[GRASS-SVN] r60042 - grass/trunk/vector/v.in.db
Fri May 2 07:17:25 PDT 2014
Author: hcho
Date: 2014-05-02 07:17:25 -0700 (Fri, 02 May 2014)
New Revision: 60042
   grass/trunk/vector/v.in.db/v.in.db.html
not not => not
Modified: grass/trunk/vector/v.in.db/v.in.db.html
--- grass/trunk/vector/v.in.db/v.in.db.html	2014-05-02 13:52:55 UTC (rev 60041)
+++ grass/trunk/vector/v.in.db/v.in.db.html	2014-05-02 14:17:25 UTC (rev 60042)
@@ -29,7 +29,7 @@
         table=pat_stazioni x=east y=north z=quota key=id output=pat_stazioni
 </pre></div>
-<p>If an ID column is not not present in the PostgreSQL table, a new
+<p>If an ID column is not present in the PostgreSQL table, a new
 column should be added. See <a href="grass-pg.html">PostgreSQL DB
 driver</a> page for details.
@@ -42,7 +42,7 @@
         table=station x="x(geom)" y="y(geom)" z="z(geom)" key=id out=meteostations
 </pre></div>
