[GRASS-SVN] r59531 - in grass/branches/develbranch_6/vector: v.parallel v.parallel2
svn_grass at osgeo.org
Mon Mar 31 14:10:47 PDT 2014
Author: neteler
Date: 2014-03-31 14:10:47 -0700 (Mon, 31 Mar 2014)
New Revision: 59531
grass/branches/develbranch_6/vector/v.parallel/main.c
grass/branches/develbranch_6/vector/v.parallel2/main.c
v.parallel: add buffer keyword
Modified: grass/branches/develbranch_6/vector/v.parallel/main.c
--- grass/branches/develbranch_6/vector/v.parallel/main.c 2014-03-31 21:10:24 UTC (rev 59530)
+++ grass/branches/develbranch_6/vector/v.parallel/main.c 2014-03-31 21:10:47 UTC (rev 59531)
@@ -40,7 +40,7 @@
G_gisinit(argv[0]);
module = G_define_module();
- module->keywords = _("vector, geometry");
+ module->keywords = _("vector, geometry, buffer");
module->description = _("Create parallel line to input lines");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/branches/develbranch_6/vector/v.parallel2/main.c
--- grass/branches/develbranch_6/vector/v.parallel2/main.c 2014-03-31 21:10:24 UTC (rev 59530)
+++ grass/branches/develbranch_6/vector/v.parallel2/main.c 2014-03-31 21:10:47 UTC (rev 59531)
@@ -42,7 +42,7 @@
G_gisinit(argv[0]);
module->description = _("Creates parallel line to input vector lines.");
