[GRASS-SVN] r60046 - grass/trunk/vector/v.in.db
svn_grass at osgeo.org
Fri May 2 09:30:15 PDT 2014
Author: hcho
Date: 2014-05-02 09:30:15 -0700 (Fri, 02 May 2014)
New Revision: 60046
grass/trunk/vector/v.in.db/main.c
Disallow overwriting the output vector when the input table is linked to the output vector because overwrting will delete the table first.
Modified: grass/trunk/vector/v.in.db/main.c
--- grass/trunk/vector/v.in.db/main.c 2014-05-02 15:25:56 UTC (rev 60045)
+++ grass/trunk/vector/v.in.db/main.c 2014-05-02 16:30:15 UTC (rev 60046)
@@ -116,6 +116,36 @@
Cats = Vect_new_cats_struct();
db_init_string(&sql);
+ if (G_get_overwrite()) {
+ /* We don't want to delete the input table when overwriting the output
+ * vector. */
+ char name[GNAME_MAX], mapset[GMAPSET_MAX];
+ if (G_name_is_fully_qualified(outvect->answer, name, mapset)) {
+ } else {
+ strcpy(name, outvect->answer);
+ strcpy(mapset, G_mapset());
+ Vect_set_open_level(1); /* no topo needed */
+ if (G_find_vector2(name, mapset) && Vect_open_old(&Map, name, mapset)) {
+ int num_dblinks;
+ num_dblinks = Vect_get_num_dblinks(&Map);
+ for (i = 0; i < num_dblinks; i++) {
+ if ((fi = Vect_get_dblink(&Map, i)) != NULL &&
+ strcmp(fi->driver, driver_opt->answer) == 0 &&
+ strcmp(fi->database, database_opt->answer) == 0 &&
+ strcmp(fi->table, table_opt->answer) == 0)
+ G_fatal_error(_("Vector <%s> cannot be overwritten "
+ "because input table <%s> is linked to "
+ "the output vector."),
+ outvect->answer, table_opt->answer);
+ Vect_close(&Map);
Vect_open_new(&Map, outvect->answer, with_z);
Vect_set_error_handler_io(NULL, &Map);
