[GRASS-SVN] r60085 - in grass-addons/grass6: display/d.anaglyph display/d.region general/g.infer general/g.region.grow raster3d/r3.in.xyz
svn_grass at osgeo.org
Sun May 4 16:38:21 PDT 2014
Author: hamish
Date: 2014-05-04 16:38:21 -0700 (Sun, 04 May 2014)
New Revision: 60085
grass-addons/grass6/display/d.anaglyph/d.anaglyph
grass-addons/grass6/display/d.region/d.region
grass-addons/grass6/general/g.infer/spearfish.py
grass-addons/grass6/general/g.region.grow/g.region.grow
grass-addons/grass6/raster3d/r3.in.xyz/r3.in.xyz
only read region, don't alter WIND file (#2230); minor quoting
Modified: grass-addons/grass6/display/d.anaglyph/d.anaglyph
--- grass-addons/grass6/display/d.anaglyph/d.anaglyph 2014-05-04 23:31:09 UTC (rev 60084)
+++ grass-addons/grass6/display/d.anaglyph/d.anaglyph 2014-05-04 23:38:21 UTC (rev 60085)
@@ -274,7 +274,7 @@
fi
if [ -n "$GIS_OPT_VLINES" ] ; then
- eval `g.region -g`
+ eval `g.region -gu`
VLINES="vline=$GIS_OPT_VLINES vline_color=black vline_height=$nsres"
else
VLINES=""
@@ -293,7 +293,7 @@
#### dynamic viewpoint height calculations
# FIXME: figure out if it is map unit extent or number of cells which controls the flipping
-eval `g.region -ge`
+eval `g.region -geu`
# various scales of the average map extent to use for the viewing height
avg_extent=`echo "$ns_extent $ew_extent" | awk '{print ($1 + $2)/2.0}'`
@@ -385,7 +385,7 @@
LARGER=`echo "$ew_extent $ns_extent" | awk '{if ($1 > $2) { print "ew" } else { print "ns" }}'`
if [ "ew" = "$LARGER" ] ; then
BUFDIST=`echo "$ew_extent $ns_extent" | awk '{print int(0.5 + ($1 - $2)/2.0)}'`
BUFDIST_EVEN=`echo "$BUFDIST $nsres" | awk '{print $1 + (10 * $2) - ($1 % $2)}'`
g.region n="n+$BUFDIST_EVEN" s="s-$BUFDIST_EVEN"
fi
Modified: grass-addons/grass6/display/d.region/d.region
--- grass-addons/grass6/display/d.region/d.region 2014-05-04 23:31:09 UTC (rev 60084)
+++ grass-addons/grass6/display/d.region/d.region 2014-05-04 23:38:21 UTC (rev 60085)
@@ -99,18 +99,18 @@
#%end
if test "$GISBASE" = ""; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
+ exec g.parser "$0" "$@"
fi
# set defaults
-originalRegionName="d_region"$$
-g.region save=$originalRegionName
+originalRegionName="d_region$$"
+g.region save="$originalRegionName"
@@ -118,8 +118,8 @@
# name: clean
# purpose: clean region settings
clean () {
- g.region region=$originalRegionName;
- g.remove --q region=$originalRegionName;
+ g.region region="$originalRegionName"
+ g.remove --q region="$originalRegionName"
@@ -127,45 +127,45 @@
# purpose: displays default region
default () {
g.region -d
# name: current
current () {
# name: raster
# purpose: displays raster region
raster () {
- g.region rast=$GIS_OPT_RAST
+ g.region rast="$GIS_OPT_RAST"
# name: vector
# purpose: displays vect region
vector () {
- g.region vect=$GIS_OPT_VECT
+ g.region vect="$GIS_OPT_VECT"
# name: rast3d
# purpose: displays rast3d region
rast3d () {
- g.region rast3d=$GIS_OPT_RAST3D
+ g.region rast3d="$GIS_OPT_RAST3D"
# name: 3dview
# purpose: displays 3dview region
view3d () {
- g.region rast3d=$GIS_OPT_3DVIEW
+ g.region rast3d="$GIS_OPT_3DVIEW"
@@ -196,7 +196,7 @@
fi
g.region w=$GIS_OPT_W s=$GIS_OPT_S e=$GIS_OPT_E n=$GIS_OPT_N
@@ -223,12 +223,12 @@
$w $s
EOF
- echo $TMP
+ echo "$TMP"
- if [ $GIS_FLAG_F -eq 1 ]; then
- cat $TMP|d.graph -m color=$GIS_OPT_COLOR
+ if [ $GIS_FLAG_F -eq 1 ] ; then
+ cat "$TMP" | d.graph -m color="$GIS_OPT_COLOR"
else
- d.graph -m color=$GIS_OPT_COLOR input=$TMP
+ d.graph -m color="$GIS_OPT_COLOR" input="$TMP"
fi
Modified: grass-addons/grass6/general/g.infer/spearfish.py
--- grass-addons/grass6/general/g.infer/spearfish.py 2014-05-04 23:31:09 UTC (rev 60084)
+++ grass-addons/grass6/general/g.infer/spearfish.py 2014-05-04 23:38:21 UTC (rev 60085)
@@ -172,9 +172,9 @@
(python-call grass_run_command "g.version" "gb" )
;Note how the flags for g.version are provided without the leading "minus": Proper call on the GRASS shell would be "g.version -gb" or "g.version -g -b"
(python-call grass_message "---------------------------")
- (python-call grass_message " Invoking: g.region -p")
+ (python-call grass_message " Invoking: g.region -pu")
(python-call grass_message " ")
- (python-call grass_run_command "g.region" "p" )
+ (python-call grass_run_command "g.region" "pu" )
(python-call grass_message " Invoking g.list -f type=vect")
Modified: grass-addons/grass6/general/g.region.grow/g.region.grow
--- grass-addons/grass6/general/g.region.grow/g.region.grow 2014-05-04 23:31:09 UTC (rev 60084)
+++ grass-addons/grass6/general/g.region.grow/g.region.grow 2014-05-04 23:38:21 UTC (rev 60085)
@@ -53,7 +53,7 @@
fi
if [ "$GIS_FLAG_A" -eq 1 ] ; then
ALIGN_FLAG="-a ewres=$ewres nsres=$nsres"
else
ALIGN_FLAG=""
Modified: grass-addons/grass6/raster3d/r3.in.xyz/r3.in.xyz
--- grass-addons/grass6/raster3d/r3.in.xyz/r3.in.xyz 2014-05-04 23:31:09 UTC (rev 60084)
+++ grass-addons/grass6/raster3d/r3.in.xyz/r3.in.xyz 2014-05-04 23:38:21 UTC (rev 60085)
@@ -236,10 +236,10 @@
fi
-eval `g.region -3 -g`
+eval `g.region -3 -gu`
if [ "$nsres" != "$nsres3" ] || [ "$ewres" != "$ewres3" ] ; then
- g.region -3 -p | grep res
+ g.region -3 -pu | grep res
g.message -e "The 2D and 3D region settings are different. Can not continue."
exit 1
fi
