[GRASS-SVN] r60094 - grass/trunk/display/d.histogram
svn_grass at osgeo.org
Sun May 4 23:27:39 PDT 2014
Author: hamish
Date: 2014-05-04 23:27:39 -0700 (Sun, 04 May 2014)
New Revision: 60094
grass/trunk/display/d.histogram/dhist.h
grass/trunk/display/d.histogram/get_stats.c
grass/trunk/display/d.histogram/main.c
quiet handled by --quiet
Modified: grass/trunk/display/d.histogram/dhist.h
--- grass/trunk/display/d.histogram/dhist.h 2014-05-05 06:07:16 UTC (rev 60093)
+++ grass/trunk/display/d.histogram/dhist.h 2014-05-05 06:27:39 UTC (rev 60094)
@@ -40,8 +40,9 @@
double, double);
int draw_slice(struct Colors *, int, DCELL, DCELL, int, double, double,
double, double, double);
/* get_stats.c */
-int get_stats(const char *, struct stat_list *, int);
+int get_stats(const char *, struct stat_list *);
/* pie.c */
int pie(struct stat_list *, struct Colors *);
Modified: grass/trunk/display/d.histogram/get_stats.c
--- grass/trunk/display/d.histogram/get_stats.c 2014-05-05 06:07:16 UTC (rev 60093)
+++ grass/trunk/display/d.histogram/get_stats.c 2014-05-05 06:27:39 UTC (rev 60094)
@@ -8,7 +8,7 @@
#include "options.h"
#include "dhist.h"
-static void run_stats(const char *mapname, int quiet, const char *tempfile)
+static void run_stats(const char *mapname, const char *tempfile)
char buf[32];
const char *argv[12];
@@ -19,8 +19,7 @@
argv[argc++] = "-r";
if (cat_ranges)
argv[argc++] = "-C";
- if (quiet)
- argv[argc++] = "-q";
argv[argc++] = type == COUNT
? "-c"
: "-a";
@@ -43,8 +42,7 @@
G_fatal_error("error running r.stats");
-int get_stats(const char *mapname, struct stat_list *dist_stats, /* linked list of stats */
- int quiet)
+int get_stats(const char *mapname, struct stat_list *dist_stats) /* linked list of stats */
char buf[1024]; /* input buffer for reading stats */
int done = 0;
@@ -72,7 +70,7 @@
G_fatal_error("Can't read frange file");
- run_stats(mapname, quiet, tempfile);
+ run_stats(mapname, tempfile);
/* open temp file and read the stats into a linked list */
fd = fopen(tempfile, "r");
Modified: grass/trunk/display/d.histogram/main.c
--- grass/trunk/display/d.histogram/main.c 2014-05-05 06:07:16 UTC (rev 60093)
+++ grass/trunk/display/d.histogram/main.c 2014-05-05 06:27:39 UTC (rev 60094)
@@ -66,7 +66,6 @@
char title[GNAME_MAX];
double tt, tb, tl, tr;
double t, b, l, r;
- int quiet;
struct GModule *module;
struct Option *opt1;
struct Option *opt2, *bg_opt;
@@ -129,10 +128,6 @@
flag1->key = 'n';
flag1->description = _("Display information for null cells");
- flag2 = G_define_flag();
- flag2->key = 'q';
- flag2->description = _("Gather the histogram quietly");
flag3 = G_define_flag();
flag3->key = 'C';
flag3->description =
@@ -168,7 +163,6 @@
G_warning(_("When -C flag is set, the nsteps argument is ignored"));
nodata = flag1->answer;
- quiet = flag2->answer ? YES : NO;
if (Rast_read_colors(map_name, "", &pcolors) == -1)
G_fatal_error(_("Color file for <%s> not available"), map_name);
@@ -182,7 +176,7 @@
/* get the distribution statistics */
- get_stats(map_name, &dist_stats, quiet);
+ get_stats(map_name, &dist_stats);
/* set up the graphics driver and initialize its color-table */
