[GRASS-SVN] r60017 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Thu May 1 12:17:11 PDT 2014
Author: huhabla
Date: 2014-05-01 12:17:11 -0700 (Thu, 01 May 2014)
New Revision: 60017
grass/trunk/lib/python/temporal/c_libraries_interface.py
grass/trunk/lib/python/temporal/list_stds.py
Added stds and time stamped map list function that is sensitive to the user mapsets access rights
Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
--- grass/trunk/lib/python/temporal/c_libraries_interface.py 2014-05-01 18:49:46 UTC (rev 60016)
+++ grass/trunk/lib/python/temporal/c_libraries_interface.py 2014-05-01 19:17:11 UTC (rev 60017)
@@ -38,13 +38,41 @@
READ_MAP_INFO=5
MAP_EXISTS=6
READ_MAP_INFO=7
+ AVAILABLE_MAPSETS = 8
TYPE_RASTER=0
TYPE_RASTER3D=1
TYPE_VECTOR=2
+def available_mapsets(lock, conn, data):
+ """!Return all available mapsets the user can access as a list of strings
+ @param lock A multiprocessing.Lock instance
+ @param conn A multiprocessing.Pipe instance used to send True or False
+ @param data The list of data entries [function_id]
+ @return Names of available mapsets as list of strings
+ mapsets = libgis.G_available_mapsets()
+ count = 0
+ mapset_list = []
+ while mapsets[count]:
+ char_list = ""
+ mapset = mapsets[count]
+ if libgis.G__mapset_permissions(mapset) > 0:
+ count += 1
+ c = 0
+ while mapset[c] != "\x00":
+ char_list += mapset[c]
+ c += 1
+ mapset_list.append(char_list)
+ conn.send(mapset_list)
def _has_timestamp(lock, conn, data):
"""!Check if the file based GRASS timestamp is present and send
True or False using the provided pipe.
@@ -586,7 +614,7 @@
# Crerate the function array
- functions = [0]*8
+ functions = [0]*9
functions[RPCDefs.STOP] = _stop
functions[RPCDefs.HAS_TIMESTAMP] = _has_timestamp
functions[RPCDefs.WRITE_TIMESTAMP] = _write_timestamp
@@ -594,6 +622,7 @@
functions[RPCDefs.REMOVE_TIMESTAMP] = _remove_timestamp
functions[RPCDefs.READ_MAP_INFO] = _read_map_info
functions[RPCDefs.MAP_EXISTS] = _map_exists
+ functions[RPCDefs.AVAILABLE_MAPSETS] = available_mapsets
libgis.G_gisinit("c_library_server")
libgis.G_debug(1, "Start C-interface server")
@@ -643,7 +672,12 @@
>>> grass.run_command("v.timestamp", map="test", date='12 Mar 1995 10:34:40', overwrite=True, quiet=True)
0
+ # Check mapsets
+ >>> ciface = tgis.CLibrariesInterface()
+ >>> mapsets = ciface.available_mapsets()
+ >>> print mapsets[0]
+ PERMANENT
# Raster map
>>> check = ciface.raster_map_exists("test", tgis.get_current_mapset())
@@ -1031,6 +1065,19 @@
name, mapset, layer, timestring])
return self.client_conn.recv()
+ def available_mapsets(self):
+ @param data Can be None
+ self._check_restart_server()
+ self.client_conn.send([RPCDefs.AVAILABLE_MAPSETS, ])
+ return self.client_conn.recv()
def stop(self):
"""!Stop the messenger server and close the pipe
Modified: grass/trunk/lib/python/temporal/list_stds.py
--- grass/trunk/lib/python/temporal/list_stds.py 2014-05-01 18:49:46 UTC (rev 60016)
+++ grass/trunk/lib/python/temporal/list_stds.py 2014-05-01 19:17:11 UTC (rev 60017)
@@ -28,6 +28,83 @@
+def get_dataset_list(type, temporal_type, columns=None, where=None, order=None):
+ """! Return a list of time stamped maps or space time datasets of a specific temporal type
+ that are registred in the temporal database
+ This method returns a dictionary, the keys are the available mapsets,
+ the values are the rows from the SQL database query.
+ @param type The type of the datasets (strds, str3ds, stvds, rast, rast3d, vect)
+ @param temporal_type The temporal type of the datasets (absolute, relative)
+ @param columns A comma separated list of columns that will be selected
+ @param where A where statement for selected listing without "WHERE"
+ @param order A comma separated list of columns to order the
+ datasets by category
+ @return A dictionary with the rows of the SQL query for each available mapset
+ >>> import grass.temporal as tgis
+ >>> tgis.init()
+ >>> name = "list_stds_test"
+ >>> sp = tgis.open_new_space_time_dataset(name=name, type="strds",
+ ... temporaltype="absolute", title="title", descr="descr", semantic="mean", dbif=None, overwrite=True)
+ >>> mapset = tgis.get_current_mapset()
+ >>> stds_list = tgis.get_dataset_list("strds", "absolute", columns="name")
+ >>> rows = stds_list[mapset]
+ >>> for row in rows:
+ ... if row["name"] == name:
+ ... print True
+ True
+ >>> stds_list = tgis.get_dataset_list("strds", "absolute", columns="name,mapset", where="mapset = '%s'"%(mapset))
+ ... if row["name"] == name and row["mapset"] == mapset:
+ ... print True
+ True
+ >>> check = sp.delete()
+ id = None
+ sp = dataset_factory(type, id)
+ dbif = SQLDatabaseInterfaceConnection()
+ dbif.connect()
+ mapsets = get_tgis_c_library_interface().available_mapsets()
+ result = {}
+ for mapset in mapsets:
+ if temporal_type == "absolute":
+ table = sp.get_type() + "_view_abs_time"
+ else:
+ table = sp.get_type() + "_view_rel_time"
+ if columns and columns.find("all") == -1:
+ sql = "SELECT " + str(columns) + " FROM " + table
+ else:
+ sql = "SELECT * FROM " + table
+ if where:
+ sql += " WHERE " + where
+ sql += " AND mapset = '%s'"%(mapset)
+ else:
+ sql += " WHERE mapset = '%s'"%(mapset)
+ if order:
+ sql += " ORDER BY " + order
+ dbif.cursor.execute(sql)
+ rows = dbif.cursor.fetchall()
+ if rows:
+ result[mapset] = rows
+ return result
def list_maps_of_stds(type, input, columns, order, where, separator, method, header, gran=None):
"""! List the maps of a space time dataset using diffetent methods
@@ -35,7 +112,7 @@
@param input Name of a space time raster dataset
@param columns A comma separated list of columns to be printed to stdout
- space time dataset by category
+ maps by category
e.g: start_time < "2001-01-01" and end_time > "2001-01-01"
@param separator The field separator character between the columns
@@ -185,3 +262,9 @@
print output
if connected:
dbif.close()
+if __name__ == "__main__":
+ import doctest
+ doctest.testmod()
