[GRASS-SVN] r60176 - grass/trunk/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Sun May 11 05:24:42 PDT 2014
Author: zarch
Date: 2014-05-11 05:24:42 -0700 (Sun, 11 May 2014)
New Revision: 60176
grass/trunk/lib/python/pygrass/modules/interface/parameter.py
Fix regexp to handle also negative range like in g.proj (datum_trans).
Modified: grass/trunk/lib/python/pygrass/modules/interface/parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2014-05-11 11:51:45 UTC (rev 60175)
+++ grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2014-05-11 12:24:42 UTC (rev 60176)
@@ -38,7 +38,7 @@
if 'values' in diz:
try:
# Check for integer ranges: "3-30"
- isrange = re.match("(?P<min>\d+)-(?P<max>\d+)",
+ isrange = re.match("(?P<min>-*\d+)-(?P<max>\d+)",
diz['values'][0])
if isrange:
range_min, range_max = isrange.groups()
@@ -46,7 +46,7 @@
self.isrange = diz['values'][0]
# Check for float ranges: "0.0-1.0"
if not isrange:
- isrange = re.match("(?P<min>\d+.\d+)-(?P<max>\d+.\d+)",
+ isrange = re.match("(?P<min>-*\d+.\d+)-(?P<max>\d+.\d+)",
diz['values'][0])
if isrange:
# We are not able to create range values from
