[GRASS-SVN] r60058 - grass/branches/releasebranch_7_0/general/g.proj
Sat May 3 10:16:44 PDT 2014
Author: martinl
Date: 2014-05-03 10:16:44 -0700 (Sat, 03 May 2014)
New Revision: 60058
   grass/branches/releasebranch_7_0/general/g.proj/create.c
   grass/branches/releasebranch_7_0/general/g.proj/main.c
g.proj: description cosmetics
        (merge r60057 from trunk)
Modified: grass/branches/releasebranch_7_0/general/g.proj/create.c
--- grass/branches/releasebranch_7_0/general/g.proj/create.c	2014-05-03 17:15:05 UTC (rev 60057)
+++ grass/branches/releasebranch_7_0/general/g.proj/create.c	2014-05-03 17:16:44 UTC (rev 60058)
@@ -34,7 +34,7 @@
     if (strcmp(mapset, "PERMANENT") != 0)
 	G_fatal_error(_("You must select the PERMANENT mapset before updating the "
-			"current location's projection (current mapset is <%s>)."),
+			"current location's projection (current mapset is <%s>)"),
 		      mapset);
     /* Read projection information from current location first */
Modified: grass/branches/releasebranch_7_0/general/g.proj/main.c
--- grass/branches/releasebranch_7_0/general/g.proj/main.c	2014-05-03 17:15:05 UTC (rev 60057)
+++ grass/branches/releasebranch_7_0/general/g.proj/main.c	2014-05-03 17:16:44 UTC (rev 60058)
@@ -7,7 +7,7 @@
  * PURPOSE:      Provides a means of reporting the contents of GRASS
  *               projection information files and creating
  *               new projection information files.
- * COPYRIGHT:    (C) 2003-2007, 2011 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2003-2014 by the GRASS Development Team
  *               This program is free software under the GNU General
  *               Public License (>=v2). Read the file COPYING that
@@ -65,7 +65,7 @@
     G_add_keyword(_("create location"));
 #ifdef HAVE_OGR
     module->label =
-	_("Prints and manipulates GRASS projection information files "
+	_("Prints or modifies GRASS projection information files "
 	  "(in various co-ordinate system descriptions).");
     module->description =
 	_("Can also be used to create new GRASS locations.");
@@ -190,8 +190,7 @@
     create = G_define_flag();
     create->key = 'c';
     create->guisection = _("Modify");
-    create->description = _("Create new projection files (modifies current "
-			    "location)");
+    create->description = _("Modify current location projection files");
     location = G_define_option();
     location->key = "location";
