[GRASS-SVN] r60049 - grass/trunk/vector/v.in.db
svn_grass at osgeo.org
Fri May 2 14:20:32 PDT 2014
Author: hcho
Date: 2014-05-02 14:20:32 -0700 (Fri, 02 May 2014)
New Revision: 60049
grass/trunk/vector/v.in.db/main.c
exit => G_fatal_error
Modified: grass/trunk/vector/v.in.db/main.c
--- grass/trunk/vector/v.in.db/main.c 2014-05-02 16:53:57 UTC (rev 60048)
+++ grass/trunk/vector/v.in.db/main.c 2014-05-02 21:20:32 UTC (rev 60049)
@@ -148,7 +148,8 @@
if (Vect_open_new(&Map, outvect->answer, with_z) == -1)
- exit(EXIT_FAILURE);
+ G_fatal_error(_("Unable to create new vector map <%s>"),
+ outvect->answer);
Vect_set_error_handler_io(NULL, &Map);
