vom gleichen Datentyp sein. CELL FCELL oder DCELL!"
+msgstr ""
+"Eingabekarten müssen vom gleichen Datentyp sein. CELL FCELL oder DCELL!"
 #: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
 msgid "Creating 3D raster map"
@@ -10430,8 +11256,11 @@
 msgstr "Programm zur Erzeugung von Oberflächen."
 #: ../raster/r.surf.idw2/main.c:84
-msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr "Lat/Long-Datenbank wird nicht von r.surf.idw2 unterstützt. Verwenden Sie stattdessen r.surf.idw."
+msgid ""
+"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr ""
+"Lat/Long-Datenbank wird nicht von r.surf.idw2 unterstützt. Verwenden Sie "
+"stattdessen r.surf.idw."
 #: ../raster/r.surf.idw2/main.c:88
 #, c-format
@@ -10451,8 +11280,14 @@
 msgstr[1] "Interpoliere Rasterkarte <%s> ... %d Zeilenn... "
 #: ../raster/r.resamp.rst/main.c:151
-msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
-msgstr "Reinterpoliert und berechnet ggf. topographische Analysen basierend auf einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von regularized splines with tension and smoothing (RST)."
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+"Reinterpoliert und berechnet ggf. topographische Analysen basierend auf "
+"einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von "
+"regularized splines with tension and smoothing (RST)."
 #: ../raster/r.resamp.rst/main.c:162
 msgid "Desired east-west resolution"
@@ -10524,7 +11359,8 @@
 #: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:166
 msgid "Output partial derivatives instead of topographic parameters"
-msgstr "Gebe partielle Ableitungen an Stelle von topographischen Parametern aus."
+msgstr ""
+"Gebe partielle Ableitungen an Stelle von topographischen Parametern aus."
 #: ../raster/r.resamp.rst/main.c:313
 #, fuzzy
@@ -10571,7 +11407,9 @@
 #: ../raster/r.resamp.rst/main.c:389
 msgid "Input map resolution differs from current region resolution!"
-msgstr "Auflösung der Eingabekarte unterscheidet sich von der aktuellen Regionsauflösung!"
+msgstr ""
+"Auflösung der Eingabekarte unterscheidet sich von der aktuellen "
+"Regionsauflösung!"
 #: ../raster/r.resamp.rst/main.c:407
 msgid "Processing all selected output files will require"
@@ -10632,7 +11470,8 @@
 #: ../raster/r.resamp.rst/main.c:527
 #, fuzzy
 msgid "Unable to write raster maps -- try increasing cell size"
-msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
+msgstr ""
+"Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
 #: ../raster/r.resamp.rst/main.c:559 ../vector/v.surf.rst/main.c:826
 #, fuzzy, c-format
@@ -10644,8 +11483,12 @@
 msgstr "Erzeugt Flussbettlinien."
 #: ../raster/r.carve/main.c:77
-msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
-msgstr "Wandelt eine Vektorkarte mit Flüssen, transformiert sie in das Rasterformat und subtrahiert die Tiefe vom Ausgabe-DEM."
+msgid ""
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
+msgstr ""
+"Wandelt eine Vektorkarte mit Flüssen, transformiert sie in das Rasterformat "
+"und subtrahiert die Tiefe vom Ausgabe-DEM."
 #: ../raster/r.carve/main.c:82
 msgid "Name of input raster elevation map"
@@ -10695,12 +11538,16 @@
 msgstr "Verarbeite Zeilen... "
 #: ../raster/r.carve/enforce_ds.c:174
-msgid "Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr "Vect läuft aus der Region und kommt wieder hinein. Diese Situation ist leider noch nicht implementiert!"
+msgid ""
+"Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr ""
+"Vect läuft aus der Region und kommt wieder hinein. Diese Situation ist "
+"leider noch nicht implementiert!"
 #: ../raster/r.carve/lobf.c:74
 msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr "Versuche durch 0 zu teilen... Keine eindeutige Lösung...Übergehe das..."
+msgstr ""
+"Versuche durch 0 zu teilen... Keine eindeutige Lösung...Übergehe das..."
 #: ../raster/r.carve/raster.c:13 ../raster/r.texture/main.c:292
 #: ../imagery/i.zc/main.c:152
@@ -10729,8 +11576,11 @@
 msgstr "Gewichte in Bezug auf die Fläche (langsamer)."
 #: ../raster/r.cross/main.c:72
-msgid "Creates a cross product of the category values from multiple raster map layers."
-msgstr "Erzeugt ein Kreuzprodukt von Kategoriewerten auf Basis mehrerer Rasterkarten."
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+"Erzeugt ein Kreuzprodukt von Kategoriewerten auf Basis mehrerer Rasterkarten."
 #: ../raster/r.cross/main.c:81
 #, c-format
@@ -10843,8 +11693,12 @@
 #: ../raster/r.texture/h_measure.c:123
 #, c-format
-msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
-msgstr "Zu viele Kategorien (gefunden %i, Max: %i). Versuchen Sie die Karte zu reklassifizieren oder zu reskalieren."
+msgid ""
+"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
+"map"
+msgstr ""
+"Zu viele Kategorien (gefunden %i, Max: %i). Versuchen Sie die Karte zu "
+"reklassifizieren oder zu reskalieren."
 #: ../raster/r.stream.extract/load.c:33
 #, fuzzy
@@ -10940,7 +11794,9 @@
 msgstr "Führt Wartungsarbeiten im Netzwerk durch."
 #: ../raster/r.stream.extract/main.c:88
-msgid "Stream extraction will use provided accumulation instead of calculating it anew"
+msgid ""
+"Stream extraction will use provided accumulation instead of calculating it "
+"anew"
 msgstr ""
 #: ../raster/r.stream.extract/main.c:93
@@ -10962,7 +11818,9 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:110
-msgid "If accumulation is larger than d8cut, SFD is used instead of MFD. Applies only if no accumulation map is given."
+msgid ""
+"If accumulation is larger than d8cut, SFD is used instead of MFD. Applies "
+"only if no accumulation map is given."
 msgstr ""
 #: ../raster/r.stream.extract/main.c:122
@@ -10970,7 +11828,9 @@
 msgstr ""
 #: ../raster/r.stream.extract/main.c:124
-msgid "Montgomery: accumulation is multiplied with pow(slope,mexp) and then compared with threshold"
+msgid ""
+"Montgomery: accumulation is multiplied with pow(slope,mexp) and then "
+"compared with threshold"
 msgstr ""
 #: ../raster/r.stream.extract/main.c:132
@@ -10984,7 +11844,8 @@
 #: ../raster/r.stream.extract/main.c:141
 #, fuzzy
 msgid "Maximum memory to be used in MB"
-msgstr "Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
+msgstr ""
+"Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
 #: ../raster/r.stream.extract/main.c:146
 #, fuzzy
@@ -11180,12 +12041,18 @@
 #: ../raster/r.stream.extract/streams.c:700
 #, fuzzy, c-format
-msgid "MFD: A * path already processed when setting drainage direction: %lld of %lld cells"
-msgstr "MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d Zellen"
+msgid ""
+"MFD: A * path already processed when setting drainage direction: %lld of "
+"%lld cells"
+msgstr ""
+"MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d "
+"Zellen"
 #: ../raster/r.li/r.li.mpa/mpa.c:43
 msgid "Calculates mean pixel attribute index on a raster map"
-msgstr "Berechnet den Mittelwert der Attribute (Rasterwerte) -Index einer Rasterkarte."
+msgstr ""
+"Berechnet den Mittelwert der Attribute (Rasterwerte) -Index einer "
+"Rasterkarte."
 #: ../raster/r.li/r.li.mpa/mpa.c:45 ../raster/r.li/r.li.renyi/renyi.c:48
 #: ../raster/r.li/r.li.patchdensity/main.c:52
@@ -11248,8 +12115,11 @@
 msgstr "Der alpha-Wert ist die Größenordnung der generalisierten Entropie"
 #: ../raster/r.li/r.li.patchdensity/main.c:50
-msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr "Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+"Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
+"Nachbarn-Algorithmus."
 #: ../raster/r.li/r.li.daemon/worker.c:135
 #, fuzzy, c-format
@@ -11298,7 +12168,8 @@
 #: ../raster/r.li/r.li.daemon/daemon.c:481
 #, fuzzy, c-format
 msgid "The configuration file can only be used with the <%s> raster map"
-msgstr "Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s Rasterkarte."
+msgstr ""
+"Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s Rasterkarte."
 #: ../raster/r.li/r.li.daemon/daemon.c:487
 #, fuzzy
@@ -11323,8 +12194,11 @@
 msgstr "Kann lseek nicht ausführen."
 #: ../raster/r.li/r.li.patchnum/main.c:49
-msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr "Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+"Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-"
 #: ../raster/r.li/r.li.richness/richness.c:42
 #, fuzzy
@@ -11340,15 +12214,20 @@
 msgstr "Berechnet die Standardabweichung der Patch-Größen einer Rasterkarte."
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:44
-msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr "Berechnet Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+"Berechnet Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:65
 msgid "The value of the patch type"
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:66
-msgid "It can be integer, double or float; it will be changed in function of map type"
+msgid ""
+"It can be integer, double or float; it will be changed in function of map "
+"type"
 msgstr ""
 #: ../raster/r.li/r.li.pielou/pielou.c:45
@@ -11364,8 +12243,12 @@
 msgstr "Berechnet Shannons Diversitäts-Index einer Rasterkarte."
 #: ../raster/r.li/r.li.mps/mps.c:51
-msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
-msgstr "Berechnet mittleren Patch-Größen-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+"Berechnet mittleren Patch-Größen-Index einer Rasterkarte, unter Verwendung "
+"eines 4-Nachbarn-Algorithmus."
 #: ../raster/r.li/r.li.simpson/simpson.c:45
 msgid "Calculates Simpson's diversity index on a raster map"
@@ -11485,7 +12368,8 @@
 #: ../raster/r.to.rast3elev/main.c:99
 msgid "The number of input and elevation maps is not equal"
+msgstr ""
 #: ../raster/r.to.rast3elev/main.c:165
 msgid "The value to fill the upper cells, default is null"
@@ -11493,7 +12377,8 @@
 #: ../raster/r.to.rast3elev/main.c:172
 msgid "The value to fill the lower cells, default is null"
-msgstr "Der Wert mit dem die unteren Zellen gefüllt werden (Standrad ist null)."
+msgstr ""
+"Der Wert mit dem die unteren Zellen gefüllt werden (Standrad ist null)."
 #: ../raster/r.to.rast3elev/main.c:185
 msgid "Use the input map values to fill the upper cells"
@@ -11515,7 +12400,9 @@
 #: ../raster/r.to.rast3elev/main.c:366
 msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr "Erzeugt eine 3D Volumenkarte basierend auf einer 2D Höhenkarte und weiteren Rasterkarten."
+msgstr ""
+"Erzeugt eine 3D Volumenkarte basierend auf einer 2D Höhenkarte und weiteren "
+"Rasterkarten."
 #: ../raster/r.to.rast3elev/main.c:400
 msgid "The upper value is not valid"
@@ -11527,11 +12414,26 @@
 #: ../raster/r.horizon/main.c:182
 msgid "Horizon angle computation from a digital elevation model."
-msgstr "Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
+msgstr ""
+"Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
 #: ../raster/r.horizon/main.c:184
-msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation:  1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction.  The input for this is the angle (in degrees), which is measured  counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
-msgstr "Berechnet Horizontwinkelhöhe auf Grundlage eines digitalen Höhenmodells. Dies Modul hat zwei verschiedende Betriebsarten:  1. Berechnet den gesamten Horizont um einen Punkt, dessen Koordinaten mit der Option 'coord' angegeben wurden. Die Horizonthöhe wird im Bogenmaß ausgegeben.  2. Berechnet eine oder mehr Rasterkarten der Horizonthöhe in einer Richtung. Eingabe dafür ist der Winkel [Grad] gemessen gegen den Uhrzeigersinn mit Osten=0, Norden=90 etc. Die Ausgabe ist die Horizonthöhe im Bogenmaß. "
+msgid ""
+"Computes horizon angle height from a digital elevation model. The module has "
+"two different modes of operation:  1. Computes the entire horizon around a "
+"single point whose coordinates are given with the 'coord' option. The "
+"horizon height (in radians). 2. Computes one or more raster maps of the "
+"horizon height in a single direction.  The input for this is the angle (in "
+"degrees), which is measured  counterclockwise with east=0, north=90 etc. The "
+"output is the horizon height in radians."
+msgstr ""
+"Berechnet Horizontwinkelhöhe auf Grundlage eines digitalen Höhenmodells. "
+"Dies Modul hat zwei verschiedende Betriebsarten:  1. Berechnet den gesamten "
+"Horizont um einen Punkt, dessen Koordinaten mit der Option 'coord' angegeben "
+"wurden. Die Horizonthöhe wird im Bogenmaß ausgegeben.  2. Berechnet eine "
+"oder mehr Rasterkarten der Horizonthöhe in einer Richtung. Eingabe dafür ist "
+"der Winkel [Grad] gemessen gegen den Uhrzeigersinn mit Osten=0, Norden=90 "
+"etc. Die Ausgabe ist die Horizonthöhe im Bogenmaß. "
 #: ../raster/r.horizon/main.c:198 ../raster/r.sun/main.c:256
 msgid "Name of the input elevation raster map [meters]"
@@ -11546,28 +12448,50 @@
 msgstr "Schrittgröße des Winkels für multidirektionalen Horizont [Grad]."
 #: ../raster/r.horizon/main.c:223
-msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
-msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich um die aktuelle Region herum ein."
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer around the present "
+"region"
+msgstr ""
+"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich um die "
+"aktuelle Region herum ein."
 #: ../raster/r.horizon/main.c:231
-msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
-msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich östlich der aktuellen Region ein."
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer eastward the present "
+"region"
+msgstr ""
+"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich östlich "
+"der aktuellen Region ein."
 #: ../raster/r.horizon/main.c:239
-msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
-msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich westlich der aktuellen Region ein."
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer westward the present "
+"region"
+msgstr ""
+"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich westlich "
 #: ../raster/r.horizon/main.c:247
-msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
-msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich nördlich der aktuellen Region ein."
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer northward the present "
+"region"
+msgstr ""
+"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich nördlich "
 #: ../raster/r.horizon/main.c:255
-msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
-msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereichsüdlich der aktuellen Region ein."
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer southward the present "
+"region"
+msgstr ""
+"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereichsüdlich der "
+"aktuellen Region ein."
 #: ../raster/r.horizon/main.c:263
 msgid "The maximum distance to consider when finding the horizon height"
-msgstr "Die maximale bei der Suche nach der Horizonthöhe zu berücksichtigende Distanz."
+msgstr ""
+"Die maximale bei der Suche nach der Horizonthöhe zu berücksichtigende "
+"Distanz."
 #: ../raster/r.horizon/main.c:272
 msgid "Prefix of the horizon raster output maps"
@@ -11595,7 +12519,8 @@
 #: ../raster/r.horizon/main.c:377
 msgid "You didn't specify a direction value or step size. Aborting."
-msgstr "Sie haben keine Wert für die Richtung oder Schrittgröße angegeben. Breche ab."
+msgstr ""
+"Sie haben keine Wert für die Richtung oder Schrittgröße angegeben. Breche ab."
 #: ../raster/r.horizon/main.c:382
 msgid "You didn't specify a horizon raster name. Aborting."
@@ -11647,7 +12572,8 @@
 #: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
 #: ../general/g.region/printwindow.c:622 ../display/d.where/main.c:107
 msgid "Can't get projection info of current location"
-msgstr "Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
+msgstr ""
+"Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
 #: ../raster/r.horizon/main.c:491 ../raster/r.sun/main.c:730
 #: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
@@ -11707,17 +12633,22 @@
 #: ../raster/r.compress/main.c:110
 #, c-format
 msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr "[%s] ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht dekomprimieren."
+msgstr ""
+"[%s] ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht "
+"dekomprimieren."
 #: ../raster/r.compress/main.c:112
 #, c-format
 msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
-msgstr "<%s> ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht komprimieren."
+msgstr ""
+"<%s> ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht "
+"komprimieren."
 #: ../raster/r.compress/main.c:117
 #, c-format
 msgid "[%s] is a GDAL-linked map - can't (un)compress"
-msgstr "[%s] ist eine per GDAL verknüpfte Karte  - kann nicht (de)komprimieren."
+msgstr ""
+"[%s] ist eine per GDAL verknüpfte Karte  - kann nicht (de)komprimieren."
 #: ../raster/r.compress/main.c:159
 #, c-format
@@ -11806,7 +12737,8 @@
 #: ../raster/r.proj/main.c:148
 #, fuzzy
 msgid "Re-projects a raster map from given location to the current location."
-msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
+msgstr ""
+"Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
 #: ../raster/r.proj/main.c:151
 msgid "Name of input raster map to re-project"
@@ -11869,11 +12801,16 @@
 #: ../raster/r.proj/main.c:219
 msgid "Print input map's bounds in the current projection and exit"
-msgstr "Gibt die Grenzen der Eingabekarte in der aktuellen Projektion aus und beendet sich."
+msgstr ""
+"Gibt die Grenzen der Eingabekarte in der aktuellen Projektion aus und "
+"beendet sich."
 #: ../raster/r.proj/main.c:225
-msgid "Print input map's bounds in the current projection and exit (shell style)"
-msgstr "Gibt die Grenzen der Eingabekarte in der aktuellen Projektion im Shellskript-Format aus und beendet sich."
+msgid ""
+"Print input map's bounds in the current projection and exit (shell style)"
+msgstr ""
+"Gibt die Grenzen der Eingabekarte in der aktuellen Projektion im Shellskript-"
+"Format aus und beendet sich."
 #: ../raster/r.proj/main.c:251 ../vector/v.proj/main.c:143
 #: ../vector/v.external/main.c:139
@@ -11891,7 +12828,8 @@
 #: ../raster/r.proj/main.c:269
 msgid "Unable to get projection info of output raster map"
-msgstr "Kann die Projektionsinformation der Ausgabe-Rasterkarte nicht ermitteln."
+msgstr ""
+"Kann die Projektionsinformation der Ausgabe-Rasterkarte nicht ermitteln."
 #: ../raster/r.proj/main.c:272
 msgid "Unable to get projection units of output raster map"
@@ -11899,7 +12837,8 @@
 #: ../raster/r.proj/main.c:275
 msgid "Unable to get projection key values of output raster map"
-msgstr "Kann die Kennzahlen der Projektion der Ausgabe-Rasterkarte nicht ermitteln."
+msgstr ""
+"Kann die Kennzahlen der Projektion der Ausgabe-Rasterkarte nicht ermitteln."
 #: ../raster/r.proj/main.c:284
 #, c-format
@@ -12037,28 +12976,53 @@
 msgstr "Modell der Sonnen-Strahlungsdichte und -Strahlungssumme."
 #: ../raster/r.sun/main.c:242
-msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-msgstr "Berechnet direkte (beam), diffuse und reflektierte Sonneneinstrahlung für einen angegebenen Tag, geographische Breite, Oberfläche und atmosphärische Kondition. Parameter (z.B. Sonnenauf- und -untergangszeiten, Sonnenwinkel, extraterrestrische Strahlung und Tageslänge) werden in der History-Datei der Rasterkarte abgespeichert. Alternativ kann die lokale Zeit angegeben werden, daraus wird der Einfallswinkel der Strahlung und/oder die Strahlungsintensität berechnet. Ein Schatteneffekt der Topographie kann eingebunden werden."
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in the map history file. "
+"Alternatively, a local time can be specified to compute solar incidence "
+"angle and/or irradiance raster maps. The shadowing effect of the topography "
+"is optionally incorporated."
+msgstr ""
+"Berechnet direkte (beam), diffuse und reflektierte Sonneneinstrahlung für "
+"einen angegebenen Tag, geographische Breite, Oberfläche und atmosphärische "
+"Kondition. Parameter (z.B. Sonnenauf- und -untergangszeiten, Sonnenwinkel, "
+"extraterrestrische Strahlung und Tageslänge) werden in der History-Datei der "
+"Rasterkarte abgespeichert. Alternativ kann die lokale Zeit angegeben werden, "
+"daraus wird der Einfallswinkel der Strahlung und/oder die "
+"Strahlungsintensität berechnet. Ein Schatteneffekt der Topographie kann "
+"eingebunden werden."
 #: ../raster/r.sun/main.c:265
-msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
-msgstr "Name der Eingabe-Expositionskarte (Geländeexposition oder Azimuth des Sonnenstandes) [in Dezimalgrad]."
+msgid ""
+"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
+"[decimal degrees]"
+msgstr ""
+"Name der Eingabe-Expositionskarte (Geländeexposition oder Azimuth des "
+"Sonnenstandes) [in Dezimalgrad]."
 #: ../raster/r.sun/main.c:274
 msgid "A single value of the orientation (aspect), 270 is south"
 msgstr "Ein einzelner Wert für die Orientierung (aspect), 270 ist Süden."
 #: ../raster/r.sun/main.c:283
-msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
-msgstr "Eingabe-Rasterkarte der Hangneigung (Geländeneigung oder Sonnenstandsinklination) [in Grad]."
+msgid ""
+"Name of the input slope raster map (terrain slope or solar panel "
+"inclination) [decimal degrees]"
+msgstr ""
+"Eingabe-Rasterkarte der Hangneigung (Geländeneigung oder "
+"Sonnenstandsinklination) [in Grad]."
 #: ../raster/r.sun/main.c:291
 msgid "A single value of inclination (slope)"
 msgstr "Ein einzelner Wert für die Inklination (slope)."
 #: ../raster/r.sun/main.c:300
-msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr "Eingabe-Rasterkarte des Linke-Trübungskoeffizienten der Atmosphäre [-]."
+msgid ""
+"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr ""
+"Eingabe-Rasterkarte des Linke-Trübungskoeffizienten der Atmosphäre [-]."
 #: ../raster/r.sun/main.c:310
 msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
@@ -12081,12 +13045,19 @@
 msgstr "Name der Eingabe-Rasterkarte mit Längengraden [Dezimalgrad]."
 #: ../raster/r.sun/main.c:358
-msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
-msgstr "Eingabe-Rasterkarte mit Koeffizient der direkten 'real-sky' Sonneneinstrahlung (dicke Wolken) [0-1]"
+msgid ""
+"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
+"[0-1]"
+msgstr ""
+"Eingabe-Rasterkarte mit Koeffizient der direkten 'real-sky' "
+"Sonneneinstrahlung (dicke Wolken) [0-1]"
 #: ../raster/r.sun/main.c:367
-msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
-msgstr "Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' Sonneneinstrahlung (Dunst) [0-1]."
+msgid ""
+"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgstr ""
+"Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' "
+"Sonneneinstrahlung (Dunst) [0-1]."
 #: ../raster/r.sun/main.c:375
 msgid "The horizon information input map prefix"
@@ -12097,20 +13068,36 @@
 msgstr "Ausgabe-Rasterkarte des Einfallswinkels (nur Modus 1)."
 #: ../raster/r.sun/main.c:401
-msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "Ausgabe der gerichteten [W.m-2] (Modus 1) Strahlung oder der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
+msgid ""
+"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
+msgstr ""
+"Ausgabe der gerichteten [W.m-2] (Modus 1) Strahlung oder der Abstrahlung [Wh."
+"m-2.day-1] (Modus 2)."
 #: ../raster/r.sun/main.c:410
-msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "Ausgabe-Rasterkarte der diffusen Sonneneinstrahlung [W.m-2] (Modus 1) oder der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
+msgid ""
+"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
+msgstr ""
+"Ausgabe-Rasterkarte der diffusen Sonneneinstrahlung [W.m-2] (Modus 1) oder "
+"der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
 #: ../raster/r.sun/main.c:419
-msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "Ausgabekarte der Grund-Ausstrahlung [W.m-2] (Modus 1) oder Intensität [Wh.m-2.day1] (Modus 2)."
+msgid ""
+"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
+"map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+"Ausgabekarte der Grund-Ausstrahlung [W.m-2] (Modus 1) oder Intensität [Wh."
+"m-2.day1] (Modus 2)."
 #: ../raster/r.sun/main.c:428
-msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "Ausgabe der globalen (Gesamt-) Strahlungsintensität/-summe [W.m-2] (Modus 1) oder Rasterkarten der Strahlungsintensität/-summe [Wh.m-2.day-1] (Modus 2)."
+msgid ""
+"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
+"irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+"Ausgabe der globalen (Gesamt-) Strahlungsintensität/-summe [W.m-2] (Modus 1) "
+"oder Rasterkarten der Strahlungsintensität/-summe [Wh.m-2.day-1] (Modus 2)."
 #: ../raster/r.sun/main.c:437
 msgid "Output insolation time raster map [h] (mode 2 only)"
@@ -12122,15 +13109,20 @@
 #: ../raster/r.sun/main.c:453
 msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr "Zeitschritt für die Berechnung der ganztägigen Strahlung [in Dezimal-Stunden]."
+msgstr ""
+"Zeitschritt für die Berechnung der ganztägigen Strahlung [in Dezimal-"
+"Stunden]."
 #: ../raster/r.sun/main.c:460
 msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr "Deklinationswert (überschreibt den intern berechneten Wert) [Bogenmaß]."
+msgstr ""
+"Deklinationswert (überschreibt den intern berechneten Wert) [Bogenmaß]."
 #: ../raster/r.sun/main.c:468
 msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr "Lokale (Sonnen-)Zeit (muss nur für Modus 1 angegeben werden) [Dezimal-Stunden]"
+msgstr ""
+"Lokale (Sonnen-)Zeit (muss nur für Modus 1 angegeben werden) [Dezimal-"
+"Stunden]"
 #: ../raster/r.sun/main.c:499
 msgid "Read the input files in this number of chunks"
@@ -12138,7 +13130,9 @@
 #: ../raster/r.sun/main.c:506
 msgid "Civil time zone value, if none, the time will be local solar time"
-msgstr "Wert der zivilen Zeitzone. Wennnicht angegeben wird die lokale Sonnenzeit verwendet."
+msgstr ""
+"Wert der zivilen Zeitzone. Wennnicht angegeben wird die lokale Sonnenzeit "
+"verwendet."
 #: ../raster/r.sun/main.c:512
 #, fuzzy
@@ -12151,7 +13145,9 @@
 #: ../raster/r.sun/main.c:558
 msgid "You must give the longitude raster if you use civil time"
-msgstr "Sie müssen eine Rasterkarte mit Breitengraden angeben, wenn Sie zivile Zeit verwenden."
+msgstr ""
+"Sie müssen eine Rasterkarte mit Breitengraden angeben, wenn Sie zivile Zeit "
+"verwenden."
 #: ../raster/r.sun/main.c:561
 msgid "Error reading civil time zone value"
@@ -12182,16 +13178,23 @@
 msgstr "Die Horizont-Schrittgröße muss größer sein als 0."
 #: ../raster/r.sun/main.c:607
-msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr "Wenn Sie die Option 'horizon' verwenden, müssen Sie auch den 'horizonstep'-Parameter angeben."
+msgid ""
+"If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr ""
+"Wenn Sie die Option 'horizon' verwenden, müssen Sie auch den 'horizonstep'-"
+"Parameter angeben."
 #: ../raster/r.sun/main.c:613
 msgid "Time and insol_time are incompatible options"
 msgstr "Time und insol_time sind nicht kompatible Optionen."
 #: ../raster/r.sun/main.c:615
-msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
-msgstr "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei bekannter lokaler Zeit"
+msgid ""
+"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
+"time"
+msgstr ""
+"Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei "
+"bekannter lokaler Zeit"
 #: ../raster/r.sun/main.c:620
 msgid "incidout requires time parameter to be set"
@@ -12203,19 +13206,29 @@
 #: ../raster/r.sun/main.c:668
 msgid "If you use -s and no horizon rasters, numpartitions must be =1"
-msgstr "Wenn sie -s und keine Horizont-Rasterkarte verwenden, muss numpartitions=1 sein."
+msgstr ""
+"Wenn sie -s und keine Horizont-Rasterkarte verwenden, muss numpartitions=1 "
+"sein."
 #: ../raster/r.sun/main.c:681
-msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
-msgstr "Wenn Sie Speicher sparen und Schatten verwenden wollen, müssen Sie einen vorher berechneten Horizont verwenden."
+msgid ""
+"If you want to save memory and to use shadows, you must use pre-calculated "
+"horizons."
+msgstr ""
+"Wenn Sie Speicher sparen und Schatten verwenden wollen, müssen Sie einen "
+"vorher berechneten Horizont verwenden."
 #: ../raster/r.sun/main.c:748
 msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
-msgstr "Die Rasterkarten latin und longin haben kein Effekt in einer Lat/Lon Location."
+msgstr ""
+"Die Rasterkarten latin und longin haben kein Effekt in einer Lat/Lon "
+"Location."
 #: ../raster/r.sun/main.c:753
 msgid "Both latin and longin raster maps must be given, or neither"
-msgstr "Entweder müssen die beiden Rasterkarten latin und longin oder keine von beiden angegeben werden."
+msgstr ""
+"Entweder müssen die beiden Rasterkarten latin und longin oder keine von "
+"beiden angegeben werden."
 #: ../raster/r.profile/main.c:51 ../display/d.profile/main.c:192
 #: ../raster3d/r3.cross.rast/main.c:229
@@ -12225,7 +13238,9 @@
 #: ../raster/r.profile/main.c:53
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr "Gibt eine Rasterkarte aus, deren Werte entlang einer (oder mehrerer) benutzerdefinierter Linien liegt."
+msgstr ""
+"Gibt eine Rasterkarte aus, deren Werte entlang einer (oder mehrerer) "
+"benutzerdefinierter Linien liegt."
 #: ../raster/r.profile/main.c:66 ../display/d.profile/main.c:206
 msgid "Profile coordinate pairs"
@@ -12239,7 +13254,9 @@
 #: ../raster/r.profile/main.c:74
 #, fuzzy
 msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
-msgstr "Datei mit zu transformierenden Koordinaten (oder \"-\" um von stdin zu lesen)."
+msgstr ""
+"Datei mit zu transformierenden Koordinaten (oder \"-\" um von stdin zu "
+"lesen)."
 #: ../raster/r.profile/main.c:82
 msgid "Resolution along profile (default = current region resolution)"
@@ -12274,7 +13291,8 @@
 #: ../raster/r.profile/main.c:164
 #, c-format
 msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
-msgstr "[Ost-Koordinate] [Nord-Koordinate] [Dist. entlang des Tracks(m)] [Höhe]"
+msgstr ""
+"[Ost-Koordinate] [Nord-Koordinate] [Dist. entlang des Tracks(m)] [Höhe]"
 #: ../raster/r.profile/main.c:166
 #, c-format
@@ -12329,7 +13347,9 @@
 #: ../raster/r.solute.transport/main.c:79
 #, fuzzy
-msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
+msgid ""
+"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
+"dirichlet- and 3 - transfer boundary condition"
 msgstr "Der Status jeder Zelle, = 0 - inaktiv, 1 - aktiv, 2 - dirichlet"
 #: ../raster/r.solute.transport/main.c:85
@@ -12356,11 +13376,14 @@
 msgstr "Wasserquellen und -senken [m^3/s]."
 #: ../raster/r.solute.transport/main.c:103
-msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgid ""
+"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:112
-msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
+msgid ""
+"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
+"reaction)"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:117
@@ -12381,19 +13404,27 @@
 #: ../raster/r.solute.transport/main.c:132
 #, fuzzy
-msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
-msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
+msgid ""
+"The resulting concentration of the numerical solute transport calculation "
+"will be written to this map. [kg/m^3]"
+msgstr ""
+"Das resultierende piezometrisches Niveau der numerischen Berechnung wird in "
+"diese Karte geschrieben."
 #: ../raster/r.solute.transport/main.c:140
 #, fuzzy
-msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in x "
+"direction [m/s]\n"
 msgstr ""
 "Berechne das Vektorfeld der Grundwasserfiltrationgeschwindigkeiten [m/s]\n"
 "und schreibe die x- und y-Komponenten in Karten mit den Namen name_[xy]."
 #: ../raster/r.solute.transport/main.c:147
 #, fuzzy
-msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in y "
 msgstr ""
@@ -12407,7 +13438,9 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:177
-msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
+msgid ""
+"Use this number of time loops if the CFL flag is off. The timestep will "
+"become dt/loops."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:187
@@ -12415,7 +13448,9 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:192 ../raster3d/r3.gwflow/main.c:131
-msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
+msgid ""
+"Use a full filled quadratic linear equation system, default is a sparse "
+"linear equation system."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:199
@@ -12429,8 +13464,12 @@
 #: ../raster/r.solute.transport/main.c:233
 #, fuzzy
-msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
-msgstr "Programm zur numerischen Berechnung von transienten, beschränkten und unbeschränkten Grundwasserfluss in zwei Dimensionen."
+msgid ""
+"Numerical calculation program for transient, confined and unconfined solute "
+"transport in two dimensions"
+msgstr ""
+"Programm zur numerischen Berechnung von transienten, beschränkten und "
+"unbeschränkten Grundwasserfluss in zwei Dimensionen."
 #: ../raster/r.solute.transport/main.c:258
 msgid "The direct LU solver do not work with sparse matrices"
@@ -12438,7 +13477,8 @@
 #: ../raster/r.solute.transport/main.c:260
 msgid "The direct Gauss solver do not work with sparse matrices"
-msgstr "Der direkte Gauss'sche Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgstr ""
+"Der direkte Gauss'sche Löser funktioniert nicht mit dünnbesetzten Matrizen."
 #: ../raster/r.solute.transport/main.c:370
 #, c-format
@@ -12462,7 +13502,8 @@
 #: ../raster/r.solute.transport/main.c:385
 #, c-format
-msgid "The time step is to large: %gs. The largest time step should be of size %gs."
+msgid ""
+"The time step is to large: %gs. The largest time step should be of size %gs."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:397
@@ -12482,8 +13523,12 @@
 #: ../raster/r.slope.aspect/main.c:153
 #, fuzzy
-msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map."
-msgstr "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen Ableitungen aus einer Rasterkarte mit Höheninformationen."
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from an elevation raster map."
+msgstr ""
+"Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
+"Ableitungen aus einer Rasterkarte mit Höheninformationen."
 #: ../raster/r.slope.aspect/main.c:155
 msgid "Aspect is calculated counterclockwise from east."
@@ -12514,12 +13559,18 @@
 msgstr "Name der Ausgabe-Rasterkarte mit horizontaler Wölbung."
 #: ../raster/r.slope.aspect/main.c:207
-msgid "Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr "Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
+msgid ""
+"Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr ""
+"Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dx (Ost-West "
+"Hangneigung)."
 #: ../raster/r.slope.aspect/main.c:214
-msgid "Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr "Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
+msgid ""
+"Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr ""
+"Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dy (Nord-Süd "
+"Hangneigung)."
 #: ../raster/r.slope.aspect/main.c:221
 msgid "Name for output second order partial derivative dxx raster map"
@@ -12539,12 +13590,16 @@
 #: ../raster/r.slope.aspect/main.c:250
 msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr "Minimale Hangneigung (in Prozent), für die eine Hangexposition berechnet werden soll."
+msgstr ""
+"Minimale Hangneigung (in Prozent), für die eine Hangexposition berechnet "
+"werden soll."
 #: ../raster/r.slope.aspect/main.c:259
 #, fuzzy
 msgid "Do not align the current region to the raster elevation map"
-msgstr "Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen anpassen."
+msgstr ""
+"Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen "
+"anpassen."
 #: ../raster/r.slope.aspect/main.c:313 ../raster/r.shaded.relief/main.c:207
 #, c-format
@@ -12559,8 +13614,12 @@
 #: ../raster/r.slope.aspect/main.c:334
 #, c-format
-msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr "Sie müssen mindestens einen der Parameter wählen: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> oder <%s>"
+msgid ""
+"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
+"%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr ""
+"Sie müssen mindestens einen der Parameter wählen: <%s>, <%s>, <%s>, <%s>, <"
+"%s>, <%s>, <%s>, <%s> oder <%s>"
 #: ../raster/r.slope.aspect/main.c:356
 #, c-format
@@ -12591,7 +13650,8 @@
 #: ../raster/r.slope.aspect/main.c:1105
 #, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
-msgstr "minimale berechnete Hangneigung %.4f, maximale berechnete Hangneigung %.4f."
+msgstr ""
+"minimale berechnete Hangneigung %.4f, maximale berechnete Hangneigung %.4f."
 #: ../raster/r.slope.aspect/main.c:1158
 #, c-format
@@ -12636,7 +13696,8 @@
 #: ../raster/r.resamp.interp/main.c:80
 #, fuzzy
 msgid "Resamples raster map to a finer grid using interpolation."
-msgstr "Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels Interpolation."
+msgstr ""
+"Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels Interpolation."
 #: ../raster/r.resamp.interp/main.c:88
 msgid "Method"
@@ -12654,7 +13715,8 @@
 #: ../raster/r.contour/main.c:90
 msgid "Produces a vector map of specified contours from a raster map."
-msgstr "Erzeugt eine Vektorkarte mit bestimmten Kontourlinien aus einer Rasterkarte."
+msgstr ""
+"Erzeugt eine Vektorkarte mit bestimmten Kontourlinien aus einer Rasterkarte."
 #: ../raster/r.contour/main.c:100
 msgid "Increment between contour levels"
@@ -12795,12 +13857,18 @@
 msgstr "Schließen ohne eine Karte zu erzeugen?"
 #: ../raster/r.digit/main.c:46
-msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
-msgstr "Interaktives Werkzeug, welches Vektorobjekte in einem Grafikfenster mit der Maus zeichnet und als Rasterkarte speichert."
+msgid ""
+"Interactive tool used to draw and save vector features on a graphics monitor "
+"using a pointing device (mouse) and save to a raster map."
+msgstr ""
+"Interaktives Werkzeug, welches Vektorobjekte in einem Grafikfenster mit der "
+"Maus zeichnet und als Rasterkarte speichert."
 #: ../raster/r.digit/main.c:55
 msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr "Display-Befehle die für den Hintergrund verwendet werden sollen (getrennt durch ';')."
+msgstr ""
+"Display-Befehle die für den Hintergrund verwendet werden sollen (getrennt "
+"durch ';')."
 #: ../raster/r.digit/main.c:78
 msgid "No graphics device selected!"
@@ -12857,7 +13925,9 @@
 #: ../raster/r.in.lidar/main.c:165
 #, fuzzy
 msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
-msgstr "Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung univariater Statistik."
+msgstr ""
+"Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung "
+"univariater Statistik."
 #: ../raster/r.in.lidar/main.c:168 ../vector/v.in.lidar/main.c:160
 #, fuzzy
@@ -12881,7 +13951,9 @@
 #: ../raster/r.in.lidar/main.c:253 ../vector/v.in.lidar/main.c:203
 #: ../vector/v.in.ogr/main.c:261
 msgid "Override dataset projection (use location's projection)"
-msgstr "Übersteuere die Projektion des Datensatzes (verwende Projektion der Location)."
+msgstr ""
+"Übersteuere die Projektion des Datensatzes (verwende Projektion der "
+"Location)."
 #: ../raster/r.in.lidar/main.c:279 ../vector/v.in.lidar/main.c:234
 #, fuzzy, c-format
@@ -12895,8 +13967,12 @@
 #: ../raster/r.in.lidar/main.c:319 ../vector/v.in.lidar/main.c:371
 #: ../vector/v.in.ogr/main.c:643
-msgid "Unable to convert input map projection information to GRASS format for checking"
-msgstr "Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format konvertieren, zwecks Überprüfung."
+msgid ""
+"Unable to convert input map projection information to GRASS format for "
+"checking"
+msgstr ""
+"Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format "
+"konvertieren, zwecks Überprüfung."
 #: ../raster/r.in.lidar/main.c:349 ../vector/v.in.lidar/main.c:401
 #: ../vector/v.in.ogr/main.c:673
@@ -12911,12 +13987,17 @@
 "You can use the -o flag to %s to override this projection check.\n"
 msgstr ""
 "\n"
-"Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu übersteuern.\n"
+"Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu "
+"übersteuern.\n"
 #: ../raster/r.in.lidar/main.c:412 ../vector/v.in.lidar/main.c:464
 #: ../vector/v.in.ogr/main.c:736
-msgid "Consider generating a new location with 'location' parameter from input data set.\n"
-msgstr "Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
+msgid ""
+"Consider generating a new location with 'location' parameter from input data "
+"set.\n"
+msgstr ""
+"Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der "
+"Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
 #: ../raster/r.in.lidar/main.c:554
 msgid "zrange will not be taken into account during scan"
@@ -12948,7 +14029,9 @@
 #: ../raster/r.surf.contour/main.c:64
 #, fuzzy
 msgid "Generates surface raster map from rasterized contours."
-msgstr "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit Höheninformationen."
+msgstr ""
+"Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit "
+"Höheninformationen."
 #: ../raster/r.surf.contour/main.c:67
 #, fuzzy
@@ -12991,7 +14074,9 @@
 #: ../raster/r.shaded.relief/main.c:148
 #, fuzzy
 msgid "Scale factor for converting meters to elevation units"
-msgstr "Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu Höheneinheiten"
+msgstr ""
+"Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu "
+"Höheneinheiten"
 #: ../raster/r.shaded.relief/main.c:155
 #, fuzzy
@@ -13020,14 +14105,21 @@
 #: ../raster/r.external/proj.c:107
 msgid ""
 "\n"
-"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the "
+"location definition for the dataset.\n"
 msgstr ""
 "\n"
-"Sie können den Schalter '-o' von r.exernal, um diese Prüfung zu übersteuern und die Einstellungen der Location für diesen Datensatz zu verwenden.\n"
+"Sie können den Schalter '-o' von r.exernal, um diese Prüfung zu übersteuern "
+"und die Einstellungen der Location für diesen Datensatz zu verwenden.\n"
 #: ../raster/r.external/window.c:23
-msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
-msgstr "Die Eingabekarte wurde rotiert und kann daher nicht eingelesen werden. Sie können 'gdalwarp' verwenden, um die Karte so zu transformieren, dass Norden nach oben zeigt."
+msgid ""
+"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
+"transform the map to North-up."
+msgstr ""
+"Die Eingabekarte wurde rotiert und kann daher nicht eingelesen werden. Sie "
+"können 'gdalwarp' verwenden, um die Karte so zu transformieren, dass Norden "
+"nach oben zeigt."
 #: ../raster/r.external/window.c:26
 msgid "Applying horizontal flip"
@@ -13168,7 +14260,8 @@
 #: ../raster/r.out.png/main.c:131
 msgid "(0 = none, 1 = fastest, 9 = best)"
-msgstr "(0 = keine Kompression, 1 = schnellste Kompression, 9 = beste Kompression)"
+msgstr ""
+"(0 = keine Kompression, 1 = schnellste Kompression, 9 = beste Kompression)"
 #: ../raster/r.out.png/main.c:138
 msgid "Make NULL cells transparent"
@@ -13240,12 +14333,19 @@
 #: ../raster/r.out.tiff/main.c:175
 #, fuzzy, c-format
-msgid "Raster map <%s>> is a floating point map. Fractional values will be rounded to integer"
-msgstr "Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. Nachkommastellen werden auf ganze Zahlen gerundet!"
+msgid ""
+"Raster map <%s>> is a floating point map. Fractional values will be rounded "
+"to integer"
+msgstr ""
+"Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. "
+"Nachkommastellen werden auf ganze Zahlen gerundet!"
 #: ../raster/r.out.tiff/main.c:181
-msgid "Color map for palette must have less than 256 colors for the available range of data"
-msgstr "Farbtabelle muss weniger als 256 Farben für die vorhandene Datenspanne haben."
+msgid ""
+"Color map for palette must have less than 256 colors for the available range "
+"of data"
+msgstr ""
+"Farbtabelle muss weniger als 256 Farben für die vorhandene Datenspanne haben."
 #: ../raster/r.out.tiff/main.c:195
 #, c-format
@@ -13438,7 +14538,9 @@
 #: ../raster/r.in.bin/main.c:426
 msgid "Either all or none of north=, south=, east= and west= must be given"
-msgstr "Entweder alle oder keine Angabe von north=, south=, east= and west= müssen angegeben werden"
+msgstr ""
+"Entweder alle oder keine Angabe von north=, south=, east= and west= müssen "
+"angegeben werden"
 #: ../raster/r.in.bin/main.c:433 ../display/d.grid/main.c:247
 #: ../raster3d/r3.in.bin/main.c:427
@@ -13469,8 +14571,12 @@
 #: ../raster/r.in.bin/main.c:464
 #, c-format
-msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
-msgstr "Ost-West (ewres: %f) und Nord-Süd (nwres: %f) Auflösung unterscheiden sich wesentlich. Haben Sie east= and west= korrekt gesetzt?"
+msgid ""
+"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
+"significantly. Did you assign east= and west= correctly?"
+msgstr ""
+"Ost-West (ewres: %f) und Nord-Süd (nwres: %f) Auflösung unterscheiden sich "
+"wesentlich. Haben Sie east= and west= korrekt gesetzt?"
 #: ../raster/r.in.bin/main.c:487
 msgid "File Size %"
@@ -13483,7 +14589,9 @@
 #: ../raster/r.kappa/calc_kappa.c:32
 #, c-format
 msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr "Kann die Datei <%s> nicht öffnen, um die Kappawerte und relevante Parameter zu schreiben."
+msgstr ""
+"Kann die Datei <%s> nicht öffnen, um die Kappawerte und relevante Parameter "
+"zu schreiben."
 #: ../raster/r.kappa/main.c:70 ../imagery/i.cluster/main.c:76
 #: ../imagery/i.class/main.c:92 ../imagery/i.maxlik/main.c:62
@@ -13496,8 +14604,12 @@
 #: ../raster/r.kappa/main.c:72
 #, fuzzy
-msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
-msgstr "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung (accuracy assessment) der Klassifikationsergebnisse."
+msgid ""
+"Calculates error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+"Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung "
+"(accuracy assessment) der Klassifikationsergebnisse."
 #: ../raster/r.kappa/main.c:78
 msgid "Name of raster map containing classification result"
@@ -13548,7 +14660,9 @@
 #: ../raster/r.kappa/prt_mat.c:39
 #, c-format
 msgid "Cannot open file <%s> to write cats and counts (error matrix)"
-msgstr "Kann die Datei <%s> nicht öffnen, um Kategorien und Anzahlen (Fehlermatrix) zu schreiben."
+msgstr ""
+"Kann die Datei <%s> nicht öffnen, um Kategorien und Anzahlen (Fehlermatrix) "
+"zu schreiben."
 #: ../raster/r.kappa/prt_label.c:17
 #, c-format
@@ -13633,7 +14747,8 @@
 #: ../raster/r.recode/read_rules.c:30
 #, fuzzy, c-format
 msgid "Data range of %s is %s to %s (entire map)"
-msgstr "Wertebereich der Rasterkarte <%s> reicht von %s bis %s (komplette Karte)."
+msgstr ""
+"Wertebereich der Rasterkarte <%s> reicht von %s bis %s (komplette Karte)."
 #: ../raster/r.recode/read_rules.c:39
 #, fuzzy, c-format
@@ -13708,12 +14823,19 @@
 msgstr "Keine Regeln angegeben. Rasterkarte <%s> nicht erzeugt."
 #: ../raster/r.neighbors/main.c:145
-msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
-msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+"Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
+"Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue "
+"Zellenwerte in einer Ausgabe-Rasterkarte."
 #: ../raster/r.neighbors/main.c:155
 #, fuzzy
-msgid "Name of an input raster map to select the cells which should be processed"
+msgid ""
+"Name of an input raster map to select the cells which should be processed"
 msgstr "Name der Rasterkarte für die Statistiken berechnet werden sollen."
 #: ../raster/r.neighbors/main.c:174 ../vector/v.neighbors/main.c:71
@@ -13769,12 +14891,15 @@
 #: ../raster/r.neighbors/main.c:296
 #, fuzzy, c-format
-msgid "Method %s not compatible with weighing window, using weight mask instead"
+msgid ""
+"Method %s not compatible with weighing window, using weight mask instead"
 msgstr "Methode %s ist nicht kompatibel mit Gauß'schem Filter."
 #: ../raster/r.neighbors/main.c:304
 #, fuzzy, c-format
-msgid "Method %s not compatible with Gaussian filter, using unweighed version instead"
+msgid ""
+"Method %s not compatible with Gaussian filter, using unweighed version "
+"instead"
 #: ../raster/r.neighbors/main.c:352
@@ -13793,16 +14918,22 @@
 msgstr "Fehler beim Lesen der Datei mit Gewichten %s."
 #: ../raster/r.spreadpath/main.c:93
-msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
-msgstr "Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von denen der kumulative Weg bestimmt wurde."
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+"Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von "
+"denen der kumulative Weg bestimmt wurde."
 #: ../raster/r.spreadpath/main.c:102
 msgid "Name of raster map containing back-path easting information"
-msgstr "Name der Rasterkarte, die die Ost Informationen zu den Rückwegen enthält."
+msgstr ""
+"Name der Rasterkarte, die die Ost Informationen zu den Rückwegen enthält."
 #: ../raster/r.spreadpath/main.c:110
 msgid "Name of raster map containing back-path northing information"
-msgstr "Name der Rasterkarte, die die Nord Informationen zu den Rückwegen enthält."
+msgstr ""
+"Name der Rasterkarte, die die Nord Informationen zu den Rückwegen enthält."
 #: ../raster/r.spreadpath/main.c:118
 msgid "The map E and N grid coordinates of starting points"
@@ -13827,7 +14958,8 @@
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
 #: ../vector/v.univar/main.c:119
 msgid "Percentile to calculate (requires extended statistics flag)"
-msgstr "zu berechnende Perzentile (erfordert den Schalter 'erweiterte Statistiken')."
+msgstr ""
+"zu berechnende Perzentile (erfordert den Schalter 'erweiterte Statistiken')."
 #: ../raster/r.univar/r3.univar_main.c:59
 #: ../raster/r.univar/r.univar_main.c:61 ../vector/v.univar/main.c:123
@@ -13858,8 +14990,12 @@
 msgstr "Raster, Statistik"
 #: ../raster/r.univar/r3.univar_main.c:103
-msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
-msgstr "Berechnet univariate Statistiken der nicht-NULL 3D-Zellen einer 3D-Rasterkarte."
+msgid ""
+"Calculates univariate statistics from the non-null 3d cells of a raster3d "
+"map."
+msgstr ""
+"Berechnet univariate Statistiken der nicht-NULL 3D-Zellen einer 3D-"
+"Rasterkarte."
 #: ../raster/r.univar/r3.univar_main.c:155
 #: ../raster/r.univar/r3.univar_main.c:193
@@ -13892,12 +15028,19 @@
 msgstr "Statistik"
 #: ../raster/r.univar/r.univar_main.c:105
-msgid "Calculates univariate statistics from the non-null cells of a raster map."
-msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
 #: ../raster/r.patch/main.c:55
-msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr "Erstellt eine Komposit-Karte, indem bekannte Kategorie-Werte einer (oder mehrerer) Rasterkarte(n) in \"NO DATA\"-Bereiche einer anderen Rasterkarte gefüllt werden."
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+"Erstellt eine Komposit-Karte, indem bekannte Kategorie-Werte einer (oder "
+"mehrerer) Rasterkarte(n) in \"NO DATA\"-Bereiche einer anderen Rasterkarte "
+"gefüllt werden."
 #: ../raster/r.patch/main.c:62
 msgid "Name of raster maps to be patched together"
@@ -14050,7 +15193,9 @@
 #: ../raster/r.surf.fractal/process.c:54
 msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr "Kann keinen Speicher für Datenbuffer reservieren. Überprüfen Sie die aktuelle Region mit g.region."
+msgstr ""
+"Kann keinen Speicher für Datenbuffer reservieren. Überprüfen Sie die "
+"aktuelle Region mit g.region."
 #: ../raster/r.surf.fractal/spec_syn.c:61
 msgid "Preliminary surface calculations..."
@@ -14068,7 +15213,8 @@
 #: ../raster/r.surf.fractal/main.c:42
 msgid "Creates a fractal surface of a given fractal dimension."
-msgstr "Erzeugt eine fraktale Oberfläche mit einer gegebenen Fraktalendimension."
+msgstr ""
+"Erzeugt eine fraktale Oberfläche mit einer gegebenen Fraktalendimension."
 #: ../raster/r.surf.fractal/main.c:48
 msgid "Fractal dimension of surface (2 < D < 3)"
@@ -14169,8 +15315,11 @@
 #: ../raster/r.stream.order/main.c:140
 #, fuzzy
-msgid "To calculate vector map both accumulation and elevation raster maps are required"
-msgstr "Berechnet Schattenbereiche aus der Sonnenposition und einer Höhenkarte."
+msgid ""
+"To calculate vector map both accumulation and elevation raster maps are "
+"required"
+msgstr ""
+"Berechnet Schattenbereiche aus der Sonnenposition und einer Höhenkarte."
 #: ../raster/r.stream.order/main.c:143
 msgid "Flag -a (use accumulation) accumulation raster map is required"
@@ -14178,8 +15327,12 @@
 #: ../raster/r.stream.order/main.c:152
 #, fuzzy
-msgid "You must select one or more output orders raster maps or insert the table name"
-msgstr "Es müssen eine oder mehrere Ausgabekarten ausgewählt werden (flout, lgout, dsout)."
+msgid ""
+"You must select one or more output orders raster maps or insert the table "
+"name"
+msgstr ""
+"Es müssen eine oder mehrere Ausgabekarten ausgewählt werden (flout, lgout, "
+"dsout)."
 #: ../raster/r.stream.order/stream_order.c:16
 #, fuzzy
@@ -14187,7 +15340,9 @@
 msgstr "Berechne Zentralitätsmaße..."
 #: ../raster/r.stream.order/stream_order.c:68
-msgid "Calculating Shreve's stream magnitude, Scheidegger's consistent integer and Drwal's streams hierarchy (old style)..."
+msgid ""
+"Calculating Shreve's stream magnitude, Scheidegger's consistent integer and "
+"Drwal's streams hierarchy (old style)..."
 msgstr ""
 #: ../raster/r.stream.order/stream_order.c:122
@@ -14269,8 +15424,12 @@
 #: ../raster/r.reclass/main.c:54
 #, fuzzy
-msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
-msgstr "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
+msgid ""
+"Creates a new raster map whose category values are based upon a "
+"reclassification of the categories in an existing raster map."
+msgstr ""
+"Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der "
+"Kategorien einer existierenden Rasterkarte basieren."
 #: ../raster/r.reclass/main.c:59
 #, fuzzy
@@ -14297,7 +15456,8 @@
 #: ../raster/r.reclass/main.c:103
 #, c-format
 msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr "Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
+msgstr ""
+"Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
 #: ../raster/r.reclass/main.c:105
 #, c-format
@@ -14356,8 +15516,11 @@
 #: ../raster/r.surf.random/main.c:40
 #, fuzzy
-msgid "Produces a raster surface map of uniform random deviates with defined range."
-msgstr "Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren Spanne vom Benutzer angegeben werden kann."
+msgid ""
+"Produces a raster surface map of uniform random deviates with defined range."
+msgstr ""
+"Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren "
+"Spanne vom Benutzer angegeben werden kann."
 #: ../raster/r.surf.random/main.c:46
 msgid "Minimum random value"
@@ -14436,11 +15599,15 @@
 #: ../raster/r.flow/io.c:87
 #, fuzzy
 msgid "Elevation raster map resolution differs from current region resolution"
-msgstr "Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen Region."
+msgstr ""
+"Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen "
+"Region."
 #: ../raster/r.flow/io.c:104
 msgid "Resolution of aspect file differs from current region resolution"
-msgstr "Auflösung der Expositionsdatei unterscheidet sich von der Auflösung der aktuellen Region"
+msgstr ""
+"Auflösung der Expositionsdatei unterscheidet sich von der Auflösung der "
+"aktuellen Region"
 #: ../raster/r.flow/io.c:121
 msgid "Reading input files: barrier"
@@ -14505,7 +15672,9 @@
 #: ../raster/r.flow/precomp.c:116
 #, c-format
 msgid "Resolution too unbalanced (%f x %f); please resample input map"
-msgstr "Auflösung ist zu unausgewogen (%f x %f); Bitte resamplen Sie die Eingabekarte."
+msgstr ""
+"Auflösung ist zu unausgewogen (%f x %f); Bitte resamplen Sie die "
+"Eingabekarte."
 #: ../raster/r.flow/main.c:424
 #, fuzzy
@@ -14514,8 +15683,12 @@
 #: ../raster/r.flow/main.c:426
 #, fuzzy
-msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
-msgstr "Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
+msgid ""
+"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
+"areas) from a elevation raster map."
+msgstr ""
+"Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope areas) "
+"aus einem angegebenen digitalen Höhenmodell (DEM)."
 #: ../raster/r.flow/main.c:435
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
@@ -14566,11 +15739,17 @@
 #: ../raster/r.flow/main.c:535
 msgid "You must select one or more output maps (flout, lgout, dsout)"
+msgstr ""
+"dsout)."
 #: ../raster/r.flow/main.c:551
-msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
-msgstr "Lat/Long Projection wird von r.flow nicht unterstützt. Bitte verwenden Sie 'r.watershed' für die Berechnung der Fussakkumulation."
+msgid ""
+"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
+"calculating flow accumulation."
+msgstr ""
+"Lat/Long Projection wird von r.flow nicht unterstützt. Bitte verwenden Sie "
+"'r.watershed' für die Berechnung der Fussakkumulation."
 #: ../raster/r.flow/mem.c:40
 #, c-format
@@ -14650,7 +15829,8 @@
 #: ../raster/r.los/main.c:160
 msgid "Lat/Long support is not (yet) implemented for this module."
-msgstr "Lat/Long-Unterstützung ist für dieses Modul (noch) nicht implementiert."
+msgstr ""
+"Lat/Long-Unterstützung ist für dieses Modul (noch) nicht implementiert."
 #: ../raster/r.los/main.c:165
 msgid "Specified observer coordinate is outside current region bounds."
@@ -14661,8 +15841,11 @@
 msgstr "Musterkarte sollte eine binäre 0/1 Rasterkarte sein."
 #: ../raster/r.los/main.c:243
-msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr "Habe ein Problem die Parameter des aktuellen Ellipsoids zu ermitteln, verwende Kugel (6370997.0)."
+msgid ""
+"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr ""
+"Habe ein Problem die Parameter des aktuellen Ellipsoids zu ermitteln, "
+"verwende Kugel (6370997.0)."
 #: ../raster/r.los/main.c:248
 #, c-format
@@ -14755,7 +15938,9 @@
 #: ../general/g.list/main.c:48
 msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr "Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten Datentyps."
+msgstr ""
+"Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten "
+"Datentyps."
 #: ../general/g.list/main.c:59 ../general/g.mlist/main.c:128
 msgid "Verbose listing (also list map titles)"
@@ -14777,7 +15962,8 @@
 #: ../general/g.setproj/main.c:88
 msgid "You must be in the PERMANENT mapset to run g.setproj"
-msgstr "Sie müssen sich in dem Mapset PERMANENT befinden um g.setproj auszuführen."
+msgstr ""
+"Sie müssen sich in dem Mapset PERMANENT befinden um g.setproj auszuführen."
 #: ../general/g.setproj/main.c:101
 msgid "PERMANENT: permission denied"
@@ -14882,8 +16068,14 @@
 msgstr "Die Information zu der UTM Zone wurde nicht aktualisiert."
 #: ../general/g.setproj/main.c:456
-msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
-msgstr "Wenn Sie aber die Zone ändern, werden alle existierenden Daten von der Projektionssoftware interpretiert. GRASS wird die Daten nicht automatisch umprojezieren oder die Header existierender Karten ändern."
+msgid ""
+"But if you change zone, all the existing data will be interpreted by "
+"projection software. GRASS will not automatically re-project or even change "
+"the headers for existing maps."
+msgstr ""
+"Wenn Sie aber die Zone ändern, werden alle existierenden Daten von der "
+"Projektionssoftware interpretiert. GRASS wird die Daten nicht automatisch "
+"umprojezieren oder die Header existierender Karten ändern."
 #: ../general/g.setproj/main.c:461
 msgid "Would you still like to change the UTM zone?"
@@ -14939,7 +16131,8 @@
 #: ../general/g.setproj/get_stp.c:43
 msgid "This should not happen see your system admin"
-msgstr "Dies sollte nicht passieren, suchen Sie ihren System-Administrator auf."
+msgstr ""
+"Dies sollte nicht passieren, suchen Sie ihren System-Administrator auf."
 #: ../general/g.setproj/get_stp.c:99
 msgid "Unable to open FIPS code file"
@@ -15016,12 +16209,15 @@
 msgstr "PostScript"
 #: ../general/g.message/main.c:37
-msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid ""
+"Prints a message, warning, progress info, or fatal error in the GRASS way."
 msgstr "Gibt eine Nachricht, Warnung oder fatalen Fehler im GRASS-Stil aus."
 #: ../general/g.message/main.c:39
 msgid "This module should be used in scripts for messages served to user."
-msgstr "Dieses Modul sollte in Skripten verwendet werden um Nachrichten an den Benutzer auszugeben."
+msgstr ""
+"Dieses Modul sollte in Skripten verwendet werden um Nachrichten an den "
+"Benutzer auszugeben."
 #: ../general/g.message/main.c:43 ../general/g.message/main.c:48
 #: ../general/g.message/main.c:53 ../general/g.message/main.c:58
@@ -15111,11 +16307,14 @@
 #: ../general/g.access/main.c:64
 msgid "UNIX filesystem access controls are not supported by MS-Windows"
-msgstr "Die Rechteverwaltung des UNIX Dateisystems wird von MS-Windows nicht unterstützt."
+msgstr ""
+"Die Rechteverwaltung des UNIX Dateisystems wird von MS-Windows nicht "
+"unterstützt."
 #: ../general/g.access/main.c:72
 msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr "Zugang zum Mapset PERMANENT muss möglich sein. Es wurde nichts verändert."
+msgstr ""
+"Zugang zum Mapset PERMANENT muss möglich sein. Es wurde nichts verändert."
 #: ../general/g.access/main.c:76
 msgid "Unable to determine mapset permissions"
@@ -15256,8 +16455,12 @@
 msgstr "Location: %s\n"
 #: ../general/g.proj/main.c:68
-msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
-msgstr "Ausgabe und Manipulation von GRASS Projektionsinformationsdateien (in verschieden Koordinatensystembeschreibungen)."
+msgid ""
+"Prints and manipulates GRASS projection information files (in various co-"
+"ordinate system descriptions)."
+msgstr ""
+"Ausgabe und Manipulation von GRASS Projektionsinformationsdateien (in "
+"verschieden Koordinatensystembeschreibungen)."
 #: ../general/g.proj/main.c:71
 msgid "Can also be used to create new GRASS locations."
@@ -15277,14 +16480,16 @@
 #: ../general/g.proj/main.c:93
 msgid "Verify datum information and print transformation parameters"
-msgstr "Überprüfe Datum-Informationen und gebe die Transformationsparameter aus."
+msgstr ""
+"Überprüfe Datum-Informationen und gebe die Transformationsparameter aus."
 #: ../general/g.proj/main.c:99
 msgid "Print projection information in PROJ.4 format"
 msgstr "Gebe die Projektionsinformationen im PROJ.4-Format aus."
 #: ../general/g.proj/main.c:105
-msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid ""
+"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
 msgstr "Ausgabe ohne Zeilenumbrüche (nur bei WKT- und PROJ.4-Ausgaben)"
 #: ../general/g.proj/main.c:115
@@ -15302,7 +16507,9 @@
 #: ../general/g.proj/main.c:129
 msgid "Name of georeferenced data file to read projection information from"
-msgstr "Name der Datei georeferenzierten Daten, von der Projektionsinformationen gelesen werden sollen"
+msgstr ""
+"Name der Datei georeferenzierten Daten, von der Projektionsinformationen "
+"gelesen werden sollen"
 #: ../general/g.proj/main.c:138
 msgid "Name of ASCII file containing a WKT projection description"
@@ -15327,7 +16534,9 @@
 #: ../general/g.proj/main.c:170
 msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
-msgstr "Akzeptiert Standard GRASS Datumcodes oder \"list\" zum Anzeigen der Liste und beenden"
+msgstr ""
+"Akzeptiert Standard GRASS Datumcodes oder \"list\" zum Anzeigen der Liste "
+"und beenden"
 #: ../general/g.proj/main.c:180
 msgid "Index number of datum transform parameters"
@@ -15335,11 +16544,17 @@
 #: ../general/g.proj/main.c:181
 msgid "\"0\" for unspecified or \"-1\" to list and exit"
-msgstr "\"0\" für nicht spezifiziert oder \"-1\" um alle aufzulisten und sich zu beenden"
+msgstr ""
+"\"0\" für nicht spezifiziert oder \"-1\" um alle aufzulisten und sich zu "
+"beenden"
 #: ../general/g.proj/main.c:187
-msgid "Force override of datum transformation information in input co-ordinate system"
-msgstr "Erzwinge das Übersteuern der Datumtransformationsinformation des Eingabe Koordinatensystems."
+msgid ""
+"Force override of datum transformation information in input co-ordinate "
+"system"
+msgstr ""
+"Erzwinge das Übersteuern der Datumtransformationsinformation des Eingabe "
+"Koordinatensystems."
 #: ../general/g.proj/main.c:193
 msgid "Create new projection files (modifies current location)"
@@ -15357,7 +16572,8 @@
 #: ../general/g.proj/main.c:218
 #, c-format
 msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr "Nur eine der Optionen '%s', '%s', '%s' oder '%s' kann angegeben werden."
+msgstr ""
+"Nur eine der Optionen '%s', '%s', '%s' oder '%s' kann angegeben werden."
 #: ../general/g.proj/main.c:261
 msgid "Projection files missing"
@@ -15366,17 +16582,21 @@
 #: ../general/g.proj/main.c:281
 #, c-format
 msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
-msgstr "Nur ein Schalter von  -%c, -%c, -%c, -%c, -%c oder -%c kann angegeben werden"
+msgstr ""
+"Nur ein Schalter von  -%c, -%c, -%c, -%c, -%c oder -%c kann angegeben werden"
 #: ../general/g.proj/main.c:308
 #, c-format
 msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
-msgstr "Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c, -%c oder -%c"
+msgstr ""
+"Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c, -%c oder "
+"-%c"
 #: ../general/g.proj/main.c:312
 #, c-format
 msgid "No output format specified, define one of flags -%c, -%c, or -%c"
-msgstr "Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c oder -%c"
+msgstr ""
+"Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c oder -%c"
 #: ../general/g.proj/create.c:17
 #, c-format
@@ -15404,12 +16624,22 @@
 #: ../general/g.proj/create.c:36
 #, c-format
-msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)."
-msgstr "Sie müssen das PERMANENT-Mapset selektieren, bevor Sie die Projektion der aktuelle Location aktualisieren (aktuelles Mapset: <%s>)."
+msgid ""
+"You must select the PERMANENT mapset before updating the current location's "
+"projection (current mapset is <%s>)."
+msgstr ""
+"Sie müssen das PERMANENT-Mapset selektieren, bevor Sie die Projektion der "
+"aktuelle Location aktualisieren (aktuelles Mapset: <%s>)."
 #: ../general/g.proj/create.c:62
-msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
-msgstr "Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn Sie aber mehrere Mapsets haben, sollten Sie  `g.region -d` in jedem ausführen, um die Einstellungen von der Standardregion zu übernehmen."
+msgid ""
+"Default region was updated to the new projection, but if you have multiple "
+"mapsets `g.region -d` should be run in each to update the region from the "
+"default"
+msgstr ""
+"Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn Sie "
+"aber mehrere Mapsets haben, sollten Sie  `g.region -d` in jedem ausführen, "
+"um die Einstellungen von der Standardregion zu übernehmen."
 #: ../general/g.proj/create.c:66
 msgid "Projection information updated"
@@ -15451,8 +16681,13 @@
 #: ../general/g.proj/input.c:259
 #, c-format
-msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
-msgstr "Einlesen der Datei %s war erfolgreich, aber die Datei enthielt keine Projektionsinformationen. Location-Definition 'XY (unprojiziert)' wird benutzt."
+msgid ""
+"Read of file %s was successful, but it did not contain projection "
+"information. 'XY (unprojected)' will be used"
+msgstr ""
+"Einlesen der Datei %s war erfolgreich, aber die Datei enthielt keine "
+"Projektionsinformationen. Location-Definition 'XY (unprojiziert)' wird "
+"benutzt."
 #: ../general/g.proj/output.c:181
 #, c-format
@@ -15461,7 +16696,9 @@
 #: ../general/g.copy/main.c:44
 #, fuzzy
-msgid "Copies available data files in the current mapset search path to the user's current mapset."
+msgid ""
+"Copies available data files in the current mapset search path to the user's "
+"current mapset."
 msgstr "Kopiert die vorhandenen Daten in die aktuelle Mapset/Location."
 #: ../general/g.copy/main.c:51
@@ -15485,8 +16722,12 @@
 msgstr "<%s> existiert bereits"
 #: ../general/g.mlist/main.c:66
-msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
-msgstr "Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten Datentyps und verwende optional ein Suchmuster."
+msgid ""
+"Lists available GRASS data base files of the user-specified data type "
+"optionally using the search pattern."
+msgstr ""
+"Datentyps und verwende optional ein Suchmuster."
 #: ../general/g.mlist/main.c:81
 msgid "Map name search pattern (default: all)"
@@ -15543,12 +16784,15 @@
 #: ../general/g.remove/main.c:41
 #, fuzzy, c-format
 msgid "Raster <%s@%s> is a base map. Remove reclassed map <%s> first."
-msgstr "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
+msgstr ""
+"[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
 #: ../general/g.remove/main.c:63 ../general/g.remove/main.c:76
 #, fuzzy, c-format
 msgid "Removing information about reclassed map from <%s@%s> failed"
-msgstr "Das Löschen der Information über die reklassifizierte Karte von [%s@%s] ist fehlgeschlagen."
+msgstr ""
+"Das Löschen der Information über die reklassifizierte Karte von [%s@%s] ist "
+"fehlgeschlagen."
 #: ../general/g.remove/main.c:103 ../general/g.mremove/main.c:63
 #: ../locale/scriptstrings/t.remove_to_translate.c:4
@@ -15605,7 +16849,9 @@
 #: ../general/g.gui/main.c:70
 msgid "Do not launch GUI after updating the default GUI setting"
-msgstr "Starten Sie das GUI nicht nachdem Sie die standard GUI-Einstellungen geändert haben."
+msgstr ""
+"Starten Sie das GUI nicht nachdem Sie die standard GUI-Einstellungen "
+"geändert haben."
 #: ../general/g.gui/main.c:98
 #, c-format
@@ -15799,8 +17045,12 @@
 #: ../general/g.findfile/main.c:96
 #, c-format
-msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
-msgstr "Der Parameter 'file' enthält einen Verweis auf das Mapset <%s>, aber der Parameter Mapset <%s> stimmt damit nicht überein."
+msgid ""
+"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
+"%s> does not correspond"
+msgstr ""
+"Der Parameter 'file' enthält einen Verweis auf das Mapset <%s>, aber der "
+"Parameter Mapset <%s> stimmt damit nicht überein."
 #: ../general/g.findfile/element.c:7
 #, fuzzy
@@ -15825,13 +17075,18 @@
 msgstr "Ändere den aktuellen Mapset-Suchpfad aus."
 #: ../general/g.mapsets/main.c:67
-msgid "Affects the user's access to data existing under the other mapsets in the current location."
-msgstr "Beeinflusst beeinflusst den Zugriff des Benutzers auf Daten in anderen Mapsets in der aktuellen Location."
+msgid ""
+"Affects the user's access to data existing under the other mapsets in the "
+"current location."
+msgstr ""
+"Beeinflusst beeinflusst den Zugriff des Benutzers auf Daten in anderen "
+"Mapsets in der aktuellen Location."
 #: ../general/g.mapsets/main.c:73
 #, fuzzy
 msgid "Name(s) of existing mapset(s) to add/remove or set"
-msgstr "Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
+msgstr ""
+"Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
 #: ../general/g.mapsets/main.c:74 ../general/g.mapsets/main.c:83
 msgid "Search path"
@@ -15923,7 +17178,9 @@
 #: ../general/g.mremove/main.c:65
 #, fuzzy
-msgid "Removes data base element files from the user's current mapset using regular expressions."
+msgid ""
+"Removes data base element files from the user's current mapset using regular "
+"expressions."
 msgstr "Löscht Karten aus dem aktuellen Mapset."
 #: ../general/g.mremove/main.c:80
@@ -15966,18 +17223,23 @@
 #: ../general/g.mremove/main.c:152
 #, fuzzy, c-format
 msgid "You must use the force flag (-%c) to actually remove them. Exiting."
-msgstr "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende mich."
+msgstr ""
+"Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende "
+"mich."
 #: ../general/g.mremove/check_reclass.c:22
 #, fuzzy, c-format
 msgid "Raster map <%s@%s> is a base map. Remove reclassed map first: %s"
+msgstr ""
 #: ../general/g.mremove/check_reclass.c:45
 #: ../general/g.mremove/check_reclass.c:59
 #, c-format
 msgid "Removing information about reclassed map from [%s@%s] failed"
+msgstr ""
+"fehlgeschlagen."
 #: ../general/g.mapset/main.c:51
 #, fuzzy
@@ -15985,8 +17247,11 @@
 msgstr "Ändere aktuelles Mapset."
 #: ../general/g.mapset/main.c:52
-msgid "Optionally create new mapset or list available mapsets in given location."
-msgstr "Erzeuge optional ein neues Mapset oder liste die verfügbaren Mapsets in der Location auf."
+msgid ""
+"Optionally create new mapset or list available mapsets in given location."
+msgstr ""
+"Erzeuge optional ein neues Mapset oder liste die verfügbaren Mapsets in der "
+"Location auf."
 #: ../general/g.mapset/main.c:56
 msgid "Name of mapset where to switch"
@@ -16003,7 +17268,9 @@
 #: ../general/g.mapset/main.c:76
 #, fuzzy
 msgid "Full path to the directory where the new location is"
-msgstr "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue L0cation befindet)."
+msgstr ""
+"Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue "
+"L0cation befindet)."
 #: ../general/g.mapset/main.c:81
 msgid "Create mapset if it doesn't exist"
@@ -16037,7 +17304,8 @@
 #: ../general/g.mapset/main.c:169
 #, fuzzy, c-format
 msgid "Mapset <%s> does not exist. Use -c flag to create it."
-msgstr "Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
+msgstr ""
+"Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
 #: ../general/g.mapset/main.c:179
 msgid "Unable to read GIS_LOCK environment variable"
@@ -16051,7 +17319,9 @@
 #: ../general/g.mapset/main.c:198
 #, fuzzy, c-format
 msgid "There appears to be an active GRASS session in selected mapset <%s>"
-msgstr "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann nicht überprüft werden."
+msgstr ""
+"%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann "
+"nicht überprüft werden."
 #: ../general/g.mapset/main.c:204
 msgid "Cleaning up temporary files..."
@@ -16102,7 +17372,9 @@
 #: ../general/g.region/main.c:88
 msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr "Gebe die aktuelle Region in Lat/Long unter Verwendung des aktuellen Ellipsoid/Datum aus."
+msgstr ""
+"Gebe die aktuelle Region in Lat/Long unter Verwendung des aktuellen "
+"Ellipsoid/Datum aus."
 #: ../general/g.region/main.c:94
 msgid "Print the current region extent"
@@ -16129,8 +17401,12 @@
 msgstr "Gebe den Konvergenzwinkel aus (Grad CCW)."
 #: ../general/g.region/main.c:125
-msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
-msgstr "Die Differenz zwischen dem Gitternord der Projektion und der wahren Nordrichtung gemessen im Zentrum der aktuellen Region."
+msgid ""
+"The difference between the projection's grid north and true north, measured "
+"at the center coordinates of the current region."
+msgstr ""
+"Die Differenz zwischen dem Gitternord der Projektion und der wahren "
+"Nordrichtung gemessen im Zentrum der aktuellen Region."
 #: ../general/g.region/main.c:131
 msgid "Print also 3D settings"
@@ -16141,8 +17417,12 @@
 msgstr "Gebe die maximale Bounding-Box in Lat/Long Koordinaten in WGS84 aus."
 #: ../general/g.region/main.c:148
-msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
-msgstr "Passe Region an die Auflösung an (Standard = passe an die Grenzen an; funktioniert nur für 2D-Auflösung)."
+msgid ""
+"Align region to resolution (default = align to bounds, works only for 2D "
+"resolution)"
+msgstr ""
+"Passe Region an die Auflösung an (Standard = passe an die Grenzen an; "
+"funktioniert nur für 2D-Auflösung)."
 #: ../general/g.region/main.c:154
 msgid "Do not update the current region"
@@ -16166,7 +17446,9 @@
 #: ../general/g.region/main.c:175
 #, fuzzy
 msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
-msgstr "Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D als auch 3D-Werte)."
+msgstr ""
+"Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D als auch 3D-"
+"Werte)."
 #: ../general/g.region/main.c:183
 #, fuzzy
@@ -16222,7 +17504,9 @@
 #: ../general/g.region/main.c:323
 msgid "Shrink region until it meets non-NULL data from this raster map"
-msgstr "Schrumpfe die Region so lange, bis sie auf nicht-NULL Zellen dieser Rasterkarte stösst."
+msgstr ""
+"Schrumpfe die Region so lange, bis sie auf nicht-NULL Zellen dieser "
+"Rasterkarte stösst."
 #: ../general/g.region/main.c:334
 msgid "Adjust region cells to cleanly align with this raster map"
@@ -16230,7 +17514,9 @@
 #: ../general/g.region/main.c:345
 msgid "Save current region settings in named region file"
-msgstr "Speichere die Einstellungen der aktuellen Region in eine benannte Regions-Datei."
+msgstr ""
+"Speichere die Einstellungen der aktuellen Region in eine benannte Regions-"
+"Datei."
 #: ../general/g.region/main.c:404
 #, c-format
@@ -16278,19 +17564,30 @@
 #: ../general/g.region/main.c:815
 msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr "Kann die Standard-Region nicht ändern. Das aktuelle Mapset ist nicht <PERMANENT>."
+msgstr ""
+"Kann die Standard-Region nicht ändern. Das aktuelle Mapset ist nicht "
+"<PERMANENT>."
 #: ../general/g.region/printwindow.c:410
 msgid "You are already in Lat/Long. Use the -p flag instead."
-msgstr "Sie sind bereits in Lat/Long. Verwenden Sie den Schalter -p statt dessen."
+msgstr ""
+"Sie sind bereits in Lat/Long. Verwenden Sie den Schalter -p statt dessen."
 #: ../general/g.region/printwindow.c:412
-msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
-msgstr "Sie befinden sich in einer einfachen XY-Location. Umprojezieren nach Lat/Lon ist nicht möglich.Verwenden Sie statt dessen den Schalter -p)."
+msgid ""
+"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
+"the -p flag instead."
+msgstr ""
+"Sie befinden sich in einer einfachen XY-Location. Umprojezieren nach Lat/Lon "
+"ist nicht möglich.Verwenden Sie statt dessen den Schalter -p)."
 #: ../general/g.region/printwindow.c:637
-msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
-msgstr "WGS84 Ausgabe nicht möglich, da diese Location keine Datumstransformationsparameter enthält. Versuchen Sie g.setproj."
+msgid ""
+"WGS84 output not possible as this location does not contain datum "
+"transformation parameters. Try running g.setproj."
+msgstr ""
+"WGS84 Ausgabe nicht möglich, da diese Location keine "
+"Datumstransformationsparameter enthält. Versuchen Sie g.setproj."
 #: ../general/g.region/printwindow.c:783
 msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -16495,7 +17792,9 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:73
-msgid "Generates the font configuration file by scanning various directories for fonts."
+msgid ""
+"Generates the font configuration file by scanning various directories for "
+"fonts."
 msgstr ""
 #: ../general/g.mkfontcap/main.c:79
@@ -16503,7 +17802,8 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:84
-msgid "Write font configuration file to standard output instead of $GISBASE/etc"
+msgid ""
+"Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:91
@@ -16511,16 +17811,21 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:93
-msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
+msgid ""
+"Comma-separated list of extra directories to scan for Freetype-compatible "
+"fonts as well as the defaults (see documentation)"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:110
 #, fuzzy, c-format
-msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid ""
+"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr "Die Datei '%s' existiert bereits und wird überschrieben."
 #: ../general/g.mkfontcap/main.c:122
-msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
+msgid ""
+"This GRASS installation was compiled without Freetype support, extradirs "
+"parameter ignored"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:149
@@ -16687,7 +17992,9 @@
 #: ../db/db.select/main.c:272
 #, fuzzy
 msgid "Performs SQL query statement(s)."
-msgstr "Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) aus)."
+msgstr ""
+"Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) "
+"aus)."
 #: ../db/db.select/main.c:307
 #, c-format
@@ -16776,7 +18083,9 @@
 #: ../db/db.connect/main.c:48
 #, fuzzy
 msgid "Prints/sets general DB connection for current mapset."
-msgstr "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und beendet sich."
+msgstr ""
+"Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
+"beendet sich."
 #: ../db/db.connect/main.c:52 ../temporal/t.connect/main.c:42
 msgid "Print current connection parameters and exit"
@@ -16793,7 +18102,9 @@
 #: ../db/db.connect/main.c:64 ../temporal/t.connect/main.c:48
 msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr "Prüfe die Verbindungsparameter, setzt sie wenn nicht vorhanden und beendet sich."
+msgstr ""
+"Prüfe die Verbindungsparameter, setzt sie wenn nicht vorhanden und beendet "
+"sich."
 #: ../db/db.connect/main.c:69 ../temporal/t.connect/main.c:53
 #, fuzzy
@@ -16961,8 +18272,12 @@
 #: ../db/drivers/ogr/describe.c:192
 #, c-format
-msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
-msgstr "Spalte '%s', Typ 'string': unbekannte Breite -> als Datentyp varchar(250) abgespeichert. Einige Daten könnten verloren gehen."
+msgid ""
+"column '%s', type 'string': unknown width -> stored as varchar(250) some "
+"data may be lost"
+msgstr ""
+"Spalte '%s', Typ 'string': unbekannte Breite -> als Datentyp varchar(250) "
+"abgespeichert. Einige Daten könnten verloren gehen."
 #: ../db/drivers/odbc/cursor.c:55 ../db/drivers/sqlite/cursor.c:56
 #: ../db/drivers/postgres/cursor.c:50
@@ -17047,7 +18362,8 @@
 msgstr "Kann den Zeitstempel nicht auslesen:"
 #: ../db/drivers/sqlite/fetch.c:218
-msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgid ""
+"SQLite driver: parsing of interval values not implemented; assuming seconds"
 msgstr ""
 #: ../db/drivers/sqlite/fetch.c:223
@@ -17227,11 +18543,15 @@
 #: ../db/drivers/mysql/parse.c:72 ../db/drivers/postgres/parse.c:59
 msgid "'user' in database definition is not supported, use db.login"
-msgstr "'user' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' verwenden."
+msgstr ""
+"'user' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' "
+"verwenden."
 #: ../db/drivers/mysql/parse.c:76 ../db/drivers/postgres/parse.c:63
 msgid "'password' in database definition is not supported, use db.login"
-msgstr "'Password' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' verwenden."
+msgstr ""
+"'Password' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db."
+"login' verwenden."
 #: ../db/drivers/mysql/parse.c:81
 #, fuzzy
@@ -17260,8 +18580,12 @@
 #: ../db/drivers/mysql/describe.c:127
 #, c-format
-msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
-msgstr "Spalte '%s' : Typ BIGINT wird als integer (4 Byte) abgespeichert. Einige Datensätze könnten beschädigt sein."
+msgid ""
+"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
+"damaged"
+msgstr ""
+"Spalte '%s' : Typ BIGINT wird als integer (4 Byte) abgespeichert. Einige "
+"Datensätze könnten beschädigt sein."
 #: ../db/drivers/dbf/cursor.c:47
 #, fuzzy
@@ -17567,18 +18891,30 @@
 #: ../db/drivers/postgres/describe.c:130
 #, c-format
-msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
-msgstr "Spalte '%s' : Typ int8 (bigint) wird als integer (4 Byte) abgespeichert. Einige Datensätze könnten beschädigt sein."
+msgid ""
+"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
+"may be damaged"
+msgstr ""
+"Spalte '%s' : Typ int8 (bigint) wird als integer (4 Byte) abgespeichert. "
+"Einige Datensätze könnten beschädigt sein."
 #: ../db/drivers/postgres/describe.c:134
 #, c-format
-msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
-msgstr "Spalte '%s' : Typ 'character' wird als Typ varchar(250) abgespeichert. Einige Daten könnten verloren gehen."
+msgid ""
+"column '%s' : type character varying is stored as varchar(250) some data may "
+"be lost"
+msgstr ""
+"Spalte '%s' : Typ 'character' wird als Typ varchar(250) abgespeichert. "
+"Einige Daten könnten verloren gehen."
 #: ../db/drivers/postgres/describe.c:140
 #, c-format
-msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
-msgstr "Spalte '%s' : Typ bool (boolean) wird als Typ char(1) mit den Werten 0 (falsch), 1 (wahr) abgespeichert."
+msgid ""
+"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
+"(true)"
+msgstr ""
+"Spalte '%s' : Typ bool (boolean) wird als Typ char(1) mit den Werten 0 "
+"(falsch), 1 (wahr) abgespeichert."
 #: ../db/db.drivers/main.c:39
 #, fuzzy
@@ -17602,8 +18938,13 @@
 msgstr "Kopiere eine Tabelle."
 #: ../db/db.copy/main.c:40
-msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
-msgstr "Es kann entweder die Option 'from_table' (auch mit 'WHERE') oder die 'select'-Option verwendet werden, aber nicht 'from_table' und 'select' können zur selben Zeit."
+msgid ""
+"Either 'from_table' (optionally with 'where') can be used or 'select' "
+"option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+"Es kann entweder die Option 'from_table' (auch mit 'WHERE') oder die "
+"'select'-Option verwendet werden, aber nicht 'from_table' und 'select' "
+"können zur selben Zeit."
 #: ../db/db.copy/main.c:46
 msgid "Input driver name"
@@ -17615,7 +18956,8 @@
 #: ../db/db.copy/main.c:59
 msgid "Input table name (only, if 'select' is not used)"
-msgstr "Name der Eingabe-Tabelle (nur wenn 'SELECT'-Statement nicht benutzt wird)."
+msgstr ""
+"Name der Eingabe-Tabelle (nur wenn 'SELECT'-Statement nicht benutzt wird)."
 #: ../db/db.copy/main.c:65
 msgid "Output driver name"
@@ -17631,7 +18973,9 @@
 #: ../db/db.copy/main.c:87
 msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr "Vollständiger Select-Ausdruck (nur wenn 'from_table' und 'where' nicht verwendet werden)."
+msgstr ""
+"Vollständiger Select-Ausdruck (nur wenn 'from_table' und 'where' nicht "
+"verwendet werden)."
 #: ../db/db.copy/main.c:88
 msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
@@ -17809,7 +19153,8 @@
 #: ../misc/m.transform/main.c:320
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
 msgid "Computes a coordinate transformation based on the control points."
-msgstr "Berechnet eine Koordinatentransformation basierend auf Kontrollpunkten."
+msgstr ""
+"Berechnet eine Koordinatentransformation basierend auf Kontrollpunkten."
 #: ../misc/m.transform/main.c:329
 msgid "Rectification polynomial order"
@@ -17881,7 +19226,9 @@
 #: ../misc/m.transform/main.c:361
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-msgstr "Datei mit zu transformierenden Koordinaten (oder \"-\" um von stdin zu lesen)."
+msgstr ""
+"Datei mit zu transformierenden Koordinaten (oder \"-\" um von stdin zu "
+"lesen)."
 #: ../misc/m.transform/main.c:362
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
@@ -17904,8 +19251,12 @@
 msgstr "Zeige Transformationsmatrix Koeffizienten."
 #: ../misc/m.cogo/main.c:229
-msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
-msgstr "Ein einfaches Hilfsprogramm, dass Kurs- und Distanzwert in Koordinaten umrechnet und umgekehrt."
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa."
+msgstr ""
+"Ein einfaches Hilfsprogramm, dass Kurs- und Distanzwert in Koordinaten "
+"umrechnet und umgekehrt."
 #: ../misc/m.cogo/main.c:231
 msgid "It assumes a cartesian coordinate system"
@@ -17976,8 +19327,12 @@
 msgstr "Erzeugt eine 3D Darstellung aus GIS Daten."
 #: ../misc/m.nviz.image/main.c:56
-msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
-msgstr "Darstellung von Oberflächen (Rasterdaten), 2D/3D Vektordaten und Volumen (3D Rasterdaten) in 3D."
+msgid ""
+"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
+"data) in 3D."
+msgstr ""
+"Darstellung von Oberflächen (Rasterdaten), 2D/3D Vektordaten und Volumen (3D "
+"Rasterdaten) in 3D."
 #: ../misc/m.nviz.image/main.c:82
 #, fuzzy
@@ -17987,12 +19342,15 @@
 #: ../misc/m.nviz.image/main.c:141
 #, c-format
 msgid "Vertical exaggeration not given, using calculated value %.0f"
-msgstr "Vertikale Überhöhung wurde nicht spezifiziert, verwende den berechneten Wert %.0f."
+msgstr ""
+"Vertikale Überhöhung wurde nicht spezifiziert, verwende den berechneten Wert "
+"%.0f."
 #: ../misc/m.nviz.image/main.c:153
 #, c-format
 msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr "Höhe des Betrachters nicht spezifiziert, verwende den berechneten Wert %.0f."
+msgstr ""
+"Höhe des Betrachters nicht spezifiziert, verwende den berechneten Wert %.0f."
 #: ../misc/m.nviz.image/main.c:239
 msgid "Unsupported output format"
@@ -18317,7 +19675,8 @@
 #: ../misc/m.nviz.image/args.c:582
 msgid "Focus to point on surface (from SW corner in map units)"
-msgstr "Fokussiere auf Punkt auf der Oberfläche (von SW Ecke in Karteneinheiten)"
+msgstr ""
+"Fokussiere auf Punkt auf der Oberfläche (von SW Ecke in Karteneinheiten)"
 #: ../misc/m.nviz.image/args.c:592 ../misc/m.nviz.image/args.c:627
 #: ../misc/m.nviz.image/args.c:639 ../misc/m.nviz.image/args.c:649
@@ -18477,8 +19836,12 @@
 msgstr "Höhe der Randzone"
 #: ../misc/m.nviz.image/args.c:900
-msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
-msgstr "Platziere den Nordpfeil an der angegeben Position \t(in Bildschirmkoordinaten von der unteren linken Ecke)"
+msgid ""
+"Place north arrow at given position \t(in screen coordinates from bottom "
+"left corner)"
+msgstr ""
+"Platziere den Nordpfeil an der angegeben Position \t(in "
+"Bildschirmkoordinaten von der unteren linken Ecke)"
 #: ../misc/m.nviz.image/args.c:902 ../misc/m.nviz.image/args.c:912
 #: ../misc/m.nviz.image/args.c:919
@@ -18615,7 +19978,8 @@
 #: ../misc/m.nviz.script/main.c:148
 msgid "Either -i flag and/or route parameter must be used"
-msgstr "Entweder der Parameter '-i' und/oder Routen-Parameter muss gesetzt werden."
+msgstr ""
+"Entweder der Parameter '-i' und/oder Routen-Parameter muss gesetzt werden."
 #: ../misc/m.nviz.script/main.c:172
 msgid "Off-screen only available with full render mode"
@@ -18632,8 +19996,13 @@
 msgstr "Habe NVIZ-Skript <%s> erzeugt."
 #: ../misc/m.nviz.script/main.c:439
-msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
-msgstr "Lasse diesen Punkt aus, der selektierte Punkt liegt außerhalb der Region. Vielleicht ist der Kameraabstand zu weit, sodass der Punkt hinter die Kante gerutscht ist?"
+msgid ""
+"Skipping this point, selected point is outside region. Perhaps the camera "
+"setback distance puts it beyond the edge?"
+msgstr ""
+"Lasse diesen Punkt aus, der selektierte Punkt liegt außerhalb der Region. "
+"Vielleicht ist der Kameraabstand zu weit, sodass der Punkt hinter die Kante "
+"gerutscht ist?"
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
 msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
@@ -18653,11 +20022,14 @@
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
 msgid "Name for output vector map (omit for display to stdout)"
-msgstr "Name der Ausgabe-Vektorausgabekarte (auslassen für Ausgabe auf stdout)."
+msgstr ""
+"Name der Ausgabe-Vektorausgabekarte (auslassen für Ausgabe auf stdout)."
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
 #, fuzzy
-msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
+msgid ""
+"Creates/modifies the color table associated with each raster map of the "
+"space time raster dataset."
 msgstr "Erzeugt/verändert die Farbtabelle einer Rasterkarte."
 #: ../locale/scriptstrings/t.rast.colors_to_translate.c:2
@@ -18720,7 +20092,9 @@
 msgstr "Lösche existierende Farbtabelle."
 #: ../locale/scriptstrings/t.select_to_translate.c:1
-msgid "Select maps from space time datasets by topological relationships to other space time datasets using temporal algebra."
+msgid ""
+"Select maps from space time datasets by topological relationships to other "
+"space time datasets using temporal algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.select_to_translate.c:4
@@ -18760,16 +20134,23 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid "Renames a column in the attribute table connected to a given vector map."
-msgstr "Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten Vektorkarte um."
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+"Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten "
+"Vektorkarte um."
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
 msgid "Old and new name of the column (old,new)"
 msgstr "Alter und neuer Name der Spalte (alt,neu)."
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
-msgstr "Importiert LÄnderdateien vom US-NGA GEOnet Names Server (GNS) in eine Vektorpunktkarte."
+msgid ""
+"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
+"points map."
+msgstr ""
+"Importiert LÄnderdateien vom US-NGA GEOnet Names Server (GNS) in eine "
+"Vektorpunktkarte."
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:4
 #: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
@@ -18787,7 +20168,8 @@
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
 msgid "Force removal (required for actual deletion of table)"
-msgstr "Erzwinge das Löschen (erforderlich um tatsächlich die Tabelle zu löschen)."
+msgstr ""
+"Erzwinge das Löschen (erforderlich um tatsächlich die Tabelle zu löschen)."
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
 #, fuzzy
@@ -18797,7 +20179,9 @@
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
 #, fuzzy
 msgid "Drapes a color raster over a shaded relief map."
-msgstr "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter Verwendung von d.his."
+msgstr ""
+"Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter "
+"Verwendung von d.his."
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
 #, fuzzy
@@ -18818,14 +20202,19 @@
 msgstr "Erzeugt eine Rasterkarte vom Ergebnis (optional)."
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
-msgstr "Berechnet univariate Statistiken von ausgewählten Spalten einer Vektorkarte."
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
+msgstr ""
+"Berechnet univariate Statistiken von ausgewählten Spalten einer Vektorkarte."
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
 #: ../locale/scriptstrings/db.univar_to_translate.c:5
 #, fuzzy
-msgid "Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
+msgid ""
+"Name of attribute column on which to calculate statistics (must be numeric)"
+msgstr ""
+"Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:7
 #: ../locale/scriptstrings/db.univar_to_translate.c:7
@@ -18882,23 +20271,33 @@
 msgstr "Anzahl Spalten, die in der Farbtabelle erscheinen sollen"
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:1
-msgid "Detect accumulation pattern in temporally accumulated space time raster datasets created by t.rast.accumulate."
+msgid ""
+"Detect accumulation pattern in temporally accumulated space time raster "
+"datasets created by t.rast.accumulate."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:4
-msgid "Input space time raster dataset that specifies the minimum values to detect the accumulation pattern"
+msgid ""
+"Input space time raster dataset that specifies the minimum values to detect "
+"the accumulation pattern"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:5
-msgid "Input space time raster dataset that specifies the maximum values to detect the accumulation pattern"
+msgid ""
+"Input space time raster dataset that specifies the maximum values to detect "
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
-msgid "The output space time raster dataset that stores the occurrence of the the accumulation pattern using the provided data range"
+msgid ""
+"The output space time raster dataset that stores the occurrence of the the "
+"accumulation pattern using the provided data range"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
-msgid "The output space time raster dataset that stores the indication of the start, intermediate and end of the specified data range"
+msgid ""
+"The output space time raster dataset that stores the indication of the "
+"start, intermediate and end of the specified data range"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
@@ -18947,19 +20346,28 @@
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
-msgid "A numerical suffix separated by an underscore will be attached to create a unique identifier"
+msgid ""
+"A numerical suffix separated by an underscore will be attached to create a "
+"unique identifier"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:14
-msgid "The minimum and maximum value of the occurrence of accumulated values, these values will be used if the min/max space time raster datasets are not specified"
+msgid ""
+"The minimum and maximum value of the occurrence of accumulated values, these "
+"values will be used if the min/max space time raster datasets are not "
+"specified"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:15
-msgid "The user defined values that indicate start, intermediate and end status in the indicator output space time raster dataset"
+msgid ""
+"The user defined values that indicate start, intermediate and end status in "
+"the indicator output space time raster dataset"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
-msgid "Register empty maps in the output space time raster datasets, otherwise they will be deleted"
+msgid ""
+"Register empty maps in the output space time raster datasets, otherwise they "
+"will be deleted"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
@@ -19005,7 +20413,8 @@
 msgstr "Eingabe-Rasterkarten"
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid "Drops a column from the attribute table connected to a given vector map."
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
 msgstr "Löscht eine Spalte der Attributtabelle einer Vektorkarte."
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
@@ -19014,13 +20423,20 @@
 msgstr "Name der Spalte"
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
-msgstr "Konvertiert alle alten GRASS Vektorkarten im aktuellen Mapset in das aktuelle Format."
+msgid ""
+"Converts all older versions of GRASS vector maps in current mapset to "
+"current format."
+msgstr ""
+"Konvertiert alle alten GRASS Vektorkarten im aktuellen Mapset in das "
+"aktuelle Format."
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
 #, fuzzy
-msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
+msgid ""
+"Calculates univariate statistics from the non-null cells for each registered "
+"raster map of a space time raster dataset."
+msgstr ""
 #: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
 #: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
@@ -19080,7 +20496,9 @@
 #: ../locale/scriptstrings/db.test_to_translate.c:1
 msgid "Test database driver, database must exist and set by db.connect."
-msgstr "Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db.connect verbunden sein."
+msgstr ""
+"Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db."
+"connect verbunden sein."
 #: ../locale/scriptstrings/db.test_to_translate.c:4
 msgid "Test name"
@@ -19107,7 +20525,9 @@
 #: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:1
 #, fuzzy
-msgid "Apply temporal and spatial oeprations on space time 3D raster datasets using temporal raster algebra."
+msgid ""
+"Apply temporal and spatial oeprations on space time 3D raster datasets using "
+"temporal raster algebra."
 msgstr "Konvertiert 3D-Rasterkarten in 2D-Rasterkarten."
 #: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:3
@@ -19119,12 +20539,16 @@
 #: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:4
 #, fuzzy
-msgid "The mapcalc expression for temporal and spatial analysis of space time 3D raster datasets."
+msgid ""
+"The mapcalc expression for temporal and spatial analysis of space time 3D "
+"raster datasets."
 msgstr "Liste die Vektorkarten der Eingabe-Location und beendet sich."
 #: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:5
 #, fuzzy
-msgid "The basename of raster maps that are stored within the result space time 3D raster dataset."
+msgid ""
+"The basename of raster maps that are stored within the result space time 3D "
+"raster dataset."
 msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
 #: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:6
@@ -19135,8 +20559,11 @@
 msgstr "Anzahl der zu bestimmenden Klassen"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid "Displays spectral response at user specified locations in group or images."
-msgstr "Zeige die Farbempfindlichkeit an Benutzerdefinierten Stellen in der Gruppe oder in Bilderen."
+msgid ""
+"Displays spectral response at user specified locations in group or images."
+msgstr ""
+"Zeige die Farbempfindlichkeit an Benutzerdefinierten Stellen in der Gruppe "
+"oder in Bilderen."
 #: ../locale/scriptstrings/i.spectral_to_translate.c:2
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
@@ -19223,7 +20650,9 @@
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:9
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-msgid "Create a new location and import the data into it. Please do not run this module in parallel or interrupt it when a new location should be created."
+msgid ""
+"Create a new location and import the data into it. Please do not run this "
+"module in parallel or interrupt it when a new location should be created."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:10
@@ -19242,7 +20671,9 @@
 msgstr "Vergrößere die Location basierend auf dem neuen Datensatz."
 #: ../locale/scriptstrings/t.rast.import_to_translate.c:14
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time raster datasets."
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the space time raster datasets."
 msgstr ""
 #: ../locale/scriptstrings/d.redraw_to_translate.c:1
@@ -19289,7 +20720,9 @@
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:9
-msgid "Use online manuals available at http://grass.osgeo.org website. This flag has no effect when displaying MAN text pages."
+msgid ""
+"Use online manuals available at http://grass.osgeo.org website. This flag "
+"has no effect when displaying MAN text pages."
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:10
@@ -19333,7 +20766,9 @@
 msgstr "Name der Expositions-Rasterkarte."
 #: ../locale/scriptstrings/t.vect.import_to_translate.c:10
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the space time vector datasets."
+msgid ""
+"import the space time vector datasets."
 msgstr ""
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
@@ -19343,7 +20778,9 @@
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
 msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr "Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-Karte."
+msgstr ""
+"Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-"
+"Karte."
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
 #, fuzzy
@@ -19367,7 +20804,8 @@
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
 msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr "Fülle Flächen ohne Daten in Rasterkarten mit Hilfe von Spline-Interpolation."
+msgstr ""
+"Fülle Flächen ohne Daten in Rasterkarten mit Hilfe von Spline-Interpolation."
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
 msgid "Interpolation method"
@@ -19485,7 +20923,8 @@
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
 #, fuzzy
-msgid "Prints attributes of vector maps registered in a space time vector dataset."
+msgid ""
+"Prints attributes of vector maps registered in a space time vector dataset."
 #: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
@@ -19501,21 +20940,32 @@
 #: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
 #, fuzzy
-msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
+msgid ""
+"Calculates univariate statistics of attributes for each registered vector "
+"map of a space time vector dataset"
+msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
 #, fuzzy
-msgid "Store raster map values at spatial and temporal positions of vector points as vector attributes."
-msgstr "Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die Attributtabelle."
+msgid ""
+"Store raster map values at spatial and temporal positions of vector points "
+"as vector attributes."
+msgstr ""
+"Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die "
+"Attributtabelle."
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
 #, fuzzy
-msgid "Name of the vector column to be created and to store sampled raster values"
+msgid ""
+"Name of the vector column to be created and to store sampled raster values"
 msgstr "Name der Attribut-Spalte die für die Label benutzt werden soll."
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
-msgid "The use of a column name forces t.vect.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names"
+msgid ""
+"The use of a column name forces t.vect.what.rast to sample only values from "
+"the first map found in an interval. Otherwise the raster map names are used "
+"as column names"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
@@ -19527,8 +20977,11 @@
 msgstr "Namen einer oder mehrerer Eingabe-Rasterkarten."
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr "Konvertiert alle alten GRASS < Ver5.7 'Site'-karten im aktuellen Mapset zu Vektorkarten."
+msgid ""
+"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgstr ""
+"Konvertiert alle alten GRASS < Ver5.7 'Site'-karten im aktuellen Mapset zu "
+"Vektorkarten."
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
 #: ../vector/v.in.sites/main.c:59
@@ -19537,8 +20990,12 @@
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
 #, fuzzy
-msgid "Create a 3D raster map from an assemblage of many coordinates using univariate statistics"
-msgstr "Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung univariater Statistik."
+msgid ""
+"Create a 3D raster map from an assemblage of many coordinates using "
+"univariate statistics"
+msgstr ""
+"Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung "
+"univariater Statistik."
 #: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
 #, fuzzy
@@ -19645,7 +21102,9 @@
 #: ../locale/scriptstrings/d.polar_to_translate.c:1
 msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr "Zeichne ein Polardiagramm einer Karte mit Winkelangaben, so wie Expositionen oder Fließrichtungen."
+msgstr ""
+"Zeichne ein Polardiagramm einer Karte mit Winkelangaben, so wie Expositionen "
+"oder Fließrichtungen."
 #: ../locale/scriptstrings/d.polar_to_translate.c:3
 #: ../locale/scriptstrings/d.correlate_to_translate.c:5
@@ -19659,7 +21118,9 @@
 #: ../locale/scriptstrings/d.polar_to_translate.c:5
 msgid "Pixel value to be interpreted as undefined (different from NULL)"
-msgstr "Pixelwert der als undefiniert interpretiert werden soll (unterschiedlich von NULL)."
+msgstr ""
+"Pixelwert der als undefiniert interpretiert werden soll (unterschiedlich von "
+"NULL)."
 #: ../locale/scriptstrings/d.polar_to_translate.c:6
 #, fuzzy
@@ -19672,8 +21133,12 @@
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
 #, fuzzy
-msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
-msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
+msgid ""
+"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
+"channels"
+msgstr ""
+"Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
+"panchromatischer Kanäle."
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
 msgid "fusion"
@@ -19722,7 +21187,9 @@
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:13
 #, fuzzy
 msgid "Input raster map for high resolution panchromatic channel"
+msgstr ""
 #: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:15
@@ -19740,7 +21207,8 @@
 #, fuzzy
-msgid "Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
+msgid ""
+"Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
 msgstr "Tasseled Cap (Kauth Thomas) Transformation für LANDSAT-TM Daten."
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:4
@@ -19801,7 +21269,9 @@
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
 #, fuzzy
-msgid "Perform spatio-temporal mapcalc expressions on temporal sampled maps of space time raster datasets."
+msgid ""
+"Perform spatio-temporal mapcalc expressions on temporal sampled maps of "
+"space time raster datasets."
 #: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
@@ -19861,16 +21331,22 @@
 msgstr "Verwende die Version des Programms mit geringem Speicherverbrauch. "
 #: ../locale/scriptstrings/t.rast.export_to_translate.c:7
-msgid "The export format of a single raster map. Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of r.pack."
+msgid ""
+"The export format of a single raster map. Supported are GTiff, AAIGrid via r."
+"out.gdal and the GRASS package format of r.pack."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:1
 #, fuzzy
-msgid "Temporally aggregates the maps of a space time raster dataset by a user defined granularity."
+msgid ""
+"Temporally aggregates the maps of a space time raster dataset by a user "
+"defined granularity."
 #: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:6
-msgid "Aggregation granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
+msgid ""
+"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
+"x days, x hours, x minutes, x seconds\" or an integer value for relative time"
 msgstr ""
 #: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
@@ -19895,8 +21371,12 @@
 msgstr "Name für automatisch erzeugte Schlüsselwert-Spalte."
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
-msgstr "Erzeugt eine neue Attributtabelle und sie zu einem Layer einer existierenden Vektorkarte."
+msgid ""
+"Creates and connects a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+"Erzeugt eine neue Attributtabelle und sie zu einem Layer einer existierenden "
+"Vektorkarte."
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
 msgid "Name of new attribute table (default: vector map name)"
@@ -19922,8 +21402,12 @@
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
 #, fuzzy
-msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: \"label varchar(250), type integer\""
-msgstr "Datentyp hängt von der verwendeten Datenbank ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION und DATE."
+msgid ""
+"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
+"PRECISION and DATE. Example: \"label varchar(250), type integer\""
+msgstr ""
+"Datentyp hängt von der verwendeten Datenbank ab, aber alle unterstützen "
+"VARCHAR(), INT, DOUBLE PRECISION und DATE."
 #: ../locale/scriptstrings/t.rename_to_translate.c:1
 #, fuzzy
@@ -19947,7 +21431,8 @@
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
 #, fuzzy
-msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
+msgid ""
+"Performs a neighborhood analysis for each map in a space time raster dataset."
 #: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:8
@@ -19961,11 +21446,15 @@
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:4
-msgid "Input space time raster dataset that defines the lower threshold, values lower this threshold are excluded from accumulation"
+msgid ""
+"Input space time raster dataset that defines the lower threshold, values "
+"lower this threshold are excluded from accumulation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:5
-msgid "Input space time raster dataset that defines the upper threshold, values upper this threshold are excluded from accumulation"
+msgid ""
+"Input space time raster dataset that defines the upper threshold, values "
+"upper this threshold are excluded from accumulation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:10
@@ -19973,7 +21462,9 @@
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:13
-msgid "Use these limits in case lower and/or upper input  space time raster datasets are not defined"
+msgid ""
+"Use these limits in case lower and/or upper input  space time raster "
+"datasets are not defined"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:14
@@ -19987,16 +21478,24 @@
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
-msgid "This method will be applied to compute the accumulative values from the input maps"
+msgid ""
+"This method will be applied to compute the accumulative values from the "
+"input maps"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
-msgid "Register empty maps in the output space time raster dataset, otherwise they will be deleted"
+msgid ""
+"Register empty maps in the output space time raster dataset, otherwise they "
+"will be deleted"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid "Produces tilings of the source projection for use in the destination region and projection."
-msgstr "Erzeugt Kacheln der der Quell-Projektion zur Verwendung in der Ziel-Region und -Projektion."
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+"Erzeugt Kacheln der der Quell-Projektion zur Verwendung in der Ziel-Region "
+"und -Projektion."
 #: ../locale/scriptstrings/r.tileset_to_translate.c:4
 msgid "Produces shell script output"
@@ -20007,8 +21506,11 @@
 msgstr "Erzeugt ein Web Map Server Query-String."
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid "Name of region to use instead of current region for bounds and resolution"
-msgstr "Name der Region die anstelle der aktuellen Region für die Ausdehnung (bounding box) und Auflösung verwendet werden soll."
+msgid ""
+"Name of region to use instead of current region for bounds and resolution"
+msgstr ""
+"Name der Region die anstelle der aktuellen Region für die Ausdehnung "
+"(bounding box) und Auflösung verwendet werden soll."
 #: ../locale/scriptstrings/r.tileset_to_translate.c:7
 msgid "Source projection"
@@ -20080,7 +21582,9 @@
 #: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
 #, fuzzy
 msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
+msgstr ""
+"Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer "
+"numerischen Spalte der Attributtabelle."
 #: ../locale/scriptstrings/t.info_to_translate.c:1
 #, fuzzy
@@ -20099,7 +21603,9 @@
 #: ../locale/scriptstrings/t.info_to_translate.c:9
 #, fuzzy
-msgid "Print history information in human readable shell style for space time datasets"
+msgid ""
+"Print history information in human readable shell style for space time "
+"datasets"
 msgstr "Schöne Ausgabe in menschenlesbaren Format."
 #: ../locale/scriptstrings/t.info_to_translate.c:10
@@ -20122,8 +21628,12 @@
 msgstr "Name der 3D Eingabe-Rasterkarte."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
-msgstr "Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder gleichem Attributwert auf."
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+"Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder "
+"gleichem Attributwert auf."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:3
 msgid "dissolve"
@@ -20143,7 +21653,9 @@
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:6
 #, fuzzy
 msgid "Name of attribute column used to dissolve common boundaries"
-msgstr "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden soll."
+msgstr ""
+"Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden "
+"soll."
 #: ../locale/scriptstrings/r.mask_to_translate.c:1
 msgid "Creates a MASK for limiting raster operation."
@@ -20216,7 +21728,9 @@
 msgstr ""
 #: ../locale/scriptstrings/t.shift_to_translate.c:8
-msgid "Shift granularity, format absolute time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or an integer value for relative time"
+msgid ""
+"Shift granularity, format absolute time \"x years, x months, x weeks, x "
+"days, x hours, x minutes, x seconds\" or an integer value for relative time"
 msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
@@ -20245,7 +21759,9 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
 msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr "Name der Attribut-Spalte, die für die thematische Darstellung (muß umerisch sein)."
+msgstr ""
+"Name der Attribut-Spalte, die für die thematische Darstellung (muß umerisch "
+"sein)."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
 msgid "Type of thematic display"
@@ -20282,11 +21798,15 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
 msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr "Kleinste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/Linien."
+msgstr ""
+"Kleinste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/"
+"Linien."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
 msgid "Maximum icon size/line width for graduated points and lines"
-msgstr "Größste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/Linien."
+msgstr ""
+"Größste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/"
+"Linien."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
 msgid "Number of classes for interval theme (integer)"
@@ -20318,7 +21838,8 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
 msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr "GRASS Farbnamen oder R:G:B Triplets. Setze das Farbschema auf eine Farbe."
+msgstr ""
+"GRASS Farbnamen oder R:G:B Triplets. Setze das Farbschema auf eine Farbe."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
 msgid "Color for graduated lines or point/area outlines"
@@ -20326,7 +21847,8 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
 msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
+msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:33
 msgid "Beginning color for custom color gradient"
@@ -20360,11 +21882,15 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
 msgid "Save thematic map commands to group file for GIS Manager"
-msgstr "Speichere die Befehle zur Erstellung der thematischen Karte in die group-Datei für den GIS-Manager."
+msgstr ""
+"Speichere die Befehle zur Erstellung der thematischen Karte in die group-"
+"Datei für den GIS-Manager."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
 msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr "Dateiname (ohne Dateiendung) für die psmap-Datei. Die Datei wird im aktuellen Verzeichnis gespeichert."
+msgstr ""
+"Dateiname (ohne Dateiendung) für die psmap-Datei. Die Datei wird im "
+"aktuellen Verzeichnis gespeichert."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
 msgid "If not set, no psmap instruction files will be created)"
@@ -20372,7 +21898,9 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
 msgid "Name of group file where thematic map commands will be saved"
-msgstr "Name der group-Datei, in der die Befehle zur Erstellung der thematischen Karte gespeichert werden."
+msgstr ""
+"Name der group-Datei, in der die Befehle zur Erstellung der thematischen "
+"Karte gespeichert werden."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
 msgid "Create graphic legend in x11 display monitor"
@@ -20388,7 +21916,9 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
 msgid "Output legend for GIS Manager (for scripting use only)"
-msgstr "Gebe die Legende für den GIS-Maneger aus (nur für die Verwendung in Skripten)."
+msgstr ""
+"Gebe die Legende für den GIS-Maneger aus (nur für die Verwendung in "
+"Skripten)."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:58
 msgid "Use math notation brackets in legend"
@@ -20397,7 +21927,8 @@
 #: ../locale/scriptstrings/db.univar_to_translate.c:1
 #, fuzzy
 msgid "Calculates univariate statistics on selected table column."
+msgstr ""
 #: ../locale/scriptstrings/t.rast.list_to_translate.c:1
 #, fuzzy
@@ -20425,7 +21956,9 @@
 msgstr "Text für die Einheit der Daten der Karte."
 #: ../locale/scriptstrings/t.rast.list_to_translate.c:9
-msgid "The granule to be used for listing. The granule must be specified as string eg.: absolute time \"1 months\" or relative time \"1\""
+msgid ""
+"The granule to be used for listing. The granule must be specified as string "
+"eg.: absolute time \"1 months\" or relative time \"1\""
 msgstr ""
 #: ../locale/scriptstrings/t.rast.list_to_translate.c:10
@@ -20451,7 +21984,9 @@
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
 #, fuzzy
 msgid "Mosaics several images and extends colormap."
-msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
+msgstr ""
+"Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-"
+"Karten."
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
 msgid "mosaicking"
@@ -20513,7 +22048,10 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid "WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+msgid ""
+"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
+"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
+"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:17
@@ -20563,7 +22101,9 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-msgid "Capabilities file to parse (input). It is relevant for WMTS_GRASS and OnEarth_GRASS drivers"
+msgid ""
+"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
+"OnEarth_GRASS drivers"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:36
@@ -20586,7 +22126,9 @@
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
-msgid "The number of v.extract processes to run in parallel. Use only if database backend is used which supports concurrent writing"
+msgid ""
+"The number of v.extract processes to run in parallel. Use only if database "
+"backend is used which supports concurrent writing"
 msgstr ""
 #: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
@@ -20609,8 +22151,12 @@
 #: ../locale/scriptstrings/v.db.update_to_translate.c:7
 #, fuzzy
-msgid "Name of other attribute column to query, can be combination of columns (e.g. co1+col2)"
-msgstr "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
+msgid ""
+"Name of other attribute column to query, can be combination of columns (e.g. "
+"co1+col2)"
+msgstr ""
+"Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in "
+"einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
 #: ../locale/scriptstrings/db.droptable_to_translate.c:1
 msgid "Drops an attribute table."
@@ -20668,7 +22214,8 @@
 msgstr "Präfix wo Erweiterungen installiert werden"
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:2
-msgid "By default only extensions built against different GIS Library are rebuilt."
+msgid ""
+"By default only extensions built against different GIS Library are rebuilt."
 msgstr ""
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:4
@@ -20692,12 +22239,16 @@
 #: ../locale/scriptstrings/g.extension.all_to_translate.c:7
 #, fuzzy
 msgid "Force operation (required for removal)"
+msgstr ""
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:1
 #, fuzzy
-msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
-msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+msgid ""
+"Performs different aggregation algorithms from r.series on all or a subset "
+"of raster maps in a space time raster dataset."
+msgstr ""
+"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:5
 #, fuzzy
@@ -20706,22 +22257,30 @@
 #: ../locale/scriptstrings/t.rast.series_to_translate.c:6
 #, fuzzy
-msgid "Do not assign the space time raster dataset start and end time to the output map"
+msgid ""
+"Do not assign the space time raster dataset start and end time to the output "
+"map"
 #: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:1
 #, fuzzy
-msgid "Apply temporal and spatial oeprations on space time raster datasets using temporal raster algebra."
+msgid ""
+"Apply temporal and spatial oeprations on space time raster datasets using "
 #: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:4
 #, fuzzy
-msgid "The mapcalc expression for temporal and spatial analysis of space time raster datasets."
+msgid ""
+"The mapcalc expression for temporal and spatial analysis of space time "
+"raster datasets."
 #: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:5
 #, fuzzy
-msgid "The basename of raster maps that are stored within the result space time raster dataset."
+msgid ""
+"The basename of raster maps that are stored within the result space time "
+"raster dataset."
 #: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:1
@@ -20732,7 +22291,9 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:1
 #, fuzzy
 msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs Frontend)."
+msgstr ""
+"Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs "
+"Frontend)."
 #: ../locale/scriptstrings/m.proj_to_translate.c:4
 #, fuzzy
@@ -20759,7 +22320,9 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:9
 #, fuzzy
 msgid "Name for output coordinate file (omit to send to stdout)"
-msgstr "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden soll)."
+msgstr ""
+"Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden "
+"soll)."
 #: ../locale/scriptstrings/m.proj_to_translate.c:11
 #, fuzzy
@@ -20787,15 +22350,21 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:18
 msgid "Use LL WGS84 as input and current location as output projection"
-msgstr "Verwende LL WGS84 als Eingabe-Projektion und aktuelle Loaction als Ausgabe-Projektion."
+msgstr ""
+"Verwende LL WGS84 als Eingabe-Projektion und aktuelle Loaction als Ausgabe-"
+"Projektion."
 #: ../locale/scriptstrings/m.proj_to_translate.c:20
 msgid "Use current location as input and LL WGS84 as output projection"
 msgstr "Verwende LL WGS84 als Eingabe-Projektion und Ausgabe-Projektion."
 #: ../locale/scriptstrings/m.proj_to_translate.c:22
-msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
-msgstr "Gebe long/lat in Dezimalgrad oder anderen Projektionen mit vielen Dezimalstellen aus"
+msgid ""
+"Output long/lat in decimal degrees, or other projections with many decimal "
+"places"
+msgstr ""
+"Gebe long/lat in Dezimalgrad oder anderen Projektionen mit vielen "
+"Dezimalstellen aus"
 #: ../locale/scriptstrings/m.proj_to_translate.c:24
 #, fuzzy
@@ -20810,7 +22379,8 @@
 #: ../locale/scriptstrings/t.list_to_translate.c:1
 #, fuzzy
 msgid "List space time datasets and maps registered in the temporal database."
-msgstr "Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
+msgstr ""
+"Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
 #: ../locale/scriptstrings/t.list_to_translate.c:5
 #, fuzzy
@@ -20819,7 +22389,8 @@
 #: ../locale/scriptstrings/t.list_to_translate.c:8
 #: ../locale/scriptstrings/t.list_to_translate.c:11
-msgid "Columns number_of_maps and granularity only available for space time datasets"
+msgid ""
+"Columns number_of_maps and granularity only available for space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:9
@@ -20844,8 +22415,12 @@
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
 #, fuzzy
-msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
-msgstr "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative DGMs mit Hilfe von gdalwarp."
+msgid ""
+"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
+"using gdalwarp."
+msgstr ""
+"Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative "
+"DGMs mit Hilfe von gdalwarp."
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:5
 #: ../imagery/i.aster.toar/main.c:99
@@ -20863,12 +22438,17 @@
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:8
 #, fuzzy
-msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
-msgstr "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein einzelnen Kanal umrechnen."
+msgid ""
+"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
+"all bands"
+msgstr ""
+"L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein "
+"einzelnen Kanal umrechnen."
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:9
 #, fuzzy
-msgid "Base name for output raster map (band number will be appended to base name)"
+msgid ""
+"Base name for output raster map (band number will be appended to base name)"
 msgstr "Name der Ausgabe-Rasterkarte (Sättigung, saturation)."
 #: ../locale/scriptstrings/v.unpack_to_translate.c:1
@@ -20933,8 +22513,12 @@
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
 #, fuzzy
-msgid "Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns."
-msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
+msgid ""
+"Calculates univariate statistics from a raster map based on vector polygon "
+"map and uploads statistics to new attribute columns."
+msgstr ""
+"Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
+"und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
 msgid "Continue if upload column(s) already exist"
@@ -20955,11 +22539,15 @@
 msgstr "Zu benutzende Interpolationsmethode."
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:1
-msgid "Aggregated data of an existing space time raster dataset using the time intervals of a second space time dataset."
+msgid ""
+"Aggregated data of an existing space time raster dataset using the time "
+"intervals of a second space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
-msgid "Time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation"
+msgid ""
+"Time intervals from this space time dataset (raster, vector or raster3d) are "
+"used for aggregation computation"
 msgstr ""
 #: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
@@ -20973,8 +22561,12 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
-msgstr "Reklassifiziert eine Rasterkarte mit Flächen größer oder kleiner als eine benutzerspezifizierte Fläche (in Hektar)."
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)."
+msgstr ""
+"Reklassifiziert eine Rasterkarte mit Flächen größer oder kleiner als eine "
+"benutzerspezifizierte Fläche (in Hektar)."
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 msgid "Lesser value option that sets the <= area size limit [hectares]"
@@ -21003,7 +22595,8 @@
 #: ../vector/v.what.rast3/main.c:75 ../vector/v.what.rast/main.c:82
 #, fuzzy
 msgid "Name of vector points map for which to edit attributes"
-msgstr "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
+msgstr ""
+"Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:7
 #: ../vector/v.what.rast3/main.c:86 ../vector/v.what.rast/main.c:97
@@ -21040,7 +22633,9 @@
 msgstr "Name der Ausgabedatei."
 #: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
-msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
+msgid ""
+"Export files using the space time dataset granularity for equidistant time "
+"between maps, where statement will be ignored"
 msgstr ""
 #: ../locale/scriptstrings/v.build.all_to_translate.c:1
@@ -21100,10 +22695,13 @@
 #: ../locale/scriptstrings/i.oif_to_translate.c:1
 #, fuzzy
 msgid "Calculates Optimum-Index-Factor table for spectral bands"
-msgstr "Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
+msgstr ""
+"Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
 #: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
+msgid ""
+"Unregisters raster, vector and raster3d maps from the temporal database or a "
+"specific space time dataset."
 msgstr ""
 #: ../locale/scriptstrings/t.unregister_to_translate.c:4
@@ -21140,11 +22738,17 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:1
 #, fuzzy
 msgid "Maintains GRASS Addons extensions in local GRASS installation."
-msgstr "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu verwalten."
+msgstr ""
+"Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu verwalten."
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
-msgstr "Download und Installation von Erweiterungen aus dem 'GRASS Addons SVN Repository' in der lokalen GRASS Installation oder Entfernt installierte Erweiterungen. "
+msgid ""
+"Downloads, installs extensions from GRASS Addons SVN repository into local "
+"GRASS installation or removes installed extensions."
+msgstr ""
+"Download und Installation von Erweiterungen aus dem 'GRASS Addons SVN "
+"Repository' in der lokalen GRASS Installation oder Entfernt installierte "
+"Erweiterungen. "
 #: ../locale/scriptstrings/g.extension_to_translate.c:6
 #, fuzzy
@@ -21176,12 +22780,16 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:14
 #, fuzzy
-msgid "List available extensions in the GRASS Addons SVN repository including module description"
+msgid ""
+"List available extensions in the GRASS Addons SVN repository including "
+"module description"
 msgstr "Zeigt die vorhandenen Regelsätze und Schluß."
 #: ../locale/scriptstrings/g.extension_to_translate.c:16
 #, fuzzy
-msgid "List available extensions in the GRASS Addons SVN repository (shell script style)"
+msgid ""
+"List available extensions in the GRASS Addons SVN repository (shell script "
+"style)"
 #: ../locale/scriptstrings/g.extension_to_translate.c:18
@@ -21191,7 +22799,8 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:20
 msgid "Install system-wide (may need system administrator rights)"
-msgstr "Systemweite Installation (eventuell Systemadministratorrechte erforderlich)."
+msgstr ""
+"Systemweite Installation (eventuell Systemadministratorrechte erforderlich)."
 #: ../locale/scriptstrings/g.extension_to_translate.c:21
 #: ../locale/scriptstrings/g.extension_to_translate.c:23
@@ -21233,7 +22842,8 @@
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
 #, fuzzy
-msgid "Replace gaps in a space time raster dataset with interpolated raster maps."
+msgid ""
+"Replace gaps in a space time raster dataset with interpolated raster maps."
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
@@ -21242,12 +22852,14 @@
 msgstr "Anzahl der Interpolationspunkte."
 #: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:7
-msgid "Assign the space time raster dataset start and end time to the output map"
+msgid ""
+"Assign the space time raster dataset start and end time to the output map"
 msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
 #, fuzzy
-msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
+msgid ""
+"Exports a raster map to a text file as x,y,z values based on cell centers."
 msgstr "."
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
@@ -21255,8 +22867,11 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid "Adds one or more columns to the attribute table connected to a given vector map."
-msgstr "Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+"Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
 msgid "Layer number where to add column(s)"
@@ -21267,12 +22882,18 @@
 msgstr "Name and Typ der neuen Spalten ('name type [,name type, ...]')"
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
-msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
+msgid ""
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
+msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:1
 #, fuzzy
-msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
+msgid ""
+"Samples the input space time dataset(s) with a sample space time dataset and "
+"print the result to stdout."
 #: ../locale/scriptstrings/t.sample_to_translate.c:4
@@ -21286,7 +22907,10 @@
 msgstr "Name der neuen Datenbank."
 #: ../locale/scriptstrings/t.sample_to_translate.c:8
-msgid "Separator character between the output columns, default is tabular \" | \". Do not use \",\" as this char is reserved to list several map ids in a sample granule"
+msgid ""
+"Separator character between the output columns, default is tabular \" | \". "
+"Do not use \",\" as this char is reserved to list several map ids in a "
+"sample granule"
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:10
@@ -21313,7 +22937,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid "The given code must be supported by the server, consult the capabilities file"
+msgid ""
+"The given code must be supported by the server, consult the capabilities file"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
@@ -21334,7 +22959,9 @@
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid "Download server capabilities to 'wms_capabilities.xml' in the current directory and exit"
+msgid ""
+"Download server capabilities to 'wms_capabilities.xml' in the current "
+"directory and exit"
 msgstr ""
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
@@ -21357,26 +22984,35 @@
 #: ../locale/scriptstrings/t.vect.export_to_translate.c:7
-msgid "The export format of a single raster map. Supported are GML via v.out.ogr and the GRASS package format of v.pack."
+msgid ""
+"The export format of a single raster map. Supported are GML via v.out.ogr "
+"and the GRASS package format of v.pack."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.mapcalc_to_translate.c:1
-msgid "Apply temporal and spatial oeprations on space time vector datasets using temporal vector algebra."
+msgid ""
+"Apply temporal and spatial oeprations on space time vector datasets using "
+"temporal vector algebra."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.mapcalc_to_translate.c:4
 #, fuzzy
-msgid "The mapcalc expression for temporal and spatial analysis of space time vector datasets."
+msgid ""
+"vector datasets."
 #: ../locale/scriptstrings/t.vect.mapcalc_to_translate.c:5
 #, fuzzy
-msgid "The basename of vector maps that are stored within the result space time vector dataset."
+msgid ""
+"The basename of vector maps that are stored within the result space time "
+"vector dataset."
 #: ../locale/scriptstrings/r.blend_to_translate.c:1
 msgid "Blends color components of two raster maps by a given ratio."
-msgstr "Mischt die Farbkomponenten zweier Rasterkarten im angegebenen Verhältnis."
+msgstr ""
+"Mischt die Farbkomponenten zweier Rasterkarten im angegebenen Verhältnis."
 #: ../locale/scriptstrings/r.blend_to_translate.c:4
 msgid "Name of first raster map for blending"
@@ -21389,7 +23025,8 @@
 #: ../locale/scriptstrings/r.blend_to_translate.c:6
 #, fuzzy
 msgid "Prefix for red, green and blue output raster maps containing"
-msgstr "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
+msgstr ""
+"Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
 #: ../locale/scriptstrings/r.blend_to_translate.c:7
 msgid "Percentage weight of first map for color blending"
@@ -21410,11 +23047,15 @@
 msgstr "Raster"
 #: ../locale/scriptstrings/t.register_to_translate.c:9
-msgid "Input file with map names, one per line. Additionally the start time and the end time can be specified per line"
+msgid ""
+"Input file with map names, one per line. Additionally the start time and the "
+"end time can be specified per line"
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:11
-msgid "Valid start date and time of the first map. Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer)."
+msgid ""
+"Valid start date and time of the first map. Format absolute time: \"yyyy-mm-"
+"dd HH:MM:SS +HHMM\", relative time is of type integer)."
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:12
@@ -21427,7 +23068,9 @@
 msgstr "Zeitschritt \t= %.2f s\n"
 #: ../locale/scriptstrings/t.register_to_translate.c:13
-msgid "Valid end date and time of all map. Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of type integer)."
+msgid ""
+"Valid end date and time of all map. Format absolute time: \"yyyy-mm-dd HH:MM:"
+"SS +HHMM\", relative time is of type integer)."
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:15
@@ -21435,7 +23078,10 @@
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid "Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer: 5)"
+msgid ""
+"Time increment between maps for valid time interval creation (format "
+"absolute: NNN seconds, minutes, hours, days, weeks, months, years; format "
+"relative is integer: 5)"
 msgstr ""
 #: ../locale/scriptstrings/t.register_to_translate.c:19
@@ -21444,7 +23090,8 @@
 msgstr "Feld-Trennzeichen"
 #: ../locale/scriptstrings/t.register_to_translate.c:21
-msgid "Create an interval (start and end time) in case an increment is provided"
+msgid ""
+"Create an interval (start and end time) in case an increment is provided"
 msgstr ""
 #: ../locale/scriptstrings/d.out.file_to_translate.c:1
@@ -21476,11 +23123,15 @@
 #: ../locale/scriptstrings/t.support_to_translate.c:9
-msgid "Update the metadata information and spatial extent of registered maps from the grass spatial database. Check for removed maps and delete them from the temporal database and all effected space time datasets."
+msgid ""
+"Update the metadata information and spatial extent of registered maps from "
+"the grass spatial database. Check for removed maps and delete them from the "
+"temporal database and all effected space time datasets."
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:10
-msgid "Update metadata information, temporal and spatial extent from registered maps"
+msgid ""
+"Update metadata information, temporal and spatial extent from registered maps"
 msgstr ""
 #: ../locale/scriptstrings/t.remove_to_translate.c:1
@@ -21508,7 +23159,9 @@
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
 #, fuzzy
-msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
+msgid ""
+"Reconnects attribute tables for all vector maps from the current mapset to a "
+"new database."
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
@@ -21546,8 +23199,12 @@
 msgstr "Datenbank-Schema"
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
-msgstr "Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung (inclination), Ausrichtung (azimuth) und einem Punkt."
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+"Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung "
+"(inclination), Ausrichtung (azimuth) und einem Punkt."
 #: ../locale/scriptstrings/r.plane_to_translate.c:4
 #, fuzzy
@@ -21577,17 +23234,23 @@
 msgstr "Art der zu erstellenden Rasterkarte."
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
+msgid ""
+"Observes specific locations in a space time raster dataset over a period of "
+"time using vector points."
 msgstr ""
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
 #, fuzzy
-msgid "Name of the new created vector map that stores the sampled values in different layers"
+msgid ""
+"Name of the new created vector map that stores the sampled values in "
+"different layers"
 msgstr "Name der Rasterkarte, die angezeigt werden soll."
 #: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
 #, fuzzy
-msgid "Names of the vector columns to be created and to store sampled raster values, one name for each STRDS"
+msgid ""
+"Names of the vector columns to be created and to store sampled raster "
+"values, one name for each STRDS"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
@@ -21623,8 +23286,11 @@
 #: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
 #, fuzzy
-msgid "Calculates univariate statistics from the non-null cells for each registered raster3d map of a space time raster3d dataset."
+msgid ""
+"raster3d map of a space time raster3d dataset."
+msgstr ""
 #: ../locale/scriptstrings/r.unpack_to_translate.c:1
 msgid "Unpacks a raster map packed with r.pack."
@@ -21641,13 +23307,17 @@
 #: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
 #, fuzzy
-msgid "Separator character between the output columns, default is tabular \"\t\""
+msgid ""
+"Separator character between the output columns, default is tabular \"\t\""
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:1
 #, fuzzy
-msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
-msgstr "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das von GpsBabel unterstützt wird."
+msgid ""
+"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+msgstr ""
+"Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das "
+"von GpsBabel unterstützt wird."
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:4
 msgid "GPS"
@@ -21682,7 +23352,9 @@
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:1
 #, fuzzy
-msgid "Performs r3.mapcalc expressions on maps of sampled space time raster3d datasets."
+msgid ""
+"Performs r3.mapcalc expressions on maps of sampled space time raster3d "
+"datasets."
 #: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:4
@@ -21867,16 +23539,24 @@
 msgstr "Kann Symbol nicht lesen; stelle daher die Punkte nicht dar."
 #: ../display/d.graph/main.c:61
-msgid "Program for generating and displaying simple graphics on the display monitor."
-msgstr "Programm zum Erstellen und Anzeigen von einfachen Grafiken im Grafikfenster."
+msgid ""
+"Program for generating and displaying simple graphics on the display monitor."
+msgstr ""
+"Programm zum Erstellen und Anzeigen von einfachen Grafiken im Grafikfenster."
 #: ../display/d.graph/main.c:66
-msgid "Name of file containing graphics commands, if not given reads from standard input"
-msgstr "Name der Datei, die Graph>ikkommandos enthält. Falls nicht angegeben, wird von der Standardeingabe gelesen."
+msgid ""
+"Name of file containing graphics commands, if not given reads from standard "
+"input"
+msgstr ""
+"Name der Datei, die Graph>ikkommandos enthält. Falls nicht angegeben, wird "
+"von der Standardeingabe gelesen."
 #: ../display/d.graph/main.c:73
 msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr "Farbe zum Zeichnen, entweder eine GRASS Standard-Farbe oder eine R:G:B-Tripel."
+msgstr ""
+"Farbe zum Zeichnen, entweder eine GRASS Standard-Farbe oder eine R:G:B-"
+"Tripel."
 #: ../display/d.graph/main.c:80
 msgid "Coordinates are given in map units"
@@ -21916,7 +23596,9 @@
 msgstr "%s - ungültiger Longitude."
 #: ../display/d.legend/main.c:88
-msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
+msgid ""
+"Displays a legend for a raster map in the active frame of the graphics "
+"monitor."
 msgstr "Zeichnet eine Legende für eine Rasterkarte im aktiven Grafikfenster."
 #: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:76
@@ -21948,8 +23630,11 @@
 msgstr "Strahlung"
 #: ../display/d.legend/main.c:131
-msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
-msgstr "Größe und Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links unten)"
+msgid ""
+"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgstr ""
+"Größe und Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist "
+"links unten)"
 #: ../display/d.legend/main.c:140
 msgid "List of discrete category numbers/values for legend"
@@ -21957,7 +23642,8 @@
 #: ../display/d.legend/main.c:150
 msgid "Use a subset of the map range for the legend (min,max)"
-msgstr "Benutze einen Teilausschnitt der Wertespanne für eine Legende (min,max)."
+msgstr ""
+"Benutze einen Teilausschnitt der Wertespanne für eine Legende (min,max)."
 #: ../display/d.legend/main.c:157 ../display/d.vect/main.c:256
 #: ../display/d.text/main.c:218 ../vector/v.label/main.c:122
@@ -22001,16 +23687,21 @@
 #: ../display/d.legend/main.c:348
 msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr "Legende liegt außerhalb des Rahmens. Text könnte nicht richtig dargestellt werden."
+msgstr ""
+"Legende liegt außerhalb des Rahmens. Text könnte nicht richtig dargestellt "
+"werden."
 #: ../display/d.legend/main.c:352
 msgid "Drawing horizontal legend as box width exceeds height"
-msgstr "Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet."
+msgstr ""
+"Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet."
 #: ../display/d.legend/main.c:363
 #, c-format
 msgid "Range information for <%s> not available (run r.support)"
-msgstr "Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support aus)."
+msgstr ""
+"Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support "
+"aus)."
 #: ../display/d.legend/main.c:368
 msgid "Input map contains no data"
@@ -22033,11 +23724,14 @@
 #: ../display/d.legend/main.c:487
 msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr "Nichts zu zeichnen! (Keine Kategorien mit Labeln? Außerhalb der Spanne?"
+msgstr ""
+"Nichts zu zeichnen! (Keine Kategorien mit Labeln? Außerhalb der Spanne?"
 #: ../display/d.legend/main.c:497
 msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr "Erzwinge eine geglättete Legende: Zu viele Kategorien für die Höhe des aktuellen Fensters."
+msgstr ""
+"Erzwinge eine geglättete Legende: Zu viele Kategorien für die Höhe des "
+"aktuellen Fensters."
 #: ../display/d.legend/main.c:527 ../display/d.histogram/main.c:180
 #, c-format
@@ -22073,7 +23767,9 @@
 msgstr "Vektor, Zeichen Label"
 #: ../display/d.labels/main.c:46
-msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
+msgid ""
+"Displays text labels (created with v.label) to the active frame on the "
+"graphics monitor."
 msgstr "Zeigt Text-Label (mit v.label erstellt) im aktiven Grafikfenster."
 #: ../display/d.labels/main.c:52
@@ -22099,11 +23795,13 @@
 #: ../display/d.labels/main.c:97
 msgid "Region size is lower than minreg, nothing displayed."
-msgstr "Region-Größe ist kleiner als die Minimal-Region; es wird nichts angezeigt."
+msgstr ""
+"Region-Größe ist kleiner als die Minimal-Region; es wird nichts angezeigt."
 #: ../display/d.labels/main.c:105
 msgid "Region size is greater than maxreg, nothing displayed."
-msgstr "Region-Größe ist größer als die Maximal-Region; es wird nichts angezeigt."
+msgstr ""
+"Region-Größe ist größer als die Maximal-Region; es wird nichts angezeigt."
 #: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:300
 #, c-format
@@ -22111,8 +23809,12 @@
 msgstr "Kann die Beshriftungsdatei <%s> nicht öffnen."
 #: ../display/d.rgb/main.c:58
-msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
-msgstr "Stellt drei Rasterkarten als rot, grün und blau Überlagerung im aktuellen Kartenfenster dar."
+msgid ""
+"Displays three user-specified raster maps as red, green, and blue overlays "
+"in the active graphics frame."
+msgstr ""
+"Stellt drei Rasterkarten als rot, grün und blau Überlagerung im aktuellen "
+"Kartenfenster dar."
 #: ../display/d.rgb/main.c:63 ../display/d.rast/main.c:81
 msgid "Make null cells opaque"
@@ -22129,7 +23831,9 @@
 msgstr "Name der Rasterkarte für  '%s'."
 #: ../display/d.grid/main.c:54
-msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
+msgid ""
+"Overlays a user-specified grid in the active display frame on the graphics "
+"monitor."
 msgstr "Überlagert ein benutzerdefiniertes Gitter im aktiven Grafikfenster."
 #: ../display/d.grid/main.c:62
@@ -22139,8 +23843,12 @@
 #: ../display/d.grid/main.c:63
 #, fuzzy
-msgid "0 for north-south resolution of the current region. In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
-msgstr "In Karteneinheiten oder im DDD:MM:SS Format.  Beispiel: \"1000\" oder \"0:10\""
+msgid ""
+"0 for north-south resolution of the current region. In map units or DDD:MM:"
+"SS format. Example: \"1000\" or \"0:10\""
+msgstr ""
+"In Karteneinheiten oder im DDD:MM:SS Format.  Beispiel: \"1000\" oder "
+"\"0:10\""
 #: ../display/d.grid/main.c:71
 msgid "Lines of the grid pass through this coordinate"
@@ -22245,7 +23953,8 @@
 "datum transformation parameters. Try running g.setproj."
 msgstr ""
 "Ausgabe in WGS84 ist unmöglich, da diese Location keine Datums-\n"
-"Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu benutzen."
+"Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu "
+"benutzen."
 #: ../display/d.grid/plot.c:538
 msgid "Error in pj_do_proj1"
@@ -22268,8 +23977,11 @@
 msgstr "Fehler in pj_do_proj6"
 #: ../display/d.linegraph/main.c:122
-msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
-msgstr "Erzeugt und stellt einfache Liniengrafiken im aktiven Grafikfenster dar."
+msgid ""
+"Generates and displays simple line graphs in the active graphics monitor "
+"display frame."
+msgstr ""
+"Erzeugt und stellt einfache Liniengrafiken im aktiven Grafikfenster dar."
 #: ../display/d.linegraph/main.c:126
 msgid "Name of data file for X axis of graph"
@@ -22345,7 +24057,9 @@
 msgstr "Vektor-Ausgabekarte"
 #: ../display/d.thematic.area/main.c:81
-msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
+msgid ""
+"Displays a thematic vector area map in the active frame on the graphics "
+"monitor."
 msgstr "Stellt eine thematische Vektorkarte im aktiven Grafikfenster dar."
 #: ../display/d.thematic.area/main.c:91
@@ -22405,15 +24119,21 @@
 #: ../display/d.thematic.area/main.c:158
 msgid "File in which to save d.graph instructions for legend display"
-msgstr "Datei in der die d.grap-Anweisungen für die Darstellung der Legende gespeichert werden."
+msgstr ""
+"Datei in der die d.grap-Anweisungen für die Darstellung der Legende "
+"gespeichert werden."
 #: ../display/d.thematic.area/main.c:164 ../display/d.vect.chart/main.c:149
 msgid "Create legend information and send to stdout"
 msgstr "Erzeuge Legendeninformation und gebe sie auf stdout aus."
 #: ../display/d.thematic.area/main.c:169
-msgid "When printing legend info , include extended statistical info from classification algorithm"
-msgstr "Beim ausgeben der Legenden-Info auch die erweiterte Statistik des Klassifikationsalgorithmus ausgeben."
+msgid ""
+"When printing legend info , include extended statistical info from "
+"classification algorithm"
+msgstr ""
+"Beim ausgeben der Legenden-Info auch die erweiterte Statistik des "
+"Klassifikationsalgorithmus ausgeben."
 #: ../display/d.thematic.area/main.c:173
 msgid "Do not draw map, only output the legend"
@@ -22422,7 +24142,9 @@
 #: ../display/d.thematic.area/main.c:192
 #, c-format
 msgid "%s: You must build topology on vector map. Run v.build."
-msgstr "%s: Sie müssen die Topologie für die Vektorkarte erstellen. Führen Sie v.build aus."
+msgstr ""
+"%s: Sie müssen die Topologie für die Vektorkarte erstellen. Führen Sie v."
+"build aus."
 #: ../display/d.thematic.area/main.c:199
 msgid "'layer' must be > 0"
@@ -22452,12 +24174,19 @@
 msgstr "Unbekannte Farbe: [%s]."
 #: ../display/d.thematic.area/main.c:303
-msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
-msgstr "Sie haben manuelle Klassengrenzen und ein Klassifikationsalgorithmus/Klassenanzahl angegeben. Die manuellen Klassengrenzen haben Vorrang und werden daher verwendet."
+msgid ""
+"You gave both manual breaks and a classification algorithm or a number of "
+"classes. The manual breaks have precedence and will thus be used."
+msgstr ""
+"Sie haben manuelle Klassengrenzen und ein Klassifikationsalgorithmus/"
+"Klassenanzahl angegeben. Die manuellen Klassengrenzen haben Vorrang und "
+"werden daher verwendet."
 #: ../display/d.thematic.area/main.c:340
 msgid "You must either give classbreaks or a classification algorithm"
-msgstr "Sie müssen entweder Klassengrenzen oder einen Klassfikationsalgorithmus angeben."
+msgstr ""
+"Sie müssen entweder Klassengrenzen oder einen Klassfikationsalgorithmus "
+"angeben."
 #: ../display/d.thematic.area/main.c:353
 #, c-format
@@ -22478,8 +24207,11 @@
 msgstr "Zeichne..."
 #: ../display/d.thematic.area/main.c:384
-msgid "The bounding box of the map is outside the current region, nothing drawn."
-msgstr "Die BoundingBox der Karte liegt außerhalb der derzeitigen Region, es wird nichts gezeichnet."
+msgid ""
+"The bounding box of the map is outside the current region, nothing drawn."
+msgstr ""
+"Die BoundingBox der Karte liegt außerhalb der derzeitigen Region, es wird "
+"nichts gezeichnet."
 #: ../display/d.thematic.area/main.c:434
 #, c-format
@@ -22521,8 +24253,13 @@
 #: ../display/d.thematic.area/plot1.c:129
 #, c-format
-msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
-msgstr "Farbdefinitionsspalte (%s) ist keine Zeichenkette. Die Spalte muss die folgende Form haben: RRR:GGG:BBB. Die RGB-Werte müssen zwischen 0 und 255 liegen."
+msgid ""
+"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
+"BBB where RGB values range 0-255."
+msgstr ""
+"Farbdefinitionsspalte (%s) ist keine Zeichenkette. Die Spalte muss die "
+"folgende Form haben: RRR:GGG:BBB. Die RGB-Werte müssen zwischen 0 und 255 "
+"liegen."
 #: ../display/d.thematic.area/plot1.c:147
 msgid "Line width column not specified."
@@ -22544,8 +24281,12 @@
 #: ../display/d.thematic.area/plot1.c:278
 #, c-format
-msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
-msgstr "Fehler in der Farbdefinitionsspalte (%s), Element %d mit Kategorie %d: Farbwert [%s]."
+msgid ""
+"Error in color definition column (%s), element %d with cat %d: colorstring "
+"[%s]"
+msgstr ""
+"Fehler in der Farbdefinitionsspalte (%s), Element %d mit Kategorie %d: "
+"Farbwert [%s]."
 #: ../display/d.thematic.area/plot1.c:285
 #, c-format
@@ -22554,13 +24295,20 @@
 #: ../display/d.thematic.area/plot1.c:353
 #, c-format
-msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr "Fehler in der Spalte mit den Linienbreiten (%s), Element %d mit cat %d: Linienbreite [%d]."
+msgid ""
+"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr ""
+"Fehler in der Spalte mit den Linienbreiten (%s), Element %d mit cat %d: "
+"Linienbreite [%d]."
 #: ../display/d.erase/main.c:33
 #, fuzzy
-msgid "Erases the contents of the active graphics display frame with user defined color."
-msgstr "Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten Farbe."
+msgid ""
+"Erases the contents of the active graphics display frame with user defined "
+"color."
+msgstr ""
+"Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten "
+"Farbe."
 #: ../display/d.erase/main.c:39
 msgid "Remove all frames and erase the screen"
@@ -22583,8 +24331,12 @@
 #: ../display/d.vect/lines.c:121
 #, fuzzy
-msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
-msgstr "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht vorhanden ist."
+msgid ""
+"Unable to display features by id, topology not available. Please try to "
+"rebuild topology using v.build or v.build.all."
+msgstr ""
+"Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht "
+"vorhanden ist."
 #: ../display/d.vect/lines.c:169
 #, fuzzy, c-format
@@ -22664,7 +24416,9 @@
 #: ../display/d.vect/main.c:98
 #, fuzzy
 msgid "Display z-coordinate of features (only for 3D vector maps)"
-msgstr "Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden sollen."
+msgstr ""
+"Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden "
+"sollen."
 #: ../display/d.vect/main.c:119
 msgid "Feature color"
@@ -22710,7 +24464,8 @@
 #: ../display/d.vect/main.c:158
 #, fuzzy
 msgid "These values will be scaled by width_scale"
-msgstr "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
+msgstr ""
+"Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
 #: ../display/d.vect/main.c:165
 #, fuzzy
@@ -22733,7 +24488,9 @@
 #: ../display/d.vect/main.c:186
 msgid "When used with the size_column option this becomes the scale factor"
-msgstr "Dies wird der Skalierungsfaktor, wenn es zusammen mit der Option size_column verwendet wird."
+msgstr ""
+"Dies wird der Skalierungsfaktor, wenn es zusammen mit der Option size_column "
+"verwendet wird."
 #: ../display/d.vect/main.c:192
 msgid "Name of numeric column containing symbol size"
@@ -22757,7 +24514,9 @@
 #: ../display/d.vect/main.c:208
 msgid "Layer number for labels (default: the given layer number)"
-msgstr "Layernummer für die Beschriftungen (Standard: die bereits gegebene Layernummer)."
+msgstr ""
+"Layernummer für die Beschriftungen (Standard: die bereits gegebene "
+"Layernummer)."
 #: ../display/d.vect/main.c:214
 #, fuzzy
@@ -22798,16 +24557,26 @@
 msgstr "Vertikale Labelausrichtung"
 #: ../display/d.vect/main.c:285
-msgid "Minimum region size (average from height and width) when map is displayed"
-msgstr "Minimale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen der Karte."
+msgid ""
+"Minimum region size (average from height and width) when map is displayed"
+msgstr ""
+"Minimale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen "
+"der Karte."
 #: ../display/d.vect/main.c:293
-msgid "Maximum region size (average from height and width) when map is displayed"
-msgstr "Maximale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen der Karte."
+msgid ""
+"Maximum region size (average from height and width) when map is displayed"
+msgstr ""
+"Maximale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen "
+"der Karte."
 #: ../display/d.vect/main.c:301
-msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
-msgstr "Füllt die Flächen mit zufälligen Farben entsprechend den Kategorienummern (oder der Layernummer, wenn 'layer=-1' angegeben wurde)."
+msgid ""
+"Random colors according to category number (or layer number if 'layer=-1' is "
+"given)"
+msgstr ""
+"Füllt die Flächen mit zufälligen Farben entsprechend den Kategorienummern "
+"(oder der Layernummer, wenn 'layer=-1' angegeben wurde)."
 #: ../display/d.vect/main.c:308
 msgid "Use values from 'cats' option as feature id"
@@ -22818,23 +24587,31 @@
 msgstr ""
 #: ../display/d.vect/main.c:314
-msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
+msgid ""
+"This makes circle areas proportionate to the size_column values instead of "
+"circle radius"
 msgstr ""
 #: ../display/d.vect/main.c:334
 #, fuzzy
 msgid "Region size is lower than minreg, nothing displayed"
+msgstr ""
 #: ../display/d.vect/main.c:342
 #, fuzzy
 msgid "Region size is greater than maxreg, nothing displayed"
+msgstr ""
 #: ../display/d.vect/main.c:355
 #, fuzzy, c-format
-msgid "The -%c flag and <%s> option cannot be used together, the -%c flag will be ignored!"
-msgstr "Die Schalter '-c' und '-a' können nicht gemeinsam verwendet werden. Der Schalter '-c' wird ignoriert!"
+msgid ""
+"The -%c flag and <%s> option cannot be used together, the -%c flag will be "
+"ignored!"
+msgstr ""
+"Die Schalter '-c' und '-a' können nicht gemeinsam verwendet werden. Der "
+"Schalter '-c' wird ignoriert!"
 #: ../display/d.vect/main.c:379 ../display/d.vect/main.c:385
 #, fuzzy, c-format
@@ -22855,8 +24632,11 @@
 #: ../display/d.vect/main.c:413
 #, fuzzy
-msgid "The bounding box of the map is outside the current region, nothing drawn"
+msgid ""
+"The bounding box of the map is outside the current region, nothing drawn"
+msgstr ""
 #: ../display/d.vect/main.c:479
 #, fuzzy
@@ -22864,12 +24644,16 @@
 msgstr "Lese Datei."
 #: ../display/d.vect/topo.c:18
-msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
+msgid ""
+"Unable to display topology, not available.Please try to rebuild topology "
+"using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/area.c:37
 #, fuzzy
-msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
+msgid ""
+"Unable to display areas, topology not available. Please try to rebuild "
+"topology using v.build or v.build.all."
 msgstr "Kann Flächen nicht darstellen, da die Topologie nicht vorhanden ist."
 #: ../display/d.vect/area.c:137
@@ -22896,8 +24680,15 @@
 #: ../display/d.vect/shape.c:77
 #, c-format
-msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
-msgstr "Farbdefinitionsspalte ('%s') ist keine Zeichenkette. Die Spalte muss die Form 'RRR:GGG:BBB' haben. Die RGB-Werte müssen zwischen 0 und 255 liegen. Sie können das Modul '%s' verwenden um Farbregeln zu definieren. Kann die Objekte nicht einfärben."
+msgid ""
+"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
+"BBB' where RGB values range 0-255. You can use '%s' module to define color "
+"rules. Unable to colorize features."
+msgstr ""
+"Farbdefinitionsspalte ('%s') ist keine Zeichenkette. Die Spalte muss die "
+"Form 'RRR:GGG:BBB' haben. Die RGB-Werte müssen zwischen 0 und 255 liegen. "
+"Sie können das Modul '%s' verwenden um Farbregeln zu definieren. Kann die "
+"Objekte nicht einfärben."
 #: ../display/d.vect/shape.c:86 ../display/d.vect/shape.c:109
 #: ../display/d.vect/shape.c:140 ../display/d.vect/shape.c:171
@@ -22936,12 +24727,14 @@
 msgstr "Spalte für die Symbolrotation (%s) is nicht numerisch."
 #: ../display/d.vect/shape.c:194
-msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgid ""
+"Vector map is not 3D. Unable to colorize features based on z-coordinates."
 msgstr ""
 #: ../display/d.vect/shape.c:198
 #, fuzzy, c-format
-msgid "Options <%s> and <%s> are mutually exclusive. Option <%s> will be ignored."
+msgid ""
+"Options <%s> and <%s> are mutually exclusive. Option <%s> will be ignored."
 msgstr "-s und -n schließen sich gegenseitig aus."
 #: ../display/d.vect/shape.c:341
@@ -22965,8 +24758,13 @@
 msgstr "Kein Attribut für cat %d: %s gefunden."
 #: ../display/d.geodesic/main.c:46
-msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
-msgstr "Stellt eine geodätische Linie, die kürzeste Distanz zwischen zwei geographischen Punkten auf dem Großkreis, in einem longitude/latitude Datensatz dar"
+msgid ""
+"Displays a geodesic line, tracing the shortest distance between two "
+"geographic points along a great circle, in a longitude/latitude data set."
+msgstr ""
+"Stellt eine geodätische Linie, die kürzeste Distanz zwischen zwei "
+"geographischen Punkten auf dem Großkreis, in einem longitude/latitude "
+"Datensatz dar"
 #: ../display/d.geodesic/main.c:69
 msgid "Text color or \"none\""
@@ -22974,8 +24772,12 @@
 #: ../display/d.where/main.c:48
 #, fuzzy
-msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
-msgstr "Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-Fenster."
+msgid ""
+"Identifies the geographic coordinates associated with point locations given "
+"in display coordinates."
+msgstr ""
+"Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-"
+"Fenster."
 #: ../display/d.where/main.c:58
 #, fuzzy
@@ -22985,7 +24787,8 @@
 #: ../display/d.where/main.c:63
 #, fuzzy
 msgid "File from which to read coordinates (\"-\" to read from stdin)"
-msgstr "Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
+msgstr ""
+"Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
 #: ../display/d.where/main.c:67
 msgid "Output lat/long in decimal degree"
@@ -22996,8 +24799,13 @@
 msgstr "Ausgabe auf den aktuellen Ellipsoid referenziert."
 #: ../display/d.where/main.c:77
-msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
-msgstr "Gibt Lat/long Ausgabe auf einen WGS84-Ellipsoiden mit den definierten Datumstransformationsparametern der aktuellen Location (sofern vorhanden) aus."
+msgid ""
+"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
+"parameters defined in current location (if available)"
+msgstr ""
+"Gibt Lat/long Ausgabe auf einen WGS84-Ellipsoiden mit den definierten "
+"Datumstransformationsparametern der aktuellen Location (sofern vorhanden) "
+"aus."
 #: ../display/d.where/main.c:83
 msgid "Output frame coordinates of current display monitor (percentage)"
@@ -23009,13 +24817,17 @@
 #: ../display/d.where/main.c:94
 msgid "Please specify a lat/long ellipsoid with -l or -w"
-msgstr "Bitte geben Sie einen Lat/Long-Ellipsoiden mit den Optionen -l oder -w an."
+msgstr ""
+"Bitte geben Sie einen Lat/Long-Ellipsoiden mit den Optionen -l oder -w an."
 #: ../display/d.where/main.c:136
 msgid ""
 "WGS84 output not possible as this location does not contain\n"
-msgstr "Ausgabe in WGS84A ist unmöglich, da diese Location keine Datums-Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu benutzen."
+msgstr ""
+"Ausgabe in WGS84A ist unmöglich, da diese Location keine Datums-"
+"benutzen."
 #: ../display/d.where/where.c:29
 #, fuzzy, c-format
@@ -23037,7 +24849,9 @@
 msgstr "Gebe die Fonts ausführlich aus."
 #: ../display/d.text/main.c:141
-msgid "Draws text in the active display frame on the graphics monitor using the current font."
+msgid ""
+"Draws text in the active display frame on the graphics monitor using the "
+"current font."
 msgstr "Zeichnet Text im aktiven Graphik-Fenster mit der aktuellen Schrift."
 #: ../display/d.text/main.c:147
@@ -23054,15 +24868,21 @@
 #: ../display/d.text/main.c:172
 msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr "Texthintergrundfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B Tripel."
+msgstr ""
+"Texthintergrundfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B "
+"Tripel."
 #: ../display/d.text/main.c:181
 msgid "The screen line number on which text will begin to be drawn"
 msgstr "Die Zeile des Grafikfensters, in der der Text beginnt."
 #: ../display/d.text/main.c:189
-msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
-msgstr "Bildschirmposition, an der der Text angefangen wird, zu zeichnen (in Prozent, [0,0] ist die untere linke Ecke)."
+msgid ""
+"Screen position at which text will begin to be drawn (percentage, [0,0] is "
+"lower left)"
+msgstr ""
+"Bildschirmposition, an der der Text angefangen wird, zu zeichnen (in "
+"Prozent, [0,0] ist die untere linke Ecke)."
 #: ../display/d.text/main.c:197
 msgid "Text alignment"
@@ -23112,7 +24932,8 @@
 "Please enter text instructions.  Enter EOF (ctrl-d) on last line to quit\n"
 msgstr ""
 "\n"
-"Bitte geben Sie Anweisungen ein.  Um dies zu beenden geben Sie in der letzten Zeile EOF (Strg-d) ein.\n"
+"Bitte geben Sie Anweisungen ein.  Um dies zu beenden geben Sie in der "
+"letzten Zeile EOF (Strg-d) ein.\n"
 #: ../display/d.text/main.c:562
 #, c-format
@@ -23145,12 +24966,14 @@
 #: ../display/d.colortable/main.c:114
 #, c-format
-msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid ""
+"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:128
 #, c-format
-msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgid ""
+"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:139
@@ -23185,7 +25008,8 @@
 #: ../display/d.info/main.c:59
 msgid "Display geographic coordinates and resolution of entire screen"
-msgstr "Zeigt geographische Koordinaten und die Auflösung des gesamten Bildschirms."
+msgstr ""
+"Zeigt geographische Koordinaten und die Auflösung des gesamten Bildschirms."
 #: ../display/d.info/main.c:66
 #, fuzzy
@@ -23209,7 +25033,9 @@
 #: ../display/d.northarrow/main.c:61 ../display/d.barscale/main.c:108
 #, fuzzy
 msgid "Screen coordinates of the rectangle's top-left corner"
-msgstr "Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist oben links)."
+msgstr ""
+"Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist "
+"oben links)."
 #: ../display/d.northarrow/main.c:62 ../display/d.barscale/main.c:109
 msgid "(0,0) is lower-left of the display frame"
@@ -23283,8 +25109,13 @@
 msgstr "Sie klicken außerhalb der Karte."
 #: ../display/d.what.rast/main.c:54
-msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
-msgstr "Erlaubt dem Nutzer interaktiv mehrere Rasterkartenkategorien übereinander an einem angeklickten Punkt in der aktuellen Region abzufragen."
+msgid ""
+"Allows the user to interactively query the category contents of multiple "
+"raster map layers at user specified locations within the current geographic "
+"region."
+msgstr ""
+"Erlaubt dem Nutzer interaktiv mehrere Rasterkartenkategorien übereinander an "
+"einem angeklickten Punkt in der aktuellen Region abzufragen."
 #: ../display/d.what.rast/main.c:75
 msgid "Field separator (terse mode only)"
@@ -23300,7 +25131,9 @@
 #: ../display/d.what.rast/main.c:89
 msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr "Gebe Zeile/Spalte für die gesamte Karte in der aktuellen Auflösung der Region aus."
+msgstr ""
+"Gebe Zeile/Spalte für die gesamte Karte in der aktuellen Auflösung der "
+"Region aus."
 #: ../display/d.what.rast/main.c:99 ../display/d.what.vect/main.c:145
 #: ../display/d.extract/main.c:79 ../display/d.measure/main.c:85
@@ -23316,8 +25149,12 @@
 msgstr "Führe log Transformation aus."
 #: ../display/d.rast.arrow/main.c:99
-msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
-msgstr "Zeichnet Pfeile, die die Exposition der Zellen repräsentieren, basierend auf einer Rasterkarte mit Expositionsdaten."
+msgid ""
+"Draws arrows representing cell aspect direction for a raster map containing "
+"aspect data."
+msgstr ""
+"Zeichnet Pfeile, die die Exposition der Zellen repräsentieren, basierend auf "
+"einer Rasterkarte mit Expositionsdaten."
 #: ../display/d.rast.arrow/main.c:103
 msgid "Name of raster aspect map to be displayed"
@@ -23371,7 +25208,8 @@
 #: ../display/d.rast.arrow/main.c:214
 msgid "Magnitude is only supported for GRASS and compass aspect maps."
-msgstr "Magnitude wird nur für GRASS sowie Kompass-Expositionskarten unterstützt."
+msgstr ""
+"Magnitude wird nur für GRASS sowie Kompass-Expositionskarten unterstützt."
 #: ../display/d.rast.arrow/main.c:219
 msgid "Scale option requires magnitude_map"
@@ -23512,8 +25350,12 @@
 msgstr " Rechts:  Beenden\n"
 #: ../display/d.what.vect/main.c:61
-msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
-msgstr "Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der aktuellen Region."
+msgid ""
+"Allows the user to interactively query a vector map layer at user-selected "
+"locations within the current geographic region."
+msgstr ""
+"Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der "
+"aktuellen Region."
 #: ../display/d.what.vect/main.c:77
 msgid "Name of existing vector map"
@@ -23653,8 +25495,12 @@
 msgstr "Berechne Histogramm"
 #: ../display/d.histogram/main.c:88
-msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
-msgstr "Stellt ein Histogramm in Torten- oder Balkenform für eine angegebene Rasterkarte dar."
+msgid ""
+"Displays a histogram in the form of a pie or bar chart for a user-specified "
+"raster map."
+msgstr ""
+"Stellt ein Histogramm in Torten- oder Balkenform für eine angegebene "
+"Rasterkarte dar."
 #: ../display/d.histogram/main.c:92
 msgid "Raster map for which histogram will be displayed"
@@ -23670,11 +25516,14 @@
 #: ../display/d.histogram/main.c:113
 msgid "Indicate if cell counts or map areas should be displayed"
-msgstr "Gibt an, ob die Zellenanzahl oder Karteneinheiten angezeigt werden sollen."
+msgstr ""
+"Gibt an, ob die Zellenanzahl oder Karteneinheiten angezeigt werden sollen."
 #: ../display/d.histogram/main.c:123
 msgid "Number of steps to divide the data range into (fp maps only)"
-msgstr "Anzahl der Klassen, in die der Wertebereich geteilt werden soll (nur Fließkommakarten)"
+msgstr ""
+"Anzahl der Klassen, in die der Wertebereich geteilt werden soll (nur "
+"Fließkommakarten)"
 #: ../display/d.histogram/main.c:130
 msgid "Display information for null cells"
@@ -23699,8 +25548,12 @@
 #: ../display/d.rast.num/main.c:79
 #, fuzzy
-msgid "Overlays cell category values on a raster map displayed in the active graphics frame."
-msgstr "Überlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-Fenster."
+msgid ""
+"Overlays cell category values on a raster map displayed in the active "
+"graphics frame."
+msgstr ""
+"Überlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-"
+"Fenster."
 #: ../display/d.rast.num/main.c:87
 msgid "Color for drawing grid, or \"none\""
@@ -23719,10 +25572,13 @@
 #, fuzzy, c-format
 msgid ""
 "Current region size: %s X %s\n"
-"Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
+"Your current region setting may be too large. Cells displayed on your "
+"graphics window may be too small for cell category number to be visible."
 msgstr ""
 "Aktuelle Region: %d rows X %d cols\n"
-"Ihre aktuelle Fenstereinstellung könnte zu groß sein. Die im Grafikfenster dargestellten Zellen könnten zu klein sein, um die Kategorien lesen zu können."
+"Ihre aktuelle Fenstereinstellung könnte zu groß sein. Die im Grafikfenster "
+"dargestellten Zellen könnten zu klein sein, um die Kategorien lesen zu "
+"können."
 #: ../display/d.rast.num/main.c:181
 #, fuzzy, c-format
@@ -23733,11 +25589,16 @@
 #: ../display/d.rast.num/main.c:184
 msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
-msgstr "Abbruch (Region größer als 200 Zeilen x 200 Spalten sind nicht erlaubt)"
+msgstr ""
+"Abbruch (Region größer als 200 Zeilen x 200 Spalten sind nicht erlaubt)"
 #: ../display/d.font/main.c:48
-msgid "Selects the font in which text will be displayed on the user's graphics monitor."
-msgstr "Selektiert die Schriftart, in welcher der Text im Grafikfenster angezeigt wird."
+msgid ""
+"Selects the font in which text will be displayed on the user's graphics "
+"monitor."
+msgstr ""
+"Selektiert die Schriftart, in welcher der Text im Grafikfenster angezeigt "
+"wird."
 #: ../display/d.font/main.c:56
 msgid "Choose new current font"
@@ -23767,8 +25628,11 @@
 #: ../display/d.font/main.c:126
 #, c-format
-msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
-msgstr "Der Name des Fonts <%s> ist nicht gültig. Überprüfe Sie den Namen oder überlegen Sie 'g.mkfontcap' auszuführen."
+msgid ""
+"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgstr ""
+"Der Name des Fonts <%s> ist nicht gültig. Überprüfe Sie den Namen oder "
+"überlegen Sie 'g.mkfontcap' auszuführen."
 #: ../display/d.mon/start.c:68
 #, fuzzy, c-format
@@ -23946,8 +25810,12 @@
 msgstr "Grafikfenster <%s> freigegeben."
 #: ../display/d.his/main.c:69
-msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
-msgstr "Zeigt das Ergebnis der Kombination Kombination von Farbwert-, Intensitäts- und Sättigungswerten (HIS) aus vom Benutzer gewählten Rasterkarten."
+msgid ""
+"Displays the result obtained by combining hue, intensity, and saturation "
+"(his) values from user-specified input raster map layers."
+msgstr ""
+"Zeigt das Ergebnis der Kombination Kombination von Farbwert-, Intensitäts- "
+"und Sättigungswerten (HIS) aus vom Benutzer gewählten Rasterkarten."
 #: ../display/d.his/main.c:97
 msgid "Percent to brighten intensity channel"
@@ -23955,7 +25823,9 @@
 #: ../display/d.extract/main.c:52
 msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr "Interaktives Auswählen und Extrahieren von Vektoren mit der Maus in eine neue Karte."
+msgstr ""
+"Interaktives Auswählen und Extrahieren von Vektoren mit der Maus in eine "
+"neue Karte."
 #: ../display/d.extract/main.c:117
 msgid "Copying tables..."
@@ -23963,7 +25833,9 @@
 #: ../display/d.extract/main.c:125
 msgid "Cannot get db link info -> cannot copy table."
-msgstr "Kann die Informationen zu Datenbankverbindung nicht lesen -> Kann Tabelle nicht kopieren."
+msgstr ""
+"Kann die Informationen zu Datenbankverbindung nicht lesen -> Kann Tabelle "
+"nicht kopieren."
 #: ../display/d.extract/extract.c:43
 msgid "Select vector(s) with mouse"
@@ -23975,11 +25847,14 @@
 #: ../display/d.extract/extract.c:45
 msgid " - M: draw box with middle mouse button to remove from display"
-msgstr "- M: Zeichne Boxe mit der mittleren Maustaste, die von der Darstellung entfernt werden soll."
+msgstr ""
+"- M: Zeichne Boxe mit der mittleren Maustaste, die von der Darstellung "
+"entfernt werden soll."
 #: ../display/d.extract/extract.c:46
 msgid " - R: quit and save selected vectors to new map\n"
-msgstr " - R: Beende und speichere die ausgewählten Vektoren in eine neuen Karte.\n"
+msgstr ""
+" - R: Beende und speichere die ausgewählten Vektoren in eine neuen Karte.\n"
 #: ../display/d.extract/extract.c:48
 msgid "L: add  M: remove  R: quit and save\n"
@@ -23991,7 +25866,8 @@
 msgstr "Eingabekarte"
 #: ../display/d.vect.chart/main.c:67
-msgid "Displays charts of vector data in the active frame on the graphics monitor."
+msgid ""
+"Displays charts of vector data in the active frame on the graphics monitor."
 msgstr "Stellt Diagramme von Vektordaten im aktiven Grafikfenster dar."
 #: ../display/d.vect.chart/main.c:86
@@ -24015,7 +25891,9 @@
 #: ../display/d.vect.chart/main.c:105
 msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr "Größe des Diagramms (Durchmesser für Tortendiagramm, Gesamtbreite für Balkendiagrramm)."
+msgstr ""
+"Größe des Diagramms (Durchmesser für Tortendiagramm, Gesamtbreite für "
+"Balkendiagrramm)."
 #: ../display/d.vect.chart/main.c:112
 msgid "Scale for size (to get size in pixels)"
@@ -24038,8 +25916,12 @@
 msgstr "Maximaler Wert wird für die Referenz des Balkenplots verwendet."
 #: ../display/d.measure/main.c:49
-msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
-msgstr "Misst die Länge und Fläche von Objekten, gezeichnet vom Benutzer, im aktiven Grafikfenster."
+msgid ""
+"Measures the lengths and areas of features drawn by the user in the active "
+"display frame on the graphics monitor."
+msgstr ""
+"Misst die Länge und Fläche von Objekten, gezeichnet vom Benutzer, im aktiven "
+"Grafikfenster."
 #: ../display/d.measure/main.c:55
 msgid "Line color 1"
@@ -24062,8 +25944,11 @@
 msgstr "Ausgabe auch in Kilometer."
 #: ../display/d.title/main.c:52
-msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
-msgstr "Erzeugt einen Titel für eine Rasterkarte in einer geeigneten Form für die Darstellung mit d.text."
+msgid ""
+"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgstr ""
+"Erzeugt einen Titel für eine Rasterkarte in einer geeigneten Form für die "
+"Darstellung mit d.text."
 #: ../display/d.title/main.c:63
 msgid "Sets the text color"
@@ -24098,8 +25983,12 @@
 msgstr ""
 #: ../display/d.zoom/main.c:64
-msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
-msgstr "Erlaubt dem Benutzer die altuelle geographische Region interaktiv mit der Maus zu ändern."
+msgid ""
+"Allows the user to change the current geographic region settings "
+"interactively, with a mouse."
+msgstr ""
+"Erlaubt dem Benutzer die altuelle geographische Region interaktiv mit der "
+"Maus zu ändern."
 #: ../display/d.zoom/main.c:84 ../vector/v.build/main.c:44
 msgid "Name of vector map"
@@ -24194,7 +26083,9 @@
 #: ../display/d.zoom/zoom.c:41
 #, c-format
 msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr "Hinweis: Bitte benutzen Sie 'd.erase', um das Grafikfenster auf die neue Region einzustellen.\n"
+msgstr ""
+"Hinweis: Bitte benutzen Sie 'd.erase', um das Grafikfenster auf die neue "
+"Region einzustellen.\n"
 #: ../display/d.rast/main.c:56
 msgid "Displays user-specified raster map in the active graphics frame."
@@ -24287,12 +26178,20 @@
 #: ../raster3d/r3.cross.rast/main.c:233
 #, fuzzy
-msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
-msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
+msgid ""
+"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
+"map"
+msgstr ""
+"Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
+"Rasterkarte basierend auf 2D-Höhenkarte."
 #: ../raster3d/r3.cross.rast/main.c:259
-msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
-msgstr "Die 2D- und 3D-Regionsparameter sind unterschiedlich. Verwende die 3D-Rasterkarteneinstellungen, um die 2D-Region anzupassen."
+msgid ""
+"The 2D and 3D region settings are different. Using the 3D raster map "
+"settings to adjust the 2D region."
+msgstr ""
+"Die 2D- und 3D-Regionsparameter sind unterschiedlich. Verwende die 3D-"
+"Rasterkarteneinstellungen, um die 2D-Region anzupassen."
 #: ../raster3d/r3.cross.rast/main.c:302
 msgid "Output map already exists. Will be overwritten!"
@@ -24404,7 +26303,9 @@
 #: ../raster3d/r3.in.ascii/main.c:94
 msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr "Zeichenkette, die NULL-Werte repräsentiert (verwenden Sie 'none' wenn keiner existiert)"
+msgstr ""
+"Zeichenkette, die NULL-Werte repräsentiert (verwenden Sie 'none' wenn keiner "
+"existiert)"
 #: ../raster3d/r3.in.ascii/main.c:184
 #, fuzzy, c-format
@@ -24426,13 +26327,17 @@
 #: ../raster3d/r3.in.ascii/main.c:284
 #, c-format
-msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
-msgstr "Nach vollständigem Import der erwarteten Daten befinden sie sich in der Input-Datei.  [%.4f ...]"
+msgid ""
+"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgstr ""
+"Nach vollständigem Import der erwarteten Daten befinden sie sich in der "
+"Input-Datei.  [%.4f ...]"
 #: ../raster3d/r3.in.ascii/main.c:322
 #, fuzzy
 msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
+msgstr ""
+"Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
 #: ../raster3d/r3.in.ascii/main.c:365
 msgid "Unable to close ASCII file"
@@ -24468,12 +26373,17 @@
 #: ../raster3d/r3.out.vtk/main.c:168
 msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
-msgstr "Bitte geben Sie drei 3D-Rasterkarten für die xyz-Vektorkarten an [x,y,z]."
+msgstr ""
+"Bitte geben Sie drei 3D-Rasterkarten für die xyz-Vektorkarten an [x,y,z]."
 #: ../raster3d/r3.out.vtk/main.c:175
 #, fuzzy
-msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
-msgstr "Keine RASTER3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die Geometrien schreiben."
+msgid ""
+"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
+"geometry."
+msgstr ""
+"Keine RASTER3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur "
+"die Geometrien schreiben."
 #: ../raster3d/r3.out.vtk/main.c:209
 msgid "No RGB Data will be created."
@@ -24492,12 +26402,18 @@
 msgstr "Interpretation von dp als Integer ist fehlgeschlagen."
 #: ../raster3d/r3.out.vtk/main.c:451 ../raster3d/r3.to.rast/main.c:271
-msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
-msgstr "Die 2D und 3D Regionsparameter sind unterschiedlich. Verwende die 2D-Fenstereinstellungen, um den 2D-Teil der 3D-Region anzupassen."
+msgid ""
+"The 2D and 3D region settings are different. Using the 2D window settings to "
+"adjust the 2D part of the 3D region."
+msgstr ""
+"Die 2D und 3D Regionsparameter sind unterschiedlich. Verwende die 2D-"
+"Fenstereinstellungen, um den 2D-Teil der 3D-Region anzupassen."
 #: ../raster3d/r3.out.vtk/main.c:542
 msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr "Kann die 3D-Rasterkarte nicht schließen. Die VTK-Datei könnte unvollständig sein."
+msgstr ""
+"Kann die 3D-Rasterkarte nicht schließen. Die VTK-Datei könnte unvollständig "
+"sein."
 #: ../raster3d/r3.out.vtk/main.c:557
 msgid "Unable to close VTK-ASCII file"
@@ -24517,13 +26433,19 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:335
 #, c-format
-msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
-msgstr "write_vtk_data: Schreibe Zelldaten %s mit %i Zeilen, %i Spalten und einer Tiefe von %i in eine VTK-ASCII-Datei."
+msgid ""
+"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
+"ascii file"
+msgstr ""
+"write_vtk_data: Schreibe Zelldaten %s mit %i Zeilen, %i Spalten und einer "
+"Tiefe von %i in eine VTK-ASCII-Datei."
 #: ../raster3d/r3.out.vtk/writeVTKData.c:441
 #, fuzzy
 msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
-msgstr "Falsche Werte in der 3D-Rasterkarte! Werte sollten zwischen 0 und 255 liegen!\n"
+msgstr ""
+"Falsche Werte in der 3D-Rasterkarte! Werte sollten zwischen 0 und 255 "
+"liegen!\n"
 #: ../raster3d/r3.out.vtk/parameters.c:30
 msgid "RASTER3D map(s) to be converted to VTK-ASCII data format"
@@ -24535,7 +26457,8 @@
 #: ../raster3d/r3.out.vtk/parameters.c:47
 msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr "Erzeugt VTK Punktedaten anstelle von VTK Zelldaten (Standard ist Zelldaten)."
+msgstr ""
+"Erzeugt VTK Punktedaten anstelle von VTK Zelldaten (Standard ist Zelldaten)."
 #: ../raster3d/r3.out.vtk/parameters.c:56
 msgid "top surface 2D raster map"
@@ -24546,16 +26469,24 @@
 msgstr "2D Rasterkarte für den Boden."
 #: ../raster3d/r3.out.vtk/parameters.c:71
-msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
-msgstr "Erzeugt 3D Höhenausgabe mit einer Ober- und einer Unterfläche. Beide Rasterkarten werden benötigt."
+msgid ""
+"Create 3d elevation output with a top and a bottom surface, both raster maps "
+"are required."
+msgstr ""
+"Erzeugt 3D Höhenausgabe mit einer Ober- und einer Unterfläche. Beide "
+"Rasterkarten werden benötigt."
 #: ../raster3d/r3.out.vtk/parameters.c:82
-msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr "Drei (R,G,B) 3D-Rasterkarten, um RGB-Werte zu erzeugen [redmap,greenmap,bluemap]"
+msgid ""
+"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr ""
+"Drei (R,G,B) 3D-Rasterkarten, um RGB-Werte zu erzeugen [redmap,greenmap,"
+"bluemap]"
 #: ../raster3d/r3.out.vtk/parameters.c:92
 msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr "Drei (x,y,z) 3D-Rasterkarten zum Erzeugen von Vektorwerten [xmap,ymap,zmap]"
+msgstr ""
+"Drei (x,y,z) 3D-Rasterkarten zum Erzeugen von Vektorwerten [xmap,ymap,zmap]"
 #: ../raster3d/r3.out.vtk/parameters.c:116
 msgid "Use 3D raster mask (if exists) with input maps"
@@ -24566,7 +26497,9 @@
 msgstr "Skalierfaktor beeinflusst den Ursprung."
 #: ../raster3d/r3.out.vtk/parameters.c:133
-msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
+msgid ""
+"Do not convert the top-bottom resolution in case of lat long projection to "
+"meters"
 msgstr ""
 #: ../raster3d/r3.out.netcdf/main.c:81
@@ -24627,7 +26560,8 @@
 #: ../raster3d/r3.out.v5d/main.c:287
 msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei"
+msgstr ""
+"Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei"
 #: ../raster3d/r3.out.v5d/main.c:294
 msgid "Use map coordinates instead of xyz coordinates"
@@ -24659,7 +26593,9 @@
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:137
-msgid "The size of the window in x, y and z direction, values must be odd integer numbers, eg: 3,3,3"
+msgid ""
+"The size of the window in x, y and z direction, values must be odd integer "
+"numbers, eg: 3,3,3"
 msgstr ""
 #: ../raster3d/r3.neighbors/main.c:209
@@ -24669,8 +26605,13 @@
 #: ../raster3d/r3.neighbors/main.c:214
 #, fuzzy
-msgid "Makes each voxel value a function of the values assigned to the voxels around it, and stores new voxel values in an output 3D raster map"
-msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
+msgid ""
+"Makes each voxel value a function of the values assigned to the voxels "
+"around it, and stores new voxel values in an output 3D raster map"
+msgstr ""
+"Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
+"Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue "
+"Zellenwerte in einer Ausgabe-Rasterkarte."
 #: ../raster3d/r3.neighbors/main.c:283
 #, fuzzy
@@ -24678,8 +26619,12 @@
 msgstr "Kann keinen Speicher für Zellbuffer reservieren."
 #: ../raster3d/r3.mkdspf/main.c:82
-msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
-msgstr "Erzeugt eine Datei aus einer existierenden grid3-Datei basierend auf einem gegebenen Threshold."
+msgid ""
+"Creates a display file from an existing grid3 file according to specified "
+"threshold levels."
+msgstr ""
+"Erzeugt eine Datei aus einer existierenden grid3-Datei basierend auf einem "
+"gegebenen Threshold."
 #: ../raster3d/r3.mkdspf/main.c:90
 msgid "Name of an existing 3d raster map"
@@ -24749,7 +26694,8 @@
 msgstr "Name der 3D Eingabe-Rasterkarte."
 #: ../raster3d/r3.retile/main.c:99
-msgid "Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgid ""
+"Retiles an existing 3D raster map with user defined x, y and z tile size."
 msgstr ""
 #: ../raster3d/r3.retile/main.c:135
@@ -24788,8 +26734,11 @@
 #: ../raster3d/r3.support/main.c:51
 #, fuzzy
-msgid "Allows creation and/or modification of raster3d map layer support files."
-msgstr "Erlaubt das Erzeugen und/oder das Modifizieren von Rasterkarten-Support-Dateien."
+msgid ""
+"Allows creation and/or modification of raster3d map layer support files."
+msgstr ""
+"Erlaubt das Erzeugen und/oder das Modifizieren von Rasterkarten-Support-"
+"Dateien."
 #: ../raster3d/r3.support/main.c:75
 #, fuzzy
@@ -24827,8 +26776,12 @@
 #: ../raster3d/r3.to.rast/main.c:96
 #, fuzzy
-msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
-msgstr "Verwende dieselbe Auflösung wie die RASTER3D-Eingabekarte für die 2D-Ausgabekarten. Dies ist unabhängig von der Auflösung der aktuellen Region. "
+msgid ""
+"Use the same resolution as the input 3D raster map for the 2D output maps, "
+"independent of the current region settings"
+msgstr ""
+"Verwende dieselbe Auflösung wie die RASTER3D-Eingabekarte für die 2D-"
+"Ausgabekarten. Dies ist unabhängig von der Auflösung der aktuellen Region. "
 #: ../raster3d/r3.to.rast/main.c:210
 msgid "Converts 3D raster maps to 2D raster maps"
@@ -24846,8 +26799,10 @@
 #: ../raster3d/r3.to.rast/main.c:308
 #, fuzzy, c-format
-msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
+msgid ""
+"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgstr ""
+"Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
 #: ../raster3d/r3.gwflow/main.c:54
 msgid "Input 3D raster map with initial piezometric heads in [m]"
@@ -24855,22 +26810,30 @@
 #: ../raster3d/r3.gwflow/main.c:60
 #, fuzzy
-msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+msgid ""
+"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
+"active, 2 - dirichlet"
 msgstr "Der Status jeder Zelle, = 0 - inaktiv, 1 - aktiv, 2 - dirichlet"
 #: ../raster3d/r3.gwflow/main.c:65
 #, fuzzy
-msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
+msgid ""
+"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
+"[m/s]"
 msgstr "Der X-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
 #: ../raster3d/r3.gwflow/main.c:70
 #, fuzzy
-msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
+msgid ""
+"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
+"[m/s]"
 msgstr "Der Y-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
 #: ../raster3d/r3.gwflow/main.c:75
 #, fuzzy
-msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
+msgid ""
+"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
+"[m/s]"
 msgstr "Der Z-Anteil des hydraulischen Durchlässigkeits Tensors [m/s]."
 #: ../raster3d/r3.gwflow/main.c:80
@@ -24890,33 +26853,44 @@
 #: ../raster3d/r3.gwflow/main.c:93
 #, fuzzy
-msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
-msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
+msgid ""
+"Output 3D raster map storing the piezometric head result of the numerical "
+"calculation"
+msgstr ""
+"Das resultierende piezometrisches Niveau der numerischen Berechnung wird in "
+"diese Karte geschrieben."
 #: ../raster3d/r3.gwflow/main.c:99
 #, fuzzy
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
+msgid ""
+"Output 3D raster map storing the groundwater filter velocity vector part in "
+"x direction [m/s]"
 msgstr ""
 "Berechne das Vektorfeld der Grundwasserfiltrationgeschwindigkeiten [m/s]\n"
 "und schreibe die x- und y-Komponenten in Karten mit den Namen name_[xy]."
 #: ../raster3d/r3.gwflow/main.c:105
 #, fuzzy
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
+msgid ""
+"y direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:111
 #, fuzzy
-msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
+msgid ""
+"z direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:117
 #, fuzzy
-msgid "Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
+msgid ""
+"Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
 msgstr ""
@@ -24927,15 +26901,20 @@
 #: ../raster3d/r3.gwflow/main.c:163
 #, fuzzy
-msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
-msgstr "Programm zur Berechnung des transienten, beschränkten Grundwasserflusses in drei Dimensionen."
+msgid ""
+"Numerical calculation program for transient, confined groundwater flow in "
+"three dimensions."
+msgstr ""
+"Programm zur Berechnung des transienten, beschränkten Grundwasserflusses in "
+"drei Dimensionen."
 #: ../raster3d/r3.gwflow/main.c:180
 #, fuzzy
 msgid ""
 "The cholesky solver does not work with sparse matrices.\n"
 "Consider to choose a full filled quadratic matrix with flag -f "
-msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgstr ""
+"Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
 #: ../raster3d/r3.gwflow/main.c:365
 #, c-format
@@ -24945,7 +26924,8 @@
 #: ../raster3d/r3.in.v5d/main.c:195
 #, fuzzy
 msgid "Import 3-dimensional Vis5D files."
-msgstr "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
+msgstr ""
+"Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
 #: ../raster3d/r3.mask/main.c:74
 msgid "Unable to open 3D raster mask file"
@@ -24985,7 +26965,8 @@
 msgid "Cannot create mask file: RASTER3D_MASK already exists"
 msgstr ""
 "Kann keine Maskendatei erzeugen: RASTER3D_MASK existiert bereits.\n"
-"Benutzen Sie 'g.remove rast3d=RASTER3D_MASK' um die existierende Maske zu löschen."
+"Benutzen Sie 'g.remove rast3d=RASTER3D_MASK' um die existierende Maske zu "
+"löschen."
 #: ../raster3d/r3.null/main.c:54
 msgid "3d raster map for which to modify null values"
@@ -25201,7 +27182,9 @@
 #: ../ps/ps.map/main.c:105
 #, fuzzy
 msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten(Rand) )."
+msgstr ""
+"Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben "
+"unten(Rand) )."
 #: ../ps/ps.map/main.c:107 ../ps/ps.map/main.c:120
 msgid "Utility"
@@ -25212,8 +27195,12 @@
 msgstr "Erzeugt EPS (Encapsulated PostScript) anstatt PostScript-Dateien."
 #: ../ps/ps.map/main.c:118
-msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
-msgstr "Beschreibe die Position der Kartenrechtecks auf dem Papier und beendet sich (Inch von der linken-oberen Ecke). "
+msgid ""
+"Describe map-box's position on the page and exit (inches from top-left of "
+"paper)"
+msgstr ""
+"Beschreibe die Position der Kartenrechtecks auf dem Papier und beendet sich "
+"(Inch von der linken-oberen Ecke). "
 #: ../ps/ps.map/main.c:123
 msgid "File containing mapping instructions"
@@ -25373,18 +27360,29 @@
 msgstr "Kann die Farbe für den Farbstreifen nicht lesen."
 #: ../ps/ps.map/ps_clrtbl.c:54
-msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
-msgstr "Ihre cats/-Datei ist ungültig. Eine cats/-Datei mit Kategorien und Labeln ist für 'colortable' notwendig für eine kategorische Legende. Werfen Sie einen Blick in die Handbuchseite von r.category. Die Erzeugung der Farbteile wurde nicht ausgeführt."
+msgid ""
+"Your cats/ file is invalid. A cats/ file with categories and labels is "
+"required for 'colortable' when using categorical legends; see the r.category "
+"help page. Colortable creation has been skipped."
+msgstr ""
+"Ihre cats/-Datei ist ungültig. Eine cats/-Datei mit Kategorien und Labeln "
+"ist für 'colortable' notwendig für eine kategorische Legende. Werfen Sie "
+"einen Blick in die Handbuchseite von r.category. Die Erzeugung der Farbteile "
+"wurde nicht ausgeführt."
 #: ../ps/ps.map/ps_clrtbl.c:69 ../ps/ps.map/ps_fclrtbl.c:93
 #: ../ps/ps.map/ps_fclrtbl.c:98
 msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr "Die Y-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere dies."
+msgstr ""
+"Die Y-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere "
+"dies."
 #: ../ps/ps.map/ps_clrtbl.c:75 ../ps/ps.map/ps_fclrtbl.c:104
 #: ../ps/ps.map/ps_fclrtbl.c:109
 msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr "Die X-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere dies."
+msgstr ""
+"Die X-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere "
+"dies."
 #: ../ps/ps.map/do_scalebar.c:192
 #, fuzzy
@@ -25510,8 +27508,11 @@
 #: ../temporal/t.connect/main.c:38
 #, fuzzy
-msgid "Prints/sets general temporal GIS database connection for current mapset."
-msgstr "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und beendet sich."
+msgid ""
+"Prints/sets general temporal GIS database connection for current mapset."
+msgstr ""
+"Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
+"beendet sich."
 #: ../temporal/t.connect/main.c:54
 #, fuzzy
@@ -25660,7 +27661,8 @@
 #: ../imagery/i.rectify/rectify.c:108
 #, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr "Rasterkarte <%s@%s>: Projektion passt nicht zu den aktuellen Einstellungen."
+msgstr ""
+"Rasterkarte <%s@%s>: Projektion passt nicht zu den aktuellen Einstellungen."
 #: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:132
 #: ../imagery/i.rectify/rectify.c:114
@@ -25678,8 +27680,12 @@
 msgstr "Bildverarbeitung, Rektifikation"
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
-msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
-msgstr "Orthorektifiziert ein Bild mittels der Foto zu Koordinaten Transformationsmatrix."
+msgid ""
+"Orthorectifies an image by using the image to photo coordinate "
+"transformation matrix."
+msgstr ""
+"Orthorektifiziert ein Bild mittels der Foto zu Koordinaten "
+"Transformationsmatrix."
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:103
 #: ../imagery/i.rectify/main.c:116
@@ -25702,8 +27708,11 @@
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
 #: ../imagery/i.rectify/main.c:153
-msgid "Use current region settings in target location (def.=calculate smallest area)"
-msgstr "Verwende die Einstellungen der aktuelle Region für die Ziellocation (Standard: Berechne den kleinsten Bereich)."
+msgid ""
+"Use current region settings in target location (def.=calculate smallest area)"
+msgstr ""
+"Verwende die Einstellungen der aktuelle Region für die Ziellocation "
+"(Standard: Berechne den kleinsten Bereich)."
 #: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:141
 #: ../imagery/i.rectify/main.c:157
@@ -25821,8 +27830,12 @@
 msgstr "Kann die Rasterkarte mit Höheninformationen nicht öffnen."
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
-msgstr "Erzeugt oder ändert interaktiv Einträge in der Datei mit der Anfangsposition der Kamera für die Bildgruppe referenziert durch Unterblöcke."
+msgid ""
+"Interactively creates or modifies entries in a camera initial exposure "
+"station file for imagery group referenced by a sub-block."
+msgstr ""
+"Erzeugt oder ändert interaktiv Einträge in der Datei mit der Anfangsposition "
+"der Kamera für die Bildgruppe referenziert durch Unterblöcke."
 #: ../imagery/i.ortho.photo/i.ortho.init/main.c:57
 #: ../imagery/i.ortho.photo/i.ortho.elev/main.c:70
@@ -26026,7 +28039,8 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
 #, c-format
-msgid "Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+msgid ""
+"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
 msgstr ""
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
@@ -26058,7 +28072,9 @@
 #: ../imagery/i.ortho.photo/i.ortho.camera/main.c:217
 #, fuzzy, c-format
 msgid "Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"
-msgstr "Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die Kameradatei [%s]."
+msgstr ""
+"Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die Kameradatei "
+"[%s]."
 #: ../imagery/i.ortho.photo/i.ortho.transform/main.c:251
 #, fuzzy
@@ -26091,7 +28107,9 @@
 msgstr "Vektor, Transformation"
 #: ../imagery/i.evapo.pt/main.c:69
-msgid "Computes evapotranspiration calculation Prestley and Taylor formulation, 1972."
+msgid ""
+"Computes evapotranspiration calculation Prestley and Taylor formulation, "
+"1972."
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:75
@@ -26130,12 +28148,18 @@
 #: ../imagery/i.landsat.acca/main.c:70
 #, c-format
-msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
-msgstr "Eingabe Rasterkarte <%s> enthält keine Fließkomma-Werte (verarbeiten Sie zunächst die DN mittels i.landsat.toar zu Strahlungswerten)."
+msgid ""
+"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
+"to radiance first)"
+msgstr ""
+"Eingabe Rasterkarte <%s> enthält keine Fließkomma-Werte (verarbeiten Sie "
+"zunächst die DN mittels i.landsat.toar zu Strahlungswerten)."
 #: ../imagery/i.landsat.acca/main.c:104
 msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr "Führt automatische Landsat TM/ETM+ Einschätzung der Wolkenbedeckung (ACCA) durch."
+msgstr ""
+"Führt automatische Landsat TM/ETM+ Einschätzung der Wolkenbedeckung (ACCA) "
+"durch."
 #: ../imagery/i.landsat.acca/main.c:111 ../imagery/i.landsat.toar/main.c:82
 msgid "Base name of input raster bands"
@@ -26179,8 +28203,11 @@
 msgstr "Verwende immer die Wolkensignatur (Schritt 14)"
 #: ../imagery/i.landsat.acca/main.c:159
-msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
-msgstr "Überspringe den zweiten Durchgang und fasse warme (nicht mehrdeutig) und kalte Wolken zusammen."
+msgid ""
+"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgstr ""
+"Überspringe den zweiten Durchgang und fasse warme (nicht mehrdeutig) und "
+"kalte Wolken zusammen."
 #: ../imagery/i.landsat.acca/main.c:164
 msgid "Include a category for cloud shadows"
@@ -26302,8 +28329,12 @@
 msgstr "Bearbeite den zweiten Durchgang..."
 #: ../imagery/i.vpoints/main.c:97
-msgid "Set registration points for an imagery group from a vector map or keyboard entry."
-msgstr "Setze Passpunkte für eine Bildgruppe basierend auf einer Vektorkarte oder durch Koordinateneingaben über die Tastatur."
+msgid ""
+"Set registration points for an imagery group from a vector map or keyboard "
+"entry."
+msgstr ""
+"Setze Passpunkte für eine Bildgruppe basierend auf einer Vektorkarte oder "
+"durch Koordinateneingaben über die Tastatur."
 #: ../imagery/i.vpoints/main.c:105 ../imagery/i.points/main.c:106
 msgid "Name of imagery group to be registered"
@@ -26368,7 +28399,9 @@
 msgstr ""
 #: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
-msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
+msgid ""
+"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
+"kind of simple atmospheric correction"
 msgstr ""
 #: ../imagery/i.albedo/main.c:127
@@ -26473,12 +28506,20 @@
 msgstr "Sites"
 #: ../imagery/i.cluster/main.c:79
-msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
-msgstr "Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels eines Clusteralgorithmus."
+msgid ""
+"Generates spectral signatures for land cover types in an image using a "
+"clustering algorithm."
+msgstr ""
+"Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels "
+"eines Clusteralgorithmus."
 #: ../imagery/i.cluster/main.c:82
-msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
-msgstr "Die resultierende Signaturdatei wird als Eingabe für i.maxlik verwendet, um eine unüberwachte Bildklassifikation zu erzeugen."
+msgid ""
+"The resulting signature file is used as input for i.maxlik, to generate an "
+"unsupervised image classification."
+msgstr ""
+"Die resultierende Signaturdatei wird als Eingabe für i.maxlik verwendet, um "
+"eine unüberwachte Bildklassifikation zu erzeugen."
 #: ../imagery/i.cluster/main.c:95 ../imagery/i.gensigset/parse.c:25
 #: ../imagery/i.gensig/parse.c:26
@@ -26673,7 +28714,9 @@
 #: ../imagery/i.cluster/main.c:288
 msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr "Speicher voll! Bitte wiederholen Sie den Lauf mit einer kleineren Stichprobengröße."
+msgstr ""
+"Speicher voll! Bitte wiederholen Sie den Lauf mit einer kleineren "
+"Stichprobengröße."
 #: ../imagery/i.cluster/main.c:294
 #, c-format
@@ -26681,12 +28724,18 @@
 msgstr "Stichprobengröße: %d Punkte\n"
 #: ../imagery/i.cluster/main.c:297
-msgid "Not enough sample points. Please run again and choose a larger sample size."
-msgstr "Nicht genügend Stichprobenpunkte. Bitte wiederholen Sie den Lauf mit einer größeren Stichprobe."
+msgid ""
+"Not enough sample points. Please run again and choose a larger sample size."
+msgstr ""
+"Nicht genügend Stichprobenpunkte. Bitte wiederholen Sie den Lauf mit einer "
+"größeren Stichprobe."
 #: ../imagery/i.cluster/main.c:301
-msgid "Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr "Nicht genug nicht-null Stichprobenpunkte. Bitte überprüfen Sie die aktuelle Region (und Maske)."
+msgid ""
+"Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr ""
+"Nicht genug nicht-null Stichprobenpunkte. Bitte überprüfen Sie die aktuelle "
+"Region (und Maske)."
 #: ../imagery/i.cluster/main.c:314
 #, c-format
@@ -26705,7 +28754,9 @@
 #: ../imagery/i.cluster/main.c:326
 #, c-format
 msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr "Kann die Signaturdatei <%s> für die Gruppe <%s> Untergruppe <%s> nicht erzeugen."
+msgstr ""
+"Kann die Signaturdatei <%s> für die Gruppe <%s> Untergruppe <%s> nicht "
+"erzeugen."
 #: ../imagery/i.cluster/main.c:331
 #, c-format
@@ -26891,12 +28942,20 @@
 msgstr "Bildverarbeitung, Klassifikation"
 #: ../imagery/i.class/main.c:96
-msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
-msgstr "Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt Trainingsgebiete zu markieren."
+msgid ""
+"Generates spectral signatures for an image by allowing the user to outline "
+"regions of interest."
+msgstr ""
+"Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt "
+"Trainingsgebiete zu markieren."
 #: ../imagery/i.class/main.c:99
-msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
-msgstr "Die resultierende Signatur-Datei kann als Eingabe für i.maxlik oder als Start-Signatur für i.cluster verwendet werden."
+msgid ""
+"The resulting signature file can be used as input for i.maxlik or as a seed "
+"signature file for i.cluster."
+msgstr ""
+"Die resultierende Signatur-Datei kann als Eingabe für i.maxlik oder als "
+"Start-Signatur für i.cluster verwendet werden."
 #: ../imagery/i.class/main.c:113 ../imagery/i.cca/main.c:95
 msgid "Name of input imagery subgroup"
@@ -26912,7 +28971,9 @@
 #: ../imagery/i.class/main.c:135
 msgid "You have a mask set. Unset mask and run again"
-msgstr "Es ist eine Maske gesetzt. Beseitigen Sie die Maske und versuchen Sie es erneut"
+msgstr ""
+"Es ist eine Maske gesetzt. Beseitigen Sie die Maske und versuchen Sie es "
+"erneut"
 #: ../imagery/i.class/main.c:144 ../imagery/i.group/main.c:117
 #: ../imagery/i.target/main.c:80
@@ -26922,7 +28983,8 @@
 #: ../imagery/i.class/main.c:253
 #, c-format
 msgid "** The following raster maps in subgroup [%s] do not exist:"
-msgstr "** Die folgenden Rasterkarten in der Untergruppe [%s] existieren nicht:"
+msgstr ""
+"** Die folgenden Rasterkarten in der Untergruppe [%s] existieren nicht:"
 #: ../imagery/i.class/main.c:262
 #, c-format
@@ -26977,7 +29039,8 @@
 #: ../imagery/i.class/add_point.c:22
 #, c-format
 msgid "Can't mark another point.  Only %d points allowed.  Sorry."
-msgstr "Kann keinen anderen Punkt markieren. Nur %d Punkte sind erlaubt. Sorry."
+msgstr ""
+"Kann keinen anderen Punkt markieren. Nur %d Punkte sind erlaubt. Sorry."
 #: ../imagery/i.class/remove_mask.c:15
 msgid "Error while removing the old MASK cell map."
@@ -27037,7 +29100,9 @@
 msgstr "Kein Zoomfenster definiert."
 #: ../imagery/i.evapo.mh/main.c:72
-msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
+msgid ""
+"Computes evapotranspiration calculation modified or original Hargreaves "
+"formulation, 2001."
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:78
@@ -27381,7 +29446,8 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:256
-msgid "Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7])"
+msgid ""
+"Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7])"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:260
@@ -27441,7 +29507,9 @@
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:61
-msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
+msgid ""
+"Computes potential evapotranspiration calculation with hourly Penman-"
+"Monteith."
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:65
@@ -27500,11 +29568,16 @@
 #: ../imagery/i.maxlik/main.c:66
 msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr "Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
+msgstr ""
+"Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
 #: ../imagery/i.maxlik/main.c:68
-msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
-msgstr "Die Klassifikation basiert auf der Information der spektralen Signatur erzeugt von .cluster, i.class, oder i.gensig."
+msgid ""
+"Classification is based on the spectral signature information generated by "
+"either i.cluster, i.class, or i.gensig."
+msgstr ""
+"Die Klassifikation basiert auf der Information der spektralen Signatur "
+"erzeugt von .cluster, i.class, oder i.gensig."
 #: ../imagery/i.maxlik/main.c:81 ../imagery/i.smap/parse.c:20
 #, fuzzy
@@ -27524,17 +29597,26 @@
 #: ../imagery/i.maxlik/main.c:92
 #, fuzzy
 msgid "Name for output raster map holding reject threshold results"
-msgstr "Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
+msgstr ""
+"Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
 #: ../imagery/i.maxlik/open.c:27
 #, c-format
-msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
-msgstr "Untergruppe <%s> der Gruppe <%s> beinhaltet keine Rasterkarten. Die Untergruppe muss mindestens 2 Rasterkarten haben."
+msgid ""
+"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
+"have at least 2 raster maps."
+msgstr ""
+"Untergruppe <%s> der Gruppe <%s> beinhaltet keine Rasterkarten. Die "
+"Untergruppe muss mindestens 2 Rasterkarten haben."
 #: ../imagery/i.maxlik/open.c:30
 #, c-format
-msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
-msgstr "Untergruppe <%s> der Gruppe <%s> hat nur eine Rasterkarte. Die Untergruppe muss mindestens 2 Rasterkarten haben."
+msgid ""
+"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
+"least 2 raster maps."
+msgstr ""
+"Untergruppe <%s> der Gruppe <%s> hat nur eine Rasterkarte. Die Untergruppe "
+"muss mindestens 2 Rasterkarten haben."
 #: ../imagery/i.maxlik/open.c:47
 #, c-format
@@ -27542,8 +29624,12 @@
 msgstr "Kann die Signaturdatei <%s> nicht öffnen."
 #: ../imagery/i.his.rgb/main.c:52
-msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
-msgstr "Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum in den RGB (Rot-Grün-Blau) Farbraum."
+msgid ""
+"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+"RGB (Red-Green-Blue) color space."
+msgstr ""
+"Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum "
+"in den RGB (Rot-Grün-Blau) Farbraum."
 #: ../imagery/i.his.rgb/main.c:58
 msgid "Name of input raster map (hue)"
@@ -27589,8 +29675,12 @@
 msgstr ""
 #: ../imagery/i.smap/main.c:44
-msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
-msgstr "Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des 'sequential maximum a posteriori (SMAP)' Ansatzes durch."
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+"Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des "
+"'sequential maximum a posteriori (SMAP)' Ansatzes durch."
 #: ../imagery/i.smap/segment.c:67
 msgid "Number of classes must be < 256"
@@ -27634,7 +29724,9 @@
 #: ../imagery/i.smap/parse.c:33
 #, fuzzy
 msgid "Name for output raster map holding goodness of fit (lower is better)"
-msgstr "Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten geschrieben werden"
+msgstr ""
+"Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten "
+"geschrieben werden"
 #: ../imagery/i.smap/parse.c:37
 msgid "Size of submatrix to process at one time"
@@ -27681,12 +29773,16 @@
 #: ../imagery/i.gensigset/subcluster.c:552
 msgid "Unreliable clustering. Try a smaller initial number of clusters"
-msgstr "Unzuverlässiger Clusterprozess. Versuchen Sie es mit einer kleineren Anzahl von Anfangsclustern."
+msgstr ""
+"Unzuverlässiger Clusterprozess. Versuchen Sie es mit einer kleineren Anzahl "
+"von Anfangsclustern."
 #: ../imagery/i.gensigset/subcluster.c:561
 #, c-format
 msgid "Removed a singular subsignature number %d (%d remain)"
-msgstr "Habe eine singuläre Unter-Signatur mit der Nummer %d entfernt (%d verbleiben)."
+msgstr ""
+"Habe eine singuläre Unter-Signatur mit der Nummer %d entfernt (%d "
+"verbleiben)."
 #: ../imagery/i.gensigset/get_train.c:35 ../imagery/i.gensig/get_train.c:32
 msgid "Finding training classes..."
@@ -27752,7 +29848,9 @@
 msgstr "Unzulässige Anzahl von Unter-Signaturen (%s)."
 #: ../imagery/i.evapo.time/main.c:79
-msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
+msgid ""
+"Computes temporal integration of satellite ET actual (ETa) following the "
+"daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:86
@@ -27882,7 +29980,9 @@
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:104
-msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.\n"
+msgid ""
+"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
+"from ASTER DN.\n"
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:108
@@ -27946,7 +30046,8 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:94
-msgid "Uses red and nir bands mostly, and some indices require additional bands."
+msgid ""
+"Uses red and nir bands mostly, and some indices require additional bands."
 msgstr ""
 #: ../imagery/i.vi/main.c:101
@@ -28102,7 +30203,9 @@
 msgstr "Maximaler Radius der Ring/Kreis-Karte (in Metern)."
 #: ../imagery/i.vi/main.c:202
-msgid "If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
+msgid ""
+"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 "
+"for Landsat -> [0-255])"
 msgstr ""
 #: ../imagery/i.vi/main.c:227
@@ -28138,7 +30241,8 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:253
-msgid "msavi2 index requires red and nir maps, and 3 parameters related to soil line"
+msgid ""
+"msavi2 index requires red and nir maps, and 3 parameters related to soil line"
 msgstr ""
 #: ../imagery/i.vi/main.c:256
@@ -28358,7 +30462,9 @@
 msgstr "Features"
 #: ../imagery/i.eb.netrad/main.c:89
-msgid "Name of the difference map of temperature from surface skin to about 2 m height [K]"
+msgid ""
+"Name of the difference map of temperature from surface skin to about 2 m "
+"height [K]"
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:90
@@ -28434,7 +30540,9 @@
 #: ../imagery/i.fft/main.c:107
 msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr "Raster Maske (MASK) gefunden, denken Sie über das Löschen nach (siehe MAN Seiten). Fahre trotzdem fort..."
+msgstr ""
+"Raster Maske (MASK) gefunden, denken Sie über das Löschen nach (siehe MAN "
+"Seiten). Fahre trotzdem fort..."
 #: ../imagery/i.fft/main.c:130
 #, c-format
@@ -28678,7 +30786,9 @@
 #: ../imagery/i.pca/main.c:300
 msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr "Die Länge des Skalierungsbereichs sollte > 0 sein. Verwende Standardwerte: 0,255. "
+msgstr ""
+"Die Länge des Skalierungsbereichs sollte > 0 sein. Verwende Standardwerte: "
+"0,255. "
 #: ../imagery/i.pca/main.c:346
 msgid "Computing covariance matrix..."
@@ -28715,7 +30825,9 @@
 #: ../imagery/i.rectify/cp.c:21
 #, fuzzy, c-format
 msgid "Not enough active control points for thin plate spline."
-msgstr "Nicht genügend aktive Kontrollpunkte für den momentanen Grad, %d werden benötigt."
+msgstr ""
+"Nicht genügend aktive Kontrollpunkte für den momentanen Grad, %d werden "
+"benötigt."
 #: ../imagery/i.rectify/cp.c:24 ../imagery/i.rectify/cp.c:51
 #: ../vector/v.rectify/cp.c:363
@@ -28740,7 +30852,9 @@
 #: ../imagery/i.rectify/cp.c:47 ../vector/v.rectify/cp.c:359
 #, c-format
 msgid "Not enough active control points for current order, %d are required."
+msgstr ""
+"benötigt."
 #: ../imagery/i.rectify/main.c:100 ../vector/v.rectify/main.c:71
 #, fuzzy
@@ -28748,8 +30862,12 @@
 #: ../imagery/i.rectify/main.c:102
-msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
-msgstr "Rektifiziert ein Bild indem eine Koordinatentransformation für jedes Pixel des Bildes basierend auf den Kontrollpunkten durchgeführt wird."
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points."
+msgstr ""
+"Rektifiziert ein Bild indem eine Koordinatentransformation für jedes Pixel "
+"des Bildes basierend auf den Kontrollpunkten durchgeführt wird."
 #: ../imagery/i.rectify/main.c:124 ../vector/v.rectify/main.c:102
 msgid "Rectification polynom order (1-3)"
@@ -28826,11 +30944,13 @@
 #: ../imagery/i.topo.corr/main.c:100
 msgid "Solar azimuth is necessary to calculate illumination terrain model"
-msgstr "Sonnenazimuth ist notwendig, um das beleuchtete Geländemodell zu berechnen."
+msgstr ""
+"Sonnenazimuth ist notwendig, um das beleuchtete Geländemodell zu berechnen."
 #: ../imagery/i.topo.corr/main.c:104
 msgid "Reflectance maps are necessary to make topographic correction"
-msgstr "Reflektionskarten sind notwendig, um topographische Korrekturen zu berechnen."
+msgstr ""
+"Reflektionskarten sind notwendig, um topographische Korrekturen zu berechnen."
 #: ../imagery/i.topo.corr/main.c:164
 msgid "Illumination model is of CELL type"
@@ -28882,7 +31002,9 @@
 #: ../imagery/i.segment/create_isegs.c:522
 #, c-format
-msgid "Segmentation processes stopped at %d due to reaching max iteration limit, more merges may be possible"
+msgid ""
+"Segmentation processes stopped at %d due to reaching max iteration limit, "
+"more merges may be possible"
 msgstr ""
 #: ../imagery/i.segment/create_isegs.c:524
@@ -28912,7 +31034,8 @@
 #: ../imagery/i.segment/create_isegs.c:1555
 #, fuzzy, c-format
 msgid "Region size is larger than 2: %d"
-msgstr "Region-Größe ist kleiner als die Minimal-Region; es wird nichts angezeigt."
+msgstr ""
+"Region-Größe ist kleiner als die Minimal-Region; es wird nichts angezeigt."
 #: ../imagery/i.segment/create_isegs.c:1197
 #, c-format
@@ -28987,7 +31110,8 @@
 msgstr "Name der Eingabe-Rasterkarte."
 #: ../imagery/i.segment/parse_args.c:117
-msgid "Must be integer values, each area will be segmented independent of the others"
+msgid ""
+"Must be integer values, each area will be segmented independent of the others"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:123
@@ -28996,7 +31120,9 @@
 msgstr "Name der Ausgabe-Rasterkarte mit vertikaler Wölbung."
 #: ../imagery/i.segment/parse_args.c:128
-msgid "Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel"
+msgid ""
+"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
+"each pixel"
 msgstr ""
 #: ../imagery/i.segment/parse_args.c:134
@@ -29162,8 +31288,12 @@
 msgstr "Speicher ist zu Ende (Out-of-memory)."
 #: ../imagery/i.rgb.his/main.c:52
-msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
-msgstr "Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS (Hue-Intensity-Saturation) Farbraum."
+msgid ""
+"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
+"Intensity-Saturation) color space."
+msgstr ""
+"Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS "
+"(Hue-Intensity-Saturation) Farbraum."
 #: ../imagery/i.rgb.his/main.c:58
 msgid "Name of input raster map (red)"
@@ -29190,8 +31320,12 @@
 msgstr "Name der Ausgabe-Rasterkarte (Sättigung, saturation)."
 #: ../imagery/i.landsat.toar/main.c:69
-msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
-msgstr "Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für Landsat MSS/TM/ETM+/OLI."
+msgid ""
+"Calculates top-of-atmosphere radiance or reflectance and temperature for "
+"Landsat MSS/TM/ETM+/OLI"
+msgstr ""
+"Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für "
+"Landsat MSS/TM/ETM+/OLI."
 #: ../imagery/i.landsat.toar/main.c:76
 #, fuzzy
@@ -29288,7 +31422,8 @@
 #: ../imagery/i.landsat.toar/main.c:181
 msgid "Minimum pixels to consider digital number as dark object"
-msgstr "Minimum Pixel um die \"digital number\" als dunkles Objekt zu betrachten"
+msgstr ""
+"Minimum Pixel um die \"digital number\" als dunkles Objekt zu betrachten"
 #: ../imagery/i.landsat.toar/main.c:190
 msgid "Rayleigh atmosphere (diffuse sky irradiance)"
@@ -29346,7 +31481,8 @@
 msgstr "Ausgabe der Strahlung am Sensor anstatt der Reflexion für alle Kanäle"
 #: ../imagery/i.landsat.toar/main.c:225
-msgid "Input raster maps use as extension the number of the band instead the code"
+msgid ""
+"Input raster maps use as extension the number of the band instead the code"
 msgstr "Eingabe-Rasterkarten verwenden die Nummer des Kanals anstatt des Codes"
 #: ../imagery/i.landsat.toar/main.c:229
@@ -29436,7 +31572,8 @@
 #: ../imagery/i.cca/main.c:88
 #, fuzzy
 msgid "Canonical components analysis (CCA) program for image processing."
-msgstr "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
+msgstr ""
+"Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
 #: ../imagery/i.cca/main.c:102
 msgid "File containing spectral signatures"
@@ -29509,7 +31646,9 @@
 " Geben Sie Variablen manuell ein."
 #: ../imagery/i.eb.evapfr/main.c:53
-msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgid ""
+"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
+"moisture (Makin, Molden and Bastiaanssen, 2001)."
 msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:63
@@ -29616,7 +31755,8 @@
 #: ../vector/v.in.dxf/main.c:91
 #, fuzzy
 msgid "Invert selection by DXF layers (don't import layers in list)"
-msgstr "Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
+msgstr ""
+"Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
 #: ../vector/v.in.dxf/main.c:96
 msgid "Import all objects into one layer"
@@ -29703,8 +31843,13 @@
 #: ../vector/v.kernel/main.c:112
 #, fuzzy
-msgid "Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
-msgstr "Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf einem Vektornetzwerk erstellt werden."
+msgid ""
+"Density is computed using a moving kernel. Optionally generates a vector "
+"density map on a vector network."
+msgstr ""
+"Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines "
+"gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf einem "
+"Vektornetzwerk erstellt werden."
 #: ../vector/v.kernel/main.c:116
 #, fuzzy
@@ -29761,7 +31906,9 @@
 #: ../vector/v.kernel/main.c:180
 #, fuzzy
 msgid "No method applied at nodes with more than 2 arcs"
-msgstr "nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;Equal split (Okabe 2009) angewendet bei Knoten;"
+msgstr ""
+"nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;"
+"Equal split (Okabe 2009) angewendet bei Knoten;"
 #: ../vector/v.kernel/main.c:181
 msgid "Equal split (Okabe 2009) applied at nodes"
@@ -29772,21 +31919,34 @@
 msgstr "Kernel Funktion"
 #: ../vector/v.kernel/main.c:197
-msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
-msgstr "Versuche eine optimale Standardabweichung mit 'stddeviation' als Maximum zu berechnen (experimentell)."
+msgid ""
+"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
+"maximum (experimental)"
+msgstr ""
+"Versuche eine optimale Standardabweichung mit 'stddeviation' als Maximum zu "
+"berechnen (experimentell)."
 #: ../vector/v.kernel/main.c:202
 msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr "Berechnet nur die optimale Standardabweichung und beendet sich (keine Karte wird geschrieben)."
+msgstr ""
+"Berechnet nur die optimale Standardabweichung und beendet sich (keine Karte "
+"wird geschrieben)."
 #: ../vector/v.kernel/main.c:207
-msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
-msgstr "Im Netzwerk-Modus: normalisiere Werte durch die Summe der Dichte multipliziert mit der Länge der Segmente. Integral über die Ausgabekarte ergibt 1.0 * mult."
+msgid ""
+"In network mode, normalize values by sum of density multiplied by length of "
+"each segment. Integral over the output map then gives 1.0 * mult"
+msgstr ""
+"Im Netzwerk-Modus: normalisiere Werte durch die Summe der Dichte "
+"multipliziert mit der Länge der Segmente. Integral über die Ausgabekarte "
+"ergibt 1.0 * mult."
 #: ../vector/v.kernel/main.c:213
 #, fuzzy
 msgid "In network mode, multiply the result by number of input points"
-msgstr "Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-Punkte."
+msgstr ""
+"Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-"
+"Punkte."
 #: ../vector/v.kernel/main.c:223 ../vector/v.in.lidar/main.c:480
 #, c-format
@@ -29808,12 +31968,20 @@
 msgstr "Unbekannte Kernelfunktion"
 #: ../vector/v.kernel/main.c:276
-msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
-msgstr "Optimale Berechnung der Standardabweichung wird nur durch die Knoten-Methode 'none' und die Kernelfunktion 'gaussian' unterstützt."
+msgid ""
+"Optimal standard deviation calculation is supported only for node method "
+"'none' and kernel function 'gaussian'."
+msgstr ""
+"Optimale Berechnung der Standardabweichung wird nur durch die Knoten-Methode "
+"'none' und die Kernelfunktion 'gaussian' unterstützt."
 #: ../vector/v.kernel/main.c:280
-msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
-msgstr "Optimale Berechnung der Standardabweichung wird nur durch die Kernel-Funktion 'gaussian' unterstützt."
+msgid ""
+"Optimal standard deviation calculation is supported only for kernel function "
+"'gaussian'."
+msgstr ""
+"Optimale Berechnung der Standardabweichung wird nur durch die Kernel-"
+"Funktion 'gaussian' unterstützt."
 #: ../vector/v.kernel/main.c:297
 #, fuzzy, c-format
@@ -29832,8 +32000,12 @@
 #: ../vector/v.kernel/main.c:358
 #, c-format
-msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
-msgstr "Automatisches Auswählen der Glättungsparameter (Standardabweichung). Der Maximalwert der möglichen Werte der Standardabweichung ist auf %f gesetzt"
+msgid ""
+"Automatic choice of smoothing parameter (standard deviation), maximum "
+"possible value of standard deviation is set to %f"
+msgstr ""
+"Automatisches Auswählen der Glättungsparameter (Standardabweichung). Der "
+"Maximalwert der möglichen Werte der Standardabweichung ist auf %f gesetzt"
 #: ../vector/v.kernel/main.c:365
 #, c-format
@@ -29852,8 +32024,12 @@
 #: ../vector/v.kernel/main.c:383
 #, c-format
-msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
-msgstr "Entfernungen zwischen allen Punkten liegt über %e (4 * Standardabweichung), daher kann kein optimaler Wert berechnet werden."
+msgid ""
+"Distances between all points are beyond %e (4 * standard deviation), unable "
+"to calculate optimal value."
+msgstr ""
+"Entfernungen zwischen allen Punkten liegt über %e (4 * Standardabweichung), "
+"daher kann kein optimaler Wert berechnet werden."
 #: ../vector/v.kernel/main.c:394
 #, c-format
@@ -29898,8 +32074,12 @@
 #: ../vector/v.rectify/main.c:73
 #, fuzzy
-msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
+msgid ""
+"Rectifies a vector by computing a coordinate transformation for each object "
+"in the vector based on the control points."
+msgstr ""
 #: ../vector/v.rectify/main.c:88
 #, fuzzy
@@ -29909,7 +32089,9 @@
 #: ../vector/v.rectify/main.c:93
 #, fuzzy
 msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
-msgstr "Name der Ausgabekarte (wenn keiner oder \"-\"  angegeben wurdeerfolgt die Ausgabe nach stdout)."
+msgstr ""
+"Name der Ausgabekarte (wenn keiner oder \"-\"  angegeben wurdeerfolgt die "
+"Ausgabe nach stdout)."
 #: ../vector/v.rectify/main.c:105
 #, fuzzy
@@ -29988,13 +32170,17 @@
 #: ../vector/v.extrude/main.c:72
 #, fuzzy
-msgid "Extrudes flat vector features to 3D vector features with defined height."
+msgid ""
+"Extrudes flat vector features to 3D vector features with defined height."
 msgstr "Presst flache Vektorobjekte in eine 3D-Form mit definierter Höhe."
 #: ../vector/v.extrude/main.c:74
 #, fuzzy
-msgid "Optionally the height can be derived from sampling of elevation raster map."
-msgstr "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit Höheninformationen."
+msgid ""
+"Optionally the height can be derived from sampling of elevation raster map."
+msgstr ""
+"Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit "
+"Höheninformationen."
 #: ../vector/v.extrude/main.c:78
 msgid "Trace elevation"
@@ -30048,7 +32234,9 @@
 #: ../vector/v.extrude/main.c:197
 #, c-format
-msgid "Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming layer '1'."
+msgid ""
+"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
+"layer '1'."
 msgstr ""
 #: ../vector/v.extrude/main.c:229
@@ -30077,7 +32265,8 @@
 #: ../vector/v.extrude/main.c:288
 #, c-format
-msgid "Unable to fetch height from DB for area %d. Using default fixed height %f."
+msgid ""
+"Unable to fetch height from DB for area %d. Using default fixed height %f."
 msgstr ""
 #: ../vector/v.extrude/main.c:314
@@ -30092,7 +32281,8 @@
 #: ../vector/v.extrude/main.c:341
 #, c-format
-msgid "Unable to fetch height from DB for line %d. Using default fixed height %f."
+msgid ""
+"Unable to fetch height from DB for line %d. Using default fixed height %f."
 msgstr ""
 #: ../vector/v.extrude/main.c:359
@@ -30160,7 +32350,8 @@
 #: ../vector/v.label/main.c:137
 msgid "Space between letters for curled labels (in map-units)"
-msgstr "Zwischenraum zwischen den Buchstaben für gewellte Label (in Karteneinheiten)."
+msgstr ""
+"Zwischenraum zwischen den Buchstaben für gewellte Label (in Karteneinheiten)."
 #: ../vector/v.label/main.c:144
 msgid "Label size (in points)"
@@ -30185,11 +32376,16 @@
 #: ../vector/v.label/main.c:200 ../vector/v.label.sa/main.c:135
 msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr "Undurchsichtig für Vektoren (nur relevant, wenn eine Hintergrundfarbe ausgewählt wurde)."
+msgstr ""
+"Undurchsichtig für Vektoren (nur relevant, wenn eine Hintergrundfarbe "
+"ausgewählt wurde)."
 #: ../vector/v.label/main.c:251
-msgid "size and space options vary significantly which may lead to crummy output"
-msgstr "Größen- und Abstandsoptionen differieren signifikant, was zu einer komischen Ausgabe führen kann."
+msgid ""
+"size and space options vary significantly which may lead to crummy output"
+msgstr ""
+"Größen- und Abstandsoptionen differieren signifikant, was zu einer komischen "
+"Ausgabe führen kann."
 #: ../vector/v.label/main.c:259
 msgid "Too many parameters for <reference>"
@@ -30221,7 +32417,8 @@
 #: ../vector/v.net.connectivity/main.c:56
 msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr "Berechnet Vertex connectivity zwischen zwei Gruppen von Knoten im Netzwerk."
+msgstr ""
+"Berechnet Vertex connectivity zwischen zwei Gruppen von Knoten im Netzwerk."
 #: ../vector/v.net.connectivity/main.c:65
 #: ../vector/v.net.connectivity/main.c:71
@@ -30288,7 +32485,8 @@
 #: ../vector/v.net.connectivity/main.c:102
 msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
-msgstr "Set1 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr ""
+"Set1 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.connectivity/main.c:107
 msgid "Set2 category values"
@@ -30301,7 +32499,8 @@
 #: ../vector/v.net.connectivity/main.c:113
 msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
-msgstr "Set2 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr ""
+"Set2 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.connectivity/main.c:146
 #: ../vector/v.net.connectivity/main.c:153
@@ -30356,8 +32555,11 @@
 #: ../vector/v.transform/main.c:74
 #, fuzzy
-msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
-msgstr "Führt eine affine Transformation (schieben, skalieren und rotieren oder GPCs) von Vektorkarten durch."
+msgid ""
+"Performs an affine transformation (shift, scale and rotate) on vector map."
+msgstr ""
+"Führt eine affine Transformation (schieben, skalieren und rotieren oder "
+"GPCs) von Vektorkarten durch."
 #: ../vector/v.transform/main.c:79
 msgid "Shift all z values to bottom=0"
@@ -30415,7 +32617,9 @@
 #: ../vector/v.transform/main.c:181
 #, fuzzy, c-format
 msgid "Columns require a valid layer. Please use '%s' parameter."
-msgstr "Der Name der Tabelle wurde nicht angegeben. Bitte verwenden Sie den Parameter '%s'."
+msgstr ""
+"Der Name der Tabelle wurde nicht angegeben. Bitte verwenden Sie den "
+"Parameter '%s'."
 #: ../vector/v.transform/main.c:211
 #, fuzzy, c-format
@@ -30473,8 +32677,13 @@
 #: ../vector/v.transform/trans_digit.c:112
 #, c-format
-msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
-msgstr "Kann den Wert der Kategorie %d aus der Tabelle <%s>, Spalte <%s> nicht selektieren. Verwende für die Kategorie %d den Standardtransformationsparameter %.3f."
+msgid ""
+"Unable to select value for category %d from table <%s>, column <%s>. For "
+"category %d using default transformation parameter %.3f."
+msgstr ""
+"Kann den Wert der Kategorie %d aus der Tabelle <%s>, Spalte <%s> nicht "
+"selektieren. Verwende für die Kategorie %d den "
+"Standardtransformationsparameter %.3f."
 #: ../vector/v.transform/trans_digit.c:123
 msgid "No category number defined. Using default transformation parameters."
@@ -30483,7 +32692,8 @@
 #: ../vector/v.in.ascii/main.c:53
 #, fuzzy
 msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
+msgstr ""
+"Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
 #: ../vector/v.in.ascii/main.c:71
 msgid "simple x,y[,z] list"
@@ -30504,15 +32714,21 @@
 #: ../vector/v.in.ascii/main.c:88
 msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr "Anzahl der Kopfzeilen, die am Anfang der Eingabedatei übersprungen werden soll (Punktmodus)."
+msgstr ""
+"Anzahl der Kopfzeilen, die am Anfang der Eingabedatei übersprungen werden "
+"soll (Punktmodus)."
 #: ../vector/v.in.ascii/main.c:97
 msgid "Column definition in SQL style (points mode)"
 msgstr "Spaltendefinition im SQL-Stil (Punkt-Modus)."
 #: ../vector/v.in.ascii/main.c:98
-msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
-msgstr "Zum Beispiel: 'x double precision, y double precision, cat int, name varchar(10)'"
+msgid ""
+"For example: 'x double precision, y double precision, cat int, name "
+"varchar(10)'"
+msgstr ""
+"Zum Beispiel: 'x double precision, y double precision, cat int, name "
+"varchar(10)'"
 #: ../vector/v.in.ascii/main.c:110 ../vector/v.in.ascii/main.c:120
 msgid "First column is 1"
@@ -30528,15 +32744,20 @@
 #: ../vector/v.in.ascii/main.c:130
 msgid "First column is 1. If 0, z coordinate is not used"
-msgstr "Erste Spalte ist 1. Wenn 0, dann wird die Z-Koordinate nicht verwendet."
+msgstr ""
+"Erste Spalte ist 1. Wenn 0, dann wird die Z-Koordinate nicht verwendet."
 #: ../vector/v.in.ascii/main.c:140
 msgid "Number of column used as category (points mode)"
 msgstr "Nummer der Spalte, die als Kategorie genutzt wird (Punkt-Modus)."
 #: ../vector/v.in.ascii/main.c:142
-msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
-msgstr "Erste Spalte ist 1. Wenn 0, dann wird jeder Zeile eine eindeutige Kategorie zugeweisen und in die neue Spalte 'cat' geschrieben."
+msgid ""
+"First column is 1. If 0, unique category is assigned to each row and written "
+"to new column 'cat'"
+msgstr ""
+"Erste Spalte ist 1. Wenn 0, dann wird jeder Zeile eine eindeutige Kategorie "
+"zugeweisen und in die neue Spalte 'cat' geschrieben."
 #: ../vector/v.in.ascii/main.c:146 ../vector/v.in.dwg/main.c:106
 msgid "Create 3D vector map"
@@ -30544,7 +32765,9 @@
 #: ../vector/v.in.ascii/main.c:151
 msgid "Create a new empty vector map and exit. Nothing is read from input."
-msgstr "Erstellt eine neue, leere Vektorkarte und beendet sich. Nichts wird eingelesen."
+msgstr ""
+"Erstellt eine neue, leere Vektorkarte und beendet sich. Nichts wird "
+"eingelesen."
 #: ../vector/v.in.ascii/main.c:156
 msgid "Don't expect a header when reading in standard format"
@@ -30556,7 +32779,8 @@
 #: ../vector/v.in.ascii/main.c:171
 msgid "Only import points falling within current region (points mode)"
-msgstr "Importiere nur Punkte die sich innerhalb der aktuellen Region befinden."
+msgstr ""
+"Importiere nur Punkte die sich innerhalb der aktuellen Region befinden."
 #: ../vector/v.in.ascii/main.c:188
 msgid "Please specify z column"
@@ -30598,7 +32822,9 @@
 #: ../vector/v.in.ascii/main.c:272 ../vector/v.in.ascii/main.c:276
 #: ../vector/v.in.ascii/main.c:281 ../vector/v.in.ascii/main.c:286
 #, fuzzy, c-format
-msgid "'%s' column number > minimum last column number (incorrect field separator or format?)"
+msgid ""
+"'%s' column number > minimum last column number (incorrect field separator "
+"or format?)"
 msgstr ""
 "Z-Spaltennummer > letzte Spaltennummer\n"
 "(falsches Trennzeichen?)"
@@ -30615,51 +32841,66 @@
 #: ../vector/v.in.ascii/main.c:417
 #, c-format
-msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
-msgstr "Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der Spalten (%d) in der Eingabe überein."
+msgid ""
+"Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr ""
+"Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der "
+"Spalten (%d) in der Eingabe überein."
 #: ../vector/v.in.ascii/main.c:445
 #, c-format
 msgid "Column number %d <%s> defined as double has only integer values"
-msgstr "Spalte Nummer %d <%s> ist als double definiert und hat nur Integer-Werte."
+msgstr ""
+"Spalte Nummer %d <%s> ist als double definiert und hat nur Integer-Werte."
 #: ../vector/v.in.ascii/main.c:450
 #, c-format
 msgid "Column number %d <%s> defined as string has only integer values"
-msgstr "Spalte Nummer %d <%s> ist als string definiert und hat nur Integer-Werte."
+msgstr ""
+"Spalte Nummer %d <%s> ist als string definiert und hat nur Integer-Werte."
 #: ../vector/v.in.ascii/main.c:457
 #, c-format
 msgid "Column number %d <%s> defined as integer has double values"
-msgstr "Spalte Nummer %d <%s> ist als integer definiert und hat nur Double-Werte."
+msgstr ""
+"Spalte Nummer %d <%s> ist als integer definiert und hat nur Double-Werte."
 #: ../vector/v.in.ascii/main.c:462
 #, c-format
 msgid "Column number %d <%s> defined as string has double values"
-msgstr "Spalte Nummer %d <%s> ist als string definiert und hat nur Double-Werte."
+msgstr ""
+"Spalte Nummer %d <%s> ist als string definiert und hat nur Double-Werte."
 #: ../vector/v.in.ascii/main.c:469
 #, c-format
 msgid "Column number %d <%s> defined as integer has string values"
-msgstr "Spalte Nummer %d <%s> ist als integer definiert und hat nur String-Werte."
+msgstr ""
+"Spalte Nummer %d <%s> ist als integer definiert und hat nur String-Werte."
 #: ../vector/v.in.ascii/main.c:474
 #, c-format
 msgid "Column number %d <%s> defined as double has string values"
-msgstr "Spalte Nummer %d <%s> ist als double definiert und hat nur String-Werte."
+msgstr ""
+"Spalte Nummer %d <%s> ist als double definiert und hat nur String-Werte."
 #: ../vector/v.in.ascii/main.c:479
 #, c-format
 msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr "Länge der Spalte %d <%s> (%d) ist geringer als die maximale Länge der Werte (%d)."
+msgstr ""
+"Länge der Spalte %d <%s> (%d) ist geringer als die maximale Länge der Werte "
+"(%d)."
 #: ../vector/v.in.ascii/main.c:519
 msgid "Populating table..."
 msgstr "Fülle Tabelle..."
 #: ../vector/v.in.ascii/main.c:525
-msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
-msgstr "Konnte Attributetabelle nicht schliessen. Der DBMI-Treiber hat nicht alle Attribute akzeptiert."
+msgid ""
+"Could not close attribute table. The DBMI driver did not accept all "
+"attributes"
+msgstr ""
+"Konnte Attributetabelle nicht schliessen. Der DBMI-Treiber hat nicht alle "
+"Attribute akzeptiert."
 #: ../vector/v.in.ascii/main.c:534 ../vector/v.in.ascii/main.c:537
 #, fuzzy
@@ -30699,11 +32940,20 @@
 #: ../vector/v.surf.rst/main.c:146
 #, fuzzy
 msgid "Performs surface interpolation from vector points map by splines."
-msgstr "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance Squared Weighting."
+msgstr ""
+"Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance "
+"Squared Weighting."
 #: ../vector/v.surf.rst/main.c:148
-msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
-msgstr "Räumliche Approximation und topographische Analyse auf Basis gegebener Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-Rasterkarte geschrieben."
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
+msgstr ""
+"Räumliche Approximation und topographische Analyse auf Basis gegebener "
+"Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten "
+"Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-"
+"Rasterkarte geschrieben."
 #: ../vector/v.surf.rst/main.c:155
 msgid "Perform cross-validation procedure without raster approximation"
@@ -30716,10 +32966,14 @@
 #: ../vector/v.surf.rst/main.c:179 ../vector/v.surf.bspline/main.c:174
 #, fuzzy
 msgid "Name of the attribute column with values to be used for approximation"
-msgstr "Name der Attributspalte mit Werten, die für die Approximation verwendet werden (wen der Layer >0)."
+msgstr ""
+"Name der Attributspalte mit Werten, die für die Approximation verwendet "
+"werden (wen der Layer >0)."
 #: ../vector/v.surf.rst/main.c:180 ../vector/v.surf.idw/main.c:101
-msgid "If not given and input is 2D vector map then category values are used. If input is 3D vector map then z-coordinates are used."
+msgid ""
+"If not given and input is 2D vector map then category values are used. If "
+"input is 3D vector map then z-coordinates are used."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:190
@@ -30771,15 +33025,21 @@
 #: ../vector/v.surf.rst/main.c:301 ../vector/v.vol.rst/main.c:339
 msgid "Minimum distance between points (to remove almost identical points)"
-msgstr "Minimale Distanz zwischen Punkten (um fast identische Punkte zu entfernen)"
+msgstr ""
+"Minimale Distanz zwischen Punkten (um fast identische Punkte zu entfernen)"
 #: ../vector/v.surf.rst/main.c:309
-msgid "Maximum distance between points on isoline (to insert additional points)"
-msgstr "Maximale Distanz zwischen den Punkten auf einer Isolinie (zum Einfügen weiterer Punkte)."
+msgid ""
+"Maximum distance between points on isoline (to insert additional points)"
+msgstr ""
+"Maximale Distanz zwischen den Punkten auf einer Isolinie (zum Einfügen "
+"weiterer Punkte)."
 #: ../vector/v.surf.rst/main.c:318
 msgid "Conversion factor for values used for approximation"
-msgstr "Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden sollen."
+msgstr ""
+"Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden "
+"sollen."
 #: ../vector/v.surf.rst/main.c:326
 msgid "Anisotropy angle (in degrees counterclockwise from East)"
@@ -30793,19 +33053,30 @@
 #: ../vector/v.surf.rst/main.c:417
 msgid "You are not outputting any raster or vector maps"
-msgstr "Sie haben weder die Ausgabe von Vektor- noch von Rasterkarten veranlasst."
+msgstr ""
+"Sie haben weder die Ausgabe von Vektor- noch von Rasterkarten veranlasst."
 #: ../vector/v.surf.rst/main.c:426
-msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
-msgstr "Beide Kreuzvalidierungsoptionen (Schalter '-c' und die 'cvdev'-Vektorkarte) müssen angegeben werden."
+msgid ""
+"Both cross-validation options (-c flag and cvdev vector output) must be "
+"specified"
+msgstr ""
+"Beide Kreuzvalidierungsoptionen (Schalter '-c' und die 'cvdev'-Vektorkarte) "
+"müssen angegeben werden."
 #: ../vector/v.surf.rst/main.c:429
-msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
-msgstr "Die Kreuzvalidierung kann nicht gleichzeitig mit Ausgabe-Rasterkarten oder der 'devi'-Datei berechnet werden."
+msgid ""
+"The cross-validation cannot be computed simultaneously with output raster or "
+"devi file"
+msgstr ""
+"Die Kreuzvalidierung kann nicht gleichzeitig mit Ausgabe-Rasterkarten oder "
+"der 'devi'-Datei berechnet werden."
 #: ../vector/v.surf.rst/main.c:447
 msgid "Using anisotropy - both theta and scalex have to be specified"
-msgstr "Benutze Anisotropie - beide Parameter theta und scalex müssen angegeben werden."
+msgstr ""
+"Benutze Anisotropie - beide Parameter theta und scalex müssen angegeben "
+"werden."
 #: ../vector/v.surf.rst/main.c:455
 msgid "Both smatt and smooth options specified - using constant"
@@ -30813,7 +33084,8 @@
 #: ../vector/v.surf.rst/main.c:465
 msgid "The computation will last too long - lower npmin is suggested"
-msgstr "Die Berechnung dauert zu lange - es wird vorgeschlagen, npmin zu reduzieren."
+msgstr ""
+"Die Berechnung dauert zu lange - es wird vorgeschlagen, npmin zu reduzieren."
 #: ../vector/v.surf.rst/main.c:483
 msgid "Not enough memory for az"
@@ -30863,7 +33135,9 @@
 msgstr "Mapset <%s> nicht gefunden."
 #: ../vector/v.surf.rst/main.c:542 ../vector/v.surf.bspline/main.c:263
-msgid "Input is 3D: using attribute values instead of z-coordinates for approximation"
+msgid ""
+"Input is 3D: using attribute values instead of z-coordinates for "
+"approximation"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:544 ../vector/v.surf.bspline/main.c:265
@@ -30873,16 +33147,22 @@
 #: ../vector/v.surf.rst/main.c:548
 #, fuzzy
 msgid "Input is 2D: using attribute values for approximation"
+msgstr ""
+"sollen."
 #: ../vector/v.surf.rst/main.c:550
 #, fuzzy
 msgid "Input is 2D: using category values for approximation"
+msgstr ""
+"sollen."
 #: ../vector/v.surf.rst/main.c:662
 #, fuzzy, c-format
-msgid "Processing all selected output files will require %d bytes of disk space for temp files"
+msgid ""
+"Processing all selected output files will require %d bytes of disk space for "
+"temp files"
 msgstr ""
 "Bearbeite alle ausgewählten Ausgabedateien.\n"
 "Werde %d Byte Plattenspeicher für temp-Dateien benötigen."
@@ -30899,12 +33179,15 @@
 #: ../vector/v.surf.rst/main.c:706
 #, fuzzy
 msgid "Unable to write raster maps - try to increase resolution"
-msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
+msgstr ""
+"Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
 #: ../vector/v.info/print.c:130
 #, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
-msgstr "Die Datenbankverbindung für die Karte <%s> ist nicht definiert in der DB-Datei."
+msgstr ""
+"Die Datenbankverbindung für die Karte <%s> ist nicht definiert in der DB-"
+"Datei."
 #: ../vector/v.info/print.c:134
 #, fuzzy, c-format
@@ -31153,8 +33436,11 @@
 #: ../vector/v.info/parse.c:30
 #, fuzzy
-msgid "Print types/names of table columns for specified layer instead of info and exit"
-msgstr "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
+msgid ""
+"Print types/names of table columns for specified layer instead of info and "
+"exit"
+msgstr ""
+"Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
 #: ../vector/v.info/parse.c:35
 #, fuzzy
@@ -31198,7 +33484,9 @@
 #: ../vector/v.what.rast3/main.c:71
 #, fuzzy
 msgid "Uploads 3d raster values at positions of vector points to the table."
-msgstr "Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die Attributtabelle."
+msgstr ""
+"Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die "
+"Attributtabelle."
 #: ../vector/v.what.rast3/main.c:81
 #, fuzzy
@@ -31282,7 +33570,8 @@
 #: ../vector/v.category/main.c:79
 #, fuzzy
 msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
+msgstr ""
+"Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
 #: ../vector/v.category/main.c:92
 msgid "Feature ids (by default all features are processed)"
@@ -31300,7 +33589,9 @@
 #: ../vector/v.category/main.c:116
 #, fuzzy
 msgid "delete category (cat=-1 to delete all categories of given layer)"
-msgstr "Gebe anstelle der Attribute die minimale Ausdehnung der Region der selektierten Vektorfeatures aus."
+msgstr ""
+"Gebe anstelle der Attribute die minimale Ausdehnung der Region der "
+"selektierten Vektorfeatures aus."
 #: ../vector/v.category/main.c:117
 msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
@@ -31311,7 +33602,9 @@
 msgstr ""
 #: ../vector/v.category/main.c:119
-msgid "copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"
+msgid ""
+"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
+"layer 1 to layer 2 and 3)"
 msgstr ""
 #: ../vector/v.category/main.c:120
@@ -31342,8 +33635,11 @@
 msgstr "Kopiere die Tabelle nicht."
 #: ../vector/v.category/main.c:160
-msgid "Database connection and attribute tables for concerned layers are not changed"
-msgstr "Die Datenbankverbindung und die Attributtabellen der betroffenen Layer werden nicht geändert."
+msgid ""
+"Database connection and attribute tables for concerned layers are not changed"
+msgstr ""
+"Die Datenbankverbindung und die Attributtabellen der betroffenen Layer "
+"werden nicht geändert."
 #: ../vector/v.category/main.c:186 ../vector/v.category/main.c:248
 #: ../vector/v.category/main.c:256 ../vector/v.kcv/main.c:120
@@ -31353,8 +33649,12 @@
 msgstr "Kann Vektorkarte <%s> auf der topologischen Ebene %d nicht öffnen"
 #: ../vector/v.category/main.c:208
-msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
-msgstr "Ungültige Kategorie (muss größer oder gleich 0 sein). Normalerweise beginnen die Kategorien bei 1."
+msgid ""
+"Invalid category number (must be equal to or greater than 0). Normally "
+"category number starts at 1."
+msgstr ""
+"Ungültige Kategorie (muss größer oder gleich 0 sein). Normalerweise beginnen "
+"die Kategorien bei 1."
 #: ../vector/v.category/main.c:217
 #, c-format
@@ -31465,7 +33765,9 @@
 #: ../vector/v.out.ogr/main.c:95 ../vector/v.external.out/link.c:26
 #, c-format
-msgid "Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s\" given)"
+msgid ""
+"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s"
+"\" given)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:160
@@ -31487,83 +33789,135 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:285
-msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
+msgid ""
+"The map contains islands. With the -c flag, islands will appear as filled "
+"areas, not holes in the output map."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:291
 #, c-format
-msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Punkt(e) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+"%d Punkt(e) gefunden, die allerdings nicht zum Export angegeben wurden. "
+"Überprüfen Sie bitte den 'type'-Parameter."
 #: ../vector/v.out.ogr/main.c:296
 #, c-format
-msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Linie(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+"%d Linie(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
 #: ../vector/v.out.ogr/main.c:302
 #, c-format
-msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Grenzlinie(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr ""
+"%d Grenzlinie(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
 #: ../vector/v.out.ogr/main.c:308
 #, c-format
-msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Zentroid(e) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"%d centroid(s) found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr ""
+"%d Zentroid(e) gefunden, die allerdings nicht zum Export angegeben wurden. "
 #: ../vector/v.out.ogr/main.c:313
 #, fuzzy, c-format
-msgid "%d area(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"%d area(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+"%d Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. "
 #: ../vector/v.out.ogr/main.c:317
 #, c-format
-msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d 3D-Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+"%d 3D-Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
 #: ../vector/v.out.ogr/main.c:322
 #, c-format
-msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Volumen gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"%d volume(s) found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr ""
+"%d Volumen gefunden, die allerdings nicht zum Export angegeben wurden. "
 #: ../vector/v.out.ogr/main.c:328
 #, fuzzy
-msgid "No points found, but requested to be exported. Will skip this feature type."
-msgstr "%d Punkt(e) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"No points found, but requested to be exported. Will skip this feature type."
+msgstr ""
+"%d Punkt(e) gefunden, die allerdings nicht exportiert werden sollen. "
 #: ../vector/v.out.ogr/main.c:337
 #, fuzzy
-msgid "No lines found, but requested to be exported. Will skip this feature type."
-msgstr "%d Linie(n) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"No lines found, but requested to be exported. Will skip this feature type."
+msgstr ""
+"%d Linie(n) gefunden, die allerdings nicht exportiert werden sollen. "
 #: ../vector/v.out.ogr/main.c:347
 #, fuzzy
-msgid "No boundaries found, but requested to be exported. Will skip this feature type."
-msgstr "%d Grenzlinie(n) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"No boundaries found, but requested to be exported. Will skip this feature "
+"type."
+msgstr ""
+"%d Grenzlinie(n) gefunden, die allerdings nicht exportiert werden sollen. "
 #: ../vector/v.out.ogr/main.c:356
 #, fuzzy
-msgid "No areas found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No areas found, but requested to be exported. Will skip this feature type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:366
 #, fuzzy
-msgid "No centroids found, but requested to be exported. Will skip this feature type."
-msgstr "%d Zentroid(e) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"No centroids found, but requested to be exported. Will skip this feature "
+"type."
+msgstr ""
+"%d Zentroid(e) gefunden, die allerdings nicht exportiert werden sollen. "
 #: ../vector/v.out.ogr/main.c:375
 #, fuzzy
-msgid "No faces found, but requested to be exported. Will skip this feature type."
-msgstr "%d 3D-Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. Überprüfen Sie bitte den 'type'-Parameter."
+msgid ""
+"No faces found, but requested to be exported. Will skip this feature type."
+msgstr ""
+"%d 3D-Fläche(n) gefunden, die allerdings nicht exportiert werden sollen. "
 #: ../vector/v.out.ogr/main.c:384
 #, fuzzy
-msgid "No kernels found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No kernels found, but requested to be exported. Will skip this feature type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:393
 #, fuzzy
-msgid "No volumes found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No volumes found, but requested to be exported. Will skip this feature type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:418
 #, c-format
@@ -31572,7 +33926,9 @@
 #: ../vector/v.out.ogr/main.c:422
 #, c-format
-msgid "Append existing layer requires opening data source in update mode, forcing '-%c' flag"
+msgid ""
+"Append existing layer requires opening data source in update mode, forcing '-"
+"%c' flag"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:440
@@ -31601,18 +33957,33 @@
 #: ../vector/v.out.ogr/main.c:508
 #, fuzzy, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) zu exportieren."
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
+"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgstr ""
+"Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische "
+"Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) "
+"zu exportieren."
 #: ../vector/v.out.ogr/main.c:520
 #, fuzzy, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options DIM "
+"(parameter 'lco') to export in 3D rather than 2D (default)."
+msgstr ""
+"zu exportieren."
 #: ../vector/v.out.ogr/main.c:527
 #, fuzzy, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export <in 3D rather than 2D (default)."
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
+"'lco') to export <in 3D rather than 2D (default)."
+msgstr ""
+"zu exportieren."
 #: ../vector/v.out.ogr/main.c:546
 msgid "Unable to create OGR layer"
@@ -31620,7 +33991,9 @@
 #: ../vector/v.out.ogr/main.c:558
 msgid "No attribute table found -> using only category numbers as attributes"
-msgstr "Keine Attributtabelle gefunden -> benutze nur Kategorienummern als Attributes."
+msgstr ""
+"Keine Attributtabelle gefunden -> benutze nur Kategorienummern als "
+"Attributes."
 #: ../vector/v.out.ogr/main.c:562
 msgid "Exporting 'cat' anyway, as it is the only attribute table field"
@@ -31667,13 +34040,16 @@
 #: ../vector/v.out.ogr/main.c:720
 #, c-format
-msgid "%d features without category were skipped. Features without category are written only when -%c flag is given."
+msgid ""
+"%d features without category were skipped. Features without category are "
+"written only when -%c flag is given."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:733
 #, fuzzy
 msgid "Output layer is empty, no features written"
-msgstr "Ausgabe-Vektorkarte in die die ausgerichteten Linien geschrieben werden."
+msgstr ""
+"Ausgabe-Vektorkarte in die die ausgerichteten Linien geschrieben werden."
 #: ../vector/v.out.ogr/main.c:734
 #, fuzzy, c-format
@@ -31709,7 +34085,9 @@
 #: ../vector/v.out.ogr/attrb.c:65
 #, c-format
 msgid "No database record for cat = %d and export of 'cat' disabled"
-msgstr "Kein Datenbankeintrag für cat = %d und der Export von 'cat' wurde deaktiviert."
+msgstr ""
+"Kein Datenbankeintrag für cat = %d und der Export von 'cat' wurde "
+"deaktiviert."
 #: ../vector/v.out.ogr/args.c:9
 #, fuzzy
@@ -31722,8 +34100,11 @@
 #: ../vector/v.out.ogr/args.c:20
 #, fuzzy
-msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
-msgstr "Die Die Kombination von Typen wird nicht von allen Formaten unterstützt."
+msgid ""
+"Combination of types is not supported by all output formats. Default is to "
+"use first type found in input vector map."
+msgstr ""
+"Die Die Kombination von Typen wird nicht von allen Formaten unterstützt."
 #: ../vector/v.out.ogr/args.c:28
 #, fuzzy
@@ -31735,7 +34116,8 @@
 msgid ""
 "For example: ESRI Shapefile: filename or directory for storage\n"
 "\t\t\tPostGIS database: connection string"
-msgstr "Zum Beispiel: ESRI Shapefile: Dateiname oder Verzeichnis für die Speicherung."
+msgstr ""
+"Zum Beispiel: ESRI Shapefile: Dateiname oder Verzeichnis für die Speicherung."
 #: ../vector/v.out.ogr/args.c:40
 #, fuzzy
@@ -31745,7 +34127,8 @@
 #: ../vector/v.out.ogr/args.c:47
 #, fuzzy
 msgid "Name for output OGR layer. If not specified, input name is used"
-msgstr "Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
+msgstr ""
+"Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
 #: ../vector/v.out.ogr/args.c:49
 #, fuzzy
@@ -31774,7 +34157,8 @@
 #: ../vector/v.out.ogr/args.c:71
 msgid "OGR dataset creation option (format specific, NAME=VALUE)"
-msgstr "Optionen zum Erzeugen des OGR-Datensatzes (formatspezifisch, NAME=WERT)."
+msgstr ""
+"Optionen zum Erzeugen des OGR-Datensatzes (formatspezifisch, NAME=WERT)."
 #: ../vector/v.out.ogr/args.c:81
 msgid "OGR layer creation option (format specific, NAME=VALUE)"
@@ -31795,17 +34179,23 @@
 #: ../vector/v.out.ogr/args.c:101
 #, fuzzy
-msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
-msgstr "Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten werden alle Objekte exportiert."
+msgid ""
+"Also export features without category (not labeled). Otherwise only features "
+"with category are exported."
+msgstr ""
+"Exportiert Vektorfeatures nur mit Kategoriewerten (Labeln). Ansonsten werden "
+"alle Objekte exportiert."
 #: ../vector/v.out.ogr/args.c:107
 msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr "Verwende .prj-Dateiformat im ESRI-Stil (nur bei Ausgabe von Shapefiles)."
+msgstr ""
+"Verwende .prj-Dateiformat im ESRI-Stil (nur bei Ausgabe von Shapefiles)."
 #: ../vector/v.out.ogr/args.c:113
 #, fuzzy
 msgid "Force 2D output even if input is 3D (applies to Shapefile output only)"
-msgstr "Erzeuge 3D Ausgabe wenn Eingabe 3D ist (nur bei Ausgabe von Shapefiles)"
+msgstr ""
+"Erzeuge 3D Ausgabe wenn Eingabe 3D ist (nur bei Ausgabe von Shapefiles)"
 #: ../vector/v.out.ogr/args.c:115 ../vector/v.out.postgis/args.c:78
 #: ../vector/v.in.ogr/main.c:252
@@ -31818,18 +34208,27 @@
 #: ../vector/v.out.ogr/args.c:127
 #, fuzzy
-msgid "Create a new empty layer in defined OGR datasource and exit. Nothing is read from input."
+msgid ""
+"Create a new empty layer in defined OGR datasource and exit. Nothing is read "
+"from input."
+msgstr ""
+"eingelesen."
 #: ../vector/v.out.ascii/main.c:51
 #, fuzzy
 msgid "Exports a vector map to a GRASS ASCII vector representation."
-msgstr "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
+msgstr ""
+"Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
 #: ../vector/v.out.ascii/main.c:52
 #, fuzzy
-msgid "By default only features with category are exported. To export all features use 'layer=-1'."
-msgstr "Exportiert Vektorobjekte nur mit Kategoriewerten (Labeln). Ansonsten werden alle Objekte exportiert."
+msgid ""
+"By default only features with category are exported. To export all features "
+"use 'layer=-1'."
+msgstr ""
+"Exportiert Vektorobjekte nur mit Kategoriewerten (Labeln). Ansonsten werden "
 #: ../vector/v.out.ascii/main.c:60
 #, c-format
@@ -31848,8 +34247,12 @@
 #: ../vector/v.out.ascii/main.c:80
 #, c-format
-msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
-msgstr "Kann die Vektorkarte <%s> topologisch nicht öffnen. Flächen werden nicht verarbeitet."
+msgid ""
+"Unable to open vector map <%s> at topology level. Areas will not be "
+"processed."
+msgstr ""
+"Kann die Vektorkarte <%s> topologisch nicht öffnen. Flächen werden nicht "
+"verarbeitet."
 #: ../vector/v.out.ascii/main.c:107
 #, fuzzy, c-format
@@ -31883,7 +34286,9 @@
 #: ../vector/v.out.ascii/args.c:31
 #, fuzzy
 msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
-msgstr "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der Schalter '-o' angegeben ist."
+msgstr ""
+"Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der "
+"Schalter '-o' angegeben ist."
 #: ../vector/v.out.ascii/args.c:33
 #, fuzzy
@@ -31892,7 +34297,8 @@
 #: ../vector/v.out.ascii/args.c:38
 msgid "Name of attribute column(s) to be exported (point mode)"
-msgstr "Name der Attribut-Spalte(n) die exportiert werden sollen (Punkt-Modus)."
+msgstr ""
+"Name der Attribut-Spalte(n) die exportiert werden sollen (Punkt-Modus)."
 #: ../vector/v.out.ascii/args.c:39
 msgid "\"*\" for all columns"
@@ -31926,7 +34332,9 @@
 #: ../vector/v.out.ascii/args.c:91
 msgid "Only export points falling within current 3D region (points mode)"
-msgstr "Exportiere nur Punkte, die sich in der aktuellen 3D-Region befinden (Punkt-Modus)."
+msgstr ""
+"Exportiere nur Punkte, die sich in der aktuellen 3D-Region befinden (Punkt-"
+"Modus)."
 #: ../vector/v.out.ascii/args.c:109 ../vector/v.out.vtk/main.c:156
 msgid "Failed to interpret 'dp' parameter as an integer"
@@ -31942,7 +34350,8 @@
 #: ../vector/v.support/main.c:61
 msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
-msgstr "Datum, an dem die Vektorkarte digitalisiert wurde (z.B., \"15 Mar 2007\")."
+msgstr ""
+"Datum, an dem die Vektorkarte digitalisiert wurde (z.B., \"15 Mar 2007\")."
 #: ../vector/v.support/main.c:68
 msgid "Person who created vector map"
@@ -31973,8 +34382,11 @@
 msgstr "Text, der an den Kommentar Metadatendatei der Karte angehängt wird"
 #: ../vector/v.support/main.c:118
-msgid "Command line to store into vector map history file (used for vector scripts)"
-msgstr "Kommentarzeile die in der History-Datei der Vektorkarte gespeichert wird (verwendet für Vektor-Skripts)"
+msgid ""
+"Command line to store into vector map history file (used for vector scripts)"
+msgstr ""
+"Kommentarzeile die in der History-Datei der Vektorkarte gespeichert wird "
+"(verwendet für Vektor-Skripts)"
 #: ../vector/v.support/main.c:122
 msgid "Replace comment instead of appending it"
@@ -31987,7 +34399,8 @@
 #: ../vector/v.proj/main.c:69
 msgid "Re-projects a vector map from one location to the current location."
-msgstr "Reprojiziert eine Vektorkarte von einer Location in die aktuelle Location."
+msgstr ""
+"Reprojiziert eine Vektorkarte von einer Location in die aktuelle Location."
 #: ../vector/v.proj/main.c:75
 #, fuzzy
@@ -32028,7 +34441,9 @@
 #: ../vector/v.proj/main.c:115
 #, fuzzy
 msgid "Assume z coordinate is ellipsoidal height and transform if possible"
-msgstr "Nehme an das die Z-Koordinate die ellipsoidale Höhe enthält und transformiere, wenn möglich."
+msgstr ""
+"Nehme an das die Z-Koordinate die ellipsoidale Höhe enthält und "
+"transformiere, wenn möglich."
 #: ../vector/v.proj/main.c:121
 msgid "Latlon output only, default is -180,180"
@@ -32167,7 +34582,8 @@
 #: ../vector/v.sample/main.c:89
 #, fuzzy
 msgid "Name of attribute column to use for comparison"
-msgstr "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
+msgstr ""
+"Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
 #: ../vector/v.sample/main.c:92
 #, fuzzy
@@ -32187,7 +34603,9 @@
 #: ../vector/v.sample/main.c:109
 #, fuzzy
 msgid "Sampled values will be multiplied by this factor"
-msgstr "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit diesem Faktor multipliziert."
+msgstr ""
+"Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit "
+"diesem Faktor multipliziert."
 #: ../vector/v.sample/main.c:130 ../vector/v.surf.idw/read_sites.c:48
 #: ../vector/v.reclass/main.c:125
@@ -32198,7 +34616,8 @@
 #: ../vector/v.sample/main.c:144
 #, c-format
 msgid "Column type <%s> not supported (must be integer or double precision)"
-msgstr "Spaltentyp <%s> wird nicht unterstützt (muss integer oder double sein)."
+msgstr ""
+"Spaltentyp <%s> wird nicht unterstützt (muss integer oder double sein)."
 #: ../vector/v.sample/main.c:150 ../vector/v.surf.idw/read_sites.c:68
 #: ../vector/v.surf.bspline/main.c:394 ../vector/v.normal/main.c:134
@@ -32238,13 +34657,23 @@
 msgstr "Kann Zeile nicht einfügen: %s"
 #: ../vector/v.net.distance/main.c:67
-msgid "Computes shortest distance via the network between the given sets of features."
-msgstr "Berechne die kürzeste Distanz zwischen einer Auswahl an Objekten über das Netzwerk."
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features."
+msgstr ""
+"Berechne die kürzeste Distanz zwischen einer Auswahl an Objekten über das "
+"Netzwerk."
 #: ../vector/v.net.distance/main.c:70
 #, fuzzy
-msgid "Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
-msgstr "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und zahlreiche Informationen über diese Beziehung wird in der Attributtabelle abgespeichert"
+msgid ""
+"Finds the shortest paths from each 'from' point to the nearest 'to' feature "
+"and various information about this relation are uploaded to the attribute "
+"table."
+msgstr ""
+"Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und "
+"zahlreiche Informationen über diese Beziehung wird in der Attributtabelle "
+"abgespeichert"
 #: ../vector/v.net.distance/main.c:97
 msgid "From layer number or name"
@@ -32263,7 +34692,8 @@
 #: ../vector/v.net.distance/main.c:108
 msgid "From WHERE conditions of SQL statement without 'where' keyword"
-msgstr "From WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr ""
+"From WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.distance/main.c:113
 msgid "To layer number or name"
@@ -32286,7 +34716,8 @@
 #: ../vector/v.net.distance/main.c:131
 msgid "To WHERE conditions of SQL statement without 'where' keyword"
-msgstr "Ziel-WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr ""
+"Ziel-WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.distance/main.c:218
 #, c-format
@@ -32344,13 +34775,18 @@
 #: ../vector/v.build/main.c:49
 #, fuzzy
-msgid "Name for output vector map where erroneous vector features are written to"
-msgstr "Name der Vektorkarte, in die fehlerhafte Vektor-Features geschrieben werden sollen."
+msgid ""
+"Name for output vector map where erroneous vector features are written to"
+msgstr ""
+"Name der Vektorkarte, in die fehlerhafte Vektor-Features geschrieben werden "
+"sollen."
 #: ../vector/v.build/main.c:61
 #, fuzzy
 msgid "Build topology or dump topology or indeces to standard output"
-msgstr "Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach stdout."
+msgstr ""
+"Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach "
+"stdout."
 #: ../vector/v.build/main.c:65
 #, fuzzy
@@ -32386,7 +34822,9 @@
 #: ../vector/v.build/main.c:106
 #, c-format
-msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
+msgid ""
+"Direct read access to OGR layers is not supported by this module. Run %s to "
+"create a link as GRASS vector map in the current mapset."
 msgstr ""
 #: ../vector/v.build/main.c:111
@@ -32399,8 +34837,12 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:244
-msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
-msgstr "Interpoliert Punkte zu einer 3D Rasterkarte unter Verwendung des regularized spline with tension (RST) Algorithmus."
+msgid ""
+"Interpolates point data to a 3D raster map using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+"Interpoliert Punkte zu einer 3D Rasterkarte unter Verwendung des regularized "
+"spline with tension (RST) Algorithmus."
 #: ../vector/v.vol.rst/main.c:249
 #, fuzzy
@@ -32522,7 +34964,9 @@
 #: ../vector/v.vol.rst/main.c:747 ../vector/v.vol.rst/main.c:765
 #, fuzzy
 msgid "Not enough disk space - cannot write temp files"
-msgstr "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht schreiben."
+msgstr ""
+"Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht "
+"schreiben."
 #: ../vector/v.vol.rst/main.c:646 ../vector/v.vol.rst/main.c:664
 #: ../vector/v.vol.rst/main.c:682 ../vector/v.vol.rst/main.c:700
@@ -32547,11 +34991,15 @@
 #: ../vector/v.vol.rst/user1.c:109
 msgid "Column type of wcolumn is not supported (must be integer or double)"
-msgstr "Spaltentyp der wcolumn wird nicht unterstützt (muss integer oder double sein)"
+msgstr ""
+"Spaltentyp der wcolumn wird nicht unterstützt (muss integer oder double sein)"
 #: ../vector/v.vol.rst/user1.c:128
-msgid "Column type of smooth column is not supported (must be integer or double)"
-msgstr "Spaltentyp der 'smooth'-Spalte wird nicht unterstützt (muss integer oder double sein)"
+msgid ""
+"Column type of smooth column is not supported (must be integer or double)"
+msgstr ""
+"Spaltentyp der 'smooth'-Spalte wird nicht unterstützt (muss integer oder "
+"double sein)"
 #: ../vector/v.net/report.c:37
 #, c-format
@@ -32625,7 +35073,9 @@
 #: ../vector/v.net/args.c:15
 #, fuzzy
 msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
-msgstr "Erforderlich für die Operation 'connect'. Verbindet Punkte innerhalb des gegebenen Schwellenwertes."
+msgstr ""
+"Erforderlich für die Operation 'connect'. Verbindet Punkte innerhalb des "
+"gegebenen Schwellenwertes."
 #: ../vector/v.net/args.c:17 ../vector/v.net/args.c:56
 msgid "Arcs"
@@ -32651,7 +35101,8 @@
 msgstr ""
 #: ../vector/v.net/args.c:42
-msgid "connect still unconnected points to vector network by inserting new line(s)"
+msgid ""
+"connect still unconnected points to vector network by inserting new line(s)"
 msgstr ""
 #: ../vector/v.net/args.c:44
@@ -32659,16 +35110,21 @@
 msgstr ""
 #: ../vector/v.net/args.c:46
-msgid "print to standard output {line_category start_point_category end_point_category}"
+msgid ""
+"print to standard output {line_category start_point_category "
+"end_point_category}"
 msgstr ""
 #: ../vector/v.net/args.c:48
-msgid "print to standard output {point_category line_category[,line_category...]}"
+msgid ""
+"print to standard output {point_category line_category[,line_category...]}"
 msgstr ""
 #: ../vector/v.net/args.c:72
 msgid "Required for operation 'connect'. Connect points in given threshold."
+msgstr ""
 #: ../vector/v.net/args.c:76
 #, fuzzy
@@ -32694,7 +35150,9 @@
 msgstr "Vektorkarte mit den Stopp-Punkten"
 #: ../vector/v.net/args.c:91
-msgid "For operation 'connect'. By default, a new line from the point to the network is created."
+msgid ""
+"For operation 'connect'. By default, a new line from the point to the "
+"network is created."
 msgstr ""
 #: ../vector/v.net/args.c:113
@@ -32724,7 +35182,9 @@
 #: ../vector/v.convert/old2new.c:88
 #, c-format
 msgid "Failed to attach an attribute (category %d) to a line."
-msgstr "Das Anfügen von einem Attribut (Kategorie %d) an eine Linie ist fehlgeschlagen."
+msgstr ""
+"Das Anfügen von einem Attribut (Kategorie %d) an eine Linie ist "
+"fehlgeschlagen."
 #: ../vector/v.convert/old2new.c:93
 #, c-format
@@ -32755,7 +35215,8 @@
 #: ../vector/v.convert/att.c:37
 msgid "No category labels (dig_cats) found, no table created"
-msgstr "Keine Kategoriebeschriftungen (dig_cats) gefunden; keine Tabelle erstellt."
+msgstr ""
+"Keine Kategoriebeschriftungen (dig_cats) gefunden; keine Tabelle erstellt."
 #: ../vector/v.convert/att.c:42
 msgid "Unable to open dig_cats file"
@@ -32778,8 +35239,13 @@
 msgstr "Eingabedatei ist portabel."
 #: ../vector/v.convert/read.c:102
-msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
-msgstr "Eingabedatei ist nicht portabel. Wir versuchen sie trotzdem zu konvertieren; dies kann aber schiefgehen. Bitte lesen Sie die Hilfeseiten für weitere Informationen."
+msgid ""
+"Input file is not portable. We will attempt to convert anyway but conversion "
+"may fail. Please read manual for detail information."
+msgstr ""
+"Eingabedatei ist nicht portabel. Wir versuchen sie trotzdem zu konvertieren; "
+"dies kann aber schiefgehen. Bitte lesen Sie die Hilfeseiten für weitere "
+"Informationen."
 #: ../vector/v.convert/read.c:188
 #, c-format
@@ -32804,7 +35270,8 @@
 #: ../vector/v.convert/read.c:195
 #, c-format
 msgid "[%d] area boundaries read and written to output"
-msgstr "[%d] Grenzen (boundaries) wurden gelesen und in die Ausgabe geschrieben"
+msgstr ""
+"[%d] Grenzen (boundaries) wurden gelesen und in die Ausgabe geschrieben"
 #: ../vector/v.convert/read.c:196
 #, c-format
@@ -32921,8 +35388,12 @@
 msgstr "Vektor, Transformation"
 #: ../vector/v.delaunay/main.c:88
-msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
-msgstr "Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit Punkten oder Zentroiden."
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+"Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit "
+"Punkten oder Zentroiden."
 #: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:97
 msgid "Use only points in current region"
@@ -32930,7 +35401,9 @@
 #: ../vector/v.delaunay/main.c:103
 msgid "Output triangulation as a graph (lines), not areas"
-msgstr "Gebe das Ergebnis der Triangulation als Graph (Linien) und nicht als Flächen aus."
+msgstr ""
+"Gebe das Ergebnis der Triangulation als Graph (Linien) und nicht als Flächen "
+"aus."
 #: ../vector/v.delaunay/main.c:143 ../vector/v.buffer/main.c:721
 #: ../vector/v.buffer/main.c:728 ../vector/v.overlay/area_area.c:111
@@ -32956,8 +35429,12 @@
 msgstr "Kann die Z-Koordinate des Zentroids nicht berechnen."
 #: ../vector/v.lidar.growing/main.c:78
-msgid "Building contour determination and Region Growing algorithm for determining the building inside"
-msgstr "Bestimmung des Gebäude Umriss und Anwendung des 'Region Growing' Verfahrens zu Ermittelung des Gebäude Inneren."
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+"Bestimmung des Gebäude Umriss und Anwendung des 'Region Growing' Verfahrens "
+"zu Ermittelung des Gebäude Inneren."
 #: ../vector/v.lidar.growing/main.c:83
 msgid "Input vector (v.lidar.edgedetection output"
@@ -32985,7 +35462,9 @@
 #: ../vector/v.outlier/main.c:249
 #, c-format
 msgid "No database connection for driver <%s> is defined. Run db.connect."
-msgstr "Keine Datenbankverbindung für Treiber <%s> definiert. Bitte db.connect benutzen"
+msgstr ""
+"Keine Datenbankverbindung für Treiber <%s> definiert. Bitte db.connect "
+"benutzen"
 #: ../vector/v.lidar.growing/main.c:176
 #, c-format
@@ -33024,12 +35503,19 @@
 msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten."
 #: ../vector/v.patch/main.c:81
-msgid "Name for output vector map where bounding boxes of input vector maps are written to"
-msgstr "Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten geschrieben werden"
+msgid ""
+"Name for output vector map where bounding boxes of input vector maps are "
+"written to"
+msgstr ""
+"Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten "
+"geschrieben werden"
 #: ../vector/v.patch/main.c:85
-msgid "Append files to existing file (overwriting existing files must be activated)"
-msgstr "Hänge Dateien an eine existierende Datei an. Das Überschreiben von existierenden Dateien muss aktiviert sein"
+msgid ""
+"Append files to existing file (overwriting existing files must be activated)"
+msgstr ""
+"Hänge Dateien an eine existierende Datei an. Das Überschreiben von "
+"existierenden Dateien muss aktiviert sein"
 #: ../vector/v.patch/main.c:90
 msgid "Copy also attribute table"
@@ -33079,7 +35565,9 @@
 #: ../vector/v.patch/main.c:337
 #, c-format
 msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr "Fehler beim Lesen der Vektorkarte <%s> - Einige Daten könnten nicht korrekt sein"
+msgstr ""
+"Fehler beim Lesen der Vektorkarte <%s> - Einige Daten könnten nicht korrekt "
+"sein"
 #: ../vector/v.patch/main.c:380
 #, c-format
@@ -33135,11 +35623,15 @@
 msgstr ""
 #: ../vector/v.external.out/link.c:46 ../vector/v.external/main.c:72
-msgid "Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with OGR support. Using GRASS-PostGIS data driver instead."
+msgid ""
+"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
+"OGR support. Using GRASS-PostGIS data driver instead."
 msgstr ""
 #: ../vector/v.external.out/link.c:53 ../vector/v.external/main.c:77
-msgid "GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver instead of native GRASS-PostGIS data driver."
+msgid ""
+"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
+"instead of native GRASS-PostGIS data driver."
 msgstr ""
 #: ../vector/v.external.out/link.c:141 ../vector/v.out.postgis/create.c:27
@@ -33263,11 +35755,15 @@
 #: ../vector/v.in.sites/main.c:100
 msgid "Floating point category values, using sequential integer for category"
-msgstr "Fließkomma Kategoriewerte -> verwende einen fortlaufenden Integer für die Kategorien."
+msgstr ""
+"Fließkomma Kategoriewerte -> verwende einen fortlaufenden Integer für die "
+"Kategorien."
 #: ../vector/v.in.sites/main.c:103
 msgid "No category values, using sequential integer for category"
-msgstr "Keine Kategoriewerte -> verwende einen fortlaufenden Integer für die Kategorien."
+msgstr ""
+"Keine Kategoriewerte -> verwende einen fortlaufenden Integer für die "
+"Kategorien."
 #: ../vector/v.in.sites/main.c:185
 msgid "Transferring sites to vector point map..."
@@ -33284,11 +35780,17 @@
 #: ../vector/v.net.salesman/main.c:130
 msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr "Erzeugt einen Ring der die gegebenen Knoten verbindet (Handelsreisenden-Problem)."
+msgstr ""
+"Erzeugt einen Ring der die gegebenen Knoten verbindet (Handelsreisenden-"
+"Problem)."
 #: ../vector/v.net.salesman/main.c:132
-msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
-msgstr "Bedenken Sie das: Das Handelsreisenden-Problem ist NP-hart. Dies Modul setzt ein heuristischen Algorithmus ein und erzeugte Ringen können suboptimal sein."
+msgid ""
+"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
+"created cycle may be sub optimal"
+msgstr ""
+"Bedenken Sie das: Das Handelsreisenden-Problem ist NP-hart. Dies Modul setzt "
+"ein heuristischen Algorithmus ein und erzeugte Ringen können suboptimal sein."
 #: ../vector/v.net.salesman/main.c:150
 msgid "Node layer (used for cities)"
@@ -33302,11 +35804,15 @@
 #: ../vector/v.net.salesman/main.c:169
 #, fuzzy
 msgid "Name for output file holding node sequence (\"-\" for stdout)"
+msgstr ""
 #: ../vector/v.net.salesman/main.c:174
 msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
-msgstr "Kategorien der Punkte ('Städte') auf den Knoten (Layer wird mit nlayer bestimmt)."
+msgstr ""
+"Kategorien der Punkte ('Städte') auf den Knoten (Layer wird mit nlayer "
+"bestimmt)."
 #: ../vector/v.net.salesman/main.c:239 ../vector/v.net.alloc/main.c:163
 #: ../vector/v.net.steiner/main.c:441 ../vector/v.net.iso/main.c:198
@@ -33389,20 +35895,32 @@
 msgstr "Findet den kürzesten Weg in einem Vektor-Netzwerk."
 #: ../vector/v.net.path/main.c:66
-msgid "Name of file containing start and end points. If not given, read from stdin"
-msgstr "Name der Datei mit Start- und Endpunkten. Falls nicht angegeben, wird von stdin gelesen."
+msgid ""
+"Name of file containing start and end points. If not given, read from stdin"
+msgstr ""
+"Name der Datei mit Start- und Endpunkten. Falls nicht angegeben, wird von "
+"stdin gelesen."
 #: ../vector/v.net.path/main.c:93
 msgid "Maximum distance to the network"
 msgstr "Maximale Distanz zum Netzwerk."
 #: ../vector/v.net.path/main.c:94
-msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
-msgstr "Wenn der Start-/Endpunkt als Koordinaten angegeben wurden. Wenn der Start-/Endpunkt außerhalb des Schwellwertes sind, wird der kürzeste Weg nicht gefunden und eine Fehlermeldung ausgegeben. Um die Verarbeitung zu beschleunigen, wählen Sie den Wert so gering wie möglich."
+msgid ""
+"If start/end are given as coordinates. If start/end point is outside this "
+"threshold, the path is not found and error message is printed. To speed up "
+"the process, keep this value as low as possible."
+msgstr ""
+"Wenn der Start-/Endpunkt als Koordinaten angegeben wurden. Wenn der Start-/"
+"Endpunkt außerhalb des Schwellwertes sind, wird der kürzeste Weg nicht "
+"gefunden und eine Fehlermeldung ausgegeben. Um die Verarbeitung zu "
+"beschleunigen, wählen Sie den Wert so gering wie möglich."
 #: ../vector/v.net.path/main.c:107
 msgid "Write output as original input segments, not each path as one line."
-msgstr "Schreibe die Ausgabe in Form der originalen Eingabesegmente und nicht jeden Weg als eine Linie."
+msgstr ""
+"Schreibe die Ausgabe in Form der originalen Eingabesegmente und nicht jeden "
+"Weg als eine Linie."
 #: ../vector/v.net.path/path.c:82
 #, c-format
@@ -33422,7 +35940,9 @@
 #: ../vector/v.net.path/path.c:209
 #, c-format
 msgid "Point with category [%d] is not reachable from point with category [%d]"
-msgstr "Punkt mit der Kategorie [%d] ist nicht erreichbar von dem Punkt mit der Kategorie [%d]."
+msgstr ""
+"Punkt mit der Kategorie [%d] ist nicht erreichbar von dem Punkt mit der "
+"Kategorie [%d]."
 #: ../vector/v.net.path/path.c:266
 #, c-format
@@ -33442,7 +35962,9 @@
 #: ../vector/v.net.path/path.c:335
 #, c-format
 msgid "%d destination(s) unreachable (including points out of threshold)"
-msgstr "%d Ziele sind unerreichbar (inklusive der Punkte außerhalb des Schwellwertes)."
+msgstr ""
+"%d Ziele sind unerreichbar (inklusive der Punkte außerhalb des "
+"Schwellwertes)."
 #: ../vector/v.out.pov/main.c:49
 msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
@@ -33467,7 +35989,9 @@
 msgstr "Verschiebewert für Z-Koordinate."
 #: ../vector/v.out.pov/main.c:75
-msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
+msgid ""
+"This string is appended to each z coordinate. Examples: '*10', '+1000', "
+"'*10+100', '*exaggeration'"
 msgstr ""
 #: ../vector/v.out.pov/main.c:82
@@ -33503,7 +36027,9 @@
 #: ../vector/v.to.points/main.c:59
 #, fuzzy
 msgid "Creates points along input lines in new vector map with 2 layers."
-msgstr "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei Layern."
+msgstr ""
+"Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei "
+"Layern."
 #: ../vector/v.to.points/main.c:79
 #, fuzzy
@@ -33527,7 +36053,9 @@
 #: ../vector/v.to.points/main.c:226
 #, c-format
-msgid "%d features without category in layer <%d> skipped. Note that features without category (usually boundaries) are not skipped when '%s=-1' is given."
+msgid ""
+"%d features without category in layer <%d> skipped. Note that features "
+"without category (usually boundaries) are not skipped when '%s=-1' is given."
 msgstr ""
 #: ../vector/v.to.points/main.c:276
@@ -33627,7 +36155,9 @@
 msgstr ""
 #: ../vector/v.clean/main.c:99
-msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
+msgid ""
+"change the type of boundary dangle to line, threshold ignored if < 0, input "
+"line type is ignored"
 msgstr ""
 #: ../vector/v.clean/main.c:101
@@ -33635,7 +36165,9 @@
 msgstr ""
 #: ../vector/v.clean/main.c:102
-msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
+msgid ""
+"change the type of bridges connecting area and island or 2 islands from "
+"boundary to line"
 msgstr ""
 #: ../vector/v.clean/main.c:104
@@ -33649,11 +36181,17 @@
 msgstr "Entferne doppelte Zentroide"
 #: ../vector/v.clean/main.c:106
-msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different"
+msgid ""
+"break (topologically clean) polygons (imported from non topological format, "
+"like ShapeFile). Boundaries are broken on each point shared between 2 and "
+"more polygons where angles of segments are different"
 msgstr ""
 #: ../vector/v.clean/main.c:109
-msgid "remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed"
+msgid ""
+"remove vertices in threshold from lines and boundaries, boundary is pruned "
+"only if topology is not damaged (new intersection, changed attachment of "
+"centroid), first and last segment of the boundary is never changed"
 msgstr ""
 #: ../vector/v.clean/main.c:113
@@ -33673,7 +36211,9 @@
 #: ../vector/v.clean/main.c:123
 #, fuzzy
 msgid "Threshold in map units, one value for each tool"
-msgstr "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: 0.0[,0.0,...])."
+msgstr ""
+"Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: "
+"0.0[,0.0,...])."
 #: ../vector/v.clean/main.c:124
 msgid "Default: 0.0[,0.0,...])"
@@ -33852,15 +36392,19 @@
 #: ../vector/v.clean/prune.c:216
 #, fuzzy, c-format
-msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgid ""
+"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 msgstr ""
 "\n"
-"%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z.B. %.2f %%"
+"%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z."
+"B. %.2f %%"
 #: ../vector/v.clean/prune.c:220
 #, c-format
 msgid "%d boundaries not pruned because pruning would damage topology"
-msgstr "%d Grenzen wurden nicht geputzt, weil das Putzen die Topologie beschädigt hätte."
+msgstr ""
+"%d Grenzen wurden nicht geputzt, weil das Putzen die Topologie beschädigt "
+"hätte."
 #: ../vector/v.clean/split.c:85
 #, fuzzy, c-format
@@ -33876,8 +36420,11 @@
 msgstr "Vertikales Trennzeichen für die Ausgabe."
 #: ../vector/v.db.select/main.c:93
-msgid "Print minimal region extent of selected vector features instead of attributes"
-msgstr "Gebe anstelle der Attribute die minimale Ausdehnung der Region der selektierten Vektorobjekte aus."
+msgid ""
+"Print minimal region extent of selected vector features instead of attributes"
+msgstr ""
+"selektierten Vektorobjekte aus."
 #: ../vector/v.db.select/main.c:94
 #, fuzzy
@@ -33886,8 +36433,12 @@
 #: ../vector/v.db.select/main.c:146
 #, c-format
-msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
-msgstr "Kann die Vektorkarte <%s> nicht im topologischen Modus öffnen. Schalter '%c' benötigt aber den topologischen Modus."
+msgid ""
+"Unable to open vector map <%s> at topology level. Flag '%c' requires "
+"topology level."
+msgstr ""
+"Kann die Vektorkarte <%s> nicht im topologischen Modus öffnen. Schalter '%c' "
+"benötigt aber den topologischen Modus."
 #: ../vector/v.db.select/main.c:180
 msgid "Unable to open select cursor"
@@ -33910,8 +36461,12 @@
 #: ../vector/v.voronoi/main.c:126
 #, fuzzy
-msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
-msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
+msgid ""
+"Creates a Voronoi diagram in current region from an input vector map "
+"containing points or centroids."
+msgstr ""
+"Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder "
+"Zentroiden."
 #: ../vector/v.voronoi/main.c:140
 #, fuzzy
@@ -33919,7 +36474,9 @@
 msgstr "Name der Ausgabedatei"
 #: ../vector/v.voronoi/main.c:141
-msgid "Applies to input areas only. Smaller values produce smoother output but can cause numerical instability."
+msgid ""
+"Applies to input areas only. Smaller values produce smoother output but can "
+"cause numerical instability."
 msgstr ""
 #: ../vector/v.voronoi/main.c:148
@@ -33928,7 +36485,9 @@
 msgstr "Maximale Länge der Segmente des Netzwerks."
 #: ../vector/v.voronoi/main.c:149
-msgid "Applies only to skeleton extraction. Default = -1 will extract the center line."
+msgid ""
+"Applies only to skeleton extraction. Default = -1 will extract the center "
+"line."
 msgstr ""
 #: ../vector/v.voronoi/main.c:155
@@ -34057,7 +36616,9 @@
 #: ../vector/v.vect.stats/main.c:181
 msgid "Column name of points map to use for statistics"
-msgstr "Name der Spalte der Punkt-Karte, welche für die Statistik verwendet werden soll"
+msgstr ""
+"Name der Spalte der Punkt-Karte, welche für die Statistik verwendet werden "
+"soll"
 #: ../vector/v.vect.stats/main.c:182
 msgid "Column of points map must be numeric"
@@ -34068,20 +36629,29 @@
 msgstr "name der Spalte, in die Punktsummen gespeichert werden sollen"
 #: ../vector/v.vect.stats/main.c:191
-msgid "Column to hold points count, must be of type integer, will be created if not existing"
-msgstr "Spalte, in die die Punktsummen geschrieben werden sollen, muss vom Typ 'integer' sein. Spalte wird angelegt, wenn sie noch nicht existiert."
+msgid ""
+"Column to hold points count, must be of type integer, will be created if not "
+"existing"
+msgstr ""
+"Spalte, in die die Punktsummen geschrieben werden sollen, muss vom Typ "
+"'integer' sein. Spalte wird angelegt, wenn sie noch nicht existiert."
 #: ../vector/v.vect.stats/main.c:198
 msgid "Column name to upload statistics"
 msgstr "Name der Spalte, in die die Statistiken geschrieben werden"
 #: ../vector/v.vect.stats/main.c:200
-msgid "Column to hold statistics, must be of type double, will be created if not existing"
-msgstr "Spalte, in die die Statistiken geschrieben werden sollen, muss vom Typ 'double' sein. Spalte wird angelegt, wenn sie noch nicht existiert."
+msgid ""
+"Column to hold statistics, must be of type double, will be created if not "
+"existing"
+msgstr ""
+"Spalte, in die die Statistiken geschrieben werden sollen, muss vom Typ "
+"'double' sein. Spalte wird angelegt, wenn sie noch nicht existiert."
 #: ../vector/v.vect.stats/main.c:207
 msgid "Print output to stdout, do not update attribute table"
-msgstr "Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
+msgstr ""
+"Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
 #: ../vector/v.vect.stats/main.c:208
 msgid "First column is always area category"
@@ -34090,7 +36660,9 @@
 #: ../vector/v.vect.stats/main.c:262
 #, c-format
 msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr "Vektorkarte <%s> ist nicht im Mapset des Benutzers und kann nicht aktualisiert werden."
+msgstr ""
+"Vektorkarte <%s> ist nicht im Mapset des Benutzers und kann nicht "
+"aktualisiert werden."
 #: ../vector/v.vect.stats/main.c:309 ../vector/v.vect.stats/main.c:385
 #, c-format
@@ -34182,8 +36754,11 @@
 #: ../vector/v.univar/main.c:96
 #, fuzzy
-msgid "Variance and standard deviation is calculated only for points if specified."
-msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
+msgid ""
+"Variance and standard deviation is calculated only for points if specified."
+msgstr ""
+"Berechnet univariate Statistiken für die Attribute. Die Varianz und "
+"Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
 #: ../vector/v.univar/main.c:131
 msgid "Weigh by line length or area size"
@@ -34199,16 +36774,22 @@
 msgstr ""
 #: ../vector/v.univar/main.c:190
-msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
-msgstr "Inkompatible Vektortypen angeben. Es kann nur die Anzahl der Objekte, das Minimum, das Maximum und der Wertebereich berechnet werden."
+msgid ""
+"Incompatible vector type(s) specified, only number of features, minimum, "
+"maximum and range can be calculated"
+msgstr ""
+"Inkompatible Vektortypen angeben. Es kann nur die Anzahl der Objekte, das "
+"Minimum, das Maximum und der Wertebereich berechnet werden."
 #: ../vector/v.univar/main.c:195
 msgid "Extended statistics is currently supported only for points/centroids"
-msgstr "Erweiterte Statistiken werden zur Zeit nur für Punkte/Zentroide unterstützt."
+msgstr ""
+"Erweiterte Statistiken werden zur Zeit nur für Punkte/Zentroide unterstützt."
 #: ../vector/v.univar/main.c:220
 msgid "'layer' must be > 0 for 'where'."
-msgstr "Parameter 'layer' muss > 0 sein, wenn der Parameter 'where' angegeben ist."
+msgstr ""
+"Parameter 'layer' muss > 0 sein, wenn der Parameter 'where' angegeben ist."
 #: ../vector/v.univar/main.c:235
 #, c-format
@@ -34226,8 +36807,12 @@
 #: ../vector/v.surf.idw/main.c:91
 #, fuzzy
-msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgid ""
+"Provides surface interpolation from vector point data by Inverse Distance "
+msgstr ""
 #: ../vector/v.surf.idw/main.c:100
 #, fuzzy
@@ -34252,8 +36837,12 @@
 msgstr "Indiziere die Punkte nicht mittels der Rasterzellen."
 #: ../vector/v.surf.idw/main.c:128
-msgid "Slower but uses less memory and includes points from outside region in the interpolation"
-msgstr "Langsamer, aber braucht weniger Speicher und integriert auch Punkte außerhalb der Region in die Interpolation."
+msgid ""
+"Slower but uses less memory and includes points from outside region in the "
+"interpolation"
+msgstr ""
+"Langsamer, aber braucht weniger Speicher und integriert auch Punkte "
+"außerhalb der Region in die Interpolation."
 #: ../vector/v.surf.idw/main.c:138
 #, fuzzy, c-format
@@ -34477,7 +37066,9 @@
 #: ../vector/v.colors/main.c:217
 #, fuzzy, c-format
 msgid "One of -%c, -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder \"rules\" muss angegeben werden!"
+msgstr ""
+"Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder "
+"\"rules\" muss angegeben werden!"
 #: ../vector/v.colors/main.c:231
 #, fuzzy, c-format
@@ -34581,8 +37172,14 @@
 msgstr "Kann Daten der Tabelle nicht selektieren."
 #: ../vector/v.class/main.c:171
-msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
-msgstr "Der Diskontinuitätsalgorithmus weist daraufhin, dass einige Klassengrenzen nicht statistisch signifikant (alpha = 0.05) sind. Es wird Ihnen geraten, die Anzahl der Klassen zu reduzieren."
+msgid ""
+"The discontinuities algorithm indicates that some class breaks are not "
+"statistically significant at alpha=0.05. You are advised to reduce the "
+"number of classes."
+msgstr ""
+"Der Diskontinuitätsalgorithmus weist daraufhin, dass einige Klassengrenzen "
+"nicht statistisch signifikant (alpha = 0.05) sind. Es wird Ihnen geraten, "
+"die Anzahl der Klassen zu reduzieren."
 #: ../vector/v.class/main.c:200
 #, c-format
@@ -34639,8 +37236,11 @@
 #: ../vector/v.surf.bspline/main.c:96
 #, fuzzy
-msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
+msgid ""
+"Performs bicubic or bilinear spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+"Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
 #: ../vector/v.surf.bspline/main.c:105
 #: ../vector/v.lidar.edgedetection/main.c:80
@@ -34651,8 +37251,12 @@
 #: ../vector/v.surf.bspline/main.c:107
 #: ../vector/v.lidar.edgedetection/main.c:82
 #: ../vector/v.lidar.correction/main.c:77 ../vector/v.outlier/main.c:77
-msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
-msgstr "Schätze die Punktedichte und Distanz der Eingabe-Vektorkarte innerhalb der aktuellen Region und beende mich."
+msgid ""
+"Estimate point density and distance for the input vector points within the "
+"current region extends and quit"
+msgstr ""
+"Schätze die Punktedichte und Distanz der Eingabe-Vektorkarte innerhalb der "
+"aktuellen Region und beende mich."
 #: ../vector/v.surf.bspline/main.c:118
 #, fuzzy
@@ -34680,11 +37284,14 @@
 #: ../vector/v.surf.bspline/main.c:191
 #, fuzzy
 msgid "Maximum memory to be used for raster output (in MB)"
-msgstr "Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
+msgstr ""
+"Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
 #: ../vector/v.surf.bspline/main.c:203
 msgid "Choose either vector or raster output, not both"
-msgstr "Wählen Sie entweder die Ausgabe im Raster- oder Vektor-Format, aber nicht beides."
+msgstr ""
+"Wählen Sie entweder die Ausgabe im Raster- oder Vektor-Format, aber nicht "
+"beides."
 #: ../vector/v.surf.bspline/main.c:206
 msgid "No raster or vector or cross-validation output"
@@ -34743,8 +37350,12 @@
 #: ../vector/v.surf.bspline/main.c:329
 #, fuzzy, c-format
-msgid "Sorry, the <%s> driver is not compatible with the vector output of this module. Try with raster output or another driver."
-msgstr "Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
+msgid ""
+"Sorry, the <%s> driver is not compatible with the vector output of this "
+"module. Try with raster output or another driver."
+msgstr ""
+"Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul "
+"erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
 #: ../vector/v.surf.bspline/main.c:352
 #, c-format
@@ -34769,7 +37380,9 @@
 #: ../vector/v.surf.bspline/main.c:413
 #, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
-msgstr "Interpolation: Tabellenerzeugung: Es war nicht möglich die Tabelle <%s> zu erstellen."
+msgstr ""
+"Interpolation: Tabellenerzeugung: Es war nicht möglich die Tabelle <%s> zu "
+"erstellen."
 #: ../vector/v.surf.bspline/main.c:481
 #, fuzzy
@@ -34803,7 +37416,9 @@
 #: ../vector/v.surf.bspline/main.c:877
 msgid "No data within this subregion. Consider increasing spline step values."
-msgstr "Keine Daten in dieser Unterregion. Überlegen Sie die Splineschrittweite zu vergrößern."
+msgstr ""
+"Keine Daten in dieser Unterregion. Überlegen Sie die Splineschrittweite zu "
+"vergrößern."
 #: ../vector/v.surf.bspline/main.c:930
 #, fuzzy
@@ -34821,8 +37436,12 @@
 msgstr "%d Punkte in der Region gelesen"
 #: ../vector/v.surf.bspline/crosscorr.c:88
-msgid "Maybe, it takes too long. It will depend on how many points you are considering."
-msgstr "Vielleicht dauert es zu lange. Es hängt davon ab wieviel Punkte Sie erwägen zu verwenden."
+msgid ""
+"Maybe, it takes too long. It will depend on how many points you are "
+"considering."
+msgstr ""
+"Vielleicht dauert es zu lange. Es hängt davon ab wieviel Punkte Sie erwägen "
+"zu verwenden."
 #: ../vector/v.surf.bspline/crosscorr.c:119
 #, c-format
@@ -34856,11 +37475,15 @@
 #: ../vector/v.drape/main.c:61
 #, fuzzy
 msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
-msgstr "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit Höheninformationen."
+msgstr ""
+"Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit "
+"Höheninformationen."
 #: ../vector/v.drape/main.c:146 ../vector/v.buffer/main.c:338
 #, c-format
-msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
+msgid ""
+"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
+"'1'."
 msgstr ""
 #: ../vector/v.drape/main.c:193
@@ -34881,7 +37504,8 @@
 #: ../vector/v.timestamp/main.c:39
 #, fuzzy
 msgid "Print/add/remove a timestamp for a vector map."
-msgstr "Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
+msgstr ""
+"Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
 #: ../vector/v.timestamp/main.c:65
 #, fuzzy, c-format
@@ -34891,7 +37515,9 @@
 #: ../vector/v.buffer/main.c:226
 #, fuzzy
 msgid "Creates a buffer around vector features of given type."
-msgstr "Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen Zentroide enthalten)."
+msgstr ""
+"Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flächen müssen "
+"Zentroide enthalten)."
 #: ../vector/v.buffer/main.c:251
 msgid "Buffer distance along major axis in map units"
@@ -34920,8 +37546,12 @@
 msgstr "Skalierfaktor für die Werte der Attributspalte"
 #: ../vector/v.buffer/main.c:290
-msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
-msgstr "Maximale Distanz zwischen theoretischen Linien und Polygonsegmenten als Vielfaches des Buffers"
+msgid ""
+"Maximum distance between theoretical arc and polygon segments as multiple of "
+"buffer"
+msgstr ""
+"Maximale Distanz zwischen theoretischen Linien und Polygonsegmenten als "
+"Vielfaches des Buffers"
 #: ../vector/v.buffer/main.c:295
 msgid "Make outside corners straight"
@@ -34938,7 +37568,9 @@
 #: ../vector/v.buffer/main.c:323
 msgid "Select a buffer distance/minordistance/angle or column, but not both."
-msgstr "Wählen Sie entweder die Buffer distance/minordistance/angle oder eine Spalte, aber nicht beides"
+msgstr ""
+"Wählen Sie entweder die Buffer distance/minordistance/angle oder eine "
+"Spalte, aber nicht beides"
 #: ../vector/v.buffer/main.c:349
 msgid "The bufcol option requires a valid layer."
@@ -34974,11 +37606,17 @@
 msgstr "Kann keine Daten der Tabelle <%s> selektieren"
 #: ../vector/v.buffer/main.c:452
-msgid "No features available for buffering. Check type option and features available in the input vector."
-msgstr "Keine Objekte zum Buffern vorhanden. Überprüfen Sie die Option type und die Objekte in der Eingabe-Vektorkarte."
+msgid ""
+"No features available for buffering. Check type option and features "
+"available in the input vector."
+msgstr ""
+"Keine Objekte zum Buffern vorhanden. Überprüfen Sie die Option type und die "
+"Objekte in der Eingabe-Vektorkarte."
 #: ../vector/v.buffer/main.c:468
-msgid "Negative distances for internal buffers are not supported and converted to positive values."
+msgid ""
+"Negative distances for internal buffers are not supported and converted to "
+"positive values."
 msgstr ""
 #: ../vector/v.buffer/main.c:478
@@ -35095,7 +37733,8 @@
 #: ../vector/v.mkgrid/main.c:68
 #, fuzzy
 msgid "Creates a vector map of a user-defined grid."
-msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
+msgstr ""
+"Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
 #: ../vector/v.mkgrid/main.c:75
 #, fuzzy
@@ -35224,7 +37863,9 @@
 msgstr "Begrenze den Import auf die aktuelle Region."
 #: ../vector/v.in.lidar/main.c:218
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector file."
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the vector file."
 msgstr ""
 #: ../vector/v.in.lidar/main.c:281
@@ -35234,7 +37875,9 @@
 #: ../vector/v.in.lidar/main.c:286 ../vector/v.in.ogr/main.c:491
 msgid "Select either the current region flag or the spatial option, not both"
-msgstr "Wählen Sie entweder den Schalter \"aktuelle Region\" oder die Option 'spatial' aber nicht beide."
+msgstr ""
+"Wählen Sie entweder den Schalter \"aktuelle Region\" oder die Option "
+"'spatial' aber nicht beide."
 #: ../vector/v.in.lidar/main.c:314 ../vector/v.in.ogr/main.c:546
 msgid "4 parameters required for 'spatial' parameter"
@@ -35282,8 +37925,12 @@
 #: ../vector/v.extract/main.c:80
 #, fuzzy
-msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
-msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
+msgid ""
+"Selects vector features from an existing vector map and creates a new vector "
+"map containing only the selected features."
+msgstr ""
+"Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine "
+"neue Karte nur mit den selektierten Objekten."
 #: ../vector/v.extract/main.c:85
 msgid "Dissolve common boundaries (default is no)"
@@ -35292,7 +37939,8 @@
 #: ../vector/v.extract/main.c:89
 #, fuzzy
 msgid "Do not copy attributes (see also 'new' parameter)"
-msgstr "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
+msgstr ""
+"Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
 #: ../vector/v.extract/main.c:94 ../vector/v.edit/args.c:198
 #: ../vector/v.select/args.c:103
@@ -35305,7 +37953,9 @@
 #: ../vector/v.extract/main.c:120
 msgid "Input text file with category numbers/number ranges to be extracted"
-msgstr "Eingabe-Textdatei mit Kategorienummern/-wertebereichen, die extrahiert werden sollen."
+msgstr ""
+"Eingabe-Textdatei mit Kategorienummern/-wertebereichen, die extrahiert "
+"werden sollen."
 #: ../vector/v.extract/main.c:121
 msgid "If '-' given reads from standard input"
@@ -35313,11 +37963,14 @@
 #: ../vector/v.extract/main.c:129
 msgid "Number of random categories matching vector objects to extract"
-msgstr "Zahl der zu zufälligen Kategorien passenden Vektorobjekten, die extrahiert werden."
+msgstr ""
+"Zahl der zu zufälligen Kategorien passenden Vektorobjekten, die extrahiert "
+"werden."
 #: ../vector/v.extract/main.c:131
 msgid "Number must be smaller than unique cat count in layer"
-msgstr "Zahl muss kleiner sein als die Anzahl der eindeutigen cat in dem Layer."
+msgstr ""
+"Zahl muss kleiner sein als die Anzahl der eindeutigen cat in dem Layer."
 #: ../vector/v.extract/main.c:139
 msgid "Desired new category value (enter -1 to keep original categories)"
@@ -35330,8 +37983,12 @@
 #: ../vector/v.extract/main.c:158
 #, fuzzy, c-format
-msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
-msgstr "Die Optionen list, file, where und random schließen sich gegenseitig aus. Bitte geben Sie nur eine von diesen an."
+msgid ""
+"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only "
+"one of them."
+msgstr ""
+"Die Optionen list, file, where und random schließen sich gegenseitig aus. "
+"Bitte geben Sie nur eine von diesen an."
 #: ../vector/v.extract/main.c:203
 #, c-format
@@ -35369,8 +38026,12 @@
 msgstr "%d Kategorien aus der Tabelle geladen."
 #: ../vector/v.extract/main.c:279
-msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
-msgstr "Diese Karte hat keine Kategorien beigefügt. Verwenden Sie v.category, um dieser Karte Kategorien zuzuordnen."
+msgid ""
+"This map has no categories attached. Use v.category to attach categories to "
+"this vector map."
+msgstr ""
+"Diese Karte hat keine Kategorien beigefügt. Verwenden Sie v.category, um "
+"dieser Karte Kategorien zuzuordnen."
 #: ../vector/v.extract/main.c:286
 msgid "Please specify random number larger than 0"
@@ -35378,16 +38039,26 @@
 #: ../vector/v.extract/main.c:290
 #, c-format
-msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
-msgstr "Die Zahl der zufälligen Kategorien muss kleiner sein, als die Zahl der Objekte. Es gibt nur %d Objekte des Typs: %s"
+msgid ""
+"Random category count must be smaller than feature count. There are only %d "
+"features of type(s): %s"
+msgstr ""
+"Die Zahl der zufälligen Kategorien muss kleiner sein, als die Zahl der "
+"Objekte. Es gibt nur %d Objekte des Typs: %s"
 #: ../vector/v.extract/main.c:313
 #, fuzzy, c-format
-msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
-msgstr "Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der eindeutigen \"%s\" Feature Kategorien %d."
+msgid ""
+"Random category count is larger or equal to uniq <%s> feature category count "
+"%d"
+msgstr ""
+"Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der "
+"eindeutigen \"%s\" Feature Kategorien %d."
 #: ../vector/v.extract/main.c:318
-msgid "There are more categories than random number generator can reach. Report this as a GRASS bug."
+msgid ""
+"There are more categories than random number generator can reach. Report "
+"this as a GRASS bug."
 msgstr ""
 #: ../vector/v.extract/main.c:349
@@ -35410,7 +38081,9 @@
 #: ../vector/v.extract/extract.c:225
 #, fuzzy
-msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
+msgid ""
+"Topology level required for extracting areas for OGR layers. Areas will be "
+"not processed."
 msgstr "Finde Zentroide der Layer: %s"
 #: ../vector/v.segment/main.c:62
@@ -35443,7 +38116,8 @@
 "Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
 "%s"
 msgstr ""
-"Kann den Punkt auf der Linie nicht bekommen: cat = %d offset = %f (Länge der Linie = %.15g)\n"
+"Kann den Punkt auf der Linie nicht bekommen: cat = %d offset = %f (Länge der "
+"Linie = %.15g)\n"
 "%s"
 #: ../vector/v.segment/main.c:216
@@ -35456,7 +38130,8 @@
 "Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
 "%s"
 msgstr ""
-"Kann das Liniensegment nicht machen: cat = %d : %f - %f (Länge der Linie = %.15g)\n"
+"Kann das Liniensegment nicht machen: cat = %d : %f - %f (Länge der Linie = "
+"%.15g)\n"
 "%s"
 #: ../vector/v.segment/main.c:244 ../vector/v.lrs/v.lrs.segment/main.c:332
@@ -35489,12 +38164,17 @@
 msgstr "writeVTKHeader: Schreibe VTK-Header"
 #: ../vector/v.out.vtk/writeVTK.c:196
-msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
-msgstr "Keine Koordinaten um Ausgabe zu erzeugen. Vielleicht wurde ein leerer Vektor-Typ ausgewählt."
+msgid ""
+"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgstr ""
+"Keine Koordinaten um Ausgabe zu erzeugen. Vielleicht wurde ein leerer Vektor-"
+"Typ ausgewählt."
 #: ../vector/v.out.vtk/writeVTK.c:632
 msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-msgstr "Kann Felder der Attributtabelle für Layer < 1 nicht exportieren. Überspringe den Export."
+msgstr ""
+"Kann Felder der Attributtabelle für Layer < 1 nicht exportieren. Überspringe "
+"den Export."
 #: ../vector/v.out.vtk/writeVTK.c:640
 msgid "No attribute table found"
@@ -35526,7 +38206,8 @@
 #: ../vector/v.out.vtk/main.c:92
 msgid "Export numeric attribute table fields as VTK scalar variables"
-msgstr "Exportiere numerische Felder der Attributtabelle als VTK-Skalar-Variablen."
+msgstr ""
+"Exportiere numerische Felder der Attributtabelle als VTK-Skalar-Variablen."
 #: ../vector/v.out.vtk/main.c:158
 msgid "dp has to be from 0 to 8"
@@ -35538,7 +38219,9 @@
 #: ../vector/v.out.vtk/main.c:186
 #, c-format
-msgid "Export of areas requires topology. Please adjust '%s' option or rebuild topology."
+msgid ""
+"Export of areas requires topology. Please adjust '%s' option or rebuild "
+"topology."
 msgstr ""
 #: ../vector/v.hull/hull.c:107
@@ -35557,7 +38240,9 @@
 #: ../vector/v.hull/main.c:75
 msgid "Create a 'flat' 2D hull even if the input is 3D points"
-msgstr "Erzeuge eine 'flache' 2D Hülle, selbst wenn die Eingabe aus 3D Punkten besteht."
+msgstr ""
+"Erzeuge eine 'flache' 2D Hülle, selbst wenn die Eingabe aus 3D Punkten "
+"besteht."
 #: ../vector/v.hull/main.c:100
 #, c-format
@@ -35587,7 +38272,8 @@
 #: ../vector/v.to.rast3/main.c:51
 #, fuzzy
 msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D Rasterkarte. "
+msgstr ""
+"Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D Rasterkarte. "
 #: ../vector/v.to.rast3/main.c:62
 #, fuzzy
@@ -35686,12 +38372,17 @@
 #, fuzzy, c-format
 msgid "Unable to make line segment: %f - %f (line length = %f)"
 msgstr ""
+"%.15g)\n"
 "%s"
 #: ../vector/v.distance/main.c:92
-msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
-msgstr "Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der Vektorkarte 'from'. "
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+"Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der "
+"Vektorkarte 'from'. "
 #: ../vector/v.distance/main.c:96
 msgid "Name of existing vector map (from)"
@@ -35721,7 +38412,9 @@
 #: ../vector/v.distance/main.c:131
 msgid "Name for output vector map containing lines connecting nearest elements"
-msgstr "Ausgabe-Vektorkarte mit Verbindungslinien zwischen den nächstgelgenen Elementen."
+msgstr ""
+"Ausgabe-Vektorkarte mit Verbindungslinien zwischen den nächstgelgenen "
+"Elementen."
 #: ../vector/v.distance/main.c:139
 msgid "Maximum distance or -1 for no limit"
@@ -35733,7 +38426,8 @@
 #: ../vector/v.distance/main.c:155
 msgid "Values describing the relation between two nearest features"
-msgstr "Werte, die die Verbindung zwischen zwei nächstgelegenen Objekte beschreiben"
+msgstr ""
+"Werte, die die Verbindung zwischen zwei nächstgelegenen Objekte beschreiben"
 #: ../vector/v.distance/main.c:165
 #, fuzzy
@@ -35756,11 +38450,14 @@
 msgstr "Ost-Koordinate eines Punktes der Ebene."
 #: ../vector/v.distance/main.c:169
-msgid "distance to the nearest point on the 'to' feature along that linear feature"
+msgid ""
+"distance to the nearest point on the 'to' feature along that linear feature"
 msgstr ""
 #: ../vector/v.distance/main.c:171
-msgid "angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive"
+msgid ""
+"angle along the nearest linear feature in the 'to' map, measured CCW from "
+"the +x axis, in radians, between -Pi and Pi inclusive"
 msgstr ""
 #: ../vector/v.distance/main.c:174
@@ -35768,33 +38465,47 @@
 msgstr ""
 #: ../vector/v.distance/main.c:187
-msgid "Column name(s) where values specified by 'upload' option will be uploaded"
-msgstr "Name(n) der Spalte(n) in denen, durch die 'upload'-Option bestimmte, Werte gespeichert werden."
+msgid ""
+"Column name(s) where values specified by 'upload' option will be uploaded"
+msgstr ""
+"Name(n) der Spalte(n) in denen, durch die 'upload'-Option bestimmte, Werte "
+"gespeichert werden."
 #: ../vector/v.distance/main.c:193
 msgid "Column name of nearest feature (used with upload=to_attr)"
-msgstr "Spaltenname der nächstgelegenen Objekte (verwendet mit upload=to_attr)."
+msgstr ""
+"Spaltenname der nächstgelegenen Objekte (verwendet mit upload=to_attr)."
 #: ../vector/v.distance/main.c:199
 #, fuzzy
 msgid "Name of table created when the 'distance to all' flag is used"
-msgstr "Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' gesetzt wurde."
+msgstr ""
+"Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' "
+"gesetzt wurde."
 #: ../vector/v.distance/main.c:204
 msgid "Print output to stdout, don't update attribute table"
+msgstr ""
 #: ../vector/v.distance/main.c:206
 msgid "First column is always category of 'from' feature called from_cat"
-msgstr "Die erste Spalte ist immer die Kategorie der 'from'-Objekte und 'from_cat' benannt."
+msgstr ""
+"Die erste Spalte ist immer die Kategorie der 'from'-Objekte und 'from_cat' "
+"benannt."
 #: ../vector/v.distance/main.c:211
 msgid "Calculate distances to all features within the threshold"
 msgstr "Berechne Distanzen zu allen Objekten innerhalb des Schwellwertes."
 #: ../vector/v.distance/main.c:213
-msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
-msgstr "Die Ausgabe wird nach stdout geschrieben und kann auch in eine neue Tabelle geschrieben werden, die von diesem Modul erzeugt wird. Es können mehrere 'upload' Optionen verwendet werden."
+msgid ""
+"Output is written to stdout but may be uploaded to a new table created by "
+"this module; multiple 'upload' options may be used."
+msgstr ""
+"Die Ausgabe wird nach stdout geschrieben und kann auch in eine neue Tabelle "
+"geschrieben werden, die von diesem Modul erzeugt wird. Es können mehrere "
+"'upload' Optionen verwendet werden."
 #: ../vector/v.distance/main.c:268
 msgid "to_column option missing"
@@ -35848,7 +38559,9 @@
 #: ../vector/v.distance/main.c:1217
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
-msgstr "Datentyp DATETIME wird noch nicht unterstützt. Es werden keine Attribute geschrieben."
+msgstr ""
+"Datentyp DATETIME wird noch nicht unterstützt. Es werden keine Attribute "
+"geschrieben."
 #: ../vector/v.distance/main.c:1235
 msgid "Unable to open default database"
@@ -35892,7 +38605,8 @@
 #: ../vector/v.distance/main.c:1588
 #, c-format
 msgid "%d categories read from the map exist in the table"
-msgstr "%d aus der Karte gelesene Kategorien existieren bereits in der Tabelle."
+msgstr ""
+"%d aus der Karte gelesene Kategorien existieren bereits in der Tabelle."
 #: ../vector/v.distance/main.c:1591
 #, c-format
@@ -35910,8 +38624,12 @@
 #: ../vector/v.qcount/main.c:71
 #, fuzzy
-msgid "Name for output quadrant centres map (number of points is written as category)"
-msgstr "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie ausgegeben."
+msgid ""
+"Name for output quadrant centres map (number of points is written as "
+"category)"
+msgstr ""
+"Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie "
+"ausgegeben."
 #: ../vector/v.qcount/main.c:77
 msgid "Number of quadrats"
@@ -35978,12 +38696,16 @@
 #: ../vector/v.to.db/report.c:201
 #, c-format
 msgid "%d categories read from vector map exist in selection from table"
-msgstr "%d Kategorien gelesen von der Vektorkarte existieren in der Selektion der Tabelle."
+msgstr ""
+"%d Kategorien gelesen von der Vektorkarte existieren in der Selektion der "
+"Tabelle."
 #: ../vector/v.to.db/report.c:204
 #, c-format
 msgid "%d categories read from vector map don't exist in selection from table"
-msgstr "%d Kategorien gelesen von der Vektorkarte existieren nicht in der Selektion der Tabelle."
+msgstr ""
+"%d Kategorien gelesen von der Vektorkarte existieren nicht in der Selektion "
+"der Tabelle."
 #: ../vector/v.to.db/report.c:206
 #, c-format
@@ -36009,7 +38731,9 @@
 #: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
 #, c-format
 msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr "Datenbankverbindung für Layer %d nicht definiert. Verwenden Sie zuerst v.db.connect."
+msgstr ""
+"Datenbankverbindung für Layer %d nicht definiert. Verwenden Sie zuerst v.db."
+"connect."
 #: ../vector/v.to.db/areas.c:28 ../vector/v.to.rast/do_areas.c:34
 msgid "Reading areas..."
@@ -36022,7 +38746,8 @@
 #: ../vector/v.to.db/parse.c:43
 msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr "Für coor sind Punkt/Zentroid erlaubt; für length sind Linie/Grenze erlaubt."
+msgstr ""
+"Für coor sind Punkt/Zentroid erlaubt; für length sind Linie/Grenze erlaubt."
 #: ../vector/v.to.db/parse.c:54
 msgid "Value to upload"
@@ -36078,11 +38803,15 @@
 msgstr ""
 #: ../vector/v.to.db/parse.c:84
-msgid "categories of areas on the left and right side of the boundary, 'qlayer' is used for area category"
+msgid ""
+"categories of areas on the left and right side of the boundary, 'qlayer' is "
+"used for area category"
 msgstr ""
 #: ../vector/v.to.db/parse.c:86
-msgid "result of a database query for all records of the geometry(or geometries) from table specified by 'qlayer' option"
+msgid ""
+"result of a database query for all records of the geometry(or geometries) "
+"from table specified by 'qlayer' option"
 msgstr ""
 #: ../vector/v.to.db/parse.c:88
@@ -36091,11 +38820,14 @@
 msgstr "Ausgabekarte der Hangneigungsfaktoren (S) für USLE."
 #: ../vector/v.to.db/parse.c:89
-msgid "line sinuousity, calculated as line length / distance between end points"
+msgid ""
+"line sinuousity, calculated as line length / distance between end points"
 msgstr ""
 #: ../vector/v.to.db/parse.c:90
-msgid "line azimuth, calculated as angle between North direction and endnode direction at startnode"
+msgid ""
+"line azimuth, calculated as angle between North direction and endnode "
+"direction at startnode"
 msgstr ""
 #: ../vector/v.to.db/parse.c:94
@@ -36132,7 +38864,8 @@
 #: ../vector/v.to.db/parse.c:132
 #, fuzzy
 msgid "Print also totals for option length, area, or count"
-msgstr "Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
+msgstr ""
+"Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
 #: ../vector/v.to.db/parse.c:178
 msgid "This option requires one column"
@@ -36168,13 +38901,19 @@
 #: ../vector/v.to.db/query.c:108
 #, c-format
-msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
-msgstr "Abfrage für Kategorie '0' (keine Kategorie) wurde nicht ausgeführt, weil zu viele (%d) Kategorien in der Abfrage sind. Alle im Folgenden berichteten Werte für cat 0 sind nicht korrekt. "
+msgid ""
+"Query for category '0' (no category) was not executed because of too many "
+"(%d) query categories. All later reported values for cat 0 are not valid."
+msgstr ""
+"Abfrage für Kategorie '0' (keine Kategorie) wurde nicht ausgeführt, weil zu "
+"viele (%d) Kategorien in der Abfrage sind. Alle im Folgenden berichteten "
+"Werte für cat 0 sind nicht korrekt. "
 #: ../vector/v.to.db/query.c:145
 #, c-format
 msgid "Multiple query results, output value set to NULL (category [%d])"
-msgstr "Mehrere Abfrage-Ergebnisse, Ausgabewert auf NULL gesetzt (Kategorie [%d])."
+msgstr ""
+"Mehrere Abfrage-Ergebnisse, Ausgabewert auf NULL gesetzt (Kategorie [%d])."
 #: ../vector/v.to.db/query.c:152
 msgid "Unable to fetch record"
@@ -36287,7 +39026,9 @@
 #: ../vector/v.lidar.edgedetection/main.c:259
 #, c-format
 msgid "It was impossible to create <%s> interpolation table in database."
-msgstr "Es war nicht möglich die <%s> Interpolations-Tabelle in der Datenbank zu erstellen."
+msgstr ""
+"Es war nicht möglich die <%s> Interpolations-Tabelle in der Datenbank zu "
+"erstellen."
 #: ../vector/v.lidar.edgedetection/main.c:392
 msgid "Allocating memory for bilinear interpolation"
@@ -36304,7 +39045,9 @@
 #: ../vector/v.lidar.edgedetection/main.c:456
 #: ../vector/v.lidar.correction/main.c:425 ../vector/v.outlier/main.c:439
 msgid "No data within this subregion. Consider changing the spline step."
-msgstr "Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu ändern."
+msgstr ""
+"Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu "
+"ändern."
 #: ../vector/v.lidar.edgedetection/main.c:464
 #: ../vector/v.lidar.correction/main.c:434
@@ -36331,7 +39074,8 @@
 #: ../vector/v.in.dwg/main.c:102
 msgid "Invert selection by layers (don't import layers in list)"
-msgstr "Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
+msgstr ""
+"Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
 #: ../vector/v.in.dwg/main.c:110
 msgid "Write circles as points (centre)"
@@ -36464,7 +39208,9 @@
 #: ../vector/v.to.3d/args.c:32
 msgid "Can be used for reverse transformation, to store height of points"
-msgstr "Kann verwendet werden, um, bei umgekehrter Transformation, die Höhen der Punkte zu speichern. "
+msgstr ""
+"Kann verwendet werden, um, bei umgekehrter Transformation, die Höhen der "
+"Punkte zu speichern. "
 #: ../vector/v.overlay/line_area.c:255 ../vector/v.overlay/area_area.c:107
 msgid "Breaking lines..."
@@ -36516,11 +39262,19 @@
 #: ../vector/v.overlay/main.c:101
 msgid "Operator defines features written to output vector map"
-msgstr "Operator bestimmt, welche Objekte in die Ausgabe-Vektorkarte geschrieben werden."
+msgstr ""
+"Operator bestimmt, welche Objekte in die Ausgabe-Vektorkarte geschrieben "
+"werden."
 #: ../vector/v.overlay/main.c:104
-msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
-msgstr "Ein Objekt wird in die Ausgabekarte geschrieben, wenn das Ergebnis der Operation 'ainput operator binput' wahr ist. Ein Eingabe-Objekt wird als wahr erachtet, wenn die Kategorie des gegebenen Layers definiert ist."
+msgid ""
+"Feature is written to output if the result of operation 'ainput operator "
+"binput' is true. Input feature is considered to be true, if category of "
+"given layer is defined."
+msgstr ""
+"Ein Objekt wird in die Ausgabekarte geschrieben, wenn das Ergebnis der "
+"Operation 'ainput operator binput' wahr ist. Ein Eingabe-Objekt wird als "
+"wahr erachtet, wenn die Kategorie des gegebenen Layers definiert ist."
 #: ../vector/v.overlay/main.c:111
 msgid "also known as 'intersection' in GIS"
@@ -36535,7 +39289,9 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:114
-msgid "features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
+msgid ""
+"features from either ainput or binput but not those from ainput overlayed by "
+"binput (only for atype=area)"
 msgstr ""
 #: ../vector/v.overlay/main.c:125
@@ -36631,7 +39387,8 @@
 #: ../vector/v.net.flow/main.c:62
 msgid "Computes the maximum flow between two sets of nodes in the network."
-msgstr "Berechnet den maximalen Fluss zwischen zwei Auswahlen von Knoten im Netzwerk."
+msgstr ""
+"Berechnet den maximalen Fluss zwischen zwei Auswahlen von Knoten im Netzwerk."
 #: ../vector/v.net.flow/main.c:84
 msgid "Name for output vector map containing a minimum cut"
@@ -36643,7 +39400,8 @@
 #: ../vector/v.net.flow/main.c:113
 msgid "Source WHERE conditions of SQL statement without 'where' keyword"
-msgstr "Source WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr ""
+"Source WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.flow/main.c:118
 msgid "Sink category values"
@@ -36655,7 +39413,8 @@
 #: ../vector/v.net.flow/main.c:124
 msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
-msgstr "Sink WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr ""
+"Sink WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.flow/main.c:198
 #, c-format
@@ -36848,7 +39607,9 @@
 #: ../vector/v.what/main.c:158
 #, fuzzy, c-format
 msgid "Number of given vector maps (%d) differs from number of layers (%d)"
-msgstr "Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der Spalten (%d) in der Eingabe überein."
+msgstr ""
+"Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der "
+"Spalten (%d) in der Eingabe überein."
 #: ../vector/v.what/main.c:167
 #, c-format
@@ -36862,8 +39623,12 @@
 #: ../vector/v.external/main.c:53
 #, fuzzy
-msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer or a PostGIS feature table."
-msgstr "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu einem OGR-Layer."
+msgid ""
+"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
+"PostGIS feature table."
+msgstr ""
+"Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu "
+"einem OGR-Layer."
 #: ../vector/v.external/main.c:133 ../vector/v.in.ogr/main.c:421
 #, c-format
@@ -36920,8 +39685,12 @@
 #: ../vector/v.external/list.c:291
 #, fuzzy, c-format
-msgid "Unable to convert input map projection to GRASS format. Projection check cannot be provided for OGR layer <%s>"
-msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; kann daher keine neue Location erstellen."
+msgid ""
+"Unable to convert input map projection to GRASS format. Projection check "
+"cannot be provided for OGR layer <%s>"
+msgstr ""
+"Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; "
+"kann daher keine neue Location erstellen."
 #: ../vector/v.external/args.c:26
 #, fuzzy
@@ -37103,8 +39872,12 @@
 msgstr "Kann die Zeile %d nicht zurückschreiben."
 #: ../vector/v.edit/main.c:60
-msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
-msgstr "Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern ausgewählter Vektorobjekte."
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
+msgstr ""
+"Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern "
+"ausgewählter Vektorobjekte."
 #: ../vector/v.edit/main.c:69
 #, c-format
@@ -37117,13 +39890,21 @@
 #: ../vector/v.edit/main.c:137
 #, fuzzy, c-format
-msgid "Unable to open vector map <%s> on topological level. Try to rebuild vector topology by v.build."
+msgid ""
+"Unable to open vector map <%s> on topological level. Try to rebuild vector "
+"topology by v.build."
+msgstr ""
 #: ../vector/v.edit/main.c:157
 #, c-format
-msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
-msgstr "Kann Vektorkarte <%s> nicht als Hintergrundkarte öffnen, da sie als zu editierende Karte ausgewählte wurde."
+msgid ""
+"Unable to open vector map <%s> as the background map. It is given as vector "
+"map to be edited."
+msgstr ""
+"Kann Vektorkarte <%s> nicht als Hintergrundkarte öffnen, da sie als zu "
+"editierende Karte ausgewählte wurde."
 #: ../vector/v.edit/main.c:168
 #, c-format
@@ -37144,8 +39925,13 @@
 #: ../vector/v.edit/main.c:231
 #, c-format
-msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
-msgstr "Die Vektorkarte <%s> ist nicht 3D. Das Werkzeug '%s' benötigt eine 3D-Vektorkarte. Bitte konvertieren Sie die Vektorkarte nach 3D z.B. mit Hilfe von %s."
+msgid ""
+"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
+"the vector map to 3D using e.g. %s."
+msgstr ""
+"Die Vektorkarte <%s> ist nicht 3D. Das Werkzeug '%s' benötigt eine 3D-"
+"Vektorkarte. Bitte konvertieren Sie die Vektorkarte nach 3D z.B. mit Hilfe "
+"von %s."
 #: ../vector/v.edit/main.c:271
 #, c-format
@@ -37211,8 +39997,12 @@
 #: ../vector/v.edit/main.c:358
 #, c-format
-msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
-msgstr "Mehrere Hintergrundkarten wurden angegeben. Selektierte Objekte werden nur von der Vektorkarte <%s> kopiert."
+msgid ""
+"Multiple background maps were given. Selected features will be copied only "
+"from vector map <%s>."
+msgstr ""
+"Mehrere Hintergrundkarten wurden angegeben. Selektierte Objekte werden nur "
+"von der Vektorkarte <%s> kopiert."
 #: ../vector/v.edit/main.c:368
 #, c-format
@@ -37330,7 +40120,9 @@
 #: ../vector/v.edit/args.c:68
 #, fuzzy
 msgid "Set new categories to selected vector features for defined layer"
-msgstr "Gebe anstelle der Attribute die minimale Ausdehnung der Region der selektierten Vektorfeatures aus."
+msgstr ""
+"Gebe anstelle der Attribute die minimale Ausdehnung der Region der "
+"selektierten Vektorfeatures aus."
 #: ../vector/v.edit/args.c:70
 msgid "Delete categories from selected vector features for defined layer"
@@ -37380,7 +40172,8 @@
 #: ../vector/v.edit/args.c:99
 #, fuzzy
 msgid "Difference in x,y,z direction for moving feature or vertex"
-msgstr "Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
+msgstr ""
+"Differenz in x,y Richtung für das Verschieben eines Features oder Vertex."
 #: ../vector/v.edit/args.c:106
 msgid "Threshold distance (coords,snap,query)"
@@ -37388,7 +40181,8 @@
 #: ../vector/v.edit/args.c:108
 msgid "'-1' for threshold based on the current resolution settings"
-msgstr "'-1' um den Schwellwert auf Basis der aktuellen Auflösung zu bestimmen."
+msgstr ""
+"'-1' um den Schwellwert auf Basis der aktuellen Auflösung zu bestimmen."
 #: ../vector/v.edit/args.c:124
 msgid "List of point coordinates"
@@ -37408,7 +40202,9 @@
 #: ../vector/v.edit/args.c:154
 msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
-msgstr "Für 'Kürzere' verwenden Sie einen negativen Schwellwert und positive Werte für 'Längere'."
+msgstr ""
+"Für 'Kürzere' verwenden Sie einen negativen Schwellwert und positive Werte "
+"für 'Längere'."
 #: ../vector/v.edit/args.c:160
 #, fuzzy
@@ -37424,8 +40220,12 @@
 msgstr "Name der Hintergrund-Vektorkarte(n)."
 #: ../vector/v.edit/args.c:176
-msgid "Snap added or modified features in the given threshold to the nearest existing feature"
-msgstr "Hinzugefügte oder veränderte Objekte, innerhalb der Toleranz, am nächsten Objekt fangen"
+msgid ""
+"Snap added or modified features in the given threshold to the nearest "
+"existing feature"
+msgstr ""
+"Hinzugefügte oder veränderte Objekte, innerhalb der Toleranz, am nächsten "
+"Objekt fangen"
 #: ../vector/v.edit/args.c:182
 msgid "Not apply snapping"
@@ -37449,7 +40249,8 @@
 #: ../vector/v.edit/args.c:204
 msgid "Close added boundaries (using threshold distance)"
-msgstr "Schließe hinzugefügte Grenzlinien (unter Verwendung der Schwellwert Distanz)."
+msgstr ""
+"Schließe hinzugefügte Grenzlinien (unter Verwendung der Schwellwert Distanz)."
 #: ../vector/v.edit/args.c:208
 msgid "Do not expect header of input data"
@@ -37492,13 +40293,21 @@
 #: ../vector/v.net.alloc/main.c:66
 #, fuzzy
-msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
-msgstr "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knoten gehen im die Berechnung mit ein."
+msgid ""
+"center node must be opened (costs >= 0). Costs of center node are used in "
+"calculation"
+msgstr ""
+"Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen "
+"Knoten gehen im die Berechnung mit ein."
 #: ../vector/v.net.alloc/main.c:111
 #, fuzzy
-msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
-msgstr "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegebn."
+msgid ""
+"Categories of centers (points on nodes) to which net will be allocated, "
+"layer for this categories is given by nlayer option"
+msgstr ""
+"Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen "
+"wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegebn."
 #: ../vector/v.net.alloc/main.c:189
 #, fuzzy, c-format
@@ -37508,7 +40317,8 @@
 #: ../vector/v.net.alloc/main.c:192
 #, fuzzy
 msgid "Not enough centers for selected nlayer. Nothing will be allocated."
-msgstr "Nicht genügend Zentren für den gewählten nlayer. Nichts wird zugewiesen."
+msgstr ""
+"Nicht genügend Zentren für den gewählten nlayer. Nichts wird zugewiesen."
 #: ../vector/v.net.alloc/main.c:203
 #, fuzzy
@@ -37518,7 +40328,8 @@
 #: ../vector/v.net.alloc/main.c:343 ../vector/v.net.alloc/main.c:354
 #: ../vector/v.net.iso/main.c:508
 msgid "Cannot get line segment, segment out of line"
-msgstr "Kann das Liniensegment nicht bekommen, Segment ist außerhalb der Linie."
+msgstr ""
+"Kann das Liniensegment nicht bekommen, Segment ist außerhalb der Linie."
 #: ../vector/v.net.spanningtree/main.c:48
 msgid "spanning tree"
@@ -37545,8 +40356,13 @@
 #: ../vector/v.net.steiner/main.c:351
 #, fuzzy
-msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
-msgstr "Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis suboptimal sein."
+msgid ""
+"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
+"is used in this module so the result may be sub optimal."
+msgstr ""
+"Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem "
+"Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis "
+"suboptimal sein."
 #: ../vector/v.net.steiner/main.c:371
 msgid "Node layer (used for terminals)"
@@ -37558,7 +40374,8 @@
 #: ../vector/v.net.steiner/main.c:383
 msgid "Categories of points on terminals (layer is specified by nlayer)"
-msgstr "Kategorien der Punkte auf den Stationen (Layer wird mit nlayer angegeben)"
+msgstr ""
+"Kategorien der Punkte auf den Stationen (Layer wird mit nlayer angegeben)"
 #: ../vector/v.net.steiner/main.c:391
 msgid "Number of steiner points (-1 for all possible)"
@@ -37575,12 +40392,17 @@
 #: ../vector/v.net.steiner/main.c:513
 #, c-format
 msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
-msgstr "Station am Knoten [%d] kann nicht mit der Station am Knoten [%d] verbunden werden"
+msgstr ""
+"Station am Knoten [%d] kann nicht mit der Station am Knoten [%d] verbunden "
+"werden"
 #: ../vector/v.net.steiner/main.c:529
 #, c-format
-msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
-msgstr "[%d] (nicht erreichbare) Knoten wurden aus der Liste der Steiner-Punktkandidaten entfernt"
+msgid ""
+"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgstr ""
+"[%d] (nicht erreichbare) Knoten wurden aus der Liste der Steiner-"
+"Punktkandidaten entfernt"
 #: ../vector/v.net.steiner/main.c:534
 #, c-format
@@ -37595,7 +40417,9 @@
 #: ../vector/v.net.steiner/main.c:561
 #, c-format
 msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
-msgstr "Steiner-Punkt am Knoten [%d] wurde zu den Stationen hinzugefügt (MST Kosten = %f)."
+msgstr ""
+"Steiner-Punkt am Knoten [%d] wurde zu den Stationen hinzugefügt (MST Kosten "
+"= %f)."
 #: ../vector/v.net.steiner/main.c:573
 msgid "No Steiner point found -> leaving cycle"
@@ -37611,12 +40435,22 @@
 msgstr "Linie"
 #: ../vector/v.net.iso/main.c:76
-msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
-msgstr "Teilt das Netz in Bänder zwischen Isokostenlinien (Richtung vom Zentrum). Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knotens gehen in die Berechnung ein."
+msgid ""
+"Splits net to bands between cost isolines (direction from centre). Centre "
+"node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation."
+msgstr ""
+"Teilt das Netz in Bänder zwischen Isokostenlinien (Richtung vom Zentrum). "
+"Knotens gehen in die Berechnung ein."
 #: ../vector/v.net.iso/main.c:114
-msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
-msgstr "Kategorie der Zentren (Punkte auf Knoten), denen das Netz zugeteilt wird. Layer für diese Kategorien wird mit der Option nlayer angegeben. "
+msgid ""
+"Categories of centres (points on nodes) to which net will be allocated. "
+"Layer for this categories is given by nlayer option."
+msgstr ""
+"Kategorie der Zentren (Punkte auf Knoten), denen das Netz zugeteilt wird. "
+"Layer für diese Kategorien wird mit der Option nlayer angegeben. "
 #: ../vector/v.net.iso/main.c:123
 msgid "Costs for isolines"
@@ -37639,7 +40473,8 @@
 #: ../vector/v.net.iso/main.c:172
 msgid "Not enough costs, everything reachable falls to first band"
-msgstr "Kosten sind nicht hoch genug. Alles in Reichweit fällt in das erste Band."
+msgstr ""
+"Kosten sind nicht hoch genug. Alles in Reichweit fällt in das erste Band."
 #: ../vector/v.net.iso/main.c:206
 msgid "Centre at closed node (costs = -1) ignored"
@@ -37652,7 +40487,8 @@
 #: ../vector/v.net.iso/main.c:227
 msgid "Not enough centres for selected nlayer. Nothing will be allocated."
+msgstr ""
 #: ../vector/v.net.iso/main.c:247
 #, c-format
@@ -37661,7 +40497,9 @@
 #: ../vector/v.what.rast/main.c:78
 msgid "Uploads raster values at positions of vector points to the table."
-msgstr "Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die Attributtabelle."
+msgstr ""
+"Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die "
+"Attributtabelle."
 #: ../vector/v.what.rast/main.c:92
 msgid "Name of existing raster map to be queried"
@@ -37682,7 +40520,9 @@
 #: ../vector/v.what.rast/main.c:176
 msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr "Rastertyp ist Fließkomma und der Spaltentyp ist Integer. Etwas Informationsgehalt der Daten geht verloren!!"
+msgstr ""
+"Rastertyp ist Fließkomma und der Spaltentyp ist Integer. Etwas "
+"Informationsgehalt der Daten geht verloren!!"
 #: ../vector/v.what.rast/main.c:535 ../vector/v.what.rast/main.c:575
 #, fuzzy, c-format
@@ -37769,8 +40609,11 @@
 msgstr "%d 'insert' Fehler."
 #: ../vector/v.in.db/main.c:57
-msgid "Creates new vector (points) map from database table containing coordinates."
-msgstr "Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die Koordinaten beinhaltet."
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+"Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die "
+"Koordinaten beinhaltet."
 #: ../vector/v.in.db/main.c:61
 msgid "Input table name"
@@ -37814,8 +40657,11 @@
 #: ../vector/v.in.db/main.c:142
 #, c-format
-msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
-msgstr "Ausgabe-Vektorkarte, Tabelle <%s> (Treiber: <%s>, Datenbank: <%s>) existiert bereits."
+msgid ""
+"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgstr ""
+"Ausgabe-Vektorkarte, Tabelle <%s> (Treiber: <%s>, Datenbank: <%s>) existiert "
+"bereits."
 #: ../vector/v.in.db/main.c:155 ../vector/v.db.connect/main.c:294
 msgid "Data type of key column must be integer"
@@ -37824,11 +40670,15 @@
 #: ../vector/v.in.db/main.c:159
 #, fuzzy, c-format
 msgid "Option <%s> must be specified when -%c flag is given"
+msgstr ""
 #: ../vector/v.in.db/main.c:164
 #, c-format
-msgid "Unable to define key column. This operation is not supported by <%s> driver. You need to define <%s> option."
+msgid ""
+"Unable to define key column. This operation is not supported by <%s> driver. "
+"You need to define <%s> option."
 msgstr ""
 #: ../vector/v.in.db/main.c:208
@@ -37869,8 +40719,11 @@
 msgstr "Kann die Tabelle <%s> nicht kopieren."
 #: ../vector/v.select/main.c:51
-msgid "Selects features from vector map (A) by features from other vector map (B)."
-msgstr "Selektiert Objekte der Vektorkarte (A) durch Objekte einer anderen Vektorkarte (B)."
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
+msgstr ""
+"Selektiert Objekte der Vektorkarte (A) durch Objekte einer anderen "
+"Vektorkarte (B)."
 #: ../vector/v.select/main.c:93
 msgid "Operator can only be 'overlap'"
@@ -37913,8 +40766,14 @@
 msgstr "Operator bestimmt das erforderte Verhältnis zwischen den Objekten"
 #: ../vector/v.select/args.c:49
-msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
-msgstr "Ein Objekt wird in die Ausgabe geschrieben, wenn das Ergebnis der Operation 'ainput operator binput' wahr ist. Ein Eingabe-Objekt wird als wahr aufgefasst, wenn die Kategorie des gegebenen Layers definiert ist."
+msgid ""
+"A feature is written to output if the result of operation 'ainput operator "
+"binput' is true. An input feature is considered to be true, if category of "
+msgstr ""
+"Ein Objekt wird in die Ausgabe geschrieben, wenn das Ergebnis der Operation "
+"'ainput operator binput' wahr ist. Ein Eingabe-Objekt wird als wahr "
+"aufgefasst, wenn die Kategorie des gegebenen Layers definiert ist."
 #: ../vector/v.select/args.c:57 ../vector/v.select/args.c:73
 #, fuzzy
@@ -37954,7 +40813,9 @@
 msgstr ""
 #: ../vector/v.select/args.c:82
-msgid "feature A is spatially related to feature B (using GEOS, requires 'relate' option)"
+msgid ""
+"feature A is spatially related to feature B (using GEOS, requires 'relate' "
+"option)"
 msgstr ""
 #: ../vector/v.select/args.c:92
@@ -37986,8 +40847,12 @@
 msgstr "Vektor, Netzwerk"
 #: ../vector/v.lrs/v.lrs.segment/main.c:74
-msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
-msgstr "Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des Linearenreferenzsystems und Positionen von stdin oder einer Datei."
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+"Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des "
+"Linearenreferenzsystems und Positionen von stdin oder einer Datei."
 #: ../vector/v.lrs/v.lrs.segment/main.c:78
 #: ../vector/v.lrs/v.lrs.create/main.c:128
@@ -38029,7 +40894,9 @@
 #: ../vector/v.lrs/v.lrs.segment/main.c:113
 msgid "Name of file containing segment rules. If not given, read from stdin."
-msgstr "Name der Datei, die Segment-Regeln enthält. Falls nicht angegeben, wird von stdin gelesen."
+msgstr ""
+"Name der Datei, die Segment-Regeln enthält. Falls nicht angegeben, wird von "
+"stdin gelesen."
 #: ../vector/v.lrs/v.lrs.segment/main.c:152
 #: ../vector/v.lrs/v.lrs.create/main.c:305
@@ -38066,7 +40933,8 @@
 "Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
 "%s"
 msgstr ""
-"Kann den Punkt auf der Linie nicht bekommen: cat = [%d] Distanz = [%f] (Linienlänge = %f)\n"
+"Kann den Punkt auf der Linie nicht bekommen: cat = [%d] Distanz = [%f] "
+"(Linienlänge = %f)\n"
 "%s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:249
@@ -38093,7 +40961,8 @@
 "Requested offset for the 1. point not found, using nearest found:\n"
 "  %s"
 msgstr ""
-"Angeforderten Versatz für den 1. Punkt nicht gefunden, verwende den Nächsten:\n"
+"Angeforderten Versatz für den 1. Punkt nicht gefunden, verwende den "
+"Nächsten:\n"
 "  %s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:269
@@ -38111,7 +40980,8 @@
 "Requested offset for the 2. point not found, using nearest found:\n"
 "  %s"
 msgstr ""
-"Angeforderten Versatz für den 2. Punkt nicht gefunden, verwende den Nächsten:\n"
+"Angeforderten Versatz für den 2. Punkt nicht gefunden, verwende den "
+"Nächsten:\n"
 "  %s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:278
@@ -38138,7 +41008,8 @@
 "Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
 "%s"
 msgstr ""
-"Kann das Linien-Segment nicht erzeugen: cat = %d : %f - %f (Länge der Linie = %f)\n"
+"Kann das Linien-Segment nicht erzeugen: cat = %d : %f - %f (Länge der Linie "
+"= %f)\n"
 "%s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:352
@@ -38169,7 +41040,8 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:133
 msgid "Output vector map where oriented lines are written"
-msgstr "Ausgabe-Vektorkarte in die die ausgerichteten Linien geschrieben werden."
+msgstr ""
+"Ausgabe-Vektorkarte in die die ausgerichteten Linien geschrieben werden."
 #: ../vector/v.lrs/v.lrs.create/main.c:138
 msgid "Output vector map of errors"
@@ -38194,19 +41066,28 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:173
 msgid "Column containing milepost position for the beginning of next segment"
-msgstr "Spalte mit den Meilensteinpositionen, die den Beginn des nächsten Segmentes kennzeichnen."
+msgstr ""
+"Spalte mit den Meilensteinpositionen, die den Beginn des nächsten Segmentes "
+"kennzeichnen."
 #: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid "Column containing offset from milepost for the beginning of next segment"
-msgstr "Spalte mit dem Versatz vom Meilenstein, um den Beginn des nächsten Segmentes zu kennzeichnen."
+msgid ""
+"Column containing offset from milepost for the beginning of next segment"
+msgstr ""
+"Spalte mit dem Versatz vom Meilenstein, um den Beginn des nächsten Segmentes "
+"zu kennzeichnen."
 #: ../vector/v.lrs/v.lrs.create/main.c:191
 msgid "Column containing milepost position for the end of previous segment"
-msgstr "Spalte mit den Meilensteinpositionen, die das Ende des vorherigen Segmentes kennzeichnen."
+msgstr ""
+"Spalte mit den Meilensteinpositionen, die das Ende des vorherigen Segmentes "
+"kennzeichnen."
 #: ../vector/v.lrs/v.lrs.create/main.c:200
 msgid "Column containing offset from milepost for the end of previous segment"
-msgstr "Spalte mit dem Versatz vom Meilenstein, um das Ende des vorherigen Segmentes zu kennzeichnen."
+msgstr ""
+"Spalte mit dem Versatz vom Meilenstein, um das Ende des vorherigen Segmentes "
+"zu kennzeichnen."
 #: ../vector/v.lrs/v.lrs.create/main.c:223
 msgid "Name of table where the reference system will be written"
@@ -38265,7 +41146,8 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:479
 #, c-format
 msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
-msgstr "Meilenstein (Start) %f+%f verwendet als %f+%f (ändere MP nach Integer)."
+msgstr ""
+"Meilenstein (Start) %f+%f verwendet als %f+%f (ändere MP nach Integer)."
 #: ../vector/v.lrs/v.lrs.create/main.c:501
 #, c-format
@@ -38299,17 +41181,21 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:750
 #, c-format
 msgid "Distance along line identical for points' cats [%d], [%d]"
-msgstr "Distanz entlang der Linie ist identisch für die Punkte der cats [%d], [%d]."
+msgstr ""
+"Distanz entlang der Linie ist identisch für die Punkte der cats [%d], [%d]."
 #: ../vector/v.lrs/v.lrs.create/main.c:764
 #, c-format
 msgid "Not enough points (%d) attached to the line (cat %d), line skip."
-msgstr "Nicht genügend Punkte (%d) der Linie (cat %d) zugeordnet, überspringe die Linie."
+msgstr ""
+"Nicht genügend Punkte (%d) der Linie (cat %d) zugeordnet, überspringe die "
+"Linie."
 #: ../vector/v.lrs/v.lrs.create/main.c:769
 #, c-format
 msgid "Unable to guess direction for the line (cat %d), line skip."
-msgstr "Kann die Richtung der Linie (cat %d) nicht erraten, überspringe die Linie."
+msgstr ""
+"Kann die Richtung der Linie (cat %d) nicht erraten, überspringe die Linie."
 #: ../vector/v.lrs/v.lrs.create/main.c:773
 #, c-format
@@ -38330,8 +41216,12 @@
 msgstr "Erstelle Topologie für Fehlerkarte (err)..."
 #: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
-msgstr "Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+"Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte "
+"einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
 #: ../vector/v.lrs/v.lrs.where/main.c:70
 msgid "Input vector map containing points"
@@ -38364,7 +41254,8 @@
 #: ../vector/v.lrs/v.lrs.label/main.c:105
 #, fuzzy
 msgid "Creates stationing from input lines, and linear reference system."
-msgstr "Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
+msgstr ""
+"Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
 #: ../vector/v.lrs/v.lrs.label/main.c:113
 msgid "Output vector map where stationing will be written"
@@ -38427,16 +41318,23 @@
 msgstr "Attribute"
 #: ../vector/v.reclass/main.c:71
-msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
-msgstr "Ändert die Kategorien einer existierenden Vektorkarte entsprechend den Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+"Ändert die Kategorien einer existierenden Vektorkarte entsprechend den "
+"Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
 #: ../vector/v.reclass/main.c:88
 msgid "The name of the column whose values are to be used as new categories"
-msgstr "Name der Spalte, deren Werte als neue Kategorien verwendet werden sollen."
+msgstr ""
+"Name der Spalte, deren Werte als neue Kategorien verwendet werden sollen."
 #: ../vector/v.reclass/main.c:89
 msgid "The source for the new key column must be type integer or string"
-msgstr "Die Quelle für die neue Schlüsselspalte muss vom Typ integer oder string sein."
+msgstr ""
+"Die Quelle für die neue Schlüsselspalte muss vom Typ integer oder string "
+"sein."
 #: ../vector/v.reclass/main.c:94
 msgid "Full path to the reclass rule file"
@@ -38522,7 +41420,8 @@
 #: ../vector/v.to.rast/do_lines.c:133
 #, c-format
 msgid "%d lines with varying height were not written to raster"
-msgstr "%d Linien mit wechselnden Höhen wurden nicht in das Raster geschrieben."
+msgstr ""
+"%d Linien mit wechselnden Höhen wurden nicht in das Raster geschrieben."
 #: ../vector/v.to.rast/main.c:47
 #, fuzzy
@@ -38558,7 +41457,8 @@
 #: ../vector/v.to.rast/main.c:87
 msgid "Name of column for 'attr' parameter (data type must be numeric)"
-msgstr "Name der Spalte für den Parameter 'attr' (Datentyp muss numerisch sein)."
+msgstr ""
+"Name der Spalte für den Parameter 'attr' (Datentyp muss numerisch sein)."
 #: ../vector/v.to.rast/main.c:93
 msgid "Name of color definition column (with RRR:GGG:BBB entries)"
@@ -38578,7 +41478,8 @@
 msgstr "Seitenlänge (Standard: %d Zeilen)."
 #: ../vector/v.to.rast/main.c:121
-msgid "All cells touched by the line will be set, not only those on the render path"
+msgid ""
+"All cells touched by the line will be set, not only those on the render path"
 msgstr ""
 #: ../vector/v.to.rast/main.c:134
@@ -38587,15 +41488,21 @@
 #: ../vector/v.to.rast/main.c:139
 msgid "Column parameter cannot be combined with use of category values option"
-msgstr "Der Parameter Spalte kann nicht mit der Benutzung des Kategoriewertes kombiniert werden."
+msgstr ""
+"Der Parameter Spalte kann nicht mit der Benutzung des Kategoriewertes "
+"kombiniert werden."
 #: ../vector/v.to.rast/main.c:144
 msgid "Column parameter cannot be combined with use of value option"
-msgstr "Der Parameter Spalte kann nicht mit der Benutzung der Wert-Option kombiniert werden."
+msgstr ""
+"Der Parameter Spalte kann nicht mit der Benutzung der Wert-Option kombiniert "
+"werden."
 #: ../vector/v.to.rast/main.c:149
 msgid "Column parameter cannot be combined with use of z coordinate"
-msgstr "Der Parameter Spalte kann nicht mit der Benutzung von Z-Koordinaten kombiniert werden."
+msgstr ""
+"Der Parameter Spalte kann nicht mit der Benutzung von Z-Koordinaten "
 #: ../vector/v.to.rast/main.c:155
 #, c-format
@@ -38638,12 +41545,14 @@
 #: ../vector/v.to.rast/vect2rast.c:162
 #, c-format
 msgid "Problem processing areas from vector map <%s>, continuing..."
-msgstr "Probleme beim Verarbeiten der Flächen der Vektorkarte <%s>, mache weiter..."
+msgstr ""
+"Probleme beim Verarbeiten der Flächen der Vektorkarte <%s>, mache weiter..."
 #: ../vector/v.to.rast/vect2rast.c:174
 #, c-format
 msgid "Problem processing lines from vector map <%s>, continuing..."
-msgstr "Probleme beim Verarbeiten der Linien der Vektorkarte <%s>, mache weiter..."
+msgstr ""
+"Probleme beim Verarbeiten der Linien der Vektorkarte <%s>, mache weiter..."
 #: ../vector/v.to.rast/vect2rast.c:199
 msgid "Creating support files for raster map..."
@@ -38694,7 +41603,8 @@
 #: ../vector/v.to.rast/support.c:175
 #, c-format
 msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr "Fehler in der Spalte mit den Farbwerten (%s),mit cat %d: Farbstring [%s]."
+msgstr ""
+"Fehler in der Spalte mit den Farbwerten (%s),mit cat %d: Farbstring [%s]."
 #: ../vector/v.to.rast/support.c:178
 msgid "Color set to [200:200:200]"
@@ -38707,7 +41617,9 @@
 #: ../vector/v.to.rast/support.c:272
 msgid "Label column was not specified, no labels will be written"
-msgstr "Spalte mit Beschriftungen wurde nicht angegeben. Es werden keine Beschriftungen ausgegeben."
+msgstr ""
+"Spalte mit Beschriftungen wurde nicht angegeben. Es werden keine "
+"Beschriftungen ausgegeben."
 #: ../vector/v.to.rast/support.c:351 ../vector/v.to.rast/support.c:496
 #, c-format
@@ -38716,12 +41628,15 @@
 #: ../vector/v.db.connect/main.c:56
 msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr "Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer Attributtabelle."
+msgstr ""
+"Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer "
+"Attributtabelle."
 #: ../vector/v.db.connect/main.c:78
 #, fuzzy
 msgid "Format: layer number[/layer name]"
-msgstr "Format: Layer[/Name des Layers] Tabelle Schlüsselspalte Datenbanktreiber"
+msgstr ""
+"Format: Layer[/Name des Layers] Tabelle Schlüsselspalte Datenbanktreiber"
 #: ../vector/v.db.connect/main.c:82
 msgid "Field separator for shell script style output"
@@ -38734,15 +41649,19 @@
 #: ../vector/v.db.connect/main.c:92
 #, fuzzy
 msgid "Print all map connection parameters in shell script style and exit"
-msgstr "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
+msgstr ""
+"Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
 #: ../vector/v.db.connect/main.c:94
 msgid "Format: layer[/layer name] table key database driver"
+msgstr ""
 #: ../vector/v.db.connect/main.c:100
 msgid "Print types/names of table columns for specified layer and exit"
-msgstr "Gebe die Typen/Namen der Tabellenspalten der angegebenen Layer aus und beendet sich. "
+msgstr ""
+"Gebe die Typen/Namen der Tabellenspalten der angegebenen Layer aus und "
+"beendet sich. "
 #: ../vector/v.db.connect/main.c:107
 msgid "Overwrite connection parameter for certain layer"
@@ -38768,18 +41687,26 @@
 #: ../vector/v.db.connect/main.c:196
 #, fuzzy, c-format
-msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr "Layer <%d> Tabelle <%s> in der Datenbank <%s> mit dem Treiber <%s> und der Schlüsselspalte <%s>\n"
+msgid ""
+"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr ""
+"Layer <%d> Tabelle <%s> in der Datenbank <%s> mit dem Treiber <%s> und der "
+"Schlüsselspalte <%s>\n"
 #: ../vector/v.db.connect/main.c:202
 #, c-format
-msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid ""
+"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr ""
 #: ../vector/v.db.connect/main.c:265
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
-msgstr "Verwenden Sie -o, um den existierenden Link für den Layer <%d> zu überschreiben."
+msgstr ""
+"Verwenden Sie -o, um den existierenden Link für den Layer <%d> zu "
+"überschreiben."
 #: ../vector/v.db.connect/main.c:273 ../vector/v.db.connect/main.c:313
 #, c-format
@@ -38788,12 +41715,20 @@
 #: ../vector/v.db.connect/main.c:301 ../vector/v.db.connect/main.c:319
 #, c-format
-msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
-msgstr "Die Tabelle <%s> ist jetzt Teil der Vektorkarte <%s> und kann mit GRASS Modulen gelöscht und überschrieben werden."
+msgid ""
+"The table <%s> is now part of vector map <%s> and may be deleted or "
+"overwritten by GRASS modules"
+msgstr ""
+"Die Tabelle <%s> ist jetzt Teil der Vektorkarte <%s> und kann mit GRASS "
+"Modulen gelöscht und überschrieben werden."
 #: ../vector/v.db.connect/main.c:350
-msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
-msgstr "Um eine neue Verbindung zu definieren müssen Sie die folgenden Parameter angeben: Treiber, Datenbank, Tabelle [, Schlüsselspalte [, Layer]]."
+msgid ""
+"For defining a new connection you have to specify these parameters: driver, "
+"database, table [, key [, layer]]"
+msgstr ""
+"Um eine neue Verbindung zu definieren müssen Sie die folgenden Parameter "
+"angeben: Treiber, Datenbank, Tabelle [, Schlüsselspalte [, Layer]]."
 #: ../vector/v.parallel/main.c:51
 msgid "Creates parallel line to input vector lines."
@@ -38896,12 +41831,16 @@
 #: ../vector/v.out.postgis/table.c:50
 #, c-format
-msgid "Invalid FID column (%s). FID column must be integer. Please specify different FID column by 'options=\"FID=<name>\"'."
+msgid ""
+"Invalid FID column (%s). FID column must be integer. Please specify "
+"different FID column by 'options=\"FID=<name>\"'."
 msgstr ""
 #: ../vector/v.out.postgis/table.c:57
 #, c-format
-msgid "Column (%s) already exists in the table. Please specify different geometry column by 'options=\"GEOMETRY_NAME=<name>\"'."
+msgid ""
+"Column (%s) already exists in the table. Please specify different geometry "
+"column by 'options=\"GEOMETRY_NAME=<name>\"'."
 msgstr ""
 #: ../vector/v.out.postgis/main.c:46
@@ -38990,15 +41929,21 @@
 #: ../vector/v.out.postgis/args.c:37
 #, fuzzy
 msgid "If not specified, input name is used"
-msgstr "Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
+msgstr ""
+"Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
 #: ../vector/v.out.postgis/args.c:44
 #, fuzzy
-msgid "Name for output vector map defined as a link to the PostGIS feature table"
+msgid ""
+"Name for output vector map defined as a link to the PostGIS feature table"
+msgstr ""
+"einem OGR-Layer."
 #: ../vector/v.out.postgis/args.c:46
-msgid "If not specified, the vector link is not created. The link can be also manually created by 'v.external' module."
+msgid ""
+"If not specified, the vector link is not created. The link can be also "
+"manually created by 'v.external' module."
 msgstr ""
 #: ../vector/v.out.postgis/args.c:53
@@ -39045,7 +41990,9 @@
 #: ../vector/v.in.ogr/main.c:147
 msgid "OGR layer name. If not given, all available layers are imported"
-msgstr "Name des OGR-Layers. Wenn nicht spezifiziert, werden alle verfügbaren Layer importiert."
+msgstr ""
+"Name des OGR-Layers. Wenn nicht spezifiziert, werden alle verfügbaren Layer "
+"importiert."
 #: ../vector/v.in.ogr/main.c:149
 msgid ""
@@ -39063,7 +42010,8 @@
 #: ../vector/v.in.ogr/main.c:179
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr "Kleinere Flächen und Inseln werden ignoriert. Sollte größer sein als snap^2."
+msgstr ""
+"Kleinere Flächen und Inseln werden ignoriert. Sollte größer sein als snap^2."
 #: ../vector/v.in.ogr/main.c:185
 msgid "Optionally change default input type"
@@ -39094,8 +42042,12 @@
 msgstr "'-1' für kein Fangen"
 #: ../vector/v.in.ogr/main.c:217
-msgid "List of column names to be used instead of original names, first is used for category column"
-msgstr "Zeige sie Spaltennamen die anstatt der Originalnamen verwendet werden. Der Erste entspricht der Kategoriespalte."
+msgid ""
+"List of column names to be used instead of original names, first is used for "
+"category column"
+msgstr ""
+"Zeige sie Spaltennamen die anstatt der Originalnamen verwendet werden. Der "
+"Erste entspricht der Kategoriespalte."
 #: ../vector/v.in.ogr/main.c:226
 #, fuzzy
@@ -39130,7 +42082,9 @@
 msgstr "Ändere Spaltenname zu Kleinbuchstaben"
 #: ../vector/v.in.ogr/main.c:284
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
+msgid ""
+"import the vector data."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:303
@@ -39170,7 +42124,8 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:558
-msgid "The 'spatial' parameters do not overlap with OGR input. Nothing to import."
+msgid ""
+"The 'spatial' parameters do not overlap with OGR input. Nothing to import."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:592
@@ -39200,17 +42155,25 @@
 #: ../vector/v.in.ogr/main.c:917
 #, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr "Schreibe Spalte <%s> mit einer festen Länge von %d Zeichen (Es könnte etwas abgeschnitten worden sein). "
+msgstr ""
+"Schreibe Spalte <%s> mit einer festen Länge von %d Zeichen (Es könnte etwas "
+"abgeschnitten worden sein). "
 #: ../vector/v.in.ogr/main.c:940
 #, c-format
-msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
-msgstr "Breite für die Spalte %s wird auf 255 gesetzt (wurde nicht von OGR bestimmt). Einige Texte können abgeschnitten worden sein!"
+msgid ""
+"Width for column %s set to 255 (was not specified by OGR), some strings may "
+"be truncated!"
+msgstr ""
+"Breite für die Spalte %s wird auf 255 gesetzt (wurde nicht von OGR "
+"bestimmt). Einige Texte können abgeschnitten worden sein!"
 #: ../vector/v.in.ogr/main.c:952
 #, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr "Schreibe Spalte %s mit einer festen Länge von %d Zeichen (Es könnte etwas abgeschnitten worden sein). "
+msgstr ""
+"Schreibe Spalte %s mit einer festen Länge von %d Zeichen (Es könnte etwas "
 #: ../vector/v.in.ogr/main.c:956
 #, c-format
@@ -39259,8 +42222,15 @@
 #: ../vector/v.in.ogr/main.c:1305
 #, c-format
-msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
-msgstr "%d Flächen repräsentieren mehrere Objekte, da sich die Polygone in dem Eingabedatensatz überlappen. Solche Flächen sind mit mehr als einer Zeile in der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist als Kategoriewert im Layer %d abgelegt."
+msgid ""
+"%d areas represent more (overlapping) features, because polygons overlap in "
+"input layer(s). Such areas are linked to more than 1 row in attribute table. "
+"The number of features for those areas is stored as category in layer %d"
+msgstr ""
+"%d Flächen repräsentieren mehrere Objekte, da sich die Polygone in dem "
+"Eingabedatensatz überlappen. Solche Flächen sind mit mehr als einer Zeile in "
+"der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist "
+"als Kategoriewert im Layer %d abgelegt."
 #: ../vector/v.in.ogr/main.c:1315
 #, c-format
@@ -39309,12 +42279,14 @@
 #: ../vector/v.in.ogr/main.c:1407
 #, c-format
 msgid "Try to import again, snapping with at least %g: 'snap=%g'"
-msgstr "Versuchen Sie den Import nochmals, Fangtoleranz mindestens %g: 'snap=%g'"
+msgstr ""
+"Versuchen Sie den Import nochmals, Fangtoleranz mindestens %g: 'snap=%g'"
 #: ../vector/v.in.ogr/main.c:1411
 #, fuzzy, c-format
 msgid "Try to import again, snapping with %g: 'snap=%g'"
+msgstr ""
 #: ../vector/v.in.ogr/main.c:1423
 #, fuzzy, c-format
@@ -39323,8 +42295,12 @@
 #: ../vector/v.in.ogr/main.c:1462
 #, fuzzy
-msgid "Input data contains 3D features. Created vector is 2D only, disable -2 flag to import 3D vector."
-msgstr "Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur 2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
+msgid ""
+"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
+"to import 3D vector."
+msgstr ""
+"Eingabekarte enthält 3D-Feature. Erstellte Vektorkarte ist allerdings nur "
+"2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
 #: ../vector/v.in.ogr/geom.c:195 ../vector/v.in.ogr/geom.c:216
 #, fuzzy
@@ -39410,8 +42386,14 @@
 #: ../vector/v.perturb/main.c:89
 #, fuzzy
-msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
-msgstr "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
+msgid ""
+"If the distribution is uniform, only one parameter, the maximum, is needed. "
+"For a normal distribution, two parameters, the mean and standard deviation, "
+"are required."
+msgstr ""
+"Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird "
+"nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind "
+"zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
 #: ../vector/v.perturb/main.c:99
 msgid "Minimum deviation in map units"
@@ -39447,8 +42429,12 @@
 msgstr "Berechne Zentralitätsmaße..."
 #: ../vector/v.net.centrality/main.c:100
-msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
-msgstr "Berechnet Degree, Centrality, Betweeness, Closeness and Eigenvektor centrality Werte im Netzwerk."
+msgid ""
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
+msgstr ""
+"Berechnet Degree, Centrality, Betweeness, Closeness and Eigenvektor "
+"centrality Werte im Netzwerk."
 #: ../vector/v.net.centrality/main.c:148
 msgid "Name of degree centrality column"
@@ -39473,7 +42459,8 @@
 #: ../vector/v.net.centrality/main.c:175
 msgid "Maximum number of iterations to compute eigenvector centrality"
-msgstr "Maximale Zahl der Iterationen zur Berechnung der Eigenvektor-Zentralität"
+msgstr ""
+"Maximale Zahl der Iterationen zur Berechnung der Eigenvektor-Zentralität"
 #: ../vector/v.net.centrality/main.c:183
 msgid "Cummulative error tolerance for eigenvector centrality"
@@ -39605,15 +42592,20 @@
 #: ../vector/v.generalize/main.c:157
 msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
-msgstr "Prozentsatz der Punkte im Ergebnis des 'douglas_reduction' Algorithmus."
+msgstr ""
+"Prozentsatz der Punkte im Ergebnis des 'douglas_reduction' Algorithmus."
 #: ../vector/v.generalize/main.c:166
 msgid "Slide of computed point toward the original point"
-msgstr "Verschieben von berechneten Punkten in Richtung seiner ursprünglichen Position."
+msgstr ""
+"Verschieben von berechneten Punkten in Richtung seiner ursprünglichen "
+"Position."
 #: ../vector/v.generalize/main.c:175
 msgid "Minimum angle between two consecutive segments in Hermite method"
-msgstr "Minimaler Winkel zwischen zwei aufeinanderfolgenden Segmenten in der Hermite-Methode."
+msgstr ""
+"Minimaler Winkel zwischen zwei aufeinanderfolgenden Segmenten in der Hermite-"
+"Methode."
 #: ../vector/v.generalize/main.c:183
 msgid "Degree threshold in network generalization"
@@ -39621,7 +42613,8 @@
 #: ../vector/v.generalize/main.c:192
 msgid "Closeness threshold in network generalization"
-msgstr "Geschlossenheits(closeness)-Schwellenwert für die Netzwerk Generalisierung."
+msgstr ""
+"Geschlossenheits(closeness)-Schwellenwert für die Netzwerk Generalisierung."
 #: ../vector/v.generalize/main.c:200
 msgid "Betweeness threshold in network generalization"
@@ -39690,13 +42683,17 @@
 #: ../vector/v.generalize/main.c:555
 #, c-format
-msgid "%d boundaries were not modified because modification would damage topology"
-msgstr "%d Grenzen wurden nicht geändert, weil Änderungen die Topologie beschädigen würden."
+msgid ""
+"%d boundaries were not modified because modification would damage topology"
+msgstr ""
+"%d Grenzen wurden nicht geändert, weil Änderungen die Topologie beschädigen "
+"würden."
 #: ../vector/v.generalize/main.c:558
 #, c-format
 msgid "%d lines/boundaries were not modified due to over-simplification"
-msgstr "%d Linien/Grenzen wurden nicht geändert wegen übertriebener Vereinfachung."
+msgstr ""
+"%d Linien/Grenzen wurden nicht geändert wegen übertriebener Vereinfachung."
 #: ../vector/v.generalize/main.c:573
 #, fuzzy, c-format
@@ -39733,12 +42730,17 @@
 #: ../vector/v.lidar.correction/main.c:71
-msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
-msgstr "Korrektur der v.lidar.growing Ausgabe. Das ist der letzte von 3 Algorithmen um LIDAR zu filtern."
+msgid ""
+"Correction of the v.lidar.growing output. It is the last of the three "
+"algorithms for LIDAR filtering."
+msgstr ""
+"Korrektur der v.lidar.growing Ausgabe. Das ist der letzte von 3 Algorithmen "
+"um LIDAR zu filtern."
 #: ../vector/v.lidar.correction/main.c:81
 msgid "Input observation vector map name (v.lidar.growing output)"
-msgstr "Eingabeüberwachung des Vektorkarten-Namens (Ausgabe von v.lidar.growing)"
+msgstr ""
+"Eingabeüberwachung des Vektorkarten-Namens (Ausgabe von v.lidar.growing)"
 #: ../vector/v.lidar.correction/main.c:84
 msgid "Output classified vector map name"
@@ -39834,7 +42836,9 @@
 msgstr "Maximale z-Höhe  (benötigt den Schalter '-z' oder Spaltenname)."
 #: ../vector/v.random/main.c:122
-msgid "The seed to initialize the random generator. If not set the process id is used."
+msgid ""
+"The seed to initialize the random generator. If not set the process id is "
+"used."
 msgstr ""
 #: ../vector/v.random/main.c:125
@@ -39870,8 +42874,12 @@
 msgstr "Tabelle sollte nur zwei Spalten haben."
 #: ../vector/v.random/main.c:223
-msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
-msgstr "Sie haben nicht unterstützte Spaltentypen erzeugt. Dieses Modul unterstützt nur die Spaltentypen INTEGER und DOUBLE PRECISION."
+msgid ""
+"You have created unsupported column type. This module supports only INTEGER "
+"and DOUBLE PRECISION column types."
+msgstr ""
+"Sie haben nicht unterstützte Spaltentypen erzeugt. Dieses Modul unterstützt "
+"nur die Spaltentypen INTEGER und DOUBLE PRECISION."
 #: ../vector/v.random/main.c:259
 msgid "Generating points..."
@@ -39884,8 +42892,14 @@
 #: ../vector/v.neighbors/main.c:55
 #, fuzzy
-msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
-msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
+msgid ""
+"Makes each cell value a function of the attribute values assigned to the "
+"vector points or centroids around it, and stores new cell values in an "
+"output raster map."
+msgstr ""
+"Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
+"Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue "
+"Zellenwerte in einer Ausgabe-Rasterkarte."
 #: ../vector/v.neighbors/main.c:77
 #, fuzzy
@@ -39931,262 +42945,275 @@
 msgstr "Erkennung von Ausreißern"
 #, fuzzy
-msgid "Loading input maps..."
-msgstr "Lese Eingaben..."
+#~ msgid "Loading input maps..."
+#~ msgstr "Lese Eingaben..."
 #, fuzzy
-msgid "Could not allocate memory"
-msgstr "Kann nicht mehr Speicher reservieren."
+#~ msgid "Could not allocate memory"
+#~ msgstr "Kann nicht mehr Speicher reservieren."
 #, fuzzy
-msgid "dseg_open(): could not write segment file"
-msgstr "Kann die Segementdatei für <%s>nicht schreiben."
+#~ msgid "dseg_open(): could not write segment file"
+#~ msgstr "Kann die Segementdatei für <%s>nicht schreiben."
 #, fuzzy
-msgid "dseg_open(): unable to re-open segment file"
-msgstr "Öffnen der temporären Datei nicht möglich."
+#~ msgid "dseg_open(): unable to re-open segment file"
+#~ msgstr "Öffnen der temporären Datei nicht möglich."
 #, fuzzy
-msgid "dseg_open(): could not read segment file"
-msgstr "Kann die Segmentdatei %s nicht erzeugen."
+#~ msgid "dseg_open(): could not read segment file"
+#~ msgstr "Kann die Segmentdatei %s nicht erzeugen."
 #, fuzzy
-msgid "dseg_open(): out of memory"
-msgstr "G_malloc: Kein Speicher mehr da."
+#~ msgid "dseg_open(): out of memory"
+#~ msgstr "G_malloc: Kein Speicher mehr da."
 #, fuzzy
-msgid "dseg_get(): could not read segment file"
-msgstr "Konnte die Ausgabedate <%s> nicht öffnen."
+#~ msgid "dseg_get(): could not read segment file"
+#~ msgstr "Konnte die Ausgabedate <%s> nicht öffnen."
 #, fuzzy
-msgid "cseg_open(): unable to create segment file"
+#~ msgid "cseg_open(): unable to create segment file"
 #, fuzzy
-msgid "cseg_open(): could not write segment file"
+#~ msgid "cseg_open(): could not write segment file"
 #, fuzzy
-msgid "cseg_open(): unable to re-open segment file"
+#~ msgid "cseg_open(): unable to re-open segment file"
 #, fuzzy
-msgid "cseg_open(): could not read segment file"
+#~ msgid "cseg_open(): could not read segment file"
 #, fuzzy
-msgid "cseg_open(): out of memory"
-msgstr "Speicher ist zu Ende (Out-of-memory)."
+#~ msgid "cseg_open(): out of memory"
+#~ msgstr "Speicher ist zu Ende (Out-of-memory)."
 #, fuzzy
-msgid "cseg_get(): could not read segment file"
+#~ msgid "cseg_get(): could not read segment file"
 #, fuzzy
-msgid "Sorry, you must choose at least one output map."
-msgstr "Entschuldigung, Sie müssen eine Ausgabe-Karte wählen."
+#~ msgid "Sorry, you must choose at least one output map."
+#~ msgstr "Entschuldigung, Sie müssen eine Ausgabe-Karte wählen."
 #, fuzzy
-msgid "Could not open input map %s"
-msgstr "Konnte die Karte nicht schließen."
+#~ msgid "Could not open input map %s"
+#~ msgstr "Konnte die Karte nicht schließen."
 #, fuzzy
-msgid "Could not load input map(s)"
+#~ msgid "Could not load input map(s)"
 #, fuzzy
-msgid "Could not sort elevation map"
-msgstr "Kann die Rasterkarte mit Höheninformationen nicht öffnen."
+#~ msgid "Could not sort elevation map"
+#~ msgstr "Kann die Rasterkarte mit Höheninformationen nicht öffnen."
 #, fuzzy
-msgid "Could not thin streams"
+#~ msgid "Could not thin streams"
 #, fuzzy
-msgid "Could not write output maps"
+#~ msgid "Could not write output maps"
 #, fuzzy
-msgid "Write vector attribute table"
-msgstr "Keine Attributtabelle erzeugen."
+#~ msgid "Write vector attribute table"
+#~ msgstr "Keine Attributtabelle erzeugen."
 #, fuzzy
-msgid "Writing raster %s"
-msgstr "Schreibe Rasterkarte <%s>."
+#~ msgid "Writing raster %s"
+#~ msgstr "Schreibe Rasterkarte <%s>."
 #, fuzzy
-msgid "seg_open(): unable to create segment file"
+#~ msgid "seg_open(): unable to create segment file"
 #, fuzzy
-msgid "seg_open(): could not write segment file"
+#~ msgid "seg_open(): could not write segment file"
 #, fuzzy
-msgid "seg_open(): unable to re-open segment file"
+#~ msgid "seg_open(): unable to re-open segment file"
 #, fuzzy
-msgid "seg_open(): could not read segment file"
+#~ msgid "seg_open(): could not read segment file"
 #, fuzzy
-msgid "seg_open(): out of memory"
+#~ msgid "seg_open(): out of memory"
 #, fuzzy
-msgid "seg_get(): could not read segment file"
+#~ msgid "seg_get(): could not read segment file"
 #, fuzzy
-msgid "bseg_open(): unable to create segment file"
+#~ msgid "bseg_open(): unable to create segment file"
 #, fuzzy
-msgid "bseg_open(): could not write segment file"
+#~ msgid "bseg_open(): could not write segment file"
 #, fuzzy
-msgid "bseg_open(): unable to re-open segment file"
+#~ msgid "bseg_open(): unable to re-open segment file"
 #, fuzzy
-msgid "bseg_open(): could not read segment file"
+#~ msgid "bseg_open(): could not read segment file"
 #, fuzzy
-msgid "bseg_open(): out of memory"
+#~ msgid "bseg_open(): out of memory"
 #, fuzzy
-msgid "bseg_put(): could not write segment file"
+#~ msgid "bseg_put(): could not write segment file"
 #, fuzzy
-msgid "bseg_get(): could not read segment file"
+#~ msgid "bseg_get(): could not read segment file"
 #, fuzzy
-msgid "Name of input coordinate file ('-' to read from stdin)"
-msgstr "Eingabe-Koordinatendatei (auslassen für lesen von stdin)."
+#~ msgid "Name of input coordinate file ('-' to read from stdin)"
+#~ msgstr "Eingabe-Koordinatendatei (auslassen für lesen von stdin)."
 #, fuzzy
-msgid "Use z coordinates for approximation (3D vector maps only)"
-msgstr "Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden sollen."
+#~ msgid "Use z coordinates for approximation (3D vector maps only)"
+#~ msgstr ""
+#~ "Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden "
+#~ "sollen."
 #, fuzzy
-msgid "Vertex coordinates"
-msgstr "Eine oder mehrere Koordinaten"
+#~ msgid "Vertex coordinates"
+#~ msgstr "Eine oder mehrere Koordinaten"
 #, fuzzy
-msgid "Name of observed flow file"
-msgstr "Name der v5d Ausgabedatei."
+#~ msgid "Name of observed flow file"
+#~ msgstr "Name der v5d Ausgabedatei."
 #, fuzzy
-msgid "cell counts"
-msgstr "Gebe Zellenanzahlen aus."
+#~ msgid "cell counts"
+#~ msgstr "Gebe Zellenanzahlen aus."
 #, fuzzy
-msgid "Performs cubic or linear spline interpolation with Tykhonov regularization."
-msgstr "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
+#~ msgid ""
+#~ "Performs cubic or linear spline interpolation with Tykhonov "
+#~ "regularization."
+#~ msgstr ""
+#~ "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-"
+#~ "Regularisierung."
 #, fuzzy
-msgid "Linear interpolation"
-msgstr "Bilineare Interpolation."
+#~ msgid "Linear interpolation"
+#~ msgstr "Bilineare Interpolation."
 #, fuzzy
-msgid "Cubic interpolation"
-msgstr "Bikubische Interpolation."
+#~ msgid "Cubic interpolation"
+#~ msgstr "Bikubische Interpolation."
 #, fuzzy
-msgid "-' for standard input"
-msgstr "Wenn '-' angegeben wird von Standardeingabe gelesen."
+#~ msgid "-' for standard input"
+#~ msgstr "Wenn '-' angegeben wird von Standardeingabe gelesen."
 #, fuzzy
-msgid "Pass %d:"
-msgstr "Durchgang %d..."
+#~ msgid "Pass %d:"
+#~ msgstr "Durchgang %d..."
 #, fuzzy
-msgid "Name of color table (for use with -z flag)"
-msgstr "Art der Farbtabelle (für die Verwendung mit dem Schalter -z)."
+#~ msgid "Name of color table (for use with -z flag)"
+#~ msgstr "Art der Farbtabelle (für die Verwendung mit dem Schalter -z)."
 #, fuzzy
-msgid "Error in color definition (%s) - feature %d with category %d"
-msgstr "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d."
+#~ msgid "Error in color definition (%s) - feature %d with category %d"
+#~ msgstr ""
+#~ "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d."
 #, fuzzy
-msgid "Exporting %i faces..."
-msgstr "Exportiere %i Punkte/Linien..."
+#~ msgid "Exporting %i faces..."
+#~ msgstr "Exportiere %i Punkte/Linien..."
 #, fuzzy
-msgid "Copying vector features..."
-msgstr "Kopiere Vektorlinien..."
+#~ msgid "Copying vector features..."
+#~ msgstr "Kopiere Vektorlinien..."
 #, fuzzy
-msgid "Name of attribute column with values to approximate"
-msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält."
+#~ msgid "Name of attribute column with values to approximate"
+#~ msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält."
 #, fuzzy
-msgid "Input vector is not 3D, can not use z coordinates"
-msgstr "Eingabekarte mit den Trainingspunkten."
+#~ msgid "Input vector is not 3D, can not use z coordinates"
+#~ msgstr "Eingabekarte mit den Trainingspunkten."
 #, fuzzy
-msgid "Option '%s' with z values or '-%c' flag must be given"
-msgstr "Entweder distance= oder value= muss angegeben werden."
+#~ msgid "Option '%s' with z values or '-%c' flag must be given"
+#~ msgstr "Entweder distance= oder value= muss angegeben werden."
 #, fuzzy
-msgid "Subregion %d of %d..."
-msgstr "Unterregion %d von %d."
+#~ msgid "Subregion %d of %d..."
+#~ msgstr "Unterregion %d von %d."
 #, fuzzy
-msgid "Base name of the new created raster maps. This name will be extended with a numerical prefix"
-msgstr "Name der Ausgabe-Rasterkarte (Sättigung, saturation)."
+#~ msgid ""
+#~ "Base name of the new created raster maps. This name will be extended with "
+#~ "a numerical prefix"
+#~ msgstr "Name der Ausgabe-Rasterkarte (Sättigung, saturation)."
 #, fuzzy
-msgid "Base name of the interpolated raster maps. This name will be extended with a numerical prefix"
+#~ msgid ""
+#~ "Base name of the interpolated raster maps. This name will be extended "
+#~ "with a numerical prefix"
 #, fuzzy
-msgid "Base name of the new created 3d raster maps. This name will be extended with a numerical prefix"
+#~ msgid ""
+#~ "Base name of the new created 3d raster maps. This name will be extended "
 #, fuzzy
-msgid "Creates watershed basins."
-msgstr ""
-"\n"
-"%s muss eine Karte der Wassereinzugsgebiete erstellen"
+#~ msgid "Creates watershed basins."
+#~ msgstr ""
+#~ "\n"
+#~ "%s muss eine Karte der Wassereinzugsgebiete erstellen"
 #, fuzzy
-msgid "Easting grid coordinates"
-msgstr "Ost Koordinaten des Austrittspunkts"
+#~ msgid "Easting grid coordinates"
+#~ msgstr "Ost Koordinaten des Austrittspunkts"
 #, fuzzy
-msgid "Northing grid coordinates"
+#~ msgid "Northing grid coordinates"
 #, fuzzy
-msgid "Created by r.water.outlet (MASK)"
-msgstr "(i)   Einzugsgebietskarte wurde von r.water.outlet (MASK) erstellt."
+#~ msgid "Created by r.water.outlet (MASK)"
+#~ msgstr "(i)   Einzugsgebietskarte wurde von r.water.outlet (MASK) erstellt."
 #, fuzzy
-msgid "Name for output basin elevation raster map (o/i)"
-msgstr "Name der Ausgabe-Expositions-Rasterkarte."
+#~ msgid "Name for output basin elevation raster map (o/i)"
+#~ msgstr "Name der Ausgabe-Expositions-Rasterkarte."
 #, fuzzy
-msgid "LiDAR LAS input file"
-msgstr "Eingabe fehlgeschlagen."
+#~ msgid "LiDAR LAS input file"
+#~ msgstr "Eingabe fehlgeschlagen."
 #, fuzzy
-msgid "data base files"
-msgstr "Datenbank, SQL"
+#~ msgid "data base files"
+#~ msgstr "Datenbank, SQL"
 #, fuzzy
-msgid "Force to rebuild all extensions"
-msgstr "Präfix wo Erweiterungen installiert werden"
+#~ msgid "Force to rebuild all extensions"
+#~ msgstr "Präfix wo Erweiterungen installiert werden"
 #, fuzzy
-msgid "No points/centroids found in <%s>"
-msgstr "%d Linien oder Grenzen in der Vektorkarte <%s@%s> gefunden."
+#~ msgid "No points/centroids found in <%s>"
+#~ msgstr "%d Linien oder Grenzen in der Vektorkarte <%s@%s> gefunden."
 #~ msgid "rows = %d, cols = %d"
 #~ msgstr "Zeilen = %d, Spalten = %d"
@@ -40221,20 +43248,29 @@
 #~ msgid "\"-\" to write to stdout"
 #~ msgstr "\"-\" um nach tdout zu schreiben"
-#~ msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
-#~ msgstr "Dies erzeugt optional Rasterkarten mit 'backlink'-UTM-Koordinaten, um Ausbreitungspfade nachzuzeichnen."
+#~ msgid ""
+#~ "It optionally produces raster maps to contain backlink UTM coordinates "
+#~ "for tracing spread paths."
+#~ msgstr ""
+#~ "Dies erzeugt optional Rasterkarten mit 'backlink'-UTM-Koordinaten, um "
+#~ "Ausbreitungspfade nachzuzeichnen."
 #~ msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
-#~ msgstr "Name der Rasterkarte mit den maximalen Ausbreitungsgeschwindigkeiten [cm/min]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit den maximalen Ausbreitungsgeschwindigkeiten [cm/"
+#~ "min]."
 #~ msgid "For wildfires: consider SPOTTING effect"
-#~ msgstr "Bei nicht zu kontrollierenden Bränden (wildfire): beachte den Effekt der Entdeckung (Spotting-Effect)."
+#~ msgstr ""
+#~ "Bei nicht zu kontrollierenden Bränden (wildfire): beachte den Effekt der "
+#~ "Entdeckung (Spotting-Effect)."
 #~ msgid "Neither \"levels\" nor \"step\" parameter specified."
 #~ msgstr "Weder den Parameter \"levels\" noch \"step\" angegeben."
 #~ msgid "Name of raster map containing LIVE fuel MOISTURE (%)"
-#~ msgstr "Name der Rasterkarte mit den aktuellen Brennmaterialfeuchtigkeiten [%]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit den aktuellen Brennmaterialfeuchtigkeiten [%]."
 #~ msgid "Character representing no data cell value"
 #~ msgstr "Zeichenkette, die NODATA-Werte repräsentiert."
@@ -40248,8 +43284,12 @@
 #~ msgid "Illegal configuration file (sample area)"
 #~ msgstr "Ungültige Konfigurationsdatei (Stichprobenfläche)."
-#~ msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
-#~ msgstr "Kann die Projektionsinformationen der aktuellen Location nicht finden: Bitte setzen Sie geog. Länge via 'lat' oder 'latin'!"
+#~ msgid ""
+#~ "Can't get projection info of current location: please set latitude via "
+#~ "'lat' or 'latin' option!"
+#~ msgstr ""
+#~ "Kann die Projektionsinformationen der aktuellen Location nicht finden: "
+#~ "Bitte setzen Sie geog. Länge via 'lat' oder 'latin'!"
 #~ msgid "Name of color definition column (for use with -a flag)"
 #~ msgstr "Name der Farbdefinitionsspalte (mit dem Schalter -a zu benutzen)."
@@ -40279,7 +43319,8 @@
 #~ msgstr "Passwort"
 #~ msgid "Existing raster map, preferably the output of r.clump"
-#~ msgstr "Existierende Rasterkarte, idealerweise die Ausgabekarte von r.clump."
+#~ msgstr ""
+#~ "Existierende Rasterkarte, idealerweise die Ausgabekarte von r.clump."
 #~ msgid "No data map specified"
 #~ msgstr "Keine Eingabekarte angegeben."
@@ -40328,7 +43369,9 @@
 #~ msgstr "Raster, Export, VRML"
 #~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-#~ msgstr "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
+#~ msgstr ""
+#~ "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language "
+#~ "(VRML)."
 #~ msgid "Name for new VRML file"
 #~ msgstr "Name der neuen VRML-Datei."
@@ -40339,8 +43382,12 @@
 #~ msgid "Run quietly"
 #~ msgstr "Arbeite schweigsam."
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
+#~ msgid ""
+#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
+#~ "quiet' instead."
+#~ msgstr ""
+#~ "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
+#~ "ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
 #~ msgid "%d clumps."
 #~ msgstr "%d Klumpen."
@@ -40357,8 +43404,12 @@
 #~ msgid "raster, import"
 #~ msgstr "Raster, Import"
-#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
-#~ msgstr "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) GRASS Rasterkarte."
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) "
+#~ "GRASS Rasterkarte."
 #~ msgid "ARC/INFO ASCII raster file (GRID) to be imported"
 #~ msgstr "ARC/INFO ASCII Rasterdatei (GRID) zum Importieren."
@@ -40382,7 +43433,8 @@
 #~ msgstr "Raster, Kostenfläche, kumulative Kosten"
 #~ msgid "Name of raster map containing grid cell cost information"
-#~ msgstr "Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
+#~ msgstr ""
+#~ "Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
 #~ msgid "Name of output raster map to contain movement directions"
 #~ msgstr "Name der Ausgabe-Rasterkarte mit Bewegungsrichtungen."
@@ -40399,8 +43451,12 @@
 #~ msgid "Optional maximum cumulative cost"
 #~ msgstr "Optionales kumulatives Kostenmaximum."
-#~ msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
-#~ msgstr "Der Schalter '-v' wurde ersetzt und in Zukunft entfernt. Bitte verwenden Sie stattdessen '--verbose'."
+#~ msgid ""
+#~ "The '-v' flag is superseded and will be removed in future. Please use '--"
+#~ "verbose' instead."
+#~ msgstr ""
+#~ "Der Schalter '-v' wurde ersetzt und in Zukunft entfernt. Bitte verwenden "
+#~ "Sie stattdessen '--verbose'."
 #~ msgid "Unable to read current window parameters"
 #~ msgstr "Kann die aktuellen Fensterparameter nicht lesen."
@@ -40468,8 +43524,12 @@
 #~ msgid "Name of filter file"
 #~ msgstr "Name der Filterdatei"
-#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
-#~ msgstr "Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
+#~ msgid ""
+#~ "quiet' instead"
+#~ msgstr ""
+#~ "Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft "
+#~ "entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
 #~ msgid "Edit header for [%s]\n"
 #~ msgstr "Schreibe Header für [%s].\n"
@@ -40481,10 +43541,14 @@
 #~ msgstr "Für welchen Layer soll die Header-Datei editiert werden?"
 #~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr "[%s] ist eine reklassifizierte Karte von [%s] - kann den Header nicht editieren! Führen Sie support für [%s] aus."
+#~ msgstr ""
+#~ "[%s] ist eine reklassifizierte Karte von [%s] - kann den Header nicht "
+#~ "editieren! Führen Sie support für [%s] aus."
 #~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "[%s] ist eine reklassifizierte Karte von [%s in %s] - kann den Header nicht editieren!"
+#~ msgstr ""
+#~ "[%s] ist eine reklassifizierte Karte von [%s in %s] - kann den Header "
+#~ "nicht editieren!"
 #~ msgid "Cannot open raster map [%s]!"
 #~ msgstr "Kann die Rasterkarte [%s] nicht öffnen!"
@@ -40523,7 +43587,9 @@
 #~ msgstr "Die Datei scheint komprimiert zu sein.\n"
 #~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr "Höchstwahrscheinlich ist die Information aus dem Header falsch, aber ich möchte, dass Sie entscheiden.\n"
+#~ msgstr ""
+#~ "Höchstwahrscheinlich ist die Information aus dem Header falsch, aber ich "
+#~ "möchte, dass Sie entscheiden.\n"
 #~ msgid "The header for [%s] says the file is compressed. "
 #~ msgstr "Der Header von [%s] sagt, dass die Datei komprimiert ist."
@@ -40531,8 +43597,12 @@
 #~ msgid "The file does NOT appear to be compressed.\n"
 #~ msgstr "Die Datei scheint NICHT komprimiert zu sein.\n"
-#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
-#~ msgstr "Header gibt an, dass %d Zeile%s in der Rasterkarte enthalten sind, aber die aktuelle Datei hat %d Zeile%s."
+#~ msgid ""
+#~ "Header indicates %d row%s in the raster map, but the actual file format "
+#~ "indicates %d row%s"
+#~ msgstr ""
+#~ "Header gibt an, dass %d Zeile%s in der Rasterkarte enthalten sind, aber "
+#~ "die aktuelle Datei hat %d Zeile%s."
 #~ msgid "Unable to write header for [%s]."
 #~ msgstr "Kann den Header für [%s] nicht schreiben."
@@ -40556,7 +43626,9 @@
 #~ msgstr "        Fließkomma-Karte"
 #~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr "Zeilen * Spalten * Bytes* pro Zelle musse genauso groß sein wie die Datei (%lu)."
+#~ msgstr ""
+#~ "Zeilen * Spalten * Bytes* pro Zelle musse genauso groß sein wie die Datei "
+#~ "(%lu)."
 #~ msgid "If you need help figuring them out, just hit ESC"
 #~ msgstr "Für Hilfe beim Herausfinden bitte ESC drücken."
@@ -40627,10 +43699,12 @@
 #~ msgid ""
 #~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
+#~ "Do you want to create/reset the null file for [%s] so that null cell "
+#~ "values are considered valid data? "
 #~ msgstr ""
 #~ "\n"
-#~ "Wollen Sie eine NULL-Datei für [%s] erzeugen/zurücksetzen, so dass Zellen mit NULL-Werten als gültige Daten angesehen werden?"
+#~ "Wollen Sie eine NULL-Datei für [%s] erzeugen/zurücksetzen, so dass Zellen "
+#~ "mit NULL-Werten als gültige Daten angesehen werden?"
 #~ msgid "Error writing null row [%d]."
 #~ msgstr "Fehler beim Schreiben der NULL-Zeile [%d]."
@@ -40645,7 +43719,8 @@
 #~ "(alle 0 (zero)-Zellen werden dann zu NULL-Werten)? "
 #~ msgid "Update the statistics (histogram, range) for [%s]? "
-#~ msgstr "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
+#~ msgstr ""
+#~ "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
 #~ msgid ""
 #~ "\n"
@@ -40674,28 +43749,50 @@
 #~ msgid ""
 #~ "USAGE for basin delineation:\n"
-#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
+#~ "[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
 #~ "\n"
 #~ "USAGE for ARMSED FILE creation:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
+#~ "ha=half_basin_map ar=ARMSED_file_name\n"
 #~ "\n"
 #~ "USAGE for slope length determination:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
+#~ "[de=depression_map] [ac=accumulation_map] [di=display_map] "
+#~ "[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
+#~ "LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or "
+#~ "map]"
 #~ msgstr ""
 #~ "VERWENDUNG für Einzugsgebietskartierung:\n"
 #~ "\n"
 #~ "VERWENDUNG für ARMSED-Datei Erzeugung:\n"
 #~ "\n"
 #~ "VERWENDUNG für Hanglängenberechnung:\n"
+#~ "map]"
 #~ msgid "SECTION 1 beginning: Initiating Variables. %d sections total."
-#~ msgstr "ABSCHNITT 1 Beginne: Initialisiere Variablen. %d Abschnitte insgesamt."
+#~ msgstr ""
+#~ "ABSCHNITT 1 Beginne: Initialisiere Variablen. %d Abschnitte insgesamt."
-#~ msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-#~ msgstr "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den Standardwert 300 MB."
+#~ msgid ""
+#~ "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
+#~ msgstr ""
+#~ "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den "
+#~ "Standardwert 300 MB."
 #~ msgid "unable to open elevation map layer"
 #~ msgstr "Kann die elevation-Karte nicht öffnen."
@@ -40721,8 +43818,11 @@
 #~ msgid "SECTION 3: Accumulating Surface Flow with MFD."
 #~ msgstr "ABSCHNITT 3: Akkumuliere Oberflächenabfluß mit MFD."
-#~ msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
-#~ msgstr "MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d Zellen"
+#~ msgid ""
+#~ "MFD: A * path already processed when distributing flow: %d of %d cells"
+#~ msgstr ""
+#~ "MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d "
+#~ "Zellen"
 #~ msgid "unable to open runoff map layer"
 #~ msgstr "Kann die runoff-Karte nicht öffnen."
@@ -40752,7 +43852,9 @@
 #~ msgstr "Modul zur Analyse von Wassereinzugsgebieten."
 #~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "Eingabekarte mit Höheninformationen, welche die Grundlage der gesamten Analyse ist."
+#~ msgstr ""
+#~ "Eingabekarte mit Höheninformationen, welche die Grundlage der gesamten "
+#~ "Analyse ist."
 #~ msgid "Input_options"
 #~ msgstr "Eingabe Optionen"
@@ -40764,10 +43866,12 @@
 #~ msgstr "Eingabekarte mit der Größe des Oberflächenabfluss pro Zelle."
 #~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "Eingabekarte oder Wert: Prozent von gestörtem Land, (für ABAG/USLE)."
+#~ msgstr ""
+#~ "Eingabekarte oder Wert: Prozent von gestörtem Land, (für ABAG/USLE)."
 #~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
+#~ msgstr ""
+#~ "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
 #~ msgid "Output map: number of cells that drain through each cell"
 #~ msgstr "Ausgabekarte mit Anzahl der Zellen, die durch jede Zelle abfließt."
@@ -40788,7 +43892,8 @@
 #~ msgstr "Ausgabekarte mit Einzugsgebietshälften mit eindeutigen Wert."
 #~ msgid "Output map: useful for visual display of results"
-#~ msgstr "Ausgabekarte: hilfreich für die visuelle Darstellung der Ergebnisse."
+#~ msgstr ""
+#~ "Ausgabekarte: hilfreich für die visuelle Darstellung der Ergebnisse."
 #~ msgid "Output map: slope length and steepness (LS) factor for USLE"
 #~ msgstr "Ausgabekarte der Hanglängen und -Neigungsfaktoren (LS) für USLE."
@@ -40826,14 +43931,19 @@
 #~ msgid "GIS Coincidence Tabulation Facility\n"
 #~ msgstr "GIS Koinzidenz-Tabellierungsanlage\n"
-#~ msgid "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr "Dieses Dienstprogramm ermöglicht Ihnen die Koinzidenz zweier Karten zu vergleichen\n"
+#~ msgid ""
+#~ "This utility will allow you to compare the coincidence of two map layers\n"
+#~ msgstr ""
+#~ "Dieses Dienstprogramm ermöglicht Ihnen die Koinzidenz zweier Karten zu "
+#~ "vergleichen\n"
 #~ msgid "The report can be made in one of 8 units."
 #~ msgstr "DerBericht kann in einer von 8 Einheiten erstellt werden."
 #~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr "Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden Buchstaben:"
+#~ msgstr ""
+#~ "Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden "
+#~ "Buchstaben:"
 #~ msgid "     'c': cells"
 #~ msgstr "     'c': Zellen"
@@ -40875,8 +43985,11 @@
 #~ msgid "'%s' being saved\n"
 #~ msgstr "'%s' wird gespeichert\n"
-#~ msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr "Möchten Sie diesen Bericht drucken (benötigt den Unix lpr-Befehl)? (y/n) [n] "
+#~ msgid ""
+#~ "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+#~ msgstr ""
+#~ "Möchten Sie diesen Bericht drucken (benötigt den Unix lpr-Befehl)? (y/n) "
+#~ "[n] "
 #~ msgid ""
 #~ "Do you wish it printed in 80 or 132 columns?\n"
@@ -40885,14 +43998,20 @@
 #~ "Möchten Sie die Ausgabe in 80 oder 132 Spalten?\n"
-#~ msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
+#~ msgid ""
+#~ "Do you wish to run this report with a different unit of measure? (y/n) "
+#~ "[y] "
 #~ msgstr "Möchten Sie diesen Bericht mit einer anderen Maßeinheit? (y/n) [y] "
 #~ msgid "raster, import, LIDAR"
 #~ msgstr "Raster, Import, LIDAR"
-#~ msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
-#~ msgstr "Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung univariater Statistik."
+#~ msgid ""
+#~ "Create a raster map from an assemblage of many coordinates using "
+#~ "univariate statistics."
+#~ msgstr ""
+#~ "Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter "
+#~ "Verwendung univariater Statistik."
 #~ msgid "Writing map, row %d"
 #~ msgstr "Schreibe Karte, Zeile %d."
@@ -40921,8 +44040,12 @@
 #~ msgid "Unable to create value map <%s>"
 #~ msgstr "Kann die Wert-Karte <%s> nicht erzeugen."
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung der DERZEITIG EINGESTELLTEN REGION."
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-"
+#~ "Auflösung der DERZEITIG EINGESTELLTEN REGION."
 #~ msgid "raster, null data"
 #~ msgstr "Raster, NULL-Werte"
@@ -40948,23 +44071,36 @@
 #~ msgid "raster, fire"
 #~ msgstr "Raster, Feuer"
-#~ msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
-#~ msgstr "Erstellt drei oder vier Rasterkarten, die 1) die Basisrate der (rechtwinkligen) Ausbreitungsgeschwindigkeit, 2) die maximale (Vorwärts-) Geschwindigkeit, 3) die Richtung der größten Ausbreitungsgeschwindigkeit und optional 4) die maximale Entdeckungsentfernung."
+#~ msgid ""
+#~ "Generates three, or four raster map layers showing 1) the base "
+#~ "(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) "
+#~ "the direction of the maximum ROS, and optionally 4) the maximum potential "
+#~ "spotting distance."
+#~ msgstr ""
+#~ "Erstellt drei oder vier Rasterkarten, die 1) die Basisrate der "
+#~ "(rechtwinkligen) Ausbreitungsgeschwindigkeit, 2) die maximale (Vorwärts-) "
+#~ "Geschwindigkeit, 3) die Richtung der größten Ausbreitungsgeschwindigkeit "
+#~ "und optional 4) die maximale Entdeckungsentfernung."
 #~ msgid "Name of raster map containing fuel MODELs"
 #~ msgstr "Name der Rasterkarte mit Brennmaterial-Modellen."
 #~ msgid "Name of raster map containing the 1-HOUR fuel MOISTURE (%)"
-#~ msgstr "Name der Rasterkarte mit den 1-Stunden-Brennmaterialfeuchtigkeiten [%]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit den 1-Stunden-Brennmaterialfeuchtigkeiten [%]."
 #~ msgid "Name of raster map containing the 10-HOUR fuel MOISTURE (%)"
-#~ msgstr "Name der Rasterkarte mit den 10-Stunden-Brennmaterialfeuchtigkeiten [%]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit den 10-Stunden-Brennmaterialfeuchtigkeiten [%]."
 #~ msgid "Name of raster map containing the 100-HOUR fuel MOISTURE (%)"
-#~ msgstr "Name der Rasterkarte mit den 100-Stunden-Brennmaterialfeuchtigkeiten [%]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit den 100-Stunden-Brennmaterialfeuchtigkeiten [%]."
 #~ msgid "Name of raster map containing midflame wind VELOCITYs (ft/min)"
-#~ msgstr "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/min]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe "
+#~ "[ft/min]."
 #~ msgid "Name of raster map containing wind DIRECTIONs (degree)"
 #~ msgstr "Name der Rasterkarte mit den Windrichtungen [Grad]."
@@ -40973,10 +44109,14 @@
 #~ msgstr "Name der Rasterkarte mit Hangneigung [Grad]."
 #~ msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-#~ msgstr "Name der Rasterkarte mit Expositionen [Grad, gegen den Uhrzeigersinn vom Osten]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit Expositionen [Grad, gegen den Uhrzeigersinn vom "
+#~ "Osten]."
 #~ msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
-#~ msgstr "Name der Rasterkarte mit den Höheninformationen [m] (gefordert von dem Schalter -s)."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit den Höheninformationen [m] (gefordert von dem "
+#~ "Schalter -s)."
 #~ msgid "Name of raster map to contain results (several new layers)"
 #~ msgstr "Name der Rasterkarten mit den Ergebnissen (mehrere Karten möglich)."
@@ -40985,40 +44125,68 @@
 #~ msgstr "Auch die maximale Entdeckungsentfernung berechnen."
 #~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr "Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen anderen Namen."
+#~ msgstr ""
+#~ "Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen "
+#~ "anderen Namen."
 #~ msgid "Percent Completed ... "
 #~ msgstr "Prozent fertig..."
-#~ msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
-#~ msgstr "Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung und der Ursprung."
+#~ msgid ""
+#~ "Simulates elliptically anisotropic spread on a graphics window and "
+#~ "generates a raster map of the cumulative time of spread, given raster "
+#~ "maps containing the rates of spread (ROS), the ROS directions and the "
+#~ "spread origins."
+#~ msgstr ""
+#~ "Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und "
+#~ "erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als "
+#~ "Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, "
+#~ "Ausbreitungsrichtung und der Ursprung."
 #~ msgid "Input_maps"
 #~ msgstr "Eingabekarten"
 #~ msgid "Name of raster map containing DIRections of max ROS (degree)"
-#~ msgstr "Name der Rasterkarte mit den Richtungen der Maximalen Ausbreitungsgeschwindigkeit [Grad]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit den Richtungen der Maximalen "
+#~ "Ausbreitungsgeschwindigkeit [Grad]."
 #~ msgid "Name of raster map containing BASE ROS (cm/min)"
-#~ msgstr "Name der Rasterkarte mit der Grund-Ausbreitungsgeschwindigkeit [cm/min]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit der Grund-Ausbreitungsgeschwindigkeit [cm/min]."
 #~ msgid "Name of raster map containing STARTing sources"
 #~ msgstr "Name der Rasterkarte mit Startpunkten."
-#~ msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-#~ msgstr "Name der Rasterkarte mit den maximalen Entdeckungsentfernungen [m] (gefordert von dem Schalter -s)."
+#~ msgid ""
+#~ "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+#~ msgstr ""
+#~ "Name der Rasterkarte mit den maximalen Entdeckungsentfernungen [m] "
+#~ "(gefordert von dem Schalter -s)."
-#~ msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
-#~ msgstr "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/min] (gefordert von dem Schalter -s)."
+#~ msgid ""
+#~ "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -"
+#~ "s)"
+#~ msgstr ""
+#~ "[ft/min] (gefordert von dem Schalter -s)."
-#~ msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
-#~ msgstr "Name der Rasterkarte,mit den genauen Brennmaterialfeuchtigkeiten einer Zelle, die von einem Brand erreicht wird [%] (gefordert von dem Schalter -s)."
+#~ msgid ""
+#~ "Name of raster map containing fine Fuel MOISture of the cell receiving a "
+#~ "spotting firebrand (%) (required w/ -s)"
+#~ msgstr ""
+#~ "Name der Rasterkarte,mit den genauen Brennmaterialfeuchtigkeiten einer "
+#~ "Zelle, die von einem Brand erreicht wird [%] (gefordert von dem Schalter -"
+#~ "s)."
 #~ msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
-#~ msgstr "Stichprobenrahmengröße, die für eine bestimmte Genauigkeit benötigt wird (3)."
+#~ msgstr ""
+#~ "Stichprobenrahmengröße, die für eine bestimmte Genauigkeit benötigt wird "
+#~ "(3)."
 #~ msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-#~ msgstr "Stichprobendichte für zusätzliche Berechnungen (Spanne: 0.0 - 1.0 (0.5))."
+#~ msgstr ""
+#~ "Stichprobendichte für zusätzliche Berechnungen (Spanne: 0.0 - 1.0 (0.5))."
 #~ msgid "INITial TIME for current simulation (0) (min)"
 #~ msgstr "Anfangszeit für die aktuelle Simulation (0) [min]."
@@ -41071,14 +44239,24 @@
 #~ msgid "No raster map specified"
 #~ msgstr "Keine Rasterkarte angegeben."
-#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
-#~ msgstr "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder \"rules\" muss angegeben werden!"
+#~ msgid ""
+#~ "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must "
+#~ "be specified!"
+#~ msgstr ""
+#~ "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" "
+#~ "oder \"rules\" muss angegeben werden!"
-#~ msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
-#~ msgstr "Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules\" und \"raster\"."
+#~ msgid ""
+#~ "Interactive mode is incompatible with \"color\", \"rules\", and \"raster"
+#~ "\" options"
+#~ msgstr ""
+#~ "Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules"
+#~ "\" und \"raster\"."
 #~ msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-#~ msgstr "Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich gegenseitig aus."
+#~ msgstr ""
+#~ "Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich "
+#~ "gegenseitig aus."
 #~ msgid "-g and -a flags are mutually exclusive"
 #~ msgstr "-g und -a schließen sich gegenseitig aus."
@@ -41095,8 +44273,10 @@
 #~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
 #~ msgstr "Farbtabelle 'grey.eq' wird für Fließkomma-Karten nicht unterstützt."
-#~ msgid "Color table 'grey.log' is not supported for floating point raster map"
-#~ msgstr "Farbtabelle 'grey.log' wird für Fließkomma-Karten nicht unterstützt."
+#~ msgid ""
+#~ "Color table 'grey.log' is not supported for floating point raster map"
+#~ msgstr ""
+#~ "Farbtabelle 'grey.log' wird für Fließkomma-Karten nicht unterstützt."
 #~ msgid "Color table for raster map <%s> set to '%s'"
 #~ msgstr "Farbtabelle der Rasterkarte für <%s> ist auf '%s' gesetzt."
@@ -41105,10 +44285,14 @@
 #~ msgstr "Raster, Import, Konvertierung"
 #~ msgid "Converts ASCII raster file to binary raster map layer."
-#~ msgstr "Konvertiert eine ASCII-Rasterdatei in eine (binäre) GRASS Rasterkarte."
+#~ msgstr ""
+#~ "Konvertiert eine ASCII-Rasterdatei in eine (binäre) GRASS Rasterkarte."
-#~ msgid "ASCII raster file to be imported. If not given reads from standard input"
-#~ msgstr "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben ist, wird von der Standardeingabe gelesen."
+#~ msgid ""
+#~ "ASCII raster file to be imported. If not given reads from standard input"
+#~ msgstr ""
+#~ "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben ist, wird "
+#~ "von der Standardeingabe gelesen."
 #~ msgid "Integer values are imported"
 #~ msgstr "Integer-Werte wurden importiert."
@@ -41119,8 +44303,12 @@
 #~ msgid "Double floating point values are imported"
 #~ msgstr "Double Fließkommawerte wurden importiert."
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#~ msgstr "Konvertiert eine GRASS-Rasterkarte in eine PPM Bilddatei mit der Auflösung der aktuellen Region."
+#~ msgid ""
+#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
+#~ "of the currently defined region."
+#~ msgstr ""
+#~ "Konvertiert eine GRASS-Rasterkarte in eine PPM Bilddatei mit der "
+#~ "Auflösung der aktuellen Region."
 #~ msgid "raster, random, cell"
 #~ msgstr "Raster, Zufall, Zelle"
@@ -41129,7 +44317,8 @@
 #~ msgstr "Erzeugt Flächenstatistiken für Rasterkarten."
 #~ msgid "Number of fp subranges to collect stats from"
-#~ msgstr "Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
+#~ msgstr ""
+#~ "Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
 #~ msgid "Print averaged values instead of intervals"
 #~ msgstr "Gib gemittelte Werte anstatt Intervalle aus."
@@ -41141,16 +44330,20 @@
 #~ msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-#~ msgstr "Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
+#~ msgstr ""
+#~ "Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
 #~ msgid "Print raw indexes of fp ranges (fp maps only)"
-#~ msgstr "Gebe rohe Indizes der Fließkomma-Spannen aus (nur Fließkommakarten)."
+#~ msgstr ""
+#~ "Gebe rohe Indizes der Fließkomma-Spannen aus (nur Fließkommakarten)."
 #~ msgid "Report for cats fp ranges (fp maps only)"
 #~ msgstr "Gebe Fließkomma-Spannen der Cats aus. (nur bei Fließkomma-Karten)"
 #~ msgid "Read fp map as integer (use map's quant rules)"
-#~ msgstr "Lese Fließkommakarte als Integerkarte (benutze Quantisierungsregeln der Karte)."
+#~ msgstr ""
+#~ "Lese Fließkommakarte als Integerkarte (benutze Quantisierungsregeln der "
+#~ "Karte)."
 #~ msgid "Unable to read raster <map %d of %d> row %d"
 #~ msgstr "Kann die Rasterkarte <map %d of %d> Zeile %d nicht lesen."
@@ -41162,7 +44355,9 @@
 #~ msgstr "%s: Kann die temporäre Datei nicht öffnen."
 #~ msgid "Resultant raster map (not used with 'distribution')"
-#~ msgstr "Resultierende Rasterkarte (wird nicht benutzt, wenn Methode 'Verteilung' gewählt wurde)."
+#~ msgstr ""
+#~ "Resultierende Rasterkarte (wird nicht benutzt, wenn Methode 'Verteilung' "
+#~ "gewählt wurde)."
 #~ msgid "Output map <%s> ignored"
 #~ msgstr "Ausgabekarte <%s> ignoriert."
@@ -41171,7 +44366,8 @@
 #~ msgstr "Noch nicht implementiert."
 #~ msgid "An output raster map needs to be defined with method '%s'"
-#~ msgstr "Eine Ausgabe-Rasterkarte muss mit der Methode '%s' definiert werden."
+#~ msgstr ""
+#~ "Eine Ausgabe-Rasterkarte muss mit der Methode '%s' definiert werden."
 #~ msgid "Traces a flow through an elevation model on a raster map."
 #~ msgstr "Verfolgt einen Fluss durch ein Höhenmodell auf einer Rasterkarte."
@@ -41179,8 +44375,12 @@
 #~ msgid "Name of movement direction map associated with the cost surface"
 #~ msgstr "Name der Bewegungsrichtungskarte verbunden mit der Kostenkarte."
-#~ msgid "Output drain vector map (recommended for cost surface made using knight's move)"
-#~ msgstr "Ausgabe Abflußvektorkarte (empfohlen für Kostenkarten erstellt mittels Rösselsprung)."
+#~ msgid ""
+#~ "Output drain vector map (recommended for cost surface made using knight's "
+#~ "move)"
+#~ msgstr ""
+#~ "Ausgabe Abflußvektorkarte (empfohlen für Kostenkarten erstellt mittels "
+#~ "Rösselsprung)."
 #~ msgid "Map coordinates of starting point(s) (E,N)"
 #~ msgstr "Koordinaten von Startpunkt(en) (O,N)"
@@ -41188,20 +44388,31 @@
 #~ msgid "Name of vector map(s) containing starting point(s)"
 #~ msgstr "Name der Vektorkarte(n) mit Startpunkte(n)."
-#~ msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
-#~ msgstr "Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muß auch eine Richtungskarte angegeben werden)."
+#~ msgid ""
+#~ "The input surface is a cost surface (if checked, a direction surface must "
+#~ "also be specified"
+#~ msgstr ""
+#~ "Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muß auch "
+#~ "eine Richtungskarte angegeben werden)."
 #~ msgid "Directional drain selected... checking for direction raster"
 #~ msgstr "gerichteter Abfluß ausgewählt... prüfe die Richtungskarte"
-#~ msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
-#~ msgstr "Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, muß eine Richtungskarte angegeben werden."
+#~ msgid ""
+#~ "Direction raster not specified, if direction flag is on, a direction "
+#~ "raster must be given"
+#~ msgstr ""
+#~ "Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, "
+#~ "muß eine Richtungskarte angegeben werden."
 #~ msgid "Direction raster found <%s>"
 #~ msgstr "Richtungskarte gefunden <%s>."
-#~ msgid "Direction map <%s> should not be specified for Surface/Hydrology drains"
-#~ msgstr "Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluß nicht angegeben werden."
+#~ msgid ""
+#~ "Direction map <%s> should not be specified for Surface/Hydrology drains"
+#~ msgstr ""
+#~ "Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluß nicht "
+#~ "angegeben werden."
 #~ msgid "Outputting a vector path"
 #~ msgstr "Gebe ein Vektorpfad aus."
@@ -41234,7 +44445,9 @@
 #~ msgstr "Gebe nur den Titel der Rasterkarte aus."
 #~ msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr "Gebe Zeitstempel der Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:Sekunde)"
+#~ msgstr ""
+#~ "Gebe Zeitstempel der Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:"
+#~ "Sekunde)"
 #~ msgid "raster, geomorphology"
 #~ msgstr "Raster, Geomorphologie"
@@ -41248,8 +44461,12 @@
 #~ msgid "raster, buffer"
 #~ msgstr "Raster, Buffer"
-#~ msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
-#~ msgstr "Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte haben."
+#~ msgid ""
+#~ "Creates a raster map layer showing buffer zones surrounding cells that "
+#~ "contain non-NULL category values."
+#~ msgstr ""
+#~ "Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte "
+#~ "haben."
 #~ msgid "Apply filter only to zero data values"
 #~ msgstr "Filter nur auf 0-Werte anwenden."
@@ -41257,20 +44474,31 @@
 #~ msgid "raster, volume"
 #~ msgstr "Raster, Volumen"
-#~ msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
-#~ msgstr "Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
+#~ msgid ""
+#~ "Calculates the volume of data \"clumps\", and (optionally) produces a "
+#~ "GRASS vector points map containing the calculated centroids of these "
+#~ "clumps."
+#~ msgstr ""
+#~ "Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-"
+#~ "Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
-#~ msgid "Existing raster map representing data that will be summed within clumps"
-#~ msgstr "Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen aufsummiert werden."
+#~ msgid ""
+#~ "Existing raster map representing data that will be summed within clumps"
+#~ msgstr ""
+#~ "Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen "
+#~ "aufsummiert werden."
 #~ msgid "Vector points map to contain clump centroids"
-#~ msgstr "Vektorkarte, die die Zentroide der Daten-\"Klumpen\" enthalten soll."
+#~ msgstr ""
+#~ "Vektorkarte, die die Zentroide der Daten-\"Klumpen\" enthalten soll."
 #~ msgid "Generate unformatted report"
 #~ msgstr "Erzeuge unformatierten Report."
 #~ msgid "No clump map specified and MASK not set."
-#~ msgstr "Keine Klumpen-Karte angegeben. Außerdem ist die Maske (MASK) nicht gesetzt."
+#~ msgstr ""
+#~ "Keine Klumpen-Karte angegeben. Außerdem ist die Maske (MASK) nicht "
+#~ "gesetzt."
 #~ msgid "Unable to find data map"
 #~ msgstr "Kann die Rasterkarte nicht finden."
@@ -41285,13 +44513,16 @@
 #~ msgstr "RGB Rasterkarte <%s> nicht gefunden"
 #~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr "Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei Karten zur Verfügung [r,g,b]"
+#~ msgstr ""
+#~ "Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei Karten zur "
+#~ "Verfügung [r,g,b]"
 #~ msgid "Vector cell map <%s> not found"
 #~ msgstr "Vektor-Zellen-Karte <%s> nicht gefunden."
 #~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr "Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]"
+#~ msgstr ""
+#~ "Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]"
 #~ msgid "Converts raster maps into the VTK-Ascii format"
 #~ msgstr "Konvertiert eine Rasterkarte in das VTK-ASCII-Format."
@@ -41321,7 +44552,8 @@
 #~ msgstr "Spezifischer Ertrag [1/m]."
 #~ msgid "Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-#~ msgstr "Anreicherungskarte (recharge map) z.B.: 6*10^-9 pro Zelle [m^3/s*m^2]."
+#~ msgstr ""
+#~ "Anreicherungskarte (recharge map) z.B.: 6*10^-9 pro Zelle [m^3/s*m^2]."
 #~ msgid "The map storing the numerical result [m]"
 #~ msgstr "Karte der numerischen Ergebnisse [m]."
@@ -41349,10 +44581,13 @@
 #~ msgstr "Sicker-Koeffizient der Drainage [1/s]."
 #~ msgid "Use a sparse matrix, only available with iterative solvers"
-#~ msgstr "Verwende eine dünnbesetzte Matrix, nur für iterative Lösungsverfahren verfügbar."
+#~ msgstr ""
+#~ "Verwende eine dünnbesetzte Matrix, nur für iterative Lösungsverfahren "
+#~ "verfügbar."
 #~ msgid "The direct cholesky solver do not work with sparse matrices"
-#~ msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+#~ msgstr ""
+#~ "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
 #~ msgid "Calculation of unconfined groundwater flow loop %i\n"
 #~ msgstr "Berechnung der unbeschränkten Grundwasserfluss Schleife %i\n"
@@ -41361,7 +44596,8 @@
 #~ msgstr "Raster, Quantisierung"
 #~ msgid "Setting quant rules for input map(s) to (%f %f) -> (%d,%d)"
-#~ msgstr "Setze Quantisierungsregeln für Eingabekarte(n) auf (%f %f) -> (%d,%d)"
+#~ msgstr ""
+#~ "Setze Quantisierungsregeln für Eingabekarte(n) auf (%f %f) -> (%d,%d)"
 #~ msgid "Quant table not changed for %s"
 #~ msgstr "Quantisierungstabelle für <%s> wurde nicht geändert."
@@ -41394,7 +44630,8 @@
 #~ msgstr "Ausgabe-Rasterkarte der Transportkapazität [kg/ms]."
 #~ msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-#~ msgstr "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
+#~ msgstr ""
+#~ "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
 #~ msgid "Output sediment concentration raster map [particle/m3]"
 #~ msgstr "Ausgabe-Rasterkarte der Sedimentkonzentration [Partikel/m3]"
@@ -41409,7 +44646,9 @@
 #~ msgstr "Raster, Abfluss, Hydrologie"
 #~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
+#~ msgstr ""
+#~ "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/"
+#~ "hr]."
 #~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
 #~ msgstr "Name der Rasterkarte der Abflußinfiltrationsrate [mm/hr]."
@@ -41426,8 +44665,12 @@
 #~ msgid "Output simulation error raster map [m]"
 #~ msgstr "Ausgabe-Rasterkarte des Simulationsfehlers [m]."
-#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
-#~ msgstr "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe erreicht wurde)."
+#~ msgid ""
+#~ "Threshold water depth [m] (diffusion increases after this water depth is "
+#~ "reached)"
+#~ msgstr ""
+#~ "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese "
+#~ "Wassertiefe erreicht wurde)."
 #~ msgid "Number of iterations \t= %d cells\n"
 #~ msgstr "Anzahl der Iterationen \t= %d Zellen\n"
@@ -41479,7 +44722,8 @@
 #~ "r.mapcalc performs arithmetic on raster map layers.\n"
 #~ "\n"
 #~ "New raster map layers can be created which are arithmetic expressions\n"
-#~ "involving existing raster map layers, integer or floating point constants,\n"
+#~ "involving existing raster map layers, integer or floating point "
+#~ "constants,\n"
 #~ "and functions.\n"
 #~ " \n"
 #~ "For more information use 'g.manual r.mapcalc'\n"
@@ -41506,7 +44750,8 @@
 #~ msgstr "Raster, Sonnenenergie"
 #~ msgid "This does nothing. It is retained for backwards compatibility"
-#~ msgstr "Dies tut nichts. Es wurde nur für die Rückwärtskompatibilität erhalten"
+#~ msgstr ""
+#~ "Dies tut nichts. Es wurde nur für die Rückwärtskompatibilität erhalten"
 #~ msgid "Unused"
 #~ msgstr "Nicht genutzt"
@@ -41527,7 +44772,8 @@
 #~ msgstr "Raster, Zufall, Oberfläche"
 #~ msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default: random)"
-#~ msgstr "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard: zufällig)."
+#~ msgstr ""
+#~ "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard: zufällig)."
 #~ msgid "No (quiet) description during run"
 #~ msgstr "Keine Beschreibung während der Bearbeitung."
@@ -41541,7 +44787,8 @@
 #~ msgid "Name for output raster map with lake"
 #~ msgstr "Name der Ausgabe-Rasterkarte mit See."
-#~ msgid "Name of raster map with given starting point(s) (at least 1 cell > 0)"
+#~ msgid ""
+#~ "Name of raster map with given starting point(s) (at least 1 cell > 0)"
 #~ msgstr "Name der Rasterkarte mit Startpunkten (mindestens eine Zelle > 0)."
 #~ msgid "Lake depth from %f to %f"
@@ -41583,8 +44830,11 @@
 #~ msgid "Raster map(s) to report on"
 #~ msgstr "Rasterkarte(n), für die ein Report erstellt werden soll."
-#~ msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
-#~ msgstr "mi;Meilen;me;Meter;k;Kilometer;a;Acres;h;Hektar;c;Zellanzahl;p;Prozent"
+#~ msgid ""
+#~ "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;"
+#~ "percent cover"
+#~ msgstr ""
+#~ "mi;Meilen;me;Meter;k;Kilometer;a;Acres;h;Hektar;c;Zellanzahl;p;Prozent"
 #~ msgid "Name of an output file to hold the report"
 #~ msgstr "Name der Ausgabedatei zum Speichern des Reports."
@@ -41622,11 +44872,19 @@
 #~ msgid "Setting window header"
 #~ msgstr "Setze Fenster-Header"
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-#~ msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %f wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
+#~ msgid ""
+#~ "Input raster map contains cells with NULL-value (no-data). The value %f "
+#~ "will be used to represent no-data values in the input map. You can "
+#~ "specify a nodata value with the %s option."
+#~ msgstr ""
+#~ "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der "
+#~ "Wert %f wurde verwendet um Nodata-Werte in der Eingabekarte zu "
+#~ "kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
 #~ msgid "GIS format to write (case sensitive, see also -l flag)"
-#~ msgstr "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung beachten, siehe auch den Schalter -l)."
+#~ msgstr ""
+#~ "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung "
+#~ "beachten, siehe auch den Schalter -l)."
 #~ msgid "File type"
 #~ msgstr "Dateityp"
@@ -41643,8 +44901,14 @@
 #~ msgid "Range to be exported: %f - %f"
 #~ msgstr "Zu exportierender Wertebereich: %f - %f"
-#~ msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %f gets converted to %d by selected GDAL datatype."
-#~ msgstr "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %f wird von dem gewählten GDAL-Datentyp nach %d konvertiert."
+#~ msgid ""
+#~ "Mismatch between metadata nodata value and actual nodata value in "
+#~ "exported raster: specified nodata value %f gets converted to %d by "
+#~ "selected GDAL datatype."
+#~ msgstr ""
+#~ "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten "
+#~ "Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %f wird von "
+#~ "dem gewählten GDAL-Datentyp nach %d konvertiert."
 #~ msgid "Cannot read raster row [%d]"
 #~ msgstr "Kann die Zeile [%d] der Rasterkarte nicht lesen."
@@ -41668,28 +44932,45 @@
 #~ msgstr "Ausgabekarte mit topographischem Index"
 #~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr "Importiert Rasterdaten (aus Formaten die GDAL unterstützt) in eine GRASS Rasterkarte."
+#~ msgstr ""
+#~ "Importiert Rasterdaten (aus Formaten die GDAL unterstützt) in eine GRASS "
+#~ "Rasterkarte."
 #~ msgid "Raster file to be imported"
 #~ msgstr "Zu importierende Rasterdatei."
 #~ msgid "Name of location to read projection from for GCPs transformation"
-#~ msgstr "Name der Location, von der Projektionsinformationen für eine GCP-Transformation gelesen werden soll."
+#~ msgstr ""
+#~ "Name der Location, von der Projektionsinformationen für eine GCP-"
+#~ "Transformation gelesen werden soll."
 #~ msgid "Name for output raster map not specified"
 #~ msgstr "Name der Ausgabe-Rasterkarte nicht angegeben"
-#~ msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
-#~ msgstr "Die polynomiale Rektifikation die von i.rectify verwendet wird funktioniert nicht gut für NOAA/AVHRR Daten. Versuchen Sie stattdessen gdalwarp mit der 'thin plate spline rectification' (-tps)."
+#~ msgid ""
+#~ "The polynomial rectification used in i.rectify does not work well with "
+#~ "NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification "
+#~ "instead. (-tps)"
+#~ msgstr ""
+#~ "Die polynomiale Rektifikation die von i.rectify verwendet wird "
+#~ "funktioniert nicht gut für NOAA/AVHRR Daten. Versuchen Sie stattdessen "
+#~ "gdalwarp mit der 'thin plate spline rectification' (-tps)."
 #~ msgid "raster, conversion, vectorization"
 #~ msgstr "Raster, Konvertieren, Vektorisieren"
-#~ msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
-#~ msgstr "Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. Derzeit werden nur Punkte unterstützt."
+#~ msgid ""
+#~ "Write raster values as z coordinate. Table is not created. Currently "
+#~ "supported only for points."
+#~ msgstr ""
+#~ "Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht "
+#~ "erzeugt. Derzeit werden nur Punkte unterstützt."
-#~ msgid "Do not build vector topology (use with care for massive point export)"
-#~ msgstr "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von extrem großen Punktmengen)."
+#~ msgid ""
+#~ "Do not build vector topology (use with care for massive point export)"
+#~ msgstr ""
+#~ "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von "
+#~ "extrem großen Punktmengen)."
 #~ msgid "Quiet - Do not show progress"
 #~ msgstr "Schweigsam - keinen Fortschritt anzeigen."
@@ -41710,7 +44991,9 @@
 #~ msgstr "(o/i) Höhenkarte des Einzugsgebiets (mit angewandter Maske (MASK))."
 #~ msgid "(o)   Topographic index ln(a/tanB) map (MASK applied)"
-#~ msgstr "(o)   Karte des Topographischen Index ln(a/tanB) (mit angewandter Maske (MASK))."
+#~ msgstr ""
+#~ "(o)   Karte des Topographischen Index ln(a/tanB) (mit angewandter Maske "
+#~ "(MASK))."
 #~ msgid "(i)   Number of topographic index classes"
 #~ msgstr "(i)   Anzahl der Klassen des Topgraphischen Indexes."
@@ -41734,7 +45017,9 @@
 #~ msgstr "(i)   OPTIONAL: Ausgabe für einen angegebenen Zeitabschnitt."
 #~ msgid "(i)   OPTIONAL Output for given topographic index class"
-#~ msgstr "(i)   OPTIONAL: Ausgabe für die angegebene Klasse des topgraphischen Index."
+#~ msgstr ""
+#~ "(i)   OPTIONAL: Ausgabe für die angegebene Klasse des topgraphischen "
+#~ "Index."
 #~ msgid "raster, rescale"
 #~ msgstr "Raster, Rescale"
@@ -41757,8 +45042,15 @@
 #~ msgid "Writing raster map, row %d"
 #~ msgstr "Schreibe Rasterkarte, Zeile %d."
-#~ msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
-#~ msgstr "GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer Gauß'schen Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird verwendet."
+#~ msgid ""
+#~ "GRASS module to produce a raster map layer of gaussian deviates whose "
+#~ "mean and standard deviation can be expressed by the user. It uses a "
+#~ "gaussian random number generator."
+#~ msgstr ""
+#~ "GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer Gauß'schen "
+#~ "Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer "
+#~ "angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird "
+#~ "verwendet."
 #~ msgid "Name of the output random surface"
 #~ msgstr "Name der Ausgabe-Rasterkarte mit zufälliger Oberfläche"
@@ -41790,8 +45082,16 @@
 #~ msgid "Found %d unresolved areas"
 #~ msgstr "Habe %d unaufgelöste Flächen gefunden."
-#~ msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
-#~ msgstr "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte mit Reibungs-Kosten kombiniert."
+#~ msgid ""
+#~ "Outputs a raster map layer showing the anisotropic cumulative cost of "
+#~ "moving between different geographic locations on an input elevation "
+#~ "raster map layer whose cell category values represent elevation combined "
+#~ "with an input raster map layer whose cell values represent friction cost."
+#~ msgstr ""
+#~ "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, "
+#~ "die beim Bewegen zwischen unterschiedlichen geographischen Orten "
+#~ "entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine "
+#~ "Rasterkarte mit Reibungs-Kosten kombiniert."
 #~ msgid "Name of elevation input raster map"
 #~ msgstr "Eingabe-Rasterkarte mit Höheninformationen."
@@ -41878,10 +45178,13 @@
 #~ msgstr "Kann keinen Speicher für Segment fbuff == NULL reservieren."
 #~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "Ausgabe-Rasterkarte <%s> nicht gefunden (keine Start-Punkte angegeben)"
+#~ msgstr ""
+#~ "Ausgabe-Rasterkarte <%s> nicht gefunden (keine Start-Punkte angegeben)"
 #~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr "Fehler beim allozieren von Speicher während des Lesens der Startpunktes der Rasterkarte %s."
+#~ msgstr ""
+#~ "Fehler beim allozieren von Speicher während des Lesens der Startpunktes "
+#~ "der Rasterkarte %s."
 #~ msgid "End of map!"
 #~ msgstr "Ende der Karte!"
@@ -41941,7 +45244,9 @@
 #~ msgstr "Raster, Ausdünnung"
 #~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr "Dünnt Zellen die nicht null sind und linienhafte Strukturen in einer Rasterkarte abbilden."
+#~ msgstr ""
+#~ "Dünnt Zellen die nicht null sind und linienhafte Strukturen in einer "
+#~ "Rasterkarte abbilden."
 #~ msgid "Deleted %d  pixels "
 #~ msgstr "Löschte %d  Pixel "
@@ -41995,7 +45300,9 @@
 #~ msgstr "Nicht genügend Speicher für zero_array_cell."
 #~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht schreiben."
+#~ msgstr ""
+#~ "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht "
+#~ "schreiben."
 #~ msgid "Quietly"
 #~ msgstr "ruhig"
@@ -42057,14 +45364,23 @@
 #~ msgid "Calculated measure #%d <%s> (56 measures available)"
 #~ msgstr "Habe die Kenngröße #%d <%s> berechnet (56 Kenngrößen verfügbar)."
-#~ msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
-#~ msgstr "Negative oder NODATA-Pixel gefunden. Dieses Modul kann NODATA-Werte in Rasterkarten noch nicht verarbeiten. Bitte füllen Sie die Löcher z.B. mit dem Modul r.fillnulls oder anderen Füllalgorithmen."
+#~ msgid ""
+#~ "Negative or no data pixel found. This module is not yet able to process "
+#~ "no data holes in a map, please fill with r.fillnulls or other algorithms"
+#~ msgstr ""
+#~ "Negative oder NODATA-Pixel gefunden. Dieses Modul kann NODATA-Werte in "
+#~ "Rasterkarten noch nicht verarbeiten. Bitte füllen Sie die Löcher z.B. mit "
+#~ "dem Modul r.fillnulls oder anderen Füllalgorithmen."
 #~ msgid "Too many iterations to required to find %s - giving up"
 #~ msgstr "Zu viele Iterationen werden benötigt um %s zu finden - gebe auf."
-#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Findet den Durchschnitt der Werte in einer Überlagerungskarte innerhalb gleicher Kategorien in einer benutzer-angegebenen Ausgangskarte."
+#~ msgid ""
+#~ "Finds the average of values in a cover map within areas assigned the same "
+#~ "category value in a user-specified base map."
+#~ msgstr ""
+#~ "Findet den Durchschnitt der Werte in einer Überlagerungskarte innerhalb "
+#~ "gleicher Kategorien in einer benutzer-angegebenen Ausgangskarte."
 #~ msgid "%s: ERROR running %s command"
 #~ msgstr "%s: Fehler  beim Ausführen des Kommandos %s."
@@ -42195,7 +45511,8 @@
 #~ msgid "raster, landscape structure analysis, dominance index"
 #~ msgstr "Raster, Landschaftsstruktur Analyse, Dominanz-Index"
-#~ msgid "Queries raster map layers on their category values and category labels."
+#~ msgid ""
+#~ "Queries raster map layers on their category values and category labels."
 #~ msgstr "Fragt Rasterkartenwerte und Kategorielabel ab."
 #~ msgid "%s: can only do up to %d raster maps, sorry\n"
@@ -42231,8 +45548,12 @@
 #~ msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
 #~ msgstr "Berechne Karte %01d von %01d (Winkel %lf, Rasterkarte <%s>)."
-#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Findet den Median der Werte einer Coverkarte innerhalb der Flächen mit gleichen Werten in einer benutzerdefinierten Basiskarte."
+#~ msgid ""
+#~ "Finds the median of values in a cover map within areas assigned the same "
+#~ msgstr ""
+#~ "Findet den Median der Werte einer Coverkarte innerhalb der Flächen mit "
+#~ "gleichen Werten in einer benutzerdefinierten Basiskarte."
 #~ msgid "Name of base raster map"
 #~ msgstr "Name der Basis-Rasterkarte."
@@ -42259,7 +45580,8 @@
 #~ msgstr "Raster, Projektion, Transformation"
 #~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
+#~ msgstr ""
+#~ "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
 #~ msgid "Name for output raster map (default: input)"
 #~ msgstr "Name der Ausgabe-Rasterkarte (Standard: input)."
@@ -42268,7 +45590,8 @@
 #~ msgstr "Auflösung der Ausgabe-Karte"
 #~ msgid "List raster maps in input location and exit"
-#~ msgstr "Listet alle Rasterkarten in der Eingabe-Location auf und beendet sich."
+#~ msgstr ""
+#~ "Listet alle Rasterkarten in der Eingabe-Location auf und beendet sich."
 #~ msgid "Name of the latitudes input raster map [decimal degrees]"
 #~ msgstr "Eingabe-Rasterkarte des Breitengrads [in Grad]."
@@ -42277,16 +45600,24 @@
 #~ msgstr "Ein einfacher Wert des Breitengrads [in Grad]."
 #~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr "Name der Rasterkarte mit dem Koeffizient der direkten Sonneneinstrahlung [-]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit dem Koeffizient der direkten Sonneneinstrahlung "
 #~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr "Name der Rasterkarte mit dem Koeffizient der diffusen Sonneneinstrahlung [-]."
+#~ msgstr ""
+#~ "Name der Rasterkarte mit dem Koeffizient der diffusen Sonneneinstrahlung "
 #~ msgid "time and insol_time are incompatible options"
 #~ msgstr "time und insol_time sind nicht kompatible Optionen."
-#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
-#~ msgstr "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei bekannter lokaler Zeit"
+#~ msgid ""
+#~ "Mode 1: instantaneous solar incidence angle & irradiance given a set "
+#~ "local time"
+#~ msgstr ""
+#~ "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei "
+#~ "bekannter lokaler Zeit"
 #~ msgid "elevin raster map <%s> not found"
 #~ msgstr "elevin Rasterkarte <%s> nicht gefunden."
@@ -42353,14 +45684,22 @@
 #~ msgid "raster, terrain"
 #~ msgstr "Raster, Terrain"
-#~ msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
-#~ msgstr "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen Ableitungen aus einer Rasterkarte mit Höheninformationen."
+#~ msgid ""
+#~ "Generates raster maps of slope, aspect, curvatures and partial "
+#~ "derivatives from a elevation raster map."
+#~ msgstr ""
+#~ "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
+#~ "Ableitungen aus einer Rasterkarte mit Höheninformationen."
 #~ msgid "Do not align the current region to the elevation layer"
-#~ msgstr "Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen anpassen."
+#~ msgstr ""
+#~ "Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen "
+#~ "anpassen."
 #~ msgid "Resamples raster map layers to a finer grid using interpolation."
-#~ msgstr "Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels Interpolation."
+#~ msgstr ""
+#~ "Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels "
+#~ "Interpolation."
 #~ msgid "raster, DEM, contours, vector"
 #~ msgstr "Raster, DGM, Konturen, Vektor"
@@ -42368,8 +45707,13 @@
 #~ msgid "Suppress single crossing error messages"
 #~ msgstr "Unterdrücke Fehlermeldungen für 'single crossing'."
-#~ msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
+#~ msgid ""
+#~ "The '-q' and '-n' flag is superseded and will be removed in future. "
+#~ "Please use '--quiet' instead."
+#~ msgstr ""
+#~ "Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der "
+#~ "kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen "
+#~ "'--quiet'."
 #~ msgid "Writing vector contours (total levels %d)..."
 #~ msgstr "Schreibe Vektorkonturen (Gesamtanzahl %d) ..."
@@ -42380,14 +45724,22 @@
 #~ msgid "Bilinear interpolation utility for raster map layers."
 #~ msgstr "Bilineares Interpolationswerkzeug für Rasterkarten."
-#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
-#~ msgstr "Spezieller Eingabewert, der dem Nord- und/oder Südpol in Längen- und Breitengrad-Gittern zugewiesen wird."
+#~ msgid ""
+#~ "Specific input value to be assigned to the north and/or south poles for "
+#~ "longitude-latitude grids"
+#~ msgstr ""
+#~ "Spezieller Eingabewert, der dem Nord- und/oder Südpol in Längen- und "
+#~ "Breitengrad-Gittern zugewiesen wird."
 #~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "Dies Moduls ist veraltet. Bitte verwenden Sie stattdessen 'r.resamp.interp'."
+#~ msgstr ""
+#~ "Dies Moduls ist veraltet. Bitte verwenden Sie stattdessen 'r.resamp."
+#~ "interp'."
 #~ msgid "Surface generation program from rasterized contours."
-#~ msgstr "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit Höheninformationen."
+#~ msgstr ""
+#~ "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit "
+#~ "Höheninformationen."
 #~ msgid "Name of existing raster map containing contours"
 #~ msgstr "Name der existierenden Rasterkarte, die Konturlinien enthält."
@@ -42395,11 +45747,18 @@
 #~ msgid "Output elevation raster map"
 #~ msgstr "Name der Ausgabe-Rasterkarte, die Höheninformationen enthält."
-#~ msgid "Unused; retained for compatibility purposes, will be removed in future"
-#~ msgstr "Unbenutzt; nur noch zu Kompatibilitätszwecken vorhanden. Dieses Feature wird in der Zukunft entfernt."
+#~ msgid ""
+#~ "Unused; retained for compatibility purposes, will be removed in future"
+#~ msgstr ""
+#~ "Unbenutzt; nur noch zu Kompatibilitätszwecken vorhanden. Dieses Feature "
+#~ "wird in der Zukunft entfernt."
-#~ msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
-#~ msgstr "Rufe langsame aber speicherschonende Operation auf (im Allgemeinen nicht benötigt, wird in Zukunft entfernt)."
+#~ msgid ""
+#~ "Invoke slow, but memory frugal operation (generally not needed, will be "
+#~ "removed in future)"
+#~ msgstr ""
+#~ "Rufe langsame aber speicherschonende Operation auf (im Allgemeinen nicht "
+#~ "benötigt, wird in Zukunft entfernt)."
 #~ msgid "Unable to write quant file"
 #~ msgstr "Kann die quant Datei nicht schreiben."
@@ -42429,22 +45788,36 @@
 #~ msgstr "Raster, Export, PNG"
 #~ msgid "Export GRASS raster as non-georeferenced PNG image."
-#~ msgstr "Exportiert GRASS-Rasterkarte in ein nicht georeferenziertes PNG-Bild."
+#~ msgstr ""
+#~ "Exportiert GRASS-Rasterkarte in ein nicht georeferenziertes PNG-Bild."
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
-#~ msgstr "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die Pixelauflösung wird aus der aktuellen Region-Einstellung übernommen."
+#~ msgid ""
+#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
+#~ "resolution of the currently defined region."
+#~ msgstr ""
+#~ "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die "
+#~ "Pixelauflösung wird aus der aktuellen Region-Einstellung übernommen."
 #~ msgid "Name for new TIFF file"
 #~ msgstr "Name für neue TIFF-Datei."
-#~ msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
-#~ msgstr "Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. Nachkommastellen werden auf ganze Zahlen gerundet!"
+#~ msgid ""
+#~ "Raster map <%s> in mapset <%s> is a floating point map. Decimal values "
+#~ "will be rounded to integer!"
+#~ msgstr ""
+#~ "Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. "
+#~ "Nachkommastellen werden auf ganze Zahlen gerundet!"
 #~ msgid "Import a binary raster file into a GRASS raster map."
 #~ msgstr "Importiert eine binäre Rasterdatei in eine GRASS Rasterkarte."
-#~ msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
-#~ msgstr "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung (accuracy assessment) der Klassifikationsergebnisse."
+#~ msgid ""
+#~ "Calculate error matrix and kappa parameter for accuracy assessment of "
+#~ "classification result."
+#~ msgstr ""
+#~ "Berechnet Fehlermatrix und Kappa-Parameter für die "
+#~ "Genauigkeitsabschätzung (accuracy assessment) der "
+#~ "Klassifikationsergebnisse."
 #~ msgid "Reading file"
 #~ msgstr "Lese Datei."
@@ -42528,8 +45901,12 @@
 #~ msgid "Raster map to be reclassified"
 #~ msgstr "Rasterkarte, die neu klassifiziert werden soll."
-#~ msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
-#~ msgstr "Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren Spanne vom Benutzer angegeben werden kann."
+#~ msgid ""
+#~ "Produces a raster map of uniform random deviates whose range can be "
+#~ "expressed by the user."
+#~ msgstr ""
+#~ "Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, "
+#~ "deren Spanne vom Benutzer angegeben werden kann."
 #~ msgid "Surface area estimation for rasters."
 #~ msgstr "Abschätzung der Größe der Rasteroberflächen."
@@ -42544,7 +45921,9 @@
 #~ msgstr "Lese Eingabe-Dateien: Höhenwerte."
 #~ msgid "Elevation file's resolution differs from current region resolution"
-#~ msgstr "Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen Region."
+#~ msgstr ""
+#~ "Auflösung der Höhenkarte unterscheidet sich von der Auflösung der "
+#~ "aktuellen Region."
 #~ msgid "Reading input files: aspect"
 #~ msgstr "Lese Eingabe-Dateien: Exposition"
@@ -42582,8 +45961,12 @@
 #~ msgid "Unable to get current region"
 #~ msgstr "Kann die aktuelle Region nicht bekommen."
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr "Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)."
+#~ msgstr ""
+#~ "Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope "
+#~ "areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
 #~ msgid "Input elevation raster map"
 #~ msgstr "Eingabe-Rasterkarte, mit Höheninformationen"
@@ -42646,7 +46029,9 @@
 #~ msgstr "Unbekannter Fehler beim Erzeugen einer neuen Location."
 #~ msgid "One-character output separator, newline, comma, space, or tab"
-#~ msgstr "Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder Tabulator."
+#~ msgstr ""
+#~ "Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder "
+#~ "Tabulator."
 #~ msgid "Mapset to list (default: current search path)"
 #~ msgstr "Aufzulistendes Mapset (Standard: aktueller Suchpfad)."
@@ -42669,8 +46054,14 @@
 #~ msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
 #~ msgstr "Standardwert: GRASS_GUI wenn definiert, ansonsten wxpython"
-#~ msgid "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
-#~ msgstr "wxpython;wxPython basiertes GUI - wxGUI;tcltk;Tcl/Tk basiertes GUI - GIS Manager (gis.m);oldtcltk;Altes Tcl/Tkbasiertes GUI - Display Manager (d.m);text;Nur Kommandozeile"
+#~ msgid ""
+#~ "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
+#~ "(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;"
+#~ "command line interface only"
+#~ msgstr ""
+#~ "wxpython;wxPython basiertes GUI - wxGUI;tcltk;Tcl/Tk basiertes GUI - GIS "
+#~ "Manager (gis.m);oldtcltk;Altes Tcl/Tkbasiertes GUI - Display Manager (d."
+#~ "m);text;Nur Kommandozeile"
 #~ msgid "Name of workspace file"
 #~ msgstr "Name der Workspace-Datei."
@@ -42700,7 +46091,9 @@
 #~ msgstr "[%s@%s] ist die Ausgangskarte für [%s]. Löschen wurde erzwungen."
 #~ msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
-#~ msgstr "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
+#~ msgstr ""
+#~ "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: "
+#~ "%s"
 #~ msgid "Force remove"
 #~ msgstr "Erzwinge das Löschen"
@@ -42708,7 +46101,10 @@
 #~ msgid "%s file(s) to be removed"
 #~ msgstr "%s Datei(en), die entfernt werden sollen."
-#~ msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
+#~ msgid ""
+#~ "Copies available data files in the user's current mapset search path and "
+#~ "location to the appropriate element directories under the user's current "
+#~ "mapset."
 #~ msgstr "Kopiert die vorhandenen Daten in die aktuelle Mapset/Location."
 #~ msgid "%s file(s) to be copied"
@@ -42730,13 +46126,19 @@
 #~ msgstr "Name(n) existierender Rasterkarte(n)."
 #~ msgid "Name(s) of existing mapset(s) to add to search path"
-#~ msgstr "Name(n) existierender Mapset(s), die zum Suchpfad hinzugefügt werden sollen."
+#~ msgstr ""
+#~ "Name(n) existierender Mapset(s), die zum Suchpfad hinzugefügt werden "
+#~ "sollen."
 #~ msgid "Name(s) of existing mapset(s) to remove from search path"
-#~ msgstr "Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
+#~ msgstr ""
+#~ "Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden "
+#~ "sollen."
 #~ msgid "Special characters: newline, space, comma, tab"
-#~ msgstr "Trennzeichen für die Ausgabe: Zeilenumbruch, Komma, Leerzeichen oder Tabulator."
+#~ msgstr ""
+#~ "Trennzeichen für die Ausgabe: Zeilenumbruch, Komma, Leerzeichen oder "
+#~ "Tabulator."
 #~ msgid "Show mapset selection dialog"
 #~ msgstr "Zeige den Mapset Auswahl Dialog. "
@@ -42757,7 +46159,9 @@
 #~ msgstr "Die folgenden Karten würden gelöscht:"
 #~ msgid "You must use the force flag to actually remove them. Exiting."
-#~ msgstr "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende mich."
+#~ msgstr ""
+#~ "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. "
+#~ "Beende mich."
 #~ msgid "Removing %s <%s>"
 #~ msgstr "Entferne %s <%s>."
@@ -42783,8 +46187,11 @@
 #~ msgid "Changes current mapset."
 #~ msgstr "Ändere aktuelles Mapset."
-#~ msgid "GIS data directory (full path to the directory where the new location is)"
-#~ msgstr "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue Location befindet)."
+#~ msgid ""
+#~ "GIS data directory (full path to the directory where the new location is)"
+#~ msgstr ""
+#~ "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die "
+#~ "neue Location befindet)."
 #~ msgid "List available mapsets"
 #~ msgstr "Zeige alle verfügbaren Mapsets."
@@ -42796,16 +46203,24 @@
 #~ msgstr "Sie haben nicht die Berechtigung dieses Mapset zu verwenden."
 #~ msgid "The mapset does not exist. Use -c flag to create it."
-#~ msgstr "Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
+#~ msgstr ""
+#~ "Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu "
+#~ "erzeugen."
-#~ msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
-#~ msgstr "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann nicht überprüft werden."
+#~ msgid ""
+#~ "%s is currently running GRASS in selected mapset or lock file cannot be "
+#~ "checked"
+#~ msgstr ""
+#~ "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei "
+#~ "kann nicht überprüft werden."
 #~ msgid "Erasing monitors..."
 #~ msgstr "Lösche Monitore... "
 #~ msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-#~ msgstr "Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D- als auch 3D-Parameter)"
+#~ msgstr ""
+#~ "Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D- als auch 3D-"
+#~ "Parameter)"
 #~ msgid "Grid resolution 2D (both north-south and east-west)"
 #~ msgstr "2D Rasterauflösung (Nord-Süd und Ost-West)."
@@ -42855,8 +46270,17 @@
 #~ msgid "general, transformation, GCP"
 #~ msgstr "Allgemein, Transformation, GCP"
-#~ msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
-#~ msgstr "idx;Punkt Index;src;Quell-Koordinaten;dst;Ziel-Koordinaten;fwd;Vorwärts-Koordinaten (Ziel);rev;Rückwärts-Koordinaten (Quelle);fxy;Vorwärts-Koordinaten-Differenz (Ziel);rxy;Rückwärts-Koordinaten-Differenz (Quelle);fd;Vorwärts-Fehler (Ziel);rd;Rückwärts-Fehler (Quelle)"
+#~ msgid ""
+#~ "idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
+#~ "forward coordinates (destination);rev;reverse coordinates (source);fxy;"
+#~ "forward coordinates difference (destination);rxy;reverse coordinates "
+#~ "difference (source);fd;forward error (destination);rd;reverse error "
+#~ "(source)"
+#~ msgstr ""
+#~ "idx;Punkt Index;src;Quell-Koordinaten;dst;Ziel-Koordinaten;fwd;Vorwärts-"
+#~ "Koordinaten (Ziel);rev;Rückwärts-Koordinaten (Quelle);fxy;Vorwärts-"
+#~ "Koordinaten-Differenz (Ziel);rxy;Rückwärts-Koordinaten-Differenz (Quelle);"
+#~ "fd;Vorwärts-Fehler (Ziel);rd;Rückwärts-Fehler (Quelle)"
 #~ msgid "Location name"
 #~ msgstr "Name der Location"
@@ -42865,7 +46289,8 @@
 #~ msgstr "Datenbank, SQL"
 #~ msgid "List all databases for a given driver and location."
-#~ msgstr "Listet alle Datenbanken für den angegebenen Treiber und Location auf."
+#~ msgstr ""
+#~ "Listet alle Datenbanken für den angegebenen Treiber und Location auf."
 #~ msgid "Removes a database."
 #~ msgstr "Entfernt eine Datenbank."
@@ -42889,13 +46314,19 @@
 #~ msgstr "Datenbank, Attributtabelle, Verbindungseinstellungen"
 #~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und beendet sich."
+#~ msgstr ""
+#~ "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
+#~ "beendet sich."
 #~ msgid "Database schema"
 #~ msgstr "Datenbank-Schema"
-#~ msgid "Do not use this option if schemas are not supported by driver/database server"
-#~ msgstr "Bitte benutzen Sie diese Option nicht, wenn Schemas nicht durch ihre Datenbank / Server unterstützt werden."
+#~ msgid ""
+#~ "Do not use this option if schemas are not supported by driver/database "
+#~ "server"
+#~ msgstr ""
+#~ "Bitte benutzen Sie diese Option nicht, wenn Schemas nicht durch ihre "
+#~ "Datenbank / Server unterstützt werden."
 #~ msgid "Error trying to read dbmscap file"
 #~ msgstr "Fehler beim Lesen der dbmscap Datei"
@@ -42910,7 +46341,9 @@
 #~ msgstr "Name der Datei, die SQL-Befehle enthält"
 #~ msgid "Selects data from attribute table (performs SQL query statement(s))."
-#~ msgstr "Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) aus)."
+#~ msgstr ""
+#~ "Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) "
+#~ "aus)."
 #~ msgid "database, connection settings"
 #~ msgstr "Datenbank, Verbindungseinstellungen"
@@ -42974,7 +46407,8 @@
 #~ msgstr "Kann nicht zu MySQL verbinden."
 #~ msgid "Cannot parse MySQL embedded database name"
-#~ msgstr "Kann den Name der eingebetteten MySQL-Datenbank nicht interpretieren."
+#~ msgstr ""
+#~ "Kann den Name der eingebetteten MySQL-Datenbank nicht interpretieren."
 #~ msgid "Cannot connect to MySQL embedded server: "
 #~ msgstr "Kann mich nicht mit dem eingebetteten MySQL-Server verbinden."
@@ -42988,8 +46422,11 @@
 #~ msgid "Cannot recognize boolean value"
 #~ msgstr "Kann den Boolean-Wert nicht erkennen."
-#~ msgid "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
-#~ msgstr "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry'  wird nicht konvertiert."
+#~ msgid ""
+#~ "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
+#~ msgstr ""
+#~ "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry'  wird nicht "
+#~ "konvertiert."
 #~ msgid "pg driver: column '%s', type %d  is not supported"
 #~ msgstr "PG-Treiber: Spalte '%s', Typ %d wird nicht unterstützt."
@@ -43015,8 +46452,12 @@
 #~ msgid "Icon size"
 #~ msgstr "Symbolgröße"
-#~ msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
-#~ msgstr "nw;Nord-West Begrenzung;ne;Nord-Ost-Begrenzung;sw;Süd-West-Begrenzung;se;Süd-Ost-Begrenzung"
+#~ msgid ""
+#~ "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East "
+#~ "edge"
+#~ msgstr ""
+#~ "nw;Nord-West Begrenzung;ne;Nord-Ost-Begrenzung;sw;Süd-West-Begrenzung;se;"
+#~ "Süd-Ost-Begrenzung"
 #~ msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d)"
 #~ msgstr "Inkonsistente Attributanzahl (<%s/%s> %d: <%s> %d)."
@@ -43052,7 +46493,8 @@
 #~ msgstr "Teile horizontal und nicht vertikal."
 #~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr "Selektiert/Startet das angegebene Grafikfenster in der angegebenen Größe."
+#~ msgstr ""
+#~ "Selektiert/Startet das angegebene Grafikfenster in der angegebenen Größe."
 #~ msgid "display, setup"
 #~ msgstr "Darstellung, Setup"
@@ -43135,8 +46577,11 @@
 #~ msgid "Uncompressed GNS file from NGA (with .txt extension)"
 #~ msgstr "Unkomprimierte GNS-Datei von NGA (mit der Dateiendung .txt)."
-#~ msgid "Set color rules for features in a vector using a numeric attribute column."
-#~ msgstr "Bestimme Farbregeln für die Objekte einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
+#~ msgid ""
+#~ "Set color rules for features in a vector using a numeric attribute column."
+#~ msgstr ""
+#~ "Bestimme Farbregeln für die Objekte einer Vektorkarte unter Verwendung "
+#~ "einer numerischen Spalte der Attributtabelle."
 #~ msgid "vector, color table"
 #~ msgstr "Vektor, Farbtabellen"
@@ -43167,14 +46612,17 @@
 #~ msgstr "Vektorkarte, von der die Attributtabelle gelöscht werden soll."
 #~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr "Name einer existierenden Attributtabelle (Standard Name der Vektorkarte)."
+#~ msgstr ""
+#~ "Name einer existierenden Attributtabelle (Standard Name der Vektorkarte)."
 #~ msgid "Layer from which to drop linked attribute table"
 #~ msgstr "Layer aus dem die Attributtabelle gelöscht werden soll."
 #, fuzzy
 #~ msgid "Drapes a color raster over a shaded relief map using d.his."
-#~ msgstr "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter Verwendung von d.his."
+#~ msgstr ""
+#~ "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter "
+#~ "Verwendung von d.his."
 #~ msgid "Name of shaded relief or aspect map"
 #~ msgstr "Name der Schummerungs- oder Expositionskarte."
@@ -43189,7 +46637,8 @@
 #~ msgstr "Name der Datentabelle"
 #~ msgid "Column on which to calculate statistics (must be numeric)"
-#~ msgstr "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
+#~ msgstr ""
+#~ "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
 #~ msgid "Database/directory for table"
 #~ msgstr "Datenbank/Verzeichnis welches die Tabelle enthält."
@@ -43201,16 +46650,22 @@
 #~ msgstr "WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'."
 #~ msgid "Join column in map table"
-#~ msgstr "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
+#~ msgstr ""
+#~ "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
 #~ msgid "Join column in other table"
-#~ msgstr "Spalte in der anderen Tabelle, die für den Join verwendet werden soll."
+#~ msgstr ""
+#~ "Spalte in der anderen Tabelle, die für den Join verwendet werden soll."
 #~ msgid "run non-interactively"
 #~ msgstr "nicht interaktiv"
-#~ msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
-#~ msgstr "Importiert Wegpunkte, Routen und Tracks von einem GPS-Gerät oder einer GPS-Download-Datei in eine Vektorkarte. "
+#~ msgid ""
+#~ "Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+#~ "file into a vector map."
+#~ msgstr ""
+#~ "Importiert Wegpunkte, Routen und Tracks von einem GPS-Gerät oder einer "
+#~ "GPS-Download-Datei in eine Vektorkarte. "
 #~ msgid "vector, import, GPS"
 #~ msgstr "Vektor, Import, GPS"
@@ -43234,10 +46689,16 @@
 #~ msgstr "Gerät oder Datei, von der Daten importiert werden sollen.ei."
 #~ msgid "Format of GPS input data (use gpsbabel supported formats)"
-#~ msgstr "Format der GPS-Inputdaten (verwenden Sie von gpsbabel unterstützte Formate)."
+#~ msgstr ""
+#~ "Format der GPS-Inputdaten (verwenden Sie von gpsbabel unterstützte "
+#~ "Formate)."
-#~ msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-#~ msgstr "Projektion der Inputdaten (PROJ.4 Stil). Wenn nicht angegeben, wird Lat/Lon WGS84 angenommen."
+#~ msgid ""
+#~ "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is "
+#~ "assumed"
+#~ msgstr ""
+#~ "Projektion der Inputdaten (PROJ.4 Stil). Wenn nicht angegeben, wird Lat/"
+#~ "Lon WGS84 angenommen."
 #~ msgid "Import SRTM HGT files into GRASS"
 #~ msgstr "Importiert SRTM HGT Dateien nach GRASS."
@@ -43277,7 +46738,8 @@
 #~ msgstr "Zeichnen aller Fenster erneut."
 #~ msgid "Do not preserve individual regions when redrawing all frames"
-#~ msgstr "Erhalte keine individuellen Regionen beim Neuzeichnen aller Fenster."
+#~ msgstr ""
+#~ "Erhalte keine individuellen Regionen beim Neuzeichnen aller Fenster."
 #~ msgid "Display the HTML man pages of GRASS"
 #~ msgstr "Zeige die HTML-Handbuchseite von GRASS."
@@ -43330,8 +46792,12 @@
 #~ msgid "LANDSAT blue channel"
 #~ msgstr "LANDSAT blauer Kanal"
-#~ msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-#~ msgstr "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das von GpsBabel unterstützt wird."
+#~ msgid ""
+#~ "Exports a vector map to a GPS receiver or file format supported by "
+#~ "GpsBabel."
+#~ msgstr ""
+#~ "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, "
+#~ "das von GpsBabel unterstützt wird."
 #~ msgid "vector, export, GPS"
 #~ msgstr "Vektor, Export, GPS"
@@ -43339,8 +46805,12 @@
 #~ msgid "GpsBabel supported output format"
 #~ msgstr "GpsBabel unterstütze Ausgabeformate. "
-#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
-#~ msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
+#~ msgid ""
+#~ "A single vector map can be connected to multiple database tables. This "
+#~ "number determines which table to use."
+#~ msgstr ""
+#~ "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
+#~ "sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
 #~ msgid "Example: income < 1000 and inhab >= 10000"
 #~ msgstr "Beispiel: Einkommen < 1000 und Einwohner >= 10000"
@@ -43409,13 +46879,18 @@
 #~ msgstr "Tabellenname der SQL DB Tabelle."
 #~ msgid "Vector map for which to add new attribute table"
-#~ msgstr "Vektorkarte, zu der eine neue Attributtabelle hinzugefügt werden soll. "
+#~ msgstr ""
+#~ "Vektorkarte, zu der eine neue Attributtabelle hinzugefügt werden soll. "
 #~ msgid "Layer where to add new attribute table"
 #~ msgstr "Layer in dem die neue Attributtabelle hinzugefügt werden soll."
-#~ msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-#~ msgstr "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
+#~ msgid ""
+#~ "Name and type of the new column(s) (types depend on database backend, but "
+#~ "all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
+#~ msgstr ""
+#~ "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank "
+#~ "ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
 #~ msgid "Import E00 file into a vector map."
 #~ msgstr "Importiert eine E00-Datei in eine Vektorkarte."
@@ -43426,8 +46901,12 @@
 #~ msgid "Input type point, line or area"
 #~ msgstr "Eingabetyp Punkt, Linie oder Fläche."
-#~ msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
-#~ msgstr "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Gerät in eine Vektorkarte."
+#~ msgid ""
+#~ "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+#~ "vector map."
+#~ msgstr ""
+#~ "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Gerät in eine "
+#~ "Vektorkarte."
 #~ msgid "Download Waypoints from GPS"
 #~ msgstr "Lade Wegpunkte vom GPS."
@@ -43502,7 +46981,9 @@
 #~ msgstr "Layernummer: Wenn -1 angegeben wird, werden alle Layer ausgewählt."
 #~ msgid "Name of column used to dissolve common boundaries"
-#~ msgstr "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden soll."
+#~ msgstr ""
+#~ "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet "
+#~ "werden soll."
 #~ msgid "raster, mask"
 #~ msgstr "Raster, Maske"
@@ -43511,7 +46992,9 @@
 #~ msgstr "Rasterkarte, die als Maske (MASK) verwendet werden soll."
 #~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-#~ msgstr "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
+#~ msgstr ""
+#~ "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 "
 #~ msgid "Create inverse MASK from specified 'maskcats' list"
 #~ msgstr "Erzeuge eine inverse Maske aus der angegebenen 'maskcats' Liste."
@@ -43532,7 +47015,9 @@
 #~ msgstr "Bestimme Farbregeln basierend auf den Standardabweichungen."
 #~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-#~ msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
+#~ msgstr ""
+#~ "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *."
+#~ "mosaic-Karten."
 #~ msgid "raster, imagery, mosaicking"
 #~ msgstr "Raster, Bildverarbeitung, Mosaikieren"
@@ -43595,7 +47080,9 @@
 #~ msgstr "Weitere Optionen für r.tileset"
 #~ msgid "Named region to request data for. Current region used if omitted"
-#~ msgstr "Benannte Region, für die Daten angefragt werden sollen. Wenn nicht angegeben wird die aktuelle Region verwendet."
+#~ msgstr ""
+#~ "Benannte Region, für die Daten angefragt werden sollen. Wenn nicht "
+#~ "angegeben wird die aktuelle Region verwendet."
 #~ msgid "Folder to save downloaded data to"
 #~ msgstr "Verzeichnis um heruntergeladene Daten zu speichern."
@@ -43626,20 +47113,28 @@
 #, fuzzy
 #~ msgid "Varchar values must be in single quotes, e.g. 'grass'"
-#~ msgstr "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
+#~ msgstr ""
+#~ "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in "
+#~ "einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
 #, fuzzy
 #~ msgid "Name of attribute column to query"
 #~ msgstr "Name der Attributespalte verwendet mit der 'query'-Option."
-#~ msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
-#~ msgstr "WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z.B. cat=1 or col1/col2>1)."
+#~ msgid ""
+#~ "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
+#~ "col2>1)"
+#~ msgstr ""
+#~ "WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z."
+#~ "B. cat=1 or col1/col2>1)."
 #~ msgid "Table to drop"
 #~ msgstr "Tabelle die gelöscht werden soll."
 #~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-#~ msgstr "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs Frontend)."
+#~ msgstr ""
+#~ "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs "
+#~ "Frontend)."
 #~ msgid "miscellaneous, projection"
 #~ msgstr "Verschiedenes, Projektion"
@@ -43648,16 +47143,24 @@
 #~ msgstr "Eingabe-Koordinatendatei (auslassen für lesen von stdin)."
 #~ msgid "Output coordinate file (omit to send to stdout)"
-#~ msgstr "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden soll)."
+#~ msgstr ""
+#~ "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben "
+#~ "werden soll)."
-#~ msgid "Script style output in CSV format respecting the field separator settings"
-#~ msgstr "Ausgabe im Skript-Style im CSV-Format unter Beachtung der Feldtrenner-Einstellungen."
+#~ msgid ""
+#~ "Script style output in CSV format respecting the field separator settings"
+#~ msgstr ""
+#~ "Ausgabe im Skript-Style im CSV-Format unter Beachtung der Feldtrenner-"
+#~ "Einstellungen."
 #~ msgid "Verbose mode (print projection parameters and filenames to stderr)"
-#~ msgstr "Gesprächiger Modus (Gebe Projektionsparameter und Dateinamen auf stderr aus)."
+#~ msgstr ""
+#~ "Gesprächiger Modus (Gebe Projektionsparameter und Dateinamen auf stderr "
+#~ "aus)."
 #~ msgid "Vector map for which to drop attribute column"
-#~ msgstr "Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
+#~ msgstr ""
+#~ "Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
 #~ msgid "Layer where to drop column"
 #~ msgstr "Layer, in dem eine Spalte gelöscht werden soll."
@@ -43671,14 +47174,22 @@
 #~ msgid "Name of .dmrc settings file"
 #~ msgstr "Name der .dmrc Datei."
-#~ msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
-#~ msgstr "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative DGMs mit Hilfe von gdalwarp."
+#~ msgid ""
+#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+#~ "using gdalwarp."
+#~ msgstr ""
+#~ "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und "
+#~ "relative DGMs mit Hilfe von gdalwarp."
 #~ msgid "Input ASTER image to be georeferenced & rectified"
 #~ msgstr "Eingabe-ASTER-Bild, das georeferenziert und rektifiziert wird."
-#~ msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
-#~ msgstr "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein einzelnen Kanal umrechnen."
+#~ msgid ""
+#~ "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
+#~ "single band"
+#~ msgstr ""
+#~ "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein "
+#~ "einzelnen Kanal umrechnen."
 #~ msgid "Name of raster map to generate legend from"
 #~ msgstr "Name der Rasterkarte von der eine Legende erzeugt werden soll."
@@ -43689,8 +47200,12 @@
 #~ msgid "Position of vertical map-legend separator (in percent)"
 #~ msgstr "Position der vertikalen Legenden Trennelemente (in Prozent)."
-#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-#~ msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
+#~ "und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
 #~ msgid "vector, raster, statistics"
 #~ msgstr "Vektor, Raster, Statistik"
@@ -43698,23 +47213,35 @@
 #~ msgid "Name of vector polygon map"
 #~ msgstr "Name der Vektorkarte (Polygone)."
-#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
+#~ msgid ""
+#~ "number determines which table to use"
+#~ msgstr ""
 #~ msgid "Name of raster map to calculate statistics from"
 #~ msgstr "Name der Rasterkarte für die Statistiken berechnet werden sollen."
-#~ msgid "Divides active display into two frames & displays maps/executes commands in each frame."
-#~ msgstr "Teilt das aktive Grafikfenster in zwei Fenster & zeigt Karten und führt Befehle in beiden Fenstern aus."
+#~ msgid ""
+#~ "Divides active display into two frames & displays maps/executes commands "
+#~ "in each frame."
+#~ msgstr ""
+#~ "Teilt das aktive Grafikfenster in zwei Fenster & zeigt Karten und führt "
+#~ "Befehle in beiden Fenstern aus."
 #~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "Geben Sie den Name der Rasterkarte ein, die im 1. Fenster gezeigt werden soll."
+#~ msgstr ""
+#~ "Geben Sie den Name der Rasterkarte ein, die im 1. Fenster gezeigt werden "
+#~ "soll."
 #~ msgid "Enter command to execute in 1st frame"
 #~ msgstr "Geben Sie den Befehl an, der im 1. Rahmen ausgeführt werden soll."
 #~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "Geben Sie den Name der Rasterkarte ein, die im 2. Fenster gezeigt werden soll."
+#~ msgstr ""
+#~ "Geben Sie den Name der Rasterkarte ein, die im 2. Fenster gezeigt werden "
+#~ "soll."
 #~ msgid "Enter command to execute in 2nd frame"
 #~ msgstr "Geben Sie den Befehl an, der im 2. Rahmen ausgeführt werden soll."
@@ -43750,7 +47277,8 @@
 #~ msgstr "Name der Datei mit den Einstellungen des GIS-Managers (.grc)."
 #~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr "Exportiert das Grafikfenster in ein GpsDrive-kompatibles Hintergrundbild."
+#~ msgstr ""
+#~ "Exportiert das Grafikfenster in ein GpsDrive-kompatibles Hintergrundbild."
 #~ msgid "display, export, GPS"
 #~ msgstr "Anzeige, Export, GPS"
@@ -43771,7 +47299,9 @@
 #~ msgstr "Zeige eher Vektorkarten als Rasterkarten."
 #~ msgid "Map prefix. Specify character(s) to view selected maps only"
-#~ msgstr "Karten-Präfix. Bestimmen Sie Buchstaben um nur ausgewählte Karten anzusehen."
+#~ msgstr ""
+#~ "Karten-Präfix. Bestimmen Sie Buchstaben um nur ausgewählte Karten "
+#~ "anzusehen."
 #~ msgid "Map number show across the monitor"
 #~ msgstr "Zeige die Kartenummer waagerecht im Grafikfenster."
@@ -43780,7 +47310,9 @@
 #~ msgstr "Zeige die Kartenummer senkrecht im Grafikfenster."
 #~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr "ZU verwendendes Mapset. Geben Sie mehrere Mapsets durch Kommas getrennt an."
+#~ msgstr ""
+#~ "ZU verwendendes Mapset. Geben Sie mehrere Mapsets durch Kommas getrennt "
+#~ "an."
 #~ msgid "Number of seconds to pause between slides"
 #~ msgstr "Pause zwischen den Bildern in Sekunden."
@@ -43791,8 +47323,11 @@
 #~ msgid "Import ASCII x,y[,z] coordinates as a series of lines."
 #~ msgstr "Importiere ASCII x,y[,z] Koordinaten als Folge von Linie(n)."
-#~ msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
-#~ msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
+#~ msgid ""
+#~ "Brovey transform to merge multispectral and high-res panchromatic channels"
+#~ msgstr ""
+#~ "Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
+#~ "panchromatischer Kanäle."
 #~ msgid "imagery, fusion, Brovey"
 #~ msgstr "Bildverarbeitung, Fusion, Brovery"
@@ -43822,7 +47357,9 @@
 #~ msgstr "Präfix für die Ausgabe-Rasterkarten (z.B. 'brov')."
 #~ msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-#~ msgstr "Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
+#~ msgstr ""
+#~ "Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, "
+#~ "& 7."
 #~ msgid "raster, imagery, statistics"
 #~ msgstr "Raster, Bildverarbeitung, Statistik"
@@ -43835,7 +47372,9 @@
 #~ msgstr "Eingabe-Rasterkarte"
 #~ msgid "Tool to maintain GRASS extensions in local GRASS installation."
-#~ msgstr "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu verwalten."
+#~ msgstr ""
+#~ "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu "
+#~ "verwalten."
 #~ msgid "general, extensions"
 #~ msgstr "Allgemein, Erweiterungen"
@@ -43852,7 +47391,8 @@
 #~ msgid "Install system-wide using sudo"
 #~ msgstr "Systemweit installieren mit sudo"
-#~ msgid "Export a raster map to a text file as x,y,z values based on cell centers."
+#~ msgid ""
+#~ "Export a raster map to a text file as x,y,z values based on cell centers."
 #~ msgstr "."
 #~ msgid "calculates univariate statistics from a GRASS raster map"
@@ -43874,7 +47414,9 @@
 #~ msgstr "GetFeature URL beginnend mit 'http'"
 #~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "Speichert den Inhalt des aktiven Grafikfensters in einer PNG-Datei im Heimat-Verzeichnis."
+#~ msgstr ""
+#~ "Speichert den Inhalt des aktiven Grafikfensters in einer PNG-Datei im "
+#~ "Heimat-Verzeichnis."
 #~ msgid "display, export"
 #~ msgstr "Anzeige, Export"
@@ -43892,7 +47434,8 @@
 #~ msgstr "Layer, in dem der Spaltenname geändert werden soll."
 #~ msgid "Base name for red, green and blue output maps containing the blend"
-#~ msgstr "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
+#~ msgstr ""
+#~ "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
 #~ msgid "Name for output file (do NOT add extension)"
 #~ msgstr "Name für die Ausgabedatei (Fügen Sie keine Dateiendung an)."
@@ -43904,13 +47447,17 @@
 #~ msgstr "(einfach=1, doppelte Größe=2, vierfache Größe=4)"
 #~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr "Breite und Höhe des auszugebenden Bildes (übersteuert die Einstellung der Auflösung)."
+#~ msgstr ""
+#~ "Breite und Höhe des auszugebenden Bildes (übersteuert die Einstellung der "
+#~ "Auflösung)."
 #~ msgid "Compression for PNG files"
 #~ msgstr "Komprimierung für PNG-Dateien."
 #~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-#~ msgstr "(0=keine, 1=schnellste, 9=am meisten; verlustfrei, nur Zeit vs. Dateigröße)."
+#~ msgstr ""
+#~ "(0=keine, 1=schnellste, 9=am meisten; verlustfrei, nur Zeit vs. "
+#~ "Dateigröße)."
 #~ msgid "File size/quality for JPEG files"
 #~ msgstr "Dateigröße/-qualität für JPEG-Dateien."
@@ -43936,8 +47483,11 @@
 #~ msgid "GeoTIFF metadata key(s) and value(s) to add"
 #~ msgstr "GeoTIFF Metadaten Schlüsselwort(e) und Wert(e)"
-#~ msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
-#~ msgstr "In der Form \"META-TAG=WERT\", trennen Sie mehrere Paare durch Kommas voneinander."
+#~ msgid ""
+#~ "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+#~ msgstr ""
+#~ "In der Form \"META-TAG=WERT\", trennen Sie mehrere Paare durch Kommas "
+#~ "voneinander."
 #~ msgid "Set background color to black (white default)"
 #~ msgstr "Setze die Hintergrundfarbe auf schwarz (Standard: weiß)."
@@ -43949,7 +47499,9 @@
 #~ msgstr "Verwende der Cairo-Treiber um das Bild zu rendern."
 #~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr "Stelle die Orientierung der Seite auf Querformat (für die PostScript-Ausgabe)."
+#~ msgstr ""
+#~ "Stelle die Orientierung der Seite auf Querformat (für die PostScript-"
+#~ "Ausgabe)."
 #~ msgid "Do not crop away margins"
 #~ msgstr "Schneide die Ränder nicht ab."
@@ -43961,10 +47513,15 @@
 #~ msgstr "Name der Schummerungskarte."
 #~ msgid "Scale factor for converting horizontal units to elevation units"
-#~ msgstr "Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu Höheneinheiten"
+#~ msgstr ""
+#~ "Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu "
+#~ "Höheneinheiten"
-#~ msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-#~ msgstr "Bestimmt den Skalierungsfaktor (nur für lat./long. Locations, kein Wert: scale=1)."
+#~ msgid ""
+#~ "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+#~ msgstr ""
+#~ "Bestimmt den Skalierungsfaktor (nur für lat./long. Locations, kein Wert: "
+#~ "scale=1)."
 #~ msgid "Reconnects vectors to a new database."
 #~ msgstr "Verbindet Vektor mit einer neuen Datenbank."
@@ -43972,8 +47529,12 @@
 #~ msgid "Name of old database"
 #~ msgstr "Name der alten Datenbank."
-#~ msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
-#~ msgstr "Die Datenbank muß in der Form angegeben werden , wie sie von v.db.connect -g ausgegeben wird, z.B mit ersetzten Variablen."
+#~ msgid ""
+#~ "The database must be in form printed by v.db.connect -g, i.e. with "
+#~ "substituted variables"
+#~ msgstr ""
+#~ "Die Datenbank muß in der Form angegeben werden , wie sie von v.db.connect "
+#~ "-g ausgegeben wird, z.B mit ersetzten Variablen."
 #~ msgid "Name of new database"
 #~ msgstr "Name der neuen Datenbank."
@@ -44011,11 +47572,16 @@
 #~ msgid "Region sensitive output"
 #~ msgstr "Regionsensitive Ausgabe"
-#~ msgid "Creation option to the output format driver. Multiple options may be listed"
-#~ msgstr "Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere Optionen angegeben werden."
+#~ msgid ""
+#~ "Creation option to the output format driver. Multiple options may be "
+#~ "listed"
+#~ msgstr ""
+#~ "Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere "
+#~ "Optionen angegeben werden."
 #~ msgid "Metadata key passed on the output dataset if possible"
-#~ msgstr "Metadaten werden, wen möglich, an den Ausgabedatensatz weitergegeben."
+#~ msgstr ""
+#~ "Metadaten werden, wen möglich, an den Ausgabedatensatz weitergegeben."
 #~ msgid "display, networking"
 #~ msgstr "Darstellung, Netzwerk"
@@ -44102,13 +47668,18 @@
 #~ msgstr "unten,oben,links,rechts"
 #~ msgid "Where to place the frame, values in percent (implies -c)"
-#~ msgstr "Wo soll das Fenster platziert werden? Werte in Prozent (impliziert -c)."
+#~ msgstr ""
+#~ "Wo soll das Fenster platziert werden? Werte in Prozent (impliziert -c)."
 #~ msgid "display, distance"
 #~ msgstr "Darstellung, Distanz"
-#~ msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
-#~ msgstr "Stellt im aktiven Grafikfenster die Kompasslinie dar, die zwei vom Benutzer angegebene Punkte verbindet."
+#~ msgid ""
+#~ "Displays the rhumbline joining two user-specified points, in the active "
+#~ "frame on the user's graphics monitor."
+#~ msgstr ""
+#~ "Stellt im aktiven Grafikfenster die Kompasslinie dar, die zwei vom "
+#~ "Benutzer angegebene Punkte verbindet."
 #~ msgid "Use mouse to size & place legend"
 #~ msgstr "Benutze Maus zum Plazieren und zur Größeneinstellung der Legende."
@@ -44129,7 +47700,9 @@
 #~ msgstr "Größe des Gitters."
 #~ msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
-#~ msgstr "In Karteneinheiten oder im DDD:MM:SS Format.  Beispiel: \"1000\" oder \"0:10\""
+#~ msgstr ""
+#~ "In Karteneinheiten oder im DDD:MM:SS Format.  Beispiel: \"1000\" oder "
+#~ "\"0:10\""
 #~ msgid "Y input file <%s> contains %s data points than the X input file"
 #~ msgstr "Y-Eingabedatei <%s> enthält %s Datenpunkte als die X-Eingabedatei."
@@ -44137,23 +47710,41 @@
 #~ msgid "The last %d point(s) will be ignored"
 #~ msgstr "Die letzten %d Punkte werden ignoriert."
-#~ msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
-#~ msgstr "int;einfache Intervalle;std;Standardabweichungen;qua;Quantile;equ;gleichwahrscheinlich(Normalverteilung);"
+#~ msgid ""
+#~ "int;simple intervals;std;standard deviations;qua;quantiles;equ;"
+#~ "equiprobable (normal distribution);"
+#~ msgstr ""
+#~ "int;einfache Intervalle;std;Standardabweichungen;qua;Quantile;equ;"
+#~ "gleichwahrscheinlich(Normalverteilung);"
 #~ msgid "Rendering method for filled polygons"
 #~ msgstr "Render-Methode für gefüllte Polygone."
-#~ msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
-#~ msgstr "d;Verwende grundlegende Funktion der Displaybibliothek (Objekte: Polylinien);c;Verwende Clipping-Funktion der Displaybibliothek (Objekte: abschneiden);l;Verwende Culling-Funktion der Displaybibliothek (Objekte: Beschneiden, Polylinien)"
+#~ msgid ""
+#~ "d;use the display library basic functions (features: polylines);c;use the "
+#~ "display library clipping functions (features: clipping);l;use the display "
+#~ "library culling functions (features: culling, polylines)"
+#~ msgstr ""
+#~ "d;Verwende grundlegende Funktion der Displaybibliothek (Objekte: "
+#~ "Polylinien);c;Verwende Clipping-Funktion der Displaybibliothek (Objekte: "
+#~ "abschneiden);l;Verwende Culling-Funktion der Displaybibliothek (Objekte: "
+#~ "Beschneiden, Polylinien)"
 #~ msgid "Invalid rendering method <%s>"
 #~ msgstr "Ungültige Render-Methode <%s>."
-#~ msgid "Erase the contents of the active display frame with user defined color"
-#~ msgstr "Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten Farbe."
+#~ msgid ""
+#~ "Erase the contents of the active display frame with user defined color"
+#~ msgstr ""
+#~ "Löscht den Inhalte des aktiven Grafikfensters mit einer "
+#~ "benutzerdefinierten Farbe."
-#~ msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "Farbe zum Löschen, entweder als GRASS Standard-Farbe oder als R:G:B-Tripel (Semicolon als Trennzeichen)."
+#~ msgid ""
+#~ "Color to erase with, either a standard GRASS color or R:G:B triplet "
+#~ "(separated by colons)"
+#~ msgstr ""
+#~ "Farbe zum Löschen, entweder als GRASS Standard-Farbe oder als R:G:B-"
+#~ "Tripel (Semicolon als Trennzeichen)."
 #~ msgid "No current frame"
 #~ msgstr "Kein aktueller Frame."
@@ -44167,8 +47758,17 @@
 #~ msgid "display, vector"
 #~ msgstr "Darstellung, Vektor"
-#~ msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
-#~ msgstr "shape;Anzeige der Geometrie der Objekte;cat;Anzeige der Kategorienummern der Objekte;topo;Anzeige der Topologieinformationen (nodes, edges);dir;Anzeige der Richtung von linearen Objekten;attr;Anzeige der ausgewählten Attribute basierend auf 'attrcol';zcoor;Anzeige der z-Kooridinate der Objekte (nur für 3D Vektorkarten)"
+#~ msgid ""
+#~ "shape;Display geometry of features;cat;Display category numbers of "
+#~ "features;topo;Display topology information (nodes, edges);dir;Display "
+#~ "direction of linear features;attr;Display selected attribute based on "
+#~ "'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
+#~ msgstr ""
+#~ "shape;Anzeige der Geometrie der Objekte;cat;Anzeige der Kategorienummern "
+#~ "der Objekte;topo;Anzeige der Topologieinformationen (nodes, edges);dir;"
+#~ "Anzeige der Richtung von linearen Objekten;attr;Anzeige der ausgewählten "
+#~ "Attribute basierend auf 'attrcol';zcoor;Anzeige der z-Kooridinate der "
+#~ "Objekte (nur für 3D Vektorkarten)"
 #~ msgid "Layer number (if -1, all layers are displayed)"
 #~ msgstr "Layernummer (wenn -1, alle Layer werden dargestellt)."
@@ -44176,8 +47776,10 @@
 #~ msgid "Type of color table (for use with -z flag)"
 #~ msgstr "Art der Farbtabelle (für die Verwendung mit dem Schalter -z)."
-#~ msgid "Name of column for line widths (these values will be scaled by wscale)"
-#~ msgstr "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
+#~ msgid ""
+#~ "Name of column for line widths (these values will be scaled by wscale)"
+#~ msgstr ""
+#~ "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
 #~ msgid "Scale factor for wcolumn"
 #~ msgstr "Skalierungsfaktor für wcolumn"
@@ -44185,20 +47787,40 @@
 #~ msgid "Name of column to be displayed"
 #~ msgstr "Name der Spalte, die angezeigt werden soll."
-#~ msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
-#~ msgstr "g;Verwende Render-Funktion von libgis (Objekte: clippen);r;verwende Render-Funktion der Rastergrafik-Bibliothek (Objekte: Polylinien);d;Verwende grundlegende Funktionen der Displaybibliothek (Objekte: Polylinien);c;Verwende Clipping-Funktion der Displaybibliothek (Objekte: clippen);l;Verwende Culling-Funktion der der Displaybibliothek (Objekte: Beschneiden, Polylinien)"
+#~ msgid ""
+#~ "g;use the libgis render functions (features: clipping);r;use the raster "
+#~ "graphics library functions (features: polylines);d;use the display "
+#~ "library basic functions (features: polylines);c;use the display library "
+#~ "clipping functions (features: clipping);l;use the display library culling "
+#~ "functions (features: culling, polylines)"
+#~ msgstr ""
+#~ "g;Verwende Render-Funktion von libgis (Objekte: clippen);r;verwende "
+#~ "Render-Funktion der Rastergrafik-Bibliothek (Objekte: Polylinien);d;"
+#~ "Verwende grundlegende Funktionen der Displaybibliothek (Objekte: "
+#~ "clippen);l;Verwende Culling-Funktion der der Displaybibliothek (Objekte: "
 #~ msgid "Get colors from map table column (of form RRR:GGG:BBB)"
 #~ msgstr "Hole die Farbe aus der Tabellenspalte (RRR:GGG:BBB)."
-#~ msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
-#~ msgstr "Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen (Die Vektorkarte wird nicht gezeichnet, wenn das Grafikfenster aktualisiert wird)."
+#~ msgid ""
+#~ "Don't add to list of vectors and commands in monitor (it won't be drawn "
+#~ "if the monitor is refreshed)"
+#~ msgstr ""
+#~ "Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen "
+#~ "(Die Vektorkarte wird nicht gezeichnet, wenn das Grafikfenster "
+#~ "aktualisiert wird)."
 #~ msgid "Colorize polygons according to z height"
 #~ msgstr "Färbe die Polygone gemäß ihrer Z-Höhe."
-#~ msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
-#~ msgstr "Die Schalter '-c' und '-a' können nicht gemeinsam verwendet werden. Der Schalter '-c' wird ignoriert!"
+#~ msgid ""
+#~ "The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
+#~ "ignored!"
+#~ msgstr ""
+#~ "Die Schalter '-c' und '-a' können nicht gemeinsam verwendet werden. Der "
+#~ "Schalter '-c' wird ignoriert!"
 #~ msgid "'layer' must be > 0 for 'cats'."
 #~ msgstr "'Layer' muss > 0 sein für den Parameter 'cats'."
@@ -44207,10 +47829,13 @@
 #~ msgstr "%d Fehler in cat Option."
 #~ msgid "Unable to display areas, topology not available"
-#~ msgstr "Kann Flächen nicht darstellen, da die Topologie nicht vorhanden ist."
+#~ msgstr ""
+#~ "Kann Flächen nicht darstellen, da die Topologie nicht vorhanden ist."
 #~ msgid "Unable to display lines by id, topology not available"
-#~ msgstr "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht vorhanden ist."
+#~ msgstr ""
+#~ "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht "
+#~ "vorhanden ist."
 #~ msgid "Unable to display topology, not available"
 #~ msgstr "Kann die Topologie nicht darstellen, da sie nicht vorhanden ist."
@@ -44218,11 +47843,16 @@
 #~ msgid "Color definition column not specified."
 #~ msgstr "Farbspalte nicht angegeben."
-#~ msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-#~ msgstr "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d: Farbwert [%s]."
+#~ msgid ""
+#~ "Error in color definition column (%s), area %d with cat %d: colorstring "
+#~ "[%s]"
+#~ msgstr ""
+#~ "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d: "
+#~ "Farbwert [%s]."
 #~ msgid "Error in color definition column (%s), area %d with cat %d"
-#~ msgstr "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d."
+#~ msgstr ""
+#~ "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d."
 #~ msgid "Line width column (%s) is not numeric."
 #~ msgstr "Spalte mit der Linienbreite (%s) ist nicht numerisch."
@@ -44242,14 +47872,22 @@
 #~ msgid "Unable to read symbol, unable to display points"
 #~ msgstr "Kann das Symbol nicht lesen; kann die Punkte nicht darstellen."
-#~ msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
-#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', Objekt ID %d mit cat %d: Farbwert '%s'."
+#~ msgid ""
+#~ "Error in color definition column '%s', feature id %d with cat %d: "
+#~ "colorstring '%s'"
+#~ msgstr ""
+#~ "Fehler in der Spalte mit den Farbwerten '%s', Objekt ID %d mit cat %d: "
+#~ "Farbwert '%s'."
 #~ msgid "Error in color definition column '%s', feature id %d with cat %d"
-#~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', Objekt ID %d mit cat %d"
+#~ msgstr ""
+#~ "Fehler in der Spalte mit den Farbwerten '%s', Objekt ID %d mit cat %d"
-#~ msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-#~ msgstr "Fehler in der Symbolgrößen-Spalte (%s), Element %d mit cat %d: Symbolgröße [%f]."
+#~ msgid ""
+#~ "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
+#~ msgstr ""
+#~ "Fehler in der Symbolgrößen-Spalte (%s), Element %d mit cat %d: "
+#~ "Symbolgröße [%f]."
 #~ msgid "Error in color definition column '%s': %d features affected"
 #~ msgstr "Fehler in der Spalte mit den Farbwerten '%s', %d Objekte betroffen."
@@ -44257,8 +47895,12 @@
 #~ msgid "display, position, querying"
 #~ msgstr "Darstellung, Position, Abfrage"
-#~ msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
-#~ msgstr "Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-Fenster."
+#~ msgid ""
+#~ "Identifies the geographic coordinates associated with point locations in "
+#~ "the active frame on the graphics monitor."
+#~ msgstr ""
+#~ "Identifiziert geographische Koordinaten an einem gegebenen Punkt im "
+#~ "Grafik-Fenster."
 #~ msgid "One mouse click only"
 #~ msgstr "Nur ein Mausklick."
@@ -44266,11 +47908,19 @@
 #~ msgid "value [%.0f,%.0f] out of range [0-100]"
 #~ msgstr "Wert [%.0f,%.0f] außerhalb der Spanne [0-100]"
-#~ msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
-#~ msgstr "<%s> ist eine Fließkommakarte. Ignoriere [lines] und zeichne einen kontinuierlichen Farbverlauf."
+#~ msgid ""
+#~ "<%s> is a floating point map. Ignoring [lines] and drawing continuous "
+#~ "color ramp"
+#~ msgstr ""
+#~ "<%s> ist eine Fließkommakarte. Ignoriere [lines] und zeichne einen "
+#~ "kontinuierlichen Farbverlauf."
-#~ msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
-#~ msgstr "<%s> ist eine Fließkommakarte. Ignoriere [cols] und zeichne einen kontinuierlichen Farbverlauf."
+#~ msgid ""
+#~ "<%s> is a floating point map. Ignoring [cols] and drawing continuous "
+#~ "color ramp"
+#~ msgstr ""
+#~ "<%s> ist eine Fließkommakarte. Ignoriere [cols] und zeichne einen "
 #~ msgid "R_color file for [%s] not available"
 #~ msgstr "Farbdatei für [%s] nicht vorhanden."
@@ -44278,14 +47928,26 @@
 #~ msgid "Range file for [%s] not available"
 #~ msgstr "Range-Dateien für [%s] nicht vorhanden. "
-#~ msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
-#~ msgstr "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafikfenster dar."
+#~ msgid ""
+#~ "Generates and displays simple graphics on map layers drawn in the active "
+#~ "graphics monitor display frame."
+#~ msgstr ""
+#~ "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafikfenster "
+#~ "dar."
-#~ msgid "Unix file containg graphing instructions, if not given reads from standard input"
-#~ msgstr "Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht angegeben ist, wird von der Standardeingabe gelesen."
+#~ msgid ""
+#~ "Unix file containg graphing instructions, if not given reads from "
+#~ "standard input"
+#~ msgstr ""
+#~ "Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht "
+#~ "angegeben ist, wird von der Standardeingabe gelesen."
-#~ msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B Tripel (durch Doppelpunkte getrennt)."
+#~ msgid ""
+#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
+#~ msgstr ""
+#~ "Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B "
+#~ "Tripel (durch Doppelpunkte getrennt)."
 #~ msgid "display, metadata"
 #~ msgstr "Anzeige, Metadaten"
@@ -44312,7 +47974,8 @@
 #~ msgstr "Darstellung, Raster, Profil"
 #~ msgid "Interactive profile plotting utility with optional output."
-#~ msgstr "Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
+#~ msgstr ""
+#~ "Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
 #~ msgid "Optional display raster"
 #~ msgstr "optionale Ansichts-Rasterkarte"
@@ -44321,7 +47984,8 @@
 #~ msgstr "Gebe Profildaten in Datei(en) mit dem Prefix 'name'."
 #~ msgid "Display raster [%s] not found. Using profile raster."
-#~ msgstr "Zu zeigendes Rasterkarte [%s] nicht gefunden. Verwende Profilraster."
+#~ msgstr ""
+#~ "Zu zeigendes Rasterkarte [%s] nicht gefunden. Verwende Profilraster."
 #~ msgid ""
 #~ "\n"
@@ -44333,7 +47997,8 @@
 #~ "Verwenden Sie die Maus, um eine Aktion auszuwählen."
 #~ msgid "Use 'd.frame -e' to remove left over frames"
-#~ msgstr "Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
+#~ msgstr ""
+#~ "Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
 #~ msgid "Error opening cell-file"
 #~ msgstr "Fehler beim Öffnen der Zell-Datei."
@@ -44399,7 +48064,9 @@
 #~ msgstr " Rechts:  Beenden\n"
 #~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten sollen.\n"
+#~ msgstr ""
+#~ " Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten "
+#~ "sollen.\n"
 #~ msgid "Enable flashing (slower)"
 #~ msgstr "Aufleuchten anschalten (ist langsamer)."
@@ -44407,8 +48074,12 @@
 #~ msgid "display, map management"
 #~ msgstr "Darstellung, Kartenverwaltung"
-#~ msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
-#~ msgstr "Bittet den Benutzer eine GRASS Datenbankdatei aus den im Menü präsentierten Dateien im Grafikfenster auszuwählen."
+#~ msgid ""
+#~ "Prompts the user to select a GRASS data base file from among files "
+#~ "displayed in a menu on the graphics monitor."
+#~ msgstr ""
+#~ "Bittet den Benutzer eine GRASS Datenbankdatei aus den im Menü "
+#~ "präsentierten Dateien im Grafikfenster auszuwählen."
 #~ msgid "Database element, one word description"
 #~ msgstr "Datenbankelement, ein Wort Beschreibung"
@@ -44443,18 +48114,25 @@
 #~ msgid "display, histogram, statistics"
 #~ msgstr "Darstellung, Histogramm, Statistik"
-#~ msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
-#~ msgstr "Überlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-Fenster."
+#~ msgid ""
+#~ "Overlays cell category values on a raster map layer displayed to the "
+#~ "graphics monitor."
+#~ msgstr ""
+#~ "Überlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-"
+#~ "Fenster."
 #~ msgid "No raster map exists in current window"
 #~ msgstr "Es existiert keine Rasterkarte im aktuellen Fenster."
 #~ msgid ""
 #~ "Current region size: %d rows X %d cols\n"
-#~ "Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
+#~ "Your current region setting may be too large. Cells displayed on your "
+#~ "graphics window may be too small for cell category number to be visible."
 #~ msgstr ""
 #~ "Aktuelle Region: %d rows X %d cols\n"
-#~ "Ihre aktuelle Fenstereinstellung könnte zu groß sein. Die im Grafikfenster dargestellten Zellen könnten zu klein sein, um die Kategorien lesen zu können."
+#~ "Ihre aktuelle Fenstereinstellung könnte zu groß sein. Die im "
+#~ "Grafikfenster dargestellten Zellen könnten zu klein sein, um die "
+#~ "Kategorien lesen zu können."
 #~ msgid "Can't clear current graphics window"
 #~ msgstr "Kann aktuelles Grafikfenster nicht säubern."
@@ -44487,16 +48165,27 @@
 #~ msgstr "Verwende Standard-Ansicht %s"
 #~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr "Erstelle eine Liste von Kommandos zum Wiederherstellen der Bildschirmgrafik."
+#~ msgstr ""
+#~ "Erstelle eine Liste von Kommandos zum Wiederherstellen der "
+#~ "Bildschirmgrafik."
 #~ msgid "Name of frame(s) to save"
 #~ msgstr "Name der Rahmen zum speichern."
-#~ msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
-#~ msgstr "Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" angezeigt werden. -1 steht für das letzte Objekt."
+#~ msgid ""
+#~ "List of object numbers to remove which are displayed after \"#\". -1 for "
+#~ "the last object."
+#~ msgstr ""
+#~ "Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" "
+#~ "angezeigt werden. -1 steht für das letzte Objekt."
-#~ msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
-#~ msgstr "Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach\"). Falls eine Option angegeben wurde, wird remove= als erstes ausgeführt."
+#~ msgid ""
+#~ "List of object numbers to move (\"from\" to \"to\"). remove= option will "
+#~ "be done first, if any."
+#~ msgstr ""
+#~ "Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach"
+#~ "\"). Falls eine Option angegeben wurde, wird remove= als erstes "
+#~ "ausgeführt."
 #~ msgid "Save current frame"
 #~ msgstr "Speichere aktuellen Rahmen."
@@ -44559,7 +48248,8 @@
 #~ msgstr "Es gibt das Grafikfenster <%s> nicht."
 #~ msgid "Error - Monitor '%s' in use by another user"
-#~ msgstr "Fehler - Grafikfenster '%s' wird von einem anderen Benutzer verwendet."
+#~ msgstr ""
+#~ "Fehler - Grafikfenster '%s' wird von einem anderen Benutzer verwendet."
 #~ msgid "Error - Locking mechanism failed"
 #~ msgstr "Fehler - Sperrvorrichtung ist fehlgeschlagen."
@@ -44576,8 +48266,11 @@
 #~ msgid "display, menu"
 #~ msgstr "Darstellung, Menue"
-#~ msgid "Creates and displays a menu within the active frame on the graphics monitor."
-#~ msgstr "Erzeugt und stellt ein Menü im aktiven Frame des Grafikfensters dar."
+#~ msgid ""
+#~ "Creates and displays a menu within the active frame on the graphics "
+#~ "monitor."
+#~ msgstr ""
+#~ "Erzeugt und stellt ein Menü im aktiven Frame des Grafikfensters dar."
 #~ msgid "Sets the color of the menu background"
 #~ msgstr "Bestimmt die Farbe des Menü Hintergrunds."
@@ -44609,8 +48302,12 @@
 #~ msgid "Error reading saturation data"
 #~ msgstr "Fehler beim Lesen der Sättigungsdaten (saturation)."
-#~ msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
-#~ msgstr "Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-Fensters zu zeichnen."
+#~ msgid ""
+#~ "Draws text in the graphics monitor's active display frame using TrueType "
+#~ "fonts."
+#~ msgstr ""
+#~ "Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-"
+#~ "Fensters zu zeichnen."
 #~ msgid "Screen position (percentage, [0,0] is bottom left)"
 #~ msgstr "Koordinaten (in Prozent, [0,0] ist unten links)."
@@ -44658,7 +48355,8 @@
 #~ msgstr "%s: Kann diese Schrift nicht lesen."
 #~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr "%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
+#~ msgstr ""
+#~ "%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
 #~ msgid "%s: No FreeType definition file"
 #~ msgstr "%s: Keine FreeType Definitionsdatei gefunden."
@@ -44706,13 +48404,18 @@
 #~ msgstr "Invertiere Kategorieliste."
 #~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr "Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
+#~ msgstr ""
+#~ "Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
 #~ msgid "Ignoring catlist: map is floating point (please use 'val=')"
-#~ msgstr "Igniriere Kategorieliste: Karte ist ein Fließkommakarte (Bitte benutzen Sie 'val=')."
+#~ msgstr ""
+#~ "Igniriere Kategorieliste: Karte ist ein Fließkommakarte (Bitte benutzen "
+#~ "Sie 'val=')."
 #~ msgid "Ignoring vallist: map is integer (please use 'cat=')"
-#~ msgstr "Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie 'cat=')."
+#~ msgstr ""
+#~ "Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie "
+#~ "'cat=')."
 #~ msgid "Font name or pathname of TTF file"
 #~ msgstr "Name des Fonts oder Pfad zu einer TIFF-Datei."
@@ -44737,7 +48440,8 @@
 #~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
 #~ msgstr ""
 #~ "Kann keine Maskendatei erzeugen: G3D_MASK existiert bereits.\n"
-#~ "Verwenden Sie 'g.remove rast3d=G3D_MASK', um die existierende Maske zu löschen."
+#~ "Verwenden Sie 'g.remove rast3d=G3D_MASK', um die existierende Maske zu "
+#~ "löschen."
 #~ msgid "Name of input 3D raster map"
 #~ msgstr "Name der Eingabe-3D-Rasterkarte"
@@ -44754,8 +48458,11 @@
 #~ msgid "Print 3D raster history instead of info"
 #~ msgstr "Gebe 3D Rasterhistorie anstelle der Info aus."
-#~ msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-#~ msgstr "Gebe nur den Zeitstempel der 3D-Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:Sekunde)"
+#~ msgid ""
+#~ "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
+#~ msgstr ""
+#~ "Gebe nur den Zeitstempel der 3D-Rasterkarte aus (Tag.Monat.Jahr Stunde:"
+#~ "Minute:Sekunde)"
 #~ msgid "Unable to close output map"
 #~ msgstr "Kann die Ausgabe-Karte nicht schließen."
@@ -44766,8 +48473,12 @@
 #~ msgid "Unable to write raster row"
 #~ msgstr "Kann die Rasterzeile nicht schreiben."
-#~ msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
-#~ msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
+#~ msgid ""
+#~ "Creates cross section 2D raster map from 3D raster map based on 2D "
+#~ "elevation map."
+#~ msgstr ""
+#~ "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
+#~ "Rasterkarte basierend auf 2D-Höhenkarte."
 #~ msgid "Elevation map not found"
 #~ msgstr "Höhenkarte nicht gefunden."
@@ -44782,7 +48493,8 @@
 #~ msgstr "Kann die Höhenkarte nicht schließen."
 #~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr "Falscher Datentyp der 3D-Rasterkarte! Kann die Rasterkarte nicht erzeugen."
+#~ msgstr ""
+#~ "Falscher Datentyp der 3D-Rasterkarte! Kann die Rasterkarte nicht erzeugen."
 #~ msgid "ASCII raster map to be imported"
 #~ msgstr "Zu importierende ASCII Raster-Datei"
@@ -44790,14 +48502,21 @@
 #~ msgid "raster3d, voxel, import"
 #~ msgstr "3D-Raster, Voxel, Import"
-#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr "Konvertiert eine 3D ASCII Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
+#~ msgid ""
+#~ "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+#~ msgstr ""
+#~ "Konvertiert eine 3D ASCII Raster Textdatei in eine (binäre) 3D-"
+#~ "Rasterkarte. "
 #~ msgid "Could not open map %s"
 #~ msgstr "Kann die Karte %s nicht öffnen."
-#~ msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
-#~ msgstr "Keine 3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die Geometrien schreiben."
+#~ msgid ""
+#~ "No 3D raster data, RGB or xyz-vector maps are provided. Will only write "
+#~ "the geometry"
+#~ msgstr ""
+#~ "Keine 3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die "
+#~ "Geometrien schreiben."
 #~ msgid "No RGB Data will be created"
 #~ msgstr "RGB-Daten werden nicht erzeugt."
@@ -44824,19 +48543,24 @@
 #~ msgstr "Kann die unterste Rasterzeile nicht lesen.\n"
 #~ msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-#~ msgstr "Falsche Werte in 3D-Rasterkarte: Werte sollten zwischen 0 und 255 liegen!\n"
+#~ msgstr ""
+#~ "Falsche Werte in 3D-Rasterkarte: Werte sollten zwischen 0 und 255 "
+#~ "liegen!\n"
 #~ msgid "G3D map(s) to be converted to VTK-ASCII data format"
 #~ msgstr "G3D Karte(n), die in das VTK-ASCII-Format konvertiert werden sollen"
 #~ msgid "write_vtk_structured_point_header: Writing VTKStructuredPoint-Header"
-#~ msgstr "write_vtk_structured_point_header: Schreibe VTKStructuredPoint-Header"
+#~ msgstr ""
+#~ "write_vtk_structured_point_header: Schreibe VTKStructuredPoint-Header"
 #~ msgid "write_vtk_structured_grid_header: Writing VTKStructuredGrid-Header"
 #~ msgstr "write_vtk_structured_grid_header: Schreibe VTKStructuredGrid-Header"
-#~ msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
-#~ msgstr "write_vtk_unstructured_grid_header: Schreibe VTKUnstructuredGrid-Header"
+#~ msgid ""
+#~ "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
+#~ msgstr ""
+#~ "write_vtk_unstructured_grid_header: Schreibe VTKUnstructuredGrid-Header"
 #~ msgid "Name of output display file"
 #~ msgstr "Name des Ausgabedisplays."
@@ -44853,8 +48577,12 @@
 #~ msgid "Converts a 3D raster map layer into an ASCII text file."
 #~ msgstr "Konvertiert eine 3D-Rasterkarte in eine ASCII-Textdatei."
-#~ msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
-#~ msgstr "Verwende dieselbe Auflösung wie die 3D-Rasterkarte für die 2D-Ausgabekarten (unabhängig von der Auflösung der aktuellen Region). "
+#~ msgid ""
+#~ "Use the same resolution as the input 3D raster map for the 2D outputmaps, "
+#~ "independent of the current region settings"
+#~ msgstr ""
+#~ "Verwende dieselbe Auflösung wie die 3D-Rasterkarte für die 2D-"
+#~ "Ausgabekarten (unabhängig von der Auflösung der aktuellen Region). "
 #~ msgid "Open 3D raster map <%s>"
 #~ msgstr "Öffne 3D-Rasterkarte <%s>."
@@ -44863,7 +48591,8 @@
 #~ msgstr "Fehler beim Öffnen der 3D-Rasterkarte <%s>."
 #~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-#~ msgstr "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
+#~ msgstr ""
+#~ "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
 #~ msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
 #~ msgstr "Der Status jeder Zelle, = 0 - inaktiv, 1 - aktiv, 2 - dirichlet"
@@ -44880,8 +48609,12 @@
 #~ msgid "Recharge raster map in m^3/s"
 #~ msgstr "Grundwasserneubildungskarte in m^3/s"
-#~ msgid "The piezometric head result of the numerical calculation will be written to this map"
-#~ msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
+#~ msgid ""
+#~ "The piezometric head result of the numerical calculation will be written "
+#~ "to this map"
+#~ msgstr ""
+#~ "Das resultierende piezometrisches Niveau der numerischen Berechnung wird "
+#~ "in diese Karte geschrieben."
 #~ msgid ""
 #~ "Calculate the groundwater distance velocity vector field \n"
@@ -44892,23 +48625,38 @@
 #~ "schreibe die X, Y und Z Komponenten in die Karten name_[xyz].\n"
 #~ "Name ist der gemeinsame Bestandteil der neuen 3D-Rasterkarten."
-#~ msgid "Use a sparse linear equation system, only available with iterative solvers"
-#~ msgstr "Verwende ein dünnbesetztes lineares Gleichungssystem, nur für iterative Lösungsverfahren verfügbar."
+#~ msgid ""
+#~ "Use a sparse linear equation system, only available with iterative solvers"
+#~ msgstr ""
+#~ "Verwende ein dünnbesetztes lineares Gleichungssystem, nur für iterative "
+#~ "Lösungsverfahren verfügbar."
-#~ msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
-#~ msgstr "Berechnet transienten, beschränkten Grundwasserflusses in drei Dimensionen."
+#~ msgid ""
+#~ "Calculates numerically transient, confined groundwater flow in three "
+#~ "dimensions."
+#~ msgstr ""
+#~ "Berechnet transienten, beschränkten Grundwasserflusses in drei "
+#~ "Dimensionen."
 #~ msgid "The direct Cholesky solver do not work with sparse matrices"
-#~ msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+#~ msgstr ""
+#~ "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
-#~ msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
-#~ msgstr "Importiert dreidimensionale Vis5D Dateien (z.B. V5D Datei mit 1 Variablen und 1 Zeitschritt)."
+#~ msgid ""
+#~ "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and "
+#~ "1 time step)."
+#~ msgstr ""
+#~ "Importiert dreidimensionale Vis5D Dateien (z.B. V5D Datei mit 1 Variablen "
+#~ "und 1 Zeitschritt)."
 #~ msgid "postscript, map, printing"
 #~ msgstr "Postscript, Karte, Drucken"
-#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten(Rand) )."
+#~ msgid ""
+#~ "List paper formats ( name width height left right top bottom(margin) )"
+#~ msgstr ""
+#~ "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben "
+#~ "unten(Rand) )."
 #~ msgid "Use '-' to enter instructions from keyboard"
 #~ msgstr "Verwenden Sie '-' für eine Eingabe über die Tastatur"
@@ -44916,11 +48664,20 @@
 #~ msgid "PostScript output file"
 #~ msgstr "PostScript Ausgabedatei"
-#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr "Maßstab der Ausgabekarte, z.B. 1:25000 (standardmäßig: Anpassung an die Seite)"
+#~ msgid ""
+#~ "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
+#~ msgstr ""
+#~ "Maßstab der Ausgabekarte, z.B. 1:25000 (standardmäßig: Anpassung an die "
+#~ "Seite)"
-#~ msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
-#~ msgstr "Die Verwendung von <%s> auf der Kommandozeile ist veraltet. Bitte verwenden Sie stattdessen die Kartierungsanweisung <%s>. Der Parameter <%s> wird in zukünftigen GRASS-Versionen nicht mehr vorhanden sein."
+#~ msgid ""
+#~ "Using <%s> from the command line is depreciated. Please use the <%s> "
+#~ "mapping instruction instead. The parameter <%s> will be removed in future "
+#~ "versions of GRASS."
+#~ msgstr ""
+#~ "Die Verwendung von <%s> auf der Kommandozeile ist veraltet. Bitte "
+#~ "verwenden Sie stattdessen die Kartierungsanweisung <%s>. Der Parameter <"
+#~ "%s> wird in zukünftigen GRASS-Versionen nicht mehr vorhanden sein."
 #~ msgid ""
 #~ "ERROR: Required parameter <%s> not set:\n"
@@ -44935,14 +48692,25 @@
 #~ msgid "Data exists after final 'end' instruction!"
 #~ msgstr "Weitere Daten existieren nach der beendenden 'end'-Instruktion!"
-#~ msgid "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping instruction. This mapping instruction is superseded and will be removed in future versions of GRASS. Please use --verbose instead."
-#~ msgstr "Die GRASS Umgebungsvariable GRASS_VERBOSE wird überschrieben von der Kartierungsanweisung VERBOSE. Diese Kartierungsanweisung wurde ersetzt und wird in zukünftigen GRASS_Versionen nicht mehr enthalten sein. Bitte verwenden Sie stattdessen '--verbose'."
+#~ msgid ""
+#~ "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE "
+#~ "mapping instruction. This mapping instruction is superseded and will be "
+#~ "removed in future versions of GRASS. Please use --verbose instead."
+#~ msgstr ""
+#~ "Die GRASS Umgebungsvariable GRASS_VERBOSE wird überschrieben von der "
+#~ "Kartierungsanweisung VERBOSE. Diese Kartierungsanweisung wurde ersetzt "
+#~ "und wird in zukünftigen GRASS_Versionen nicht mehr enthalten sein. Bitte "
+#~ "verwenden Sie stattdessen '--verbose'."
 #~ msgid "Cannot set GRASS_VERBOSE variable."
 #~ msgstr "Kann die GRASS_VERBOSE Variable nicht setzen."
-#~ msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
-#~ msgstr "Die Kartierungsanweisung <%s> wird umbenannt in <%s> in zukünftigen Versionen von GRASS. Bitte verwenden Sie sattdessen <%s>."
+#~ msgid ""
+#~ "The mapping instruction <%s> will be renamed to <%s> in future versions "
+#~ "of GRASS. Please use <%s> instead."
+#~ msgstr ""
+#~ "Die Kartierungsanweisung <%s> wird umbenannt in <%s> in zukünftigen "
+#~ "Versionen von GRASS. Bitte verwenden Sie sattdessen <%s>."
 #~ msgid "Reading raster map <%s in %s> ..."
 #~ msgstr "Lese Rasterkarte <%s in %s> ..."
@@ -44957,13 +48725,21 @@
 #~ msgstr "Bildverarbeitung, Orthorektifikation"
 #~ msgid "Creates control points on an image to be ortho-rectified."
-#~ msgstr "Erzeuge Kontrollpunkte in einem Bild, welches orthorektifiziert werden soll."
+#~ msgstr ""
+#~ "Erzeuge Kontrollpunkte in einem Bild, welches orthorektifiziert werden "
+#~ "soll."
-#~ msgid "Name of image to be rectified which will be initially drawn on screen"
-#~ msgstr "Name der Karte, die rektifiziert werden soll, diese wird anfänglich auf dem Bildschirm dargestellt."
+#~ msgid ""
+#~ "Name of image to be rectified which will be initially drawn on screen"
+#~ msgstr ""
+#~ "Name der Karte, die rektifiziert werden soll, diese wird anfänglich auf "
+#~ "dem Bildschirm dargestellt."
-#~ msgid "Name of a map from target mapset which will be initially drawn on screen"
-#~ msgstr "Name einer Karte im Zielmapset, welche anfänglich auf dem Bildschirm dargestellt wird."
+#~ msgid ""
+#~ "Name of a map from target mapset which will be initially drawn on screen"
+#~ msgstr ""
+#~ "Name einer Karte im Zielmapset, welche anfänglich auf dem Bildschirm "
+#~ "dargestellt wird."
 #~ msgid "No camera reference file selected for group [%s]"
 #~ msgstr "Keine Kamerareferenzdatei ausgewählt für die Gruppe [%s]."
@@ -44975,7 +48751,8 @@
 #~ msgstr "Keine Anfangs-Kameraposition für die Gruppe [%s]."
 #~ msgid "Bad format in initial camera exposure station for group [%s]"
-#~ msgstr "Schlechtes Format in der Anfangs-Kameraposition für die Gruppe [%s]."
+#~ msgstr ""
+#~ "Schlechtes Format in der Anfangs-Kameraposition für die Gruppe [%s]."
 #~ msgid "No photo points for group [%s]"
 #~ msgstr "Keine Bildpositionen für die Gruppe [%s]."
@@ -45037,7 +48814,8 @@
 #~ "Berechne lokale Kamerawinkel? "
 #~ msgid "Enter a name for the camera angle map:"
-#~ msgstr "Geben Sie einen Namen für die Karte mit den Kamera-Winkelangaben ein:"
+#~ msgstr ""
+#~ "Geben Sie einen Namen für die Karte mit den Kamera-Winkelangaben ein:"
 #~ msgid "Map name <%s> is illegal"
 #~ msgstr "Kartenname <%s> ist ein ungültiger Name."
@@ -45113,17 +48891,22 @@
 #~ msgid "Group [%s] targeted for location [%s], mapset [%s]"
 #~ msgstr "Gruppe [%s] zielt auf Location [%s], Mapset [%s]."
-#~ msgid "Interactively select and modify the imagery group camera reference file."
+#~ msgid ""
+#~ "Interactively select and modify the imagery group camera reference file."
 #~ msgstr "Wähle und ändere die Kamerareferenzdatei der Bildgruppe interaktiv."
 #~ msgid "Name of camera reference file to use"
 #~ msgstr "Name der zu verwendenden Kamerareferenzdatei."
 #~ msgid "Enter a camera reference file to be used with this imagery group"
-#~ msgstr "Geben Sie eine Kamerareferenzdatei ein, die mit dieser Bildgruppe verwendet werden soll."
+#~ msgstr ""
+#~ "Geben Sie eine Kamerareferenzdatei ein, die mit dieser Bildgruppe "
+#~ "verwendet werden soll."
 #~ msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-#~ msgstr "Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die Kameradatei [%s]."
+#~ msgstr ""
+#~ "Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die "
+#~ "Kameradatei [%s]."
 #~ msgid "Interactively mark fiducial or reseau points on an image."
 #~ msgstr "Markiere Rahmenmarken oder Reseaupunkte interaktiv in einem Bild."
@@ -45159,25 +48942,81 @@
 #~ msgstr "Kann die Maske (MASK) der 'CELL'-Karte nicht öffnen."
 #~ msgid "Unable to allocate the cell buffer in display_signature()."
-#~ msgstr "Kann keinen Speicher für Zellbuffer in display_signature() reservieren."
+#~ msgstr ""
+#~ "Kann keinen Speicher für Zellbuffer in display_signature() reservieren."
 #~ msgid "Did not find input cell map MASK."
 #~ msgstr "Kann die Maske (MASK) der Input-'CELL'-Karte nicht finden."
 #~ msgid "QC, Quality Control, surface reflectance, Modis"
-#~ msgstr "QC, Qualitätskontrolle, Oberflächenreflexion, surface reflectance, Modis"
+#~ msgstr ""
+#~ "QC, Qualitätskontrolle, Oberflächenreflexion, surface reflectance, Modis"
-#~ msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);"
-#~ msgstr "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);"
+#~ msgid ""
+#~ "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
+#~ "surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);"
+#~ "mod11A2;LST 1Km 8-days (Day/Night);"
+#~ msgstr ""
-#~ msgid "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;mo
 d09A1s: StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask;"
-#~ msgstr "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;m
 od09A1s: StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask;"
+#~ msgid ""
+#~ "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;"
+#~ "cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;"
+#~ "diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;"
+#~ "modland_qa_bits;mod09: MODIS Land General Quality Assessment;"
+#~ "mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;"
+#~ "data_quality_flag_11A1;mod11A1: Detailed Quality Indications;"
+#~ "emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;"
+#~ "mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: "
+#~ "Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity "
+#~ "Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality "
+#~ "Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;"
+#~ "aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;"
+#~ "brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;"
+#~ "cirrus_detected;mod09A1s: StateQA Internal Snow Mask;cloud_shadow;"
+#~ "mod09A1s: StateQA Internal Snow Mask;cloud_state;mod09A1s: StateQA "
+#~ "Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA Internal "
+#~ "Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;"
+#~ "internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;"
+#~ "mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA "
+#~ "Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal "
+#~ "Snow Mask;"
+#~ msgstr ""
+#~ "Snow Mask;"
 #~ msgid "Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7])"
 #~ msgstr "Kanalnummer des MODIS Produkts (mod09Q1=[1,2],mod09A1=[1-7])"
-#~ msgid "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;mod09A1 Band 7: SWIR 3;"
-#~ msgstr "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;mod09A1 Band 7: SWIR 3;"
+#~ msgid ""
+#~ "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: "
+#~ "Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: "
+#~ "SWIR 2;7;mod09A1 Band 7: SWIR 3;"
+#~ msgstr ""
 #~ msgid "This flag is only available for MOD11A1 @ 1Km products"
 #~ msgstr "Dieser Schalter ist nur für MOD11A1 @ 1km Produkte vorhanden"
@@ -45213,7 +49052,8 @@
 #~ msgstr "Name der Rasterkarte mit Klassifikationsergebnissen."
 #~ msgid "Name for raster map holding reject threshold results"
-#~ msgstr "Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
+#~ msgstr ""
+#~ "Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
 #~ msgid "imagery, color transformation, RGB, HIS"
 #~ msgstr "Bildverarbeitung, Farbtransformation, RGB, HIS"
@@ -45247,7 +49087,8 @@
 #, fuzzy
 #~ msgid "Creates, edits, and lists groups and subgroups of imagery data."
-#~ msgstr "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
+#~ msgstr ""
+#~ "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
 #~ msgid "Name of imagery sub-group"
 #~ msgstr "Name der Bild-Untergruppe."
@@ -45298,7 +49139,8 @@
 #~ msgstr "Höhen-Rasterkarte unbekanntes Typs."
 #~ msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
-#~ msgstr "Reflektion der Rasterkarte <%s> ist nicht vom Typ DCELL - ignoriert."
+#~ msgstr ""
+#~ "Reflektion der Rasterkarte <%s> ist nicht vom Typ DCELL - ignoriert."
 #~ msgid "Minnaert constant = %lf"
 #~ msgstr "Minnaert Konstante = %lf"
@@ -45307,18 +49149,36 @@
 #~ msgstr "C-Faktor Konstante = %lf (a=%.4f; m=%.4f)"
 #, fuzzy
-#~ msgid "imagery, Landsat, radiance, reflectance, brightness temperature, atmospheric correction"
-#~ msgstr "Bildbearbeitung, Landsat, top-of-atmosphere Strahlung, dos-type einfache atmosphärische Korrektion"
+#~ msgid ""
+#~ "imagery, Landsat, radiance, reflectance, brightness temperature, "
+#~ "atmospheric correction"
+#~ msgstr ""
+#~ "Bildbearbeitung, Landsat, top-of-atmosphere Strahlung, dos-type einfache "
+#~ "atmosphärische Korrektion"
 #, fuzzy
-#~ msgid "mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 MSS;mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;oli8;Landsat_8 OLI/TIRS"
-#~ msgstr "mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 MSS;mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;ot8;Landsat_8 OLI/TIRS"
+#~ msgid ""
+#~ "mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 "
+#~ "MSS;mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM"
+#~ "+;oli8;Landsat_8 OLI/TIRS"
+#~ msgstr ""
+#~ "+;ot8;Landsat_8 OLI/TIRS"
-#~ msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr "Kann das Realteil-Bild im 'cell_misc' Ordner nicht öffnen. Rasterkarte wurde wahrscheinlich nicht mit i.fft erstellt."
+#~ msgid ""
+#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
+#~ "probably wasn't created by i.fft"
+#~ msgstr ""
+#~ "Kann das Realteil-Bild im 'cell_misc' Ordner nicht öffnen. Rasterkarte "
+#~ "wurde wahrscheinlich nicht mit i.fft erstellt."
-#~ msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
-#~ msgstr "Kann das Bild mit dem imaginären Teil im 'cell_misc' Ordner nicht öffnen. Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
+#~ msgid ""
+#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
+#~ msgstr ""
+#~ "Kann das Bild mit dem imaginären Teil im 'cell_misc' Ordner nicht öffnen. "
+#~ "Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
 #~ msgid "Power 2 values: %d rows %d columns"
 #~ msgstr "'hoch zwei'-Werte: %d Zeilen %d Spalten."
@@ -45336,7 +49196,8 @@
 #~ msgstr "Bildverarbeitung, Statistik"
 #~ msgid "Canonical components analysis (cca) program for image processing."
-#~ msgstr "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
+#~ msgstr ""
+#~ "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
 #~ msgid "Illegal group name <%s>"
 #~ msgstr "Unzulässiger Gruppen-Name <%s>."
@@ -45356,7 +49217,8 @@
 #~ msgstr "Untergruppe ist zu groß. Die Maximalanzahl der Kanäle ist %d."
 #~ msgid "nviz - Visualization and animation tool for GRASS data."
-#~ msgstr "nviz - Visualisations- und Animations-Werkzeug für GRASS Datensätze."
+#~ msgstr ""
+#~ "nviz - Visualisations- und Animations-Werkzeug für GRASS Datensätze."
 #~ msgid "Name of raster map(s) for Elevation"
 #~ msgstr "Name der Rasterkarte(n) mit Höheninformationen."
@@ -45377,7 +49239,9 @@
 #~ msgstr "Schnellstart - Lade keine Daten."
 #~ msgid "Exit after completing script launched from the command line"
-#~ msgstr "Beendet sich nachdem das, von der Kommandozeile gestartete, Skript fertig ist"
+#~ msgstr ""
+#~ "Beendet sich nachdem das, von der Kommandozeile gestartete, Skript fertig "
+#~ "ist"
 #~ msgid "Start in Demo mode (skip the \"please wait\" message)"
 #~ msgstr "Starte im Demo-Modus (überspringe die \"please wait\" Mitteilung)"
@@ -45395,7 +49259,9 @@
 #~ msgstr "Lade gespeicherte Zustandsdatei."
 #~ msgid "Number of elevation files does not match number of colors files"
-#~ msgstr "Die Anzahl der Dateien mit Höheninformationen stimmt nicht mit denen der Farbinformationen überein."
+#~ msgstr ""
+#~ "Die Anzahl der Dateien mit Höheninformationen stimmt nicht mit denen der "
+#~ "Farbinformationen überein."
 #~ msgid "Loading data failed"
 #~ msgstr "Laden der Daten fehlgeschlagen."
@@ -45436,8 +49302,13 @@
 #~ msgid "vector, kernel density"
 #~ msgstr "Vektor, Kerndichte"
-#~ msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
-#~ msgstr "Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf einem Vektornetzwerk erstellt werden."
+#~ msgid ""
+#~ "Generates a raster density map from vector point data using a moving "
+#~ "kernel or optionally generates a vector density map on a vector network."
+#~ msgstr ""
+#~ "Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines "
+#~ "gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf "
+#~ "einem Vektornetzwerk erstellt werden."
 #~ msgid "Input vector with training points"
 #~ msgstr "Eingabekarte mit den Trainingspunkten."
@@ -45451,11 +49322,17 @@
 #~ msgid "Standard deviation in map units"
 #~ msgstr "Standardabweichung in Karteneinheiten."
-#~ msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
-#~ msgstr "nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;Equal split (Okabe 2009) angewendet bei Knoten;"
+#~ msgid ""
+#~ "none;No method applied at nodes with more than 2 arcs;split;Equal split "
+#~ "(Okabe 2009) applied at nodes;"
+#~ msgstr ""
+#~ "nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;"
+#~ "Equal split (Okabe 2009) angewendet bei Knoten;"
 #~ msgid "In network mode, multiply the result by number of input points."
-#~ msgstr "Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-Punkte."
+#~ msgstr ""
+#~ "Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-"
+#~ "Punkte."
 #~ msgid "Verbose module output (retained for backwards compatibility)"
 #~ msgstr "Gesprächige Modulausgabe (für Rückwärtskompatibilität erhalten)"
@@ -45628,8 +49505,12 @@
 #~ msgid "Cannot grant privileges on table:\n"
 #~ msgstr "Kann Privilegien für die Tabelle nicht zuweisen:\n"
-#~ msgid "Cannot add database link to vector, link for given field probably already exists."
-#~ msgstr "Kann Datenbankverknüpfung nicht zum Vektor hinzufügen. Vermutlich besteht schon eine Verknüpfung für das Feld."
+#~ msgid ""
+#~ "Cannot add database link to vector, link for given field probably already "
+#~ "exists."
+#~ msgstr ""
+#~ "Kann Datenbankverknüpfung nicht zum Vektor hinzufügen. Vermutlich besteht "
+#~ "schon eine Verknüpfung für das Feld."
 #~ msgid "vector, editing, digitization"
 #~ msgstr "Vektor, Editiern, Digitalisieren"
@@ -45643,8 +49524,12 @@
 #~ msgid "New empty map created."
 #~ msgstr "Neue, leere Karte erstellt."
-#~ msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-#~ msgstr "Karte <%s> existiert noch nicht im aktuellen Mapset. verwenden Sie den Schalter -n, um eine neue Karte zu erzeugen."
+#~ msgid ""
+#~ "Map <%s> does not exist in current mapset. Add flag -n to create a new "
+#~ "map."
+#~ msgstr ""
+#~ "Karte <%s> existiert noch nicht im aktuellen Mapset. verwenden Sie den "
+#~ "Schalter -n, um eine neue Karte zu erzeugen."
 #~ msgid "Cannot open driver '%s'<BR>"
 #~ msgstr "Kann Treiber '%s' nicht öffnen<BR>"
@@ -45655,8 +49540,11 @@
 #~ msgid "Cannot open select cursor"
 #~ msgstr "Kann den Select-Cursor nicht öffnen."
-#~ msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-#~ msgstr "kann den Select-Cursor nicht öffnen:<BR>'%s'<BR>der Datenbank '%s' mit Treiber '%s'<BR>"
+#~ msgid ""
+#~ "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+#~ msgstr ""
+#~ "kann den Select-Cursor nicht öffnen:<BR>'%s'<BR>der Datenbank '%s' mit "
+#~ "Treiber '%s'<BR>"
 #~ msgid "Cannot fetch next record"
 #~ msgstr "Kann die nächste Zeile nicht holen."
@@ -45664,8 +49552,10 @@
 #~ msgid "No database record"
 #~ msgstr "Kein Datenbankeintrag"
-#~ msgid "<HR>   Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
-#~ msgstr "<HR>   Angenommene Datenkodierung:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
+#~ msgid ""
+#~ "<HR>   Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
+#~ msgstr ""
+#~ "<HR>   Angenommene Datenkodierung:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
 #~ msgid "Zoom by window"
 #~ msgstr "Zoom mittels Fenster"
@@ -45731,7 +49621,8 @@
 #~ msgstr "Datenbankverbindung nicht definiert.<BR>"
 #~ msgid "driver: %s<BR>database: %s<BR>table: %s<BR>key column: %s<BR>"
-#~ msgstr "Treiber: %s<BR>Datenbank: %s<BR>Tabelle: %s<BR>Schlüsselspalte: %s<BR>"
+#~ msgstr ""
+#~ "Treiber: %s<BR>Datenbank: %s<BR>Tabelle: %s<BR>Schlüsselspalte: %s<BR>"
 #~ msgid "Line %d"
 #~ msgstr "Linie %d"
@@ -45739,8 +49630,13 @@
 #~ msgid "No categories"
 #~ msgstr "Keine Kategorien"
-#~ msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
-#~ msgstr "Es gibt keine weiteren Objekte mit der Kategorie %d (Layer %d) in der Karte, aber es existieren Einträge in der Tabelle. Sollen diese Tabellen-Einträge gelöscht werden?"
+#~ msgid ""
+#~ "There are no more features with category %d (layer %d) in the map, but "
+#~ "there is record in the table. Delete this record?"
+#~ msgstr ""
+#~ "Es gibt keine weiteren Objekte mit der Kategorie %d (Layer %d) in der "
+#~ "Karte, aber es existieren Einträge in der Tabelle. Sollen diese Tabellen-"
+#~ "Einträge gelöscht werden?"
 #~ msgid "Cannot delete record: %s"
 #~ msgstr "Kann Eintrag nicht löschen: %s"
@@ -45817,8 +49713,12 @@
 #~ msgid "vector, transformation"
 #~ msgstr "Vektor, Transformation"
-#~ msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
-#~ msgstr "Führt eine affine Transformation (schieben, skalieren und rotieren oder GPCs) von Vektorkarten durch."
+#~ msgid ""
+#~ "Performs an affine transformation (shift, scale and rotate, or GPCs) on "
+#~ "vector map."
+#~ msgstr ""
+#~ "Führt eine affine Transformation (schieben, skalieren und rotieren oder "
+#~ "GPCs) von Vektorkarten durch."
 #~ msgid "Suppress display of residuals or other information"
 #~ msgstr "Unterdrücke die Darstellung der Residuen oder anderer Informationen"
@@ -45826,32 +49726,55 @@
 #~ msgid "Print the transformation matrix to stdout"
 #~ msgstr "Gebe Transformations-Matrix auf stdout aus."
-#~ msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
-#~ msgstr "Anstelle von Punkten verwende Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
+#~ msgid ""
+#~ "Instead of points use transformation parameters (xshift, yshift, zshift, "
+#~ "xscale, yscale, zscale, zrot)"
+#~ msgstr ""
+#~ "Anstelle von Punkten verwende Transformationsparameter (xshift, yshift, "
+#~ "zshift, xscale, yscale, zscale, zrot)."
 #~ msgid "ASCII file holding transform coordinates"
 #~ msgstr "ASCII-Datei mit den Transformationskoordinaten"
-#~ msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
-#~ msgstr "Wenn nicht gegeben, verwende verwende stattdessen Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
+#~ msgid ""
+#~ "If not given, transformation parameters (xshift, yshift, zshift, xscale, "
+#~ "yscale, zscale, zrot) are used instead"
+#~ msgstr ""
+#~ "Wenn nicht gegeben, verwende verwende stattdessen "
+#~ "Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, "
+#~ "zrot)."
 #~ msgid "Name of table containing transformation parameters"
 #~ msgstr "Name der Tabelle mit den Transformationsparametern"
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
-#~ msgstr "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden sein. Transformationsparameter werden automatisch verwendet wenn kein pointsfile angegeben wurde."
+#~ msgid ""
+#~ "The '%c' flag is deprecated and will be removed in future. Transformation "
+#~ "parameters are used automatically when no pointsfile is given."
+#~ msgstr ""
+#~ "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden "
+#~ "sein. Transformationsparameter werden automatisch verwendet wenn kein "
+#~ "pointsfile angegeben wurde."
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
-#~ msgstr "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden sein. Bitte verwenden Sie stattdessen '--quiet'."
+#~ msgid ""
+#~ "The '%c' flag is deprecated and will be removed in future. Please use '--"
+#~ "quiet' instead."
+#~ msgstr ""
+#~ "sein. Bitte verwenden Sie stattdessen '--quiet'."
 #~ msgid "Column names are not defined. Please use '%s' parameter."
-#~ msgstr "Spaltennamen sind nicht definiert. Bitte verwenden Sie den Parameter '%s'."
+#~ msgstr ""
+#~ "Spaltennamen sind nicht definiert. Bitte verwenden Sie den Parameter '%s'."
 #~ msgid "Please specify a valid layer with '%s' parameter."
 #~ msgstr "Bitte geben Sie mit dem Parameter '%s' einen gültigen Layer an."
-#~ msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
-#~ msgstr "Name der Tabelle und Name der Ausgabe-Vektorkarte müssenunterschiedlich sein. Sonst wird die Tabelle überschrieben."
+#~ msgid ""
+#~ "Name of table and name for output vector map must be different. Otherwise "
+#~ "the table is overwritten."
+#~ msgstr ""
+#~ "Name der Tabelle und Name der Ausgabe-Vektorkarte müssenunterschiedlich "
+#~ "sein. Sonst wird die Tabelle überschrieben."
 #~ msgid "Unable to open file with coordinates <%s>"
 #~ msgstr "Kann die Datei mit den Koordinaten <%s> nicht öffnen"
@@ -45895,10 +49818,14 @@
 #~ msgstr "Unbekanntes Schlüsselwort <%s im Vektorheader."
 #~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#~ msgstr "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
+#~ msgstr ""
+#~ "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-"
+#~ "Vektordatei."
 #~ msgid "ASCII file to be imported, if not given reads from standard input"
-#~ msgstr "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben wird von der Standardeingabe gelesen."
+#~ msgstr ""
+#~ "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben wird von "
+#~ "der Standardeingabe gelesen."
 #~ msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
 #~ msgstr "point;einfache x,y[,z] Liste;standard;GRASS Vektor-ASCII-Format"
@@ -45917,12 +49844,15 @@
 #~ "Y-Spaltennummer > letzte Spaltennummer\n"
 #~ "(falsches Trennzeichen?)"
-#~ msgid "z column number > minimum last column number (incorrect field separator?)"
+#~ msgid ""
+#~ "z column number > minimum last column number (incorrect field separator?)"
 #~ msgstr ""
 #~ "Z-Spaltennummer > letzte Spaltennummer\n"
-#~ msgid "cat column number > minimum last column number (incorrect field separator?)"
+#~ msgid ""
+#~ "cat column number > minimum last column number (incorrect field "
+#~ "separator?)"
 #~ msgstr "cat-Spaltennummer > letzte Spaltennummer (falsches Trennzeichen?)"
 #~ msgid "x column is not of number type"
@@ -45998,7 +49928,8 @@
 #~ msgstr "Gebe Vektor-Punktkarte mit Abweichungen aus"
 #~ msgid "Output cross-validation errors vector point file"
-#~ msgstr "Gebe eine Vektor-Punktkarte mit den Fehlern der Kreuzvalidierung aus."
+#~ msgstr ""
+#~ "Gebe eine Vektor-Punktkarte mit den Fehlern der Kreuzvalidierung aus."
 #~ msgid "Output vector map showing quadtree segmentation"
 #~ msgstr "Ausgabe-Vektorkarte mit der 'quadtree'-Segmentierung."
@@ -46009,14 +49940,22 @@
 #~ msgid "Name of the raster map used as mask"
 #~ msgstr "Name der Rasterkarte, die als Maske benutzt werden soll"
-#~ msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
-#~ msgstr "Name der Attributspalte mit Werten, die für die Approximation verwendet werden (wen der Layer >0)."
+#~ msgid ""
+#~ "Name of the attribute column with values to be used for approximation (if "
+#~ "layer>0)"
+#~ msgstr ""
+#~ "Name der Attributspalte mit Werten, die für die Approximation verwendet "
+#~ "werden (wen der Layer >0)."
 #~ msgid "Both z-coordinate and zcol attribute defined, only one is allowed"
-#~ msgstr "z-Koordinate und 'zcol' wurden angegeben, aber nur eine Angabe ist erlaubt."
+#~ msgstr ""
+#~ "z-Koordinate und 'zcol' wurden angegeben, aber nur eine Angabe ist "
+#~ "erlaubt."
 #~ msgid "Only smoothing column defined, zcol or -z flag is missing"
-#~ msgstr "Nur die Spalte mit dem Glättungsfaktor wurde definiert, zcol oder -z fehlt."
+#~ msgstr ""
+#~ "Nur die Spalte mit dem Glättungsfaktor wurde definiert, zcol oder -z "
+#~ "fehlt."
 #~ msgid ""
 #~ "Processing all selected output files\n"
@@ -46026,7 +49965,9 @@
 #~ "Werde %d Byte Plattenspeicher für temp-Dateien benötigen."
 #~ msgid "Cannot write raster maps -- try to increase resolution"
-#~ msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
+#~ msgstr ""
+#~ "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu "
+#~ "erhöhen."
 #~ msgid "vector, metadata, history"
 #~ msgstr "Vektor, Metadaten, history"
@@ -46037,8 +49978,10 @@
 #~ msgid "Print vector history instead of info"
 #~ msgstr "Gebe den Werdegang anstelle einer Info aus."
-#~ msgid "Print types/names of table columns for specified layer instead of info"
-#~ msgstr "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
+#~ msgid ""
+#~ "Print types/names of table columns for specified layer instead of info"
+#~ msgstr ""
+#~ "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
 #~ msgid "Print topology information only"
 #~ msgstr "Gebe nur Informationen zur Topologie aus."
@@ -46119,22 +50062,46 @@
 #~ msgstr "Vektor, Kategorie "
 #~ msgid "Attach, delete or report vector categories to map geometry."
-#~ msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
+#~ msgstr ""
+#~ "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
-#~ msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/';layers;print only layer numbers"
-#~ msgstr "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines gegebenen Layers;chlayer;Ändere die Layer-Nummer (z.B. layer=3,1 ändert von Layer 3 auf Layer 1);sum;Addiert den in 'cat' angegeben Wert zu dem aktuellen Kategoriewert;report;Gebe einen Bericht  im Shellskript-Stil aus (Statistiken ): Layer Typ Anzahl Min Max;print;Gebe Kategoriewerte aus, mehrere cats im selben Layer werden durch '/' getrennt;layers;gebe nur Layer Nummern aus"
+#~ msgid ""
+#~ "add;add a new category;del;delete all categories of given layer;chlayer;"
+#~ "change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add "
+#~ "the value specified by cat option to the current category value;report;"
+#~ "print report (statistics), in shell style: layer type count min max;print;"
+#~ "print category values, more cats in the same layer are separated by '/';"
+#~ "layers;print only layer numbers"
+#~ msgstr ""
+#~ "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines "
+#~ "gegebenen Layers;chlayer;Ändere die Layer-Nummer (z.B. layer=3,1 ändert "
+#~ "von Layer 3 auf Layer 1);sum;Addiert den in 'cat' angegeben Wert zu dem "
+#~ "aktuellen Kategoriewert;report;Gebe einen Bericht  im Shellskript-Stil "
+#~ "aus (Statistiken ): Layer Typ Anzahl Min Max;print;Gebe Kategoriewerte "
+#~ "aus, mehrere cats im selben Layer werden durch '/' getrennt;layers;gebe "
+#~ "nur Layer Nummern aus"
-#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
-#~ msgstr "Konvertiert eine GRASS Vektorkarte in ein OGR unterstütztes Vektorformat."
+#~ msgid ""
+#~ "Converts GRASS vector map to one of the supported OGR vector formats."
+#~ msgstr ""
+#~ "Konvertiert eine GRASS Vektorkarte in ein OGR unterstütztes Vektorformat."
-#~ msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
-#~ msgstr "Objekt-Typ(en): Kombinationen der Typen wird nicht von allen Formaten unterstützt. Standard: der erste in der Eingabe gefundene Typ."
+#~ msgid ""
+#~ "Feature type(s). Combinations not supported by all output formats. "
+#~ "Default: first type found in input."
+#~ msgstr ""
+#~ "Objekt-Typ(en): Kombinationen der Typen wird nicht von allen Formaten "
+#~ "unterstützt. Standard: der erste in der Eingabe gefundene Typ."
 #~ msgid "For example: ESRI Shapefile: filename or directory for storage"
-#~ msgstr "Zum Beispiel: ESRI Shapefile: Dateiname oder Verzeichnis für die Speicherung."
+#~ msgstr ""
+#~ "Zum Beispiel: ESRI Shapefile: Dateiname oder Verzeichnis für die "
+#~ "Speicherung."
 #~ msgid "OGR layer name. If not specified, input name is used."
-#~ msgstr "Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
+#~ msgstr ""
+#~ "Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename "
+#~ "verwendet."
 #~ msgid "OGR format"
 #~ msgstr "OGR-Format."
@@ -46142,11 +50109,16 @@
 #~ msgid "Open an existing datasource for update"
 #~ msgstr "Öffne eine existierende Datenquelle zum Aktualisieren"
-#~ msgid "Export features with category (labeled) only. Otherwise all features are exported"
-#~ msgstr "Exportiert Vektorobjekte nur mit Kategoriewerten (Labeln). Ansonsten werden alle Objekte exportiert."
+#~ msgid ""
+#~ "Export features with category (labeled) only. Otherwise all features are "
+#~ "exported"
+#~ msgstr ""
+#~ "Exportiert Vektorobjekte nur mit Kategoriewerten (Labeln). Ansonsten "
+#~ "werden alle Objekte exportiert."
 #~ msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-#~ msgstr "Erzeuge 3D Ausgabe wenn Eingabe 3D ist (nur bei Ausgabe von Shapefiles)"
+#~ msgstr ""
+#~ "Erzeuge 3D Ausgabe wenn Eingabe 3D ist (nur bei Ausgabe von Shapefiles)"
 #~ msgid "Export lines as polygons"
 #~ msgstr "Exportiere Linien als Polygone."
@@ -46160,47 +50132,100 @@
 #~ msgid "Could not determine input map's feature type(s)."
 #~ msgstr "Der Objekttyp der Eingabekarte konnte nicht bestimmt werden."
-#~ msgid "The map contains islands. To preserve them in the output map, use the -c flag"
-#~ msgstr "Die Karte enthält Inseln. Verwenden Sie den Schalter -c, um Inseln in der Ausgabe-Karte zu erhalten."
+#~ msgid ""
+#~ "The map contains islands. To preserve them in the output map, use the -c "
+#~ "flag"
+#~ msgstr ""
+#~ "Die Karte enthält Inseln. Verwenden Sie den Schalter -c, um Inseln in der "
+#~ "Ausgabe-Karte zu erhalten."
-#~ msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
+#~ msgid ""
+#~ "%d areas found, but not requested to be exported. Verify 'type' parameter."
+#~ msgstr ""
+#~ "%d Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+#~ "Überprüfen Sie bitte den 'type'-Parameter."
-#~ msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d Kern(en) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie den Parameter 'type'."
+#~ msgid ""
+#~ "%d kernel(s) found, but not requested to be exported. Verify 'type' "
+#~ "parameter."
+#~ msgstr ""
+#~ "%d Kern(en) gefunden, die allerdings nicht zum Export angegeben wurden. "
+#~ "Überprüfen Sie den Parameter 'type'."
-#~ msgid "No points found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Punkte gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometrie-Typ."
+#~ msgid ""
+#~ "No points found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
+#~ "Keine Punkte gefunden, die allerdings exportiert werden sollen. "
+#~ "Überspringe diesen Geometrie-Typ."
-#~ msgid "No lines found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Linien gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
+#~ msgid ""
+#~ "No lines found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
+#~ "Keine Linien gefunden, die allerdings exportiert werden sollen. "
+#~ "Überspringe diesen Geometry-Typ."
-#~ msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Grenzen gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
+#~ msgid ""
+#~ "No boundaries found, but requested to be exported. Will skip this "
+#~ "geometry type."
+#~ msgstr ""
+#~ "Keine Grenzen gefunden, die allerdings exportiert werden sollen. "
-#~ msgid "No areas found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Flächen gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
+#~ msgid ""
+#~ "No areas found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
+#~ "Keine Flächen gefunden, die allerdings exportiert werden sollen. "
-#~ msgid "No centroids found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Zentroide gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
+#~ msgid ""
+#~ "No centroids found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
+#~ "Keine Zentroide gefunden, die allerdings exportiert werden sollen. "
-#~ msgid "No faces found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Faces gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
+#~ msgid ""
+#~ "No faces found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
+#~ "Keine Faces gefunden, die allerdings exportiert werden sollen. "
-#~ msgid "No kernels found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Kerne gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
+#~ msgid ""
+#~ "No kernels found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
+#~ "Keine Kerne gefunden, die allerdings exportiert werden sollen. "
-#~ msgid "No volumes found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Keine Volumen gefunden, obwohl sie exportiert werden sollen. Überspringe diesen Geometry-Typ."
+#~ msgid ""
+#~ "No volumes found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
+#~ "Keine Volumen gefunden, obwohl sie exportiert werden sollen. Überspringe "
+#~ "diesen Geometry-Typ."
 #~ msgid "Nothing to export"
 #~ msgstr "Nichts zu exportieren."
-#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-#~ msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') oder '-z' Flag um nach 3D und nicht 2D (Standard) zu exportieren"
+#~ msgid ""
+#~ "Vector map <%s> is 3D. Use format specific layer creation options "
+#~ "(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+#~ msgstr ""
+#~ "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische "
+#~ "Layererzeugungsoptionen (Parameter 'lco') oder '-z' Flag um nach 3D und "
+#~ "nicht 2D (Standard) zu exportieren"
-#~ msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
-#~ msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) zu exportieren."
+#~ msgid ""
+#~ "(parameter 'lco') to export in 3D rather than 2D (default)"
+#~ msgstr ""
+#~ "Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D "
+#~ "(Standard) zu exportieren."
 #~ msgid "Key column '%s' not found"
 #~ msgstr "Schlüsselspalte '%s' nicht gefunden."
@@ -46224,19 +50249,25 @@
 #~ msgstr "habe Typ '%d' erhalten."
 #~ msgid "Feature has more categories. Only first category (%d) is exported."
-#~ msgstr "Objekt hat mehrere Kategorien. Nur die erste Kategorie (%d) wurde exportiert."
+#~ msgstr ""
+#~ "Objekt hat mehrere Kategorien. Nur die erste Kategorie (%d) wurde "
+#~ "exportiert."
 #~ msgid "Unable to select record from table <%s> (key %s, column %s)"
-#~ msgstr "Kann Daten nicht aus der Tabelle selektieren<%s> (key %s, column %s)."
+#~ msgstr ""
+#~ "Kann Daten nicht aus der Tabelle selektieren<%s> (key %s, column %s)."
 #~ msgid "Column <%s>: unsupported data type"
 #~ msgstr "Spalte <%s>: nicht unterstützter Datentyp."
 #~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
+#~ msgstr ""
+#~ "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
 #~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-#~ msgstr "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der Schalter '-o' angegeben ist."
+#~ msgstr ""
+#~ "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der "
+#~ "Schalter '-o' angegeben ist."
 #~ msgid "Format 'point' is not supported for old version"
 #~ msgstr "Das Format 'point' wird nicht von der alten Version unterstützt."
@@ -46257,7 +50288,9 @@
 #~ msgstr "Liste die Vektorkarten der Eingabe-Location und beendet sich."
 #~ msgid "Assume z co-ordinate is ellipsoidal height and transform if possible"
-#~ msgstr "Nehme an das die Z-Koordinate die ellipsoidale Höhe enthält und transformiere, wenn möglich."
+#~ msgstr ""
+#~ "Nehme an das die Z-Koordinate die ellipsoidale Höhe enthält und "
+#~ "transformiere, wenn möglich."
 #~ msgid "Reprojecting primitives: "
 #~ msgstr "Reprojeziere Primitive:"
@@ -46275,7 +50308,8 @@
 #~ msgstr "Vektordatei die Beispielpunkte enthält."
 #~ msgid "Vector map attribute column to use for comparison"
-#~ msgstr "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
+#~ msgstr ""
+#~ "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
 #~ msgid "Vector map to store differences"
 #~ msgstr "Vektorkarte, die die Unterschiede beinhalten soll."
@@ -46283,17 +50317,24 @@
 #~ msgid "Raster map to be sampled"
 #~ msgstr "Rasterkarte, die abgefragt wird."
-#~ msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
-#~ msgstr "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit diesem Faktor multipliziert."
+#~ msgid ""
+#~ "Option scaling factor for values read from raster map. Sampled values "
+#~ "will be multiplied by this factor"
+#~ msgstr ""
+#~ "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit "
+#~ "diesem Faktor multipliziert."
 #~ msgid "Bilinear interpolation (default is nearest neighbor)"
 #~ msgstr "Bilineare Interpolation (Standard: Nächster Nachbar)."
 #~ msgid "Cubic convolution interpolation (default is nearest neighbor)"
-#~ msgstr "Interpolation mittels kubischer Faltung (Standard: Nächster Nachbar)."
+#~ msgstr ""
+#~ "Interpolation mittels kubischer Faltung (Standard: Nächster Nachbar)."
 #~ msgid "Flags -b & -c are mutually exclusive. Choose only one."
-#~ msgstr "Die Schalter -b und -c schließen sich gegenseitig aus. Bitte wählen Sie nur Einen."
+#~ msgstr ""
+#~ "Die Schalter -b und -c schließen sich gegenseitig aus. Bitte wählen Sie "
+#~ "nur Einen."
 #~ msgid "Checking vector points..."
 #~ msgstr "Prüfe Vektorpunkte..."
@@ -46301,8 +50342,14 @@
 #~ msgid "vector, network, shortest path"
 #~ msgstr "Vektor, Netzwerk, kürzester Pfad"
-#~ msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
-#~ msgstr "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und zahlreiche Informationen über diese Beziehung wird in der Attributtabelle abgespeichert"
+#~ msgid ""
+#~ "Finds the shortest paths from a feature 'to' to every feature 'from' and "
+#~ "various information about this realtion are uploaded to the attribute "
+#~ "table."
+#~ msgstr ""
+#~ "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' "
+#~ "und zahlreiche Informationen über diese Beziehung wird in der "
+#~ "Attributtabelle abgespeichert"
 #~ msgid "vector, geometry"
 #~ msgstr "Vektor, Geometrie"
@@ -46338,13 +50385,22 @@
 #~ msgstr "Erzeugt Topologie für GRASS Vektorkarten."
 #~ msgid "Name for vector map where erroneous vector features are written to"
-#~ msgstr "Name der Vektorkarte, in die fehlerhafte Vektor-Objekte geschrieben werden sollen."
+#~ msgstr ""
+#~ "Name der Vektorkarte, in die fehlerhafte Vektor-Objekte geschrieben "
+#~ "werden sollen."
 #~ msgid "Build topology or dump topology or spatial index to stdout"
-#~ msgstr "Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach stdout."
+#~ msgstr ""
+#~ "Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index "
+#~ "nach stdout."
-#~ msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
-#~ msgstr "build;Erzeuge Topologie;dump;Schreibe Topologie nach stdout;sdump;Schreibe den räumlichen Index nach stdout;cdump;Schreibe den Kategorie-Index nach stdout"
+#~ msgid ""
+#~ "build;build topology;dump;write topology to stdout;sdump;write spatial "
+#~ "index to stdout;cdump;write category index to stdout"
+#~ msgstr ""
+#~ "build;Erzeuge Topologie;dump;Schreibe Topologie nach stdout;sdump;"
+#~ "Schreibe den räumlichen Index nach stdout;cdump;Schreibe den Kategorie-"
+#~ "Index nach stdout"
 #~ msgid "Name of the vector map with input x,y,z,w"
 #~ msgstr "Name der Vektorkarte mit x,y,z,w"
@@ -46412,8 +50468,19 @@
 #~ msgid "Required for operation 'connect'"
 #~ msgstr "Benötigt für die Operation 'connect'."
-#~ msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
-#~ msgstr "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe {line_category start_point_category end_point_category} aus;nreport;Gebe auf der Standardausgabe {point_category line_category [line_category...]}aus"
+#~ msgid ""
+#~ "nodes;new point is placed on each node (line end) if doesn't exist;"
+#~ "connect;connect still unconnected points to vector network by inserting "
+#~ "new line(s);report;print to standard output {line_category "
+#~ "start_point_category end_point_category};nreport;print to standard output "
+#~ "{point_category line_category[,line_category...]}"
+#~ msgstr ""
+#~ "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, "
+#~ "wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des "
+#~ "Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe "
+#~ "{line_category start_point_category end_point_category} aus;nreport;Gebe "
+#~ "auf der Standardausgabe {point_category line_category [line_category...]}"
+#~ "aus"
 #~ msgid "Output vector map must be specified"
 #~ msgstr "Ausgabe-Vektorkarte muss angegeben werden."
@@ -46436,20 +50503,39 @@
 #~ msgid "vector, buffer"
 #~ msgstr "Vektor, Buffer"
-#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
-#~ msgstr "Erzeugt einen Buffer um die Objekte mit gegebenen Typ (Flächen müssen Zentroide enthalten)."
+#~ msgid ""
+#~ "Creates a buffer around features of given type (areas must contain "
+#~ "centroid)."
+#~ msgstr ""
+#~ "Erzeugt einen Buffer um die Objekte mit gegebenen Typ (Flächen müssen "
+#~ "Zentroide enthalten)."
-#~ msgid "This is an alias to the distance option. It is retained for backwards compatibility"
-#~ msgstr "Dies ist ein Alias für die Distanz-Option. Es wurde nur für rückwärts Kompatibilität erhalten"
+#~ msgid ""
+#~ "This is an alias to the distance option. It is retained for backwards "
+#~ "compatibility"
+#~ msgstr ""
+#~ "Dies ist ein Alias für die Distanz-Option. Es wurde nur für rückwärts "
+#~ "Kompatibilität erhalten"
 #~ msgid "Buffer distance in map units"
 #~ msgstr "Bufferdistanz in Karteneinheiten"
-#~ msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
-#~ msgstr "Die Option 'bufcol' kann Fehler enthalten während des Säuberungsschrittes. Wenn Sie auf Probleme stoßen, verwenden Sie die die Option 'debug' oder säubern Sie manuell mit v.clean tool=break; v.category step=0; v.extract -d type=area."
+#~ msgid ""
+#~ "The bufcol option may contain bugs during the cleaning step. If you "
+#~ "encounter problems, use the debug option or clean manually with v.clean "
+#~ "tool=break; v.category step=0; v.extract -d type=area"
+#~ msgstr ""
+#~ "Die Option 'bufcol' kann Fehler enthalten während des "
+#~ "Säuberungsschrittes. Wenn Sie auf Probleme stoßen, verwenden Sie die die "
+#~ "Option 'debug' oder säubern Sie manuell mit v.clean tool=break; v."
+#~ "category step=0; v.extract -d type=area."
-#~ msgid "The buffer option has been replaced by the distance option and will be removed in future."
-#~ msgstr "Die Buffer-Option wurde durch die Distanz-Option ersetzt und wird in Zukunft entfernt."
+#~ msgid ""
+#~ "The buffer option has been replaced by the distance option and will be "
+#~ "removed in future."
+#~ msgstr ""
+#~ "Die Buffer-Option wurde durch die Distanz-Option ersetzt und wird in "
+#~ "Zukunft entfernt."
 #~ msgid "Use the distance option instead of the buffer option."
 #~ msgstr "Verwende die Distanz-Option anstelle der Buffer-Option."
@@ -46461,7 +50547,8 @@
 #~ msgstr "Schreibe Buffer..."
 #~ msgid "Create a new vector map layer by combining other vector map layers."
-#~ msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten"
+#~ msgstr ""
+#~ "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten"
 #~ msgid "Patching vector map <%s@%s>..."
 #~ msgstr "Kombiniere Vektorkarte <%s@%s>..."
@@ -46481,8 +50568,14 @@
 #~ msgid "vector, geometry, topology"
 #~ msgstr "Vektor, Geometrie, Topology"
-#~ msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
-#~ msgstr "no;Weise Polyline keine Kategorie zu;first;Weise der Polyline die Kategorie der ersten Linie zu;multi;Weise der Polylinie mehrere Kategorien zu"
+#~ msgid ""
+#~ "no;Do not assign any category number to polyline;first;Assign category "
+#~ "number of first line to polyline;multi;Assign multiple category numbers "
+#~ "to polyline"
+#~ msgstr ""
+#~ "no;Weise Polyline keine Kategorie zu;first;Weise der Polyline die "
+#~ "Kategorie der ersten Linie zu;multi;Weise der Polylinie mehrere "
+#~ "Kategorien zu"
 #~ msgid "%d lines or boundaries found in vector map <%s@%s>"
 #~ msgstr "%d Linien oder Grenzen in der Vektorkarte <%s@%s> gefunden."
@@ -46494,7 +50587,9 @@
 #~ msgstr "%d Objekte geschrieben."
 #~ msgid "Create points along input lines in new vector with 2 layers."
-#~ msgstr "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei Layern."
+#~ msgstr ""
+#~ "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei "
+#~ "Layern."
 #~ msgid "Output vector map where points will be written"
 #~ msgstr "Ausgabe-Vektorkarte, in welche die Punkten geschrieben werden"
@@ -46523,18 +50618,67 @@
 #~ msgid "%s: No font definition file"
 #~ msgstr "%s: Keine Font Definitionsdatei."
-#~ msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
-#~ msgstr "Numerische Spalte mit Werten, um den Vorrang bei überlappenden Beschriftungen zu kären. Die Beschriftung mit dem geringeren Gewicht wird verdeckt."
+#~ msgid ""
+#~ "Numeric column to give precedence in case of overlapping labels. The "
+#~ "label with a smaller weight is hidden."
+#~ msgstr ""
+#~ "Numerische Spalte mit Werten, um den Vorrang bei überlappenden "
+#~ "Beschriftungen zu kären. Die Beschriftung mit dem geringeren Gewicht wird "
+#~ "verdeckt."
-#~ msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
-#~ msgstr "Kann die Überlappungsgewichte nicht laden. Die Spalte %s in der Tabelle <%s> ist nicht numerisch."
+#~ msgid ""
+#~ "Cannot load overlap weights. Column %s is not of numeric type in table <"
+#~ "%s>"
+#~ msgstr ""
+#~ "Kann die Überlappungsgewichte nicht laden. Die Spalte %s in der Tabelle <"
+#~ "%s> ist nicht numerisch."
 #, fuzzy
-#~ msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed;rmarea;remove small
  areas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
-#~ msgstr "break;Teilt Linien an jeder Überschneidung;rmdupl;Entfernt doppelte Geometrie-Feature (Achten Sie auf die Kategorien!);rmdangle;Entfernt Überstände (dangles), Schwellwert wird ignoriert, wenn <0;chdangle;Ändert den Typ eines Überstands (dangle) zu einer Linie, Schwellwert wird ignoriert, wenn <0, Eingabe-Linien-Typ wird ignoriert;rmbridge;Entfernt Brücken, die eine Fläche und eine Insel oder 2 Inseln verbindet;chbridge;Ändert den Typ einer Brücke, die eine Fläche und eine Insel oder 2 Inseln verbindet von Grenze zu Linie;snap;Richtet Linien an Vertices innerhalb des Schwellwertes aus;rmdac;Entfernt doppelte Zentroide (Option 'type' wird ignoriert);bpol;Teilt (topologisch sauber) Polygone (importiert aus nicht topologischen Formaten, wie z.B. ShapeFile). Grenzen werden an jedem Punkt geteilt, der 2 oder mehr Polygonen gemeinsam ist und die Winkel der Segmente verschieden sind.;prune;Entfernt Vertices innerhalb des Schwellwertes von Linien und Grenzen. Gre
 nzen werden nur gesäubert, wenn die Topologie nicht beschädigt wird (neue Überschneidungen, veränderte Zuordnung von Zentroiden), das erste und letzte Segment einer Grenze wird nie geändert;rmarea;Entfernt kleine Flächen, die längste Grenze mit einer benachbarten Fläche wird entfernt;rmline;Entfernt alle Linien und Grenzen mit der Länge null, Schwellwert wird ignoriert;rmsa;Entfernt spitze Winkel zwischen Linien an einem Knoten"
+#~ msgid ""
+#~ "break;break lines at each intersection;rmdupl;remove duplicate geometry "
+#~ "features (pay attention to categories!);rmdangle;remove dangles, "
+#~ "threshold ignored if < 0;chdangle;change the type of boundary dangle to "
+#~ "line, threshold ignored if < 0, input line type is ignored;rmbridge;"
+#~ "remove bridges connecting area and island or 2 islands;chbridge;change "
+#~ "the type of bridges connecting area and island or 2 islands from boundary "
+#~ "to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate "
+#~ "area centroids ('type' option ignored);bpol;break (topologically clean) "
+#~ "polygons (imported from non topological format, like ShapeFile). "
+#~ "Boundaries are broken on each point shared between 2 and more polygons "
+#~ "where angles of segments are different;prune;remove vertices in threshold "
+#~ "from lines and boundaries, boundary is pruned only if topology is not "
+#~ "damaged (new intersection, changed attachment of centroid), first and "
+#~ "last segment of the boundary is never changed;rmarea;remove small areas, "
+#~ "the longest boundary with adjacent area is removed;rmline;remove all "
+#~ "lines or boundaries of zero length, threshold is ignored;rmsa;remove "
+#~ "small angles between lines at nodes"
+#~ msgstr ""
+#~ "break;Teilt Linien an jeder Überschneidung;rmdupl;Entfernt doppelte "
+#~ "Geometrie-Feature (Achten Sie auf die Kategorien!);rmdangle;Entfernt "
+#~ "Überstände (dangles), Schwellwert wird ignoriert, wenn <0;chdangle;Ändert "
+#~ "den Typ eines Überstands (dangle) zu einer Linie, Schwellwert wird "
+#~ "ignoriert, wenn <0, Eingabe-Linien-Typ wird ignoriert;rmbridge;Entfernt "
+#~ "Brücken, die eine Fläche und eine Insel oder 2 Inseln verbindet;chbridge;"
+#~ "Ändert den Typ einer Brücke, die eine Fläche und eine Insel oder 2 Inseln "
+#~ "verbindet von Grenze zu Linie;snap;Richtet Linien an Vertices innerhalb "
+#~ "des Schwellwertes aus;rmdac;Entfernt doppelte Zentroide (Option 'type' "
+#~ "wird ignoriert);bpol;Teilt (topologisch sauber) Polygone (importiert aus "
+#~ "nicht topologischen Formaten, wie z.B. ShapeFile). Grenzen werden an "
+#~ "jedem Punkt geteilt, der 2 oder mehr Polygonen gemeinsam ist und die "
+#~ "Winkel der Segmente verschieden sind.;prune;Entfernt Vertices innerhalb "
+#~ "des Schwellwertes von Linien und Grenzen. Grenzen werden nur gesäubert, "
+#~ "wenn die Topologie nicht beschädigt wird (neue Überschneidungen, "
+#~ "veränderte Zuordnung von Zentroiden), das erste und letzte Segment einer "
+#~ "Grenze wird nie geändert;rmarea;Entfernt kleine Flächen, die längste "
+#~ "Grenze mit einer benachbarten Fläche wird entfernt;rmline;Entfernt alle "
+#~ "Linien und Grenzen mit der Länge null, Schwellwert wird ignoriert;rmsa;"
+#~ "Entfernt spitze Winkel zwischen Linien an einem Knoten"
-#~ msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-#~ msgstr "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: 0.0[,0.0,...])."
+#~ msgid ""
+#~ "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+#~ msgstr ""
+#~ "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug "
+#~ "(Standard: 0.0[,0.0,...])."
 #~ msgid "Copying vector lines..."
 #~ msgstr "Kopiere Vektorlinien..."
@@ -46553,10 +50697,15 @@
 #~ "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 #~ msgstr ""
 #~ "\n"
-#~ "%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z.B. %.2f %%"
+#~ "%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, "
+#~ "z.B. %.2f %%"
-#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
-#~ msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
+#~ msgid ""
+#~ "Creates a Voronoi diagram from an input vector map containing points or "
+#~ "centroids."
+#~ msgstr ""
+#~ "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten "
+#~ "oder Zentroiden."
 #~ msgid "Reading sites..."
 #~ msgstr "Lese sites..."
@@ -46576,20 +50725,32 @@
 #~ msgid "creating spatial index"
 #~ msgstr "Erzeuge räumlichen Index"
-#~ msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
-#~ msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
+#~ msgid ""
+#~ "Calculates univariate statistics for attribute. Variance and standard "
+#~ "deviation is calculated only for points if specified."
+#~ msgstr ""
+#~ "Berechnet univariate Statistiken für die Attribute. Die Varianz und "
+#~ "Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
 #~ msgid "Column name"
 #~ msgstr "Spaltenname"
 #~ msgid "The '-%c' flag is currently broken, please use v.distance instead."
-#~ msgstr "Der Schalter '-%c' ist momentan kaputt. Bitte verwenden Sie stattdessen v.distance."
+#~ msgstr ""
+#~ "Der Schalter '-%c' ist momentan kaputt. Bitte verwenden Sie stattdessen v."
+#~ "distance."
-#~ msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
-#~ msgstr "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance Squared Weighting."
+#~ msgid ""
+#~ "Surface interpolation from vector point data by Inverse Distance Squared "
+#~ "Weighting."
+#~ msgstr ""
+#~ "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance "
+#~ "Squared Weighting."
 #~ msgid "If set to 0, z coordinates are used (3D vector only)"
-#~ msgstr "Wenn auf 0 gesetzt, dann werden die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
+#~ msgstr ""
+#~ "Wenn auf 0 gesetzt, dann werden die Z-Koordinate genutzt (nur bei 3D-"
+#~ "Vektoren)."
 #~ msgid "Attribute table column with values to interpolate"
 #~ msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält."
@@ -46597,8 +50758,11 @@
 #~ msgid "Required if layer > 0"
 #~ msgstr "Erfordert wenn Layer >0"
-#~ msgid "Power parameter; greater values assign greater influence to closer points"
-#~ msgstr "Power-Parameter; größere Werte geben ein näheren Punkten ein stärkeres Gewicht."
+#~ msgid ""
+#~ "Power parameter; greater values assign greater influence to closer points"
+#~ msgstr ""
+#~ "Power-Parameter; größere Werte geben ein näheren Punkten ein stärkeres "
+#~ "Gewicht."
 #~ msgid "No data points found"
 #~ msgstr "Keine Datenpunkte gefunden."
@@ -46616,13 +50780,16 @@
 #~ msgstr "Füge Punkte an punktlose Knoten hinzu"
 #~ msgid "New points are excluded from shortest path calculations."
-#~ msgstr "Neue Punkte werden aus der Berechnung der kürzesten Pfade ausgeschlossen."
+#~ msgstr ""
+#~ "Neue Punkte werden aus der Berechnung der kürzesten Pfade ausgeschlossen."
 #~ msgid "vector, geometry, sampling"
 #~ msgstr "Vektor, Geometrie, Stichproben"
 #~ msgid "Converts vector map to 3D by sampling of elevation raster map."
-#~ msgstr "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit Höheninformationen."
+#~ msgstr ""
+#~ "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit "
+#~ "Höheninformationen."
 #~ msgid "Sampling method"
 #~ msgstr "Abtast-Methode (sampling)."
@@ -46637,7 +50804,9 @@
 #~ msgstr "Z-Wert für unbekannte Höhen."
 #~ msgid "Will set Z to this value, if value from raster map can not be read"
-#~ msgstr "Werde Z auf diesen Wert setzen, wenn der Wert der Rasterkarte nicht gelesen werden kann."
+#~ msgstr ""
+#~ "Werde Z auf diesen Wert setzen, wenn der Wert der Rasterkarte nicht "
+#~ "gelesen werden kann."
 #~ msgid "Layer 0 not supported"
 #~ msgstr "Layer 0 wird nicht unterstützt."
@@ -46646,10 +50815,15 @@
 #~ msgstr "Zu Ihrer Abfrage passen keine Objekte"
 #~ msgid "Due to error attribute data to new map are not transferred"
-#~ msgstr "Auf Grund eines Fehlers werden die Attributdaten nicht in die neue Karte übetragen."
+#~ msgstr ""
+#~ "Auf Grund eines Fehlers werden die Attributdaten nicht in die neue Karte "
+#~ "übetragen."
-#~ msgid "No features drapped. Check Your computational region and input raster map."
-#~ msgstr "Keine Objekte wurden drapiert. Überprüfen Sie die aktuelle Region und die Eingabe-Rasterkarte."
+#~ msgid ""
+#~ "No features drapped. Check Your computational region and input raster map."
+#~ msgstr ""
+#~ "Keine Objekte wurden drapiert. Überprüfen Sie die aktuelle Region und die "
+#~ "Eingabe-Rasterkarte."
 #~ msgid "Rebuilding topology..."
 #~ msgstr "Baue Topologie neu auf..."
@@ -46670,7 +50844,8 @@
 #~ msgstr "Linien-Buffer... "
 #~ msgid "The tolerance was reset to %g (map units). [category %d]"
-#~ msgstr "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt [Kategorie %d]."
+#~ msgstr ""
+#~ "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt [Kategorie %d]."
 #~ msgid "Areas buffers... "
 #~ msgstr "Flächen-Buffer ..."
@@ -46679,7 +50854,8 @@
 #~ msgstr "Füge Zentroide hinzu..."
 #~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
+#~ msgstr ""
+#~ "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
 #~ msgid "region;current region;coor;use 'coor' and 'box' options"
 #~ msgstr "region;aktuelle Region;coor;Verwende die 'coor' und 'box' Optionen"
@@ -46690,23 +50866,39 @@
 #~ msgid "vector, extract"
 #~ msgstr "Vektor, extrahieren"
-#~ msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
-#~ msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
+#~ msgid ""
+#~ "Selects vector objects from an existing vector map and creates a new map "
+#~ "containing only the selected objects."
+#~ msgstr ""
+#~ "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine "
+#~ "neue Karte nur mit den selektierten Objekten."
 #~ msgid "Do not copy table (see also 'new' parameter)"
-#~ msgstr "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
+#~ msgstr ""
+#~ "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
-#~ msgid "Layer number (if -1, all features in all layers of given type are extracted)"
-#~ msgstr "Layernummer (wenn -1, dann werden alle Objekte in allen Layern des angegebenen Typs extrahiert)."
+#~ msgid ""
+#~ "Layer number (if -1, all features in all layers of given type are "
+#~ "extracted)"
+#~ msgstr ""
+#~ "Layernummer (wenn -1, dann werden alle Objekte in allen Layern des "
+#~ "angegebenen Typs extrahiert)."
-#~ msgid "Enter -1 to keep original categories or the desired NEW category value"
-#~ msgstr "Geben Sie -1 ein, um die originalen Kategorien beizubehalten oder der erwünschte NEUE Kategoriewert."
+#~ msgid ""
+#~ "Enter -1 to keep original categories or the desired NEW category value"
+#~ msgstr ""
+#~ "Geben Sie -1 ein, um die originalen Kategorien beizubehalten oder der "
+#~ "erwünschte NEUE Kategoriewert."
 #~ msgid "If new >= 0, table is not copied"
 #~ msgstr "Wenn neu >= 0, wird die Tabelle nicht kopiert."
-#~ msgid "List, file, where and random options are exclusive. Please specify only one of them"
-#~ msgstr "Die Optionen list, file, where und random schließen sich gegenseitig aus. Bitte geben Sie nur eine von diesen an."
+#~ msgid ""
+#~ "List, file, where and random options are exclusive. Please specify only "
+#~ "one of them"
+#~ msgstr ""
+#~ "Die Optionen list, file, where und random schließen sich gegenseitig aus. "
+#~ "Bitte geben Sie nur eine von diesen an."
 #~ msgid "Process file <%s> for category numbers"
 #~ msgstr "Bearbeite Datei <%s> für Kategorienummern."
@@ -46714,14 +50906,19 @@
 #~ msgid "%d categories loaded from table <%s>"
 #~ msgstr "%d Kategorien von der Tabelle <%s> geladen."
-#~ msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
-#~ msgstr "Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der eindeutigen \"%s\" Objekt-Kategorien %d."
+#~ msgid ""
+#~ "Random category count is larger or equal to uniq \"%s\" feature category "
+#~ "count %d"
+#~ msgstr ""
+#~ "Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der "
+#~ "eindeutigen \"%s\" Objekt-Kategorien %d."
 #~ msgid "Name of input vector map containing lines"
 #~ msgstr "Namde der Eingabe-Vektorkarte mit Linien."
 #~ msgid "Name for output vector map where segments will be written"
-#~ msgstr "Name der Ausgabe-Vektorkarte, in die die Segmente geschrieben werden."
+#~ msgstr ""
+#~ "Name der Ausgabe-Vektorkarte, in die die Segmente geschrieben werden."
 #~ msgid "Converts a GRASS binary vector map to VTK ASCII output."
 #~ msgstr "Konvertieren eine GRASS Vektorkarte zu einer VTK ASCII-Datei."
@@ -46736,16 +50933,22 @@
 #~ msgstr "Liest die Vertices einer Vektorlinie"
 #~ msgid "Use all vector points (do not limit to current region)"
-#~ msgstr "Verwende alle Punkte (beschränkt sich nicht auf die aktuelle Region)."
+#~ msgstr ""
+#~ "Verwende alle Punkte (beschränkt sich nicht auf die aktuelle Region)."
 #~ msgid "Convex hull calculation requires at least three points. Exiting."
-#~ msgstr "Die Berechnung der konvexen Hülle erfordert mindestens drei Punkte. Beende mich."
+#~ msgstr ""
+#~ "Die Berechnung der konvexen Hülle erfordert mindestens drei Punkte. "
+#~ "Beende mich."
 #~ msgid "vector, volume, conversion"
 #~ msgstr "Vektor, Volumen, Konvertierung"
-#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
-#~ msgstr "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D-Rasterkarte. "
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr ""
+#~ "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D-Rasterkarte. "
 #~ msgid "Column name (type must be numeric)"
 #~ msgstr "Spaltenname (Spaltentyp muss numerisch sein)."
@@ -46759,8 +50962,23 @@
 #~ msgid "Layer number (to)"
 #~ msgstr "Layer-Nummer (to)."
-#~ msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate of the nearest point on the 'to' feature;to_along;distance to the nearest point on the 'to' feature along that linear feature;to_angle;angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature given by to_column option"
-#~ msgstr "cat;Kategorie des nächsten Objektes;dist;Minimumdistanz zum nächsten Objekt;to_x;X Koordinate des nächsten Punkts des 'to'-Objektes;to_y;Y Koordinate des nächsten Punktes des 'to'-Objektes;to_along;Distanz zum nächsten Punkt des 'to'-Objektes entlang des linearen Objektes;to_angle;Winkel entlang des nächsten linearen Objektes der 'to'-Karte, gemessen gegen den Uhrzeigersinn von der positiven X-Achse im Bogenmaß (zwischen -Pi und Pi);to_attr;Attribut des nächsten Objektes gegeben durch die Option to_column"
+#~ msgid ""
+#~ "cat;category of the nearest feature;dist;minimum distance to nearest "
+#~ "feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y "
+#~ "coordinate of the nearest point on the 'to' feature;to_along;distance to "
+#~ "the nearest point on the 'to' feature along that linear feature;to_angle;"
+#~ "angle along the nearest linear feature in the 'to' map, measured CCW from "
+#~ "the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute "
+#~ "of nearest feature given by to_column option"
+#~ msgstr ""
+#~ "cat;Kategorie des nächsten Objektes;dist;Minimumdistanz zum nächsten "
+#~ "Objekt;to_x;X Koordinate des nächsten Punkts des 'to'-Objektes;to_y;Y "
+#~ "Koordinate des nächsten Punktes des 'to'-Objektes;to_along;Distanz zum "
+#~ "nächsten Punkt des 'to'-Objektes entlang des linearen Objektes;to_angle;"
+#~ "Winkel entlang des nächsten linearen Objektes der 'to'-Karte, gemessen "
+#~ "gegen den Uhrzeigersinn von der positiven X-Achse im Bogenmaß (zwischen -"
+#~ "Pi und Pi);to_attr;Attribut des nächsten Objektes gegeben durch die "
+#~ "Option to_column"
 #~ msgid "From_map"
 #~ msgstr "From_map"
@@ -46775,7 +50993,9 @@
 #~ msgstr "Vektorkarte mit Stichprobenpunkten."
 #~ msgid "Output quadrant centres, number of points is written as category"
-#~ msgstr "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie ausgegeben."
+#~ msgstr ""
+#~ "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie "
+#~ "ausgegeben."
 #~ msgid "Counting sites in quadrats..."
 #~ msgstr "Zähle Sites in den Quadraten..."
@@ -46795,11 +51015,15 @@
 #~ msgid "Query layer number (read from)"
 #~ msgstr "Abfragelayernummer (lesen)"
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
-#~ msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar),r(adians),d(egrees)"
+#~ msgid ""
+#~ "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),"
+#~ "d(egrees)"
+#~ msgstr ""
+#~ "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar),r(adians),d(egrees)"
 #~ msgid "In print mode prints totals for options: length,area,count"
-#~ msgstr "Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
+#~ msgstr ""
+#~ "Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
 #~ msgid "vector, transformation, 3D"
 #~ msgstr "Vektor, Transformation, 3D"
@@ -46807,14 +51031,26 @@
 #~ msgid "%s failed"
 #~ msgstr "%s fehlgeschlagen"
-#~ msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
-#~ msgstr "and;auch als 'intersection' im GIS bekannt;or;auch als 'union' im GIS bekannt (nur für atype=area);not;Objekt von ainput nicht überlagert von Objekten von binput;xor;Objekt von ainput oder binput, aber nicht solche von ainput die von binput überlagert werden(nur für atype=area)"
+#~ msgid ""
+#~ "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
+#~ "(only for atype=area);not;features from ainput not overlayed by features "
+#~ "from binput;xor;features from either ainput or binput but not those from "
+#~ "ainput overlayed by binput (only for atype=area)"
+#~ msgstr ""
+#~ "and;auch als 'intersection' im GIS bekannt;or;auch als 'union' im GIS "
+#~ "bekannt (nur für atype=area);not;Objekt von ainput nicht überlagert von "
+#~ "Objekten von binput;xor;Objekt von ainput oder binput, aber nicht solche "
+#~ "von ainput die von binput überlagert werden(nur für atype=area)"
 #~ msgid "Copying vector objects from vector map <%s>..."
 #~ msgstr "Kopiere Vektorobjekte von der Vektorkarte <%s>..."
-#~ msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
-#~ msgstr "left;Parallele Linie ist links;right;Parallele Linie ist rechts;both;Parallele Linien auf beiden Seiten"
+#~ msgid ""
+#~ "left;Parallel line is on the left;right;Parallel line is on the right;"
+#~ "both;Parallel lines on both sides"
+#~ msgstr ""
+#~ "left;Parallele Linie ist links;right;Parallele Linie ist rechts;both;"
+#~ "Parallele Linien auf beiden Seiten"
 #~ msgid "vector, network, flow"
 #~ msgstr "Vektor, Netzwerk, Fluss"
@@ -46847,17 +51083,23 @@
 #~ msgstr "Vektor, External, Import"
 #~ msgid "Creates a new vector as a read-only link to OGR layer."
-#~ msgstr "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu einem OGR-Layer."
+#~ msgstr ""
+#~ "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu "
+#~ "einem OGR-Layer."
 #~ msgid "Output vector. If not given, available layers are printed only."
-#~ msgstr "Ausgabevektor. Wenn nicht benannt, werden alle verfügbaren Layer lediglichangezeigt."
+#~ msgstr ""
+#~ "Ausgabevektor. Wenn nicht benannt, werden alle verfügbaren Layer "
+#~ "lediglichangezeigt."
 #~ msgid ""
-#~ "OGR layer name. If not given, available layers are printed only. Examples:\n"
+#~ "OGR layer name. If not given, available layers are printed only. "
+#~ "Examples:\n"
 #~ "\t\tESRI Shapefile: shapefile name\n"
 #~ "\t\tMapInfo File: mapinfo file name"
 #~ msgstr ""
-#~ "OGR Layer-Name. Falls nicht angegeben, werden alle vorhandenen Layernamen lediglich angezeigt. Beispiele:\n"
+#~ "OGR Layer-Name. Falls nicht angegeben, werden alle vorhandenen Layernamen "
+#~ "lediglich angezeigt. Beispiele:\n"
 #~ "\t\tESRI Shapefile: Name des Shapefiles\n"
 #~ "\t\tMapInfo File: Name der MapInfo-Datei"
@@ -46877,10 +51119,38 @@
 #~ msgstr "Vektor, Editieren, Geometrie"
 #~ msgid "Creating new DB connection based on default mapset settings..."
-#~ msgstr "Erzeuge neue DB-Verbindung, basierend auf den Mapset-Einstellungen..."
+#~ msgstr ""
+#~ "Erzeuge neue DB-Verbindung, basierend auf den Mapset-Einstellungen..."
-#~ msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
-#~ msgstr "create;Erzeuge ein neue (leere) Vektorkarte;add;Fügt neue Objekte zu einer existierenden Vektorkarte hinzu;delete;Entfernt selektierte Objekte von einer Vektorkarte;move;Verschiebt selektierte Objekte in einer Vektorkarte;vertexmove;Verschiebt einen Vertex selektierter Vektorlinien;vertexdel;Entfernt einen Vertex aus selektierten Vektorlinien;vertexadd;Fügt einen neuen Vertex zu selektierten Vektorlinien hinzu;merge;Vereinigt selektierte Vektorlinien;break;Teilt Vektorlinien;select;Selektiert Linien und gibt ihre ID aus;catadd;Vergibt neue Kategorien für selektierte Vektorobjekte eines bestimmten Layers;catdel;Löscht Kategorien von selektierten Vektorobjekten eines bestimmten Layers;copy;Kopiert selektierte Feature;snap;Fange Vektorobjekt innerhalb des angegebenen Toleranz;flip;Drehe die Richtung selektierter Vektorlinien um;connect;Verbinde zwei Linien;zbulk;Z-Massen-Beschriftung (automatisierte Zuweisung der Z Koordinate zu Vektorlinien);chtype;Ändere den T
 yp des Features(Punkt<->Zentroid, Linie<->Grenze)"
+#~ msgid ""
+#~ "create;Create new (empty) vector map;add;Add new features to existing "
+#~ "vector map;delete;Delete selected features from vector map;move;Move "
+#~ "selected features in vector map;vertexmove;Move vertex of selected vector "
+#~ "lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add "
+#~ "new vertex to selected vector lines;merge;Merge selected vector lines;"
+#~ "break;Break/split vector lines;select;Select lines and print their ID's;"
+#~ "catadd;Set new categories to selected vector features for defined layer;"
+#~ "catdel;Delete categories from selected vector features for defined layer;"
+#~ "copy;Copy selected features;snap;Snap vector features in given threshold;"
+#~ "flip;Flip direction of selected vector lines;connect;Connect two lines;"
+#~ "zbulk;Z bulk-labeling (automated assignment of z coordinate to vector "
+#~ "lines);chtype;Change feature type (point<->centroid, line<->boundary)"
+#~ msgstr ""
+#~ "create;Erzeuge ein neue (leere) Vektorkarte;add;Fügt neue Objekte zu "
+#~ "einer existierenden Vektorkarte hinzu;delete;Entfernt selektierte Objekte "
+#~ "von einer Vektorkarte;move;Verschiebt selektierte Objekte in einer "
+#~ "Vektorkarte;vertexmove;Verschiebt einen Vertex selektierter Vektorlinien;"
+#~ "vertexdel;Entfernt einen Vertex aus selektierten Vektorlinien;vertexadd;"
+#~ "Fügt einen neuen Vertex zu selektierten Vektorlinien hinzu;merge;"
+#~ "Vereinigt selektierte Vektorlinien;break;Teilt Vektorlinien;select;"
+#~ "Selektiert Linien und gibt ihre ID aus;catadd;Vergibt neue Kategorien für "
+#~ "selektierte Vektorobjekte eines bestimmten Layers;catdel;Löscht "
+#~ "Kategorien von selektierten Vektorobjekten eines bestimmten Layers;copy;"
+#~ "Kopiert selektierte Feature;snap;Fange Vektorobjekt innerhalb des "
+#~ "angegebenen Toleranz;flip;Drehe die Richtung selektierter Vektorlinien um;"
+#~ "connect;Verbinde zwei Linien;zbulk;Z-Massen-Beschriftung (automatisierte "
+#~ "Zuweisung der Z Koordinate zu Vektorlinien);chtype;Ändere den Typ des "
+#~ "Features(Punkt<->Zentroid, Linie<->Grenze)"
 #~ msgid "ASCII file to be converted to binary vector map"
 #~ msgstr "ASCII-Datei, die in eine Vektorkarte konvertiert werden soll."
@@ -46889,13 +51159,23 @@
 #~ msgstr "Lese von der Standardeingabe, wenn nicht angegeben (oder \"-\")."
 #~ msgid "Difference in x,y direction for moving feature or vertex"
-#~ msgstr "Differenz in x,y Richtung für das Verschieben eines Objektes oder Vertex."
+#~ msgstr ""
+#~ "Differenz in x,y Richtung für das Verschieben eines Objektes oder Vertex."
-#~ msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
-#~ msgstr "length; Selektiere nur Linien oder Grenzen kürzer/länger als der Schwellwert; dangle; Selektiere Überstände (dangles) kürzer/länger als der Schwellwert"
+#~ msgid ""
+#~ "length;Select only lines or boundaries shorter/longer than threshold "
+#~ "distance;dangle;Select dangles shorter/longer than threshold distance"
+#~ msgstr ""
+#~ "length; Selektiere nur Linien oder Grenzen kürzer/länger als der "
+#~ "Schwellwert; dangle; Selektiere Überstände (dangles) kürzer/länger als "
+#~ "der Schwellwert"
-#~ msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
-#~ msgstr "no; Kein Fangen; node; Nur an Knoten Fangen; vertex; Erlaube Fangen auch an Vertices"
+#~ msgid ""
+#~ "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also "
+#~ "to vertex"
+#~ msgstr ""
+#~ "no; Kein Fangen; node; Nur an Knoten Fangen; vertex; Erlaube Fangen auch "
+#~ "an Vertices"
 #~ msgid "Error reading ASCII file: '%s'"
 #~ msgstr "Fehler beim Lesen der ASCII-Datei: '%s'."
@@ -46918,11 +51198,20 @@
 #~ msgid "Allocate subnets for nearest centres (direction from centre)."
 #~ msgstr "Sammle Teilnetze für nächste Zentren (Richtung: vom Zentrum)."
-#~ msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
-#~ msgstr "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knoten gehen im die Berechnung mit ein."
+#~ msgid ""
+#~ "Centre node must be opened (costs >= 0). Costs of centre node are used in "
+#~ "calculation"
+#~ msgstr ""
+#~ "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen "
+#~ "Knoten gehen im die Berechnung mit ein."
-#~ msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
-#~ msgstr "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegeben."
+#~ msgid ""
+#~ "Categories of centres (points on nodes) to which net will be allocated, "
+#~ "layer for this categories is given by nlayer option"
+#~ msgstr ""
+#~ "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen "
+#~ "wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option "
+#~ "angegeben."
 #~ msgid "Number of centres: [%d] (nlayer: [%d])"
 #~ msgstr "Zahl der Zentren: [%d] (nlayer: [%d])."
@@ -46942,8 +51231,13 @@
 #~ msgid "Create Steiner tree for the network and given terminals"
 #~ msgstr "Erzeuge 'Steiner Tree' für das Netzwerk und die gegebenen Stationen"
-#~ msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
-#~ msgstr "Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis suboptimal sein."
+#~ msgid ""
+#~ "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic "
+#~ "algorithm is used in this module so the result may be sub optimal"
+#~ msgstr ""
+#~ "Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem "
+#~ "Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis "
+#~ "suboptimal sein."
 #~ msgid "vector, network, isolines"
 #~ msgstr "Vektor, Netzwerk, Isolinien"
@@ -46952,7 +51246,8 @@
 #~ msgstr "Vektor, Raster, Attributtabelle"
 #~ msgid "Name of input vector points map for which to edit attribute table"
-#~ msgstr "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
+#~ msgstr ""
+#~ "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
 #~ msgid "Column name (will be updated by raster values)"
 #~ msgstr "Spaltenname (die mit den Rasterwerten aktualisiert wird)."
@@ -46978,8 +51273,26 @@
 #~ msgid "overlap;features partially or completely overlap"
 #~ msgstr "overlap; Objekte überlappen sich teilweise oder vollständig"
-#~ msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
-#~ msgstr "overlap;Objekte überlappen sich ganz oder teilweise;equals;Objekte sind im Raum gleich (mit GEOS);disjoint;Objekte überschneiden sich räumlich nicht (mit GEOS);intersects;Objekte überschneiden sich räumlich (mit GEOS);touches;Objekte berühren sich räumlich (mit  GEOS);crosses;Objekte kreuzen sich räumlich (mit GEOS);within;Objekt A ist komplett innerhalb von Objekt B (mit GEOS);contains;Objekt B ist komplett innerhalb von Objekt A (mit GEOS);overlaps;Objekte überlappen sich räumlich (mit GEOS);relate;Objekt A besitzt einen räumlichen Bezug zu Objekt B (mit GEOS, Option 'relate' erforderlich);"
+#~ msgid ""
+#~ "overlap;features partially or completely overlap;equals;features are "
+#~ "spatially equals (using GEOS);disjoint;features do not spatially "
+#~ "intersect (using GEOS);intersects;features spatially intersect (using "
+#~ "GEOS);touches;features spatially touches (using GEOS);crosses;features "
+#~ "spatially crosses (using GEOS);within;feature A is completely inside "
+#~ "feature B (using GEOS);contains;feature B is completely inside feature A "
+#~ "(using GEOS);overlaps;features spatially overlap (using GEOS);relate;"
+#~ "feature A is spatially related to feature B (using GEOS, requires "
+#~ "'relate' option);"
+#~ msgstr ""
+#~ "overlap;Objekte überlappen sich ganz oder teilweise;equals;Objekte sind "
+#~ "im Raum gleich (mit GEOS);disjoint;Objekte überschneiden sich räumlich "
+#~ "nicht (mit GEOS);intersects;Objekte überschneiden sich räumlich (mit "
+#~ "GEOS);touches;Objekte berühren sich räumlich (mit  GEOS);crosses;Objekte "
+#~ "kreuzen sich räumlich (mit GEOS);within;Objekt A ist komplett innerhalb "
+#~ "von Objekt B (mit GEOS);contains;Objekt B ist komplett innerhalb von "
+#~ "Objekt A (mit GEOS);overlaps;Objekte überlappen sich räumlich (mit GEOS);"
+#~ "relate;Objekt A besitzt einen räumlichen Bezug zu Objekt B (mit GEOS, "
+#~ "Option 'relate' erforderlich);"
 #~ msgid "vector, LIDAR"
 #~ msgstr "Vektor, LIDAR"
@@ -46996,29 +51309,43 @@
 #~ msgid "Unable to access table <%s>"
 #~ msgstr "Kann nicht auf die Tabelle <%s> zugreifen."
-#~ msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-#~ msgstr "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
+#~ msgid ""
+#~ "Bicubic or bilinear spline interpolation with Tykhonov regularization."
+#~ msgstr ""
+#~ "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-"
+#~ "Regularisierung."
 #~ msgid "Name of input vector map of sparse points"
 #~ msgstr "Eingabe Vektorkarte mit wenigen Punkten."
 #~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#~ msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält (wenn layer > 0)."
+#~ msgstr ""
+#~ "Spalte der Attributtabelle, die zu interpolierende Werte enthält (wenn "
+#~ "layer > 0)."
 #~ msgid "Need either 3D vector or layer and column with z values"
-#~ msgstr "Brauche entweder ein 3D Vektor oder ein Layer und Spalte mit Z-Werten. "
+#~ msgstr ""
+#~ "Brauche entweder ein 3D Vektor oder ein Layer und Spalte mit Z-Werten. "
 #~ msgid "Layer but not column with z values given"
 #~ msgstr "Ein Layer aber keine Spalte mit Z-Werten erhalten."
-#~ msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
-#~ msgstr "Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
+#~ msgid ""
+#~ "Sorry, <%s> driver is not allowed for vector output in this module. Try "
+#~ "with a raster output or other driver."
+#~ msgstr ""
+#~ "Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul "
+#~ "erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
 #~ msgid "Cannot read field info"
 #~ msgstr "Kann Feld-Information nicht lesen."
-#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
-#~ msgstr "Kann keinen Speicher für Hilfsmatrix reservieren. Erwägen Sie die Auflösung der Region zu ändern."
+#~ msgid ""
+#~ "Cannot allocate memory for auxiliar matrix.Consider changing region "
+#~ "resolution"
+#~ msgstr ""
+#~ "Kann keinen Speicher für Hilfsmatrix reservieren. Erwägen Sie die "
+#~ "Auflösung der Region zu ändern."
 #~ msgid "vector, LIDAR, edges"
 #~ msgstr "Vektor, LIDAR, Kanten"
@@ -47030,7 +51357,9 @@
 #~ msgstr "Erzeugt Lineares Referenzsystem"
 #~ msgid "Creates stationing from input lines, and linear reference system"
-#~ msgstr "Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
+#~ msgstr ""
+#~ "Erzeuge Stationen auf Basis der Eingabelinien und dem "
+#~ "Linearenreferenzsystem."
 #~ msgid "vector, reclass, attributes"
 #~ msgstr "Vektor, Re-Klassifizierung, Attribute"
@@ -47041,8 +51370,15 @@
 #~ msgid "vector, raster, conversion"
 #~ msgstr "Vektor, Raster, Konvertierung"
-#~ msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
-#~ msgstr "attr;Lese Werte aus der Attributtabelle;cat;Verwende Kategoriewerte;val;Verwende Werte angegeben durch die Option 'value';z;Verwende die Z-Koordinate (nur Punkte oder Konturen);dir;Ausgabe als Flussrichtung (nur Linien)"
+#~ msgid ""
+#~ "attr;read values from attribute table;cat;use category values;val;use "
+#~ "value specified by value option;z;use z coordinate (points or contours "
+#~ "only);dir;output as flow direction (lines only)"
+#~ msgstr ""
+#~ "attr;Lese Werte aus der Attributtabelle;cat;Verwende Kategoriewerte;val;"
+#~ "Verwende Werte angegeben durch die Option 'value';z;Verwende die Z-"
+#~ "Koordinate (nur Punkte oder Konturen);dir;Ausgabe als Flussrichtung (nur "
+#~ "Linien)"
 #~ msgid "Unable to process areas from vector map <%s>"
 #~ msgstr "Kann Flächen der Vektorkarte <%s> nicht verarbeiten."
@@ -47057,7 +51393,8 @@
 #~ msgstr "Name der Schlüsselspalte."
 #~ msgid "Print all map connection parameters and exit in shell script style"
-#~ msgstr "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
+#~ msgstr ""
+#~ "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
 #~ msgid "When printing, limit to layer specified by the layer option"
 #~ msgstr "Beim Druck auf die Layer in der Layer-Option beschränken"
@@ -47068,8 +51405,11 @@
 #~ msgid "Create parallel line to input lines"
 #~ msgstr "Erzeuge eine parallele Linie zu der eingegebenen Linie."
-#~ msgid "Offset in map units, positive for right side, negative for left side."
-#~ msgstr "Versatz in Karteneinheiten, positiv für die rechte und negativ für die linke Seite."
+#~ msgid ""
+#~ "Offset in map units, positive for right side, negative for left side."
+#~ msgstr ""
+#~ "Versatz in Karteneinheiten, positiv für die rechte und negativ für die "
+#~ "linke Seite."
 #~ msgid "Layer number or name with route paths or -1"
 #~ msgstr "Layer-Nummer oder -Name mit Routing-Angaben oder -1"
@@ -47092,14 +51432,24 @@
 #~ msgid "Min-area & snap"
 #~ msgstr "Min-Fläche & Fangen"
-#~ msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
-#~ msgstr "point;Importiere Zentroide als Punkte;line;Importiere Grenzen als Linien;boundary;Importiere Linien als Grenzen;centroid;Importiere Punkte als Zentroide"
+#~ msgid ""
+#~ "point;import area centroids as points;line;import area boundaries as "
+#~ "lines;boundary;import lines as area boundaries;centroid;import points as "
+#~ "centroids"
+#~ msgstr ""
+#~ "point;Importiere Zentroide als Punkte;line;Importiere Grenzen als Linien;"
+#~ "boundary;Importiere Linien als Grenzen;centroid;Importiere Punkte als "
+#~ "Zentroide"
 #~ msgid "Data source contains %d layers:"
 #~ msgstr "Datenquelle enthält %d Layer:"
-#~ msgid "Unable to convert input map projection to GRASS format; cannot create new location"
-#~ msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; kann daher keine neue Location erstellen."
+#~ msgid ""
+#~ "Unable to convert input map projection to GRASS format; cannot create new "
+#~ "location"
+#~ msgstr ""
+#~ "Kann die Projektion der Eingabekarte nicht in das GRASS-Format "
+#~ "konvertieren; kann daher keine neue Location erstellen."
 #~ msgid "Layer: %s"
 #~ msgstr "Layer: %s"
@@ -47155,8 +51505,12 @@
 #~ msgid "Write centroids:"
 #~ msgstr "Schreibe Zentroide:"
-#~ msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
-#~ msgstr "Eingabekarte enthält 3D-Objekte. Erstellte Vektorkarte ist allerdings nur 2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
+#~ msgid ""
+#~ "Input data contains 3D features. Created vector is 2D only, use -z flag "
+#~ "to import 3D vector"
+#~ msgstr ""
+#~ "Eingabekarte enthält 3D-Objekte. Erstellte Vektorkarte ist allerdings nur "
+#~ "2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
 #~ msgid "Cannot read part of geometry"
 #~ msgstr "Kann Teil der Geometrie nicht lesen."
@@ -47173,7 +51527,8 @@
 #~ msgid "vector, network, components"
 #~ msgstr "Vektor, Netzwerk, Komponenten"
-#~ msgid "weak;Weakly connected components;strong;Strongly connected components;"
+#~ msgid ""
+#~ "weak;Weakly connected components;strong;Strongly connected components;"
 #~ msgstr "weak;Schwach verbundene Elemente;strong;Stark verbundene Elemente;"
 #~ msgid "vector, geometry, statistics"
@@ -47185,20 +51540,49 @@
 #~ msgid "Vector points to be spatially perturbed"
 #~ msgstr "Vektorpunkte die räumlich gestört werden sollen."
-#~ msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
-#~ msgstr "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
+#~ msgid ""
+#~ "Parameter(s) of distribution. If the distribution is uniform, only one "
+#~ "parameter, the maximum, is needed. For a normal distribution, two "
+#~ "parameters, the mean and standard deviation, are required."
+#~ msgstr ""
+#~ "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird "
+#~ "nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind "
+#~ "zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
 #~ msgid "vector, network, centrality measures"
 #~ msgstr "Vektor, Netzwerk, Zentralitätsmaß"
-#~ msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
-#~ msgstr "Vektor, Generalisierung, Vereinfachung, Glättung, Verschiebung, Netzwerk-Generalisierung"
+#~ msgid ""
+#~ "vector, generalization, simplification, smoothing, displacement, network "
+#~ "generalization"
+#~ msgstr ""
+#~ "Vektor, Generalisierung, Vereinfachung, Glättung, Verschiebung, Netzwerk-"
+#~ "Generalisierung"
 #~ msgid "Vector based generalization."
 #~ msgstr "Vektorbasierte Generalisierung."
-#~ msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
-#~ msgstr "douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht beieinander liegen;reumann;Reumann-Witkam Algorithmus;boyle;Boyle's vorausschauender Algorithmus;sliding_averaging;McMaster's gleitender Mittelwert-Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit kubischen Hermite-Splines;snakes;Snake-Methoden zum Glätten von Linien;network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die dicht beieinander liegen;"
+#~ msgid ""
+#~ "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
+#~ "Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
+#~ "reduction;Vertex Reduction Algorithm eliminates points close to each "
+#~ "other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking "
+#~ "Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;"
+#~ "distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;"
+#~ "Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;"
+#~ "Snakes method for line smoothing;network;Network generalization;"
+#~ "displacement;Displacement of lines close to each other;"
+#~ msgstr ""
+#~ "douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker "
+#~ "Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;"
+#~ "reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht "
+#~ "beieinander liegen;reumann;Reumann-Witkam Algorithmus;boyle;Boyle's "
+#~ "vorausschauender Algorithmus;sliding_averaging;McMaster's gleitender "
+#~ "Mittelwert-Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-"
+#~ "Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit "
+#~ "kubischen Hermite-Splines;snakes;Snake-Methoden zum Glätten von Linien;"
+#~ "network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die "
+#~ "dicht beieinander liegen;"
 #~ msgid "Copy attributes"
 #~ msgstr "Kopiere Attribute"
@@ -47224,11 +51608,17 @@
 #~ msgid "Column name and type (i.e. INTEGER, DOUBLE PRECISION) for z values"
 #~ msgstr "Spaltenname und -typ (z.B. INTEGER, DOUBLE PRECISION) für z Werte."
-#~ msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
-#~ msgstr "Wenn kein Typ angegeben wurde, wird DOUBLE PRECISION verwendet. Schreibe Z Werte in eine Spalte an Stelle einer 3D Vektorkarte."
+#~ msgid ""
+#~ "If type is not given then DOUBLE PRECISION is used. Writes Z data to "
+#~ "column instead of 3D vector."
+#~ msgstr ""
+#~ "Wenn kein Typ angegeben wurde, wird DOUBLE PRECISION verwendet. Schreibe "
+#~ "Z Werte in eine Spalte an Stelle einer 3D Vektorkarte."
 #~ msgid "v.random can't create 3D vector and attribute table at same time"
-#~ msgstr "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit erstellen."
+#~ msgstr ""
+#~ "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit "
+#~ "erstellen."
 #~ msgid "Using 'double precision' for column <%s>"
 #~ msgstr "Verwende 'double precision' für die Spalte <%s>"
@@ -47237,7 +51627,9 @@
 #~ msgstr "Vektor, Raster, Aggregation"
 #~ msgid "The configuration file can be used only with \t\t\t%s rasterfile"
-#~ msgstr "Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s Rasterkarte."
+#~ msgstr ""
+#~ "Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s "
+#~ "Rasterkarte."
 #~ msgid "Name of the Manning's n value"
 #~ msgstr "Name des Manning's n Parameters."
@@ -47276,14 +51668,26 @@
 #~ msgid "Sets the legend's text color"
 #~ msgstr "Setzt die Texfarbe für die Legende."
-#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
-#~ msgstr "Datei die Instruktionen zum Kartenzeichnen enthält (Oder benutzen Sie input=- für eine interaktive Eingabe über die Tastatur)."
+#~ msgid ""
+#~ "File containing mapping instructions (or use input=- to enter from "
+#~ "keyboard)"
+#~ msgstr ""
+#~ "Datei die Instruktionen zum Kartenzeichnen enthält (Oder benutzen Sie "
+#~ "input=- für eine interaktive Eingabe über die Tastatur)."
-#~ msgid "Product creation date not in metadata file <%s>, input this data in the command line parameters"
-#~ msgstr "Erzeugungsdatum des Produkts nicht in der Metadaten-Datei <%s>. Geben Sie die Daten in der Kommandozeile ein."
+#~ msgid ""
+#~ "Product creation date not in metadata file <%s>, input this data in the "
+#~ "command line parameters"
+#~ msgstr ""
+#~ "Erzeugungsdatum des Produkts nicht in der Metadaten-Datei <%s>. Geben Sie "
+#~ "die Daten in der Kommandozeile ein."
-#~ msgid "Unable to read solar elevation from metadata file in metadata file <%s>, input this data in the command line parameters"
-#~ msgstr "Kann die Sonnenhöhe nicht aus der Metadaten-Datei <%s> lesen. Geben Sie diese Daten auf der Kommandozeile ein."
+#~ msgid ""
+#~ "Unable to read solar elevation from metadata file in metadata file <%s>, "
+#~ "input this data in the command line parameters"
+#~ msgstr ""
+#~ "Kann die Sonnenhöhe nicht aus der Metadaten-Datei <%s> lesen. Geben Sie "
+#~ "diese Daten auf der Kommandozeile ein."
 #~ msgid "Unknown column type '%s'"
 #~ msgstr "Unbekannter Spalten-Typ '%s'"
@@ -47291,17 +51695,29 @@
 #~ msgid "Building partial topology..."
 #~ msgstr "Erzeuge partielle Topologie..."
-#~ msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
-#~ msgstr "Konvertiert Beschreibungen von Koordinatensystemen (z.B. Projektinosinformationen) in verschiedene Formate (inklusive des GRASS-Formats)."
+#~ msgid ""
+#~ "Converts co-ordinate system descriptions (i.e. projection information) "
+#~ "between various formats (including GRASS format)."
+#~ msgstr ""
+#~ "Konvertiert Beschreibungen von Koordinatensystemen (z.B. "
+#~ "Projektinosinformationen) in verschiedene Formate (inklusive des GRASS-"
+#~ "Formats)."
 #~ msgid "Create/Edit"
 #~ msgstr "Erzeuge/Editiere"
-#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
-#~ msgstr "Erzeuge neue Projektionsdateien. Dies modifiziert die Projektionsinformationen der aktuellen Location, solange nicht der Parameter 'location' angegeben ist."
+#~ msgid ""
+#~ "Create new projection files (modifies current location unless 'location' "
+#~ "option specified)"
+#~ msgstr ""
+#~ "Erzeuge neue Projektionsdateien. Dies modifiziert die "
+#~ "Projektionsinformationen der aktuellen Location, solange nicht der "
+#~ "Parameter 'location' angegeben ist."
 #~ msgid "Enable interactive prompting (for command-line use only)"
-#~ msgstr "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der Befehlszeile)."
+#~ msgstr ""
+#~ "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der "
+#~ "Befehlszeile)."
 #~ msgid "Location %s created!"
 #~ msgstr "Location '%s' erstellt!"
@@ -47313,10 +51729,13 @@
 #~ msgstr ""
 #~ "\n"
 #~ "\n"
-#~ "WARNUNG! Eine Projektionsinformation für diese Location existiert bereits!\n"
+#~ "WARNUNG! Eine Projektionsinformation für diese Location existiert "
+#~ "bereits!\n"
-#~ msgid "Would you still like to overwrite the current projection information "
-#~ msgstr "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
+#~ msgid ""
+#~ "Would you still like to overwrite the current projection information "
+#~ msgstr ""
+#~ "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
 #~ msgid "Error writing PROJ_INFO"
 #~ msgstr "Fehler beim Schreiben der Datei PROJ_INFO."
@@ -47333,8 +51752,12 @@
 #~ msgid "Use G3D mask (if exists) with input map"
 #~ msgstr "Benutzt G3D Maske (falls existent) mit der Eingabekarte"
-#~ msgid "No vector map of sparse points to interpolate was specified. Interpolation will be done with <%s> vector map"
-#~ msgstr "Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die Interpolation erfolgt mit der <%s> Vektorkarte"
+#~ msgid ""
+#~ "No vector map of sparse points to interpolate was specified. "
+#~ "Interpolation will be done with <%s> vector map"
+#~ msgstr ""
+#~ "Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die "
+#~ "Interpolation erfolgt mit der <%s> Vektorkarte"
 #~ msgid "Inconsistent number of attributes (<%s/%s> %d: <%s> %d"
 #~ msgstr "Inkonsistente Attributanzahl (<%s/%s> %d: <%s> %d."
@@ -47429,8 +51852,12 @@
 #~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
 #~ msgstr "Konvertiert eine 3D-Rasterkarte (G3D) in das VTK-ASCII-Format."
-#~ msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
-#~ msgstr "Die 2D und 3D Regions Parameter sind unterschiedlich. Die G3D-Parameter werden verwendet, um die 2D Region anzupassen."
+#~ msgid ""
+#~ "The 2d and 3d region settings are different. The g3d settings are used to "
+#~ "adjust the 2d region."
+#~ msgstr ""
+#~ "Die 2D und 3D Regions Parameter sind unterschiedlich. Die G3D-Parameter "
+#~ "werden verwendet, um die 2D Region anzupassen."
 #~ msgid "unable to close input 3d raster map"
 #~ msgstr "Kann die Eingabe-3D-Rasterkarte nicht schließen."
@@ -47505,10 +51932,16 @@
 #~ msgstr "%d Grenzen wurden gelöscht, Flächen werden nicht erhalten."
 #~ msgid "New centroids were calculated, attribute attachment may be changed"
-#~ msgstr "Neue Zentroide wurden berechnet. Attributzuordnung kann sich geändert haben."
+#~ msgstr ""
+#~ "Neue Zentroide wurden berechnet. Attributzuordnung kann sich geändert "
+#~ "haben."
-#~ msgid "Areas may have disappeared and/or area attribute attachment may have changed"
-#~ msgstr "Flächen können verschwunden sein und/oder die Zuordnung der Attribute kann sich geändert haben."
+#~ msgid ""
+#~ "Areas may have disappeared and/or area attribute attachment may have "
+#~ "changed"
+#~ msgstr ""
+#~ "Flächen können verschwunden sein und/oder die Zuordnung der Attribute "
+#~ "kann sich geändert haben."
 #~ msgid "Try v.clean tool=prune thresh=%f"
 #~ msgstr "Versuchen Sie v.clean tool=prune thresh=%f"
@@ -47529,7 +51962,9 @@
 #~ msgstr " %.1f Zellen pro Minute\n"
 #~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr "Habe die Eingabe-Rasterkarte <%s> rektifiziert. Sie wird als <%s> gespeichert."
+#~ msgstr ""
+#~ "Habe die Eingabe-Rasterkarte <%s> rektifiziert. Sie wird als <%s> "
+#~ "gespeichert."
 #, fuzzy
 #~ msgid "Cannot open file [%s] in mapset [%s]"
@@ -47608,7 +52043,8 @@
 #~ "Sie müssen zumindest [north= south= east= west=] OR [r=\tc=] angeben."
 #~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr "Sie müssen alle Grenzen der geographischen Region (n,s,e,w) angeben."
+#~ msgstr ""
+#~ "Sie müssen alle Grenzen der geographischen Region (n,s,e,w) angeben."
 #~ msgid "Illegal number of rows <%s>"
 #~ msgstr "Ungültiger Zeilenanzahl <%s>."
@@ -47655,11 +52091,18 @@
 #~ msgid "Unable to write row %d"
 #~ msgstr "Kann die Zeile %d nicht schreiben."
-#~ msgid "Unable to write raster map. You might want to check available disk space and write permissions."
-#~ msgstr "Kann die Rasterkarte nicht schreiben. Sie sollten den verfügbaren Plattenplatz und die Schreibberechtigungen überprüfen."
+#~ msgid ""
+#~ "Unable to write raster map. You might want to check available disk space "
+#~ "and write permissions."
+#~ msgstr ""
+#~ "Kann die Rasterkarte nicht schreiben. Sie sollten den verfügbaren "
+#~ "Plattenplatz und die Schreibberechtigungen überprüfen."
-#~ msgid "Please select the file(s) you wish to rectify by naming an output file"
-#~ msgstr "Bitte wählen Sie die Dateie(n), die Sie rektifizieren möchten, in dem Sie eine Ausgabedatei benennen."
+#~ msgid ""
+#~ "Please select the file(s) you wish to rectify by naming an output file"
+#~ msgstr ""
+#~ "Bitte wählen Sie die Dateie(n), die Sie rektifizieren möchten, in dem Sie "
+#~ "eine Ausgabedatei benennen."
 #~ msgid "%s@%s: projection doesn't match current settings"
 #~ msgstr "%s@%s: Projektion passt nicht zu den aktuellen Einstellungen."
@@ -47683,7 +52126,8 @@
 #~ msgstr "Mapset der Eingabe-Rasterkarte."
 #~ msgid "You have to use a different location for input than the current"
-#~ msgstr "Sie müssen eine andere Location als Input verwenden als die Aktuelle."
+#~ msgstr ""
+#~ "Sie müssen eine andere Location als Input verwenden als die Aktuelle."
 #~ msgid "Checking location <%s>, mapset <%s>..."
 #~ msgstr "Prüfe Location <%s>, Mapset <%s>..."
@@ -47722,7 +52166,8 @@
 #~ msgstr "Zero (0) ist eine reale Höhenangabe"
 #~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr " %d.%02d.%02d, Tagnummer %d, Zeit: %02i:%02i:%02i (dezimale Zeit: %f)\n"
+#~ msgstr ""
+#~ " %d.%02d.%02d, Tagnummer %d, Zeit: %02i:%02i:%02i (dezimale Zeit: %f)\n"
 #~ msgid " long: %f, lat: %f, timezone: %f\n"
 #~ msgstr "geogr. Länge: %f, geogr. Breite: %f, Zeitzone: %f\n"
@@ -47789,8 +52234,12 @@
 #~ msgid "New MAPSET name"
 #~ msgstr "Neuer Mapset Name."
-#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
-#~ msgstr "Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch möglich."
+#~ msgid ""
+#~ "Displays and overlays raster map layers in the active display frame on "
+#~ "the graphics monitor."
+#~ msgstr ""
+#~ "Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch "
+#~ "möglich."
 #~ msgid "Displays vector data in the active frame on the graphics monitor."
 #~ msgstr "Stellt GRASS Vektorkarten im aktiven Grafikfenster dar."
@@ -47804,8 +52253,11 @@
 #~ msgid "Island size [%.1e], island not imported"
 #~ msgstr "Inselgröße [%.1e], Insel nicht importiert."
-#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr "Nummer der Spalte, die als X-Koordinate (erste Spalte ist 1)  für den Punkt-Modus genutzt wird."
+#~ msgid ""
+#~ "Number of column used as x coordinate (first column is 1) for points mode"
+#~ msgstr ""
+#~ "Nummer der Spalte, die als X-Koordinate (erste Spalte ist 1)  für den "
+#~ "Punkt-Modus genutzt wird."
 #~ msgid "Duplicate area centroids"
 #~ msgstr "Doppelte Zentroide"
@@ -47816,8 +52268,14 @@
 #~ msgid "Failed in attempt to open %s"
 #~ msgstr "Fehlschlag beim Versuch '%s' zu öffnen."
-#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
-#~ msgstr "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition werden vom Osten gegen den Uhrzeigersinn berechnet."
+#~ msgid ""
+#~ "Generates raster map layers of slope, aspect, curvatures and partial "
+#~ "derivatives from a raster map layer of true elevation values. Aspect is "
+#~ "calculated counterclockwise from east."
+#~ msgstr ""
+#~ "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
+#~ "Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition "
+#~ "werden vom Osten gegen den Uhrzeigersinn berechnet."
 #~ msgid "Raster elevation file name"
 #~ msgstr "Rasterkarte mit Höheninformationen."
@@ -47832,10 +52290,12 @@
 #~ msgstr "Dateiname für Ausgabekarte mit horizontaler Wölbung."
 #~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr "Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
+#~ msgstr ""
+#~ "Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
 #~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr "Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
+#~ msgstr ""
+#~ "Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
 #~ msgid "Output second order partial derivative dxx filename"
 #~ msgstr "Ausgabekarte der zweiten partiellen Ableitung dxx."
@@ -47882,8 +52342,14 @@
 #~ msgid "DXY [%s] COMPLETE"
 #~ msgstr "DXY [%s] KOMPLETT"
-#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
-#~ msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %g wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
+#~ msgid ""
+#~ "Input raster map contains cells with NULL-value (no-data). The value %g "
+#~ "was used to represent no-data values in the input map. You can specify "
+#~ "nodata value by %s parameter."
+#~ msgstr ""
+#~ "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der "
+#~ "Wert %g wurde verwendet um Nodata-Werte in der Eingabekarte zu "
+#~ "kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
 #~ msgid "raster, terrain analysis"
 #~ msgstr "Raster, Geländeanalyse"
@@ -47907,7 +52373,9 @@
 #~ msgstr "Kann die Maske (MASK) nicht öffnen."
 #~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer Hülle zu erzeugen."
+#~ msgstr ""
+#~ "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer "
+#~ "Hülle zu erzeugen."
 #~ msgid "Name of output vector area map"
 #~ msgstr "Name der Ausgabe-Vektorkarte mit Flächen."
@@ -47918,14 +52386,22 @@
 #~ msgid "It was impossible to create <Auxiliar_outlier_table>."
 #~ msgstr "Kann <Auxiliar_outlier_table> nicht erzeugen"
-#~ msgid "It was not possible to drop <%s> table. Nothing will be done. Try to drop it manually."
-#~ msgstr "Es war nicht möglich die Tabelle <%s> zu löschen. Nichts wird unternommen. Versuchen Sie die Tabelle manuell zu löschen."
+#~ msgid ""
+#~ "It was not possible to drop <%s> table. Nothing will be done. Try to drop "
+#~ "it manually."
+#~ msgstr ""
+#~ "Es war nicht möglich die Tabelle <%s> zu löschen. Nichts wird "
+#~ "unternommen. Versuchen Sie die Tabelle manuell zu löschen."
 #~ msgid "Cross Validation was success!"
 #~ msgstr "Die Kreuzvalidierung war erfolgreich."
-#~ msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
-#~ msgstr "Interpolation: Die Auflösung der Region ist zu hoch: %d Zellen. Überlegen Sie die Auflösung zu ändern."
+#~ msgid ""
+#~ "Interpolation: The region resolution is too high: %d cells. Consider to "
+#~ "change it."
+#~ msgstr ""
+#~ "Interpolation: Die Auflösung der Region ist zu hoch: %d Zellen. Überlegen "
+#~ "Sie die Auflösung zu ändern."
 #~ msgid "Creating auxiliar table for archiving overlapping zones"
 #~ msgstr "Erstelle Hilfstabelle um überlappende Zonen zu archivieren"
@@ -47953,7 +52429,9 @@
 #~ msgstr "Gib mehr Kommentare aus (Standard=schweigsam)."
 #~ msgid "All non-NULL and non-zero cells are considered as blocking terrain"
-#~ msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Hindernis aufgefasst."
+#~ msgstr ""
+#~ "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als "
+#~ "echte Hindernis aufgefasst."
 #~ msgid "It was impossible to open table"
 #~ msgstr "Es war unmöglich die Tabelle zu öffnen."
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_el.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_el\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2014-03-27 20:41+0100\n"
+"POT-Creation-Date: 2014-03-31 21:29+0200\n"
 "PO-Revision-Date: 2009-02-19 10:29+0200\n"
 "Last-Translator: Vasilios Antoniou <vantoniou at gmail.com>\n"
 "Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -1101,8 +1101,9 @@
 msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
 #: ../raster/r.stream.snap/main.c:47
-msgid "Delineates basins for stream network."
-msgstr ""
+#, fuzzy
+msgid "Snap point to modelled river network."
+msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
 #: ../raster/r.stream.snap/main.c:48
 msgid ""
@@ -1149,8 +1150,8 @@
 msgstr "¼íïìá åéóáãþìåíïõ äéáíõóìáôéêïý ÷Üñôç "
 #: ../raster/r.stream.snap/main.c:63 ../raster/r.stream.segment/main.c:64
-#: ../raster/r.stream.stats/main.c:60 ../raster/r.stream.channel/main.c:64
-#: ../raster/r.stream.order/main.c:32
+#: ../raster/r.stream.stats/main.c:60 ../raster/r.stream.distance/main.c:60
+#: ../raster/r.stream.channel/main.c:64 ../raster/r.stream.order/main.c:32
 #, fuzzy
 msgid "Name for input raster map with stream network"
 msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
@@ -8974,11 +8975,6 @@
 msgid "watercourse distance"
 msgstr ""
-#: ../raster/r.stream.distance/main.c:60
-#, fuzzy
-msgid "Name for input raster map with stream network"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
 #: ../raster/r.stream.distance/main.c:72
 #, fuzzy
 msgid "Calculation method"
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_es.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_es\n"
 "PO-Revision-Date: 2011-05-17 16:53+0100\n"
 "Last-Translator: Joana Palahí <joana at sigte.udg.edu>\n"
 "Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -1135,8 +1135,9 @@
 msgstr "%s: no se puede convertir a WKT"
-msgstr ""
+#, fuzzy
+msgstr "Mapa vectorial de puntos final"
 msgid ""
@@ -1183,8 +1184,8 @@
 msgstr "Nombre del mapa vectorial de puntos de entrada"
 #, fuzzy
 msgstr "Nombre del mapa ráster de entrada"
@@ -9535,11 +9536,6 @@
 msgstr "ráster, teselado"
-#, fuzzy
-msgstr "Nombre del mapa ráster de entrada"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_fr.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_fr\n"
 "PO-Revision-Date: 2014-01-01 11:35+0100\n"
 "Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
 "Language-Team: Français <grass-translations at lists.osgeo.org>\n"
@@ -1156,8 +1156,9 @@
 msgstr "%s : impossible de convertir en WKT"
-msgstr ""
+#, fuzzy
+msgstr "couche vecteur des points d'arrivée"
 msgid ""
@@ -1205,8 +1206,8 @@
 msgstr "Nom de la couche vecteur 2D source"
 #, fuzzy
 msgstr "Nom du nouveau fichier raster"
@@ -9998,11 +9999,6 @@
 msgstr "Erreur de calcul des distances"
-#, fuzzy
-msgstr "Nom du nouveau fichier raster"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_it.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -14,7 +14,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_it\n"
 "PO-Revision-Date: 2013-11-20 18:19+0100\n"
 "Last-Translator: az\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
@@ -1134,8 +1134,9 @@
 msgstr "%s, Impossibile convertire a WKT"
-msgstr ""
+#, fuzzy
+msgstr "Mappa vettoriale dei punti di arrivo"
 msgid ""
@@ -1182,12 +1183,18 @@
 msgid "Name of output vector points map"
 msgstr "Nome della mappa vettoriale dei punti di arrivo"
+# #-#-#-#-#  grassmods_it.po (grassmods_it)  #-#-#-#-#
+# codificato/classificato
 #, fuzzy
-msgstr "Nome della mappa raster d'inserimento dati"
+msgstr ""
+"#-#-#-#-#  grassmods_it.po (grassmods_it)  #-#-#-#-#\n"
+"Nome della mappa raster d'inserimento dati\n"
+"Nome della mappa raster di input del reticolo idrografico codificato"
 #: ../raster/r.stream.snap/main.c:64 ../raster/r.stream.snap/main.c:70
 #: ../raster/r.spread/main.c:121 ../raster/r.spread/main.c:133
@@ -9401,12 +9408,6 @@
 msgstr "raster, distanza"
-# codificato/classificato
-#, fuzzy
-msgstr "Nome della mappa raster di input del reticolo idrografico codificato"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_ja.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -13,7 +13,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ja\n"
 "PO-Revision-Date: 2012-03-08 17:49+0900\n"
 "Last-Translator: taniguchi <taniguti at apptec.co.jp>\n"
 "Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
@@ -1125,8 +1125,9 @@
 msgstr "%s: WKT に変換できません"
-msgstr ""
+#, fuzzy
+msgstr "終了ポイントベクトルマップ  "
 msgid ""
@@ -1174,8 +1175,8 @@
 msgstr "���"
 #, fuzzy
 msgstr "入力ラスターマップ名"
@@ -9329,11 +9330,6 @@
 msgstr "解析距離エラー"
-#, fuzzy
-msgstr "入力ラスターマップ名"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_ko.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ko\n"
 "PO-Revision-Date: 2005-08-09 22:53-0500\n"
 "Last-Translator: Huidae Cho\n"
 "Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -1095,8 +1095,9 @@
 msgstr "출력할 래스터맵"
-msgstr ""
+#, fuzzy
+msgstr "출력할 래스터맵"
 msgid ""
@@ -1143,8 +1144,8 @@
 msgstr "출력할 래스터맵"
 #, fuzzy
 msgstr "출력할 래스터맵"
@@ -9046,11 +9047,6 @@
 msgstr ""
-#, fuzzy
-msgstr "출력할 래스터맵"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_lv.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_lv\n"
 "PO-Revision-Date: 2012-01-27 14:24+0200\n"
 "Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
 "Language-Team: Latvian\n"
@@ -1120,8 +1120,9 @@
 msgstr "Nevar izveidot ierakstu tabulā: %s"
-msgstr ""
+#, fuzzy
+msgstr "Neveiksme atverot ieejas dig ieejas failu"
 msgid ""
@@ -1169,11 +1170,15 @@
 msgstr "Vektorkartes nosaukums"
 #, fuzzy
-msgstr "Rastra kartes nosaukums"
+msgstr ""
+"#-#-#-#-#  grassmods_lv.po (grassmods_lv)  #-#-#-#-#\n"
+"Rastra kartes nosaukums\n"
+"Jaunas rastra kartes nosaukums"
@@ -9261,11 +9266,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Jaunas rastra kartes nosaukums"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_pl.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_pl\n"
 "PO-Revision-Date: 2013-07-16 12:26+0100\n"
 "Last-Translator: Milena Nowotarska <do.milenki * gmail.com>\n"
 "Language-Team: Polish <grass-translations at lists.osgeo.org>\n"
@@ -1123,8 +1123,9 @@
 msgstr "%s: Nie można przekonwertować do WKT"
-msgstr ""
+#, fuzzy
+msgstr "Wyjściowa mapa wektorowa punktów końcowych"
 msgid ""
@@ -1172,11 +1173,15 @@
 msgstr "nazwa wejściowego pliku wektorowego"
 #, fuzzy
-msgstr "Nazwa wejściowej mapy rastrowej"
+msgstr ""
+"#-#-#-#-#  grassmods_pl.po (grassmods_pl)  #-#-#-#-#\n"
+"Nazwa wejściowej mapy rastrowej\n"
+"Wejściowa mapa rastrowa zakodowanej sieci rzecznej"
@@ -9244,11 +9249,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Wejściowa mapa rastrowa zakodowanej sieci rzecznej"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_pt.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_pt\n"
 "PO-Revision-Date: 2007-06-21 21:54-0300\n"
 "Last-Translator: Daniel de Castro Victoria <daniel dot victoria at gmail dot "
 "com>\n"
@@ -1137,8 +1137,9 @@
 msgstr "%s: Não consegui ler a fonte"
-msgstr ""
+#, fuzzy
+msgstr "Mapa vetor dos pontos finais"
 msgid ""
@@ -1186,11 +1187,15 @@
 msgstr "Nome do mapa vetorial (2d) de entrada"
 #, fuzzy
-msgstr "Nome do Raster de entrada"
+msgstr ""
+"#-#-#-#-#  grassmods_pt.po (grassmods_pt)  #-#-#-#-#\n"
+"Nome do Raster de entrada\n"
+"Nome do novo arquivo raster"
@@ -9590,11 +9595,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Nome do novo arquivo raster"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -11,7 +11,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_pt_br\n"
 "PO-Revision-Date: 2011-08-03 03:03-0300\n"
 "Last-Translator: Fred Ulisses Maranhão <fred.maranhao at gmail.com>\n"
 "Language-Team: Brasilian Portuguese <grass-translations at lists.osgeo.org>\n"
-msgstr ""
+#, fuzzy
 msgid ""
@@ -1184,11 +1185,15 @@
 #, fuzzy
+msgstr ""
+"#-#-#-#-#  grassmods_pt_br.po (grassmods_pt_br)  #-#-#-#-#\n"
+"Nome do mapa raster de rede de drenagem coded de entrada"
@@ -9536,11 +9541,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Nome do mapa raster de rede de drenagem coded de entrada"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_ro.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ro\n"
 "PO-Revision-Date: 2013-07-17 22:14+0200\n"
 "Last-Translator: Andreea Marin <andreea.marin09 yahoo.com>\n"
 "Language-Team: GRASS Translation Team <grass-translations at lists.osgeo.org>\n"
@@ -1075,7 +1075,7 @@
 msgstr "Imposibil de inserat rândul: %s"
 msgstr ""
@@ -1124,11 +1124,15 @@
 msgstr "Nume pentru harta vectorială de ieșire"
 #, fuzzy
-msgstr "Numele a două 2-%d hărți raster de intrare"
+msgstr ""
+"#-#-#-#-#  grassmods_ro.po (grassmods_ro)  #-#-#-#-#\n"
+"Numele a două 2-%d hărți raster de intrare\n"
+"Nume pentru harta vectorială de intrare"
@@ -8834,11 +8838,6 @@
 msgstr "raster, distanță"
-#, fuzzy
-msgstr "Nume pentru harta vectorială de intrare"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_ru.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -6,7 +6,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ru\n"
 "PO-Revision-Date: 2009-05-15 00:23-0600\n"
 "Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
 "Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
@@ -1121,8 +1121,9 @@
 msgstr "%s: невозможно конвертировать в WKT"
-msgstr ""
+#, fuzzy
+msgstr "Конец точечного векторного слоя"
 msgid ""
@@ -1170,8 +1171,8 @@
 msgstr "Имя исходного точечного векторного слоя"
 #, fuzzy
 msgstr "Название вводного растрового слоя"
@@ -9483,11 +9484,6 @@
 msgstr "Ошибка анализа расстояний"
-#, fuzzy
-msgstr "Название вводного растрового слоя"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_sl.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_sl\n"
 "PO-Revision-Date: 2005-06-10 11:15+0200\n"
 "Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
 "Language-Team: Sloven¹èina <grass-translations at lists.osgeo.org>\n"
@@ -1130,8 +1130,9 @@
 msgstr "Ne morem vnesti v tabelo: %s"
-msgstr ""
+#, fuzzy
+msgstr "Vektorski sloj konènih toèk"
 msgid ""
@@ -1179,11 +1180,15 @@
 msgstr "Ime vhodnega rastrskega sloja"
 #, fuzzy
-msgstr "Ime vhodnega rastrskega sloja"
+msgstr ""
+"#-#-#-#-#  grassmods_sl.po (grassmods_sl)  #-#-#-#-#\n"
+"Ime vhodnega rastrskega sloja\n"
+"Ime novega rastrskega sloja"
@@ -9377,11 +9382,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Ime novega rastrskega sloja"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_th.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_th\n"
 "PO-Revision-Date: 2008-01-05 15:19+0700\n"
 "Last-Translator: man <mansv68 at yahoo.co.th>\n"
 "Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
@@ -1119,8 +1119,9 @@
 msgstr "%s: ไม่สามารถแปลงไปเป็น WKT"
-msgstr ""
+#, fuzzy
+msgstr "จุดสิ้นสุด ของแผนที่เชิงเส้น"
 msgid ""
@@ -1168,8 +1169,8 @@
 msgstr "ชื่อของ แผนที่เชิงเส้น จุด ที่จะนำเข้า"
 #, fuzzy
 msgstr "ชื่อของแผนที่เชิงภาพ"
@@ -9362,11 +9363,6 @@
 msgstr "อ่าน ระยะทางผิดพลาด"
-#, fuzzy
-msgstr "ชื่อของแผนที่เชิงภาพ"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_tr.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -9,7 +9,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_tr\n"
 "PO-Revision-Date: 2008-11-16 01:15+0200\n"
 "Last-Translator: Osman Yalçın YILMAZ <yilmazy at istanbul.edu.tr>\n"
 "Language-Team: Türkçe <grass-translations at lists.osgeo.org>\n"
@@ -1117,8 +1117,9 @@
 msgstr "%s: WKT'ye dönüştürülemiyor"
-msgstr ""
+#, fuzzy
+msgstr "Nokta vektör haritasını durdur"
 msgid ""
@@ -1166,8 +1167,8 @@
 msgstr "Girdi vektör nokta haritasının adı"
 #, fuzzy
 msgstr "Girdi raster haritası adı"
@@ -9129,11 +9130,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Girdi raster haritası adı"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_vi.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_vi\n"
 "PO-Revision-Date: 2010-08-27 14:37+0700\n"
 "Last-Translator: \n"
 "Language-Team: Vietnamese <grass-translations at lists.osgeo.org>\n"
 msgstr "%s: Không thể đổi thành WKT"
-msgstr ""
+#, fuzzy
+msgstr "Bản đồ vec-tơ chứa các điểm kết thúc"
 msgid ""
 msgstr "Tên của bản đồ vector điểm đầu vào"
 #, fuzzy
-msgstr "Tên bản đồ raster đầu vào"
+msgstr ""
+"#-#-#-#-#  grassmods_vi.po (grassmods_vi)  #-#-#-#-#\n"
+"Tên bản đồ raster đầu vào\n"
+"Tên tập tin raster mới"
@@ -9507,11 +9512,6 @@
 msgstr "Lỗi phân tách các khoảng cách"
-#, fuzzy
-msgstr "Tên tập tin raster mới"
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grassmods_zh.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_zh\n"
 "PO-Revision-Date: 2007-12-13 16:33+0100\n"
 "Last-Translator: Zhang Jun <nilarcs at gmail.com>\n"
 "Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
 msgstr "无法向表中插入新记录:%s"
-msgstr ""
+#, fuzzy
+msgstr "终止点矢量图"
 msgid ""
 msgstr "输入的 2D 矢量地图的名称"
 #, fuzzy
-msgstr "输入栅格图的名称"
+msgstr ""
+"#-#-#-#-#  grassmods_zh.po (grassmods_zh)  #-#-#-#-#\n"
+"输入栅格图的名称\n"
+"新的栅格文件的名称"
@@ -9406,11 +9411,6 @@
 msgstr ""
-#, fuzzy
-msgstr "新的栅格文件的名称"
 #, fuzzy
Modified: grass/trunk/locale/po/grasswxpy_cs.po
--- grass/trunk/locale/po/grasswxpy_cs.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasswxpy_cs.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -11,7 +11,7 @@
 msgstr ""
 "Project-Id-Version: grasswxpy_cs\n"
 "PO-Revision-Date: 2012-11-20 19:03+0100\n"
 "Last-Translator: Jan Trochta <j.trochta at gmail.com>\n"
 "Language-Team:  <cs at li.org>\n"
@@ -42,7 +42,7 @@
 #: ../gui/wxpython/iscatt/toolbars.py:44
 #: ../gui/wxpython/iscatt/toolbars.py:135
 #: ../gui/wxpython/gui_core/toolbars.py:84
-#: ../gui/wxpython/gui_core/widgets.py:986 ../gui/wxpython/nviz/tools.py:1892
+#: ../gui/wxpython/gui_core/widgets.py:997 ../gui/wxpython/nviz/tools.py:1892
 #: ../gui/wxpython/vnet/dialogs.py:867
 msgid "Settings"
 msgstr "Nastavení"
@@ -640,7 +640,7 @@
 #: ../gui/wxpython/gui_core/gselect.py:1419
 #: ../gui/wxpython/gui_core/gselect.py:1429
 #: ../gui/wxpython/gui_core/gselect.py:1430
-#: ../gui/wxpython/gui_core/widgets.py:1047
+#: ../gui/wxpython/gui_core/widgets.py:1058
 #: ../gui/wxpython/gmodeler/preferences.py:549
 #: ../gui/wxpython/animation/dialogs.py:333
 #: ../gui/wxpython/vnet/dialogs.py:1474
@@ -815,7 +815,7 @@
 msgid "Select font"
 msgstr "Zvolit font"
-#: ../gui/wxpython/gui_core/toolbars.py:73 ../gui/wxpython/menustrings.py:2001
+#: ../gui/wxpython/gui_core/toolbars.py:73 ../gui/wxpython/menustrings.py:2035
 #: ../gui/wxpython/lmgr/layertree.py:72
 msgid "Quit"
 msgstr "Ukončit"
@@ -869,6 +869,7 @@
 msgstr "Spustit příkaz (Ctrl+R)"
 #: ../gui/wxpython/gui_core/forms.py:514
+#: ../gui/wxpython/modules/mcalc_builder.py:151
 msgid "Copy the current command string to the clipboard"
 msgstr "Kopírovat příkaz jako řetězec do schránky"
@@ -1018,80 +1019,80 @@
 msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:82
+#: ../gui/wxpython/gui_core/widgets.py:84
 msgid " (...)"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:788
+#: ../gui/wxpython/gui_core/widgets.py:799
 #: ../gui/wxpython/gui_core/dialogs.py:671
 #: ../gui/wxpython/gui_core/dialogs.py:724
 #: ../gui/wxpython/gui_core/dialogs.py:1429 ../gui/wxpython/dbmgr/base.py:1244
 msgid "Select all"
 msgstr "Vybrat vše"
-#: ../gui/wxpython/gui_core/widgets.py:789
+#: ../gui/wxpython/gui_core/widgets.py:800
 #: ../gui/wxpython/gui_core/dialogs.py:1431 ../gui/wxpython/dbmgr/base.py:1245
 msgid "Deselect all"
 msgstr "Zrušit výběr"
-#: ../gui/wxpython/gui_core/widgets.py:851
+#: ../gui/wxpython/gui_core/widgets.py:862
 msgid "Fulltext search"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:852
+#: ../gui/wxpython/gui_core/widgets.py:863
 msgid "Type to search in all modules. Press Enter for next match."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:909
+#: ../gui/wxpython/gui_core/widgets.py:920
 msgid "Searching, please type more characters."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:918
+#: ../gui/wxpython/gui_core/widgets.py:929
 #, python-format
 msgid "%d modules match"
 msgstr "%d modulů odpovídá"
-#: ../gui/wxpython/gui_core/widgets.py:992
+#: ../gui/wxpython/gui_core/widgets.py:1003
 #, fuzzy
 msgid "Save current settings"
 msgstr "Nastavení serveru"
-#: ../gui/wxpython/gui_core/widgets.py:995
+#: ../gui/wxpython/gui_core/widgets.py:1006
 #, fuzzy
 msgid "Delete currently selected settings"
 msgstr "Odstranit vybraný mapset"
-#: ../gui/wxpython/gui_core/widgets.py:1016
+#: ../gui/wxpython/gui_core/widgets.py:1027
 #, fuzzy
 msgid "Load settings:"
 msgstr "Ukázat nastavení"
-#: ../gui/wxpython/gui_core/widgets.py:1034
+#: ../gui/wxpython/gui_core/widgets.py:1045
 #, fuzzy, python-format
 msgid "Settings <%s> not found"
 msgstr "Vektorová mapa <%s> nebyla nalezena."
-#: ../gui/wxpython/gui_core/widgets.py:1048
-#: ../gui/wxpython/gui_core/widgets.py:1064
+#: ../gui/wxpython/gui_core/widgets.py:1059
+#: ../gui/wxpython/gui_core/widgets.py:1075
 #, fuzzy
 msgid "Save settings"
-#: ../gui/wxpython/gui_core/widgets.py:1053
+#: ../gui/wxpython/gui_core/widgets.py:1064
 msgid "Name not given, settings is not saved."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1062
+#: ../gui/wxpython/gui_core/widgets.py:1073
 msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
 msgstr "Soubor <%s> již existuje. Přejete si tento soubor přepsat?"
-#: ../gui/wxpython/gui_core/widgets.py:1111
+#: ../gui/wxpython/gui_core/widgets.py:1122
 #, fuzzy
 msgid "No settings is defined. Operation canceled."
 msgstr "Nebyla vybrána žádná mapová vrstva. Operace ukončena."
-#: ../gui/wxpython/gui_core/widgets.py:1145
+#: ../gui/wxpython/gui_core/widgets.py:1156
 #, fuzzy
 msgid "Unable to save settings"
 msgstr "Nelze provést nastavení '%s'"
@@ -1224,8 +1225,8 @@
 msgstr "Jméno vektorové mapy:"
 #: ../gui/wxpython/gui_core/dialogs.py:234
-#: ../gui/wxpython/gui_core/dialogs.py:353 ../gui/wxpython/menustrings.py:545
-#: ../gui/wxpython/menustrings.py:1457
+#: ../gui/wxpython/gui_core/dialogs.py:353 ../gui/wxpython/menustrings.py:562
+#: ../gui/wxpython/menustrings.py:1491
 msgid "Create new vector map"
 msgstr "Vytvořit novou vektorovou mapu"
@@ -1514,7 +1515,7 @@
 #: ../gui/wxpython/gui_core/dialogs.py:1650
 #: ../gui/wxpython/gui_core/preferences.py:816
 #: ../gui/wxpython/gmodeler/preferences.py:529
-#: ../gui/wxpython/modules/mcalc_builder.py:235
+#: ../gui/wxpython/modules/mcalc_builder.py:237
 #: ../gui/wxpython/modules/vclean.py:143 ../gui/wxpython/scripts/vkrige.py:141
 msgid "Allow output files to overwrite existing files"
 msgstr "Povolit přepsání existujících souborů"
@@ -1530,24 +1531,24 @@
 msgstr "Importovat vybrané vrstvy"
 #: ../gui/wxpython/gui_core/dialogs.py:1812 ../gui/wxpython/menustrings.py:167
-#: ../gui/wxpython/menustrings.py:1159 ../gui/wxpython/lmgr/layertree.py:64
+#: ../gui/wxpython/menustrings.py:1176 ../gui/wxpython/lmgr/layertree.py:64
 #, fuzzy
 msgid "Link external vector data"
 msgstr "Připojit vektorová data"
 #: ../gui/wxpython/gui_core/dialogs.py:1814 ../gui/wxpython/menustrings.py:61
-#: ../gui/wxpython/menustrings.py:1053 ../gui/wxpython/lmgr/layertree.py:62
+#: ../gui/wxpython/menustrings.py:1070 ../gui/wxpython/lmgr/layertree.py:62
 msgid "Import vector data"
 msgstr "Import vektorových dat"
 #: ../gui/wxpython/gui_core/dialogs.py:1818 ../gui/wxpython/menustrings.py:165
-#: ../gui/wxpython/menustrings.py:1157 ../gui/wxpython/lmgr/layertree.py:58
+#: ../gui/wxpython/menustrings.py:1174 ../gui/wxpython/lmgr/layertree.py:58
 #, fuzzy
 msgid "Link external raster data"
 msgstr "Připojit rastrová data"
 #: ../gui/wxpython/gui_core/dialogs.py:1820 ../gui/wxpython/menustrings.py:30
-#: ../gui/wxpython/menustrings.py:1022 ../gui/wxpython/lmgr/layertree.py:56
+#: ../gui/wxpython/menustrings.py:1039 ../gui/wxpython/lmgr/layertree.py:56
 msgid "Import raster data"
 msgstr "Import rastrových dat"
@@ -2258,8 +2259,8 @@
 msgid "Command log saved to '%s'"
 msgstr "Výstup příkazů"
-#: ../gui/wxpython/gui_core/ghelp.py:47 ../gui/wxpython/menustrings.py:1017
-#: ../gui/wxpython/menustrings.py:1018
+#: ../gui/wxpython/gui_core/ghelp.py:47 ../gui/wxpython/menustrings.py:1034
+#: ../gui/wxpython/menustrings.py:1035
 msgid "About GRASS GIS"
 msgstr "O GIS GRASS"
@@ -2431,8 +2432,8 @@
 #: ../gui/wxpython/gui_core/simplelmgr.py:417
 #: ../gui/wxpython/rlisetup/frame.py:130
-#: ../gui/wxpython/gmodeler/frame.py:1283 ../gui/wxpython/menustrings.py:925
-#: ../gui/wxpython/menustrings.py:1837
+#: ../gui/wxpython/gmodeler/frame.py:1283 ../gui/wxpython/menustrings.py:942
+#: ../gui/wxpython/menustrings.py:1871
 #: ../gui/wxpython/animation/dialogs.py:631
 #: ../gui/wxpython/animation/dialogs.py:822
 #: ../gui/wxpython/lmgr/layertree.py:396
@@ -2811,8 +2812,8 @@
 msgid "Add"
 msgstr "Přidat"
-#: ../gui/wxpython/dbmgr/base.py:2078 ../gui/wxpython/menustrings.py:909
-#: ../gui/wxpython/menustrings.py:1821
+#: ../gui/wxpython/dbmgr/base.py:2078 ../gui/wxpython/menustrings.py:926
+#: ../gui/wxpython/menustrings.py:1855
 msgid "Rename column"
 msgstr "Přejmenovat sloupec"
@@ -3055,8 +3056,8 @@
 msgid "Reload attribute data (selected layer only)"
 msgstr "Znovu načíst atributové data (pouze vybraná vrstva)"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:100 ../gui/wxpython/menustrings.py:891
-#: ../gui/wxpython/menustrings.py:1803
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:100 ../gui/wxpython/menustrings.py:908
+#: ../gui/wxpython/menustrings.py:1837
 msgid "Query"
 msgstr "Dotaz"
@@ -3202,8 +3203,8 @@
 msgid "No attributes found"
 msgstr "Nenalezeny žásndé atributy"
-#: ../gui/wxpython/dbmgr/dialogs.py:115 ../gui/wxpython/menustrings.py:680
-#: ../gui/wxpython/menustrings.py:1592
+#: ../gui/wxpython/dbmgr/dialogs.py:115 ../gui/wxpython/menustrings.py:697
+#: ../gui/wxpython/menustrings.py:1626
 msgid "Update attributes"
 msgstr "Modifikovat atributy"
@@ -3785,8 +3786,8 @@
 msgid "Remove a configuration file"
 msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:133 ../gui/wxpython/menustrings.py:921
-#: ../gui/wxpython/menustrings.py:1833
+#: ../gui/wxpython/rlisetup/frame.py:133 ../gui/wxpython/menustrings.py:938
+#: ../gui/wxpython/menustrings.py:1867
 #, fuzzy
 msgid "Create"
 msgstr "Vytvořit RGB"
@@ -3797,8 +3798,8 @@
 msgstr "Vytvořit novou location?"
 #: ../gui/wxpython/rlisetup/frame.py:136 ../gui/wxpython/menustrings.py:180
-#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1172
-#: ../gui/wxpython/menustrings.py:1835 ../gui/wxpython/lmgr/layertree.py:402
+#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1189
+#: ../gui/wxpython/menustrings.py:1869 ../gui/wxpython/lmgr/layertree.py:402
 msgid "Rename"
 msgstr "Přejmenovat"
@@ -3941,7 +3942,7 @@
 msgstr "Vzorové body profilu"
 #: ../gui/wxpython/rlisetup/wizard.py:742 ../gui/wxpython/menustrings.py:336
-#: ../gui/wxpython/menustrings.py:1248
+#: ../gui/wxpython/menustrings.py:1265
 msgid "Moving window"
 msgstr "Pohybující se okno"
@@ -4342,32 +4343,32 @@
 msgid "Failed to read instruction %(inst)s: file %(file)s not found."
 msgstr "Nelze načíst seznam: %s"
-#: ../gui/wxpython/psmap/toolbars.py:61 ../gui/wxpython/menustrings.py:1994
+#: ../gui/wxpython/psmap/toolbars.py:61 ../gui/wxpython/menustrings.py:2028
 msgid "Generate text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:63 ../gui/wxpython/menustrings.py:1992
+#: ../gui/wxpython/psmap/toolbars.py:63 ../gui/wxpython/menustrings.py:2026
 msgid "Load text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:65 ../gui/wxpython/menustrings.py:1996
+#: ../gui/wxpython/psmap/toolbars.py:65 ../gui/wxpython/menustrings.py:2030
 #, fuzzy
 msgid "Generate PostScript output"
 msgstr "Nástroj pro tvorbu mapových výstupů ve formátu PostScript."
-#: ../gui/wxpython/psmap/toolbars.py:67 ../gui/wxpython/menustrings.py:1998
+#: ../gui/wxpython/psmap/toolbars.py:67 ../gui/wxpython/menustrings.py:2032
 #, fuzzy
 msgid "Generate PDF output"
 msgstr "Vytvořit bodovou vrstvu"
-#: ../gui/wxpython/psmap/toolbars.py:69 ../gui/wxpython/menustrings.py:1989
+#: ../gui/wxpython/psmap/toolbars.py:69 ../gui/wxpython/menustrings.py:2023
 #: ../gui/wxpython/modules/histogram.py:449
 #: ../gui/wxpython/mapdisp/frame.py:673 ../gui/wxpython/wxplot/base.py:560
 #: ../gui/wxpython/gcp/mapdisplay.py:412
 msgid "Page setup"
 msgstr "Nastavení stránky"
-#: ../gui/wxpython/psmap/toolbars.py:70 ../gui/wxpython/menustrings.py:1990
+#: ../gui/wxpython/psmap/toolbars.py:70 ../gui/wxpython/menustrings.py:2024
 msgid "Specify paper size, margins and orientation"
 msgstr ""
@@ -4381,7 +4382,7 @@
 msgstr "Zvětšit podle výchozího regionu"
 #: ../gui/wxpython/psmap/toolbars.py:75 ../gui/wxpython/psmap/dialogs.py:619
-#: ../gui/wxpython/psmap/dialogs.py:674 ../gui/wxpython/menustrings.py:2004
+#: ../gui/wxpython/psmap/dialogs.py:674 ../gui/wxpython/menustrings.py:2038
 #, fuzzy
 msgid "Map frame"
 msgstr "Měřítko mapy"
@@ -4390,7 +4391,7 @@
 msgid "Click and drag to place map frame"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:78 ../gui/wxpython/menustrings.py:2023
+#: ../gui/wxpython/psmap/toolbars.py:78 ../gui/wxpython/menustrings.py:2057
 #, fuzzy
 msgid "Delete selected object"
 msgstr "Odstranit vybranou lokaci"
@@ -4406,13 +4407,13 @@
 msgstr "Ukončit Grafické modelování"
 #: ../gui/wxpython/psmap/toolbars.py:84 ../gui/wxpython/psmap/dialogs.py:3705
-#: ../gui/wxpython/psmap/dialogs.py:3710 ../gui/wxpython/menustrings.py:2016
+#: ../gui/wxpython/psmap/dialogs.py:3710 ../gui/wxpython/menustrings.py:2050
 #: ../gui/wxpython/animation/dialogs.py:1196
 #, fuzzy
 msgid "Text"
 msgstr "Test"
-#: ../gui/wxpython/psmap/toolbars.py:86 ../gui/wxpython/menustrings.py:2012
+#: ../gui/wxpython/psmap/toolbars.py:86 ../gui/wxpython/menustrings.py:2046
 #, fuzzy
 msgid "Map info"
 msgstr "Přidat mapové prvky"
@@ -4422,21 +4423,21 @@
 msgid "Legend"
 msgstr "Legenda"
-#: ../gui/wxpython/psmap/toolbars.py:90 ../gui/wxpython/menustrings.py:2014
+#: ../gui/wxpython/psmap/toolbars.py:90 ../gui/wxpython/menustrings.py:2048
 #: ../gui/wxpython/nviz/tools.py:1991
 #, fuzzy
 msgid "Scale bar"
 msgstr "Přidat vrstvu"
 #: ../gui/wxpython/psmap/toolbars.py:92 ../gui/wxpython/psmap/dialogs.py:4061
-#: ../gui/wxpython/psmap/dialogs.py:4109 ../gui/wxpython/menustrings.py:2018
+#: ../gui/wxpython/psmap/dialogs.py:4109 ../gui/wxpython/menustrings.py:2052
 #, fuzzy
 msgid "Image"
 msgstr "Obraz"
 #: ../gui/wxpython/psmap/toolbars.py:94 ../gui/wxpython/psmap/dialogs.py:4494
-#: ../gui/wxpython/menustrings.py:2020 ../gui/wxpython/nviz/tools.py:1946
+#: ../gui/wxpython/menustrings.py:2054 ../gui/wxpython/nviz/tools.py:1946
 #, fuzzy
 msgid "North Arrow"
 msgstr "Měřítko a směrová růžice"
@@ -4717,7 +4718,7 @@
 msgid "Invalid scale or map center!"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1144 ../gui/wxpython/menustrings.py:2006
+#: ../gui/wxpython/psmap/dialogs.py:1144 ../gui/wxpython/menustrings.py:2040
 #: ../gui/wxpython/nviz/tools.py:652 ../gui/wxpython/nviz/mapwindow.py:1672
 #: ../gui/wxpython/lmgr/layertree.py:765
 msgid "Raster map"
@@ -4792,7 +4793,7 @@
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:1315 ../gui/wxpython/menustrings.py:182
-#: ../gui/wxpython/menustrings.py:1174 ../gui/wxpython/menustrings.py:2022
+#: ../gui/wxpython/menustrings.py:1191 ../gui/wxpython/menustrings.py:2056
 #: ../gui/wxpython/nviz/tools.py:1098 ../gui/wxpython/nviz/tools.py:1976
 #: ../gui/wxpython/nviz/tools.py:2024
 msgid "Delete"
@@ -4852,7 +4853,7 @@
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:1727 ../gui/wxpython/menustrings.py:331
-#: ../gui/wxpython/menustrings.py:1243 ../gui/wxpython/nviz/tools.py:789
+#: ../gui/wxpython/menustrings.py:1260 ../gui/wxpython/nviz/tools.py:789
 #: ../gui/wxpython/nviz/tools.py:2400
 msgid "Mask"
 msgstr "Maska"
@@ -5111,7 +5112,7 @@
 msgid "Choose vector maps and their order in legend"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2617 ../gui/wxpython/menustrings.py:2008
+#: ../gui/wxpython/psmap/dialogs.py:2617 ../gui/wxpython/menustrings.py:2042
 #: ../gui/wxpython/nviz/tools.py:1177 ../gui/wxpython/lmgr/layertree.py:768
 msgid "Vector map"
 msgstr "Vektorová mapa"
@@ -6201,13 +6202,13 @@
 msgid "Label and comment"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:199
+#: ../gui/wxpython/gmodeler/dialogs.py:198
 #: ../gui/wxpython/gmodeler/frame.py:1345
 #, fuzzy
 msgid "Label:"
 msgstr "Vrstva"
-#: ../gui/wxpython/gmodeler/dialogs.py:203
+#: ../gui/wxpython/gmodeler/dialogs.py:202
 #: ../gui/wxpython/gmodeler/frame.py:734
 #: ../gui/wxpython/gmodeler/frame.py:1357
 #, fuzzy
@@ -6342,7 +6343,7 @@
 msgstr "Odstranit vše"
 #: ../gui/wxpython/gmodeler/preferences.py:29
-#: ../gui/wxpython/menustrings.py:1957
+#: ../gui/wxpython/menustrings.py:1991
 msgid "Modeler settings"
 msgstr "Nastavení modelování"
@@ -6404,7 +6405,7 @@
 msgstr "Příkazy"
 #: ../gui/wxpython/gmodeler/preferences.py:508
-#: ../gui/wxpython/menustrings.py:1973
+#: ../gui/wxpython/menustrings.py:2007
 msgid "Model properties"
 msgstr "Vlastnosti modelu"
@@ -6521,7 +6522,7 @@
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
 msgstr "Soubor s modelem <%s> již existuje. Přejete si tento soubor přepsat?"
-#: ../gui/wxpython/gmodeler/frame.py:416 ../gui/wxpython/menustrings.py:1944
+#: ../gui/wxpython/gmodeler/frame.py:416 ../gui/wxpython/menustrings.py:1978
 msgid "Save model"
 msgstr "Uložit model"
@@ -6571,7 +6572,7 @@
 msgid "Model exported to <%s>"
 msgstr "Model exportován do <%s>"
-#: ../gui/wxpython/gmodeler/frame.py:734 ../gui/wxpython/menustrings.py:1969
+#: ../gui/wxpython/gmodeler/frame.py:734 ../gui/wxpython/menustrings.py:2003
 #, fuzzy
 msgid "Add comment"
 msgstr "Přidat vrstvu s příkazem"
@@ -6753,8 +6754,8 @@
 msgid "Update"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:1938
-#: ../gui/wxpython/menustrings.py:1988
+#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:1972
+#: ../gui/wxpython/menustrings.py:2022
 msgid "&File"
 msgstr "&Soubor"
@@ -6762,7 +6763,7 @@
 msgid "Workspace"
 msgstr "Pracovní oblast"
-#: ../gui/wxpython/menustrings.py:5 ../gui/wxpython/menustrings.py:1939
+#: ../gui/wxpython/menustrings.py:5 ../gui/wxpython/menustrings.py:1973
 #: ../gui/wxpython/nviz/tools.py:1094
 msgid "New"
 msgstr "Nový"
@@ -6771,7 +6772,7 @@
 msgid "Create new workspace"
 msgstr "Vytvořit nový soubor pracovní oblasti"
-#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:1941
+#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:1975
 msgid "Open"
 msgstr "Otevřít"
@@ -6779,7 +6780,7 @@
 msgid "Load workspace from file"
 msgstr "Načíst soubor workspace"
-#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/menustrings.py:1943
+#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/menustrings.py:1977
 #: ../gui/wxpython/modules/colorrules.py:416
 msgid "Save"
 msgstr "Uložit"
@@ -6789,7 +6790,7 @@
 msgid "Save workspace"
 msgstr "Uložit pracovní oblast"
-#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:1945
+#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:1979
 msgid "Save as"
 msgstr "Uložit jako"
@@ -6797,7 +6798,7 @@
 msgid "Save workspace to file"
 msgstr "Uložit pracovní oblast do souboru"
-#: ../gui/wxpython/menustrings.py:13 ../gui/wxpython/menustrings.py:1947
+#: ../gui/wxpython/menustrings.py:13 ../gui/wxpython/menustrings.py:1981
 #: ../gui/wxpython/mapswipe/dialogs.py:162
 msgid "Close"
 msgstr "Zavřít"
@@ -6868,20 +6869,20 @@
 msgid "Close all open map display windows"
 msgstr "Zavřít Mapový displej %d"
-#: ../gui/wxpython/menustrings.py:31 ../gui/wxpython/menustrings.py:1023
+#: ../gui/wxpython/menustrings.py:31 ../gui/wxpython/menustrings.py:1040
 #, fuzzy
 msgid "Common formats import"
 msgstr "Export do běžných formátů"
-#: ../gui/wxpython/menustrings.py:32 ../gui/wxpython/menustrings.py:1024
+#: ../gui/wxpython/menustrings.py:32 ../gui/wxpython/menustrings.py:1041
 msgid "Import raster data into a GRASS map layer using GDAL."
 msgstr "Import rastrových dat pomocí GDAL."
-#: ../gui/wxpython/menustrings.py:33 ../gui/wxpython/menustrings.py:1025
+#: ../gui/wxpython/menustrings.py:33 ../gui/wxpython/menustrings.py:1042
 msgid "ASCII x,y,z point import and gridding"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:34 ../gui/wxpython/menustrings.py:1026
+#: ../gui/wxpython/menustrings.py:34 ../gui/wxpython/menustrings.py:1043
 #, fuzzy
 msgid ""
 "Creates a raster map from an assemblage of many coordinates using univariate "
@@ -6890,96 +6891,96 @@
 "Vytvoří rastrovou mapu smontováním více souřadnic za pomoci univariantní "
 "statistiky"
-#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:1027
+#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:1044
 msgid "ASCII grid import"
 msgstr "Import ASCII mřížky (grid)"
-#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1028
+#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1045
 #, fuzzy
 msgid "Converts a GRASS ASCII raster file to binary raster map."
 msgstr "Převede ASCII rastrový soubor na binární rastrovou mapu."
-#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1029
+#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1046
 #, fuzzy
 msgid "ASCII polygons, lines, and point import"
 msgstr "Import ASCII polygony a linie"
-#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:1030
+#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:1047
 msgid "Creates raster maps from ASCII polygon/line/point data files."
 msgstr ""
 "Vytvoří rastrové mapy z ASCII polygonových/liniových/bodových datových "
 "souborů."
-#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1031
+#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1048
 #, fuzzy
 msgid "Raw binary array import"
 msgstr "Matlab and MapGen import"
-#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1032
+#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1049
 msgid "Import a binary raster file into a GRASS raster map layer."
 msgstr "Importuje binární rastrový soubor jako GRASS rastrovou mapu."
-#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1033
+#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1050
 msgid "ESRI ASCII grid import"
 msgstr "Import ESRI ASCII mřížku (grid)"
-#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1034
+#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1051
 #, fuzzy
 msgid ""
 "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
 msgstr "Převede ESRI ARC/INFO ascii rastr (GRID) na (binární) rastrovou mapu."
-#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1035
+#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1052
 msgid "GRIDATB.FOR import"
 msgstr "GRIDATB.FOR import"
-#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1036
+#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1053
 #, fuzzy
 msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
 msgstr ""
 "Importuje mapový soubor GRIDATB.FOR (TOPMODEL) jako rastrovou mapu GRASSu"
-#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1037
+#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1054
 msgid "Matlab 2D array import"
 msgstr "Import Matlab 2D pole"
-#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1038
+#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1055
 msgid "Imports a binary MAT-File(v4) to a GRASS raster."
 msgstr "Importuje soubor MAT (v4) jako rastrový soubor GRASSu."
-#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1039
+#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1056
 #, fuzzy
 msgid "PNG import"
 msgstr "PNG export"
-#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1040
+#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1057
 #, fuzzy
 msgid "Imports non-georeferenced PNG format image."
 msgstr "Export GRASS rastrové mapy jako  souřadnicově nepřipojený PNG obraz."
-#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1041
+#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1058
 msgid "SPOT NDVI import"
 msgstr "SPOT NDVI import"
-#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1042
+#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1059
 #, fuzzy
 msgid "Imports SPOT VGT NDVI data into a raster map."
 msgstr "Import SPOT VGT NDVI souboru jako rastrové mapy"
-#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1043
+#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1060
 msgid "SRTM HGT import"
 msgstr "SRTM HGT import"
-#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1044
+#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1061
 #, fuzzy
 msgid "Imports SRTM HGT files into raster map."
-#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1045
+#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1062
 msgid "Terra ASTER HDF import"
 msgstr "Terra ASTER HDF import"
-#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1046
+#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1063
 #, fuzzy
 msgid ""
 "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
@@ -6989,131 +6990,131 @@
 "příbuzných DMT za použití gdalwarp."
 #: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:85
-#: ../gui/wxpython/menustrings.py:1047 ../gui/wxpython/menustrings.py:1077
+#: ../gui/wxpython/menustrings.py:1064 ../gui/wxpython/menustrings.py:1094
 #, fuzzy
 msgid "LAS LiDAR points import"
 msgstr "ASCII x,y,z export"
-#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1048
+#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1065
 #, fuzzy
 msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
 msgstr ""
 "statistiky"
-#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1049
+#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1066
 #, fuzzy
 msgid "Unpack raster map"
 msgstr "Překrývat rastrové mapy"
-#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1050
+#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1067
 msgid "Unpacks a raster map packed with r.pack."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:294
-#: ../gui/wxpython/menustrings.py:1051 ../gui/wxpython/menustrings.py:1206
+#: ../gui/wxpython/menustrings.py:1068 ../gui/wxpython/menustrings.py:1223
 #, fuzzy
 msgid "Reproject raster map from different GRASS location"
 msgstr "Změna projekce rastrové mapy ze zvolené location do aktuální location."
 #: ../gui/wxpython/menustrings.py:60 ../gui/wxpython/menustrings.py:295
-#: ../gui/wxpython/menustrings.py:1052 ../gui/wxpython/menustrings.py:1207
+#: ../gui/wxpython/menustrings.py:1069 ../gui/wxpython/menustrings.py:1224
 #, fuzzy
 msgid "Re-projects a raster map from given location to the current location."
-#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1054
+#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1071
 #, fuzzy
 msgid "Common import formats"
-#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:1055
+#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:1072
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr "Převede vektorové vrstvy do GRASS vektoru pomocí OGR."
-#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1056
+#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1073
 #, fuzzy
 msgid "ASCII points or GRASS ASCII format"
 msgstr "Import ASCII body/GRASS ASCII vektory"
-#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1057
+#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1074
 #, fuzzy
 msgid "Creates a vector map from an ASCII points file or ASCII vector file."
 msgstr "Vytvoří vektorovou mapu ze souboru ASCII bodů nebo ASCII vektoru"
-#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:1058
+#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:1075
 msgid "ASCII points as a vector lines"
 msgstr "Import ASCII body jako vektorové linie"
-#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1059
+#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1076
 #, fuzzy
 msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
 msgstr "Importuje ASCII x,y[,z] souřadnice jako sérii linií."
-#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1060
+#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1077
 msgid "Historical GRASS vector import"
 msgstr "Import starého vektorového formátu GRASS"
-#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:1061
+#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:1078
 msgid "Imports older versions of GRASS vector maps."
 msgstr "Importuje starší verze GRASS vektorových map."
-#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1062
+#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1079
 msgid "Historical GRASS vector import (all maps)"
 msgstr "Import starého vektorového formátu GRASS (všechny mapy)"
-#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1063
+#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1080
 #, fuzzy
 msgid ""
 "Converts all older versions of GRASS vector maps in current mapset to "
 "current format."
 msgstr "Převede starou verzi GRASS vektoru (< 5.7) do současného formátu"
-#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1064
+#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1081
 msgid "DXF import"
 msgstr "Import DXF"
-#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1065
+#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1082
 msgid "Converts files in DXF format to GRASS vector map format."
 msgstr "Převede soubory ve formátu DXF do formátu GRASS-vektor"
-#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1066
+#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1083
 msgid "WFS"
 msgstr "WFS"
-#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1067
+#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1084
 #, fuzzy
 msgid "Imports GetFeature from a WFS server."
 msgstr "Import GetFeature z WFS"
-#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1068
+#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1085
 msgid "ESRI e00 import"
 msgstr "ESRI e00 import"
-#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1069
+#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1086
 #, fuzzy
 msgid "Imports E00 file into a vector map."
 msgstr "Importuje soubory ve formátu E00 jako vektorovou mapu."
-#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1070
+#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1087
 #, fuzzy
 msgid "GPS data import"
 msgstr "GPSBabel GPS import"
-#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1071
+#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1088
 msgid "Geonames import"
 msgstr "GEonames import"
-#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1072
+#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1089
 #, fuzzy
 msgid "Imports geonames.org country files into a vector points map."
 msgstr "Importuje soubry zemí z geonames.org do GRASS bodové vektorové mapy. "
-#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1073
+#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1090
 msgid "GEOnet import"
 msgstr "GEOnet import"
-#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1074
+#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1091
 msgid ""
 "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
 "points map."
@@ -7121,121 +7122,121 @@
 "Importuje US-NGA GEOnet jmenný server (GNS) soubory o státech do vektorové "
 "bodové mapy mapy GRASSu"
-#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1075
+#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1092
 #, fuzzy
 msgid "Matlab array or Mapgen format import"
 msgstr "Import Matlab pole a MapGen"
-#: ../gui/wxpython/menustrings.py:84 ../gui/wxpython/menustrings.py:1076
+#: ../gui/wxpython/menustrings.py:84 ../gui/wxpython/menustrings.py:1093
 #, fuzzy
 msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
 msgstr "Importuje vektory ve formátu Mapgen nebo Matlab do GRASS."
-#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1078
+#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1095
 #, fuzzy
 msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
-#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:1079
+#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:1096
 #, fuzzy
 msgid "Unpack vector map"
 msgstr "Spojit vektorové mapy"
-#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:1080
+#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:1097
 #, fuzzy
 msgid "Unpacks a vector map packed with v.pack."
 msgstr "Aktualizuje matadata vektorové vrstvy."
-#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:566
-#: ../gui/wxpython/menustrings.py:1081 ../gui/wxpython/menustrings.py:1478
+#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:583
+#: ../gui/wxpython/menustrings.py:1098 ../gui/wxpython/menustrings.py:1512
 #, fuzzy
 msgid "Reproject vector map from different GRASS location"
 msgstr ""
 "Změní projekci vektorové mapy ze zvolené location do aktuální location."
-#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:567
-#: ../gui/wxpython/menustrings.py:1082 ../gui/wxpython/menustrings.py:1479
+#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:584
+#: ../gui/wxpython/menustrings.py:1099 ../gui/wxpython/menustrings.py:1513
 msgid "Re-projects a vector map from one location to the current location."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1083
+#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1100
 msgid "Import 3D raster data"
 msgstr "Import 3D rastrových map"
-#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1084
+#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1101
 msgid "ASCII 3D import"
 msgstr "ASCII 3D import"
-#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1085
+#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1102
 #, fuzzy
 msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
 msgstr ""
 "Převede 3D ASCII rastrový textový soubor na (binární) 3D rastrovou mapovou "
 "vrstvu "
-#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1086
+#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1103
 #, fuzzy
 msgid "Raw binary array 3D import"
-#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1087
+#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1104
 #, fuzzy
 msgid "Imports a binary raster file into a GRASS 3D raster map."
-#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1088
+#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1105
 msgid "Vis5D import"
 msgstr "Vis5D import"
-#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1089
+#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1106
 #, fuzzy
 msgid "Import 3-dimensional Vis5D files."
 msgstr ""
 "Exportuje 3D rastrový soubor GRASSu do 3-dimenzionálního Vis5D souboru."
-#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1090
+#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1107
 msgid "Import database table"
 msgstr "Import databázové tabulky"
-#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1091
+#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1108
 msgid "Multiple import formats using OGR"
 msgstr "Import různých formátů pomocí OGR"
-#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:1092
+#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:1109
 msgid "Imports attribute tables in various formats."
 msgstr "Importuje atributové tabulky v různých formátech."
-#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1093
+#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1110
 msgid "Export raster map"
 msgstr "Export rastrové mapy"
 #: ../gui/wxpython/menustrings.py:102 ../gui/wxpython/menustrings.py:135
-#: ../gui/wxpython/menustrings.py:1094 ../gui/wxpython/menustrings.py:1127
+#: ../gui/wxpython/menustrings.py:1111 ../gui/wxpython/menustrings.py:1144
 msgid "Common export formats"
-#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1095
+#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1112
 msgid "Exports GRASS raster maps into GDAL supported formats."
 msgstr ""
 "Exportuje GRASS rastrové vrstvy do jednoho z formátů podporovaných knihovnou "
 "GDAL."
-#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1096
+#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1113
 msgid "ASCII grid export"
 msgstr "ASCII grid export"
-#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1097
+#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1114
 #, fuzzy
 msgid "Converts a raster map layer into a GRASS ASCII text file."
 msgstr "Převede rastrovou mapu do ASCII souboru."
-#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1098
+#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1115
 #, fuzzy
 msgid "ASCII x,y,z points export"
-#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1099
+#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1116
 #, fuzzy
 msgid ""
 "Exports a raster map to a text file as x,y,z values based on cell centers."
@@ -7243,72 +7244,72 @@
 "Exportuje rastrovou mapu do textového souboru jako hodnoty x,y,z dle středů "
 "buněk."
-#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1100
+#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1117
 msgid "ESRI ASCII grid export"
 msgstr "ESRI ASCII grid export"
-#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1101
+#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1118
 msgid "Converts a raster map layer into an ESRI ARCGRID file."
 msgstr "Převede rastrovou mapu na soubor ESRI ARCGRID."
-#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1102
+#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1119
 msgid "GRIDATB.FOR export"
 msgstr "GRIDATB.FOR export"
-#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1103
+#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1120
 #, fuzzy
 msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
 msgstr "Exportuje rastrovou mapu GRASSu do GRIDATB.FOR souboru (TOPMODEL)"
-#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1104
+#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1121
 msgid "Matlab 2D array export"
 msgstr "Export do Matlab 2D pole"
-#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1105
+#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1122
 msgid "Exports a GRASS raster to a binary MAT-File."
 msgstr "Exportuje rastrový soubor GRASSu do binárního souboru MAT."
-#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1106
+#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1123
 #, fuzzy
 msgid "Raw binary array export"
-#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1107
+#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1124
 msgid "Exports a GRASS raster to a binary array."
 msgstr "Exportuje rastrový soubor GRASSu do binárního pole."
-#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1108
+#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1125
 msgid "MPEG-1 export"
 msgstr "MPEG-1 export"
-#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1109
+#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1126
 #, fuzzy
 msgid "Converts raster map series to MPEG movie."
 msgstr "Program, vytvářející MPEG ze série rastrových map"
-#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1110
+#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1127
 msgid "PNG export"
 msgstr "PNG export"
-#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1111
+#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1128
 #, fuzzy
 msgid "Export a GRASS raster map as a non-georeferenced PNG image."
 msgstr "Export GRASS rastrové mapy jako nepřipojený PNG obraz."
-#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1112
+#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1129
 msgid "PPM export"
 msgstr "PPM export"
-#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1113
+#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1130
 #, fuzzy
 msgid "Converts a GRASS raster map to a PPM image file."
 msgstr "Převede rastrovou mapu na vektorovou."
-#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1114
+#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1131
 msgid "PPM from RGB export"
 msgstr "Export PPM z RGB vrstev"
-#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1115
+#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1132
 #, fuzzy
 msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
 msgstr ""
@@ -7316,89 +7317,89 @@
 "podle aktuálně definovaného regionu."
 #: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:144
-#: ../gui/wxpython/menustrings.py:1116 ../gui/wxpython/menustrings.py:1136
+#: ../gui/wxpython/menustrings.py:1133 ../gui/wxpython/menustrings.py:1153
 msgid "POV-Ray export"
 msgstr "POV-Ray export"
-#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1117
+#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1134
 #, fuzzy
 msgid "Converts a raster map layer into a height-field file for POV-Ray."
 msgstr "Převede rastrovou mapu do souboru pro POVRAY."
-#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1118
+#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1135
 msgid "TIFF export"
 msgstr "TIFF export"
-#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1119
+#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1136
 #, fuzzy
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
-#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:1120
+#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:1137
 msgid "VRML export"
 msgstr "VRML export"
-#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1121
+#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1138
 #, fuzzy
 msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
 msgstr "Export rastrové mapy do Virtual Reality Modeling Language (VRML)"
 #: ../gui/wxpython/menustrings.py:130 ../gui/wxpython/menustrings.py:148
-#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1122
-#: ../gui/wxpython/menustrings.py:1140 ../gui/wxpython/menustrings.py:1151
+#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1139
+#: ../gui/wxpython/menustrings.py:1157 ../gui/wxpython/menustrings.py:1168
 msgid "VTK export"
 msgstr "VTK export"
-#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1123
+#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1140
 #, fuzzy
 msgid "Converts raster maps into the VTK-ASCII format."
 msgstr "Převede rastrové mapy do formátu VTK-Ascii"
-#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1124
+#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1141
 #, fuzzy
 msgid "Pack raster map"
-#: ../gui/wxpython/menustrings.py:133 ../gui/wxpython/menustrings.py:1125
+#: ../gui/wxpython/menustrings.py:133 ../gui/wxpython/menustrings.py:1142
 msgid "Packs up a raster map and support files for copying."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1126
+#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1143
 msgid "Export vector map"
 msgstr "Export vektorové mapy"
-#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1128
+#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1145
 #, fuzzy
 msgid ""
 "Exports a vector map layer to any of the supported OGR vector formats. By "
 "default a vector map layer is exported to Esri Shapefile format."
 msgstr "Konvertuje mapu do jednoho z podporovaných vektorových formátů OGR."
-#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1129
+#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1146
 #, fuzzy
 msgid "ASCII points or GRASS ASCII vector export"
 msgstr "Export ASCII bodů/GRASS ASCII vektorů"
-#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1130
+#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1147
 msgid ""
 "Exports a vector map to a GRASS ASCII vector representation. By default only "
 "features with category are exported. To export all features use 'layer=-1'."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1131
+#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1148
 msgid "DXF export"
 msgstr "DXF export"
-#: ../gui/wxpython/menustrings.py:140 ../gui/wxpython/menustrings.py:1132
+#: ../gui/wxpython/menustrings.py:140 ../gui/wxpython/menustrings.py:1149
 #, fuzzy
 msgid "Exports vector map to DXF file format."
 msgstr "Exportuje GRASS vektory jako soubor DXF."
-#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1133
+#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1150
 msgid "Multiple GPS export formats using GPSBabel"
 msgstr "Export různých formátů GPS pomocí GPSBabel"
-#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1134
+#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1151
 #, fuzzy
 msgid ""
 "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
@@ -7406,131 +7407,131 @@
 "Exportuje vektorovou mapu do GPS přijímače nebo do formátu, který podporuje "
 "GPSBabel."
-#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1135
+#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1152
 #, fuzzy
 msgid "PostGIS export"
 msgstr "PNG export"
-#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1137
+#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1154
 #, fuzzy
 msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
 msgstr "Převede do POV-Ray formátu, GRASS x,y,z -> POV-Ray x,y,z"
-#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1138
+#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1155
 msgid "SVG export"
 msgstr "SVG export"
-#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1139
+#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1156
 #, fuzzy
 msgid "Exports a vector map to SVG file."
 msgstr "Exportuje GRASS vektory jako soubor SVG."
-#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1141
+#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1158
 #, fuzzy
 msgid "Converts a vector map to VTK ASCII output."
 msgstr "Převeď GRASS vektor na formát VTK ASCII."
-#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1142
+#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1159
 #, fuzzy
 msgid "Pack vector map"
-#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1143
+#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1160
 msgid "Packs up a vector map and support files for copying."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1144
+#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1161
 msgid "Export 3D raster maps"
 msgstr "Export 3D rastrových map"
-#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1145
+#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1162
 msgid "ASCII 3D export"
 msgstr "ASCII 3D export"
-#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1146
+#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1163
 #, fuzzy
 msgid "Converts a 3D raster map layer into a ASCII text file."
 msgstr "Převede 3D rastrovou mapovou vrstvu do ASCII textového souboru"
-#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1147
+#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1164
 #, fuzzy
 msgid "Raw binary array 3D export"
-#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1148
+#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1165
 #, fuzzy
 msgid "Exports a GRASS 3D raster map to a binary array."
-#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1149
+#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1166
 msgid "Vis5D export"
 msgstr "Vis5D export"
-#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1150
+#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1167
 #, fuzzy
 msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1152
+#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1169
 #, fuzzy
 msgid "Converts 3D raster maps into the VTK-ASCII format."
-#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1153
+#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1170
 msgid "Export database table"
 msgstr "Export databázové tabulky"
-#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1154
+#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1171
 #, fuzzy
 msgid "Common export formats using OGR"
-#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1155
+#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1172
 msgid "Exports attribute tables into various formats."
 msgstr "Exportuje atributové tabulky v různých formátech."
-#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:1156
+#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:1173
 #, fuzzy
 msgid "Link external data"
-#: ../gui/wxpython/menustrings.py:166 ../gui/wxpython/menustrings.py:1158
+#: ../gui/wxpython/menustrings.py:166 ../gui/wxpython/menustrings.py:1175
 msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
 msgstr "Připojí rastrový soubor podporovaný GDAL jako GRASS rastrovou vrstvu"
-#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:1160
+#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:1177
 msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
 msgstr "Vytvoří nový pseudo- vektor jako připojenou vrstvu pomocí OGR."
-#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1161
+#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1178
 #, fuzzy
 msgid "Output format for raster data"
 msgstr "Import rastrové mapy"
-#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1162
+#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1179
 msgid "Defines raster output format utilizing GDAL library."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1163
+#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1180
 #, fuzzy
 msgid "Output format for vector data"
 msgstr "Import vektorové mapy"
-#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1164
+#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1181
 msgid "Defines vector output format utilizing OGR library."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1165
+#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1182
 #, fuzzy
 msgid "Manage maps"
 msgstr "Vyčistit vektorovou mapu"
-#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:1166
+#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:1183
 msgid "Copy"
 msgstr "Kopírovat"
-#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:1167
+#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:1184
 #, fuzzy
 msgid ""
 "Copies available data files in the current mapset search path to the user's "
@@ -7539,22 +7540,22 @@
 "Kopíruje dostupná data z uživatelem zadaného mapsetu a location do "
 "aktuálního mapsetu."
-#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:935
-#: ../gui/wxpython/menustrings.py:1168 ../gui/wxpython/menustrings.py:1847
+#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:952
+#: ../gui/wxpython/menustrings.py:1185 ../gui/wxpython/menustrings.py:1881
 msgid "List"
 msgstr "Seznam"
-#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:1169
+#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:1186
 #, fuzzy
 msgid "Lists available GRASS data base files of the user-specified data type."
 msgstr ""
 "Seznam dostupných souborů uživatelem zadaného typu dat na standardní výstup"
-#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:1170
+#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:1187
 msgid "List filtered"
 msgstr "filtrovaný seznam"
-#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:1171
+#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:1188
 #, fuzzy
 msgid ""
 "Lists available GRASS data base files of the user-specified data type "
@@ -7562,19 +7563,19 @@
 msgstr ""
-#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:1173
+#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:1190
 msgid "Renames data base element files in the user's current mapset."
 msgstr "Přejmenuje data v aktuálním mapsetu"
-#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:1175
+#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:1192
 msgid "Removes data base element files from the user's current mapset."
 msgstr "Maže datové soubory z aktuálního mapsetu"
-#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:1176
+#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:1193
 msgid "Delete filtered"
 msgstr "Smaže vybrané"
-#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:1177
+#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:1194
 #, fuzzy
 msgid ""
 "Removes data base element files from the user's current mapset using regular "
@@ -7582,115 +7583,115 @@
 #: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:318
-#: ../gui/wxpython/menustrings.py:604 ../gui/wxpython/menustrings.py:838
-#: ../gui/wxpython/menustrings.py:1230 ../gui/wxpython/menustrings.py:1516
-#: ../gui/wxpython/menustrings.py:1750
+#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:855
+#: ../gui/wxpython/menustrings.py:1247 ../gui/wxpython/menustrings.py:1550
+#: ../gui/wxpython/menustrings.py:1784
 msgid "Map type conversions"
 msgstr "Konverze typu mapové vrstvy"
 #: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:319
-#: ../gui/wxpython/menustrings.py:1231
+#: ../gui/wxpython/menustrings.py:1248
 msgid "Raster to vector"
 msgstr "Automatická vektorizace rastrové vrstvy"
 #: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:320
-#: ../gui/wxpython/menustrings.py:1232
+#: ../gui/wxpython/menustrings.py:1249
 #, fuzzy
 msgid "Converts a raster map into a vector map."
 #: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:321
-#: ../gui/wxpython/menustrings.py:1233
+#: ../gui/wxpython/menustrings.py:1250
 msgid "Raster series to volume"
 msgstr "Konverze řady rastrových vrstev na volume"
 #: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:322
-#: ../gui/wxpython/menustrings.py:1234
+#: ../gui/wxpython/menustrings.py:1251
 msgid "Converts 2D raster map slices to one 3D raster volume map."
 msgstr "Převede 2D pláty rastrových map na jednu 3D rastrovou mapu."
 #: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:323
-#: ../gui/wxpython/menustrings.py:1235
+#: ../gui/wxpython/menustrings.py:1252
 msgid "Raster 2.5D to volume"
 msgstr "2.5D mapa na volume"
 #: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:324
-#: ../gui/wxpython/menustrings.py:1236
+#: ../gui/wxpython/menustrings.py:1253
 msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
 msgstr ""
 "Vytvoří 3D volume vrstvu založenou na 2D výškového modelu a hodnotových "
 "rastrových mapách."
-#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:605
-#: ../gui/wxpython/menustrings.py:1517
+#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:622
+#: ../gui/wxpython/menustrings.py:1551
 msgid "Vector to raster"
 msgstr "Rasterizace vektorové vrstvy"
-#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:606
-#: ../gui/wxpython/menustrings.py:1518
+#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:623
+#: ../gui/wxpython/menustrings.py:1552
 msgid "Converts (rasterize) a vector map into a raster map."
 msgstr "Převod (rastrizace) vektorové mapy do rastrové."
-#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:607
-#: ../gui/wxpython/menustrings.py:1519
+#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:624
+#: ../gui/wxpython/menustrings.py:1553
 msgid "Vector to volume"
 msgstr "Převod vektorové vrstvy na volume"
-#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:608
-#: ../gui/wxpython/menustrings.py:1520
+#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:625
+#: ../gui/wxpython/menustrings.py:1554
 #, fuzzy
 msgid "Converts a vector map (only points) into a 3D raster map."
 msgstr ""
 "Převede binární GRASS vektorovou mapovou vrstvu (pouze body) na 3D GRASS "
 "rastrovou mapovou vrstvu."
-#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:609
-#: ../gui/wxpython/menustrings.py:1521
+#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:626
+#: ../gui/wxpython/menustrings.py:1555
 msgid "2D vector to 3D vector"
 msgstr "2D vektorové mapa na 3D"
-#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:610
-#: ../gui/wxpython/menustrings.py:1522
+#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:627
+#: ../gui/wxpython/menustrings.py:1556
 msgid "Performs transformation of 2D vector features to 3D."
 msgstr "Převede 2D vektorovou mapu na mapu 3D"
-#: ../gui/wxpython/menustrings.py:199 ../gui/wxpython/menustrings.py:611
-#: ../gui/wxpython/menustrings.py:1523
+#: ../gui/wxpython/menustrings.py:199 ../gui/wxpython/menustrings.py:628
+#: ../gui/wxpython/menustrings.py:1557
 msgid "Sites to vector"
 msgstr "Vytvoření vektorové vrstvy z bodů (sites, GRASS 5.x)"
-#: ../gui/wxpython/menustrings.py:200 ../gui/wxpython/menustrings.py:612
-#: ../gui/wxpython/menustrings.py:1524
+#: ../gui/wxpython/menustrings.py:200 ../gui/wxpython/menustrings.py:629
+#: ../gui/wxpython/menustrings.py:1558
 msgid "Converts a GRASS site_lists file into a vector map."
 msgstr "Převede starý GRASS vektorový formát do vektorové mapy."
-#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:839
-#: ../gui/wxpython/menustrings.py:1751
+#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:856
+#: ../gui/wxpython/menustrings.py:1785
 msgid "Volume to raster series"
 msgstr "Převod volume na řadu rastrových vrstev"
-#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:840
-#: ../gui/wxpython/menustrings.py:1752
+#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:857
+#: ../gui/wxpython/menustrings.py:1786
 msgid "Converts 3D raster maps to 2D raster maps"
 msgstr "Převede 3D rastrové mapy na 2D rastrové mapy"
-#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1926
+#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1960
 msgid "Georectify"
 msgstr "Georektifikace"
-#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/menustrings.py:1927
+#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/menustrings.py:1961
 msgid "Manage Ground Control Points for Georectification"
 msgstr "Správa vlicovacích bodů pro georektifikaci"
-#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:1928
+#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:1962
 msgid "Graphical modeler"
 msgstr "Grafické modelování"
-#: ../gui/wxpython/menustrings.py:206 ../gui/wxpython/menustrings.py:1929
+#: ../gui/wxpython/menustrings.py:206 ../gui/wxpython/menustrings.py:1963
 msgid "Launch Graphical modeler"
 msgstr "Spustit grafické modelování"
-#: ../gui/wxpython/menustrings.py:207 ../gui/wxpython/menustrings.py:1977
+#: ../gui/wxpython/menustrings.py:207 ../gui/wxpython/menustrings.py:2011
 msgid "Run model"
 msgstr "Spustit model"
@@ -7709,15 +7710,15 @@
 "vector data, and volumes (3D raster data) in 3D."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:211 ../gui/wxpython/menustrings.py:1007
-#: ../gui/wxpython/menustrings.py:1919 ../gui/wxpython/menustrings.py:1923
+#: ../gui/wxpython/menustrings.py:211 ../gui/wxpython/menustrings.py:1024
+#: ../gui/wxpython/menustrings.py:1953 ../gui/wxpython/menustrings.py:1957
 #: ../gui/wxpython/animation/frame.py:52
 #, fuzzy
 msgid "Animation tool"
 msgstr "Kvantizace"
-#: ../gui/wxpython/menustrings.py:212 ../gui/wxpython/menustrings.py:1008
-#: ../gui/wxpython/menustrings.py:1920 ../gui/wxpython/menustrings.py:1924
+#: ../gui/wxpython/menustrings.py:212 ../gui/wxpython/menustrings.py:1025
+#: ../gui/wxpython/menustrings.py:1954 ../gui/wxpython/menustrings.py:1958
 msgid "Launch animation tool."
 msgstr ""
@@ -7734,22 +7735,22 @@
 "Jednoduchý nástroj pro převod zaměření a měření vzdáleností do souřadnic a "
 "naopak."
-#: ../gui/wxpython/menustrings.py:215 ../gui/wxpython/menustrings.py:1934
+#: ../gui/wxpython/menustrings.py:215 ../gui/wxpython/menustrings.py:1968
 #: ../gui/wxpython/lmgr/toolbars.py:144
 msgid "Cartographic Composer"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:216 ../gui/wxpython/menustrings.py:1935
+#: ../gui/wxpython/menustrings.py:216 ../gui/wxpython/menustrings.py:1969
 #, fuzzy
 msgid "Launch Cartographic Composer"
-#: ../gui/wxpython/menustrings.py:217 ../gui/wxpython/menustrings.py:1932
+#: ../gui/wxpython/menustrings.py:217 ../gui/wxpython/menustrings.py:1966
 #, fuzzy
 msgid "Map Swipe"
 msgstr "Typ mapové vrstvy:"
-#: ../gui/wxpython/menustrings.py:218 ../gui/wxpython/menustrings.py:1933
+#: ../gui/wxpython/menustrings.py:218 ../gui/wxpython/menustrings.py:1967
 #, fuzzy
 msgid "Launch Map Swipe"
 msgstr "Spustit skript"
@@ -7771,7 +7772,7 @@
 msgid "Quit the GRASS wxGUI session."
 msgstr "Ukončit WxGUI sezení"
-#: ../gui/wxpython/menustrings.py:223 ../gui/wxpython/menustrings.py:1955
+#: ../gui/wxpython/menustrings.py:223 ../gui/wxpython/menustrings.py:1989
 msgid "&Settings"
 msgstr "&Nastavení"
@@ -7955,7 +7956,7 @@
 msgid "Updates or removes installed GRASS AddOns extension(s)."
 msgstr "Správa rozšíření GRASS"
-#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1956
+#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1990
 msgid "Preferences"
 msgstr "Vlastnosti"
@@ -7965,88 +7966,88 @@
 "Uživatelské nastavení grafického prostředí (font displeje, příkazy, "
 "digitizér, atd)"
-#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1178
+#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1195
 msgid "&Raster"
 msgstr "&Rastr"
-#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1179
+#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1196
 msgid "Develop raster map"
 msgstr "Vytvořit rastrovou mapu"
-#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1180
+#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1197
 msgid "Compress/decompress"
 msgstr "Komprimovat/dekomprimovat "
-#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1181
+#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1198
 msgid "Compresses and decompresses raster maps."
 msgstr "Komprimuje a dekomprimuje rastrové soubory."
-#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1182
+#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1199
 msgid "Region boundaries"
 msgstr "Hranice regionu"
-#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1183
+#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1200
 msgid "Sets the boundary definitions for a raster map."
 msgstr "Definuje hranice rastrové mapy."
-#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1184
+#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1201
 msgid "Manage NULL values"
 msgstr "Spravovat NULL hodnoty"
-#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1185
+#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1202
 msgid "Manages NULL-values of given raster map."
 msgstr "Správa NULL hodnot dané rastrové mapy."
-#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1186
+#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1203
 msgid "Quantization"
 msgstr "Kvantizace"
-#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1187
+#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1204
 msgid "Produces the quantization file for a floating-point map."
 msgstr "Vytváří kvantizační soubor pro mapu s plovoucí desetinnou čárkou."
-#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1188
+#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1205
 msgid "Timestamp"
 msgstr "Časové razítko"
-#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1189
+#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1206
 #, fuzzy
 msgid ""
 "Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
 "raster map."
 msgstr "Vytiskni/přidej/smaž časovou značku rastrových map."
-#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1190
+#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1207
 msgid "Resample using aggregate statistics"
 msgstr "Převzorkování za použití agregačních statik"
-#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1191
+#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1208
 msgid "Resamples raster map layers to a coarser grid using aggregation."
 msgstr "Převzorkovat rastrovou vrstvu na hrubší s využitím agregace."
-#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1192
+#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1209
 msgid "Resample using multiple methods"
 msgstr "Převzorkování (změna rozlišení) za použití různých metod"
-#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1193
+#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1210
 #, fuzzy
 msgid "Resamples raster map to a finer grid using interpolation."
 msgstr "Převzorkovat rastrovou vrstvu na jemnější s využitím interpolace."
-#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1194
+#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1211
 msgid "Resample using nearest neighbor"
 msgstr "Převzorkování (změna rozlišení) metodou nejbližšího souseda"
-#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1195
+#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1212
 msgid "GRASS raster map layer data resampling capability."
 msgstr "Modul pro převzorkování rastrových map."
-#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1196
+#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1213
 msgid "Resample using spline tension"
 msgstr ""
 "Převzorkování (změna rozlišení) pomocí RST (regularized spline tension)"
-#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:1197
+#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:1214
 msgid ""
 "Reinterpolates and optionally computes topographic analysis from input "
 "raster map to a new raster map (possibly with different resolution) using "
@@ -8056,128 +8057,128 @@
 "rastrového souboru do nové rastrové mapy (volitelně s novým rozlišením) za "
 "použití RST -regularized spline s tension a vyhlazení - smothing."
-#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1198
+#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1215
 #, fuzzy
 msgid "Resample using bspline"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1199
+#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1216
 #, fuzzy
 msgid ""
 "Performs bilinear or bicubic spline interpolation with Tykhonov "
 "regularization."
 msgstr "Bikubická nebo bilineární interpolace s Tykhonovou regularizací"
-#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1200
+#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1217
 #, fuzzy
 msgid "Resample using analytic kernel"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1201
+#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1218
 #, fuzzy
 msgid "Resamples raster map layers using an analytic kernel."
-#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:568
-#: ../gui/wxpython/menustrings.py:1202 ../gui/wxpython/menustrings.py:1480
+#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:585
+#: ../gui/wxpython/menustrings.py:1219 ../gui/wxpython/menustrings.py:1514
 msgid "Support file maintenance"
 msgstr "Vytvoření a správa podpůrného souboru"
-#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1203
+#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1220
 msgid "Allows creation and/or modification of raster map layer support files."
 msgstr "Umožňuje vytvořit a/nebo modifikovat podpůrné soubory rastrové mapy."
-#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1204
+#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1221
 msgid "Update map statistics"
 msgstr "Aktualizovat mapovou statistiku"
-#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:1205
+#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:1222
 msgid "Update raster map statistics"
 msgstr "Aktualizuj statistiku rastru"
-#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1208
+#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1225
 msgid "Tiling"
 msgstr "Dlaždice"
-#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1209
+#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1226
 msgid ""
 "Produces tilings of the source projection for use in the destination region "
 "and projection."
 msgstr ""
 "Vytvoří dlaždice zdrojové projekce pro použití v cílovém regionu a projekci."
-#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:587
-#: ../gui/wxpython/menustrings.py:1210 ../gui/wxpython/menustrings.py:1499
+#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:604
+#: ../gui/wxpython/menustrings.py:1227 ../gui/wxpython/menustrings.py:1533
 msgid "Manage colors"
 msgstr "Správa barev"
-#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:588
-#: ../gui/wxpython/menustrings.py:1211 ../gui/wxpython/menustrings.py:1500
+#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:605
+#: ../gui/wxpython/menustrings.py:1228 ../gui/wxpython/menustrings.py:1534
 msgid "Color tables"
 msgstr "Tabulka barev"
-#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1212
+#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1229
 #, fuzzy
 msgid "Creates/modifies the color table associated with a raster map."
 msgstr "Vytvoří/upraví tabulku barev spojenou s rastrovou mapou."
-#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1213
+#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1230
 msgid "Color tables (stddev)"
 msgstr "Tabulka barev (stddev)"
-#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:1214
+#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:1231
 #, fuzzy
 msgid "Sets color rules based on stddev from a raster map's mean value."
 msgstr ""
 "Nastavit pravidla barev podle směrodatné odchylky z průměrné hodnoty mapy."
-#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:590
-#: ../gui/wxpython/menustrings.py:1215 ../gui/wxpython/menustrings.py:1502
+#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:607
+#: ../gui/wxpython/menustrings.py:1232 ../gui/wxpython/menustrings.py:1536
 #, fuzzy
 msgid "Manage color rules interactively"
 msgstr "Překódovat interaktivně"
-#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:1216
+#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:1233
 msgid "Interactive management of raster color tables."
 msgstr "Interaktivní správa rastrové tabulky barev."
-#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:592
-#: ../gui/wxpython/menustrings.py:1217 ../gui/wxpython/menustrings.py:1504
+#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:609
+#: ../gui/wxpython/menustrings.py:1234 ../gui/wxpython/menustrings.py:1538
 msgid "Export color table"
 msgstr "Exportovat barevnou tabulku"
-#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:1218
+#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:1235
 #, fuzzy
 msgid "Exports the color table associated with a raster map."
 msgstr "Exportuje tabulku barev spojenou s rastrovou mapou."
-#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1219
+#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1236
 msgid "Blend 2 color rasters"
 msgstr "Smíchat 2 barevné rastrové mapy"
-#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1220
+#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1237
 msgid "Blends color components of two raster maps by a given ratio."
 msgstr "Spojí barevné části dvou rastrových map zadaným poměrem."
-#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1221
+#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1238
 msgid "Create RGB"
 msgstr "Vytvořit RGB"
-#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1222
+#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1239
 msgid ""
 "Combines red, green and blue raster maps into a single composite raster map."
 msgstr ""
 "Kombinuje červenou, zelenou a modrou mapovou vrstvu do jedinné mapové "
 "kompozice."
-#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:745
-#: ../gui/wxpython/menustrings.py:1223 ../gui/wxpython/menustrings.py:1657
+#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:762
+#: ../gui/wxpython/menustrings.py:1240 ../gui/wxpython/menustrings.py:1691
 msgid "RGB to HIS"
 msgstr "Transformace RGB -> HIS"
-#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1224
+#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1241
 msgid ""
 "Generates red, green and blue raster map layers combining hue, intensity and "
 "saturation (HIS) values from user-specified input raster map layers."
@@ -8185,33 +8186,33 @@
 "Vytvoří červené, zelené a modré rastrové mapy kombinací hodnot odstínu,"
 "intenzity a nasycení (his) z uživatelem zadaných vstupních rastrových map."
-#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1225
+#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1242
 msgid "Query raster maps"
 msgstr "Dotazování rastrové vrstvy"
-#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1226
+#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1243
 msgid "Query values by coordinates"
 msgstr "Dotaz na hodnoty podle souřadnic"
-#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1227
+#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1244
 #, fuzzy
 msgid "Queries raster maps on their category values and category labels."
 msgstr ""
 "Program sloužící k dotazování rastrových map podle jejich kategorií a popisů."
-#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:1228
+#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:1245
 msgid "Query colors by value"
 msgstr "Dotaz na barvu podle hodnoty"
-#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:1229
+#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:1246
 msgid "Queries colors for a raster map layer."
 msgstr "Dotazuje se na barvu rastrové vrstvy"
-#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1237
+#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1254
 msgid "Buffer rasters"
 msgstr "Obalová zóna rastrové mapy"
-#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1238
+#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1255
 #, fuzzy
 msgid ""
 "Creates a raster map showing buffer zones surrounding cells that contain non-"
@@ -8220,41 +8221,41 @@
 "Vytvoří rastrovou mapu zachycující obalové zóny kolem buněk s neNULLovou "
 "hodnotou."
-#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1239
+#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1256
 msgid "Concentric circles"
 msgstr "Soustředné kruhy"
-#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1240
+#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1257
 msgid "Creates a raster map containing concentric rings around a given point."
 msgstr "Vytvoří rastrovou mapu obsahující centrické kruhy okolo zadaného bodu."
-#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1241
+#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1258
 msgid "Closest points"
 msgstr "Nejbližší body"
-#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1242
+#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1259
 msgid "Locates the closest points between objects in two raster maps."
 msgstr "Nalezne nejbližší body mezi objekty ze dvou rastrových map."
-#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1244
+#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1261
 #, fuzzy
 msgid "Creates a MASK for limiting raster operation."
 msgstr "Vytvoří MASKu proomezení rastrových operací"
-#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1245
+#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1262
 msgid "Raster map calculator"
 msgstr "3D rastrový kalkulátor"
-#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1246
+#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1263
 #, fuzzy
 msgid "Raster map calculator."
-#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1247
+#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1264
 msgid "Neighborhood analysis"
 msgstr "Analýza okolí"
-#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1249
+#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1266
 msgid ""
 "Makes each cell category value a function of the category values assigned to "
 "the cells around it, and stores new cell values in an output raster map "
@@ -8263,11 +8264,11 @@
 "Hodnota každé buňky v novém rastru bude funkcí hodnot kategorii sousedních "
 "buněk a bude uložena jako hodnota ve výstupní rastrové mapě."
-#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1250
+#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1267
 msgid "Neighborhood points"
-#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1251
+#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1268
 #, fuzzy
 msgid ""
 "Neighborhood analysis tool for vector point maps. Makes each cell value a "
@@ -8277,25 +8278,25 @@
 "Vytvoří pro každou buňku funkci hodnot atributů vektorových bodů nebo "
 "centroidů v okolí, a uloží je v nové rastrové mapě."
-#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1252
+#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1269
 msgid "Overlay rasters"
-#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1253
+#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1270
 msgid "Cross product"
 msgstr "Výsledek přeložení"
-#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1254
+#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1271
 msgid ""
 "Creates a cross product of the category values from multiple raster map "
 "layers."
 msgstr "Vytvoří násobné překrytí hodnot kategorií z několika rastrových map."
-#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1255
+#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1272
 msgid "Raster series"
 msgstr "Série rastrových map"
-#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1256
+#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1273
 msgid ""
 "Makes each output cell value a function of the values assigned to the "
 "corresponding cells in the input raster map layers."
@@ -8303,11 +8304,11 @@
 "Hodnota každé buňky ve výstupním rastrovém souboru je funkcí hodnot několika "
 "dalších buněk ve vstupním rastrovém souboru."
-#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1257
+#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1274
 msgid "Patch raster maps"
-#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1258
+#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1275
 msgid ""
 "Creates a composite raster map layer by using known category values from one "
 "(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
@@ -8316,40 +8317,45 @@
 "jedné nebo několika map tak, že vyplní oblasti \"bez žádných dat\" v "
 "jinémapové vrstvě."
-#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1259
+#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1276
 msgid "Statistical overlay"
 msgstr "Statistický překryv"
-#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1260
+#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1277
 #, fuzzy
 msgid ""
 "Calculates category or object oriented statistics (accumulator-based "
 "statistics)."
 msgstr "Počítá statistky podle kategorií nebo objektově orientované."
-#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1261
+#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1278
 #, fuzzy
 msgid "Quantiles overlay"
-#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1262
+#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1279
+#, fuzzy
+msgid "Compute category quantiles using two passes."
+msgstr "Vypočítat quantily použitím dvou průchodů"
+#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1280
 msgid "Solar radiance and shadows"
 msgstr "Solární záření a stíny"
-#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1263
+#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1281
 msgid "LatLong map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1264
+#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1282
 #, fuzzy
 msgid "Creates a latitude/longitude raster map."
 msgstr "Vytvořit novou vektorovou mapu"
-#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1265
+#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1283
 msgid "Solar irradiance and irradiation"
 msgstr "Sluneční záření a ozáření"
-#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1266
+#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1284
 #, fuzzy
 msgid ""
 "Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
@@ -8366,11 +8372,11 @@
 "Alternativně stačí specifikovat čas pro výpočet slunečního úhlu a/nebo mapy "
 "ozáření. Také lze volitelně zahrnout efekt stínu terénu."
-#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1267
+#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1285
 msgid "Shadows map"
 msgstr "Stínovaná mapa"
-#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1268
+#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1286
 #, fuzzy
 msgid ""
 "Calculates cast shadow areas from sun position and elevation raster map. "
@@ -8381,12 +8387,12 @@
 "specifikována přesná pozice Slunce nebo B: pozice je spočítána samostatně z "
 "hodnoty datum/čas pomocí r.sunmask."
-#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1269
+#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1287
 #, fuzzy
 msgid "Sunshine hours and solar angles"
-#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1270
+#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1288
 msgid ""
 "Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
 "the angle between the direction of the geometric center of the sun's "
@@ -8394,23 +8400,23 @@
 "north in clockwise direction."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1271
+#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1289
 msgid "Terrain analysis"
 msgstr "Terénní analýza"
-#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1272
+#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1290
 msgid "Generate contour lines"
 msgstr "Vytvořit vrstevnice"
-#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1273
+#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1291
 msgid "Produces a vector map of specified contours from a raster map."
 msgstr "Vytvoří vektorovou vrstvu obsahující vrstevnice z modelu terénu."
-#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1274
+#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1292
 msgid "Cost surface"
 msgstr "Povrch nákladů"
-#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1275
+#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1293
 msgid ""
 "Creates a raster map showing the cumulative cost of moving between different "
 "geographic locations on an input raster map whose cell category values "
@@ -8420,11 +8426,11 @@
 "polohami na vstupní rastrové vrstvě kde každá hodnota buňky prezentuje "
 "náklad."
-#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1276
+#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1294
 msgid "Cumulative movement costs"
 msgstr "Výpočet kumulativního pohyby nákladů mezi lokacemi"
-#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1277
+#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1295
 #, fuzzy
 msgid ""
 "Outputs a raster map showing the anisotropic cumulative cost. Computes "
@@ -8438,30 +8444,30 @@
 "jejížhodnoty buněk reprezentují výšku kombinovanou s další mapou, jejíž "
 "hodnoty reprezentují frikční povrch."
-#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1278
+#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1296
 msgid "Least cost route or flow"
 msgstr "Nejméně nákladná cesta nebo dráha odtoku"
-#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1279
+#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1297
 #, fuzzy
 msgid ""
 "Traces a flow through an elevation model or cost surface on a raster map."
 msgstr "Určí směr povrchového odtoku na rastrovém modelu terénu."
-#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1280
+#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1298
 msgid "Shaded relief"
 msgstr "Mapa stínovaného reliéfu"
-#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1281
+#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1299
 #, fuzzy
 msgid "Creates shaded relief map from an elevation map (DEM). "
 msgstr "Vytvoří mapu stínovaného reliéfu ze vstupní mapy elevace (DMT)."
-#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1282
+#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1300
 msgid "Slope and aspect"
 msgstr "Míra svahu a expozice"
-#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1283
+#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1301
 #, fuzzy
 msgid ""
 "Generates raster maps of slope, aspect, curvatures and partial derivatives "
@@ -8472,11 +8478,11 @@
 "odvozenou z digitálního modelu terénu. Expozice je počítána proti směru "
 "hodinových ručiček s počátkem na východě."
-#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1284
+#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1302
 msgid "Terrain parameters"
 msgstr "Parametry terénu"
-#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1285
+#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1303
 #, fuzzy
 msgid ""
 "Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
@@ -8485,48 +8491,48 @@
 "Používá multisklalární přístup, vypočítává kvadratické koeficienty pro okno "
 "libovolné velikosti (pomocí metody nejmenších čtverců)."
-#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1286
+#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1304
 msgid "Textural features"
 msgstr "Texturální prvky"
-#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1287
+#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1305
 msgid "Generate images with textural features from a raster map."
 msgstr "Vytvoří obrázky s texturálními vlastnostmi rastrové mapy."
-#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1288
+#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1306
 msgid "Visibility"
 msgstr "Viditelnost"
-#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1289
+#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1307
 #, fuzzy
 msgid ""
 "Computes the viewshed of a point on an elevation raster map. Default format: "
 "NULL (invisible), vertical angle wrt viewpoint (visible)."
 msgstr "Převede binární GRASS vektorovou mapu do GRASS rastrové mapy."
-#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1290
+#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1308
 #, fuzzy
 msgid "Visibility [DEPRECATED]"
-#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1291
+#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1309
 msgid "Line-of-sight raster analysis program."
 msgstr "Vytváří rastrovou mapu linií dohlednosti."
-#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1292
+#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1310
 msgid "Distance to features"
 msgstr "Vzdálenost k prvkům"
-#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1293
+#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1311
 #, fuzzy
 msgid "Generates a raster map containing distances to nearest raster features."
 msgstr "Vytvoří rastrovou mapu vzdáleností k prvkům ve vstupní mapě."
-#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1294
+#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1312
 msgid "Horizon angle"
 msgstr "Úhel horizontu"
-#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1295
+#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1313
 msgid ""
 "Horizon angle computation from a digital elevation model. Computes horizon "
 "angle height from a digital elevation model. The module has two different "
@@ -8538,15 +8544,15 @@
 "horizon height in radians."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1296
+#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1314
 msgid "Transform features"
 msgstr "Prvky transformace"
-#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1297
+#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1315
 msgid "Clump"
 msgstr "Shromáždit"
-#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1298
+#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1316
 msgid ""
 "Recategorizes data in a raster map by grouping cells that form physically "
 "discrete areas into unique categories."
@@ -8554,31 +8560,31 @@
 "Změní kategorie dat rastrového souboru tak, že seskupí sousedící buňky "
 "formující fyzicky spojité oblasti do jedinečných kategorií."
-#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1299
+#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1317
 msgid "Grow"
 msgstr "Růst "
-#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1300
+#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1318
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
 msgstr "Vytvoří rastrovou spojitých oblastí zvětšených o jednu buňku."
-#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1301
+#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1319
 msgid "Thin"
 msgstr "Ztenčit"
-#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1302
+#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1320
 msgid "Thins non-zero cells that denote linear features in a raster map layer."
 msgstr "Zmenší nenulové buňky tak, aby vznikly lineární struktury."
-#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1303
+#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1321
 msgid "Hydrologic modeling"
 msgstr "Hydrologické modelování"
-#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1304
+#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1322
 msgid "Carve stream channels"
 msgstr "Rozdělit stream na kanály"
-#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1305
+#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1323
 #, fuzzy
 msgid ""
 "Generates stream channels. Takes vector stream data, transforms it to raster "
@@ -8587,20 +8593,20 @@
 "Vezme vektorová data potoků, převede je na rastr a odečte hloubku z "
 "výstupního DMT."
-#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1306
+#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1324
 msgid "Fill lake"
 msgstr "Vyplnit jezera"
-#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1307
+#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1325
 #, fuzzy
 msgid "Fills lake at given point to given level."
 msgstr "Vyplní jezero do zadané hloubky"
-#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1308
+#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1326
 msgid "Depressionless map and flowlines"
 msgstr "Model terénu bez depresí a mapa odtoku "
-#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1309
+#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1327
 #, fuzzy
 msgid ""
 "Filters and generates a depressionless elevation map and a flow direction "
@@ -8609,19 +8615,19 @@
 "Z rastrové mapy digitálního modelu terénu odstraní uměle vytvořené sníženiny "
 "a vytvoří mapu směru odtoku."
-#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1310
+#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1328
 msgid "Flow accumulation"
 msgstr "Akumulace toku gridu"
-#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1311
+#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1329
 msgid "Flow computation for massive grids (float version)."
 msgstr "Výpočet odtoku pro velké rastry."
-#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1312
+#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1330
 msgid "Flow lines"
 msgstr "Linie toku"
-#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1313
+#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1331
 #, fuzzy
 msgid ""
 "Constructs flowlines. Computes flowlines, flowpath lengths, and "
@@ -8630,47 +8636,125 @@
 "Konstrukce svahových křivek (drah odtoku), délek odtoku a hustoty odtoku (do "
 "svahu) z rastrové mapy elevace (DMT)"
-#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1314
+#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1332
 msgid "Watershed analysis"
 msgstr "Analýza povodí"
-#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1315
+#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1333
 msgid "Calculates hydrological parameters and RUSLE factors."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1316
+#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1334
 msgid "Watershed subbasins"
 msgstr "Rozvodnice subpovodí"
-#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1317
+#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1335
 msgid "Generates watershed subbasins raster map."
 msgstr "Vytvoří mapy povodí v rastrové mapě."
-#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1318
+#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1336
 msgid "Watershed basin creation"
 msgstr "Vytvoření rozvodnice povodí"
-#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1319
+#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1337
 #, fuzzy
 msgid "Creates watershed basins from a drainage direction map."
-#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1320
+#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1338
+msgid "River channel characteristics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1339
+msgid "Calculates local parameters for individual streams."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1340
+msgid "River distance and elevation characteristics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1341
+msgid ""
+"Calculates distance to and elevation above streams and outlets. The module "
+"can work in stream mode where target are streams and outlets mode where "
+"targets are outlets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1342
+msgid "Extraction of stream networks"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1343
+#, fuzzy
+msgid "Performs stream network extraction."
+msgstr "Provádí údržbu síťě."
+#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1344
+msgid "River ordering and hierarchy"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1345
+msgid ""
+"Calculates Strahler's and more streams hierarchy. Basic module for "
+"topological analysis of drainage network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1346
+#, fuzzy
+msgid "River segment characteristics"
+msgstr "Zprávy a statistiky"
+#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1347
+msgid ""
+"Divides network into near straight-line segments and calculate its order."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1348
+#, fuzzy
+msgid "River elevation change"
+msgstr "Zpět předchozí změny"
+#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1349
+msgid "Calculates local parameters for slope subsystem."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1350
+msgid "Position correction of water outlet point"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1351
+msgid ""
+"Snap point to modelled river network. Input can be stream network, point "
+"vector map with outlets or outlet coordinates."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1352
+#, fuzzy
+msgid "Horton's statistics"
+msgstr "Základní statistiky 3D pixelu (voxel)"
+#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1353
+msgid ""
+"Calculates Horton's statistics for Strahler and Horton ordered networks "
+"created with r.stream.order."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1354
 msgid "SIMWE Overland flow modeling"
 msgstr "Modelování povrchového odtoku SIMWE"
-#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1321
+#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1355
 #, fuzzy
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
 msgstr ""
 "Hydrologický model povrchového odtoku s použitím metody vzorkování cesty "
 "(SIMWE)"
-#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1322
+#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1356
 msgid "SIMWE Sediment flux modeling"
 msgstr "Modelování toku sedimentů SIMWE"
-#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1323
+#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1357
 #, fuzzy
 msgid ""
 "Sediment transport and erosion/deposition simulation using path sampling "
@@ -8679,51 +8763,51 @@
 "Simulace transportu sedimentů a eroze/usazování za použití metody vzorkování "
 "cesty (SIMWE)"
-#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1324
+#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1358
 msgid "Topographic index map"
 msgstr "Mapa s topografickým indexem"
-#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1325
+#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1359
 #, fuzzy
 msgid "Creates topographic index map from elevation raster map."
 msgstr ""
 "Vytvoří mapu topografického indexu, [ln(a/tan(beta))], z rastrové mapy "
 "digitálního modelu terénu."
-#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1326
+#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1360
 msgid "TOPMODEL simulation"
 msgstr "Simulace TOPMODEL"
-#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1327
+#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1361
 msgid "Simulates TOPMODEL which is a physically based hydrologic model."
 msgstr "Simuluje TOPMODEL, což je dynamický hydrologický model."
-#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1328
+#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1362
 msgid "USLE K-factor"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1329
+#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1363
 msgid "Computes USLE Soil Erodibility Factor (K)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1330
+#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1364
 msgid "USLE R-factor"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1331
+#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1365
 msgid "Computes USLE R factor, Rainfall erosivity index."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:851
-#: ../gui/wxpython/menustrings.py:1332 ../gui/wxpython/menustrings.py:1763
+#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:868
+#: ../gui/wxpython/menustrings.py:1366 ../gui/wxpython/menustrings.py:1797
 msgid "Groundwater modeling"
 msgstr "Modelování povrchového odtku"
-#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1333
+#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1367
 msgid "Groundwater flow"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1334
+#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1368
 msgid ""
 "Numerical calculation program for transient, confined and unconfined "
 "groundwater flow in two dimensions."
@@ -8731,62 +8815,62 @@
 "Numerický výpočetní program pro přechodné, omezené a neohraničenéproudění "
 "podzemních vod ve dvou rozměrech."
-#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1335
+#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1369
 msgid "Groundwater solute transport"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1336
+#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1370
 msgid ""
 "Numerical calculation program for transient, confined and unconfined solute "
 "transport in two dimensions"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1337
+#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1371
 msgid "Landscape structure modeling"
 msgstr "Modelování struktury krajiny"
-#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1338
+#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1372
 msgid "Analyze landscape"
 msgstr "Analýza charakteristik krajiny"
-#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1339
+#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1373
 msgid "Analyze patches"
 msgstr "Analýza plošek"
-#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1340
+#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1374
 msgid "Landscape patch analysis"
 msgstr "Analýza krajiných \"patch\" charakteristik"
-#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1341
+#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1375
 msgid "Set up sampling and analysis framework"
 msgstr "Nastavit vzorkování a analýzu rámce"
-#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1342
+#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1376
 msgid "Configuration editor for r.li.'index'"
 msgstr "Konfigurační editor pro r.li.'index'"
-#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1343
+#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1377
 msgid "Edge density"
 msgstr "Hustota hran"
-#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1344
+#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1378
 msgid ""
 "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr "Počítá index hustoty hran rastrové mapy za použití algoritmu 4 sousedů"
-#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1345
+#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1379
 msgid "Contrast weighted edge density"
 msgstr "Vážený rozdíl hustoty hran"
-#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1346
+#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1380
 msgid "Calculates contrast weighted edge density index on a raster map"
 msgstr "Počítej podle kontrastu vážený index hustoty hran"
-#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1347
+#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1381
 msgid "Patch area mean"
 msgstr "Průměrná velikost opravy"
-#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1348
+#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1382
 msgid ""
 "Calculates mean patch size index on a raster map, using a 4 neighbour "
 "algorithm"
@@ -8794,100 +8878,100 @@
 "Počítá průměrný index velikosti plošek rastrové mapy za použití algoritmu 4 "
 "sousedů."
-#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1349
+#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1383
 msgid "Patch area range"
 msgstr "Rozmezí opravených ploch"
-#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1350
+#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1384
 msgid "Calculates range of patch area size on a raster map"
 msgstr "Počítá rozsah velikosti plošek na v rastrové mapě"
-#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1351
+#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1385
 msgid "Patch area Std Dev"
 msgstr "Střední odchylka opravených ploch"
-#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1352
+#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1386
 msgid "Calculates standard deviation of patch area a raster map"
 msgstr "Počítá standardní odchylku plošek rastrové mapy"
-#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1353
+#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1387
 msgid "Patch area Coeff Var"
 msgstr "Koeficient odchylky plochy plošek"
-#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1354
+#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1388
 msgid "Calculates coefficient of variation of patch area on a raster map"
 msgstr "Počítám koeficient variance plošky v rastrové mapě"
-#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1355
+#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1389
 msgid "Patch density"
 msgstr "Hustota plošek"
-#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1356
+#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1390
 msgid ""
 "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 "Počítá index hustoty plošek na rastrové mapě za použití algoritmu 4 sousedů"
-#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1357
+#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1391
 msgid "Patch number"
 msgstr "Číslo plošky"
-#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1358
+#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1392
 msgid ""
 "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
 "Počítá index počtu plošek na rastrové mapě za použití algoritmu 4 sousedů."
-#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1359
+#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1393
 msgid "Dominance's diversity"
 msgstr "Dominanceova diverzita"
-#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1360
+#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1394
 msgid "Calculates dominance's diversity index on a raster map"
 msgstr "Počítám index diversity dominance rastrové mapy"
-#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1361
+#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1395
 msgid "Shannon's diversity"
 msgstr "Shannonova diverzita"
-#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1362
+#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1396
 msgid "Calculates Shannon's diversity index on a raster map"
 msgstr "Počítá  Shannonův index diversity v rastrové mapě"
-#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1363
+#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1397
 msgid "Simpson's diversity"
 msgstr "Simpsnova diverzita"
-#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1364
+#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1398
 msgid "Calculates Simpson's diversity index on a raster map"
 msgstr "Spočítá Simpsonův index diversity index rastrové mapy"
-#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1365
+#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1399
 msgid "Richness"
 msgstr "Bohatost"
-#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1366
+#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1400
 #, fuzzy
 msgid "Calculates richness index on a raster map"
 msgstr "Počítám index tvaru rastrové mapy"
-#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1367
+#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1401
 msgid "Shape index"
 msgstr "Index ostrosti"
-#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1368
+#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1402
 msgid "Calculates shape index on a raster map"
-#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1369
+#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1403
 msgid "Wildfire modeling"
 msgstr "Modelování požáru"
-#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1370
+#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1404
 msgid "Rate of spread"
 msgstr "Rychlost šíření"
-#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1371
+#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1405
 #, fuzzy
 msgid ""
 "Generates rate of spread raster maps. Generates three, or four raster map "
@@ -8900,22 +8984,22 @@
 "volitelně, 4. - maximální potenciální vzdálenost, na kterou se může přenést "
 "požár jiskrami."
-#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1372
+#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1406
 msgid "Least-cost spread paths"
 msgstr "Vytvořit trasy s nejmenším odporem šíření"
-#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1373
+#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1407
 msgid ""
 "Recursively traces the least cost path backwards to cells from which the "
 "cumulative cost was determined."
 msgstr ""
 "Sleduje cestu zpět až do místa, odkud započal výpočet kumulativních nákladů."
-#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1374
+#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1408
 msgid "Anisotropic spread simulation"
 msgstr "Simulace anisotropicého jevu šíření"
-#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1375
+#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1409
 #, fuzzy
 msgid ""
 "Simulates elliptically anisotropic spread. Generates a raster map of the "
@@ -8928,24 +9012,24 @@
 "rastrovou mapu kumulativního času šíření, Daná rastrová mapa obsahuje "
 "rychlost šíření (ROS), směr šíření a zdroj šíření."
-#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1376
+#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1410
 msgid "Change category values and labels"
 msgstr "Modifikovat hodnoty kategorií a štítky"
-#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1377
+#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1411
 msgid "Interactively edit category values"
 msgstr "Interaktivně editovat hodnoty kategorií"
-#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1378
+#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1412
 #, fuzzy
 msgid "Edits cell values in a raster map."
 msgstr "Interaktivní editace rastrových buněk v zadané mapě."
-#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1379
+#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1413
 msgid "Reclassify by size"
 msgstr "Reklasifikovat podle velikosti"
-#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1380
+#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1414
 msgid ""
 "Reclasses a raster map greater or less than user specified area size (in "
 "hectares)."
@@ -8953,12 +9037,12 @@
 "Reklasifikuje rastrovou mapu na větší nebo menší než uživatelem zadané "
 "hraniční velikosti ploch (v hektarech)."
-#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:678
-#: ../gui/wxpython/menustrings.py:1381 ../gui/wxpython/menustrings.py:1590
+#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:695
+#: ../gui/wxpython/menustrings.py:1415 ../gui/wxpython/menustrings.py:1624
 msgid "Reclassify"
 msgstr "Reklasifikovat"
-#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1382
+#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1416
 #, fuzzy
 msgid ""
 "Reclassify raster map based on category values. Creates a new raster map "
@@ -8968,50 +9052,50 @@
 "Vytvoří novou mapovou vrstvu jejíž hodnoty budou založeny na reklasifikaci "
 "hodnot výchozí rastrové mapy."
-#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1383
+#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1417
 msgid "Recode"
 msgstr "Překódovat"
-#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1384
+#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1418
 msgid "Recodes categorical raster maps."
 msgstr "Překódovává categorie rastrové mapy."
-#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1385
+#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1419
 msgid "Rescale"
 msgstr "Změnit měřítko"
-#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1386
+#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1420
 msgid "Rescales the range of category values in a raster map layer."
 msgstr "Změní rozsahy hodnot v kategoriích rastrové mapy."
-#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1387
+#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1421
 msgid "Rescale with histogram"
 msgstr "Změnit měřítko s histogramem"
-#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1388
+#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1422
 msgid ""
 "Rescales histogram equalized the range of category values in a raster map "
 "layer."
 msgstr ""
 "Změní kategorie histogramu rastrové mapy podle rozsahu hodnot kategorií."
-#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1389
+#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1423
 msgid "Generate random cells"
 msgstr "Vytvořit rastrovou vrstvu s náhodnými hodnotami"
-#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1390
+#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1424
 msgid "Random cells"
 msgstr "Náhodné buňky"
-#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1391
+#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1425
 msgid "Generates random cell values with spatial dependence."
 msgstr "Vytvoří prostorově závislé pole náhodných hodnot."
-#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1392
+#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1426
 msgid "Random cells and vector points"
 msgstr "Vytvořit rastrovou vrstvu a vektorové body s náhodnými hodnotami"
-#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1393
+#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1427
 msgid ""
 "Creates a raster map layer and vector point map containing randomly located "
 "points."
@@ -9019,23 +9103,23 @@
 "Vytvoří rastrovou vrstvu a bodovou vektorovou vrstvu obsahující náhodně "
 "rozmístěné body."
-#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1394
+#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1428
 msgid "Generate surfaces"
 msgstr "Vytvořit povrch"
-#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1395
+#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1429
 msgid "Fractal surface"
 msgstr "Vytvořit povrch na základě fraktálu"
-#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1396
+#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1430
 msgid "Creates a fractal surface of a given fractal dimension."
 msgstr "Vytváří fraktální povrch o zadané fraktální dimenzi"
-#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1397
+#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1431
 msgid "Gaussian kernel density surface"
 msgstr "Vytvoř povrch Gaussových odchylek"
-#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1398
+#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1432
 #, fuzzy
 msgid ""
 "Generates a raster density map from vector points map. Density is computed "
@@ -9046,23 +9130,23 @@
 "pohybuje 2D isotropické Gaussiánské jádro nebo volitelně generuje vektorovou "
 "mapu hustoty na vektorové síti s 1D jádrem."
-#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1399
+#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1433
 msgid "Gaussian deviates surface"
-#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1400
+#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1434
 #, fuzzy
 msgid ""
 "Generates a raster map using gaussian random number generator. Mean and "
 "standard deviation of gaussian deviates can be expressed by the user."
-#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1401
+#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1435
 #: ../gui/wxpython/nviz/tools.py:4587
 msgid "Plane"
 msgstr "Rovinná plocha"
-#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1402
+#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1436
 msgid ""
 "Creates raster plane map given dip (inclination), aspect (azimuth) and one "
 "point."
@@ -9070,11 +9154,11 @@
 "Vytvoří rastrovou mapu plochy při zadání ponoru (sklonu), expozice (azimut) "
 "a jednoho bodu."
-#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1403
+#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1437
 msgid "Random deviates surface"
 msgstr "Vytvoř náhodný povrch"
-#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1404
+#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1438
 #, fuzzy
 msgid ""
 "Produces a raster surface map of uniform random deviates with defined range."
@@ -9082,51 +9166,51 @@
 "Vytvoří rastrovou mapu uniformních náhodných odchylek, jejichž rozsah může "
 "být zadán uživatelem."
-#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1405
+#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1439
 msgid "Random surface with spatial dependence"
 msgstr "Vytvořit náhodný povrch s prostorovým vztahem"
-#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1406
+#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1440
 msgid "Generates random surface(s) with spatial dependence."
 msgstr "Vytvoří prostorově závislé povrchy náhodných hodnot."
-#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1407
+#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1441
 msgid "Interpolate surfaces"
 msgstr "Interpolovat povrch"
-#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1408
+#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1442
 msgid "Bilinear and bicubic from vector points"
 msgstr "Bilineární a bikubická interpolace z vektorových bodů"
-#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1409
+#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1443
 #, fuzzy
 msgid ""
 "Performs bicubic or bilinear spline interpolation with Tykhonov "
 "regularization."
-#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1410
+#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1444
 msgid "IDW from raster points"
 msgstr "Interpolace IDW z rastrových bodů"
-#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1411
+#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1445
 msgid "Surface interpolation utility for raster map."
 msgstr "Nástroj pro interpolaci povrchů rastrových map."
-#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1412
+#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1446
 msgid "IDW from raster points (alternate method for sparse points)"
 msgstr ""
 "Interpolace IDW z rastrových bodů (alternativní metoda pro malý počet bodů)"
-#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1413
+#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1447
 msgid "Surface generation program."
 msgstr "Tvorba povrchu"
-#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1414
+#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1448
 msgid "IDW from vector points"
 msgstr "Interpolace IDW z vektorových bodů"
-#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1415
+#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1449
 #, fuzzy
 msgid ""
 "Provides surface interpolation from vector point data by Inverse Distance "
@@ -9135,20 +9219,20 @@
 "Interpolace povrchu z vektorových bodových dat na základě metody Inverse "
 "Distance Squared Weighting (IDW)."
-#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1416
+#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1450
 msgid "Raster contours"
 msgstr "Rastrové vrstevnice"
-#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1417
+#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1451
 #, fuzzy
 msgid "Generates surface raster map from rasterized contours."
 msgstr "Program pro tvorbu povrchů z vrstevnic uložených v rastrové vrstvě."
-#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1418
+#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1452
 msgid "Regularized spline tension"
 msgstr "Interpolace pomocí RST (regularized spline tension)"
-#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1419
+#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1453
 #, fuzzy
 msgid ""
 "Performs surface interpolation from vector points map by splines. Spatial "
@@ -9160,46 +9244,46 @@
 "ve vektorovém formátu pro vytvoření rastrové vrtsvy s desetinnou čárkou za "
 "použití interpolace RST (regularized spline with tension)."
-#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1420
+#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1454
 msgid "Ordinary or block kriging"
 msgstr "Běžné nebo blokové krigování"
-#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1421
+#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1455
 msgid "Performs ordinary or block kriging."
 msgstr "Provede běžné nwebo blokové krigování."
-#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1422
+#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1456
 msgid "Fill NULL cells"
 msgstr "Vyplnit NULLové buňky"
-#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1423
+#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1457
 #, fuzzy
 msgid "Fills no-data areas in raster maps using spline interpolation."
 msgstr ""
 "V rastrových mapách vyplní plochy s prázdnými hodnotami za použití v.surf."
 "rst spline interpolace"
-#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:717
-#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:995
-#: ../gui/wxpython/menustrings.py:1424 ../gui/wxpython/menustrings.py:1629
-#: ../gui/wxpython/menustrings.py:1737 ../gui/wxpython/menustrings.py:1907
+#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:734
+#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1012
+#: ../gui/wxpython/menustrings.py:1458 ../gui/wxpython/menustrings.py:1663
+#: ../gui/wxpython/menustrings.py:1771 ../gui/wxpython/menustrings.py:1941
 msgid "Reports and statistics"
 msgstr "Zprávy, výpisy a statistiky"
-#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1425
+#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1459
 msgid "Basic raster metadata"
 msgstr "Základní  výpis metadat rastrové mapy"
-#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1426
+#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1460
 #, fuzzy
 msgid "Outputs basic information about a raster map."
 msgstr "Vypíše základní informace o uživatelem vybrané rastrové vrstvě."
-#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1427
+#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1461
 msgid "Manage category information"
 msgstr "Upravit informace o kategoriích"
-#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1428
+#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1462
 msgid ""
 "Manages category values and labels associated with user-specified raster map "
 "layers."
@@ -9207,46 +9291,46 @@
 "Spravuje hodnoty kategorií a štítky spojené s uživatelem zadanou rastrovou "
 "vrstvou."
-#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1429
+#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1463
 msgid "General statistics"
 msgstr "Obecné statistiky"
-#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1430
+#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1464
 #, fuzzy
 msgid "Generates area statistics for raster map."
 msgstr "Vytvoří statistiku ploch pro rastrové vrstvy."
-#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1431
+#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1465
 msgid "Quantiles for large data sets"
 msgstr "Qvantilové statistiky pro velké množství dat"
-#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1432
+#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1466
 msgid "Compute quantiles using two passes."
 msgstr "Vypočítá qvantily použitím dvou průchodů."
-#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1433
+#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1467
 msgid "Range of category values"
 msgstr "Rozsah hodnot kategorii"
-#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1434
+#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1468
 msgid "Prints terse list of category values found in a raster map layer."
 msgstr ""
 "Vytiskne pouze stručný seznam hodnot kategorií, nalezených v rastrové mapě."
-#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1435
+#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1469
 msgid "Sum area by raster map and category"
 msgstr "Výpis ploch v rastrové mapě podle kategorií"
-#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1436
+#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1470
 #, fuzzy
 msgid "Reports statistics for raster maps."
 msgstr "Vypíše statistiky pro rastrové vrstvy."
-#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1437
+#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1471
 msgid "Statistics for clumped cells"
 msgstr "Souhrnná statistika spojených buněk (po použití r.clump)"
-#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1438
+#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1472
 #, fuzzy
 msgid ""
 "Calculates the volume of data \"clumps\". Optionally produces a GRASS vector "
@@ -9255,50 +9339,50 @@
 "Spočítá objem spojitých oblastí a (volitelně) vytvoří bodovou vektorovou "
 "mapu obsahující spočítané centroidy těchto spojitých oblastí."
-#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1439
+#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1473
 msgid "Total corrected area"
 msgstr "Celkem opravených ploch"
-#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1440
+#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1474
 #, fuzzy
 msgid "Prints estimation of surface area for raster map."
-#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1441
+#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1475
 #: ../gui/wxpython/lmgr/layertree.py:579 ../gui/wxpython/lmgr/layertree.py:606
 msgid "Univariate raster statistics"
 msgstr "Univariantní statistika rastrové vrstvy"
-#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1442
+#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1476
 msgid ""
 "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr "Spočítá univariantní statistiku z ne-nullových buněk rastrové mapy."
-#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1443
+#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1477
 msgid "Sample transects"
 msgstr "Vzorové body profilu"
-#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1444
+#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1478
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
 msgstr ""
 "Vytvoří rastrovou mapu hodnot, ležících na uživatelem definovaných liniích."
-#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1445
+#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1479
 msgid "Sample transects (bearing/distance)"
 msgstr "Kontrolní hodnoty profilu (použít azimut/vzdálenost)"
-#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1446
+#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1480
 msgid ""
 "Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
 "Vytvoří rastrovou mapu, jejíž hodnoty leží na uživatelem definovaném "
 "transektu."
-#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1447
+#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1481
 msgid "Covariance/correlation"
 msgstr "Kovariance/korelace"
-#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1448
+#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1482
 msgid ""
 "Outputs a covariance/correlation matrix for user-specified raster map "
 "layer(s)."
@@ -9306,30 +9390,30 @@
 "Vytvoří kovarianční/korelační matici pro uživatelem zadanou rastrovou "
 "mapu(y)."
-#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1449
+#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1483
 msgid "Linear regression"
 msgstr "Lineární regrese"
-#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1450
+#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1484
 #, fuzzy
 msgid "Calculates linear regression from two raster maps: y = a + b*x."
 msgstr "Počítá lineární regresi pro dvě rastrové mapy: y = a + b*x"
-#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1451
+#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1485
 #, fuzzy
 msgid "Multiple regression"
-#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1452
+#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1486
 #, fuzzy
 msgid "Calculates multiple linear regression from raster maps."
-#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1453
+#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1487
 msgid "Mutual category occurrences"
 msgstr "Společný výskyt kategorie (koincidence)"
-#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1454
+#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1488
 msgid ""
 "Tabulates the mutual occurrence (coincidence) of categories for two raster "
 "map layers."
@@ -9337,23 +9421,23 @@
 "Vytvoří tabulku mutualoccurrence (koincidence) kategorií pro dvě rastrové "
 "mapy."
-#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1455
+#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1489
 msgid "&Vector"
 msgstr "&Vektor"
-#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1456
+#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1490
 msgid "Develop vector map"
 msgstr "Vytvořit vektorovou mapu"
-#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1458
+#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1492
 msgid "Create new empty vector map"
 msgstr "Vytvořit novou prázdnou vektorovou mapu"
-#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1459
+#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1493
 msgid "Edit vector map (non-interactively)"
 msgstr "Editovat vektorovu mapu (NEinteraktivnÄ›) "
-#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1460
+#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1494
 msgid ""
 "Edits a vector map, allows adding, deleting and modifying selected vector "
 "features."
@@ -9361,28 +9445,28 @@
 "Edituje vektorovou mapu, umožňuje přidání, mazání a modifikaci vektorových "
 "prvků."
-#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1461
+#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1495
 msgid "Convert object types"
 msgstr "Změnit typy vektorových prvků"
-#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1462
+#: ../gui/wxpython/menustrings.py:567 ../gui/wxpython/menustrings.py:1496
 #, fuzzy
 msgid "Changes type of vector features."
 msgstr "Vybrat vektorový prvek"
-#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1463
+#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1497
 msgid "Parallel lines"
 msgstr "Rovnoběžné linie"
-#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1464
+#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1498
 msgid "Creates parallel line to input vector lines."
 msgstr "Vytvoří rovnoběžné linie ke vstupní linii"
-#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1465
+#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1499
 msgid "Dissolve boundaries"
 msgstr "Rozloží společné hranice "
-#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1466
+#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1500
 msgid ""
 "Dissolves boundaries between adjacent areas sharing a common category number "
 "or attribute."
@@ -9390,42 +9474,42 @@
 "Rozloží hranice mezi sousedícími plochami, sdílejícími společné číslo "
 "kategorie nebo atribut."
-#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1467
+#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1501
 msgid "Create 3D vector over raster"
 msgstr "Vytvořit 3D vektor nad rastrem"
-#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1468
+#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1502
 #, fuzzy
 msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
 msgstr "Převede 2D vektorovou vrstvu na 3D za pomoci rastru výšek nad mořem."
-#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1469
+#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1503
 msgid "Extrude 3D vector map"
 msgstr "Vytvořit 3D vektorovou mapu"
-#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1470
+#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1504
 msgid ""
 "Extrudes flat vector features to 3D vector features with defined height. "
 "Optionally the height can be derived from sampling of elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1471
+#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1505
 msgid "Create labels"
 msgstr "Vytvořit popisky"
-#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1472
+#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1506
 msgid "Creates paint labels for a vector map from attached attributes."
 msgstr "Vytvoří barevné popisky pro vektorovou mapu z přiložených atributů."
-#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1473
+#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1507
 msgid "Create optimally placed labels"
 msgstr "Vytvořit optimálně umístěné popisky"
-#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1474
+#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1508
 msgid "Reposition vector map"
 msgstr "Tranformace vektorové vrstvy"
-#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1475
+#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1509
 #, fuzzy
 msgid ""
 "Performs an affine transformation (shift, scale and rotate) on vector map."
@@ -9433,12 +9517,12 @@
 "Vykoná afinní transformaci ( posunutí, změna měřítka a otočení, nebo GPC) "
 "vektorové mapy."
-#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1476
+#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1510
 #, fuzzy
 msgid "Rectify vector map"
 msgstr "Vybrat vektorovou mapu"
-#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1477
+#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1511
 #, fuzzy
 msgid ""
 "Rectifies a vector by computing a coordinate transformation for each object "
@@ -9447,130 +9531,130 @@
 "Rektifikuje obrazová data výpočtem transformace každého pixelu obrazu pomocí "
 "vlicovacích bodů (GCP)"
-#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1481
+#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1515
 msgid "Updates vector map metadata."
 msgstr "Aktualizuje matadata vektorové vrstvy."
-#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1482
+#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:1516
 #, fuzzy
 msgid "Topology maintenance"
 msgstr "Vytvoření a správa podpůrného souboru"
-#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1483
+#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1517
 msgid "Create or rebuild topology"
 msgstr "Vytvořit/znovu sestavit topologii"
-#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1484
+#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1518
 msgid ""
 "Creates topology for vector map. Optionaly also checks for topological "
 "errors."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1485
+#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1519
 msgid "Rebuild topology on all vector maps"
 msgstr "Přebudujetopologii všech vektorových map"
-#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1486
+#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1520
 msgid "Rebuilds topology on all vector maps in the current mapset."
 msgstr "Přebuduje topologii všech vektorových map v současném mapsetu."
-#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1487
+#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1521
 msgid "Build polylines"
 msgstr "Vytvořit mnohonásobné linie"
-#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1488
+#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1522
 msgid "Builds polylines from lines or boundaries."
 msgstr "Vytvořit mnohonásobné linie z linií a hranic."
-#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1489
+#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1523
 msgid "Split lines"
 msgstr "Rozdělit linie"
-#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1490
+#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1524
 msgid "Splits vector lines to shorter segments."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1491
+#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1525
 msgid "Split polylines"
-#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1492
+#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:1526
 msgid "Creates points/segments from input vector lines and positions."
 msgstr "Vytvoří body/segmenty ze vstupních vektorových linií a pozic."
-#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1493
+#: ../gui/wxpython/menustrings.py:598 ../gui/wxpython/menustrings.py:1527
 msgid "Clean vector map"
 msgstr "Vyčistit vektorovou mapu"
-#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1494
+#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1528
 msgid "Toolset for cleaning topology of vector map."
 msgstr "Sada nástrojů k čištění topologie vektorové mapy."
-#: ../gui/wxpython/menustrings.py:583 ../gui/wxpython/menustrings.py:1495
+#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1529
 msgid "Smooth or simplify"
 msgstr "Vyhladit, nebo zjednodušit"
-#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1496
+#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1530
 #, fuzzy
 msgid "Performs vector based generalization."
 msgstr "Databázové spojení"
-#: ../gui/wxpython/menustrings.py:585 ../gui/wxpython/menustrings.py:1497
+#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1531
 msgid "Add centroids"
 msgstr "Přidat centroidy"
-#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1498
+#: ../gui/wxpython/menustrings.py:603 ../gui/wxpython/menustrings.py:1532
 msgid "Adds missing centroids to closed boundaries."
 msgstr "K uzavřeným hranicím přidá chybějící centroidy."
-#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1501
+#: ../gui/wxpython/menustrings.py:606 ../gui/wxpython/menustrings.py:1535
 #, fuzzy
 msgid "Creates/modifies the color table associated with a vector map."
 msgstr "Vytvoří/upraví tabulku barev spojenou s rastrovou mapou."
-#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1503
+#: ../gui/wxpython/menustrings.py:608 ../gui/wxpython/menustrings.py:1537
 msgid "Interactive management of vector color tables."
 msgstr "Interaktivní správa vektorové tabulky barev"
-#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1505
+#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:1539
 #, fuzzy
 msgid "Exports the color table associated with a vector map."
 msgstr "Exportuje tabulku barev spojenou s rastrovou mapou."
-#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1506
+#: ../gui/wxpython/menustrings.py:611 ../gui/wxpython/menustrings.py:1540
 msgid "Query vector map"
 msgstr "Dotaz na vektorovou mapu"
-#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1507
+#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:1541
 msgid "Query with coordinate(s)"
 msgstr "Souřadnicový dotaz"
-#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1508
+#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1542
 #, fuzzy
 msgid "Queries a vector map at given locations."
 msgstr "Dotazovat vektorovou mapu v daných locations."
-#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:894
-#: ../gui/wxpython/menustrings.py:1509 ../gui/wxpython/menustrings.py:1806
+#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:911
+#: ../gui/wxpython/menustrings.py:1543 ../gui/wxpython/menustrings.py:1840
 msgid "Query vector attribute data"
 msgstr "Atributový dotaz"
-#: ../gui/wxpython/menustrings.py:598 ../gui/wxpython/menustrings.py:895
-#: ../gui/wxpython/menustrings.py:1510 ../gui/wxpython/menustrings.py:1807
+#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:912
+#: ../gui/wxpython/menustrings.py:1544 ../gui/wxpython/menustrings.py:1841
 msgid "Prints vector map attributes."
 msgstr "Vypsat vektorové atributy"
-#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1511
+#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1545
 #, fuzzy
 msgid "Feature selection"
 msgstr "Obrátit výběr"
-#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1512
+#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1546
 #, fuzzy
 msgid "Select by attributes"
 msgstr "Duplicitní atributy"
-#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1513
+#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1547
 #, fuzzy
 msgid ""
 "Selects vector features from an existing vector map and creates a new vector "
@@ -9579,53 +9663,53 @@
 "Vybrat objekty z existující vektorové mapy a vytvořit novou mapu obsahující "
 "jenom vybrané objekty."
-#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1514
+#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1548
 #, fuzzy
 msgid "Select by another map"
 msgstr "Vybrat rastrovou mapu:"
-#: ../gui/wxpython/menustrings.py:603 ../gui/wxpython/menustrings.py:1515
+#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1549
 msgid ""
 "Selects features from vector map (A) by features from other vector map (B)."
 msgstr ""
 "Vybere prvky z vektorové vrstvy (A)  podle prvků z druhé vektorové vrstvy (B)"
-#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1525
+#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1559
 msgid "Buffer vectors"
 msgstr "Buffer vektorů"
-#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:1526
+#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1560
 #, fuzzy
 msgid "Creates a buffer around vector features of given type."
 msgstr ""
 "Vytvoří buffer okolo prvků zadaného typu (plochy musí obsahovat centroid)"
-#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:1527
+#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1561
 msgid "Lidar analysis"
 msgstr "Analýza LIDAR dat"
-#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1528
+#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1562
 msgid "Identify and remove outliers"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:714
-#: ../gui/wxpython/menustrings.py:1529 ../gui/wxpython/menustrings.py:1626
+#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:731
+#: ../gui/wxpython/menustrings.py:1563 ../gui/wxpython/menustrings.py:1660
 msgid "Removes outliers from vector point data."
 msgstr "Vyjme outsidery z bodových vektorových dat"
-#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1530
+#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1564
 msgid "Detect edges"
 msgstr "Detekce hran"
-#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1531
+#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1565
 msgid "Detects the object's edges from a LIDAR data set."
 msgstr "Detekovat hrany objektů z LIDAR dat."
-#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1532
+#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1566
 msgid "Detect interiors"
 msgstr "Detekovat vnitřní plochy"
-#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:1533
+#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1567
 msgid ""
 "Building contour determination and Region Growing algorithm for determining "
 "the building inside"
@@ -9633,11 +9717,11 @@
 "Hledání linií a algoritmus růstu regionu (Region Growing) pro nalezení "
 "vnitřků budov"
-#: ../gui/wxpython/menustrings.py:622 ../gui/wxpython/menustrings.py:1534
+#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1568
 msgid "Correct and reclassify objects"
 msgstr "Spravit a reklasifikovat prvky"
-#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:1535
+#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1569
 msgid ""
 "Correction of the v.lidar.growing output. It is the last of the three "
 "algorithms for LIDAR filtering."
@@ -9645,33 +9729,33 @@
 "Výstup korekce v.lidar.growing. Jedná se o poslední ze tří algoritmů LIDAR "
 "filtrace"
-#: ../gui/wxpython/menustrings.py:624 ../gui/wxpython/menustrings.py:1536
+#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1570
 msgid "Linear referencing"
 msgstr "Lineární referencování pro vektorové vrstvy"
-#: ../gui/wxpython/menustrings.py:625 ../gui/wxpython/menustrings.py:1537
+#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1571
 msgid "Create LRS"
 msgstr "Vytvořit LRS"
-#: ../gui/wxpython/menustrings.py:626 ../gui/wxpython/menustrings.py:1538
+#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1572
 #, fuzzy
 msgid "Creates a linear reference system."
 msgstr "vytvořit lineární referenční systém"
-#: ../gui/wxpython/menustrings.py:627 ../gui/wxpython/menustrings.py:1539
+#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1573
 msgid "Create stationing"
 msgstr "vytvořit staničení"
-#: ../gui/wxpython/menustrings.py:628 ../gui/wxpython/menustrings.py:1540
+#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1574
 #, fuzzy
 msgid "Creates stationing from input lines, and linear reference system."
 msgstr "Vytváří staničení ze vstupních linií, a lineární referenční systém "
-#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1541
+#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1575
 msgid "Create points/segments"
 msgstr "Vytvořit body/segmenty"
-#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1542
+#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1576
 msgid ""
 "Creates points/segments from input lines, linear reference system and "
 "positions read from stdin or a file."
@@ -9679,11 +9763,11 @@
 "Vytvoří body/segmenty ze vstupních linií, lineární referenční systém a "
 "umístění jsou čteny ze standartního vstupu nebo souboru."
-#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1543
+#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1577
 msgid "Find line id and offset"
 msgstr "Nalézt ID linie a odchylku"
-#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1544
+#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1578
 msgid ""
 "Finds line id and real km+offset for given points in vector map using linear "
 "reference system."
@@ -9691,11 +9775,11 @@
 "Nalezne id linie a skutečnou délku + odchylku pro dané body ve vektorové "
 "mapě používající lineární referenční systém."
-#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1545
+#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1579
 msgid "Nearest features"
 msgstr "Nejbližší prvky"
-#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:1546
+#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1580
 msgid ""
 "Finds the nearest element in vector map 'to' for elements in vector map "
 "'from'."
@@ -9703,34 +9787,34 @@
 "Hledá nejbližší prvek ve vektorové vrstvě 'do_mapy' pro prvky ve vektorové "
 "vrstvÄ› 'z_mapy'"
-#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1547
+#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1581
 msgid "Network analysis"
 msgstr "Síťová analýza"
-#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1548
+#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1582
 #: ../gui/wxpython/mapdisp/toolbars.py:53
 #, fuzzy
 msgid "Vector network analysis tool"
-#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1549
+#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1583
 msgid "Tool for interactive vector network analysis."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1550
+#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1584
 #, fuzzy
 msgid "Network preparation"
-#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1551
+#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1585
 msgid "Performs network maintenance."
-#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1552
+#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1586
 msgid "Allocate subnets"
 msgstr "Přidělit podsítě"
-#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1553
+#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1587
 #, fuzzy
 msgid ""
 "Allocate subnets for nearest centers (direction from center). center node "
@@ -9740,11 +9824,11 @@
 "uzel musí být otevřen ( hodnota >=0). Hodnota středního bodu bude použita "
 "při výpočtu."
-#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1554
+#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1588
 msgid "Split net"
 msgstr "Rozdělit síť"
-#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1555
+#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1589
 #, fuzzy
 msgid ""
 "Splits net by cost isolines. Splits net to bands between cost isolines "
@@ -9755,19 +9839,19 @@
 "při výpočtu."
-#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1556
+#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:1590
 msgid "Shortest path"
 msgstr "Nejkratší cesta"
-#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1557
+#: ../gui/wxpython/menustrings.py:662 ../gui/wxpython/menustrings.py:1591
 msgid "Finds shortest path on vector network."
 msgstr "Nalézá nejkratší cestu ve vektorové síti."
-#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1558
+#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1592
 msgid "Shortest path for sets of features"
 msgstr "Nejkratší cesta pro skupinu prvků"
-#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1559
+#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1593
 msgid ""
 "Computes shortest distance via the network between the given sets of "
 "features. Finds the shortest paths from each 'from' point to the nearest "
@@ -9775,82 +9859,82 @@
 "attribute table."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1560
+#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1594
 msgid "Shortest path using timetables"
 msgstr "Nejkratší cesta pomocí časového rozvrhu"
-#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1561
+#: ../gui/wxpython/menustrings.py:666 ../gui/wxpython/menustrings.py:1595
 msgid "Finds shortest path using timetables."
 msgstr "Hledá nejkratší cestu pomocí časového rozvrhu."
-#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1562
+#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1596
 msgid "Shortest path for all pairs"
 msgstr "Nejkratší cesta pro všechny dvojice"
-#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1563
+#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1597
 msgid "Computes the shortest path between all pairs of nodes in the network."
 msgstr "Vypočítá nejkratší cestu mezi páry bodů v síti."
-#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1564
+#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1598
 msgid "Visibility network"
 msgstr "Viditelnost/linie viditelnosti"
-#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1565
+#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1599
 #, fuzzy
 msgid "Performs visibility graph construction."
 msgstr "Tvorba grafu viditelnosti."
-#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1566
+#: ../gui/wxpython/menustrings.py:671 ../gui/wxpython/menustrings.py:1600
 msgid "Bridges and articulation points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1567
+#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1601
 #, fuzzy
 msgid "Computes bridges and articulation points in the network."
 msgstr "Vypočítá silně a slabě připojené součásti v síti"
-#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1568
+#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1602
 msgid "Maximum flow"
 msgstr "Maximální tok"
-#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1569
+#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1603
 #, fuzzy
 msgid "Computes the maximum flow between two sets of nodes in the network."
-#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1570
+#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1604
 msgid "Vertex connectivity"
 msgstr "Spojení vrcholů"
-#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1571
+#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1605
 #, fuzzy
 msgid "Computes vertex connectivity between two sets of nodes in the network."
-#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1572
+#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1606
 msgid "Components"
 msgstr "Součásti"
-#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:1573
+#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1607
 msgid "Computes strongly and weakly connected components in the network."
-#: ../gui/wxpython/menustrings.py:662 ../gui/wxpython/menustrings.py:1574
+#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1608
 #, fuzzy
 msgid "Centrality"
 msgstr "Test normality"
-#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1575
+#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1609
 msgid ""
 "Computes degree, centrality, betweeness, closeness and eigenvector "
 "centrality measures in the network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1576
+#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1610
 msgid "Steiner tree"
 msgstr "Steinerův strom"
-#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1577
+#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1611
 #, fuzzy
 msgid ""
 "Creates Steiner tree for the network and given terminals. Note that 'Minimum "
@@ -9860,19 +9944,19 @@
 "'Minimální Steinerův strom' je NP-těžká úloha, v tomto module je použit "
 "heuristický algoritmus, výsledek nemusí být optimální"
-#: ../gui/wxpython/menustrings.py:666 ../gui/wxpython/menustrings.py:1578
+#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1612
 msgid "Minimum spanning tree"
 msgstr "Strom nejkratší vzdálenosti"
-#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1579
+#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1613
 msgid "Computes minimum spanning tree for the network."
 msgstr "Vypočítá nejkratší vzdálenosti pro síť"
-#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1580
+#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1614
 msgid "Traveling salesman analysis"
 msgstr "Problém obchodního cestujícího"
-#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1581
+#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1615
 #, fuzzy
 msgid ""
 "Creates a cycle connecting given nodes (Traveling salesman problem). Note "
@@ -9882,41 +9966,41 @@
 "TSP je NP-těžká úloha, v tomto modulu je použit heuristický algoritmus, "
 "vytvoření smyčky nemusí být optimální řešení"
-#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:671
-#: ../gui/wxpython/menustrings.py:1582 ../gui/wxpython/menustrings.py:1583
+#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:688
+#: ../gui/wxpython/menustrings.py:1616 ../gui/wxpython/menustrings.py:1617
 msgid "Overlay vector maps"
 msgstr "Překrýt vektorové mapy"
-#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1584
+#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1618
 msgid "Overlays two vector maps."
 msgstr "Překrytí dvou vektorových map."
-#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1585
+#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1619
 msgid "Patch vector maps"
 msgstr "Spojit vektorové mapy"
-#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1586
+#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1620
 #, fuzzy
 msgid "Creates a new vector map by combining other vector maps."
 msgstr ""
 "Vytvoří nový binární vektorovou mapu kombinací více vektorových vrstev."
-#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1587
+#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1621
 #, fuzzy
 msgid "Manage categories"
 msgstr "Upravit nebo vypsat kategorie"
-#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1588
+#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1622
 #, fuzzy
 msgid "Change or report categories"
-#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1589
+#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1623
 #, fuzzy
 msgid "Attaches, deletes or reports vector categories to map geometry."
 msgstr "Přilož, smaž nebo vypiš vektorové kategorie do mapové geometrie."
-#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1591
+#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1625
 msgid ""
 "Changes vector category values for an existing vector map according to "
 "results of SQL queries or a value in attribute table column."
@@ -9924,11 +10008,11 @@
 "Změnit hodnoty kategorií pro existující vektorovou vrstvu podle výsledků SQL "
 "dotazu nebo podle hodnot sloupce v tabulce."
-#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1593
+#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1627
 msgid "Update area attributes from raster"
 msgstr "Aktualizovat atributy plochy z rastru"
-#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1594
+#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1628
 #, fuzzy
 msgid ""
 "Calculates univariate statistics from a raster map based on vector polygon "
@@ -9937,79 +10021,79 @@
 "Spočítá jednorozměrnou statistiku z rastrové mapy zalžené na vektorových "
 "polygonech a uloží výsledek do nového stributového sloupce."
-#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1595
+#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1629
 #, fuzzy
 msgid "Update area attributes from vector"
-#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1596
+#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1630
 #, fuzzy
 msgid "Count points in areas, calculate statistics from point attributes."
-#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1597
+#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1631
 msgid "Update point attributes from areas"
 msgstr "Aktualizovat bodové atributy z ploch"
-#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1598
+#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1632
 msgid "Uploads vector values at positions of vector points to the table."
 msgstr ""
 "Uloží hodnoty rastrové mapy na pozicích bodů překryvné vektorové mapy do "
 "atributové tabulky."
-#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1599
+#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1633
 #, fuzzy
 msgid "Update database values from vector"
 msgstr "Nahraje data do databáze na základě vektorových prvků."
-#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1600
+#: ../gui/wxpython/menustrings.py:705 ../gui/wxpython/menustrings.py:1634
 #, fuzzy
 msgid "Populates attribute values from vector features."
-#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1601
+#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1635
 msgid "Sample raster maps at point locations"
 msgstr "příklad rastrových map v cílové location"
-#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1602
+#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1636
 msgid "Uploads raster values at positions of vector points to the table."
 msgstr ""
 "Uloží hodnoty rastru pod vektorovými body do jejich atributové tabulky."
-#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1603
+#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1637
 msgid "Sample raster neighborhood around points"
 msgstr "Vzorkovat okolí v rastrové vrstvě v okolí daného bodu"
-#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1604
+#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1638
 msgid "Samples a raster map at vector point locations."
 msgstr "Získává vzorky z rastrové mapy místech vektorových bodů"
-#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1605
+#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1639
 msgid "Generate area for current region"
 msgstr "Vytvořit plochu pokrývající aktuální region"
-#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1606
+#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1640
 #, fuzzy
 msgid "Creates a vector polygon from the current region extent."
 msgstr "Vytvořit novou vektorovou mapu pokrývající současný region"
-#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1607
+#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1641
 msgid "Generate areas from points"
 msgstr "Vytvořit plochy z bodových dat"
-#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1608
+#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1642
 msgid "Convex hull"
 msgstr "Konvexní obal"
-#: ../gui/wxpython/menustrings.py:697 ../gui/wxpython/menustrings.py:1609
+#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1643
 msgid "Produces a 2D/3D convex hull for a given vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1610
+#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1644
 msgid "Delaunay triangles"
 msgstr "Vytvořit Delaunayovu triangulační síť bodové vrstvy"
-#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1611
+#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1645
 msgid ""
 "Creates a Delaunay triangulation from an input vector map containing points "
 "or centroids."
@@ -10017,11 +10101,11 @@
 "Vytváří Delaunayovu triangulaci ze vstupní vektorové mapy obsahující body "
 "nebo centroidy."
-#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1612
+#: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1646
 msgid "Voronoi diagram/Thiessen polygons"
 msgstr "Vytvořit Voronoi diagram/Thiessenovy polygony bodové vrstvy"
-#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1613
+#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1647
 #, fuzzy
 msgid ""
 "Creates a Voronoi diagram in current region from an input vector map "
@@ -10030,101 +10114,101 @@
 "Vytvořit Voronoi diagram ze vstupní vektorové vrstvy obsahující body nebo "
 "centroidy."
-#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1614
+#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1648
 msgid "Generate grid"
 msgstr "Vytvořit mřížku"
-#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1615
+#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1649
 #, fuzzy
 msgid "Creates a vector map of a user-defined grid."
 msgstr "Vytvoří GRASS vektorovou mapu podle uživatelem definované mřížky"
-#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1616
+#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1650
 msgid "Generate points"
 msgstr "Vytvořit bodovou vrstvu"
-#: ../gui/wxpython/menustrings.py:705 ../gui/wxpython/menustrings.py:1617
+#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1651
 msgid "Generate from database"
 msgstr "Vytvořit z databáze"
-#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1618
+#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1652
 msgid ""
 "Creates new vector (points) map from database table containing coordinates."
 msgstr ""
 "Vytvoří novou vektorovou (bodovou) mapu na základě databázové takulky "
 "obsahující souřadnice."
-#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1619
+#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1653
 msgid "Generate points along lines"
 msgstr "Vytvořit body podél linií"
-#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1620
+#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1654
 #, fuzzy
 msgid "Creates points along input lines in new vector map with 2 layers."
 msgstr ""
 "Vytvoří body podél vstupních linií a uloží do nového souboru o dvou vrstvách."
-#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1621
+#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1655
 msgid "Generate random points"
 msgstr "Vytvořit náhodnou bodovou vrstvu"
-#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1622
+#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1656
 #, fuzzy
 msgid "Generates randomly 2D/3D vector points map."
 msgstr "Náhodně vytvořit 2D/3D bodovou vektorovou vrstvu."
-#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1623
+#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1657
 msgid "Perturb points"
 msgstr "Rozházet body"
-#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1624
+#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1658
 #, fuzzy
 msgid "Random location perturbations of vector points."
 msgstr "Náhodná odchylka location vektorových bodů"
-#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1625
+#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1659
 msgid "Remove outliers in point sets"
 msgstr "Odstranit body mimo sadu bodů"
-#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1627
+#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1661
 msgid "Test/training point sets"
 msgstr "Testovací/trénovací sada bodů"
-#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1628
+#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1662
 msgid "Randomly partition points into test/train sets."
 msgstr "Náhodně rozdělit body do testovacích množin."
-#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1630
+#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1664
 msgid "Basic vector metadata"
 msgstr "Základní metadata vektorové mapy"
-#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1631
+#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1665
 #, fuzzy
 msgid "Outputs basic information about a vector map."
 msgstr "Vypíše základní informace o uživatelem vybrané rastrové mapě."
-#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1632
+#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1666
 msgid "Classify attribute data"
 msgstr "Klasifikovat atributové data"
-#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1633
+#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1667
 msgid "Classifies attribute data, e.g. for thematic mapping"
 msgstr "Klasifikuje atributové data, například pro tématické mapy"
-#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1634
+#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1668
 msgid "Report topology by category"
 msgstr "Zpráva o topologii podle kategorií"
-#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1635
+#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1669
 #, fuzzy
 msgid "Reports geometry statistics for vector maps."
 msgstr "Vypíše údaje o geometrii vektorové mapy."
-#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1636
+#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1670
 msgid "Univariate attribute statistics for points"
 msgstr "Univariantní statistika vektorových bodů a jejich atributů"
-#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1637
+#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1671
 msgid ""
 "Calculates univariate statistics for attribute. Variance and standard "
 "deviation is calculated only for points if specified."
@@ -10132,87 +10216,87 @@
 "Spočítá základní statistiky pro atributy. Variance a standardní odchylka "
 "jsou počítány pouze pokud jsou zadány body."
-#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1638
+#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1672
 msgid "Univariate statistics for attribute columns"
 msgstr "Univariantní statistika atributových sloupců"
-#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1639
+#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1673
 msgid ""
 "Calculates univariate statistics on selected table column for a GRASS vector "
 "map."
 msgstr ""
 "Spočítá univariantní statistiku pro vybraný sloupec tabulky vektorové vrstvy."
-#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1640
+#: ../gui/wxpython/menustrings.py:745 ../gui/wxpython/menustrings.py:1674
 msgid "Quadrat indices"
 msgstr "Ukazatel zkusné plochy"
-#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1641
+#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1675
 msgid "Indices for quadrat counts of sites lists."
 msgstr "Indexy pro kvadratické počty pro seznam bodů"
-#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1642
+#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1676
 msgid "Test normality"
-#: ../gui/wxpython/menustrings.py:731 ../gui/wxpython/menustrings.py:1643
+#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1677
 #, fuzzy
 msgid "Tests for normality for vector points."
 msgstr "Test normality bodů"
-#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1644
+#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1678
 msgid "&Imagery"
 msgstr "&Obraz"
-#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1645
+#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1679
 msgid "Develop images and groups"
 msgstr "Vytvořit obrazový soubor a skupiny"
-#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1646
+#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1680
 msgid "Create/edit group"
 msgstr "Vytvořit/upravit skupinu"
-#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1647
+#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1681
 #, fuzzy
 msgid "Creates, edits, and lists groups of imagery files."
 msgstr "Vytváří, edituje a vypisuje skupiny a podskupiny obrazových dat."
-#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1648
+#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1682
 msgid "Target group"
 msgstr "Cílová obrazová skupina"
-#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1649
+#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1683
 msgid "Targets an imagery group to a GRASS location and mapset."
 msgstr "Určí cíl obrazové skupiny jako location a mapset GRASSu."
-#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1650
+#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1684
 msgid "Mosaic images"
 msgstr "Vytvořit mozaiku více jak 4 sousední obrazové soubory"
-#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1651
+#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1685
 #, fuzzy
 msgid "Mosaics several images and extends colormap."
 msgstr ""
 "Vytvoří mozaiku ze 4 a více snímků, roztáhne barevnou paletu a vytvoří mapu "
 "*.mosaic"
-#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1652
+#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1686
 msgid "Manage image colors"
 msgstr "Správa barevné škály obrazových dat"
-#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1653
+#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1687
 msgid "Color balance for RGB"
 msgstr "Vyvážení barev pro RGB"
-#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1654
+#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1688
 msgid "Performs auto-balancing of colors for LANDSAT images."
 msgstr "Provádí automatické vyvážení barev pro snímky z družice LANDSAT."
-#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1655
+#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1689
 msgid "HIS to RGB"
 msgstr "Transformace HIS -> RGB"
-#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1656
+#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1690
 msgid ""
 "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
 "RGB (Red-Green-Blue) color space."
@@ -10220,7 +10304,7 @@
 "Převede rastrové mapy z HIS (odstín-intenzita-sytost) do RGB (červená-zelená-"
 "modrá)"
-#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1658
+#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1692
 msgid ""
 "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
 "Intensity-Saturation) color space."
@@ -10228,11 +10312,11 @@
 "Převede rastrové mapy z RGB (červená-zelená-modrá) do HIS (odstín-intenzita-"
 "sytost)"
-#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1659
+#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1693
 msgid "Rectify image or raster"
 msgstr "Rektifikovat obraz nebo rastrovou mapu"
-#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1660
+#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1694
 msgid ""
 "Rectifies an image by computing a coordinate transformation for each pixel "
 "in the image based on the control points."
@@ -10240,32 +10324,32 @@
-#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1661
+#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1695
 #: ../gui/wxpython/lmgr/layertree.py:574
 msgid "Histogram"
 msgstr "Histogram"
-#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1662
+#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1696
 msgid "Generate histogram of image"
 msgstr "Vytvořit histogram obrazu"
-#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1663
+#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1697
 msgid "Spectral response"
 msgstr "Spektrální odezva"
-#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1664
+#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1698
 msgid ""
 "Displays spectral response at user specified locations in group or images."
 msgstr ""
 "Zobrazí spektrální odrazivost na uživatelem zadaných místech ve skupině "
 "obrazů."
-#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1665
+#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1699
 #, fuzzy
 msgid "Pan sharpening"
 msgstr "Broveyovo ostření obrazu"
-#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1666
+#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1700
 #, fuzzy
 msgid ""
 "Image fusion algorithms to sharpen multispectral with high-res panchromatic "
@@ -10274,15 +10358,15 @@
 "Broveyova transformace pro sloučení multispektrálních kanálů s "
 "panchromatickými kanály vyššího rozlišení"
-#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1667
+#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1701
 msgid "Classify image"
 msgstr "Klasifikace obrazových dat"
-#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1668
+#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1702
 msgid "Clustering input for unsupervised classification"
 msgstr "Metoda shlukování pro neřízenou klasifikaci"
-#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1669
+#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1703
 #, fuzzy
 msgid ""
 "Generates spectral signatures for land cover types in an image using a "
@@ -10292,19 +10376,19 @@
 "Výsledný soubor spektrálních signatur je používán jako vstup pro modul i."
 "maxlik,který na jeho základě provede neřízenou klasifikaci snímku."
-#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1670
+#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1704
 msgid "Input for supervised MLC"
 msgstr "Vstup pro řízenou klasifikaci MLC"
-#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1671
+#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1705
 msgid "Generates statistics for i.maxlik from raster map."
 msgstr "Vytvoří statistiku pro výstupní rastrovou mapu z i.maxlik"
-#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1672
+#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1706
 msgid "Maximum likelihood classification (MLC)"
 msgstr "Klasifikátor MLC (Maximum likelihood classification)"
-#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1673
+#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1707
 #, fuzzy
 msgid ""
 "Classifies the cell spectral reflectances in imagery data. Classification is "
@@ -10315,13 +10399,13 @@
 "založená na informaci o spektrálních příznacích vytvořených pomocí i."
 "cluster, i.class nebo i.gensig."
-#: ../gui/wxpython/menustrings.py:762 ../gui/wxpython/menustrings.py:1674
-#: ../gui/wxpython/menustrings.py:1930
+#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1708
+#: ../gui/wxpython/menustrings.py:1964
 msgid "Interactive input for supervised classification"
 msgstr "Interaktivní vstup pro řízenou klasifikaci"
-#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1675
-#: ../gui/wxpython/menustrings.py:1931
+#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1709
+#: ../gui/wxpython/menustrings.py:1965
 #, fuzzy
 msgid ""
 "Generates spectral signatures by allowing the user to outline training areas."
@@ -10329,19 +10413,19 @@
 "Vytvoří spektrální signatury pro obrazová data povolením uživateli načrtnout "
 "oblasti zájmu."
-#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1676
+#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1710
 msgid "Input for supervised SMAP"
 msgstr "Vstup pro řízenou klasifikaci SMAP"
-#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1677
+#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1711
 msgid "Generates statistics for i.smap from raster map."
 msgstr "Vytvoří statistiku pro výstupní rastrovou mapu z i.smap"
-#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1678
+#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1712
 msgid "Sequential maximum a posteriori classification (SMAP)"
 msgstr "Klasifikátor SMAP (Sequential maximum a posterior)"
-#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1679
+#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1713
 msgid ""
 "Performs contextual image classification using sequential maximum a "
 "posteriori (SMAP) estimation."
@@ -10349,278 +10433,278 @@
 "Provede kontextuální klasifikaci obrazu s využitím metody SMAP (sequential "
 "maximum a posterior)."
-#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1680
+#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1714
 #, fuzzy
 msgid "Object segmentation"
 msgstr "Otočení:"
-#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1681
+#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1715
 msgid "Identifies segments (objects) from imagery data."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1682
+#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1716
 msgid "Filter image"
 msgstr "Filrace obrazu"
-#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1683
+#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1717
 msgid "Edge detection"
-#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1684
+#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1718
 msgid "Zero-crossing \"edge detection\" raster function for image processing."
 msgstr "Žádné-křížení \"detekce hran\" rastrová funkce zpracování obrazu."
-#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1685
+#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1719
 msgid "Matrix/convolving filter"
 msgstr "Uživatelská definice maticového filtru"
-#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1686
+#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1720
 msgid "Performs raster map matrix filter."
 msgstr "Maticový filtr na rastrové mapě."
-#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1687
+#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1721
 msgid "Transform image"
 msgstr "Transformace obrazu"
-#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1688
+#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1722
 msgid "Canonical correlation"
 msgstr "Kanonické komponenty"
-#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1689
+#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1723
 #, fuzzy
 msgid "Canonical components analysis (CCA) program for image processing."
 msgstr ""
 "Program pro zpracování obrazových dat - kónickou transformaci komponent "
 "(cca)."
-#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1690
+#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1724
 msgid "Principal components"
 msgstr "Hlavní komponenty"
-#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1691
+#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1725
 #, fuzzy
 msgid "Principal components analysis (PCA) for image processing."
 msgstr "Program pro analýzu hlavních komponent (pca) snímků."
-#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1692
+#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1726
 msgid "Fast Fourier"
 msgstr "Fourierova transformace"
-#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1693
+#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1727
 msgid "Fast Fourier Transform (FFT) for image processing."
 msgstr "Rychlá Fourierova transformace (FFT) pro zpracování obrazových dat."
-#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1694
+#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1728
 msgid "Inverse Fast Fourier"
 msgstr "Inverzní Fourierova transformace"
-#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1695
+#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1729
 msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
 msgstr ""
 "Rychlá inverzní Fourierova transformace (IFFT) pro zpracování obrazových dat."
-#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1696
+#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1730
 #, fuzzy
 msgid "Satellite images tools"
 msgstr "Nastavit velikost obrazu"
-#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1697
+#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1731
 msgid "Aster DN to radiance/reflectance"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1698
+#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1732
 msgid ""
 "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
 "from ASTER DN."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1699
+#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1733
 msgid "Landsat DN to radiance/reflectance"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1700
+#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1734
 msgid ""
 "Calculates top-of-atmosphere radiance or reflectance and temperature for "
 "Landsat MSS/TM/ETM+/OLI"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1701
+#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1735
 msgid "Landsat cloud cover assessment"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1702
+#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1736
 msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1703
+#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1737
 msgid "Modis quality control"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1704
+#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1738
 #, fuzzy
 msgid "Extracts quality control parameters from Modis QC layers."
 msgstr "Definujte parametry pro "
-#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1705
+#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1739
 msgid "Atmospheric correction"
 msgstr "Atmosférické korekce"
-#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1706
+#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1740
 #, fuzzy
 msgid ""
 "Performs atmospheric correction using the 6S algorithm. 6S - Second "
 "Simulation of Satellite Signal in the Solar Spectrum."
 msgstr "Proveď atmosferické korekce pomocí 6S algoritmu."
-#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1707
+#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1741
 msgid "Satellite images products"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1708
+#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1742
 #, fuzzy
 msgid "Vegetation indices"
 msgstr "Hranice regionu"
-#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1709
+#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1743
 msgid ""
 "Calculates different types of vegetation indices. Uses red and nir bands "
 "mostly, and some indices require additional bands."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1710
+#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1744
 msgid "Tasseled cap vegetation index"
 msgstr "Vegetační index (tassled cap)"
-#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1711
+#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1745
 #, fuzzy
 msgid ""
 "Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
 msgstr "Transformace Cap (Kauth Thomas) pro data LANDSAT-TM"
-#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1712
+#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1746
 msgid "Albedo"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1713
+#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1747
 msgid "Computes broad band albedo from surface reflectance."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1714
+#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1748
 #, fuzzy
 msgid "Emissivity"
 msgstr "Emise"
-#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1715
+#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1749
 msgid "Computes emissivity from NDVI, generic method for sparse land."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1716
+#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1750
 msgid "Biomass growth"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1717
+#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1751
 msgid "Computes biomass growth, precursor of crop yield calculation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1718
+#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1752
 msgid "Evapotranspiration calculation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1719
+#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1753
 msgid "Instantaneaous Net Radiation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1720
+#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:1754
 msgid "Net radiation approximation (Bastiaanssen, 1995)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1721
+#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1755
 msgid "Soil heat flux"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1722
+#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1756
 msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1723
+#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1757
 msgid "Sensible heat flux"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1724
+#: ../gui/wxpython/menustrings.py:829 ../gui/wxpython/menustrings.py:1758
 msgid "Computes sensible heat flux iteration SEBAL 01."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1725
+#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1759
 msgid "Evaporative fraction"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1726
+#: ../gui/wxpython/menustrings.py:831 ../gui/wxpython/menustrings.py:1760
 msgid ""
 "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
 "moisture (Makin, Molden and Bastiaanssen, 2001)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1727
+#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1761
 msgid "Actual Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1728
+#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:1762
 msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1729
+#: ../gui/wxpython/menustrings.py:834 ../gui/wxpython/menustrings.py:1763
 msgid "Temporal integration of ETa"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1730
+#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1764
 msgid ""
 "Computes temporal integration of satellite ET actual (ETa) following the "
 "daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1731
+#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1765
 msgid "Hargreaves methods Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1732
+#: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1766
 msgid ""
 "Computes evapotranspiration calculation modified or original Hargreaves "
 "formulation, 2001."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1733
+#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:1767
 msgid "Penman-Monteith Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1734
+#: ../gui/wxpython/menustrings.py:839 ../gui/wxpython/menustrings.py:1768
 msgid ""
 "Computes potential evapotranspiration calculation with hourly Penman-"
 "Monteith."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1735
+#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1769
 msgid "Priestley-Taylor Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1736
+#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1770
 msgid ""
 "Computes evapotranspiration calculation Prestley and Taylor formulation, "
 "1972."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1738
+#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1772
 msgid "Bit pattern comparison "
 msgstr "Korelace (bit pattern comparsion) pro ID pixelů s nízkou kvalitou"
-#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1739
+#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1773
 msgid "Compares bit patterns with a raster map."
 msgstr "Porovnává bitové vzory s rastrovou mapou."
-#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1740
+#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1774
 msgid "Kappa analysis"
 msgstr "Kappa analýza "
-#: ../gui/wxpython/menustrings.py:829 ../gui/wxpython/menustrings.py:1741
+#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1775
 #, fuzzy
 msgid ""
 "Calculates error matrix and kappa parameter for accuracy assessment of "
@@ -10628,90 +10712,90 @@
 msgstr ""
 "Spočítá chybovou matici a parametr kappa pro evaluaci výsledků klasifikace."
-#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1742
+#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1776
 msgid "OIF for LandSat TM"
 msgstr "Faktor optimálního indexu pro LandSat TM"
-#: ../gui/wxpython/menustrings.py:831 ../gui/wxpython/menustrings.py:1743
+#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1777
 #, fuzzy
 msgid "Calculates Optimum-Index-Factor table for spectral bands"
 msgstr ""
 "Spočítá tabulku optimálního faktoru indexu pro kanály 1-5 a 7 družice "
 "LANDSAT TM"
-#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1744
+#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1778
 msgid "V&olumes"
 msgstr "&3D rastr"
-#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:1745
+#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1779
 msgid "Develop volumes"
 msgstr "Vytvořit 3D rastrové mapy"
-#: ../gui/wxpython/menustrings.py:834 ../gui/wxpython/menustrings.py:1746
+#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1780
 msgid "Manage 3D NULL values"
 msgstr "Upravit 3D NULL hodnoty"
-#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1747
+#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1781
 msgid "Explicitly create the 3D NULL-value bitmap file."
 msgstr "Vytvořit výlučně soubor s bitmapou 3D NULL-hodnota"
-#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1748
+#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1782
 msgid "Manage timestamp"
 msgstr "Správa časového razítka"
-#: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1749
+#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1783
 msgid "Print/add/remove a timestamp for a 3D raster map"
 msgstr "Vytiskni/přidej/smaž časové razítko pro 3D rastrovou mapu"
-#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1753
+#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1787
 #, fuzzy
 msgid "3D color tables"
 msgstr "Tabulka barev"
-#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1754
+#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1788
 #, fuzzy
 msgid "Creates/modifies the color table associated with a 3D raster map."
-#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1755
+#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1789
 #, fuzzy
 msgid "Export 3D color table"
 msgstr "Exportovat barevnou tabulku"
-#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1756
+#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1790
 #, fuzzy
 msgid "Exports the color table associated with a 3D raster map."
-#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1757
+#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1791
 msgid "3D Mask"
 msgstr "3D Maska"
-#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1758
+#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1792
 msgid "Establishes the current working 3D raster mask."
 msgstr "Vytvoří aktuální pracovní 3D rastrovou masku."
-#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1759
+#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1793
 msgid "Volume calculator"
 msgstr "3D mapový kalkulátor"
-#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1760
+#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1794
 #, fuzzy
 msgid "3D raster map calculator."
 msgstr "3D rastrový kalkulátor"
-#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1761
+#: ../gui/wxpython/menustrings.py:866 ../gui/wxpython/menustrings.py:1795
 msgid "Cross section"
 msgstr "Průřez"
-#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1762
+#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1796
 #, fuzzy
 msgid ""
 "Creates cross section 2D raster map from 3D raster map based on 2D elevation "
 "map"
 msgstr "Vytvoří průniky 2D mapy z g3d rastru objemů na základ 2D mapy elevace"
-#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1764
+#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1798
 #, fuzzy
 msgid ""
 "Numerical calculation program for transient, confined groundwater flow in "
@@ -10720,11 +10804,11 @@
 "Numerický výpočetní program pro přechodné, omezené a neohraničenéproudění "
 "podzemních vod ve třech rozměrech."
-#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1765
+#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1799
 msgid "Interpolate volume from points"
 msgstr "Interpolovat 3D rastrovou vrstvu z vektorových bodů "
-#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1766
+#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1800
 msgid ""
 "Interpolates point data to a 3D raster map using regularized spline with "
 "tension (RST) algorithm."
@@ -10732,146 +10816,146 @@
 "Interpoluje bodová data do G3D 3D rastrové grid vrstvy za použití "
 "regularized spline with tension (RST)"
-#: ../gui/wxpython/menustrings.py:855 ../gui/wxpython/menustrings.py:1767
+#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1801
 #, fuzzy
 msgid "Reports and Statistics"
 msgstr "Zprávy,výpisy a statistiky"
-#: ../gui/wxpython/menustrings.py:856 ../gui/wxpython/menustrings.py:1768
+#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:1802
 msgid "Basic volume metadata"
 msgstr "Základní metadata 3D rastrové vrstvy"
-#: ../gui/wxpython/menustrings.py:857 ../gui/wxpython/menustrings.py:1769
+#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1803
 msgid "Outputs basic information about a user-specified 3D raster map layer."
 msgstr "Vypíše základní informace o uživatelem vybrané 3D rastrové vrstvě."
-#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1770
+#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1804
 msgid "Voxel statistics"
 msgstr "Základní statistiky 3D pixelu (voxel)"
-#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1771
+#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1805
 #, fuzzy
 msgid "Generates volume statistics for 3D raster maps."
 msgstr "Vytvoří objemové statistiky pro 3D rastrové vrstvy."
-#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1772
+#: ../gui/wxpython/menustrings.py:877 ../gui/wxpython/menustrings.py:1806
 msgid "Univariate statistics for volumes"
 msgstr "Univariantní statistika 3D rastrové vrstvyy"
-#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1773
+#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1807
 msgid ""
 "Calculates univariate statistics from the non-null 3d cells of a raster3d "
 "map."
 msgstr ""
 "Spočítá univariantní statistiku z ne-nullových 3D buněk 3D rastrové vrstvy."
-#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1774
+#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1808
 msgid "&Database"
 msgstr "&Databáze"
-#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1775
+#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1809
 msgid "Database information"
 msgstr "Informace o databázi"
-#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1776
+#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1810
 #, fuzzy
 msgid "List databases"
 msgstr "Seznam tabulek"
-#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1777
+#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:1811
 #, fuzzy
 msgid "Lists all databases for a given driver and location."
 msgstr "Vypíše všechny tabulky pro danou databázi."
-#: ../gui/wxpython/menustrings.py:866 ../gui/wxpython/menustrings.py:1778
+#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1812
 msgid "List drivers"
 msgstr "Seznam ovladačů"
-#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1779
+#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1813
 #, fuzzy
 msgid "Lists all database drivers."
 msgstr "Vypiš všechny databázové ovladače."
-#: ../gui/wxpython/menustrings.py:868 ../gui/wxpython/menustrings.py:1780
+#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1814
 msgid "List tables"
-#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1781
+#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1815
 msgid "Lists all tables for a given database."
-#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1782
+#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1816
 msgid "Describe table"
 msgstr "Popsat tabulku"
-#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1783
+#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1817
 msgid "Describes a table in detail."
 msgstr "Popiš tabulku (detailně)."
-#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1784
+#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1818
 msgid "List columns"
 msgstr "Seznam sloupců"
-#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:1785
+#: ../gui/wxpython/menustrings.py:890 ../gui/wxpython/menustrings.py:1819
 msgid "List all columns for a given table."
 msgstr "vypíše všechny sloupce pro zadanou tabulku."
-#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1786
+#: ../gui/wxpython/menustrings.py:891 ../gui/wxpython/menustrings.py:1820
 msgid "Manage databases"
 msgstr "Správa tabulek"
-#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1787
+#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1821
 msgid "Connect"
 msgstr "Spojení "
-#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1788
+#: ../gui/wxpython/menustrings.py:893 ../gui/wxpython/menustrings.py:1822
 #, fuzzy
 msgid "Prints/sets general DB connection for current mapset."
 msgstr ""
 "Vytisknout/nastavit obecné DB připojení aktuálního mapsetu a ukončit se."
-#: ../gui/wxpython/menustrings.py:877 ../gui/wxpython/menustrings.py:1789
+#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1823
 msgid "Login"
 msgstr "Přihlášení"
-#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1790
+#: ../gui/wxpython/menustrings.py:895 ../gui/wxpython/menustrings.py:1824
 #, fuzzy
 msgid "Sets user/password for DB driver/database."
 msgstr "Nastavit uživatele/heslo pro ovladač/databázi"
-#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1791
+#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1825
 #, fuzzy
 msgid "Create database"
 msgstr "Vytvořit tabulku"
-#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1792
+#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1826
 #, fuzzy
 msgid "Creates an empty database."
-#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1793
+#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1827
 #, fuzzy
 msgid "Drop database"
 msgstr "Databáze"
-#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:1794
+#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1828
 #, fuzzy
 msgid "Removes an existing database."
-#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1795
+#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1829
 msgid "Drop table"
 msgstr "Smazat tabulku"
-#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1796
+#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1830
 msgid "Drops an attribute table."
 msgstr "Vyjmout atributovou tabulku."
-#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1797
+#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1831
 msgid "Copy table"
 msgstr "Kopírovat tabulku"
-#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1798
+#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1832
 msgid ""
 "Copy a table. Either 'from_table' (optionally with 'where') can be used or "
 "'select' option, but not 'from_table' and 'select' at the same time."
@@ -10879,80 +10963,80 @@
 "Kopíruj tabulku. Použita může být buď volba 'from_table' (volitelně s "
 "'where') nebo volba 'select', ale nikoliv 'from_table' a 'select' současně."
-#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:907
-#: ../gui/wxpython/menustrings.py:1799 ../gui/wxpython/menustrings.py:1819
+#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:924
+#: ../gui/wxpython/menustrings.py:1833 ../gui/wxpython/menustrings.py:1853
 msgid "Drop column"
 msgstr "Odstranit sloupec"
-#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1800
+#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1834
 #, fuzzy
 msgid "Drops a column from selected attribute table."
-#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1801
+#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1835
 msgid "Test"
 msgstr "Test"
-#: ../gui/wxpython/menustrings.py:890 ../gui/wxpython/menustrings.py:1802
+#: ../gui/wxpython/menustrings.py:907 ../gui/wxpython/menustrings.py:1836
 msgid "Test database driver, database must exist and set by db.connect."
 msgstr ""
 "Otestuj ovladač databáze, databáze musí existovat a nastavena pomocí db."
 "connect"
-#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1804
+#: ../gui/wxpython/menustrings.py:909 ../gui/wxpython/menustrings.py:1838
 msgid "Query any table"
 msgstr "Dotazovat jakoukoliv tabulku"
-#: ../gui/wxpython/menustrings.py:893 ../gui/wxpython/menustrings.py:1805
+#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1839
 #, fuzzy
 msgid "Selects data from attribute table. Performs SQL query statement(s)."
 msgstr "Vyber data z tabulky."
-#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1808
+#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1842
 msgid "SQL statement"
 msgstr "SQL příkaz"
-#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1809
+#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1843
 msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1810
+#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1844
 msgid "Vector database connections"
 msgstr "Databázové spojení"
-#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1811
+#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:1845
 msgid "New table"
-#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1812
+#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1846
 msgid ""
 "Creates and connects a new attribute table to a given layer of an existing "
 "vector map."
 msgstr ""
 "Vytvoří a připojí novou atributovou tabulku k dané vrstvě vektorové mapy."
-#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1813
+#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1847
 msgid "Remove table"
 msgstr "Odstranit tabulku"
-#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1814
+#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1848
 msgid "Removes existing attribute table of a vector map."
 msgstr "Odstraní existující atributovou tabulu z vektorové mapy."
-#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1815
+#: ../gui/wxpython/menustrings.py:920 ../gui/wxpython/menustrings.py:1849
 msgid "Join table"
 msgstr "Spojit tabulky"
-#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1816
+#: ../gui/wxpython/menustrings.py:921 ../gui/wxpython/menustrings.py:1850
 #, fuzzy
 msgid "Joins a database table to a vector map table."
 msgstr "Umožní připojení tabulky k vektorové mapě."
-#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1817
+#: ../gui/wxpython/menustrings.py:922 ../gui/wxpython/menustrings.py:1851
 msgid "Add columns"
 msgstr "Přidat nový sloupec"
-#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1818
+#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1852
 msgid ""
 "Adds one or more columns to the attribute table connected to a given vector "
 "map."
@@ -10960,407 +11044,407 @@
 "Přidává jeden nebo více sloupečků k atributové tabulce připojené k zadané "
 "vektorové mapě."
-#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:1820
+#: ../gui/wxpython/menustrings.py:925 ../gui/wxpython/menustrings.py:1854
 msgid ""
 "Drops a column from the attribute table connected to a given vector map."
 msgstr "Odstraní soupec z atributové tabulky připojené k dané vektorové mapě."
-#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1822
+#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1856
 msgid ""
 "Renames a column in the attribute table connected to a given vector map."
 msgstr ""
 "Přejmenuje sloupec v atributové tabulce připojené k zadané vektorové mapě."
-#: ../gui/wxpython/menustrings.py:911 ../gui/wxpython/menustrings.py:1823
+#: ../gui/wxpython/menustrings.py:928 ../gui/wxpython/menustrings.py:1857
 msgid "Change values"
 msgstr "Změnit atributy"
-#: ../gui/wxpython/menustrings.py:912 ../gui/wxpython/menustrings.py:1824
+#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1858
 #, fuzzy
 msgid "Updates a column in the attribute table connected to a vector map."
 msgstr ""
 "Umožní přiřadit novou hodnotu sloupci v atributové tabulce připojené k "
 "zadané mapě."
-#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1825
+#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1859
 msgid "Drop row"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1826
+#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1860
 #, fuzzy
 msgid "Removes a vector feature from a vector map through attribute selection."
 msgstr ""
 "Nastavit pravidla barev vektorových prvků použitím číselného atributového "
 "sloupce."
-#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1827
+#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1861
 msgid "Reconnect vectors to database"
 msgstr "Znovu navázat spojení vetoru s databází"
-#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:1828
+#: ../gui/wxpython/menustrings.py:933 ../gui/wxpython/menustrings.py:1862
 #, fuzzy
 msgid ""
 "Reconnects attribute tables for all vector maps from the current mapset to a "
 "new database."
 msgstr "Přebuduje topologii všech vektorových map v současném mapsetu."
-#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1829
+#: ../gui/wxpython/menustrings.py:934 ../gui/wxpython/menustrings.py:1863
 msgid "Set vector map - database connection"
-#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1830
+#: ../gui/wxpython/menustrings.py:935 ../gui/wxpython/menustrings.py:1864
 msgid "Prints/sets DB connection for a vector map to attribute table."
 msgstr ""
 "Vytiskne/nastaví připojení databáze pro vektorovou mapu k atributové tabulce"
-#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1831
+#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1865
 #, fuzzy
 msgid "Temporal"
 msgstr "Mód kategorie"
-#: ../gui/wxpython/menustrings.py:920 ../gui/wxpython/menustrings.py:1832
+#: ../gui/wxpython/menustrings.py:937 ../gui/wxpython/menustrings.py:1866
 #, fuzzy
 msgid "Manage datasets"
-#: ../gui/wxpython/menustrings.py:922 ../gui/wxpython/menustrings.py:1834
+#: ../gui/wxpython/menustrings.py:939 ../gui/wxpython/menustrings.py:1868
 #, fuzzy
 msgid "Creates a space time dataset."
-#: ../gui/wxpython/menustrings.py:924 ../gui/wxpython/menustrings.py:1836
+#: ../gui/wxpython/menustrings.py:941 ../gui/wxpython/menustrings.py:1870
 #, fuzzy
 msgid "Renames a space time dataset"
-#: ../gui/wxpython/menustrings.py:926 ../gui/wxpython/menustrings.py:1838
+#: ../gui/wxpython/menustrings.py:943 ../gui/wxpython/menustrings.py:1872
 #, fuzzy
 msgid "Removes space time datasets from temporal database."
-#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1839
+#: ../gui/wxpython/menustrings.py:944 ../gui/wxpython/menustrings.py:1873
 #, fuzzy
 msgid "Update metadata"
 msgstr "Aktualizuje matadata vektorové vrstvy."
-#: ../gui/wxpython/menustrings.py:928 ../gui/wxpython/menustrings.py:1840
+#: ../gui/wxpython/menustrings.py:945 ../gui/wxpython/menustrings.py:1874
 msgid "Modifies the metadata of a space time dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1841
+#: ../gui/wxpython/menustrings.py:946 ../gui/wxpython/menustrings.py:1875
 msgid "Merge"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1842
+#: ../gui/wxpython/menustrings.py:947 ../gui/wxpython/menustrings.py:1876
 msgid "Merge several space time datasets into a single one"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1843
+#: ../gui/wxpython/menustrings.py:948 ../gui/wxpython/menustrings.py:1877
 #, fuzzy
 msgid "Temporally shift"
-#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1844
+#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1878
 msgid "Temporally shift the maps of a space time dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:933 ../gui/wxpython/menustrings.py:1845
+#: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1879
 #, fuzzy
 msgid "Snap maps of dataset"
 msgstr "Import rastrových dat"
-#: ../gui/wxpython/menustrings.py:934 ../gui/wxpython/menustrings.py:1846
+#: ../gui/wxpython/menustrings.py:951 ../gui/wxpython/menustrings.py:1880
 msgid "Temporally snap the maps of a space time dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1848
+#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1882
 msgid "List space time datasets and maps registered in the temporal database."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:937 ../gui/wxpython/menustrings.py:1849
+#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1883
 #, fuzzy
 msgid "Manage maps in datasets"
-#: ../gui/wxpython/menustrings.py:938 ../gui/wxpython/menustrings.py:1850
+#: ../gui/wxpython/menustrings.py:955 ../gui/wxpython/menustrings.py:1884
 #, fuzzy
 msgid "Register maps in datasets"
 msgstr "Nastavení rastru"
-#: ../gui/wxpython/menustrings.py:939 ../gui/wxpython/menustrings.py:1851
+#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1885
 msgid "Registers raster, vector and raster3d maps in a space time datasets."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1852
+#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1886
 #, fuzzy
 msgid "Unregister maps from datasets"
-#: ../gui/wxpython/menustrings.py:941 ../gui/wxpython/menustrings.py:1853
+#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1887
 msgid ""
 "Unregisters raster, vector and raster3d maps from the temporal database or a "
 "specific space time dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:942 ../gui/wxpython/menustrings.py:1854
+#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1888
 #, fuzzy
 msgid "List raster dataset maps"
 msgstr "Připojit rastrová data"
-#: ../gui/wxpython/menustrings.py:943 ../gui/wxpython/menustrings.py:1855
+#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1889
 #, fuzzy
 msgid "Lists registered maps of a space time raster dataset."
-#: ../gui/wxpython/menustrings.py:944 ../gui/wxpython/menustrings.py:1856
+#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1890
 #, fuzzy
 msgid "List vector dataset maps"
 msgstr "Připojit vektorová data"
-#: ../gui/wxpython/menustrings.py:945 ../gui/wxpython/menustrings.py:1857
+#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1891
 #, fuzzy
 msgid "Lists registered maps of a space time vector dataset."
 msgstr "Import vektorových dat"
-#: ../gui/wxpython/menustrings.py:946 ../gui/wxpython/menustrings.py:1858
+#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1892
 #, fuzzy
 msgid "List raster3D dataset maps"
-#: ../gui/wxpython/menustrings.py:947 ../gui/wxpython/menustrings.py:1859
+#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1893
 #, fuzzy
 msgid "Lists registered maps of a space time raster3d dataset."
-#: ../gui/wxpython/menustrings.py:948 ../gui/wxpython/menustrings.py:1860
+#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1894
 #, fuzzy
 msgid "Import"
 msgstr "&Import"
-#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1861
+#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1895
 #, fuzzy
 msgid "Import raster dataset"
-#: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1862
+#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1896
 #, fuzzy
 msgid "Imports space time raster dataset."
-#: ../gui/wxpython/menustrings.py:951 ../gui/wxpython/menustrings.py:1863
+#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1897
 #, fuzzy
 msgid "Import vector dataset"
-#: ../gui/wxpython/menustrings.py:952 ../gui/wxpython/menustrings.py:1864
+#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1898
 #, fuzzy
 msgid "Import a space time vector dataset archive file"
-#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1865
+#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1899
 #: ../gui/wxpython/animation/dialogs.py:767
 #: ../gui/wxpython/lmgr/layertree.py:557
 #, fuzzy
 msgid "Export"
 msgstr "MPEG-1 export"
-#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1866
+#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1900
 #, fuzzy
 msgid "Export raster dataset"
-#: ../gui/wxpython/menustrings.py:955 ../gui/wxpython/menustrings.py:1867
+#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1901
 #, fuzzy
 msgid "Exports space time raster dataset."
-#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1868
+#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1902
 msgid "Export raster dataset as VTK time series"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1869
+#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1903
 #, fuzzy
 msgid "Exports space time raster dataset as VTK time series."
-#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1870
+#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1904
 #, fuzzy
 msgid "Export vector dataset"
-#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1871
+#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1905
 msgid "Export a space time vector dataset.as GRASS specific archive file"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1872
+#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1906
 #, fuzzy
 msgid "Convert raster dataset to volume"
 msgstr "Program, vytvářející MPEG ze série rastrových map"
-#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1873
+#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1907
 #, fuzzy
 msgid "Converts a space time raster dataset into a raster3d map."
 msgstr "Převede binární GRASS vektorovou mapu do GRASS rastrové mapy."
-#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1874
+#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1908
 #, fuzzy
 msgid "Extraction"
 msgstr "Nastavení písma"
-#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1875
+#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1909
 #, fuzzy
 msgid "Extract subset of raster dataset"
-#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1876
+#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1910
 #, fuzzy
 msgid "Extracts a subset of a space time raster datasets."
-#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1877
+#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1911
 #, fuzzy
 msgid "Extract subset of vector dataset"
-#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1878
+#: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1912
 #, fuzzy
 msgid "Extracts a subset of a space time vector dataset."
-#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1879
+#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1913
 #, fuzzy
 msgid "Extract subset of raster3D dataset"
-#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1880
+#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1914
 #, fuzzy
 msgid "Extracts a subset of a space time raster3d dataset."
-#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1881
+#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1915
 #, fuzzy
 msgid "Query vector dataset attribute data"
 msgstr "Atributový dotaz"
-#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1882
+#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1916
 #, fuzzy
 msgid ""
 "Prints attributes of vector maps registered in a space time vector dataset."
-#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1883
+#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1917
 #, fuzzy
 msgid "Raster dataset color table"
 msgstr "Nastavit tabulku barev"
-#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1884
+#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1918
 #, fuzzy
 msgid ""
 "Creates/modifies the color table associated with each raster map of the "
 "space time raster dataset."
 msgstr "Vytvoří/upraví tabulku barev spojenou s rastrovou mapou."
-#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1885
+#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1919
 #, fuzzy
 msgid "Raster calculations"
-#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1886
+#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1920
 msgid ""
 "Perform spatio-temporal mapcalc expressions on temporal sampled maps of "
 "space time raster datasets."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1887
+#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1921
 #, fuzzy
 msgid "Raster3D calculations"
-#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1888
+#: ../gui/wxpython/menustrings.py:993 ../gui/wxpython/menustrings.py:1922
 msgid ""
 "Performs r3.mapcalc expressions on maps of sampled space time raster3d "
 "datasets."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1889
+#: ../gui/wxpython/menustrings.py:994 ../gui/wxpython/menustrings.py:1923
 #, fuzzy
 msgid "Interpolate gaps in raster datasets"
-#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1890
+#: ../gui/wxpython/menustrings.py:995 ../gui/wxpython/menustrings.py:1924
 msgid ""
 "Replace gaps in a space time raster dataset with interpolated raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1891
+#: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1925
 #, fuzzy
 msgid "Aggregation"
 msgstr "Otočení:"
-#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1892
+#: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1926
 #, fuzzy
 msgid "Neighborhood analysis in raster dataset"
 msgstr "Analýza okolí"
-#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1893
+#: ../gui/wxpython/menustrings.py:998 ../gui/wxpython/menustrings.py:1927
 msgid ""
 "Performs a neighborhood analysis for each map in a space time raster dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1894
+#: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1928
 #, fuzzy
 msgid "Aggregation in raster datasets"
-#: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1895
+#: ../gui/wxpython/menustrings.py:1000 ../gui/wxpython/menustrings.py:1929
 msgid ""
 "Performs different aggregation algorithms from r.series on all or a subset "
 "of raster maps in a space time raster dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1896
+#: ../gui/wxpython/menustrings.py:1001 ../gui/wxpython/menustrings.py:1930
 #, fuzzy
 msgid "Temporal aggregation"
-#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1897
+#: ../gui/wxpython/menustrings.py:1002 ../gui/wxpython/menustrings.py:1931
 msgid ""
 "Temporally aggregates the maps of a space time raster dataset by a user "
 "defined granularity."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1898
+#: ../gui/wxpython/menustrings.py:1003 ../gui/wxpython/menustrings.py:1932
 msgid "Temporal aggregation by dataset"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1899
+#: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1933
 msgid ""
 "Aggregated data of an existing space time raster dataset using the time "
 "intervals of a second space time dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1900
+#: ../gui/wxpython/menustrings.py:1005 ../gui/wxpython/menustrings.py:1934
 #, fuzzy
 msgid "Sampling"
 msgstr "Vzorové body profilu"
-#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1901
+#: ../gui/wxpython/menustrings.py:1006 ../gui/wxpython/menustrings.py:1935
 #, fuzzy
 msgid "Temporal sampling"
-#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1902
+#: ../gui/wxpython/menustrings.py:1007 ../gui/wxpython/menustrings.py:1936
 msgid ""
 "Samples the input space time dataset(s) with a sample space time dataset and "
 "print the result to stdout."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1903
+#: ../gui/wxpython/menustrings.py:1008 ../gui/wxpython/menustrings.py:1937
 #, fuzzy
 msgid "Query raster dataset by vector points dataset"
 msgstr "Získává vzorky z rastrové mapy místech vektorových bodů"
-#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1904
+#: ../gui/wxpython/menustrings.py:1009 ../gui/wxpython/menustrings.py:1938
 #, fuzzy
 msgid ""
 "Store raster map values at spatial and temporal positions of vector points "
@@ -11368,44 +11452,44 @@
 msgstr ""
 "Uloží hodnoty rastru pod vektorovými body do jejich atributové tabulky."
-#: ../gui/wxpython/menustrings.py:993 ../gui/wxpython/menustrings.py:1905
+#: ../gui/wxpython/menustrings.py:1010 ../gui/wxpython/menustrings.py:1939
 msgid "Observe specific locations in raster dataset"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:994 ../gui/wxpython/menustrings.py:1906
+#: ../gui/wxpython/menustrings.py:1011 ../gui/wxpython/menustrings.py:1940
 msgid ""
 "Observes specific locations in a space time raster dataset over a period of "
 "time using vector points."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1908
+#: ../gui/wxpython/menustrings.py:1013 ../gui/wxpython/menustrings.py:1942
 #, fuzzy
 msgid "Space time datasets metadata"
-#: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1909
+#: ../gui/wxpython/menustrings.py:1014 ../gui/wxpython/menustrings.py:1943
 #, fuzzy
 msgid "Lists information about space time datasets and maps."
 msgstr "Vypíše základní informace o uživatelem vybrané rastrové vrstvě."
-#: ../gui/wxpython/menustrings.py:998 ../gui/wxpython/menustrings.py:1910
+#: ../gui/wxpython/menustrings.py:1015 ../gui/wxpython/menustrings.py:1944
 #, fuzzy
 msgid "Univariate raster dataset statistics"
 msgstr "Univariantní statistika rastrové vrstvy"
-#: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1911
+#: ../gui/wxpython/menustrings.py:1016 ../gui/wxpython/menustrings.py:1945
 #, fuzzy
 msgid ""
 "Calculates univariate statistics from the non-null cells for each registered "
 "raster map of a space time raster dataset."
 msgstr "Spočítá univariantní statistiku z ne-nullových buněk rastrové mapy."
-#: ../gui/wxpython/menustrings.py:1000 ../gui/wxpython/menustrings.py:1912
+#: ../gui/wxpython/menustrings.py:1017 ../gui/wxpython/menustrings.py:1946
 #, fuzzy
 msgid "Univariate vector dataset statistics"
-#: ../gui/wxpython/menustrings.py:1001 ../gui/wxpython/menustrings.py:1913
+#: ../gui/wxpython/menustrings.py:1018 ../gui/wxpython/menustrings.py:1947
 #, fuzzy
 msgid ""
 "Calculates univariate statistics of attributes for each registered vector "
@@ -11413,12 +11497,12 @@
 msgstr ""
 "Spočítá univariantní statistiku pro vybraný sloupec tabulky vektorové vrstvy."
-#: ../gui/wxpython/menustrings.py:1002 ../gui/wxpython/menustrings.py:1914
+#: ../gui/wxpython/menustrings.py:1019 ../gui/wxpython/menustrings.py:1948
 #, fuzzy
 msgid "Univariate raster3D dataset statistics"
-#: ../gui/wxpython/menustrings.py:1003 ../gui/wxpython/menustrings.py:1915
+#: ../gui/wxpython/menustrings.py:1020 ../gui/wxpython/menustrings.py:1949
 #, fuzzy
 msgid ""
@@ -11426,303 +11510,303 @@
 msgstr ""
-#: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1916
+#: ../gui/wxpython/menustrings.py:1021 ../gui/wxpython/menustrings.py:1950
 #, fuzzy
 msgid "Report temporal topology"
 msgstr "Načíst nebo podat zprávu o topologii"
-#: ../gui/wxpython/menustrings.py:1005 ../gui/wxpython/menustrings.py:1917
+#: ../gui/wxpython/menustrings.py:1022 ../gui/wxpython/menustrings.py:1951
 #, fuzzy
 msgid "Lists temporal topology of a space time dataset."
-#: ../gui/wxpython/menustrings.py:1006 ../gui/wxpython/menustrings.py:1918
-#: ../gui/wxpython/menustrings.py:1922
+#: ../gui/wxpython/menustrings.py:1023 ../gui/wxpython/menustrings.py:1952
+#: ../gui/wxpython/menustrings.py:1956
 msgid "GUI tools"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:1009 ../gui/wxpython/menustrings.py:1921
+#: ../gui/wxpython/menustrings.py:1026 ../gui/wxpython/menustrings.py:1955
 #, fuzzy
 msgid "Plot temporal extents"
 msgstr "Zobrazit meze výpočetního regionu "
-#: ../gui/wxpython/menustrings.py:1010 ../gui/wxpython/menustrings.py:1981
-#: ../gui/wxpython/menustrings.py:2024
+#: ../gui/wxpython/menustrings.py:1027 ../gui/wxpython/menustrings.py:2015
+#: ../gui/wxpython/menustrings.py:2058
 msgid "&Help"
 msgstr "&Nápověda"
-#: ../gui/wxpython/menustrings.py:1011
+#: ../gui/wxpython/menustrings.py:1028
 msgid "GRASS help"
 msgstr "Nápověda GRASS GIS"
-#: ../gui/wxpython/menustrings.py:1012 ../gui/wxpython/menustrings.py:1014
+#: ../gui/wxpython/menustrings.py:1029 ../gui/wxpython/menustrings.py:1031
 #, fuzzy
 msgid "Display the HTML man pages of GRASS GIS"
 msgstr "Zobrazuje manuálové stránky GRASSu ve formátu HTML"
-#: ../gui/wxpython/menustrings.py:1013
+#: ../gui/wxpython/menustrings.py:1030
 msgid "GUI help"
 msgstr "Nápověda wxGUI"
-#: ../gui/wxpython/menustrings.py:1015
+#: ../gui/wxpython/menustrings.py:1032
 msgid "About system"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:1016
+#: ../gui/wxpython/menustrings.py:1033
 #, fuzzy
 msgid "Prints system information"
-#: ../gui/wxpython/menustrings.py:1021
+#: ../gui/wxpython/menustrings.py:1038
 #, fuzzy
 msgid "Import, export and link data"
-#: ../gui/wxpython/menustrings.py:1925
+#: ../gui/wxpython/menustrings.py:1959
 #, fuzzy
 msgid "Attribute table manager"
 msgstr "Správce atributových dat"
-#: ../gui/wxpython/menustrings.py:1940
+#: ../gui/wxpython/menustrings.py:1974
 msgid "Create new model"
 msgstr "Vytvořit nový model"
-#: ../gui/wxpython/menustrings.py:1942
+#: ../gui/wxpython/menustrings.py:1976
 msgid "Load model from file"
 msgstr "Načíst model ze souboru"
-#: ../gui/wxpython/menustrings.py:1946
+#: ../gui/wxpython/menustrings.py:1980
 msgid "Save model to file"
 msgstr "Uložit model do souboru"
-#: ../gui/wxpython/menustrings.py:1948
+#: ../gui/wxpython/menustrings.py:1982
 msgid "Close model file"
 msgstr "Zavřít soubor modelu"
-#: ../gui/wxpython/menustrings.py:1949
+#: ../gui/wxpython/menustrings.py:1983
 msgid "Export to image"
 msgstr "Export do obrazu"
-#: ../gui/wxpython/menustrings.py:1950
+#: ../gui/wxpython/menustrings.py:1984
 msgid "Export model to image"
 msgstr "Export modelu do obrázku"
-#: ../gui/wxpython/menustrings.py:1951
+#: ../gui/wxpython/menustrings.py:1985
 msgid "Export to Python"
 msgstr "Export do Python"
-#: ../gui/wxpython/menustrings.py:1952
+#: ../gui/wxpython/menustrings.py:1986
 msgid "Export model to Python script"
 msgstr "Exportovat model do Python skriptu"
-#: ../gui/wxpython/menustrings.py:1953
+#: ../gui/wxpython/menustrings.py:1987
 msgid "Quit modeler"
 msgstr "Ukončit modelování"
-#: ../gui/wxpython/menustrings.py:1954
+#: ../gui/wxpython/menustrings.py:1988
 msgid "Close modeler window"
 msgstr "Zavřít okno modelování"
-#: ../gui/wxpython/menustrings.py:1958
+#: ../gui/wxpython/menustrings.py:1992
 msgid "&Model"
 msgstr "&Modelování"
-#: ../gui/wxpython/menustrings.py:1959
+#: ../gui/wxpython/menustrings.py:1993
 #, fuzzy
 msgid "Add command"
 msgstr "Přidat vrstvu s příkazem"
-#: ../gui/wxpython/menustrings.py:1960
+#: ../gui/wxpython/menustrings.py:1994
 #, fuzzy
 msgid "Add action (GRASS command) to model"
 msgstr "Přidat akci do modelu"
-#: ../gui/wxpython/menustrings.py:1961
+#: ../gui/wxpython/menustrings.py:1995
 msgid "Add data"
 msgstr "Přidata data"
-#: ../gui/wxpython/menustrings.py:1962
+#: ../gui/wxpython/menustrings.py:1996
 msgid "Add data item to model"
 msgstr "Přidat data do modelu"
-#: ../gui/wxpython/menustrings.py:1963
+#: ../gui/wxpython/menustrings.py:1997
 msgid "Define relation"
 msgstr "Definovat vztah"
-#: ../gui/wxpython/menustrings.py:1964
+#: ../gui/wxpython/menustrings.py:1998
 msgid "Define relation between data and action items"
 msgstr "Definovat vztah mezi daty a akcemi"
-#: ../gui/wxpython/menustrings.py:1965
+#: ../gui/wxpython/menustrings.py:1999
 #, fuzzy
 msgid "Add loop / series"
 msgstr "Přidat smyčku"
-#: ../gui/wxpython/menustrings.py:1966
+#: ../gui/wxpython/menustrings.py:2000
 #, fuzzy
 msgid "Adds loop (series) to model"
 msgstr "Přidat smyčku do modelu"
-#: ../gui/wxpython/menustrings.py:1967
+#: ../gui/wxpython/menustrings.py:2001
 msgid "Add condition"
 msgstr "Přidat podmínku"
-#: ../gui/wxpython/menustrings.py:1968
+#: ../gui/wxpython/menustrings.py:2002
 msgid "Adds condition (if/else) to model"
 msgstr "Přidá podmínky (if/else) do modelu"
-#: ../gui/wxpython/menustrings.py:1970
+#: ../gui/wxpython/menustrings.py:2004
 #, fuzzy
 msgid "Adds comment to model"
-#: ../gui/wxpython/menustrings.py:1971
+#: ../gui/wxpython/menustrings.py:2005
 msgid "Remove item"
 msgstr "Odstranit prvek"
-#: ../gui/wxpython/menustrings.py:1972
+#: ../gui/wxpython/menustrings.py:2006
 msgid "Remove action/data from model"
 msgstr "Odstranit data/akce z modelu"
-#: ../gui/wxpython/menustrings.py:1974
+#: ../gui/wxpython/menustrings.py:2008
 msgid "Model properties (name, purpose, etc.)"
 msgstr "Vlastnosti modelu (jméno, účel, atd.)"
-#: ../gui/wxpython/menustrings.py:1975
+#: ../gui/wxpython/menustrings.py:2009
 msgid "Delete intermediate data"
 msgstr "Smazat dočasná data"
-#: ../gui/wxpython/menustrings.py:1976
+#: ../gui/wxpython/menustrings.py:2010
 msgid "Delete intermediate data defined in the model"
 msgstr "Smazat průběžná data definována v modellu"
-#: ../gui/wxpython/menustrings.py:1978
+#: ../gui/wxpython/menustrings.py:2012
 msgid "Run entire model"
 msgstr "Sopustit celý model"
-#: ../gui/wxpython/menustrings.py:1979
+#: ../gui/wxpython/menustrings.py:2013
 msgid "Validate model"
 msgstr "Vyhodnotit model"
-#: ../gui/wxpython/menustrings.py:1980
+#: ../gui/wxpython/menustrings.py:2014
 msgid "Validate entire model"
 msgstr "Vyhodnotit celý model"
-#: ../gui/wxpython/menustrings.py:1982 ../gui/wxpython/menustrings.py:2025
+#: ../gui/wxpython/menustrings.py:2016 ../gui/wxpython/menustrings.py:2059
 #: ../gui/wxpython/timeline/frame.py:131
 msgid "Help"
 msgstr "Nápověda"
-#: ../gui/wxpython/menustrings.py:1983
+#: ../gui/wxpython/menustrings.py:2017
 msgid "Display the HTML man pages of Graphical modeler"
 msgstr "Zobrazit manuálové HTML stránky Grafického modelování"
-#: ../gui/wxpython/menustrings.py:1984
+#: ../gui/wxpython/menustrings.py:2018
 msgid "About Graphical Modeler"
 msgstr "O grafickém modelování"
-#: ../gui/wxpython/menustrings.py:1985
+#: ../gui/wxpython/menustrings.py:2019
 msgid "Display information about Graphical Modeler"
 msgstr "Zobrazit informace o Grafickém modelování"
-#: ../gui/wxpython/menustrings.py:1991
+#: ../gui/wxpython/menustrings.py:2025
 #, fuzzy
 msgid "Load instruction file"
 msgstr "Nelze načíst seznam: %s"
-#: ../gui/wxpython/menustrings.py:1993
+#: ../gui/wxpython/menustrings.py:2027
 #, fuzzy
 msgid "Export instruction file"
-#: ../gui/wxpython/menustrings.py:1995
+#: ../gui/wxpython/menustrings.py:2029
 #, fuzzy
 msgid "Export to PostScript"
-#: ../gui/wxpython/menustrings.py:1997
+#: ../gui/wxpython/menustrings.py:2031
 #, fuzzy
 msgid "Export to PDF"
-#: ../gui/wxpython/menustrings.py:1999 ../gui/wxpython/menustrings.py:2000
+#: ../gui/wxpython/menustrings.py:2033 ../gui/wxpython/menustrings.py:2034
 #, fuzzy
 msgid "Launch ps.map dialog"
 msgstr "Spustit skript"
-#: ../gui/wxpython/menustrings.py:2002
+#: ../gui/wxpython/menustrings.py:2036
 #, fuzzy
 msgid "Close Cartographic Composer"
 msgstr "Ukončit Grafické modelování"
-#: ../gui/wxpython/menustrings.py:2003
+#: ../gui/wxpython/menustrings.py:2037
 #, fuzzy
 msgid "&Insert"
 msgstr "&Instalovat"
-#: ../gui/wxpython/menustrings.py:2005
+#: ../gui/wxpython/menustrings.py:2039
 #, fuzzy
 msgid "Add or edit map frame"
 msgstr "Přidat rastrovou vrstvu"
-#: ../gui/wxpython/menustrings.py:2007
+#: ../gui/wxpython/menustrings.py:2041
 #, fuzzy
 msgid "Add or edit raster map"
 msgstr "Přidat 3D rastrovou mapu"
-#: ../gui/wxpython/menustrings.py:2009
+#: ../gui/wxpython/menustrings.py:2043
 #, fuzzy
 msgid "Add or edit vector map"
 msgstr "vektorová mapa"
-#: ../gui/wxpython/menustrings.py:2010
+#: ../gui/wxpython/menustrings.py:2044
 #, fuzzy
 msgid "Map legend"
 msgstr "Legenda"
-#: ../gui/wxpython/menustrings.py:2011
+#: ../gui/wxpython/menustrings.py:2045
 #, fuzzy
 msgid "Add or edit raster and vector legend"
 msgstr "Přidat vytvořenou rastrovou mapu do stromu vrstev"
-#: ../gui/wxpython/menustrings.py:2013
+#: ../gui/wxpython/menustrings.py:2047
 #, fuzzy
 msgid "Add or edit map info"
 msgstr "Přidat mapové prvky"
-#: ../gui/wxpython/menustrings.py:2015
+#: ../gui/wxpython/menustrings.py:2049
 #, fuzzy
 msgid "Add or edit scale bar"
 msgstr "Přidat vrstvu"
-#: ../gui/wxpython/menustrings.py:2017
+#: ../gui/wxpython/menustrings.py:2051
 #: ../gui/wxpython/animation/dialogs.py:813
 #, fuzzy
 msgid "Add text"
 msgstr "Přidat vrstvu s textem"
-#: ../gui/wxpython/menustrings.py:2019
+#: ../gui/wxpython/menustrings.py:2053
 #, fuzzy
 msgid "Add image"
-#: ../gui/wxpython/menustrings.py:2021
+#: ../gui/wxpython/menustrings.py:2055
 #, fuzzy
 msgid "Add north arrow"
 msgstr "Měřítko a směrová růžice"
-#: ../gui/wxpython/menustrings.py:2026
+#: ../gui/wxpython/menustrings.py:2060
 #, fuzzy
 msgid "Display the HTML man pages of Cartographic Composer"
-#: ../gui/wxpython/menustrings.py:2027
+#: ../gui/wxpython/menustrings.py:2061
 #, fuzzy
 msgid "About Cartographic Composer"
-#: ../gui/wxpython/menustrings.py:2028
+#: ../gui/wxpython/menustrings.py:2062
 #, fuzzy
 msgid "Display information about Cartographic Composer"
@@ -11763,7 +11847,7 @@
 msgstr "Rektifikuji obrazy. prosím počkejte..."
 #: ../gui/wxpython/animation/controller.py:524
-#: ../gui/wxpython/animation/frame.py:574
+#: ../gui/wxpython/animation/frame.py:577
 #, python-format
 msgid "%(from)s %(dash)s %(to)s"
 msgstr ""
@@ -11835,7 +11919,7 @@
 msgid "Add space-time dataset or series of map layers for animation"
 msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:45 ../gui/wxpython/lmgr/frame.py:1177
+#: ../gui/wxpython/animation/nviztask.py:46 ../gui/wxpython/lmgr/frame.py:1177
 #, python-format
 msgid ""
 "Reading workspace file <%s> failed.\n"
@@ -11844,17 +11928,17 @@
 "Čtení souboru workspace <%s> selhalo. \n"
 "Neplatný soubor, nelze parsovat XML dokument."
-#: ../gui/wxpython/animation/nviztask.py:54
+#: ../gui/wxpython/animation/nviztask.py:55
 #, fuzzy, python-format
 msgid "No 3d view information in workspace file <%s>."
 msgstr "Nastavení 3D zobrazení bylo uloženo do souboru <%s>."
-#: ../gui/wxpython/animation/nviztask.py:240
+#: ../gui/wxpython/animation/nviztask.py:263
 #, fuzzy
 msgid "Please add only one layer in the list."
 msgstr "Přidat připojené vrstvy do stromu vrstev"
-#: ../gui/wxpython/animation/nviztask.py:246
+#: ../gui/wxpython/animation/nviztask.py:269
 #, fuzzy
 msgid "No map series nor space-time dataset is added."
 msgstr "Vytvořit z databáze"
@@ -12420,7 +12504,7 @@
 msgid " ({} out of {})"
 msgstr ""
-#: ../gui/wxpython/animation/frame.py:577
+#: ../gui/wxpython/animation/frame.py:580
 #, python-format
 msgid "to %(to)s"
 msgstr ""
@@ -12500,155 +12584,160 @@
 msgid "Load expression from file"
 msgstr "Načíst výraz ze souboru"
-#: ../gui/wxpython/modules/mcalc_builder.py:153
+#: ../gui/wxpython/modules/mcalc_builder.py:155
 msgid "exponent"
 msgstr "exponent"
-#: ../gui/wxpython/modules/mcalc_builder.py:155
+#: ../gui/wxpython/modules/mcalc_builder.py:157
 msgid "divide"
 msgstr "dělění"
-#: ../gui/wxpython/modules/mcalc_builder.py:157
+#: ../gui/wxpython/modules/mcalc_builder.py:159
 msgid "add"
 msgstr "sečíst"
-#: ../gui/wxpython/modules/mcalc_builder.py:159
+#: ../gui/wxpython/modules/mcalc_builder.py:161
 msgid "subtract"
 msgstr "odečíst"
-#: ../gui/wxpython/modules/mcalc_builder.py:161
+#: ../gui/wxpython/modules/mcalc_builder.py:163
 msgid "modulus"
 msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:163
+#: ../gui/wxpython/modules/mcalc_builder.py:165
 msgid "multiply"
 msgstr "násobit"
-#: ../gui/wxpython/modules/mcalc_builder.py:168
+#: ../gui/wxpython/modules/mcalc_builder.py:170
 msgid "left shift"
 msgstr "posun doleva"
-#: ../gui/wxpython/modules/mcalc_builder.py:170
+#: ../gui/wxpython/modules/mcalc_builder.py:172
 msgid "right shift"
 msgstr "posun doprava"
-#: ../gui/wxpython/modules/mcalc_builder.py:172
+#: ../gui/wxpython/modules/mcalc_builder.py:174
 msgid "right shift (unsigned)"
 msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:174
+#: ../gui/wxpython/modules/mcalc_builder.py:176
 msgid "greater than"
 msgstr "více než"
-#: ../gui/wxpython/modules/mcalc_builder.py:176
+#: ../gui/wxpython/modules/mcalc_builder.py:178
 msgid "greater than or equal to"
 msgstr "více než nebo rovno"
-#: ../gui/wxpython/modules/mcalc_builder.py:178
+#: ../gui/wxpython/modules/mcalc_builder.py:180
 msgid "less than"
 msgstr "méně než"
-#: ../gui/wxpython/modules/mcalc_builder.py:180
+#: ../gui/wxpython/modules/mcalc_builder.py:182
 msgid "less than or equal to"
 msgstr "méně než nebo rovno"
-#: ../gui/wxpython/modules/mcalc_builder.py:182
+#: ../gui/wxpython/modules/mcalc_builder.py:184
 msgid "equal to"
 msgstr "rovno"
-#: ../gui/wxpython/modules/mcalc_builder.py:184
+#: ../gui/wxpython/modules/mcalc_builder.py:186
 msgid "not equal to"
 msgstr "není rovno"
-#: ../gui/wxpython/modules/mcalc_builder.py:187
+#: ../gui/wxpython/modules/mcalc_builder.py:189
 #, fuzzy
 msgid "one's complement"
 msgstr "Zobr. výpoč. region"
-#: ../gui/wxpython/modules/mcalc_builder.py:189
+#: ../gui/wxpython/modules/mcalc_builder.py:191
 msgid "NOT"
 msgstr "NOT"
-#: ../gui/wxpython/modules/mcalc_builder.py:191
+#: ../gui/wxpython/modules/mcalc_builder.py:193
 msgid "bitwise AND"
 msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:193
+#: ../gui/wxpython/modules/mcalc_builder.py:195
 msgid "bitwise OR"
 msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:195
+#: ../gui/wxpython/modules/mcalc_builder.py:197
 msgid "logical AND"
 msgstr "Logické AND"
-#: ../gui/wxpython/modules/mcalc_builder.py:197
+#: ../gui/wxpython/modules/mcalc_builder.py:199
 msgid "logical AND (ignores NULLs)"
 msgstr "logické AND (ignoruje NULL hodnoty)"
-#: ../gui/wxpython/modules/mcalc_builder.py:199
+#: ../gui/wxpython/modules/mcalc_builder.py:201
 msgid "logical OR"
 msgstr "logické OR"
-#: ../gui/wxpython/modules/mcalc_builder.py:201
+#: ../gui/wxpython/modules/mcalc_builder.py:203
 msgid "logical OR (ignores NULLs)"
 msgstr "logické OR (ignoruje NULL hodnoty)"
-#: ../gui/wxpython/modules/mcalc_builder.py:203
+#: ../gui/wxpython/modules/mcalc_builder.py:205
 #, fuzzy
 msgid "conditional"
 msgstr "Volitelné"
-#: ../gui/wxpython/modules/mcalc_builder.py:216
+#: ../gui/wxpython/modules/mcalc_builder.py:218
 #, fuzzy
 msgid "Name for new 3D raster map to create"
 msgstr "Jméno pro nově vytvářenou %s"
-#: ../gui/wxpython/modules/mcalc_builder.py:218
+#: ../gui/wxpython/modules/mcalc_builder.py:220
 #, fuzzy
 msgid "Name for new raster map to create"
-#: ../gui/wxpython/modules/mcalc_builder.py:222
+#: ../gui/wxpython/modules/mcalc_builder.py:224
 #, fuzzy
 msgid "Insert existing 3D raster map"
 msgstr "Vložit existující %s"
-#: ../gui/wxpython/modules/mcalc_builder.py:224
+#: ../gui/wxpython/modules/mcalc_builder.py:226
 #, fuzzy
 msgid "Insert existing raster map"
-#: ../gui/wxpython/modules/mcalc_builder.py:228
+#: ../gui/wxpython/modules/mcalc_builder.py:230
 msgid "Insert mapcalc function"
 msgstr "Vložit funkci mapcalc"
-#: ../gui/wxpython/modules/mcalc_builder.py:239
+#: ../gui/wxpython/modules/mcalc_builder.py:241
 msgid "Add created raster map into layer tree"
-#: ../gui/wxpython/modules/mcalc_builder.py:489
+#: ../gui/wxpython/modules/mcalc_builder.py:504
 #, fuzzy
 msgid "You must enter the name of a new raster map to create."
 msgstr "Musíte vložit jméno nově vytvářené mapy"
-#: ../gui/wxpython/modules/mcalc_builder.py:499
+#: ../gui/wxpython/modules/mcalc_builder.py:514
 #, fuzzy
 msgid "You must enter an expression to create a new raster map."
 msgstr "Musíte vložit mapcalc formuli pro vytvoření nové mapy"
-#: ../gui/wxpython/modules/mcalc_builder.py:538
+#: ../gui/wxpython/modules/mcalc_builder.py:553
 msgid "Choose a file name to save the expression"
 msgstr "Vyberte jméno souboru pro uložení výrazu"
-#: ../gui/wxpython/modules/mcalc_builder.py:539
-#: ../gui/wxpython/modules/mcalc_builder.py:560
+#: ../gui/wxpython/modules/mcalc_builder.py:554
+#: ../gui/wxpython/modules/mcalc_builder.py:575
 msgid "Expression file (*)|*"
 msgstr "SOubor s výrazem (*)|*"
-#: ../gui/wxpython/modules/mcalc_builder.py:559
+#: ../gui/wxpython/modules/mcalc_builder.py:574
 msgid "Choose a file name to load the expression"
 msgstr "Vyberte soubor pro načtení výrazu"
+#: ../gui/wxpython/modules/mcalc_builder.py:609
+#, fuzzy, python-brace-format
+msgid "'{cmd}' copied to clipboard"
+msgstr "'%s' zkopírováno do schránky"
 #: ../gui/wxpython/modules/vclean.py:37 ../gui/wxpython/modules/vclean.py:119
 msgid "Set up vector cleaning tools"
 msgstr "Nastavit vektorový čistící nástroj"
@@ -18872,10 +18961,6 @@
 #~ msgid "Function not supported yet"
 #~ msgstr "Funcke ještě není ilplementována"
-#, fuzzy
-#~ msgid "Compute category quantiles using two passes."
-#~ msgstr "Vypočítat quantily použitím dvou průchodů"
 #~ msgid "GRASS GIS Map Display: "
 #~ msgstr "GRASS GIS Mapové okno: "
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasswxpy_de.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grasswxpy_de\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2014-03-27 20:41+0100\n"
+"POT-Creation-Date: 2014-03-31 21:29+0200\n"
 "PO-Revision-Date: 2014-03-24 16:24+0100\n"
 "Last-Translator: Helmut Kudrnovsky <hellik at web.de>\n"
 "Language-Team: German <grass-translations at lists.osgeo.org>\n"
@@ -44,7 +44,7 @@
 #: ../gui/wxpython/iscatt/toolbars.py:44
 #: ../gui/wxpython/iscatt/toolbars.py:135
 #: ../gui/wxpython/gui_core/toolbars.py:84
-#: ../gui/wxpython/gui_core/widgets.py:986 ../gui/wxpython/nviz/tools.py:1892
+#: ../gui/wxpython/gui_core/widgets.py:997 ../gui/wxpython/nviz/tools.py:1892
 #: ../gui/wxpython/vnet/dialogs.py:867
 msgid "Settings"
 msgstr "Einstellungen"
@@ -75,7 +75,9 @@
 msgstr ""
 #: ../gui/wxpython/iscatt/toolbars.py:56
-msgid "Zoom to scatter plot data extend mode (click on scatter plot for zooming to extend)"
+msgid ""
+"Zoom to scatter plot data extend mode (click on scatter plot for zooming to "
+"extend)"
 msgstr ""
 #: ../gui/wxpython/iscatt/toolbars.py:58
@@ -157,7 +159,8 @@
 #, python-format
 msgid ""
 "Interactive Scatter Plot Tool can not be used.\n"
-"Number of cells (rows*cols) <%d> in current regionis higher than maximum limit <%d>.\n"
+"Number of cells (rows*cols) <%d> in current regionis higher than maximum "
+"limit <%d>.\n"
 "\n"
 "You can reduce number of cells in current region using <g.region> command."
 msgstr ""
@@ -165,15 +168,19 @@
 #: ../gui/wxpython/iscatt/controllers.py:232
 #, python-format
 msgid ""
-"Number of cells (rows*cols) <%d> in current region is higher than recommended threshold <%d>.\n"
-"It is strongly advised to reduce number of cells in current region bellow recommend threshold.\n"
+"Number of cells (rows*cols) <%d> in current region is higher than "
+"recommended threshold <%d>.\n"
+"It is strongly advised to reduce number of cells in current region bellow "
+"recommend threshold.\n"
 " It can be done by <g.region> command.\n"
 "\n"
 "Do you want to continue using Interactive Scatter Plot Tool with this region?"
 msgstr ""
 #: ../gui/wxpython/iscatt/controllers.py:288
-msgid "Scatter plot with same band combination (regardless x y order) is already displayed."
+msgid ""
+"Scatter plot with same band combination (regardless x y order) is already "
+"displayed."
 msgstr ""
 #: ../gui/wxpython/iscatt/controllers.py:301
@@ -190,14 +197,17 @@
 #, python-format
 msgid ""
 "Scatter plot cannot be added.\n"
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <%d>.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <"
+"%d>.\n"
 msgstr ""
 #: ../gui/wxpython/iscatt/controllers.py:318
 #, python-format
 msgid ""
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended limit <%d>.\n"
-"It is strongly advised to reduce range extend of bands(e. g. using r.rescale) bellow recommended threshold.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended "
+"limit <%d>.\n"
+"It is strongly advised to reduce range extend of bands(e. g. using r."
+"rescale) bellow recommended threshold.\n"
 "\n"
 "Do you really want to add this scatter plot?"
 msgstr ""
@@ -299,7 +309,9 @@
 msgstr "%d Karte aus dem aktuellen Mapset gelöscht"
 #: ../gui/wxpython/iscatt/dialogs.py:191
-msgid "Scatter plot with same bands combination (regardless x y order) has been already added into the list."
+msgid ""
+"Scatter plot with same bands combination (regardless x y order) has been "
+"already added into the list."
 msgstr ""
 #: ../gui/wxpython/iscatt/dialogs.py:253 ../gui/wxpython/iclass/dialogs.py:708
@@ -359,8 +371,11 @@
 #: ../gui/wxpython/wxplot/dialogs.py:691
 #: ../gui/wxpython/wxplot/dialogs.py:1137 ../gui/wxpython/gcp/manager.py:2408
 #: ../gui/wxpython/vnet/dialogs.py:1186
-msgid "Apply and save changes to user settings file (default for next sessions)"
-msgstr "Wende Änderungen an und speichere sie in den Benutzereinstellungen (Standard für die nächste Sitzung)"
+msgid ""
+"Apply and save changes to user settings file (default for next sessions)"
+msgstr ""
+"Wende Änderungen an und speichere sie in den Benutzereinstellungen (Standard "
+"für die nächste Sitzung)"
 #: ../gui/wxpython/iscatt/dialogs.py:361
 #: ../gui/wxpython/gui_core/dialogs.py:1663
@@ -612,7 +627,7 @@
 #: ../gui/wxpython/gui_core/gselect.py:1419
 #: ../gui/wxpython/gui_core/gselect.py:1429
 #: ../gui/wxpython/gui_core/gselect.py:1430
-#: ../gui/wxpython/gui_core/widgets.py:1047
+#: ../gui/wxpython/gui_core/widgets.py:1058
 #: ../gui/wxpython/gmodeler/preferences.py:549
 #: ../gui/wxpython/animation/dialogs.py:333
 #: ../gui/wxpython/vnet/dialogs.py:1474
@@ -782,7 +797,7 @@
 msgid "Select font"
 msgstr "Schrift auswählen"
-#: ../gui/wxpython/gui_core/toolbars.py:73 ../gui/wxpython/menustrings.py:2001
+#: ../gui/wxpython/gui_core/toolbars.py:73 ../gui/wxpython/menustrings.py:2035
 #: ../gui/wxpython/lmgr/layertree.py:72
 msgid "Quit"
 msgstr "Beenden"
@@ -835,6 +850,7 @@
 msgstr "Führe den Befehl aus (Ctrl+R)"
 #: ../gui/wxpython/gui_core/forms.py:514
+#: ../gui/wxpython/modules/mcalc_builder.py:151
 msgid "Copy the current command string to the clipboard"
 msgstr "Kopiere die aktuelle Befehlszeile in die Zwischenablage"
@@ -852,8 +868,12 @@
 msgstr "Schließe den Dialog beim Beenden"
 #: ../gui/wxpython/gui_core/forms.py:578
-msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
-msgstr "Schließe Dialog, wenn Befehl erfolgreich ausgeführt. Ändere dies in den Einstellungen (Reiter 'Befehle')."
+msgid ""
+"Close dialog when command is successfully finished. Change this settings in "
+"Preferences dialog ('Command' tab)."
+msgstr ""
+"Schließe Dialog, wenn Befehl erfolgreich ausgeführt. Ändere dies in den "
+"Einstellungen (Reiter 'Befehle')."
 #: ../gui/wxpython/gui_core/forms.py:745
 #, python-format
@@ -978,77 +998,79 @@
 msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:82
+#: ../gui/wxpython/gui_core/widgets.py:84
 msgid " (...)"
 msgstr " (...)"
-#: ../gui/wxpython/gui_core/widgets.py:788
+#: ../gui/wxpython/gui_core/widgets.py:799
 #: ../gui/wxpython/gui_core/dialogs.py:671
 #: ../gui/wxpython/gui_core/dialogs.py:724
 #: ../gui/wxpython/gui_core/dialogs.py:1429 ../gui/wxpython/dbmgr/base.py:1244
 msgid "Select all"
 msgstr "Alle selektieren"
-#: ../gui/wxpython/gui_core/widgets.py:789
+#: ../gui/wxpython/gui_core/widgets.py:800
 #: ../gui/wxpython/gui_core/dialogs.py:1431 ../gui/wxpython/dbmgr/base.py:1245
 msgid "Deselect all"
 msgstr "Alle Selektierungen aufheben"
-#: ../gui/wxpython/gui_core/widgets.py:851
+#: ../gui/wxpython/gui_core/widgets.py:862
 #, fuzzy
 msgid "Fulltext search"
 msgstr "Volle Ausdehnung"
-#: ../gui/wxpython/gui_core/widgets.py:852
+#: ../gui/wxpython/gui_core/widgets.py:863
 #, fuzzy
 msgid "Type to search in all modules. Press Enter for next match."
 msgstr "Finde Modul - (Enter-Taste für nächsten Treffer)"
-#: ../gui/wxpython/gui_core/widgets.py:909
+#: ../gui/wxpython/gui_core/widgets.py:920
 msgid "Searching, please type more characters."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:918
+#: ../gui/wxpython/gui_core/widgets.py:929
 #, python-format
 msgid "%d modules match"
 msgstr "%d Module stimmen überein"
-#: ../gui/wxpython/gui_core/widgets.py:992
+#: ../gui/wxpython/gui_core/widgets.py:1003
 msgid "Save current settings"
 msgstr "Speichere aktuelle Einstellungen"
-#: ../gui/wxpython/gui_core/widgets.py:995
+#: ../gui/wxpython/gui_core/widgets.py:1006
 msgid "Delete currently selected settings"
 msgstr "Lösche ausgewähltes Einstellungen"
-#: ../gui/wxpython/gui_core/widgets.py:1016
+#: ../gui/wxpython/gui_core/widgets.py:1027
 msgid "Load settings:"
 msgstr "Lade Einstellungen:"
-#: ../gui/wxpython/gui_core/widgets.py:1034
+#: ../gui/wxpython/gui_core/widgets.py:1045
 #, python-format
 msgid "Settings <%s> not found"
 msgstr "Einstellungen <%s> nicht gefunden"
-#: ../gui/wxpython/gui_core/widgets.py:1048
-#: ../gui/wxpython/gui_core/widgets.py:1064
+#: ../gui/wxpython/gui_core/widgets.py:1059
+#: ../gui/wxpython/gui_core/widgets.py:1075
 msgid "Save settings"
 msgstr "Speichere Einstellungen"
-#: ../gui/wxpython/gui_core/widgets.py:1053
+#: ../gui/wxpython/gui_core/widgets.py:1064
 msgid "Name not given, settings is not saved."
 msgstr "Name nicht angegeben, Einstellungen werden nicht gespeichert."
-#: ../gui/wxpython/gui_core/widgets.py:1062
+#: ../gui/wxpython/gui_core/widgets.py:1073
 #, python-format
 msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
-msgstr "Einstellung <%s> existiert bereits. Wollen Sie die Einstellungen überschreiben?"
+msgstr ""
+"Einstellung <%s> existiert bereits. Wollen Sie die Einstellungen "
+"überschreiben?"
-#: ../gui/wxpython/gui_core/widgets.py:1111
+#: ../gui/wxpython/gui_core/widgets.py:1122
 msgid "No settings is defined. Operation canceled."
 msgstr "Keine Einstellungen angegeben. Operation abgebrochen."
-#: ../gui/wxpython/gui_core/widgets.py:1145
+#: ../gui/wxpython/gui_core/widgets.py:1156
 msgid "Unable to save settings"
 msgstr "Kann Einstellungen nicht speichern."
@@ -1175,8 +1197,8 @@
 msgstr "Name der Vektorkarte:"
 #: ../gui/wxpython/gui_core/dialogs.py:234
-#: ../gui/wxpython/gui_core/dialogs.py:353 ../gui/wxpython/menustrings.py:545
-#: ../gui/wxpython/menustrings.py:1457
+#: ../gui/wxpython/gui_core/dialogs.py:353 ../gui/wxpython/menustrings.py:562
+#: ../gui/wxpython/menustrings.py:1491
 msgid "Create new vector map"
 msgstr "Erzeuge neue Vektorkarte"
@@ -1218,8 +1240,12 @@
 #: ../gui/wxpython/gui_core/dialogs.py:418
 #, python-format
-msgid "Vector map <%s> already exists in the current mapset. Do you want to overwrite it?"
-msgstr "Die Vektorkarte <%s> existiert bereits im aktuellen Mapset. Wollen Sie diese überschreiben?"
+msgid ""
+"Vector map <%s> already exists in the current mapset. Do you want to "
+"overwrite it?"
+msgstr ""
+"Die Vektorkarte <%s> existiert bereits im aktuellen Mapset. Wollen Sie diese "
+"überschreiben?"
 #: ../gui/wxpython/gui_core/dialogs.py:421
 #: ../gui/wxpython/lmgr/layertree.py:796
@@ -1252,13 +1278,17 @@
 #: ../gui/wxpython/gui_core/dialogs.py:622
 #: ../gui/wxpython/gui_core/dialogs.py:1367
-msgid "Put here a regular expression. Characters '.*' stand for anything, character '^' stands for the beginning and '$' for the end."
+msgid ""
+"Put here a regular expression. Characters '.*' stand for anything, character "
+"'^' stands for the beginning and '$' for the end."
 msgstr ""
 #: ../gui/wxpython/gui_core/dialogs.py:629
 #, fuzzy
 msgid "Select existing group or enter name of new group:"
-msgstr "Selektieren Sie zu editierenden die Gruppe oder geben Sie einen Namen für eine neue Gruppe ein:"
+msgstr ""
+"Selektieren Sie zu editierenden die Gruppe oder geben Sie einen Namen für "
+"eine neue Gruppe ein:"
 #: ../gui/wxpython/gui_core/dialogs.py:640
 msgid "Edit/create subgroup"
@@ -1267,7 +1297,9 @@
 #: ../gui/wxpython/gui_core/dialogs.py:649
 #, fuzzy
 msgid "Select existing subgroup or enter name of new subgroup:"
+msgstr ""
 #: ../gui/wxpython/gui_core/dialogs.py:677
 #: ../gui/wxpython/gui_core/dialogs.py:730
@@ -1445,7 +1477,7 @@
 #: ../gui/wxpython/gui_core/dialogs.py:1650
 #: ../gui/wxpython/gui_core/preferences.py:816
 #: ../gui/wxpython/gmodeler/preferences.py:529
-#: ../gui/wxpython/modules/mcalc_builder.py:235
+#: ../gui/wxpython/modules/mcalc_builder.py:237
 #: ../gui/wxpython/modules/vclean.py:143 ../gui/wxpython/scripts/vkrige.py:141
 msgid "Allow output files to overwrite existing files"
 msgstr "Erlaube, dass Ausgabedateien existierende Dateien überschreiben"
@@ -1461,22 +1493,22 @@
 msgstr "Importiere ausgewählte Ebenen"
 #: ../gui/wxpython/gui_core/dialogs.py:1812 ../gui/wxpython/menustrings.py:167
-#: ../gui/wxpython/menustrings.py:1159 ../gui/wxpython/lmgr/layertree.py:64
+#: ../gui/wxpython/menustrings.py:1176 ../gui/wxpython/lmgr/layertree.py:64
 msgid "Link external vector data"
 msgstr "Einbindung externer Vektordaten"
 #: ../gui/wxpython/gui_core/dialogs.py:1814 ../gui/wxpython/menustrings.py:61
-#: ../gui/wxpython/menustrings.py:1053 ../gui/wxpython/lmgr/layertree.py:62
+#: ../gui/wxpython/menustrings.py:1070 ../gui/wxpython/lmgr/layertree.py:62
 msgid "Import vector data"
 msgstr "Importiere Vektordaten"
 #: ../gui/wxpython/gui_core/dialogs.py:1818 ../gui/wxpython/menustrings.py:165
-#: ../gui/wxpython/menustrings.py:1157 ../gui/wxpython/lmgr/layertree.py:58
+#: ../gui/wxpython/menustrings.py:1174 ../gui/wxpython/lmgr/layertree.py:58
 msgid "Link external raster data"
 msgstr "Einbindung externer Rasterdaten"
 #: ../gui/wxpython/gui_core/dialogs.py:1820 ../gui/wxpython/menustrings.py:30
-#: ../gui/wxpython/menustrings.py:1022 ../gui/wxpython/lmgr/layertree.py:56
+#: ../gui/wxpython/menustrings.py:1039 ../gui/wxpython/lmgr/layertree.py:56
 msgid "Import raster data"
 msgstr "Importiere Rasterdaten"
@@ -1702,7 +1734,9 @@
 #: ../gui/wxpython/gui_core/preferences.py:305
 msgid "Automatically copy selected text to clipboard (in Command console)"
-msgstr "Kopiere selektierten Text automatisch in die Zwischenablage (in der Kommandozeile)"
+msgstr ""
+"Kopiere selektierten Text automatisch in die Zwischenablage (in der "
+"Kommandozeile)"
 #: ../gui/wxpython/gui_core/preferences.py:320
 msgid "Workspace settings"
@@ -1721,8 +1755,12 @@
 msgstr "Speichere das aktuelle Fensterlayout als Standard"
 #: ../gui/wxpython/gui_core/preferences.py:353
-msgid "Save current position and size of Layer Manager window and opened Map Display window(s) and use as default for next sessions."
-msgstr "Speichere die aktuelle Position und Größe des 'Layer Manager'-Fensters und der geöffneten Kartenfenster als Standardwerte für die nächste Sitzung."
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+"Speichere die aktuelle Position und Größe des 'Layer Manager'-Fensters und "
+"der geöffneten Kartenfenster als Standardwerte für die nächste Sitzung."
 #: ../gui/wxpython/gui_core/preferences.py:372
 #: ../gui/wxpython/nviz/tools.py:96
@@ -1816,7 +1854,9 @@
 #: ../gui/wxpython/gui_core/preferences.py:684
 #: ../gui/wxpython/mapdisp/statusbar.py:527
 msgid "Constrain display resolution to computational settings"
-msgstr "Beschränke die Auflösung des Kartenfensters auf die Einstellungen des Arbeitsbereichs."
+msgstr ""
+"Beschränke die Auflösung des Kartenfensters auf die Einstellungen des "
+"Arbeitsbereichs."
 #: ../gui/wxpython/gui_core/preferences.py:697
 msgid "Enable auto-rendering"
@@ -1976,15 +2016,20 @@
 #: ../gui/wxpython/gui_core/preferences.py:1207
 msgid ""
 "\n"
-"Note: This only controls the coordinates displayed in the lower-left of the Map Display\n"
-"window's status bar. It is purely cosmetic and does not affect the working location's\n"
-"projection in any way. You will need to enable the Projection check box in the drop-down\n"
+"Note: This only controls the coordinates displayed in the lower-left of the "
+"Map Display\n"
+"window's status bar. It is purely cosmetic and does not affect the working "
+"location's\n"
+"projection in any way. You will need to enable the Projection check box in "
+"the drop-down\n"
 "menu located at the bottom of the Map Display window.\n"
 msgstr ""
 "\n"
 "Beachte: Dies beeinflusst nur die Koordinaten angezeigt in der Map Display-\n"
-"Statusleiste. Dies ist nur kosmetisch und beeinflusst nicht die Projektion der aktuellen\n"
-"Location. Aktiviere die Projektion-Checkbox im Drop down-Menue am unteren Ende des Map Display-Fensters.\n"
+"Statusleiste. Dies ist nur kosmetisch und beeinflusst nicht die Projektion "
+"der aktuellen\n"
+"Location. Aktiviere die Projektion-Checkbox im Drop down-Menue am unteren "
+"Ende des Map Display-Fensters.\n"
 #: ../gui/wxpython/gui_core/preferences.py:1222
 #: ../gui/wxpython/location_wizard/wizard.py:1319
@@ -2000,8 +2045,12 @@
 msgstr "EPSG Datei:"
 #: ../gui/wxpython/gui_core/preferences.py:1270
-msgid "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string directly."
-msgstr "Lade EPSG-Codes. Eingabe des EPSG-Code oder direkte Eingabe des Proj.4-String."
+msgid ""
+"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
+"directly."
+msgstr ""
+"Lade EPSG-Codes. Eingabe des EPSG-Code oder direkte Eingabe des Proj.4-"
+"String."
 #: ../gui/wxpython/gui_core/preferences.py:1278
 msgid "&Load EPSG codes"
@@ -2061,7 +2110,8 @@
 "    - You may only write to the current mapset.\n"
 "    - You may only write to mapsets which you own."
 msgstr ""
-"Selektiere ein Mapset, um es zugänglich zu machen und deselektiere es, um es zu verbergen. \n"
+"Selektiere ein Mapset, um es zugänglich zu machen und deselektiere es, um es "
+"zu verbergen. \n"
 "  Bemerkungen:\n"
 "    - Das aktuelle Mapset ist immer zugänglich.\n"
 "    - Sie können nur in der selektierten Mapset speichern.\n"
@@ -2108,8 +2158,12 @@
 msgstr "log. Datei"
 #: ../gui/wxpython/gui_core/goutput.py:154
-msgid "Toggle to save list of executed commands into a file; content saved when switching off."
-msgstr "Umschalten, um ausgeführte Befehle in Datei zu speichern. Inhalt wird beim Ausschalten gespeichert."
+msgid ""
+"Toggle to save list of executed commands into a file; content saved when "
+"switching off."
+msgstr ""
+"Umschalten, um ausgeführte Befehle in Datei zu speichern. Inhalt wird beim "
+"Ausschalten gespeichert."
 #: ../gui/wxpython/gui_core/goutput.py:377
 #: ../gui/wxpython/gui_core/goutput.py:464
@@ -2165,8 +2219,8 @@
 msgid "Command log saved to '%s'"
 msgstr "Befehlsausgabe in '%s' gespeichert"
-#: ../gui/wxpython/gui_core/ghelp.py:47 ../gui/wxpython/menustrings.py:1017
-#: ../gui/wxpython/menustrings.py:1018
+#: ../gui/wxpython/gui_core/ghelp.py:47 ../gui/wxpython/menustrings.py:1034
+#: ../gui/wxpython/menustrings.py:1035
 msgid "About GRASS GIS"
 msgstr "Über GRASS GIS"
@@ -2335,8 +2389,8 @@
 #: ../gui/wxpython/gui_core/simplelmgr.py:417
 #: ../gui/wxpython/rlisetup/frame.py:130
-#: ../gui/wxpython/gmodeler/frame.py:1283 ../gui/wxpython/menustrings.py:925
-#: ../gui/wxpython/menustrings.py:1837
+#: ../gui/wxpython/gmodeler/frame.py:1283 ../gui/wxpython/menustrings.py:942
+#: ../gui/wxpython/menustrings.py:1871
 #: ../gui/wxpython/animation/dialogs.py:631
 #: ../gui/wxpython/animation/dialogs.py:822
 #: ../gui/wxpython/lmgr/layertree.py:396
@@ -2392,8 +2446,12 @@
 #: ../gui/wxpython/dbmgr/base.py:154
 #, python-format
-msgid "Attribute table <%s> not found. For creating the table switch to 'Manage layers' tab."
-msgstr "Attributtabelle <%s> nicht gefunden. Um die Tabelle zu erstellen wechseln Sie in das Register 'Layer verwalten'."
+msgid ""
+"Attribute table <%s> not found. For creating the table switch to 'Manage "
+"layers' tab."
+msgstr ""
+"Attributtabelle <%s> nicht gefunden. Um die Tabelle zu erstellen wechseln "
+"Sie in das Register 'Layer verwalten'."
 #: ../gui/wxpython/dbmgr/base.py:165
 #, python-format
@@ -2426,16 +2484,21 @@
 #: ../gui/wxpython/dbmgr/base.py:310
 msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
-msgstr "Kann den Wert nicht dekodieren. Stellen Sie die Kodierung in den GUI Einstellungen ('Attribute') ein."
+msgstr ""
+"Kann den Wert nicht dekodieren. Stellen Sie die Kodierung in den GUI "
+"Einstellungen ('Attribute') ein."
 #: ../gui/wxpython/dbmgr/base.py:319
 #, python-format
 msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to convert value '%(val)s' in key column (%(key)s) to integer.\n"
+"Error loading attribute data. Record number: %(rec)d. Unable to convert "
+"value '%(val)s' in key column (%(key)s) to integer.\n"
 "\n"
 "Details: %(detail)s"
 msgstr ""
-"Fehler beim Laden der Attributdaten. Datensatz Nummer: %(rec)d. Kann den Wert '%(val)s' in der Schlüsselspalte (%(key)s) nicht nach integer umwandeln.\n"
+"Fehler beim Laden der Attributdaten. Datensatz Nummer: %(rec)d. Kann den "
+"Wert '%(val)s' in der Schlüsselspalte (%(key)s) nicht nach integer "
+"umwandeln.\n"
 "\n"
 "Einzelheiten: %(detail)s"
@@ -2504,7 +2567,9 @@
 #: ../gui/wxpython/dbmgr/base.py:907
 msgid "Unable to add column to the table. No column name defined."
-msgstr "Kann Die Spalte der Tabelle nicht hinzufügen. Es wurde kein Spaltenname definiert."
+msgstr ""
+"Kann Die Spalte der Tabelle nicht hinzufügen. Es wurde kein Spaltenname "
+"definiert."
 #: ../gui/wxpython/dbmgr/base.py:920
 #, python-format
@@ -2626,8 +2691,12 @@
 #: ../gui/wxpython/dbmgr/base.py:1508
 #, python-format
-msgid "Selected data records (%d) will be permanently deleted from table. Do you want to delete them?"
-msgstr "Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
+msgid ""
+"Selected data records (%d) will be permanently deleted from table. Do you "
+"want to delete them?"
+msgstr ""
+"Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. "
+"Wollen Sie diese Datensätze löschen?"
 #: ../gui/wxpython/dbmgr/base.py:1511 ../gui/wxpython/dbmgr/base.py:1557
 msgid "Delete records"
@@ -2635,8 +2704,12 @@
 #: ../gui/wxpython/dbmgr/base.py:1554
 #, python-format
-msgid "All data records (%d) will be permanently deleted from table. Do you want to delete them?"
-msgstr "Alle Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
+msgid ""
+"All data records (%d) will be permanently deleted from table. Do you want to "
+"delete them?"
+msgstr ""
+"Alle Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen "
+"Sie diese Datensätze löschen?"
 #: ../gui/wxpython/dbmgr/base.py:1728
 msgid "Nothing to extract."
@@ -2699,8 +2772,8 @@
 msgid "Add"
 msgstr "Hinzufügen"
-#: ../gui/wxpython/dbmgr/base.py:2078 ../gui/wxpython/menustrings.py:909
-#: ../gui/wxpython/menustrings.py:1821
+#: ../gui/wxpython/dbmgr/base.py:2078 ../gui/wxpython/menustrings.py:926
+#: ../gui/wxpython/menustrings.py:1855
 msgid "Rename column"
 msgstr "Spalte umbenennen"
@@ -2718,13 +2791,21 @@
 #: ../gui/wxpython/dbmgr/base.py:2206
 #, python-format
-msgid "Unable to rename column <%(column)s> to <%(columnTo)s>. Column already exists in the table <%(table)s>."
-msgstr "Kann die Spalte <%(column)s> nicht in <%(columnTo)s> umbenennen. Spalte existiert bereits in der Tabelle <%(table)s>."
+msgid ""
+"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
+"exists in the table <%(table)s>."
+msgstr ""
+"Kann die Spalte <%(column)s> nicht in <%(columnTo)s> umbenennen. Spalte "
+"existiert bereits in der Tabelle <%(table)s>."
 #: ../gui/wxpython/dbmgr/base.py:2222
 #, python-format
-msgid "Unable to rename column. Column <%(column)s> doesn't exist in the table <%(table)s>."
-msgstr "Kann die Spalte nicht umbenennen. Die Spalte <%(column)s> existiert nicht in der Tabelle <%(table)s>."
+msgid ""
+"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
+"%(table)s>."
+msgstr ""
+"Kann die Spalte nicht umbenennen. Die Spalte <%(column)s> existiert nicht in "
+"der Tabelle <%(table)s>."
 #: ../gui/wxpython/dbmgr/base.py:2249
 msgid "Drop selected column"
@@ -2736,8 +2817,12 @@
 #: ../gui/wxpython/dbmgr/base.py:2281
-msgid "Selected column %s will PERMANENTLY removed from table. Do you want to drop the column?"
-msgstr "Selektierte Spalte '%s' wird unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Spalte löschen?"
+msgid ""
+"Selected column %s will PERMANENTLY removed from table. Do you want to drop "
+"the column?"
+msgstr ""
+"Selektierte Spalte '%s' wird unwiderruflich aus der Tabelle gelöscht. Wollen "
+"Sie diese Spalte löschen?"
 #: ../gui/wxpython/dbmgr/base.py:2284 ../gui/wxpython/dbmgr/base.py:2321
 msgid "Drop column(s)"
@@ -2752,7 +2837,8 @@
 msgstr ""
 "Selektierte Spalten\n"
 "%s\n"
-"werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Spalten löschen?"
+"werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Spalten "
+"löschen?"
 #: ../gui/wxpython/dbmgr/base.py:2406
 msgid "List of layers"
@@ -2866,17 +2952,25 @@
 #: ../gui/wxpython/dbmgr/base.py:3155
 msgid "Unable to create new table. Table name or key column name is missing."
-msgstr "Kann keine neue Tabelle anlegen. Tabellenname oder Name der Schlüsselspalte fehlen."
+msgstr ""
+"Kann keine neue Tabelle anlegen. Tabellenname oder Name der Schlüsselspalte "
+"fehlen."
 #: ../gui/wxpython/dbmgr/base.py:3161
 #, python-format
 msgid "Unable to create new table. Table <%s> already exists in the database."
-msgstr "Kann neue Tabelle nicht anlegen. Die Tabelle <%s> existiert bereits in der Datenbank."
+msgstr ""
+"Kann neue Tabelle nicht anlegen. Die Tabelle <%s> existiert bereits in der "
+"Datenbank."
 #: ../gui/wxpython/dbmgr/base.py:3199
 #, python-format
-msgid "Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already exists."
-msgstr "Kann der Vektorkarte <%(vector)s> keinen neuen Layer hinzufügen. Der Layer %(layer)d existiert bereits."
+msgid ""
+"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
+"exists."
+msgstr ""
+"Kann der Vektorkarte <%(vector)s> keinen neuen Layer hinzufügen. Der Layer "
+"%(layer)d existiert bereits."
 #: ../gui/wxpython/dbmgr/manager.py:70
 #, fuzzy
@@ -2889,8 +2983,13 @@
 #: ../gui/wxpython/dbmgr/manager.py:85
 #, python-format
-msgid "Database connection for vector map <%s> is not defined in DB file. You can define new connection in 'Manage layers' tab."
-msgstr "Die Datenbankverbindung der Vektorkarte <%s> ist nicht in der DB-Datei definiert. Sie können eine neue Verbindung in dem Register 'Layer verwalten' definieren."
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. You can "
+"define new connection in 'Manage layers' tab."
+msgstr ""
+"Die Datenbankverbindung der Vektorkarte <%s> ist nicht in der DB-Datei "
+"definiert. Sie können eine neue Verbindung in dem Register 'Layer verwalten' "
+"definieren."
 #: ../gui/wxpython/dbmgr/manager.py:90
 msgid "Please wait, loading attribute data..."
@@ -2916,8 +3015,8 @@
 msgid "Reload attribute data (selected layer only)"
 msgstr "Neuladen der Attributdaten (nur ausgewählte Ebene)"
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:100 ../gui/wxpython/menustrings.py:891
-#: ../gui/wxpython/menustrings.py:1803
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:100 ../gui/wxpython/menustrings.py:908
+#: ../gui/wxpython/menustrings.py:1837
 msgid "Query"
 msgstr "Abfrage"
@@ -3044,11 +3143,13 @@
 msgid ""
 "No attribute table found.\n"
 "\n"
-"Do you want to create a new attribute table and defined a link to vector map <%s>?"
+"Do you want to create a new attribute table and defined a link to vector map "
+"<%s>?"
 msgstr ""
 "Keine Attributtabelle gefunden.\n"
 "\n"
-"Möchten Sie eine neue Attributtabelle und einen Link zur Vektorkarte <%s>  erzeugen?"
+"Möchten Sie eine neue Attributtabelle und einen Link zur Vektorkarte <%s>  "
+"erzeugen?"
 #: ../gui/wxpython/dbmgr/dialogs.py:77
 msgid "Create table?"
@@ -3062,8 +3163,8 @@
 msgid "No attributes found"
 msgstr "Keine Attribute gefunden"
-#: ../gui/wxpython/dbmgr/dialogs.py:115 ../gui/wxpython/menustrings.py:680
-#: ../gui/wxpython/menustrings.py:1592
+#: ../gui/wxpython/dbmgr/dialogs.py:115 ../gui/wxpython/menustrings.py:697
+#: ../gui/wxpython/menustrings.py:1626
 msgid "Update attributes"
 msgstr "Attribute aktualisieren"
@@ -3090,7 +3191,8 @@
 #: ../gui/wxpython/dbmgr/dialogs.py:226
 #, python-format
 msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
-msgstr "Spalte <%(col)s>: Wert '%(value)s' muss als %(type)s eingegeben werden."
+msgstr ""
+"Spalte <%(col)s>: Wert '%(value)s' muss als %(type)s eingegeben werden."
 #: ../gui/wxpython/dbmgr/dialogs.py:434
 msgid "Unknown"
@@ -3254,8 +3356,12 @@
 #: ../gui/wxpython/location_wizard/wizard.py:160
 #, python-format
-msgid "Name <%(name)s> is not a valid name for location. Please use only ASCII characters excluding %(chars)s and space."
-msgstr "Der Name <%(name)s> ist kein gültiger Name für Locations. Bitte verwenden Sie nur ASCII-Zeichen ohne %(chars)s und Leerzeichen."
+msgid ""
+"Name <%(name)s> is not a valid name for location. Please use only ASCII "
+"characters excluding %(chars)s and space."
+msgstr ""
+"Der Name <%(name)s> ist kein gültiger Name für Locations. Bitte verwenden "
+"Sie nur ASCII-Zeichen ohne %(chars)s und Leerzeichen."
 #: ../gui/wxpython/location_wizard/wizard.py:163
 msgid "Invalid location name"
@@ -3275,8 +3381,12 @@
 msgstr "Kann die Location nicht erzeugen"
 #: ../gui/wxpython/location_wizard/wizard.py:206
-msgid "Title of the location is limited only to one line and 256 characters. The rest of the text will be ignored."
-msgstr "Der Titel der Location ist auf eine Zeile und 256 Zeichen beschränkt. Der Rest des Textes wird ignoriert."
+msgid ""
+"Title of the location is limited only to one line and 256 characters. The "
+"rest of the text will be ignored."
+msgstr ""
+"Der Titel der Location ist auf eine Zeile und 256 Zeichen beschränkt. Der "
+"Rest des Textes wird ignoriert."
 #: ../gui/wxpython/location_wizard/wizard.py:213
 msgid "Choose method for creating a new location"
@@ -3292,16 +3402,20 @@
 #: ../gui/wxpython/location_wizard/wizard.py:225
 msgid "Read projection and datum terms from a georeferenced data file"
-msgstr "Einlesen von Projektions- und Datumsinformationen aus georeferenzierter Datei"
+msgstr ""
+"Einlesen von Projektions- und Datumsinformationen aus georeferenzierter Datei"
 #: ../gui/wxpython/location_wizard/wizard.py:228
 #, fuzzy
 msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
-msgstr "Einlesen von Projektions- und Datumsinformationen aus WKT oder PRJ Datei"
+msgstr ""
+"Einlesen von Projektions- und Datumsinformationen aus WKT oder PRJ Datei"
 #: ../gui/wxpython/location_wizard/wizard.py:231
 msgid "Specify projection and datum terms using custom PROJ.4 parameters"
-msgstr "Angabe von Projektions- und Datumsinformationen über anwendungsspezifische PROJ.4 Parameter"
+msgstr ""
+"Angabe von Projektions- und Datumsinformationen über anwendungsspezifische "
+"PROJ.4 Parameter"
 #: ../gui/wxpython/location_wizard/wizard.py:234
 msgid "Create a generic Cartesian coordinate system (XY)"
@@ -3440,7 +3554,8 @@
 #: ../gui/wxpython/location_wizard/wizard.py:1518
 msgid "Choose method of specifying georeferencing parameters"
-msgstr "Wählen Sie eine Methode, um die Parameter der Georeferenzierung zuwählen"
+msgstr ""
+"Wählen Sie eine Methode, um die Parameter der Georeferenzierung zuwählen"
 #: ../gui/wxpython/location_wizard/wizard.py:1526
 msgid "Enter PROJ.4 parameters string:"
@@ -3511,7 +3626,8 @@
 #: ../gui/wxpython/location_wizard/wizard.py:1934
 msgid "Location wizard canceled. Location not created."
-msgstr "Location-Assistent wurde abgebrochen. Die Location wurde nicht erzeugt."
+msgstr ""
+"Location-Assistent wurde abgebrochen. Die Location wurde nicht erzeugt."
 #: ../gui/wxpython/location_wizard/wizard.py:2057
 msgid "Unable to create new location"
@@ -3519,8 +3635,12 @@
 #: ../gui/wxpython/location_wizard/wizard.py:2076
 #, python-format
-msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will need to change the default GIS data directory in the GRASS startup screen."
-msgstr "Die Location <%(loc)s> wird im GIS-Verzeichnis <%(dir)s> angelegt. Sie müssen das Standard GIS-Verzeichnis auf dem GRASS Startbildschirm anpassen."
+msgid ""
+"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
+"need to change the default GIS data directory in the GRASS startup screen."
+msgstr ""
+"Die Location <%(loc)s> wird im GIS-Verzeichnis <%(dir)s> angelegt. Sie "
+"müssen das Standard GIS-Verzeichnis auf dem GRASS Startbildschirm anpassen."
 #: ../gui/wxpython/location_wizard/wizard.py:2081
 msgid "New GIS data directory"
@@ -3633,8 +3753,8 @@
 msgid "Remove a configuration file"
 msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:133 ../gui/wxpython/menustrings.py:921
-#: ../gui/wxpython/menustrings.py:1833
+#: ../gui/wxpython/rlisetup/frame.py:133 ../gui/wxpython/menustrings.py:938
+#: ../gui/wxpython/menustrings.py:1867
 msgid "Create"
 msgstr "Erzeuge"
@@ -3644,8 +3764,8 @@
 msgstr "Neue Location erzeugen?"
 #: ../gui/wxpython/rlisetup/frame.py:136 ../gui/wxpython/menustrings.py:180
-#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1172
-#: ../gui/wxpython/menustrings.py:1835 ../gui/wxpython/lmgr/layertree.py:402
+#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1189
+#: ../gui/wxpython/menustrings.py:1869 ../gui/wxpython/lmgr/layertree.py:402
 msgid "Rename"
 msgstr "Umbenennen"
@@ -3680,7 +3800,9 @@
 #: ../gui/wxpython/rlisetup/frame.py:241
 #, python-format
-msgid "Set te new name for %s \"                                            \"configuration file"
+msgid ""
+"Set te new name for %s \"                                            "
+"\"configuration file"
 msgstr ""
 #: ../gui/wxpython/rlisetup/frame.py:243
@@ -3706,7 +3828,8 @@
 #: ../gui/wxpython/rlisetup/wizard.py:135
 #, fuzzy
 msgid "r.li.setup wizard canceled. Configuration file not created."
+msgstr ""
 #: ../gui/wxpython/rlisetup/wizard.py:434
 #, fuzzy
@@ -3785,7 +3908,7 @@
 msgstr "Karteneinheiten"
 #: ../gui/wxpython/rlisetup/wizard.py:742 ../gui/wxpython/menustrings.py:336
-#: ../gui/wxpython/menustrings.py:1248
+#: ../gui/wxpython/menustrings.py:1265
 msgid "Moving window"
 msgstr "Moving window"
@@ -4154,7 +4277,8 @@
 "Map frame position changed, old value: %(old1)s %(old2)s\n"
 "new value: %(new1)s %(new2)s"
 msgstr ""
-"Position des Kartenausschnitts hat sich geändert, alter Wert: %(old1)s %(old2)s\n"
+"Position des Kartenausschnitts hat sich geändert, alter Wert: %(old1)s "
+"%(old2)s\n"
 "neuer Wert: %(new1)s %(new2)s"
 #: ../gui/wxpython/psmap/instructions.py:644
@@ -4163,7 +4287,8 @@
 "Map frame size changed, old value: %(old1)s %(old2)s\n"
 msgstr ""
-"Größe des Kartenausschnitts hat sich geändert, alter Wert: %(old1)s %(old2)s\n"
+"Größe des Kartenausschnitts hat sich geändert, alter Wert: %(old1)s "
+"%(old2)s\n"
 #: ../gui/wxpython/psmap/instructions.py:691
@@ -4183,43 +4308,52 @@
 #: ../gui/wxpython/psmap/instructions.py:818
 #: ../gui/wxpython/psmap/instructions.py:1700
 #, python-format
-msgid "Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
-msgstr "Zeichen in der Position %s werden nicht von der Zeichenkodierung ISO-8859-1 (Latin 1), welche vom Modul benötigt wird, unterstützt."
+msgid ""
+"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
+"which is required by module ps.map."
+msgstr ""
+"Zeichen in der Position %s werden nicht von der Zeichenkodierung ISO-8859-1 "
+"(Latin 1), welche vom Modul benötigt wird, unterstützt."
 #: ../gui/wxpython/psmap/instructions.py:822
 #: ../gui/wxpython/psmap/instructions.py:1704
-msgid "Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
-msgstr "Nicht alle Zeichen werden von der Zeichenkodierung ISO-8859-1 (Latin 1), welche von dem Modul ps.map benötigt wird."
+msgid ""
+"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
+"required by module ps.map."
+msgstr ""
+"Nicht alle Zeichen werden von der Zeichenkodierung ISO-8859-1 (Latin 1), "
+"welche von dem Modul ps.map benötigt wird."
 #: ../gui/wxpython/psmap/instructions.py:938
 #, python-format
 msgid "Failed to read instruction %(inst)s: file %(file)s not found."
-msgstr "Lesen der Anweisungen %(inst)s fehlgeschlagen: Datei %(file)s nicht gefunden."
+msgstr ""
+"Lesen der Anweisungen %(inst)s fehlgeschlagen: Datei %(file)s nicht gefunden."
-#: ../gui/wxpython/psmap/toolbars.py:61 ../gui/wxpython/menustrings.py:1994
+#: ../gui/wxpython/psmap/toolbars.py:61 ../gui/wxpython/menustrings.py:2028
 msgid "Generate text file with mapping instructions"
 msgstr "Erzeuge Textdatei mit Anweisungen zur Kartographie"
-#: ../gui/wxpython/psmap/toolbars.py:63 ../gui/wxpython/menustrings.py:1992
+#: ../gui/wxpython/psmap/toolbars.py:63 ../gui/wxpython/menustrings.py:2026
 msgid "Load text file with mapping instructions"
 msgstr "Lade Textdatei mit Anweisungen zur Kartographie"
-#: ../gui/wxpython/psmap/toolbars.py:65 ../gui/wxpython/menustrings.py:1996
+#: ../gui/wxpython/psmap/toolbars.py:65 ../gui/wxpython/menustrings.py:2030
 msgid "Generate PostScript output"
 msgstr "Erzeuge PostScript-Ausgabe"
-#: ../gui/wxpython/psmap/toolbars.py:67 ../gui/wxpython/menustrings.py:1998
+#: ../gui/wxpython/psmap/toolbars.py:67 ../gui/wxpython/menustrings.py:2032
 msgid "Generate PDF output"
 msgstr "Erzeuge PDF-Ausgabe"
-#: ../gui/wxpython/psmap/toolbars.py:69 ../gui/wxpython/menustrings.py:1989
+#: ../gui/wxpython/psmap/toolbars.py:69 ../gui/wxpython/menustrings.py:2023
 #: ../gui/wxpython/modules/histogram.py:449
 #: ../gui/wxpython/mapdisp/frame.py:673 ../gui/wxpython/wxplot/base.py:560
 #: ../gui/wxpython/gcp/mapdisplay.py:412
 msgid "Page setup"
 msgstr "Seiteneinstellungen"
-#: ../gui/wxpython/psmap/toolbars.py:70 ../gui/wxpython/menustrings.py:1990
+#: ../gui/wxpython/psmap/toolbars.py:70 ../gui/wxpython/menustrings.py:2024
 msgid "Specify paper size, margins and orientation"
 msgstr "Papiergröße, Ränder und Ausrichtung angeben"
@@ -4232,7 +4366,7 @@
 msgstr "Auf die Gesamtausdehnung zoomen"
 #: ../gui/wxpython/psmap/toolbars.py:75 ../gui/wxpython/psmap/dialogs.py:619
-#: ../gui/wxpython/psmap/dialogs.py:674 ../gui/wxpython/menustrings.py:2004
+#: ../gui/wxpython/psmap/dialogs.py:674 ../gui/wxpython/menustrings.py:2038
 msgid "Map frame"
 msgstr "Kartenrahmen"
@@ -4240,7 +4374,7 @@
 msgid "Click and drag to place map frame"
 msgstr "Anklicken und verschieben, um Kartenrahmen zu platzieren"
-#: ../gui/wxpython/psmap/toolbars.py:78 ../gui/wxpython/menustrings.py:2023
+#: ../gui/wxpython/psmap/toolbars.py:78 ../gui/wxpython/menustrings.py:2057
 msgid "Delete selected object"
 msgstr "Lösche ausgewähltes Objekt"
@@ -4253,12 +4387,12 @@
 msgstr "Kartenlayout beenden"
 #: ../gui/wxpython/psmap/toolbars.py:84 ../gui/wxpython/psmap/dialogs.py:3705
-#: ../gui/wxpython/psmap/dialogs.py:3710 ../gui/wxpython/menustrings.py:2016
+#: ../gui/wxpython/psmap/dialogs.py:3710 ../gui/wxpython/menustrings.py:2050
 #: ../gui/wxpython/animation/dialogs.py:1196
 msgid "Text"
 msgstr "Text"
-#: ../gui/wxpython/psmap/toolbars.py:86 ../gui/wxpython/menustrings.py:2012
+#: ../gui/wxpython/psmap/toolbars.py:86 ../gui/wxpython/menustrings.py:2046
 msgid "Map info"
 msgstr "Karteninformation"
@@ -4267,19 +4401,19 @@
 msgid "Legend"
 msgstr "Legende"
-#: ../gui/wxpython/psmap/toolbars.py:90 ../gui/wxpython/menustrings.py:2014
+#: ../gui/wxpython/psmap/toolbars.py:90 ../gui/wxpython/menustrings.py:2048
 #: ../gui/wxpython/nviz/tools.py:1991
 msgid "Scale bar"
 msgstr "Maßstabsbalken"
 #: ../gui/wxpython/psmap/toolbars.py:92 ../gui/wxpython/psmap/dialogs.py:4061
-#: ../gui/wxpython/psmap/dialogs.py:4109 ../gui/wxpython/menustrings.py:2018
+#: ../gui/wxpython/psmap/dialogs.py:4109 ../gui/wxpython/menustrings.py:2052
 msgid "Image"
 msgstr "Bild"
 #: ../gui/wxpython/psmap/toolbars.py:94 ../gui/wxpython/psmap/dialogs.py:4494
-#: ../gui/wxpython/menustrings.py:2020 ../gui/wxpython/nviz/tools.py:1946
+#: ../gui/wxpython/menustrings.py:2054 ../gui/wxpython/nviz/tools.py:1946
 msgid "North Arrow"
 msgstr "Nordpfeil"
@@ -4535,7 +4669,7 @@
 msgid "Invalid scale or map center!"
 msgstr "Ungültiger Maßstab oder Kartenmitte"
-#: ../gui/wxpython/psmap/dialogs.py:1144 ../gui/wxpython/menustrings.py:2006
+#: ../gui/wxpython/psmap/dialogs.py:1144 ../gui/wxpython/menustrings.py:2040
 #: ../gui/wxpython/nviz/tools.py:652 ../gui/wxpython/nviz/mapwindow.py:1672
 #: ../gui/wxpython/lmgr/layertree.py:765
 msgid "Raster map"
@@ -4601,7 +4735,7 @@
 msgstr "Runter"
 #: ../gui/wxpython/psmap/dialogs.py:1315 ../gui/wxpython/menustrings.py:182
-#: ../gui/wxpython/menustrings.py:1174 ../gui/wxpython/menustrings.py:2022
+#: ../gui/wxpython/menustrings.py:1191 ../gui/wxpython/menustrings.py:2056
 #: ../gui/wxpython/nviz/tools.py:1098 ../gui/wxpython/nviz/tools.py:1976
 #: ../gui/wxpython/nviz/tools.py:2024
 msgid "Delete"
@@ -4653,7 +4787,7 @@
 msgstr "Liste der Kategorien (z.B. 1,3,5-7)"
 #: ../gui/wxpython/psmap/dialogs.py:1727 ../gui/wxpython/menustrings.py:331
-#: ../gui/wxpython/menustrings.py:1243 ../gui/wxpython/nviz/tools.py:789
+#: ../gui/wxpython/menustrings.py:1260 ../gui/wxpython/nviz/tools.py:789
 #: ../gui/wxpython/nviz/tools.py:2400
 msgid "Mask"
 msgstr "Maske"
@@ -4878,7 +5012,7 @@
 msgid "Choose vector maps and their order in legend"
 msgstr "Wähle Vektorkarten und ihre Reihenfolge in der Legende"
-#: ../gui/wxpython/psmap/dialogs.py:2617 ../gui/wxpython/menustrings.py:2008
+#: ../gui/wxpython/psmap/dialogs.py:2617 ../gui/wxpython/menustrings.py:2042
 #: ../gui/wxpython/nviz/tools.py:1177 ../gui/wxpython/lmgr/layertree.py:768
 msgid "Vector map"
 msgstr "Vektorkarte"
@@ -5213,7 +5347,9 @@
 #: ../gui/wxpython/psmap/frame.py:234
 msgid "Program ps2pdf is not available. Please install it first to create PDF."
-msgstr "Das Programm ps2pdf ist nicht vorhanden. Bitte installieren Sie es um PDFs zu erzeugen."
+msgstr ""
+"Das Programm ps2pdf ist nicht vorhanden. Bitte installieren Sie es um PDFs "
+"zu erzeugen."
 #: ../gui/wxpython/psmap/frame.py:278
 msgid "Generating PDF..."
@@ -5248,7 +5384,8 @@
 "\n"
 " %s"
 msgstr ""
-"Das Programm ps2pdf ist nicht vorhanden. Bitte installieren Sie es um PDFs zu erzeugen.\n"
+"zu erzeugen.\n"
 "\n"
 " %s"
@@ -5291,7 +5428,9 @@
 #: ../gui/wxpython/psmap/frame.py:1024
 msgid "Press button with green triangle icon to generate preview."
-msgstr "Bitte klicken Sie auf den Button mit dem grünen Dreieck um Vorschau zu erzeugen."
+msgstr ""
+"Bitte klicken Sie auf den Button mit dem grünen Dreieck um Vorschau zu "
+"erzeugen."
 #: ../gui/wxpython/psmap/frame.py:1048
 msgid "wxGUI Cartographic Composer"
@@ -5522,7 +5661,8 @@
 "\t\tDetails: %(detail)s\n"
 "\t\tLine: '%(line)s'\n"
 msgstr ""
-"Fehler: Das Lesen der Einstellungen aus Datei <%(file)s> ist fehlgeschlagen.\n"
+"Fehler: Das Lesen der Einstellungen aus Datei <%(file)s> ist "
+"fehlgeschlagen.\n"
 "\t\tEinzelheiten: %(detail)s\n"
 "\t\tZeile: '%(line)s'\n"
@@ -5595,7 +5735,8 @@
 "Kann den Befehl nicht ausführen:\n"
 "%(cmd)s\n"
 "\n"
-"Option <%(opt)s>: Das Lesen von der Standardeingabe wird vom wxGUI nicht unterstützt"
+"Option <%(opt)s>: Das Lesen von der Standardeingabe wird vom wxGUI nicht "
+"unterstützt"
 #: ../gui/wxpython/core/gconsole.py:606
 #, python-format
@@ -5608,8 +5749,11 @@
 msgstr "%(min)d Min %(sec)d Sek"
 #: ../gui/wxpython/core/gconsole.py:617
-msgid "Please note that the data are left in inconsistent state and may be corrupted"
-msgstr "Daten wurden in einem inkonsistenten Zustand zurückgelassen und können beschädigt sein"
+msgid ""
+"Please note that the data are left in inconsistent state and may be corrupted"
+msgstr ""
+"Daten wurden in einem inkonsistenten Zustand zurückgelassen und können "
+"beschädigt sein"
 #: ../gui/wxpython/core/gconsole.py:619
 msgid "Command aborted"
@@ -5632,7 +5776,8 @@
 "\n"
 "Number of skipped lines: %(line)d"
 msgstr ""
-"Einige Zeilen wurden beim Lesen der Einstellungen aus Datei <%(file)s> übersprungen.\n"
+"Einige Zeilen wurden beim Lesen der Einstellungen aus Datei <%(file)s> "
+"übersprungen.\n"
 "Siehe 'Befehlsausgabe' Fenster für Einzelheiten.\n"
 "\n"
 "Anzahl übersprungener Zeilen: %(line)d"
@@ -5669,12 +5814,15 @@
 #: ../gui/wxpython/core/render.py:447
 msgid "GISBASE not set. You must be in GRASS GIS to run this program."
-msgstr "GISBASE wurde nicht gesetzt. Sie müssen in GRASS GIS sein, um dieses Programm auszuführen."
+msgstr ""
+"GISBASE wurde nicht gesetzt. Sie müssen in GRASS GIS sein, um dieses "
+"Programm auszuführen."
 #: ../gui/wxpython/core/render.py:492
 #, python-format
 msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
-msgstr "Fehler: Unable to open '%(file)s'. Begründung: %(ret)s. wxGUI exited.\n"
+msgstr ""
+"Fehler: Unable to open '%(file)s'. Begründung: %(ret)s. wxGUI exited.\n"
 #: ../gui/wxpython/core/render.py:500
@@ -5704,8 +5852,13 @@
 msgstr "Kann nicht auf die Rasterkarte <%s> zoomen."
 #: ../gui/wxpython/core/render.py:689
-msgid "Unable to get current geographic extent. Force quiting wxGUI. Please manually run g.region to fix the problem."
-msgstr "Kann die aktuelle geographische Ausdehnung nicht ermitteln. Erzwinge das Schließen von wxGUI. Führen Sie bitte g.region manuell aus, um das Problem zu beheben."
+msgid ""
+"Unable to get current geographic extent. Force quiting wxGUI. Please "
+"manually run g.region to fix the problem."
+msgstr ""
+"Kann die aktuelle geographische Ausdehnung nicht ermitteln. Erzwinge das "
+"Schließen von wxGUI. Führen Sie bitte g.region manuell aus, um das Problem "
+"zu beheben."
 #: ../gui/wxpython/core/render.py:1006
 #, python-format
@@ -5920,13 +6073,13 @@
 msgid "Label and comment"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:199
+#: ../gui/wxpython/gmodeler/dialogs.py:198
 #: ../gui/wxpython/gmodeler/frame.py:1345
 #, fuzzy
 msgid "Label:"
 msgstr "Label"
-#: ../gui/wxpython/gmodeler/dialogs.py:203
+#: ../gui/wxpython/gmodeler/dialogs.py:202
 #: ../gui/wxpython/gmodeler/frame.py:734
 #: ../gui/wxpython/gmodeler/frame.py:1357
 #, fuzzy
@@ -6038,7 +6191,8 @@
 #: ../gui/wxpython/gmodeler/dialogs.py:700
 #, python-format
 msgid "Variable <%s> already exists in the model. Adding variable failed."
-msgstr "Variable <%s> ist im Modell bereits vorhanden. Hinzufügen nicht erfolgreich."
+msgstr ""
+"Variable <%s> ist im Modell bereits vorhanden. Hinzufügen nicht erfolgreich."
 #: ../gui/wxpython/gmodeler/dialogs.py:729
 msgid "Do you want to delete all variables from the model?"
@@ -6060,7 +6214,7 @@
 msgstr "Alle löschen"
 #: ../gui/wxpython/gmodeler/preferences.py:29
-#: ../gui/wxpython/menustrings.py:1957
+#: ../gui/wxpython/menustrings.py:1991
 msgid "Modeler settings"
 msgstr "Modeler-Einstellungen"
@@ -6120,7 +6274,7 @@
 msgstr "Befehle"
 #: ../gui/wxpython/gmodeler/preferences.py:508
-#: ../gui/wxpython/menustrings.py:1973
+#: ../gui/wxpython/menustrings.py:2007
 msgid "Model properties"
 msgstr "Modell-Eigenschaften"
@@ -6206,8 +6360,12 @@
 #: ../gui/wxpython/gmodeler/frame.py:347 ../gui/wxpython/gmodeler/frame.py:473
-msgid "Current model is not empty. Do you want to store current settings to model file?"
-msgstr "Aktuelles Modell ist nicht leer. Wollen sie die aktuellen Einstellungen in eine Modell-Datei speichern?"
+msgid ""
+"Current model is not empty. Do you want to store current settings to model "
+"file?"
+msgstr ""
+"Aktuelles Modell ist nicht leer. Wollen sie die aktuellen Einstellungen in "
+"eine Modell-Datei speichern?"
 #: ../gui/wxpython/gmodeler/frame.py:350 ../gui/wxpython/gmodeler/frame.py:476
 msgid "Create new model?"
@@ -6230,9 +6388,10 @@
 #: ../gui/wxpython/gmodeler/frame.py:413 ../gui/wxpython/gmodeler/frame.py:450
 #, python-format
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
-msgstr "Modell-Datei <%s> existiert bereits. Wollen Sie diese Datei überschreiben?"
+msgstr ""
+"Modell-Datei <%s> existiert bereits. Wollen Sie diese Datei überschreiben?"
-#: ../gui/wxpython/gmodeler/frame.py:416 ../gui/wxpython/menustrings.py:1944
+#: ../gui/wxpython/gmodeler/frame.py:416 ../gui/wxpython/menustrings.py:1978
 msgid "Save model"
 msgstr "Speichere Modell"
@@ -6273,14 +6432,16 @@
 #: ../gui/wxpython/mapdisp/frame.py:585 ../gui/wxpython/gcp/mapdisplay.py:383
 #: ../gui/wxpython/mapswipe/frame.py:515
 msgid "Choose a file name to save the image (no need to add extension)"
-msgstr "Wähle einen Dateinamen, um Bild zu speichern (Anfügen einer Extension nicht erforderlich)"
+msgstr ""
+"Wähle einen Dateinamen, um Bild zu speichern (Anfügen einer Extension nicht "
+"erforderlich)"
 #: ../gui/wxpython/gmodeler/frame.py:598 ../gui/wxpython/gmodeler/frame.py:605
 #, python-format
 msgid "Model exported to <%s>"
 msgstr "Modell exportiert in <%s>"
-#: ../gui/wxpython/gmodeler/frame.py:734 ../gui/wxpython/menustrings.py:1969
+#: ../gui/wxpython/gmodeler/frame.py:734 ../gui/wxpython/menustrings.py:2003
 #, fuzzy
 msgid "Add comment"
 msgstr "Befehlsebene hinzufügen"
@@ -6310,7 +6471,9 @@
 #: ../gui/wxpython/gmodeler/frame.py:941
 msgid "Writing current settings to model file failed."
-msgstr "Das Schreiben der aktuellen Einstellungen in die Modell-Datei nicht erfolgreich."
+msgstr ""
+"Das Schreiben der aktuellen Einstellungen in die Modell-Datei nicht "
+"erfolgreich."
 #: ../gui/wxpython/gmodeler/frame.py:951 ../gui/wxpython/lmgr/frame.py:1399
 #, python-format
@@ -6450,15 +6613,19 @@
 msgstr "Speichere Datei"
 #: ../gui/wxpython/gmodeler/frame.py:1788
-msgid "Python script is locally modificated. Refresh will discard all changes. Do you really want to continue?"
-msgstr "Python-Skript wurde lokal geändert. Aktualisierung wird die Änderungen überschreiben. Wollen Sie wirklich fortfahren?"
+msgid ""
+"Python script is locally modificated. Refresh will discard all changes. Do "
+"you really want to continue?"
+msgstr ""
+"Python-Skript wurde lokal geändert. Aktualisierung wird die Änderungen "
+"überschreiben. Wollen Sie wirklich fortfahren?"
 #: ../gui/wxpython/gmodeler/frame.py:1791
 msgid "Update"
 msgstr "Update"
-#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:1938
-#: ../gui/wxpython/menustrings.py:1988
+#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:1972
+#: ../gui/wxpython/menustrings.py:2022
 msgid "&File"
 msgstr "&Datei"
@@ -6466,7 +6633,7 @@
 msgid "Workspace"
 msgstr "Projekt"
-#: ../gui/wxpython/menustrings.py:5 ../gui/wxpython/menustrings.py:1939
+#: ../gui/wxpython/menustrings.py:5 ../gui/wxpython/menustrings.py:1973
 #: ../gui/wxpython/nviz/tools.py:1094
 msgid "New"
 msgstr "Neu"
@@ -6475,7 +6642,7 @@
 msgid "Create new workspace"
 msgstr "Erzeuge neues Projekt"
-#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:1941
+#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:1975
 msgid "Open"
 msgstr "Öffnen"
@@ -6483,7 +6650,7 @@
 msgid "Load workspace from file"
 msgstr "Lade Projekt aus einer Datei"
-#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/menustrings.py:1943
+#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/menustrings.py:1977
 #: ../gui/wxpython/modules/colorrules.py:416
 msgid "Save"
 msgstr "Speichern"
@@ -6493,7 +6660,7 @@
 msgid "Save workspace"
 msgstr "Speichere Projekt"
-#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:1945
+#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:1979
 msgid "Save as"
 msgstr "Speichern unter"
@@ -6501,7 +6668,7 @@
 msgid "Save workspace to file"
 msgstr "Speichere Projekt in Datei"
-#: ../gui/wxpython/menustrings.py:13 ../gui/wxpython/menustrings.py:1947
+#: ../gui/wxpython/menustrings.py:13 ../gui/wxpython/menustrings.py:1981
 #: ../gui/wxpython/mapswipe/dialogs.py:162
 msgid "Close"
 msgstr "Schließen"
@@ -6544,7 +6711,8 @@
 #: ../gui/wxpython/menustrings.py:23
 msgid "Add multiple raster or vector map layers to current display"
-msgstr "Mehrere Raster- oder Vektorkarten zum aktuellen Kartenfenster hinzufügen"
+msgstr ""
+"Mehrere Raster- oder Vektorkarten zum aktuellen Kartenfenster hinzufügen"
 #: ../gui/wxpython/menustrings.py:24
 msgid "New map display window"
@@ -6562,762 +6730,821 @@
 msgid "Close all open map display windows"
 msgstr "Schließe alle offenen Kartenfenster"
-#: ../gui/wxpython/menustrings.py:31 ../gui/wxpython/menustrings.py:1023
+#: ../gui/wxpython/menustrings.py:31 ../gui/wxpython/menustrings.py:1040
 msgid "Common formats import"
 msgstr "Häufige Importformate"
-#: ../gui/wxpython/menustrings.py:32 ../gui/wxpython/menustrings.py:1024
+#: ../gui/wxpython/menustrings.py:32 ../gui/wxpython/menustrings.py:1041
 msgid "Import raster data into a GRASS map layer using GDAL."
 msgstr "Importiere Rasterdaten mittels GDAL"
-#: ../gui/wxpython/menustrings.py:33 ../gui/wxpython/menustrings.py:1025
+#: ../gui/wxpython/menustrings.py:33 ../gui/wxpython/menustrings.py:1042
 msgid "ASCII x,y,z point import and gridding"
 msgstr "ASCII x,y,z-Punkt Import und Gridding"
-#: ../gui/wxpython/menustrings.py:34 ../gui/wxpython/menustrings.py:1026
+#: ../gui/wxpython/menustrings.py:34 ../gui/wxpython/menustrings.py:1043
 #, fuzzy
-msgid "Creates a raster map from an assemblage of many coordinates using univariate statistics."
-msgstr "Erstellen einer Rasterkarte unter Verwendung einer Sammlung von vielen Koordinaten mit univariater Statistik."
+msgid ""
+"Creates a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+"Erstellen einer Rasterkarte unter Verwendung einer Sammlung von vielen "
+"Koordinaten mit univariater Statistik."
-#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:1027
+#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:1044
 msgid "ASCII grid import"
 msgstr "Importiere ASCII-Raster"
-#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1028
+#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1045
 #, fuzzy
 msgid "Converts a GRASS ASCII raster file to binary raster map."
-msgstr "Konvertiert eine ASCII-Rasterdatei in eine (binᅵre) GRASS Rasterkarte."
+msgstr ""
+"Konvertiert eine ASCII-Rasterdatei in eine (binᅵre) GRASS Rasterkarte."
-#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1029
+#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1046
 #, fuzzy
 msgid "ASCII polygons, lines, and point import"
 msgstr "Polygone und Linien einer ASCII-Datei"
-#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:1030
+#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:1047
 msgid "Creates raster maps from ASCII polygon/line/point data files."
 msgstr "Erzeuge eine Rasterkarte aus ASCII Flächen/Linien/Punkt Daten."
-#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1031
+#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1048
 #, fuzzy
 msgid "Raw binary array import"
 msgstr "Exportiert eine GRASS Rasterkarte als binᅵres Array."
-#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1032
+#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1049
 msgid "Import a binary raster file into a GRASS raster map layer."
 msgstr "Importiere eine binäre Rasterdatei in eine GRASS-Rasterkarte."
-#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1033
+#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1050
 msgid "ESRI ASCII grid import"
 msgstr "ESRI ASCII Rasterimport"
-#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1034
+#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1051
 #, fuzzy
-msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
-msgstr "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binᅵre) GRASS Rasterkarte."
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+msgstr ""
+"Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binᅵre) "
+"GRASS Rasterkarte."
-#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1035
+#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1052
 msgid "GRIDATB.FOR import"
 msgstr "Importiere GRIDATB.FOR "
-#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1036
+#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1053
 #, fuzzy
 msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
-msgstr "Importiert GRIDATB.FOR Kartendatei (TOPMODEL) in eine GRASS Rasterkarte."
+msgstr ""
+"Importiert GRIDATB.FOR Kartendatei (TOPMODEL) in eine GRASS Rasterkarte."
-#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1037
+#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1054
 msgid "Matlab 2D array import"
 msgstr "Matlab 2D-Array-Import"
-#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1038
+#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1055
 msgid "Imports a binary MAT-File(v4) to a GRASS raster."
 msgstr "Importiere eine Binäre MAT-Datei (v.4) in eine GRASS Rasterkarte."
-#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1039
+#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1056
 #, fuzzy
 msgid "PNG import"
 msgstr "PNG Export"
-#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1040
+#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1057
 #, fuzzy
 msgid "Imports non-georeferenced PNG format image."
 msgstr "Exportiere GRASS Raster als nicht georeferenziertes PNG-Bild."
-#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1041
+#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1058
 msgid "SPOT NDVI import"
 msgstr "SPOT NDVI Import"
-#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1042
+#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1059
 #, fuzzy
 msgid "Imports SPOT VGT NDVI data into a raster map."
 msgstr "Importiert SPOT VGT NDVI Datei in eine Rasterkarte."
-#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1043
+#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1060
 msgid "SRTM HGT import"
 msgstr "SRTM (.hgt) Import"
-#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1044
+#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1061
 #, fuzzy
 msgid "Imports SRTM HGT files into raster map."
 msgstr "Importiere eine SPOT VGT NDVI Datei in eine Rasterkarte"
-#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1045
+#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1062
 msgid "Terra ASTER HDF import"
 msgstr "Terra ASTER HDF Import"
-#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1046
+#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1063
 #, fuzzy
-msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
-msgstr "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative DGMs mit Hilfe von gdalwarp."
+msgid ""
+"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
+"using gdalwarp."
+msgstr ""
+"Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative "
+"DGMs mit Hilfe von gdalwarp."
 #: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:85
-#: ../gui/wxpython/menustrings.py:1047 ../gui/wxpython/menustrings.py:1077
+#: ../gui/wxpython/menustrings.py:1064 ../gui/wxpython/menustrings.py:1094
 #, fuzzy
 msgid "LAS LiDAR points import"
 msgstr "ASCII x,y,z Punkte-Export"
-#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1048
+#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1065
 #, fuzzy
 msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
+msgstr ""
-#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1049
+#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1066
 msgid "Unpack raster map"
 msgstr "Rasterkarte auspacken"
-#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1050
+#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1067
 msgid "Unpacks a raster map packed with r.pack."
 msgstr "Dekomprimiert eine Rasterkarte zusammengepackt mit r.pack."
 #: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:294
-#: ../gui/wxpython/menustrings.py:1051 ../gui/wxpython/menustrings.py:1206
+#: ../gui/wxpython/menustrings.py:1068 ../gui/wxpython/menustrings.py:1223
 #, fuzzy
 msgid "Reproject raster map from different GRASS location"
-msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
+msgstr ""
+"Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
 #: ../gui/wxpython/menustrings.py:60 ../gui/wxpython/menustrings.py:295
-#: ../gui/wxpython/menustrings.py:1052 ../gui/wxpython/menustrings.py:1207
+#: ../gui/wxpython/menustrings.py:1069 ../gui/wxpython/menustrings.py:1224
 #, fuzzy
 msgid "Re-projects a raster map from given location to the current location."
+msgstr ""
-#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1054
+#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1071
 msgid "Common import formats"
-#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:1055
+#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:1072
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr "Konvertiere Vektordaten in GRASS-Vektorkarten via OGR."
-#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1056
+#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1073
 #, fuzzy
 msgid "ASCII points or GRASS ASCII format"
 msgstr "ASCII Punktdatei oder GRASS ASCII Vektordatei"
-#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1057
+#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1074
 #, fuzzy
 msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
+msgstr ""
+"Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
-#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:1058
+#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:1075
 msgid "ASCII points as a vector lines"
 msgstr "ASCII-Punkte als Vektorlinie"
-#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1059
+#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1076
 #, fuzzy
 msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
 msgstr "Importiere ASCII x,y[,z]-Koordinaten in eine Folge von Linien."
-#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1060
+#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1077
 msgid "Historical GRASS vector import"
 msgstr "Import alter GRASS Vektordaten"
-#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:1061
+#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:1078
 msgid "Imports older versions of GRASS vector maps."
 msgstr "Importiere ältere Versionen von GRASS Vektorkarten."
-#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1062
+#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1079
 msgid "Historical GRASS vector import (all maps)"
 msgstr "Import alter GRASS Vektordaten (alle Karten)"
-#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1063
-msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
-msgstr "Konvertiere alle alten GRASS Vektorkarten des aktuellen Mapsets in aktuelles Format."
+#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1080
+msgid ""
+"Converts all older versions of GRASS vector maps in current mapset to "
+"current format."
+msgstr ""
+"Konvertiere alle alten GRASS Vektorkarten des aktuellen Mapsets in aktuelles "
+"Format."
-#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1064
+#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1081
 msgid "DXF import"
 msgstr "DXF Import"
-#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1065
+#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1082
 msgid "Converts files in DXF format to GRASS vector map format."
 msgstr "Konvertiere DXF Daten in GRASS Vektorkarten"
-#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1066
+#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1083
 msgid "WFS"
 msgstr "WFS"
-#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1067
+#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1084
 #, fuzzy
 msgid "Imports GetFeature from a WFS server."
 msgstr "Importiertiere Daten von WMS Server"
-#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1068
+#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1085
 msgid "ESRI e00 import"
 msgstr "ESRI e00 Import"
-#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1069
+#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1086
 #, fuzzy
 msgid "Imports E00 file into a vector map."
 msgstr "Importiere e00-Daten in eine Vektorkarte."
-#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1070
+#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1087
 #, fuzzy
 msgid "GPS data import"
 msgstr "Importiere Datentabelle"
-#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1071
+#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1088
 msgid "Geonames import"
 msgstr "Importiere Geonames"
-#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1072
+#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1089
 #, fuzzy
 msgid "Imports geonames.org country files into a vector points map."
 msgstr "Importiert Länderdateien von geonames.org in eine Vektorpunktkarte."
-#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1073
+#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1090
 msgid "GEOnet import"
 msgstr "GEOnet Import"
-#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1074
-msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
-msgstr "Importiere US-NGA GEOnet Names Server (GNS) Länderdaten in eine GRASS Vektorpunkte Karte."
+#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1091
+msgid ""
+"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
+"points map."
+msgstr ""
+"Importiere US-NGA GEOnet Names Server (GNS) Länderdaten in eine GRASS "
+"Vektorpunkte Karte."
-#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1075
+#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1092
 msgid "Matlab array or Mapgen format import"
 msgstr "Matlab Array- und MapGen-Import"
-#: ../gui/wxpython/menustrings.py:84 ../gui/wxpython/menustrings.py:1076
+#: ../gui/wxpython/menustrings.py:84 ../gui/wxpython/menustrings.py:1093
 msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
 msgstr "Importiert Mapgen oder Matlab-ASCII Vektordaten nach GRASS."
-#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1078
+#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1095
 #, fuzzy
 msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
-#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:1079
+#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:1096
 #, fuzzy
 msgid "Unpack vector map"
 msgstr "Patche Vektorkarten"
-#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:1080
+#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:1097
 #, fuzzy
 msgid "Unpacks a vector map packed with v.pack."
-#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:566
-#: ../gui/wxpython/menustrings.py:1081 ../gui/wxpython/menustrings.py:1478
+#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:583
+#: ../gui/wxpython/menustrings.py:1098 ../gui/wxpython/menustrings.py:1512
 #, fuzzy
 msgid "Reproject vector map from different GRASS location"
-msgstr "Re-Projektion einer Vektorkarte von einer Location zur aktuellen Location."
+msgstr ""
+"Re-Projektion einer Vektorkarte von einer Location zur aktuellen Location."
-#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:567
-#: ../gui/wxpython/menustrings.py:1082 ../gui/wxpython/menustrings.py:1479
+#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:584
+#: ../gui/wxpython/menustrings.py:1099 ../gui/wxpython/menustrings.py:1513
 msgid "Re-projects a vector map from one location to the current location."
+msgstr ""
-#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1083
+#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1100
 msgid "Import 3D raster data"
 msgstr "Importiere 3D Rasterdaten"
-#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1084
+#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1101
 msgid "ASCII 3D import"
 msgstr "ASCII 3D Import"
-#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1085
+#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1102
 #, fuzzy
 msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
 msgstr "Konvertiert eine 3D-Rasterkarte in eine ASCII-Datei."
-#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1086
+#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1103
 #, fuzzy
 msgid "Raw binary array 3D import"
-#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1087
+#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1104
 #, fuzzy
 msgid "Imports a binary raster file into a GRASS 3D raster map."
 msgstr "Importiere binäre Rasterdatei in eine GRASS-Rasterkarte."
-#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1088
+#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1105
 msgid "Vis5D import"
 msgstr "Vis5D Datei Import"
-#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1089
+#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1106
 #, fuzzy
 msgid "Import 3-dimensional Vis5D files."
 msgstr "Importiert SRTM HGT Dateien nach GRASS."
-#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1090
+#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1107
 msgid "Import database table"
 msgstr "Importiere Datenbanktabelle"
-#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1091
+#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1108
 msgid "Multiple import formats using OGR"
 msgstr "Verschiedene Formate mit OGR importieren"
-#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:1092
+#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:1109
 msgid "Imports attribute tables in various formats."
 msgstr "Importiere Attributtabellen in versch. Formaten."
-#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1093
+#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1110
 msgid "Export raster map"
 msgstr "Exportiere Rasterkarte"
 #: ../gui/wxpython/menustrings.py:102 ../gui/wxpython/menustrings.py:135
-#: ../gui/wxpython/menustrings.py:1094 ../gui/wxpython/menustrings.py:1127
+#: ../gui/wxpython/menustrings.py:1111 ../gui/wxpython/menustrings.py:1144
 msgid "Common export formats"
 msgstr "Geläufige Exportformate"
-#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1095
+#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1112
 msgid "Exports GRASS raster maps into GDAL supported formats."
 msgstr "Exportiert GRASS Rasterkarten in GDAL-unterstütze Formate."
-#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1096
+#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1113
 msgid "ASCII grid export"
 msgstr "ASCII Grid Export"
-#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1097
+#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1114
 #, fuzzy
 msgid "Converts a raster map layer into a GRASS ASCII text file."
-#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1098
+#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1115
 msgid "ASCII x,y,z points export"
-#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1099
+#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1116
 #, fuzzy
-msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
-msgstr "Exportiert eine Rasterkarte in eine Textdatei (x,y,z-werte; Zentrum der Zellen)"
+msgid ""
+"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+"Exportiert eine Rasterkarte in eine Textdatei (x,y,z-werte; Zentrum der "
+"Zellen)"
-#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1100
+#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1117
 msgid "ESRI ASCII grid export"
 msgstr "ESRI ASCII Grid Export"
-#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1101
+#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1118
 msgid "Converts a raster map layer into an ESRI ARCGRID file."
 msgstr "Exportiert eine Rasterkarte in eine ESRI ARCGRID Datei."
-#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1102
+#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1119
 msgid "GRIDATB.FOR export"
 msgstr "GRIDATB.FOR Export"
-#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1103
+#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1120
 #, fuzzy
 msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
 msgstr "Exportiert eine GRASS Rasterkarte als GRIDATB.FOR (TOPMODEL) Karte."
-#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1104
+#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1121
 msgid "Matlab 2D array export"
 msgstr "Matlab 2D-Array-Export"
-#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1105
+#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1122
 msgid "Exports a GRASS raster to a binary MAT-File."
 msgstr "Exportiere eine GRASS Rasterkarte als binäre MAT-Datei."
-#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1106
+#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1123
 msgid "Raw binary array export"
 msgstr "Binary-Array-Export"
-#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1107
+#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1124
 msgid "Exports a GRASS raster to a binary array."
 msgstr "Exportiert eine GRASS Rasterkarte als binäres Array."
-#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1108
+#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1125
 msgid "MPEG-1 export"
 msgstr "MPEG-1 Export"
-#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1109
+#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1126
 #, fuzzy
 msgid "Converts raster map series to MPEG movie."
-msgstr "Programm zum Konvertieren von Serien von Rasterkarten zu einem MPEG-Film."
+msgstr ""
+"Programm zum Konvertieren von Serien von Rasterkarten zu einem MPEG-Film."
-#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1110
+#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1127
 msgid "PNG export"
 msgstr "PNG Export"
-#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1111
+#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1128
 #, fuzzy
 msgid "Export a GRASS raster map as a non-georeferenced PNG image."
 msgstr "Exportiert GRASS Raster als nicht georeferenziertes PNG-Bild"
-#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1112
+#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1129
 msgid "PPM export"
 msgstr "PPM Export"
-#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1113
+#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1130
 #, fuzzy
 msgid "Converts a GRASS raster map to a PPM image file."
 msgstr "Konvertiert eine Rasterkarte in eine Vektorkarte"
-#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1114
+#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1131
 msgid "PPM from RGB export"
 msgstr "PPM aus RGB Export"
-#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1115
+#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1132
 #, fuzzy
 msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflᅵsung der DERZEITIG EINGESTELLTEN REGION."
+msgstr ""
+"Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-"
+"Auflᅵsung der DERZEITIG EINGESTELLTEN REGION."
 #: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:144
-#: ../gui/wxpython/menustrings.py:1116 ../gui/wxpython/menustrings.py:1136
+#: ../gui/wxpython/menustrings.py:1133 ../gui/wxpython/menustrings.py:1153
 msgid "POV-Ray export"
 msgstr "POV-Ray Export"
-#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1117
+#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1134
 #, fuzzy
 msgid "Converts a raster map layer into a height-field file for POV-Ray."
 msgstr "Exportiert eine Rasterkarte in eine Hᅵhenfeld-Datei fᅵr POVRAY."
-#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1118
+#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1135
 msgid "TIFF export"
 msgstr "TIFF Export"
-#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1119
+#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1136
 #, fuzzy
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
 msgstr "Exportiere eine GRASS Rasterkarte als binᅵre MAT-Datei."
-#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:1120
+#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:1137
 msgid "VRML export"
 msgstr "VRML Export"
-#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1121
+#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1138
 #, fuzzy
 msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
+msgstr ""
+"Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
 #: ../gui/wxpython/menustrings.py:130 ../gui/wxpython/menustrings.py:148
-#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1122
-#: ../gui/wxpython/menustrings.py:1140 ../gui/wxpython/menustrings.py:1151
+#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1139
+#: ../gui/wxpython/menustrings.py:1157 ../gui/wxpython/menustrings.py:1168
 msgid "VTK export"
 msgstr "VTK Export"
-#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1123
+#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1140
 #, fuzzy
 msgid "Converts raster maps into the VTK-ASCII format."
 msgstr "Konvertiert eine Rasterkarte in das VTK-ASCII-Format."
-#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1124
+#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1141
 msgid "Pack raster map"
 msgstr "Rasterkarten packen"
-#: ../gui/wxpython/menustrings.py:133 ../gui/wxpython/menustrings.py:1125
+#: ../gui/wxpython/menustrings.py:133 ../gui/wxpython/menustrings.py:1142
 msgid "Packs up a raster map and support files for copying."
 msgstr "Packt eine Rasterkarte und ihre Hilfsdateien zum Kopieren."
-#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1126
+#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1143
 msgid "Export vector map"
 msgstr "Exportiere Vektorkarte"
-#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1128
+#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1145
 #, fuzzy
-msgid "Exports a vector map layer to any of the supported OGR vector formats. By default a vector map layer is exported to Esri Shapefile format."
+msgid ""
+"Exports a vector map layer to any of the supported OGR vector formats. By "
+"default a vector map layer is exported to Esri Shapefile format."
 msgstr "Konvertiert in eines von OGR unterstᅵtzten Formaten"
-#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1129
+#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1146
 #, fuzzy
 msgid "ASCII points or GRASS ASCII vector export"
-#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1130
-msgid "Exports a vector map to a GRASS ASCII vector representation. By default only features with category are exported. To export all features use 'layer=-1'."
+#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1147
+msgid ""
+"Exports a vector map to a GRASS ASCII vector representation. By default only "
+"features with category are exported. To export all features use 'layer=-1'."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1131
+#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1148
 msgid "DXF export"
 msgstr "DXF Export"
-#: ../gui/wxpython/menustrings.py:140 ../gui/wxpython/menustrings.py:1132
+#: ../gui/wxpython/menustrings.py:140 ../gui/wxpython/menustrings.py:1149
 #, fuzzy
 msgid "Exports vector map to DXF file format."
 msgstr "Exportiert GRASS Vektorkarten in das DXF-Dateiformat."
-#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1133
+#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1150
 msgid "Multiple GPS export formats using GPSBabel"
 msgstr "Exportiere in verschiedene GPS-Formate mit GPSBabel"
-#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1134
+#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1151
 #, fuzzy
-msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
-msgstr "Exportiert eine Vektorkarte in ein GPS-Gerät oder als von GPSBabel unterstütztes Datenformat."
+msgid ""
+"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+msgstr ""
+"Exportiert eine Vektorkarte in ein GPS-Gerät oder als von GPSBabel "
+"unterstütztes Datenformat."
-#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1135
+#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1152
 #, fuzzy
 msgid "PostGIS export"
 msgstr "PNG Export"
-#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1137
+#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1154
 #, fuzzy
 msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
 msgstr "Convertiert in POV-Ray Format, (GRASS x,y,z -nach POV-Ray x,z,y)"
-#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1138
+#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1155
 msgid "SVG export"
 msgstr "SVG Export"
-#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1139
+#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1156
 #, fuzzy
 msgid "Exports a vector map to SVG file."
 msgstr "Exportiert eine GRASS Vektorkarte nach SVG."
-#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1141
+#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1158
 #, fuzzy
 msgid "Converts a vector map to VTK ASCII output."
 msgstr "Konvertieren eine GRASS Vektorkarte zu einer VTK ASCII-Datei."
-#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1142
+#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1159
 #, fuzzy
 msgid "Pack vector map"
-#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1143
+#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1160
 #, fuzzy
 msgid "Packs up a vector map and support files for copying."
-#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1144
+#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1161
 msgid "Export 3D raster maps"
 msgstr "Exportiere 3D Rasterkarten"
-#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1145
+#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1162
 msgid "ASCII 3D export"
 msgstr "ASCII 3D Export"
-#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1146
+#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1163
 #, fuzzy
 msgid "Converts a 3D raster map layer into a ASCII text file."
-#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1147
+#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1164
 #, fuzzy
 msgid "Raw binary array 3D export"
-#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1148
+#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1165
 #, fuzzy
 msgid "Exports a GRASS 3D raster map to a binary array."
-#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1149
+#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1166
 msgid "Vis5D export"
 msgstr "Vis5D Export"
-#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1150
+#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1167
 msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr "Exportiert eine GRASS 3D Rasterkarte in eine 3-dimensionale Vis5D Datei."
+msgstr ""
+"Exportiert eine GRASS 3D Rasterkarte in eine 3-dimensionale Vis5D Datei."
-#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1152
+#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1169
 msgid "Converts 3D raster maps into the VTK-ASCII format."
 msgstr "Konvertiert eine 3D Rasterkarte in das VTK-ASCII-Format."
-#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1153
+#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1170
 msgid "Export database table"
 msgstr "Exportiere Datenbanktabelle"
-#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1154
+#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1171
 msgid "Common export formats using OGR"
 msgstr "Häufige Exportformate via OGR"
-#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1155
+#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1172
 msgid "Exports attribute tables into various formats."
 msgstr "Importiere Attributtabellen in verschiedene Formate."
-#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:1156
+#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:1173
 #, fuzzy
 msgid "Link external data"
 msgstr "Einbindung externer Rasterdaten"
-#: ../gui/wxpython/menustrings.py:166 ../gui/wxpython/menustrings.py:1158
+#: ../gui/wxpython/menustrings.py:166 ../gui/wxpython/menustrings.py:1175
 msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
 msgstr "Verknüpfe GDAL-Rasterdaten mit GRASS als Pseudo-Rasterkarte."
-#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:1160
+#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:1177
 msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr "Erzeugt eine neue Pseudo-Vektorkarte als Verknüpfung zu einem OGR-Layer."
+msgstr ""
+"Erzeugt eine neue Pseudo-Vektorkarte als Verknüpfung zu einem OGR-Layer."
-#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1161
+#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1178
 #, fuzzy
 msgid "Output format for raster data"
 msgstr "Massen-Import von Rasterdaten"
-#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1162
+#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1179
 msgid "Defines raster output format utilizing GDAL library."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1163
+#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1180
 #, fuzzy
 msgid "Output format for vector data"
 msgstr "Massen-Import von Vektordaten"
-#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1164
+#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1181
 msgid "Defines vector output format utilizing OGR library."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1165
+#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1182
 #, fuzzy
 msgid "Manage maps"
 msgstr "Vektorkarten verwalten"
-#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:1166
+#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:1183
 msgid "Copy"
 msgstr "Kopieren"
-#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:1167
+#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:1184
 #, fuzzy
-msgid "Copies available data files in the current mapset search path to the user's current mapset."
-msgstr "Kopiert verfügbare Daten aus dem aktuellen Suchpfad des Benutzer-Mapset und Location in die entsprechenden Verzeichnisse im aktuellen Mapset (vereint alle verfügbaren Daten der Location im aktuellen Mapset)"
+msgid ""
+"Copies available data files in the current mapset search path to the user's "
+"current mapset."
+msgstr ""
+"Kopiert verfügbare Daten aus dem aktuellen Suchpfad des Benutzer-Mapset und "
+"Location in die entsprechenden Verzeichnisse im aktuellen Mapset (vereint "
+"alle verfügbaren Daten der Location im aktuellen Mapset)"
-#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:935
-#: ../gui/wxpython/menustrings.py:1168 ../gui/wxpython/menustrings.py:1847
+#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:952
+#: ../gui/wxpython/menustrings.py:1185 ../gui/wxpython/menustrings.py:1881
 msgid "List"
 msgstr "Auflisten"
-#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:1169
+#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:1186
 msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr "Listet alle verfügbaren GRASS Datenbankdateien im spezifizierten Typ auf."
+msgstr ""
+"Listet alle verfügbaren GRASS Datenbankdateien im spezifizierten Typ auf."
-#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:1170
+#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:1187
 msgid "List filtered"
 msgstr "Gefilterte Liste"
-#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:1171
-msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
-msgstr "Listet alle verfügbaren GRASS Datenbankdateien im spezifizierten Typ mit optionalem Suchmuster auf."
+#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:1188
+msgid ""
+"Lists available GRASS data base files of the user-specified data type "
+"optionally using the search pattern."
+msgstr ""
+"Listet alle verfügbaren GRASS Datenbankdateien im spezifizierten Typ mit "
+"optionalem Suchmuster auf."
-#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:1173
+#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:1190
 msgid "Renames data base element files in the user's current mapset."
 msgstr "Benennt Datenbank Daten im aktuellen Mapset um"
-#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:1175
+#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:1192
 msgid "Removes data base element files from the user's current mapset."
 msgstr "Löscht Datenbank Daten im aktuellen Mapset umDaten."
-#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:1176
+#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:1193
 msgid "Delete filtered"
 msgstr "Lösche gefilterte Auswahl."
-#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:1177
+#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:1194
 #, fuzzy
-msgid "Removes data base element files from the user's current mapset using regular expressions."
+msgid ""
+"Removes data base element files from the user's current mapset using regular "
+"expressions."
 #: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:318
-#: ../gui/wxpython/menustrings.py:604 ../gui/wxpython/menustrings.py:838
-#: ../gui/wxpython/menustrings.py:1230 ../gui/wxpython/menustrings.py:1516
-#: ../gui/wxpython/menustrings.py:1750
+#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:855
+#: ../gui/wxpython/menustrings.py:1247 ../gui/wxpython/menustrings.py:1550
+#: ../gui/wxpython/menustrings.py:1784
 msgid "Map type conversions"
 msgstr "Kartentyp Umwandlung"
 #: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:319
-#: ../gui/wxpython/menustrings.py:1231
+#: ../gui/wxpython/menustrings.py:1248
 msgid "Raster to vector"
 msgstr "Raster zu Vektor"
 #: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:320
-#: ../gui/wxpython/menustrings.py:1232
+#: ../gui/wxpython/menustrings.py:1249
 #, fuzzy
 msgid "Converts a raster map into a vector map."
 #: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:321
-#: ../gui/wxpython/menustrings.py:1233
+#: ../gui/wxpython/menustrings.py:1250
 msgid "Raster series to volume"
 msgstr "Raster-Serie zu Volumen"
 #: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:322
-#: ../gui/wxpython/menustrings.py:1234
+#: ../gui/wxpython/menustrings.py:1251
 msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr "Konvertiert Schnitte von 2D Rasterkarten in eine 3D Rastervolumenkarte."
+msgstr ""
+"Konvertiert Schnitte von 2D Rasterkarten in eine 3D Rastervolumenkarte."
 #: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:323
-#: ../gui/wxpython/menustrings.py:1235
+#: ../gui/wxpython/menustrings.py:1252
 msgid "Raster 2.5D to volume"
 msgstr "2,5D Raster zu Volumen"
 #: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:324
-#: ../gui/wxpython/menustrings.py:1236
+#: ../gui/wxpython/menustrings.py:1253
 msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr "Erzeugt eine 3D Volumenkarte aus 2D Höheninformationen und einer Wertekarte"
+msgstr ""
+"Erzeugt eine 3D Volumenkarte aus 2D Höheninformationen und einer Wertekarte"
-#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:605
-#: ../gui/wxpython/menustrings.py:1517
+#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:622
+#: ../gui/wxpython/menustrings.py:1551
 msgid "Vector to raster"
 msgstr "Vektor zu Raster"
-#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:606
-#: ../gui/wxpython/menustrings.py:1518
+#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:623
+#: ../gui/wxpython/menustrings.py:1552
 msgid "Converts (rasterize) a vector map into a raster map."
 msgstr "Konvertiert eine Vektorkarte in eine Rasterkarte."
-#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:607
-#: ../gui/wxpython/menustrings.py:1519
+#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:624
+#: ../gui/wxpython/menustrings.py:1553
 msgid "Vector to volume"
 msgstr "Vektor zu Volumen"
-#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:608
-#: ../gui/wxpython/menustrings.py:1520
+#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:625
+#: ../gui/wxpython/menustrings.py:1554
 #, fuzzy
 msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr "Konvertiert eine GRASS Vektorkarte (nur Punkte) in eine 3D GRASS Rasterkarte."
+msgstr ""
+"Konvertiert eine GRASS Vektorkarte (nur Punkte) in eine 3D GRASS Rasterkarte."
-#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:609
-#: ../gui/wxpython/menustrings.py:1521
+#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:626
+#: ../gui/wxpython/menustrings.py:1555
 msgid "2D vector to 3D vector"
 msgstr "2D Vektor zu 3D Vektor"
-#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:610
-#: ../gui/wxpython/menustrings.py:1522
+#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:627
+#: ../gui/wxpython/menustrings.py:1556
 msgid "Performs transformation of 2D vector features to 3D."
 msgstr "Transformiert 2D Vektorobjekte nach 3D."
-#: ../gui/wxpython/menustrings.py:199 ../gui/wxpython/menustrings.py:611
-#: ../gui/wxpython/menustrings.py:1523
+#: ../gui/wxpython/menustrings.py:199 ../gui/wxpython/menustrings.py:628
+#: ../gui/wxpython/menustrings.py:1557
 msgid "Sites to vector"
 msgstr "Sites zu Vektor"
-#: ../gui/wxpython/menustrings.py:200 ../gui/wxpython/menustrings.py:612
-#: ../gui/wxpython/menustrings.py:1524
+#: ../gui/wxpython/menustrings.py:200 ../gui/wxpython/menustrings.py:629
+#: ../gui/wxpython/menustrings.py:1558
 msgid "Converts a GRASS site_lists file into a vector map."
 msgstr "Konvertiert eine GRASS site_lists Datei in eine Vektorkarte"
-#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:839
-#: ../gui/wxpython/menustrings.py:1751
+#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:856
+#: ../gui/wxpython/menustrings.py:1785
 msgid "Volume to raster series"
 msgstr "Volumen zu Raster-Serie"
-#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:840
-#: ../gui/wxpython/menustrings.py:1752
+#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:857
+#: ../gui/wxpython/menustrings.py:1786
 msgid "Converts 3D raster maps to 2D raster maps"
 msgstr "Konvertiert 3D Rasterkarten in 2D Rasterkarten."
-#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1926
+#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1960
 msgid "Georectify"
 msgstr "Georektifizieren"
-#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/menustrings.py:1927
+#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/menustrings.py:1961
 msgid "Manage Ground Control Points for Georectification"
 msgstr "Verwalte Ground Control Points für Georeferenzierung"
-#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:1928
+#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:1962
 msgid "Graphical modeler"
 msgstr "Grafischer Modellierer"
-#: ../gui/wxpython/menustrings.py:206 ../gui/wxpython/menustrings.py:1929
+#: ../gui/wxpython/menustrings.py:206 ../gui/wxpython/menustrings.py:1963
 msgid "Launch Graphical modeler"
 msgstr "Starte den Grafischen Modellierer"
-#: ../gui/wxpython/menustrings.py:207 ../gui/wxpython/menustrings.py:1977
+#: ../gui/wxpython/menustrings.py:207 ../gui/wxpython/menustrings.py:2011
 msgid "Run model"
 msgstr "Start des Modells"
@@ -7330,18 +7557,20 @@
 msgstr "3D Rendering einschalten"
 #: ../gui/wxpython/menustrings.py:210
-msgid "Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgid ""
+"Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D "
+"vector data, and volumes (3D raster data) in 3D."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:211 ../gui/wxpython/menustrings.py:1007
-#: ../gui/wxpython/menustrings.py:1919 ../gui/wxpython/menustrings.py:1923
+#: ../gui/wxpython/menustrings.py:211 ../gui/wxpython/menustrings.py:1024
+#: ../gui/wxpython/menustrings.py:1953 ../gui/wxpython/menustrings.py:1957
 #: ../gui/wxpython/animation/frame.py:52
 #, fuzzy
 msgid "Animation tool"
 msgstr "Animation"
-#: ../gui/wxpython/menustrings.py:212 ../gui/wxpython/menustrings.py:1008
-#: ../gui/wxpython/menustrings.py:1920 ../gui/wxpython/menustrings.py:1924
+#: ../gui/wxpython/menustrings.py:212 ../gui/wxpython/menustrings.py:1025
+#: ../gui/wxpython/menustrings.py:1954 ../gui/wxpython/menustrings.py:1958
 msgid "Launch animation tool."
 msgstr ""
@@ -7351,24 +7580,28 @@
 #: ../gui/wxpython/menustrings.py:214
 #, fuzzy
-msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa. It assumes a cartesian coordinate system"
-msgstr "Eine einfache Anwendung zur Konvertierung von Richtung und Entfernung in Koordinaten und umgekehrt."
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa. It assumes a cartesian coordinate system"
+msgstr ""
+"Eine einfache Anwendung zur Konvertierung von Richtung und Entfernung in "
+"Koordinaten und umgekehrt."
-#: ../gui/wxpython/menustrings.py:215 ../gui/wxpython/menustrings.py:1934
+#: ../gui/wxpython/menustrings.py:215 ../gui/wxpython/menustrings.py:1968
 #: ../gui/wxpython/lmgr/toolbars.py:144
 msgid "Cartographic Composer"
 msgstr "Kartenlayout"
-#: ../gui/wxpython/menustrings.py:216 ../gui/wxpython/menustrings.py:1935
+#: ../gui/wxpython/menustrings.py:216 ../gui/wxpython/menustrings.py:1969
 msgid "Launch Cartographic Composer"
 msgstr "Starte Kartenlayout"
-#: ../gui/wxpython/menustrings.py:217 ../gui/wxpython/menustrings.py:1932
+#: ../gui/wxpython/menustrings.py:217 ../gui/wxpython/menustrings.py:1966
 #, fuzzy
 msgid "Map Swipe"
 msgstr "Typ der Kartenebene:"
-#: ../gui/wxpython/menustrings.py:218 ../gui/wxpython/menustrings.py:1933
+#: ../gui/wxpython/menustrings.py:218 ../gui/wxpython/menustrings.py:1967
 #, fuzzy
 msgid "Launch Map Swipe"
 msgstr "Starte Skript"
@@ -7389,7 +7622,7 @@
 msgid "Quit the GRASS wxGUI session."
 msgstr "Beende wxGUI-Session."
-#: ../gui/wxpython/menustrings.py:223 ../gui/wxpython/menustrings.py:1955
+#: ../gui/wxpython/menustrings.py:223 ../gui/wxpython/menustrings.py:1989
 msgid "&Settings"
 msgstr "&Einstellungen"
@@ -7420,7 +7653,8 @@
 #: ../gui/wxpython/menustrings.py:231
 msgid "Set/unset access to other mapsets in current location"
-msgstr "Zugriff auf andere Mapsets der aktuellen Location ermöglichen/verwehren"
+msgstr ""
+"Zugriff auf andere Mapsets der aktuellen Location ermöglichen/verwehren"
 #: ../gui/wxpython/menustrings.py:232
 msgid "User access"
@@ -7428,7 +7662,9 @@
 #: ../gui/wxpython/menustrings.py:233
 #, fuzzy
-msgid "Controls access to the current mapset for other users on the system. If no option given, prints current status."
+msgid ""
+"Controls access to the current mapset for other users on the system. If no "
+"option given, prints current status."
 msgstr "Kontrolliert den Zugriff anderer Benutzer auf das aktuelle Mapset."
 #: ../gui/wxpython/menustrings.py:234
@@ -7436,7 +7672,9 @@
 msgstr "Ändern der Arbeitsumgebung "
 #: ../gui/wxpython/menustrings.py:235
-msgid "Changes/reports current mapset. Optionally create new mapset or list available mapsets in given location."
+msgid ""
+"Changes/reports current mapset. Optionally create new mapset or list "
+"available mapsets in given location."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:236
@@ -7474,7 +7712,9 @@
 #: ../gui/wxpython/menustrings.py:245
 #, fuzzy
-msgid "Outputs and modifies the user's current GRASS variable settings. Prints all defined GRASS variables if no option is given."
+msgid ""
+"Outputs and modifies the user's current GRASS variable settings. Prints all "
+"defined GRASS variables if no option is given."
 msgstr "Gibt die aktuellen GRASS-Variablen aus und modifiziert sie."
 #: ../gui/wxpython/menustrings.py:246
@@ -7492,7 +7732,8 @@
 #: ../gui/wxpython/menustrings.py:249
 msgid "Creates new mapset in the current location, changes current mapset."
-msgstr "Erzeugt neues Mapset in der aktuellen Location, ändert aktuelles Mapset."
+msgstr ""
+"Erzeugt neues Mapset in der aktuellen Location, ändert aktuelles Mapset."
 #: ../gui/wxpython/menustrings.py:250
 #, fuzzy
@@ -7512,8 +7753,13 @@
 msgstr "Kartenprojektion anzeigen"
 #: ../gui/wxpython/menustrings.py:254
-msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
-msgstr "Konvertiert die Beschreibung von Koordinatesystemen (z.B. Projektionsinformationen) zwischen verschiedenen Formaten (einschliesslich GRASS)."
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format)."
+msgstr ""
+"Konvertiert die Beschreibung von Koordinatesystemen (z.B. "
+"Projektionsinformationen) zwischen verschiedenen Formaten (einschliesslich "
+"GRASS)."
 #: ../gui/wxpython/menustrings.py:255
 msgid "Manage projections"
@@ -7521,7 +7767,10 @@
 #: ../gui/wxpython/menustrings.py:256
 #, fuzzy
-msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions). Can also be used to create new GRASS locations."
+msgid ""
+"Prints and manipulates GRASS projection information files (in various co-"
+"ordinate system descriptions). Can also be used to create new GRASS "
+"locations."
 msgstr "Anzeigen und ändern der GRASS Projektionsdateien (in verschiedenen"
 #: ../gui/wxpython/menustrings.py:257
@@ -7530,7 +7779,9 @@
 #: ../gui/wxpython/menustrings.py:258
 msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr "Konvertiert Koordinaten von einer Projektion zu einer anderen (cs2cs Frontend)."
+msgstr ""
+"Konvertiert Koordinaten von einer Projektion zu einer anderen (cs2cs "
+"Frontend)."
 #: ../gui/wxpython/menustrings.py:259
 msgid "Addons extensions"
@@ -7554,7 +7805,7 @@
 msgid "Updates or removes installed GRASS AddOns extension(s)."
 msgstr "Entfernen einer installierten Erweiterung aus den GRASS Addons."
-#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1956
+#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1990
 msgid "Preferences"
 msgstr "Einstellungen"
@@ -7562,3262 +7813,3846 @@
 msgid "User GUI preferences (display font, commands, digitizer, etc.)"
 msgstr "GUI Einstellungen (Schriftarten, Befehle, Digitalisierer etc.)"
-#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1178
+#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1195
 msgid "&Raster"
 msgstr "&Raster"
-#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1179
+#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1196
 msgid "Develop raster map"
 msgstr "Rasterkarten pflegen"
-#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1180
+#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1197
 msgid "Compress/decompress"
 msgstr "Komprimieren/dekomprimieren"
-#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1181
+#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1198
 msgid "Compresses and decompresses raster maps."
 msgstr "Komprimiert und dekomprimiert Rasterkarten."
-#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1182
+#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1199
 msgid "Region boundaries"
 msgstr "Grenzen der Region"
-#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1183
+#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1200
 msgid "Sets the boundary definitions for a raster map."
 msgstr "Setzt die Begrenzungs-Definition (boundary) für eine Rasterkarte."
-#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1184
+#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1201
 msgid "Manage NULL values"
 msgstr "NULL-Werte verwalten"
-#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1185
+#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1202
 msgid "Manages NULL-values of given raster map."
 msgstr "Verwaltet NULL-Werte einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1186
+#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1203
 msgid "Quantization"
 msgstr "Quantisierung"
-#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1187
+#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1204
 msgid "Produces the quantization file for a floating-point map."
 msgstr "Produziert eine Quantisierungsdatei für eine Fließkomma-Karte."
-#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1188
+#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1205
 msgid "Timestamp"
 msgstr "Zeitstempel"
-#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1189
+#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1206
 #, fuzzy
-msgid "Modifies a timestamp for a raster map. Print/add/remove a timestamp for a raster map."
-msgstr "Ausgeben/Hinzufügen/Entfernen eines Zeitstempels für eine 3D-Rasterkarte"
+msgid ""
+"Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
+"raster map."
+msgstr ""
+"Ausgeben/Hinzufügen/Entfernen eines Zeitstempels für eine 3D-Rasterkarte"
-#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1190
+#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1207
 msgid "Resample using aggregate statistics"
 msgstr "Resamplen mittels Aggregation"
-#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1191
+#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1208
 msgid "Resamples raster map layers to a coarser grid using aggregation."
 msgstr "Resamplen einer Rasterkarte zu gröberer Auflösung mittels Aggregation."
-#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1192
+#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1209
 msgid "Resample using multiple methods"
 msgstr "Resamplen mittels verschiedener Methoden"
-#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1193
+#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1210
 #, fuzzy
 msgid "Resamples raster map to a finer grid using interpolation."
-msgstr "Resamplen einer Rasterkarte zu feinerer Auflösung mittels Interpolation."
+msgstr ""
+"Resamplen einer Rasterkarte zu feinerer Auflösung mittels Interpolation."
-#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1194
+#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1211
 msgid "Resample using nearest neighbor"
 msgstr "Resamplen mittels Nearest-Neighbor"
-#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1195
+#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1212
 msgid "GRASS raster map layer data resampling capability."
 msgstr "Möglichkeiten GRASS Rasterkarte zu resamplen."
-#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1196
+#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1213
 msgid "Resample using spline tension"
 msgstr "Resampeln mittels Spline mit Tension"
-#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:1197
-msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
-msgstr "Reinterpoliert und berechnet ggf. topographische Analysen basierend auf einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von regularized splines with tension and smoothing (RST)."
+#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:1214
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+"Reinterpoliert und berechnet ggf. topographische Analysen basierend auf "
+"einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von "
+"regularized splines with tension and smoothing (RST)."
-#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1198
+#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1215
 #, fuzzy
 msgid "Resample using bspline"
 msgstr "Resampeln mittels Spline-Tension"
-#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1199
+#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1216
 #, fuzzy
-msgid "Performs bilinear or bicubic spline interpolation with Tykhonov regularization."
-msgstr "Bikubische oder bilineare Splineinterpolation mit Tykhonov Regularisierung."
+msgid ""
+"Performs bilinear or bicubic spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+"Bikubische oder bilineare Splineinterpolation mit Tykhonov Regularisierung."
-#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1200
+#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1217
 #, fuzzy
 msgid "Resample using analytic kernel"
-#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1201
+#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1218
 #, fuzzy
 msgid "Resamples raster map layers using an analytic kernel."
-#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:568
-#: ../gui/wxpython/menustrings.py:1202 ../gui/wxpython/menustrings.py:1480
+#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:585
+#: ../gui/wxpython/menustrings.py:1219 ../gui/wxpython/menustrings.py:1514
 msgid "Support file maintenance"
 msgstr "Wartung der Hilfsdateien"
-#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1203
+#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1220
 msgid "Allows creation and/or modification of raster map layer support files."
 msgstr "Ermöglicht Erzeugung und/oder Änderung von Rasterkarten-Hilfsdateien."
-#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1204
+#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1221
 msgid "Update map statistics"
 msgstr "Aktualisiere Karten-Statistiken"
-#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:1205
+#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:1222
 msgid "Update raster map statistics"
 msgstr "Aktualisiere die Statistik der Rasterkarte."
-#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1208
+#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1225
 msgid "Tiling"
 msgstr "Kacheln erzeugen"
-#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1209
-msgid "Produces tilings of the source projection for use in the destination region and projection."
-msgstr "Erzeugt Kacheln der Quelloprojection um sie in der Zielprojektion und -location zu nutzen"
+#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1226
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+"Erzeugt Kacheln der Quelloprojection um sie in der Zielprojektion und -"
+"location zu nutzen"
-#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:587
-#: ../gui/wxpython/menustrings.py:1210 ../gui/wxpython/menustrings.py:1499
+#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:604
+#: ../gui/wxpython/menustrings.py:1227 ../gui/wxpython/menustrings.py:1533
 msgid "Manage colors"
 msgstr "Farben verwalten"
-#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:588
-#: ../gui/wxpython/menustrings.py:1211 ../gui/wxpython/menustrings.py:1500
+#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:605
+#: ../gui/wxpython/menustrings.py:1228 ../gui/wxpython/menustrings.py:1534
 msgid "Color tables"
 msgstr "Farbtabellen"
-#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1212
+#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1229
 #, fuzzy
 msgid "Creates/modifies the color table associated with a raster map."
 msgstr "Erzeugt / modifiziert die Farbtabelle einer Rasterkarte"
-#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1213
+#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1230
 msgid "Color tables (stddev)"
 msgstr "Farbtabellen (Stdabw)"
-#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:1214
+#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:1231
 #, fuzzy
 msgid "Sets color rules based on stddev from a raster map's mean value."
 msgstr "Bestimme Farbregeln basierend auf der Standardabweichung."
-#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:590
-#: ../gui/wxpython/menustrings.py:1215 ../gui/wxpython/menustrings.py:1502
+#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:607
+#: ../gui/wxpython/menustrings.py:1232 ../gui/wxpython/menustrings.py:1536
 #, fuzzy
 msgid "Manage color rules interactively"
 msgstr "oder gebe Werte interaktiv ein"
-#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:1216
+#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:1233
 msgid "Interactive management of raster color tables."
 msgstr "Interaktive Bearbeitung der Rasterfarbtabelle."
-#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:592
-#: ../gui/wxpython/menustrings.py:1217 ../gui/wxpython/menustrings.py:1504
+#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:609
+#: ../gui/wxpython/menustrings.py:1234 ../gui/wxpython/menustrings.py:1538
 msgid "Export color table"
 msgstr "Exportiere Farbtabelle"
-#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:1218
+#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:1235
 #, fuzzy
 msgid "Exports the color table associated with a raster map."
 msgstr "Exportiert die einer Rasterkarte zugeordnetenn Farbtabelle."
-#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1219
+#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1236
 msgid "Blend 2 color rasters"
 msgstr "Mische 2 Farbraster"
-#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1220
+#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1237
 msgid "Blends color components of two raster maps by a given ratio."
 msgstr "Vereint Farbkomponenten von zwei Rasterkarten"
-#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1221
+#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1238
 msgid "Create RGB"
 msgstr "Erzeuge RGB"
-#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1222
-msgid "Combines red, green and blue raster maps into a single composite raster map."
+#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1239
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
 msgstr "Kombiniert die Farbkanäle rot, grün und blau zu einer Komposit-Karte."
-#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:745
-#: ../gui/wxpython/menustrings.py:1223 ../gui/wxpython/menustrings.py:1657
+#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:762
+#: ../gui/wxpython/menustrings.py:1240 ../gui/wxpython/menustrings.py:1691
 msgid "RGB to HIS"
 msgstr "RGB zu HIS"
-#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1224
-msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
-msgstr "Erzeugt rot, grün und blaue (RGB) Karten aus einer benutzerspezifizierten Kombination von Wert-, Intensitäts- und Sättigungs-Karten (HIS)."
+#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1241
+msgid ""
+"Generates red, green and blue raster map layers combining hue, intensity and "
+"saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+"Erzeugt rot, grün und blaue (RGB) Karten aus einer benutzerspezifizierten "
+"Kombination von Wert-, Intensitäts- und Sättigungs-Karten (HIS)."
-#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1225
+#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1242
 msgid "Query raster maps"
 msgstr "Rasterkarten abfragen"
-#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1226
+#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1243
 msgid "Query values by coordinates"
 msgstr "Abfrage mittels Koordinaten"
-#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1227
+#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1244
 #, fuzzy
 msgid "Queries raster maps on their category values and category labels."
 msgstr "Fragt Rasterkartenwerte und deren Kategoriewerte &- beschriftungen ab."
-#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:1228
+#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:1245
 msgid "Query colors by value"
 msgstr "Farben über Wert abfragen"
-#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:1229
+#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:1246
 msgid "Queries colors for a raster map layer."
 msgstr "Gibt Farbwerte für eine Rasterkarte aus."
-#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1237
+#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1254
 msgid "Buffer rasters"
 msgstr "Rasterzellen buffern"
-#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1238
+#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1255
 #, fuzzy
-msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
-msgstr "Erzeugt eine Rasterkarte mit Pufferzonen um Pixel, die keine NULL-Werte haben."
+msgid ""
+"Creates a raster map showing buffer zones surrounding cells that contain non-"
+"NULL category values."
+msgstr ""
+"Erzeugt eine Rasterkarte mit Pufferzonen um Pixel, die keine NULL-Werte "
+"haben."
-#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1239
+#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1256
 msgid "Concentric circles"
 msgstr "Konzentrische Kreise"
-#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1240
+#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1257
 msgid "Creates a raster map containing concentric rings around a given point."
-msgstr "Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen Punkt ziehen."
+msgstr ""
+"Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen "
+"Punkt ziehen."
-#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1241
+#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1258
 msgid "Closest points"
 msgstr "Nächstgelegene Punkte"
-#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1242
+#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1259
 msgid "Locates the closest points between objects in two raster maps."
 msgstr "Findet den nächsten Punkt zwischen Objekten in zwei Rasterkarten."
-#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1244
+#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1261
 msgid "Creates a MASK for limiting raster operation."
-msgstr "Erzeugt eine MASK für räumlich eingeschränkte Rasterkartenberechnungen."
+msgstr ""
+"Erzeugt eine MASK für räumlich eingeschränkte Rasterkartenberechnungen."
-#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1245
+#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1262
 msgid "Raster map calculator"
 msgstr "Rasterkartenrechner"
-#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1246
+#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1263
 #, fuzzy
 msgid "Raster map calculator."
 msgstr "3D Rasterkartenrechner"
-#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1247
+#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1264
 msgid "Neighborhood analysis"
 msgstr "Nachbarschaftsanalyse"
-#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1249
-msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
-msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Kategoriewerte basierend auf einer Fenstergrösse zu und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
+#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1266
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+"Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
+"Kategoriewerte basierend auf einer Fenstergrösse zu und erstellt neue "
+"Zellenwerte in einer Ausgabe-Rasterkarte."
-#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1250
+#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1267
 msgid "Neighborhood points"
 msgstr "Benachbarte Punkte"
-#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1251
+#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1268
 #, fuzzy
-msgid "Neighborhood analysis tool for vector point maps. Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
-msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Vektorpunkte oder Zentroide und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
+msgid ""
+"Neighborhood analysis tool for vector point maps. Makes each cell value a "
+"function of the attribute values assigned to the vector points or centroids "
+"around it, and stores new cell values in an output raster map."
+msgstr ""
+"Vektorpunkte oder Zentroide und erstellt neue Zellenwerte in einer Ausgabe-"
+"Rasterkarte."
-#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1252
+#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1269
 msgid "Overlay rasters"
 msgstr "Karten überlagern"
-#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1253
+#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1270
 msgid "Cross product"
 msgstr "Kreuzprodukt"
-#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1254
-msgid "Creates a cross product of the category values from multiple raster map layers."
+#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1271
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
 msgstr "Erzeugt ein Kreuzprodukt der Kategriewerte verschiedener Rasterkarten"
-#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1255
+#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1272
 msgid "Raster series"
 msgstr "Raster-Serie"
-#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1256
-msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
-msgstr "Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
+#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1273
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+"Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer "
+"korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
-#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1257
+#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1274
 msgid "Patch raster maps"
 msgstr "Rasterkarten patchen"
-#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1258
-msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr "Erzeugt eine Komposit-Rasterkarte unter Nutzung von Werten aus einer (oder mehrerer) Karte, um NULL-Werte einer anderen Karte zu füllen."
+#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1275
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+"Erzeugt eine Komposit-Rasterkarte unter Nutzung von Werten aus einer (oder "
+"mehrerer) Karte, um NULL-Werte einer anderen Karte zu füllen."
-#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1259
+#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1276
 msgid "Statistical overlay"
 msgstr "Statistik Überlagerung"
-#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1260
+#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1277
 #, fuzzy
-msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
+msgid ""
+"Calculates category or object oriented statistics (accumulator-based "
+"statistics)."
 msgstr "Berechnet kategorie- oder objektorientierte Statistik."
-#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1261
+#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1278
 msgid "Quantiles overlay"
 msgstr "Quantile ᅵberlagern"
-#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1262
+#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1279
+#, fuzzy
+msgid "Compute category quantiles using two passes."
+msgstr "Berechne Quantile in zwei Durchgᅵngen"
+#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1280
 msgid "Solar radiance and shadows"
 msgstr "Solarstrahlung und Schatten"
-#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1263
+#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1281
 #, fuzzy
 msgid "LatLong map"
 msgstr "Lese Karte %s ..."
-#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1264
+#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1282
 #, fuzzy
 msgid "Creates a latitude/longitude raster map."
 msgstr "Die aktuelle Projektion ist nicht longitude-latitude."
-#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1265
+#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1283
 msgid "Solar irradiance and irradiation"
 msgstr "Sonnenstrahlungsdichte und -summe"
-#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1266
-msgid "Solar irradiance and irradiation model. Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1284
+msgid ""
+"Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
+"reflected solar irradiation raster maps for given day, latitude, surface and "
+"atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, "
+"declination, extraterrestrial irradiance, daylight length) are saved in the "
+"map history file. Alternatively, a local time can be specified to compute "
+"solar incidence angle and/or irradiance raster maps. The shadowing effect of "
+"the topography is optionally incorporated."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1267
+#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1285
 msgid "Shadows map"
 msgstr "Schattenkarten"
-#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1268
+#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1286
 #, fuzzy
-msgid "Calculates cast shadow areas from sun position and elevation raster map. Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
-msgstr "Berechnet verschattete Bereiche aus der Sonnenposition und einem DGM. Es wird eintweder eine genaue Sonnenposition oder Datumsinformationen zur Berechnung (mit r.sunmask) erwartet."
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map. "
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
+msgstr ""
+"Berechnet verschattete Bereiche aus der Sonnenposition und einem DGM. Es "
+"wird eintweder eine genaue Sonnenposition oder Datumsinformationen zur "
+"Berechnung (mit r.sunmask) erwartet."
-#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1269
+#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1287
 #, fuzzy
 msgid "Sunshine hours and solar angles"
 msgstr "Sonnenscheinstunden"
-#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1270
-msgid "Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: the angle between the direction of the geometric center of the sun's apparent disk and the (idealized) horizon. Solar azimuth: the angle from due north in clockwise direction."
+#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1288
+msgid ""
+"Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
+"the angle between the direction of the geometric center of the sun's "
+"apparent disk and the (idealized) horizon. Solar azimuth: the angle from due "
+"north in clockwise direction."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1271
+#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1289
 msgid "Terrain analysis"
 msgstr "Reliefanalyse"
-#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1272
+#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1290
 msgid "Generate contour lines"
 msgstr "Kontourlinien erzeugen"
-#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1273
+#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1291
 msgid "Produces a vector map of specified contours from a raster map."
 msgstr "Erzeugt eine Vektorkarte ausgewählter Konturen aus einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1274
+#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1292
 msgid "Cost surface"
 msgstr "Kostenoberfläche"
-#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1275
-msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
-msgstr "Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die Kategoriewerte der Eingabekarte repräsentieren die Kosten."
+#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1293
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
+msgstr ""
+"Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen "
+"zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die "
+"Kategoriewerte der Eingabekarte repräsentieren die Kosten."
-#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1276
+#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1294
 msgid "Cumulative movement costs"
 msgstr "Kumulierte Bewegungskosten"
-#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1277
+#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1295
 #, fuzzy
-msgid "Outputs a raster map showing the anisotropic cumulative cost. Computes anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
-msgstr "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte mit Reibungs-Kosten kombiniert."
+msgid ""
+"Outputs a raster map showing the anisotropic cumulative cost. Computes "
+"anisotropic cumulative cost of moving between different geographic locations "
+"on an input elevation raster map whose cell category values represent "
+"elevation combined with an input raster map layer whose cell values "
+"represent friction cost."
+msgstr ""
+"Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die "
+"beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. "
+"Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte "
+"mit Reibungs-Kosten kombiniert."
-#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1278
+#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1296
 msgid "Least cost route or flow"
 msgstr "Route/Fluß geringster Kosten"
-#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1279
+#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1297
 #, fuzzy
-msgid "Traces a flow through an elevation model or cost surface on a raster map."
+msgid ""
+"Traces a flow through an elevation model or cost surface on a raster map."
 msgstr "Verfolgt einen Fluss durch ein Rasterhöhenmodell."
-#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1280
+#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1298
 msgid "Shaded relief"
 msgstr "Reliefschattierungen"
-#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1281
+#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1299
 #, fuzzy
 msgid "Creates shaded relief map from an elevation map (DEM). "
-msgstr "Erstellt eine geschummerte Reliefkarte auf Basis einer Höhenkarte (DHM)."
+msgstr ""
+"Erstellt eine geschummerte Reliefkarte auf Basis einer Höhenkarte (DHM)."
-#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1282
+#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1300
 msgid "Slope and aspect"
 msgstr "Hangneigung und -exposition"
-#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1283
+#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1301
 #, fuzzy
-msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from an elevation raster map. Aspect is calculated counterclockwise from east."
-msgstr "Erzeugt Hangneigungs-, Hangexpositions-, Wölbungs- und partielle Ableitungskarten von einer Rasterkarte mit Höheninformationen.Hangexpositionen werden von Osten gegen den Uhrzeigersinn berechnet."
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from an elevation raster map. Aspect is calculated counterclockwise from "
+"east."
+msgstr ""
+"Erzeugt Hangneigungs-, Hangexpositions-, Wölbungs- und partielle "
+"Ableitungskarten von einer Rasterkarte mit Höheninformationen."
+"Hangexpositionen werden von Osten gegen den Uhrzeigersinn berechnet."
-#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1284
+#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1302
 msgid "Terrain parameters"
 msgstr "Reliefparameter"
-#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1285
-msgid "Extracts terrain parameters from a DEM. Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1303
+msgid ""
+"Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
+"taking fitting quadratic parameters to any size window (via least squares)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1286
+#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1304
 msgid "Textural features"
 msgstr "Textur-Feature"
-#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1287
+#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1305
 msgid "Generate images with textural features from a raster map."
 msgstr "Erzeugt Texturbilder von einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1288
+#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1306
 msgid "Visibility"
 msgstr "Sichtbarkeit"
-#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1289
+#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1307
 #, fuzzy
-msgid "Computes the viewshed of a point on an elevation raster map. Default format: NULL (invisible), vertical angle wrt viewpoint (visible)."
+msgid ""
+"Computes the viewshed of a point on an elevation raster map. Default format: "
+"NULL (invisible), vertical angle wrt viewpoint (visible)."
 msgstr "Berechnet Schlagschatten aus der Sonnenposition und einer Höhenkarte."
-#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1290
+#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1308
 #, fuzzy
 msgid "Visibility [DEPRECATED]"
-#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1291
+#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1309
 msgid "Line-of-sight raster analysis program."
 msgstr "Sichtbarkeitsanalyse (Line of Sight) für Rasterkarten."
-#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1292
+#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1310
 msgid "Distance to features"
 msgstr "Distanz zum Objekt"
-#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1293
+#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1311
 #, fuzzy
 msgid "Generates a raster map containing distances to nearest raster features."
-msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
+msgstr ""
+"Erzeugt eine Rasterkarte mit Distanzen zu Featuren in der Eingabekarte."
-#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1294
+#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1312
 msgid "Horizon angle"
 msgstr "Horizontwinkel"
-#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1295
-msgid "Horizon angle computation from a digital elevation model. Computes horizon angle height from a digital elevation model. The module has two different modes of operation: 1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction. The input for this is the angle (in degrees), which is measured counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
+#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1313
+msgid ""
+"Horizon angle computation from a digital elevation model. Computes horizon "
+"angle height from a digital elevation model. The module has two different "
+"modes of operation: 1. Computes the entire horizon around a single point "
+"whose coordinates are given with the 'coord' option. The horizon height (in "
+"radians). 2. Computes one or more raster maps of the horizon height in a "
+"single direction. The input for this is the angle (in degrees), which is "
+"measured counterclockwise with east=0, north=90 etc. The output is the "
+"horizon height in radians."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1296
+#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1314
 msgid "Transform features"
 msgstr "Transformiere Objekte"
-#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1297
+#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1315
 msgid "Clump"
 msgstr "Klumpen"
-#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1298
-msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
-msgstr "Rekategoriziert Daten aus Rasterkarten durch Zusammenfassen von räumlich getrennten, aber gleichartigen Zellen zu eigenständigen Kategorien."
+#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1316
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
+msgstr ""
+"Rekategoriziert Daten aus Rasterkarten durch Zusammenfassen von räumlich "
+"getrennten, aber gleichartigen Zellen zu eigenständigen Kategorien."
-#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1299
+#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1317
 msgid "Grow"
 msgstr "Wachsen"
-#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1300
+#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1318
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr "Erstellt eine Rasterkarte mit Flächen, die um jeweils eine Zelle erweitert wurde"
+msgstr ""
+"Erstellt eine Rasterkarte mit Flächen, die um jeweils eine Zelle erweitert "
+"wurde"
-#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1301
+#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1319
 msgid "Thin"
 msgstr "Ausdünnen"
-#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1302
+#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1320
 msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr "Dünnt Rasterstrukturen aus, die nicht null (0) sind und linienhafte Strukturen zeigen."
+msgstr ""
+"Dünnt Rasterstrukturen aus, die nicht null (0) sind und linienhafte "
+"Strukturen zeigen."
-#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1303
+#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1321
 msgid "Hydrologic modeling"
 msgstr "Hydrologische Modellierung"
-#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1304
+#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1322
 msgid "Carve stream channels"
 msgstr "Abflusslinien graben"
-#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1305
+#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1323
 #, fuzzy
-msgid "Generates stream channels. Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
-msgstr "Erzeugt aus Abflusslinien (Vektor) Resterdaten und substrahiert die Tiefe vom ausgegebenen DHM "
+msgid ""
+"Generates stream channels. Takes vector stream data, transforms it to raster "
+"and subtracts depth from the output DEM."
+msgstr ""
+"Erzeugt aus Abflusslinien (Vektor) Resterdaten und substrahiert die Tiefe "
+"vom ausgegebenen DHM "
-#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1306
+#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1324
 msgid "Fill lake"
 msgstr "Fülle Seen"
-#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1307
+#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1325
 msgid "Fills lake at given point to given level."
 msgstr "Füllt Seen von einem gegebenen Punkt bis zu einem bestimmten Stand."
-#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1308
+#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1326
 msgid "Depressionless map and flowlines"
 msgstr "Senkenloses Höhenmodell und Abflusslinienkarte"
-#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1309
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
-msgstr "Filtert und erzeugt aus einem Höhenmodell sowohl eine depressionslose Höhenkarte als auch eine Karte mit Fließrichtungen."
+#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1327
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
+msgstr ""
+"Filtert und erzeugt aus einem Höhenmodell sowohl eine depressionslose "
+"Höhenkarte als auch eine Karte mit Fließrichtungen."
-#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1310
+#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1328
 msgid "Flow accumulation"
 msgstr "Flußakkumulation"
-#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1311
+#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1329
 msgid "Flow computation for massive grids (float version)."
-msgstr "Berechnung der Fließrichtung und -mengen für sehr großen Rastern (Float-Version)."
+msgstr ""
+"Berechnung der Fließrichtung und -mengen für sehr großen Rastern (Float-"
+"Version)."
-#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1312
+#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1330
 msgid "Flow lines"
 msgstr "Flußlinien"
-#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1313
+#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1331
 #, fuzzy
-msgid "Constructs flowlines. Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
-msgstr "Berechnung von Abflusslinien, Länge der Fliesswege und Flussdichte aus einem digitalen Höhenmodell."
+msgid ""
+"Constructs flowlines. Computes flowlines, flowpath lengths, and "
+"flowaccumulation (contributing areas) from a elevation raster map."
+msgstr ""
+"Berechnung von Abflusslinien, Länge der Fliesswege und Flussdichte aus einem "
+"digitalen Höhenmodell."
-#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1314
+#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1332
 msgid "Watershed analysis"
 msgstr "Wassereinzugsgebiet Analyse"
-#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1315
+#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1333
 msgid "Calculates hydrological parameters and RUSLE factors."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1316
+#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1334
 msgid "Watershed subbasins"
 msgstr "Einzugsgebietsunterflächen"
-#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1317
+#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1335
 msgid "Generates watershed subbasins raster map."
 msgstr "Erzeugt Rasterkarte der Sub-Wassereinzugsgebiete."
-#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1318
+#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1336
 msgid "Watershed basin creation"
 msgstr "Wassereinzugsgebietsberechnung"
-#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1319
+#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1337
 #, fuzzy
 msgid "Creates watershed basins from a drainage direction map."
-#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1320
+#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1338
+#, fuzzy
+msgid "River channel characteristics"
+msgstr "Bericht und Statistiken"
+#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1339
+msgid "Calculates local parameters for individual streams."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1340
+msgid "River distance and elevation characteristics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1341
+msgid ""
+"Calculates distance to and elevation above streams and outlets. The module "
+"can work in stream mode where target are streams and outlets mode where "
+"targets are outlets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1342
+msgid "Extraction of stream networks"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1343
+#, fuzzy
+msgid "Performs stream network extraction."
+msgstr "Führt Netzwerkwartung durch."
+#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1344
+msgid "River ordering and hierarchy"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1345
+msgid ""
+"Calculates Strahler's and more streams hierarchy. Basic module for "
+"topological analysis of drainage network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1346
+#, fuzzy
+msgid "River segment characteristics"
+#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1347
+msgid ""
+"Divides network into near straight-line segments and calculate its order."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1348
+#, fuzzy
+msgid "River elevation change"
+msgstr "Vorherige Änderungen rückgängig machen"
+#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1349
+msgid "Calculates local parameters for slope subsystem."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1350
+msgid "Position correction of water outlet point"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1351
+msgid ""
+"Snap point to modelled river network. Input can be stream network, point "
+"vector map with outlets or outlet coordinates."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1352
+#, fuzzy
+msgid "Horton's statistics"
+msgstr "Grafik Statistiken"
+#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1353
+msgid ""
+"Calculates Horton's statistics for Strahler and Horton ordered networks "
+"created with r.stream.order."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1354
 msgid "SIMWE Overland flow modeling"
 msgstr "SIMWE Oberflächenabflussmodellierung"
-#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1321
+#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1355
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr "Hydrologische Simulation des Oberflächenabfluss mittels \"path sampling\" (SIMWE)."
+msgstr ""
+"Hydrologische Simulation des Oberflächenabfluss mittels \"path sampling"
+"\" (SIMWE)."
-#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1322
+#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1356
 msgid "SIMWE Sediment flux modeling"
 msgstr "SIMWE Sedimentbewegungsmodellierung"
-#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1323
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
-msgstr "Sedimenttransport und Erosions-/Deposition-Simulation mittels \"path sampling\" (SIMWE)."
+#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1357
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
+"Sedimenttransport und Erosions-/Deposition-Simulation mittels \"path sampling"
+"\" (SIMWE)."
-#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1324
+#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1358
 msgid "Topographic index map"
 msgstr "Karte mit topographischem Index"
-#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1325
+#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1359
 msgid "Creates topographic index map from elevation raster map."
 msgstr "Erstellt Karten des topographischen Index auf Basis einer Höhenkarte."
-#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1326
+#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1360
 msgid "TOPMODEL simulation"
 msgstr "TOPMODEL Simulation"
-#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1327
+#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1361
 msgid "Simulates TOPMODEL which is a physically based hydrologic model."
 msgstr "TOPMODEL Simulation (physikalisch basiertes hydrologisches Modell)."
-#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1328
+#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1362
 msgid "USLE K-factor"
 msgstr "USLE K-Faktor"
-#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1329
+#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1363
 msgid "Computes USLE Soil Erodibility Factor (K)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1330
+#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1364
 msgid "USLE R-factor"
 msgstr "USLE R-Faktor"
-#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1331
+#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1365
 msgid "Computes USLE R factor, Rainfall erosivity index."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:851
-#: ../gui/wxpython/menustrings.py:1332 ../gui/wxpython/menustrings.py:1763
+#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:868
+#: ../gui/wxpython/menustrings.py:1366 ../gui/wxpython/menustrings.py:1797
 msgid "Groundwater modeling"
 msgstr "Grundwassermodellierung"
-#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1333
+#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1367
 msgid "Groundwater flow"
 msgstr "Grundwasserfluss"
-#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1334
-msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
-msgstr "Numerische Berechnung von transientem, beschränktem und unbeschränktem Grundwasserfluss in zwei Dimensionen."
+#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1368
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
+msgstr ""
+"Numerische Berechnung von transientem, beschränktem und unbeschränktem "
+"Grundwasserfluss in zwei Dimensionen."
-#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1335
+#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1369
 #, fuzzy
 msgid "Groundwater solute transport"
 msgstr "\t 1. Teste 2d solute_transport"
-#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1336
+#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1370
 #, fuzzy
-msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
-msgstr "Programm zur numerischen Berechnung von transienten, beschrᅵnkten und unbeschrᅵnkten Grundwasserfluss in zwei Dimensionen."
+msgid ""
+"Numerical calculation program for transient, confined and unconfined solute "
+"transport in two dimensions"
+msgstr ""
+"Programm zur numerischen Berechnung von transienten, beschrᅵnkten und "
+"unbeschrᅵnkten Grundwasserfluss in zwei Dimensionen."
-#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1337
+#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1371
 msgid "Landscape structure modeling"
 msgstr "Landschaftsstruktur Modellierung"
-#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1338
+#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1372
 msgid "Analyze landscape"
 msgstr "Landschaftsanalyse"
-#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1339
+#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1373
 msgid "Analyze patches"
 msgstr "Analysiere Patches"
-#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1340
+#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1374
 msgid "Landscape patch analysis"
 msgstr "Landschaft-Patchanalyse"
-#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1341
+#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1375
 msgid "Set up sampling and analysis framework"
 msgstr "Definiert eine Test- und Analyseumgebung"
-#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1342
+#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1376
 msgid "Configuration editor for r.li.'index'"
 msgstr "Editor für Konfigurationsdateien für r.li.'index'."
-#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1343
+#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1377
 msgid "Edge density"
 msgstr "Kantendichte"
-#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1344
-msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr "Berechnet die Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
+#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1378
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+"Berechnet die Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines "
+"4-Nachbarn-Algorithmus."
-#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1345
+#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1379
 msgid "Contrast weighted edge density"
 msgstr "Kantendichte (gewichtet nach Kontrast)"
-#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1346
+#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1380
 msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr "Berechnet den Kanten-Dichte-Index einer Rasterkarte gewichtet nach dem Kontrast"
+msgstr ""
+"Berechnet den Kanten-Dichte-Index einer Rasterkarte gewichtet nach dem "
+"Kontrast"
-#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1347
+#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1381
 msgid "Patch area mean"
 msgstr "Mittlere Patchgröße"
-#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1348
-msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
-msgstr "Berechnet die mittlere Patchgrößein einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
+#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1382
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+"Berechnet die mittlere Patchgrößein einer Rasterkarte, unter Verwendung "
+"eines 4-Nachbarn-Algorithmus."
-#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1349
+#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1383
 msgid "Patch area range"
 msgstr "Patchgröße (Wertebereich)"
-#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1350
+#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1384
 msgid "Calculates range of patch area size on a raster map"
 msgstr "Berechnet die Spanne der Patch-Größen einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1351
+#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1385
 msgid "Patch area Std Dev"
 msgstr "Patchgröße (Standardabweichung)"
-#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1352
+#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1386
 msgid "Calculates standard deviation of patch area a raster map"
 msgstr "Berechnet die Standardabweichung der Patch-Größen einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1353
+#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1387
 msgid "Patch area Coeff Var"
 msgstr "Patchgröße (Variationskoeffizient)"
-#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1354
+#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1388
 msgid "Calculates coefficient of variation of patch area on a raster map"
 msgstr "Berechnet Variationskoeffizient der Patch-Größen einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1355
+#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1389
 msgid "Patch density"
 msgstr "Patchdichte"
-#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1356
-msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr "Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
+#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1390
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+"Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
+"Nachbarn-Algorithmus."
-#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1357
+#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1391
 msgid "Patch number"
 msgstr "Patchanzahl"
-#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1358
-msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr "Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
+#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1392
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+"Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-"
-#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1359
+#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1393
 msgid "Dominance's diversity"
 msgstr "Diversitätsindex (nach Dominanz)"
-#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1360
+#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1394
 msgid "Calculates dominance's diversity index on a raster map"
 msgstr "Berechnet den Dominanz-Diversitäts-Index einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1361
+#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1395
 msgid "Shannon's diversity"
 msgstr "Shannon's Diversitätsindex"
-#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1362
+#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1396
 msgid "Calculates Shannon's diversity index on a raster map"
 msgstr "Berechnet Shannons Diversitätsindex einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1363
+#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1397
 msgid "Simpson's diversity"
 msgstr "Simpson's Diversitätsindex"
-#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1364
+#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1398
 msgid "Calculates Simpson's diversity index on a raster map"
 msgstr "Berechnet Simpsons-Diversitätsindex einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1365
+#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1399
 msgid "Richness"
 msgstr "Vielfalt"
-#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1366
+#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1400
 #, fuzzy
 msgid "Calculates richness index on a raster map"
 msgstr "Berechnet den Form-Index einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1367
+#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1401
 msgid "Shape index"
 msgstr "Shape Index"
-#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1368
+#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1402
 msgid "Calculates shape index on a raster map"
-#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1369
+#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1403
 msgid "Wildfire modeling"
 msgstr "Feuermodellierung"
-#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1370
+#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1404
 msgid "Rate of spread"
 msgstr "Ausbreitungsgeschwindigkeit"
-#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1371
+#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1405
 #, fuzzy
-msgid "Generates rate of spread raster maps. Generates three, or four raster map layers showing the base (perpendicular) rate of spread (ROS), the maximum (forward) ROS, the direction of the maximum ROS, and optionally the maximum potential spotting distance for fire spread simulation."
-msgstr "Erstellt drei oder optional vier Rasterkarten, die 1) die Basisrate der (lotrechten) Ausbreitung (ROS), 2) die maximale (Vorwärts-) Ausbreitung, 3) die Richtung der größten Ausbreitung, und optional 4) die maximal zu erkennende potentielle Ausbreitung, zeigen."
+msgid ""
+"Generates rate of spread raster maps. Generates three, or four raster map "
+"layers showing the base (perpendicular) rate of spread (ROS), the maximum "
+"(forward) ROS, the direction of the maximum ROS, and optionally the maximum "
+"potential spotting distance for fire spread simulation."
+msgstr ""
+"Erstellt drei oder optional vier Rasterkarten, die 1) die Basisrate der "
+"(lotrechten) Ausbreitung (ROS), 2) die maximale (Vorwärts-) Ausbreitung, 3) "
+"die Richtung der größten Ausbreitung, und optional 4) die maximal zu "
+"erkennende potentielle Ausbreitung, zeigen."
-#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1372
+#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1406
 msgid "Least-cost spread paths"
 msgstr "Geringsten-Kosten-Ausbreitungspfade"
-#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1373
-msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
-msgstr "Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von denen der kumulative Weg bestimmt wurde."
+#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1407
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+"Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von "
+"denen der kumulative Weg bestimmt wurde."
-#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1374
+#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1408
 msgid "Anisotropic spread simulation"
 msgstr "Anisotropische Ausbreitungssimulation"
-#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1375
+#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1409
 #, fuzzy
-msgid "Simulates elliptically anisotropic spread. Generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins. It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths. Usable for fire spread simulations."
-msgstr "Simuliert elliptische anisotrophe Ausbreitung in einem Kartenfenster und erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung und der Ursprung."
+msgid ""
+"Simulates elliptically anisotropic spread. Generates a raster map of the "
+"cumulative time of spread, given raster maps containing the rates of spread "
+"(ROS), the ROS directions and the spread origins. It optionally produces "
+"raster maps to contain backlink UTM coordinates for tracing spread paths. "
+"Usable for fire spread simulations."
+msgstr ""
+"Simuliert elliptische anisotrophe Ausbreitung in einem Kartenfenster und "
+"erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als "
+"Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung "
+"und der Ursprung."
-#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1376
+#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1410
 msgid "Change category values and labels"
 msgstr "Kategoriewerte und Label ändern"
-#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1377
+#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1411
 msgid "Interactively edit category values"
 msgstr "Interaktive Bearbeitung der Kategoriewerte"
-#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1378
+#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1412
 #, fuzzy
 msgid "Edits cell values in a raster map."
 msgstr "Editiere interaktiv Zellwerte einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1379
+#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1413
 msgid "Reclassify by size"
 msgstr "Klassifizieren nach Größe"
-#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1380
-msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
-msgstr "Reklassifiziert Bereiche eine Rasterkarte (größer oder kleiner) nach einer benutzerspezifischen Größe (in ha)."
+#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1414
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)."
+msgstr ""
+"Reklassifiziert Bereiche eine Rasterkarte (größer oder kleiner) nach einer "
+"benutzerspezifischen Größe (in ha)."
-#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:678
-#: ../gui/wxpython/menustrings.py:1381 ../gui/wxpython/menustrings.py:1590
+#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:695
+#: ../gui/wxpython/menustrings.py:1415 ../gui/wxpython/menustrings.py:1624
 msgid "Reclassify"
 msgstr "Reklassifiziere"
-#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1382
+#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1416
 #, fuzzy
-msgid "Reclassify raster map based on category values. Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
-msgstr "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
+msgid ""
+"Reclassify raster map based on category values. Creates a new raster map "
+"whose category values are based upon a reclassification of the categories in "
+"an existing raster map."
+msgstr ""
+"Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der "
+"Kategorien einer existierenden Rasterkarte basieren."
-#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1383
+#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1417
 msgid "Recode"
 msgstr "Umkodieren"
-#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1384
+#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1418
 msgid "Recodes categorical raster maps."
 msgstr "Rekodiert kategoriale Rasterkarten."
-#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1385
+#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1419
 msgid "Rescale"
 msgstr "Neu skalieren"
-#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1386
+#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1420
 msgid "Rescales the range of category values in a raster map layer."
 msgstr "Reskaliert die Spanne der Kategoriewerte einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1387
+#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1421
 msgid "Rescale with histogram"
 msgstr "Neuskalierung mit Histogramm"
-#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1388
-msgid "Rescales histogram equalized the range of category values in a raster map layer."
-msgstr "Reskaliert ein normalisiertes Histogram basierend auf der Spanne der Kategoriewerte einer Rasterkarte."
+#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1422
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+"Reskaliert ein normalisiertes Histogram basierend auf der Spanne der "
+"Kategoriewerte einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1389
+#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1423
 msgid "Generate random cells"
 msgstr "Erzeuge zufällige Zellen"
-#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1390
+#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1424
 msgid "Random cells"
 msgstr "Zufällige Zellen"
-#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1391
+#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1425
 msgid "Generates random cell values with spatial dependence."
 msgstr "Erzeugt zufällig Zellwerte mit räumlicher Abhängigkeit."
-#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1392
+#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1426
 msgid "Random cells and vector points"
 msgstr "Zufällige Zellen und Vektorpunkte"
-#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1393
-msgid "Creates a raster map layer and vector point map containing randomly located points."
-msgstr "Erzeugt eine Rasterkarte und eine Vektorkarte (Punkte) deren Inhalte räumlich zufällig verteilt sind."
+#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1427
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
+msgstr ""
+"Erzeugt eine Rasterkarte und eine Vektorkarte (Punkte) deren Inhalte "
+"räumlich zufällig verteilt sind."
-#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1394
+#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1428
 msgid "Generate surfaces"
 msgstr "Erzeuge Oberflächen"
-#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1395
+#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1429
 msgid "Fractal surface"
 msgstr "Fraktale Oberfläche"
-#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1396
+#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1430
 msgid "Creates a fractal surface of a given fractal dimension."
-msgstr "Erzeugt fraktale Oberflächen nach einer definierten fraktalen Dimension "
+msgstr ""
+"Erzeugt fraktale Oberflächen nach einer definierten fraktalen Dimension "
-#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1397
+#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1431
 msgid "Gaussian kernel density surface"
 msgstr "Gauß'sche Kerndichte Oberfläche"
-#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1398
+#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1432
 #, fuzzy
-msgid "Generates a raster density map from vector points map. Density is computed using a moving kernel. Optionally generates a vector density map on a vector network."
-msgstr "Erzeugt eine Dichte-Rasterkarte aus Vektorpunkten mittels eines \"moving Kernels\" oder erzeugt optional eine Dichte-Vektorkarte aus einem Netzwerk."
+msgid ""
+"Generates a raster density map from vector points map. Density is computed "
+"using a moving kernel. Optionally generates a vector density map on a vector "
+"network."
+msgstr ""
+"Erzeugt eine Dichte-Rasterkarte aus Vektorpunkten mittels eines \"moving "
+"Kernels\" oder erzeugt optional eine Dichte-Vektorkarte aus einem Netzwerk."
-#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1399
+#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1433
 msgid "Gaussian deviates surface"
 msgstr "Oberflächen (Gauß'sche Deviate)"
-#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1400
+#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1434
 #, fuzzy
-msgid "Generates a raster map using gaussian random number generator. Mean and standard deviation of gaussian deviates can be expressed by the user."
+msgid ""
+"Generates a raster map using gaussian random number generator. Mean and "
+"standard deviation of gaussian deviates can be expressed by the user."
+msgstr ""
-#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1401
+#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1435
 #: ../gui/wxpython/nviz/tools.py:4587
 msgid "Plane"
 msgstr "Ebene"
-#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1402
-msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
-msgstr "Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung (inclination), Ausrichtung (azimuth) und einem Punkt."
+#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1436
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+"Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung "
+"(inclination), Ausrichtung (azimuth) und einem Punkt."
-#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1403
+#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1437
 msgid "Random deviates surface"
 msgstr "Oberfläche zufälliger Abweichungen"
-#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1404
+#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1438
 #, fuzzy
-msgid "Produces a raster surface map of uniform random deviates with defined range."
-msgstr "Erzeugt eine Rasterkarte mit gleichverteilten zufälligen Abweichungen, deren Wertebereiche vom Benutzer festgelegt werden können."
+msgid ""
+"Produces a raster surface map of uniform random deviates with defined range."
+msgstr ""
+"Erzeugt eine Rasterkarte mit gleichverteilten zufälligen Abweichungen, deren "
+"Wertebereiche vom Benutzer festgelegt werden können."
-#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1405
+#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1439
 msgid "Random surface with spatial dependence"
 msgstr "Zufällige Oberfläche mit räumlicher Abhängigkeit"
-#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1406
+#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1440
 msgid "Generates random surface(s) with spatial dependence."
 msgstr "Erzeugt zufällige Oberfläche(n) mit räumlicher Abhängigkeit."
-#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1407
+#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1441
 msgid "Interpolate surfaces"
 msgstr "Interpoliere Oberflächen"
-#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1408
+#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1442
 msgid "Bilinear and bicubic from vector points"
 msgstr "Bilinear und Bikubisch aus Vektorpunkten"
-#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1409
+#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1443
 #, fuzzy
-msgid "Performs bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr "Bikubische oder bilineare Splineinterpolation mit Tykhonov Regularisierung."
+msgid ""
+"Performs bicubic or bilinear spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+"Bikubische oder bilineare Splineinterpolation mit Tykhonov Regularisierung."
-#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1410
+#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1444
 msgid "IDW from raster points"
 msgstr "IDW aus Rasterpunkten"
-#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1411
+#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1445
 msgid "Surface interpolation utility for raster map."
 msgstr "Oberflächeinterpolation für Rasterkarten."
-#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1412
+#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1446
 msgid "IDW from raster points (alternate method for sparse points)"
 msgstr "IDW aus Rasterpunkten (alternative Methode für dünngesäte Punkte)"
-#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1413
+#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1447
 msgid "Surface generation program."
 msgstr "Erzeugt Rasteroberflächen."
-#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1414
+#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1448
 msgid "IDW from vector points"
 msgstr "IDW aus Vektorpunkten"
-#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1415
+#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1449
 #, fuzzy
-msgid "Provides surface interpolation from vector point data by Inverse Distance Squared Weighting."
-msgstr "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance Squared Weighting."
+msgid ""
+"Provides surface interpolation from vector point data by Inverse Distance "
+"Squared Weighting."
+msgstr ""
+"Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance "
-#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1416
+#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1450
 msgid "Raster contours"
 msgstr "Rasterkontouren"
-#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1417
+#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1451
 #, fuzzy
 msgid "Generates surface raster map from rasterized contours."
 msgstr "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien."
-#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1418
+#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1452
 msgid "Regularized spline tension"
 msgstr "Regularized spline tension"
-#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1419
+#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1453
 #, fuzzy
-msgid "Performs surface interpolation from vector points map by splines. Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
-msgstr "Räumliche Approximation und topographische Analyse auf Basis gegebener Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-Rasterkarte geschrieben."
+msgid ""
+"Performs surface interpolation from vector points map by splines. Spatial "
+"approximation and topographic analysis from given point or isoline data in "
+"vector format to floating point raster format using regularized spline with "
+"tension."
+msgstr ""
+"Räumliche Approximation und topographische Analyse auf Basis gegebener "
+"Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten "
+"Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-"
+"Rasterkarte geschrieben."
-#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1420
+#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1454
 msgid "Ordinary or block kriging"
 msgstr "Gewöhnliches oder Block Kriging"
-#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1421
+#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1455
 msgid "Performs ordinary or block kriging."
 msgstr "Führt gewöhnliches oder Block Kriging durch."
-#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1422
+#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1456
 msgid "Fill NULL cells"
 msgstr "Fülle NULL-Zellen"
-#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1423
+#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1457
 msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr "Füllt Flächen ohne Daten in Rasterkarten mit Hilfe der Spline-Interpolation."
+msgstr ""
+"Füllt Flächen ohne Daten in Rasterkarten mit Hilfe der Spline-Interpolation."
-#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:717
-#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:995
-#: ../gui/wxpython/menustrings.py:1424 ../gui/wxpython/menustrings.py:1629
-#: ../gui/wxpython/menustrings.py:1737 ../gui/wxpython/menustrings.py:1907
+#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:734
+#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1012
+#: ../gui/wxpython/menustrings.py:1458 ../gui/wxpython/menustrings.py:1663
+#: ../gui/wxpython/menustrings.py:1771 ../gui/wxpython/menustrings.py:1941
 msgid "Reports and statistics"
-#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1425
+#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1459
 msgid "Basic raster metadata"
 msgstr "Grundlegende Raster-Metadaten"
-#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1426
+#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1460
 #, fuzzy
 msgid "Outputs basic information about a raster map."
 msgstr "Gebe grundlegende Informationen über eine Rasterkarte aus."
-#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1427
+#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1461
 msgid "Manage category information"
 msgstr "Verwalte Kategorieinformationen"
-#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1428
-msgid "Manages category values and labels associated with user-specified raster map layers."
-msgstr "Verwaltet die Kategoriewerte und Beschriftungen von benutzerdefinierten Rasterkarten."
+#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1462
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+"Verwaltet die Kategoriewerte und Beschriftungen von benutzerdefinierten "
+"Rasterkarten."
-#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1429
+#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1463
 msgid "General statistics"
 msgstr "Allgemeine Statistiken"
-#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1430
+#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1464
 #, fuzzy
 msgid "Generates area statistics for raster map."
 msgstr "Erzeugt Flächenstatistiken für Rasterkarten."
-#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1431
+#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1465
 msgid "Quantiles for large data sets"
 msgstr "Quantile für große Datensätze"
-#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1432
+#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1466
 msgid "Compute quantiles using two passes."
 msgstr "Berechne Quantile in zwei Durchgängen"
-#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1433
+#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1467
 msgid "Range of category values"
 msgstr "Wertebereich der Kategoriewerte"
-#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1434
+#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1468
 msgid "Prints terse list of category values found in a raster map layer."
 msgstr "Gibt eine kurze Liste der Kategoriewerte einer Rasterkarte aus."
-#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1435
+#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1469
 msgid "Sum area by raster map and category"
 msgstr "Addiere Flächen nach Rasterkarte und Kategorie"
-#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1436
+#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1470
 #, fuzzy
 msgid "Reports statistics for raster maps."
 msgstr "Gibt statistische Werte für eine Rasterkarte aus."
-#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1437
+#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1471
 msgid "Statistics for clumped cells"
 msgstr "Statistiken für geklumpte Zellen"
-#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1438
+#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1472
 #, fuzzy
-msgid "Calculates the volume of data \"clumps\". Optionally produces a GRASS vector points map containing the calculated centroids of these clumps."
-msgstr "Berechnet das Volumen von Daten-\"Klumpen\". Optional kann eine GRASS-Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
+msgid ""
+"Calculates the volume of data \"clumps\". Optionally produces a GRASS vector "
+"points map containing the calculated centroids of these clumps."
+msgstr ""
+"Berechnet das Volumen von Daten-\"Klumpen\". Optional kann eine GRASS-"
+"Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
-#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1439
+#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1473
 msgid "Total corrected area"
 msgstr "Gesamte korrigierte Fläche"
-#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1440
+#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1474
 #, fuzzy
 msgid "Prints estimation of surface area for raster map."
-#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1441
+#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1475
 #: ../gui/wxpython/lmgr/layertree.py:579 ../gui/wxpython/lmgr/layertree.py:606
 msgid "Univariate raster statistics"
 msgstr "Univariate Statistiken"
-#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1442
-msgid "Calculates univariate statistics from the non-null cells of a raster map."
-msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1476
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1443
+#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1477
 msgid "Sample transects"
 msgstr "Transekt-Stichprobe"
-#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1444
+#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1478
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr "Gibt Werte einer Rasterkarte aus, die entlang einer/mehrerer benutzerdefinierter Linien liegen."
+msgstr ""
+"Gibt Werte einer Rasterkarte aus, die entlang einer/mehrerer "
+"benutzerdefinierter Linien liegen."
-#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1445
+#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1479
 msgid "Sample transects (bearing/distance)"
 msgstr "Transekt-Stichprobe (Azimuth, Distanz)"
-#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1446
-msgid "Outputs raster map layer values lying along user defined transect line(s)."
-msgstr "Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer benutzerdefinierter Transekte liegen."
+#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1480
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+"Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer "
+"benutzerdefinierter Transekte liegen."
-#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1447
+#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1481
 msgid "Covariance/correlation"
 msgstr "Kovarianz/Korrelation"
-#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1448
-msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
-msgstr "Gibt eine Kovarianz-/Korrelations-Matrix für benutzerdefiniert Rasterkarten aus."
+#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1482
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map "
+"layer(s)."
+msgstr ""
+"Gibt eine Kovarianz-/Korrelations-Matrix für benutzerdefiniert Rasterkarten "
+"aus."
-#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1449
+#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1483
 msgid "Linear regression"
 msgstr "Lineare Regression"
-#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1450
+#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1484
 msgid "Calculates linear regression from two raster maps: y = a + b*x."
 msgstr "Berechnet lineare Regression zweier Rasterkarten: y = a + b*x."
-#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1451
+#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1485
 msgid "Multiple regression"
 msgstr "Multiple Regression"
-#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1452
+#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1486
 #, fuzzy
 msgid "Calculates multiple linear regression from raster maps."
-#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1453
+#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1487
 msgid "Mutual category occurrences"
 msgstr "gemeinsame Auftreten von Kategorien"
-#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1454
-msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
-msgstr "Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei Rasterkarten."
+#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1488
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+"Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei "
+"Rasterkarten."
-#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1455
+#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1489
 msgid "&Vector"
 msgstr "&Vektor"
-#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1456
+#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1490
 msgid "Develop vector map"
 msgstr "Vektorkarten pflegen"
-#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1458
+#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1492
 msgid "Create new empty vector map"
 msgstr "Erzeuge eine neue und leere Vektorkarte"
-#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1459
+#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1493
 msgid "Edit vector map (non-interactively)"
 msgstr "Editiere Vektorkarte (nicht interaktiv)"
-#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1460
-msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
-msgstr "Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern ausgewählter Vektorobjekte."
+#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1494
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
+msgstr ""
+"Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern "
+"ausgewählter Vektorobjekte."
-#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1461
+#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1495
 msgid "Convert object types"
 msgstr "Konvertiert Objekttypen"
-#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1462
+#: ../gui/wxpython/menustrings.py:567 ../gui/wxpython/menustrings.py:1496
 #, fuzzy
 msgid "Changes type of vector features."
 msgstr "Selektiere Vektorfeature"
-#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1463
+#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1497
 msgid "Parallel lines"
 msgstr "Parallele Linien"
-#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1464
+#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1498
 msgid "Creates parallel line to input vector lines."
 msgstr "Erzeugt parallele Linie zu Eingabe-Linien."
-#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1465
+#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1499
 msgid "Dissolve boundaries"
 msgstr "Grenzen auflösen"
-#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1466
-msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
-msgstr "Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder gleichem Attributwert auf."
+#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1500
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+"Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder "
+"gleichem Attributwert auf."
-#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1467
+#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1501
 msgid "Create 3D vector over raster"
 msgstr "Erzeuge 3D Vektor aus Raster"
-#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1468
+#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1502
 #, fuzzy
 msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
-msgstr "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit Höheninformationen."
+msgstr ""
+"Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit "
+"Höheninformationen."
-#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1469
+#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1503
 msgid "Extrude 3D vector map"
 msgstr "3D Vektorkarte herauspressen"
-#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1470
-msgid "Extrudes flat vector features to 3D vector features with defined height. Optionally the height can be derived from sampling of elevation raster map."
+#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1504
+msgid ""
+"Extrudes flat vector features to 3D vector features with defined height. "
+"Optionally the height can be derived from sampling of elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1471
+#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1505
 msgid "Create labels"
 msgstr "Erzeuge Beschriftungen"
-#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1472
+#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1506
 msgid "Creates paint labels for a vector map from attached attributes."
 msgstr "Erzeugt Paint-Label für Vektorkarten von zugehörigen Attributen."
-#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1473
+#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1507
 msgid "Create optimally placed labels"
 msgstr "Erzeugt optimal plazierte Beschriftungen"
-#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1474
+#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1508
 msgid "Reposition vector map"
 msgstr "Vektorkarte repositionieren"
-#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1475
+#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1509
 #, fuzzy
-msgid "Performs an affine transformation (shift, scale and rotate) on vector map."
-msgstr "Führt eine affine Transformation (schieben, skalieren und rotieren oder GPCs) von Vektorkarten durch."
+msgid ""
+"Performs an affine transformation (shift, scale and rotate) on vector map."
+msgstr ""
+"Führt eine affine Transformation (schieben, skalieren und rotieren oder "
+"GPCs) von Vektorkarten durch."
-#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1476
+#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1510
 #, fuzzy
 msgid "Rectify vector map"
 msgstr "Vektorkarte selektieren"
-#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1477
+#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1511
 #, fuzzy
-msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
-msgstr "Rektifiziert ein Bild durch Berechnung einer Koordinatentransformation für jedes Pixel des Bildes basierend auf den Kontrollpunkten."
+msgid ""
+"Rectifies a vector by computing a coordinate transformation for each object "
+"in the vector based on the control points."
+msgstr ""
+"Rektifiziert ein Bild durch Berechnung einer Koordinatentransformation für "
+"jedes Pixel des Bildes basierend auf den Kontrollpunkten."
-#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1481
+#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1515
 msgid "Updates vector map metadata."
 msgstr "Aktualisiert Metadaten der Vektorkarte."
-#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1482
+#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:1516
 msgid "Topology maintenance"
 msgstr "Wartung der Topologie"
-#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1483
+#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1517
 msgid "Create or rebuild topology"
 msgstr "Topologie erzeugen/wiederherstellen"
-#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1484
-msgid "Creates topology for vector map. Optionaly also checks for topological errors."
+#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1518
+msgid ""
+"Creates topology for vector map. Optionaly also checks for topological "
+"errors."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1485
+#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1519
 msgid "Rebuild topology on all vector maps"
 msgstr "Erzeuge Topologie für alle Vektorkarten."
-#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1486
+#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1520
 msgid "Rebuilds topology on all vector maps in the current mapset."
 msgstr "Erzeuge Topologie für alle Vektorkarten im aktuellen Mapset."
-#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1487
+#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1521
 msgid "Build polylines"
 msgstr "Erstelle Poly-Linien"
-#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1488
+#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1522
 msgid "Builds polylines from lines or boundaries."
 msgstr "Erstellt Poly-Linien aus Linien und Grenzen."
-#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1489
+#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1523
 msgid "Split lines"
 msgstr "Teilt Linien"
-#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1490
+#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1524
 msgid "Splits vector lines to shorter segments."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1491
+#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1525
 msgid "Split polylines"
 msgstr "Teile Poly-Linien"
-#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1492
+#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:1526
 msgid "Creates points/segments from input vector lines and positions."
 msgstr "Erzeuge Punkte/Segmente aus Eingabe-Linien und Positionen."
-#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1493
+#: ../gui/wxpython/menustrings.py:598 ../gui/wxpython/menustrings.py:1527
 msgid "Clean vector map"
 msgstr "Vektorkarte säuberen"
-#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1494
+#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1528
 msgid "Toolset for cleaning topology of vector map."
 msgstr "Werkzeugkasten zum Säubern der Topologie von Vektorkarten."
-#: ../gui/wxpython/menustrings.py:583 ../gui/wxpython/menustrings.py:1495
+#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1529
 msgid "Smooth or simplify"
 msgstr "Glätten oder Vereinfachen"
-#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1496
+#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1530
 #, fuzzy
 msgid "Performs vector based generalization."
 msgstr "Vektor Datenbank Verbindungen"
-#: ../gui/wxpython/menustrings.py:585 ../gui/wxpython/menustrings.py:1497
+#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1531
 msgid "Add centroids"
 msgstr "Zentroide hinzufügen"
-#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1498
+#: ../gui/wxpython/menustrings.py:603 ../gui/wxpython/menustrings.py:1532
 msgid "Adds missing centroids to closed boundaries."
 msgstr "Fügt fehlende Zentroide zu geschlossenen Grenzen hinzu."
-#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1501
+#: ../gui/wxpython/menustrings.py:606 ../gui/wxpython/menustrings.py:1535
 #, fuzzy
 msgid "Creates/modifies the color table associated with a vector map."
 msgstr "Erzeugt / modifiziert die Farbtabelle einer Rasterkarte"
-#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1503
+#: ../gui/wxpython/menustrings.py:608 ../gui/wxpython/menustrings.py:1537
 msgid "Interactive management of vector color tables."
 msgstr "Interaktives Verwalten der Vektorfarbtabelle"
-#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1505
+#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:1539
 #, fuzzy
 msgid "Exports the color table associated with a vector map."
 msgstr "Exportiert die einer Rasterkarte zugeordnetenn Farbtabelle."
-#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1506
+#: ../gui/wxpython/menustrings.py:611 ../gui/wxpython/menustrings.py:1540
 msgid "Query vector map"
 msgstr "Vektorkarten abfragen"
-#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1507
+#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:1541
 msgid "Query with coordinate(s)"
 msgstr "Abfrage mittels Koordinate(n)"
-#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1508
+#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1542
 #, fuzzy
 msgid "Queries a vector map at given locations."
 msgstr "Fraget Vektorkarten an gegebenen Positionen ab."
-#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:894
-#: ../gui/wxpython/menustrings.py:1509 ../gui/wxpython/menustrings.py:1806
+#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:911
+#: ../gui/wxpython/menustrings.py:1543 ../gui/wxpython/menustrings.py:1840
 msgid "Query vector attribute data"
 msgstr "Frage Vektorattributdaten ab"
-#: ../gui/wxpython/menustrings.py:598 ../gui/wxpython/menustrings.py:895
-#: ../gui/wxpython/menustrings.py:1510 ../gui/wxpython/menustrings.py:1807
+#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:912
+#: ../gui/wxpython/menustrings.py:1544 ../gui/wxpython/menustrings.py:1841
 msgid "Prints vector map attributes."
 msgstr "Gebe Vektorattribute aus."
-#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1511
+#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1545
 msgid "Feature selection"
 msgstr "Objektauswahl"
-#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1512
+#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1546
 #, fuzzy
 msgid "Select by attributes"
 msgstr "Doppelte Attribute"
-#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1513
+#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1547
 #, fuzzy
-msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
-msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
+msgid ""
+"Selects vector features from an existing vector map and creates a new vector "
+"map containing only the selected features."
+msgstr ""
+"Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine "
+"neue Karte nur mit den selektierten Objekten."
-#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1514
+#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1548
 #, fuzzy
 msgid "Select by another map"
 msgstr "Selektiere Rasterkarte:"
-#: ../gui/wxpython/menustrings.py:603 ../gui/wxpython/menustrings.py:1515
-msgid "Selects features from vector map (A) by features from other vector map (B)."
-msgstr "Selektiert Objekte einer Vektorkarte (A) durch Objekte einer anderen Vektorkarte (B). "
+#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1549
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
+msgstr ""
+"Selektiert Objekte einer Vektorkarte (A) durch Objekte einer anderen "
+"Vektorkarte (B). "
-#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1525
+#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1559
 msgid "Buffer vectors"
 msgstr "Vektor buffern"
-#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:1526
+#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1560
 #, fuzzy
 msgid "Creates a buffer around vector features of given type."
-msgstr "Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flᅵchen mᅵssen Zentroide enthalten)."
+msgstr ""
+"Erzeugt einen Buffer um die Feature mit gegebenen Typ (Flᅵchen mᅵssen "
+"Zentroide enthalten)."
-#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:1527
+#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1561
 msgid "Lidar analysis"
 msgstr "Lidar Analyse"
-#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1528
+#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1562
 msgid "Identify and remove outliers"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:714
-#: ../gui/wxpython/menustrings.py:1529 ../gui/wxpython/menustrings.py:1626
+#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:731
+#: ../gui/wxpython/menustrings.py:1563 ../gui/wxpython/menustrings.py:1660
 msgid "Removes outliers from vector point data."
 msgstr "Entfernt Ausreißer aus einem Punkt-Vektordatensatz."
-#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1530
+#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1564
 msgid "Detect edges"
 msgstr "Kantenerkennung"
-#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1531
+#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1565
 msgid "Detects the object's edges from a LIDAR data set."
 msgstr "Erkennt Kanten von Objekten aus einem LIDAR-Datensatz."
-#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1532
+#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1566
 msgid "Detect interiors"
 msgstr "Innenräume erkennen"
-#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:1533
-msgid "Building contour determination and Region Growing algorithm for determining the building inside"
-msgstr "Bestimmung der Gebäudeumrisse und Ermittelung des Gebäudeinneren mittels des 'Region Growing' Verfahrens"
+#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1567
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+"Bestimmung der Gebäudeumrisse und Ermittelung des Gebäudeinneren mittels des "
+"'Region Growing' Verfahrens"
-#: ../gui/wxpython/menustrings.py:622 ../gui/wxpython/menustrings.py:1534
+#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1568
 msgid "Correct and reclassify objects"
 msgstr "Korrigiere und Reklassifiziere Objekte"
-#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:1535
-msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
-msgstr "Korrektur der v.lidar.growing Ausgabe. Dies ist der letzte von drei LiDAR Filter-Algorithmen."
+#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1569
+msgid ""
+"Correction of the v.lidar.growing output. It is the last of the three "
+"algorithms for LIDAR filtering."
+msgstr ""
+"Korrektur der v.lidar.growing Ausgabe. Dies ist der letzte von drei LiDAR "
+"Filter-Algorithmen."
-#: ../gui/wxpython/menustrings.py:624 ../gui/wxpython/menustrings.py:1536
+#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1570
 msgid "Linear referencing"
 msgstr "Lineare Referenzierung"
-#: ../gui/wxpython/menustrings.py:625 ../gui/wxpython/menustrings.py:1537
+#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1571
 msgid "Create LRS"
 msgstr "Erzeuge LRS"
-#: ../gui/wxpython/menustrings.py:626 ../gui/wxpython/menustrings.py:1538
+#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1572
 #, fuzzy
 msgid "Creates a linear reference system."
 msgstr "Erzeuge lineares Referenzsystem"
-#: ../gui/wxpython/menustrings.py:627 ../gui/wxpython/menustrings.py:1539
+#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1573
 msgid "Create stationing"
 msgstr "Erzeuge Stationen"
-#: ../gui/wxpython/menustrings.py:628 ../gui/wxpython/menustrings.py:1540
+#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1574
 #, fuzzy
 msgid "Creates stationing from input lines, and linear reference system."
-msgstr "Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
+msgstr ""
+"Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
-#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1541
+#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1575
 msgid "Create points/segments"
 msgstr "Erzeuge Punkte/Segmente"
-#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1542
-msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
-msgstr "Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des Linearenreferenzsystems und Positionen von stdin oder einer Datei."
+#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1576
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+"Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des "
+"Linearenreferenzsystems und Positionen von stdin oder einer Datei."
-#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1543
+#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1577
 msgid "Find line id and offset"
 msgstr "Finde Linien ID und Versatz"
-#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1544
-msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
-msgstr "Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
+#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1578
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+"Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte "
+"einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
-#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1545
+#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1579
 msgid "Nearest features"
 msgstr "Nächstliegendes Objekt"
-#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:1546
-msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
-msgstr "Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der Vektorkarte 'from'. "
+#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1580
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+"Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der "
+"Vektorkarte 'from'. "
-#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1547
+#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1581
 msgid "Network analysis"
 msgstr "Netzwerkanalyse"
-#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1548
+#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1582
 #: ../gui/wxpython/mapdisp/toolbars.py:53
 #, fuzzy
 msgid "Vector network analysis tool"
-#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1549
+#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1583
 msgid "Tool for interactive vector network analysis."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1550
+#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1584
 #, fuzzy
 msgid "Network preparation"
-#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1551
+#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1585
 msgid "Performs network maintenance."
 msgstr "Führt Netzwerkwartung durch."
-#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1552
+#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1586
 msgid "Allocate subnets"
 msgstr "Subnetze ausweisen"
-#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1553
-msgid "Allocate subnets for nearest centers (direction from center). center node must be opened (costs >= 0). Costs of center node are used in calculation"
+#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1587
+msgid ""
+"Allocate subnets for nearest centers (direction from center). center node "
+"must be opened (costs >= 0). Costs of center node are used in calculation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1554
+#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1588
 msgid "Split net"
 msgstr "Teile das Netz"
-#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1555
-msgid "Splits net by cost isolines. Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
+#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1589
+msgid ""
+"Splits net by cost isolines. Splits net to bands between cost isolines "
+"(direction from centre). Centre node must be opened (costs >= 0). Costs of "
+"centre node are used in calculation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1556
+#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:1590
 msgid "Shortest path"
 msgstr "Kürzester Pfad"
-#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1557
+#: ../gui/wxpython/menustrings.py:662 ../gui/wxpython/menustrings.py:1591
 msgid "Finds shortest path on vector network."
 msgstr "Findet den kürzesten Weg in einem Vektor-Netzwerk."
-#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1558
+#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1592
 msgid "Shortest path for sets of features"
 msgstr "Kürzester Pfad für eine Gruppen von Objekten"
-#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1559
-msgid "Computes shortest distance via the network between the given sets of features. Finds the shortest paths from each 'from' point to the nearest 'to' feature and various information about this relation are uploaded to the attribute table."
+#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1593
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features. Finds the shortest paths from each 'from' point to the nearest "
+"'to' feature and various information about this relation are uploaded to the "
+"attribute table."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1560
+#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1594
 msgid "Shortest path using timetables"
 msgstr "Kürzester Pfad mittels Zeittabellen"
-#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1561
+#: ../gui/wxpython/menustrings.py:666 ../gui/wxpython/menustrings.py:1595
 msgid "Finds shortest path using timetables."
 msgstr "Findet den kürzesten Weg mit Hilfe einer Zeittabellen."
-#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1562
+#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1596
 msgid "Shortest path for all pairs"
 msgstr "Kürzester Pfad für alle Paare"
-#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1563
+#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1597
 msgid "Computes the shortest path between all pairs of nodes in the network."
-msgstr "Berechnet den kürzesten Pfad zwischen allen Paaren von Knoten des Netzwerks."
+msgstr ""
+"Berechnet den kürzesten Pfad zwischen allen Paaren von Knoten des Netzwerks."
-#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1564
+#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1598
 msgid "Visibility network"
 msgstr "Sichtbarkeitsnetzwerk"
-#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1565
+#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1599
 #, fuzzy
 msgid "Performs visibility graph construction."
 msgstr "Konstruktion des Sichtbarkeits-Graphen."
-#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1566
+#: ../gui/wxpython/menustrings.py:671 ../gui/wxpython/menustrings.py:1600
 msgid "Bridges and articulation points"
 msgstr "Brücken und Artikulationspunkte"
-#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1567
+#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1601
 msgid "Computes bridges and articulation points in the network."
 msgstr "Berechnet Brücken und Artikulationspunkte im Netzwerk."
-#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1568
+#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1602
 msgid "Maximum flow"
 msgstr "Maximaler Fluss"
-#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1569
+#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1603
 msgid "Computes the maximum flow between two sets of nodes in the network."
-msgstr "Berechnet den maximalen Fluss zwischen zwei Gruppen von Knoten im Netzwerk."
+msgstr ""
+"Berechnet den maximalen Fluss zwischen zwei Gruppen von Knoten im Netzwerk."
-#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1570
+#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1604
 msgid "Vertex connectivity"
 msgstr "Vertex-Konnektivität"
-#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1571
+#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1605
 msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr "Berechnet Vertex Konnektivität zwischen zwei Gruppen von Knoten im Netzwerk."
+msgstr ""
+"Berechnet Vertex Konnektivität zwischen zwei Gruppen von Knoten im Netzwerk."
-#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1572
+#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1606
 msgid "Components"
 msgstr "Komponenten"
-#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:1573
+#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1607
 msgid "Computes strongly and weakly connected components in the network."
 msgstr "Berechnet stark und schwach verbundene Komponenten im Netzwerk."
-#: ../gui/wxpython/menustrings.py:662 ../gui/wxpython/menustrings.py:1574
+#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1608
 msgid "Centrality"
 msgstr "Zentralheit"
-#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1575
-msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
-msgstr "Berechnet Grad, Zentralität, Betweenness, Closeness und Eigenvektorzentralitätsmaße im Netzwerk."
+#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1609
+msgid ""
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
+msgstr ""
+"Berechnet Grad, Zentralität, Betweenness, Closeness und "
+"Eigenvektorzentralitätsmaße im Netzwerk."
-#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1576
+#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1610
 msgid "Steiner tree"
 msgstr "Steiner-Problematik"
-#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1577
-msgid "Creates Steiner tree for the network and given terminals. Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal."
+#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1611
+msgid ""
+"Creates Steiner tree for the network and given terminals. Note that 'Minimum "
+"Steiner Tree' problem is NP-hard and heuristic algorithm is used in this "
+"module so the result may be sub optimal."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:666 ../gui/wxpython/menustrings.py:1578
+#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1612
 msgid "Minimum spanning tree"
 msgstr "Minimaler aufspannender Baum"
-#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1579
+#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1613
 msgid "Computes minimum spanning tree for the network."
 msgstr "Berechnet den minimalen aufspannenden Baum für das Netzwerk."
-#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1580
+#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1614
 msgid "Traveling salesman analysis"
 msgstr "Traveling-Salesman-Problematik"
-#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1581
-msgid "Creates a cycle connecting given nodes (Traveling salesman problem). Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
+#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1615
+msgid ""
+"Creates a cycle connecting given nodes (Traveling salesman problem). Note "
+"that TSP is NP-hard, heuristic algorithm is used by this module and created "
+"cycle may be sub optimal"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:671
-#: ../gui/wxpython/menustrings.py:1582 ../gui/wxpython/menustrings.py:1583
+#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:688
+#: ../gui/wxpython/menustrings.py:1616 ../gui/wxpython/menustrings.py:1617
 msgid "Overlay vector maps"
 msgstr "Vektorkarten überlagern"
-#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1584
+#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1618
 msgid "Overlays two vector maps."
 msgstr "Überlagert zwei Vektorkarten."
-#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1585
+#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1619
 msgid "Patch vector maps"
 msgstr "Patche Vektorkarten"
-#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1586
+#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1620
 #, fuzzy
 msgid "Creates a new vector map by combining other vector maps."
 msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten."
-#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1587
+#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1621
 #, fuzzy
 msgid "Manage categories"
 msgstr "Verwalten oder Berichten von Kategorien"
-#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1588
+#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1622
 #, fuzzy
 msgid "Change or report categories"
-#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1589
+#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1623
 #, fuzzy
 msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr "Fᅵge hinzu, Lᅵsche oder Berichte Vektorkategorien einer Kartengeometrie."
+msgstr ""
+"Fᅵge hinzu, Lᅵsche oder Berichte Vektorkategorien einer Kartengeometrie."
-#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1591
-msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
-msgstr "Ändert die Kategorien einer existierenden Vektorkarte entsprechend den Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
+#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1625
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+"Ändert die Kategorien einer existierenden Vektorkarte entsprechend den "
+"Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
-#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1593
+#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1627
 msgid "Update area attributes from raster"
 msgstr "Aktualisiere Flächenattribute aus Raster"
-#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1594
+#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1628
 #, fuzzy
-msgid "Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns."
-msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte fᅵr Polygone und fᅵgt die Ergebnisse als neue Spalte der Attributtabelle an."
+msgid ""
+"Calculates univariate statistics from a raster map based on vector polygon "
+"map and uploads statistics to new attribute columns."
+msgstr ""
+"Berechnet Kennzahlen univariater Statistik einer Rasterkarte fᅵr Polygone "
+"und fᅵgt die Ergebnisse als neue Spalte der Attributtabelle an."
-#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1595
+#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1629
 #, fuzzy
 msgid "Update area attributes from vector"
-#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1596
+#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1630
 #, fuzzy
 msgid "Count points in areas, calculate statistics from point attributes."
 msgstr "Univariate Statistik fᅵr Punktattribute"
-#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1597
+#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1631
 msgid "Update point attributes from areas"
 msgstr "Aktualisiere Punktattribute aus Flächen"
-#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1598
+#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1632
 msgid "Uploads vector values at positions of vector points to the table."
 msgstr "Schreibt den Vektorwert an der Stelle der Vektorpunkte in die Tabelle."
-#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1599
+#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1633
 msgid "Update database values from vector"
 msgstr "Füllt Datenbank basierend auf Vektorobjekten"
-#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1600
+#: ../gui/wxpython/menustrings.py:705 ../gui/wxpython/menustrings.py:1634
 #, fuzzy
 msgid "Populates attribute values from vector features."
 msgstr "Füllt Datenbank basierend auf Vektorobjekten."
-#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1601
+#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1635
 msgid "Sample raster maps at point locations"
 msgstr "Rasterkarte an Punktpositionen abtasten"
-#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1602
+#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1636
 msgid "Uploads raster values at positions of vector points to the table."
-msgstr "Übernimmt die Rasterwerte an den Positionen der Vektorpunkte in die Attributtabelle."
+msgstr ""
+"Übernimmt die Rasterwerte an den Positionen der Vektorpunkte in die "
+"Attributtabelle."
-#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1603
+#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1637
 msgid "Sample raster neighborhood around points"
 msgstr "Rasterkarte in der Umgebung von Punktpositionen abtasten"
-#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1604
+#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1638
 msgid "Samples a raster map at vector point locations."
 msgstr "Fragt eine Rasterkarte an den Positionen von Vektorpunkten ab."
-#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1605
+#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1639
 msgid "Generate area for current region"
 msgstr "Erzeuge Fläche aus aktueller Region"
-#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1606
+#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1640
 msgid "Creates a vector polygon from the current region extent."
 msgstr "Erzeugt ein Polygon aus der aktuellen Region."
-#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1607
+#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1641
 msgid "Generate areas from points"
 msgstr "Erzeuge Fläche aus Punkten"
-#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1608
+#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1642
 msgid "Convex hull"
 msgstr "Konvexe Hülle"
-#: ../gui/wxpython/menustrings.py:697 ../gui/wxpython/menustrings.py:1609
+#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1643
 #, fuzzy
 msgid "Produces a 2D/3D convex hull for a given vector map."
 msgstr "Erzeugt eine konvexe Hülle für eine Vektorkarte."
-#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1610
+#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1644
 msgid "Delaunay triangles"
 msgstr "Delaunay-Dreiecke"
-#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1611
-msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
-msgstr "Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit Punkten oder Zentroiden."
+#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1645
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+"Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit "
+"Punkten oder Zentroiden."
-#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1612
+#: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1646
 msgid "Voronoi diagram/Thiessen polygons"
 msgstr "Voronoi Diagramm / Thiessen Polygone"
-#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1613
+#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1647
 #, fuzzy
-msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
-msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
+msgid ""
+"Creates a Voronoi diagram in current region from an input vector map "
+"containing points or centroids."
+msgstr ""
+"Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder "
+"Zentroiden."
-#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1614
+#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1648
 msgid "Generate grid"
 msgstr "Gitternetz erzeugen"
-#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1615
+#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1649
 #, fuzzy
 msgid "Creates a vector map of a user-defined grid."
-msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
+msgstr ""
+"Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
-#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1616
+#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1650
 msgid "Generate points"
 msgstr "Erzeuge Punkte"
-#: ../gui/wxpython/menustrings.py:705 ../gui/wxpython/menustrings.py:1617
+#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1651
 msgid "Generate from database"
 msgstr "Erzeuge aus Datenbank"
-#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1618
-msgid "Creates new vector (points) map from database table containing coordinates."
-msgstr "Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die Koordinaten beinhaltet."
+#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1652
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+"Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die "
+"Koordinaten beinhaltet."
-#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1619
+#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1653
 msgid "Generate points along lines"
 msgstr "Erzeuge Punkte entlang von Linien"
-#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1620
+#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1654
 #, fuzzy
 msgid "Creates points along input lines in new vector map with 2 layers."
-msgstr "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei Layern."
+msgstr ""
+"Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei "
+"Layern."
-#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1621
+#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1655
 msgid "Generate random points"
 msgstr "Erzeuge zufällige Punkte"
-#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1622
+#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1656
 #, fuzzy
 msgid "Generates randomly 2D/3D vector points map."
 msgstr "Erzeugt zufᅵllige 2D/3D GRASS Vektor-Punktkarten."
-#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1623
+#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1657
 msgid "Perturb points"
 msgstr "Durchmische Punkte"
-#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1624
+#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1658
 #, fuzzy
 msgid "Random location perturbations of vector points."
 msgstr "Zufᅵllige Stᅵrung der Position von GRASS Vektorpunkten."
-#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1625
+#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1659
 msgid "Remove outliers in point sets"
 msgstr "Entferne Ausreißer aus Punktmenge"
-#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1627
+#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1661
 msgid "Test/training point sets"
 msgstr "Test-/Trainings-Punktmenge"
-#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1628
+#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1662
 msgid "Randomly partition points into test/train sets."
 msgstr "Teile die Punkte zufällig in ein Test- und ein Training-Datensatz."
-#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1630
+#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1664
 msgid "Basic vector metadata"
 msgstr "Grundlegende Vektor-Metadaten"
-#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1631
+#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1665
 #, fuzzy
 msgid "Outputs basic information about a vector map."
 msgstr "Gibt grundlegende Informationen einer bestimmten Vektorkarte aus."
-#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1632
+#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1666
 msgid "Classify attribute data"
 msgstr "Klassifiziert Attributdaten"
-#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1633
+#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1667
 msgid "Classifies attribute data, e.g. for thematic mapping"
 msgstr "Klassifiziert Attributdaten, z.B. für thematische Karten."
-#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1634
+#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1668
 msgid "Report topology by category"
 msgstr "Berichte Topologie nach Kategorien getrennt"
-#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1635
+#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1669
 #, fuzzy
 msgid "Reports geometry statistics for vector maps."
 msgstr "Gibt statistische Werte fᅵr Geometrie der Vektorobjekte aus."
-#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1636
+#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1670
 msgid "Univariate attribute statistics for points"
 msgstr "Univariate Statistik für Punktattribute"
-#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1637
-msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
-msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
+#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1671
+msgid ""
+"Calculates univariate statistics for attribute. Variance and standard "
+"deviation is calculated only for points if specified."
+msgstr ""
+"Berechnet univariate Statistiken für die Attribute. Die Varianz und "
+"Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
-#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1638
+#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1672
 msgid "Univariate statistics for attribute columns"
 msgstr "Univariate Statistik für Attributspalten"
-#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1639
-msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
-msgstr "Berechnet univariate Statistiken in ausgewählten Tabellenspalten einer GRASS Vektorkarte."
+#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1673
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
+msgstr ""
+"Berechnet univariate Statistiken in ausgewählten Tabellenspalten einer GRASS "
+"Vektorkarte."
-#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1640
+#: ../gui/wxpython/menustrings.py:745 ../gui/wxpython/menustrings.py:1674
 msgid "Quadrat indices"
 msgstr "Quadrat Indices"
-#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1641
+#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1675
 msgid "Indices for quadrat counts of sites lists."
 msgstr "Indices der Quadrat-Count-Methode von site Listen."
-#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1642
+#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1676
 msgid "Test normality"
 msgstr "Test auf Normalverteilung"
-#: ../gui/wxpython/menustrings.py:731 ../gui/wxpython/menustrings.py:1643
+#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1677
 #, fuzzy
 msgid "Tests for normality for vector points."
 msgstr "Test auf Normalverteilung fᅵr Punkte."
-#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1644
+#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1678
 msgid "&Imagery"
 msgstr "&Bildverarbeitung"
-#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1645
+#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1679
 msgid "Develop images and groups"
 msgstr "Bilder und Gruppen pflegen"
-#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1646
+#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1680
 msgid "Create/edit group"
 msgstr "Erzeuge/editiere Gruppe"
-#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1647
+#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1681
 msgid "Creates, edits, and lists groups of imagery files."
 msgstr "Erzeugt, editiert und listet Gruppen von Bilddateien."
-#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1648
+#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1682
 msgid "Target group"
 msgstr "Zielgruppe"
-#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1649
+#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1683
 msgid "Targets an imagery group to a GRASS location and mapset."
 msgstr "Legt das Ziel für eine Bildgruppe auf eine GRASS Location mit Mapset."
-#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1650
+#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1684
 msgid "Mosaic images"
 msgstr "Mosaikiere Bilder"
-#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1651
+#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1685
 #, fuzzy
 msgid "Mosaics several images and extends colormap."
-msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
+msgstr ""
+"Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-"
+"Karten."
-#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1652
+#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1686
 msgid "Manage image colors"
 msgstr "Verwalte Bildfarben"
-#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1653
+#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1687
 msgid "Color balance for RGB"
 msgstr "Farbenabgleich für RGB"
-#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1654
+#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1688
 msgid "Performs auto-balancing of colors for LANDSAT images."
 msgstr "Automatischer Farbabgleich für LANDSAT Bilder."
-#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1655
+#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1689
 msgid "HIS to RGB"
 msgstr "HIS zu RGB"
-#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1656
-msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
-msgstr "Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum in den RGB (Rot-Grün-Blau) Farbraum."
+#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1690
+msgid ""
+"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+"RGB (Red-Green-Blue) color space."
+msgstr ""
+"Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum "
+"in den RGB (Rot-Grün-Blau) Farbraum."
-#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1658
-msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
-msgstr "Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS (Hue-Intensity-Saturation) Farbraum."
+#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1692
+msgid ""
+"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
+"Intensity-Saturation) color space."
+msgstr ""
+"Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS "
+"(Hue-Intensity-Saturation) Farbraum."
-#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1659
+#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1693
 msgid "Rectify image or raster"
 msgstr "Rektifiziere Bild oder Raster"
-#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1660
-msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1694
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points."
+msgstr ""
-#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1661
+#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1695
 #: ../gui/wxpython/lmgr/layertree.py:574
 msgid "Histogram"
 msgstr "Histogramm"
-#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1662
+#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1696
 msgid "Generate histogram of image"
 msgstr "Erzeuge Histogramm eines Bildes"
-#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1663
+#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1697
 msgid "Spectral response"
 msgstr "Spektralwert"
-#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1664
-msgid "Displays spectral response at user specified locations in group or images."
-msgstr "Zeigt die Spektralwerte von Gruppen oder Bildern an einem ausgewählten Ort an."
+#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1698
+msgid ""
+"Displays spectral response at user specified locations in group or images."
+msgstr ""
+"Zeigt die Spektralwerte von Gruppen oder Bildern an einem ausgewählten Ort "
+"an."
-#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1665
+#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1699
 #, fuzzy
 msgid "Pan sharpening"
 msgstr "Brovey-Schärfen"
-#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1666
+#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1700
 #, fuzzy
-msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
-msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
+msgid ""
+"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
+"channels"
+msgstr ""
+"Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
+"panchromatischer Kanäle."
-#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1667
+#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1701
 msgid "Classify image"
 msgstr "Bild klassifizieren"
-#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1668
+#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1702
 msgid "Clustering input for unsupervised classification"
 msgstr "Clustert die Eingabe für eine unüberwachte Klassifikation."
-#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1669
+#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1703
 #, fuzzy
-msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm. The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
-msgstr "Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels eines Clusteralgorithmus."
+msgid ""
+"Generates spectral signatures for land cover types in an image using a "
+"clustering algorithm. The resulting signature file is used as input for i."
+"maxlik, to generate an unsupervised image classification."
+msgstr ""
+"Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels "
+"eines Clusteralgorithmus."
-#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1670
+#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1704
 msgid "Input for supervised MLC"
 msgstr "Eingabe für überwachte MLC"
-#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1671
+#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1705
 msgid "Generates statistics for i.maxlik from raster map."
 msgstr "Erzeugt Statistiken für i.maxlik aus einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1672
+#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1706
 msgid "Maximum likelihood classification (MLC)"
 msgstr "Maximum Likelihood Klassifikation (MLC)"
-#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1673
-msgid "Classifies the cell spectral reflectances in imagery data. Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
+#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1707
+msgid ""
+"Classifies the cell spectral reflectances in imagery data. Classification is "
+"based on the spectral signature information generated by either i.cluster, i."
+"class, or i.gensig."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:762 ../gui/wxpython/menustrings.py:1674
-#: ../gui/wxpython/menustrings.py:1930
+#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1708
+#: ../gui/wxpython/menustrings.py:1964
 #, fuzzy
 msgid "Interactive input for supervised classification"
-msgstr "Interaktive Eingabe für eine überwachte Klassifikation (benötigt Xterm)."
+msgstr ""
+"Interaktive Eingabe für eine überwachte Klassifikation (benötigt Xterm)."
-#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1675
-#: ../gui/wxpython/menustrings.py:1931
+#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1709
+#: ../gui/wxpython/menustrings.py:1965
 #, fuzzy
-msgid "Generates spectral signatures by allowing the user to outline training areas."
-msgstr "Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt Trainingsgebiete zu markieren."
+msgid ""
+"Generates spectral signatures by allowing the user to outline training areas."
+msgstr ""
+"Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt "
+"Trainingsgebiete zu markieren."
-#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1676
+#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1710
 msgid "Input for supervised SMAP"
 msgstr "Eingabe für überwachte SMAP"
-#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1677
+#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1711
 msgid "Generates statistics for i.smap from raster map."
 msgstr "Erzeugt Statistiken für i.smap aus einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1678
+#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1712
 msgid "Sequential maximum a posteriori classification (SMAP)"
 msgstr "Sequential maximum a posteriori classification (SMAP)"
-#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1679
-msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
-msgstr "Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des 'sequential maximum a posteriori (SMAP)' Ansatzes durch."
+#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1713
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+"Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des "
+"'sequential maximum a posteriori (SMAP)' Ansatzes durch."
-#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1680
+#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1714
 #, fuzzy
 msgid "Object segmentation"
 msgstr "Orientierung"
-#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1681
+#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1715
 msgid "Identifies segments (objects) from imagery data."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1682
+#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1716
 msgid "Filter image"
 msgstr "Bild filtern"
-#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1683
+#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1717
 msgid "Edge detection"
-#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1684
+#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1718
 msgid "Zero-crossing \"edge detection\" raster function for image processing."
 msgstr "Zero-crossing: Funktion der Bildverarbeitung zur Kantenerkennung."
-#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1685
+#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1719
 msgid "Matrix/convolving filter"
 msgstr "Matrix/Faltungs-Filter"
-#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1686
+#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1720
 msgid "Performs raster map matrix filter."
 msgstr "Raster-Matrix-Filter ausführen"
-#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1687
+#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1721
 msgid "Transform image"
 msgstr "Bildtransformation"
-#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1688
+#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1722
 msgid "Canonical correlation"
 msgstr "Kanonische Korrelation"
-#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1689
+#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1723
 #, fuzzy
 msgid "Canonical components analysis (CCA) program for image processing."
-msgstr "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
+msgstr ""
+"Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
-#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1690
+#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1724
 msgid "Principal components"
 msgstr "Hauptkomponenten"
-#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1691
+#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1725
 msgid "Principal components analysis (PCA) for image processing."
 msgstr "Hauptkomponentenanalyse (PCA) für Bildverarbeitung."
-#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1692
+#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1726
 msgid "Fast Fourier"
 msgstr "Fast Fourier"
-#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1693
+#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1727
 msgid "Fast Fourier Transform (FFT) for image processing."
 msgstr "Fast Fourier Transformation (FFT) für die Bildverarbeitung."
-#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1694
+#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1728
 msgid "Inverse Fast Fourier"
 msgstr "Inverse Fast Fourier"
-#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1695
+#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1729
 msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
 msgstr "Inverse Fast Fourier Transformation (IFFT) für die Bildverarbeitung."
-#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1696
+#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1730
 msgid "Satellite images tools"
 msgstr "Wergzeuge zur Satellitenbildverarbeitung"
-#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1697
+#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1731
 msgid "Aster DN to radiance/reflectance"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1698
-msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN."
+#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1732
+msgid ""
+"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
+"from ASTER DN."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1699
+#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1733
 msgid "Landsat DN to radiance/reflectance"
 msgstr "Landsat Zahlen zu Strahlung/Reflexion"
-#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1700
+#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1734
 #, fuzzy
-msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
-msgstr "Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für Landsat MSS/TM/ETM+."
+msgid ""
+"Calculates top-of-atmosphere radiance or reflectance and temperature for "
+"Landsat MSS/TM/ETM+/OLI"
+msgstr ""
+"Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für "
+"Landsat MSS/TM/ETM+."
-#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1701
+#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1735
 msgid "Landsat cloud cover assessment"
 msgstr "Landsat Wolkenbedeckungsanalyse"
-#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1702
+#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1736
 msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr "Führt Landsat TM/ETM+ automatische Einschätzung der Wolkenbedeckung (ACCA) durch."
+msgstr ""
+"Führt Landsat TM/ETM+ automatische Einschätzung der Wolkenbedeckung (ACCA) "
+"durch."
-#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1703
+#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1737
 msgid "Modis quality control"
 msgstr "Modis Qualitätskontrolle"
-#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1704
+#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1738
 msgid "Extracts quality control parameters from Modis QC layers."
 msgstr "Extrahiert Qualitätsparameter aus der Modis QC Ebenen."
-#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1705
+#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1739
 msgid "Atmospheric correction"
 msgstr "Atmosphärische Korrektion"
-#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1706
+#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1740
 #, fuzzy
-msgid "Performs atmospheric correction using the 6S algorithm. 6S - Second Simulation of Satellite Signal in the Solar Spectrum."
+msgid ""
+"Performs atmospheric correction using the 6S algorithm. 6S - Second "
+"Simulation of Satellite Signal in the Solar Spectrum."
 msgstr "Führt eine atmosphärische Korrektion mit dem 6S-Algorithmus durch."
-#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1707
+#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1741
 msgid "Satellite images products"
 msgstr "Satellitenbildprodukte"
-#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1708
+#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1742
 #, fuzzy
 msgid "Vegetation indices"
-#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1709
-msgid "Calculates different types of vegetation indices. Uses red and nir bands mostly, and some indices require additional bands."
+#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1743
+msgid ""
+"Calculates different types of vegetation indices. Uses red and nir bands "
+"mostly, and some indices require additional bands."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1710
+#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1744
 msgid "Tasseled cap vegetation index"
 msgstr "Tasseled-Cap Vegetationsindex"
-#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1711
+#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1745
 #, fuzzy
-msgid "Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
+msgid ""
+"Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
 msgstr "Tasseled Cap (Kauth Thomas) Transformation für LANDSAT-TM Daten."
-#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1712
+#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1746
 msgid "Albedo"
 msgstr "Albedo"
-#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1713
+#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1747
 msgid "Computes broad band albedo from surface reflectance."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1714
+#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1748
 msgid "Emissivity"
 msgstr "Emissivitᅵt"
-#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1715
+#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1749
 msgid "Computes emissivity from NDVI, generic method for sparse land."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1716
+#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1750
 msgid "Biomass growth"
 msgstr "Biomassenwachstum"
-#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1717
+#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1751
 msgid "Computes biomass growth, precursor of crop yield calculation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1718
+#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1752
 #, fuzzy
 msgid "Evapotranspiration calculation"
 msgstr "Berechnung des Mittelwerts."
-#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1719
+#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1753
 msgid "Instantaneaous Net Radiation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1720
+#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:1754
 msgid "Net radiation approximation (Bastiaanssen, 1995)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1721
+#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1755
 #, fuzzy
 msgid "Soil heat flux"
 msgstr "SIMWE Sedimentbewegungsmodellierung"
-#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1722
+#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1756
 msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1723
+#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1757
 #, fuzzy
 msgid "Sensible heat flux"
-#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1724
+#: ../gui/wxpython/menustrings.py:829 ../gui/wxpython/menustrings.py:1758
 msgid "Computes sensible heat flux iteration SEBAL 01."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1725
+#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1759
 msgid "Evaporative fraction"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1726
-msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
+#: ../gui/wxpython/menustrings.py:831 ../gui/wxpython/menustrings.py:1760
+msgid ""
+"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
+"moisture (Makin, Molden and Bastiaanssen, 2001)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1727
+#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1761
 #, fuzzy
 msgid "Actual Evapotranspiration"
-#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1728
+#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:1762
 msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1729
+#: ../gui/wxpython/menustrings.py:834 ../gui/wxpython/menustrings.py:1763
 #, fuzzy
 msgid "Temporal integration of ETa"
 msgstr ""
 "\n"
 "++ Lasse gwflow Integrations-Tests laufen++"
-#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1730
-msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
+#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1764
+msgid ""
+"Computes temporal integration of satellite ET actual (ETa) following the "
+"daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1731
+#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1765
 msgid "Hargreaves methods Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1732
-msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
+#: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1766
+msgid ""
+"Computes evapotranspiration calculation modified or original Hargreaves "
+"formulation, 2001."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1733
+#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:1767
 msgid "Penman-Monteith Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1734
-msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
+#: ../gui/wxpython/menustrings.py:839 ../gui/wxpython/menustrings.py:1768
+msgid ""
+"Computes potential evapotranspiration calculation with hourly Penman-"
+"Monteith."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1735
+#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1769
 msgid "Priestley-Taylor Evapotranspiration"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1736
-msgid "Computes evapotranspiration calculation Prestley and Taylor formulation, 1972."
+#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1770
+msgid ""
+"Computes evapotranspiration calculation Prestley and Taylor formulation, "
+"1972."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1738
+#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1772
 msgid "Bit pattern comparison "
 msgstr "vergleiche Bitmuster"
-#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1739
+#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1773
 msgid "Compares bit patterns with a raster map."
 msgstr "Vergleicht Bitmuster mit einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1740
+#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1774
 msgid "Kappa analysis"
 msgstr "Kappa Analyse"
-#: ../gui/wxpython/menustrings.py:829 ../gui/wxpython/menustrings.py:1741
+#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1775
 #, fuzzy
-msgid "Calculates error matrix and kappa parameter for accuracy assessment of classification result."
-msgstr "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung (accuracy assessment) der Klassifikationsergebnisse."
+msgid ""
+"Calculates error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+"Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung "
+"(accuracy assessment) der Klassifikationsergebnisse."
-#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1742
+#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1776
 msgid "OIF for LandSat TM"
 msgstr "OIF für LandSat TM"
-#: ../gui/wxpython/menustrings.py:831 ../gui/wxpython/menustrings.py:1743
+#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1777
 #, fuzzy
 msgid "Calculates Optimum-Index-Factor table for spectral bands"
-msgstr "Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
+msgstr ""
+"Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
-#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1744
+#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1778
 msgid "V&olumes"
 msgstr "&Volumen"
-#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:1745
+#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1779
 msgid "Develop volumes"
 msgstr "Volumen pflegen"
-#: ../gui/wxpython/menustrings.py:834 ../gui/wxpython/menustrings.py:1746
+#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1780
 msgid "Manage 3D NULL values"
 msgstr "3D NULLwerte verwalten"
-#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1747
+#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1781
 msgid "Explicitly create the 3D NULL-value bitmap file."
 msgstr "Erstelle explizit ein 3D NULL-Wert Bitmap Datei."
-#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1748
+#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1782
 msgid "Manage timestamp"
 msgstr "Zeitstempel verwalten"
-#: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1749
+#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1783
 msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr "Ausgeben/Hinzufügen/Entfernen eines Zeitstempels für eine 3D-Rasterkarte"
+msgstr ""
+"Ausgeben/Hinzufügen/Entfernen eines Zeitstempels für eine 3D-Rasterkarte"
-#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1753
+#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1787
 #, fuzzy
 msgid "3D color tables"
 msgstr "Farbtabellen"
-#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1754
+#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1788
 #, fuzzy
 msgid "Creates/modifies the color table associated with a 3D raster map."
 msgstr "Erzeugt / modifiziert die Farbtabelle einer Rasterkarte"
-#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1755
+#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1789
 #, fuzzy
 msgid "Export 3D color table"
 msgstr "Exportiere Farbtabelle"
-#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1756
+#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1790
 #, fuzzy
 msgid "Exports the color table associated with a 3D raster map."
 msgstr "Exportiert die einer Rasterkarte zugeordnetenn Farbtabelle."
-#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1757
+#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1791
 msgid "3D Mask"
 msgstr "3D Maske"
-#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1758
+#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1792
 msgid "Establishes the current working 3D raster mask."
 msgstr "Aktuelle 3D Maske erstellen."
-#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1759
+#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1793
 msgid "Volume calculator"
 msgstr "Volumenrechner"
-#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1760
+#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1794
 #, fuzzy
 msgid "3D raster map calculator."
 msgstr "3D Rasterkartenrechner"
-#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1761
+#: ../gui/wxpython/menustrings.py:866 ../gui/wxpython/menustrings.py:1795
 msgid "Cross section"
 msgstr "Querschnitt"
-#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1762
+#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1796
 #, fuzzy
-msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
-msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
+msgid ""
+"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
+"map"
+msgstr ""
+"Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
+"Rasterkarte basierend auf 2D-Höhenkarte."
-#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1764
+#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1798
 #, fuzzy
-msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions."
-msgstr "Programm zur numerischen Berechnung des transienten, beschränkten Grundwasserflusses in drei Dimensionen."
+msgid ""
+"Numerical calculation program for transient, confined groundwater flow in "
+"three dimensions."
+msgstr ""
+"Programm zur numerischen Berechnung des transienten, beschränkten "
+"Grundwasserflusses in drei Dimensionen."
-#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1765
+#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1799
 msgid "Interpolate volume from points"
 msgstr "Interpoliere Volumen aus Punkten"
-#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1766
-msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
-msgstr "Interpoliert Punkte zu einem G3D Grid Volumen unter Verwendung des regularized spline with tension (RST) Algorithmus."
+#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1800
+msgid ""
+"Interpolates point data to a 3D raster map using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+"Interpoliert Punkte zu einem G3D Grid Volumen unter Verwendung des "
+"regularized spline with tension (RST) Algorithmus."
-#: ../gui/wxpython/menustrings.py:855 ../gui/wxpython/menustrings.py:1767
+#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1801
 #, fuzzy
 msgid "Reports and Statistics"
 msgstr "Bericht und Statistiken"
-#: ../gui/wxpython/menustrings.py:856 ../gui/wxpython/menustrings.py:1768
+#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:1802
 msgid "Basic volume metadata"
 msgstr "Grundlegende Volumen-Metadaten"
-#: ../gui/wxpython/menustrings.py:857 ../gui/wxpython/menustrings.py:1769
+#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1803
 msgid "Outputs basic information about a user-specified 3D raster map layer."
 msgstr "Gibt Basisinformationen einer benutzerdefinierten 3D Rasterkarte aus."
-#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1770
+#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1804
 msgid "Voxel statistics"
 msgstr "Voxel-Statistik"
-#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1771
+#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1805
 msgid "Generates volume statistics for 3D raster maps."
 msgstr "Erzeugt Volumenstatistik für 3D-Rasterkarten."
-#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1772
+#: ../gui/wxpython/menustrings.py:877 ../gui/wxpython/menustrings.py:1806
 msgid "Univariate statistics for volumes"
 msgstr "Univariate Statistiken für Volumen"
-#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1773
-msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
-msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer 3D-Rasterkarte."
+#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1807
+msgid ""
+"Calculates univariate statistics from the non-null 3d cells of a raster3d "
+"map."
+msgstr ""
+"Berechnet univariate Statistiken der nicht-NULL Zellen einer 3D-Rasterkarte."
-#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1774
+#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1808
 msgid "&Database"
 msgstr "&Datenbank"
-#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1775
+#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1809
 msgid "Database information"
 msgstr "Datenbankinformation"
-#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1776
+#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1810
 msgid "List databases"
 msgstr "Datenbanken auflisten"
-#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1777
+#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:1811
 #, fuzzy
 msgid "Lists all databases for a given driver and location."
 msgstr "Listet alle Tabellen einer Datenbank."
-#: ../gui/wxpython/menustrings.py:866 ../gui/wxpython/menustrings.py:1778
+#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1812
 msgid "List drivers"
 msgstr "Treiber auflisten"
-#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1779
+#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1813
 msgid "Lists all database drivers."
 msgstr "Listet alle Datenbanktreiber."
-#: ../gui/wxpython/menustrings.py:868 ../gui/wxpython/menustrings.py:1780
+#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1814
 msgid "List tables"
 msgstr "Tabellen auflisten"
-#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1781
+#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1815
 msgid "Lists all tables for a given database."
-#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1782
+#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1816
 msgid "Describe table"
 msgstr "Tabelle beschreiben"
-#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1783
+#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1817
 msgid "Describes a table in detail."
 msgstr "Beschreibe eine Tabelle detailliert."
-#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1784
+#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1818
 msgid "List columns"
 msgstr "Spalten auflisten"
-#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:1785
+#: ../gui/wxpython/menustrings.py:890 ../gui/wxpython/menustrings.py:1819
 msgid "List all columns for a given table."
 msgstr "Listet alle Spalten einer Tabelle."
-#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1786
+#: ../gui/wxpython/menustrings.py:891 ../gui/wxpython/menustrings.py:1820
 msgid "Manage databases"
 msgstr "Datenbanken verwalten"
-#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1787
+#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1821
 msgid "Connect"
 msgstr "Verbinde"
-#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1788
+#: ../gui/wxpython/menustrings.py:893 ../gui/wxpython/menustrings.py:1822
 #, fuzzy
 msgid "Prints/sets general DB connection for current mapset."
-msgstr "Gibt oder setzt allgemeine Datenbankverbindung für das aktuelle Mapset und beendet sich."
+msgstr ""
+"Gibt oder setzt allgemeine Datenbankverbindung für das aktuelle Mapset und "
+"beendet sich."
-#: ../gui/wxpython/menustrings.py:877 ../gui/wxpython/menustrings.py:1789
+#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1823
 msgid "Login"
 msgstr "Login"
-#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1790
+#: ../gui/wxpython/menustrings.py:895 ../gui/wxpython/menustrings.py:1824
 #, fuzzy
 msgid "Sets user/password for DB driver/database."
 msgstr "Setzt Benutzername/Passwort für Treiber/Datenbank."
-#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1791
+#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1825
 msgid "Create database"
 msgstr "Erzeuge Datenbank"
-#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1792
+#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1826
 msgid "Creates an empty database."
 msgstr "Erzeugt eine leere Datenbank."
-#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1793
+#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1827
 #, fuzzy
 msgid "Drop database"
 msgstr "Datenbank"
-#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:1794
+#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1828
 #, fuzzy
 msgid "Removes an existing database."
 msgstr "Entfernt eine Tabelle aus einer Datenbank."
-#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1795
+#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1829
 msgid "Drop table"
 msgstr "Tabelle löschen"
-#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1796
+#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1830
 msgid "Drops an attribute table."
 msgstr "Löscht eine Attributtabelle."
-#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1797
+#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1831
 msgid "Copy table"
 msgstr "Tabelle kopieren"
-#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1798
-msgid "Copy a table. Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1832
+msgid ""
+"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
+"'select' option, but not 'from_table' and 'select' at the same time."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:907
-#: ../gui/wxpython/menustrings.py:1799 ../gui/wxpython/menustrings.py:1819
+#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:924
+#: ../gui/wxpython/menustrings.py:1833 ../gui/wxpython/menustrings.py:1853
 msgid "Drop column"
 msgstr "Lösche Spalte"
-#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1800
+#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1834
 #, fuzzy
 msgid "Drops a column from selected attribute table."
 msgstr "Löscht eine Spalte von selektierter Attributtabelle"
-#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1801
+#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1835
 msgid "Test"
 msgstr "Testen"
-#: ../gui/wxpython/menustrings.py:890 ../gui/wxpython/menustrings.py:1802
+#: ../gui/wxpython/menustrings.py:907 ../gui/wxpython/menustrings.py:1836
 msgid "Test database driver, database must exist and set by db.connect."
-msgstr "Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db.connect verbunden sein."
+msgstr ""
+"Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db."
+"connect verbunden sein."
-#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1804
+#: ../gui/wxpython/menustrings.py:909 ../gui/wxpython/menustrings.py:1838
 msgid "Query any table"
 msgstr "Frage beliebige Tabelle ab"
-#: ../gui/wxpython/menustrings.py:893 ../gui/wxpython/menustrings.py:1805
+#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1839
 #, fuzzy
 msgid "Selects data from attribute table. Performs SQL query statement(s)."
 msgstr "Selektiert Daten aus der Attributtabelle (führt SQL-Befehle aus)."
-#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1808
+#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1842
 msgid "SQL statement"
 msgstr "SQL-Ausdruck"
-#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1809
+#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1843
 msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1810
+#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1844
 msgid "Vector database connections"
 msgstr "Vektor Datenbank Verbindungen"
-#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1811
+#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:1845
 msgid "New table"
 msgstr "Neue Tabelle"
-#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1812
-msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
-msgstr "Erzeugt und verbindet eine neue Attributtabelle für einen Layer einer existierenden Vektorkarte."
+#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1846
+msgid ""
+"Creates and connects a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+"Erzeugt und verbindet eine neue Attributtabelle für einen Layer einer "
+"existierenden Vektorkarte."
-#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1813
+#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1847
 msgid "Remove table"
 msgstr "Entferne Tabelle"
-#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1814
+#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1848
 msgid "Removes existing attribute table of a vector map."
 msgstr "Entfernt eine existierende Attributtabelle einer Vektorkarte."
-#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1815
+#: ../gui/wxpython/menustrings.py:920 ../gui/wxpython/menustrings.py:1849
 msgid "Join table"
 msgstr "Tabelle joinen"
-#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1816
+#: ../gui/wxpython/menustrings.py:921 ../gui/wxpython/menustrings.py:1850
 #, fuzzy
 msgid "Joins a database table to a vector map table."
 msgstr "Ermöglicht die Verknüpfung einer Tabelle mit einer Vektorkarte."
-#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1817
+#: ../gui/wxpython/menustrings.py:922 ../gui/wxpython/menustrings.py:1851
 msgid "Add columns"
 msgstr "Spalte hinzufügen"
-#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1818
-msgid "Adds one or more columns to the attribute table connected to a given vector map."
-msgstr "Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte hinzu."
+#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1852
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+"Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte "
+"hinzu."
-#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:1820
-msgid "Drops a column from the attribute table connected to a given vector map."
-msgstr "Löscht eine Spalte in einer Attributtabelle die mit einer bestimmten Vektorkarte verbunden ist."
+#: ../gui/wxpython/menustrings.py:925 ../gui/wxpython/menustrings.py:1854
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
+msgstr ""
+"Löscht eine Spalte in einer Attributtabelle die mit einer bestimmten "
+"Vektorkarte verbunden ist."
-#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1822
-msgid "Renames a column in the attribute table connected to a given vector map."
-msgstr "Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten Vektorkarte um."
+#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1856
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+"Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten "
+"Vektorkarte um."
-#: ../gui/wxpython/menustrings.py:911 ../gui/wxpython/menustrings.py:1823
+#: ../gui/wxpython/menustrings.py:928 ../gui/wxpython/menustrings.py:1857
 msgid "Change values"
 msgstr "Werte ändern"
-#: ../gui/wxpython/menustrings.py:912 ../gui/wxpython/menustrings.py:1824
+#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1858
 #, fuzzy
 msgid "Updates a column in the attribute table connected to a vector map."
 msgstr "Aktualisiert eine Spalte einer Attributtabelle einer Vektorkarte."
-#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1825
+#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1859
 msgid "Drop row"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1826
+#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1860
 #, fuzzy
 msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr "Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
+msgstr ""
+"Bestimme Farbregeln für Feature einer Vektorkarte unter Verwendung einer "
+"numerischen Spalte der Attributtabelle."
-#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1827
+#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1861
 msgid "Reconnect vectors to database"
 msgstr "Verbinde Vektoren erneut mit Datenbank"
-#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:1828
+#: ../gui/wxpython/menustrings.py:933 ../gui/wxpython/menustrings.py:1862
 #, fuzzy
-msgid "Reconnects attribute tables for all vector maps from the current mapset to a new database."
+msgid ""
+"Reconnects attribute tables for all vector maps from the current mapset to a "
+"new database."
 msgstr "Sie können nur Vektorkarten des aktuellen Mapsets editieren."
-#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1829
+#: ../gui/wxpython/menustrings.py:934 ../gui/wxpython/menustrings.py:1863
 msgid "Set vector map - database connection"
 msgstr "Gebe die Vektorkarte - Datenbankverbindung"
-#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1830
+#: ../gui/wxpython/menustrings.py:935 ../gui/wxpython/menustrings.py:1864
 msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr "Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer Attributtabelle."
+msgstr ""
+"Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer "
+"Attributtabelle."
-#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1831
+#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1865
 #, fuzzy
 msgid "Temporal"
 msgstr "Kategorie-Modus"
-#: ../gui/wxpython/menustrings.py:920 ../gui/wxpython/menustrings.py:1832
+#: ../gui/wxpython/menustrings.py:937 ../gui/wxpython/menustrings.py:1866
 #, fuzzy
 msgid "Manage datasets"
-#: ../gui/wxpython/menustrings.py:922 ../gui/wxpython/menustrings.py:1834
+#: ../gui/wxpython/menustrings.py:939 ../gui/wxpython/menustrings.py:1868
 #, fuzzy
 msgid "Creates a space time dataset."
-#: ../gui/wxpython/menustrings.py:924 ../gui/wxpython/menustrings.py:1836
+#: ../gui/wxpython/menustrings.py:941 ../gui/wxpython/menustrings.py:1870
 #, fuzzy
 msgid "Renames a space time dataset"
-#: ../gui/wxpython/menustrings.py:926 ../gui/wxpython/menustrings.py:1838
+#: ../gui/wxpython/menustrings.py:943 ../gui/wxpython/menustrings.py:1872
 #, fuzzy
 msgid "Removes space time datasets from temporal database."
-#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1839
+#: ../gui/wxpython/menustrings.py:944 ../gui/wxpython/menustrings.py:1873
 #, fuzzy
 msgid "Update metadata"
 msgstr "Aktualisiert Metadaten der Vektorkarte."
-#: ../gui/wxpython/menustrings.py:928 ../gui/wxpython/menustrings.py:1840
+#: ../gui/wxpython/menustrings.py:945 ../gui/wxpython/menustrings.py:1874
 msgid "Modifies the metadata of a space time dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1841
+#: ../gui/wxpython/menustrings.py:946 ../gui/wxpython/menustrings.py:1875
 msgid "Merge"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1842
+#: ../gui/wxpython/menustrings.py:947 ../gui/wxpython/menustrings.py:1876
 msgid "Merge several space time datasets into a single one"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1843
+#: ../gui/wxpython/menustrings.py:948 ../gui/wxpython/menustrings.py:1877
 #, fuzzy
 msgid "Temporally shift"
-#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1844
+#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1878
 msgid "Temporally shift the maps of a space time dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:933 ../gui/wxpython/menustrings.py:1845
+#: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1879
 #, fuzzy
 msgid "Snap maps of dataset"
 msgstr "Importiere Rasterdaten"
-#: ../gui/wxpython/menustrings.py:934 ../gui/wxpython/menustrings.py:1846
+#: ../gui/wxpython/menustrings.py:951 ../gui/wxpython/menustrings.py:1880
 msgid "Temporally snap the maps of a space time dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1848
+#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1882
 msgid "List space time datasets and maps registered in the temporal database."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:937 ../gui/wxpython/menustrings.py:1849
+#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1883
 #, fuzzy
 msgid "Manage maps in datasets"
-#: ../gui/wxpython/menustrings.py:938 ../gui/wxpython/menustrings.py:1850
+#: ../gui/wxpython/menustrings.py:955 ../gui/wxpython/menustrings.py:1884
 #, fuzzy
 msgid "Register maps in datasets"
 msgstr "Rasterkarteneinstellungen"
-#: ../gui/wxpython/menustrings.py:939 ../gui/wxpython/menustrings.py:1851
+#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1885
 msgid "Registers raster, vector and raster3d maps in a space time datasets."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1852
+#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1886
 #, fuzzy
 msgid "Unregister maps from datasets"
 msgstr "Erzeuge aus Datenbank"
-#: ../gui/wxpython/menustrings.py:941 ../gui/wxpython/menustrings.py:1853
-msgid "Unregisters raster, vector and raster3d maps from the temporal database or a specific space time dataset."
+#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1887
+msgid ""
+"Unregisters raster, vector and raster3d maps from the temporal database or a "
+"specific space time dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:942 ../gui/wxpython/menustrings.py:1854
+#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1888
 #, fuzzy
 msgid "List raster dataset maps"
 msgstr "Liste der Rasterlayer"
-#: ../gui/wxpython/menustrings.py:943 ../gui/wxpython/menustrings.py:1855
+#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1889
 #, fuzzy
 msgid "Lists registered maps of a space time raster dataset."
-#: ../gui/wxpython/menustrings.py:944 ../gui/wxpython/menustrings.py:1856
+#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1890
 #, fuzzy
 msgid "List vector dataset maps"
 msgstr "Editiere Vektorkarte"
-#: ../gui/wxpython/menustrings.py:945 ../gui/wxpython/menustrings.py:1857
+#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1891
 #, fuzzy
 msgid "Lists registered maps of a space time vector dataset."
 msgstr "Importiere Vektordaten"
-#: ../gui/wxpython/menustrings.py:946 ../gui/wxpython/menustrings.py:1858
+#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1892
 #, fuzzy
 msgid "List raster3D dataset maps"
-#: ../gui/wxpython/menustrings.py:947 ../gui/wxpython/menustrings.py:1859
+#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1893
 #, fuzzy
 msgid "Lists registered maps of a space time raster3d dataset."
-#: ../gui/wxpython/menustrings.py:948 ../gui/wxpython/menustrings.py:1860
+#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1894
 #, fuzzy
 msgid "Import"
 msgstr "&Import"
-#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1861
+#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1895
 #, fuzzy
 msgid "Import raster dataset"
-#: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1862
+#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1896
 #, fuzzy
 msgid "Imports space time raster dataset."
-#: ../gui/wxpython/menustrings.py:951 ../gui/wxpython/menustrings.py:1863
+#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1897
 #, fuzzy
 msgid "Import vector dataset"
-#: ../gui/wxpython/menustrings.py:952 ../gui/wxpython/menustrings.py:1864
+#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1898
 #, fuzzy
 msgid "Import a space time vector dataset archive file"
-#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1865
+#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1899
 #: ../gui/wxpython/animation/dialogs.py:767
 #: ../gui/wxpython/lmgr/layertree.py:557
 msgid "Export"
 msgstr "Export"
-#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1866
+#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1900
 #, fuzzy
 msgid "Export raster dataset"
-#: ../gui/wxpython/menustrings.py:955 ../gui/wxpython/menustrings.py:1867
+#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1901
 #, fuzzy
 msgid "Exports space time raster dataset."
-#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1868
+#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1902
 msgid "Export raster dataset as VTK time series"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1869
+#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1903
 #, fuzzy
 msgid "Exports space time raster dataset as VTK time series."
-#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1870
+#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1904
 #, fuzzy
 msgid "Export vector dataset"
-#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1871
+#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1905
 msgid "Export a space time vector dataset.as GRASS specific archive file"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1872
+#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1906
 #, fuzzy
 msgid "Convert raster dataset to volume"
-msgstr "Programm zum Konvertieren von Serien von Rasterkarten zu einem MPEG-Film."
+msgstr ""
+"Programm zum Konvertieren von Serien von Rasterkarten zu einem MPEG-Film."
-#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1873
+#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1907
 #, fuzzy
 msgid "Converts a space time raster dataset into a raster3d map."
 msgstr "Konvertiert eine Vektorkarte in eine Rasterkarte."
-#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1874
+#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1908
 #, fuzzy
 msgid "Extraction"
 msgstr "Textrotation"
-#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1875
+#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1909
 #, fuzzy
 msgid "Extract subset of raster dataset"
-#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1876
+#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1910
 #, fuzzy
 msgid "Extracts a subset of a space time raster datasets."
-#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1877
+#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1911
 #, fuzzy
 msgid "Extract subset of vector dataset"
-#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1878
+#: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1912
 #, fuzzy
 msgid "Extracts a subset of a space time vector dataset."
-#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1879
+#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1913
 #, fuzzy
 msgid "Extract subset of raster3D dataset"
-#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1880
+#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1914
 #, fuzzy
 msgid "Extracts a subset of a space time raster3d dataset."
-#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1881
+#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1915
 #, fuzzy
 msgid "Query vector dataset attribute data"
 msgstr "Frage Vektorattributdaten ab"
-#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1882
+#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1916
 #, fuzzy
-msgid "Prints attributes of vector maps registered in a space time vector dataset."
+msgid ""
+"Prints attributes of vector maps registered in a space time vector dataset."
-#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1883
+#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1917
 #, fuzzy
 msgid "Raster dataset color table"
 msgstr "Farbtabelle setzen"
-#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1884
+#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1918
 #, fuzzy
-msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
+msgid ""
+"Creates/modifies the color table associated with each raster map of the "
+"space time raster dataset."
-#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1885
+#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1919
 #, fuzzy
 msgid "Raster calculations"
 msgstr "Rasterkartenrechner"
-#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1886
-msgid "Perform spatio-temporal mapcalc expressions on temporal sampled maps of space time raster datasets."
+#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1920
+msgid ""
+"Perform spatio-temporal mapcalc expressions on temporal sampled maps of "
+"space time raster datasets."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1887
+#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1921
 #, fuzzy
 msgid "Raster3D calculations"
-#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1888
-msgid "Performs r3.mapcalc expressions on maps of sampled space time raster3d datasets."
+#: ../gui/wxpython/menustrings.py:993 ../gui/wxpython/menustrings.py:1922
+msgid ""
+"Performs r3.mapcalc expressions on maps of sampled space time raster3d "
+"datasets."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1889
+#: ../gui/wxpython/menustrings.py:994 ../gui/wxpython/menustrings.py:1923
 #, fuzzy
 msgid "Interpolate gaps in raster datasets"
-#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1890
-msgid "Replace gaps in a space time raster dataset with interpolated raster maps."
+#: ../gui/wxpython/menustrings.py:995 ../gui/wxpython/menustrings.py:1924
+msgid ""
+"Replace gaps in a space time raster dataset with interpolated raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1891
+#: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1925
 #, fuzzy
 msgid "Aggregation"
-#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1892
+#: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1926
 #, fuzzy
 msgid "Neighborhood analysis in raster dataset"
 msgstr "Nachbarschaftsanalyse"
-#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1893
-msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
+#: ../gui/wxpython/menustrings.py:998 ../gui/wxpython/menustrings.py:1927
+msgid ""
+"Performs a neighborhood analysis for each map in a space time raster dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1894
+#: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1928
 #, fuzzy
 msgid "Aggregation in raster datasets"
-#: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1895
-msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
+#: ../gui/wxpython/menustrings.py:1000 ../gui/wxpython/menustrings.py:1929
+msgid ""
+"Performs different aggregation algorithms from r.series on all or a subset "
+"of raster maps in a space time raster dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1896
+#: ../gui/wxpython/menustrings.py:1001 ../gui/wxpython/menustrings.py:1930
 #, fuzzy
 msgid "Temporal aggregation"
 msgstr ""
 "\n"
-#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1897
-msgid "Temporally aggregates the maps of a space time raster dataset by a user defined granularity."
+#: ../gui/wxpython/menustrings.py:1002 ../gui/wxpython/menustrings.py:1931
+msgid ""
+"Temporally aggregates the maps of a space time raster dataset by a user "
+"defined granularity."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1898
+#: ../gui/wxpython/menustrings.py:1003 ../gui/wxpython/menustrings.py:1932
 #, fuzzy
 msgid "Temporal aggregation by dataset"
 msgstr ""
 "\n"
-#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1899
-msgid "Aggregated data of an existing space time raster dataset using the time intervals of a second space time dataset."
+#: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1933
+msgid ""
+"Aggregated data of an existing space time raster dataset using the time "
+"intervals of a second space time dataset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1900
+#: ../gui/wxpython/menustrings.py:1005 ../gui/wxpython/menustrings.py:1934
 #, fuzzy
 msgid "Sampling"
 msgstr "Karteneinheiten"
-#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1901
+#: ../gui/wxpython/menustrings.py:1006 ../gui/wxpython/menustrings.py:1935
 #, fuzzy
 msgid "Temporal sampling"
-#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1902
-msgid "Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout."
+#: ../gui/wxpython/menustrings.py:1007 ../gui/wxpython/menustrings.py:1936
+msgid ""
+"Samples the input space time dataset(s) with a sample space time dataset and "
+"print the result to stdout."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1903
+#: ../gui/wxpython/menustrings.py:1008 ../gui/wxpython/menustrings.py:1937
 #, fuzzy
 msgid "Query raster dataset by vector points dataset"
 msgstr "Fragt eine Rasterkarte an den Positionen von Vektorpunkten ab."
-#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1904
+#: ../gui/wxpython/menustrings.py:1009 ../gui/wxpython/menustrings.py:1938
 #, fuzzy
-msgid "Store raster map values at spatial and temporal positions of vector points as vector attributes."
-msgstr "Übernimmt die Rasterwerte an den Positionen der Vektorpunkte in die Attributtabelle."
+msgid ""
+"Store raster map values at spatial and temporal positions of vector points "
+"as vector attributes."
+msgstr ""
+"Übernimmt die Rasterwerte an den Positionen der Vektorpunkte in die "
+"Attributtabelle."
-#: ../gui/wxpython/menustrings.py:993 ../gui/wxpython/menustrings.py:1905
+#: ../gui/wxpython/menustrings.py:1010 ../gui/wxpython/menustrings.py:1939
 msgid "Observe specific locations in raster dataset"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:994 ../gui/wxpython/menustrings.py:1906
-msgid "Observes specific locations in a space time raster dataset over a period of time using vector points."
+#: ../gui/wxpython/menustrings.py:1011 ../gui/wxpython/menustrings.py:1940
+msgid ""
+"Observes specific locations in a space time raster dataset over a period of "
+"time using vector points."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1908
+#: ../gui/wxpython/menustrings.py:1013 ../gui/wxpython/menustrings.py:1942
 #, fuzzy
 msgid "Space time datasets metadata"
-#: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1909
+#: ../gui/wxpython/menustrings.py:1014 ../gui/wxpython/menustrings.py:1943
 #, fuzzy
 msgid "Lists information about space time datasets and maps."
 msgstr "Gebe grundlegende Informationen über eine Rasterkarte aus."
-#: ../gui/wxpython/menustrings.py:998 ../gui/wxpython/menustrings.py:1910
+#: ../gui/wxpython/menustrings.py:1015 ../gui/wxpython/menustrings.py:1944
 #, fuzzy
 msgid "Univariate raster dataset statistics"
 msgstr "Univariate Statistiken"
-#: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1911
+#: ../gui/wxpython/menustrings.py:1016 ../gui/wxpython/menustrings.py:1945
 #, fuzzy
-msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
-msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+msgid ""
+"Calculates univariate statistics from the non-null cells for each registered "
+"raster map of a space time raster dataset."
+msgstr ""
+"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
-#: ../gui/wxpython/menustrings.py:1000 ../gui/wxpython/menustrings.py:1912
+#: ../gui/wxpython/menustrings.py:1017 ../gui/wxpython/menustrings.py:1946
 #, fuzzy
 msgid "Univariate vector dataset statistics"
-#: ../gui/wxpython/menustrings.py:1001 ../gui/wxpython/menustrings.py:1913
+#: ../gui/wxpython/menustrings.py:1018 ../gui/wxpython/menustrings.py:1947
 #, fuzzy
-msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
-msgstr "Berechnet univariate Statistiken in ausgewählten Tabellenspalten einer GRASS Vektorkarte."
+msgid ""
+"Calculates univariate statistics of attributes for each registered vector "
+"map of a space time vector dataset"
+msgstr ""
+"Berechnet univariate Statistiken in ausgewählten Tabellenspalten einer GRASS "
+"Vektorkarte."
-#: ../gui/wxpython/menustrings.py:1002 ../gui/wxpython/menustrings.py:1914
+#: ../gui/wxpython/menustrings.py:1019 ../gui/wxpython/menustrings.py:1948
 #, fuzzy
 msgid "Univariate raster3D dataset statistics"
-#: ../gui/wxpython/menustrings.py:1003 ../gui/wxpython/menustrings.py:1915
+#: ../gui/wxpython/menustrings.py:1020 ../gui/wxpython/menustrings.py:1949
 #, fuzzy
-msgid "Calculates univariate statistics from the non-null cells for each registered raster3d map of a space time raster3d dataset."
+msgid ""
+"raster3d map of a space time raster3d dataset."
+msgstr ""
-#: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1916
+#: ../gui/wxpython/menustrings.py:1021 ../gui/wxpython/menustrings.py:1950
 #, fuzzy
 msgid "Report temporal topology"
 msgstr "Lade oder berichte Topologie"
-#: ../gui/wxpython/menustrings.py:1005 ../gui/wxpython/menustrings.py:1917
+#: ../gui/wxpython/menustrings.py:1022 ../gui/wxpython/menustrings.py:1951
 #, fuzzy
 msgid "Lists temporal topology of a space time dataset."
-#: ../gui/wxpython/menustrings.py:1006 ../gui/wxpython/menustrings.py:1918
-#: ../gui/wxpython/menustrings.py:1922
+#: ../gui/wxpython/menustrings.py:1023 ../gui/wxpython/menustrings.py:1952
+#: ../gui/wxpython/menustrings.py:1956
 msgid "GUI tools"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:1009 ../gui/wxpython/menustrings.py:1921
+#: ../gui/wxpython/menustrings.py:1026 ../gui/wxpython/menustrings.py:1955
 #, fuzzy
 msgid "Plot temporal extents"
 msgstr "Zeige den Arbeitsbereich"
-#: ../gui/wxpython/menustrings.py:1010 ../gui/wxpython/menustrings.py:1981
-#: ../gui/wxpython/menustrings.py:2024
+#: ../gui/wxpython/menustrings.py:1027 ../gui/wxpython/menustrings.py:2015
+#: ../gui/wxpython/menustrings.py:2058
 msgid "&Help"
 msgstr "&Hilfe"
-#: ../gui/wxpython/menustrings.py:1011
+#: ../gui/wxpython/menustrings.py:1028
 msgid "GRASS help"
 msgstr "GRASS GIS Hilfe"
-#: ../gui/wxpython/menustrings.py:1012 ../gui/wxpython/menustrings.py:1014
+#: ../gui/wxpython/menustrings.py:1029 ../gui/wxpython/menustrings.py:1031
 #, fuzzy
 msgid "Display the HTML man pages of GRASS GIS"
 msgstr "Zeige die HTML-Handbuchseite von GRASS."
-#: ../gui/wxpython/menustrings.py:1013
+#: ../gui/wxpython/menustrings.py:1030
 msgid "GUI help"
 msgstr "GUI Hilfe"
-#: ../gui/wxpython/menustrings.py:1015
+#: ../gui/wxpython/menustrings.py:1032
 msgid "About system"
 msgstr "Systeminformationen"
-#: ../gui/wxpython/menustrings.py:1016
+#: ../gui/wxpython/menustrings.py:1033
 msgid "Prints system information"
 msgstr "Gibt Systeminformationen aus."
-#: ../gui/wxpython/menustrings.py:1021
+#: ../gui/wxpython/menustrings.py:1038
 #, fuzzy
 msgid "Import, export and link data"
-#: ../gui/wxpython/menustrings.py:1925
+#: ../gui/wxpython/menustrings.py:1959
 #, fuzzy
 msgid "Attribute table manager"
 msgstr "Attributtabellen Manager"
-#: ../gui/wxpython/menustrings.py:1940
+#: ../gui/wxpython/menustrings.py:1974
 msgid "Create new model"
 msgstr "Neues Modell erstellen"
-#: ../gui/wxpython/menustrings.py:1942
+#: ../gui/wxpython/menustrings.py:1976
 msgid "Load model from file"
 msgstr "Lade Modell aus einer Datei"
-#: ../gui/wxpython/menustrings.py:1946
+#: ../gui/wxpython/menustrings.py:1980
 msgid "Save model to file"
 msgstr "Speichere Modell in Datei"
-#: ../gui/wxpython/menustrings.py:1948
+#: ../gui/wxpython/menustrings.py:1982
 msgid "Close model file"
 msgstr "Schließe Modell-Datei"
-#: ../gui/wxpython/menustrings.py:1949
+#: ../gui/wxpython/menustrings.py:1983
 msgid "Export to image"
 msgstr "Exportiere in Bild"
-#: ../gui/wxpython/menustrings.py:1950
+#: ../gui/wxpython/menustrings.py:1984
 msgid "Export model to image"
 msgstr "Exportiere Modell als Bild"
-#: ../gui/wxpython/menustrings.py:1951
+#: ../gui/wxpython/menustrings.py:1985
 msgid "Export to Python"
 msgstr "Exportiere in Python"
-#: ../gui/wxpython/menustrings.py:1952
+#: ../gui/wxpython/menustrings.py:1986
 msgid "Export model to Python script"
 msgstr "Exportiere Modell als Python-Skript"
-#: ../gui/wxpython/menustrings.py:1953
+#: ../gui/wxpython/menustrings.py:1987
 msgid "Quit modeler"
 msgstr "Beende Modeler"
-#: ../gui/wxpython/menustrings.py:1954
+#: ../gui/wxpython/menustrings.py:1988
 msgid "Close modeler window"
 msgstr "Schließe Modeler-Fenster"
-#: ../gui/wxpython/menustrings.py:1958
+#: ../gui/wxpython/menustrings.py:1992
 msgid "&Model"
 msgstr "&Modell"
-#: ../gui/wxpython/menustrings.py:1959
+#: ../gui/wxpython/menustrings.py:1993
 msgid "Add command"
 msgstr "Befehlsebene hinzufügen"
-#: ../gui/wxpython/menustrings.py:1960
+#: ../gui/wxpython/menustrings.py:1994
 msgid "Add action (GRASS command) to model"
 msgstr "Füge Aktion (GRASS Modul) zu Modell hinzu"
-#: ../gui/wxpython/menustrings.py:1961
+#: ../gui/wxpython/menustrings.py:1995
 msgid "Add data"
 msgstr "Füge Daten hinzu"
-#: ../gui/wxpython/menustrings.py:1962
+#: ../gui/wxpython/menustrings.py:1996
 msgid "Add data item to model"
 msgstr "Füge Daten-Objekt zu Modell hinzu"
-#: ../gui/wxpython/menustrings.py:1963
+#: ../gui/wxpython/menustrings.py:1997
 msgid "Define relation"
 msgstr "Definiere Beziehung"
-#: ../gui/wxpython/menustrings.py:1964
+#: ../gui/wxpython/menustrings.py:1998
 msgid "Define relation between data and action items"
 msgstr "Definiere Beziehung zwischen Daten und Aktionen"
-#: ../gui/wxpython/menustrings.py:1965
+#: ../gui/wxpython/menustrings.py:1999
 msgid "Add loop / series"
 msgstr "Schleife / Serie hinzufügen"
-#: ../gui/wxpython/menustrings.py:1966
+#: ../gui/wxpython/menustrings.py:2000
 msgid "Adds loop (series) to model"
 msgstr "Füge Schleife (Serien) zum Modell"
-#: ../gui/wxpython/menustrings.py:1967
+#: ../gui/wxpython/menustrings.py:2001
 msgid "Add condition"
 msgstr "Bedingung hinzufügen"
-#: ../gui/wxpython/menustrings.py:1968
+#: ../gui/wxpython/menustrings.py:2002
 msgid "Adds condition (if/else) to model"
 msgstr "Füge Bedingung (if/else) zu Modell hinzu"
-#: ../gui/wxpython/menustrings.py:1970
+#: ../gui/wxpython/menustrings.py:2004
 #, fuzzy
 msgid "Adds comment to model"
-#: ../gui/wxpython/menustrings.py:1971
+#: ../gui/wxpython/menustrings.py:2005
 msgid "Remove item"
 msgstr "Entferne Objekt"
-#: ../gui/wxpython/menustrings.py:1972
+#: ../gui/wxpython/menustrings.py:2006
 msgid "Remove action/data from model"
 msgstr "Entferne Aktion/Daten aus Modell"
-#: ../gui/wxpython/menustrings.py:1974
+#: ../gui/wxpython/menustrings.py:2008
 msgid "Model properties (name, purpose, etc.)"
 msgstr "Modell-Eigenschaften (Name, Verwendungszweck, etc.)"
-#: ../gui/wxpython/menustrings.py:1975
+#: ../gui/wxpython/menustrings.py:2009
 msgid "Delete intermediate data"
 msgstr "Lösche temporäre Daten"
-#: ../gui/wxpython/menustrings.py:1976
+#: ../gui/wxpython/menustrings.py:2010
 msgid "Delete intermediate data defined in the model"
 msgstr "Lösche im Modell als temporär definierte Daten"
-#: ../gui/wxpython/menustrings.py:1978
+#: ../gui/wxpython/menustrings.py:2012
 msgid "Run entire model"
 msgstr "Starte gesamtes Modell"
-#: ../gui/wxpython/menustrings.py:1979
+#: ../gui/wxpython/menustrings.py:2013
 msgid "Validate model"
 msgstr "Überprüfung des Modells"
-#: ../gui/wxpython/menustrings.py:1980
+#: ../gui/wxpython/menustrings.py:2014
 msgid "Validate entire model"
 msgstr "Überprüfe gesamtes Modell"
-#: ../gui/wxpython/menustrings.py:1982 ../gui/wxpython/menustrings.py:2025
+#: ../gui/wxpython/menustrings.py:2016 ../gui/wxpython/menustrings.py:2059
 #: ../gui/wxpython/timeline/frame.py:131
 msgid "Help"
 msgstr "Hilfe"
-#: ../gui/wxpython/menustrings.py:1983
+#: ../gui/wxpython/menustrings.py:2017
 msgid "Display the HTML man pages of Graphical modeler"
 msgstr "Zeige HTML-Handbuchseite des Grafischen Modellierers"
-#: ../gui/wxpython/menustrings.py:1984
+#: ../gui/wxpython/menustrings.py:2018
 msgid "About Graphical Modeler"
 msgstr "Über den Grafischen Modellierer"
-#: ../gui/wxpython/menustrings.py:1985
+#: ../gui/wxpython/menustrings.py:2019
 msgid "Display information about Graphical Modeler"
 msgstr "Zeige Information über den Grafischen Modellierer an"
-#: ../gui/wxpython/menustrings.py:1991
+#: ../gui/wxpython/menustrings.py:2025
 #, fuzzy
 msgid "Load instruction file"
 msgstr "Kann Anweisungen nicht lesen %s"
-#: ../gui/wxpython/menustrings.py:1993
+#: ../gui/wxpython/menustrings.py:2027
 #, fuzzy
 msgid "Export instruction file"
-#: ../gui/wxpython/menustrings.py:1995
+#: ../gui/wxpython/menustrings.py:2029
 #, fuzzy
 msgid "Export to PostScript"
-#: ../gui/wxpython/menustrings.py:1997
+#: ../gui/wxpython/menustrings.py:2031
 #, fuzzy
 msgid "Export to PDF"
 msgstr "Export nach:"
-#: ../gui/wxpython/menustrings.py:1999 ../gui/wxpython/menustrings.py:2000
+#: ../gui/wxpython/menustrings.py:2033 ../gui/wxpython/menustrings.py:2034
 #, fuzzy
 msgid "Launch ps.map dialog"
 msgstr "Starte Skript"
-#: ../gui/wxpython/menustrings.py:2002
+#: ../gui/wxpython/menustrings.py:2036
 #, fuzzy
 msgid "Close Cartographic Composer"
 msgstr "Kartenlayout"
-#: ../gui/wxpython/menustrings.py:2003
+#: ../gui/wxpython/menustrings.py:2037
 #, fuzzy
 msgid "&Insert"
 msgstr "&Installiere"
-#: ../gui/wxpython/menustrings.py:2005
+#: ../gui/wxpython/menustrings.py:2039
 #, fuzzy
 msgid "Add or edit map frame"
 msgstr "Zeichne einen Rahmen um den Kartenausschnitt"
-#: ../gui/wxpython/menustrings.py:2007
+#: ../gui/wxpython/menustrings.py:2041
 #, fuzzy
 msgid "Add or edit raster map"
 msgstr "Rasterkarte hinzufügen"
-#: ../gui/wxpython/menustrings.py:2009
+#: ../gui/wxpython/menustrings.py:2043
 #, fuzzy
 msgid "Add or edit vector map"
 msgstr "Vektorkarte hinzufügen"
-#: ../gui/wxpython/menustrings.py:2010
+#: ../gui/wxpython/menustrings.py:2044
 #, fuzzy
 msgid "Map legend"
 msgstr "Legende hinzufügen"
-#: ../gui/wxpython/menustrings.py:2011
+#: ../gui/wxpython/menustrings.py:2045
 #, fuzzy
 msgid "Add or edit raster and vector legend"
 msgstr "Georeferenzieren von Raster- und Vektorkarten"
-#: ../gui/wxpython/menustrings.py:2013
+#: ../gui/wxpython/menustrings.py:2047
 #, fuzzy
 msgid "Add or edit map info"
 msgstr "Karteninformation hinzufügen"
-#: ../gui/wxpython/menustrings.py:2015
+#: ../gui/wxpython/menustrings.py:2049
 #, fuzzy
 msgid "Add or edit scale bar"
 msgstr "Maßstab hinzufügen"
-#: ../gui/wxpython/menustrings.py:2017
+#: ../gui/wxpython/menustrings.py:2051
 #: ../gui/wxpython/animation/dialogs.py:813
 msgid "Add text"
 msgstr "Text hinzufügen"
-#: ../gui/wxpython/menustrings.py:2019
+#: ../gui/wxpython/menustrings.py:2053
 msgid "Add image"
 msgstr "Bild hinzufügen"
-#: ../gui/wxpython/menustrings.py:2021
+#: ../gui/wxpython/menustrings.py:2055
 msgid "Add north arrow"
 msgstr "Nordpfeil hinzufügen"
-#: ../gui/wxpython/menustrings.py:2026
+#: ../gui/wxpython/menustrings.py:2060
 #, fuzzy
 msgid "Display the HTML man pages of Cartographic Composer"
-#: ../gui/wxpython/menustrings.py:2027
+#: ../gui/wxpython/menustrings.py:2061
 #, fuzzy
 msgid "About Cartographic Composer"
 msgstr "Kartenlayout beenden"
-#: ../gui/wxpython/menustrings.py:2028
+#: ../gui/wxpython/menustrings.py:2062
 #, fuzzy
 msgid "Display information about Cartographic Composer"
@@ -10833,7 +11668,9 @@
 #: ../gui/wxpython/animation/controller.py:240
 #: ../gui/wxpython/animation/dialogs.py:729
-msgid "More animations are using one window. Please select different window for each animation."
+msgid ""
+"More animations are using one window. Please select different window for "
+"each animation."
 msgstr ""
 #: ../gui/wxpython/animation/controller.py:396
@@ -10856,7 +11693,7 @@
 msgstr "Rektifiziere Bilder, bitte warten"
 #: ../gui/wxpython/animation/controller.py:524
-#: ../gui/wxpython/animation/frame.py:574
+#: ../gui/wxpython/animation/frame.py:577
 #, python-format
 msgid "%(from)s %(dash)s %(to)s"
 msgstr ""
@@ -10929,7 +11766,7 @@
 msgid "Add space-time dataset or series of map layers for animation"
 msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:45 ../gui/wxpython/lmgr/frame.py:1177
+#: ../gui/wxpython/animation/nviztask.py:46 ../gui/wxpython/lmgr/frame.py:1177
 #, python-format
 msgid ""
 "Reading workspace file <%s> failed.\n"
@@ -10938,17 +11775,17 @@
 "Lesen der Workspace-Datei <%s> fehlgeschlagen.\n"
 "Ungültige Datei, Parsen des XML-Dokumentes nicht möglich."
-#: ../gui/wxpython/animation/nviztask.py:54
+#: ../gui/wxpython/animation/nviztask.py:55
 #, fuzzy, python-format
 msgid "No 3d view information in workspace file <%s>."
 msgstr "Einstellungen für 3D-Ansicht gespeichert in Datei <%s>."
-#: ../gui/wxpython/animation/nviztask.py:240
+#: ../gui/wxpython/animation/nviztask.py:263
 #, fuzzy
 msgid "Please add only one layer in the list."
 msgstr "Selektierte Kartenebenen der Baumstruktur hinzufügen"
-#: ../gui/wxpython/animation/nviztask.py:246
+#: ../gui/wxpython/animation/nviztask.py:269
 #, fuzzy
 msgid "No map series nor space-time dataset is added."
@@ -11301,7 +12138,9 @@
 msgstr "Erzeugungsoptionen:"
 #: ../gui/wxpython/animation/dialogs.py:1000
-msgid "Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. Options depend on ffmpeg version."
+msgid ""
+"Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. "
+"Options depend on ffmpeg version."
 msgstr ""
 #: ../gui/wxpython/animation/dialogs.py:1022
@@ -11405,7 +12244,9 @@
 msgstr "Koordinatenformat"
 #: ../gui/wxpython/animation/dialogs.py:1536
-msgid "Click and then press key up or down to preview different date and time formats. Type custom format string."
+msgid ""
+"Click and then press key up or down to preview different date and time "
+"formats. Type custom format string."
 msgstr ""
 #: ../gui/wxpython/animation/dialogs.py:1545
@@ -11417,7 +12258,9 @@
 msgstr ""
 #: ../gui/wxpython/animation/dialogs.py:1555
-msgid "When animating instant-based data which have irregular timestamps you can display 'no data frame' (checked option) or keep last frame."
+msgid ""
+"When animating instant-based data which have irregular timestamps you can "
+"display 'no data frame' (checked option) or keep last frame."
 msgstr ""
 #: ../gui/wxpython/animation/dialogs.py:1577
@@ -11441,7 +12284,9 @@
 msgstr "Verzeichnis %s nicht gefunden."
 #: ../gui/wxpython/animation/temporal_manager.py:107
-msgid "It is not allowed to display data with different temporal types (absolute and relative)."
+msgid ""
+"It is not allowed to display data with different temporal types (absolute "
+"and relative)."
 msgstr ""
 #: ../gui/wxpython/animation/temporal_manager.py:121
@@ -11450,7 +12295,10 @@
 msgstr ""
 #: ../gui/wxpython/animation/temporal_manager.py:132
-msgid "You are going to display data with different temporal types of maps (interval and point). It is recommended to use data of one temporal type to avoid confusion."
+msgid ""
+"You are going to display data with different temporal types of maps "
+"(interval and point). It is recommended to use data of one temporal type to "
+"avoid confusion."
 msgstr ""
 #: ../gui/wxpython/animation/temporal_manager.py:229
@@ -11490,7 +12338,7 @@
 msgid " ({} out of {})"
 msgstr ""
-#: ../gui/wxpython/animation/frame.py:577
+#: ../gui/wxpython/animation/frame.py:580
 #, python-format
 msgid "to %(to)s"
 msgstr ""
@@ -11508,15 +12356,19 @@
 msgstr ""
 #: ../gui/wxpython/animation/utils.py:160
-msgid "The temporal type (absolute/relative) of space-time datasets has to be the same."
+msgid ""
+"The temporal type (absolute/relative) of space-time datasets has to be the "
+"same."
 msgstr ""
 #: ../gui/wxpython/animation/utils.py:164
-msgid "The map type (point/interval) of space-time datasets has to be the same."
+msgid ""
+"The map type (point/interval) of space-time datasets has to be the same."
 msgstr ""
 #: ../gui/wxpython/animation/utils.py:168
-msgid "The temporal extents of maps in space-time datasets have to be the same."
+msgid ""
+"The temporal extents of maps in space-time datasets have to be the same."
 msgstr ""
 #: ../gui/wxpython/animation/utils.py:176
@@ -11524,7 +12376,9 @@
 msgstr ""
 #: ../gui/wxpython/animation/utils.py:180
-msgid "The number of maps to animate has to be the same as the number of maps in temporal dataset."
+msgid ""
+"The number of maps to animate has to be the same as the number of maps in "
+"temporal dataset."
 msgstr ""
 #: ../gui/wxpython/modules/mcalc_builder.py:58
@@ -11564,147 +12418,153 @@
 msgid "Load expression from file"
 msgstr "Lade ausdruck aus Datei"
-#: ../gui/wxpython/modules/mcalc_builder.py:153
+#: ../gui/wxpython/modules/mcalc_builder.py:155
 msgid "exponent"
 msgstr "Exponent"
-#: ../gui/wxpython/modules/mcalc_builder.py:155
+#: ../gui/wxpython/modules/mcalc_builder.py:157
 msgid "divide"
 msgstr "dividiere"
-#: ../gui/wxpython/modules/mcalc_builder.py:157
+#: ../gui/wxpython/modules/mcalc_builder.py:159
 msgid "add"
 msgstr "addiere"
-#: ../gui/wxpython/modules/mcalc_builder.py:159
+#: ../gui/wxpython/modules/mcalc_builder.py:161
 msgid "subtract"
 msgstr "subtrahiere"
-#: ../gui/wxpython/modules/mcalc_builder.py:161
+#: ../gui/wxpython/modules/mcalc_builder.py:163
 msgid "modulus"
 msgstr "modulus"
-#: ../gui/wxpython/modules/mcalc_builder.py:163
+#: ../gui/wxpython/modules/mcalc_builder.py:165
 msgid "multiply"
 msgstr "multipliziere"
-#: ../gui/wxpython/modules/mcalc_builder.py:168
+#: ../gui/wxpython/modules/mcalc_builder.py:170
 msgid "left shift"
 msgstr "links Verschiebung"
-#: ../gui/wxpython/modules/mcalc_builder.py:170
+#: ../gui/wxpython/modules/mcalc_builder.py:172
 msgid "right shift"
 msgstr "rechts Verschiebung"
-#: ../gui/wxpython/modules/mcalc_builder.py:172
+#: ../gui/wxpython/modules/mcalc_builder.py:174
 msgid "right shift (unsigned)"
 msgstr "rechts Verschiebung (vorzeichenlos)"
-#: ../gui/wxpython/modules/mcalc_builder.py:174
+#: ../gui/wxpython/modules/mcalc_builder.py:176
 msgid "greater than"
 msgstr "größer als"
-#: ../gui/wxpython/modules/mcalc_builder.py:176
+#: ../gui/wxpython/modules/mcalc_builder.py:178
 msgid "greater than or equal to"
 msgstr "größer als oder gleich"
-#: ../gui/wxpython/modules/mcalc_builder.py:178
+#: ../gui/wxpython/modules/mcalc_builder.py:180
 msgid "less than"
 msgstr "kleiner als"
-#: ../gui/wxpython/modules/mcalc_builder.py:180
+#: ../gui/wxpython/modules/mcalc_builder.py:182
 msgid "less than or equal to"
 msgstr "kleiner als oder gleich"
-#: ../gui/wxpython/modules/mcalc_builder.py:182
+#: ../gui/wxpython/modules/mcalc_builder.py:184
 msgid "equal to"
 msgstr "gleich"
-#: ../gui/wxpython/modules/mcalc_builder.py:184
+#: ../gui/wxpython/modules/mcalc_builder.py:186
 msgid "not equal to"
 msgstr "ungleich"
-#: ../gui/wxpython/modules/mcalc_builder.py:187
+#: ../gui/wxpython/modules/mcalc_builder.py:189
 msgid "one's complement"
 msgstr "Einserkomplement"
-#: ../gui/wxpython/modules/mcalc_builder.py:189
+#: ../gui/wxpython/modules/mcalc_builder.py:191
 msgid "NOT"
 msgstr "NICHT"
-#: ../gui/wxpython/modules/mcalc_builder.py:191
+#: ../gui/wxpython/modules/mcalc_builder.py:193
 msgid "bitwise AND"
 msgstr "bitweises UND"
-#: ../gui/wxpython/modules/mcalc_builder.py:193
+#: ../gui/wxpython/modules/mcalc_builder.py:195
 msgid "bitwise OR"
 msgstr "bitweises ODER"
-#: ../gui/wxpython/modules/mcalc_builder.py:195
+#: ../gui/wxpython/modules/mcalc_builder.py:197
 msgid "logical AND"
 msgstr "logisches UND"
-#: ../gui/wxpython/modules/mcalc_builder.py:197
+#: ../gui/wxpython/modules/mcalc_builder.py:199
 msgid "logical AND (ignores NULLs)"
 msgstr "logisches UND (ignoriert NULL)"
-#: ../gui/wxpython/modules/mcalc_builder.py:199
+#: ../gui/wxpython/modules/mcalc_builder.py:201
 msgid "logical OR"
 msgstr "logisches ODER"
-#: ../gui/wxpython/modules/mcalc_builder.py:201
+#: ../gui/wxpython/modules/mcalc_builder.py:203
 msgid "logical OR (ignores NULLs)"
 msgstr "logisches ODER (ignoriert NULL)"
-#: ../gui/wxpython/modules/mcalc_builder.py:203
+#: ../gui/wxpython/modules/mcalc_builder.py:205
 msgid "conditional"
 msgstr "bedingt"
-#: ../gui/wxpython/modules/mcalc_builder.py:216
+#: ../gui/wxpython/modules/mcalc_builder.py:218
 msgid "Name for new 3D raster map to create"
 msgstr "Name für neu zu erzeugende 3D Rasterkarte"
-#: ../gui/wxpython/modules/mcalc_builder.py:218
+#: ../gui/wxpython/modules/mcalc_builder.py:220
 msgid "Name for new raster map to create"
-#: ../gui/wxpython/modules/mcalc_builder.py:222
+#: ../gui/wxpython/modules/mcalc_builder.py:224
 msgid "Insert existing 3D raster map"
 msgstr "Füge existierende 3D Rasterkarte ein"
-#: ../gui/wxpython/modules/mcalc_builder.py:224
+#: ../gui/wxpython/modules/mcalc_builder.py:226
 msgid "Insert existing raster map"
 msgstr "Füge existierende Rasterkarte ein"
-#: ../gui/wxpython/modules/mcalc_builder.py:228
+#: ../gui/wxpython/modules/mcalc_builder.py:230
 msgid "Insert mapcalc function"
 msgstr "Füge mapcalc-Funktion ein"
-#: ../gui/wxpython/modules/mcalc_builder.py:239
+#: ../gui/wxpython/modules/mcalc_builder.py:241
 msgid "Add created raster map into layer tree"
 msgstr "Erzeugte Karte der Baumstruktur hinzufügen"
-#: ../gui/wxpython/modules/mcalc_builder.py:489
+#: ../gui/wxpython/modules/mcalc_builder.py:504
 msgid "You must enter the name of a new raster map to create."
 msgstr "Sie müssen einen Namen für die zu erzeugenden Rasterkarte eingeben."
-#: ../gui/wxpython/modules/mcalc_builder.py:499
+#: ../gui/wxpython/modules/mcalc_builder.py:514
 msgid "You must enter an expression to create a new raster map."
-msgstr "Sie müssen ein Ausdruck eingeben, um eine neue Rasterkarte zu erzeugen."
+msgstr ""
+"Sie müssen ein Ausdruck eingeben, um eine neue Rasterkarte zu erzeugen."
-#: ../gui/wxpython/modules/mcalc_builder.py:538
+#: ../gui/wxpython/modules/mcalc_builder.py:553
 msgid "Choose a file name to save the expression"
 msgstr "Wählen Sie einen Dateinamen, um den Ausdruck zu speichern"
-#: ../gui/wxpython/modules/mcalc_builder.py:539
-#: ../gui/wxpython/modules/mcalc_builder.py:560
+#: ../gui/wxpython/modules/mcalc_builder.py:554
+#: ../gui/wxpython/modules/mcalc_builder.py:575
 msgid "Expression file (*)|*"
 msgstr "Terminus-Datei (*)|*"
-#: ../gui/wxpython/modules/mcalc_builder.py:559
+#: ../gui/wxpython/modules/mcalc_builder.py:574
 msgid "Choose a file name to load the expression"
 msgstr "Wählen Sie einen Dateinamen, um den Ausdruck zu laden"
+#: ../gui/wxpython/modules/mcalc_builder.py:609
+#, fuzzy, python-brace-format
+msgid "'{cmd}' copied to clipboard"
+msgstr "'%s' in die Zwischenablage kopiert"
 #: ../gui/wxpython/modules/vclean.py:37 ../gui/wxpython/modules/vclean.py:119
 msgid "Set up vector cleaning tools"
 msgstr "Einstellen der Vektor-Cleaning-Tools"
@@ -11822,7 +12682,8 @@
 #: ../gui/wxpython/modules/vclean.py:386
 msgid "Please select a cleaning tool to move up"
-msgstr "Wählen sie ein Vektor-Cleaning-Tool aus, um es weiter nach oben zu reihen"
+msgstr ""
+"Wählen sie ein Vektor-Cleaning-Tool aus, um es weiter nach oben zu reihen"
 #: ../gui/wxpython/modules/vclean.py:408
 #, python-format
@@ -11835,7 +12696,8 @@
 #: ../gui/wxpython/modules/vclean.py:412
 msgid "Please select a cleaning tool to move down"
-msgstr "Bitte wählen Sie ein Cleaning-Werkzeug aus, um es nach unten zu verschieben"
+msgstr ""
+"Bitte wählen Sie ein Cleaning-Werkzeug aus, um es nach unten zu verschieben"
 #: ../gui/wxpython/modules/vclean.py:423
 #, python-format
@@ -11886,7 +12748,8 @@
 #: ../gui/wxpython/modules/vclean.py:527
 msgid "Vector cleaning command copied to clipboard"
-msgstr "Befehl zum Säubern von Vektordaten wurden in die Zwischenablage kopiert"
+msgstr ""
+"Befehl zum Säubern von Vektordaten wurden in die Zwischenablage kopiert"
 #: ../gui/wxpython/modules/colorrules.py:74
 msgid "Check all"
@@ -11997,7 +12860,8 @@
 #: ../gui/wxpython/modules/colorrules.py:878
 #, python-format
 msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
-msgstr "Gib Rasterkategoriewerte oder Prozent (%(range)s = %(min)d-%(max)d) ein"
+msgstr ""
+"Gib Rasterkategoriewerte oder Prozent (%(range)s = %(min)d-%(max)d) ein"
 #: ../gui/wxpython/modules/colorrules.py:966
 msgid "Create new color rules for vector map"
@@ -12064,8 +12928,12 @@
 #: ../gui/wxpython/modules/colorrules.py:1137
 #, python-format
-msgid "Database connection for vector map <%s> is not defined in DB file.  Do you want to create and connect new attribute table?"
-msgstr "Die Datenbankverbindung der Vektorkarte <%s> ist nicht in der DB-Datei definiert. Möchten Sie eine neue Verbindung anlegen?"
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file.  Do you "
+"want to create and connect new attribute table?"
+msgstr ""
+"Die Datenbankverbindung der Vektorkarte <%s> ist nicht in der DB-Datei "
+"definiert. Möchten Sie eine neue Verbindung anlegen?"
 #: ../gui/wxpython/modules/colorrules.py:1140
 msgid "No database connection defined"
@@ -12073,8 +12941,12 @@
 #: ../gui/wxpython/modules/colorrules.py:1212
 #, python-format
-msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute table cannot be edited."
-msgstr "Die selektierte Karte <%(map)s> ist nicht im aktuellen Mapset <%(mapset)s>. Attributtabelle kann nicht geändert werden."
+msgid ""
+"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
+"table cannot be edited."
+msgstr ""
+"Die selektierte Karte <%(map)s> ist nicht im aktuellen Mapset <%(mapset)s>. "
+"Attributtabelle kann nicht geändert werden."
 #: ../gui/wxpython/modules/colorrules.py:1365
 #, python-format
@@ -12087,8 +12959,13 @@
 #: ../gui/wxpython/modules/colorrules.py:1458
 #, python-format
-msgid "Number of loaded records reached %d, displaying all the records will be time-consuming and may lead to computer freezing, do you still want to continue?"
-msgstr "Anzahl der geladenen Zeilen erreicht %d. Alle Zeilen anzuzeigen wird sehr lange dauern und könnte dazu führen, dass der Computer einfriert. Wollen Sie fortfahren?"
+msgid ""
+"Number of loaded records reached %d, displaying all the records will be time-"
+"consuming and may lead to computer freezing, do you still want to continue?"
+msgstr ""
+"Anzahl der geladenen Zeilen erreicht %d. Alle Zeilen anzuzeigen wird sehr "
+"lange dauern und könnte dazu führen, dass der Computer einfriert. Wollen Sie "
+"fortfahren?"
 #: ../gui/wxpython/modules/colorrules.py:1462
 msgid "Too many records"
@@ -12364,8 +13241,12 @@
 #: ../gui/wxpython/mapwin/analysis.py:233
 #: ../gui/wxpython/mapwin/analysis.py:340
 #, python-format
-msgid "Click and drag with left mouse button to measure.%sDouble click with left button to clear."
-msgstr "Klicken und ziehen mit der linken Maustaste um zu messen.%sDoppelklick mit der linken Maustaste, um zu Löschen."
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
+msgstr ""
+"Klicken und ziehen mit der linken Maustaste um zu messen.%sDoppelklick mit "
+"der linken Maustaste, um zu Löschen."
 #: ../gui/wxpython/mapwin/analysis.py:239
 msgid "Measuring distance"
@@ -12524,8 +13405,11 @@
 msgstr "Fly-through Modus"
 #: ../gui/wxpython/mapdisp/toolbars.py:62
-msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
-msgstr "Mit der Maus verschieben. Strg-Taste ändert den Modus und Umschalttaste beschleunigt."
+msgid ""
+"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+msgstr ""
+"Mit der Maus verschieben. Strg-Taste ändert den Modus und Umschalttaste "
+"beschleunigt."
 #: ../gui/wxpython/mapdisp/toolbars.py:64
 msgid "Click mouse to zoom"
@@ -12555,8 +13439,15 @@
 msgstr "Vektordigitalisierer nicht vorhanden"
 #: ../gui/wxpython/mapdisp/toolbars.py:109
-msgid "Note that the wxGUI's vector digitizer is currently disabled (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"v.digit\" from the Develop Vector menu."
-msgstr "Beachten Sie, dass der Vektordigitalisierer derzeit unter MS Windows nicht funktioniert (dieses wird hoffentlich bald behoben sein). Bitte achten Sie auf aktualisierte Versionen von GRASS. In der Zwischenzeit können Sie \"v.digit\" aus dem Menü \"Vektor\" - \"Vektorkarten pflegen\" verwenden."
+msgid ""
+"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
+"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
+"In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr ""
+"Beachten Sie, dass der Vektordigitalisierer derzeit unter MS Windows nicht "
+"funktioniert (dieses wird hoffentlich bald behoben sein). Bitte achten Sie "
+"auf aktualisierte Versionen von GRASS. In der Zwischenzeit können Sie \"v."
+"digit\" aus dem Menü \"Vektor\" - \"Vektorkarten pflegen\" verwenden."
 #: ../gui/wxpython/mapdisp/gprint.py:150
 msgid ""
@@ -12603,32 +13494,51 @@
 #: ../gui/wxpython/mapdisp/statusbar.py:436
-msgid "Show/hide computational region extent (set with g.region). Display region drawn as a blue box inside the computational region, computational region inside a display region as a red box)."
-msgstr "Zeige/verberge den Arbeitsbereich (mit g.region definiert). Zeige die Region als blaues Rechteck im Arbeitsbereich und den Arbeitsbereich als rotes Rechteck im Kartenfenster."
+msgid ""
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
+msgstr ""
+"Zeige/verberge den Arbeitsbereich (mit g.region definiert). Zeige die Region "
+"als blaues Rechteck im Arbeitsbereich und den Arbeitsbereich als rotes "
+"Rechteck im Kartenfenster."
 #: ../gui/wxpython/mapdisp/statusbar.py:484
 msgid "Display mode"
 msgstr "Anzeige-Modus"
 #: ../gui/wxpython/mapdisp/statusbar.py:491
-msgid "Align region extent based on display size from center point. Default value for new map displays can be set up in 'User GUI settings' dialog."
-msgstr "Richte Arbeitsbereich am Kartenfenster aus. Standardwert für neue Kartenfenster kann in 'GUI Einstellungen' definiert werden."
+msgid ""
+"Align region extent based on display size from center point. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
+msgstr ""
+"Richte Arbeitsbereich am Kartenfenster aus. Standardwert für neue "
+"Kartenfenster kann in 'GUI Einstellungen' definiert werden."
 #: ../gui/wxpython/mapdisp/statusbar.py:524
 msgid "Display resolution"
 msgstr "Auflösung des Kartenfensters"
 #: ../gui/wxpython/mapdisp/statusbar.py:530
-msgid "Constrain display resolution to computational region settings. Default value for new map displays can be set up in 'User GUI settings' dialog."
-msgstr "Beschränke die Auflösung des Kartenfensters auf die Einstellungen des Arbeitsbereichs. Standardwert für neue Kartenfenster kann in 'GUI Einstellungen' definiert werden. "
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
+msgstr ""
+"Beschränke die Auflösung des Kartenfensters auf die Einstellungen des "
+"Arbeitsbereichs. Standardwert für neue Kartenfenster kann in 'GUI "
+"Einstellungen' definiert werden. "
 #: ../gui/wxpython/mapdisp/statusbar.py:567
 msgid "Map scale"
 msgstr "Kartenmaßstab"
 #: ../gui/wxpython/mapdisp/statusbar.py:581
-msgid "As everyone's monitors and resolutions are set differently these values are not true map scales, but should get you into the right neighborhood."
-msgstr "Da die Bildschirmauflösungen an jedem Arbeitsplatz unterschiedlich sind, können die Maßstabsangaben nicht exakt sein. Die Größenordnung wird stimmen."
+msgid ""
+"As everyone's monitors and resolutions are set differently these values are "
+"not true map scales, but should get you into the right neighborhood."
+msgstr ""
+"Da die Bildschirmauflösungen an jedem Arbeitsplatz unterschiedlich sind, "
+"können die Maßstabsangaben nicht exakt sein. Die Größenordnung wird stimmen."
 #: ../gui/wxpython/mapdisp/statusbar.py:634
 msgid "Go to"
@@ -12652,8 +13562,12 @@
 msgstr "Verwende definierte Projektion"
 #: ../gui/wxpython/mapdisp/statusbar.py:779
-msgid "Reproject coordinates displayed in the statusbar. Projection can be defined in GUI preferences dialog (tab 'Projection')"
-msgstr "Umprojezierte Koordinaten in der Statusleiste angezeigt. Die Projektion kann in GUI Einstellungen (Reiter 'Projektion') definiert werden."
+msgid ""
+"Reproject coordinates displayed in the statusbar. Projection can be defined "
+"in GUI preferences dialog (tab 'Projection')"
+msgstr ""
+"Umprojezierte Koordinaten in der Statusleiste angezeigt. Die Projektion kann "
+"in GUI Einstellungen (Reiter 'Projektion') definiert werden."
 #: ../gui/wxpython/mapdisp/statusbar.py:804
 msgid "MASK"
@@ -12682,7 +13596,8 @@
 #: ../gui/wxpython/mapdisp/frame.py:253
-msgid "GRASS GIS %(version)s Map Display: %(id)s  - Location: %(loc)s@%(mapset)s"
+msgid ""
+"GRASS GIS %(version)s Map Display: %(id)s  - Location: %(loc)s@%(mapset)s"
 msgstr "GRASS GIS Kartenfenster: %(id)d  - Location: %(loc)s"
 #: ../gui/wxpython/mapdisp/frame.py:271 ../gui/wxpython/lmgr/layertree.py:871
@@ -12710,7 +13625,8 @@
 "Details: %s"
 msgstr ""
 "Kann nicht in 3D Modus wechseln.\n"
-"Die Nviz Python Erweiterung wurde nicht gefunden oder nicht korrekt geladen.\n"
+"Die Nviz Python Erweiterung wurde nicht gefunden oder nicht korrekt "
+"geladen.\n"
 "Schalte zurück auf 2D Modus.\n"
 "\n"
 "Einzelheiten: %s"
@@ -12805,8 +13721,12 @@
 msgstr "Neigung:"
 #: ../gui/wxpython/nviz/tools.py:271
-msgid "Adjusts the viewing height above the surface (angle of view automatically adjusts to maintain the same center of view)"
-msgstr "Passt die Höhe des Blickpunktes über der Oberfläche an (der Blickwinkel wird automatisch adjustiert, um das Bildzentrum zu erhalten) "
+msgid ""
+"Adjusts the viewing height above the surface (angle of view automatically "
+"adjusts to maintain the same center of view)"
+msgstr ""
+"Passt die Höhe des Blickpunktes über der Oberfläche an (der Blickwinkel wird "
+"automatisch adjustiert, um das Bildzentrum zu erhalten) "
 #: ../gui/wxpython/nviz/tools.py:276
 msgid "Adjusts the relative height of features above the plane of the surface"
@@ -12825,8 +13745,12 @@
 msgstr "hier"
 #: ../gui/wxpython/nviz/tools.py:309
-msgid "Allows you to select a point on the surface that becomes the new center of view. Click on the button and then on the surface."
-msgstr "Erlaubt Ihnen ein neues Zentrum der Ansicht zu wählen. Klicken Sie zunächst auf den Button und dann auf die Oberfläche."
+msgid ""
+"Allows you to select a point on the surface that becomes the new center of "
+"view. Click on the button and then on the surface."
+msgstr ""
+"Erlaubt Ihnen ein neues Zentrum der Ansicht zu wählen. Klicken Sie zunächst "
+"auf den Button und dann auf die Oberfläche."
 #: ../gui/wxpython/nviz/tools.py:315
 msgid "center"
@@ -12841,8 +13765,12 @@
 msgstr "oben"
 #: ../gui/wxpython/nviz/tools.py:325
-msgid "Sets the viewer directly over the scene's center position. This top view orients approximately north south."
-msgstr "Ansicht direkt von oben über dem Zentrum. Die Ansicht ist ungefähr in Nord-Süd-Richtung."
+msgid ""
+"Sets the viewer directly over the scene's center position. This top view "
+"orients approximately north south."
+msgstr ""
+"Ansicht direkt von oben über dem Zentrum. Die Ansicht ist ungefähr in Nord-"
+"Süd-Richtung."
 #: ../gui/wxpython/nviz/tools.py:329
 msgid "reset"
@@ -12857,8 +13785,13 @@
 msgstr "Erscheinungsbild"
 #: ../gui/wxpython/nviz/tools.py:392
-msgid "Press 'Record' button and start changing the view. It is recommended to use fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr "Klicken Sie auf den 'Aufnehmen' Button und beginnen Sie die Ansicht zu verändern. Es ist empfehlenswert den fly-through Modus zu verwenden um flüssige Bewegungen zu erhalten."
+msgid ""
+"Press 'Record' button and start changing the view. It is recommended to use "
+"fly-through mode (Map Display toolbar) to achieve smooth motion."
+msgstr ""
+"Klicken Sie auf den 'Aufnehmen' Button und beginnen Sie die Ansicht zu "
+"verändern. Es ist empfehlenswert den fly-through Modus zu verwenden um "
+"flüssige Bewegungen zu erhalten."
 #: ../gui/wxpython/nviz/tools.py:403
 msgid "Record"
@@ -12889,8 +13822,10 @@
 msgstr "Wählen Sie ein Verzeichnis für Bilder"
 #: ../gui/wxpython/nviz/tools.py:490
-msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
-msgstr "Erzeugte Dateinamen haben folgendes Muster: prefix_1.ppm, prefix_2.ppm, ..."
+msgid ""
+"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+msgstr ""
+"Erzeugte Dateinamen haben folgendes Muster: prefix_1.ppm, prefix_2.ppm, ..."
 #: ../gui/wxpython/nviz/tools.py:546 ../gui/wxpython/nviz/tools.py:1859
 #: ../gui/wxpython/nviz/preferences.py:361
@@ -13082,8 +14017,12 @@
 msgstr "Rotiert die aktuelle Schnittfläche um die horizontale Achse"
 #: ../gui/wxpython/nviz/tools.py:1042
-msgid "Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)"
-msgstr "Bestimmt die Z-Koordinate der aktuellen Schnittfläche (nur sinnvoll wenn die Neigung nicht 0 ist)"
+msgid ""
+"Sets the Z coordinate of the current cutting plane (only meaningful when "
+"tilt is not 0)"
+msgstr ""
+"Bestimmt die Z-Koordinate der aktuellen Schnittfläche (nur sinnvoll wenn die "
+"Neigung nicht 0 ist)"
 #: ../gui/wxpython/nviz/tools.py:1111
 msgid "Fine resolution:"
@@ -13270,7 +14209,8 @@
 #: ../gui/wxpython/nviz/tools.py:2087
 msgid "Do you want to record new animation without saving the previous one?"
-msgstr "Wollen Sie eine neue Animation aufzeichnen ohne die vorherige zu speichern?"
+msgstr ""
+"Wollen Sie eine neue Animation aufzeichnen ohne die vorherige zu speichern?"
 #: ../gui/wxpython/nviz/tools.py:2090
 msgid "Animation already axists"
@@ -13445,8 +14385,12 @@
 msgstr "Passt Entfernung und Richtung des Betrachters an"
 #: ../gui/wxpython/nviz/tools.py:5164
-msgid "Adjusts the light direction. Click and drag the puck to change the light direction."
-msgstr "Passt die Richtung der Beleuchtung an. Verschieben Sie die Scheibe um die Richtung zu ändern."
+msgid ""
+"Adjusts the light direction. Click and drag the puck to change the light "
+"direction."
+msgstr ""
+"Passt die Richtung der Beleuchtung an. Verschieben Sie die Scheibe um die "
+"Richtung zu ändern."
 #: ../gui/wxpython/nviz/preferences.py:32
 #, fuzzy
@@ -13455,7 +14399,8 @@
 #: ../gui/wxpython/nviz/preferences.py:49
 msgid "Revert settings to default, changes are not applied"
-msgstr "Kehre zu den Standardeinstellungen zurück und wende die Änderungen nicht an"
+msgstr ""
+"Kehre zu den Standardeinstellungen zurück und wende die Änderungen nicht an"
 #: ../gui/wxpython/nviz/preferences.py:72
 #: ../gui/wxpython/nviz/preferences.py:135
@@ -13520,13 +14465,21 @@
 #: ../gui/wxpython/nviz/mapwindow.py:224
-msgid "Opening 3D view was not successful. Please try to change the value of depth buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
-msgstr "Öffnen der 3D-Ansicht war nicht erfolgreich. Ändere den Wert des Tiefenbuffers in den GUI-Einstellungen > Map Display > Fortgeschritten und erneuter GUI-Start."
+msgid ""
+"Opening 3D view was not successful. Please try to change the value of depth "
+"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+msgstr ""
+"Öffnen der 3D-Ansicht war nicht erfolgreich. Ändere den Wert des "
+"Tiefenbuffers in den GUI-Einstellungen > Map Display > Fortgeschritten und "
+"erneuter GUI-Start."
 #: ../gui/wxpython/nviz/mapwindow.py:559
 #, python-format
-msgid "Image is too large, your OpenGL implementation supports maximum texture size %d px."
-msgstr "Bild ist zu groß. Ihr OpenGL unterstützt maximal Texturen der Größe %d px."
+msgid ""
+"Image is too large, your OpenGL implementation supports maximum texture size "
+"%d px."
+msgstr ""
+"Bild ist zu groß. Ihr OpenGL unterstützt maximal Texturen der Größe %d px."
 #: ../gui/wxpython/nviz/mapwindow.py:1057
 msgid "Easting"
@@ -13642,8 +14595,16 @@
 "%s"
 #: ../gui/wxpython/nviz/wxnviz.py:32 ../gui/wxpython/wxplot/profile.py:34
-msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
-msgstr "Dieses erfordert NumPy, das nicht importiert werden konnte. Es ist eventuell nicht installiert (es ist nicht Bestandteil der Standard-Python-Distribution). Gehe zur Numeric Python Website (http://numpy.scipy.org), um den Quellcode oder Binaries zu erhalten."
+msgid ""
+"This module requires the NumPy module, which could not be imported. It "
+"probably is not installed (it's not part of the standard Python "
+"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
+"information on downloading source or binaries."
+msgstr ""
+"Dieses erfordert NumPy, das nicht importiert werden konnte. Es ist eventuell "
+"nicht installiert (es ist nicht Bestandteil der Standard-Python-"
+"Distribution). Gehe zur Numeric Python Website (http://numpy.scipy.org), um "
+"den Quellcode oder Binaries zu erhalten."
 #: ../gui/wxpython/nviz/wxnviz.py:482 ../gui/wxpython/nviz/wxnviz.py:494
 #, python-format
@@ -13656,7 +14617,8 @@
 #: ../gui/wxpython/wxplot/base.py:41
 msgid "Draw transect in map display window to profile"
-msgstr "Zeichne ein Transekt in das Kartenfenster, für das ein Profil erstellt wird"
+msgstr ""
+"Zeichne ein Transekt in das Kartenfenster, für das ein Profil erstellt wird"
 #: ../gui/wxpython/wxplot/base.py:43
 msgid "Plot options"
@@ -13727,7 +14689,8 @@
 #: ../gui/wxpython/wxplot/profile.py:275
 msgid "You must draw a transect to profile in the map display window."
-msgstr "Sie müssen ein Transekt im Kartenfenster zeichnen, um ein Profil zu erhalten."
+msgstr ""
+"Sie müssen ein Transekt im Kartenfenster zeichnen, um ein Profil zu erhalten."
 #: ../gui/wxpython/wxplot/profile.py:276
 msgid "Nothing to profile"
@@ -13926,8 +14889,11 @@
 msgstr "Maßstab"
 #: ../gui/wxpython/wxplot/dialogs.py:1034
-msgid "Automatic axis scaling, custom max and min, or scale matches data range (min)"
-msgstr "Automatische Achsenskalierung, benutzerdefiniertes max und min oder Maßstab nach Wertebereich der Daten (min)"
+msgid ""
+"Automatic axis scaling, custom max and min, or scale matches data range (min)"
+msgstr ""
+"Automatische Achsenskalierung, benutzerdefiniertes max und min oder Maßstab "
+"nach Wertebereich der Daten (min)"
 #: ../gui/wxpython/wxplot/dialogs.py:1039
 msgid "Custom min"
@@ -14201,7 +15167,8 @@
 #: ../gui/wxpython/lmgr/layertree.py:551
 msgid "Set computational region from selected map(s) (ignore NULLs)"
-msgstr "Arbeitsbereich auf Grundlage selektierter Karte setzen (ignoriere NULLwerte)"
+msgstr ""
+"Arbeitsbereich auf Grundlage selektierter Karte setzen (ignoriere NULLwerte)"
 #: ../gui/wxpython/lmgr/layertree.py:584
 #, fuzzy
@@ -14223,8 +15190,12 @@
 #: ../gui/wxpython/lmgr/layertree.py:752
-msgid "Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII characters excluding %(chars)s and space."
-msgstr "Der Name <%(name)s> ist kein gültiger Name für Locations. Bitte verwenden Sie nur ASCII-Zeichen ohne %(chars)s und Leerzeichen."
+msgid ""
+"Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII "
+"characters excluding %(chars)s and space."
+msgstr ""
+"Der Name <%(name)s> ist kein gültiger Name für Locations. Bitte verwenden "
+"Sie nur ASCII-Zeichen ohne %(chars)s und Leerzeichen."
 #: ../gui/wxpython/lmgr/layertree.py:755 ../gui/wxpython/gis_set.py:980
 msgid "Invalid name"
@@ -14247,8 +15218,11 @@
 #: ../gui/wxpython/lmgr/layertree.py:793
-msgid "%s <%s> already exists in the current mapset. Do you want to overwrite it?"
-msgstr "Die Vektorkarte <%s> existiert bereits im aktuellen Mapset. Wollen Sie diese überschreiben?"
+msgid ""
+"%s <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr ""
+"Die Vektorkarte <%s> existiert bereits im aktuellen Mapset. Wollen Sie diese "
+"überschreiben?"
 #: ../gui/wxpython/lmgr/layertree.py:803
@@ -14262,7 +15236,9 @@
 #: ../gui/wxpython/lmgr/layertree.py:827
 msgid "Unable to display histogram of raster map. No map name defined."
-msgstr "Kann das Histogramm der Rasterkarte nicht anzeigen. Kein Kartenname angegeben."
+msgstr ""
+"Kann das Histogramm der Rasterkarte nicht anzeigen. Kein Kartenname "
+"angegeben."
 #: ../gui/wxpython/lmgr/layertree.py:1031
 msgid "Layer group:"
@@ -14286,11 +15262,13 @@
 msgstr "Transparenz:"
 #: ../gui/wxpython/lmgr/menudata.py:42
-msgid "Unable to parse user toolboxes XML files. Default main menu will be loaded."
+msgid ""
+"Unable to parse user toolboxes XML files. Default main menu will be loaded."
 msgstr ""
 #: ../gui/wxpython/lmgr/menudata.py:64
-msgid "Unable to parse user toolboxes XML files. Default module tree will be loaded."
+msgid ""
+"Unable to parse user toolboxes XML files. Default module tree will be loaded."
 msgstr ""
 #: ../gui/wxpython/lmgr/toolbars.py:46
@@ -14387,7 +15365,9 @@
 #: ../gui/wxpython/lmgr/toolbars.py:238
 msgid "Generate command for m.nviz.image based on current state"
-msgstr "Erzeugt den Befehl für m.nviz.image auf der Grundlage der aktuellen Einstellungen"
+msgstr ""
+"Erzeugt den Befehl für m.nviz.image auf der Grundlage der aktuellen "
+"Einstellungen"
 #: ../gui/wxpython/lmgr/toolbars.py:240
 msgid "3D view mode settings"
@@ -14503,7 +15483,8 @@
 #: ../gui/wxpython/lmgr/frame.py:420 ../gui/wxpython/gis_set.py:487
 msgid "Do you want to set the default region extents and resolution now?"
-msgstr "Möchten Sie nun die Ausdehnung und Auflösung der Standardregion eingeben?"
+msgstr ""
+"Möchten Sie nun die Ausdehnung und Auflösung der Standardregion eingeben?"
 #: ../gui/wxpython/lmgr/frame.py:422 ../gui/wxpython/gis_set.py:486
 #, python-format
@@ -14520,7 +15501,8 @@
 #: ../gui/wxpython/lmgr/frame.py:560 ../gui/wxpython/lmgr/frame.py:2124
 msgid "Do you want to store current settings to workspace file?"
-msgstr "Wollen Sie die aktuellen Einstellungen in einer Projektdatei speichern?"
+msgstr ""
+"Wollen Sie die aktuellen Einstellungen in einer Projektdatei speichern?"
 #: ../gui/wxpython/lmgr/frame.py:568
 #, python-format
@@ -14529,8 +15511,12 @@
 #: ../gui/wxpython/lmgr/frame.py:643
 #, python-format
-msgid "Command '%s' not yet implemented in the WxGUI. Try adding it as a command layer instead."
-msgstr "Befehl '%s' wurde noch nicht im wxGUI implementiert. Versuchen Sie es als Befehlsebene hinzuzufügen."
+msgid ""
+"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
+"layer instead."
+msgstr ""
+"Befehl '%s' wurde noch nicht im wxGUI implementiert. Versuchen Sie es als "
+"Befehlsebene hinzuzufügen."
 #: ../gui/wxpython/lmgr/frame.py:794 ../gui/wxpython/lmgr/frame.py:1659
 msgid "Selected map layer is not vector."
@@ -14555,8 +15541,12 @@
 #: ../gui/wxpython/lmgr/frame.py:843
 #, python-format
-msgid "Script <%s> is not executable. Do you want to set the permissions that allows you to run this script (note that you must be the owner of the file)?"
-msgstr "Skript <%s> ist nicht ausführbar. Wollen Sie die Berechtigung der Datei ändern (Sie müssen dafür Eigentümer der Datei sein)?"
+msgid ""
+"Script <%s> is not executable. Do you want to set the permissions that "
+"allows you to run this script (note that you must be the owner of the file)?"
+msgstr ""
+"Skript <%s> ist nicht ausführbar. Wollen Sie die Berechtigung der Datei "
+"ändern (Sie müssen dafür Eigentümer der Datei sein)?"
 #: ../gui/wxpython/lmgr/frame.py:848
 msgid "Set permission?"
@@ -14568,8 +15558,12 @@
 #: ../gui/wxpython/lmgr/frame.py:868
 #, python-format
-msgid "Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this directory to GRASS_ADDON_PATH?"
-msgstr "Verzeichnis '%s' ist nicht im GRASS_ADDON_PATH. Möchten Sie das Verzeichnis zum GRASS_ADDON_PATH hinzufügen?"
+msgid ""
+"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
+"directory to GRASS_ADDON_PATH?"
+msgstr ""
+"Verzeichnis '%s' ist nicht im GRASS_ADDON_PATH. Möchten Sie das Verzeichnis "
+"zum GRASS_ADDON_PATH hinzufügen?"
 #: ../gui/wxpython/lmgr/frame.py:871
 msgid "Update Addons path?"
@@ -14641,8 +15635,12 @@
 msgstr "Platform"
 #: ../gui/wxpython/lmgr/frame.py:1112
-msgid "Current workspace is not empty. Do you want to store current settings to workspace file?"
-msgstr "Aktuelles Projekt ist nicht leer. Wollen Sie die aktuellen Einstellungen in einer Projektdatei speichern?"
+msgid ""
+"Current workspace is not empty. Do you want to store current settings to "
+"workspace file?"
+msgstr ""
+"Aktuelles Projekt ist nicht leer. Wollen Sie die aktuellen Einstellungen in "
+"einer Projektdatei speichern?"
 #: ../gui/wxpython/lmgr/frame.py:1115
 msgid "Create new workspace?"
@@ -14675,11 +15673,13 @@
 #: ../gui/wxpython/lmgr/frame.py:1348 ../gui/wxpython/lmgr/frame.py:1364
 #, python-format
 msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
-msgstr "Projektdatei <%s> existiert bereits. Wollen Sie die Datei überschreiben?"
+msgstr ""
+"Projektdatei <%s> existiert bereits. Wollen Sie die Datei überschreiben?"
 #: ../gui/wxpython/lmgr/frame.py:1388
 msgid "Writing current settings to workspace file failed."
-msgstr "Schreiben der aktuellen Einstellungen in die Workspace-Datei fehlgeschlagen."
+msgstr ""
+"Schreiben der aktuellen Einstellungen in die Workspace-Datei fehlgeschlagen."
 #: ../gui/wxpython/lmgr/frame.py:1435
 msgid "Enter new name:"
@@ -14708,8 +15708,12 @@
 msgstr "Nicht unterstützter Kartenebenentyp <%s>."
 #: ../gui/wxpython/lmgr/frame.py:1977
-msgid "Note that cell values can only be displayed for regions of less than 10,000 cells."
-msgstr "Zellwerte können nur für Regionen mit weniger als 10000 Zellen angezeigt werden."
+msgid ""
+"Note that cell values can only be displayed for regions of less than 10,000 "
+"cells."
+msgstr ""
+"Zellwerte können nur für Regionen mit weniger als 10000 Zellen angezeigt "
+"werden."
 #: ../gui/wxpython/lmgr/frame.py:2059
 #, python-format
@@ -14724,7 +15728,8 @@
 #: ../gui/wxpython/lmgr/frame.py:2062
 msgid "Do you want to remove selected map layer(s) from layer tree?"
-msgstr "Wollen Sie die selektierten Kartenebene(n) aus der Baumstruktur entfernen?"
+msgstr ""
+"Wollen Sie die selektierten Kartenebene(n) aus der Baumstruktur entfernen?"
 #: ../gui/wxpython/lmgr/frame.py:2066
 msgid "Remove map layer"
@@ -14739,8 +15744,14 @@
 msgstr "Keine Kartenebene selektiert. Breche die Operation ab."
 #: ../gui/wxpython/lmgr/frame.py:2172
-msgid "Display resolution is currently not constrained to computational settings. It's suggested to constrain map to region geometry. Do you want to constrain the resolution?"
-msgstr "Die Auflösung des Kartenfensters stimmt nicht mit dem Arbeitsbereich überein. Wir schlagen vor, dass Sie das Kartenfenster auf den Arbeitsbereich beschränken. Wollen Sie die Auflösung beschränken?"
+msgid ""
+"Display resolution is currently not constrained to computational settings. "
+"It's suggested to constrain map to region geometry. Do you want to constrain "
+"the resolution?"
+msgstr ""
+"Die Auflösung des Kartenfensters stimmt nicht mit dem Arbeitsbereich "
+"überein. Wir schlagen vor, dass Sie das Kartenfenster auf den Arbeitsbereich "
+"beschränken. Wollen Sie die Auflösung beschränken?"
 #: ../gui/wxpython/lmgr/frame.py:2181
 msgid "Constrain map to region geometry?"
@@ -14842,7 +15853,9 @@
 msgstr "Vektorkarte <%s> nicht in aktueller Mapset gefunden"
 #: ../gui/wxpython/timeline/frame.py:177
-msgid "Datasets have different temporal type (absolute x relative), which is not allowed."
+msgid ""
+"Datasets have different temporal type (absolute x relative), which is not "
+"allowed."
 msgstr ""
 #: ../gui/wxpython/timeline/frame.py:192
@@ -14992,11 +16005,14 @@
 #: ../gui/wxpython/gcp/manager.py:399
 msgid "You must select a valid location before selecting a mapset"
-msgstr "Sie müssen zuerst eine gültige Location wählen, bevor Sie ein Mapset wählen können."
+msgstr ""
+"Sie müssen zuerst eine gültige Location wählen, bevor Sie ein Mapset wählen "
+"können."
 #: ../gui/wxpython/gcp/manager.py:412
 msgid "You must select a valid location and mapset in order to continue"
-msgstr "Sie müssen zuerst eine gültige Location und Mapset wählen, um fortzufahren."
+msgstr ""
+"Sie müssen zuerst eine gültige Location und Mapset wählen, um fortzufahren."
 #: ../gui/wxpython/gcp/manager.py:431
 msgid "Select image/map group to georectify"
@@ -15024,7 +16040,8 @@
 #: ../gui/wxpython/gcp/manager.py:537
 msgid "You must select a valid image/map group in order to continue"
-msgstr "Sie müssen eine gültige Gruppe von Bildern/Karten wählen, um fortzufahren."
+msgstr ""
+"Sie müssen eine gültige Gruppe von Bildern/Karten wählen, um fortzufahren."
 #: ../gui/wxpython/gcp/manager.py:544
 msgid "You must enter an map name extension in order to continue"
@@ -15032,7 +16049,8 @@
 #: ../gui/wxpython/gcp/manager.py:610
 msgid "Select maps to display for ground control point (GCP) creation"
-msgstr "Wählen Sie eine darzustellende Karte für Erzeugung von Passpunkten (GCP)."
+msgstr ""
+"Wählen Sie eine darzustellende Karte für Erzeugung von Passpunkten (GCP)."
 #: ../gui/wxpython/gcp/manager.py:618 ../gui/wxpython/gcp/manager.py:2601
 msgid "Select source map to display:"
@@ -15116,12 +16134,14 @@
 #: ../gui/wxpython/gcp/manager.py:1382
 msgid ""
-"Insufficient points defined and active (checked) for selected rectification method.\n"
+"Insufficient points defined and active (checked) for selected rectification "
+"method.\n"
 "3+ points needed for 1st order,\n"
 "6+ points for 2nd order, and\n"
 "10+ points for 3rd order."
 msgstr ""
-"Nicht ausreichend Punkte gesetzt und aktiv (checked) für die gewählte Rektifizierungsmethode.\n"
+"Nicht ausreichend Punkte gesetzt und aktiv (checked) für die gewählte "
+"Rektifizierungsmethode.\n"
 "3+ Punkte benötigt für 1. Ordnung,\n"
 "7+ Punkte für 2. Ordnung und\n"
 "10+ Punkte für 3. Ordnung."
@@ -15371,7 +16391,9 @@
 msgstr ""
 #: ../gui/wxpython/iclass/digit.py:57
-msgid "You are trying to create a training area outside the computational region. Please, use g.region to set the appropriate region first."
+msgid ""
+"You are trying to create a training area outside the computational region. "
+"Please, use g.region to set the appropriate region first."
 msgstr ""
 #: ../gui/wxpython/iclass/digit.py:66
@@ -15680,7 +16702,9 @@
 msgstr "Es wurde kein Kartenebene ausgewählt"
 #: ../gui/wxpython/iclass/frame.py:992
-msgid "Due to recent changes in classes, signatures can be outdated and should be recalculated. Do you still want to continue?"
+msgid ""
+"Due to recent changes in classes, signatures can be outdated and should be "
+"recalculated. Do you still want to continue?"
 msgstr ""
 #: ../gui/wxpython/iclass/frame.py:995
@@ -15701,7 +16725,9 @@
 #: ../gui/wxpython/iclass/frame.py:1068
-msgid "Group <%(group)s> does not have enough files (it has %(files)d files). Operation canceled."
+msgid ""
+"Group <%(group)s> does not have enough files (it has %(files)d files). "
+"Operation canceled."
 msgstr "Objekt-ID %d kann nicht gelesen werden. Operation abgebrochen."
 #: ../gui/wxpython/iclass/frame.py:1077
@@ -15800,8 +16826,12 @@
 msgstr "&Location-Assistent"
 #: ../gui/wxpython/gis_set.py:155
-msgid "Start location wizard. After location is created successfully, GRASS session is started."
-msgstr "Starte den Location-Assistenten. Nach der erfolgreichen Einrichtung der Location wird GRASS gestartet."
+msgid ""
+"Start location wizard. After location is created successfully, GRASS session "
+"is started."
+msgstr ""
+"Starte den Location-Assistenten. Nach der erfolgreichen Einrichtung der "
+"Location wird GRASS gestartet."
 #: ../gui/wxpython/gis_set.py:159
 msgid "Rename mapset"
@@ -15829,7 +16859,9 @@
 #: ../gui/wxpython/gis_set.py:226 ../gui/wxpython/gis_set.py:697
 msgid "Unable to set GRASS database. Check your locale settings."
-msgstr "Kann die GRASS Datenbank nicht setzten. Bitte überprüfen Sie ihre lokalen Einstellungen."
+msgstr ""
+"Kann die GRASS Datenbank nicht setzten. Bitte überprüfen Sie ihre lokalen "
+"Einstellungen."
 #: ../gui/wxpython/gis_set.py:244
@@ -15853,8 +16885,12 @@
 #: ../gui/wxpython/gis_set.py:456
-msgid "Do you want to import <%(name)s> to the newly created location? The location's default region will be set from this imported map."
-msgstr "Möchten Sie die Location anhand der Datenquelle <%(name)s> erzeugen? Die Standardregion wird auf Grundlage der importierten Karte erstellt."
+msgid ""
+"Do you want to import <%(name)s> to the newly created location? The "
+"location's default region will be set from this imported map."
+msgstr ""
+"Möchten Sie die Location anhand der Datenquelle <%(name)s> erzeugen? Die "
+"Standardregion wird auf Grundlage der importierten Karte erstellt."
 #: ../gui/wxpython/gis_set.py:461
 #, fuzzy
@@ -15883,7 +16919,8 @@
 "\n"
 "This mapset cannot be renamed."
 msgstr ""
-"Das Mapset <PERMANENT> muss in jeder gültigen GRASS Location vorhanden sein.\n"
+"Das Mapset <PERMANENT> muss in jeder gültigen GRASS Location vorhanden "
+"sein.\n"
 "\n"
 "Dieses Mapset kann nicht umbenannt werden."
@@ -15956,18 +16993,21 @@
 "\n"
 "This mapset cannot be deleted."
 msgstr ""
+"sein.\n"
 "\n"
 "Dieses Mapset kann nicht gelöscht werden."
 #: ../gui/wxpython/gis_set.py:647
 #, python-format
 msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
+"Do you want to continue with deleting mapset <%(mapset)s> from location <"
+"%(location)s>?\n"
 "\n"
 "ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
 msgstr ""
-"Wollen Sie mit dem Löschen des Mapsets <%(mapset)s> der Location <%(location)s> fortfahren?\n"
+"Wollen Sie mit dem Löschen des Mapsets <%(mapset)s> der Location <"
+"%(location)s> fortfahren?\n"
 "\n"
 "ALLE KARTEN in diesem Mapset werden UNWIDERRUFLICH GELÖSCHT!"
@@ -16016,7 +17056,8 @@
 #: ../gui/wxpython/gis_set.py:861
 #, python-format
 msgid ""
-"Mapset <%s> is reserved for direct read access to OGR layers. Please consider to use another name for your mapset.\n"
+"Mapset <%s> is reserved for direct read access to OGR layers. Please "
+"consider to use another name for your mapset.\n"
 "\n"
 "Are you really sure that you want to create this mapset?"
 msgstr ""
@@ -16039,14 +17080,16 @@
 "\n"
 "Concurrent use not allowed.\n"
 "\n"
-"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
+"Do you want to try to remove .gislock (note that you need permission for "
+"this operation) and continue?"
 msgstr ""
 "GRASS läuft bereits in dem gewählten Mapset <%(mapset)s>\n"
 "(datei %(lock)s gefunden).\n"
 "\n"
 "Gleichzeitiger Betrieb ist nicht erlaubt..\n"
 "\n"
-"Wollen Sie versuchen .gislock zu löschen (Sie brauchen entsprechende Rechte für diese Operation) und Fortzufahren?"
+"Wollen Sie versuchen .gislock zu löschen (Sie brauchen entsprechende Rechte "
+"für diese Operation) und Fortzufahren?"
 #: ../gui/wxpython/gis_set.py:906 ../gui/wxpython/gis_set.py:918
 msgid "Lock file found"
@@ -16056,11 +17099,14 @@
 msgid ""
 "ARE YOU REALLY SURE?\n"
 "\n"
-"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
+"If you really are running another GRASS session doing this could corrupt "
+"your data. Have another look in the processor manager just to be sure..."
 msgstr ""
 "SIND SIE WIRKLICH SICHER?\n"
 "\n"
-"Wenn Sie schon eine andere GRASS-Sitzung geöffnet haben, könnte das Weitermachen hier Ihre Daten beschädigen. Überprüfen Sie sicherheitshalber die Prozesstabelle..."
+"Wenn Sie schon eine andere GRASS-Sitzung geöffnet haben, könnte das "
+"Weitermachen hier Ihre Daten beschädigen. Überprüfen Sie sicherheitshalber "
+"die Prozesstabelle..."
 #: ../gui/wxpython/gis_set.py:929
 #, python-format
@@ -16075,16 +17121,26 @@
 #: ../gui/wxpython/gis_set.py:977
 #, python-format
-msgid "Name <%(name)s> is not a valid name for location or mapset. Please use only ASCII characters excluding %(chars)s and space."
-msgstr "Der Name <%(name)s> ist kein gültiger Name für Locations oder Mapsets. Bitte verwenden Sie nur ASCII-Zeichen ohne %(chars)s und Leerzeichen."
+msgid ""
+"Name <%(name)s> is not a valid name for location or mapset. Please use only "
+"ASCII characters excluding %(chars)s and space."
+msgstr ""
+"Der Name <%(name)s> ist kein gültiger Name für Locations oder Mapsets. Bitte "
+"verwenden Sie nur ASCII-Zeichen ohne %(chars)s und Leerzeichen."
 #: ../gui/wxpython/gis_set.py:1045
 msgid "Starting GRASS for the first time"
 msgstr "Starte GRASS zum ersten Mal"
 #: ../gui/wxpython/gis_set.py:1046
-msgid "GRASS needs a directory in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory."
-msgstr "GRASS braucht eine Verzeichnis, in dem es seine Daten speichern kann. Erstellen Sie jetzt eins, wenn Sie es noch nicht getan haben. Eine beliebte Wahl ist \"grassdata\" im eigenen Heimatverzeichnis."
+msgid ""
+"GRASS needs a directory in which to store its data. Create one now if you "
+"have not already done so. A popular choice is \"grassdata\", located in your "
+"home directory."
+msgstr ""
+"GRASS braucht eine Verzeichnis, in dem es seine Daten speichern kann. "
+"Erstellen Sie jetzt eins, wenn Sie es noch nicht getan haben. Eine beliebte "
+"Wahl ist \"grassdata\" im eigenen Heimatverzeichnis."
 #: ../gui/wxpython/mapswipe/toolbars.py:28
 msgid "Quit Map Swipe"
@@ -16209,7 +17265,9 @@
 #: ../gui/wxpython/vdigit/toolbars.py:128
 #: ../gui/wxpython/vdigit/toolbars.py:152
 msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
-msgstr "Links: neuer Punkt; Ctrl+Links: letzten Punkt zurücknehmen; Rechts: Linie beenden"
+msgstr ""
+"Links: neuer Punkt; Ctrl+Links: letzten Punkt zurücknehmen; Rechts: Linie "
+"beenden"
 #: ../gui/wxpython/vdigit/toolbars.py:127
 msgid "Digitize new boundary"
@@ -16222,7 +17280,9 @@
 #: ../gui/wxpython/vdigit/toolbars.py:133
 #, fuzzy
 msgid "Digitize new area (boundary without category)"
-msgstr "Neue Fläche digitalisieren (Flächengrenzen ohne Kategorie und einem Zentroid mit Kategorie)"
+msgstr ""
+"Neue Fläche digitalisieren (Flächengrenzen ohne Kategorie und einem Zentroid "
+"mit Kategorie)"
 #: ../gui/wxpython/vdigit/toolbars.py:136
 #, fuzzy
@@ -16388,9 +17448,14 @@
 #: ../gui/wxpython/vdigit/toolbars.py:829
 msgid ""
-"Topology for vector map <%s> is not available. Topology is required by digitizer.\n"
-"Do you want to rebuild topology (takes some time) and open the vector map for editing?"
-msgstr "Die Topologie der Vektorkarte <%s> ist nicht vorhanden. Topologie ist für den Digitizer erforderlich. Wollen Sie die Topologie erneuern (benötigt einige Zeit) und die Vektorkarte dann zum Bearbeiten öffnen?"
+"Topology for vector map <%s> is not available. Topology is required by "
+"digitizer.\n"
+"Do you want to rebuild topology (takes some time) and open the vector map "
+"for editing?"
+msgstr ""
+"Die Topologie der Vektorkarte <%s> ist nicht vorhanden. Topologie ist für "
+"den Digitizer erforderlich. Wollen Sie die Topologie erneuern (benötigt "
+"einige Zeit) und die Vektorkarte dann zum Bearbeiten öffnen?"
 #: ../gui/wxpython/vdigit/toolbars.py:833
 #, fuzzy
@@ -16404,7 +17469,8 @@
 #: ../gui/wxpython/vdigit/toolbars.py:887
-msgid "Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
+msgid ""
+"Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
 msgstr "Nicht unterstützter Objekttyp %d. Operation abgebrochen."
 #: ../gui/wxpython/vdigit/toolbars.py:948
@@ -16419,7 +17485,8 @@
 #: ../gui/wxpython/vdigit/toolbars.py:957
 #, python-format
 msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
-msgstr "Bitte warten Sie, ich erneuere die Topologie schließe die Vektorkarte <%s>..."
+msgstr ""
+"Bitte warten Sie, ich erneuere die Topologie schließe die Vektorkarte <%s>..."
 #: ../gui/wxpython/vdigit/toolbars.py:971
 #, python-format
@@ -16443,7 +17510,9 @@
 #: ../gui/wxpython/vdigit/g.gui.vdigit.py:100
-msgid "Vector map <%s> not found in current mapset. New vector map can be created by providing '-c' flag."
+msgid ""
+"Vector map <%s> not found in current mapset. New vector map can be created "
+"by providing '-c' flag."
 #: ../gui/wxpython/vdigit/g.gui.vdigit.py:103
@@ -16523,7 +17592,9 @@
 #: ../gui/wxpython/vdigit/preferences.py:60
 msgid "Close dialog and save changes to user settings file"
-msgstr "Beende den Dialog und speichere die Änderungen in Datei mit Benutzereinstellungen"
+msgstr ""
+"Beende den Dialog und speichere die Änderungen in Datei mit "
+"Benutzereinstellungen"
 #: ../gui/wxpython/vdigit/preferences.py:152
 msgid "Snapping"
@@ -16566,8 +17637,11 @@
 msgstr "Selektiere nur Objekte innerhalb der Auswahlbox"
 #: ../gui/wxpython/vdigit/preferences.py:224
-msgid "By default are selected all features overlapping selection bounding box "
-msgstr "Standardmäßig sind alle Objekte selektiert die von der Auswahlbox geschnitten werden "
+msgid ""
+"By default are selected all features overlapping selection bounding box "
+msgstr ""
+"Standardmäßig sind alle Objekte selektiert die von der Auswahlbox "
+"geschnitten werden "
 #: ../gui/wxpython/vdigit/preferences.py:227
 msgid "Check for duplicates"
@@ -16687,8 +17761,12 @@
 msgstr "Umfang"
 #: ../gui/wxpython/vdigit/preferences.py:503
-msgid "Note: These settings are stored in the workspace not in the vector digitizer preferences."
-msgstr "Beachte: Diese Einstellungen werden im Workspace und nicht in den Einstellungen für die Vektordigitalisierung gespeichert."
+msgid ""
+"Note: These settings are stored in the workspace not in the vector digitizer "
+"preferences."
+msgstr ""
+"Beachte: Diese Einstellungen werden im Workspace und nicht in den "
+"Einstellungen für die Vektordigitalisierung gespeichert."
 #: ../gui/wxpython/vdigit/preferences.py:532
 msgid "Digitize new line segment"
@@ -16757,7 +17835,9 @@
 #: ../gui/wxpython/vdigit/preferences.py:618
 #, python-format
 msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
-msgstr "Fangtoleranz ist %(value).1f %(units)s (basiert auf Auflösung des Arbeitsbereichs)"
+msgstr ""
+"Fangtoleranz ist %(value).1f %(units)s (basiert auf Auflösung des "
+"Arbeitsbereichs)"
 #: ../gui/wxpython/vdigit/preferences.py:674
 #, python-format
@@ -16783,8 +17863,14 @@
 #: ../gui/wxpython/vdigit/wxdisplay.py:940
 #, python-format
-msgid "Topology for vector map <%s> is not available. Topology is required by digitizer. Do you want to rebuild topology (takes some time) and open the vector map for editing?"
+msgid ""
+"digitizer. Do you want to rebuild topology (takes some time) and open the "
+"vector map for editing?"
+msgstr ""
 #: ../gui/wxpython/vdigit/wxdisplay.py:944
 msgid "Topology missing"
@@ -16828,8 +17914,11 @@
 #: ../gui/wxpython/vdigit/wxdigit.py:101
 #, python-format
-msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
-msgstr "Kann Datenbank <%(db)s> nicht mit Treiber <%(driver)s> öffnen. Operation abgebrochen."
+msgid ""
+"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgstr ""
+"Kann Datenbank <%(db)s> nicht mit Treiber <%(driver)s> öffnen. Operation "
+"abgebrochen."
 #: ../gui/wxpython/vdigit/wxdigit.py:109
 #, python-format
@@ -16930,7 +18019,8 @@
 #: ../gui/wxpython/vnet/vnet_core.py:210
 #, python-format
 msgid ""
-"Temporary map '%s' with result was changed outside vector network analysis tool.\n"
+"Temporary map '%s' with result was changed outside vector network analysis "
+"tool.\n"
 "Showed result may not correspond original analysis result."
 msgstr ""
@@ -16979,7 +18069,8 @@
 #: ../gui/wxpython/vnet/vnet_core.py:894
 #, python-format
 msgid ""
-"Input map '%s' for analysis was changed outside vector network analysis tool.\n"
+"Input map '%s' for analysis was changed outside vector network analysis "
+"tool.\n"
 "Topology column may not correspond to changed situation."
 msgstr ""
@@ -17217,7 +18308,9 @@
 #: ../gui/wxpython/vnet/vnet_data.py:183
-msgid "Chosen column '%s' does not exist in attribute table of layer '%s' of vector map '%s'.\n"
+msgid ""
+"Chosen column '%s' does not exist in attribute table of layer '%s' of vector "
+"map '%s'.\n"
 msgstr "Entfernt eine existierende Attributtabelle einer Vektorkarte."
 #: ../gui/wxpython/vnet/vnet_data.py:237
@@ -17602,800 +18695,949 @@
 msgstr "Kann nicht setzen"
 #, fuzzy
-msgid "Function not supported yet"
-msgstr "Funktion  noch nicht implementiert"
+#~ msgid "Function not supported yet"
+#~ msgstr "Funktion  noch nicht implementiert"
 #, fuzzy
-msgid "Compute category quantiles using two passes."
-msgstr "Berechne Quantile in zwei Durchgᅵngen"
+#~ msgid "Vector map %s already exists. "
+#~ msgstr "Die Datei existiert bereits."
 #, fuzzy
-msgid "Vector map %s already exists. "
-msgstr "Die Datei existiert bereits."
+#~ msgid "Temporary map %s  already exists.\n"
 #, fuzzy
-msgid "Temporary map %s  already exists.\n"
+#~ msgid "Name for output raster layer:"
+#~ msgstr "Name für Ausgaberasterkarte:"
 #, fuzzy
-msgid "Name for output raster layer:"
-msgstr "Name für Ausgaberasterkarte:"
+#~ msgid "Overwrite existing layer"
+#~ msgstr "überschreibe existierende Datei"
 #, fuzzy
-msgid "Overwrite existing layer"
-msgstr "überschreibe existierende Datei"
+#~ msgid "SQL Spatial Query"
+#~ msgstr "SQL Abfrage"
 #, fuzzy
-msgid "SQL Spatial Query"
-msgstr "SQL Abfrage"
+#~ msgid "thematic area (choropleth) map"
+#~ msgstr "Zeigt thematische Vektorkarten an."
-#, fuzzy
-msgid "thematic area (choropleth) map"
-msgstr "Zeigt thematische Vektorkarten an."
+#~ msgid "wms"
+#~ msgstr "wms"
-msgid "wms"
-msgstr "wms"
 #, fuzzy
-msgid "Exporting images, please wait..."
-msgstr "Rektifiziere Bilder, bitte warten"
+#~ msgid "Exporting images, please wait..."
+#~ msgstr "Rektifiziere Bilder, bitte warten"
 #, fuzzy
-msgid "Select raster maps for animation"
-msgstr "Wähle Rasterkarte 3 (optional):"
+#~ msgid "Select raster maps for animation"
+#~ msgstr "Wähle Rasterkarte 3 (optional):"
 #, fuzzy
-msgid "No data selected."
-msgstr "Keine Karte ausgewählt!"
+#~ msgid "No data selected."
+#~ msgstr "Keine Karte ausgewählt!"
-msgid "PostGIS (PG)"
-msgstr "PostGIS (PG)"
+#~ msgid "PostGIS (PG)"
+#~ msgstr "PostGIS (PG)"
 #, fuzzy
-msgid "Exports a vector map layer to PostGIS feature table."
-msgstr "Exportiert eine GRASS Vektorkarte nach SVG."
+#~ msgid "Exports a vector map layer to PostGIS feature table."
+#~ msgstr "Exportiert eine GRASS Vektorkarte nach SVG."
 #, fuzzy
-msgid "Uninstall extension"
-msgstr "Aktualisiert installierte Erweiterungen"
+#~ msgid "Uninstall extension"
+#~ msgstr "Aktualisiert installierte Erweiterungen"
 #, fuzzy
-msgid "Performs cubic or linear spline interpolation with Tykhonov regularization."
-msgstr "Bikubische oder bilineare Splineinterpolation mit Tykhonov Regularisierung."
+#~ msgid ""
+#~ "Performs cubic or linear spline interpolation with Tykhonov "
+#~ "regularization."
+#~ msgstr ""
+#~ "Bikubische oder bilineare Splineinterpolation mit Tykhonov "
+#~ "Regularisierung."
 #, fuzzy
-msgid "Run analysis"
-msgstr "Reliefanalyse"
+#~ msgid "Run analysis"
+#~ msgstr "Reliefanalyse"
-msgid "Delete area(s)"
-msgstr "Löschen Flächen"
+#~ msgid "Delete area(s)"
+#~ msgstr "Löschen Flächen"
 #, fuzzy
-msgid "Raster maps in selected group:"
-msgstr "Layerauswahl"
+#~ msgid "Raster maps in selected group:"
+#~ msgstr "Layerauswahl"
 #, fuzzy
-msgid "No data"
-msgstr "Importiere Daten"
+#~ msgid "No data"
+#~ msgstr "Importiere Daten"
 #, fuzzy
-msgid "Vector map <%s>: no attribute table found"
-msgstr "Vektorkarte <%s> nicht gefunden"
+#~ msgid "Vector map <%s>: no attribute table found"
+#~ msgstr "Vektorkarte <%s> nicht gefunden"
 #, fuzzy
-msgid "Analysis can not be done."
-msgstr "Analyse konnte nicht"
+#~ msgid "Analysis can not be done."
+#~ msgstr "Analyse konnte nicht"
 #, fuzzy
-msgid "bilinear"
-msgstr "Linie"
+#~ msgid "bilinear"
+#~ msgstr "Linie"
 #, fuzzy
-msgid "cubicspline"
-msgstr "Rhumblinie"
+#~ msgid "cubicspline"
+#~ msgstr "Rhumblinie"
 #, fuzzy
-msgid "Import waypoints, routes, and tracks from a GPS receiver or many common GPS file formats."
-msgstr "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Empfᅵnger oder direkt GPS Daten in eine Verktorkarte."
+#~ msgid ""
+#~ "Import waypoints, routes, and tracks from a GPS receiver or many common "
+#~ "GPS file formats."
+#~ msgstr ""
+#~ "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Empfᅵnger oder "
+#~ "direkt GPS Daten in eine Verktorkarte."
 #, fuzzy
-msgid "Exports a vector map to a GRASS ASCII vector representation."
-msgstr "Konvertiere eine binᅵre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
+#~ msgid "Exports a vector map to a GRASS ASCII vector representation."
+#~ msgstr ""
+#~ "Konvertiere eine binᅵre GRASS-Vektordatei in eine GRASS ASCII-"
+#~ "Vektorkarte."
 #, fuzzy
-msgid "Changes/reports current mapset."
-msgstr "Wechsle aktuelles Mapset."
+#~ msgid "Changes/reports current mapset."
+#~ msgstr "Wechsle aktuelles Mapset."
 #, fuzzy
-msgid "Create color rules"
-msgstr "Geben Sie Farbregeln ein"
+#~ msgid "Create color rules"
+#~ msgstr "Geben Sie Farbregeln ein"
-msgid "Neighborhood analysis tool for vector point maps."
-msgstr "Nachbarschaftsanalyse-Werkzeug fᅵr Vektorpunktkarten."
+#~ msgid "Neighborhood analysis tool for vector point maps."
+#~ msgstr "Nachbarschaftsanalyse-Werkzeug fᅵr Vektorpunktkarten."
 #, fuzzy
-msgid "Generates rate of spread raster map layers."
-msgstr "Erzeugt Flᅵchenstatistiken fᅵr Rasterkarten."
+#~ msgid "Generates rate of spread raster map layers."
+#~ msgstr "Erzeugt Flᅵchenstatistiken fᅵr Rasterkarten."
 #, fuzzy
-msgid "Generates a raster density map from vector points map."
-msgstr "Erzeugt zufᅵllige 2D/3D GRASS Vektor-Punktkarten."
+#~ msgid "Generates a raster density map from vector points map."
+#~ msgstr "Erzeugt zufᅵllige 2D/3D GRASS Vektor-Punktkarten."
 #, fuzzy
-msgid "Extrudes flat vector features to 3D with defined height."
-msgstr "Presst flache Vektorobjekte in eine 3D-Form mit definierter Hᅵhe."
+#~ msgid "Extrudes flat vector features to 3D with defined height."
+#~ msgstr "Presst flache Vektorobjekte in eine 3D-Form mit definierter Hᅵhe."
 #, fuzzy
-msgid "Creates topology for vector map."
-msgstr "Erzeugt Topologie fᅵr GRASS Vektorkarten."
+#~ msgid "Creates topology for vector map."
+#~ msgstr "Erzeugt Topologie fᅵr GRASS Vektorkarten."
 #, fuzzy
-msgid "Removes outlier points from a LIDAR data set."
-msgstr "Erkennt Kanten von Objekten aus einem LIDAR-Datensatz."
+#~ msgid "Removes outlier points from a LIDAR data set."
+#~ msgstr "Erkennt Kanten von Objekten aus einem LIDAR-Datensatz."
 #, fuzzy
-msgid "Allocate subnets for nearest centers (direction from center)."
-msgstr "Allokiere Teilnetze für das nächste Zentrum (Richtung vom Zentrum)."
+#~ msgid "Allocate subnets for nearest centers (direction from center)."
+#~ msgstr "Allokiere Teilnetze für das nächste Zentrum (Richtung vom Zentrum)."
 #, fuzzy
-msgid "Calculates univariate statistics for attribute."
-msgstr "Univariate Statistik fᅵr Punktattribute"
+#~ msgid "Calculates univariate statistics for attribute."
+#~ msgstr "Univariate Statistik fᅵr Punktattribute"
 #, fuzzy
-msgid "Creates a sunshine hours map."
+#~ msgid "Creates a sunshine hours map."
 #, fuzzy
-msgid "Selects data from attribute table."
-msgstr "Selektiert Daten einer Tabelle."
+#~ msgid "Selects data from attribute table."
+#~ msgstr "Selektiert Daten einer Tabelle."
 #, fuzzy
-msgid "Optional Location Title"
-msgstr "Location-Titel"
+#~ msgid "Optional Location Title"
+#~ msgstr "Location-Titel"
 #, fuzzy
-msgid "WKT or PRJ file:"
-msgstr "WKT-Datei:"
+#~ msgid "WKT or PRJ file:"
+#~ msgstr "WKT-Datei:"
 #, fuzzy
-msgid "Unable to open file '%(file)s' for writting. Details: %(det)s"
-msgstr "Kann die Datei <%s> nicht zum Schreiben öffnen."
+#~ msgid "Unable to open file '%(file)s' for writting. Details: %(det)s"
+#~ msgstr "Kann die Datei <%s> nicht zum Schreiben öffnen."
 #, fuzzy
-msgid "SVN Revision:"
-msgstr "GIS Library Revision:"
+#~ msgid "SVN Revision:"
+#~ msgstr "GIS Library Revision:"
-msgid "GIS Library Revision:"
+#~ msgid "GIS Library Revision:"
-msgid "Download and import data from WMS servers."
-msgstr "Lädt Daten von einem WMS Server herunter und importiert sie."
+#~ msgid "Download and import data from WMS servers."
+#~ msgstr "Lädt Daten von einem WMS Server herunter und importiert sie."
-msgid "Install extension from add-ons"
-msgstr "Installiere Erweiterungen von Addons"
+#~ msgid "Install extension from add-ons"
+#~ msgstr "Installiere Erweiterungen von Addons"
 #, fuzzy
-msgid "Sharpen image by merging multispectral and high-res panchromatic channels"
-msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
+#~ msgid ""
+#~ "Sharpen image by merging multispectral and high-res panchromatic channels"
+#~ msgstr ""
+#~ "Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
+#~ "panchromatischer Kanäle."
 #, fuzzy
-msgid ""
-"Failed to add attribute table. Details:\n"
-"%s"
-msgstr "müssen Sie Attributtabellen kopieren"
+#~ msgid ""
+#~ "Failed to add attribute table. Details:\n"
+#~ "%s"
+#~ msgstr "müssen Sie Attributtabellen kopieren"
-msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>.You will need to change the default GIS data directory in the GRASS startup screen."
-msgstr "Die Location <%(loc)s> wird im GIS-Verzeichnis <%(dir)s> angelegt. Sie müssen das Standard GIS-Verzeichnis auf dem GRASS Startbildschrim ändern."
+#~ msgid ""
+#~ "Location <%(loc)s> will be created in GIS data directory <%(dir)s>.You "
+#~ "will need to change the default GIS data directory in the GRASS startup "
+#~ "screen."
+#~ msgstr ""
+#~ "Die Location <%(loc)s> wird im GIS-Verzeichnis <%(dir)s> angelegt. Sie "
+#~ "müssen das Standard GIS-Verzeichnis auf dem GRASS Startbildschrim ändern."
-msgid "File not found."
-msgstr "Datei nicht gefunden"
+#~ msgid "File not found."
+#~ msgstr "Datei nicht gefunden"
 #, fuzzy
-msgid "Plot text settings saved to file '%s'."
-msgstr "Profil-Einstellungen in der Datei '%s' gespeichert."
+#~ msgid "Plot text settings saved to file '%s'."
+#~ msgstr "Profil-Einstellungen in der Datei '%s' gespeichert."
 #, fuzzy
-msgid "Enable zooming by mouse wheel"
-msgstr "Aktiviere Auto-Zooming auf selektierte Kartenlayer"
+#~ msgid "Enable zooming by mouse wheel"
+#~ msgstr "Aktiviere Auto-Zooming auf selektierte Kartenlayer"
-msgid ""
-"Statistics for %s\n"
-"\n"
-"%s\n"
-msgstr ""
-"Statistiken für  %s\n"
-"\n"
-"%s\n"
+#~ msgid ""
+#~ "Statistics for %s\n"
+#~ "\n"
+#~ "%s\n"
+#~ msgstr ""
+#~ "Statistiken für  %s\n"
+#~ "\n"
+#~ "%s\n"
 #, fuzzy
-msgid "RStream Utility is not available. You can install it by %s"
-msgstr "Hardcopy Map Output Utility ist nicht verfügbar. Dies kann mit Hilfe von %s installiert werden"
+#~ msgid "RStream Utility is not available. You can install it by %s"
+#~ msgstr ""
+#~ "Hardcopy Map Output Utility ist nicht verfügbar. Dies kann mit Hilfe von "
+#~ "%s installiert werden"
 #, fuzzy
-msgid "Experimental WMS support for wxGUI not available. You can install it by '%s'"
+#~ msgid ""
+#~ "Experimental WMS support for wxGUI not available. You can install it by "
+#~ "'%s'"
+#~ msgstr ""
 #, fuzzy
-msgid "Start new map display (experimental WMS support)"
-msgstr "Neue Anzeige öffnen"
+#~ msgid "Start new map display (experimental WMS support)"
+#~ msgstr "Neue Anzeige öffnen"
 #, fuzzy
-msgid "Report or upload vector features to DB"
-msgstr "Transformiert 2D Vektorfeature nach 3D."
+#~ msgid "Report or upload vector features to DB"
+#~ msgstr "Transformiert 2D Vektorfeature nach 3D."
-msgid "Interpolates point data to a RASTER3D grid volume using regularized spline with tension (RST) algorithm."
-msgstr "Interpoliert Punkte zu einem RASTER3D Grid Volumen unter Verwendung des regularized spline with tension (RST) Algorithmus."
+#~ msgid ""
+#~ "Interpolates point data to a RASTER3D grid volume using regularized "
+#~ "spline with tension (RST) algorithm."
+#~ msgstr ""
+#~ "Interpoliert Punkte zu einem RASTER3D Grid Volumen unter Verwendung des "
+#~ "regularized spline with tension (RST) Algorithmus."
 #, fuzzy
-msgid "GSoC testing"
-msgstr "Beende das Editieren"
+#~ msgid "GSoC testing"
+#~ msgstr "Beende das Editieren"
-msgid "WMS"
-msgstr "WMS"
+#~ msgid "WMS"
+#~ msgstr "WMS"
 #, fuzzy
-msgid "Calculates points in polygons and univariate statistics from points based on vector polygon map and uploads statistics to new attribute columns."
-msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte fᅵr Polygone und fᅵgt die Ergebnisse als neue Spalte der Attributtabelle an."
+#~ msgid ""
+#~ "Calculates points in polygons and univariate statistics from points based "
+#~ "on vector polygon map and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Berechnet Kennzahlen univariater Statistik einer Rasterkarte fᅵr "
+#~ "Polygone und fᅵgt die Ergebnisse als neue Spalte der Attributtabelle an."
 #, fuzzy
-msgid "On display"
-msgstr "Fenster"
+#~ msgid "On display"
+#~ msgstr "Fenster"
 #, fuzzy
-msgid "GRASS GIS Hardcopy Map Output Utility"
-msgstr "Werkzeug zur Erstellung von Ausgabekarten im PostScript-Format."
+#~ msgid "GRASS GIS Hardcopy Map Output Utility"
+#~ msgstr "Werkzeug zur Erstellung von Ausgabekarten im PostScript-Format."
 #, fuzzy
-msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
-msgstr "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
+#~ msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
+#~ msgstr ""
+#~ "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei."
 #, fuzzy
-msgid "Exports the color table associated with a raster3d map layer."
-msgstr "Exportiert die einer Rasterkarte zugeordnetenn Farbtabelle."
+#~ msgid "Exports the color table associated with a raster3d map layer."
+#~ msgstr "Exportiert die einer Rasterkarte zugeordnetenn Farbtabelle."
 #, fuzzy
-msgid "Vector querying is not implemented yet"
+#~ msgid "Vector querying is not implemented yet"
-msgid "(z)"
-msgstr "(z)"
+#~ msgid "(z)"
+#~ msgstr "(z)"
 #, fuzzy
-msgid "Direct OGR"
-msgstr "Richtung"
+#~ msgid "Direct OGR"
+#~ msgstr "Richtung"
 #, fuzzy
-msgid "Generates stream channels"
-msgstr "Abflusslinien graben"
+#~ msgid "Generates stream channels"
+#~ msgstr "Abflusslinien graben"
-msgid "Error saving preferences"
-msgstr "Fehler beim Speichern der Einstellungen"
+#~ msgid "Error saving preferences"
+#~ msgstr "Fehler beim Speichern der Einstellungen"
 #, fuzzy
-msgid "Imports Mapgen or Matlab vector maps into GRASS."
-msgstr "Importiere Mapgen oder Matlab Vektordaten in GRASS."
+#~ msgid "Imports Mapgen or Matlab vector maps into GRASS."
+#~ msgstr "Importiere Mapgen oder Matlab Vektordaten in GRASS."
-msgid "ASCII x,y,z export"
-msgstr "ASCII x,y,z Export"
+#~ msgid "ASCII x,y,z export"
+#~ msgstr "ASCII x,y,z Export"
-msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
-msgstr "Konvertieren aller alten GRASS < Ver5.7 Vektorkarten des aktuellen Mapsets in aktuelles Format"
+#~ msgid ""
+#~ "Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
+#~ "format"
+#~ msgstr ""
+#~ "Konvertieren aller alten GRASS < Ver5.7 Vektorkarten des aktuellen "
+#~ "Mapsets in aktuelles Format"
-msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
-msgstr "Konvertiert eine 3D-Rasterkarte (RASTER3D) in das VTK-ASCII-Format."
+#~ msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
+#~ msgstr "Konvertiert eine 3D-Rasterkarte (RASTER3D) in das VTK-ASCII-Format."
-msgid "Install new extension from GRASS AddOns SVN repository."
-msgstr "Installiere neue Erweiterungen aus dem GRASS AddOns SVN-Archiv."
+#~ msgid "Install new extension from GRASS AddOns SVN repository."
+#~ msgstr "Installiere neue Erweiterungen aus dem GRASS AddOns SVN-Archiv."
-msgid ""
-"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
-"You can disable this message from digitization settings. Or you can create and link attribute table to the vector map using Attribute Table Manager."
-msgstr ""
-"Es ist keine Attributtabelle mit der Vektorkarte <%(vector)s> verlinkt. %(msg)s\n"
-" Sie können diese Meldung in den Digitalisierungseinstellungen ausschalten. Oder Sie können mit dem Attributtabellenmanager eine Attributtabelle erzeugen und mit der Vektorkarte verknüpfen "
+#~ msgid ""
+#~ "No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
+#~ "You can disable this message from digitization settings. Or you can "
+#~ "create and link attribute table to the vector map using Attribute Table "
+#~ "Manager."
+#~ msgstr ""
+#~ "Es ist keine Attributtabelle mit der Vektorkarte <%(vector)s> verlinkt. "
+#~ "%(msg)s\n"
+#~ " Sie können diese Meldung in den Digitalisierungseinstellungen "
+#~ "ausschalten. Oder Sie können mit dem Attributtabellenmanager eine "
+#~ "Attributtabelle erzeugen und mit der Vektorkarte verknüpfen "
-msgid "Fetch full info including description and keywords (takes time)"
-msgstr "Abruf der gesamten Information inklusive Beschreibung und Schlüsselworte (etwas Geduld)"
+#~ msgid "Fetch full info including description and keywords (takes time)"
+#~ msgstr ""
+#~ "Abruf der gesamten Information inklusive Beschreibung und Schlüsselworte "
+#~ "(etwas Geduld)"
-msgid "&Abort"
-msgstr "&Breche ab"
+#~ msgid "&Abort"
+#~ msgstr "&Breche ab"
-msgid "Creates a mask for limiting raster operation."
-msgstr "Erzeuge eine Maske (MASK) um Rasteroperationen zu begrenzen."
+#~ msgid "Creates a mask for limiting raster operation."
+#~ msgstr "Erzeuge eine Maske (MASK) um Rasteroperationen zu begrenzen."
-msgid "Matlab array and MapGen import"
-msgstr "Matlab Array- und MapGen-Import"
+#~ msgid "Matlab array and MapGen import"
+#~ msgstr "Matlab Array- und MapGen-Import"
-msgid "Raster File Series to MPEG Conversion Program."
-msgstr "Programm zum Konvertieren von Serien von Rasterkarten zu einem MPEG-Film."
+#~ msgid "Raster File Series to MPEG Conversion Program."
+#~ msgstr ""
+#~ "Programm zum Konvertieren von Serien von Rasterkarten zu einem MPEG-Film."
 #, fuzzy
-msgid "Converts to one of the supported OGR vector formats."
-msgstr "Konvertiert in eines von OGR unterstützten Formaten"
+#~ msgid "Converts to one of the supported OGR vector formats."
+#~ msgstr "Konvertiert in eines von OGR unterstützten Formaten"
 #, fuzzy
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
-msgstr "Filtert und erzeugt aus einem Höhenmodell sowohl eine depressionslose Höhenkarte  als auch eine Karte mit Fließrichtungen."
+#~ msgid ""
+#~ "Filters and generates a depressionless elevation map and a flow direction "
+#~ "map from a given elevation layer."
+#~ msgstr ""
+#~ "Filtert und erzeugt aus einem Höhenmodell sowohl eine depressionslose "
+#~ "Höhenkarte  als auch eine Karte mit Fließrichtungen."
-msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
-msgstr "Berechnung von Abflusslinien, Länge der Fliesswege und Flussdichte aus einem digitalen Höhenmodell (DHM)"
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)"
+#~ msgstr ""
+#~ "Berechnung von Abflusslinien, Länge der Fliesswege und Flussdichte aus "
+#~ "einem digitalen Höhenmodell (DHM)"
-msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
-msgstr "Overland flow hydrologic-Simulation mittels path sampling-Methode (SIMWE)"
+#~ msgid ""
+#~ "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+#~ msgstr ""
+#~ "Overland flow hydrologic-Simulation mittels path sampling-Methode (SIMWE)"
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)"
-msgstr "Sedimenttransport and Erosions-/Deposition-Simulation durch die path sampling-Methode (SIMWE)"
+#~ msgid ""
+#~ "Sediment transport and erosion/deposition simulation using path sampling "
+#~ "method (SIMWE)"
+#~ msgstr ""
+#~ "Sedimenttransport and Erosions-/Deposition-Simulation durch die path "
+#~ "sampling-Methode (SIMWE)"
-msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
-msgstr "Erstellt Topographischen Index [ln(a/tan(beta))] auf Basis einer Höhenkarte."
+#~ msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+#~ msgstr ""
+#~ "Erstellt Topographischen Index [ln(a/tan(beta))] auf Basis einer "
+#~ "Höhenkarte."
-msgid "Reclassify raster map using rules"
-msgstr "Reklassifiziere Rasterkarte mittels Regeln"
+#~ msgid "Reclassify raster map using rules"
+#~ msgstr "Reklassifiziere Rasterkarte mittels Regeln"
-msgid "Manage add-ons extensions"
-msgstr "Verwalte Add-ons-Erweiterungen"
+#~ msgid "Manage add-ons extensions"
+#~ msgstr "Verwalte Add-ons-Erweiterungen"
-msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr ""
+#~ "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-"
+#~ "Rasterkarte. "
-msgid "import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable and 1 time step)"
-msgstr "Importiere 3-dimensionale Vis5D Daten (z.B. die v5d-Daten mit einer Variablen und einem Zeitstempel)"
+#~ msgid ""
+#~ "import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable "
+#~ "and 1 time step)"
+#~ msgstr ""
+#~ "Importiere 3-dimensionale Vis5D Daten (z.B. die v5d-Daten mit einer "
+#~ "Variablen und einem Zeitstempel)"
-msgid "Converts a 3D raster map layer into an ASCII text file"
-msgstr "Exportiert eine 3D-Rasterkarte in eine ASCII-Textdatei."
+#~ msgid "Converts a 3D raster map layer into an ASCII text file"
+#~ msgstr "Exportiert eine 3D-Rasterkarte in eine ASCII-Textdatei."
-msgid "Calculates linear regression from two raster maps: y = a + b*x"
-msgstr "Berechnet lineare Regression zweier Rasterkarten: y = a + b*x."
+#~ msgid "Calculates linear regression from two raster maps: y = a + b*x"
+#~ msgstr "Berechnet lineare Regression zweier Rasterkarten: y = a + b*x."
-msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr "Exportiert eine GRASS 3D Rasterkarte in eine 3-dimensionale Vis5D Datei"
+#~ msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+#~ msgstr ""
+#~ "Exportiert eine GRASS 3D Rasterkarte in eine 3-dimensionale Vis5D Datei"
-msgid "Lists available GRASS data base files of the user-specified data type to standard output."
-msgstr "Listet alle verfügbaren GRASS Datenbankdateien im spezifiezierten Typ im Standard Output auf"
+#~ msgid ""
+#~ "Lists available GRASS data base files of the user-specified data type to "
+#~ "standard output."
+#~ msgstr ""
+#~ "Listet alle verfügbaren GRASS Datenbankdateien im spezifiezierten Typ im "
+#~ "Standard Output auf"
-msgid "Creates cross section 2D raster map from 3d raster map based on 2D elevation map"
-msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
+#~ msgid ""
+#~ "Creates cross section 2D raster map from 3d raster map based on 2D "
+#~ "elevation map"
+#~ msgstr ""
+#~ "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
+#~ "Rasterkarte basierend auf 2D-Höhenkarte."
-msgid "Generates volume statistics for raster3d maps."
-msgstr "Erzeugt Volumenstatistik für 3D-Rasterkarten."
+#~ msgid "Generates volume statistics for raster3d maps."
+#~ msgstr "Erzeugt Volumenstatistik für 3D-Rasterkarten."
 #, fuzzy
-msgid "Watershed basin analysis program"
-msgstr "Programm zur Analyse von Wassereinzugsgebieten."
+#~ msgid "Watershed basin analysis program"
+#~ msgstr "Programm zur Analyse von Wassereinzugsgebieten."
 #, fuzzy
-msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation."
-msgstr "Fülle Flächen ohne Daten in Rasterkarten mit Hilfe der v.surf.rst Spline-Interpolation."
+#~ msgid ""
+#~ "Fills no-data areas in raster maps using v.surf.rst splines interpolation."
+#~ msgstr ""
+#~ "Fülle Flächen ohne Daten in Rasterkarten mit Hilfe der v.surf.rst Spline-"
+#~ "Interpolation."
 #, fuzzy
-msgid "Create parallel line to input lines"
-msgstr "Erzeuge parallele Linien zu existierenden Linien."
+#~ msgid "Create parallel line to input lines"
+#~ msgstr "Erzeuge parallele Linien zu existierenden Linien."
 #, fuzzy
-msgid "Mosaics up to four images, extending the color table."
-msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
+#~ msgid "Mosaics up to four images, extending the color table."
+#~ msgstr ""
+#~ "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *."
+#~ "mosaic-Karten."
 #, fuzzy
-msgid "Extract quality control parameters from Modis QC layers"
-msgstr "Extrahiert Terrainparameter von einem DEM."
+#~ msgid "Extract quality control parameters from Modis QC layers"
+#~ msgstr "Extrahiert Terrainparameter von einem DEM."
 #, fuzzy
-msgid "Import raster or vector data"
-msgstr "Importiere Rasterdaten"
+#~ msgid "Import raster or vector data"
+#~ msgstr "Importiere Rasterdaten"
 #, fuzzy
-msgid "Profile plot settings"
-msgstr "Profileinstellungen"
+#~ msgid "Profile plot settings"
+#~ msgstr "Profileinstellungen"
-msgid "Quit GRASS GIS"
-msgstr "Verlasse GRASS GIS"
+#~ msgid "Quit GRASS GIS"
+#~ msgstr "Verlasse GRASS GIS"
 #, fuzzy
-msgid ""
-"Reading workspace file <%(file)s> failed.\n"
-"Invalid file, unable to parse XML document.\n"
-"\n"
-"%(err)s"
-msgstr "Lesen der Projektdatei <%s> fehlgeschlagen. Ungᅵltige Datei; kann das XML-Dokument nicht parsen."
+#~ msgid ""
+#~ "Reading workspace file <%(file)s> failed.\n"
+#~ "Invalid file, unable to parse XML document.\n"
+#~ "\n"
+#~ "%(err)s"
+#~ msgstr ""
+#~ "Lesen der Projektdatei <%s> fehlgeschlagen. Ungᅵltige Datei; kann das "
+#~ "XML-Dokument nicht parsen."
-msgid "GRASS GIS Map Calculator"
-msgstr "GRASS GIS Kartenrechner"
+#~ msgid "GRASS GIS Map Calculator"
+#~ msgstr "GRASS GIS Kartenrechner"
-msgid "GRASS GIS Map Calculator (3D raster)"
-msgstr "GRASS GIS Kartenrechner (3D Raster)"
+#~ msgid "GRASS GIS Map Calculator (3D raster)"
+#~ msgstr "GRASS GIS Kartenrechner (3D Raster)"
-msgid "C&onfig"
-msgstr "K&onfiguration"
+#~ msgid "C&onfig"
+#~ msgstr "K&onfiguration"
-msgid "Projection for current location"
-msgstr "Projektion der aktuellen Location"
+#~ msgid "Projection for current location"
+#~ msgstr "Projektion der aktuellen Location"
-msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask it"
-msgstr "Berechnet verschattete Bereiche aus der Sonnenposition und einem DGM. Fall A: Es wird die genaue Sonnenposition benötigt; Fall B: Datum- und Zeitinformationen zur Berechnung der Sonnenposition (mit r.sunmask) werden benötigt"
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask it"
+#~ msgstr ""
+#~ "Berechnet verschattete Bereiche aus der Sonnenposition und einem DGM. "
+#~ "Fall A: Es wird die genaue Sonnenposition benötigt; Fall B: Datum- und "
+#~ "Zeitinformationen zur Berechnung der Sonnenposition (mit r.sunmask) "
+#~ "werden benötigt"
-msgid "Show menu tree in new window"
-msgstr "Zeige Menuebaum in neuem Fenster"
+#~ msgid "Show menu tree in new window"
+#~ msgstr "Zeige Menuebaum in neuem Fenster"
-msgid "logical AND (ignores NULLs"
-msgstr "logisches UND (ignoriert NULL"
+#~ msgid "logical AND (ignores NULLs"
+#~ msgstr "logisches UND (ignoriert NULL"
-msgid "logical OR (ignores NULLs"
-msgstr "logisches ODER (ignoriert NULL"
+#~ msgid "logical OR (ignores NULLs"
+#~ msgstr "logisches ODER (ignoriert NULL"
-msgid "3D Raster map"
-msgstr "3D Rasterkarte"
+#~ msgid "3D Raster map"
+#~ msgstr "3D Rasterkarte"
-msgid "Error in command execution '%s'"
-msgstr "Fehler bei der Ausfᅵhrung des Befehls '%s'"
+#~ msgid "Error in command execution '%s'"
+#~ msgstr "Fehler bei der Ausfᅵhrung des Befehls '%s'"
-msgid "Select GRASS module"
-msgstr "Wählen Sie das GRASS-Modul"
+#~ msgid "Select GRASS module"
+#~ msgstr "Wählen Sie das GRASS-Modul"
 #, fuzzy
-msgid "Unable to get list of available mapsets."
-msgstr "Kann Mapset nicht löschen"
+#~ msgid "Unable to get list of available mapsets."
+#~ msgstr "Kann Mapset nicht löschen"
 #, fuzzy
-msgid "Unable to get list of accessible mapsets."
+#~ msgid "Unable to get list of accessible mapsets."
 #, fuzzy
-msgid "Menu tree window"
-msgstr "Fenster ersetzt den standard."
+#~ msgid "Menu tree window"
+#~ msgstr "Fenster ersetzt den standard."
-msgid "help"
-msgstr "Hilfe"
+#~ msgid "help"
+#~ msgstr "Hilfe"
-msgid "Run"
-msgstr "Los"
+#~ msgid "Run"
+#~ msgstr "Los"
-msgid "Saved NVIZ Settings"
-msgstr "Gespeicherte Nviz-Einstellungen"
+#~ msgid "Saved NVIZ Settings"
+#~ msgstr "Gespeicherte Nviz-Einstellungen"
 #, fuzzy
-msgid "Load and apply settings from user settings file"
+#~ msgid "Load and apply settings from user settings file"
+#~ msgstr ""
+#~ "Beende den Dialog und speichere die Änderungen in Datei mit "
+#~ "Benutzereinstellungen"
-msgid "Note that the 3D view mode is currently not working under MS Windows (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS."
-msgstr "Beachten Sie, dass die 3D-Ansicht-Modus derzeit unter MS Windows nicht funktioniert (dieses wird hoffentlich bald behoben sein). Bitte achten Sie auf aktualisierte Versionen von GRASS."
+#~ msgid ""
+#~ "Note that the 3D view mode is currently not working under MS Windows "
+#~ "(hopefully this will be fixed soon). Please keep an eye out for updated "
+#~ "versions of GRASS."
+#~ msgstr ""
+#~ "Beachten Sie, dass die 3D-Ansicht-Modus derzeit unter MS Windows nicht "
+#~ "funktioniert (dieses wird hoffentlich bald behoben sein). Bitte achten "
+#~ "Sie auf aktualisierte Versionen von GRASS."
-msgid "Note that the vector digitizer is currently not working under MS Windows (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS."
-msgstr "Beachten Sie, dass der Vektordigitalisierer derzeit unter MS Windows nicht funktioniert (dieses wird hoffentlich bald behoben sein). Bitte achten Sie auf aktualisierte Versionen von GRASS."
+#~ msgid ""
+#~ "Note that the vector digitizer is currently not working under MS Windows "
+#~ msgstr ""
+#~ "Beachten Sie, dass der Vektordigitalisierer derzeit unter MS Windows "
+#~ "nicht funktioniert (dieses wird hoffentlich bald behoben sein). Bitte "
+#~ "achten Sie auf aktualisierte Versionen von GRASS."
-msgid "Create new workspace file"
-msgstr "Erzeuge neue Projektdatei"
+#~ msgid "Create new workspace file"
+#~ msgstr "Erzeuge neue Projektdatei"
-msgid "Load map layers into workspace"
-msgstr "Kartenebenen in das Projekt laden"
+#~ msgid "Load map layers into workspace"
+#~ msgstr "Kartenebenen in das Projekt laden"
-msgid "Open existing workspace file"
-msgstr "Öffne bestehende Projektdatei"
+#~ msgid "Open existing workspace file"
+#~ msgstr "Öffne bestehende Projektdatei"
-msgid "Save current workspace to file"
-msgstr "Speichere aktuelles Projekt in Datei"
+#~ msgid "Save current workspace to file"
+#~ msgstr "Speichere aktuelles Projekt in Datei"
-msgid "Close this window without executing the command"
-msgstr "Schließe dieses Fenster ohne den Befehl auszuführen."
+#~ msgid "Close this window without executing the command"
+#~ msgstr "Schließe dieses Fenster ohne den Befehl auszuführen."
-msgid "Show manual page of the command"
-msgstr "Zeige die Handbuchseite des Befehls."
+#~ msgid "Show manual page of the command"
+#~ msgstr "Zeige die Handbuchseite des Befehls."
-msgid "Run the command"
-msgstr "Führe den Befehl aus"
+#~ msgid "Run the command"
+#~ msgstr "Führe den Befehl aus"
-msgid "coarse:"
-msgstr "grob:"
+#~ msgid "coarse:"
+#~ msgstr "grob:"
-msgid "fine:"
-msgstr "fein:"
+#~ msgid "fine:"
+#~ msgstr "fein:"
-msgid "Downloads and imports data from WMS servers."
-msgstr "Laden und importieren von Daten von einem WMS-Server."
+#~ msgid "Downloads and imports data from WMS servers."
+#~ msgstr "Laden und importieren von Daten von einem WMS-Server."
-msgid "Matlab and MapGen import"
-msgstr "Matlab and MapGen Import"
+#~ msgid "Matlab and MapGen import"
+#~ msgstr "Matlab and MapGen Import"
-msgid "r.recode.rules - Use ascii rules file to recode categories in raster map"
-msgstr "r.recode.rules - Verwenden Sie ASCII-Regeldateien, um eine Rasterkarte umzukodieren."
+#~ msgid ""
+#~ "r.recode.rules - Use ascii rules file to recode categories in raster map"
+#~ msgstr ""
+#~ "r.recode.rules - Verwenden Sie ASCII-Regeldateien, um eine Rasterkarte "
+#~ "umzukodieren."
-msgid "COPYING file missing"
-msgstr "COPYING Datei fehlt"
+#~ msgid "COPYING file missing"
+#~ msgstr "COPYING Datei fehlt"
-msgid "Official GRASS site: http://grass.osgeo.org"
-msgstr "Offizielle GRASS Webseite: http://grass.osgeo.org"
+#~ msgid "Official GRASS site: http://grass.osgeo.org"
+#~ msgstr "Offizielle GRASS Webseite: http://grass.osgeo.org"
-msgid "GIS Library"
-msgstr "GIS Bibliothek"
+#~ msgid "GIS Library"
+#~ msgstr "GIS Bibliothek"
-msgid "Force re-rendering of all layers"
-msgstr "Erzwinge Neuanzeige aller Karten"
+#~ msgid "Force re-rendering of all layers"
+#~ msgstr "Erzwinge Neuanzeige aller Karten"
-msgid "Show Nviz settings dialog"
-msgstr "Zeige Nviz Einstellungsdialog"
+#~ msgid "Show Nviz settings dialog"
+#~ msgstr "Zeige Nviz Einstellungsdialog"
-msgid "Nviz properties"
-msgstr "Nviz Eigenschaften"
+#~ msgid "Nviz properties"
+#~ msgstr "Nviz Eigenschaften"
-msgid "Parameter %(name)s (%(desc)s) is missing.\n"
-msgstr "Parameter %(name)s (%(desc)s) fehlt.\n"
+#~ msgid "Parameter %(name)s (%(desc)s) is missing.\n"
+#~ msgstr "Parameter %(name)s (%(desc)s) fehlt.\n"
-msgid "Vector point layer not found (id=%d)"
-msgstr "Vektor-Punktebene nicht gefunden (id=%d)"
+#~ msgid "Vector point layer not found (id=%d)"
+#~ msgstr "Vektor-Punktebene nicht gefunden (id=%d)"
-msgid "Unable to set data layer properties (id=%d)"
-msgstr "Kann die Eigenschaften der Datenebene (id=%d) nicht setzen."
+#~ msgid "Unable to set data layer properties (id=%d)"
+#~ msgstr "Kann die Eigenschaften der Datenebene (id=%d) nicht setzen."
-msgid "User GUI settings"
-msgstr "GUI-Benutzereinstellungen"
+#~ msgid "User GUI settings"
+#~ msgstr "GUI-Benutzereinstellungen"
-msgid "Select file extension:"
-msgstr "Wählen Sie die Dateiendung:"
+#~ msgid "Select file extension:"
+#~ msgstr "Wählen Sie die Dateiendung:"
-msgid "Export GRASS raster as non-georeferenced PNG image format."
-msgstr "Exportiert GRASS Raster als nicht georeferenziertes PNG-Bild"
+#~ msgid "Export GRASS raster as non-georeferenced PNG image format."
+#~ msgstr "Exportiert GRASS Raster als nicht georeferenziertes PNG-Bild"
-msgid "Raster"
-msgstr "Raster"
+#~ msgid "Raster"
+#~ msgstr "Raster"
-msgid "Volumes"
-msgstr "Volumen"
+#~ msgid "Volumes"
+#~ msgstr "Volumen"
-msgid "GRASS GIS help"
-msgstr "GRASS GIS Hilfe"
+#~ msgid "GRASS GIS help"
+#~ msgstr "GRASS GIS Hilfe"
-msgid "Reading workspace file <%s> failed. Invalid file, unable to parse XML document."
-msgstr "Lesen der Projektdatei <%s> fehlgeschlagen. Ungültige Datei; kann das XML-Dokument nicht parsen."
+#~ msgid ""
+#~ "Reading workspace file <%s> failed. Invalid file, unable to parse XML "
+#~ "document."
+#~ msgstr ""
+#~ "Lesen der Projektdatei <%s> fehlgeschlagen. Ungültige Datei; kann das XML-"
+#~ "Dokument nicht parsen."
-msgid "Writing current settings to workspace file failed (%s)."
-msgstr "Das Schreiben der aktuellen Einstellungen in die Projektdatei ist fehlgeschlagen (%s)."
+#~ msgid "Writing current settings to workspace file failed (%s)."
+#~ msgstr ""
+#~ "Das Schreiben der aktuellen Einstellungen in die Projektdatei ist "
+#~ "fehlgeschlagen (%s)."
-msgid "Add layer group"
-msgstr "Ebenen-Gruppe hinzufügen"
+#~ msgid "Add layer group"
+#~ msgstr "Ebenen-Gruppe hinzufügen"
-msgid "Add RGB layer"
-msgstr "RGB-Ebene hinzufügen"
+#~ msgid "Add RGB layer"
+#~ msgstr "RGB-Ebene hinzufügen"
-msgid "Reload GCPs from selected POINTS file"
-msgstr "Lade erneut GCPs aus POINTS-Datei"
+#~ msgid "Reload GCPs from selected POINTS file"
+#~ msgstr "Lade erneut GCPs aus POINTS-Datei"
-msgid "Flow computation for massive grids (Float version)."
-msgstr "Berechnung von Fließrichtung und -mengen auf sehr großen Rastern (Float-Version)"
+#~ msgid "Flow computation for massive grids (Float version)."
+#~ msgstr ""
+#~ "Berechnung von Fließrichtung und -mengen auf sehr großen Rastern (Float-"
+#~ "Version)"
-msgid "Calculates univariate statistics from a GRASS raster map based on vector polygons and uploads statistics to new attribute columns."
-msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
+#~ msgid ""
+#~ "Calculates univariate statistics from a GRASS raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
+#~ "und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
-msgid "Icon size:"
-msgstr "Symbolgröße:"
+#~ msgid "Icon size:"
+#~ msgstr "Symbolgröße:"
-msgid "%(primitives)d primitives (%(points)d points)"
-msgstr "%(primitives)d Primitive (%(points)d Punkte)"
+#~ msgid "%(primitives)d primitives (%(points)d points)"
+#~ msgstr "%(primitives)d Primitive (%(points)d Punkte)"
-msgid ""
-"Unable to initialize display driver of vector digitizer. See 'Command output' for details.\n"
-"\n"
-"Details:"
-msgstr ""
-"Kann den Displaytreiber des Vektordigitalisierers nicht initializieren. Siehe 'Befehlsausgabe' Fenster für Einzelheiten.\n"
-"\n"
-"Details:"
+#~ msgid ""
+#~ "Unable to initialize display driver of vector digitizer. See 'Command "
+#~ "output' for details.\n"
+#~ "\n"
+#~ "Details:"
+#~ msgstr ""
+#~ "Kann den Displaytreiber des Vektordigitalisierers nicht initializieren. "
+#~ "Siehe 'Befehlsausgabe' Fenster für Einzelheiten.\n"
+#~ "\n"
+#~ "Details:"
-msgid "Command '%s' not yet implemented in the GUI. Try adding it as a command layer instead."
-msgstr "Befehl '%s' wurde noch nicht im GUI implementiert. Versuchen Sie es stattdessen als Befehlsebene hinzuzufügen."
+#~ msgid ""
+#~ "Command '%s' not yet implemented in the GUI. Try adding it as a command "
+#~ "layer instead."
+#~ msgstr ""
+#~ "Befehl '%s' wurde noch nicht im GUI implementiert. Versuchen Sie es "
+#~ "stattdessen als Befehlsebene hinzuzufügen."
-msgid "Note that the wxGUI's 3D view mode is currently disabled (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
-msgstr "Beachten Sie, dass die 3D-Ansicht-Modus derzeit unter MS Windows nicht funktioniert (dieses wird hoffentlich bald behoben sein). Bitte achten Sie auf aktualisierte Versionen von GRASS. In der Zwischenzeit können Sie \"nviz\" aus dem Menü \"Datei\" verwenden."
+#~ msgid ""
+#~ "Note that the wxGUI's 3D view mode is currently disabled (hopefully this "
+#~ "will be fixed soon). Please keep an eye out for updated versions of "
+#~ "GRASS. In the meantime you can use \"NVIZ\" from the File menu."
+#~ msgstr ""
+#~ "Sie auf aktualisierte Versionen von GRASS. In der Zwischenzeit können Sie "
+#~ "\"nviz\" aus dem Menü \"Datei\" verwenden."
-msgid "<%(name)s>: layer type <%(type)s> is not supported yet."
-msgstr "<%(name)s>: Layertyp <%(type)s> wird noch nicht unterstützt."
+#~ msgid "<%(name)s>: layer type <%(type)s> is not supported yet."
+#~ msgstr "<%(name)s>: Layertyp <%(type)s> wird noch nicht unterstützt."
-msgid "Check a mapset to make it accessible, uncheck it to hide it.%sNote: The current mapset is always accessible."
-msgstr "Selektiere ein Mapset, um es zugänglich zu machen und deselektiere es, um es zu verbergen. %sBemerkung: Das aktuelle Mapset ist immer zugänglich."
+#~ msgid ""
+#~ "Check a mapset to make it accessible, uncheck it to hide it.%sNote: The "
+#~ "current mapset is always accessible."
+#~ msgstr ""
+#~ "Selektiere ein Mapset, um es zugänglich zu machen und deselektiere es, um "
+#~ "es zu verbergen. %sBemerkung: Das aktuelle Mapset ist immer zugänglich."
-msgid "Create mapset"
-msgstr "Mapset erstellen"
+#~ msgid "Create mapset"
+#~ msgstr "Mapset erstellen"
-msgid "3d view tools"
-msgstr "3D Ansichtswerkzeuge"
+#~ msgid "3d view tools"
+#~ msgstr "3D Ansichtswerkzeuge"
-msgid "Create a MASK for limiting raster operation"
-msgstr "Erzeugt eine MASK für räumlich eingeschränkte Rasterkartenberechnungen"
+#~ msgid "Create a MASK for limiting raster operation"
+#~ msgstr ""
+#~ "Erzeugt eine MASK für räumlich eingeschränkte Rasterkartenberechnungen"
-msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr "Importiere Mapgen oder Matlab-ASCII Vektordaten nach GRASS."
+#~ msgid "Import Mapgen or Matlab-ASCII vector maps into GRASS."
+#~ msgstr "Importiere Mapgen oder Matlab-ASCII Vektordaten nach GRASS."
-msgid "use| X coord"
-msgstr "verwende| X Koordinate"
+#~ msgid "use| X coord"
+#~ msgstr "verwende| X Koordinate"
-msgid "Reproject coordinates displayed in the statusbar. Projection can be defined in GUI preferences dialog (tab 'Display')"
-msgstr "Umprojezierte Koordinaten in der Statusleiste angezeigt. Die Projektion kann in GUI Einstellungen (Reiter 'Fenster') definiert werden."
+#~ msgid ""
+#~ "Reproject coordinates displayed in the statusbar. Projection can be "
+#~ "defined in GUI preferences dialog (tab 'Display')"
+#~ msgstr ""
+#~ "Umprojezierte Koordinaten in der Statusleiste angezeigt. Die Projektion "
+#~ "kann in GUI Einstellungen (Reiter 'Fenster') definiert werden."
-msgid "Select raster map 1 (required):"
-msgstr "Wähle Rasterkarte 1 (erfordert):"
+#~ msgid "Select raster map 1 (required):"
+#~ msgstr "Wähle Rasterkarte 1 (erfordert):"
-msgid "width"
-msgstr "Breite"
+#~ msgid "width"
+#~ msgstr "Breite"
-msgid "Source name"
-msgstr "Name der Quelle"
+#~ msgid "Source name"
+#~ msgstr "Name der Quelle"
-msgid "Fine:"
-msgstr "fein:"
+#~ msgid "Fine:"
+#~ msgstr "fein:"
-msgid "Look at:"
-msgstr "Schau auf:"
+#~ msgid "Look at:"
+#~ msgstr "Schau auf:"
-msgid "Coarse:"
-msgstr "Grob:"
+#~ msgid "Coarse:"
+#~ msgstr "Grob:"
-msgid "wire color"
-msgstr "Gitterfarbe"
+#~ msgid "wire color"
+#~ msgstr "Gitterfarbe"
-msgid "Show/hide 3D view mode settings dialog"
-msgstr "Einstellungen für 3D Ansicht anzeigen/ausblenden"
+#~ msgid "Show/hide 3D view mode settings dialog"
+#~ msgstr "Einstellungen für 3D Ansicht anzeigen/ausblenden"
-msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+#~ msgid ""
+#~ "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+#~ msgstr ""
-msgid "Create new color table for vector map"
-msgstr "Erstelle eine neue Farbtabelle für Vektorkarten"
+#~ msgid "Create new color table for vector map"
+#~ msgstr "Erstelle eine neue Farbtabelle für Vektorkarten"
-msgid "Enter vector attribute values or ranges (n or n1 to n2)"
-msgstr "Geben Sie Vektorattributwerte oder -bereich ein (n oder n1 bis n2)"
+#~ msgid "Enter vector attribute values or ranges (n or n1 to n2)"
+#~ msgstr "Geben Sie Vektorattributwerte oder -bereich ein (n oder n1 bis n2)"
-msgid "Save color table to file"
-msgstr "Speichere Farbtabelle in Datei"
+#~ msgid "Save color table to file"
+#~ msgstr "Speichere Farbtabelle in Datei"
-msgid "RGB color column:"
-msgstr "RGB-Spalte:"
+#~ msgid "RGB color column:"
+#~ msgstr "RGB-Spalte:"
-msgid "3D View Toolbar"
-msgstr "Werkzeugleiste 3D-Ansicht"
+#~ msgid "3D View Toolbar"
+#~ msgstr "Werkzeugleiste 3D-Ansicht"
-msgid "by color"
-msgstr "nach Farbe"
+#~ msgid "by color"
+#~ msgstr "nach Farbe"
-msgid "color"
-msgstr "Farbe"
+#~ msgid "color"
+#~ msgstr "Farbe"
-msgid "Settings named '%s' not found"
-msgstr "Einstellungen <%s> nicht gefunden"
+#~ msgid "Settings named '%s' not found"
+#~ msgstr "Einstellungen <%s> nicht gefunden"
-msgid "&Clear output"
-msgstr "&Lösche Ausgabe"
+#~ msgid "&Clear output"
+#~ msgstr "&Lösche Ausgabe"
-msgid "Abort the running command"
-msgstr "Breche den laufenden Befehl ab"
+#~ msgid "Abort the running command"
+#~ msgstr "Breche den laufenden Befehl ab"
-msgid "ERROR: Rendering failed"
-msgstr "FEHLER: Rendering erfolglos"
+#~ msgid "ERROR: Rendering failed"
+#~ msgstr "FEHLER: Rendering erfolglos"
-msgid "Profile text settings"
-msgstr "Profiltexteinstellungen"
+#~ msgid "Profile text settings"
+#~ msgstr "Profiltexteinstellungen"
-msgid "Select raster map to profile"
-msgstr "Wähle zu profilierende Rasterkarte"
+#~ msgid "Select raster map to profile"
+#~ msgstr "Wähle zu profilierende Rasterkarte"
-msgid "Profile settings saved to file '%s'."
+#~ msgid "Profile settings saved to file '%s'."
-msgid "Close all"
-msgstr "Alles schließen"
+#~ msgid "Close all"
+#~ msgstr "Alles schließen"
-msgid "Analyze"
-msgstr "Analysieren"
+#~ msgid "Analyze"
+#~ msgstr "Analysieren"
-msgid "Display 3D view mode manual page"
-msgstr "Zeige Manual für 3D Ansichtsmodus an"
+#~ msgid "Display 3D view mode manual page"
+#~ msgstr "Zeige Manual für 3D Ansichtsmodus an"
-msgid "(step):"
-msgstr "(Schrittweite):"
+#~ msgid "(step):"
+#~ msgstr "(Schrittweite):"
-msgid "Menu style (requires GUI restart):"
-msgstr "Menü-Stil (benötigt GUI-Neustart):"
+#~ msgid "Menu style (requires GUI restart):"
+#~ msgstr "Menü-Stil (benötigt GUI-Neustart):"
-msgid "GRASS GIS Histogram of raster map"
-msgstr "GRASS GIS Histogramm einer Rasterkarte"
+#~ msgid "GRASS GIS Histogram of raster map"
+#~ msgstr "GRASS GIS Histogramm einer Rasterkarte"
-msgid "Emission"
-msgstr "Emission"
+#~ msgid "Emission"
+#~ msgstr "Emission"
-msgid "symbol"
-msgstr "Symbol"
+#~ msgid "symbol"
+#~ msgstr "Symbol"
-msgid "At least %d GCPs required. Operation cancelled."
-msgstr "Es werden mindestens %d GCPs benötigt. Operation abgebrochen."
+#~ msgid "At least %d GCPs required. Operation cancelled."
+#~ msgstr "Es werden mindestens %d GCPs benötigt. Operation abgebrochen."
-msgid "Invalid coordinate value. Operation cancelled."
-msgstr "Ungültige Koordinate. Operation abgebrochen."
+#~ msgid "Invalid coordinate value. Operation cancelled."
+#~ msgstr "Ungültige Koordinate. Operation abgebrochen."
-msgid "Create an arbitrary non-earth coordinate system (XY)"
-msgstr "Verwende ein beliebiges nicht erdbezogenes Koordinatensystem (XY)"
+#~ msgid "Create an arbitrary non-earth coordinate system (XY)"
+#~ msgstr "Verwende ein beliebiges nicht erdbezogenes Koordinatensystem (XY)"
-msgid "You must enter the name of a new map to create"
-msgstr "Sie müssen den Namen der neu zu erezugenden Karte eingeben."
+#~ msgid "You must enter the name of a new map to create"
+#~ msgstr "Sie müssen den Namen der neu zu erezugenden Karte eingeben."
-msgid "You must enter a mapcalc statement to create a new map"
-msgstr "Sie müssen ein mapcalc-Ausdruck eingeben, um eine neue Karte zu erzeugen."
+#~ msgid "You must enter a mapcalc statement to create a new map"
+#~ msgstr ""
+#~ "Sie müssen ein mapcalc-Ausdruck eingeben, um eine neue Karte zu erzeugen."
-msgid "Unable to display histogram of raster map."
-msgstr "Kann das Histogramm der Rasterkarte nicht anzeigen."
+#~ msgid "Unable to display histogram of raster map."
+#~ msgstr "Kann das Histogramm der Rasterkarte nicht anzeigen."
-msgid "Operation cancelled."
-msgstr "Operation abgebrochen."
+#~ msgid "Operation cancelled."
+#~ msgstr "Operation abgebrochen."
-msgid "Reading feature id %d failed. Operation cancelled."
-msgstr "Objekt-ID %d kann nicht gelesen werden. Operation abgebrochen."
+#~ msgid "Reading feature id %d failed. Operation cancelled."
+#~ msgstr "Objekt-ID %d kann nicht gelesen werden. Operation abgebrochen."
-msgid "Database link %d not available. Operation cancelled."
-msgstr "Datenbankverbindung %d ist nicht vorhanden. Operation abgebrochen."
+#~ msgid "Database link %d not available. Operation cancelled."
+#~ msgstr "Datenbankverbindung %d ist nicht vorhanden. Operation abgebrochen."
-msgid "Unable to start database driver <%s>. Operation cancelled."
-msgstr "Kann Datenbanktreiber <%s> nicht starten. Operation abgebrochen."
+#~ msgid "Unable to start database driver <%s>. Operation cancelled."
+#~ msgstr "Kann Datenbanktreiber <%s> nicht starten. Operation abgebrochen."
-msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation cancelled."
+#~ msgid ""
+#~ "Unable to open database <%(db)s> by driver <%(driver)s>. Operation "
+#~ "cancelled."
+#~ msgstr ""
+#~ "Kann Datenbank <%(db)s> nicht mit Treiber <%(driver)s> öffnen. Operation "
+#~ "abgebrochen."
-msgid "Unable to execute SQL query '%s'. Operation cancelled."
-msgstr "SQL Abfrage '%s' kann nicht ausgeführt werden. Operation abgebrochen."
+#~ msgid "Unable to execute SQL query '%s'. Operation cancelled."
+#~ msgstr ""
+#~ "SQL Abfrage '%s' kann nicht ausgeführt werden. Operation abgebrochen."
-msgid "Feature id %d is marked as dead. Operation cancelled."
-msgstr "Objekt-ID %d als tot markiert. Operation abgebrochen."
+#~ msgid "Feature id %d is marked as dead. Operation cancelled."
+#~ msgstr "Objekt-ID %d als tot markiert. Operation abgebrochen."
-msgid "Unsupported feature type %d. Operation cancelled."
-msgstr "Nicht unterstützter Objekttyp %d. Operation abgebrochen."
+#~ msgid "Unsupported feature type %d. Operation cancelled."
+#~ msgstr "Nicht unterstützter Objekttyp %d. Operation abgebrochen."
-msgid "Unable to insert new record."
-msgstr "Kann den neuen Datensatz nicht einfügen."
+#~ msgid "Unable to insert new record."
+#~ msgstr "Kann den neuen Datensatz nicht einfügen."
-msgid "Unable to update existing record."
-msgstr "Kann existierenden Datensatz nicht aktualisieren."
+#~ msgid "Unable to update existing record."
+#~ msgstr "Kann existierenden Datensatz nicht aktualisieren."
-msgid "Close Map Display %d"
-msgstr "Schließe Kartenanzeige %d"
+#~ msgid "Close Map Display %d"
+#~ msgstr "Schließe Kartenanzeige %d"
-msgid "Script file '%s' doesn't exist. Operation cancelled."
-msgstr "Skript-Datei '%s' ist nicht vorhanden. Berechnung wurde abgebrochen."
+#~ msgid "Script file '%s' doesn't exist. Operation cancelled."
+#~ msgstr ""
+#~ "Skript-Datei '%s' ist nicht vorhanden. Berechnung wurde abgebrochen."
-msgid "No map layer selected. Operation cancelled."
-msgstr "Keine Kartenebene selektiert. Breche die Operation ab."
+#~ msgid "No map layer selected. Operation cancelled."
+#~ msgstr "Keine Kartenebene selektiert. Breche die Operation ab."
-msgid "Creates, edits, and lists groups and subgroups of imagery files."
-msgstr "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
+#~ msgid "Creates, edits, and lists groups and subgroups of imagery files."
+#~ msgstr ""
+#~ "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
-msgid "Add action (GRASS module) to model"
-msgstr "Füge Aktion (GRASS Modul) zu Modell hinzu"
+#~ msgid "Add action (GRASS module) to model"
+#~ msgstr "Füge Aktion (GRASS Modul) zu Modell hinzu"
-msgid "Add loop"
-msgstr "Loop hinzufügen"
+#~ msgid "Add loop"
+#~ msgstr "Loop hinzufügen"
-msgid "Adds loop (for) to model"
-msgstr "Füge Loop (for) zu Modell hinzu"
+#~ msgid "Adds loop (for) to model"
+#~ msgstr "Füge Loop (for) zu Modell hinzu"
-msgid "Draw/re-draw profile"
-msgstr "(erneutes) zeichnen des Profils"
+#~ msgid "Draw/re-draw profile"
+#~ msgstr "(erneutes) zeichnen des Profils"
-msgid "Quit digitizing tool"
-msgstr "Beende Digitalisierungswerkzeug"
+#~ msgid "Quit digitizing tool"
+#~ msgstr "Beende Digitalisierungswerkzeug"
-msgid "&Stop"
-msgstr "S&top"
+#~ msgid "&Stop"
+#~ msgstr "S&top"
-msgid ""
-"Current name: %s\n"
-"Enter new name:"
-msgstr ""
-"Aktueller Name: %s\n"
-"\n"
-"Geben Sie den neuen Namen ein:"
+#~ msgid ""
+#~ "Current name: %s\n"
+#~ "Enter new name:"
+#~ msgstr ""
+#~ "Aktueller Name: %s\n"
+#~ "\n"
+#~ "Geben Sie den neuen Namen ein:"
-msgid "Fills lake from seed at given level."
-msgstr "Füllt Seen bis zu einem bestimmten Level."
+#~ msgid "Fills lake from seed at given level."
+#~ msgstr "Füllt Seen bis zu einem bestimmten Level."
-msgid "Create a new vector from the current region."
-msgstr "Erzeuge einen neuen Vektor aus der aktuellen Region."
+#~ msgid "Create a new vector from the current region."
+#~ msgstr "Erzeuge einen neuen Vektor aus der aktuellen Region."
-msgid "Select WKT file"
-msgstr "Wählen Sie eine WKT-Datei"
+#~ msgid "Select WKT file"
+#~ msgstr "Wählen Sie eine WKT-Datei"
 #~ msgid "GRASS GIS Map Display: "
 #~ msgstr "GRASS GIS Kartenfenster: "
@@ -18436,8 +19678,12 @@
 #~ msgid "vector labels"
 #~ msgstr "Vektorbeschriftung"
-#~ msgid "Unknown default DB connection. Please define DB connection using db.connect module."
-#~ msgstr "Unbekannte Standard Datenbankverbindung. Bitte definieren Sie eine Datenbankverbindung mit dem Modul db.connect."
+#~ msgid ""
+#~ "Unknown default DB connection. Please define DB connection using db."
+#~ "connect module."
+#~ msgstr ""
+#~ "Unbekannte Standard Datenbankverbindung. Bitte definieren Sie eine "
+#~ "Datenbankverbindung mit dem Modul db.connect."
 #~ msgid "Highlighting"
 #~ msgstr "Highlighting"
@@ -18487,8 +19733,12 @@
 #~ msgid "Add new GRASS module to the model"
 #~ msgstr "Neues GRASS-Modul zu Modell hinzufügen"
-#~ msgid "Selected data records (%d) will permanently deleted from table. Do you want to delete them?"
-#~ msgstr "Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
+#~ msgid ""
+#~ "Selected data records (%d) will permanently deleted from table. Do you "
+#~ "want to delete them?"
+#~ msgstr ""
+#~ "Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle "
+#~ "gelöscht. Wollen Sie diese Datensätze löschen?"
 #~ msgid "Normalize"
 #~ msgstr "Normalisiere"
@@ -18514,23 +19764,30 @@
 #~ msgid "Set size and position"
 #~ msgstr "Definiere Größe und Position"
-#~ msgid "Click and drag on the map display to set legend size and position and then press OK"
-#~ msgstr "Klicken und Verschieben im Kartenfenster, um Größe und Position der Legende zu bestimmen. Mit klick auf OK beenden."
+#~ msgid ""
+#~ "Click and drag on the map display to set legend size and position and "
+#~ "then press OK"
+#~ msgstr ""
+#~ "Klicken und Verschieben im Kartenfenster, um Größe und Position der "
+#~ "Legende zu bestimmen. Mit klick auf OK beenden."
 #~ msgid ""
 #~ "Drag legend object with mouse in pointer mode to position.\n"
 #~ "Double-click to change options.\n"
 #~ "Define raster map name for legend in properties dialog."
 #~ msgstr ""
-#~ "Ziehen Sie das Legenden-Objekt mit Maus im Zeiger-Modus in die gewünschte Position.\n"
+#~ "Ziehen Sie das Legenden-Objekt mit Maus im Zeiger-Modus in die gewünschte "
+#~ "Position.\n"
 #~ "Doppelklick ändert die Einstellung.\n"
-#~ "Geben Sie den Namen der Rasterkarte für die Legende im Eigenschaften-Dialog an."
+#~ "Geben Sie den Namen der Rasterkarte für die Legende im Eigenschaften-"
+#~ "Dialog an."
 #~ msgid ""
 #~ "Drag scale object with mouse in pointer mode to position.\n"
 #~ "Double-click to change options."
 #~ msgstr ""
-#~ "Ziehen Sie das Maßstabs-Objekt mit der Maus im Zeiger-Modus in die gewünschte Position.\n"
+#~ "Ziehen Sie das Maßstabs-Objekt mit der Maus im Zeiger-Modus in die "
+#~ "gewünschte Position.\n"
 #~ "Doppelklick ändert die Einstellung."
 #~ msgid "Legend of raster map <%s>"
@@ -18546,8 +19803,13 @@
 #~ "(C) 2011 GRASS Entwicklerteam\n"
 #~ "\n"
-#~ msgid "This program is free software under the GNU General Public License(>=v2). Read the file COPYING that comes with GRASS for details."
-#~ msgstr "Dieses Programm ist freie Software unter der GNU General Public License(>=v2). Lesen Sie für Details die Datei COPYING, die mit GRASS ausgeliefert wird."
+#~ msgid ""
+#~ "This program is free software under the GNU General Public License(>=v2). "
+#~ "Read the file COPYING that comes with GRASS for details."
+#~ msgstr ""
+#~ "Dieses Programm ist freie Software unter der GNU General Public "
+#~ "License(>=v2). Lesen Sie für Details die Datei COPYING, die mit GRASS "
+#~ "ausgeliefert wird."
 #~ msgid ""
 #~ "(C) 2010-%s by the GRASS Development Team\n"
@@ -18573,7 +19835,9 @@
 #~ msgstr "Auf Oberfläche(n) darstellen:"
 #~ msgid "Querying is not implemented in standalone mode of Map Display"
-#~ msgstr "Abfragen sind in der 'stand alone' Version des Kartenfensters nicht umgesetzt"
+#~ msgstr ""
+#~ "Abfragen sind in der 'stand alone' Version des Kartenfensters nicht "
+#~ "umgesetzt"
 #~ msgid "3D view settings"
 #~ msgstr "Einstellungen der 3D-Ansicht"
@@ -18581,17 +19845,24 @@
 #~ msgid "At least one raster map required"
 #~ msgstr "Mindestens eine Rasterkarte erfordert"
-#~ msgid "Inconsistent number of columns in the table <%(table)s>. Try to change field separator in GUI Settings, Attributes tab, Data browser section."
-#~ msgstr "Inkonsistente Spaltenanzahl in der Tabelle <%(table)s>. Versuchen Sie den Spaltentrenner in den GUI-Einstellungen/Attribute/Daten-Browser zu ändern."
+#~ msgid ""
+#~ "Inconsistent number of columns in the table <%(table)s>. Try to change "
+#~ "field separator in GUI Settings, Attributes tab, Data browser section."
+#~ msgstr ""
+#~ "Inkonsistente Spaltenanzahl in der Tabelle <%(table)s>. Versuchen Sie den "
+#~ "Spaltentrenner in den GUI-Einstellungen/Attribute/Daten-Browser zu ändern."
-#~ msgid "Field separator must be ASCII character not <%s> (use e.g. ';', '&', '#')"
-#~ msgstr "Feldtrenner muss ein ASCII-Zeichen sein, nicht <%s> (z.B. ';', '&', '#')"
+#~ msgid ""
+#~ "Field separator must be ASCII character not <%s> (use e.g. ';', '&', '#')"
+#~ msgstr ""
+#~ "Feldtrenner muss ein ASCII-Zeichen sein, nicht <%s> (z.B. ';', '&', '#')"
 #~ msgid "Field separator:"
 #~ msgstr "Feldtrenner:"
 #~ msgid "You must run this command from the menu or command line"
-#~ msgstr "Sie müssen diesen Befehl aus dem Menü oder der Kommandozeile starten"
+#~ msgstr ""
+#~ "Sie müssen diesen Befehl aus dem Menü oder der Kommandozeile starten"
 #~ msgid "Menu tree"
 #~ msgstr "Menue-Baum"
@@ -18620,27 +19891,42 @@
 #~ msgid "Solar irradiance and irradiation model."
 #~ msgstr "Modellierung der Sonnenstrahlungsdichte und -summe."
-#~ msgid "Calculates cast shadow areas from sun position and elevation raster map."
-#~ msgstr "Berechnet Schlagschatten aus der Sonnenposition und einer Höhenkarte."
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and elevation raster map."
+#~ msgstr ""
+#~ "Berechnet Schlagschatten aus der Sonnenposition und einer Höhenkarte."
-#~ msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
-#~ msgstr "Erzeugt Karten der Hangneigung, Exposition, Krümmung und partiellen Ableitungen aus einer Höhenkarte."
+#~ msgid ""
+#~ "Generates raster maps of slope, aspect, curvatures and partial "
+#~ "derivatives from a elevation raster map."
+#~ msgstr ""
+#~ "Erzeugt Karten der Hangneigung, Exposition, Krümmung und partiellen "
+#~ "Ableitungen aus einer Höhenkarte."
 #~ msgid "Extracts terrain parameters from a DEM."
 #~ msgid "Horizon angle computation from a digital elevation model."
-#~ msgstr "Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
+#~ msgstr ""
+#~ "Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
 #, fuzzy
 #~ msgid "Generates stream channels."
-#~ msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
-#~ msgstr "Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, Nebeneinanderstellung und Kanten"
+#~ msgid ""
+#~ "Contains a set of measures for attributes, diversity, texture, "
+#~ "juxtaposition, and edge."
+#~ msgstr ""
+#~ "Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, "
+#~ "Nebeneinanderstellung und Kanten"
-#~ msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
-#~ msgstr "Berechnet Attribute, Patch-Grösse, Kerngebiets-Grösse, Form, Fraktale Dimension und Umfang für ein Satz von Patches in einer Landschaft."
+#~ msgid ""
+#~ "Calculates attribute, patch size, core (interior) size, shape, fractal "
+#~ "dimension, and perimeter measures for sets of patches in a landscape."
+#~ msgstr ""
+#~ "Berechnet Attribute, Patch-Grösse, Kerngebiets-Grösse, Form, Fraktale "
+#~ "Dimension und Umfang für ein Satz von Patches in einer Landschaft."
 #, fuzzy
 #~ msgid "Reclassify raster map based on category values."
@@ -18655,17 +19941,25 @@
 #~ msgid "Splits net by cost isolines."
 #~ msgstr "Teilt das Netz durch Isokostenlinien."
-#~ msgid "Computes shortest distance via the network between the given sets of features."
-#~ msgstr "Berechnet kürzeste Distanzen im Netzwerk zwischen Gruppen von Objekten."
+#~ msgid ""
+#~ "Computes shortest distance via the network between the given sets of "
+#~ "features."
+#~ msgstr ""
+#~ "Berechnet kürzeste Distanzen im Netzwerk zwischen Gruppen von Objekten."
 #~ msgid "Create Steiner tree for the network and given terminals"
-#~ msgstr "Erzeuge 'Steiner Tree' für das Netzwerk und die gegebenen Stationen."
+#~ msgstr ""
+#~ "Erzeuge 'Steiner Tree' für das Netzwerk und die gegebenen Stationen."
 #~ msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-#~ msgstr "Erzeugt einen Ring, der die gegebenen Knoten verbindet (Handelsreisenden-Problem)."
+#~ msgstr ""
+#~ "Erzeugt einen Ring, der die gegebenen Knoten verbindet (Handelsreisenden-"
+#~ "Problem)."
 #~ msgid "Classifies the cell spectral reflectances in imagery data."
-#~ msgstr "Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
+#~ msgstr ""
+#~ "Klassifiziert die spektrale Reflektion (spectral reflectance) in "
+#~ "Bilddaten."
 #~ msgid "Copy a table."
 #~ msgstr "Kopiere eine Tabelle. "
@@ -18677,7 +19971,8 @@
 #~ msgstr "Kann Vorschau nicht erzeugen. %s"
 #~ msgid "Fetch list of available extensions by clicking on 'Fetch' button"
-#~ msgstr "Rufe Liste vorhandener Erweiterungen bei Klick auf  'Fetch' button ab"
+#~ msgstr ""
+#~ "Rufe Liste vorhandener Erweiterungen bei Klick auf  'Fetch' button ab"
 #~ msgid "%d items match"
 #~ msgstr "%d Objekte stimmen überein"
@@ -18734,7 +20029,8 @@
 #~ msgstr ""
 #~ "\n"
-#~ "Definieren Sie den Rasterkartennamen für die Legende im Eigenschaften-Dialog."
+#~ "Definieren Sie den Rasterkartennamen für die Legende im Eigenschaften-"
+#~ "Dialog."
 #~ msgid "Command dialog"
 #~ msgstr "Befehlsdialog"
@@ -18754,14 +20050,22 @@
 #~ msgid "Version"
 #~ msgstr "Version"
-#~ msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
-#~ msgstr "GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer Gauß'schen Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird verwendet."
+#~ msgid ""
+#~ "GRASS module to produce a raster map layer of gaussian deviates whose "
+#~ "mean and standard deviation can be expressed by the user. It uses a "
+#~ "gaussian random number generator."
+#~ msgstr ""
+#~ "GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer Gauß'schen "
+#~ "Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer "
+#~ "angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird "
+#~ "verwendet."
 #~ msgid "Reconnects vectors to a new database."
 #~ msgstr "Verbindet Vektor mit einer neuen Datenbank."
 #~ msgid "Fetch full info including description and keywords"
-#~ msgstr "Abruf der gesamten Information inklusive Beschreibung und Schlüsselworte"
+#~ msgstr ""
+#~ "Abruf der gesamten Information inklusive Beschreibung und Schlüsselworte"
 #~ msgid "Layer / Style"
 #~ msgstr "Layer / Style"
@@ -18782,8 +20086,16 @@
 #~ msgid "legend object"
 #~ msgstr "Legendenobjekt"
-#~ msgid "Note that the wxGUI's 3D view mode is currently disabled on MS Windows (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
-#~ msgstr "3D-Ansicht-Modus derzeit unter MS Windows nicht aktiviert (dies wird hoffentlich bald behoben sein). Bitte achten Sie auf aktualisierte Versionen von GRASS. In der Zwischenzeit können Sie \"NVIZ\" unter File menue verwenden."
+#~ msgid ""
+#~ "Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
+#~ "versions of GRASS. In the meantime you can use \"NVIZ\" from the File "
+#~ "menu."
+#~ msgstr ""
+#~ "3D-Ansicht-Modus derzeit unter MS Windows nicht aktiviert (dies wird "
+#~ "hoffentlich bald behoben sein). Bitte achten Sie auf aktualisierte "
+#~ "Versionen von GRASS. In der Zwischenzeit können Sie \"NVIZ\" unter File "
+#~ "menue verwenden."
 #~ msgid "Comp. region"
 #~ msgstr "Arbeitsbereich"
@@ -18818,8 +20130,14 @@
 #~ msgid "values"
 #~ msgstr "Werte"
-#~ msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
-#~ msgstr "Zeigt die Grenze von jedem r.le patch und deren Verlauf, zeigt das Attribut, Größe, Umfang und Flächenindizes jedes Patches und speichert die Daten in einer Ergebnisdatei "
+#~ msgid ""
+#~ "Displays the boundary of each r.le patch and shows how the boundary is "
+#~ "traced, displays the attribute, size, perimeter and shape indices for "
+#~ "each patch and saves the data in an output file."
+#~ msgstr ""
+#~ "Zeigt die Grenze von jedem r.le patch und deren Verlauf, zeigt das "
+#~ "Attribut, Größe, Umfang und Flächenindizes jedes Patches und speichert "
+#~ "die Daten in einer Ergebnisdatei "
 #~ msgid "Attribute query"
 #~ msgstr "Attributabfrage"
@@ -18917,8 +20235,12 @@
 #~ msgid "Cl&ear"
 #~ msgstr "&Säubere"
-#~ msgid "Vector map <%s> already exists. Change extension name and georectify again."
-#~ msgstr "Die Vektorkarte <%s> existiert bereits. Ändern Sie die Namenserweiterung und georektifizieren Sie erneut."
+#~ msgid ""
+#~ "Vector map <%s> already exists. Change extension name and georectify "
+#~ "again."
+#~ msgstr ""
+#~ "Die Vektorkarte <%s> existiert bereits. Ändern Sie die Namenserweiterung "
+#~ "und georektifizieren Sie erneut."
 #~ msgid "For all vector maps georectified successfully,"
 #~ msgstr "Für alle erfolgreich georektifizierten Vektorkarten,  "
@@ -19057,15 +20379,21 @@
 #~ msgid "Please select attribute column and RGB color column first"
 #~ msgstr "Bitte wählen Sie zuerst die Attributspalte und die RGB-Farbspalte."
-#~ msgid "Color table already exists. Check out 'replace existing color table' to overwrite it."
-#~ msgstr "Farbtabelle existiert bereits. Wählen Sie 'replace existing color table', um diese zu überschreiben."
+#~ msgid ""
+#~ "Color table already exists. Check out 'replace existing color table' to "
+#~ "overwrite it."
+#~ msgstr ""
+#~ "Farbtabelle existiert bereits. Wählen Sie 'replace existing color table', "
+#~ "um diese zu überschreiben."
 #~ msgid "Close current"
 #~ msgstr "Aktuelles einklappen "
 #, fuzzy
 #~ msgid "Lists available GIS elements of the user-specified data type."
-#~ msgstr "Listet alle verfügbaren GRASS Datenbankdateien im spezifiezierten Typ im Standard Output auf"
+#~ msgstr ""
 #~ msgid "Postscript plot"
 #~ msgstr "Postscript Plot"
@@ -19115,7 +20443,9 @@
 #, fuzzy
 #~ msgid "Unable to fetch interface description for command '%s'."
-#~ msgstr "Kann die Interface-Beschreibung für den Befehl '%s' nicht ermitteln. Details: %s"
+#~ msgstr ""
+#~ "Kann die Interface-Beschreibung für den Befehl '%s' nicht ermitteln. "
+#~ "Details: %s"
 #, fuzzy
 #~ msgid "Menu style:"
@@ -19124,8 +20454,12 @@
 #~ msgid "Icon theme:"
 #~ msgstr "Symbol-Design:"
-#~ msgid "Note: For changing the icon theme, you must save the settings and restart this GUI."
-#~ msgstr "Hinweis: Um das Symbol-Design zu ändern müssen die Einstellungen gespeichert werden und das GUI erneut gestartet werden."
+#~ msgid ""
+#~ "Note: For changing the icon theme, you must save the settings and restart "
+#~ "this GUI."
+#~ msgstr ""
+#~ "Hinweis: Um das Symbol-Design zu ändern müssen die Einstellungen "
+#~ "gespeichert werden und das GUI erneut gestartet werden."
 #, fuzzy
 #~ msgid "No mapsets available in location <%s>"
@@ -19232,7 +20566,9 @@
 #~ msgstr "Füge keine Kategorien zu Flächengrenzen hinzu"
 #~ msgid "Unable to encode text. Please set encoding in GUI preferences."
-#~ msgstr "Kann den Text nicht kodieren. Bitte definieren Sie die Kodierung in den GUI Einstellungen."
+#~ msgstr ""
+#~ "Kann den Text nicht kodieren. Bitte definieren Sie die Kodierung in den "
+#~ "GUI Einstellungen."
 #, fuzzy
 #~ msgid "Adjust display zoom"
@@ -19262,8 +20598,12 @@
 #~ msgid "ASCII polygons and lines import"
 #~ msgstr "Importiere ASCII Polygone und Zeilen"
-#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
-#~ msgstr "Konvertiert ein ESRI ARC/INFO ASCII-Raster (GRID) in eine (binäre) GRASS Rasterkarte."
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "Konvertiert ein ESRI ARC/INFO ASCII-Raster (GRID) in eine (binäre) GRASS "
+#~ "Rasterkarte."
 #~ msgid "Import of SPOT VGT NDVI file into a raster map"
 #~ msgstr "Importiere eine SPOT VGT NDVI Datei in eine Rasterkarte"
@@ -19271,8 +20611,12 @@
 #~ msgid "Import SRTM HGT files into GRASS"
 #~ msgstr "Importiere SRTM (.hgt) Daten"
-#~ msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
-#~ msgstr "Georeferenzieren, entzerren und Importieren von Terra-ASTER Bildern und entsprechende DHM mit gdalwarp."
+#~ msgid ""
+#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+#~ "using gdalwarp."
+#~ msgstr ""
+#~ "Georeferenzieren, entzerren und Importieren von Terra-ASTER Bildern und "
+#~ "entsprechende DHM mit gdalwarp."
 #~ msgid "Downloads and imports data from WMS servers"
 #~ msgstr "Lade und importiere Daten von einem WMS-Server"
@@ -19281,7 +20625,8 @@
 #~ msgstr "ASCII Punkte/GRASS ASCII Vektorimport"
 #~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
-#~ msgstr "Erstelle eine Vektorkarte aus ASCII Punktdaten oder ASCII Vektordaten."
+#~ msgstr ""
+#~ "Erstelle eine Vektorkarte aus ASCII Punktdaten oder ASCII Vektordaten."
 #~ msgid "Import GetFeature from WFS"
 #~ msgstr "Importiere GetFeature von einem WFS-Server"
@@ -19289,14 +20634,22 @@
 #~ msgid "Garmin GPS import"
 #~ msgstr "Garmin GPS Import"
-#~ msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
-#~ msgstr "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Empfänger in eine Verktorkarte."
+#~ msgid ""
+#~ "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+#~ "vector map."
+#~ msgstr ""
+#~ "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Empfänger in eine "
+#~ "Verktorkarte."
 #~ msgid "GPSBabel GPS import"
 #~ msgstr "GPSBabel GPS Import"
-#~ msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
-#~ msgstr "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Empfänger oder direkt GPS Daten in eine Verktorkarte."
+#~ msgid ""
+#~ "Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+#~ "file into a vector map."
+#~ msgstr ""
+#~ "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Empfänger oder "
+#~ "direkt GPS Daten in eine Verktorkarte."
 #~ msgid "Converts a raster map layer into an ASCII text file."
 #~ msgstr "Exportiert eine Rasterkarte in eine ASCII-Textdatei."
@@ -19307,17 +20660,29 @@
 #~ msgid "Binary export"
 #~ msgstr "Export in Binärdatei"
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#~ msgstr "Exportiere GRASS Rasterkarte in ein PPM-Bild. Die Pixelauflösung wird aus der aktuellen Regions-Einstellung übernommen."
+#~ msgid ""
+#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
+#~ "of the currently defined region."
+#~ msgstr ""
+#~ "Exportiere GRASS Rasterkarte in ein PPM-Bild. Die Pixelauflösung wird aus "
+#~ "der aktuellen Regions-Einstellung übernommen."
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung der DERZEITIG EINGESTELLTEN REGION."
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-"
+#~ "Auflösung der DERZEITIG EINGESTELLTEN REGION."
 #~ msgid "Converts a raster map layer into a height-field file for POVRAY."
 #~ msgstr "Exportiert eine Rasterkarte in eine Höhenfeld-Datei für POVRAY."
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
-#~ msgstr "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die Pixelauflösung wird aus der aktuellen Regions-Einstellung übernommen."
+#~ msgid ""
+#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
+#~ "resolution of the currently defined region."
+#~ msgstr ""
+#~ "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die "
+#~ "Pixelauflösung wird aus der aktuellen Regions-Einstellung übernommen."
 #~ msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
 #~ msgstr "Exportiert eine Rasterkarte in eine VRML Datei"
@@ -19329,7 +20694,9 @@
 #~ msgstr "ASCII Punkte/GRASS ASCII Vektor Export"
 #~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr "Konvertiert eine binäre GRASS Vektor Karte in eine GRASS ASCII Vektor Karte"
+#~ msgstr ""
+#~ "Konvertiert eine binäre GRASS Vektor Karte in eine GRASS ASCII Vektor "
+#~ "Karte"
 #~ msgid "Exports GRASS vector map layers to DXF file format."
 #~ msgstr "Exportiert GRASS Vektorkartenkarten in das DXF Format."
@@ -19349,17 +20716,24 @@
 #~ msgid "Converts a raster map into a vector map layer."
 #~ msgstr "Konvertiert eine Rasterkarte in eine Vektorkarte."
-#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
-#~ msgstr "Konvertiert eine GRASS Vektorkarte (nur Punkte) in eine 3D GRASS Rasterkarte."
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr ""
+#~ "Konvertiert eine GRASS Vektorkarte (nur Punkte) in eine 3D GRASS "
+#~ "Rasterkarte."
 #~ msgid "Change default GUI"
 #~ msgstr "Wechsle das Standard GUI"
 #~ msgid "Changes the default GRASS graphical user interface (GUI) setting."
-#~ msgstr "Ändert die Standardeinstellung für die graphische Benutzeroberfläche (GUI) von GRASS."
+#~ msgstr ""
+#~ "Ändert die Standardeinstellung für die graphische Benutzeroberfläche "
+#~ "(GUI) von GRASS."
 #~ msgid "Print projection information (in conventional GRASS format)."
-#~ msgstr "Gebe die Projektionsinformation aus (im konventionellen GRASS-Format)."
+#~ msgstr ""
+#~ "Gebe die Projektionsinformation aus (im konventionellen GRASS-Format)."
 #~ msgid "Change projection for current location"
 #~ msgstr "Ändere Projektion der aktuellen Location"
@@ -19368,19 +20742,29 @@
 #~ msgstr "Interaktive Änderung der Projektions-Einstellung der Location."
 #~ msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-#~ msgstr "Konvertiert Koordinaten zwischen versch. Projektionen (Frontend für cs2cs)."
+#~ msgstr ""
+#~ "Konvertiert Koordinaten zwischen versch. Projektionen (Frontend für "
+#~ "cs2cs)."
 #~ msgid "Digitize raster (requires XTerm)"
 #~ msgstr "Raster digitalisieren (erfordert XTerm)"
-#~ msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
-#~ msgstr "Interaktives Werkzeug, um Vektorobjekte in einem Kartenfenster mit der Maus zu zeichnen und als Rasterkarte zu speichern."
+#~ msgid ""
+#~ "Interactive tool used to draw and save vector features on a graphics "
+#~ "monitor using a pointing device (mouse) and save to a raster map."
+#~ msgstr ""
+#~ "Interaktives Werkzeug, um Vektorobjekte in einem Kartenfenster mit der "
+#~ "Maus zu zeichnen und als Rasterkarte zu speichern."
 #~ msgid "Set color rules based on stddev from a map's mean value."
 #~ msgstr "Bestimme Farbregeln basierend auf der Standardabweichung."
-#~ msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
-#~ msgstr "Erzeugt eine Rasterkarte mit Pufferzonen um Pixel, die keine NULL-Werte haben."
+#~ msgid ""
+#~ "Creates a raster map layer showing buffer zones surrounding cells that "
+#~ "contain non-NULL category values."
+#~ msgstr ""
+#~ "Erzeugt eine Rasterkarte mit Pufferzonen um Pixel, die keine NULL-Werte "
+#~ "haben."
 #~ msgid "Map calculator for raster map algebra."
 #~ msgstr "Kartenrechner für Rasterkarten-Algebra."
@@ -19389,10 +20773,13 @@
 #~ msgstr "Berechnet kategorie- oder objektorientierte Statistik."
 #~ msgid "Generates a raster map layer of distance to features in input layer."
-#~ msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Objekten in der Eingabekarte."
+#~ msgstr ""
+#~ "Erzeugt eine Rasterkarte mit Distanzen zu Objekten in der Eingabekarte."
 #~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr "Dünnt Non-Zero-Zellen aus, die in einer Rasterkarte Linienstrukturen darstellen."
+#~ msgstr ""
+#~ "Dünnt Non-Zero-Zellen aus, die in einer Rasterkarte Linienstrukturen "
+#~ "darstellen."
 #~ msgid "Watershed basin analysis program."
 #~ msgstr "Analyseprogramme für Wassereinzugsgebiete."
@@ -19403,8 +20790,12 @@
 #~ msgid "Set up (requires XTerm)"
 #~ msgstr "Setup (erfordert XTerm)"
-#~ msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
-#~ msgstr "Interaktives Werkzeug zur Erzeugung eine Stichprobe- und Analyse-Rahmens, welche von den anderen r.le-Progammen verwendet werden. "
+#~ msgid ""
+#~ "Interactive tool used to setup the sampling and analysis framework that "
+#~ "will be used by the other r.le programs."
+#~ msgstr ""
+#~ "Interaktives Werkzeug zur Erzeugung eine Stichprobe- und Analyse-Rahmens, "
+#~ "welche von den anderen r.le-Progammen verwendet werden. "
 #~ msgid "Bilinear from raster points"
 #~ msgstr "Bilinear aus Rasterpunkten"
@@ -19436,26 +20827,38 @@
 #~ msgid "Extrudes flat vector object to 3D with defined height."
 #~ msgstr "Presst flache Vektorobjekte in eine 3D-Form mit definierter Höhe."
-#~ msgid "Set color rules for features in a vector using a numeric attribute column."
-#~ msgstr "Bestimme Farbregeln für Objekte einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
+#~ msgid ""
+#~ "Set color rules for features in a vector using a numeric attribute column."
+#~ msgstr ""
+#~ "Bestimme Farbregeln für Objekte einer Vektorkarte unter Verwendung einer "
+#~ "numerischen Spalte der Attributtabelle."
 #~ msgid "Queries a vector map layer at given locations."
 #~ msgstr "Fragt eine Vektorkarten an gegebenen Positionen ab."
-#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
-#~ msgstr "Erzeugt einen Buffer um Objekte bestimmten Typs (Flächen müssen Zentroide enthalten)."
+#~ msgid ""
+#~ "Creates a buffer around features of given type (areas must contain "
+#~ "centroid)."
+#~ msgstr ""
+#~ "Erzeugt einen Buffer um Objekte bestimmten Typs (Flächen müssen Zentroide "
+#~ "enthalten)."
 #~ msgid "Create a new vector map layer by combining other vector map layers."
-#~ msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten."
+#~ msgstr ""
+#~ "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten."
 #~ msgid "Attach, delete or report vector categories to map geometry."
-#~ msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
+#~ msgstr ""
+#~ "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
 #~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
+#~ msgstr ""
+#~ "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
 #~ msgid "Create points along input lines in new vector with 2 layers."
-#~ msgstr "Erzeuge Punkte entlang der Eingabelinien in neue Vektorkarte mit zwei Layern."
+#~ msgstr ""
+#~ "Erzeuge Punkte entlang der Eingabelinien in neue Vektorkarte mit zwei "
+#~ "Layern."
 #~ msgid "Randomly generate a 2D/3D vector points map."
 #~ msgstr "Erzeugt zufällige 2D/3D GRASS Vektor-Punktkarten."
@@ -19463,11 +20866,17 @@
 #~ msgid "Random location perturbations of GRASS vector points"
 #~ msgstr "Zufällige Mischung der Positionen von GRASS Vektorpunkten."
-#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-#~ msgstr "Berechnet univariate Statistik einer Rasterkarte, basierend auf Polygone und ergänzt die Ergebnisse als neue Spalte der Attributtabelle."
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ msgstr ""
+#~ "Berechnet univariate Statistik einer Rasterkarte, basierend auf Polygone "
+#~ "und ergänzt die Ergebnisse als neue Spalte der Attributtabelle."
 #~ msgid "Outputs basic information about a user-specified vector map."
-#~ msgstr "Gibt grundlegende Informationen über eine benutzerdefinierte Vektorkarte aus."
+#~ msgstr ""
+#~ "Gibt grundlegende Informationen über eine benutzerdefinierte Vektorkarte "
+#~ "aus."
 #~ msgid "Reports geometry statistics for vectors."
 #~ msgstr "Gibt statistische Werte für Geometrie der Vektorobjekte aus."
@@ -19476,7 +20885,9 @@
 #~ msgstr "Test auf Normalverteilung für Punkte."
 #~ msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-#~ msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
+#~ msgstr ""
 #~ msgid "Ortho photo rectification (requires Xterm)"
 #~ msgstr "Orthophoto Rektifizierung (erfordert Xterm)"
@@ -19488,31 +20899,41 @@
 #~ msgstr "Kartenrechner für 3D Rasterkarten-Algebra"
 #~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr "Gibt oder setzt allgemeine Datenbankverbindung für das aktuelle Mapset und beendet sich."
+#~ msgstr ""
+#~ "Gibt oder setzt allgemeine Datenbankverbindung für das aktuelle Mapset "
+#~ "und beendet sich."
 #~ msgid "Display the HTML man pages of GRASS"
 #~ msgstr "Zeige die HTML-Handbuchseite von GRASS."
 #~ msgid ""
-#~ "Unable to initialize display driver of vector digitizer. See 'Command output' for details.\n"
 #~ "\n"
 #~ "Details: "
 #~ msgstr ""
-#~ "Kann die Anzeige für die Vektordigitalisierung nicht initialisieren. Siehe 'Command output' für Details.\n"
+#~ "Kann die Anzeige für die Vektordigitalisierung nicht initialisieren. "
+#~ "Siehe 'Command output' für Details.\n"
 #~ "\n"
 #~ "Details:"
 #~ msgid ""
 #~ "Unable to open vector map <%s> for editing.\n"
 #~ "\n"
-#~ "Data are probably corrupted, try to run v.build to rebuild the topology (Vector->Develop vector map->Create/rebuild topology)."
+#~ "Data are probably corrupted, try to run v.build to rebuild the topology "
+#~ "(Vector->Develop vector map->Create/rebuild topology)."
 #~ msgstr ""
 #~ "Kann die Vektorkarte <%s> nicht zum Editieren öffnen.\n"
 #~ "\n"
-#~ "Daten sind vermutlich beschädigt. Versuchen Sie v.build auszuführen, um die Topologie wiederherzustellen (Vektor->Vektorkarten pflegen->Topologie erzeugen/wiederherstellen)."
+#~ "Daten sind vermutlich beschädigt. Versuchen Sie v.build auszuführen, um "
+#~ "die Topologie wiederherzustellen (Vektor->Vektorkarten pflegen->Topologie "
+#~ "erzeugen/wiederherstellen)."
-#~ msgid "Module r.mapcalc cannot be used in the model. Use r.mapcalculator instead."
-#~ msgstr "Modul r.mapcalc kann im Modell nicht benützt werden. Verwenden sie stattdessen r.mapcalculator."
+#~ msgid ""
+#~ "Module r.mapcalc cannot be used in the model. Use r.mapcalculator instead."
+#~ msgstr ""
+#~ "Modul r.mapcalc kann im Modell nicht benützt werden. Verwenden sie "
+#~ "stattdessen r.mapcalculator."
 #~ msgid "Show Help"
 #~ msgstr "Zeige Hilfe"
@@ -19520,8 +20941,12 @@
 #~ msgid "Show Help for GCP Manager"
 #~ msgstr "Zeige Hilfe für GCP Manager"
-#~ msgid "Unable to initialize display driver of vector digitizer. See 'Command output' for details."
-#~ msgstr "Kann die Anzeige für die Vektordigitalisierung nicht initialisieren. Siehe 'Command output' für Details."
+#~ msgid ""
+#~ "output' for details."
+#~ msgstr ""
+#~ "Siehe 'Command output' für Details."
 #~ msgid "Unable to initialize display driver of vector digitizer"
 #~ msgstr "Kann die Anzeige für die Vektordigitalisierung nicht initialisieren"
@@ -19556,23 +20981,32 @@
 #~ msgid "Bulk link of raster data"
 #~ msgstr "Massen-Verknüpfung von Rasterdaten"
-#~ msgid "Link multiple GDAL supported raster maps as pseudo GRASS raster map layers."
-#~ msgstr "Verknüpfe mehrere GDAL-Rasterdaten mit GRASS als Pseudo-Rasterkarten."
+#~ msgid ""
+#~ "Link multiple GDAL supported raster maps as pseudo GRASS raster map "
+#~ "layers."
+#~ msgstr ""
+#~ "Verknüpfe mehrere GDAL-Rasterdaten mit GRASS als Pseudo-Rasterkarten."
 #~ msgid "Bulk import of vector data"
 #~ msgstr "Massen-Import von Vektordaten"
 #~ msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr"
-#~ msgstr "Konvertiert selektierte OGR-Datensätze zu GRASS Vektorkarten mit v.in.ogr"
+#~ msgstr ""
+#~ "Konvertiert selektierte OGR-Datensätze zu GRASS Vektorkarten mit v.in.ogr"
 #~ msgid "Creates a new vector as a read-only link to OGR layer."
-#~ msgstr "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu einem OGR-Layer."
+#~ msgstr ""
+#~ "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu "
+#~ "einem OGR-Layer."
 #~ msgid "Bulk link of vector data"
 #~ msgstr "Massen-Verknüpfung von Vektordaten"
-#~ msgid "Creates multiple new pseduo-vector maps as a read-only links using OGR."
-#~ msgstr "Erzeugt mehrere neue Pseudo-Vektorkarte als nur lesbare Verknüpfung zu OGR-Layeren."
+#~ msgid ""
+#~ "Creates multiple new pseduo-vector maps as a read-only links using OGR."
+#~ msgstr ""
+#~ "Erzeugt mehrere neue Pseudo-Vektorkarte als nur lesbare Verknüpfung zu "
+#~ "OGR-Layeren."
 #~ msgid "Bulk import of DXF"
 #~ msgstr "Massen-Import von DXF"
@@ -19593,8 +21027,11 @@
 #~ msgstr "Neukodieren der Kategorien mit einer Regel-Datei"
 #, fuzzy
-#~ msgid "r.recode.file - Use ascii rules file to recode categories in raster map"
-#~ msgstr "r.recode.rules - Verwenden Sie ASCII-Regeldateien, um eine Rasterkarte umzukodieren."
+#~ msgid ""
+#~ "r.recode.file - Use ascii rules file to recode categories in raster map"
+#~ msgstr ""
+#~ "umzukodieren."
 #~ msgid "Allows projection conversion of vector maps."
 #~ msgstr "Ermöglicht die Umwandlung der Projektion von Vektorkarten."
@@ -19615,7 +21052,9 @@
 #~ msgstr "GRASS GIS Kartenfenster: 1"
 #~ msgid "Select image/map to display for ground control point (GCP) creation"
-#~ msgstr "Wählen Sie ein Bild/Karte, die für die Erzeugung der Ground Control Points (GCPs) angezeigt werden soll."
+#~ msgstr ""
+#~ "Wählen Sie ein Bild/Karte, die für die Erzeugung der Ground Control "
+#~ "Points (GCPs) angezeigt werden soll."
 #~ msgid "Select display image/map:"
 #~ msgstr "Wähle anzuzeigendes Bild/Karte:"
@@ -19639,7 +21078,8 @@
 #~ msgstr "Georektifikationseinstellungen"
 #~ msgid "RMS error for selected points forward: %(fwd)s backward: %(bkw)s"
-#~ msgstr "RMS-Fehler für selektierte Punkte vorwärts: %(fwd)s rückwärts: %(bkw)s"
+#~ msgstr ""
+#~ "RMS-Fehler für selektierte Punkte vorwärts: %(fwd)s rückwärts: %(bkw)s"
 #~ msgid "Y coord"
 #~ msgstr "Y Koordinate"
@@ -19735,7 +21175,9 @@
 #~ msgstr "Finde den kürzesten Weg für selektierten Start- und Endknoten"
 #~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer Hülle zu erzeugen."
+#~ msgstr ""
+#~ "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer "
+#~ "Hülle zu erzeugen."
 #~ msgid "GRASS GIS GUI help"
 #~ msgstr "GRASS GIS GUI-Hilfe"
@@ -19778,7 +21220,8 @@
 #~ "Details: %s"
 #~ msgstr ""
 #~ "Kann Vektordigitalisierer nicht starten.\n"
-#~ "Die VDigit Python-Erweiterung konnte nicht gefunden werden oder wurde nicht korrekt geladen.\n"
+#~ "Die VDigit Python-Erweiterung konnte nicht gefunden werden oder wurde "
+#~ "nicht korrekt geladen.\n"
 #~ "Schalte zurück auf 2D Grafikausgabe.\n"
 #~ "\n"
 #~ "Einzelheiten: %s"
@@ -19791,7 +21234,8 @@
 #~ "Details: %s"
 #~ msgstr ""
 #~ "Kann 3D-Anzeige nicht starten.\n"
-#~ "Die GLCanvas Klasse wurde in dieser Version von wxPython nicht mitgeliefert!\n"
+#~ "Die GLCanvas Klasse wurde in dieser Version von wxPython nicht "
+#~ "mitgeliefert!\n"
 #~ "\n"
@@ -19839,7 +21283,9 @@
 #~ msgstr "Mehrfachverbindung zu OGR"
 #~ msgid "Creates a new vectors as a read-only link to OGR layers"
-#~ msgstr "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu einem OGR-Layer"
+#~ msgstr ""
+#~ "einem OGR-Layer"
 #~ msgid "Multiple DXF layers import"
 #~ msgstr "Importiere mehrere DXF Datensätze"
@@ -19880,8 +21326,13 @@
 #~ msgid "Choose DXF file:"
 #~ msgstr "Wählen Sie DXF-Datei:"
-#~ msgid "Check mapset to make it accessible, uncheck it to hide it.%sNote: PERMANENT and current mapset are always accessible."
-#~ msgstr "Aktiviere das Mapset, um es zugägnlich zu machen und deaktiviere um es zu verbergen. %sBemerkung: PERMANENT und das aktuelle Mapset sind immer zugänglich."
+#~ msgid ""
+#~ "Check mapset to make it accessible, uncheck it to hide it.%sNote: "
+#~ "PERMANENT and current mapset are always accessible."
+#~ msgstr ""
+#~ "Aktiviere das Mapset, um es zugägnlich zu machen und deaktiviere um es zu "
+#~ "verbergen. %sBemerkung: PERMANENT und das aktuelle Mapset sind immer "
+#~ "zugänglich."
 #~ msgid "GRASS %s Map Calculator"
 #~ msgstr "GRASS %s Kartenrechner"
@@ -19889,20 +21340,26 @@
 #~ msgid "Create & manage ground control points"
 #~ msgstr "Erzeuge & verwalte Ground Control Points"
-#~ msgid "Unable to determine default DB connection settings. Please define DB connection using db.connect module."
-#~ msgstr "Kann die Standardeinstellungen der Datenbankverbindung nicht ermitteln. Bitte definieren Sie eine DB-Verbindung mit dem Modul db.connect."
+#~ msgid ""
+#~ "Unable to determine default DB connection settings. Please define DB "
+#~ "connection using db.connect module."
+#~ msgstr ""
+#~ "Kann die Standardeinstellungen der Datenbankverbindung nicht ermitteln. "
+#~ "Bitte definieren Sie eine DB-Verbindung mit dem Modul db.connect."
 #~ msgid "Import raster map"
 #~ msgstr "Importiere Rasterkarte"
 #~ msgid "Converts selected GDAL layers to GRASS raster maps using r.in.gdal"
-#~ msgstr "Konvertiert ausgewählte GDAL-Layer in GRASS Rasterkarte mittels r.in.gdal"
+#~ msgstr ""
+#~ "Konvertiert ausgewählte GDAL-Layer in GRASS Rasterkarte mittels r.in.gdal"
 #~ msgid "Link GDAL supported raster files to a binary raster map layers"
 #~ msgstr "Verbinde GDAL-unterstützte Rasterdaten als Rasterkarte"
 #~ msgid "Converts selected DXF layers to GRASS vector maps (using v.in.dxf)"
-#~ msgstr "Konvertiert selektierte DXF-Layer zu GRASS Vektorkarten (mit v.in.dxf)"
+#~ msgstr ""
+#~ "Konvertiert selektierte DXF-Layer zu GRASS Vektorkarten (mit v.in.dxf)"
 #~ msgid "Map calculator for raster map algebra"
 #~ msgstr "Kartenrechner für Rasterkarten-Algebra"
@@ -19913,8 +21370,12 @@
 #~ msgid "Finds shortest path for selected starting and ending node."
 #~ msgstr "Findet den kürzesten Weg von einem Start- zu einem Endpunktsknoten."
-#~ msgid "Creates and adds a new attribute table to a given layer of an existing vector map."
-#~ msgstr "Erzeugt eine neue Attributtabelle für einen Layer einer existierenden Vektorkarte."
+#~ msgid ""
+#~ "Creates and adds a new attribute table to a given layer of an existing "
+#~ "vector map."
+#~ msgstr ""
+#~ "Erzeugt eine neue Attributtabelle für einen Layer einer existierenden "
+#~ "Vektorkarte."
 #~ msgid "Reconnect vector to database"
 #~ msgstr "Verbinde Vektor erneut mit Datenbank"
@@ -19926,19 +21387,31 @@
 #~ msgstr "GRASS_PYCMDFILE - Datei nicht gefunden. Starte p.mon."
 #~ msgid "Tool to maintain GRASS extensions in local GRASS installation."
-#~ msgstr "Werkzeug zur Verwaltung von GRASS-Erweiterungen in der lokalen GRASS-Installation."
+#~ msgstr ""
+#~ "Werkzeug zur Verwaltung von GRASS-Erweiterungen in der lokalen GRASS-"
+#~ "Installation."
 #~ msgid "Raster File Series to MPEG Conversion."
 #~ msgstr "Konvertierung von Serien von Rasterkarten zu einem MPEG-Film."
-#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
+#~ msgid ""
+#~ "Converts GRASS vector map to one of the supported OGR vector formats."
 #~ msgstr "Konvertiert GRASS Vektorkarte in ein von OGR unterstütztes Format."
-#~ msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
-#~ msgstr "Kopiert verfügbare Daten aus dem aktuellen Suchpfad des Mapsets und der Location des Benutzers in die entsprechenden Verzeichnisse im aktuellen Mapset."
+#~ msgid ""
+#~ "Copies available data files in the user's current mapset search path and "
+#~ "location to the appropriate element directories under the user's current "
+#~ "mapset."
+#~ msgstr ""
+#~ "Kopiert verfügbare Daten aus dem aktuellen Suchpfad des Mapsets und der "
+#~ "Location des Benutzers in die entsprechenden Verzeichnisse im aktuellen "
+#~ "Mapset."
-#~ msgid "Hardcopy Map Output Utility is not available. You can install it by %s"
-#~ msgstr "Hardcopy Map Output Utility ist nicht verfügbar. Sie können es mit %s installieren"
+#~ msgid ""
+#~ "Hardcopy Map Output Utility is not available. You can install it by %s"
+#~ msgstr ""
+#~ "Hardcopy Map Output Utility ist nicht verfügbar. Sie können es mit %s "
+#~ "installieren"
 #~ msgid "3D view mode tools"
 #~ msgstr "3D Ansicht-Werkszeugsleiste"
@@ -19952,14 +21425,21 @@
 #~ msgid "Imports geonames.org country files into a GRASS vector points map."
 #~ msgstr "Importiert Länderdateien von geonames.org in eine Vektorpunktkarte."
-#~ msgid "Export a raster map to a text file as x,y,z values based on cell centers."
-#~ msgstr "Exportiert eine Rasterkarte in eine Textdatei (x,y,z-werte; Zentrum der Zellen)"
+#~ msgid ""
+#~ "Export a raster map to a text file as x,y,z values based on cell centers."
+#~ msgstr ""
+#~ "Exportiert eine Rasterkarte in eine Textdatei (x,y,z-werte; Zentrum der "
+#~ "Zellen)"
 #~ msgid "Export GRASS raster as non-georeferenced PNG image."
 #~ msgstr "Exportiere GRASS Raster als nicht georeferenziertes PNG-Bild."
-#~ msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-#~ msgstr "Exportiert eine Vektorkarte in ein GPS-Gerät oder als von GPSBabel unterstütztes Datenformat."
+#~ msgid ""
+#~ "Exports a vector map to a GPS receiver or file format supported by "
+#~ "GpsBabel."
+#~ msgstr ""
+#~ "Exportiert eine Vektorkarte in ein GPS-Gerät oder als von GPSBabel "
+#~ "unterstütztes Datenformat."
 #~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
 #~ msgstr "Konvertiert eine 3D-Rasterkarte (G3D) in das VTK-ASCII-Format."
@@ -19973,8 +21453,12 @@
 #~ msgid "Interactively edit cell values in a raster map."
 #~ msgstr "Editiere interaktiv Zellwerte einer Rasterkarte."
-#~ msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
-#~ msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
+#~ msgid ""
+#~ "Selects vector objects from an existing vector map and creates a new map "
+#~ "containing only the selected objects."
+#~ msgstr ""
+#~ "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine "
+#~ "neue Karte nur mit den selektierten Objekten."
 #~ msgid "Allocate subnets for nearest centres (direction from centre)."
 #~ msgstr "Allokiere Teilnetze für das nächste Zentrum (Richtung vom Zentrum)."
@@ -20020,15 +21504,24 @@
 #~ "\n"
 #~ "New attribute table can be created by Attribute Table Manager."
 #~ msgstr ""
-#~ "Es ist keine Attributtabelle mit der Vektorkarte <%(vector)s> verlinkt. %(msg)s\n"
+#~ "Es ist keine Attributtabelle mit der Vektorkarte <%(vector)s> verlinkt. "
+#~ "%(msg)s\n"
 #~ "\n"
-#~ "Eine neue Attributtabelle kann mit dem Attributtabellenmanager erzeugt werden."
+#~ "Eine neue Attributtabelle kann mit dem Attributtabellenmanager erzeugt "
+#~ "werden."
-#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte."
+#~ msgid ""
+#~ "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+#~ msgstr ""
+#~ "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-"
+#~ "Rasterkarte."
-#~ msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
-#~ msgstr "Importiere 3-dimensionale Vis5D Daten (z.B. die v5d-Daten mit einer Variablen und einem Zeitstempel)."
+#~ msgid ""
+#~ "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and "
+#~ "1 time step)."
+#~ msgstr ""
+#~ "Importiere 3-dimensionale Vis5D Daten (z.B. die v5d-Daten mit einer "
+#~ "Variablen und einem Zeitstempel)."
 #~ msgid "Converts a 3D raster map layer into an ASCII text file."
 #~ msgstr "Exportiert eine 3D-Rasterkarte in eine ASCII-Textdatei."
@@ -20036,11 +21529,19 @@
 #~ msgid "Topographic correction"
 #~ msgstr "Topographische Korrektur"
-#~ msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
-#~ msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
+#~ msgid ""
+#~ "Creates cross section 2D raster map from 3D raster map based on 2D "
+#~ "elevation map."
+#~ msgstr ""
+#~ "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
+#~ "Rasterkarte basierend auf 2D-Höhenkarte."
-#~ msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
-#~ msgstr "Programm zur numerischen Berechnung des transienten, beschränkten Grundwasserflusses in drei Dimensionen."
+#~ msgid ""
+#~ "Calculates numerically transient, confined groundwater flow in three "
+#~ "dimensions."
+#~ msgstr ""
+#~ "Programm zur numerischen Berechnung des transienten, beschränkten "
+#~ "Grundwasserflusses in drei Dimensionen."
 #~ msgid "'%(cmd)s' failed. Details: %(det)s"
 #~ msgstr "'%(cmd)s' fehlgeschlagen. Einzelheiten: %(det)s"
@@ -20054,17 +21555,27 @@
 #~ msgid "Output basic information about a raster map layer."
 #~ msgstr "Gebe grundlegende Informationen über eine Rasterkarte aus."
-#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
-#~ msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
+#~ msgid ""
+#~ "Creates a Voronoi diagram from an input vector map containing points or "
+#~ "centroids."
+#~ msgstr ""
+#~ "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten "
+#~ "oder Zentroiden."
 #~ msgid "Interactive input for supervised classification (requires Xterm)"
-#~ msgstr "Interaktive Eingabe für eine überwachte Klassifikation (benötigt Xterm)."
+#~ msgstr ""
+#~ "Interaktive Eingabe für eine überwachte Klassifikation (benötigt Xterm)."
-#~ msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
-#~ msgstr "Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt Trainingsgebiete zu markieren."
+#~ msgid ""
+#~ "Generates spectral signatures for an image by allowing the user to "
+#~ "outline regions of interest."
+#~ msgstr ""
+#~ "Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt "
+#~ "Trainingsgebiete zu markieren."
 #~ msgid "Writing new feature failed. Operation cancelled."
-#~ msgstr "Schreiben eines neuen Objektes fehlgeschlagen. Operation abgebrochen."
+#~ msgstr ""
+#~ "Schreiben eines neuen Objektes fehlgeschlagen. Operation abgebrochen."
 #~ msgid "Georectification Toolbar"
 #~ msgstr "Werkzeugleiste Georektifizierung"
@@ -20073,7 +21584,8 @@
 #~ msgid ""
 #~ "No layers marked for import.\n"
 #~ "Operation canceled."
-#~ msgstr "Keine Erweiterung zum Entfernen ausgewählt. Breche die Operation ab."
+#~ msgstr ""
+#~ "Keine Erweiterung zum Entfernen ausgewählt. Breche die Operation ab."
 #, fuzzy
 #~ msgid ""
@@ -20081,7 +21593,8 @@
 #~ "Layer and category number must be integer.\n"
 #~ "Layer number must be greater then zero."
 #~ msgstr ""
-#~ "Kann den neuen Layer/Kategorie <%(layer)s/%(category)s> nicht hinzufügen.\n"
+#~ "Kann den neuen Layer/Kategorie <%(layer)s/%(category)s> nicht "
+#~ "hinzufügen.\n"
 #~ "Layer und Kategorie Nummern müssen integer sein.\n"
 #~ "Layer Nummern müssen größer als Null sein."
@@ -20094,8 +21607,10 @@
 #~ msgid "Vector settings"
 #~ msgstr "Vektor Einstellungen"
-#~ msgid "Queries raster map layers on their category values and category labels."
-#~ msgstr "Fragt Rasterkartenwerte und deren Kategoriewerte &- beschriftungen ab."
+#~ msgid ""
+#~ "Queries raster map layers on their category values and category labels."
+#~ msgstr ""
+#~ "Fragt Rasterkartenwerte und deren Kategoriewerte &- beschriftungen ab."
 #~ msgid "Summary and display (requires XTerm)"
 #~ msgstr "Zusammenfassung und Darstellung  (erfordert XTerm)"
@@ -20156,7 +21671,8 @@
 #~ msgstr "Raster Einstellungen"
 #~ msgid "No data source defined, settings is not saved."
-#~ msgstr "Keine Datenquelle angegeben, Einstellungen werden nicht gespeichert."
+#~ msgstr ""
+#~ "Keine Datenquelle angegeben, Einstellungen werden nicht gespeichert."
 #~ msgid "Menu tree (double-click to run command)"
 #~ msgstr "Baumstruktur (Doppelklick, um einen Befehl auszuführen)"
@@ -20185,14 +21701,19 @@
 #~ msgid "Traces a flow through an elevation model on a raster map."
 #~ msgstr "Verfolgt einen Fluss durch ein Rasterhöhenmodell."
-#~ msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-#~ msgstr "Bikubische oder bilineare Spline-Interpolation mit Tykhonov Regularisierung."
+#~ msgid ""
+#~ "Bicubic or bilinear spline interpolation with Tykhonov regularization."
+#~ msgstr ""
+#~ "Bikubische oder bilineare Spline-Interpolation mit Tykhonov "
+#~ "Regularisierung."
 #~ msgid "Creates Linear Reference System"
 #~ msgstr "Erzeugt lineares Referenzsystem"
 #~ msgid "Creates stationing from input lines, and linear reference system"
-#~ msgstr "Erzeuge Stationen auf Basis der Eingabe-Linien und dem linearen Referenzsystem."
+#~ msgstr ""
+#~ "Erzeuge Stationen auf Basis der Eingabe-Linien und dem linearen "
+#~ "Referenzsystem."
 #~ msgid "Populates database values from vector features."
 #~ msgstr "Füllt Datenbank basierend auf Vektorobjekten."
@@ -20200,8 +21721,11 @@
 #~ msgid "Produces a convex hull for a given vector map."
 #~ msgstr "Erzeugt eine konvexe Hülle für eine Vektorkarte."
-#~ msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
-#~ msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
+#~ msgid ""
+#~ "Brovey transform to merge multispectral and high-res panchromatic channels"
+#~ msgstr ""
+#~ "Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
+#~ "panchromatischer Kanäle."
 #~ msgid " List of layers "
 #~ msgstr "Liste der Layer"
@@ -20287,11 +21811,18 @@
 #~ msgid "ERROR: %s\n"
 #~ msgstr "FEHLER: %s\n"
-#~ msgid "Attempt to import data source <%(name)s> as raster or vector failed. "
-#~ msgstr "Der Versuch die Datei <%(name)s> als raster oder Vektor zu importieren ist fehlgeschlagen."
+#~ msgid ""
+#~ "Attempt to import data source <%(name)s> as raster or vector failed. "
+#~ msgstr ""
+#~ "Der Versuch die Datei <%(name)s> als raster oder Vektor zu importieren "
+#~ "ist fehlgeschlagen."
-#~ msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Color rules cannot be edited."
-#~ msgstr "Die selektierte Karte <%(map)s> ist nicht im aktuellen Mapset <%(mapset)s>. Farbregeln können nicht geändert werden."
+#~ msgid ""
+#~ "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Color rules "
+#~ "cannot be edited."
+#~ msgstr ""
+#~ "Die selektierte Karte <%(map)s> ist nicht im aktuellen Mapset <"
+#~ "%(mapset)s>. Farbregeln können nicht geändert werden."
 #~ msgid "Zoom to computational, default, saved region, ..."
 #~ msgstr "Auf Arbeitsbereich, Standard-, gespeicherte Region zoomen, ..."
@@ -20300,7 +21831,9 @@
 #~ msgstr "Kartenfenster in Bilddatei speichern"
 #~ msgid "Select the group you want to edit or enter name of new group:"
-#~ msgstr "Selektieren Sie zu editierenden die Gruppe oder geben Sie einen Namen für eine neue Gruppe ein:"
+#~ msgstr ""
+#~ "Selektieren Sie zu editierenden die Gruppe oder geben Sie einen Namen für "
+#~ "eine neue Gruppe ein:"
 #~ msgid "Add linked layers into layer tree"
 #~ msgstr "Importierte Ebenen der Baumstruktur hinzufügen"
@@ -20311,8 +21844,12 @@
 #~ msgid "Close dialog when command is successfully finished"
 #~ msgstr "Schließe Dialog, wenn Befehl erfolgreich ausgeführt"
-#~ msgid "Selected column '%s' will PERMANENTLY removed from table. Do you want to drop the column?"
-#~ msgstr "Selektierte Spalte '%s' wird unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Spalte löschen?"
+#~ msgid ""
+#~ "Selected column '%s' will PERMANENTLY removed from table. Do you want to "
+#~ "drop the column?"
+#~ msgstr ""
+#~ "Selektierte Spalte '%s' wird unwiderruflich aus der Tabelle gelöscht. "
+#~ "Wollen Sie diese Spalte löschen?"
 #~ msgid "Unknow tag"
 #~ msgstr "Unbekannter Tag"
@@ -20326,19 +21863,30 @@
 #~ msgid "loop"
 #~ msgstr "Schleife"
-#~ msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
-#~ msgstr "Erstellen einer Rasterkarte unter Verwendung einer Sammlung von vielen Koordinaten mit univariater Statistik."
+#~ msgid ""
+#~ "Create a raster map from an assemblage of many coordinates using "
+#~ "univariate statistics."
+#~ msgstr ""
+#~ "Erstellen einer Rasterkarte unter Verwendung einer Sammlung von vielen "
+#~ "Koordinaten mit univariater Statistik."
 #~ msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-#~ msgstr "Importiert GRIDATB.FOR Kartendatei (TOPMODEL) in eine GRASS Rasterkarte."
+#~ msgstr ""
+#~ "Importiert GRIDATB.FOR Kartendatei (TOPMODEL) in eine GRASS Rasterkarte."
-#~ msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
-#~ msgstr "Eine einfache Anwendung zur Konvertierung von Richtung und Entfernung in Koordinaten und umgekehrt."
+#~ msgid ""
+#~ "A simple utility for converting bearing and distance measurements to "
+#~ "coordinates and vice versa."
+#~ msgstr ""
+#~ "Eine einfache Anwendung zur Konvertierung von Richtung und Entfernung in "
+#~ "Koordinaten und umgekehrt."
 #~ msgid "Controls access to the current mapset for other users on the system."
 #~ msgstr "Kontrolliert den Zugriff anderer Benutzer auf das aktuelle Mapset."
-#~ msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
+#~ msgid ""
+#~ "Prints and manipulates GRASS projection information files (in various co-"
+#~ "ordinate system descriptions)."
 #~ msgstr "Anzeigen und ändern der GRASS Projektionsdateien (in verschiedenen"
 #~ msgid "Update installed extensions"
@@ -20348,85 +21896,174 @@
 #~ msgstr "Entfernen einer installierten Erweiterung aus den GRASS Addons."
 #~ msgid "Resamples raster map layers to a finer grid using interpolation."
-#~ msgstr "Resamplen einer Rasterkarte zu feinerer Auflösung mittels Interpolation."
+#~ msgstr ""
+#~ "Resamplen einer Rasterkarte zu feinerer Auflösung mittels Interpolation."
 #~ msgid "Re-projects a raster map from one location to the current location."
-#~ msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
+#~ msgstr ""
+#~ "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
 #~ msgid "Creates/modifies the color table associated with a raster map layer."
 #~ msgstr "Erzeugt / modifiziert die Farbtabelle einer Rasterkarte"
-#~ msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map layer."
-#~ msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Vektorpunkte oder Zentroide und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
+#~ msgid ""
+#~ "Makes each cell value a function of the attribute values assigned to the "
+#~ "vector points or centroids around it, and stores new cell values in an "
+#~ "output raster map layer."
+#~ msgstr ""
+#~ "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
+#~ "Vektorpunkte oder Zentroide und erstellt neue Zellenwerte in einer "
+#~ "Ausgabe-Rasterkarte."
-#~ msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
-#~ msgstr "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte mit Reibungs-Kosten kombiniert."
+#~ msgid ""
+#~ "Outputs a raster map layer showing the anisotropic cumulative cost of "
+#~ "moving between different geographic locations on an input elevation "
+#~ "raster map layer whose cell category values represent elevation combined "
+#~ "with an input raster map layer whose cell values represent friction cost."
+#~ msgstr ""
+#~ "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, "
+#~ "die beim Bewegen zwischen unterschiedlichen geographischen Orten "
+#~ "entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine "
+#~ "Rasterkarte mit Reibungs-Kosten kombiniert."
 #~ msgid "Creates shaded relief map from an elevation map (DEM)."
-#~ msgstr "Erstellt eine geschummerte Reliefkarte auf Basis einer Höhenkarte (DHM)."
+#~ msgstr ""
+#~ "Erstellt eine geschummerte Reliefkarte auf Basis einer Höhenkarte (DHM)."
-#~ msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
-#~ msgstr "Erzeugt aus Abflusslinien (Vektor) Resterdaten und substrahiert die Tiefe vom ausgegebenen DHM "
+#~ msgid ""
+#~ "Takes vector stream data, transforms it to raster and subtracts depth "
+#~ "from the output DEM."
+#~ msgstr ""
+#~ "Erzeugt aus Abflusslinien (Vektor) Resterdaten und substrahiert die Tiefe "
+#~ "vom ausgegebenen DHM "
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
-#~ msgstr "Berechnung von Abflusslinien, Länge der Fliesswege und Flussdichte aus einem digitalen Höhenmodell."
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)."
+#~ msgstr ""
+#~ "Berechnung von Abflusslinien, Länge der Fliesswege und Flussdichte aus "
+#~ "einem digitalen Höhenmodell."
-#~ msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
-#~ msgstr "Erstellt drei oder optional vier Rasterkarten, die 1) die Basisrate der (lotrechten) Ausbreitung (ROS), 2) die maximale (Vorwärts-) Ausbreitung, 3) die Richtung der größten Ausbreitung, und optional 4) die maximal zu erkennende potentielle Ausbreitung, zeigen."
+#~ msgid ""
+#~ "Generates three, or four raster map layers showing 1) the base "
+#~ "(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) "
+#~ "the direction of the maximum ROS, and optionally 4) the maximum potential "
+#~ "spotting distance."
+#~ msgstr ""
+#~ "Erstellt drei oder optional vier Rasterkarten, die 1) die Basisrate der "
+#~ "(lotrechten) Ausbreitung (ROS), 2) die maximale (Vorwärts-) Ausbreitung, "
+#~ "3) die Richtung der größten Ausbreitung, und optional 4) die maximal zu "
+#~ "erkennende potentielle Ausbreitung, zeigen."
-#~ msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
-#~ msgstr "Simuliert elliptische anisotrophe Ausbreitung in einem Kartenfenster und erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung und der Ursprung."
+#~ msgid ""
+#~ "Simulates elliptically anisotropic spread on a graphics window and "
+#~ "generates a raster map of the cumulative time of spread, given raster "
+#~ "maps containing the rates of spread (ROS), the ROS directions and the "
+#~ "spread origins."
+#~ msgstr ""
+#~ "Simuliert elliptische anisotrophe Ausbreitung in einem Kartenfenster und "
+#~ "erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als "
+#~ "Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, "
+#~ "Ausbreitungsrichtung und der Ursprung."
-#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-#~ msgstr "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation "
+#~ "der Kategorien einer existierenden Rasterkarte basieren."
-#~ msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
-#~ msgstr "Erzeugt eine Dichte-Rasterkarte aus Vektorpunkten mittels eines \"moving Kernels\" oder erzeugt optional eine Dichte-Vektorkarte aus einem Netzwerk."
+#~ msgid ""
+#~ "Generates a raster density map from vector point data using a moving "
+#~ "kernel or optionally generates a vector density map on a vector network."
+#~ msgstr ""
+#~ "Erzeugt eine Dichte-Rasterkarte aus Vektorpunkten mittels eines \"moving "
+#~ "Kernels\" oder erzeugt optional eine Dichte-Vektorkarte aus einem "
+#~ "Netzwerk."
-#~ msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
-#~ msgstr "Erzeugt eine Rasterkarte mit gleichverteilten zufälligen Abweichungen, deren Wertebereiche vom Benutzer festgelegt werden können."
+#~ msgid ""
+#~ "Produces a raster map of uniform random deviates whose range can be "
+#~ "expressed by the user."
+#~ msgstr ""
+#~ "Erzeugt eine Rasterkarte mit gleichverteilten zufälligen Abweichungen, "
+#~ "deren Wertebereiche vom Benutzer festgelegt werden können."
-#~ msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
-#~ msgstr "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance Squared Weighting."
+#~ msgid ""
+#~ "Surface interpolation from vector point data by Inverse Distance Squared "
+#~ "Weighting."
+#~ msgstr ""
+#~ "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance "
+#~ "Squared Weighting."
-#~ msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
-#~ msgstr "Räumliche Approximation und topographische Analyse auf Basis gegebener Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-Rasterkarte geschrieben."
+#~ msgid ""
+#~ "Spatial approximation and topographic analysis from given point or "
+#~ "isoline data in vector format to floating point raster format using "
+#~ "regularized spline with tension."
+#~ msgstr ""
+#~ "Räumliche Approximation und topographische Analyse auf Basis gegebener "
+#~ "Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten "
+#~ "Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-"
+#~ "Rasterkarte geschrieben."
-#~ msgid "Report and statistics"
-#~ msgstr "Bericht und Statistiken"
 #~ msgid "Generates area statistics for raster map layers."
 #~ msgstr "Erzeugt Flächenstatistiken für Rasterkarten."
-#~ msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
-#~ msgstr "Berechnet das Volumen von Daten-\"Klumpen\". Optional kann eine GRASS-Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
+#~ msgid ""
+#~ "Calculates the volume of data \"clumps\", and (optionally) produces a "
+#~ "GRASS vector points map containing the calculated centroids of these "
+#~ "clumps."
+#~ msgstr ""
+#~ "Berechnet das Volumen von Daten-\"Klumpen\". Optional kann eine GRASS-"
+#~ "Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
 #~ msgid "Converts vector map to 3D by sampling of elevation raster map."
-#~ msgstr "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit Höheninformationen."
+#~ msgstr ""
+#~ "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit "
+#~ "Höheninformationen."
-#~ msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
-#~ msgstr "Führt eine affine Transformation (schieben, skalieren und rotieren oder GPCs) von Vektorkarten durch."
+#~ msgid ""
+#~ "Performs an affine transformation (shift, scale and rotate, or GPCs) on "
+#~ "vector map."
+#~ msgstr ""
+#~ "Führt eine affine Transformation (schieben, skalieren und rotieren oder "
+#~ "GPCs) von Vektorkarten durch."
 #~ msgid "Visibility graph construction."
 #~ msgstr "Konstruktion des Sichtbarkeits-Graphen."
-#~ msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
-#~ msgstr "Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels eines Clusteralgorithmus."
+#~ msgid ""
+#~ "Generates spectral signatures for land cover types in an image using a "
+#~ "clustering algorithm."
+#~ msgstr ""
+#~ "Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes "
+#~ "mittels eines Clusteralgorithmus."
 #~ msgid "Canonical components analysis (cca) program for image processing."
-#~ msgstr "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
+#~ msgstr ""
+#~ "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
-#~ msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
-#~ msgstr "Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für Landsat MSS/TM/ETM+."
+#~ msgid ""
+#~ "Calculates top-of-atmosphere radiance or reflectance and temperature for "
+#~ "Landsat MSS/TM/ETM+."
+#~ msgstr ""
+#~ "Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für "
 #~ msgid "Performs atmospheric correction using the 6S algorithm."
 #~ msgstr "Führt eine atmosphärische Korrektion mit dem 6S-Algorithmus durch."
-#~ msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
-#~ msgstr "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung (accuracy assessment) der Klassifikationsergebnisse."
+#~ msgid ""
+#~ "Calculate error matrix and kappa parameter for accuracy assessment of "
+#~ "classification result."
+#~ msgstr ""
+#~ "Berechnet Fehlermatrix und Kappa-Parameter für die "
+#~ "Genauigkeitsabschätzung (accuracy assessment) der "
+#~ "Klassifikationsergebnisse."
 #~ msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-#~ msgstr "Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
+#~ msgstr ""
+#~ "Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, "
+#~ "& 7."
 #~ msgid "Report and Statistics"
@@ -20437,17 +22074,24 @@
 #~ msgid "Allows to join a table to a vector map table."
 #~ msgstr "Ermöglicht die Verknüpfung einer Tabelle mit einer Vektorkarte."
-#~ msgid "Allows to update a column in the attribute table connected to a vector map."
+#~ msgid ""
+#~ "Allows to update a column in the attribute table connected to a vector "
+#~ "map."
 #~ msgstr "Aktualisiert eine Spalte einer Attributtabelle einer Vektorkarte."
 #~ msgid "Uninstall GRASS Addons extensions"
 #~ msgstr "Entferne Add-ons-Erweiterungen"
 #~ msgid "No extension selected for removal. Operation canceled."
+#~ msgstr ""
-#~ msgid "The 'xml2' parser is required, please install it first. You may also try running r.in.wms directly from the command line."
-#~ msgstr "Ein 'xml2'-Parser wird benötigt, installiere diesen zuerst. Probiere auch r.in.wms in der Kommandozeile."
+#~ msgid ""
+#~ "The 'xml2' parser is required, please install it first. You may also try "
+#~ "running r.in.wms directly from the command line."
+#~ msgstr ""
+#~ "Ein 'xml2'-Parser wird benötigt, installiere diesen zuerst. Probiere auch "
+#~ "r.in.wms in der Kommandozeile."
 #~ msgid ""
 #~ "Geodesic distance is not yet supported by this tool.\n"
@@ -20490,14 +22134,22 @@
 #~ msgid "Invalid line in GISRC file (%(e)s):%(l)s\n"
 #~ msgstr "Fehlerhafte Zeile in GISRC Datei (%s):%s\n"
-#~ msgid "Do you want to import data source <%(name)s> to created location? Default region will be set to match imported map."
-#~ msgstr "Möchten Sie die Location anhand der Datenquelle <%(name)s> erzeugen? Die Standardregion wird auf Grundlage der importierten Karte erstellt."
+#~ msgid ""
+#~ "Do you want to import data source <%(name)s> to created location? Default "
+#~ "region will be set to match imported map."
+#~ msgstr ""
+#~ "Möchten Sie die Location anhand der Datenquelle <%(name)s> erzeugen? Die "
+#~ "Standardregion wird auf Grundlage der importierten Karte erstellt."
 #~ msgid "Unable to load icon theme. Reason: %s"
 #~ msgstr "Kann das Symbol-Design nicht laden. Grund: %s"
-#~ msgid "Digitize new area (composition of boundaries without category and one centroid with category)"
-#~ msgstr "Neue Fläche digitalisieren (Flächengrenzen ohne Kategorie und einem Zentroid mit Kategorie)"
+#~ msgid ""
+#~ "Digitize new area (composition of boundaries without category and one "
+#~ "centroid with category)"
+#~ msgstr ""
+#~ "Neue Fläche digitalisieren (Flächengrenzen ohne Kategorie und einem "
+#~ "Zentroid mit Kategorie)"
 #, fuzzy
 #~ msgid "Select WKT or PRJ file"
@@ -20521,5 +22173,11 @@
 #~ msgid "Georectify raster and vector maps"
 #~ msgstr "Georeferenzieren von Raster- und Vektorkarten"
-#~ msgid "Calculates cast shadow areas from sun position and DEM. Either A: exact sun position is specified, or B: date/time to calculate the sun position by r.sunmask itself."
-#~ msgstr "Berechnet verschattete Bereiche aus der Sonnenposition und einem DGM. Es wird eintweder eine genaue Sonnenposition oder Datumsinformationen zur Berechnung (mit r.sunmask) erwartet."
+#~ msgid ""
+#~ "Calculates cast shadow areas from sun position and DEM. Either A: exact "
+#~ "sun position is specified, or B: date/time to calculate the sun position "
+#~ "by r.sunmask itself."
+#~ msgstr ""
+#~ "Berechnet verschattete Bereiche aus der Sonnenposition und einem DGM. Es "
+#~ "wird eintweder eine genaue Sonnenposition oder Datumsinformationen zur "
+#~ "Berechnung (mit r.sunmask) erwartet."
Modified: grass/trunk/locale/po/grasswxpy_el.po
--- grass/trunk/locale/po/grasswxpy_el.po	2014-03-31 12:38:20 UTC (rev 59526)
+++ grass/trunk/locale/po/grasswxpy_el.po	2014-03-31 19:37:40 UTC (rev 59527)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasswxpy_el\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2014-03-27 20:41+0100\n"
+"POT-Creation-Date: 2014-03-31 21:29+0200\n"
 "PO-Revision-Date: 2013-02-07 20:23+0200\n"
 "Last-Translator: Nikos Ves <vesnikos at gmail.com>\n"
 "Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -37,7 +37,7 @@
 #: ../gui/wxpython/iscatt/toolbars.py:44
 #: ../gui/wxpython/iscatt/toolbars.py:135
 #: ../gui/wxpython/gui_core/toolbars.py:84
-#: ../gui/wxpython/gui_core/widgets.py:986 ../gui/wxpython/nviz/tools.py:1892
+#: ../gui/wxpython/gui_core/widgets.py:997 ../gui/wxpython/nviz/tools.py:1892
 #: ../gui/wxpython/vnet/dialogs.py:867
 msgid "Settings"
 msgstr "Επιλογές"
@@ -608,7 +608,7 @@
 #: ../gui/wxpython/gui_core/gselect.py:1419
 #: ../gui/wxpython/gui_core/gselect.py:1429
 #: ../gui/wxpython/gui_core/gselect.py:1430
-#: ../gui/wxpython/gui_core/widgets.py:1047
+#: ../gui/wxpython/gui_core/widgets.py:1058
 #: ../gui/wxpython/gmodeler/preferences.py:549
 #: ../gui/wxpython/animation/dialogs.py:333
 #: ../gui/wxpython/vnet/dialogs.py:1474
@@ -775,7 +775,7 @@
 msgid "Select font"
 msgstr "Επιλοφή γραμματοσηράς"
-#: ../gui/wxpython/gui_core/toolbars.py:73 ../gui/wxpython/menustrings.py:2001
+#: ../gui/wxpython/gui_core/toolbars.py:73 ../gui/wxpython/menustrings.py:2035
 #: ../gui/wxpython/lmgr/layertree.py:72
 msgid "Quit"
 msgstr "Έξοδος"
@@ -827,6 +827,7 @@
 msgstr "Εκτέλεση της εντολής (Ctrl +R)"
 #: ../gui/wxpython/gui_core/forms.py:514
+#: ../gui/wxpython/modules/mcalc_builder.py:151
 msgid "Copy the current command string to the clipboard"
 msgstr ""
@@ -972,75 +973,75 @@
 msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:82
+#: ../gui/wxpython/gui_core/widgets.py:84
 msgid " (...)"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:788
+#: ../gui/wxpython/gui_core/widgets.py:799
 #: ../gui/wxpython/gui_core/dialogs.py:671
 #: ../gui/wxpython/gui_core/dialogs.py:724
 #: ../gui/wxpython/gui_core/dialogs.py:1429 ../gui/wxpython/dbmgr/base.py:1244
 msgid "Select all"
 msgstr "Επιλογή όλων"
-#: ../gui/wxpython/gui_core/widgets.py:789
+#: ../gui/wxpython/gui_core/widgets.py:800
 #: ../gui/wxpython/gui_core/dialogs.py:1431 ../gui/wxpython/dbmgr/base.py:1245
 msgid "Deselect all"
 msgstr "Αποεπιλογή όλων"
-#: ../gui/wxpython/gui_core/widgets.py:851
+#: ../gui/wxpython/gui_core/widgets.py:862
 msgid "Fulltext search"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:852
+#: ../gui/wxpython/gui_core/widgets.py:863
 msgid "Type to search in all modules. Press Enter for next match."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:909
+#: ../gui/wxpython/gui_core/widgets.py:920
 msgid "Searching, please type more characters."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:918
+#: ../gui/wxpython/gui_core/widgets.py:929
 #, python-format
 msgid "%d modules match"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:992
+#: ../gui/wxpython/gui_core/widgets.py:1003
 msgid "Save current settings"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:995
+#: ../gui/wxpython/gui_core/widgets.py:1006
 msgid "Delete currently selected settings"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1016
+#: ../gui/wxpython/gui_core/widgets.py:1027
 msgid "Load settings:"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1034
+#: ../gui/wxpython/gui_core/widgets.py:1045
 #, python-format
 msgid "Settings <%s> not found"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1048
-#: ../gui/wxpython/gui_core/widgets.py:1064
+#: ../gui/wxpython/gui_core/widgets.py:1059
+#: ../gui/wxpython/gui_core/widgets.py:1075
 msgid "Save settings"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1053
+#: ../gui/wxpython/gui_core/widgets.py:1064
 msgid "Name not given, settings is not saved."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1062
+#: ../gui/wxpython/gui_core/widgets.py:1073
 #, python-format
 msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1111
+#: ../gui/wxpython/gui_core/widgets.py:1122
 msgid "No settings is defined. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1145
+#: ../gui/wxpython/gui_core/widgets.py:1156
 msgid "Unable to save settings"
 msgstr ""
@@ -1165,8 +1166,8 @@
 msgstr "Όνομα διανυσματικού χάρτη:"
 #: ../gui/wxpython/gui_core/dialogs.py:234
-#: ../gui/wxpython/gui_core/dialogs.py:353 ../gui/wxpython/menustrings.py:545
-#: ../gui/wxpython/menustrings.py:1457
+#: ../gui/wxpython/gui_core/dialogs.py:353 ../gui/wxpython/menustrings.py:562
+#: ../gui/wxpython/menustrings.py:1491
 msgid "Create new vector map"
 msgstr ""
@@ -1438,7 +1439,7 @@
 #: ../gui/wxpython/gui_core/dialogs.py:1650
 #: ../gui/wxpython/gui_core/preferences.py:816
 #: ../gui/wxpython/gmodeler/preferences.py:529
-#: ../gui/wxpython/modules/mcalc_builder.py:235
+#: ../gui/wxpython/modules/mcalc_builder.py:237
 #: ../gui/wxpython/modules/vclean.py:143 ../gui/wxpython/scripts/vkrige.py:141
 msgid "Allow output files to overwrite existing files"
 msgstr ""
@@ -1454,22 +1455,22 @@
 msgstr "%Εισαγωγή επιλεγμένων επιπέδων."
 #: ../gui/wxpython/gui_core/dialogs.py:1812 ../gui/wxpython/menustrings.py:167
-#: ../gui/wxpython/menustrings.py:1159 ../gui/wxpython/lmgr/layertree.py:64
+#: ../gui/wxpython/menustrings.py:1176 ../gui/wxpython/lmgr/layertree.py:64
 msgid "Link external vector data"
 msgstr ""
 #: ../gui/wxpython/gui_core/dialogs.py:1814 ../gui/wxpython/menustrings.py:61
-#: ../gui/wxpython/menustrings.py:1053 ../gui/wxpython/lmgr/layertree.py:62
+#: ../gui/wxpython/menustrings.py:1070 ../gui/wxpython/lmgr/layertree.py:62
 msgid "Import vector data"
 msgstr ""
 #: ../gui/wxpython/gui_core/dialogs.py:1818 ../gui/wxpython/menustrings.py:165
-#: ../gui/wxpython/menustrings.py:1157 ../gui/wxpython/lmgr/layertree.py:58
+#: ../gui/wxpython/menustrings.py:1174 ../gui/wxpython/lmgr/layertree.py:58
 msgid "Link external raster data"
 msgstr ""
 #: ../gui/wxpython/gui_core/dialogs.py:1820 ../gui/wxpython/menustrings.py:30
-#: ../gui/wxpython/menustrings.py:1022 ../gui/wxpython/lmgr/layertree.py:56
+#: ../gui/wxpython/menustrings.py:1039 ../gui/wxpython/lmgr/layertree.py:56
 msgid "Import raster data"
 msgstr "Εισαγωγή raster δεδομένων"
@@ -2150,8 +2151,8 @@
 msgid "Command log saved to '%s'"
 msgstr "Οι επιλογές αποθηκεύτηκαν στο αρχείο '%s'."
-#: ../gui/wxpython/gui_core/ghelp.py:47 ../gui/wxpython/menustrings.py:1017
-#: ../gui/wxpython/menustrings.py:1018
+#: ../gui/wxpython/gui_core/ghelp.py:47 ../gui/wxpython/menustrings.py:1034
+#: ../gui/wxpython/menustrings.py:1035
 msgid "About GRASS GIS"
 msgstr "Σχετικα με το GRASS GIS"
@@ -2317,8 +2318,8 @@
 #: ../gui/wxpython/gui_core/simplelmgr.py:417
 #: ../gui/wxpython/rlisetup/frame.py:130
-#: ../gui/wxpython/gmodeler/frame.py:1283 ../gui/wxpython/menustrings.py:925
-#: ../gui/wxpython/menustrings.py:1837
+#: ../gui/wxpython/gmodeler/frame.py:1283 ../gui/wxpython/menustrings.py:942
+#: ../gui/wxpython/menustrings.py:1871
 #: ../gui/wxpython/animation/dialogs.py:631
 #: ../gui/wxpython/animation/dialogs.py:822
 #: ../gui/wxpython/lmgr/layertree.py:396
@@ -2675,8 +2676,8 @@
 msgid "Add"
 msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2078 ../gui/wxpython/menustrings.py:909
-#: ../gui/wxpython/menustrings.py:1821
+#: ../gui/wxpython/dbmgr/base.py:2078 ../gui/wxpython/menustrings.py:926
+#: ../gui/wxpython/menustrings.py:1855
 msgid "Rename column"
 msgstr "Μετονομασία στήλης"
@@ -2896,8 +2897,8 @@
 msgid "Reload attribute data (selected layer only)"
 msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:100 ../gui/wxpython/menustrings.py:891
-#: ../gui/wxpython/menustrings.py:1803
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:100 ../gui/wxpython/menustrings.py:908
+#: ../gui/wxpython/menustrings.py:1837
 msgid "Query"
 msgstr "Ερώτημα"
@@ -3039,8 +3040,8 @@
 msgid "No attributes found"
 msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:115 ../gui/wxpython/menustrings.py:680
-#: ../gui/wxpython/menustrings.py:1592
+#: ../gui/wxpython/dbmgr/dialogs.py:115 ../gui/wxpython/menustrings.py:697
+#: ../gui/wxpython/menustrings.py:1626
 msgid "Update attributes"
 msgstr ""
@@ -3602,8 +3603,8 @@
 msgid "Remove a configuration file"
 msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:133 ../gui/wxpython/menustrings.py:921
-#: ../gui/wxpython/menustrings.py:1833
+#: ../gui/wxpython/rlisetup/frame.py:133 ../gui/wxpython/menustrings.py:938
+#: ../gui/wxpython/menustrings.py:1867
 #, fuzzy
 msgid "Create"
 msgstr "Δημιοιυργία RGB"
@@ -3613,8 +3614,8 @@
 msgstr ""
 #: ../gui/wxpython/rlisetup/frame.py:136 ../gui/wxpython/menustrings.py:180
-#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1172
-#: ../gui/wxpython/menustrings.py:1835 ../gui/wxpython/lmgr/layertree.py:402
+#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1189
+#: ../gui/wxpython/menustrings.py:1869 ../gui/wxpython/lmgr/layertree.py:402
 msgid "Rename"
 msgstr "Μετονομασία"
@@ -3745,7 +3746,7 @@
 msgstr "μονάδες χάρτη"
 #: ../gui/wxpython/rlisetup/wizard.py:742 ../gui/wxpython/menustrings.py:336
-#: ../gui/wxpython/menustrings.py:1248
+#: ../gui/wxpython/menustrings.py:1265
 msgid "Moving window"
 msgstr ""
@@ -4133,30 +4134,30 @@
 msgid "Failed to read instruction %(inst)s: file %(file)s not found."
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:61 ../gui/wxpython/menustrings.py:1994
+#: ../gui/wxpython/psmap/toolbars.py:61 ../gui/wxpython/menustrings.py:2028
 msgid "Generate text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:63 ../gui/wxpython/menustrings.py:1992
+#: ../gui/wxpython/psmap/toolbars.py:63 ../gui/wxpython/menustrings.py:2026
 msgid "Load text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:65 ../gui/wxpython/menustrings.py:1996
+#: ../gui/wxpython/psmap/toolbars.py:65 ../gui/wxpython/menustrings.py:2030
 msgid "Generate PostScript output"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:67 ../gui/wxpython/menustrings.py:1998
+#: ../gui/wxpython/psmap/toolbars.py:67 ../gui/wxpython/menustrings.py:2032
 msgid "Generate PDF output"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:69 ../gui/wxpython/menustrings.py:1989
+#: ../gui/wxpython/psmap/toolbars.py:69 ../gui/wxpython/menustrings.py:2023
 #: ../gui/wxpython/modules/histogram.py:449
 #: ../gui/wxpython/mapdisp/frame.py:673 ../gui/wxpython/wxplot/base.py:560
 #: ../gui/wxpython/gcp/mapdisplay.py:412
 msgid "Page setup"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:70 ../gui/wxpython/menustrings.py:1990
+#: ../gui/wxpython/psmap/toolbars.py:70 ../gui/wxpython/menustrings.py:2024
 msgid "Specify paper size, margins and orientation"
 msgstr ""
@@ -4169,7 +4170,7 @@
 msgstr ""
 #: ../gui/wxpython/psmap/toolbars.py:75 ../gui/wxpython/psmap/dialogs.py:619
-#: ../gui/wxpython/psmap/dialogs.py:674 ../gui/wxpython/menustrings.py:2004
+#: ../gui/wxpython/psmap/dialogs.py:674 ../gui/wxpython/menustrings.py:2038
 msgid "Map frame"
 msgstr ""
@@ -4177,7 +4178,7 @@
 msgid "Click and drag to place map frame"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:78 ../gui/wxpython/menustrings.py:2023
+#: ../gui/wxpython/psmap/toolbars.py:78 ../gui/wxpython/menustrings.py:2057
 msgid "Delete selected object"
 msgstr ""
@@ -4190,12 +4191,12 @@
 msgstr ""
 #: ../gui/wxpython/psmap/toolbars.py:84 ../gui/wxpython/psmap/dialogs.py:3705
-#: ../gui/wxpython/psmap/dialogs.py:3710 ../gui/wxpython/menustrings.py:2016
+#: ../gui/wxpython/psmap/dialogs.py:3710 ../gui/wxpython/menustrings.py:2050
 #: ../gui/wxpython/animation/dialogs.py:1196
 msgid "Text"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:86 ../gui/wxpython/menustrings.py:2012
+#: ../gui/wxpython/psmap/toolbars.py:86 ../gui/wxpython/menustrings.py:2046
 msgid "Map info"
 msgstr ""
@@ -4204,19 +4205,19 @@
 msgid "Legend"
 msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:90 ../gui/wxpython/menustrings.py:2014
+#: ../gui/wxpython/psmap/toolbars.py:90 ../gui/wxpython/menustrings.py:2048
 #: ../gui/wxpython/nviz/tools.py:1991
 msgid "Scale bar"
 msgstr "Κλίμακα"
 #: ../gui/wxpython/psmap/toolbars.py:92 ../gui/wxpython/psmap/dialogs.py:4061
-#: ../gui/wxpython/psmap/dialogs.py:4109 ../gui/wxpython/menustrings.py:2018
+#: ../gui/wxpython/psmap/dialogs.py:4109 ../gui/wxpython/menustrings.py:2052
 msgid "Image"
 msgstr ""
 #: ../gui/wxpython/psmap/toolbars.py:94 ../gui/wxpython/psmap/dialogs.py:4494
-#: ../gui/wxpython/menustrings.py:2020 ../gui/wxpython/nviz/tools.py:1946
+#: ../gui/wxpython/menustrings.py:2054 ../gui/wxpython/nviz/tools.py:1946
 msgid "North Arrow"
 msgstr ""
@@ -4466,7 +4467,7 @@
 msgid "Invalid scale or map center!"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1144 ../gui/wxpython/menustrings.py:2006
+#: ../gui/wxpython/psmap/dialogs.py:1144 ../gui/wxpython/menustrings.py:2040
 #: ../gui/wxpython/nviz/tools.py:652 ../gui/wxpython/nviz/mapwindow.py:1672
 #: ../gui/wxpython/lmgr/layertree.py:765
 msgid "Raster map"
@@ -4532,7 +4533,7 @@
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:1315 ../gui/wxpython/menustrings.py:182
-#: ../gui/wxpython/menustrings.py:1174 ../gui/wxpython/menustrings.py:2022
+#: ../gui/wxpython/menustrings.py:1191 ../gui/wxpython/menustrings.py:2056
 #: ../gui/wxpython/nviz/tools.py:1098 ../gui/wxpython/nviz/tools.py:1976
 #: ../gui/wxpython/nviz/tools.py:2024
 msgid "Delete"
@@ -4584,7 +4585,7 @@
 msgstr ""
 #: ../gui/wxpython/psmap/dialogs.py:1727 ../gui/wxpython/menustrings.py:331
-#: ../gui/wxpython/menustrings.py:1243 ../gui/wxpython/nviz/tools.py:789
+#: ../gui/wxpython/menustrings.py:1260 ../gui/wxpython/nviz/tools.py:789
 #: ../gui/wxpython/nviz/tools.py:2400
 msgid "Mask"
 msgstr "Μάσκα"
@@ -4809,7 +4810,7 @@
 msgid "Choose vector maps and their order in legend"
 msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2617 ../gui/wxpython/menustrings.py:2008
+#: ../gui/wxpython/psmap/dialogs.py:2617 ../gui/wxpython/menustrings.py:2042
 #: ../gui/wxpython/nviz/tools.py:1177 ../gui/wxpython/lmgr/layertree.py:768
 msgid "Vector map"
 msgstr "Διανυσματικός Χάρτης"
@@ -5818,12 +5819,12 @@
 msgid "Label and comment"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:199
+#: ../gui/wxpython/gmodeler/dialogs.py:198
 #: ../gui/wxpython/gmodeler/frame.py:1345
 msgid "Label:"
 msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:203
+#: ../gui/wxpython/gmodeler/dialogs.py:202
 #: ../gui/wxpython/gmodeler/frame.py:734
 #: ../gui/wxpython/gmodeler/frame.py:1357
 #, fuzzy
@@ -5953,7 +5954,7 @@
 msgstr "Διαγραφή όλων"
 #: ../gui/wxpython/gmodeler/preferences.py:29
-#: ../gui/wxpython/menustrings.py:1957
+#: ../gui/wxpython/menustrings.py:1991
 msgid "Modeler settings"
 msgstr ""
@@ -6014,7 +6015,7 @@
 msgstr "Εντολή"
 #: ../gui/wxpython/gmodeler/preferences.py:508
-#: ../gui/wxpython/menustrings.py:1973
+#: ../gui/wxpython/menustrings.py:2007
 msgid "Model properties"
 msgstr ""
@@ -6128,7 +6129,7 @@
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
 msgstr "Το αρχείο Μοντέλου <%s> υπάρχει. Θέλετε να γίνει αντικατάσταση;"
-#: ../gui/wxpython/gmodeler/frame.py:416 ../gui/wxpython/menustrings.py:1944
+#: ../gui/wxpython/gmodeler/frame.py:416 ../gui/wxpython/menustrings.py:1978
 msgid "Save model"
 msgstr ""
@@ -6176,7 +6177,7 @@
 msgid "Model exported to <%s>"
 msgstr "Το μονέλο εξάχθηκε στο <%s>"
-#: ../gui/wxpython/gmodeler/frame.py:734 ../gui/wxpython/menustrings.py:1969
+#: ../gui/wxpython/gmodeler/frame.py:734 ../gui/wxpython/menustrings.py:2003
 #, fuzzy
 msgid "Add comment"
 msgstr "Προσθήκη στήλης"
@@ -6352,8 +6353,8 @@
 msgid "Update"
 msgstr "Ανανέωση"
-#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:1938
-#: ../gui/wxpython/menustrings.py:1988
+#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:1972
+#: ../gui/wxpython/menustrings.py:2022
 msgid "&File"
 msgstr "&Αρχείο"
@@ -6361,7 +6362,7 @@
 msgid "Workspace"
 msgstr "Επιφάνεια εργασίας"
-#: ../gui/wxpython/menustrings.py:5 ../gui/wxpython/menustrings.py:1939
+#: ../gui/wxpython/menustrings.py:5 ../gui/wxpython/menustrings.py:1973
 #: ../gui/wxpython/nviz/tools.py:1094
 msgid "New"
 msgstr "Νέο"
@@ -6370,7 +6371,7 @@
 msgid "Create new workspace"
 msgstr "Δημιουργία νέας Επιφάνειας Εργασίας"
-#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:1941
+#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:1975
 msgid "Open"
 msgstr "Αν&οιγμα"
@@ -6378,7 +6379,7 @@
 msgid "Load workspace from file"
 msgstr "Φόρτωση Επιφάνειας Εργασίας απο αρχείο"
-#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/menustrings.py:1943
+#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/menustrings.py:1977
 #: ../gui/wxpython/modules/colorrules.py:416
 msgid "Save"
 msgstr "Αποθήκευση"
@@ -6388,7 +6389,7 @@
 msgid "Save workspace"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:1945
+#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:1979
 msgid "Save as"
 msgstr "Αποθήκευση ως"
@@ -6396,7 +6397,7 @@
 msgid "Save workspace to file"
 msgstr "Αποθήκευση Επιφάνειας εργασίας σε αρχείο"
-#: ../gui/wxpython/menustrings.py:13 ../gui/wxpython/menustrings.py:1947
+#: ../gui/wxpython/menustrings.py:13 ../gui/wxpython/menustrings.py:1981
 #: ../gui/wxpython/mapswipe/dialogs.py:162
 msgid "Close"
 msgstr "Κλεισιμο"
@@ -6457,731 +6458,731 @@
 msgid "Close all open map display windows"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:31 ../gui/wxpython/menustrings.py:1023
+#: ../gui/wxpython/menustrings.py:31 ../gui/wxpython/menustrings.py:1040
 msgid "Common formats import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:32 ../gui/wxpython/menustrings.py:1024
+#: ../gui/wxpython/menustrings.py:32 ../gui/wxpython/menustrings.py:1041
 msgid "Import raster data into a GRASS map layer using GDAL."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:33 ../gui/wxpython/menustrings.py:1025
+#: ../gui/wxpython/menustrings.py:33 ../gui/wxpython/menustrings.py:1042
 msgid "ASCII x,y,z point import and gridding"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:34 ../gui/wxpython/menustrings.py:1026
+#: ../gui/wxpython/menustrings.py:34 ../gui/wxpython/menustrings.py:1043
 msgid ""
 "Creates a raster map from an assemblage of many coordinates using univariate "
 "statistics."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:1027
+#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:1044
 msgid "ASCII grid import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1028
+#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1045
 msgid "Converts a GRASS ASCII raster file to binary raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1029
+#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1046
 msgid "ASCII polygons, lines, and point import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:1030
+#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:1047
 msgid "Creates raster maps from ASCII polygon/line/point data files."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1031
+#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1048
 msgid "Raw binary array import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1032
+#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1049
 msgid "Import a binary raster file into a GRASS raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1033
+#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1050
 msgid "ESRI ASCII grid import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1034
+#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1051
 msgid ""
 "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1035
+#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1052
 msgid "GRIDATB.FOR import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1036
+#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1053
 #, fuzzy
 msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
 msgstr "Εισαγωγή ενός αρχείου SPOT VGT NDVI σε raster χάρτη"
-#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1037
+#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1054
 msgid "Matlab 2D array import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1038
+#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1055
 msgid "Imports a binary MAT-File(v4) to a GRASS raster."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1039
+#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1056
 msgid "PNG import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1040
+#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1057
 msgid "Imports non-georeferenced PNG format image."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1041
+#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1058
 msgid "SPOT NDVI import"
 msgstr "Εισαγωγή SPOT NDVI"
-#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1042
+#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1059
 #, fuzzy
 msgid "Imports SPOT VGT NDVI data into a raster map."
-#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1043
+#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1060
 msgid "SRTM HGT import"
 msgstr "Εισαγωγή SRTM HGT"
-#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1044
+#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1061
 #, fuzzy
 msgid "Imports SRTM HGT files into raster map."
 msgstr "Εισαγωγή αρχείων SRTM HGT στο GRASS"
-#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1045
+#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1062
 msgid "Terra ASTER HDF import"
 msgstr "Εισαγωγή terra ASTER HDF"
-#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1046
+#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1063
 msgid ""
 "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
 "using gdalwarp."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:85
-#: ../gui/wxpython/menustrings.py:1047 ../gui/wxpython/menustrings.py:1077
+#: ../gui/wxpython/menustrings.py:1064 ../gui/wxpython/menustrings.py:1094
 msgid "LAS LiDAR points import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1048
+#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1065
 msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1049
+#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1066
 msgid "Unpack raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1050
+#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1067
 msgid "Unpacks a raster map packed with r.pack."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:294
-#: ../gui/wxpython/menustrings.py:1051 ../gui/wxpython/menustrings.py:1206
+#: ../gui/wxpython/menustrings.py:1068 ../gui/wxpython/menustrings.py:1223
 msgid "Reproject raster map from different GRASS location"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:60 ../gui/wxpython/menustrings.py:295
-#: ../gui/wxpython/menustrings.py:1052 ../gui/wxpython/menustrings.py:1207
+#: ../gui/wxpython/menustrings.py:1069 ../gui/wxpython/menustrings.py:1224
 msgid "Re-projects a raster map from given location to the current location."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1054
+#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1071
 msgid "Common import formats"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:1055
+#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:1072
 msgid "Converts vector layers into a GRASS vector map using OGR."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1056
+#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1073
 msgid "ASCII points or GRASS ASCII format"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1057
+#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1074
 msgid "Creates a vector map from an ASCII points file or ASCII vector file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:1058
+#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:1075
 msgid "ASCII points as a vector lines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1059
+#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1076
 msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1060
+#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1077
 msgid "Historical GRASS vector import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:1061
+#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:1078
 msgid "Imports older versions of GRASS vector maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1062
+#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1079
 msgid "Historical GRASS vector import (all maps)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1063
+#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1080
 msgid ""
 "Converts all older versions of GRASS vector maps in current mapset to "
 "current format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1064
+#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1081
 msgid "DXF import"
 msgstr "Εισαγωγή DXF"
-#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1065
+#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1082
 msgid "Converts files in DXF format to GRASS vector map format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1066
+#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1083
 msgid "WFS"
 msgstr "WFS"
-#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1067
+#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1084
 #, fuzzy
 msgid "Imports GetFeature from a WFS server."
 msgstr "Μεταφόρτωση και εισαγωγή δεδομένων απο διακομηστές WMS"
-#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1068
+#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1085
 msgid "ESRI e00 import"
 msgstr "Εισαγωγή ESRI e00"
-#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1069
+#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1086
 #, fuzzy
 msgid "Imports E00 file into a vector map."
 msgstr "Εισαγωγή αρχείου ESRI e00 σε διανυσματικό χάρτη."
-#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1070
+#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1087
 msgid "GPS data import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1071
+#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1088
 msgid "Geonames import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1072
+#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1089
 msgid "Imports geonames.org country files into a vector points map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1073
+#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1090
 msgid "GEOnet import"
 msgstr "Εισαγωγή GEOnet"
-#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1074
+#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1091
 msgid ""
 "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
 "points map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1075
+#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1092
 msgid "Matlab array or Mapgen format import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:84 ../gui/wxpython/menustrings.py:1076
+#: ../gui/wxpython/menustrings.py:84 ../gui/wxpython/menustrings.py:1093
 msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1078
+#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1095
 msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:1079
+#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:1096
 #, fuzzy
 msgid "Unpack vector map"
 msgstr "Νέος διανυσματικός χαρτης"
-#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:1080
+#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:1097
 msgid "Unpacks a vector map packed with v.pack."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:566
-#: ../gui/wxpython/menustrings.py:1081 ../gui/wxpython/menustrings.py:1478
+#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:583
+#: ../gui/wxpython/menustrings.py:1098 ../gui/wxpython/menustrings.py:1512
 msgid "Reproject vector map from different GRASS location"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:567
-#: ../gui/wxpython/menustrings.py:1082 ../gui/wxpython/menustrings.py:1479
+#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:584
+#: ../gui/wxpython/menustrings.py:1099 ../gui/wxpython/menustrings.py:1513
 msgid "Re-projects a vector map from one location to the current location."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1083
+#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1100
 msgid "Import 3D raster data"
 msgstr "Εισαγωγή δεδομένων 3D raster."
-#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1084
+#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1101
 msgid "ASCII 3D import"
 msgstr "εισαγωγή 3D ASCII"
-#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1085
+#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1102
 msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1086
+#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1103
 msgid "Raw binary array 3D import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1087
+#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1104
 #, fuzzy
 msgid "Imports a binary raster file into a GRASS 3D raster map."
-#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1088
+#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1105
 msgid "Vis5D import"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1089
+#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1106
 msgid "Import 3-dimensional Vis5D files."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1090
+#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1107
 msgid "Import database table"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1091
+#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1108
 msgid "Multiple import formats using OGR"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:1092
+#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:1109
 msgid "Imports attribute tables in various formats."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1093
+#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1110
 msgid "Export raster map"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:102 ../gui/wxpython/menustrings.py:135
-#: ../gui/wxpython/menustrings.py:1094 ../gui/wxpython/menustrings.py:1127
+#: ../gui/wxpython/menustrings.py:1111 ../gui/wxpython/menustrings.py:1144
 msgid "Common export formats"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1095
+#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1112
 msgid "Exports GRASS raster maps into GDAL supported formats."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1096
+#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1113
 msgid "ASCII grid export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1097
+#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1114
 msgid "Converts a raster map layer into a GRASS ASCII text file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1098
+#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1115
 msgid "ASCII x,y,z points export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1099
+#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1116
 msgid ""
 "Exports a raster map to a text file as x,y,z values based on cell centers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1100
+#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1117
 msgid "ESRI ASCII grid export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1101
+#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1118
 msgid "Converts a raster map layer into an ESRI ARCGRID file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1102
+#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1119
 msgid "GRIDATB.FOR export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1103
+#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1120
 msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1104
+#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1121
 msgid "Matlab 2D array export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1105
+#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1122
 msgid "Exports a GRASS raster to a binary MAT-File."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1106
+#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1123
 msgid "Raw binary array export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1107
+#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1124
 msgid "Exports a GRASS raster to a binary array."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1108
+#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1125
 msgid "MPEG-1 export"
 msgstr "εξαγωγή MPEG-1"
-#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1109
+#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1126
 msgid "Converts raster map series to MPEG movie."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1110
+#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1127
 msgid "PNG export"
 msgstr "εξαγωγή PNG"
-#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1111
+#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1128
 msgid "Export a GRASS raster map as a non-georeferenced PNG image."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1112
+#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1129
 msgid "PPM export"
 msgstr "εξαγωγή PPM"
-#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1113
+#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1130
 msgid "Converts a GRASS raster map to a PPM image file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1114
+#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1131
 msgid "PPM from RGB export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1115
+#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1132
 msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:144
-#: ../gui/wxpython/menustrings.py:1116 ../gui/wxpython/menustrings.py:1136
+#: ../gui/wxpython/menustrings.py:1133 ../gui/wxpython/menustrings.py:1153
 msgid "POV-Ray export"
 msgstr "εξαγωγή POV-Ray"
-#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1117
+#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1134
 msgid "Converts a raster map layer into a height-field file for POV-Ray."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1118
+#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1135
 msgid "TIFF export"
 msgstr "εξαγωγή TIFF"
-#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1119
+#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1136
 msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:1120
+#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:1137
 msgid "VRML export"
 msgstr "εξαγωγή VRML"
-#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1121
+#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1138
 msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:130 ../gui/wxpython/menustrings.py:148
-#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1122
-#: ../gui/wxpython/menustrings.py:1140 ../gui/wxpython/menustrings.py:1151
+#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1139
+#: ../gui/wxpython/menustrings.py:1157 ../gui/wxpython/menustrings.py:1168
 msgid "VTK export"
 msgstr "εξαγωγή VKT"
-#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1123
+#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1140
 msgid "Converts raster maps into the VTK-ASCII format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1124
+#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1141
 msgid "Pack raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:133 ../gui/wxpython/menustrings.py:1125
+#: ../gui/wxpython/menustrings.py:133 ../gui/wxpython/menustrings.py:1142
 msgid "Packs up a raster map and support files for copying."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1126
+#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1143
 msgid "Export vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1128
+#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1145
 msgid ""
 "Exports a vector map layer to any of the supported OGR vector formats. By "
 "default a vector map layer is exported to Esri Shapefile format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1129
+#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1146
 msgid "ASCII points or GRASS ASCII vector export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1130
+#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1147
 msgid ""
 "Exports a vector map to a GRASS ASCII vector representation. By default only "
 "features with category are exported. To export all features use 'layer=-1'."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1131
+#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1148
 msgid "DXF export"
 msgstr "εξαγωγή DXF"
-#: ../gui/wxpython/menustrings.py:140 ../gui/wxpython/menustrings.py:1132
+#: ../gui/wxpython/menustrings.py:140 ../gui/wxpython/menustrings.py:1149
 msgid "Exports vector map to DXF file format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1133
+#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1150
 msgid "Multiple GPS export formats using GPSBabel"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1134
+#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1151
 msgid ""
 "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1135
+#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1152
 #, fuzzy
 msgid "PostGIS export"
-#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1137
+#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1154
 msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1138
+#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1155
 msgid "SVG export"
 msgstr "εξαγωγή SVG"
-#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1139
+#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1156
 msgid "Exports a vector map to SVG file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1141
+#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1158
 msgid "Converts a vector map to VTK ASCII output."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1142
+#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1159
 #, fuzzy
 msgid "Pack vector map"
-#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1143
+#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1160
 msgid "Packs up a vector map and support files for copying."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1144
+#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1161
 msgid "Export 3D raster maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1145
+#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1162
 msgid "ASCII 3D export"
 msgstr "εξαγωγή ASCII 3D"
-#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1146
+#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1163
 msgid "Converts a 3D raster map layer into a ASCII text file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1147
+#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1164
 msgid "Raw binary array 3D export"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1148
+#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1165
 msgid "Exports a GRASS 3D raster map to a binary array."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1149
+#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1166
 msgid "Vis5D export"
 msgstr "εξαγωγή Vis5D"
-#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1150
+#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1167
 msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1152
+#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1169
 msgid "Converts 3D raster maps into the VTK-ASCII format."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1153
+#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1170
 msgid "Export database table"
 msgstr "εξαγωγή Βάση δεδομένων"
-#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1154
+#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1171
 msgid "Common export formats using OGR"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1155
+#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1172
 msgid "Exports attribute tables into various formats."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:1156
+#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:1173
 msgid "Link external data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:166 ../gui/wxpython/menustrings.py:1158
+#: ../gui/wxpython/menustrings.py:166 ../gui/wxpython/menustrings.py:1175
 msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:1160
+#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:1177
 msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1161
+#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1178
 msgid "Output format for raster data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1162
+#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1179
 msgid "Defines raster output format utilizing GDAL library."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1163
+#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1180
 msgid "Output format for vector data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1164
+#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1181
 msgid "Defines vector output format utilizing OGR library."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1165
+#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1182
 #, fuzzy
 msgid "Manage maps"
 msgstr "Διαχείριση χρωμάτων εικόνων"
-#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:1166
+#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:1183
 msgid "Copy"
 msgstr "Αντιγραφή"
-#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:1167
+#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:1184
 msgid ""
 "Copies available data files in the current mapset search path to the user's "
 "current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:935
-#: ../gui/wxpython/menustrings.py:1168 ../gui/wxpython/menustrings.py:1847
+#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:952
+#: ../gui/wxpython/menustrings.py:1185 ../gui/wxpython/menustrings.py:1881
 msgid "List"
 msgstr "Λίστα"
-#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:1169
+#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:1186
 msgid "Lists available GRASS data base files of the user-specified data type."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:1170
+#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:1187
 msgid "List filtered"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:1171
+#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:1188
 msgid ""
 "Lists available GRASS data base files of the user-specified data type "
 "optionally using the search pattern."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:1173
+#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:1190
 msgid "Renames data base element files in the user's current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:1175
+#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:1192
 msgid "Removes data base element files from the user's current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:1176
+#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:1193
 msgid "Delete filtered"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:1177
+#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:1194
 msgid ""
 "Removes data base element files from the user's current mapset using regular "
 "expressions."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:318
-#: ../gui/wxpython/menustrings.py:604 ../gui/wxpython/menustrings.py:838
-#: ../gui/wxpython/menustrings.py:1230 ../gui/wxpython/menustrings.py:1516
-#: ../gui/wxpython/menustrings.py:1750
+#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:855
+#: ../gui/wxpython/menustrings.py:1247 ../gui/wxpython/menustrings.py:1550
+#: ../gui/wxpython/menustrings.py:1784
 msgid "Map type conversions"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:319
-#: ../gui/wxpython/menustrings.py:1231
+#: ../gui/wxpython/menustrings.py:1248
 msgid "Raster to vector"
 msgstr "Raster σε διανυσματικό"
 #: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:320
-#: ../gui/wxpython/menustrings.py:1232
+#: ../gui/wxpython/menustrings.py:1249
 msgid "Converts a raster map into a vector map."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:321
-#: ../gui/wxpython/menustrings.py:1233
+#: ../gui/wxpython/menustrings.py:1250
 msgid "Raster series to volume"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:322
-#: ../gui/wxpython/menustrings.py:1234
+#: ../gui/wxpython/menustrings.py:1251
 msgid "Converts 2D raster map slices to one 3D raster volume map."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:323
-#: ../gui/wxpython/menustrings.py:1235
+#: ../gui/wxpython/menustrings.py:1252
 msgid "Raster 2.5D to volume"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:324
-#: ../gui/wxpython/menustrings.py:1236
+#: ../gui/wxpython/menustrings.py:1253
 msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:605
-#: ../gui/wxpython/menustrings.py:1517
+#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:622
+#: ../gui/wxpython/menustrings.py:1551
 msgid "Vector to raster"
 msgstr "Διανυσματικό σε raster"
-#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:606
-#: ../gui/wxpython/menustrings.py:1518
+#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:623
+#: ../gui/wxpython/menustrings.py:1552
 msgid "Converts (rasterize) a vector map into a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:607
-#: ../gui/wxpython/menustrings.py:1519
+#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:624
+#: ../gui/wxpython/menustrings.py:1553
 msgid "Vector to volume"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:608
-#: ../gui/wxpython/menustrings.py:1520
+#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:625
+#: ../gui/wxpython/menustrings.py:1554
 msgid "Converts a vector map (only points) into a 3D raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:609
-#: ../gui/wxpython/menustrings.py:1521
+#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:626
+#: ../gui/wxpython/menustrings.py:1555
 msgid "2D vector to 3D vector"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:610
-#: ../gui/wxpython/menustrings.py:1522
+#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:627
+#: ../gui/wxpython/menustrings.py:1556
 msgid "Performs transformation of 2D vector features to 3D."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:199 ../gui/wxpython/menustrings.py:611
-#: ../gui/wxpython/menustrings.py:1523
+#: ../gui/wxpython/menustrings.py:199 ../gui/wxpython/menustrings.py:628
+#: ../gui/wxpython/menustrings.py:1557
 msgid "Sites to vector"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:200 ../gui/wxpython/menustrings.py:612
-#: ../gui/wxpython/menustrings.py:1524
+#: ../gui/wxpython/menustrings.py:200 ../gui/wxpython/menustrings.py:629
+#: ../gui/wxpython/menustrings.py:1558
 msgid "Converts a GRASS site_lists file into a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:839
-#: ../gui/wxpython/menustrings.py:1751
+#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:856
+#: ../gui/wxpython/menustrings.py:1785
 msgid "Volume to raster series"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:840
-#: ../gui/wxpython/menustrings.py:1752
+#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:857
+#: ../gui/wxpython/menustrings.py:1786
 msgid "Converts 3D raster maps to 2D raster maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1926
+#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1960
 msgid "Georectify"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/menustrings.py:1927
+#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/menustrings.py:1961
 msgid "Manage Ground Control Points for Georectification"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:1928
+#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:1962
 msgid "Graphical modeler"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:206 ../gui/wxpython/menustrings.py:1929
+#: ../gui/wxpython/menustrings.py:206 ../gui/wxpython/menustrings.py:1963
 msgid "Launch Graphical modeler"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:207 ../gui/wxpython/menustrings.py:1977
+#: ../gui/wxpython/menustrings.py:207 ../gui/wxpython/menustrings.py:2011
 msgid "Run model"
 msgstr ""
@@ -7199,14 +7200,14 @@
 "vector data, and volumes (3D raster data) in 3D."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:211 ../gui/wxpython/menustrings.py:1007
-#: ../gui/wxpython/menustrings.py:1919 ../gui/wxpython/menustrings.py:1923
+#: ../gui/wxpython/menustrings.py:211 ../gui/wxpython/menustrings.py:1024
+#: ../gui/wxpython/menustrings.py:1953 ../gui/wxpython/menustrings.py:1957
 #: ../gui/wxpython/animation/frame.py:52
 msgid "Animation tool"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:212 ../gui/wxpython/menustrings.py:1008
-#: ../gui/wxpython/menustrings.py:1920 ../gui/wxpython/menustrings.py:1924
+#: ../gui/wxpython/menustrings.py:212 ../gui/wxpython/menustrings.py:1025
+#: ../gui/wxpython/menustrings.py:1954 ../gui/wxpython/menustrings.py:1958
 msgid "Launch animation tool."
 msgstr ""
@@ -7220,20 +7221,20 @@
 "coordinates and vice versa. It assumes a cartesian coordinate system"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:215 ../gui/wxpython/menustrings.py:1934
+#: ../gui/wxpython/menustrings.py:215 ../gui/wxpython/menustrings.py:1968
 #: ../gui/wxpython/lmgr/toolbars.py:144
 msgid "Cartographic Composer"
 msgstr "Χαρτογραφική Σύνθεση"
-#: ../gui/wxpython/menustrings.py:216 ../gui/wxpython/menustrings.py:1935
+#: ../gui/wxpython/menustrings.py:216 ../gui/wxpython/menustrings.py:1969
 msgid "Launch Cartographic Composer"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:217 ../gui/wxpython/menustrings.py:1932
+#: ../gui/wxpython/menustrings.py:217 ../gui/wxpython/menustrings.py:1966
 msgid "Map Swipe"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:218 ../gui/wxpython/menustrings.py:1933
+#: ../gui/wxpython/menustrings.py:218 ../gui/wxpython/menustrings.py:1967
 msgid "Launch Map Swipe"
 msgstr ""
@@ -7254,7 +7255,7 @@
 msgid "Quit the GRASS wxGUI session."
 msgstr "Έξοδος απο GRASS GUI"
-#: ../gui/wxpython/menustrings.py:223 ../gui/wxpython/menustrings.py:1955
+#: ../gui/wxpython/menustrings.py:223 ../gui/wxpython/menustrings.py:1989
 msgid "&Settings"
 msgstr ""
@@ -7425,7 +7426,7 @@
 msgid "Updates or removes installed GRASS AddOns extension(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1956
+#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1990
 msgid "Preferences"
 msgstr ""
@@ -7433,350 +7434,354 @@
 msgid "User GUI preferences (display font, commands, digitizer, etc.)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1178
+#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1195
 msgid "&Raster"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1179
+#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1196
 msgid "Develop raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1180
+#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1197
 msgid "Compress/decompress"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1181
+#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1198
 msgid "Compresses and decompresses raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1182
+#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1199
 msgid "Region boundaries"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1183
+#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1200
 msgid "Sets the boundary definitions for a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1184
+#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1201
 msgid "Manage NULL values"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1185
+#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1202
 msgid "Manages NULL-values of given raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1186
+#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1203
 msgid "Quantization"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1187
+#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1204
 msgid "Produces the quantization file for a floating-point map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1188
+#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1205
 msgid "Timestamp"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1189
+#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1206
 msgid ""
 "Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
 "raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1190
+#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1207
 msgid "Resample using aggregate statistics"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1191
+#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1208
 msgid "Resamples raster map layers to a coarser grid using aggregation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1192
+#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1209
 msgid "Resample using multiple methods"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1193
+#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1210
 msgid "Resamples raster map to a finer grid using interpolation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1194
+#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1211
 msgid "Resample using nearest neighbor"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1195
+#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1212
 msgid "GRASS raster map layer data resampling capability."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1196
+#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1213
 msgid "Resample using spline tension"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:1197
+#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:1214
 msgid ""
 "Reinterpolates and optionally computes topographic analysis from input "
 "raster map to a new raster map (possibly with different resolution) using "
 "regularized spline with tension and smoothing."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1198
+#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1215
 msgid "Resample using bspline"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1199
+#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1216
 msgid ""
 "Performs bilinear or bicubic spline interpolation with Tykhonov "
 "regularization."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1200
+#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1217
 msgid "Resample using analytic kernel"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1201
+#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1218
 msgid "Resamples raster map layers using an analytic kernel."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:568
-#: ../gui/wxpython/menustrings.py:1202 ../gui/wxpython/menustrings.py:1480
+#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:585
+#: ../gui/wxpython/menustrings.py:1219 ../gui/wxpython/menustrings.py:1514
 msgid "Support file maintenance"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1203
+#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1220
 msgid "Allows creation and/or modification of raster map layer support files."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1204
+#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1221
 msgid "Update map statistics"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:1205
+#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:1222
 msgid "Update raster map statistics"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1208
+#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1225
 msgid "Tiling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1209
+#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1226
 msgid ""
 "Produces tilings of the source projection for use in the destination region "
 "and projection."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:587
-#: ../gui/wxpython/menustrings.py:1210 ../gui/wxpython/menustrings.py:1499
+#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:604
+#: ../gui/wxpython/menustrings.py:1227 ../gui/wxpython/menustrings.py:1533
 msgid "Manage colors"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:588
-#: ../gui/wxpython/menustrings.py:1211 ../gui/wxpython/menustrings.py:1500
+#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:605
+#: ../gui/wxpython/menustrings.py:1228 ../gui/wxpython/menustrings.py:1534
 msgid "Color tables"
 msgstr "Χρωματικοί πίνακες"
-#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1212
+#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1229
 msgid "Creates/modifies the color table associated with a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1213
+#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1230
 msgid "Color tables (stddev)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:1214
+#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:1231
 msgid "Sets color rules based on stddev from a raster map's mean value."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:590
-#: ../gui/wxpython/menustrings.py:1215 ../gui/wxpython/menustrings.py:1502
+#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:607
+#: ../gui/wxpython/menustrings.py:1232 ../gui/wxpython/menustrings.py:1536
 msgid "Manage color rules interactively"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:1216
+#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:1233
 msgid "Interactive management of raster color tables."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:592
-#: ../gui/wxpython/menustrings.py:1217 ../gui/wxpython/menustrings.py:1504
+#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:609
+#: ../gui/wxpython/menustrings.py:1234 ../gui/wxpython/menustrings.py:1538
 msgid "Export color table"
 msgstr "Εξαγωγή χρωματικών κανόνων"
-#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:1218
+#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:1235
 msgid "Exports the color table associated with a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1219
+#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1236
 msgid "Blend 2 color rasters"
 msgstr "Μίξη 2 χρωμάτικών raster"
-#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1220
+#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1237
 msgid "Blends color components of two raster maps by a given ratio."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1221
+#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1238
 msgid "Create RGB"
-#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1222
+#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1239
 msgid ""
 "Combines red, green and blue raster maps into a single composite raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:745
-#: ../gui/wxpython/menustrings.py:1223 ../gui/wxpython/menustrings.py:1657
+#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:762
+#: ../gui/wxpython/menustrings.py:1240 ../gui/wxpython/menustrings.py:1691
 msgid "RGB to HIS"
 msgstr "RGB σε HIS "
-#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1224
+#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1241
 msgid ""
 "Generates red, green and blue raster map layers combining hue, intensity and "
 "saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1225
+#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1242
 msgid "Query raster maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1226
+#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1243
 msgid "Query values by coordinates"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1227
+#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1244
 msgid "Queries raster maps on their category values and category labels."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:1228
+#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:1245
 msgid "Query colors by value"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:1229
+#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:1246
 msgid "Queries colors for a raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1237
+#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1254
 msgid "Buffer rasters"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1238
+#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1255
 msgid ""
 "Creates a raster map showing buffer zones surrounding cells that contain non-"
 "NULL category values."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1239
+#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1256
 msgid "Concentric circles"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1240
+#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1257
 msgid "Creates a raster map containing concentric rings around a given point."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1241
+#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1258
 msgid "Closest points"
 msgstr "Κοντινότερα σημεία"
-#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1242
+#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1259
 msgid "Locates the closest points between objects in two raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1244
+#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1261
 msgid "Creates a MASK for limiting raster operation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1245
+#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1262
 #, fuzzy
 msgid "Raster map calculator"
 msgstr "Raster map calculator"
-#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1246
+#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1263
 msgid "Raster map calculator."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1247
+#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1264
 msgid "Neighborhood analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1249
+#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1266
 msgid ""
 "Makes each cell category value a function of the category values assigned to "
 "the cells around it, and stores new cell values in an output raster map "
 "layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1250
+#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1267
 msgid "Neighborhood points"
 msgstr "Γειτονικά σημεία"
-#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1251
+#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1268
 msgid ""
 "Neighborhood analysis tool for vector point maps. Makes each cell value a "
 "function of the attribute values assigned to the vector points or centroids "
 "around it, and stores new cell values in an output raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1252
+#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1269
 msgid "Overlay rasters"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1253
+#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1270
 msgid "Cross product"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1254
+#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1271
 msgid ""
 "Creates a cross product of the category values from multiple raster map "
 "layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1255
+#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1272
 msgid "Raster series"
 msgstr "Σειρά raster"
-#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1256
+#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1273
 msgid ""
 "Makes each output cell value a function of the values assigned to the "
 "corresponding cells in the input raster map layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1257
+#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1274
 msgid "Patch raster maps"
 msgstr "Συραφή χαρτών raster"
-#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1258
+#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1275
 msgid ""
 "Creates a composite raster map layer by using known category values from one "
 "(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1259
+#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1276
 msgid "Statistical overlay"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1260
+#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1277
 msgid ""
 "Calculates category or object oriented statistics (accumulator-based "
 "statistics)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1261
+#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1278
 msgid "Quantiles overlay"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1262
+#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1279
+msgid "Compute category quantiles using two passes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1280
 msgid "Solar radiance and shadows"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1263
+#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1281
 msgid "LatLong map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1264
+#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1282
 msgid "Creates a latitude/longitude raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1265
+#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1283
 msgid "Solar irradiance and irradiation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1266
+#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1284
 msgid ""
 "Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
 "reflected solar irradiation raster maps for given day, latitude, surface and "
@@ -7787,22 +7792,22 @@
 "the topography is optionally incorporated."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1267
+#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1285
 msgid "Shadows map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1268
+#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1286
 msgid ""
 "Calculates cast shadow areas from sun position and elevation raster map. "
 "Either exact sun position (A) is specified, or date/time to calculate the "
 "sun position (B) by r.sunmask itself."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1269
+#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1287
 msgid "Sunshine hours and solar angles"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1270
+#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1288
 msgid ""
 "Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
 "the angle between the direction of the geometric center of the sun's "
@@ -7810,34 +7815,34 @@
 "north in clockwise direction."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1271
+#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1289
 msgid "Terrain analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1272
+#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1290
 msgid "Generate contour lines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1273
+#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1291
 msgid "Produces a vector map of specified contours from a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1274
+#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1292
 msgid "Cost surface"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1275
+#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1293
 msgid ""
 "Creates a raster map showing the cumulative cost of moving between different "
 "geographic locations on an input raster map whose cell category values "
 "represent cost."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1276
+#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1294
 msgid "Cumulative movement costs"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1277
+#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1295
 msgid ""
 "Outputs a raster map showing the anisotropic cumulative cost. Computes "
 "anisotropic cumulative cost of moving between different geographic locations "
@@ -7846,83 +7851,83 @@
 "represent friction cost."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1278
+#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1296
 msgid "Least cost route or flow"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1279
+#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1297
 msgid ""
 "Traces a flow through an elevation model or cost surface on a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1280
+#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1298
 msgid "Shaded relief"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1281
+#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1299
 msgid "Creates shaded relief map from an elevation map (DEM). "
 msgstr ""
-#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1282
+#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1300
 msgid "Slope and aspect"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1283
+#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1301
 msgid ""
 "Generates raster maps of slope, aspect, curvatures and partial derivatives "
 "from an elevation raster map. Aspect is calculated counterclockwise from "
 "east."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1284
+#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1302
 msgid "Terrain parameters"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1285
+#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1303
 msgid ""
 "Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
 "taking fitting quadratic parameters to any size window (via least squares)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1286
+#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1304
 msgid "Textural features"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1287
+#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1305
 msgid "Generate images with textural features from a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1288
+#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1306
 msgid "Visibility"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1289
+#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1307
 msgid ""
 "Computes the viewshed of a point on an elevation raster map. Default format: "
 "NULL (invisible), vertical angle wrt viewpoint (visible)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1290
+#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1308
 msgid "Visibility [DEPRECATED]"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1291
+#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1309
 msgid "Line-of-sight raster analysis program."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1292
+#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1310
 msgid "Distance to features"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1293
+#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1311
 msgid "Generates a raster map containing distances to nearest raster features."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1294
+#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1312
 msgid "Horizon angle"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1295
+#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1313
 msgid ""
 "Horizon angle computation from a digital elevation model. Computes horizon "
 "angle height from a digital elevation model. The module has two different "
@@ -7934,328 +7939,404 @@
 "horizon height in radians."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1296
+#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1314
 msgid "Transform features"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1297
+#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1315
 msgid "Clump"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1298
+#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1316
 msgid ""
 "Recategorizes data in a raster map by grouping cells that form physically "
 "discrete areas into unique categories."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1299
+#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1317
 msgid "Grow"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1300
+#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1318
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1301
+#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1319
 msgid "Thin"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1302
+#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1320
 msgid "Thins non-zero cells that denote linear features in a raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1303
+#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1321
 msgid "Hydrologic modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1304
+#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1322
 msgid "Carve stream channels"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1305
+#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1323
 msgid ""
 "Generates stream channels. Takes vector stream data, transforms it to raster "
 "and subtracts depth from the output DEM."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1306
+#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1324
 msgid "Fill lake"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1307
+#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1325
 msgid "Fills lake at given point to given level."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1308
+#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1326
 msgid "Depressionless map and flowlines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1309
+#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1327
 msgid ""
 "Filters and generates a depressionless elevation map and a flow direction "
 "map from a given elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1310
+#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1328
 msgid "Flow accumulation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1311
+#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1329
 msgid "Flow computation for massive grids (float version)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1312
+#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1330
 msgid "Flow lines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1313
+#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1331
 msgid ""
 "Constructs flowlines. Computes flowlines, flowpath lengths, and "
 "flowaccumulation (contributing areas) from a elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1314
+#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1332
 msgid "Watershed analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1315
+#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1333
 msgid "Calculates hydrological parameters and RUSLE factors."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1316
+#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1334
 msgid "Watershed subbasins"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1317
+#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1335
 msgid "Generates watershed subbasins raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1318
+#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1336
 msgid "Watershed basin creation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1319
+#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1337
 msgid "Creates watershed basins from a drainage direction map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1320
+#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1338
+msgid "River channel characteristics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1339
+msgid "Calculates local parameters for individual streams."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1340
+msgid "River distance and elevation characteristics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1341
+msgid ""
+"Calculates distance to and elevation above streams and outlets. The module "
+"can work in stream mode where target are streams and outlets mode where "
+"targets are outlets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1342
+msgid "Extraction of stream networks"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1343
+msgid "Performs stream network extraction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1344
+msgid "River ordering and hierarchy"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1345
+msgid ""
+"Calculates Strahler's and more streams hierarchy. Basic module for "
+"topological analysis of drainage network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1346
+#, fuzzy
+msgid "River segment characteristics"
+msgstr "Γενικές στατιστικές"
+#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1347
+msgid ""
+"Divides network into near straight-line segments and calculate its order."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1348
+msgid "River elevation change"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1349
+msgid "Calculates local parameters for slope subsystem."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1350
+msgid "Position correction of water outlet point"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1351
+msgid ""
+"Snap point to modelled river network. Input can be stream network, point "
+"vector map with outlets or outlet coordinates."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1352
+#, fuzzy
+msgid "Horton's statistics"
+#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1353
+msgid ""
+"Calculates Horton's statistics for Strahler and Horton ordered networks "
+"created with r.stream.order."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1354
 msgid "SIMWE Overland flow modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1321
+#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1355
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1322
+#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1356
 msgid "SIMWE Sediment flux modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1323
+#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1357
 msgid ""
 "Sediment transport and erosion/deposition simulation using path sampling "
 "method (SIMWE)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1324
+#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1358
 msgid "Topographic index map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1325
+#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1359
 msgid "Creates topographic index map from elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1326
+#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1360
 msgid "TOPMODEL simulation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1327
+#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1361
 msgid "Simulates TOPMODEL which is a physically based hydrologic model."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1328
+#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1362
 msgid "USLE K-factor"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1329
+#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1363
 msgid "Computes USLE Soil Erodibility Factor (K)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1330
+#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1364
 msgid "USLE R-factor"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1331
+#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1365
 msgid "Computes USLE R factor, Rainfall erosivity index."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:851
-#: ../gui/wxpython/menustrings.py:1332 ../gui/wxpython/menustrings.py:1763
+#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:868
+#: ../gui/wxpython/menustrings.py:1366 ../gui/wxpython/menustrings.py:1797
 msgid "Groundwater modeling"
 msgstr "Μοντελοποίηση υπογείων νερών"
-#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1333
+#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1367
 msgid "Groundwater flow"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1334
+#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1368
 msgid ""
 "Numerical calculation program for transient, confined and unconfined "
 "groundwater flow in two dimensions."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1335
+#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1369
 msgid "Groundwater solute transport"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1336
+#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1370
 msgid ""
 "Numerical calculation program for transient, confined and unconfined solute "
 "transport in two dimensions"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1337
+#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1371
 msgid "Landscape structure modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1338
+#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1372
 msgid "Analyze landscape"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1339
+#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1373
 msgid "Analyze patches"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1340
+#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1374
 msgid "Landscape patch analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1341
+#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1375
 msgid "Set up sampling and analysis framework"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1342
+#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1376
 msgid "Configuration editor for r.li.'index'"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1343
+#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1377
 msgid "Edge density"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1344
+#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1378
 msgid ""
 "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1345
+#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1379
 msgid "Contrast weighted edge density"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1346
+#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1380
 msgid "Calculates contrast weighted edge density index on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1347
+#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1381
 msgid "Patch area mean"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1348
+#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1382
 msgid ""
 "Calculates mean patch size index on a raster map, using a 4 neighbour "
 "algorithm"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1349
+#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1383
 msgid "Patch area range"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1350
+#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1384
 msgid "Calculates range of patch area size on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1351
+#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1385
 msgid "Patch area Std Dev"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1352
+#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1386
 msgid "Calculates standard deviation of patch area a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1353
+#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1387
 msgid "Patch area Coeff Var"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1354
+#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1388
 msgid "Calculates coefficient of variation of patch area on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1355
+#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1389
 msgid "Patch density"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1356
+#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1390
 msgid ""
 "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1357
+#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1391
 msgid "Patch number"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1358
+#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1392
 msgid ""
 "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1359
+#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1393
 msgid "Dominance's diversity"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1360
+#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1394
 msgid "Calculates dominance's diversity index on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1361
+#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1395
 msgid "Shannon's diversity"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1362
+#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1396
 msgid "Calculates Shannon's diversity index on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1363
+#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1397
 msgid "Simpson's diversity"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1364
+#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1398
 msgid "Calculates Simpson's diversity index on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1365
+#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1399
 msgid "Richness"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1366
+#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1400
 #, fuzzy
 msgid "Calculates richness index on a raster map"
 msgstr "Υπολογίζει την γραμμικη συσχέτιση δυο raster: y = a + b*x"
-#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1367
+#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1401
 msgid "Shape index"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1368
+#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1402
 msgid "Calculates shape index on a raster map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1369
+#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1403
 msgid "Wildfire modeling"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1370
+#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1404
 msgid "Rate of spread"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1371
+#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1405
 msgid ""
 "Generates rate of spread raster maps. Generates three, or four raster map "
 "layers showing the base (perpendicular) rate of spread (ROS), the maximum "
@@ -8263,21 +8344,21 @@
 "potential spotting distance for fire spread simulation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1372
+#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1406
 msgid "Least-cost spread paths"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1373
+#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1407
 msgid ""
 "Recursively traces the least cost path backwards to cells from which the "
 "cumulative cost was determined."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1374
+#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1408
 msgid "Anisotropic spread simulation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1375
+#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1409
 msgid ""
 "Simulates elliptically anisotropic spread. Generates a raster map of the "
 "cumulative time of spread, given raster maps containing the rates of spread "
@@ -8286,202 +8367,202 @@
 "Usable for fire spread simulations."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1376
+#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1410
 msgid "Change category values and labels"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1377
+#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1411
 msgid "Interactively edit category values"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1378
+#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1412
 msgid "Edits cell values in a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1379
+#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1413
 msgid "Reclassify by size"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1380
+#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1414
 msgid ""
 "Reclasses a raster map greater or less than user specified area size (in "
 "hectares)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:678
-#: ../gui/wxpython/menustrings.py:1381 ../gui/wxpython/menustrings.py:1590
+#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:695
+#: ../gui/wxpython/menustrings.py:1415 ../gui/wxpython/menustrings.py:1624
 msgid "Reclassify"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1382
+#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1416
 msgid ""
 "Reclassify raster map based on category values. Creates a new raster map "
 "whose category values are based upon a reclassification of the categories in "
 "an existing raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1383
+#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1417
 msgid "Recode"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1384
+#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1418
 msgid "Recodes categorical raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1385
+#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1419
 msgid "Rescale"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1386
+#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1420
 msgid "Rescales the range of category values in a raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1387
+#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1421
 msgid "Rescale with histogram"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1388
+#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1422
 msgid ""
 "Rescales histogram equalized the range of category values in a raster map "
 "layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1389
+#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1423
 msgid "Generate random cells"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1390
+#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1424
 msgid "Random cells"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1391
+#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1425
 msgid "Generates random cell values with spatial dependence."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1392
+#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1426
 msgid "Random cells and vector points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1393
+#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1427
 msgid ""
 "Creates a raster map layer and vector point map containing randomly located "
 "points."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1394
+#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1428
 msgid "Generate surfaces"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1395
+#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1429
 msgid "Fractal surface"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1396
+#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1430
 msgid "Creates a fractal surface of a given fractal dimension."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1397
+#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1431
 msgid "Gaussian kernel density surface"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1398
+#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1432
 msgid ""
 "Generates a raster density map from vector points map. Density is computed "
 "using a moving kernel. Optionally generates a vector density map on a vector "
 "network."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1399
+#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1433
 msgid "Gaussian deviates surface"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1400
+#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1434
 msgid ""
 "Generates a raster map using gaussian random number generator. Mean and "
 "standard deviation of gaussian deviates can be expressed by the user."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1401
+#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1435
 #: ../gui/wxpython/nviz/tools.py:4587
 msgid "Plane"
 msgstr "Επίπεδο"
-#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1402
+#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1436
 msgid ""
 "Creates raster plane map given dip (inclination), aspect (azimuth) and one "
 "point."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1403
+#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1437
 msgid "Random deviates surface"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1404
+#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1438
 msgid ""
 "Produces a raster surface map of uniform random deviates with defined range."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1405
+#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1439
 msgid "Random surface with spatial dependence"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1406
+#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1440
 msgid "Generates random surface(s) with spatial dependence."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1407
+#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1441
 msgid "Interpolate surfaces"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1408
+#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1442
 msgid "Bilinear and bicubic from vector points"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1409
+#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1443
 msgid ""
 "Performs bicubic or bilinear spline interpolation with Tykhonov "
 "regularization."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1410
+#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1444
 msgid "IDW from raster points"
 msgstr "IDW απο σημεία raster"
-#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1411
+#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1445
 msgid "Surface interpolation utility for raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1412
+#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1446
 msgid "IDW from raster points (alternate method for sparse points)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1413
+#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1447
 msgid "Surface generation program."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1414
+#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1448
 msgid "IDW from vector points"
 msgstr "IDW απο διανυσματικα σημεία"
-#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1415
+#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1449
 msgid ""
 "Provides surface interpolation from vector point data by Inverse Distance "
 "Squared Weighting."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1416
+#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1450
 msgid "Raster contours"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1417
+#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1451
 msgid "Generates surface raster map from rasterized contours."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1418
+#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1452
 msgid "Regularized spline tension"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1419
+#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1453
 msgid ""
 "Performs surface interpolation from vector points map by splines. Spatial "
 "approximation and topographic analysis from given point or isoline data in "
@@ -8489,545 +8570,545 @@
 "tension."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1420
+#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1454
 msgid "Ordinary or block kriging"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1421
+#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1455
 msgid "Performs ordinary or block kriging."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1422
+#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1456
 msgid "Fill NULL cells"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1423
+#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1457
 msgid "Fills no-data areas in raster maps using spline interpolation."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:717
-#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:995
-#: ../gui/wxpython/menustrings.py:1424 ../gui/wxpython/menustrings.py:1629
-#: ../gui/wxpython/menustrings.py:1737 ../gui/wxpython/menustrings.py:1907
+#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:734
+#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1012
+#: ../gui/wxpython/menustrings.py:1458 ../gui/wxpython/menustrings.py:1663
+#: ../gui/wxpython/menustrings.py:1771 ../gui/wxpython/menustrings.py:1941
 msgid "Reports and statistics"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1425
+#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1459
 msgid "Basic raster metadata"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1426
+#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1460
 msgid "Outputs basic information about a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1427
+#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1461
 msgid "Manage category information"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1428
+#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1462
 msgid ""
 "Manages category values and labels associated with user-specified raster map "
 "layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1429
+#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1463
 msgid "General statistics"
-#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1430
+#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1464
 #, fuzzy
 msgid "Generates area statistics for raster map."
 msgstr "Εισαγωγή αρχείου ESRI e00 σε διανυσματικό χάρτη."
-#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1431
+#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1465
 msgid "Quantiles for large data sets"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1432
+#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1466
 msgid "Compute quantiles using two passes."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1433
+#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1467
 msgid "Range of category values"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1434
+#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1468
 msgid "Prints terse list of category values found in a raster map layer."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1435
+#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1469
 msgid "Sum area by raster map and category"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1436
+#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1470
 msgid "Reports statistics for raster maps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1437
+#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1471
 msgid "Statistics for clumped cells"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1438
+#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1472
 msgid ""
 "Calculates the volume of data \"clumps\". Optionally produces a GRASS vector "
 "points map containing the calculated centroids of these clumps."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1439
+#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1473
 msgid "Total corrected area"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1440
+#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1474
 msgid "Prints estimation of surface area for raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1441
+#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1475
 #: ../gui/wxpython/lmgr/layertree.py:579 ../gui/wxpython/lmgr/layertree.py:606
 msgid "Univariate raster statistics"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1442
+#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1476
 msgid ""
 "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1443
+#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1477
 msgid "Sample transects"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1444
+#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1478
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1445
+#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1479
 msgid "Sample transects (bearing/distance)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1446
+#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1480
 msgid ""
 "Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1447
+#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1481
 msgid "Covariance/correlation"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1448
+#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1482
 msgid ""
 "Outputs a covariance/correlation matrix for user-specified raster map "
 "layer(s)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1449
+#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1483
 msgid "Linear regression"
 msgstr "Γραμμική συσχέτιση"
-#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1450
+#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1484
 msgid "Calculates linear regression from two raster maps: y = a + b*x."
-#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1451
+#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1485
 #, fuzzy
 msgid "Multiple regression"
-#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1452
+#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1486
 #, fuzzy
 msgid "Calculates multiple linear regression from raster maps."
-#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1453
+#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1487
 msgid "Mutual category occurrences"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1454
+#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1488
 msgid ""
 "Tabulates the mutual occurrence (coincidence) of categories for two raster "
 "map layers."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1455
+#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1489
 msgid "&Vector"
 msgstr "&Διανυσματικό"
-#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1456
+#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1490
 msgid "Develop vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1458
+#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1492
 msgid "Create new empty vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1459
+#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1493
 msgid "Edit vector map (non-interactively)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1460
+#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1494
 msgid ""
 "Edits a vector map, allows adding, deleting and modifying selected vector "
 "features."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1461
+#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1495
 msgid "Convert object types"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1462
+#: ../gui/wxpython/menustrings.py:567 ../gui/wxpython/menustrings.py:1496
 msgid "Changes type of vector features."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1463
+#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1497
 msgid "Parallel lines"
 msgstr "Παράλληλες γραμμές"
-#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1464
+#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1498
 msgid "Creates parallel line to input vector lines."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1465
+#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1499
 msgid "Dissolve boundaries"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1466
+#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1500
 msgid ""
 "Dissolves boundaries between adjacent areas sharing a common category number "
 "or attribute."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1467
+#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1501
 msgid "Create 3D vector over raster"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1468
+#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1502
 msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1469
+#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1503
 msgid "Extrude 3D vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1470
+#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1504
 msgid ""
 "Extrudes flat vector features to 3D vector features with defined height. "
 "Optionally the height can be derived from sampling of elevation raster map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1471
+#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1505
 msgid "Create labels"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1472
+#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1506
 msgid "Creates paint labels for a vector map from attached attributes."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1473
+#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1507
 msgid "Create optimally placed labels"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1474
+#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1508
 msgid "Reposition vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1475
+#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1509
 msgid ""
 "Performs an affine transformation (shift, scale and rotate) on vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1476
+#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1510
 msgid "Rectify vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1477
+#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1511
 msgid ""
 "Rectifies a vector by computing a coordinate transformation for each object "
 "in the vector based on the control points."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1481
+#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1515
 msgid "Updates vector map metadata."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1482
+#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:1516
 msgid "Topology maintenance"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1483
+#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1517
 msgid "Create or rebuild topology"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1484
+#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1518
 msgid ""
 "Creates topology for vector map. Optionaly also checks for topological "
 "errors."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1485
+#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1519
 msgid "Rebuild topology on all vector maps"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1486
+#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1520
 msgid "Rebuilds topology on all vector maps in the current mapset."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1487
+#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1521
 msgid "Build polylines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1488
+#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1522
 msgid "Builds polylines from lines or boundaries."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1489
+#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1523
 msgid "Split lines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1490
+#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1524
 msgid "Splits vector lines to shorter segments."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1491
+#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1525
 msgid "Split polylines"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1492
+#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:1526
 msgid "Creates points/segments from input vector lines and positions."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1493
+#: ../gui/wxpython/menustrings.py:598 ../gui/wxpython/menustrings.py:1527
 msgid "Clean vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1494
+#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1528
 msgid "Toolset for cleaning topology of vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:583 ../gui/wxpython/menustrings.py:1495
+#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1529
 msgid "Smooth or simplify"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1496
+#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1530
 msgid "Performs vector based generalization."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:585 ../gui/wxpython/menustrings.py:1497
+#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1531
 msgid "Add centroids"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1498
+#: ../gui/wxpython/menustrings.py:603 ../gui/wxpython/menustrings.py:1532
 msgid "Adds missing centroids to closed boundaries."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1501
+#: ../gui/wxpython/menustrings.py:606 ../gui/wxpython/menustrings.py:1535
 msgid "Creates/modifies the color table associated with a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1503
+#: ../gui/wxpython/menustrings.py:608 ../gui/wxpython/menustrings.py:1537
 msgid "Interactive management of vector color tables."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1505
+#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:1539
 msgid "Exports the color table associated with a vector map."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1506
+#: ../gui/wxpython/menustrings.py:611 ../gui/wxpython/menustrings.py:1540
 msgid "Query vector map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1507
+#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:1541
 msgid "Query with coordinate(s)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1508
+#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1542
 msgid "Queries a vector map at given locations."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:894
-#: ../gui/wxpython/menustrings.py:1509 ../gui/wxpython/menustrings.py:1806
+#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:911
+#: ../gui/wxpython/menustrings.py:1543 ../gui/wxpython/menustrings.py:1840
 msgid "Query vector attribute data"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:598 ../gui/wxpython/menustrings.py:895
-#: ../gui/wxpython/menustrings.py:1510 ../gui/wxpython/menustrings.py:1807
+#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:912
+#: ../gui/wxpython/menustrings.py:1544 ../gui/wxpython/menustrings.py:1841
 msgid "Prints vector map attributes."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1511
+#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1545
 msgid "Feature selection"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1512
+#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1546
 msgid "Select by attributes"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1513
+#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1547
 msgid ""
 "Selects vector features from an existing vector map and creates a new vector "
 "map containing only the selected features."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1514
+#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1548
 msgid "Select by another map"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:603 ../gui/wxpython/menustrings.py:1515
+#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1549
 msgid ""
 "Selects features from vector map (A) by features from other vector map (B)."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1525
+#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1559
 msgid "Buffer vectors"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:1526
+#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1560
 msgid "Creates a buffer around vector features of given type."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:1527
+#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1561
 msgid "Lidar analysis"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1528
+#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1562
 msgid "Identify and remove outliers"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:714
-#: ../gui/wxpython/menustrings.py:1529 ../gui/wxpython/menustrings.py:1626
+#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:731
+#: ../gui/wxpython/menustrings.py:1563 ../gui/wxpython/menustrings.py:1660
 msgid "Removes outliers from vector point data."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1530
+#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1564
 msgid "Detect edges"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1531
+#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1565
 msgid "Detects the object's edges from a LIDAR data set."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1532
+#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1566
 msgid "Detect interiors"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:1533
+#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1567
 msgid ""
 "Building contour determination and Region Growing algorithm for determining "
 "the building inside"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:622 ../gui/wxpython/menustrings.py:1534
+#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1568
 msgid "Correct and reclassify objects"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:1535
+#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1569
 msgid ""
 "Correction of the v.lidar.growing output. It is the last of the three "
 "algorithms for LIDAR filtering."
