[GRASS-SVN] r60260 - in grass-addons/grass6/raster: . r.out.mbtiles_prep
svn_grass at osgeo.org
Fri May 16 05:41:40 PDT 2014
Author: hamish
Date: 2014-05-16 05:41:40 -0700 (Fri, 16 May 2014)
New Revision: 60260
Added:
grass-addons/grass6/raster/r.out.mbtiles_prep/
grass-addons/grass6/raster/r.out.mbtiles_prep/Makefile
grass-addons/grass6/raster/r.out.mbtiles_prep/description.html
grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
+r.out.mbtiles_prep: prepares a TMS tileset bundle ready for conversion into mbtiles spatialite file format by Geopaparazzi
Copied: grass-addons/grass6/raster/r.out.mbtiles_prep/Makefile (from rev 60077, grass-addons/grass6/raster/r.game_of_life/Makefile)
--- grass-addons/grass6/raster/r.out.mbtiles_prep/Makefile (rev 0)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/Makefile 2014-05-16 12:41:40 UTC (rev 60260)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.out.mbtiles_prep
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Copied: grass-addons/grass6/raster/r.out.mbtiles_prep/description.html (from rev 60077, grass-addons/grass6/raster/r.surf.volcano/description.html)
--- grass-addons/grass6/raster/r.out.mbtiles_prep/description.html (rev 0)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/description.html 2014-05-16 12:41:40 UTC (rev 60260)
@@ -0,0 +1,43 @@
+<h2>DESCRIPTION</h2>
+<em>r.out.mbtiles_prep</em> creates a TMS tileset and support files ready to
+load into software like Geopaparazzi which will make the final conversion to
+a mbtiles spatialite database file.
+<h2>NOTES</h2>
+Either an individual raster map or a raster map imagery group may be given as input.
+<p>
+If not specified the zoom level will be automatically chosen.
+<p>
+<h2>EXAMPLE</h2>
+Creates a tileset for the North Carolina sample dataset's <tt>soilsID</tt> raster
+map at automatically chosen zoom levels 11-14.
+<div class="code"><pre>
+g.region rast=soilsID
+r.out.mbtiles_prep in=soilsID out=soil_tiles format=jpeg
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="i.group.html">i.group</a></em>
+<br><br>
+<a href="http://www.gdal.org/gdal2tiles.html">gdal2tiles</a><br>
+<a href="https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-parameters">mapurl specification</a><br>
+<h2>AUTHOR</h2>
+Hamish Bowman<br>
+<i>Geology Dept.<br>
+University of Otago<BT>
+Dunedin, New Zealand</i>
+<p>
+<i>Last changed: $Date$</i>
Added: grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
--- grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep (rev 0)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-16 12:41:40 UTC (rev 60260)
@@ -0,0 +1,352 @@
+#!/bin/sh
+# MODULE: r.out.mbtiles_prep
+# AUTHOR(S): M. Hamish Bowman, Dunedin, New Zealand
+# PURPOSE: Export a raster map into a TMS bundle ready for conversion
+# to mbtiles format
+# COPYRIGHT: (C) 2014 Hamish Bowman, and the GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# *** NOT FOR NAVIGATIONAL USE - USE AT YOUR OWN RISK ***
+# https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-Converting-Tile-Set-to-.mbtiles
+# https://github.com/geopaparazzi/geopaparazzi/wiki/.mapurl-parameters
+#%Module
+#% description: Export GRASS raster as a TMS tree ready for converting to mbtiles format.
+#% keywords: raster, export, tms, mbtiles
+#%End
+#%Option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input raster map
+#% gisprompt: old,cell,raster
+#%End
+#%Option
+#% key: output
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% label: Name for output project directory
+#% description: default: input map name
+#% gisprompt: new_file,file,output
+#%End
+#%Option
+#% key: format
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: string
+#% description: Image format to store the tiles
+#% options: png,jpeg
+#% answer: png
+#%End
+#%Option
+#% key: zoom
+#% type: string
+#% required: no
+#% multiple: no
+#% label: TMS zoom levels to create
+#% description: Format: '0-19', or '10' (default: automatic)
+#%End
+#%Flag
+#% key: t
+#% description: Create a tarball
+#%End
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+#### check if we have awk, gdalwarp, gdal2tiles, seq
+pgms="awk seq gdalwarp gdal2tiles.py"
+for pgm in $pgms ; do
+ if [ ! -x "`which $pgm`" ] ; then
+ g.message -e "$pgm is required, please install it first."
+ exit 1
+ fi
+done
+MAP_NAME="$GIS_OPT_INPUT"
+if [ -n "$GIS_OPT_OUTPUT" ] ; then
+ OUTFILE="$GIS_OPT_OUTPUT"
+else
+ OUTFILE="$MAP_NAME"
+fi
+g.findfile element=cell file="$MAP_NAME" > /dev/null
+if [ $? -eq 0 ] ; then
+ MAP_TYPE=raster
+else
+ g.findfile element=group file="$MAP_NAME" > /dev/null
+ if [ $? -eq 0 ] ; then
+ MAP_TYPE=group
+ else
+ g.message -e "Could not find [$MAP_NAME]"
+ exit 1
+ fi
+fi
+cleanup()
+ #remove temporary files
+ if [ -e "$TMPFILE" ] ; then
+ rm -rf "$TMPFILE"*
+ fi
+# what to do in case of user break:
+exitprocedure()
+ g.message -e message='User break!'
+ cleanup
+ exit 1
+# shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+#### setup temporary file
+TMPFILE="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMPFILE" ] ; then
+ g.message -e "Unable to create temporary file"
+ exit 1
+fi
+TMP_GTIFF="${TMPFILE}_export.tif"
+TMP_DIR=`dirname "$TMP_GTIFF"`
+TMP_GMERC="$TMP_DIR"/`basename "$TMP_GTIFF" .tif`_gmerc.tif
+if [ "$MAP_TYPE" = "raster" ] ; then
+ r.out.tiff -t input="$MAP_NAME" output="$TMP_GTIFF"
+else
+ r.out.gdal input="$MAP_NAME" output="$TMP_GTIFF" format=GTiff
+fi
+# TMS tiles need to be in funny google merc projection
+gdalwarp -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
+## -srcnodata -dstnodata -dstalpha
+if [ $? -ne 0 ] ; then
+ g.message -e "Problem running gdalwarp"
+ cleanup
+ exit 1
+fi
+# free the disk space ASAP
+rm -f "$TMP_GTIFF"
+# Screen DPI is monitor/device dependent, and therefore a crude one
+# size fits none.
+# a: major radius of Earth (WGS84)
+# pixel factor: meters/pixel for a 256 pixel wide tile
+# zoom_level, map_scale results at 96 dpi, 45deg:
+# [0 1 : 418365887]
+# [1 1 : 209182943]
+# [2 1 : 104591472]
+# [3 1 : 52295736]
+# [4 1 : 26147868]
+# [5 1 : 13073934]
+# [6 1 : 6536967]
+# [7 1 : 3268483]
+# [8 1 : 1634242]
+# [9 1 : 817121]
+# [10 1 : 408560]
+# [11 1 : 204280]
+# [12 1 : 102140]
+# [13 1 : 51070]
+# [14 1 : 25535]
+# [15 1 : 12768]
+# [16 1 : 6384]
+# [17 1 : 3192]
+# [18 1 : 1596]
+# [19 1 : 798]
+# [20 1 : 399]
+calc_webtile_scale()
+ lat=$1
+ scale=$2
+ dpi=$3
+ echo "$lat $scale $dpi" | awk \
+ a = 6378137.0;
+ PI = 3.14159265358979323846;
+ pixelfact = a * 2*PI / 256;
+ resolution = pixelfact * cos($1 * PI/180) / 2^$2;
+ printf("%.0f\n", $3 * resolution / 0.0254)
+if [ -n "$GIS_OPT_ZOOM" ] ; then
+ ZOOM="$GIS_OPT_ZOOM"
+else
+ # calc map scale from map extent and dpi
+ eval `g.region -gu`
+ eval `g.region -legu`
+ # adjust as needed:
+ SCREEN_DPI=96
+ #SCALE_NS=$ns_extent/(($rows/$DPI)*$INCH2METER)
+ #SCALE_EW=$ew_extent/(($cols/$DPI)*$INCH2METER)
+ SCALE_NS=`echo "$ns_extent $rows $SCREEN_DPI" | awk '{print $1/(($2/$3)*0.0254)}'`
+ SCALE_EW=`echo "$ew_extent $cols $SCREEN_DPI" | awk '{print $1/(($2/$3)*0.0254)}'`
+ # for use with TMS the two above should be the same.
+ MAP_SCALE=`echo "$SCALE_NS $SCALE_EW" | awk '{print int(0.5 + ($1 + $2) / 2)}'`
+ # beware zoom levels lower than 9 (~1:500k) badly distort the Mercator
+ minzoom=0
+ maxzoom=3
+ for zoom in `seq 0 20` ; do
+ zoomscale=`calc_webtile_scale $center_lat $zoom $SCREEN_DPI`
+ #echo "[$zoom 1 : $zoomscale]" # @ ${SCREEN_DPI}dpi]"
+ if [ "$zoomscale" -gt "$MAP_SCALE" ] ; then
+ maxzoom=`expr "$zoom" + 1`
+ minzoom=`expr "$maxzoom" - 3`
+ fi
+ done
+ if [ "$maxzoom" -gt 20 ] ; then
+ maxzoom=20
+ fi
+ if [ "$minzoom" -lt 0 ] ; then
+ minzoom=0
+ fi
+ ZOOM="$minzoom-$maxzoom"
+fi
+ TITLE=`r.info -m "$MAP_NAME" | cut -f2- -d=`
+else
+ TITLE=`r.info -m $(i.group -g $MAP_NAME | head -n 1) | cut -f2- -d=`
+fi
+if [ -z "$TITLE" ] ; then
+ TITLE="$MAP_NAME"
+fi
+if [ -n "$GRASS_VERBOSE" ] && [ "$GRASS_VERBOSE" -gt 1 ] ; then
+ VERBOSE="-v"
+else
+ VERBOSE=""
+fi
+OUT_DIR="$TMP_DIR"/`basename "$TMP_GMERC" .tif`
+g.message "Generating tiles for zoom level(s) $ZOOM"
+gdal2tiles.py $VERBOSE -r bilinear -z "$ZOOM" -w none -t "$TITLE" \
+ "$TMP_GMERC" "$OUT_DIR"
+ G2T_OK=1
+else
+ g.message -e "gdal2tiles failed."
+ cleanup
+ exit 1
+fi
+rm -f "$TMP_GMERC"
+rm -f `find $(dirname "$OUT_DIR") | grep .aux.xml`
+#### write out .mapurl file
+# get max extent bbox in lat/lon
+eval `g.region -bgu`
+URLFILE="$OUT_DIR"/`basename "$OUTFILE"`.mapurl
+cat << EOF > "$URLFILE"
+url=$OUTFILE/ZZZ/XXX/YYY.png
+minzoom=$minzoom
+maxzoom=$maxzoom
+center=$ll_clon $ll_clat
+bounds=$ll_w $ll_s $ll_e $ll_n
+type=tms
+mbtiles=$OUTFILE/$OUTFILE.mbtiles
+name=$TITLE
+description=Exported zoom level(s) $ZOOM from GRASS GIS r.out.mbtiles_prep
+defaultzoom=`expr $maxzoom - 1`
+format=png
+request_type=run,fill,load,reset_metadata
+EOF
+if [ "$GIS_OPT_FORMAT" = "jpeg" ] ; then
+ g.message "Converting to JPEG ..."
+ cd "$OUT_DIR"
+ for file in `find . | grep '.png$'` ; do
+ outfile=`echo "$file" | sed -e 's/\.png$/.jpg/'`
+ pngtopnm "$file" | pnmtojpeg > "$outfile"
+ rm "$file"
+ fi
+ done
+ # sed -i is not portable to BSD/Mac
+ mv tilemapresource.xml tilemapresource.xml.tmp
+ sed -e 's+mime-type="image/png"+mime-type="image/jpeg"+' \
+ -e 's+extension="png"+extension="jpg"+' \
+ tilemapresource.xml.tmp > tilemapresource.xml
+ rm tilemapresource.xml.tmp
+ mv "$URLFILE" "$URLFILE".tmp
+ sed -e 's+^format=png+format=jpg+' "$URLFILE".tmp > "$URLFILE"
+ rm "$URLFILE".tmp
+ cd - > /dev/null
+fi
+mv "$OUT_DIR" "$OUTFILE"
+mv "$OUTFILE"/*.mapurl "$OUTFILE"/..
+cleanup
+if [ "$GIS_FLAG_T" -eq 1 ] ; then
+ cd `dirname "$OUTFILE"`
+ tar cf `basename "$OUTFILE"`.tar `basename "$OUTFILE"` `basename "$OUTFILE"`.mapurl
+fi
+g.message "Done."
Property changes on: grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
+ text/x-sh
Added: svn:eol-style
+ native
