[GRASS-SVN] r60101 - grass/trunk/raster3d/r3.stats
svn_grass at osgeo.org
Mon May 5 02:06:44 PDT 2014
Author: hamish
Date: 2014-05-05 02:06:44 -0700 (Mon, 05 May 2014)
New Revision: 60101
grass/trunk/raster3d/r3.stats/local_proto.h
grass/trunk/raster3d/r3.stats/main.c
grass/trunk/raster3d/r3.stats/support.c
add flag to print only bin number and cell counts
Modified: grass/trunk/raster3d/r3.stats/local_proto.h
--- grass/trunk/raster3d/r3.stats/local_proto.h 2014-05-05 08:50:41 UTC (rev 60100)
+++ grass/trunk/raster3d/r3.stats/local_proto.h 2014-05-05 09:06:44 UTC (rev 60101)
@@ -40,7 +40,7 @@
stat_table *create_stat_table(int nsteps, equal_val_array *values,
double min, double max);
void free_stat_table(stat_table *stats);
-void print_stat_table(stat_table *stats);
+void print_stat_table(stat_table *stats, int);
void update_stat_table(stat_table *stats, RASTER3D_Region *region);
void heapsort_eqvals(equal_val_array *data, int n);
void downheap_eqvals(equal_val_array *data, int n, int k);
Modified: grass/trunk/raster3d/r3.stats/main.c
--- grass/trunk/raster3d/r3.stats/main.c 2014-05-05 08:50:41 UTC (rev 60100)
+++ grass/trunk/raster3d/r3.stats/main.c 2014-05-05 09:06:44 UTC (rev 60101)
@@ -39,7 +39,7 @@
unsigned int x, y, z;
struct Option *inputfile, *steps;
- struct Flag *equal;
+ struct Flag *equal, *counts_only;
struct GModule *module;
G_gisinit(argv[0]);
@@ -60,12 +60,15 @@
steps->answer = "20";
steps->description = _("Number of subranges to collect stats from");
equal = G_define_flag();
equal->key = 'e';
equal->description =
_("Calculate statistics based on equal value groups");
+ counts_only = G_define_flag();
+ counts_only->key = 'c';
+ counts_only->description = _("Only print cell counts");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -156,7 +159,7 @@
else {
- /*create the statistic table based on value ranges */
+ /* create the statistic table based on value ranges */
/* get the range of the map */
Rast3d_range_load(map);
@@ -193,8 +196,9 @@
if(stats) {
/* Compute the volume and percentage */
update_stat_table(stats, ®ion);
/* Print the statistics to stdout */
- print_stat_table(stats);
+ print_stat_table(stats, counts_only->answer);
free_stat_table(stats);
Modified: grass/trunk/raster3d/r3.stats/support.c
--- grass/trunk/raster3d/r3.stats/support.c 2014-05-05 08:50:41 UTC (rev 60100)
+++ grass/trunk/raster3d/r3.stats/support.c 2014-05-05 09:06:44 UTC (rev 60101)
@@ -246,7 +246,7 @@
+void print_stat_table(stat_table *stats, int counts_only)
int i;
@@ -269,6 +269,13 @@
fprintf(stdout, "\nNumber of groups with equal values: %i",
stats->nsteps);
+ else if (counts_only) {
+ for (i = 0; i < stats->nsteps; i++) {
+ fprintf(stdout, "%d %ld\n",
+ stats->table[i]->num, stats->table[i]->count);
+ fprintf(stdout, "* %ld\n", stats->null->count);
else {
/* 1234567 012345678901234567 012345678901234567 0123456789012 0123456 0123456789 */
fprintf(stdout,
@@ -288,17 +295,18 @@
- fprintf(stdout,
- "\nSum of non Null cells: \n\tVolume = %13.3lf \n\tPercentage = %7.3lf \n\tCell count = %i\n",
- stats->sum_vol, stats->sum_perc, stats->sum_count);
+ if (!counts_only) {
+ fprintf(stdout,
+ "\nSum of non Null cells: \n\tVolume = %13.3lf \n\tPercentage = %7.3lf \n\tCell count = %i\n",
+ stats->sum_vol, stats->sum_perc, stats->sum_count);
- fprintf(stdout,
- "\nSum of all cells: \n\tVolume = %13.3lf \n\tPercentage = %7.3lf \n\tCell count = %i\n",
- stats->sum_vol + stats->null->vol,
- stats->sum_perc + stats->null->perc,
- stats->sum_count + stats->null->count);
+ fprintf(stdout,
+ "\nSum of all cells: \n\tVolume = %13.3lf \n\tPercentage = %7.3lf \n\tCell count = %i\n",
+ stats->sum_vol + stats->null->vol,
+ stats->sum_perc + stats->null->perc,
+ stats->sum_count + stats->null->count);
return;
