[GRASS-SVN] r60194 - grass/branches/develbranch_6/lib/gis
svn_grass at osgeo.org
Sun May 11 13:46:46 PDT 2014
Author: neteler
Date: 2014-05-11 13:46:46 -0700 (Sun, 11 May 2014)
New Revision: 60194
grass/branches/develbranch_6/lib/gis/gisinit.c
libgis: improve version mismatch compilation warning (modified patch from trac #1467)
Modified: grass/branches/develbranch_6/lib/gis/gisinit.c
--- grass/branches/develbranch_6/lib/gis/gisinit.c 2014-05-11 20:45:14 UTC (rev 60193)
+++ grass/branches/develbranch_6/lib/gis/gisinit.c 2014-05-11 20:46:46 UTC (rev 60194)
@@ -51,8 +51,10 @@
G_set_program_name(pgm);
if (strcmp(version, GIS_H_VERSION) != 0)
- G_fatal_error(_("Incompatible library version for module. "
- "You need to rebuild GRASS or untangle multiple installations."));
+ G_fatal_error(_("Module built against version %s but "
+ "trying to use version %s."
+ "You need to rebuild GRASS GIS or untangle multiple installations."),
+ version, GIS_H_VERSION);
/* Make sure location and mapset are set */
G_location_path();
@@ -87,9 +89,10 @@
return 0;
gisinit();
return 0;
