[GRASS-SVN] r60021 - grass/branches/releasebranch_6_4/vector/v.kcv
svn_grass at osgeo.org
Thu May 1 13:00:52 PDT 2014
Author: neteler
Date: 2014-05-01 13:00:52 -0700 (Thu, 01 May 2014)
New Revision: 60021
grass/branches/releasebranch_6_4/vector/v.kcv/description.html
v.kcv manual updated
Modified: grass/branches/releasebranch_6_4/vector/v.kcv/description.html
--- grass/branches/releasebranch_6_4/vector/v.kcv/description.html 2014-05-01 19:57:10 UTC (rev 60020)
+++ grass/branches/releasebranch_6_4/vector/v.kcv/description.html 2014-05-01 20:00:52 UTC (rev 60021)
@@ -1,48 +1,70 @@
<h2>DESCRIPTION</h2>
- <I>v.kcv</I> randomly divides a points lists into <I>k</I> sets of
- test/train data (for <b>k</b>-fold <b>c</b>ross <b>v</b>alidation).
- Test partitions are mutually exclusive. That is, a point will
- appear in only one test partition and <I>k-1</I> training partitions.
- The program generates a random point using the selected
- random number generator and then finds the closest point to
- it. This site is removed from the candidate list (meaning
- that it will not be selected for any other test set) and
- saved in the first test partition file. This is repeated
- until enough points have been selected for the test partition.
- The number of points chosen for test partitions
- depends upon the number of sites available and the number
- of partitions chosen (this number is made as consistent as
- possible while ensuring that all sites will be chosen for
- testing). This process of filling up a test partition is
- done <I>k</I> times.
+<em>v.kcv</em> randomly divides a points lists into <em>k</em> sets of
+test/train data (for <b>k</b>-fold <b>c</b>ross <b>v</b>alidation).
+Test partitions are mutually exclusive. That is, a point will appear in
+only one test partition and <em>k-1</em> training partitions.
+The module generates a random point using the selected random number
+generator and then finds the closest point to it. This site is removed
+from the candidate list (meaning that it will not be selected for any
+other test set) and saved in the first test partition file. This is
+repeated until enough points have been selected for the test partition.
+The number of points chosen for test partitions depends upon the number
+of sites available and the number of partitions chosen (this number is
+made as consistent as possible while ensuring that all sites will be
+chosen for testing). This process of filling up a test partition is
+done <em>k</em> times.
<h2>NOTES</h2>
- An ideal random sites generator will follow a Poisson dis
- <!-- BUG: missing text -->
- only be as random as the original points. This program
- simply divides points up in a random manner.<p>
- Be warned that random number generation occurs over the
- intervals defined by the region of the map.<p>
+An ideal random sites generator will follow a Poisson distribution and
+will only be as random as the original sites. This module simply
+divides vector points up in a random manner.
- This program may not work properly with Lat-long data.
+<p>
+Be warned that random number generation occurs over the
+intervals defined by the current region of the map.
+<p>
+This program may not work properly with Lat-long data.
+<h2>EXAMPLES</h2>
+All examples are based on the North Carolina sample dataset.
+<div class="code"><pre>
+g.copy vect=geonames_wake,my_geonames_wake
+v.kcv input=my_geonames_wake output=my_geonames_wake_kvc column=part k=10
+</pre></div>
+<p>
+g.copy vect=geodetic_pts,my_geodetic_pts
+v.kcv input=my_geodetic_pts output=my_geodetic_pts_kvc column=part k=10
+</pre></div>
<h2>SEE ALSO</h2>
-<I><a href=v.random.html>v.random</a></I> and
-<I><a href=g.region.html>g.region</a></I>
+<em>
+<a href=v.random.html>v.random</a>,
+<a href=g.region.html>g.region</a>
+</em>
<h2>AUTHOR</h2>
-<a href="http://mccauley-usa.com/">James Darrell McCauley</a>
-<a href="mailto:darrell at mccauley-usa.com"><darrell at mccauley-usa.com></a>,
+James Darrell McCauley,
<br>when he was at:
-<a href="http://ABE.www.ecn.purdue.edu/ABE/">Agricultural
-Engineering</a>
+<a href="http://ABE.www.ecn.purdue.edu/ABE/">Agricultural Engineering</a>
<a href="http://www.purdue.edu/">Purdue University</a>
<p>
-Update to 5.7 Radim Blazek 10 / 2004
+27 Jan 1994: fixed RAND_MAX for Solaris 2.3<br>
+13 Sep 2000: released under GPL<br>
+Updated to 5.7 Radim Blazek 10 / 2004<br>
+OGR support by Martin Landa (2009)<br>
+Speed-up by Jan Vandrol and Jan Ruzicka (2013)
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
