[GRASS-SVN] r60105 - grass-addons/grass7/gui/wxpython/newgui
svn_grass at osgeo.org
Mon May 5 03:10:23 PDT 2014
Author: hamish
Date: 2014-05-05 03:10:23 -0700 (Mon, 05 May 2014)
New Revision: 60105
grass-addons/grass7/gui/wxpython/newgui/render2.py
updated d.legend command line options
Modified: grass-addons/grass7/gui/wxpython/newgui/render2.py
--- grass-addons/grass7/gui/wxpython/newgui/render2.py 2014-05-05 09:52:45 UTC (rev 60104)
+++ grass-addons/grass7/gui/wxpython/newgui/render2.py 2014-05-05 10:10:23 UTC (rev 60105)
@@ -360,7 +360,7 @@
@param id overlay id (for PseudoDC)
@param type overlay type ('barscale', 'legend', etc.)
@param cmd GRASS command to render overlay,
- given as list, e.g. ['d.legend', 'map=elevation at PERMANENT']
+ given as list, e.g. ['d.legend', 'rast=elevation at PERMANENT']
@param Map render.Map instance
@param active layer is active, will be rendered only if True
@param hidden layer is hidden, won't be listed in Layer Manager if True
