[GRASS-SVN] r60254 - grass/branches/releasebranch_7_0/imagery/i.pca
svn_grass at osgeo.org
Thu May 15 14:03:02 PDT 2014
Author: neteler
Date: 2014-05-15 14:03:02 -0700 (Thu, 15 May 2014)
New Revision: 60254
grass/branches/releasebranch_7_0/imagery/i.pca/i.pca.html
i.pca: manual example cosmetics
Modified: grass/branches/releasebranch_7_0/imagery/i.pca/i.pca.html
--- grass/branches/releasebranch_7_0/imagery/i.pca/i.pca.html 2014-05-15 21:01:29 UTC (rev 60253)
+++ grass/branches/releasebranch_7_0/imagery/i.pca/i.pca.html 2014-05-15 21:03:02 UTC (rev 60254)
@@ -10,11 +10,13 @@
correspond to percent importance with .1 being the scores of the
principal component with the highest importance.
-<p>The current geographic region definition and MASK settings are
+<p>
+The current geographic region definition and MASK settings are
respected when reading the input raster map layers. When the rescale
option is used, the output files are rescaled to fit the min,max range.
-<p>The order of the input bands does not matter for the output maps
+<p>
+The order of the input bands does not matter for the output maps
(PC scores), but does matter for the vectors (loadings), since each
loading refers to a specific input band.
@@ -51,6 +53,7 @@
Using Landsat imagery in the North Carolina sample dataset:
<div class="code"><pre>
+g.region rast=lsat7_2002_10 -p
i.pca in=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70 \
out=lsat7_2002_pca
