[GRASS-SVN] r60138 - grass/trunk/display/d.legend
Tue May 6 19:53:27 PDT 2014
Author: hamish
Date: 2014-05-06 19:53:27 -0700 (Tue, 06 May 2014)
New Revision: 60138
   grass/trunk/display/d.legend/histogram.c
   grass/trunk/display/d.legend/local_proto.h
   grass/trunk/display/d.legend/main.c
histogram support for categorical maps, run grass_indent.sh on histogram.c
Modified: grass/trunk/display/d.legend/histogram.c
--- grass/trunk/display/d.legend/histogram.c	2014-05-06 21:10:47 UTC (rev 60137)
+++ grass/trunk/display/d.legend/histogram.c	2014-05-07 02:53:27 UTC (rev 60138)
@@ -13,11 +13,12 @@
 void draw_histogram(const char *map_name, int x0, int y0, int width,
 		    int height, int color, int flip, int horiz,
-		    int map_type)
+		    int map_type, int is_fp)
     int i, nsteps;
     long cell_count;
     double max_width, width_mult, dx;
+    double dy, y0_adjust;	/* only needed for CELL maps */
     struct stat_list dist_stats;
     struct stat_node *ptr;
@@ -40,51 +41,97 @@
     ptr = dist_stats.ptr;
+    if (!is_fp) {
+	dy = (nsteps + 3.0) / (1 + dist_stats.maxcat - dist_stats.mincat);
+	if (flip)
+	    dy *= -1;
+	if (dist_stats.mincat == 0)
+	    y0_adjust = dy;
+	else
+	    y0_adjust = 0;
+	if (!flip)  /* mmph */
+	    y0_adjust += 0.5;
     for (i = dist_stats.mincat; i <= dist_stats.maxcat; i++) {
 	if (!ptr)
 	    break;
-	if (ptr->cat == i) {       /* AH-HA!! found the stat */
-            cell_count = ptr->stat;
+	if (ptr->cat == i) {	/* AH-HA!! found the stat */
+	    cell_count = ptr->stat;
-            if (ptr->next != NULL)
-                ptr = ptr->next;
-        else {                  /* we have to look for the stat */
+	    if (ptr->next != NULL)
+		ptr = ptr->next;
+	else {			/* we have to look for the stat */
-            /* loop until we find it, or pass where it should be */
-            while (ptr->cat < i && ptr->next != NULL)
-                ptr = ptr->next;
+	    /* loop until we find it, or pass where it should be */
+	    while (ptr->cat < i && ptr->next != NULL)
+		ptr = ptr->next;
-                    ptr = ptr->next;
-            else                /* stat cannot be found */
+		    ptr = ptr->next;
+	    else		/* stat cannot be found */
 		G_debug(4, "No matching stat found, i=%d", i);
 	if (!cell_count)
 	    continue;
 	dx = cell_count * width_mult;
-	if (horiz) {
-	    if (flip)
-		D_move_abs(x0 + width - i - 1, y0 - 1);
-	    else
-		D_move_abs(x0 + i + 1, y0 - 1);
+	if (is_fp) {
+	    if (horiz) {
+		if (flip)
+		    D_move_abs(x0 + width - i - 1, y0 - 1);
+		else
+		    D_move_abs(x0 + i + 1, y0 - 1);
-	    D_cont_rel(0, -dx);
+		D_cont_rel(0, -dx);
+	    else {  /* vertical */
+		if (flip)
+		    D_move_abs(x0 - 1, y0 - 1 + height - i);
+		else
+		    D_move_abs(x0 - 1, y0 + 1 + i);
+		D_cont_rel(-dx, 0);
-	else {  /* vertical */
-	    if (flip)
-		D_move_abs(x0 - 1, y0 - 1 + height - i);
-	    else
-		D_move_abs(x0 - 1, y0 + 1 + i);
+	else {	/* categorical */
-	    D_cont_rel(-dx, 0);
+	    if (horiz) {
+		if (flip)
+		    D_box_abs(x0 + width + y0_adjust + ((i - 1) * dy),
+			      y0 - 1,
+			      x0 + width + y0_adjust + 1 + (i * dy),
+			      y0 - 1 - dx);
+		else
+		    D_box_abs(x0 + y0_adjust + ((i - 1) * dy),
+			      y0 - 1,
+			      x0 - 1 + y0_adjust + (i * dy),
+			      y0 - 1 - dx);
+		if (flip)
+		    /* GRASS_EPSILON fudge around D_box_abs() weirdness + PNG driver */
+		    D_box_abs(x0 - 1 - GRASS_EPSILON * 10,
+			      y0 + height + y0_adjust + ((i - 1) * dy),
+			      x0 - 1 - dx,
+			      y0 + height + y0_adjust + 1 + (i * dy));
+		else
+			      y0 + y0_adjust + ((i - 1) * dy),
+			      x0 - 1 - dx,
+			      y0 + y0_adjust - 1 + (i * dy));
Modified: grass/trunk/display/d.legend/local_proto.h
--- grass/trunk/display/d.legend/local_proto.h	2014-05-06 21:10:47 UTC (rev 60137)
+++ grass/trunk/display/d.legend/local_proto.h	2014-05-07 02:53:27 UTC (rev 60138)
@@ -27,7 +27,7 @@
 /* histogram.c */
-void draw_histogram(const char *, int, int, int, int, int, int, int, int);
+void draw_histogram(const char *, int, int, int, int, int, int, int, int, int);
 /* get_stats.c */
 void get_stats(const char *, struct stat_list *, int, int);
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c	2014-05-06 21:10:47 UTC (rev 60137)
+++ grass/trunk/display/d.legend/main.c	2014-05-07 02:53:27 UTC (rev 60138)
@@ -467,7 +467,7 @@
 	    if (!hide_catnum)
 		if (i > maxCat)
 		    maxCat = (double)i;
-	    k++;		/* count of actual boxes drawn (hide_nodata option invaidates using j-1) */
+	    k++;	/* count of actual boxes drawn (hide_nodata option invaidates using j-1) */
 	lines = k;
@@ -526,10 +526,10 @@
 	/* switch to a smooth legend for CELL maps with too many cats */
 	/*  an alternate solution is to set   dots_per_line=1         */
-	if ((dots_per_line == 0) && (do_smooth == 0)) {
+	if ((dots_per_line == 0) && (do_smooth == FALSE)) {
 	    if (!use_catlist) {
 		G_message(_("Forcing a smooth legend: too many categories for current window height"));
-		do_smooth = 1;
+		do_smooth = TRUE;
@@ -540,7 +540,7 @@
 		    y0 = ((b - t) - (dots_per_line * lines)) / 2;
-	/*      D_text_size(dots_per_line*4/5., dots_per_line*4/5.);    redundant */
+	/* D_text_size(dots_per_line*4/5., dots_per_line*4/5.);    redundant */
 	/* if(Rast_is_c_null_value(&min_ind) && Rast_is_c_null_value(&max_ind))
 	   min_ind = 1;
@@ -616,9 +616,10 @@
 	cats_num = catlistCount;
 	do_cats = catlistCount;
 	lines = catlistCount;
-	do_smooth = 0;
+	do_smooth = FALSE;
     if (do_smooth) {
 	int wleg, lleg, dx, dy;
 	double txsiz;
@@ -813,14 +814,25 @@
 	    units = "";
 	if(strlen(units)) {
+	    double x_pos, y_pos;
+	    int default_pos = TRUE;
 	    D_use_color(color);
 	    /* D_text_size() should be already set */
-	    if (horiz)
-		D_pos_abs((x0 + x1)/2. - (strlen(units) * txsiz * 0.81)/2,
-			  y1 + (txsiz * 3));
-	    else
-		D_pos_abs(x1 - 4, y0 - (txsiz * 1.75));
+	    if (horiz) {
+		x_pos = (x0 + x1)/2. - (strlen(units) * txsiz * 0.81)/2;
+		y_pos = y1 + (txsiz * 3);
+	    else {
+		x_pos = x1 - 4;
+		if (default_pos)
+		    y_pos = y0 - (txsiz * 1.75);
+		else
+		    y_pos = y1 + (txsiz * 2.75);
+	    D_pos_abs(x_pos, y_pos);
 	    D_text(units);
@@ -831,7 +843,7 @@
 		G_warning(_("Histogram constrained by range not yet implemented"));
 	    else
 		draw_histogram(map_name, x0, y0, wleg, lleg, color, flip,
-			       horiz, maptype);
+			       horiz, maptype, fp);
@@ -843,7 +855,7 @@
 	/* set legend box bounds */
 	true_l = l;
-	true_r = r;		/* preserve window width */
+	true_r = r;	/* preserve window width */
 	l = x0;
 	t = y0;
 	r = x1;
@@ -858,7 +870,7 @@
 	    dots_per_line = (b - t) / (lines + 2);	/* + another line for 'x of y categories' text */
 	/* adjust text size */
-	/*      txsiz = (int)((y1-y0)/(1.5*(lines+5))); */
+	/*  txsiz = (int)((y1-y0)/(1.5*(lines+5))); */
 	txsiz = (y1 - y0) / (2.0 * lines);
 	/* scale text to fit in window if position not manually set */
