[GRASS-SVN] r60219 - in grass/trunk/gui/wxpython: dbmgr rlisetup
svn_grass at osgeo.org
Tue May 13 01:04:41 PDT 2014
Author: lucadelu
Date: 2014-05-13 01:04:41 -0700 (Tue, 13 May 2014)
New Revision: 60219
grass/trunk/gui/wxpython/dbmgr/base.py
grass/trunk/gui/wxpython/rlisetup/wizard.py
g.gui.rlisetup: fix problems encountered on windows and clean up
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py 2014-05-13 05:18:32 UTC (rev 60218)
+++ grass/trunk/gui/wxpython/dbmgr/base.py 2014-05-13 08:04:41 UTC (rev 60219)
@@ -2273,7 +2273,7 @@
else:
deleteColumns = "column '%s'" % tlist.GetItemText(item)
deleteDialog = wx.MessageBox(parent = self,
- message = _("Selected column %s will PERMANENTLY removed "
+ message = _("Selected %s will PERMANENTLY removed "
"from table. Do you want to drop the column?") % \
(deleteColumns),
caption = _("Drop column(s)"),
Modified: grass/trunk/gui/wxpython/rlisetup/wizard.py
--- grass/trunk/gui/wxpython/rlisetup/wizard.py 2014-05-13 05:18:32 UTC (rev 60218)
+++ grass/trunk/gui/wxpython/rlisetup/wizard.py 2014-05-13 08:04:41 UTC (rev 60219)
@@ -49,8 +49,8 @@
def __init__(self, parent):
self.parent = parent
self.wizard = wiz.Wizard(parent=parent, id=wx.ID_ANY,
- title=_("Create new configuration file for " \
- "r.li modules"))
+ title=_("Create new configuration file for "
+ "r.li modules"))
self.rlipath = retRLiPath()
self.msAreaList = []
@@ -113,7 +113,7 @@
#run_wizard
if self.wizard.RunWizard(self.startpage):
dlg = wx.MessageDialog(parent=self.parent,
- message=_("Do you want to create r.li " \
+ message=_("Do you want to create r.li "
"configuration file <%s>?") % self.startpage.conf_name,
caption=_("Create new r.li configuration file?"),
style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
@@ -128,7 +128,7 @@
self.wizard.Destroy()
GMessage(parent=self.parent,
message=_("r.li.setup wizard canceled. "
- "Configuration file not created."))
+ "Configuration file not created."))
self._cleanup()
def _write_confile(self):
@@ -183,14 +183,14 @@
self.per_rl = float(self.SF_RL) / float(self.rasterinfo['rows'])
self.per_cl = float(self.SF_CL) / float(self.rasterinfo['cols'])
fil.write("SAMPLINGFRAME %r|%r|%r|%r\n" % (self.per_x, self.per_y,
- self.per_rl, self.per_cl))
+ self.per_rl,
+ self.per_cl))
elif self.startpage.region == 'draw':
self._temp_region()
tregion = self.drawsampleframepage.tregion
# should we call this? with align param?
- RunCommand('g.region', align=self.startpage.rast,
- n=tregion['n'], s=tregion['s'],
- w=tregion['w'], e=tregion['e'])
+ RunCommand('g.region', align=self.startpage.rast, n=tregion['n'],
+ s=tregion['s'], w=tregion['w'], e=tregion['e'])
newreg = grass.region()
self.SF_N = newreg['n'] # set env(SF_N) $n
self.SF_S = newreg['s'] # set env(SF_S) $s
@@ -198,9 +198,9 @@
self.SF_W = newreg['w'] # set env(SF_W) $w
self.SF_Y = abs(round(self.gregion['n'] - newreg['n']) / newreg['nsres'])
-# set env(SF_Y) [expr abs(round(($s_n - $n) / $nres)) ]
+# set env(SF_Y) [expr abs(round(($s_n - $n) / $nres)) ]
self.SF_X = abs(round(self.gregion['w'] - newreg['w']) / newreg['ewres'])
-# set env(SF_X) [expr abs(round(($s_w - $w) / $sres)) ]
+# set env(SF_X) [expr abs(round(($s_w - $w) / $sres)) ]
self.SF_RL = abs(round(newreg['n'] - newreg['s']) / newreg['nsres'])
# set env(SF_RL) [expr abs(round(($n - $s) / $nres)) ]
self.SF_CL = abs(round(newreg['e'] - newreg['w']) / newreg['ewres'])
@@ -339,7 +339,7 @@
fil.write("SYSTEMATICCONTIGUOUS\n")
elif self.units.distrtype == 'stratified_random':
fil.write("STRATIFIEDRANDOM %s|%s\n" % (self.units.distr1,
- self.units.distr2))
+ self.units.distr2))
elif self.units.distrtype == 'systematic_noncontiguos':
fil.write("SYSTEMATICNONCONTIGUOUS %s\n" % self.units.distr1)
elif self.units.distrtype == 'centered_oversites':
@@ -363,7 +363,7 @@
if self.samplingareapage.samplingtype == SamplingType.MUNITSC:
tregion = tregion.region
abs_y = abs(round((float(s_n) - tregion['n']) / tregion['nsres']))
- abs_x = abs(round((float(s_w) - tregion['w']) / tregion['ewres']))
+ abs_x = abs(round((float(s_w) - tregion['w']) / tregion['ewres']))
abs_rl = abs(round((tregion['n'] - tregion['s']) / tregion['nsres']))
abs_cl = abs(round((tregion['e'] - tregion['w']) / tregion['ewres']))
@@ -437,55 +437,56 @@
#name of output configuration file
self.newconflabel = wx.StaticText(parent=self, id=wx.ID_ANY,
- label=_('Name for new configuration file to create'))
+ label=_('Name for new configuration file to create'))
self.newconftxt = wx.TextCtrl(parent=self, id=wx.ID_ANY,
size=(250, -1))
wx.CallAfter(self.newconftxt.SetFocus)
self.sizer.Add(item=self.newconflabel, border=5, pos=(0, 0),
- flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
+ flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
self.sizer.Add(item=self.newconftxt, border=5, pos=(0, 1),
#raster
self.mapsellabel = wx.StaticText(parent=self, id=wx.ID_ANY,
- label=_('Raster map to use to select areas'))
+ label=_('Raster map to use to select areas'))
self.mapselect = gselect.Select(parent=self, id=wx.ID_ANY,
size=(250, -1), type='cell',
multiple=False)
self.sizer.Add(item=self.mapsellabel, border=5, pos=(1, 0),
self.sizer.Add(item=self.mapselect, border=5, pos=(1, 1),
#vector
self.vectsellabel = wx.StaticText(parent=self, id=wx.ID_ANY,
- label=_('Vector map to use to select areas'))
+ label=_('Vector map to use to select areas'))
self.vectselect = gselect.Select(parent=self, id=wx.ID_ANY,
size=(250, -1), type='vector',
multiple=False)
self.sizer.Add(item=self.vectsellabel, border=5, pos=(2, 0),
self.sizer.Add(item=self.vectselect, border=5, pos=(2, 1),
#define sampling region
self.sampling_reg = wx.RadioBox(parent=self, id=wx.ID_ANY,
- label=" %s " % _("Define sampling " \
- " region (region for analysis)"),
- choices=[_('Whole map layer'),
- _('Keyboard setting'),
- _('Draw the sampling frame')],
- majorDimension=1,
- style=wx.RA_SPECIFY_ROWS)
+ label=" %s " % _("Define sampling "
+ "region (region for analysis)"),
+ choices=[_('Whole map layer'),
+ _('Keyboard setting'),
+ _('Draw the sampling frame')],
+ majorDimension=1,
+ style=wx.RA_SPECIFY_ROWS)
self.sizer.Add(item=self.sampling_reg,
- flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
- pos=(4, 0), span=(1, 2))
+ flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
+ pos=(4, 0), span=(1, 2))
#bindings
self.sampling_reg.Bind(wx.EVT_RADIOBOX, self.OnSampling)
self.newconftxt.Bind(wx.EVT_KILL_FOCUS, self.OnName)
self.newconftxt.Bind(wx.EVT_TEXT, self.OnNameChanged)
self.vectselect.Bind(wx.EVT_TEXT, self.OnVector)
self.mapselect.Bind(wx.EVT_TEXT, self.OnRast)
+ self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
wx.CallAfter(wx.FindWindowById(wx.ID_FORWARD).Enable, False)
@@ -528,6 +529,13 @@
next = wx.FindWindowById(wx.ID_FORWARD)
next.Enable(self.CheckInput())
+ def OnEnterPage(self, event):
+ """!Sets the default values, for the entire map
+ next = wx.FindWindowById(wx.ID_FORWARD)
+ next.Enable(self.CheckInput())
+ wx.CallAfter(wx.FindWindowById(wx.ID_FORWARD).Enable, self.CheckInput())
def CheckInput(self):
"""!Check input fields.
@@ -539,10 +547,8 @@
def OnExitPage(self, event=None):
"""!Function during exiting"""
- if self.conf_name == '' or self.rast == '':
- wx.FindWindowById(wx.ID_FORWARD).Enable(False)
- else:
- wx.FindWindowById(wx.ID_FORWARD).Enable(True)
if event.GetDirection():
if self.region == 'key':
self.SetNext(self.parent.keyboardpage)
@@ -572,17 +578,17 @@
#column up/left
self.ColUpLeftlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
- label=_("Column of upper left " \
- "corner"))
+ label=_("Column of upper left "
+ "corner"))
self.ColUpLefttxt = wx.TextCtrl(parent=self, id=wx.ID_ANY,
size=(250, -1))
wx.CallAfter(self.ColUpLeftlabel.SetFocus)
self.sizer.Add(item=self.ColUpLeftlabel, border=5, pos=(1, 1),
self.sizer.Add(item=self.ColUpLefttxt, border=5, pos=(1, 2),
#row up/left
self.RowUpLeftlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
label=_('Row of upper left corner'))
@@ -604,9 +610,9 @@
wx.CallAfter(self.RowLenlabel.SetFocus)
self.sizer.Add(item=self.RowLenlabel, border=5, pos=(3, 1),
self.sizer.Add(item=self.RowLentxt, border=5, pos=(3, 2),
#column lenght
self.ColLenlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
@@ -616,9 +622,9 @@
wx.CallAfter(self.ColLenlabel.SetFocus)
self.sizer.Add(item=self.ColLenlabel, border=5, pos=(4, 1),
self.sizer.Add(item=self.ColLentxt, border=5, pos=(4, 2),
self.ColUpLefttxt.SetValue(self.col_up)
self.RowUpLefttxt.SetValue(self.row_up)
@@ -707,8 +713,7 @@
map_.DeleteAllLayers()
cmdlist = ['d.rast', 'map=%s' % rast]
map_.AddLayer(ltype='raster', command=cmdlist, active=True,
- name=rast, hidden=False, opacity=1.0,
- render=True)
+ name=rast, hidden=False, opacity=1.0, render=True)
@@ -730,25 +735,25 @@
# toggles
self.radioBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
- label="",
- choices=[_("Whole map layer"),
- _("Regions"),
- _("Sample units"),
- _("Moving window"),
- _("Select areas from the\n"
- "overlayed vector map")],
- majorDimension=1,
- style=wx.RA_SPECIFY_COLS | wx.NO_BORDER)
+ label="",
+ choices=[_("Whole map layer"),
+ _("Regions"),
+ _("Sample units"),
+ _("Moving window"),
+ _("Select areas from the\n"
+ "overlayed vector map")],
+ majorDimension=1,
+ style=wx.RA_SPECIFY_COLS | wx.NO_BORDER)
# layout
self.sizer.SetVGap(10)
self.sizer.Add(item=self.radioBox, flag=wx.ALIGN_LEFT, pos=(0, 0))
self.regionBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
- label=_("Choose a method"),
- choices=[_('Use keyboard to enter sampling area'),
- _('Use mouse to draw sampling area')],
- majorDimension=1,
+ label=_("Choose a method"),
+ choices=[_('Use keyboard to enter sampling area'),
+ _('Use mouse to draw sampling area')],
+ majorDimension=1,
#self.regionBox.EnableItem(1, False)
self.regionBox.SetItemToolTip(1, _("This option is not supported yet"))
self.sizer.Add(self.regionBox, flag=wx.ALIGN_CENTER, pos=(1, 0))
@@ -776,7 +781,7 @@
self.areaPanelSizer = wx.GridBagSizer(1, 3)
self.areaPanel = wx.Panel(parent=self, id=wx.ID_ANY)
self.areaText = wx.StaticText(parent=self.areaPanel, id=wx.ID_ANY,
- label=_('Do you want to check vector areas?'))
+ label=_('Do you want to check vector areas?'))
self.areaOK = wx.Button(self.areaPanel, wx.ID_ANY, 'Yes', (50, 80))
self.areaOK.SetToolTip(wx.ToolTip(_("Select if use area by area")))
self.areaNO = wx.Button(self.areaPanel, wx.ID_ANY, 'No', (50, 80))
@@ -784,11 +789,9 @@
self.areaOK.Bind(wx.EVT_BUTTON, self.OnVectYes)
self.areaNO.Bind(wx.EVT_BUTTON, self.OnVectNo)
self.areaPanelSizer.Add(self.areaText, flag=wx.ALIGN_CENTER,
- pos=(0, 0))
- self.areaPanelSizer.Add(self.areaOK, flag=wx.ALIGN_CENTER,
- pos=(0, 1))
- self.areaPanelSizer.Add(self.areaNO, flag=wx.ALIGN_CENTER,
- pos=(0, 2))
+ pos=(0, 0))
+ self.areaPanelSizer.Add(self.areaOK, flag=wx.ALIGN_CENTER, pos=(0, 1))
+ self.areaPanelSizer.Add(self.areaNO, flag=wx.ALIGN_CENTER, pos=(0, 2))
self.areaPanel.SetSizer(self.areaPanelSizer)
self.sizer.Add(self.areaPanel, flag=wx.ALIGN_CENTER, pos=(3, 0))
@@ -951,8 +954,8 @@
self.parent.wizard.ShowPage(self.parent.summarypage)
else:
- self.title.SetLabel(_('Draw sample region ' + \
- str(self.regioncount) + ' of ' + \
+ self.title.SetLabel(_('Draw sample region ' +
+ str(self.regioncount) + ' of ' +
str(numregions)))
@@ -981,8 +984,7 @@
- render=True)
#def OnExitPage(self, event=None):
#!Function during exiting
@@ -1051,14 +1053,13 @@
_('Stratified random'),
_('Systematic non contiguos'),
_('Centered over sites')]
- self.distributionBox.EnableItem(5, False) # disable 'draw' for now
self.panelSizer.Add(item=self.distributionBox, pos=(3, 0), span=(1, 2),
self.distr1Label = wx.StaticText(parent=self.scrollPanel, id=wx.ID_ANY,
- label=_("What number of Sampling " \
- "Units to use?"))
+ label=_("What number of Sampling "
+ "Units to use?"))
self.distr1Txt = wx.TextCtrl(parent=self.scrollPanel, id=wx.ID_ANY,
size=(250, -1))
self.panelSizer.Add(item=self.distr1Label, pos=(4, 0),
@@ -1174,14 +1175,14 @@
self.sizer.AddGrowableCol(2)
self.width = ''
self.height = ''
- self.boxtype = ''
+ self.boxtype = 'rectangle'
# type of shape
self.typeBox = wx.RadioBox(parent=self, id=wx.ID_ANY,
- label=" %s " % _("Select type of shape"),
- choices=[_('Rectangle'), _('Circle'),
- ('None')],
- majorDimension=1,
- style=wx.RA_SPECIFY_COLS)
+ label=" %s " % _("Select type of shape"),
+ choices=[_('Rectangle'), _('Circle')],
+# ('None')],
+ majorDimension=1,
+ style=wx.RA_SPECIFY_COLS)
self.sizer.Add(self.typeBox, flag=wx.ALIGN_LEFT, pos=(1, 1))
@@ -1192,9 +1193,9 @@
label=_('Width size (in cells) ?'))
self.widthTxt = wx.TextCtrl(parent=self, id=wx.ID_ANY, size=(250, -1))
self.sizer.Add(item=self.widthLabel, border=5, pos=(2, 1),
self.sizer.Add(item=self.widthTxt, border=5, pos=(2, 2),
self.heightLabel = wx.StaticText(parent=self, id=wx.ID_ANY,
label=_('Height size (in cells) ?'))
self.heightTxt = wx.TextCtrl(parent=self, id=wx.ID_ANY, size=(250, -1))
@@ -1203,18 +1204,19 @@
self.sizer.Add(item=self.heightTxt, border=5, pos=(3, 2),
- self.widthLabels = [_('Width size (in cells)? '),
- _('What radius size (in meters)? ')]
- self.heightLabels = [_('Height size (in cells)? '),
+ self.widthLabels = [_('Width size (in cells) ?'),
+ _('What radius size (in meters) ?')]
+ self.heightLabels = [_('Height size (in cells) ?'),
_('Name of the circle mask')]
self.widthTxt.Bind(wx.EVT_TEXT, self.OnWidth)
self.heightTxt.Bind(wx.EVT_TEXT, self.OnHeight)
+ wx.FindWindowById(wx.ID_FORWARD).Enable(False)
# This is an hack to force the user to choose Rectangle or Circle
- self.typeBox.SetSelection(2),
- self.typeBox.ShowItem(2, False)
+# self.typeBox.SetSelection(2),
+# self.typeBox.ShowItem(2, False)
if self.parent.samplingareapage.samplingtype == SamplingType.MVWIN:
self.title.SetLabel(_("Set moving windows"))
self.OnType(None)
@@ -1228,20 +1230,32 @@
self.parent.samplingareapage.samplingtype = SamplingType.KMVWINR
else:
- self.parent.samplingareapage.samplingtype = SamplingType.KUNITSR
+ self.parent.samplingareapage.samplingtype = SamplingType.KMVWINC
- else:
+ elif chosen == 1:
else:
- self.parent.samplingareapage.samplingtype = SamplingType.KUNITSC
+ self.parent.samplingareapage.samplingtype = SamplingType.MMVWINC
self.boxtype = 'circle'
+ def CheckInput(self):
+ """!Check input fields.
+ @return True if configuration file is given and raster xor vector map,
+ False otherwise
+ return bool(self.width and bool(self.height))
def OnWidth(self, event):
self.width = event.GetString()
def OnHeight(self, event):
self.height = event.GetString()
class UnitsMousePage(TitledPage):
@@ -1264,7 +1278,7 @@
self.sizer.Add(self.typeBox, flag=wx.ALIGN_LEFT, pos=(0, 0),
- span=(1, 2))
+ span=(1, 2))
self.regionPanelSizer = wx.GridBagSizer(1, 2)
self.regionNumPanel = wx.Panel(parent=self, id=wx.ID_ANY)
@@ -1281,7 +1295,7 @@
self.regionNumPanel.SetSizer(self.regionPanelSizer)
self.sizer.Add(self.regionNumPanel, flag=wx.ALIGN_LEFT, pos=(1, 0),
- span=(1, 2))
+ span=(1, 2))
self.typeBox.Bind(wx.EVT_RADIOBOX, self.OnType)
self.regionNumTxt.Bind(wx.EVT_TEXT, self.OnNumRegions)
@@ -1408,8 +1422,7 @@
- render=True)
@@ -1432,17 +1445,17 @@
- label=_('Is this area ok?'))
+ label=_('Is this area ok?'))
self.areaOK.Bind(wx.EVT_BUTTON, self.OnYes)
self.areaNO.Bind(wx.EVT_BUTTON, self.OnNo)
- pos=(0, 0))
+ pos=(0, 0))
- pos=(0, 1))
+ pos=(0, 1))
- pos=(0, 2))
+ pos=(0, 2))
self.sizer.Add(self.areaPanel, flag=wx.ALIGN_CENTER, pos=(2, 0))
@@ -1478,8 +1491,8 @@
convertFeature(self.vect, self.outname, cat, self.rast)
cmdlistcat = ['d.rast', 'map=%s' % self.outname]
self.map_.AddLayer(ltype='raster', command=cmdlistcat, active=True,
- name=self.outname, hidden=False, opacity=1.0,
- render=True)
+ name=self.outname, hidden=False, opacity=1.0,
+ render=True)
for l in self.map_.GetListOfLayers():
if l.name == self.outname:
self.mapPanel.mapWindow.ZoomToMap(layers=[l], render=True,
@@ -1517,8 +1530,8 @@
self.map_.DeleteAllLayers()
cmdlist = ['d.rast', 'map=%s' % self.rast]
self.map_.AddLayer(ltype='raster', command=cmdlist, active=True,
- name=self.rast, hidden=False, opacity=1.0,
- render=True)
+ name=self.rast, hidden=False, opacity=1.0,
+ render=True)
self.newCat()
@@ -1544,9 +1557,9 @@
self.conftxt = wx.StaticText(parent=self, id=wx.ID_ANY,
label="")
self.sizer.Add(item=self.conflabel, border=5, pos=(0, 0),
self.sizer.Add(item=self.conftxt, border=5, pos=(0, 1),
#raster name
self.rastlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
@@ -1560,29 +1573,26 @@
#vector name
self.vectlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
- label=_('Vector name:'))
- self.vecttxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
+ label=_('Vector name:'))
+ self.vecttxt = wx.StaticText(parent=self, id=wx.ID_ANY, label="")
self.sizer.Add(item=self.vectlabel, border=5, pos=(2, 0),
self.sizer.Add(item=self.vecttxt, border=5, pos=(2, 1),
#region type name
self.regionlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
- label=_('Region type:'))
- self.regiontxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
+ label=_('Region type:'))
+ self.regiontxt = wx.StaticText(parent=self, id=wx.ID_ANY, label="")
self.sizer.Add(item=self.regionlabel, border=5, pos=(3, 0),
self.sizer.Add(item=self.regiontxt, border=5, pos=(3, 1),
#region keyboard
self.regionkeylabel = wx.StaticText(parent=self, id=wx.ID_ANY,
label="")
- self.regionkeytxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
+ self.regionkeytxt = wx.StaticText(parent=self, id=wx.ID_ANY, label="")
self.sizer.Add(item=self.regionkeylabel, border=5, pos=(4, 0),
self.sizer.Add(item=self.regionkeytxt, border=5, pos=(4, 1),
@@ -1591,34 +1601,31 @@
#sampling area
self.samplinglabel = wx.StaticText(parent=self, id=wx.ID_ANY,
label=_('Sampling area type:'))
- self.samplingtxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
+ self.samplingtxt = wx.StaticText(parent=self, id=wx.ID_ANY, label="")
self.sizer.Add(item=self.samplinglabel, border=5, pos=(5, 0),
self.sizer.Add(item=self.samplingtxt, border=5, pos=(5, 1),
#shapetype
- self.shapelabel = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
- self.shapetxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
+ self.shapelabel = wx.StaticText(parent=self, id=wx.ID_ANY, label="")
+ self.shapetxt = wx.StaticText(parent=self, id=wx.ID_ANY, label="")
self.sizer.Add(item=self.shapelabel, border=5, pos=(6, 0),
self.sizer.Add(item=self.shapetxt, border=5, pos=(6, 1),
#shapedim
self.shapewidthlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
+ label="")
self.shapewidthtxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
+ label="")
self.sizer.Add(item=self.shapewidthlabel, border=5, pos=(7, 0),
self.sizer.Add(item=self.shapewidthtxt, border=5, pos=(7, 1),
self.shapeheightlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
+ label="")
self.shapeheighttxt = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
+ label="")
self.sizer.Add(item=self.shapeheightlabel, border=5, pos=(8, 0),
self.sizer.Add(item=self.shapeheighttxt, border=5, pos=(8, 1),
@@ -1638,7 +1645,7 @@
self.sizer.Add(item=self.unitsmoretxt, border=5, pos=(10, 1),
self.unitsmorelabel2 = wx.StaticText(parent=self, id=wx.ID_ANY,
- label="")
+ label="")
self.unitsmoretxt2 = wx.StaticText(parent=self, id=wx.ID_ANY, label="")
self.sizer.Add(item=self.unitsmorelabel2, border=5, pos=(11, 0),
