[GRASS-SVN] r60198 - grass/branches/develbranch_6/vector/v.in.db
svn_grass at osgeo.org
Sun May 11 14:12:39 PDT 2014
Author: neteler
Date: 2014-05-11 14:12:38 -0700 (Sun, 11 May 2014)
New Revision: 60198
grass/branches/develbranch_6/vector/v.in.db/description.html
v.in.db manual: typo; cosmetics
Modified: grass/branches/develbranch_6/vector/v.in.db/description.html
--- grass/branches/develbranch_6/vector/v.in.db/description.html 2014-05-11 21:08:37 UTC (rev 60197)
+++ grass/branches/develbranch_6/vector/v.in.db/description.html 2014-05-11 21:12:38 UTC (rev 60198)
@@ -1,7 +1,7 @@
<h2>DESCRIPTION</h2>
-<em>v.in.db</em>
-creates new vector (points) map from database table containing coordinates.
+<em>v.in.db</em> creates a new vector (points) map from database table
+containing coordinates.
<h2>EXAMPLE</h2>
@@ -12,19 +12,20 @@
table=pat_stazioni x=east y=north z=quota key=id output=pat_stazioni
</pre></div>
<p>
-If an ID column is not not present in the PostgreSQL table,
+If an ID column is not present in the PostgreSQL table,
a new column should be added. See <a href="grass-pg.html">pg</a> driver
page for detail.
<h3>2) Creating a map from PostGIS:</h3>
To extract coordinate values from PostGIS, functions have to be used:
<div class="code"><pre>
v.in.db driver=pg database="host=myserver.itc.it,dbname=mydb" \
table=station x="x(geom)" y="y(geom)" z="z(geom)" key=id out=meteostations
</pre></div>
<p>
page for detail.
@@ -78,11 +79,13 @@
<a href="db.in.ogr.html">db.in.ogr</a>,
<a href="v.info.html">v.info</a>,
<a href="v.in.ogr.html">v.in.ogr</a>,
-<a href="v.to.db.html">v.to.db</a>,<br>
-<a href="sql.html">SQL support in GRASS GIS</a>
+<a href="v.to.db.html">v.to.db</a>
</em>
+<p>
+<a href="sql.html">SQL support in GRASS GIS</a>
<h2>AUTHOR</h2>
Radim Blazek
