[GRASS-SVN] r60214 - grass-addons/grass7/vector/v.civil/v.civil.road
svn_grass at osgeo.org
Mon May 12 16:11:08 PDT 2014
Author: jfc
Date: 2014-05-12 16:11:08 -0700 (Mon, 12 May 2014)
New Revision: 60214
grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py
v.civil.road: fix some bugs in default options and transversal
Modified: grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py
--- grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py 2014-05-12 23:07:02 UTC (rev 60213)
+++ grass-addons/grass7/vector/v.civil/v.civil.road/v.civil.road.py 2014-05-12 23:11:08 UTC (rev 60214)
@@ -152,7 +152,7 @@
#%end
#%option
-#% key: LPScale
+#% key: lpscale
#% type: integer
#% description: Long profile vertical scale (V/H, V/1)
#% options: 0-100
@@ -162,7 +162,7 @@
#%end
#%option
-#% key: LPopt
+#% key: lpopt
#% type: string
#% description: Long profile Values for Longmark,distMark_x,distMark_y,DistGitarr.
#% required: no
@@ -179,7 +179,7 @@
#%end
#%option G_OPT_V_OUTPUT
-#% key: LPaxisX
+#% key: lpaxisx
#% description: Name of long profile axis x
#% required: no
#% answer: _LP_AxisX
@@ -187,7 +187,7 @@
#%end
-#% key: LPaxisXmarks
+#% key: lpaxisxmarks
#% description: Name of long profile axis x marks
#% required: no
#% answer: _LP_AxisXmarks
@@ -195,7 +195,7 @@
#%end
-#% key: LPaxisY
+#% key: lpaxisy
#% description: Name of long profile axis y
#% required: no
#% answer: _LP_AxisY
@@ -203,7 +203,7 @@
#%end
-#% key: LPaxisYmarks
+#% key: lpaxisymarks
#% description: Name of long profile axis y marks
#% required: no
#% answer: _LP_AxisYmarks
@@ -211,7 +211,7 @@
#%end
-#% key: LPterrain
+#% key: lpterrain
#% description: Name of long profile terrain
#% required: no
#% answer: _LP_Terr
@@ -219,7 +219,7 @@
#%end
-#% key: LPras
+#% key: lpras
#% description: Name of long profile vertical alignment
#% required: no
#% answer: _LP_Ras
@@ -227,7 +227,7 @@
#%end
-#% key: LPejeref
+#% key: lpejeref
#% description: Name of long profile vertical polygon
#% required: no
#% answer: _LP_Polygon
@@ -269,7 +269,7 @@
#%option
-#% key: LTScale
+#% key: ltscale
#% type: double
#% description: Cross section vertical scale (V/H, V/1)
#% required: no
@@ -278,7 +278,7 @@
#%end
#%option
-#% key: LTopt
+#% key: ltopt
#% type: string
#% description: Cross section options values for Longmark,distMark_x,distMark_y.
#% required: no
@@ -287,28 +287,28 @@
#%end
#%option
-#% key: LTopt2
+#% key: ltopt2
#% type: string
#% description: Cross section options values for nrows,distTP_x,distTP_y.
#% required: no
-#% answer: 10,50,50
+#% answer: 10,10,10
#% guisection: Cross
#%end
-#%option G_OPT_V_TYPE
-#% key: cross_opt
-#% options: slope_left,displ_left,edge,displ_rigth,slope_rigth
-#% answer: slope_left,displ_left,edge,displ_rigth,slope_rigth
-#% required: no
-#% description: Add lines to the cross section
-#% guisection: Cross
-#%end
+##%option G_OPT_V_TYPE
+##% key: cross_opt
+##% options: slope_left,displ_left,edge,displ_rigth,slope_rigth
+##% answer: slope_left,displ_left,edge,displ_rigth,slope_rigth
+##% required: no
+##% description: Add lines to the cross section
+##% guisection: Cross
+##%end
#% key: displ_opt
#% options: displ_left0,displ_left,displ_left-1,displ_rigth0,displ_rigth,displ_rigth-1
#% required: no
-#% answer: displ_left0,displ_rigth-1
+#% answer: displ_left0,displ_left-1,displ_rigth0,displ_rigth-1
#% description: Cross points section-Displaced
#%end
@@ -332,7 +332,7 @@
-#% key: LTaxisX
+#% key: ltaxisx
#% description: Name of cross section coord axis x
#% required: no
#% answer: _TP_AxisX
@@ -340,7 +340,7 @@
#%end
-#% key: LTaxisXmarks
+#% key: ltaxisxmarks
#% required: no
#% answer: _TP_AxisXmarks
@@ -348,7 +348,7 @@
#%end
-#% key: LTaxisY
+#% key: ltaxisy
#% description: Name of cross section coord axis y
#% required: no
#% answer: _TP_AxisY
@@ -356,7 +356,7 @@
#%end
-#% key: LTaxisYmarks
+#% key: ltaxisymarks
#% required: no
#% answer: _TP_AxisYmarks
@@ -364,7 +364,7 @@
#%end
-#% key: LTterrain
+#% key: ltterrain
#% description: Name of cross sections terrain
#% required: no
#% answer: _TP_Terr
@@ -372,7 +372,7 @@
#%end
-#% key: LTras
+#% key: ltras
#% description: Name of cross section plataform
#% required: no
#% answer: _TP_Ras
@@ -534,6 +534,7 @@
#% description: Insert point in polygon layers (vertical, section an transversal)
#%end
#%option
#% key: pklayer
#% type: string
@@ -565,6 +566,8 @@
#% answer: 1
#%end
import os, sys
from math import *
@@ -1904,7 +1907,7 @@
zt_ant=zt
Li=Li+h
- puntos_talud.append([x1,y1,z1]+pt[3:]+[tipo]+[pt[4]])
+ puntos_talud.append([x1,y1,z1]+pt[3:]+[tipo]+[pt[4]])
else:
puntos_talud.append([pta])
@@ -2063,61 +2066,36 @@
return TransDespl
-def get_SeccTerr(Trans,Trans_Pklist,Desplaz_izq,Desplaz_der,Puntos_Talud_izq,Puntos_Talud_der):
+def get_ptoByPk(Trans_Pklist,listaPtos):
- talud_izq=[]
+ salida=[]
for ptoss in Trans_Pklist:
esta=0
- for ptot in Puntos_Talud_izq:
+ for ptot in listaPtos:
if len(ptot)>1 and ptoss[4] == ptot[4]:
- talud_izq.append(ptot)
+ salida.append(ptot)
esta=1
continue
if esta==0:
- talud_izq.append([])
+ salida.append([])
+ return salida
- talud_der=[]
- for ptoss in Trans_Pklist:
- esta=0
- for ptot in Puntos_Talud_der:
- if len(ptot)>1 and ptoss[4] == ptot[4]:
- talud_der.append(ptot)
- esta=1
- continue
- if esta==0:
- talud_der.append([])
+def get_SeccTerr(Trans_Pklist,Desplaz_izq,Desplaz_der,Puntos_Talud_izq,Puntos_Talud_der):
+ talud_izq=get_ptoByPk(Trans_Pklist,Puntos_Talud_izq)
+ talud_der=get_ptoByPk(Trans_Pklist,Puntos_Talud_der)
secc_izq=[talud_izq]
for desp in Desplaz_izq:
- desp_izq=[]
- esta=0
- for ptot in desp:
- if len(ptot)>1 and ptoss[4] == ptot[-1]:
- desp_izq.append(ptot)
- esta=1
- continue
- if esta==0:
- desp_izq.append([])
- secc_izq.append(desp_izq)
+ secc_izq.append(get_ptoByPk(Trans_Pklist,desp))
secc_der=[]
for desp in Desplaz_der:
- desp_der=[]
- esta=0
- for ptot in desp:
- desp_der.append(ptot)
- esta=1
- continue
- if esta==0:
- desp_der.append([])
- secc_der.append(desp_der)
+ secc_der.append(get_ptoByPk(Trans_Pklist,desp))
secc_der.append(talud_der)
secc = secc_izq+[Trans_Pklist]+secc_der
+ secc = [[row[i] for row in secc] for i in range(len(secc[0]))] # transpuesta
return secc
@@ -2232,14 +2210,11 @@
return eje_x,eje_y,mark_x,mark_y,ptos_terr_ref,ptos_eje,ASeg_ref,APtos_caract_ref
-def gen_TransProfile(Trans,Trans_Terr,Trans_Pklist,Puntos_Talud_izq,Puntos_Talud_der,Desplaz_izq,Desplaz_der,escala,opt1,opt2):
+def gen_TransProfile(Trans,Trans_Terr,Trans_Pklist,secc,escala,opt1,opt2):
- secc = get_SeccTerr(Trans,Trans_Pklist,Desplaz_izq,Desplaz_der,Puntos_Talud_izq,Puntos_Talud_der)
- secc = [[row[i] for row in secc] for i in range(len(secc[0]))] # transpuesta
+ cerox=0
+ ceroy=0
- cerox=100
- ceroy=100
mark_lon,mark_x_dist,mark_y_dist=opt1.split(',')
mark_lon,mark_x_dist,mark_y_dist=int(mark_lon),int(mark_x_dist),int(mark_y_dist)
@@ -2254,14 +2229,18 @@
for j in range (0,columnas):
anchos_colum,centros_colum,maxfila,minfila,dif_fila=[],[],[],[],[]
for i in range(0,filas):
ancho_secc=round(sqrt((Trans[h][0][0]-Trans[h][-1][0])**2+(Trans[h][0][1]-Trans[h][-1][1])**2),6)
centro_s=round(sqrt((Trans[h][0][0]-Trans[h][1][0])**2+(Trans[h][0][1]-Trans[h][1][1])**2),6)
anchos_colum.append(ancho_secc)
centros_colum.append(centro_s)
max_trans=max([p[2] for p in secc[h]+Trans_Terr[h] if p!=[]])
maxfila.append(max_trans)
min_trans=min([p[2] for p in secc[h]+Trans_Terr[h] if p!=[]])
minfila.append(min_trans)
dif_fila.append((max_trans-min_trans)*escala)
h=h+1
if h == len(Trans_Pklist):break
@@ -2271,21 +2250,16 @@
min_filas.append(minfila)
dif_filas.append(dif_fila)
- for k in range(len(max_filas[0])-len(max_filas[-1])):
- max_filas[-1].append(0)
- for k in range(len(min_filas[0])-len(min_filas[-1])):
- min_filas[-1].append(100000)
for k in range(len(dif_filas[0])-len(dif_filas[-1])):
dif_filas[-1].append(0)
- max_filas2 = [[row[i] for row in max_filas] for i in range(len(max_filas[0]))] # transpuesta
- max_filas2 = [max(row) for row in max_filas2]
- min_filas2 = [[row[i] for row in min_filas] for i in range(len(min_filas[0]))] # transpuesta
- min_filas2 = [min(row) for row in min_filas2]
- alto_filas = [(max_filas2[i]-min_filas2[i])*escala for i in range(len(max_filas2)) ]
+ dif_filas2 = [[row[i] for row in dif_filas] for i in range(len(dif_filas[0]))] # transpuesta
+ alto_filas = [max(row) for row in dif_filas2]
hy_tot = sum(alto_filas)+sep_y*filas
ceroy = ceroy + hy_tot
puntos_terr_ref,ptos_eje_ref=[],[]
ejes_x,ejes_y,mark_x,mark_y=[],[],[],[]
h,q,w,t=0,0,0,0
@@ -2296,8 +2270,8 @@
orig_x=cerox+(sep_x*j)+sum(ancho_colum[0:j])+sep_eje_x
final_x=cerox+(sep_x*j)+sum(ancho_colum[0:j])+ancho_colum[j]+sep_eje_x
centro_x=orig_x+centro_secc[j]
- orig_y=ceroy
+ orig_y=ceroy
cotaMax=max_filas[j][i]
@@ -2305,17 +2279,21 @@
dif_y_ref=(cotaMin)-int(cotaMin)
# origen y final del eje y
- orig_y=orig_y-(alto_filas[i])
+ orig_y=orig_y-(alto_filas[i])-sep_y
final_y=orig_y+dif_filas[j][i]+dif_y_ref
- cero_y_ref=(cotaMin-orig_y)-dif_y_ref
- ptos_eje,ptos_terr=[],[]
+ #cero_y_ref=(cotaMin-orig_y)-dif_y_ref
+ ptos_terr=[]
b=0
for pto in Trans_Terr[h]:
dist=sqrt((Trans_Pklist[h][0]-pto[0])**2+(Trans_Pklist[h][1]-pto[1])**2)
if dist==0:b=1
if b==0: dist=-dist
ptos_terr.append([centro_x+dist,orig_y+(pto[2]-cotaMin)*escala+dif_y_ref,0,h+1,Trans_Pklist[h][4]])
+ puntos_terr_ref.append(ptos_terr)
+ ptos_eje=[]
b=0
for pto in secc[h]:
@@ -2326,6 +2304,7 @@
cota_ras=orig_y+(pto[2]-cotaMin)*escala+dif_y_ref
t=t+1
ptos_eje.append([centro_x+dist,cota_ras,0,t,h+1,Trans_Pklist[h][4],round(pto[2],2),round(dist,2)])
+ ptos_eje_ref.append(ptos_eje)
# Eje y
ejes_y.append([[orig_x-sep_eje_x,final_y,0,h+1,"'Y'"],[orig_x-sep_eje_x,orig_y,0,h+1,"'Y'"]])
@@ -2358,8 +2337,6 @@
mark_y.append([[orig_x-mark_lon-sep_eje_x,final_y,0,w,round(cotaMax-dif_y_ref,2)],[orig_x+mark_lon-sep_eje_x,final_y,0]])
mark_x.extend(mark2_x)
- puntos_terr_ref.append(ptos_terr)
- ptos_eje_ref.append(ptos_eje)
h=h+1
@@ -2949,23 +2926,40 @@
posi=tablepks.index(pklist2[0])
table2=[]
categ=len(table)+1
- for i,pk in enumerate(pklist2):
- table2.append([table[posi-1][0]+i,table[posi-1][1]+i,table[posi-1][2]+i,categ+i,pk]+table[posi-1][5:])
+ secleft,secright="",""
+ typeleft,typeright="",""
table_plant= read_TablePlant(NameMap)
Puntos_Eje=get_PtosEjePlanta(table_plant)
if options["pklayer"]=="Vertical":
+ for i,pk in enumerate(pklist2):
+ table2.append([table[posi-1][0]+i,table[posi-1][1]+i,table[posi-1][2]+i,categ+i,pk]+table[posi-1][5]+[0,0,0])
update_TableAlz(NameMap,table2)
table_alz=read_TableAlz(NameMap)
corrige_Alzado(Puntos_Eje,table_alz,NameMap)
elif options["pklayer"]=="Section":
+ for num in range(len(table[posi-1][5].split(';'))):
+ secleft+="-1 0;"
+ typeleft+="l;"
+ secleft=secleft[:-1]
+ typeleft=typeleft[:-1]
+ secright+="-1 0;"
+ typeright+="l;"
+ secright=secright[:-1]
+ typeright=typeright[:-1]
+ table2.append([table[posi-1][0]+i,table[posi-1][1]+i,table[posi-1][2]+i,categ+i,pk]+[secleft,secright,typeleft,typeright])
update_TableSection(NameMap,table2)
table_secc=read_TableSection(NameMap)
corrige_Section(Puntos_Eje,table_secc,NameMap)
elif options["pklayer"]=="Trans":
+ table2.append([table[posi-1][0]+i,table[posi-1][1]+i,table[posi-1][2]+i,categ+i,pk]+table[posi-1][5:])
update_TableTransv(NameMap,table2)
table_transv=read_TableTransv(NameMap)
corrige_Transv(Puntos_Eje,table_transv,NameMap)
@@ -3012,8 +3006,6 @@
Desplazados_izq,Desplazados_der,DPtos_caract=generate_Desplaz(table_plant,table_secc,Puntos2)
- #print len(Puntos),len(Puntos2),len(Desplazados_izq[0]),len(Desplazados_izq[1]),len(Desplazados_izq[2]),len(Desplazados_der[0]),len(Desplazados_der[1]),len(Desplazados_der[2])
Desplaz_Areas=generate_DesplazAreas(Desplazados_izq[:],Puntos2[:],Desplazados_der[:])
Transversales,Trans_Pklist=generate_Transv(Puntos,table_transv)
@@ -3097,6 +3089,7 @@
else: name1=options['pks']
write_Transv(Pks,Trans_Pklist,[],name1,'')
if options['dem']:
@@ -3202,14 +3195,14 @@
if flags['l']:
- scale=float(options['LPScale'])
- opt1=options['LPopt']
+ scale=float(options['lpscale'])
+ opt1=options['lpopt']
- if re.search(r'^_', options['LPterrain']): nameTerr=NameMap+options['LPterrain']
- else: nameTerr=options['LPterrain']
+ if re.search(r'^_', options['lpterrain']): nameTerr=NameMap+options['lpterrain']
+ else: nameTerr=options['lpterrain']
- if re.search(r'^_', options['LPras']): nameRas=NameMap+options['LPras']
- else: nameRas=options['LPras']
+ if re.search(r'^_', options['lpras']): nameRas=NameMap+options['lpras']
+ else: nameRas=options['lpras']
(eje_x,eje_y,mark_x,mark_y,ptos_terr_ref,ptos_eje_ref,ASeg_ref,
APtos_caract_ref)=gen_LongProfileGuitarr(ASegmentos,APuntos_caract,Puntos,Puntos_Long_Terreno,table_alz,scale,opt1)
@@ -3219,8 +3212,8 @@
#write_Polyline(ptos_ref,nameRas)
# Eje alzado
- if re.search(r'^_', options['LPejeref']): nameEdgeRef=NameMap+options['LPejeref']
- else: nameEdgeRef=options['LPejeref']
+ if re.search(r'^_', options['lpejeref']): nameEdgeRef=NameMap+options['lpejeref']
+ else: nameEdgeRef=options['lpejeref']
write_Polyline(ptos_eje_ref,nameEdgeRef)
g.run_command('v.db.addtable', map=nameEdgeRef, layer=1, key='cat', table=nameEdgeRef+"_Lin", columns='label varchar(25)', quiet=True)
@@ -3243,16 +3236,16 @@
if flags['m']:
- if re.search(r'^_', options['LPaxisX']): nameEdgeX=NameMap+options['LPaxisX']
- else: nameEdgeX=options['LPaxisX']
+ if re.search(r'^_', options['lpaxisx']): nameEdgeX=NameMap+options['lpaxisx']
+ else: nameEdgeX=options['lpaxisx']
- if re.search(r'^_', options['LPaxisXmarks']): nameEdgeXmarks=NameMap+options['LPaxisXmarks']
- else: nameEdgeXmarks=options['LPaxisXmarks']
+ if re.search(r'^_', options['lpaxisxmarks']): nameEdgeXmarks=NameMap+options['lpaxisxmarks']
+ else: nameEdgeXmarks=options['lpaxisxmarks']
- if re.search(r'^_', options['LPaxisY']): nameEdgeY=NameMap+options['LPaxisY']
- else: nameEdgeY=options['LPaxisY']
+ if re.search(r'^_', options['lpaxisy']): nameEdgeY=NameMap+options['lpaxisy']
+ else: nameEdgeY=options['lpaxisy']
- if re.search(r'^_', options['LPaxisYmarks']): nameEdgeYmarks=NameMap+options['LPaxisYmarks']
+ if re.search(r'^_', options['lpaxisymarks']): nameEdgeYmarks=NameMap+options['lpaxisymarks']
else: nameEdgeYmarks=options['LPedgeYmarks']
write_Polylines(eje_x,nameEdgeX,1)
@@ -3279,18 +3272,19 @@
if flags['f']:
- scale2=float(options['LTScale'])
- opt1=options['LTopt']
- opt2=options['LTopt2']
+ scale2=float(options['ltscale'])
+ opt1=options['ltopt']
+ opt2=options['ltopt2']
- if re.search(r'^_', options['LTterrain']): nameTTerr=NameMap+options['LTterrain']
- else: nameTTerr=options['LTterrain']
+ if re.search(r'^_', options['ltterrain']): nameTTerr=NameMap+options['ltterrain']
+ else: nameTTerr=options['ltterrain']
- if re.search(r'^_', options['LTras']): nameTRas=NameMap+options['LTras']
- else: nameTRas=options['LTras']
+ if re.search(r'^_', options['ltras']): nameTRas=NameMap+options['ltras']
+ else: nameTRas=options['ltras']
- (ejes_x,ejes_y,mark_x,mark_y,ptos_terr_ref,
- ptos_eje)=gen_TransProfile(Transversales,Transversales_Terreno,Trans_Pklist,Puntos_Talud_izq,Puntos_Talud_der,Desplazados_izq,Desplazados_der,scale2,opt1,opt2)
+ Secc=get_SeccTerr(Trans_Pklist,Desplazados_izq,Desplazados_der,Puntos_Talud_izq,Puntos_Talud_der)
+ if flags['X']: Secc=lineasAgua
+ (ejes_x,ejes_y,mark_x,mark_y,ptos_terr_ref,ptos_eje)=gen_TransProfile(Transversales,Transversales_Terreno,Trans_Pklist,Secc,scale2,opt1,opt2)
# Terreno
write_Polylines(ptos_terr_ref,nameTTerr,1)
@@ -3307,17 +3301,17 @@
if flags['g']:
- if re.search(r'^_', options['LTaxisX']): nameTEdgeX=NameMap+options['LTaxisX']
- else: nameTEdgeX=options['LTaxisX']
+ if re.search(r'^_', options['ltaxisx']): nameTEdgeX=NameMap+options['ltaxisx']
+ else: nameTEdgeX=options['ltaxisx']
- if re.search(r'^_', options['LTaxisXmarks']): nameTEdgeXmarks=NameMap+options['LTaxisXmarks']
- else: nameTEdgeXmarks=options['LTaxisXmarks']
+ if re.search(r'^_', options['ltaxisxmarks']): nameTEdgeXmarks=NameMap+options['ltaxisxmarks']
+ else: nameTEdgeXmarks=options['ltaxisxmarks']
- if re.search(r'^_', options['LTaxisY']): nameTEdgeY=NameMap+options['LTaxisY']
- else: nameTEdgeY=options['LTaxisY']
+ if re.search(r'^_', options['ltaxisy']): nameTEdgeY=NameMap+options['ltaxisy']
+ else: nameTEdgeY=options['ltaxisy']
- if re.search(r'^_', options['LTaxisYmarks']): nameTEdgeYmarks=NameMap+options['LTaxisYmarks']
- else: nameTEdgeYmarks=options['LTaxisYmarks']
+ if re.search(r'^_', options['ltaxisymarks']): nameTEdgeYmarks=NameMap+options['ltaxisymarks']
+ else: nameTEdgeYmarks=options['ltaxisymarks']
write_Polylines(ejes_x,nameTEdgeX,1)
write_Polylines(mark_x,nameTEdgeXmarks,1)
