[GRASS-SVN] r60271 - grass/branches/develbranch_6/vector/v.buffer2
svn_grass at osgeo.org
Fri May 16 11:52:23 PDT 2014
Author: neteler
Date: 2014-05-16 11:52:23 -0700 (Fri, 16 May 2014)
New Revision: 60271
grass/branches/develbranch_6/vector/v.buffer2/main.c
v.buffer: msg about degree units in lat-long
Modified: grass/branches/develbranch_6/vector/v.buffer2/main.c
--- grass/branches/develbranch_6/vector/v.buffer2/main.c 2014-05-16 18:51:44 UTC (rev 60270)
+++ grass/branches/develbranch_6/vector/v.buffer2/main.c 2014-05-16 18:52:23 UTC (rev 60271)
@@ -10,7 +10,7 @@
* PURPOSE: Vector buffer
- * COPYRIGHT: (C) 2001-2012 by the GRASS Development Team
+ * COPYRIGHT: (C) 2001-2014 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -438,6 +438,10 @@
type = Vect_option_to_types(type_opt);
+ /* TODO: no geodesic support yet in GEOS */
+ if (G_projection() == PROJECTION_LL)
+ G_important_message(_("Note: In latitude-longitude coordinate system distances are in degree units"));
if ((dista_opt->answer && bufcol_opt->answer) ||
(!(dista_opt->answer || bufcol_opt->answer)))
G_fatal_error(_("Select a buffer distance/minordistance/angle "
