[GRASS-SVN] r60231 - grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon
svn_grass at osgeo.org
Tue May 13 11:29:59 PDT 2014
Author: neteler
Date: 2014-05-13 11:29:59 -0700 (Tue, 13 May 2014)
New Revision: 60231
grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c
r.li: use G_config_dir() (backport of trunk, r60221)
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c 2014-05-13 17:19:21 UTC (rev 60230)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c 2014-05-13 18:29:59 UTC (rev 60231)
@@ -72,13 +72,13 @@
/* strip off leading path if present */
char testpath[GPATH_MAX];
- sprintf(testpath, "%s%s", G_home(), "/.grass7/r.li/");
+ sprintf(testpath, "%s%c%s%c", G_config_path(), HOST_DIRSEP, "r.li", HOST_DIRSEP);
if (strncmp(file, testpath, strlen(testpath)) == 0)
file += strlen(testpath);
/* TODO: check if this path is portable */
/* TODO: use G_rc_path() */
- sprintf(pathSetup, "%s/.grass7/r.li/%s", G_home(), file);
+ sprintf(pathSetup, "%s%c%s%c%s", G_config_path(), HOST_DIRSEP, "r.li", HOST_DIRSEP, file);
G_debug(1, "r.li.daemon pathSetup: [%s]", pathSetup);
parsed = parseSetup(pathSetup, l, g, raster);
@@ -101,25 +101,24 @@
else {
/* text file output */
/* check if ~/.grass7/ exists */
- sprintf(out, "%s/.grass7/", G_home());
+ sprintf(out, "%s", G_config_path());
doneDir = G_mkdir(out);
if (doneDir == -1 && errno != EEXIST)
- G_fatal_error(_("Cannot create %s/.grass7/ directory"), G_home());
+ G_fatal_error(_("Cannot create %s directory"), out);
/* check if ~/.grass7/r.li/ exists */
- sprintf(out, "%s/.grass7/r.li/", G_home());
+ sprintf(out, "%s%c%s%c", G_config_path(), HOST_DIRSEP, "r.li", HOST_DIRSEP);
- G_fatal_error(_("Cannot create %s/.grass7/r.li/ directory"),
- G_home());
/* check if ~/.grass7/r.li/output exists */
- sprintf(out, "%s/.grass7/r.li/output", G_home());
+ sprintf(out, "%s%c%s%c%s", G_config_path(), HOST_DIRSEP, "r.li", HOST_DIRSEP, "output");
- G_fatal_error(_("Cannot create %s/.grass7/r.li/output/ directory"),
- G_home());
- sprintf(out, "%s/.grass7/r.li/output/%s", G_home(), output);
+ sprintf(out, "%s%c%s%c%s%c%s",
+ G_config_path(), HOST_DIRSEP, "r.li", HOST_DIRSEP, "output", HOST_DIRSEP, output);
res = open(out, O_WRONLY | O_CREAT | O_TRUNC, 0644);
i = 0;
