[GRASS-SVN] r60204 - in grass/trunk: display/d.mon gui/wxpython/mapdisp include/defs lib/display scripts/d.out.file scripts/d.redraw
svn_grass at osgeo.org
Sun May 11 18:55:09 PDT 2014
Author: hcho
Date: 2014-05-11 18:55:09 -0700 (Sun, 11 May 2014)
New Revision: 60204
grass/trunk/display/d.mon/list.c
grass/trunk/display/d.mon/start.c
grass/trunk/display/d.mon/stop.c
grass/trunk/gui/wxpython/mapdisp/main.py
grass/trunk/include/defs/gis.h
grass/trunk/lib/display/r_raster.c
grass/trunk/scripts/d.out.file/d.out.file.py
grass/trunk/scripts/d.redraw/d.redraw.py
Convert MONITOR_*_*FILE variable names to upper case
Modified: grass/trunk/display/d.mon/list.c
--- grass/trunk/display/d.mon/list.c 2014-05-12 01:53:47 UTC (rev 60203)
+++ grass/trunk/display/d.mon/list.c 2014-05-12 01:55:09 UTC (rev 60204)
@@ -25,7 +25,9 @@
strcmp(tokens[2], "ENVFILE") != 0)
continue;
*list = G_realloc(*list, (*n + 1) * sizeof(char *));
- (*list)[*n] = G_store(tokens[1]);
+ /* GRASS variable names are upper case, but monitor names are lower
+ * case. */
+ (*list)[*n] = G_store_lower(tokens[1]);
(*n)++;
G_free_tokens(tokens);
tokens = NULL;
@@ -59,7 +61,7 @@
const char *str;
env_name = NULL;
- G_asprintf(&env_name, "MONITOR_%s_ENVFILE", name);
+ G_asprintf(&env_name, "MONITOR_%s_ENVFILE", G_store_upper(name));
str = G__getenv(env_name);
if (!str)
return FALSE;
@@ -76,7 +78,7 @@
FILE *fd;
cmd_name = NULL;
- G_asprintf(&cmd_name, "MONITOR_%s_CMDFILE", name);
+ G_asprintf(&cmd_name, "MONITOR_%s_CMDFILE", G_store_upper(name));
cmd_value = G__getenv(cmd_name);
if (!cmd_value)
G_fatal_error(_("Command file not found"));
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c 2014-05-12 01:53:47 UTC (rev 60203)
+++ grass/trunk/display/d.mon/start.c 2014-05-12 01:55:09 UTC (rev 60204)
@@ -13,13 +13,16 @@
/* start file-based monitor */
void start(const char *name, const char *output)
+ char *u_name;
char *env_name;
if (!output)
return;
+ u_name = G_store_upper(name);
env_name = NULL;
- G_asprintf(&env_name, "MONITOR_%s_MAPFILE", name);
+ G_asprintf(&env_name, "MONITOR_%s_MAPFILE", u_name);
G_setenv(env_name, output);
@@ -28,11 +31,14 @@
const char *env_value, const char *cmd_value,
int width, int height)
+ char *u_name;
char progname[GPATH_MAX];
char *env_name, *map_value, str_width[1024], str_height[1024];
env_name = NULL;
G_asprintf(&map_value, "%s.ppm", tempfile);
G_setenv(env_name, map_value);
/* close(creat(map_value, 0666)); */
@@ -59,6 +65,7 @@
int truecolor)
const char *curr_mon;
+ char *u_name;
char *env_name, *env_value, *cmd_value;
char *tempfile, buf[1024];
int env_fd;
@@ -69,8 +76,10 @@
tempfile = G_tempfile();
env_name = env_value = NULL;
+ G_asprintf(&env_name, "MONITOR_%s_ENVFILE", u_name);
G_asprintf(&env_value, "%s.env", tempfile);
G_setenv(env_name, env_value);
env_fd = creat(env_value, 0666);
@@ -101,7 +110,7 @@
close(env_fd);
cmd_value = NULL;
- G_asprintf(&env_name, "MONITOR_%s_CMDFILE", name);
+ G_asprintf(&env_name, "MONITOR_%s_CMDFILE", u_name);
G_asprintf(&cmd_value, "%s.cmd", tempfile);
G_setenv(env_name, cmd_value);
close(creat(cmd_value, 0666));
Modified: grass/trunk/display/d.mon/stop.c
--- grass/trunk/display/d.mon/stop.c 2014-05-12 01:53:47 UTC (rev 60203)
+++ grass/trunk/display/d.mon/stop.c 2014-05-12 01:55:09 UTC (rev 60204)
@@ -26,11 +26,14 @@
int stop(const char *name)
+ char *u_name;
char *env_name;
const char *env_file;
env_name = NULL;
env_file = G__getenv(env_name);
if (!env_file)
@@ -43,11 +46,14 @@
int stop_wx(const char *name)
+ char *u_name;
char *env_name;
const char *pid;
env_name = NULL;
- G_asprintf(&env_name, "MONITOR_%s_PID", name);
+ G_asprintf(&env_name, "MONITOR_%s_PID", u_name);
pid = G__getenv(env_name);
if (!pid) {
@@ -71,11 +77,13 @@
void clean_env(const char *name)
int i;
+ char *u_name;
const char *env_prefix = "MONITOR_";
const char *env;
int env_prefix_len;
char **tokens;
env_prefix_len = strlen(env_prefix);
tokens = NULL;
@@ -85,7 +93,7 @@
tokens = G_tokenize(env, "_");
if (G_number_of_tokens(tokens) != 3 ||
- strcmp(tokens[1], name) != 0)
+ strcmp(tokens[1], u_name) != 0)
continue;
G_unsetenv(env);
i--; /* env has been removed for the list */
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py 2014-05-12 01:53:47 UTC (rev 60203)
+++ grass/trunk/gui/wxpython/mapdisp/main.py 2014-05-12 01:55:09 UTC (rev 60204)
@@ -436,7 +436,7 @@
grass.verbose(_("Starting map display <%s>...") % (monName))
RunCommand('g.gisenv',
- set = 'MONITOR_%s_PID=%d' % (monName, os.getpid()))
+ set = 'MONITOR_%s_PID=%d' % (monName.upper(), os.getpid()))
gmMap = MapApp(0)
# set title
@@ -448,7 +448,7 @@
# clean up GRASS env variables
env = grass.gisenv()
- env_name = 'MONITOR_%s' % monName
+ env_name = 'MONITOR_%s' % monName.upper()
for key in env.keys():
if key.find(env_name) == 0:
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h 2014-05-12 01:53:47 UTC (rev 60203)
+++ grass/trunk/include/defs/gis.h 2014-05-12 01:55:09 UTC (rev 60204)
@@ -610,6 +610,8 @@
int G_strcasecmp(const char *, const char *);
int G_strncasecmp(const char *, const char *, int);
char *G_store(const char *);
+char *G_store_upper(const char *);
+char *G_store_lower(const char *);
char *G_strchg(char *, char, char);
char *G_str_replace(const char *, const char *, const char *);
void G_strip(char *);
Modified: grass/trunk/lib/display/r_raster.c
--- grass/trunk/lib/display/r_raster.c 2014-05-12 01:53:47 UTC (rev 60203)
+++ grass/trunk/lib/display/r_raster.c 2014-05-12 01:55:09 UTC (rev 60204)
@@ -108,12 +108,16 @@
if (m) {
char *env;
const char *v;
+ char *u_m;
if (p)
G_warning(_("%s variable defined, %s ignored"),
"MONITOR", "GRASS_RENDER_IMMEDIATE");
+ /* GRASS variable names should be upper case. */
+ u_m = G_store_upper(m);
env = NULL;
- G_asprintf(&env, "MONITOR_%s_MAPFILE", m);
+ G_asprintf(&env, "MONITOR_%s_MAPFILE", u_m);
v = G__getenv(env);
if (G_strncasecmp(m, "wx", 2) == 0)
p = NULL; /* use default display driver */
@@ -127,7 +131,7 @@
G_putenv("GRASS_PNGFILE", v);
- G_asprintf(&env, "MONITOR_%s_ENVFILE", m);
+ G_asprintf(&env, "MONITOR_%s_ENVFILE", u_m);
v = G__getenv(env);
if (v)
read_env_file(v);
@@ -176,7 +180,8 @@
\brief Append command to the cmd file
Cmd file is created by d.mon by defining GRASS variable
- \c MONITOR_<name>_CMDFILE, where \c \<name\> is name of the monitor.
+ \c MONITOR_<name>_CMDFILE, where \c \<name\> is the upper case name of
+ the monitor.
Command string is usually generated by G_recreate_command(), NULL is
used to clean up list of commands (see d.erase command).
@@ -190,7 +195,7 @@
int D_save_command(const char *cmd)
const char *mon_name, *mon_cmd;
- char *env, *flag;
+ char *env, *flag, *u_mon_name;
FILE *fd;
G_debug(1, "D_save_command(): %s", cmd);
@@ -199,8 +204,11 @@
if (!mon_name)
return 0;
+ u_mon_name = G_store_upper(mon_name);
env = NULL;
- G_asprintf(&env, "MONITOR_%s_CMDFILE", mon_name);
+ G_asprintf(&env, "MONITOR_%s_CMDFILE", u_mon_name);
mon_cmd = G__getenv(env);
if (!mon_cmd)
return 0;
Modified: grass/trunk/scripts/d.out.file/d.out.file.py
--- grass/trunk/scripts/d.out.file/d.out.file.py 2014-05-12 01:53:47 UTC (rev 60203)
+++ grass/trunk/scripts/d.out.file/d.out.file.py 2014-05-12 01:55:09 UTC (rev 60204)
@@ -44,7 +44,7 @@
options, flags = gcore.parser()
gisenv = gcore.gisenv()
if 'MONITOR' in gisenv:
- cmd_file = gisenv['MONITOR_{monitor}_CMDFILE'.format(monitor=gisenv['MONITOR'])]
+ cmd_file = gisenv['MONITOR_{monitor}_CMDFILE'.format(monitor=gisenv['MONITOR'].upper())]
dout_cmd = 'd.out.file'
for param, val in options.iteritems():
if val:
Modified: grass/trunk/scripts/d.redraw/d.redraw.py
--- grass/trunk/scripts/d.redraw/d.redraw.py 2014-05-12 01:53:47 UTC (rev 60203)
+++ grass/trunk/scripts/d.redraw/d.redraw.py 2014-05-12 01:55:09 UTC (rev 60204)
@@ -39,7 +39,7 @@
if not mon:
grass.fatal(_("No monitor selected. Run `d.mon` to select monitor."))
- monCmd = env.get('MONITOR_%s_CMDFILE' % mon)
+ monCmd = env.get('MONITOR_%s_CMDFILE' % mon.upper())
if not monCmd:
grass.fatal(_("No cmd file found for monitor <%s>") % mon)
