[GRASS-SVN] r60117 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Mon May 5 12:09:10 PDT 2014
Author: martinl
Date: 2014-05-05 12:09:09 -0700 (Mon, 05 May 2014)
New Revision: 60117
grass/trunk/lib/python/script/task.py
libpython: fix grass-interface.dtd location
Modified: grass/trunk/lib/python/script/task.py
--- grass/trunk/lib/python/script/task.py 2014-05-05 17:32:48 UTC (rev 60116)
+++ grass/trunk/lib/python/script/task.py 2014-05-05 19:09:09 UTC (rev 60117)
@@ -455,7 +455,7 @@
def get_interface_description(cmd):
"""!Returns the XML description for the GRASS cmd (force text encoding to "utf-8").
- The DTD must be located in $GISBASE/etc/grass-interface.dtd,
+ The DTD must be located in $GISBASE/gui/xml/grass-interface.dtd,
otherwise the parser will not succeed.
@param cmd command (name of GRASS module)
@@ -490,11 +490,7 @@
raise ScriptError, _("Unable to fetch interface description for command '%(cmd)s'."
"\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' : e }
- # if cmderr and cmderr[:7] != 'WARNING':
- # raise ScriptError, _("Unable to fetch interface description for command '%(cmd)s'."
- # "\n\nDetails: %(det)s") % { 'cmd': cmd, 'det' : decode(cmderr) }
- desc = cmdout.replace('grass-interface.dtd', os.path.join(os.getenv('GISBASE'), 'etc', 'grass-interface.dtd'))
+ desc = cmdout.replace('grass-interface.dtd', os.path.join(os.getenv('GISBASE'), 'gui', 'xml', 'grass-interface.dtd'))
return convert_xml_to_utf8(desc)
def parse_interface(name, parser = processTask, blackList = None):
